[U-Boot] Pull request: u-boot-arm/master
Hi Wolfgang,
Following the opening of the merge window, the following changes since commit bfcc40bb09b05c90cc3b1496abb270eb8aa72134:
Merge branch 'next' of ../next (2011-12-23 20:53:58 +0100)
git://git.denx.de/u-boot-arm.git master
Christian Riesch (7): spl: display_options.o is required for SPI flash support in SPL sf: Add spi_boot() to allow booting from SPI flash in an SPL arm, davinci: Add SPL support for DA850 SoCs arm, da850evm: Add an SPL for SPI boot mkimage: Fix variable length header support arm, davinci: Add support for generating AIS images to the Makefile arm, davinci: Fix build warnings for cam_enc_4xx
Fabio Estevam (1): vision2: Fix checkpatch warning
Simon Glass (14): tegra2: Tidy UART selection tegra2: Add UARTB support tegra2: config: Enable SPI flash on Seaboard tegra2: Enable SPI environment on Seaboard tegra2: Implement SPI / UART GPIO switch tegra2: spi: Support SPI / UART switch tegra2: Plumb in SPI/UART switch code tegra: Fix build error in plutux, medcom tegra: Move cpu_init_cp15() to arch_cpu_init() tegra: Move clock_early_init() to arch_cpu_init() tegra: add clock_ll_start_uart() to enable UART prior to reloc tegra: Add a function mux feature tegra: Add support for UART init in cpu board.c tegra: Move boards over to use arch-level board UART function
Stefano Babic (2): ARM: omap3: added common configuration for Technexion TAM3517 ARM: omap3: add support to Technexion twister board
Thierry Reding (7): tegra2: Always build with USE_PRIVATE_LIBGCC=yes. tegra2: Change CONFIG_SYS_TEXT_BASE to 0x00108000. tegra2: Move tegra2_mmc_init() prototype to public header. tegra2: Add common Avionic Design Tamonten support. tegra2: Add Avionic Design Plutux support. tegra2: Add Avionic Design Medcom support. tegra2: Optimize out-of-tree build for Ventana.
Thomas Weber (1): Devkit8000: Switch over to enable_gpmc_cs_config
Tom Warren (2): tegra2: spi: Add SPI driver for Tegra2 SOC arm: Tegra: Fix Harmony and Ventana builds in u-boot-tegra/master
.gitignore | 1 + MAINTAINERS | 6 + Makefile | 13 + arch/arm/cpu/arm926ejs/davinci/Makefile | 3 +- arch/arm/cpu/arm926ejs/davinci/spl.c | 35 ++- arch/arm/cpu/armv7/tegra2/Makefile | 2 +- arch/arm/cpu/armv7/tegra2/board.c | 58 +++ arch/arm/cpu/armv7/tegra2/clock.c | 14 + arch/arm/cpu/armv7/tegra2/config.mk | 2 + arch/arm/cpu/armv7/tegra2/funcmux.c | 58 +++ arch/arm/include/asm/arch-tegra2/board.h | 30 ++ arch/arm/include/asm/arch-tegra2/clock.h | 11 + arch/arm/include/asm/arch-tegra2/funcmux.h | 41 ++ arch/arm/include/asm/arch-tegra2/mmc.h | 27 ++ arch/arm/include/asm/arch-tegra2/tegra2.h | 1 + arch/arm/include/asm/arch-tegra2/tegra2_spi.h | 76 ++++ arch/arm/include/asm/arch-tegra2/uart-spi-switch.h | 46 +++ board/avionic-design/common/tamonten.c | 116 ++++++ board/avionic-design/common/tamonten.h | 32 ++ board/avionic-design/medcom/Makefile | 50 +++ board/avionic-design/medcom/medcom.c | 45 +++ board/avionic-design/plutux/Makefile | 50 +++ board/avionic-design/plutux/plutux.c | 45 +++ board/davinci/da8xxevm/da850evm.c | 4 +- board/davinci/da8xxevm/u-boot-spl.lds | 73 ++++ board/nvidia/common/Makefile | 47 +++ board/nvidia/common/board.c | 73 +--- board/nvidia/common/board.h | 2 +- board/nvidia/common/uart-spi-switch.c | 138 +++++++ board/nvidia/harmony/Makefile | 1 - board/nvidia/harmony/harmony.c | 2 +- board/nvidia/seaboard/Makefile | 1 - board/nvidia/seaboard/seaboard.c | 5 +- board/nvidia/ventana/Makefile | 6 +- board/technexion/twister/Makefile | 38 ++ board/technexion/twister/twister.c | 116 ++++++ board/technexion/twister/twister.h | 411 ++++++++++++++++++++ board/timll/devkit8000/devkit8000.c | 19 +- board/ttcontrol/vision2/vision2.c | 3 +- boards.cfg | 3 + doc/README.SPL | 1 + doc/README.davinci | 9 + drivers/mmc/tegra2_mmc.h | 2 - drivers/mtd/spi/Makefile | 4 + drivers/mtd/spi/spi_spl_load.c | 58 +++ drivers/spi/Makefile | 1 + drivers/spi/tegra2_spi.c | 279 +++++++++++++ include/configs/da850evm.h | 87 ++++ include/configs/harmony.h | 3 + include/configs/medcom.h | 64 +++ include/configs/plutux.h | 64 +++ include/configs/seaboard.h | 20 + include/configs/tam3517-common.h | 361 +++++++++++++++++ include/configs/tegra2-common.h | 5 +- include/configs/twister.h | 54 +++ include/configs/ventana.h | 3 + include/spi_flash.h | 3 + lib/Makefile | 2 + tools/mkimage.c | 97 +++--- 59 files changed, 2687 insertions(+), 134 deletions(-) create mode 100644 arch/arm/cpu/armv7/tegra2/funcmux.c create mode 100644 arch/arm/include/asm/arch-tegra2/board.h create mode 100644 arch/arm/include/asm/arch-tegra2/funcmux.h create mode 100644 arch/arm/include/asm/arch-tegra2/mmc.h create mode 100644 arch/arm/include/asm/arch-tegra2/tegra2_spi.h create mode 100644 arch/arm/include/asm/arch-tegra2/uart-spi-switch.h create mode 100644 board/avionic-design/common/tamonten.c create mode 100644 board/avionic-design/common/tamonten.h create mode 100644 board/avionic-design/medcom/Makefile create mode 100644 board/avionic-design/medcom/medcom.c create mode 100644 board/avionic-design/plutux/Makefile create mode 100644 board/avionic-design/plutux/plutux.c create mode 100644 board/davinci/da8xxevm/u-boot-spl.lds create mode 100644 board/nvidia/common/Makefile create mode 100644 board/nvidia/common/uart-spi-switch.c create mode 100644 board/technexion/twister/Makefile create mode 100644 board/technexion/twister/twister.c create mode 100644 board/technexion/twister/twister.h create mode 100644 drivers/mtd/spi/spi_spl_load.c create mode 100644 drivers/spi/tegra2_spi.c create mode 100644 include/configs/medcom.h create mode 100644 include/configs/plutux.h create mode 100644 include/configs/tam3517-common.h create mode 100644 include/configs/twister.h
Amicalement,
Dear Albert ARIBAUD,
In message 4EF59AE7.9030402@aribaud.net you wrote:
Hi Wolfgang,
Applied, thanks.
Albert ARIBAUD
