[U-Boot] [PATCH 3/3] AT91: add RTT and GPBR based RTC support
adds kernel compatible RTC handling to u-boot using the RTT and one GPBRegister
Signed-off-by: Reinhard Meyer reinhard.meyer@emk-elektronik.de --- drivers/rtc/Makefile | 1 + drivers/rtc/at91sam9.c | 100 ++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 101 insertions(+), 0 deletions(-) create mode 100644 drivers/rtc/at91sam9.c
diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile index 772a49a..53db3d0 100644 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -29,6 +29,7 @@ LIB = $(obj)librtc.a
COBJS-$(CONFIG_RTC_BFIN) += bfin_rtc.o COBJS-y += date.o +COBJS-$(CONFIG_RTC_AT91SAM9) += at91sam9.o COBJS-$(CONFIG_RTC_DS12887) += ds12887.o COBJS-$(CONFIG_RTC_DS1302) += ds1302.o COBJS-$(CONFIG_RTC_DS1306) += ds1306.o diff --git a/drivers/rtc/at91sam9.c b/drivers/rtc/at91sam9.c new file mode 100644 index 0000000..6ec8e8e --- /dev/null +++ b/drivers/rtc/at91sam9.c @@ -0,0 +1,100 @@ +/* + * (C) Copyright 2010 + * Reinhard Meyer, reinhard.meyer@emk-elektronik.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Date & Time support for the internal Real-time Timer + * of AT91SAM9260 and compatibles. + * Compatible with the LinuX rtc driver workaround: + * The RTT cannot be written to, but only reset. + * The actual time is the sum of RTT and one of + * the four GPBR registers. + * + * The at91sam9260 has 4 GPBR (0-3). + * For their typical use see at91_gpbr.h ! + * + * make sure u-boot and kernel use the same GPBR ! + */ + +#include <common.h> +#include <command.h> +#include <rtc.h> +#include <asm/errno.h> +#include <asm/arch/hardware.h> +#include <asm/arch/io.h> +#include <asm/arch/at91_rtt.h> +#include <asm/arch/at91_gpbr.h> + +#if defined(CONFIG_CMD_DATE) + +int rtc_get (struct rtc_time *tmp) +{ + at91_rtt_t *rtt = (at91_rtt_t *) AT91_RTT_BASE; + at91_gpbr_t *gpbr = (at91_gpbr_t *) AT91_GPR_BASE; + ulong tim; + ulong tim2; + ulong off; + + do { + tim = readl(&rtt->vr); + tim2 = readl(&rtt->vr); + } while (tim!=tim2); + off = readl(&gpbr->reg[AT91_GPBR_INDEX_TIMEOFF]); + /* off==0 means time is invalid, but we ignore that */ + to_tm (tim+off, tmp); + return 0; +} + +int rtc_set (struct rtc_time *tmp) +{ + at91_rtt_t *rtt = (at91_rtt_t *) AT91_RTT_BASE; + at91_gpbr_t *gpbr = (at91_gpbr_t *) AT91_GPR_BASE; + ulong tim; + + tim = mktime (tmp->tm_year, tmp->tm_mon, tmp->tm_mday, + tmp->tm_hour, tmp->tm_min, tmp->tm_sec); + + /* clear alarm, set prescaler to 32768, clear counter */ + writel(32768+AT91_RTT_RTTRST, &rtt->mr); + writel(~0, &rtt->ar); + writel(tim, &gpbr->reg[AT91_GPBR_INDEX_TIMEOFF]); + /* wait for counter clear to happen, takes less than a 1/32768th second */ + while (readl(&rtt->vr) != 0) + ; + return 0; +} + +void rtc_reset (void) +{ + at91_rtt_t *rtt = (at91_rtt_t *) AT91_RTT_BASE; + at91_gpbr_t *gpbr = (at91_gpbr_t *) AT91_GPR_BASE; + + /* clear alarm, set prescaler to 32768, clear counter */ + writel(32768+AT91_RTT_RTTRST, &rtt->mr); + writel(~0, &rtt->ar); + writel(0, &gpbr->reg[AT91_GPBR_INDEX_TIMEOFF]); + /* wait for counter clear to happen, takes less than a 1/32768th second */ + while (readl(&rtt->vr) != 0) + ; +} + +#endif
Reinhard Meyer (-VC)
