[U-Boot-Users] [PATCH] add ft_cpu_setup(..)-function for mpc8260
Hello everybody.
On proposal from Heiko Schocher: This patch adds ft_cpu_setup(..) - function for mpc8260.
Signed-off-by: Sergej Stepanov Sergej.Stepanov@ids.de --
diff -pruN --exclude='.svn' u-boot-1.2.0-orig/cpu/mpc8260/cpu.c u-boot-1.2.0/cpu/mpc8260/cpu.c --- u-boot-1.2.0-orig/cpu/mpc8260/cpu.c 2007-01-07 00:13:11.000000000 +0100 +++ u-boot-1.2.0/cpu/mpc8260/cpu.c 2007-09-03 14:02:54.000000000 +0200 @@ -294,3 +294,18 @@ void watchdog_reset (void) #endif /* CONFIG_WATCHDOG */
/* ------------------------------------------------------------------------- */ + +#if defined(CONFIG_OF_FLAT_TREE) +void ft_cpu_setup (void *blob, bd_t *bd) +{ + u32 *p; + ulong clock; + int len; + + clock = bd->bi_busfreq; + p = ft_get_prop (blob, "/cpus/" OF_CPU "/bus-frequency", &len); + if (p != NULL) + *p = cpu_to_be32 (clock); +} +#endif /* CONFIG_OF_FLAT_TREE */ +/* ------------------------------------------------------------------------- */
Dear Sergei,
CONFIG_OF_FLAT_TREE is deprecated, as it is going to be replaced by CONFIG_OF_LIBFDT.
Please change your code to use the new style and resubmit. Thanks.
Wolfgang Denk wrote:
Dear Sergei,
...and use Grant's 5xxx code as the model of how to do it the New Improved LIBFDT Way. http://www.denx.de/cgi-bin/gitweb.cgi?p=u-boot/u-boot-mpc5xxx.git;a=blob;f=cpu/mpc5xxx/cpu.c;h=7f16b92a6cac06af26f00a9a267f7bd6c371323a;hb=cf2817a84c2e9bea2c5dfc084bce2f2d2563ac43
On the 83xx family, I did a table-based fixup which turned out uglier than what Grant did and I intend to switch over to Grant's methodology when I get some breathing room.
Best regards, gvb
Jerry Van Baren
Sergej Stepanov
