[PATCH v2] board: rockchip: Fix binman_init failure on EVB-RK3568
For some newer SoCs like RK3568, the Rockchip has not released any DDR drivers yet so idbloader needs to create manually using DDR binaries offered by rkbin. This indeed no requirement to enable TPL in the U-Boot source code.
If we mark TPL disabled and mark BINMAN enabled by default then there would be an issue of binman_init failure during board relocation. This is true as binman failed to find the top-level node like u-boot-tpl here.
Here is the boot issue observed in Radxa-CM3 RK3566 board,
U-Boot 2023.01-rc4-00057-gac2505d463-dirty (Jan 04 2023 - 23:44:18 +0530)
Model: Radxa Compute Module 3(CM3) IO Board DRAM: 2 GiB binman_init failed:-2 initcall sequence 000000007ffd2008 failed at call 0000000000a18cac (err=-2) ### ERROR ### Please RESET the board ###
This might be fixed via binman node in rockchip-u-boot.dtsi however disable BINMAN_FDT for evb-rk3568 defconfig for now as we are at the end of the release cycle.
Fixes: 05713d570762 ("rockchip: generate u-boot-rockchip.bin with binman for ARM64 boards") Cc: Quentin Schulz quentin.schulz@theobroma-systems.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - disable BINMAN_FDT in defconfig instead disabling BINMAN in ARCH_ROCKCHIP
configs/evb-rk3568_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/evb-rk3568_defconfig b/configs/evb-rk3568_defconfig index db3acf5be5..e799690578 100644 --- a/configs/evb-rk3568_defconfig +++ b/configs/evb-rk3568_defconfig @@ -64,4 +64,5 @@ CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y +# CONFIG_BINMAN_FDT is not set CONFIG_ERRNO_STR=y
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v2:
Fixes: 05713d570762 ("rockchip: generate u-boot-rockchip.bin with binman for ARM64 boards") Cc: Quentin Schulz quentin.schulz@theobroma-systems.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com Reviewed-by: Kever Yang kever.yang@rock-chips.com
Jagan Teki
Kever Yang
