[PATCH v2] mx6slevk: Convert to DM_ETH
This fixes the following warning:
===================== WARNING ====================== This board does not use CONFIG_DM_ETH (Driver Model for Ethernet drivers). Please update the board to use CONFIG_DM_ETH before the v2020.07 release. Failure to update by the deadline may result in board removal. See doc/driver-model/migration.rst for more info. ====================================================
Signed-off-by: Pedro Jardim jardim.c.pedro@gmail.com
Changes since v1" - Remove CONFIG_ETHPRIME --- board/freescale/mx6slevk/mx6slevk.c | 31 ----------------------------- configs/mx6slevk_defconfig | 3 +++ include/configs/mx6slevk.h | 6 ------ 3 files changed, 3 insertions(+), 37 deletions(-)
diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c index 453f281418..43029e4245 100644 --- a/board/freescale/mx6slevk/mx6slevk.c +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -21,7 +21,6 @@ #include <fsl_esdhc_imx.h> #include <i2c.h> #include <mmc.h> -#include <netdev.h> #include <power/pmic.h> #include <power/pfuze100_pmic.h> #include "../common/pfuze.h" @@ -102,35 +101,11 @@ static iomux_v3_cfg_t const usdhc3_pads[] = { }; #endif
-static iomux_v3_cfg_t const fec_pads[] = { - MX6_PAD_FEC_MDC__FEC_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_FEC_MDIO__FEC_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_FEC_CRS_DV__FEC_RX_DV | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_FEC_RXD0__FEC_RX_DATA0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_FEC_RXD1__FEC_RX_DATA1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_FEC_TX_EN__FEC_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_FEC_TXD0__FEC_TX_DATA0 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_FEC_TXD1__FEC_TX_DATA1 | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_FEC_REF_CLK__FEC_REF_OUT | MUX_PAD_CTRL(ENET_PAD_CTRL), - MX6_PAD_FEC_RX_ER__GPIO_4_19 | MUX_PAD_CTRL(NO_PAD_CTRL), - MX6_PAD_FEC_TX_CLK__GPIO_4_21 | MUX_PAD_CTRL(NO_PAD_CTRL), -}; - static void setup_iomux_uart(void) { imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); }
-static void setup_iomux_fec(void) -{ - imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads)); - - /* Power up LAN8720 PHY */ - gpio_request(ETH_PHY_POWER, "eth_pwr"); - gpio_direction_output(ETH_PHY_POWER , 1); - udelay(15000); -} - int board_mmc_get_env_dev(int devno) { return devno; @@ -179,12 +154,6 @@ int power_init_board(void) #endif
#ifdef CONFIG_FEC_MXC -int board_eth_init(bd_t *bis) -{ - setup_iomux_fec(); - - return cpu_eth_init(bis); -}
static int setup_fec(void) { diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index dc22e830a3..163cb1a7ae 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -61,3 +61,6 @@ CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y +CONFIG_DM_ETH=y +CONFIG_FEC_MXC=y +CONFIG_PHY_SMSC=y diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index 6b2a174e7a..71d72d8c74 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -32,12 +32,7 @@ #define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000
-#define CONFIG_FEC_MXC -#define IMX_FEC_BASE ENET_BASE_ADDR -#define CONFIG_FEC_XCV_TYPE RMII -#define CONFIG_FEC_MXC_PHYADDR 0 - -#define CONFIG_PHY_SMSC
#define CONFIG_EXTRA_ENV_SETTINGS \ "script=boot.scr\0" \
Hi Pedro,
Changes since v1"
Patch looks good, but the "Changes since v1" should be placed below the --- line. Please see below.
Please place it here.
Reviewed-by: Fabio Estevam festevam@gmail.com
Fabio Estevam
Pedro Jardim
