[U-Boot] [PATCH] usb.h: use standard __LITTLE_ENDIAN from Linux headers
Rather than forcing people to define a custom "LITTLEENDIAN", just use the __LITTLE_ENDIAN one from the Linux byteorder headers that every arch is already setting up.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/usb_storage.c | 2 -- include/usb.h | 4 ++-- 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/common/usb_storage.c b/common/usb_storage.c index 94f659f..bb468aa 100644 --- a/common/usb_storage.c +++ b/common/usb_storage.c @@ -45,8 +45,6 @@ * New Note: * Support for USB Mass Storage Devices (BBB) has been added. It has * only been tested with USB memory sticks. - * Nota bene: if you are using the BBB support with a little-endian - * CPU then you MUST define LITTLEENDIAN in the configuration file! */
diff --git a/include/usb.h b/include/usb.h index 510df95..e7ede32 100644 --- a/include/usb.h +++ b/include/usb.h @@ -263,13 +263,13 @@ int usb_set_interface(struct usb_device *dev, int interface, int alternate); ((x_ & 0xFF000000UL) >> 24)); \ })
-#ifdef LITTLEENDIAN +#if __LITTLE_ENDIAN # define swap_16(x) (x) # define swap_32(x) (x) #else # define swap_16(x) __swap_16(x) # define swap_32(x) __swap_32(x) -#endif /* LITTLEENDIAN */ +#endif
/* * Calling this entity a "pipe" is glorifying it. A USB pipe
Hello Mike,
2009/1/1 Mike Frysinger vapier@gentoo.org:
Rather than forcing people to define a custom "LITTLEENDIAN", just use the __LITTLE_ENDIAN one from the Linux byteorder headers that every arch is already setting up. common/usb_storage.c | 2 -- include/usb.h | 4 ++-- 2 files changed, 2 insertions(+), 4 deletions(-)
- New Note:
- Support for USB Mass Storage Devices (BBB) has been added. It has
- only been tested with USB memory sticks.
- Nota bene: if you are using the BBB support with a little-endian
- CPU then you MUST define LITTLEENDIAN in the configuration file!
There are a few more C-files (*usb_ohci.c) that has this comment, please remove them all. Also clean up the config files that has this flag set. This flag seem to be set only for this reason.
I would prefer '#if defined(__LITTLE_ENDIAN)'
Kind Regards,
Remy
- Calling this entity a "pipe" is glorifying it. A USB pipe
-- 1.6.0.6
- New Note:
i was avoiding touching non-common code as i dont have the hardware to test. but easy enough to change. -mike
Signed-off-by: Mike Frysinger vapier@gentoo.org --- v1 - convert more usb LITTLEENDIAN users
common/usb_storage.c | 2 -- cpu/arm920t/s3c24x0/usb_ohci.c | 4 +--- cpu/mips/au1x00_usb_ohci.c | 6 ++---- include/configs/VCMA9.h | 1 - include/configs/afeb9260.h | 1 - include/configs/at91cap9adk.h | 1 - include/configs/at91sam9260ek.h | 1 - include/configs/at91sam9261ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/delta.h | 2 -- include/configs/mp2usb.h | 1 - include/configs/sh7785lcr.h | 1 - include/configs/smdk6400.h | 1 - include/configs/trab.h | 1 - include/configs/trizepsiv.h | 2 -- include/usb.h | 4 ++-- 16 files changed, 5 insertions(+), 25 deletions(-)
diff --git a/cpu/arm920t/s3c24x0/usb_ohci.c b/cpu/arm920t/s3c24x0/usb_ohci.c index 641f270..9cbd477 100644 --- a/cpu/arm920t/s3c24x0/usb_ohci.c +++ b/cpu/arm920t/s3c24x0/usb_ohci.c @@ -29,9 +29,7 @@ */ /* * IMPORTANT NOTES - * 1 - you MUST define LITTLEENDIAN in the configuration file for the - * board or this driver will NOT work! - * 2 - this driver is intended for use with USB Mass Storage Devices + * 1 - this driver is intended for use with USB Mass Storage Devices * (BBB) ONLY. There is NO support for Interrupt or Isochronous pipes! */
diff --git a/cpu/mips/au1x00_usb_ohci.c b/cpu/mips/au1x00_usb_ohci.c index 17489da..ea02efb 100644 --- a/cpu/mips/au1x00_usb_ohci.c +++ b/cpu/mips/au1x00_usb_ohci.c @@ -27,9 +27,7 @@ */ /* * IMPORTANT NOTES - * 1 - you MUST define LITTLEENDIAN in the configuration file for the - * board or this driver will NOT work! - * 2 - this driver is intended for use with USB Mass Storage Devices + * 1 - this driver is intended for use with USB Mass Storage Devices * (BBB) ONLY. There is NO support for Interrupt or Isochronous pipes! */
@@ -56,7 +54,7 @@ #define USBH_ENABLE_CE (1<<3) #define USBH_ENABLE_RD (1<<4)
-#ifdef LITTLEENDIAN +#ifdef __LITTLE_ENDIAN #define USBH_ENABLE_INIT (USBH_ENABLE_CE | USBH_ENABLE_E | USBH_ENABLE_C) #else #define USBH_ENABLE_INIT (USBH_ENABLE_CE | USBH_ENABLE_E | USBH_ENABLE_C | USBH_ENABLE_BE) diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index 0bc2f68..a65013c 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -36,7 +36,6 @@ #define CONFIG_ARM920T 1 /* This is an ARM920T Core */ #define CONFIG_S3C2410 1 /* in a SAMSUNG S3C2410 SoC */ #define CONFIG_VCMA9 1 /* on a MPL VCMA9 Board */ -#define LITTLEENDIAN 1 /* used by usb_ohci.c */
/* input clock of PLL */ #define CONFIG_SYS_CLK_FREQ 12000000/* VCMA9 has 12MHz input clock */ diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index d63a1a0..33ad66b 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -115,7 +115,6 @@
/* USB */ #define CONFIG_USB_OHCI_NEW 1 -#define LITTLEENDIAN 1 #define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 /* AT91SAM9260_UHP_BASE */ diff --git a/include/configs/at91cap9adk.h b/include/configs/at91cap9adk.h index b2baf1b..c232f61 100644 --- a/include/configs/at91cap9adk.h +++ b/include/configs/at91cap9adk.h @@ -132,7 +132,6 @@
/* USB */ #define CONFIG_USB_OHCI_NEW 1 -#define LITTLEENDIAN 1 #define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00700000 /* AT91_BASE_UHP */ diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 1538929..c59cf39 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -117,7 +117,6 @@
/* USB */ #define CONFIG_USB_OHCI_NEW 1 -#define LITTLEENDIAN 1 #define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 /* AT91SAM9260_UHP_BASE */ diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 0016b4f..082fd45 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -130,7 +130,6 @@
/* USB */ #define CONFIG_USB_OHCI_NEW 1 -#define LITTLEENDIAN 1 #define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 /* AT91SAM9261_UHP_BASE */ diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index d9ebc87..b478acf 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -137,7 +137,6 @@
/* USB */ #define CONFIG_USB_OHCI_NEW 1 -#define LITTLEENDIAN 1 #define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00a00000 /* AT91SAM9263_UHP_BASE */ diff --git a/include/configs/delta.h b/include/configs/delta.h index 08b28ca..e63dca3 100644 --- a/include/configs/delta.h +++ b/include/configs/delta.h @@ -131,8 +131,6 @@ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "delta" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 3
-#define LITTLEENDIAN 1 /* used by usb_ohci.c */ - #define CONFIG_BOOTDELAY -1 #define CONFIG_ETHADDR 08:00:3e:26:0a:5b #define CONFIG_NETMASK 255.255.0.0 diff --git a/include/configs/mp2usb.h b/include/configs/mp2usb.h index cbbdb0c..d8b6414 100644 --- a/include/configs/mp2usb.h +++ b/include/configs/mp2usb.h @@ -216,7 +216,6 @@ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */
#define CONFIG_SYS_DEVICE_DEREGISTER /* needs device_deregister */ -#define LITTLEENDIAN 1 /* used by usb_ohci.c */
#define CONFIG_SYS_HZ 1000 #define CONFIG_SYS_HZ_CLOCK (AT91C_MASTER_CLOCK/2) /* AT91C_TC0_CMR is implicitly set to */ diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index 1b59059..ebca448 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -123,7 +123,6 @@ #undef CONFIG_SYS_DIRECT_FLASH_TFTP
/* R8A66597 */ -#define LITTLEENDIAN /* for include/usb.h */ #define CONFIG_USB_R8A66597_HCD #define CONFIG_R8A66597_BASE_ADDR SH7785LCR_USB_BASE #define CONFIG_R8A66597_XTAL 0x0000 /* 12MHz */ diff --git a/include/configs/smdk6400.h b/include/configs/smdk6400.h index 1784cc6..d7ecbf6 100644 --- a/include/configs/smdk6400.h +++ b/include/configs/smdk6400.h @@ -294,7 +294,6 @@ #define CONFIG_SYS_USB_OHCI_SLOT_NAME "s3c6400" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 3 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 -#define LITTLEENDIAN 1 /* used by usb_ohci.c */
#define CONFIG_USB_STORAGE 1 #endif diff --git a/include/configs/trab.h b/include/configs/trab.h index 562cd60..0a7a73d 100644 --- a/include/configs/trab.h +++ b/include/configs/trab.h @@ -44,7 +44,6 @@ #define CONFIG_S3C2400 1 /* in a SAMSUNG S3C2400 SoC */ #define CONFIG_TRAB 1 /* on a TRAB Board */ #undef CONFIG_TRAB_50MHZ /* run the CPU at 50 MHz */ -#define LITTLEENDIAN 1 /* used by usb_ohci.c */
/* automatic software updates (see board/trab/auto_update.c) */ #define CONFIG_AUTO_UPDATE 1 diff --git a/include/configs/trizepsiv.h b/include/configs/trizepsiv.h index b2065ee..0a8e994 100644 --- a/include/configs/trizepsiv.h +++ b/include/configs/trizepsiv.h @@ -42,8 +42,6 @@ */ #define CONFIG_PXA27X 1 /* This is an PXA27x CPU */
-#define LITTLEENDIAN 1 /* used by usb_ohci.c */ - #define CONFIG_MMC 1 #define BOARD_LATE_INIT 1
diff --git a/include/usb.h b/include/usb.h index 510df95..befb201 100644 --- a/include/usb.h +++ b/include/usb.h @@ -263,13 +263,13 @@ int usb_set_interface(struct usb_device *dev, int interface, int alternate); ((x_ & 0xFF000000UL) >> 24)); \ })
-#ifdef LITTLEENDIAN +#ifdef __LITTLE_ENDIAN # define swap_16(x) (x) # define swap_32(x) (x) #else # define swap_16(x) __swap_16(x) # define swap_32(x) __swap_32(x) -#endif /* LITTLEENDIAN */ +#endif
Hello Mike,
2009/1/2 Mike Frysinger vapier@gentoo.org:
I applied this patch to the u-boot-usb 'testing' branch. When it compiles properly and no regressions are being detected, I move it to the 'next' branch for the next U-boot release.
Thanks.
Remy
- New Note:
- IMPORTANT NOTES
- 1 - you MUST define LITTLEENDIAN in the configuration file for the
- 2 - this driver is intended for use with USB Mass Storage Devices
- 1 - this driver is intended for use with USB Mass Storage Devices
- IMPORTANT NOTES
-- 1.6.0.6
Mike Frysinger
Remy Bohmer
