[U-Boot] [PATCH v10 00/10] usb: Extend ehci and ohci generic driver
This series improves generic ehci and ohci drivers by addition of : _ error path during probe (clocks, resets and phy release) _ .remove callback _ add generic PHY framework for both generic ehci and ohci drivers _ add RESET and CLOCK framework for generic ohci driver
To implement these features, some new methods are needed in reset, clock and in dm/core framework: _ add reset_request() and reset_assert_all() methods in RESET framework _ add clk_count() and clk_disable_all() methods in CLOCK framework _ add ofnode_count_phandle_with_args() and dev_count_phandle_with_args() in dm/core
v10: _ add dev_count_phandle_with_args() requested by Simon Glass _ fix some mirno remarks
v9: _ rename reset_assert_all() in reset_release_all() as this function not only assert all resets but also free all of them _ rename clk_disable_all() in clk_release_all() as this function not only disable all clocks but also free all of them _ add a check in reset_release_all()/clk_disable_all() to verify if reset/clock has been previously requested before asserting/disabling and freeing it.
v8: _ rework error path by propagating the initial error code until the end of probe() _ replace devm_kmalloc() with devm_kcalloc() _ fix cosmetics remarks
v7: _ replace clk_count() and reset_count() methods by ofnode_count_phandle_with_args() in patches 3, 4 and 5
v6: _ replace clk_get_by_index() by dev_read_phandle_with_args() in clk_count() in patch 4 _ add Reviewed-by Simon Glass for patch 2 and 5
v5: _ rebase on top of dm/master requested by Simon Glass in order to use livetree update _ replace fdtdec_parse_phandle_with_args() by dev_read_phandle_with_args() in patch 2
v4: _ add clk_disable_all() and reset_assert_all() methods into CLOCK and RESET framework as suggested by Simon Glass and Marek Vasut _ add reset_count() and clk_count() methods which returns respectively the number of resets and clocks declared into "resets" and "clocks" DT properties. This allows to allocate the right amount of memory to keep resets and clocks reference _ update the memory allocation for deasserted resets and enabled clocks reference list. Replace lists by arrays. v3: _ keep enabled clocks and deasserted resets reference in list in order to disable clock or assert resets in error path or in .remove callback _ add missing commit message _ use struct generic_ehci * instead of struct udevice * as parameter for ehci_release_resets() and ehci_release_clocks() _ test return value on generic_phy_get_by_index() and generic_phy_init() _ split previous patch 5 in 3 independant patch for CLOCK, RESET and PHY support
v2: _ add needed reset_request() in RESET framework _ add error path in ehci/ohci-generic to disable clocks and to assert resets _ add .remove callback with clocks, resets and phy release _ split the replacement of printf() by error() in an independant patch
Patrice Chotard (10): reset: add reset_request() reset: add reset_release_all() clk: add clk_release_all() dm: core: add ofnode_count_phandle_with_args() usb: host: ehci-generic: replace printf() by error() usb: host: ehci-generic: add error path and .remove callback usb: host: ehci-generic: add generic PHY support usb: host: ohci-generic: add CLOCK support usb: host: ohci-generic: add RESET support usb: host: ohci-generic: add generic PHY support
drivers/clk/clk-uclass.c | 26 +++++++ drivers/core/of_access.c | 7 ++ drivers/core/ofnode.c | 12 ++++ drivers/reset/reset-uclass.c | 34 ++++++++++ drivers/usb/host/ehci-generic.c | 147 +++++++++++++++++++++++++++++++++------- drivers/usb/host/ohci-generic.c | 122 ++++++++++++++++++++++++++++++++- include/clk.h | 14 ++++ include/dm/of_access.h | 18 +++++ include/dm/ofnode.h | 17 +++++ include/dm/read.h | 25 +++++++ include/reset.h | 27 ++++++++ 11 files changed, 424 insertions(+), 25 deletions(-)
This is needed in error path to assert previously deasserted reset by using a saved reset_ctl reference.
Signed-off-by: Patrice Chotard patrice.chotard@st.com Reviewed-by: Simon Glass sjg@chromium.org ---
v10: _ none v9: _ none v8: _ none v7: _ none v6: _ none v5: _ none v4: _ none v3: _ none v2: _ none
drivers/reset/reset-uclass.c | 9 +++++++++ include/reset.h | 9 +++++++++ 2 files changed, 18 insertions(+)
diff --git a/drivers/reset/reset-uclass.c b/drivers/reset/reset-uclass.c index de3695f..4fd82b9 100644 --- a/drivers/reset/reset-uclass.c +++ b/drivers/reset/reset-uclass.c @@ -97,6 +97,15 @@ int reset_get_by_name(struct udevice *dev, const char *name, return reset_get_by_index(dev, index, reset_ctl); }
+int reset_request(struct reset_ctl *reset_ctl) +{ + struct reset_ops *ops = reset_dev_ops(reset_ctl->dev); + + debug("%s(reset_ctl=%p)\n", __func__, reset_ctl); + + return ops->request(reset_ctl); +} + int reset_free(struct reset_ctl *reset_ctl) { struct reset_ops *ops = reset_dev_ops(reset_ctl->dev); diff --git a/include/reset.h b/include/reset.h index f45fcf8..4f2e35f 100644 --- a/include/reset.h +++ b/include/reset.h @@ -100,6 +100,15 @@ int reset_get_by_name(struct udevice *dev, const char *name, struct reset_ctl *reset_ctl);
/** + * reset_request - Request a reset signal. + * + * @reset_ctl: A reset control struct. + * + * @return 0 if OK, or a negative error code. + */ +int reset_request(struct reset_ctl *reset_ctl); + +/** * reset_free - Free a previously requested reset signal. * * @reset_ctl: A reset control struct that was previously successfully
Add reset_release_all() method which Assert/Free an array of resets signal that has been previously successfully requested by reset_get_by_*()
v10: _ none v9: _ to avoid confusion, rename reset_assert_all() in reset_release_all() as this function not only assert all resets but also free all of them _ add a check in reset_release_all() to verify if a reset has been previously requested before asserting and freeing it. v8: _ none v7: _ none v6: _ none v5: _ none v4: _ add reset_assert_all() method as suggested by Marek Vasut and Simon Glass
drivers/reset/reset-uclass.c | 25 +++++++++++++++++++++++++ include/reset.h | 18 ++++++++++++++++++ 2 files changed, 43 insertions(+)
diff --git a/drivers/reset/reset-uclass.c b/drivers/reset/reset-uclass.c index 4fd82b9..307a297 100644 --- a/drivers/reset/reset-uclass.c +++ b/drivers/reset/reset-uclass.c @@ -42,6 +42,7 @@ int reset_get_by_index(struct udevice *dev, int index,
debug("%s(dev=%p, index=%d, reset_ctl=%p)\n", __func__, dev, index, reset_ctl); + reset_ctl->dev = NULL;
ret = dev_read_phandle_with_args(dev, "resets", "#reset-cells", 0, index, &args); @@ -87,6 +88,7 @@ int reset_get_by_name(struct udevice *dev, const char *name,
debug("%s(dev=%p, name=%s, reset_ctl=%p)\n", __func__, dev, name, reset_ctl); + reset_ctl->dev = NULL;
index = dev_read_stringlist_search(dev, "reset-names", name); if (index < 0) { @@ -133,6 +135,29 @@ int reset_deassert(struct reset_ctl *reset_ctl) return ops->rst_deassert(reset_ctl); }
+int reset_release_all(struct reset_ctl *reset_ctl, int count) +{ + int i, ret; + + for (i = 0; i < count; i++) { + debug("%s(reset_ctl[%d]=%p)\n", __func__, i, &reset_ctl[i]); + + /* check if reset has been previously requested */ + if (!reset_ctl[i].dev) + continue; + + ret = reset_assert(&reset_ctl[i]); + if (ret) + return ret; + + ret = reset_free(&reset_ctl[i]); + if (ret) + return ret; + } + + return 0; +} + UCLASS_DRIVER(reset) = { .id = UCLASS_RESET, .name = "reset", diff --git a/include/reset.h b/include/reset.h index 4f2e35f..7185ade 100644 --- a/include/reset.h +++ b/include/reset.h @@ -144,6 +144,18 @@ int reset_assert(struct reset_ctl *reset_ctl); */ int reset_deassert(struct reset_ctl *reset_ctl);
+/** + * reset_release_all - Assert/Free an array of previously requested resets. + * + * For each reset contained in the reset array, this function will check if + * reset has been previously requested and then will assert and free it. + * + * @reset_ctl: A reset struct array that was previously successfully + * requested by reset_get_by_*(). + * @count Number of reset contained in the array + * @return 0 if OK, or a negative error code. + */ +int reset_release_all(struct reset_ctl *reset_ctl, int count); #else static inline int reset_get_by_index(struct udevice *dev, int index, struct reset_ctl *reset_ctl) @@ -171,6 +183,12 @@ static inline int reset_deassert(struct reset_ctl *reset_ctl) { return 0; } + +static inline int reset_release_all(struct reset_ctl *reset_ctl, int count) +{ + return 0; +} + #endif
#endif
Add clk_release_all() method which Disable/Free an array of clocks that has been previously requested by clk_request/get_by_*()
v10: _ none v9: _ to avoid confusion, rename clk_disable_all() in clk_release_all() as this function not only disable all clocks but also free all of them _ add a check in clk_release_all() to verify if a clock has been previously requested before asserting and freeing it. v8: _ replace clk->dev by clk[i].dev in clk_request() param v7: _ none v6: _ none v5: _ none v4: _ none v3: _ add commit message v2: _ create this independant path for printf() replacement
drivers/clk/clk-uclass.c | 26 ++++++++++++++++++++++++++ include/clk.h | 14 ++++++++++++++ 2 files changed, 40 insertions(+)
diff --git a/drivers/clk/clk-uclass.c b/drivers/clk/clk-uclass.c index 83b6328..ffbe872 100644 --- a/drivers/clk/clk-uclass.c +++ b/drivers/clk/clk-uclass.c @@ -65,6 +65,8 @@ int clk_get_by_index(struct udevice *dev, int index, struct clk *clk) debug("%s(dev=%p, index=%d, clk=%p)\n", __func__, dev, index, clk);
assert(clk); + clk->dev = NULL; + ret = dev_read_phandle_with_args(dev, "clocks", "#clock-cells", 0, index, &args); if (ret) { @@ -102,6 +104,7 @@ int clk_get_by_name(struct udevice *dev, const char *name, struct clk *clk) int index;
debug("%s(dev=%p, name=%s, clk=%p)\n", __func__, dev, name, clk); + clk->dev = NULL;
index = dev_read_stringlist_search(dev, "clock-names", name); if (index < 0) { @@ -187,6 +190,29 @@ int clk_disable(struct clk *clk) return ops->disable(clk); }
+int clk_release_all(struct clk *clk, int count) +{ + int i, ret; + + for (i = 0; i < count; i++) { + debug("%s(clk[%d]=%p)\n", __func__, i, &clk[i]); + + /* check if clock has been previously requested */ + if (!clk[i].dev) + continue; + + ret = clk_disable(&clk[i]); + if (ret && ret != -ENOSYS) + return ret; + + ret = clk_free(&clk[i]); + if (ret && ret != -ENOSYS) + return ret; + } + + return 0; +} + UCLASS_DRIVER(clk) = { .id = UCLASS_CLK, .name = "clk", diff --git a/include/clk.h b/include/clk.h index 5a5c2ff..a905a41 100644 --- a/include/clk.h +++ b/include/clk.h @@ -174,6 +174,20 @@ int clk_enable(struct clk *clk); */ int clk_disable(struct clk *clk);
+/** + * clk_release_all() - Disable (turn off)/Free an array of previously + * requested clocks. + * + * For each clock contained in the clock array, this function will check if + * clock has been previously requested and then will disable and free it. + * + * @clk: A clock struct array that was previously successfully + * requested by clk_request/get_by_*(). + * @count Number of clock contained in the array + * @return zero on success, or -ve error code. + */ +int clk_release_all(struct clk *clk, int count); + int soc_clk_dump(void);
#endif
This function is usefull to get phandle number contained in a property list. For example, this allows to allocate the right amount of memory to keep clock's reference contained into the "clocks" property.
To implement it, either of_count_phandle_with_args() or fdtdec_parse_phandle_with_args() are used respectively for live tree and flat tree. By passing index = -1, these 2 functions returns the number of phandle contained into the property list.
Add also the dev_count_phandle_with_args() based on ofnode_count_phandle_with_args()
Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
v10: _ add dev_count_phandle_with_args() requested by Simon Glass v9: _ none v8: _ none v7: _ add ofnode_count_phandle_with_args() which returns the phandle number contained into a property list. drivers/core/of_access.c | 7 +++++++ drivers/core/ofnode.c | 12 ++++++++++++ include/dm/of_access.h | 18 ++++++++++++++++++ include/dm/ofnode.h | 17 +++++++++++++++++ include/dm/read.h | 25 +++++++++++++++++++++++++ 5 files changed, 79 insertions(+)
diff --git a/drivers/core/of_access.c b/drivers/core/of_access.c index 93a6560..76d5996 100644 --- a/drivers/core/of_access.c +++ b/drivers/core/of_access.c @@ -641,6 +641,13 @@ int of_parse_phandle_with_args(const struct device_node *np, index, out_args); }
+int of_count_phandle_with_args(const struct device_node *np, + const char *list_name, const char *cells_name) +{ + return __of_parse_phandle_with_args(np, list_name, cells_name, 0, + -1, NULL); +} + static void of_alias_add(struct alias_prop *ap, struct device_node *np, int id, const char *stem, int stem_len) { diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index ac312d6..02bc5d2 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -307,6 +307,18 @@ int ofnode_parse_phandle_with_args(ofnode node, const char *list_name, return 0; }
+int ofnode_count_phandle_with_args(ofnode node, const char *list_name, + const char *cells_name) +{ + if (ofnode_is_np(node)) + return of_count_phandle_with_args(ofnode_to_np(node), + list_name, cells_name); + else + return fdtdec_parse_phandle_with_args(gd->fdt_blob, + ofnode_to_offset(node), list_name, cells_name, + 0, -1, NULL); +} + ofnode ofnode_path(const char *path) { if (of_live_active()) diff --git a/include/dm/of_access.h b/include/dm/of_access.h index 142f0f4..5be29b1 100644 --- a/include/dm/of_access.h +++ b/include/dm/of_access.h @@ -315,6 +315,24 @@ int of_parse_phandle_with_args(const struct device_node *np, int index, struct of_phandle_args *out_args);
/** + * of_count_phandle_with_args() - Count the number of phandle in a list + * + * @np: pointer to a device tree node containing a list + * @list_name: property name that contains a list + * @cells_name: property name that specifies phandles' arguments count + * @return number of phandle found, -ENOENT if + * @list_name does not exist, -EINVAL if a phandle was not found, + * @cells_name could not be found, the arguments were truncated or there + * were too many arguments. + * + * Returns number of phandle found on success, on error returns appropriate + * errno value. + * + */ +int of_count_phandle_with_args(const struct device_node *np, + const char *list_name, const char *cells_name); + +/** * of_alias_scan() - Scan all properties of the 'aliases' node * * The function scans all the properties of the 'aliases' node and populates diff --git a/include/dm/ofnode.h b/include/dm/ofnode.h index 149622a..3f2cfbb 100644 --- a/include/dm/ofnode.h +++ b/include/dm/ofnode.h @@ -423,6 +423,23 @@ int ofnode_parse_phandle_with_args(ofnode node, const char *list_name, struct ofnode_phandle_args *out_args);
/** + * ofnode_count_phandle_with_args() - Count number of phandle in a list + * + * This function is useful to count phandles into a list. + * Returns number of phandle on success, on error returns appropriate + * errno value. + * + * @node: device tree node containing a list + * @list_name: property name that contains a list + * @cells_name: property name that specifies phandles' arguments count + * @return number of phandle on success, -ENOENT if @list_name does not + * exist, -EINVAL if a phandle was not found, @cells_name could not + * be found. + */ +int ofnode_count_phandle_with_args(ofnode node, const char *list_name, + const char *cells_name); + +/** * ofnode_path() - find a node by full path * * @path: Full path to node, e.g. "/bus/spi@1" diff --git a/include/dm/read.h b/include/dm/read.h index 8c9846e..84da28e 100644 --- a/include/dm/read.h +++ b/include/dm/read.h @@ -197,6 +197,24 @@ int dev_read_phandle_with_args(struct udevice *dev, const char *list_name, struct ofnode_phandle_args *out_args);
/** + * dev_count_phandle_with_args() - Return phandle number in a list + * + * This function is usefull to get phandle number contained in a property list. + * For example, this allows to allocate the right amount of memory to keep + * clock's reference contained into the "clocks" property. + * + * + * @dev: device whose node containing a list + * @list_name: property name that contains a list + * @cells_name: property name that specifies phandles' arguments count + * @Returns number of phandle found on success, on error returns appropriate + * errno value. + */ + +int dev_count_phandle_with_args(struct udevice *dev, const char *list_name, + const char *cells_name); + +/** * dev_read_addr_cells() - Get the number of address cells for a device's node * * This walks back up the tree to find the closest #address-cells property @@ -371,6 +389,13 @@ static inline int dev_read_phandle_with_args(struct udevice *dev, out_args); }
+static inline int dev_count_phandle_with_args(struct udevice *dev, + const char *list_name, const char *cells_name) +{ + return ofnode_count_phandle_with_args(dev_ofnode(dev), list_name, + cells_name); +} + static inline int dev_read_addr_cells(struct udevice *dev) { return fdt_address_cells(gd->fdt_blob, dev_of_offset(dev));
this allows to get file, line and function location of the current error message.
Signed-off-by: patrice chotard patrice.chotard@st.com Reviewed-by: Simon Glass sjg@chromium.org ---
v10: _ none v9: _ none v8: _ none v7: _ none v6: _ none v5: _ none v4: _ none v3: _ add commit message v2: _ create this independant path for printf() replacement
drivers/usb/host/ehci-generic.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index fb78462..2116ae1 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -34,7 +34,7 @@ static int ehci_usb_probe(struct udevice *dev) if (ret < 0) break; if (clk_enable(&clk)) - printf("failed to enable clock %d\n", i); + error("failed to enable clock %d\n", i); clk_free(&clk); }
@@ -46,7 +46,7 @@ static int ehci_usb_probe(struct udevice *dev) if (ret < 0) break; if (reset_deassert(&reset)) - printf("failed to deassert reset %d\n", i); + error("failed to deassert reset %d\n", i); reset_free(&reset); }
Use an array to save enabled clocks reference and deasserted resets in order to respectively disabled and asserted them in case of error during probe() or during driver removal.
v10: _ none v9: _ remove useless reset_free() and clk_free() in case of reset and clock has been correctly get and deasserted/enabled
v8: _ replace devm_kmalloc() by devm_kcalloc() _ fix error path by propagating initial error code until the end of probe()
v7: _ replace clk_count() and reset_count() by ofnode_count_phandle_with_args()
v6: _ none
v5: _ none
v4: _ update the memory allocation for deasserted resets and enabled clocks reference list. Replace lists by arrays. _ usage of new RESET and CLOCK methods clk_count(), reset_count(), reset_assert_all() and clk_disable_all().
v3: _ keep enabled clocks and deasserted resets reference in list in order to disable clock or assert resets in error path or in .remove callback _ use struct generic_ehci * instead of struct udevice * as parameter for ehci_release_resets() and ehci_release_clocks() drivers/usb/host/ehci-generic.c | 118 ++++++++++++++++++++++++++++++++-------- 1 file changed, 95 insertions(+), 23 deletions(-)
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index 2116ae1..e058445 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -6,6 +6,7 @@
#include <common.h> #include <clk.h> +#include <dm/ofnode.h> #include <reset.h> #include <asm/io.h> #include <dm.h> @@ -18,43 +19,114 @@ */ struct generic_ehci { struct ehci_ctrl ctrl; + struct clk *clocks; + struct reset_ctl *resets; + int clock_count; + int reset_count; };
static int ehci_usb_probe(struct udevice *dev) { + struct generic_ehci *priv = dev_get_priv(dev); struct ehci_hccr *hccr; struct ehci_hcor *hcor; - int i; - - for (i = 0; ; i++) { - struct clk clk; - int ret; - - ret = clk_get_by_index(dev, i, &clk); - if (ret < 0) - break; - if (clk_enable(&clk)) - error("failed to enable clock %d\n", i); - clk_free(&clk); + int i, err, ret, clock_nb, reset_nb; + + err = 0; + priv->clock_count = 0; + clock_nb = ofnode_count_phandle_with_args(dev_ofnode(dev), "clocks", + "#clock-cells"); + if (clock_nb > 0) { + priv->clocks = devm_kcalloc(dev, clock_nb, sizeof(struct clk), + GFP_KERNEL); + if (!priv->clocks) + return -ENOMEM; + + for (i = 0; i < clock_nb; i++) { + err = clk_get_by_index(dev, i, &priv->clocks[i]); + + if (err < 0) + break; + err = clk_enable(&priv->clocks[i]); + if (err) { + error("failed to enable clock %d\n", i); + clk_free(&priv->clocks[i]); + goto clk_err; + } + priv->clock_count++; + } + } else { + if (clock_nb != -ENOENT) { + error("failed to get clock phandle(%d)\n", clock_nb); + return clock_nb; + } }
- for (i = 0; ; i++) { - struct reset_ctl reset; - int ret; + priv->reset_count = 0; + reset_nb = ofnode_count_phandle_with_args(dev_ofnode(dev), "resets", + "#reset-cells"); + if (reset_nb > 0) { + priv->resets = devm_kcalloc(dev, reset_nb, + sizeof(struct reset_ctl), + GFP_KERNEL); + if (!priv->resets) + return -ENOMEM; + + for (i = 0; i < reset_nb; i++) { + err = reset_get_by_index(dev, i, &priv->resets[i]); + if (err < 0) + break;
- ret = reset_get_by_index(dev, i, &reset); - if (ret < 0) - break; - if (reset_deassert(&reset)) - error("failed to deassert reset %d\n", i); - reset_free(&reset); + if (reset_deassert(&priv->resets[i])) { + error("failed to deassert reset %d\n", i); + reset_free(&priv->resets[i]); + goto reset_err; + } + priv->reset_count++; + } + } else { + if (reset_nb != -ENOENT) { + error("failed to get reset phandle(%d)\n", reset_nb); + goto clk_err; + } }
hccr = map_physmem(devfdt_get_addr(dev), 0x100, MAP_NOCACHE); hcor = (struct ehci_hcor *)((uintptr_t)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
- return ehci_register(dev, hccr, hcor, NULL, 0, USB_INIT_HOST); + err = ehci_register(dev, hccr, hcor, NULL, 0, USB_INIT_HOST); + if (err) + goto reset_err; + + return 0; + +reset_err: + ret = reset_release_all(priv->resets, priv->reset_count); + if (ret) + error("failed to assert all resets\n"); +clk_err: + ret = clk_release_all(priv->clocks, priv->clock_count); + if (ret) + error("failed to disable all clocks\n"); + + return err; +} + +static int ehci_usb_remove(struct udevice *dev) +{ + struct generic_ehci *priv = dev_get_priv(dev); + int ret; + + ret = ehci_deregister(dev); + if (ret) + return ret; + + ret = reset_release_all(priv->resets, priv->reset_count); + if (ret) + return ret; + + return clk_release_all(priv->clocks, priv->clock_count); }
static const struct udevice_id ehci_usb_ids[] = { @@ -67,7 +139,7 @@ U_BOOT_DRIVER(ehci_generic) = { .id = UCLASS_USB, .of_match = ehci_usb_ids, .probe = ehci_usb_probe, - .remove = ehci_deregister, + .remove = ehci_usb_remove, .ops = &ehci_usb_ops, .priv_auto_alloc_size = sizeof(struct generic_ehci), .flags = DM_FLAG_ALLOC_PRIV_DMA,
v6: _ none
v5: _ none
Extend ehci-generic driver with generic PHY framework
v10: _ none v9: _ none v8: _ rework error path by propagating the initial error code until the end of probe() v7: _ none v6: _ none v5: _ none v4: _ update the memory allocation for deasserted resets and enabled clocks reference list. Replace lists by arrays. _ usage of new RESET and CLOCK methods clk_count(), reset_count(), reset_assert_all() and clk_disable_all(). v3: _ keep enabled clocks and deasserted resets reference in list in order to disable clock or assert resets in error path or in .remove callback _ use struct generic_ehci * instead of struct udevice * as parameter for ehci_release_resets() and ehci_release_clocks() drivers/usb/host/ehci-generic.c | 31 ++++++++++++++++++++++++++++++- 1 file changed, 30 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index e058445..3f751f1 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -7,6 +7,7 @@ #include <common.h> #include <clk.h> #include <dm/ofnode.h> +#include <generic-phy.h> #include <reset.h> #include <asm/io.h> #include <dm.h> @@ -21,6 +22,7 @@ struct generic_ehci { struct ehci_ctrl ctrl; struct clk *clocks; struct reset_ctl *resets; + struct phy phy; int clock_count; int reset_count; }; @@ -91,16 +93,37 @@ static int ehci_usb_probe(struct udevice *dev) } }
+ err = generic_phy_get_by_index(dev, 0, &priv->phy); + if (err) { + if (err != -ENOENT) { + error("failed to get usb phy\n"); + goto reset_err; + } + } + + err = generic_phy_init(&priv->phy); + if (err) { + error("failed to init usb phy\n"); + goto reset_err; + } + hccr = map_physmem(devfdt_get_addr(dev), 0x100, MAP_NOCACHE); hcor = (struct ehci_hcor *)((uintptr_t)hccr + HC_LENGTH(ehci_readl(&hccr->cr_capbase)));
err = ehci_register(dev, hccr, hcor, NULL, 0, USB_INIT_HOST); if (err) - goto reset_err; + goto phy_err;
+phy_err: + if (generic_phy_valid(&priv->phy)) { + ret = generic_phy_exit(&priv->phy); + if (ret) + error("failed to release phy\n"); + } + reset_err: ret = reset_release_all(priv->resets, priv->reset_count); if (ret) @@ -122,6 +145,12 @@ static int ehci_usb_remove(struct udevice *dev) if (ret) return ret;
+ if (generic_phy_valid(&priv->phy)) { + ret = generic_phy_exit(&priv->phy); + if (ret) + return ret; + } + ret = reset_release_all(priv->resets, priv->reset_count); if (ret) return ret;
use array to save enabled clocks reference in order to disabled them in case of error during probe() or during driver removal.
v10: _ replace ofnode_count_phandle_with_args() by dev_count_phandle_with_args()
v9: _ remove useless clk_free() when a clock is correctly requested and enabled _ replace clk_disable_all() by clk_release_all()
v7: _ replace clk_count() by ofnode_count_phandle_with_args()
v6: _ none
v5: _ none
v4: _ use generic_phy_valid() before generic_phy_exit() call
v3: _ extract in this patch the CLOCK support add-on from previous patch 5 _ keep enabled clocks reference in list in order to disable clocks in error path or in .remove callback
v2: _ add error path management _ add .remove callback
drivers/usb/host/ohci-generic.c | 55 +++++++++++++++++++++++++++++++++++++++-- 1 file changed, 53 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/ohci-generic.c b/drivers/usb/host/ohci-generic.c index f85738f..f5b27cc 100644 --- a/drivers/usb/host/ohci-generic.c +++ b/drivers/usb/host/ohci-generic.c @@ -5,7 +5,9 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> +#include <dm/ofnode.h> #include "ohci.h"
#if !defined(CONFIG_USB_OHCI_NEW) @@ -14,18 +16,67 @@
struct generic_ohci { ohci_t ohci; + struct clk *clocks; /* clock list */ + int clock_count; /* number of clock in clock list */ };
static int ohci_usb_probe(struct udevice *dev) { struct ohci_regs *regs = (struct ohci_regs *)devfdt_get_addr(dev); + struct generic_ohci *priv = dev_get_priv(dev); + int i, err, ret, clock_nb;
- return ohci_register(dev, regs); + err = 0; + priv->clock_count = 0; + clock_nb = dev_count_phandle_with_args(dev, "clocks", "#clock-cells"); + if (clock_nb > 0) { + priv->clocks = devm_kcalloc(dev, clock_nb, sizeof(struct clk), + GFP_KERNEL); + if (!priv->clocks) + return -ENOMEM; + + for (i = 0; i < clock_nb; i++) { + err = clk_get_by_index(dev, i, &priv->clocks[i]); + if (err < 0) + break; + + err = clk_enable(&priv->clocks[i]); + if (err) { + error("failed to enable clock %d\n", i); + clk_free(&priv->clocks[i]); + goto clk_err; + } + priv->clock_count++; + } + } else if (clock_nb != -ENOENT) { + error("failed to get clock phandle(%d)\n", clock_nb); + return clock_nb; + } + + err = ohci_register(dev, regs); + if (err) + goto clk_err; + + return 0; + +clk_err: + ret = clk_release_all(priv->clocks, priv->clock_count); + if (ret) + error("failed to disable all clocks\n"); + + return err; }
static int ohci_usb_remove(struct udevice *dev) { - return ohci_deregister(dev); + struct generic_ohci *priv = dev_get_priv(dev); + int ret; + + ret = ohci_deregister(dev); + if (ret) + return ret; + + return clk_release_all(priv->clocks, priv->clock_count); }
static const struct udevice_id ohci_usb_ids[] = {
v6: _ none
v5: _ none
use array to save deasserted resets reference in order to assert them in case of error during probe() or during driver removal.
v9: _ remove useless reset_free() when a reset is correctly requested and deasserted _ replace reset_assert_all() by reset_release_all()
v8: _ rework error path by propagating the initial error code until the end of probe() _ replace devm_kmalloc() by devm_kcalloc()
v7: _ replace reset_count() by ofnode_count_phandle_with_args()
v6: _ none
v5: _ none
v4: _ update the memory allocation for deasserted resets. Replace lists by arrays. _ usage of new RESET methods reset_assert_all() and clk_disable_all().
v3: _ extract in this patch the RESET support add-on from previous patch 5 _ keep deasserted resets reference in list in order to assert resets in error path or in .remove callback
drivers/usb/host/ohci-generic.c | 42 +++++++++++++++++++++++++++++++++++++++-- 1 file changed, 40 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/ohci-generic.c b/drivers/usb/host/ohci-generic.c index f5b27cc..95d54c1 100644 --- a/drivers/usb/host/ohci-generic.c +++ b/drivers/usb/host/ohci-generic.c @@ -8,6 +8,7 @@ #include <clk.h> #include <dm.h> #include <dm/ofnode.h> +#include <reset.h> #include "ohci.h"
#if !defined(CONFIG_USB_OHCI_NEW) @@ -17,14 +18,16 @@ struct generic_ohci { ohci_t ohci; struct clk *clocks; /* clock list */ + struct reset_ctl *resets; /* reset list */ int clock_count; /* number of clock in clock list */ + int reset_count; /* number of reset in reset list */ };
static int ohci_usb_probe(struct udevice *dev) { struct ohci_regs *regs = (struct ohci_regs *)devfdt_get_addr(dev); struct generic_ohci *priv = dev_get_priv(dev); - int i, err, ret, clock_nb; + int i, err, ret, clock_nb, reset_nb;
err = 0; priv->clock_count = 0; @@ -53,12 +56,43 @@ static int ohci_usb_probe(struct udevice *dev) return clock_nb; }
+ priv->reset_count = 0; + reset_nb = dev_count_phandle_with_args(dev, "resets", "#reset-cells"); + if (reset_nb > 0) { + priv->resets = devm_kcalloc(dev, reset_nb, + sizeof(struct reset_ctl), + GFP_KERNEL); + if (!priv->resets) + return -ENOMEM; + + for (i = 0; i < reset_nb; i++) { + err = reset_get_by_index(dev, i, &priv->resets[i]); + if (err < 0) + break; + + err = reset_deassert(&priv->resets[i]); + if (err) { + error("failed to deassert reset %d\n", i); + reset_free(&priv->resets[i]); + goto reset_err; + } + priv->reset_count++; + } + } else if (reset_nb != -ENOENT) { + error("failed to get reset phandle(%d)\n", reset_nb); + goto clk_err; + } + err = ohci_register(dev, regs); if (err) - goto clk_err; + goto reset_err;
+reset_err: + ret = reset_release_all(priv->resets, priv->reset_count); + if (ret) + error("failed to assert all resets\n"); clk_err: ret = clk_release_all(priv->clocks, priv->clock_count); if (ret) @@ -76,6 +110,10 @@ static int ohci_usb_remove(struct udevice *dev) if (ret) return ret;
+ ret = reset_release_all(priv->resets, priv->reset_count); + if (ret) + return ret; + return clk_release_all(priv->clocks, priv->clock_count); }
v6: _ none
v5: _ none
Extend ohci-generic driver with generic PHY framework
v10: _ none
v9: _ none
v7: _ none
v6: _ none
v5: _ none
v3: _ extract in this patch the PHY support add-on from previous patch 5
drivers/usb/host/ohci-generic.c | 31 ++++++++++++++++++++++++++++++- 1 file changed, 30 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/ohci-generic.c b/drivers/usb/host/ohci-generic.c index 95d54c1..9249039 100644 --- a/drivers/usb/host/ohci-generic.c +++ b/drivers/usb/host/ohci-generic.c @@ -8,6 +8,7 @@ #include <clk.h> #include <dm.h> #include <dm/ofnode.h> +#include <generic-phy.h> #include <reset.h> #include "ohci.h"
@@ -19,6 +20,7 @@ struct generic_ohci { ohci_t ohci; struct clk *clocks; /* clock list */ struct reset_ctl *resets; /* reset list */ + struct phy phy; int clock_count; /* number of clock in clock list */ int reset_count; /* number of reset in reset list */ }; @@ -83,12 +85,33 @@ static int ohci_usb_probe(struct udevice *dev) goto clk_err; }
+ err = generic_phy_get_by_index(dev, 0, &priv->phy); + if (err) { + if (err != -ENOENT) { + error("failed to get usb phy\n"); + goto reset_err; + } + } + + err = generic_phy_init(&priv->phy); + if (err) { + error("failed to init usb phy\n"); + goto reset_err; + } + err = ohci_register(dev, regs); if (err) - goto reset_err; + goto phy_err;
+phy_err: + if (generic_phy_valid(&priv->phy)) { + ret = generic_phy_exit(&priv->phy); + if (ret) + error("failed to release phy\n"); + } + reset_err: ret = reset_release_all(priv->resets, priv->reset_count); if (ret) @@ -110,6 +133,12 @@ static int ohci_usb_remove(struct udevice *dev) if (ret) return ret;
