[U-Boot] [PATCH 1/1] efi_loader: set image_base and image_size to correct values
Currently, image's image_base points to an address where the image was temporarily uploaded for further loading. Since efi_loader relocates the image to final destination, image_base and image_size should reflect that.
This bug was detected in UEFI SCT, "Loaded Image Protocol Test - test 2," which shows that 'Unload' function doesn't fit into a range suggested by image_base and image_size. TestCase/UEFI/EFI/Protocol/LoadedImage/BlackBoxTest/ LoadedImageBBTestMain.c:1002
This patch also reverts a patch, "efi_loader: save image relocation address and size" since newly added fields are no longer needed.
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org
Rebase the patch. Keep the relocation address in struct efi_image_object. We will use the address to free the image in UnloadImage.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_image_loader.c | 7 ++----- 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/lib/efi_loader/efi_image_loader.c b/lib/efi_loader/efi_image_loader.c index a18ce0a5705..39902152f3c 100644 --- a/lib/efi_loader/efi_image_loader.c +++ b/lib/efi_loader/efi_image_loader.c @@ -212,7 +212,6 @@ void *efi_load_pe(struct efi_loaded_image_obj *handle, void *efi, int rel_idx = IMAGE_DIRECTORY_ENTRY_BASERELOC; void *entry; uint64_t image_base; - uint64_t image_size; unsigned long virt_size = 0; int supported = 0;
@@ -256,7 +255,6 @@ void *efi_load_pe(struct efi_loaded_image_obj *handle, void *efi, IMAGE_NT_HEADERS64 *nt64 = (void *)nt; IMAGE_OPTIONAL_HEADER64 *opt = &nt64->OptionalHeader; image_base = opt->ImageBase; - image_size = opt->SizeOfImage; efi_set_code_and_data_type(loaded_image_info, opt->Subsystem); efi_reloc = efi_alloc(virt_size, loaded_image_info->image_code_type); @@ -272,7 +270,6 @@ void *efi_load_pe(struct efi_loaded_image_obj *handle, void *efi, } else if (nt->OptionalHeader.Magic == IMAGE_NT_OPTIONAL_HDR32_MAGIC) { IMAGE_OPTIONAL_HEADER32 *opt = &nt->OptionalHeader; image_base = opt->ImageBase; - image_size = opt->SizeOfImage; efi_set_code_and_data_type(loaded_image_info, opt->Subsystem); efi_reloc = efi_alloc(virt_size, loaded_image_info->image_code_type); @@ -315,10 +312,10 @@ void *efi_load_pe(struct efi_loaded_image_obj *handle, void *efi, invalidate_icache_all();
/* Populate the loaded image interface bits */ - loaded_image_info->image_base = efi; - loaded_image_info->image_size = image_size; handle->reloc_base = efi_reloc; handle->reloc_size = virt_size; + loaded_image_info->image_base = efi_reloc; + loaded_image_info->image_size = virt_size;
return entry; }
efi_set_code_and_data_type(loaded_image_info, opt->Subsystem); efi_reloc = efi_alloc(virt_size, loaded_image_info->image_code_type);image_size = opt->SizeOfImage;
return entry;
With this patch GRUB is not able to load the modules which are included in grubaa64.efi
## Starting EFI application at 40400000 ... error: unknown filesystem. Entering rescue mode... grub rescue>
Function grub_efi_modules_addr() expects image_base to point to the unrelocated image:
header = image->image_base; coff_header = &(header->coff_header); sections = (struct grub_pe32_section_table *) ((char *) coff_header + sizeof (*coff_header) + coff_header->optional_header_size);
The UEFI SCT II specifcation test 5.3.1.1.11 requires
Check on Application Images which have Unload function. Unload field should be valid and its entry address should be within the range of [ImageBase, ImageBase+ImageSize]
@Leif Any idea how to sort this out?
Best regards
Heinrich
return entry;
Best regards
Heinrich
@Alex:
Why did you decide to copy all loaded image sections before relocation? Couldn't we just apply the relocations in-situ?
When LoadImage() is called for a file path we always assign new memory. To stay consistent when LoadImage() is called for a memory image we should copy it. Then in both cases in-situ relocation will not mess up the source of the loaded image. And in both cases we own the malloc()ed memory location and can free() it on Unload() or Exit() in case of an application.
Best regards
Heinrich
return entry;
Oh, really?
Here "image" points to 'grub' itself, right? If so,
It seems to me that the above code shows that we should also copy PE headers, along with sections, after a new location is allocated in efi_load_pe().
Then my patch should work again, I didn't test it though.
Thanks, -Takahiro Akashi
Best regards
Heinrich
return entry;
Oh, really?
No, we should not copy more but less. The portable executable protocol is defines that an executable can be executed without relocation if loaded at the preferred address. This implies that the relative position of all sections can remain unchanged and we can do the relocation in place (w/o copying again). This is also what EDK II does.
So when LoadImage() is called for a file load it and relocate in place. If LoadImage() is called for a memory location, copy it and relocate in place.
Best regards
Heinrich
Best regards
Heinrich
# This discussion should be in ML as more people can join?
return entry;
Oh, really?
I think we should carefully use those words like "load" and "relocate".
Right if you mean optional header's "ImageBase" by preferred address.
Not 'can', but 'must'. This is part of "load" operation, using "VirtualAddress" in section headers. That is why we allocate a permanent space of 'virt_size' for this image.
If you mean moving sections by "relocation", it's not true. What Alex's efi_loader_relocate() does is that all the slots listed in optional header's relocation information (data directory) be updated depending on a loaded address (that is, the first address of allocated space).
What is passed to efi_load_pe() is just a temporary buffer
and we have to load it to the final destination and relocate it (or more precisely recalculate addresses/offsets) as I said above.
Best regards
Heinrich
Best regards
Heinrich
AKASHI Takahiro
