[PATCH 1/1] cmd: CMD_ACPI depends on ACPIGEN
Trying to compile qemu-x86_64_defconfig with CONFIG_CMD_ACPI=y and CONFIG_ACPIGEN=n fails with
ld.bfd: cmd/built-in.o: in function `do_acpi_items': cmd/acpi.c:162: undefined reference to `acpi_dump_items'
Add the missing configuration dependency.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/Kconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 0625ee4050..928a2a0a2d 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -84,7 +84,8 @@ menu "Info commands"
config CMD_ACPI bool "acpi" - default y if ACPIGEN + depends on ACPIGEN + default y help List and dump ACPI tables. ACPI (Advanced Configuration and Power Interface) is used mostly on x86 for providing information to the -- 2.29.2
- depends on ACPIGEN
- default y
Shouldn't be rather
default ACPIGEN
- default y
Shouldn't be rather
default ACPIGEN
Actually it makes no difference...
Am 20. Januar 2021 21:47:45 MEZ schrieb Andy Shevchenko andriy.shevchenko@linux.intel.com:
- default y
Shouldn't be rather
default ACPIGEN
Thanks for reviewing.
You cannot drop the depends line.
If you only want to change the last line only, 'default y' is easier to read and matches the style of the rest of our code.
Best regards
Heinrich
On Thu, Jan 21, 2021 at 4:38 AM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
applied to u-boot-x86, thanks!
Andy Shevchenko
Bin Meng
