[PATCH V2] doc: usage: modify mmc man-page
Modify mmc man-page. - Change a description about mmc erase command. - Add whitespace to distinguish.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- Changelog on V2: - Added Bin Meng's reviewed-tag - Fixed typo in commit-msg - Changed from count to cnt --- doc/usage/mmc.rst | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/doc/usage/mmc.rst b/doc/usage/mmc.rst index 57284ed6741e..458c7642c076 100644 --- a/doc/usage/mmc.rst +++ b/doc/usage/mmc.rst @@ -40,7 +40,7 @@ The 'mmc write' command writes raw data to MMC device from memory address with b cnt block count
-The 'mmc erase' command erases MMC device from block offset until count. +The 'mmc erase' command erases *cnt* blocks on the MMC device starting at block *blk#*.
blk# start block offset @@ -110,6 +110,7 @@ The 'mmc partconf' command shows or changes PARTITION_CONFIG field. partitions to access
The 'mmc bootpart-resize' command changes sizes of boot and RPMB partitions. + dev device number boot part size MB
Jaehoon Chung
