[PATCH] rockchip: dts: rk3328: fix sdram params
The rk3328 sdram driver read sdram parameters from the devicetree into a struct rk3328_sdram_params using dev_read_u32_array.
After commit 5ab30c3176bf ("ram: rockchip: Update ddr pctl regs for px30") changed the size of struct ddr_pctl_regs, a member of struct rk3328_sdram_params, U-Boot TPL can no longer initialize DRAM on RK3328.
Add ten u32 to the sdram parameter array in devicetree to align with this size change. This fixes DRAM initialization on RK3328.
Fixes: 5ab30c3176bf ("ram: rockchip: Update ddr pctl regs for px30") Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3328-sdram-ddr3-666.dtsi | 10 ++++++++++ arch/arm/dts/rk3328-sdram-ddr4-666.dtsi | 10 ++++++++++ arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi | 10 ++++++++++ arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi | 10 ++++++++++ 4 files changed, 40 insertions(+)
diff --git a/arch/arm/dts/rk3328-sdram-ddr3-666.dtsi b/arch/arm/dts/rk3328-sdram-ddr3-666.dtsi index 3e88ed443ba0..c5acfe4ac2a0 100644 --- a/arch/arm/dts/rk3328-sdram-ddr3-666.dtsi +++ b/arch/arm/dts/rk3328-sdram-ddr3-666.dtsi @@ -92,6 +92,16 @@ 0xffffffff 0xffffffff 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff
0x00000004 0x0000000a diff --git a/arch/arm/dts/rk3328-sdram-ddr4-666.dtsi b/arch/arm/dts/rk3328-sdram-ddr4-666.dtsi index 0859649a6905..c5fa2903c5c1 100644 --- a/arch/arm/dts/rk3328-sdram-ddr4-666.dtsi +++ b/arch/arm/dts/rk3328-sdram-ddr4-666.dtsi @@ -89,6 +89,16 @@ 0xffffffff 0xffffffff 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff
0x00000004 0x0000000c diff --git a/arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi b/arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi index d63c761a0283..07f27b2b7bab 100644 --- a/arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi +++ b/arch/arm/dts/rk3328-sdram-lpddr3-1600.dtsi @@ -92,6 +92,16 @@ 0xffffffff 0xffffffff 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff
0x00000004 0x0000000b diff --git a/arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi b/arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi index df42bb29ce88..d53d3a0fdfb2 100644 --- a/arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi +++ b/arch/arm/dts/rk3328-sdram-lpddr3-666.dtsi @@ -92,6 +92,16 @@ 0xffffffff 0xffffffff 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff + 0xffffffff
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com # roc-rk3328-cc
Hi Kever and Tom,
Can someone merge this soon, rk3328 platform has broken in the last two RCs.
Thanks, Jagan.
On Fri, Feb 17, 2023 at 11:39:35PM +0530, Jagan Teki wrote:
Hi Kever and Tom,
I would really like to see a rockchip PR of fixes at this point, yes. I believe we'll need one of the TPL/binary-blob related series as well?
Fixes: 5ab30c3176bf ("ram: rockchip: Update ddr pctl regs for px30") Signed-off-by: Jonas Karlman jonas@kwiboo.se Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Kever Yang kever.yang@rock-chips.com Reviewed-by: Jagan Teki jagan@amarulasolutions.com Tested-by: Jagan Teki jagan@amarulasolutions.com # roc-rk3328-cc
Thanks! This allows booting the rock64-rk3328 with v2023.04-rc2, which otherwise just hangs after loading TPL (or SPL?).
Tested-by: Vagrant Cascadian vagrant@debian.org
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
0xffffffff
participants (6)
Jagan Teki
Jonas Karlman
Kever Yang
Vagrant Cascadian
