[U-Boot] [Patch v3 1/2] powerpc/mpc8xxx: Fix DDR3 timing_cfg_1 and sdram_mode registers
The write recovery time of both registers should match. Since mode register doesn't support cycles of 9,11,13,15, we should use next higher number for both registers.
Signed-off-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c | 20 ++++++++++++++------ 1 files changed, 14 insertions(+), 6 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c index 41bad35..06064a5 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c @@ -333,6 +333,9 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr, unsigned char acttoact_mclk; /* Last write data pair to read command issue interval (tWTR) */ unsigned char wrtord_mclk; + /* DDR_SDRAM_MODE doesn't support 9,11,13,15 */ + const u8 wrrec_table[] = { + 1, 2, 3, 4, 5, 6, 7, 8, 10, 10, 12, 12, 14, 14, 0, 0};
pretoact_mclk = picos_to_mclk(common_dimm->tRP_ps); acttopre_mclk = picos_to_mclk(common_dimm->tRAS_ps); @@ -371,6 +374,8 @@ static void set_timing_cfg_1(fsl_ddr_cfg_regs_t *ddr,
refrec_ctrl = picos_to_mclk(common_dimm->tRFC_ps) - 8; wrrec_mclk = picos_to_mclk(common_dimm->tWR_ps); + + wrrec_mclk = wrrec_table[wrrec_mclk - 1]; if (popts->OTF_burst_chop_en) wrrec_mclk += 2;
@@ -810,6 +815,12 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, unsigned int bl; /* BL: Burst Length */
unsigned int wr_mclk; + /* + * DDR_SDRAM_MODE doesn't support 9,11,13,15 + * Please refer JEDEC Standard No. 79-3E for Mode Register MR0 + * for this table + */ + const u8 wr_table[] = {1, 2, 3, 4, 5, 5, 6, 6, 7, 7, 0, 0};
const unsigned int mclk_ps = get_memory_clk_period_ps(); int i; @@ -853,13 +864,10 @@ static void set_ddr_sdram_mode(fsl_ddr_cfg_regs_t *ddr, * 1=fast exit DLL on (tXP) */ dll_on = 1; + wr_mclk = (common_dimm->tWR_ps + mclk_ps - 1) / mclk_ps; - if (wr_mclk >= 12) - wr = 6; - else if (wr_mclk >= 9) - wr = 5; - else - wr = wr_mclk - 4; + wr = wr_table[wr_mclk - 5]; + dll_rst = 0; /* dll no reset */ mode = 0; /* normal mode */
This patch revised clk_adjust and wrlvl_start timings for corenet_ds, based on testing on Virtium VL33B5163F-K9S and Kingston KVR1333D3Q8R9S/4G.
Signed-off-by: York Sun yorksun@freescale.com --- board/freescale/corenet_ds/ddr.c | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/freescale/corenet_ds/ddr.c b/board/freescale/corenet_ds/ddr.c index f8df9d1..07b950f 100644 --- a/board/freescale/corenet_ds/ddr.c +++ b/board/freescale/corenet_ds/ddr.c @@ -170,8 +170,8 @@ const board_specific_parameters_t board_specific_parameters[][30] = { * lo| hi| num| clk| wrlvl | cpo |wrdata|2T * mhz| mhz|ranks|adjst| start | delay| */ - { 0, 850, 4, 1, 5, 0xff, 2, 0}, - {851, 950, 4, 3, 5, 0xff, 2, 0}, + { 0, 850, 4, 4, 6, 0xff, 2, 0}, + {851, 950, 4, 5, 7, 0xff, 2, 0}, {951, 1050, 4, 5, 8, 0xff, 2, 0}, {1051, 1250, 4, 5, 10, 0xff, 2, 0}, {1251, 1350, 4, 5, 11, 0xff, 2, 0}, @@ -188,8 +188,8 @@ const board_specific_parameters_t board_specific_parameters[][30] = { * lo| hi| num| clk| wrlvl | cpo |wrdata|2T * mhz| mhz|ranks|adjst| start | delay| */ - { 0, 850, 4, 1, 5, 0xff, 2, 0}, - {851, 950, 4, 3, 5, 0xff, 2, 0}, + { 0, 850, 4, 4, 6, 0xff, 2, 0}, + {851, 950, 4, 5, 7, 0xff, 2, 0}, {951, 1050, 4, 5, 8, 0xff, 2, 0}, {1051, 1250, 4, 5, 10, 0xff, 2, 0}, {1251, 1350, 4, 5, 11, 0xff, 2, 0},
York Sun
