[U-Boot-Users] directly execute linux zImage: cmd_bootz
Hi !
Attached is a patch for armboot that directly calls a Linux zImage. It has been tested on my PXA250 platform.
Prerequisites:
- works only on arm, because it takes stuff from asm_arm/armlinux.c - set CONFIG_KERNEL_RAM_BASE to where the zImage is in Flash
Problems:
- I have no clue if the tag list get's correctly set up, I'm using a kernel 2.4 which doesn't use the tags anyway. - how can I pass the cmdline? - Kernel 2.4. clobbers r2, the pointer to the tag list. In your fixup code you can have
MACHINE_START(...) BOOT_PARAMS(0xa0000100) ... MACHINE_END
but how put I *params to some fixed address?
I guess this is rather ugly, so comments on how to do it better are welcomed :-)
Hello
Holger Schurig wrote:
Hi !
Prerequisites:
Problems:
AFAICS 2.4 uses the tag list if there is one prepared by the bootloader.
By using the "ATAG_CMDLINE" in the tag list. Make sure you have defined "CONFIG_CMDLINE_TAG" in your u-boot config file.
can have
See http://sourceforge.net/mailarchive/forum.php?thread_id=1531608&forum_id=...
Dave
Nope. You have to pass BOOT_PARAMS(). See recent discussion on arm-linux-kernel.
Robert
No, it doesn't. See
http://www.arm.linux.org.uk/developer/booting.php
to find out that a boot loader should pass the address of the tag list in r2 to the kernel. It's near the end. And then see
http://lists.arm.linux.org.uk/pipermail/linux-arm-kernel/2003-January/013126...
to see that 2.4-kernels currently don't use r2 and can't use in order to stay compatible. In fact, a 2.4. kernel trashes r2 right at the start, see
http://lists.arm.linux.org.uk/pipermail/linux-arm-kernel/2003-January/013140...
However, 2.5-kernels already employ the r2-rule.
I'm not sure, but I think that only Kernels for ARM (and for XScale) use this tagging at all, correct?
See http://sourceforge.net/mailarchive/forum.php?thread_id=1531608&forum_id=... 98
Ahh, here is the trick, use gd->bd->bi_boot_params
Thanks.
Hi
No, it doesn't. See
I'm not speaking about the pointer to the tag list (which should be passed in r2, Linux 2.4 uses BOOT_PARAMS instead), i'm speacking about the tag list itself. Parameter passing from the bootloader to the kernel via the tag list is working, at least for me (using linux-2.4.19-rmk4 kernel).
Dave
"David Müller (ELSOFT AG)"
Holger Schurig
Robert Schwebel
