[PATCH] video: Add support for NewVision NV3052C SPI panels
This driver is mostly copied from the Linux kernel and includes support for two physical panels that use this driver.
Signed-off-by: John Watts contact@jookia.org --- This patch is a straightforward port of the kernel NV3052C SPI driver to U-Boot, keeping full compatibility with mainline device tree bindings. --- drivers/video/Kconfig | 6 + drivers/video/Makefile | 1 + drivers/video/newvision-nv3052c.c | 608 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 615 insertions(+)
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index e9d069d440..67409a39d2 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -612,6 +612,12 @@ config VIDEO_LCD_HITACHI_TX18D42VM lcd controller which needs to be initialized over SPI, once that is done they work like a regular LVDS panel.
+config VIDEO_LCD_NEWVISION_NV3052C + bool "NewVision NV3052C RGB/SPI panel support" + select VIDEO_MIPI_DBI + ---help--- + Support for panels built around the NewVision NV3052C controller. + config VIDEO_LCD_SPI_CS string "SPI CS pin for LCD related config job" depends on VIDEO_LCD_SSD2828 || VIDEO_LCD_HITACHI_TX18D42VM diff --git a/drivers/video/Makefile b/drivers/video/Makefile index ad77c60973..c82588ba0b 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -66,6 +66,7 @@ obj-$(CONFIG_VIDEO_LCD_RENESAS_R69328) += renesas-r69328.o obj-$(CONFIG_VIDEO_LCD_SAMSUNG_LTL106HL02) += samsung-ltl106hl02.o obj-$(CONFIG_VIDEO_LCD_SSD2828) += ssd2828.o obj-$(CONFIG_VIDEO_LCD_TDO_TL070WSH30) += tdo-tl070wsh30.o +obj-$(CONFIG_VIDEO_LCD_NEWVISION_NV3052C) += newvision-nv3052c.o obj-$(CONFIG_VIDEO_MCDE_SIMPLE) += mcde_simple.o obj-${CONFIG_VIDEO_MESON} += meson/ obj-${CONFIG_VIDEO_MIPI_DSI} += mipi_dsi.o diff --git a/drivers/video/newvision-nv3052c.c b/drivers/video/newvision-nv3052c.c new file mode 100644 index 0000000000..2ffa6ae9ed --- /dev/null +++ b/drivers/video/newvision-nv3052c.c @@ -0,0 +1,608 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * NewVision NV3052C IPS LCD panel driver + * + * Copyright (C) 2020, Paul Cercueil paul@crapouillou.net + * Copyright (C) 2022, Christophe Branchereau cbranchereau@gmail.com + */ + +#include <asm/gpio.h> +#include <backlight.h> +#include <dm/device_compat.h> +#include <dm.h> +#include <linux/delay.h> +#include <mipi_dbi.h> +#include <panel.h> +#include <power/regulator.h> + +struct nv3052c_reg { + u8 cmd; + u8 val; +}; + +struct nv3052c_panel_info { + struct display_timing default_timing; + const struct nv3052c_reg *panel_regs; + unsigned int panel_regs_len; +}; + +struct nv3052c { + const struct nv3052c_panel_info *panel_info; + struct udevice *supply; + struct gpio_desc reset_gpio; + struct udevice *backlight; + struct spi_slave *spi; + struct mipi_dbi dbi; +}; + +static const struct nv3052c_reg ltk035c5444t_panel_regs[] = { + // EXTC Command set enable, select page 1 + { 0xff, 0x30 }, { 0xff, 0x52 }, { 0xff, 0x01 }, + // Mostly unknown registers + { 0xe3, 0x00 }, + { 0x40, 0x00 }, + { 0x03, 0x40 }, + { 0x04, 0x00 }, + { 0x05, 0x03 }, + { 0x08, 0x00 }, + { 0x09, 0x07 }, + { 0x0a, 0x01 }, + { 0x0b, 0x32 }, + { 0x0c, 0x32 }, + { 0x0d, 0x0b }, + { 0x0e, 0x00 }, + { 0x23, 0xa0 }, + { 0x24, 0x0c }, + { 0x25, 0x06 }, + { 0x26, 0x14 }, + { 0x27, 0x14 }, + { 0x38, 0xcc }, // VCOM_ADJ1 + { 0x39, 0xd7 }, // VCOM_ADJ2 + { 0x3a, 0x4a }, // VCOM_ADJ3 + { 0x28, 0x40 }, + { 0x29, 0x01 }, + { 0x2a, 0xdf }, + { 0x49, 0x3c }, + { 0x91, 0x77 }, // EXTPW_CTRL2 + { 0x92, 0x77 }, // EXTPW_CTRL3 + { 0xa0, 0x55 }, + { 0xa1, 0x50 }, + { 0xa4, 0x9c }, + { 0xa7, 0x02 }, + { 0xa8, 0x01 }, + { 0xa9, 0x01 }, + { 0xaa, 0xfc }, + { 0xab, 0x28 }, + { 0xac, 0x06 }, + { 0xad, 0x06 }, + { 0xae, 0x06 }, + { 0xaf, 0x03 }, + { 0xb0, 0x08 }, + { 0xb1, 0x26 }, + { 0xb2, 0x28 }, + { 0xb3, 0x28 }, + { 0xb4, 0x33 }, + { 0xb5, 0x08 }, + { 0xb6, 0x26 }, + { 0xb7, 0x08 }, + { 0xb8, 0x26 }, + { 0xf0, 0x00 }, + { 0xf6, 0xc0 }, + // EXTC Command set enable, select page 2 + { 0xff, 0x30 }, { 0xff, 0x52 }, { 0xff, 0x02 }, + // Set gray scale voltage to adjust gamma + { 0xb0, 0x0b }, // PGAMVR0 + { 0xb1, 0x16 }, // PGAMVR1 + { 0xb2, 0x17 }, // PGAMVR2 + { 0xb3, 0x2c }, // PGAMVR3 + { 0xb4, 0x32 }, // PGAMVR4 + { 0xb5, 0x3b }, // PGAMVR5 + { 0xb6, 0x29 }, // PGAMPR0 + { 0xb7, 0x40 }, // PGAMPR1 + { 0xb8, 0x0d }, // PGAMPK0 + { 0xb9, 0x05 }, // PGAMPK1 + { 0xba, 0x12 }, // PGAMPK2 + { 0xbb, 0x10 }, // PGAMPK3 + { 0xbc, 0x12 }, // PGAMPK4 + { 0xbd, 0x15 }, // PGAMPK5 + { 0xbe, 0x19 }, // PGAMPK6 + { 0xbf, 0x0e }, // PGAMPK7 + { 0xc0, 0x16 }, // PGAMPK8 + { 0xc1, 0x0a }, // PGAMPK9 + // Set gray scale voltage to adjust gamma + { 0xd0, 0x0c }, // NGAMVR0 + { 0xd1, 0x17 }, // NGAMVR0 + { 0xd2, 0x14 }, // NGAMVR1 + { 0xd3, 0x2e }, // NGAMVR2 + { 0xd4, 0x32 }, // NGAMVR3 + { 0xd5, 0x3c }, // NGAMVR4 + { 0xd6, 0x22 }, // NGAMPR0 + { 0xd7, 0x3d }, // NGAMPR1 + { 0xd8, 0x0d }, // NGAMPK0 + { 0xd9, 0x07 }, // NGAMPK1 + { 0xda, 0x13 }, // NGAMPK2 + { 0xdb, 0x13 }, // NGAMPK3 + { 0xdc, 0x11 }, // NGAMPK4 + { 0xdd, 0x15 }, // NGAMPK5 + { 0xde, 0x19 }, // NGAMPK6 + { 0xdf, 0x10 }, // NGAMPK7 + { 0xe0, 0x17 }, // NGAMPK8 + { 0xe1, 0x0a }, // NGAMPK9 + // EXTC Command set enable, select page 3 + { 0xff, 0x30 }, { 0xff, 0x52 }, { 0xff, 0x03 }, + // Set various timing settings + { 0x00, 0x2a }, // GIP_VST_1 + { 0x01, 0x2a }, // GIP_VST_2 + { 0x02, 0x2a }, // GIP_VST_3 + { 0x03, 0x2a }, // GIP_VST_4 + { 0x04, 0x61 }, // GIP_VST_5 + { 0x05, 0x80 }, // GIP_VST_6 + { 0x06, 0xc7 }, // GIP_VST_7 + { 0x07, 0x01 }, // GIP_VST_8 + { 0x08, 0x03 }, // GIP_VST_9 + { 0x09, 0x04 }, // GIP_VST_10 + { 0x70, 0x22 }, // GIP_ECLK1 + { 0x71, 0x80 }, // GIP_ECLK2 + { 0x30, 0x2a }, // GIP_CLK_1 + { 0x31, 0x2a }, // GIP_CLK_2 + { 0x32, 0x2a }, // GIP_CLK_3 + { 0x33, 0x2a }, // GIP_CLK_4 + { 0x34, 0x61 }, // GIP_CLK_5 + { 0x35, 0xc5 }, // GIP_CLK_6 + { 0x36, 0x80 }, // GIP_CLK_7 + { 0x37, 0x23 }, // GIP_CLK_8 + { 0x40, 0x03 }, // GIP_CLKA_1 + { 0x41, 0x04 }, // GIP_CLKA_2 + { 0x42, 0x05 }, // GIP_CLKA_3 + { 0x43, 0x06 }, // GIP_CLKA_4 + { 0x44, 0x11 }, // GIP_CLKA_5 + { 0x45, 0xe8 }, // GIP_CLKA_6 + { 0x46, 0xe9 }, // GIP_CLKA_7 + { 0x47, 0x11 }, // GIP_CLKA_8 + { 0x48, 0xea }, // GIP_CLKA_9 + { 0x49, 0xeb }, // GIP_CLKA_10 + { 0x50, 0x07 }, // GIP_CLKB_1 + { 0x51, 0x08 }, // GIP_CLKB_2 + { 0x52, 0x09 }, // GIP_CLKB_3 + { 0x53, 0x0a }, // GIP_CLKB_4 + { 0x54, 0x11 }, // GIP_CLKB_5 + { 0x55, 0xec }, // GIP_CLKB_6 + { 0x56, 0xed }, // GIP_CLKB_7 + { 0x57, 0x11 }, // GIP_CLKB_8 + { 0x58, 0xef }, // GIP_CLKB_9 + { 0x59, 0xf0 }, // GIP_CLKB_10 + // Map internal GOA signals to GOA output pad + { 0xb1, 0x01 }, // PANELD2U2 + { 0xb4, 0x15 }, // PANELD2U5 + { 0xb5, 0x16 }, // PANELD2U6 + { 0xb6, 0x09 }, // PANELD2U7 + { 0xb7, 0x0f }, // PANELD2U8 + { 0xb8, 0x0d }, // PANELD2U9 + { 0xb9, 0x0b }, // PANELD2U10 + { 0xba, 0x00 }, // PANELD2U11 + { 0xc7, 0x02 }, // PANELD2U24 + { 0xca, 0x17 }, // PANELD2U27 + { 0xcb, 0x18 }, // PANELD2U28 + { 0xcc, 0x0a }, // PANELD2U29 + { 0xcd, 0x10 }, // PANELD2U30 + { 0xce, 0x0e }, // PANELD2U31 + { 0xcf, 0x0c }, // PANELD2U32 + { 0xd0, 0x00 }, // PANELD2U33 + // Map internal GOA signals to GOA output pad + { 0x81, 0x00 }, // PANELU2D2 + { 0x84, 0x15 }, // PANELU2D5 + { 0x85, 0x16 }, // PANELU2D6 + { 0x86, 0x10 }, // PANELU2D7 + { 0x87, 0x0a }, // PANELU2D8 + { 0x88, 0x0c }, // PANELU2D9 + { 0x89, 0x0e }, // PANELU2D10 + { 0x8a, 0x02 }, // PANELU2D11 + { 0x97, 0x00 }, // PANELU2D24 + { 0x9a, 0x17 }, // PANELU2D27 + { 0x9b, 0x18 }, // PANELU2D28 + { 0x9c, 0x0f }, // PANELU2D29 + { 0x9d, 0x09 }, // PANELU2D30 + { 0x9e, 0x0b }, // PANELU2D31 + { 0x9f, 0x0d }, // PANELU2D32 + { 0xa0, 0x01 }, // PANELU2D33 + // EXTC Command set enable, select page 2 + { 0xff, 0x30 }, { 0xff, 0x52 }, { 0xff, 0x02 }, + // Unknown registers + { 0x01, 0x01 }, + { 0x02, 0xda }, + { 0x03, 0xba }, + { 0x04, 0xa8 }, + { 0x05, 0x9a }, + { 0x06, 0x70 }, + { 0x07, 0xff }, + { 0x08, 0x91 }, + { 0x09, 0x90 }, + { 0x0a, 0xff }, + { 0x0b, 0x8f }, + { 0x0c, 0x60 }, + { 0x0d, 0x58 }, + { 0x0e, 0x48 }, + { 0x0f, 0x38 }, + { 0x10, 0x2b }, + // EXTC Command set enable, select page 0 + { 0xff, 0x30 }, { 0xff, 0x52 }, { 0xff, 0x00 }, + // Display Access Control + { 0x36, 0x0a }, // bgr = 1, ss = 1, gs = 0 +}; + +static const struct nv3052c_reg fs035vg158_panel_regs[] = { + // EXTC Command set enable, select page 1 + { 0xff, 0x30 }, { 0xff, 0x52 }, { 0xff, 0x01 }, + // Mostly unknown registers + { 0xe3, 0x00 }, + { 0x40, 0x00 }, + { 0x03, 0x40 }, + { 0x04, 0x00 }, + { 0x05, 0x03 }, + { 0x08, 0x00 }, + { 0x09, 0x07 }, + { 0x0a, 0x01 }, + { 0x0b, 0x32 }, + { 0x0c, 0x32 }, + { 0x0d, 0x0b }, + { 0x0e, 0x00 }, + { 0x23, 0x20 }, // RGB interface control: DE MODE PCLK-N + { 0x24, 0x0c }, + { 0x25, 0x06 }, + { 0x26, 0x14 }, + { 0x27, 0x14 }, + { 0x38, 0x9c }, //VCOM_ADJ1, different to ltk035c5444t + { 0x39, 0xa7 }, //VCOM_ADJ2, different to ltk035c5444t + { 0x3a, 0x50 }, //VCOM_ADJ3, different to ltk035c5444t + { 0x28, 0x40 }, + { 0x29, 0x01 }, + { 0x2a, 0xdf }, + { 0x49, 0x3c }, + { 0x91, 0x57 }, //EXTPW_CTRL2, different to ltk035c5444t + { 0x92, 0x57 }, //EXTPW_CTRL3, different to ltk035c5444t + { 0xa0, 0x55 }, + { 0xa1, 0x50 }, + { 0xa4, 0x9c }, + { 0xa7, 0x02 }, + { 0xa8, 0x01 }, + { 0xa9, 0x01 }, + { 0xaa, 0xfc }, + { 0xab, 0x28 }, + { 0xac, 0x06 }, + { 0xad, 0x06 }, + { 0xae, 0x06 }, + { 0xaf, 0x03 }, + { 0xb0, 0x08 }, + { 0xb1, 0x26 }, + { 0xb2, 0x28 }, + { 0xb3, 0x28 }, + { 0xb4, 0x03 }, // Unknown, different to ltk035c5444 + { 0xb5, 0x08 }, + { 0xb6, 0x26 }, + { 0xb7, 0x08 }, + { 0xb8, 0x26 }, + { 0xf0, 0x00 }, + { 0xf6, 0xc0 }, + // EXTC Command set enable, select page 0 + { 0xff, 0x30 }, { 0xff, 0x52 }, { 0xff, 0x02 }, + // Set gray scale voltage to adjust gamma + { 0xb0, 0x0b }, // PGAMVR0 + { 0xb1, 0x16 }, // PGAMVR1 + { 0xb2, 0x17 }, // PGAMVR2 + { 0xb3, 0x2c }, // PGAMVR3 + { 0xb4, 0x32 }, // PGAMVR4 + { 0xb5, 0x3b }, // PGAMVR5 + { 0xb6, 0x29 }, // PGAMPR0 + { 0xb7, 0x40 }, // PGAMPR1 + { 0xb8, 0x0d }, // PGAMPK0 + { 0xb9, 0x05 }, // PGAMPK1 + { 0xba, 0x12 }, // PGAMPK2 + { 0xbb, 0x10 }, // PGAMPK3 + { 0xbc, 0x12 }, // PGAMPK4 + { 0xbd, 0x15 }, // PGAMPK5 + { 0xbe, 0x19 }, // PGAMPK6 + { 0xbf, 0x0e }, // PGAMPK7 + { 0xc0, 0x16 }, // PGAMPK8 + { 0xc1, 0x0a }, // PGAMPK9 + // Set gray scale voltage to adjust gamma + { 0xd0, 0x0c }, // NGAMVR0 + { 0xd1, 0x17 }, // NGAMVR0 + { 0xd2, 0x14 }, // NGAMVR1 + { 0xd3, 0x2e }, // NGAMVR2 + { 0xd4, 0x32 }, // NGAMVR3 + { 0xd5, 0x3c }, // NGAMVR4 + { 0xd6, 0x22 }, // NGAMPR0 + { 0xd7, 0x3d }, // NGAMPR1 + { 0xd8, 0x0d }, // NGAMPK0 + { 0xd9, 0x07 }, // NGAMPK1 + { 0xda, 0x13 }, // NGAMPK2 + { 0xdb, 0x13 }, // NGAMPK3 + { 0xdc, 0x11 }, // NGAMPK4 + { 0xdd, 0x15 }, // NGAMPK5 + { 0xde, 0x19 }, // NGAMPK6 + { 0xdf, 0x10 }, // NGAMPK7 + { 0xe0, 0x17 }, // NGAMPK8 + { 0xe1, 0x0a }, // NGAMPK9 + // EXTC Command set enable, select page 3 + { 0xff, 0x30 }, { 0xff, 0x52 }, { 0xff, 0x03 }, + // Set various timing settings + { 0x00, 0x2a }, // GIP_VST_1 + { 0x01, 0x2a }, // GIP_VST_2 + { 0x02, 0x2a }, // GIP_VST_3 + { 0x03, 0x2a }, // GIP_VST_4 + { 0x04, 0x61 }, // GIP_VST_5 + { 0x05, 0x80 }, // GIP_VST_6 + { 0x06, 0xc7 }, // GIP_VST_7 + { 0x07, 0x01 }, // GIP_VST_8 + { 0x08, 0x03 }, // GIP_VST_9 + { 0x09, 0x04 }, // GIP_VST_10 + { 0x70, 0x22 }, // GIP_ECLK1 + { 0x71, 0x80 }, // GIP_ECLK2 + { 0x30, 0x2a }, // GIP_CLK_1 + { 0x31, 0x2a }, // GIP_CLK_2 + { 0x32, 0x2a }, // GIP_CLK_3 + { 0x33, 0x2a }, // GIP_CLK_4 + { 0x34, 0x61 }, // GIP_CLK_5 + { 0x35, 0xc5 }, // GIP_CLK_6 + { 0x36, 0x80 }, // GIP_CLK_7 + { 0x37, 0x23 }, // GIP_CLK_8 + { 0x40, 0x03 }, // GIP_CLKA_1 + { 0x41, 0x04 }, // GIP_CLKA_2 + { 0x42, 0x05 }, // GIP_CLKA_3 + { 0x43, 0x06 }, // GIP_CLKA_4 + { 0x44, 0x11 }, // GIP_CLKA_5 + { 0x45, 0xe8 }, // GIP_CLKA_6 + { 0x46, 0xe9 }, // GIP_CLKA_7 + { 0x47, 0x11 }, // GIP_CLKA_8 + { 0x48, 0xea }, // GIP_CLKA_9 + { 0x49, 0xeb }, // GIP_CLKA_10 + { 0x50, 0x07 }, // GIP_CLKB_1 + { 0x51, 0x08 }, // GIP_CLKB_2 + { 0x52, 0x09 }, // GIP_CLKB_3 + { 0x53, 0x0a }, // GIP_CLKB_4 + { 0x54, 0x11 }, // GIP_CLKB_5 + { 0x55, 0xec }, // GIP_CLKB_6 + { 0x56, 0xed }, // GIP_CLKB_7 + { 0x57, 0x11 }, // GIP_CLKB_8 + { 0x58, 0xef }, // GIP_CLKB_9 + { 0x59, 0xf0 }, // GIP_CLKB_10 + // Map internal GOA signals to GOA output pad + { 0xb1, 0x01 }, // PANELD2U2 + { 0xb4, 0x15 }, // PANELD2U5 + { 0xb5, 0x16 }, // PANELD2U6 + { 0xb6, 0x09 }, // PANELD2U7 + { 0xb7, 0x0f }, // PANELD2U8 + { 0xb8, 0x0d }, // PANELD2U9 + { 0xb9, 0x0b }, // PANELD2U10 + { 0xba, 0x00 }, // PANELD2U11 + { 0xc7, 0x02 }, // PANELD2U24 + { 0xca, 0x17 }, // PANELD2U27 + { 0xcb, 0x18 }, // PANELD2U28 + { 0xcc, 0x0a }, // PANELD2U29 + { 0xcd, 0x10 }, // PANELD2U30 + { 0xce, 0x0e }, // PANELD2U31 + { 0xcf, 0x0c }, // PANELD2U32 + { 0xd0, 0x00 }, // PANELD2U33 + // Map internal GOA signals to GOA output pad + { 0x81, 0x00 }, // PANELU2D2 + { 0x84, 0x15 }, // PANELU2D5 + { 0x85, 0x16 }, // PANELU2D6 + { 0x86, 0x10 }, // PANELU2D7 + { 0x87, 0x0a }, // PANELU2D8 + { 0x88, 0x0c }, // PANELU2D9 + { 0x89, 0x0e }, // PANELU2D10 + { 0x8a, 0x02 }, // PANELU2D11 + { 0x97, 0x00 }, // PANELU2D24 + { 0x9a, 0x17 }, // PANELU2D27 + { 0x9b, 0x18 }, // PANELU2D28 + { 0x9c, 0x0f }, // PANELU2D29 + { 0x9d, 0x09 }, // PANELU2D30 + { 0x9e, 0x0b }, // PANELU2D31 + { 0x9f, 0x0d }, // PANELU2D32 + { 0xa0, 0x01 }, // PANELU2D33 + // EXTC Command set enable, select page 2 + { 0xff, 0x30 }, { 0xff, 0x52 }, { 0xff, 0x02 }, + // Unknown registers + { 0x01, 0x01 }, + { 0x02, 0xda }, + { 0x03, 0xba }, + { 0x04, 0xa8 }, + { 0x05, 0x9a }, + { 0x06, 0x70 }, + { 0x07, 0xff }, + { 0x08, 0x91 }, + { 0x09, 0x90 }, + { 0x0a, 0xff }, + { 0x0b, 0x8f }, + { 0x0c, 0x60 }, + { 0x0d, 0x58 }, + { 0x0e, 0x48 }, + { 0x0f, 0x38 }, + { 0x10, 0x2b }, + // EXTC Command set enable, select page 0 + { 0xff, 0x30 }, { 0xff, 0x52 }, { 0xff, 0x00 }, + // Display Access Control + { 0x36, 0x0a }, // bgr = 1, ss = 1, gs = 0 +}; + +static const struct nv3052c_panel_info ltk035c5444t_panel_info = { + .default_timing = { + .pixelclock.typ = 24000000, + .hactive.typ = 640, + .hfront_porch.typ = 96, + .hback_porch.typ = 16, + .hsync_len.typ = 48, + .vactive.typ = 480, + .vfront_porch.typ = 5, + .vback_porch.typ = 2, + .vsync_len.typ = 13, + .flags = DISPLAY_FLAGS_HSYNC_LOW | DISPLAY_FLAGS_VSYNC_LOW | DISPLAY_FLAGS_DE_HIGH | DISPLAY_FLAGS_PIXDATA_NEGEDGE, + }, + .panel_regs = ltk035c5444t_panel_regs, + .panel_regs_len = ARRAY_SIZE(ltk035c5444t_panel_regs), +}; + +static const struct nv3052c_panel_info fs035vg158_panel_info = { + .default_timing = { + .pixelclock.typ = 21000000, + .hactive.typ = 640, + .hfront_porch.typ = 34, + .hback_porch.typ = 20, + .hsync_len.typ = 4, + .vactive.typ = 480, + .vfront_porch.typ = 12, + .vback_porch.typ = 6, + .vsync_len.typ = 4, + .flags = DISPLAY_FLAGS_VSYNC_LOW | DISPLAY_FLAGS_VSYNC_LOW | DISPLAY_FLAGS_DE_HIGH | DISPLAY_FLAGS_PIXDATA_NEGEDGE, + }, + .panel_regs = fs035vg158_panel_regs, + .panel_regs_len = ARRAY_SIZE(fs035vg158_panel_regs), +}; + +static const struct nv3052c_panel_info *panel_infos[] = { + <k035c5444t_panel_info, + &fs035vg158_panel_info, +}; + +static int nv3052c_panel_enable_backlight(struct udevice *dev) +{ + struct nv3052c *priv = dev_get_priv(dev); + struct mipi_dbi *dbi = &priv->dbi; + int err; + + err = mipi_dbi_command(dbi, MIPI_DCS_SET_DISPLAY_ON); + if (err) { + dev_err(dev, "Unable to enable display: %d\n", err); + return err; + } + + if (priv->backlight) { + /* Wait for the picture to be ready before enabling backlight */ + mdelay(120); + err = backlight_enable(priv->backlight); + } + + return err; +} + +static int nv3052c_panel_get_display_timing(struct udevice *dev, + struct display_timing *timing) +{ + struct nv3052c *priv = dev_get_priv(dev); + const struct nv3052c_panel_info *info = priv->panel_info; + const struct display_timing *our_timing = &info->default_timing; + + memcpy(timing, our_timing, sizeof(*our_timing)); + + return 0; +} + +static int nv3052c_panel_of_to_plat(struct udevice *dev) +{ + struct nv3052c *priv = dev_get_priv(dev); + int panel_info_index = dev_get_driver_data(dev); + int err; + + priv->spi = dev_get_parent_priv(dev); + priv->panel_info = panel_infos[panel_info_index]; + + if (CONFIG_IS_ENABLED(DM_REGULATOR)) { + err = device_get_supply_regulator(dev, "power-supply", + &priv->supply); + if (err) { + dev_err(dev, "Failed to get power supply: %d\n", err); + return err; + } + } + + err = gpio_request_by_name(dev, "reset-gpios", 0, &priv->reset_gpio, + GPIOD_IS_OUT); + if (err) { + dev_err(dev, "Failed to get reset GPIO: %d\n", err); + return err; + } + + err = uclass_get_device_by_phandle(UCLASS_PANEL_BACKLIGHT, dev, + "backlight", &priv->backlight); + if (err) { + dev_err(dev, "Failed to get backlight: %d\n", err); + return err; + } + + return 0; +} + +static int nv3052c_panel_probe(struct udevice *dev) +{ + struct nv3052c *priv = dev_get_priv(dev); + const struct nv3052c_reg *panel_regs = priv->panel_info->panel_regs; + unsigned int panel_regs_len = priv->panel_info->panel_regs_len; + struct mipi_dbi *dbi = &priv->dbi; + unsigned int i; + int err; + + err = mipi_dbi_spi_init(priv->spi, &priv->dbi, NULL); + if (err) { + dev_err(dev, "MPI DBI init failed: %d\n", err); + return err; + } + + if (CONFIG_IS_ENABLED(DM_REGULATOR)) { + err = regulator_set_enable(priv->supply, true); + if (err) { + dev_err(dev, "Failed to enable power supply: %d\n", err); + return err; + } + } + + /* Reset the chip */ + dm_gpio_set_value(&priv->reset_gpio, true); + mdelay(1); + dm_gpio_set_value(&priv->reset_gpio, false); + mdelay(150); + + for (i = 0; i < panel_regs_len; i++) { + err = mipi_dbi_command(dbi, panel_regs[i].cmd, + panel_regs[i].val); + + if (err) { + dev_err(dev, "Unable to set register: %d\n", err); + goto err_disable_regulator; + } + } + + err = mipi_dbi_command(dbi, MIPI_DCS_EXIT_SLEEP_MODE); + if (err) { + dev_err(dev, "Unable to exit sleep mode: %d\n", err); + goto err_disable_regulator; + } + + return 0; + +err_disable_regulator: + if (CONFIG_IS_ENABLED(DM_REGULATOR)) + regulator_set_enable(priv->supply, false); + + return err; +} + +static const struct panel_ops nv3052c_panel_ops = { + .enable_backlight = nv3052c_panel_enable_backlight, + .get_display_timing = nv3052c_panel_get_display_timing, +}; + +static const struct udevice_id nv3052c_panel_ids[] = { + { .compatible = "leadtek,ltk035c5444t", .data = 0 }, + { .compatible = "fascontek,fs035vg158", .data = 1 }, + { } +}; + +U_BOOT_DRIVER(nv3052c_panel) = { + .name = "nv3052c_panel", + .id = UCLASS_PANEL, + .of_match = nv3052c_panel_ids, + .ops = &nv3052c_panel_ops, + .of_to_plat = nv3052c_panel_of_to_plat, + .probe = nv3052c_panel_probe, + .priv_auto = sizeof(struct nv3052c), +};
--- base-commit: 0cc0eab0a140b5e660c25a27e116c9be538c1c12 change-id: 20240601-panel_nv3052c-76bab2b2c358
John Watts
