[U-Boot] [PATCH v2 0/4] Add support for treating compiler warnings as errors
To enforce a zero-warnings policy (e.g. in CI builds), all compiler warnings have to be treated as errors.
Extend Kbuild and buildman with according options to achieve this. Enable these new options in all Travis CI builds. All builds with compiler warnings will now fail. Only DTC warnings are still being ignored.
Example build which failed due to a compiler warning: https://travis-ci.org/danielschwierzeck/u-boot/jobs/333349371#L936
The patch which fixes the warning above: https://patchwork.ozlabs.org/patch/866009/
Changes in v2: - new patch - replace 'W=err' with 'KCFLAGS=-Werror'
Daniel Schwierzeck (4): README: add doc for how to supply user specific compiler flags to Kbuild buildman: add option -E for treating compiler warnings as errors travis.yml: fix 'set +e' in build script travis.yml: run buildman with option -E
.travis.yml | 5 ++--- README | 5 +++++ tools/buildman/builder.py | 5 ++++- tools/buildman/builderthread.py | 2 ++ tools/buildman/cmdline.py | 2 ++ tools/buildman/control.py | 3 ++- 6 files changed, 17 insertions(+), 5 deletions(-)
Probably not all users are aware of this possibility, thus add a pointer to the README. Also add a useful example.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
README | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/README b/README index b53ea7dfe3..b055ae7ef2 100644 --- a/README +++ b/README @@ -3719,6 +3719,11 @@ this behavior and build U-Boot to some external directory: Note that the command line "O=" setting overrides the KBUILD_OUTPUT environment variable.
+User specific CPPFLAGS, AFLAGS and CFLAGS can be passed to the compiler by +setting the according environment variables KCPPFLAGS, KAFLAGS and KCFLAGS. +For example to treat all compiler warnings as errors: + + make KCFLAGS=-Werror
Please be aware that the Makefiles assume you are using GNU make, so for instance on NetBSD you might need to use "gmake" instead of
Add a new option '-E' for treating all compiler warnings as errors. Eventually this will pass 'KCFLAGS=-Werror' to Kbuild.
Changes in v2: - replace 'W=err' with 'KCFLAGS=-Werror'
tools/buildman/builder.py | 5 ++++- tools/buildman/builderthread.py | 2 ++ tools/buildman/cmdline.py | 2 ++ tools/buildman/control.py | 3 ++- 4 files changed, 10 insertions(+), 2 deletions(-)
diff --git a/tools/buildman/builder.py b/tools/buildman/builder.py index acb0810457..4e72b7d60d 100644 --- a/tools/buildman/builder.py +++ b/tools/buildman/builder.py @@ -212,7 +212,8 @@ class Builder: gnu_make='make', checkout=True, show_unknown=True, step=1, no_subdirs=False, full_path=False, verbose_build=False, incremental=False, per_board_out_dir=False, - config_only=False, squash_config_y=False): + config_only=False, squash_config_y=False, + warnings_as_errors=False): """Create a new Builder object
Args: @@ -237,6 +238,7 @@ class Builder: board rather than a thread-specific directory config_only: Only configure each build, don't build it squash_config_y: Convert CONFIG options with the value 'y' to '1' + warnings_as_errors: Treat all compiler warnings as errors """ self.toolchains = toolchains self.base_dir = base_dir @@ -270,6 +272,7 @@ class Builder: if not self.squash_config_y: self.config_filenames += EXTRA_CONFIG_FILENAMES
+ self.warnings_as_errors = warnings_as_errors self.col = terminal.Color()
self._re_function = re.compile('(.*): In function.*') diff --git a/tools/buildman/builderthread.py b/tools/buildman/builderthread.py index 9e8ca80c5b..9ac101a5a4 100644 --- a/tools/buildman/builderthread.py +++ b/tools/buildman/builderthread.py @@ -216,6 +216,8 @@ class BuilderThread(threading.Thread): args.append('-s') if self.builder.num_jobs is not None: args.extend(['-j', str(self.builder.num_jobs)]) + if self.builder.warnings_as_errors: + args.append('KCFLAGS=-Werror') config_args = ['%s_defconfig' % brd.target] config_out = '' args.extend(self.builder.toolchains.GetMakeArguments(brd)) diff --git a/tools/buildman/cmdline.py b/tools/buildman/cmdline.py index 74247f0aff..6949d6bf2c 100644 --- a/tools/buildman/cmdline.py +++ b/tools/buildman/cmdline.py @@ -32,6 +32,8 @@ def ParseArgs(): help="Don't build, just configure each commit") parser.add_option('-e', '--show_errors', action='store_true', default=False, help='Show errors and warnings') + parser.add_option('-E', '--warnings-as-errors', action='store_true', + default=False, help='Treat all compiler warnings as errors') parser.add_option('-f', '--force-build', dest='force_build', action='store_true', default=False, help='Force build of boards even if already built') diff --git a/tools/buildman/control.py b/tools/buildman/control.py index 73b1a14fb6..3cac9f7cf6 100644 --- a/tools/buildman/control.py +++ b/tools/buildman/control.py @@ -263,7 +263,8 @@ def DoBuildman(options, args, toolchains=None, make_func=None, boards=None, incremental=options.incremental, per_board_out_dir=options.per_board_out_dir, config_only=options.config_only, - squash_config_y=not options.preserve_config_y) + squash_config_y=not options.preserve_config_y, + warnings_as_errors=options.warnings_as_errors) builder.force_config_on_failure = not options.quick if make_func: builder.do_make = make_func
The build script should not manipulate shell flags (especially '-e'). A non-zero exit value can also be catched with 'cmd || ret=$?'.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com ---
Changes in v2: None
.travis.yml | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/.travis.yml b/.travis.yml index 2a98c4bb11..1e55e1b7f1 100644 --- a/.travis.yml +++ b/.travis.yml @@ -101,9 +101,8 @@ script: # # Exit code 129 means warnings only. - if [[ "${BUILDMAN}" != "" ]]; then - set +e; - tools/buildman/buildman -P ${BUILDMAN}; - ret=$?; + ret=0; + tools/buildman/buildman -P ${BUILDMAN} || ret=$?; if [[ $ret -ne 0 && $ret -ne 129 ]]; then tools/buildman/buildman -sdeP ${BUILDMAN}; exit $ret;
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Reviewed-by: Tom Rini trini@konsulko.com
This forces all compiler warnings to be treated as errors.
Changes in v2: None
.travis.yml | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/.travis.yml b/.travis.yml index 1e55e1b7f1..59d1dd99e8 100644 --- a/.travis.yml +++ b/.travis.yml @@ -102,7 +102,7 @@ script: # Exit code 129 means warnings only. - if [[ "${BUILDMAN}" != "" ]]; then ret=0; - tools/buildman/buildman -P ${BUILDMAN} || ret=$?; + tools/buildman/buildman -P -E ${BUILDMAN} || ret=$?; if [[ $ret -ne 0 && $ret -ne 129 ]]; then tools/buildman/buildman -sdeP ${BUILDMAN}; exit $ret;
Daniel Schwierzeck
