[PATCH v2 4/4] mach-sunxi: Add SPI-NAND SPL-Support
This patch uses the refactored sunxi SPI-SPL driver from the previous patches of this series to add support for SPL booting from SPI-NAND. SPI-NAND-Boot is supported by, at least, the V3s.
Signed-off-by: Benedikt-Alexander Mokroß u-boot@bamkrs.de --- Changes for v2: - Removed a misplaced - in the line @@ -0,0 +1,496 @@ (I don't know what happened there)
arch/arm/mach-sunxi/spl/spi/Kconfig | 16 + arch/arm/mach-sunxi/spl/spi/Makefile | 1 + .../mach-sunxi/spl/spi/spl_spi_sunxi_nand.c | 497 ++++++++++++++++++ 3 files changed, 678 insertions(+) create mode 100644 arch/arm/mach-sunxi/spl/spi/spl_spi_sunxi_nand.c
diff --git a/arch/arm/mach-sunxi/spl/spi/Kconfig b/arch/arm/mach-sunxi/spl/spi/Kconfig index 04e2e506d3..ef14e14ea7 100644 --- a/arch/arm/mach-sunxi/spl/spi/Kconfig +++ b/arch/arm/mach-sunxi/spl/spi/Kconfig @@ -8,6 +8,22 @@ config SPL_SPI_SUNXI_NOR sunxi SPI-NOR Flash. It uses the same method as the boot ROM, so does not need any extra configuration.
+config SPL_SPI_SUNXI_NAND + bool "Support for SPI-NAND Flash on Allwinner SoCs in SPL" + depends on MACH_SUN8I_V3S + help + Enable support for SPI-NAND Flash. This option allows SPL to read from + sunxi SPI-NAND Flash. It uses the same method as the boot ROM, so does + not need any extra configuration. + +config SPL_SPI_SUNXI_NAND_USE_GENERIC2K_ON_UNKNOWN + bool "Generic SPI-NAND config with 2K page-size" + depends on SPL_SPI_SUNXI_NAND + default n + help + If no known spi-nand is found, try with generic settings for spi-nand with a + page-size of 2K. + choice prompt "SPI Clockdivider" depends on SPL_SPI_SUNXI diff --git a/arch/arm/mach-sunxi/spl/spi/Makefile b/arch/arm/mach-sunxi/spl/spi/Makefile index 52e58a3c65..696f436e98 100644 --- a/arch/arm/mach-sunxi/spl/spi/Makefile +++ b/arch/arm/mach-sunxi/spl/spi/Makefile @@ -10,6 +10,7 @@ ifdef CONFIG_SPL_BUILD
obj-$(CONFIG_SPL_SPI_SUNXI) += spl_spi_sunxi.o +obj-$(CONFIG_SPL_SPI_SUNXI_NAND) += spl_spi_sunxi_nand.o obj-$(CONFIG_SPL_SPI_SUNXI_NOR) += spl_spi_sunxi_nor.o
endif diff --git a/arch/arm/mach-sunxi/spl/spi/spl_spi_sunxi_nand.c b/arch/arm/mach-sunxi/spl/spi/spl_spi_sunxi_nand.c new file mode 100644 index 0000000000..66cec60839 --- /dev/null +++ b/arch/arm/mach-sunxi/spl/spi/spl_spi_sunxi_nand.c @@ -0,0 +1,496 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Benedikt-Alexander Mokroß u-boot@bamkrs.de + */ + +#include "spl_spi_sunxi.h" + +/*****************************************************************************/ + +#define DUMMY_BURST_BYTE 0x00 + +#ifndef CONFIG_SPL_SPINAND_SUNXI_SPL_SIZE +#define CONFIG_SPL_SPINAND_SUNXI_SPL_SIZE 0x6000 +#endif +#ifndef CONFIG_SPL_SPINAND_SUNXI_UBOOT_PADDING +#define CONFIG_SPL_SPINAND_SUNXI_UBOOT_PADDING 0x2000 +#endif +#ifndef CONFIG_SPL_SPINAND_SUNXI_PAGESIZE +#define CONFIG_SPL_SPINAND_SUNXI_PAGESIZE 2048 +#endif +#ifndef CONFIG_SYS_SPI_U_BOOT_OFFS +#define CONFIG_SYS_SPI_U_BOOT_OFFS (CONFIG_SPL_SPINAND_SUNXI_SPL_SIZE * (CONFIG_SPL_SPINAND_SUNXI_PAGESIZE / 1024)) + CONFIG_SPL_SPINAND_SUNXI_UBOOT_PADDING +#endif + +/*****************************************************************************/ + +struct sunxi_nand_config { + const char *name; + u32 jedec_id; + u32 page_mask; + u8 page_shift; + u32 addr_mask; + u8 addr_shift; +}; + +/*****************************************************************************/ + +static const char *sunxi_spl_name = "sunxi SPI-NAND"; + +/** + * List of known NANDS. For now, all of them are generic 2k devices. + */ +static struct sunxi_nand_config sunxi_known_nands[] = { + { + .name = "Macronix MX35LF1GE4AB", + .jedec_id = 0x00C212C2, /* MX35LFxGE4AB repeat the C2x2 over and over again */ + .page_mask = 0x00FFFFFF, + .page_shift = 11, + .addr_mask = 0x7FF, + .addr_shift = 0, + }, + { + .name = "Macronix MX35LF2GE4AB", + .jedec_id = 0x00C222C2, + .page_mask = 0x00FFFFFF, + .page_shift = 11, + .addr_mask = 0x7FF, + .addr_shift = 0, + }, + { + .name = "Winbond W25N01GVxxIG", + .jedec_id = 0x00EFAA21, + .page_mask = 0x0000FFFF, + .page_shift = 11, + .addr_mask = 0x7FF, + .addr_shift = 0, + }, + { + .name = "GigaDevice GD5F1GQ4RCxxG", + .jedec_id = 0x00C8B148, /* 3.3v */ + .page_mask = 0x00FFFFFF, + .page_shift = 11, + .addr_mask = 0x7FF, + .addr_shift = 0, + }, + { + .name = "GigaDevice GD5F1GQ4RCxxG", + .jedec_id = 0x00C8A148, /* 1.8V */ + .page_mask = 0x00FFFFFF, + .page_shift = 11, + .addr_mask = 0x7FF, + .addr_shift = 0, + }, + + { /* Sentinel */ + .name = NULL, + } +}; + +#ifdef CONFIG_SPL_SPI_SUNXI_NAND_USE_GENERIC2K_ON_UNKNOWN +/** + * Generic 2k device-configuration + */ +static struct sunxi_nand_config sunxi_generic_nand_config = { + .name = "Generic 2K SPI-NAND", + .jedec_id = 0xFFFFFFFF, + .page_mask = 0x00FFFFFF, + .page_shift = 11, + .addr_mask = 0x7FF, + .addr_shift = 0, +}; +#endif + +/* + * Enumerate all known nands and return the config if found. + * Returns NULL if none is found or if CONFIG_SPL_SPI_SUNXI_NAND_USE_GENERIC2K_ON_UNKNOWN + * is set, returns a generic configuration compatible to most standard 2k Page-Size SPI-NANDs + */ +static struct sunxi_nand_config *sunxi_spinand_enumerate(u32 jedec_id) +{ + struct sunxi_nand_config *ptr = sunxi_known_nands; + + while (ptr->name) { + if (jedec_id == ptr->jedec_id) { + return ptr; + } + ++ptr; + } +#ifdef CONFIG_SPL_SPI_SUNXI_NAND_USE_GENERIC2K_ON_UNKNOWN + return &sunxi_generic_nand_config; +#else + return NULL; +#endif +} + +/*****************************************************************************/ + +#define SPI_READ_MAX_SIZE 60 /* FIFO size, minus 4 bytes of the header */ + +/** + * Load a page in devices cache + */ +static void sunxi_spi0_load_page(struct sunxi_nand_config *config, u32 addr, ulong spi_ctl_reg, + ulong spi_ctl_xch_bitmask, + ulong spi_fifo_reg, + ulong spi_tx_reg, + ulong spi_rx_reg, + ulong spi_bc_reg, + ulong spi_tc_reg, + ulong spi_bcc_reg) { + /* Read Page in Cache */ + u8 status = 0x01; + + addr = addr >> (config->page_shift); + addr = addr & config->page_mask; + + writel(4, spi_bc_reg); /* Burst counter (total bytes) */ + writel(4, spi_tc_reg); /* Transfer counter (bytes to send) */ + if (spi_bcc_reg) + writel(4, spi_bcc_reg); /* SUN6I also needs this */ + + /* Send the Read Data Bytes (13h) command header */ + writeb(0x13, spi_tx_reg); + writeb((u8)(addr >> 16), spi_tx_reg); + writeb((u8)(addr >> 8), spi_tx_reg); + writeb((u8)(addr), spi_tx_reg); + + /* Start the data transfer */ + setbits_le32(spi_ctl_reg, spi_ctl_xch_bitmask); + + /* Wait till all bytes are send */ + while ((readl(spi_fifo_reg) & 0x7F0000) > 0) + ; + + /* wait till all bytes are read */ + while ((readl(spi_fifo_reg) & 0x7F) < 4) + ; + + /* Discard the 4 empty bytes from our send */ + readl(spi_rx_reg); + + /* Wait until page loaded */ + do { + /* tCS = 100ns + tRD_ECC 70ns -> 200ns wait */ + ndelay(200); + + /* Poll */ + writel(2 + 1, spi_bc_reg); /* Burst counter (total bytes) */ + writel(2, spi_tc_reg); /* Transfer counter (bytes to send) */ + if (spi_bcc_reg) + writel(2, spi_bcc_reg); /* SUN6I also needs this */ + /* Send the Read Status Bytes (0FC0h) command header */ + writeb(0x0F, spi_tx_reg); + writeb(0xC0, spi_tx_reg); + + /* Start the data transfer */ + setbits_le32(spi_ctl_reg, spi_ctl_xch_bitmask); + + while ((readl(spi_fifo_reg) & 0x7F) < 2 + 1) + ; + + /* skip 2 since we send 2 */ + readb(spi_rx_reg); + readb(spi_rx_reg); + + status = readb(spi_rx_reg); + + } while ((status & 0x01) == 0x01); +} + +static void spi0_load_page(struct sunxi_nand_config *config, u32 addr) +{ + uintptr_t base = sunxi_spi0_base_address(); + + if (is_sun6i_gen_spi()) { + sunxi_spi0_load_page(config, addr, + base + SUN6I_SPI0_TCR, + SUN6I_TCR_XCH, + base + SUN6I_SPI0_FIFO_STA, + base + SUN6I_SPI0_TXD, + base + SUN6I_SPI0_RXD, + base + SUN6I_SPI0_MBC, + base + SUN6I_SPI0_MTC, + base + SUN6I_SPI0_BCC); + } else { + sunxi_spi0_load_page(config, addr, + base + SUN4I_SPI0_CTL, + SUN4I_CTL_XCH, + base + SUN4I_SPI0_FIFO_STA, + base + SUN4I_SPI0_TX, + base + SUN4I_SPI0_RX, + base + SUN4I_SPI0_BC, + base + SUN4I_SPI0_TC, + 0); + } +} + +/** + * Read data from devices cache + */ +static void sunxi_spi0_read_cache(struct sunxi_nand_config *config, u8 *buf, u32 addr, u32 bufsize, + ulong spi_ctl_reg, + ulong spi_ctl_xch_bitmask, + ulong spi_fifo_reg, + ulong spi_tx_reg, + ulong spi_rx_reg, + ulong spi_bc_reg, + ulong spi_tc_reg, + ulong spi_bcc_reg) +{ + addr = addr >> (config->addr_shift); + addr = addr & config->addr_mask; + + writel(4 + bufsize, spi_bc_reg); /* Burst counter (total bytes) */ + writel(4, spi_tc_reg); /* Transfer counter (bytes to send) */ + if (spi_bcc_reg) + writel(4, spi_bcc_reg); /* SUN6I also needs this */ + + /* Send the Read Data Bytes (0Bh) command header */ + writeb(0x0B, spi_tx_reg); + writeb((u8)((addr >> 8)), spi_tx_reg); + writeb((u8)(addr), spi_tx_reg); + writeb(DUMMY_BURST_BYTE, spi_tx_reg); + + /* Start the data transfer */ + setbits_le32(spi_ctl_reg, spi_ctl_xch_bitmask); + + /* Wait until everything is received in the RX FIFO */ + while ((readl(spi_fifo_reg) & 0x7F) < 4 + bufsize) + ; + + /* Skip 4 bytes since we send 4 */ + readl(spi_rx_reg); + + /* Read the data */ + while (bufsize-- > 0) + *buf++ = readb(spi_rx_reg); + + /* tSHSL time is up to 100 ns in various SPI flash datasheets */ + ndelay(100); +} + +static void spi0_read_cache(struct sunxi_nand_config *config, void *buf, u32 addr, u32 len) +{ + uintptr_t base = sunxi_spi0_base_address(); + + if (is_sun6i_gen_spi()) { + sunxi_spi0_read_cache(config, buf, addr, len, + base + SUN6I_SPI0_TCR, + SUN6I_TCR_XCH, + base + SUN6I_SPI0_FIFO_STA, + base + SUN6I_SPI0_TXD, + base + SUN6I_SPI0_RXD, + base + SUN6I_SPI0_MBC, + base + SUN6I_SPI0_MTC, + base + SUN6I_SPI0_BCC); + } else { + sunxi_spi0_read_cache(config, buf, addr, len, + base + SUN4I_SPI0_CTL, + SUN4I_CTL_XCH, + base + SUN4I_SPI0_FIFO_STA, + base + SUN4I_SPI0_TX, + base + SUN4I_SPI0_RX, + base + SUN4I_SPI0_BC, + base + SUN4I_SPI0_TC, + 0); + } +} + +/** + * Load (bulk) data to cache an read it + * Handles chunking to SPI's buffsize + */ +static void spi0_read_data(struct sunxi_nand_config *config, void *buf, u32 addr, u32 len) +{ + u8 *buf8 = buf; + u32 chunk_len; + u32 curr_page; + u32 last_page = (addr >> (config->page_shift)) & config->page_mask; + + /* Load first page */ + spi0_load_page(config, addr); + + while (len > 0) { + /* Check if new data must be loaded in cache */ + curr_page = (addr >> (config->page_shift)) & config->page_mask; + if (curr_page > last_page) { + spi0_load_page(config, addr); + last_page = curr_page; + } + + /* Chunk to SPI-Buffers max size */ + chunk_len = len; + if (chunk_len > SPI_READ_MAX_SIZE) { + chunk_len = SPI_READ_MAX_SIZE; + } + + /* Check if chunk length exceeds page */ + if ((((addr + chunk_len) >> (config->page_shift)) & config->page_mask) > curr_page) { + chunk_len = ((curr_page + 1) << (config->page_shift)) - addr; + } + + /* Read data from cache */ + spi0_read_cache(config, buf8, addr, chunk_len); + len -= chunk_len; + buf8 += chunk_len; + addr += chunk_len; + } +} + +/** + * Read ID Bytes register + */ +static u32 sunxi_spi0_read_id(ulong spi_ctl_reg, + ulong spi_ctl_xch_bitmask, + ulong spi_fifo_reg, + ulong spi_tx_reg, + ulong spi_rx_reg, + ulong spi_bc_reg, + ulong spi_tc_reg, + ulong spi_bcc_reg) +{ + u8 idbuf[3]; + + writel(2 + 3, spi_bc_reg); /* Burst counter (total bytes) */ + writel(2, spi_tc_reg); /* Transfer counter (bytes to send) */ + if (spi_bcc_reg) + writel(2, spi_bcc_reg); /* SUN6I also needs this */ + + /* Send the Read ID Bytes (9Fh) command header */ + writeb(0x9F, spi_tx_reg); + writeb(DUMMY_BURST_BYTE, spi_tx_reg); + + /* Start the data transfer */ + setbits_le32(spi_ctl_reg, spi_ctl_xch_bitmask); + + /* Wait until everything is received in the RX FIFO */ + while ((readl(spi_fifo_reg) & 0x7F) < 2 + 3) + ; + + /* Skip 2 bytes */ + readb(spi_rx_reg); + readb(spi_rx_reg); + + /* Read the data */ + //while (bufsize-- > 0) + idbuf[0] = readb(spi_rx_reg); + idbuf[1] = readb(spi_rx_reg); + idbuf[2] = readb(spi_rx_reg); + + /* tSHSL time is up to 100 ns in various SPI flash datasheets */ + ndelay(100); + + return idbuf[2] | (idbuf[1] << 8) | (idbuf[0] << 16); +} + +static u32 spi0_read_id(void) +{ + uintptr_t base = sunxi_spi0_base_address(); + + if (is_sun6i_gen_spi()) { + return sunxi_spi0_read_id( + base + SUN6I_SPI0_TCR, + SUN6I_TCR_XCH, + base + SUN6I_SPI0_FIFO_STA, + base + SUN6I_SPI0_TXD, + base + SUN6I_SPI0_RXD, + base + SUN6I_SPI0_MBC, + base + SUN6I_SPI0_MTC, + base + SUN6I_SPI0_BCC); + } else { + return sunxi_spi0_read_id( + base + SUN4I_SPI0_CTL, + SUN4I_CTL_XCH, + base + SUN4I_SPI0_FIFO_STA, + base + SUN4I_SPI0_TX, + base + SUN4I_SPI0_RX, + base + SUN4I_SPI0_BC, + base + SUN4I_SPI0_TC, + 0); + } +} + +static ulong spi_load_read(struct spl_load_info *load, ulong sector, ulong count, void *buf) +{ + spi0_read_data((struct sunxi_nand_config *)load->priv, buf, sector, count); + + return count; +} + +/*****************************************************************************/ + +static int spl_spi_nand_load_image(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev) +{ + int ret = 0; + u32 id = 0; + struct image_header *header; + struct sunxi_nand_config *config; + + header = (struct image_header *)(CONFIG_SYS_TEXT_BASE); + + sunxi_spi0_init(); + id = spi0_read_id(); + + /* + * If we receive only zeros, there is most definetly no device attached. + */ + if (id == 0) { + sunxi_spi0_deinit(); + printf("%s: Received only zeros on jedec_id probe, assuming no spi-nand attached.\n", sunxi_spl_name); + return -1; + } + + /* + * Check if device is known and compatible. + */ + config = sunxi_spinand_enumerate(id); + if (!config) { + sunxi_spi0_deinit(); + printf("%s: Unknown chip %x\n", sunxi_spl_name, id); + return -1; + } + + printf("%s: Found %s (%x)\n", sunxi_spl_name, config->name, id); + + /* + * Read the header data from the image and parse it for validity. + */ + spi0_read_data(config, (void *)header, CONFIG_SYS_SPI_U_BOOT_OFFS, 0x40); + if (image_check_hcrc(header)) { + printf("%s: u-boot hcrc OK!\n", sunxi_spl_name); + + /* If it is an FIT-Image, load as FIT, if not, parse header normaly */ + if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && image_get_magic(header) == FDT_MAGIC) { + struct spl_load_info load; + + debug("%s: Found FIT image\n", sunxi_spl_name); + load.dev = NULL; + load.priv = (void *)config; + load.filename = NULL; + load.bl_len = 1; + load.read = spi_load_read; + ret = spl_load_simple_fit(spl_image, &load, CONFIG_SYS_SPI_U_BOOT_OFFS, header); + + } else { + ret = spl_parse_image_header(spl_image, header); + if (ret) { + printf("%s: spl_parse_image_header: %x\n", sunxi_spl_name, ret); + sunxi_spi0_deinit(); + return ret; + } + /* + * If everything is fine, read the rest of u-boot and start + */ + spi0_read_data(config, (void *)spl_image->load_addr, CONFIG_SYS_SPI_U_BOOT_OFFS, spl_image->size); + return 0; + } + } + printf("%s: u-boot hcrc ERROR!\n", sunxi_spl_name); + sunxi_spi0_deinit(); + return -1; +} + +/* Use priority 0 to override the default if it happens to be linked in */ +SPL_LOAD_IMAGE_METHOD("sunxi SPI-NAND", 0, BOOT_DEVICE_SPI, spl_spi_nand_load_image);
