[U-Boot-Users] changes for IDS8247 Board
Hallo,
we did some changes for u-boot-1.2.0 to support our IDS8247 board.
Thanks and regards. --- Sergej I. Stepanov IDS GmbH Nobelstr. 18 D-76275 Ettlingen T +49 (0) 72 43/2 18-615 F +49 (0) 72 43/2 18-400 http://www.ids.de Email: Sergej.Stepanov@ids.de --------
diff -rpuN u-boot-1.2.0_orig/board/ids8247/ids8247.c u-boot-1.2.0_IDS8247/board/ids8247/ids8247.c --- u-boot-1.2.0_orig/board/ids8247/ids8247.c 2007-01-07 00:13:11.000000000 +0100 +++ u-boot-1.2.0_IDS8247/board/ids8247/ids8247.c 2007-08-02 12:24:49.000000000 +0200 @@ -19,12 +19,20 @@ * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA + * + * FCC1 was activated and FCC2 was deactivated for IDS8247 platform + * Sergej Stepanov, IDS GmbH, Germany, Sergej.Stepanov@ids.de + * */
#include <common.h> #include <ioports.h> #include <mpc8260.h>
+#if defined(CONFIG_OF_FLAT_TREE) +#include <ft_build.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
/* @@ -38,12 +46,12 @@ const iop_conf_t iop_conf_tab[4][32] = {
/* Port A configuration */ { /* conf ppar psor pdir podr pdat */ - /* PA31 */ { 0, 1, 1, 0, 0, 0 }, /* FCC1 COL */ - /* PA30 */ { 0, 1, 1, 0, 0, 0 }, /* FCC1 CRS */ - /* PA29 */ { 0, 1, 1, 1, 0, 0 }, /* FCC1 TXER */ - /* PA28 */ { 0, 1, 1, 1, 0, 0 }, /* FCC1 TXEN */ - /* PA27 */ { 0, 1, 1, 0, 0, 0 }, /* FCC1 RXDV */ - /* PA26 */ { 0, 1, 1, 0, 0, 0 }, /* FCC1 RXER */ + /* PA31 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 COL */ + /* PA30 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 CRS */ + /* PA29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 TXER */ + /* PA28 */ { 1, 1, 1, 1, 0, 0 }, /* FCC1 TXEN */ + /* PA27 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 RXDV */ + /* PA26 */ { 1, 1, 1, 0, 0, 0 }, /* FCC1 RXER */ /* PA25 */ { 0, 0, 0, 0, 1, 0 }, /* 8247_P0 */ #if defined(CONFIG_SOFT_I2C) /* PA24 */ { 1, 0, 0, 0, 1, 1 }, /* I2C_SDA2 */ @@ -53,14 +61,14 @@ const iop_conf_t iop_conf_tab[4][32] = { /* PA23 */ { 0, 0, 0, 1, 0, 0 }, /* PA23 */ #endif /* PA22 */ { 0, 0, 0, 0, 1, 0 }, /* SMC2_DCD */ - /* PA21 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 TXD3 */ - /* PA20 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 TXD2 */ - /* PA19 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 TXD1 */ - /* PA18 */ { 0, 1, 0, 1, 0, 0 }, /* FCC1 TXD0 */ - /* PA17 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 RXD0 */ - /* PA16 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 RXD1 */ - /* PA15 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 RXD2 */ - /* PA14 */ { 0, 1, 0, 0, 0, 0 }, /* FCC1 RXD3 */ + /* PA21 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD3 */ + /* PA20 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD2 */ + /* PA19 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD1 */ + /* PA18 */ { 1, 1, 0, 1, 0, 0 }, /* FCC1 TXD0 */ + /* PA17 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD0 */ + /* PA16 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD1 */ + /* PA15 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD2 */ + /* PA14 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 RXD3 */ /* PA13 */ { 0, 0, 0, 1, 1, 0 }, /* SMC2_RTS */ /* PA12 */ { 0, 0, 0, 0, 1, 0 }, /* SMC2_CTS */ /* PA11 */ { 0, 0, 0, 1, 1, 0 }, /* SMC2_DTR */ @@ -79,20 +87,20 @@ const iop_conf_t iop_conf_tab[4][32] = {
/* Port B configuration */ { /* conf ppar psor pdir podr pdat */ - /* PB31 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TX_ER */ - /* PB30 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_DV */ - /* PB29 */ { 1, 1, 1, 1, 0, 0 }, /* FCC2 MII TX_EN */ - /* PB28 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_ER */ - /* PB27 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII COL */ - /* PB26 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII CRS */ - /* PB25 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[3] */ - /* PB24 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[2] */ - /* PB23 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[1] */ - /* PB22 */ { 1, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[0] */ - /* PB21 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[0] */ - /* PB20 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[1] */ - /* PB19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[2] */ - /* PB18 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[3] */ + /* PB31 */ { 0, 1, 0, 1, 0, 0 }, /* FCC2 MII TX_ER */ + /* PB30 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_DV */ + /* PB29 */ { 0, 1, 1, 1, 0, 0 }, /* FCC2 MII TX_EN */ + /* PB28 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_ER */ + /* PB27 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII COL */ + /* PB26 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII CRS */ + /* PB25 */ { 0, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[3] */ + /* PB24 */ { 0, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[2] */ + /* PB23 */ { 0, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[1] */ + /* PB22 */ { 0, 1, 0, 1, 0, 0 }, /* FCC2 MII TxD[0] */ + /* PB21 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[0] */ + /* PB20 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[1] */ + /* PB19 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[2] */ + /* PB18 */ { 0, 1, 0, 0, 0, 0 }, /* FCC2 MII RxD[3] */ /* PB17 */ { 0, 0, 0, 0, 0, 0 }, /* PB17 */ /* PB16 */ { 0, 0, 0, 0, 0, 0 }, /* PB16 */ /* PB15 */ { 0, 0, 0, 0, 0, 0 }, /* PB15 */ @@ -123,8 +131,8 @@ const iop_conf_t iop_conf_tab[4][32] = { /* PC26 */ { 0, 0, 0, 1, 0, 0 }, /* PC26 */ /* PC25 */ { 0, 1, 1, 0, 0, 0 }, /* SYNC_IN */ /* PC24 */ { 0, 0, 0, 1, 0, 0 }, /* PC24 */ - /* PC23 */ { 0, 1, 0, 1, 0, 0 }, /* ATMTFCLK */ - /* PC22 */ { 0, 1, 0, 0, 0, 0 }, /* ATMRFCLK */ + /* PC23 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII TX_CLK */ + /* PC22 */ { 1, 1, 0, 0, 0, 0 }, /* FCC1 MII RX_CLK */ /* PC21 */ { 0, 1, 0, 0, 0, 0 }, /* SCC1 EN RXCLK */ /* PC20 */ { 0, 1, 0, 0, 0, 0 }, /* SCC1 EN TXCLK */ /* PC19 */ { 1, 1, 0, 0, 0, 0 }, /* FCC2 MII RX_CLK */ @@ -180,7 +188,7 @@ const iop_conf_t iop_conf_tab[4][32] = { /* PD10 */ { 0, 0, 0, 0, 0, 0 }, /* PD10 */ /* PD9 */ { 0, 0, 0, 0, 0, 0 }, /* PD9 */ /* PD8 */ { 0, 0, 0, 0, 0, 0 }, /* PD8 */ - /* PD7 */ { 0, 0, 0, 1, 0, 1 }, /* MII_MDIO */ + /* PD7 */ { 1, 0, 0, 1, 0, 1 }, /* MII_MDIO */ /* PD6 */ { 0, 0, 0, 1, 0, 1 }, /* PD6 */ /* PD5 */ { 0, 0, 0, 1, 0, 1 }, /* PD5 */ /* PD4 */ { 0, 0, 0, 1, 0, 1 }, /* PD4 */ @@ -224,7 +232,7 @@ static long int try_init (volatile memct * mapped by the controller. That means, that the initial mapping has * to be (at least) twice as large as the maximum expected size. */ - maxsize = (1 + (~orx | 0x7fff)) / 2; + maxsize = (1 + (~orx | 0x7fff))/* / 2*/;
sdmr_ptr = &memctl->memc_psdmr; orx_ptr = &memctl->memc_or2; @@ -316,3 +324,28 @@ nand_init (void) }
#endif /* CFG_CMD_NAND */ + +#if defined(CONFIG_OF_FLAT_TREE) && defined(CONFIG_OF_BOARD_SETUP) +void +ft_board_setup(void *blob, bd_t *bd) +{ + u32 *p; + int len; + ulong clock; + /* do what ft_cpu_setup does */ + + clock = bd->bi_busfreq; + p = ft_get_prop(blob, "/cpus/" OF_CPU "/bus-frequency", &len); + if (p != NULL) + *p = cpu_to_be32(clock); + + p = ft_get_prop(blob, "/" OF_SOC "/console@0000/clock-frequency", &len); + memcpy(p, bd->bi_enetaddr, 6); + + p = ft_get_prop(blob, "/memory/reg", &len); + if (p != NULL) { + *p++ = cpu_to_be32(bd->bi_memstart); + *p = cpu_to_be32(bd->bi_memsize); + } +} +#endif diff -rpuN u-boot-1.2.0_orig/include/configs/IDS8247.h u-boot-1.2.0_IDS8247/include/configs/IDS8247.h --- u-boot-1.2.0_orig/include/configs/IDS8247.h 2007-01-07 00:13:11.000000000 +0100 +++ u-boot-1.2.0_IDS8247/include/configs/IDS8247.h 2007-08-02 12:25:07.000000000 +0200 @@ -19,6 +19,13 @@ * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA + * + * for IDS8247 platform + * - FCC1 is activated + * - FCC2 is deactivated + * - I2C is activated + * Sergej Stepanov, IDS GmbH, Germany, Sergej.Stepanov@ids.de + * */
/* @@ -27,7 +34,7 @@
#ifndef __CONFIG_H #define __CONFIG_H - +#undef DEBUG /* * High Level Configuration Options * (easy to change) @@ -120,6 +127,20 @@
#define CFG_NS16550_COM1 (CFG_UART_BASE + 0x8000)
+ +/* pass open firmware flat tree */ +#define CONFIG_OF_FLAT_TREE 1 +#define CONFIG_OF_BOARD_SETUP 1 + +/* maximum size of the flat tree (8K) */ +//#define OF_FLAT_TREE_MAX_SIZE 8192 + +#define OF_CPU "PowerPC,8247@0" +#define OF_SOC "soc8247@e0008000" +#define OF_TBCLK (bd->bi_busfreq / 4) +#define OF_STDOUT_PATH "/soc8247@e0008000/console@0000" + + /* * select ethernet configuration * @@ -135,8 +156,22 @@ #undef CONFIG_ETHER_ON_SCC /* define if ether on SCC */ #define CONFIG_ETHER_ON_FCC /* define if ether on FCC */ #undef CONFIG_ETHER_NONE /* define if ether on something else */ -#define CONFIG_ETHER_INDEX 2 /* which SCC/FCC channel for ethernet */ +#define CONFIG_ETHER_INDEX 1 /* which SCC/FCC channel for ethernet */ +#define CONFIG_ETHER_ON_FCC1 +#define FCC_ENET
+#if 1 /* FCC */ +/* + * - Rx-CLK is CLK10 + * - Tx-CLK is CLK9 + * - RAM for BD/Buffers is on the 60x Bus (see 28-13) + * - Enable Full Duplex in FSMR + */ +# define CFG_CMXFCR_MASK (CMXFCR_FC1|CMXFCR_RF1CS_MSK|CMXFCR_TF1CS_MSK) +# define CFG_CMXFCR_VALUE (CMXFCR_RF1CS_CLK10|CMXFCR_TF1CS_CLK9) +# define CFG_CPMFCR_RAMTYPE 0 +# define CFG_FCC_PSMR (FCC_PSMR_FDE|FCC_PSMR_LPB) +#else /* * - Rx-CLK is CLK13 * - Tx-CLK is CLK14 @@ -147,7 +182,7 @@ # define CFG_CMXFCR_VALUE (CMXFCR_RF2CS_CLK13|CMXFCR_TF2CS_CLK14) # define CFG_CPMFCR_RAMTYPE 0 # define CFG_FCC_PSMR (FCC_PSMR_FDE|FCC_PSMR_LPB) - +#endif
/* system clock rate (CLKIN) - equal to the 60x and local bus speed */ #define CONFIG_8260_CLKIN 66666666 /* in Hz */ @@ -161,7 +196,12 @@
#define CONFIG_BOOTP_MASK (CONFIG_BOOTP_DEFAULT|CONFIG_BOOTP_BOOTFILESIZE)
+#define CONFIG_RTC_PCF8563 +#define CFG_I2C_RTC_ADDR 0x51 + #define CONFIG_COMMANDS (CONFIG_CMD_DFL | \ + CFG_CMD_ASKENV | \ + CFG_CMD_DATE | \ CFG_CMD_DHCP | \ CFG_CMD_NFS | \ CFG_CMD_NAND | \ @@ -203,7 +243,10 @@ */ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */
- +#define CFG_FLASH_CFI /* The flash is CFI compatible */ +#define CFG_FLASH_CFI_DRIVER /* Use common CFI driver */ +#define CFG_FLASH_BANKS_LIST { 0xFF800000 } +#define CFG_MAX_FLASH_BANKS_DETECT 1 /* What should the base address of the main FLASH be and how big is * it (in MBytes)? This must contain TEXT_BASE from board/ids8247/config.mk * The main FLASH is whichever is connected to *CS0. @@ -219,7 +262,7 @@ * FLASH organization */ #define CFG_MAX_FLASH_BANKS 1 /* max num of memory banks */ -#define CFG_MAX_FLASH_SECT 64 /* max num of sects on one chip */ +#define CFG_MAX_FLASH_SECT 128 /* max number of sectors on one chip */
#define CFG_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ #define CFG_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ @@ -496,17 +539,23 @@ BRx_MS_SDRAM_P |\ BRx_V)
-#define CFG_OR2_PRELIM CFG_OR2
/* SDRAM initialization values */ -#define CFG_OR2 ((~(CFG_GLOBAL_SDRAM_LIMIT-1) & ORxS_SDAM_MSK) |\ +/*#define CFG_OR2 ((~(CFG_GLOBAL_SDRAM_LIMIT-1) & ORxS_SDAM_MSK) | \ ORxS_BPD_4 |\ ORxS_ROWST_PBI0_A10 |\ ORxS_NUMR_12) +*/ +#define CFG_OR2 ((~(CFG_GLOBAL_SDRAM_LIMIT-1) & ORxS_SDAM_MSK) |\ + ORxS_BPD_4 |\ + ORxS_ROWST_PBI0_A9 |\ + ORxS_NUMR_12) + +#define CFG_OR2_PRELIM CFG_OR2
-#define CFG_PSDMR (PSDMR_SDAM_A13_IS_A5 |\ +/*#define CFG_PSDMR (PSDMR_SDAM_A13_IS_A5 | \ PSDMR_BSMA_A15_A17 |\ PSDMR_SDA10_PBI0_A11 |\ PSDMR_RFRC_5_CLK |\ @@ -516,6 +565,17 @@ PSDMR_LDOTOPRE_2C |\ PSDMR_WRC_3C |\ PSDMR_CL_3) +*/ +#define CFG_PSDMR (PSDMR_SDAM_A14_IS_A5 |\ + PSDMR_BSMA_A15_A17 |\ + PSDMR_SDA10_PBI0_A10 |\ + PSDMR_RFRC_5_CLK |\ + PSDMR_PRETOACT_2W |\ + PSDMR_ACTTORW_2W |\ + PSDMR_BL |\ + PSDMR_LDOTOPRE_2C |\ + PSDMR_WRC_3C |\ + PSDMR_CL_3)
/* Bank 3 - UART */
We're trying to get away from model numbers in the soc node; could you make it soc@e0008000 instead?
- Rx-CLK is CLK10
- Tx-CLK is CLK9
Don't use #if 1; Either provide something meaningful to #ifdef/#ifndef on (even if it's curently always/never set), or remove the alternate code.
ORxS_BPD_4 |\
ORxS_NUMR_12)
Likewise, no commented out code, please. If you're trying to support multiple versions or configurations of the board, use an ifdef.
-Scott
Your Signed-off-by: line is missing.
Please repost, but please also clean up the coding style issyes (trailing white space, indentation not by TAB, C++ comments).
See http://www.denx.de/wiki/UBoot/Patches
Scott Wood
Sergej Stepanov
