[PATCH 1/5] arch: rockchip: rk3588: Fix missing suffix 'A' for Edgeble Neu6A
Add missing suffix 'A' for Edgeble Neu6A SoM and IO boards.
Fixes: <15b2d1fb727> ("board: rockchip: Add Edgeble Neural Compute Module 6") Signed-off-by: Jagan Teki jagan@edgeble.ai --- arch/arm/mach-rockchip/rk3588/Kconfig | 10 +++++----- doc/board/rockchip/rockchip.rst | 2 +- 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index 3596b82f1f..5eecd26f86 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -10,14 +10,14 @@ config TARGET_RK3588_NEU6 bool "Edgeble Neural Compute Module 6(Neu6) SoM" select BOARD_LATE_INIT help - Neu6: - Neural Compute Module 6A(Neu6a) is a 96boards SoM-CB compute module + Neu6A: + Neural Compute Module 6A(Neu6A) is a 96boards SoM-CB compute module based on Rockchip RK3588 from Edgeble AI.
- Neu6-IO: - Neural Compute Module 6(Neu6) IO board is an industrial form factor + Neu6A-IO: + Neural Compute Module 6A(Neu6A) IO board is an industrial form factor IO board and Neu6a needs to mount on top of this IO board in order to - create complete Edgeble Neural Compute Module 6(Neu6) IO platform. + create complete Edgeble Neural Compute Module 6A(Neu6A) IO platform.
config TARGET_ROCK5B_RK3588 bool "Radxa ROCK5B RK3588 board" diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 99376fb54c..1f46924a3d 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -98,7 +98,7 @@ List of mainline supported Rockchip boards:
* rk3588 - Rockchip EVB (evb-rk3588) - - Edgeble Neural Compute Module 6 SoM - Neu6a (neu6a-io-rk3588) + - Edgeble Neural Compute Module 6A SoM - Neu6a (neu6a-io-rk3588) - Radxa ROCK 5B (rock5b-rk3588)
* rv1108
Rockchip RK3588J is the industrial-grade version of RK3588 SoC and is operated with -40 °C to +85 °C temparature.
Add rk3588j specific dtsi for adding rk3588j specific operating points and other changes to be add in future.
Kernel commit: commit <8274a04ff1dc> ("arm64: dts: rockchip: Add Rockchip RK3588J")
Signed-off-by: Jagan Teki jagan@edgeble.ai --- arch/arm/dts/rk3588j.dtsi | 7 +++++++ 1 file changed, 7 insertions(+) create mode 100644 arch/arm/dts/rk3588j.dtsi
diff --git a/arch/arm/dts/rk3588j.dtsi b/arch/arm/dts/rk3588j.dtsi new file mode 100644 index 0000000000..38b9dbf38a --- /dev/null +++ b/arch/arm/dts/rk3588j.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2022 Rockchip Electronics Co., Ltd. + * + */ + +#include "rk3588.dtsi"
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- Copyright (c) 2022 Rockchip Electronics Co., Ltd.
Add rk3588j-u-boot.dtsi for adding U-Boot specific nodes and properties for Rockchip RK3588J SoC.
Signed-off-by: Jagan Teki jagan@edgeble.ai --- arch/arm/dts/rk3588j-u-boot.dtsi | 6 ++++++ 1 file changed, 6 insertions(+) create mode 100644 arch/arm/dts/rk3588j-u-boot.dtsi
diff --git a/arch/arm/dts/rk3588j-u-boot.dtsi b/arch/arm/dts/rk3588j-u-boot.dtsi new file mode 100644 index 0000000000..f5c9e329a5 --- /dev/null +++ b/arch/arm/dts/rk3588j-u-boot.dtsi @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#include "rk3588-u-boot.dtsi"
Thanks, - Kever
- Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd.
Neural Compute Module 6B(Neu6B) is a 96boards SoM-CB compute module based on Rockchip RK3588J from Edgeble AI.
General features: - Rockchip RK3588J - up to 32GB LPDDR4x - up to 128GB eMMC - 2x MIPI CSI2 FPC - On module WiFi6/BT
Neural Compute Module 6B(Neu6B) IO board is an industrial form factor ready-to-use IO board from Edgeble AI.
General features: - microSD slot - 1x HDMI Out - 1x HDMI In - 2x DP - 1x eDP - 2x MIPI DSI connector - 4x MIPI CSI2 connector - 2x USB Host - 2x USB 3.0 OTG/Host - 1x SATA - 1x 2.5Gbps Ethernet - 1x M.2 B-Key for 4G/5G cards - 1x M.2 M-Key slot - 1x Onboard PoE - 1x RS485, RS232, CAN - 1x Audio, MIC port - RTC battery slot - 40-pin GPIO expansion
Neu6B needs to mount on top of this IO board in order to create a complete Edgeble Neural Compute Module 6B(Neu6B) IO platform.
Kernel commits: commit <5f06c3f508f7> ("arm64: dts: rockchip: Add rk3588 Edgeble Neu6 Model B SoM") commit <3a9181a43b94> ("arm64: dts: rockchip: Add rk3588 Edgeble Neu6 Model B IO")
Signed-off-by: Jagan Teki jagan@edgeble.ai --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3588-edgeble-neu6b-io.dts | 27 ++++++++++++++++++++ arch/arm/dts/rk3588-edgeble-neu6b.dtsi | 32 ++++++++++++++++++++++++ 3 files changed, 60 insertions(+) create mode 100644 arch/arm/dts/rk3588-edgeble-neu6b-io.dts create mode 100644 arch/arm/dts/rk3588-edgeble-neu6b.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 480269fa60..145e14eae9 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -173,6 +173,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3568) += \
dtb-$(CONFIG_ROCKCHIP_RK3588) += \ rk3588-edgeble-neu6a-io.dtb \ + rk3588-edgeble-neu6b-io.dtb \ rk3588-evb1-v10.dtb \ rk3588-rock-5b.dtb
diff --git a/arch/arm/dts/rk3588-edgeble-neu6b-io.dts b/arch/arm/dts/rk3588-edgeble-neu6b-io.dts new file mode 100644 index 0000000000..e9d5a8bab5 --- /dev/null +++ b/arch/arm/dts/rk3588-edgeble-neu6b-io.dts @@ -0,0 +1,27 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 Edgeble AI Technologies Pvt. Ltd. + */ + +/dts-v1/; +#include "rk3588j.dtsi" +#include "rk3588-edgeble-neu6b.dtsi" + +/ { + model = "Edgeble Neu6B IO Board"; + compatible = "edgeble,neural-compute-module-6b-io", + "edgeble,neural-compute-module-6b", "rockchip,rk3588"; + + aliases { + serial2 = &uart2; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; +}; + +&uart2 { + pinctrl-0 = <&uart2m0_xfer>; + status = "okay"; +}; diff --git a/arch/arm/dts/rk3588-edgeble-neu6b.dtsi b/arch/arm/dts/rk3588-edgeble-neu6b.dtsi new file mode 100644 index 0000000000..1c5bcf1280 --- /dev/null +++ b/arch/arm/dts/rk3588-edgeble-neu6b.dtsi @@ -0,0 +1,32 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2023 Edgeble AI Technologies Pvt. Ltd. + */ + +/ { + compatible = "edgeble,neural-compute-module-6b", "rockchip,rk3588"; + + aliases { + mmc0 = &sdhci; + }; + + vcc12v_dcin: vcc12v-dcin-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc12v_dcin"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <12000000>; + regulator-max-microvolt = <12000000>; + }; +}; + +&sdhci { + bus-width = <8>; + no-sdio; + no-sd; + non-removable; + max-frequency = <200000000>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + status = "okay"; +};
General features:
- Rockchip RK3588J
- up to 128GB eMMC
- 2x MIPI CSI2 FPC
General features:
- microSD slot
- 1x HDMI Out
- 1x HDMI In
- 2x DP
- 1x eDP
- 2x USB Host
- 1x SATA
- 1x M.2 M-Key slot
- 1x Onboard PoE
- RTC battery slot
Thanks, - Kever
- rk3588-edgeble-neu6b-io.dtb \ rk3588-evb1-v10.dtb \ rk3588-rock-5b.dtb
- Copyright (c) 2023 Edgeble AI Technologies Pvt. Ltd.
- model = "Edgeble Neu6B IO Board";
- compatible = "edgeble,neural-compute-module-6b-io",
- aliases {
serial2 = &uart2;
- chosen {
+&uart2 {
- pinctrl-0 = <&uart2m0_xfer>;
- status = "okay";
- compatible = "edgeble,neural-compute-module-6b", "rockchip,rk3588";
- aliases {
mmc0 = &sdhci;
- vcc12v_dcin: vcc12v-dcin-regulator {
regulator-boot-on;
+&sdhci {
- bus-width = <8>;
- no-sdio;
- no-sd;
- non-removable;
- max-frequency = <200000000>;
- mmc-hs400-1_8v;
- mmc-hs400-enhanced-strobe;
- status = "okay";
Add support for this SoM and IO board.
Signed-off-by: Jagan Teki jagan@edgeble.ai --- .../dts/rk3588-edgeble-neu6b-io-u-boot.dtsi | 22 +++++++ arch/arm/mach-rockchip/rk3588/Kconfig | 10 +++ .../neural-compute-module-6/MAINTAINERS | 1 + configs/neu6b-io-rk3588_defconfig | 64 +++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + 5 files changed, 98 insertions(+) create mode 100644 arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi create mode 100644 configs/neu6b-io-rk3588_defconfig
diff --git a/arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi b/arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi new file mode 100644 index 0000000000..cd7626b24b --- /dev/null +++ b/arch/arm/dts/rk3588-edgeble-neu6b-io-u-boot.dtsi @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#include "rk3588j-u-boot.dtsi" + +/ { + aliases { + mmc0 = &sdmmc; + }; + + chosen { + stdout-path = &uart2; + u-boot,spl-boot-order = &sdmmc; + }; +}; + +&sdmmc { + bus-width = <4>; + status = "okay"; +}; diff --git a/arch/arm/mach-rockchip/rk3588/Kconfig b/arch/arm/mach-rockchip/rk3588/Kconfig index 5eecd26f86..82fe142264 100644 --- a/arch/arm/mach-rockchip/rk3588/Kconfig +++ b/arch/arm/mach-rockchip/rk3588/Kconfig @@ -19,6 +19,16 @@ config TARGET_RK3588_NEU6 IO board and Neu6a needs to mount on top of this IO board in order to create complete Edgeble Neural Compute Module 6A(Neu6A) IO platform.
+ Neu6B: + Neural Compute Module 6B(Neu6B) is a 96boards SoM-CB compute module + based on Rockchip RK3588J from Edgeble AI. + + Neu6A-IO: + Neural Compute Module 6B(Neu6B) IO board is an industrial form factor + IO board and Neu6a needs to mount on top of this IO board in order to + create complete Edgeble Neural Compute Module 6B(Neu6B) IO platform. + +config TARGET_ROCK5B_RK3588 config TARGET_ROCK5B_RK3588 bool "Radxa ROCK5B RK3588 board" select BOARD_LATE_INIT diff --git a/board/edgeble/neural-compute-module-6/MAINTAINERS b/board/edgeble/neural-compute-module-6/MAINTAINERS index 249df957f1..bc7f9b0e68 100644 --- a/board/edgeble/neural-compute-module-6/MAINTAINERS +++ b/board/edgeble/neural-compute-module-6/MAINTAINERS @@ -4,3 +4,4 @@ S: Maintained F: board/edgeble/neural-compute-module-6 F: include/configs/neural-compute-module-6.h F: configs/neu6a-io-rk3588_defconfig +F: configs/neu6b-io-rk3588_defconfig diff --git a/configs/neu6b-io-rk3588_defconfig b/configs/neu6b-io-rk3588_defconfig new file mode 100644 index 0000000000..c7bc3b1965 --- /dev/null +++ b/configs/neu6b-io-rk3588_defconfig @@ -0,0 +1,64 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_DEFAULT_DEVICE_TREE="rk3588-edgeble-neu6b-io" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_RK3588_NEU6=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-edgeble-neu6b-io.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_ATF=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_REGULATOR_PWM=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 1f46924a3d..32df1497c5 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -99,6 +99,7 @@ List of mainline supported Rockchip boards: * rk3588 - Rockchip EVB (evb-rk3588) - Edgeble Neural Compute Module 6A SoM - Neu6a (neu6a-io-rk3588) + - Edgeble Neural Compute Module 6B SoM - Neu6b (neu6b-io-rk3588) - Radxa ROCK 5B (rock5b-rk3588)
* rv1108
Thanks, - Kever
- aliases {
mmc0 = &sdmmc;
- chosen {
+&sdmmc {
- bus-width = <4>;
- status = "okay";
Neu6B:
Neu6A-IO:
- rk3588
- rv1108
Hi Kever,
Please pick them up in MW.
Thanks, Jagan.
Thanks, - Kever
Neu6:
Neu6A:
based on Rockchip RK3588 from Edgeble AI.Neural Compute Module 6A(Neu6A) is a 96boards SoM-CB compute module
Neu6-IO:
Neu6A-IO:
IO board and Neu6a needs to mount on top of this IO board in order toNeural Compute Module 6A(Neu6A) IO board is an industrial form factor
- rk3588
- rv1108
Jagan Teki
Kever Yang
