[U-Boot] Please pull u-boot-mpc85xx.git
Merge branch 'master' of git://git.denx.de/u-boot-i2c (2013-01-29 15:36:27 -0500)
git://www.denx.de/git/u-boot-mpc85xx.git master
for you to fetch changes up to d4ed6542788169b789c7eed142efc0a6fa5ca698:
corenet: Disable video on P2020DS (2013-01-30 11:25:16 -0600)
---------------------------------------------------------------- Anatolij Gustschin (1): mpc8xxx: fix DDR init value to use CONFIG_MEM_INIT_VALUE
Andy Fleming (1): corenet: Disable video on P2020DS
Hongtao Jia (2): powerpc/mpc8572ds: Enable bank interleaving to cs0+cs1 for dual-rank DIMMs powerpc/mpc8544ds: Add USB controller support for MPC8544DS
James Yang (5): Move DDR command parsing to separate function Fix data stage name matching issue Add copy command to FSL DDR interactive README.fsl-ddr typos and update to reflect hotkey powerpc/mpc8xxxx: FSL DDR debugger auto run of stored commands
Poonam Aggrwal (2): powerpc/mpc85xx: Few updates for B4860 cpu changes powerpc/mpc85xx:Add support of B4420 SoC
Prabhakar Kushwaha (8): board/T4240qds:Fix TLB and LAW size of NAND flash boards/T4240qds:Fix IFC AMASK init as per FPGA register space board/freescale/common:Add support of QTAG register powerpc/mpc85xx:Fix Core cluster configuration loop powerpc/t4240qds: Print FPGA detail version powerpc/mpc85xx: Add BSC9132/BSC9232 processor support powerpc/85xx: Add BSC9132QDS support board/common: Add support for QIXIS read/write using i2c
Scott Wood (1): powerpc/mpc85xx: add support for MMUv2 page sizes
Shaohui Xie (1): powerpc/p2041: move Lanes mux to board early init
Shaveta Leekha (3): powerpc/qixis: enable qixis dump command and add switch dumping command powerpc/b4860qds: Add support to dump switch settings on b4860qds board powerpc/t4240qds: Add support to dump switch settings on t4240qds board
Shengzhou Liu (1): powerpc/t4240: Adding workaround errata A-005871
Timur Tabi (1): powerpc/t4qds: move VSC3316 config data from t4qds.h to t4qds.c
Vakul Garg (1): powerpc/mpc85xx: Add property 'fsl, sec-era' in device tree node 'crypto'
Valentin Longchamp (2): powerpc/p2041: add RCW file for P2041RDB powerpc/p2041: set RCW and PBI files for .pbl build or P2041RDB
York Sun (4): powerpc/mpc85xx: Reserve default boot page powerpc/t4240qds: Update IFC timing for NOR flash powerpc/b4860qds: Added Support for B4860QDS powerpc/mpc8xxx: Enable entering DDR debugging by key press
MAINTAINERS | 4 + arch/powerpc/cpu/mpc85xx/Makefile | 5 + arch/powerpc/cpu/mpc85xx/b4860_ids.c | 6 + arch/powerpc/cpu/mpc85xx/b4860_serdes.c | 60 ++ arch/powerpc/cpu/mpc85xx/bsc9132_serdes.c | 96 +++ arch/powerpc/cpu/mpc85xx/cmd_errata.c | 4 + arch/powerpc/cpu/mpc85xx/cpu_init.c | 44 +- arch/powerpc/cpu/mpc85xx/fdt.c | 24 + arch/powerpc/cpu/mpc85xx/start.S | 2 +- arch/powerpc/cpu/mpc85xx/tlb.c | 19 +- arch/powerpc/cpu/mpc8xxx/cpu.c | 2 + arch/powerpc/cpu/mpc8xxx/ddr/ctrl_regs.c | 4 + arch/powerpc/cpu/mpc8xxx/ddr/ddr.h | 3 +- arch/powerpc/cpu/mpc8xxx/ddr/interactive.c | 324 ++++++--- arch/powerpc/cpu/mpc8xxx/ddr/main.c | 8 +- arch/powerpc/cpu/mpc8xxx/fdt.c | 78 +- arch/powerpc/include/asm/config_mpc85xx.h | 39 +- arch/powerpc/include/asm/immap_85xx.h | 34 +- arch/powerpc/include/asm/mmu.h | 52 +- arch/powerpc/include/asm/processor.h | 2 + board/freescale/b4860qds/Makefile | 54 ++ board/freescale/b4860qds/b4860qds.c | 505 +++++++++++++ board/freescale/b4860qds/b4860qds.h | 26 + board/freescale/b4860qds/b4860qds_crossbar_con.h | 67 ++ board/freescale/b4860qds/b4860qds_qixis.h | 37 + board/freescale/b4860qds/ddr.c | 190 +++++ board/freescale/b4860qds/eth_b4860qds.c | 338 +++++++++ board/freescale/b4860qds/law.c | 44 ++ board/freescale/b4860qds/pci.c | 39 + board/freescale/b4860qds/tlb.c | 127 ++++ board/freescale/bsc9132qds/Makefile | 52 ++ board/freescale/bsc9132qds/README | 150 ++++ board/freescale/bsc9132qds/bsc9132qds.c | 403 +++++++++++ board/freescale/bsc9132qds/ddr.c | 209 ++++++ board/freescale/bsc9132qds/law.c | 35 + board/freescale/bsc9132qds/tlb.c | 92 +++ board/freescale/common/qixis.c | 107 ++- board/freescale/common/qixis.h | 13 + board/freescale/corenet_ds/rcw_p2041rdb.cfg | 11 + board/freescale/p2041rdb/eth.c | 39 - board/freescale/p2041rdb/p2041rdb.c | 44 ++ board/freescale/t4qds/law.c | 2 +- board/freescale/t4qds/t4qds.c | 83 ++- board/freescale/t4qds/t4qds.h | 11 - board/freescale/t4qds/tlb.c | 2 +- boards.cfg | 12 + doc/README.b4860qds | 330 +++++++++ doc/README.fsl-ddr | 33 +- drivers/net/fm/Makefile | 1 + drivers/net/fm/b4860.c | 79 +++ include/configs/B4860QDS.h | 820 ++++++++++++++++++++++ include/configs/BSC9132QDS.h | 667 ++++++++++++++++++ include/configs/MPC8544DS.h | 12 + include/configs/MPC8572DS.h | 2 +- include/configs/P2020DS.h | 2 +- include/configs/P2041RDB.h | 2 + include/configs/t4qds.h | 12 +- 57 files changed, 5257 insertions(+), 205 deletions(-) create mode 100644 arch/powerpc/cpu/mpc85xx/bsc9132_serdes.c create mode 100644 board/freescale/b4860qds/Makefile create mode 100644 board/freescale/b4860qds/b4860qds.c create mode 100644 board/freescale/b4860qds/b4860qds.h create mode 100644 board/freescale/b4860qds/b4860qds_crossbar_con.h create mode 100644 board/freescale/b4860qds/b4860qds_qixis.h create mode 100644 board/freescale/b4860qds/ddr.c create mode 100644 board/freescale/b4860qds/eth_b4860qds.c create mode 100644 board/freescale/b4860qds/law.c create mode 100644 board/freescale/b4860qds/pci.c create mode 100644 board/freescale/b4860qds/tlb.c create mode 100644 board/freescale/bsc9132qds/Makefile create mode 100644 board/freescale/bsc9132qds/README create mode 100644 board/freescale/bsc9132qds/bsc9132qds.c create mode 100644 board/freescale/bsc9132qds/ddr.c create mode 100644 board/freescale/bsc9132qds/law.c create mode 100644 board/freescale/bsc9132qds/tlb.c create mode 100644 board/freescale/corenet_ds/rcw_p2041rdb.cfg create mode 100644 doc/README.b4860qds create mode 100644 drivers/net/fm/b4860.c create mode 100644 include/configs/B4860QDS.h create mode 100644 include/configs/BSC9132QDS.h
As an aside, will you be doing an MMC review / pull request soon? There's been a few patches going of late I'd like to see a ack/nak on, thanks!
Yes. I have some internal review stuff to finish, but I will get to MMC next.
15:36:27 -0500)
dual-rank DIMMs
command
board
board
'crypto'
-- Tom
Andy Fleming
Andy Fleming
