[U-Boot] [PATCH 1/2] armv8: ls1046a: added usb feature support
The LS1046A processor has three integrated USB 3.0 controllers (USB1, USB2, and USB3) that allow direct connection to the USB ports with appropriate protection circuitry and power supplies. USB1 and USB2 ports are powered by a NX5P2190UK device, which supplies 5v power at up to 1.2 A. The power enable and power-fault-detect pins are connected to the LS1046A processor via CPLD for individual port management.
Signed-off-by: Tang Yuantian yuantian.tang@nxp.com --- arch/arm/dts/fsl-ls1046a.dtsi | 22 ++++++++++++++++++++++ include/configs/ls1046ardb.h | 8 ++++++++ include/linux/usb/xhci-fsl.h | 2 +- 3 files changed, 31 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/fsl-ls1046a.dtsi b/arch/arm/dts/fsl-ls1046a.dtsi index 359a9d1..ee3180e 100644 --- a/arch/arm/dts/fsl-ls1046a.dtsi +++ b/arch/arm/dts/fsl-ls1046a.dtsi @@ -216,5 +216,27 @@ big-endian; status = "disabled"; }; + + usb0: usb@2f00000 { + compatible = "fsl,layerscape-dwc3"; + reg = <0x0 0x2f00000 0x0 0x10000>; + interrupts = <0 60 4>; + dr_mode = "host"; + }; + + usb1: usb@3000000 { + compatible = "fsl,layerscape-dwc3"; + reg = <0x0 0x3000000 0x0 0x10000>; + interrupts = <0 61 4>; + dr_mode = "host"; + }; + + usb2: usb@3100000 { + compatible = "fsl,layerscape-dwc3"; + reg = <0x0 0x3100000 0x0 0x10000>; + interrupts = <0 63 4>; + dr_mode = "host"; + }; + }; }; diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 2fe8fc1..d363d1f 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -211,6 +211,14 @@ #define CONFIG_SPI_FLASH_BAR #endif
+/* USB */ +#define CONFIG_HAS_FSL_XHCI_USB +#ifdef CONFIG_HAS_FSL_XHCI_USB +#define CONFIG_USB_XHCI_FSL +#define CONFIG_USB_MAX_CONTROLLER_COUNT 3 +#define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 +#endif + /* SATA */ #define CONFIG_LIBATA #define CONFIG_SCSI_AHCI diff --git a/include/linux/usb/xhci-fsl.h b/include/linux/usb/xhci-fsl.h index 15cac40..1fa3161 100644 --- a/include/linux/usb/xhci-fsl.h +++ b/include/linux/usb/xhci-fsl.h @@ -62,7 +62,7 @@ struct fsl_xhci { #define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_XHCI_USB2_ADDR #define CONFIG_SYS_FSL_XHCI_USB3_ADDR 0 -#elif defined(CONFIG_LS1043A) +#elif defined(CONFIG_LS1043A) || defined(CONFIG_ARCH_LS1046A) #define CONFIG_SYS_FSL_XHCI_USB1_ADDR CONFIG_SYS_XHCI_USB1_ADDR #define CONFIG_SYS_FSL_XHCI_USB2_ADDR CONFIG_SYS_XHCI_USB2_ADDR #define CONFIG_SYS_FSL_XHCI_USB3_ADDR CONFIG_SYS_XHCI_USB3_ADDR
Signed-off-by: Tang Yuantian yuantian.tang@nxp.com --- configs/ls1046aqds_defconfig | 6 ++++++ configs/ls1046aqds_lpuart_defconfig | 6 ++++++ configs/ls1046aqds_nand_defconfig | 6 ++++++ configs/ls1046aqds_qspi_defconfig | 6 ++++++ configs/ls1046aqds_sdcard_ifc_defconfig | 6 ++++++ configs/ls1046aqds_sdcard_qspi_defconfig | 6 ++++++ configs/ls1046ardb_emmc_defconfig | 6 ++++++ configs/ls1046ardb_qspi_defconfig | 6 ++++++ configs/ls1046ardb_sdcard_defconfig | 6 ++++++ 9 files changed, 54 insertions(+)
diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index 2cc1a0b..f194b65 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -20,9 +20,15 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index 25bb5f9..11446ac 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -21,6 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_SPI=y @@ -28,3 +29,8 @@ CONFIG_SPI_FLASH=y CONFIG_FSL_DSPI=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 74fcd4a..7d86bfd 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -24,9 +24,15 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig index c8a68fa..08a9e85 100644 --- a/configs/ls1046aqds_qspi_defconfig +++ b/configs/ls1046aqds_qspi_defconfig @@ -22,6 +22,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y @@ -29,3 +30,8 @@ CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index fe9ad0e..69280bd 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -24,9 +24,15 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index 1700082..c7295aa 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y @@ -32,3 +33,8 @@ CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index fd21959..e3c21e3 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -21,9 +21,15 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index fa17373..1081853 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -18,6 +18,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y @@ -25,3 +26,8 @@ CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_QSPI_AHB_INIT=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index 0b810d3..61de047 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -21,9 +21,15 @@ CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y +CONFIG_CMD_USB=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y
