[PATCH] arm: socfpga: Add watchdog 1 support to A10
Add watchdog 1 support to A10, ensure the same enable/disable process as watchdog 0.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Teik Heng Chong teik.heng.chong@intel.com --- .../mach-socfpga/include/mach/base_addr_a10.h | 1 + .../include/mach/reset_manager_arria10.h | 1 + arch/arm/mach-socfpga/reset_manager_arria10.c | 21 ++++++++++++++----- arch/arm/mach-socfpga/spl_a10.c | 2 +- 4 files changed, 19 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/base_addr_a10.h b/arch/arm/mach-socfpga/include/mach/base_addr_a10.h index b947cc0729..246618f4da 100644 --- a/arch/arm/mach-socfpga/include/mach/base_addr_a10.h +++ b/arch/arm/mach-socfpga/include/mach/base_addr_a10.h @@ -17,6 +17,7 @@ #define SOCFPGA_FPGAMGRDATA_ADDRESS 0xffcfe400 #define SOCFPGA_FPGAMGRREGS_ADDRESS 0xffd03000 #define SOCFPGA_L4WD0_ADDRESS 0xffd00200 +#define SOCFPGA_L4WD1_ADDRESS 0xffd00300 #define SOCFPGA_SYSMGR_ADDRESS 0xffd06000 #define SOCFPGA_PINMUX_SHARED_3V_IO_ADDRESS 0xffd07000 #define SOCFPGA_PINMUX_DEDICATED_IO_ADDRESS 0xffd07200 diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h index 9aacf3e2c6..53efb64234 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h @@ -13,6 +13,7 @@ void socfpga_watchdog_disable(void); void socfpga_reset_deassert_noc_ddr_scheduler(void); int socfpga_reset_deassert_bridges_handoff(void); void socfpga_reset_deassert_wd0(void); +void socfpga_reset_deassert_wd1(void); int socfpga_bridges_reset(void);
#define RSTMGR_A10_STATUS 0x00 diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c index 13a5cf314b..25c7291246 100644 --- a/arch/arm/mach-socfpga/reset_manager_arria10.c +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -61,6 +61,9 @@ void socfpga_watchdog_disable(void) /* assert reset for watchdog */ setbits_le32(socfpga_get_rstmgr_addr() + RSTMGR_A10_PER1MODRST, ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); + + setbits_le32(socfpga_get_rstmgr_addr() + RSTMGR_A10_PER1MODRST, + ALT_RSTMGR_PER1MODRST_WD1_SET_MSK); }
/* Release NOC ddr scheduler from reset */ @@ -116,6 +119,13 @@ void socfpga_reset_deassert_wd0(void) ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); }
+/* Release Watchdog 1 from reset through reset manager */ +void socfpga_reset_deassert_wd1(void) +{ + clrbits_le32(socfpga_get_rstmgr_addr() + RSTMGR_A10_PER1MODRST, + ALT_RSTMGR_PER1MODRST_WD1_SET_MSK); +} + /* * Assert or de-assert SoCFPGA reset manager reset. */ @@ -154,15 +164,16 @@ void socfpga_per_reset(u32 reset, int set) }
/* - * Assert reset on every peripheral but L4WD0. + * Assert reset on every peripheral but L4WD0 & l4WD1. * Watchdog must be kept intact to prevent glitches * and/or hangs. * For the Arria10, we disable all the peripherals except L4 watchdog0, - * L4 Timer 0, and ECC. + * L4 watchdog1, L4 Timer 0, and ECC. */ void socfpga_per_reset_all(void) { - const u32 l4wd0 = (1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)) | + const u32 l4wd = (1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD0)) | + 1 << RSTMGR_RESET(SOCFPGA_RESET(L4WD1)) | (1 << RSTMGR_RESET(SOCFPGA_RESET(L4SYSTIMER0)))); unsigned mask_ecc_ocp = ALT_RSTMGR_PER0MODRST_EMACECC0_SET_MSK | @@ -174,8 +185,8 @@ void socfpga_per_reset_all(void) ALT_RSTMGR_PER0MODRST_QSPIECC_SET_MSK | ALT_RSTMGR_PER0MODRST_SDMMCECC_SET_MSK;
- /* disable all components except ECC_OCP, L4 Timer0 and L4 WD0 */ - writel(~l4wd0, socfpga_get_rstmgr_addr() + RSTMGR_A10_PER1MODRST); + /* disable all components except ECC_OCP, L4 Timer0, L4 WD0 & l4 WD1 */ + writel(~l4wd, socfpga_get_rstmgr_addr() + RSTMGR_A10_PER1MODRST); setbits_le32(socfpga_get_rstmgr_addr() + RSTMGR_A10_PER0MODRST, ~mask_ecc_ocp);
diff --git a/arch/arm/mach-socfpga/spl_a10.c b/arch/arm/mach-socfpga/spl_a10.c index 96bad162df..5d661fb995 100644 --- a/arch/arm/mach-socfpga/spl_a10.c +++ b/arch/arm/mach-socfpga/spl_a10.c @@ -255,7 +255,7 @@ void board_init_f(ulong dummy) socfpga_sdram_remap_zero(); socfpga_pl310_clear();
- /* Assert reset to all except L4WD0 and L4TIMER0 */ + /* Assert reset to all except L4WD0, L4WD1 and L4TIMER0 */ socfpga_per_reset_all(); socfpga_watchdog_disable();
