[U-Boot] [PATCH] taurus: board updates
taurus changes: - rename at91_spl_board_init to spl_board_init fixes problems with recovery button and nand erase sector 0 - adapt CONFIG_SPL_MAX_SIZE and CONFIG_SPL_BSS_MAX_SIZE - add CONFIG_AT91_HW_WDT_TIMEOUT 15 - CONFIG_SF_DEFAULT_MODE SPI_MODE_3 not mode 0
Signed-off-by: Heiko Schocher hs@denx.de ---
board/siemens/taurus/taurus.c | 8 +++----- include/configs/taurus.h | 13 +++++++------ 2 files changed, 10 insertions(+), 11 deletions(-)
diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 554a0c2..d10411c 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -79,7 +79,7 @@ void matrix_init(void) &mat->scfg[3]); }
-void at91_spl_board_init(void) +void spl_board_init(void) { taurus_nand_hw_init(); at91_spi0_hw_init(TAURUS_SPI_MASK); @@ -92,9 +92,7 @@ void at91_spl_board_init(void) at91_set_gpio_output(AT91_PIN_PA10, 0); at91_set_gpio_output(AT91_PIN_PA11, 0); at91_set_gpio_output(AT91_PIN_PA12, 0); -#endif
-#if defined(CONFIG_BOARD_AXM) /* Configure recovery button PINs */ at91_set_gpio_input(AT91_PIN_PA26, 1); at91_set_gpio_input(AT91_PIN_PA27, 1); @@ -113,13 +111,13 @@ void at91_spl_board_init(void) #endif struct spi_flash *flash;
- debug("Recovery button pressed\n"); + puts("Recovery button pressed\n"); nand_init(); spl_nand_erase_one(0, 0); flash = spi_flash_probe(CONFIG_SF_DEFAULT_BUS, 0, CONFIG_SF_DEFAULT_SPEED, - SPI_MODE_3); + CONFIG_SF_DEFAULT_MODE); if (!flash) { puts("no flash\n"); } else { diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 6d18f2f..dd35a8f 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -95,7 +95,7 @@ * leaving the correct space for initial global data structure above * that address while providing maximum stack area below. */ -# define CONFIG_SYS_INIT_SP_ADDR \ +#define CONFIG_SYS_INIT_SP_ADDR \ (ATMEL_BASE_SRAM1 + 0x1000 - GENERATED_GBL_DATA_SIZE)
/* NAND flash */ @@ -119,6 +119,7 @@ #define CONFIG_AT91_WANTS_COMMON_PHY
#define CONFIG_AT91SAM9_WATCHDOG +#define CONFIG_AT91_HW_WDT_TIMEOUT 15 #if !defined(CONFIG_SPL_BUILD) /* Enable the watchdog */ #define CONFIG_HW_WATCHDOG @@ -154,8 +155,8 @@ #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define CONFIG_SF_DEFAULT_SPEED 1000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 #endif
/* load address */ @@ -255,14 +256,14 @@ /* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_TEXT_BASE 0x0 -#define CONFIG_SPL_MAX_SIZE (15 * 1024) -#define CONFIG_SPL_STACK (16 * 1024) +#define CONFIG_SPL_MAX_SIZE (29 * 512) +#define CONFIG_SPL_STACK (ATMEL_BASE_SRAM1 + 0x4000) #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE - \ CONFIG_SYS_MALLOC_LEN) #define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN
#define CONFIG_SPL_BSS_START_ADDR CONFIG_SPL_MAX_SIZE -#define CONFIG_SPL_BSS_MAX_SIZE (3 * 1024) +#define CONFIG_SPL_BSS_MAX_SIZE (3 * 512)
#define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT
Hello Andreas,
Am 15.06.2015 um 14:40 schrieb Heiko Schocher:
taurus changes:
ping? I got no comments for this patch ... are there any issues?
Thanks!
bye, Heiko
nand_init(); spl_nand_erase_one(0, 0); flash = spi_flash_probe(CONFIG_SF_DEFAULT_BUS, 0, CONFIG_SF_DEFAULT_SPEED,puts("Recovery button pressed\n");
SPI_MODE_3);
if (!flash) { puts("no flash\n"); } else {CONFIG_SF_DEFAULT_MODE);
- leaving the correct space for initial global data structure above
- that address while providing maximum stack area below.
Hi Heiko,
sorry for the late reply!
No real objections with this patch, it just will not apply without the AXM patch (patchwork #484257). Could you please rebase and re-send both?
Andreas
On 06/15/2015 02:40 PM, Heiko Schocher wrote:
taurus changes:
SPI_MODE_3);
Andreas Bießmann
Heiko Schocher
