[U-Boot] board_pci_pre_scan() and board_pci_post_scan()
Hi Simon,
With driver model pci conversion on x86 boards, we now missed the call to board_pci_pre_scan() and board_pci_post_scan() which are called in the non-dm path. For example, board_pci_post_scan() in arch/x86/lib/fsp/fsp_common.c is not called to do any work as requested by FSP after pci enumeration.
I am not sure where we could insert these call back in the dm. Do you have any possible solution on this?
Regards, Bin
Hi Bin,
On 27 July 2015 at 01:45, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
I know that the post-scan is needed for FSP - and in fact for Minnowmax I added in back in a recent patch[1]. What is the pre-scan used for?
Hi Simon,
On Mon, Aug 3, 2015 at 6:31 AM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
I see fsp_init_phase_pci() is called in arch_misc_init() which is really late in your patch. According to FSP spec, we should call this as soon as pci bus is enumerated. The original non-dm codes does this correctly. As for pre-scan, so far it does nothing. I believe we can drop it.
Regards, Bin
Hi Bin,
On 2 August 2015 at 20:03, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Hi Bin,
Hi Simon,
What does the FSP actually do with this? Also we may enumerate it twice with your recent patches.
pci_uclass_post_probe() is the place where we kick off and complete scanning of the bus. I'm open to options on this one, but perhaps if we can forcing a bus problem as per your recent patch then we could just call the FSP function there?
Hi Simon,
On Tue, Aug 4, 2015 at 2:52 AM, Simon Glass sjg@chromium.org wrote:
Hi Bin,
Hi Simon,
Hi Bin,
Hi Simon,
I have no idea we don't have the source codes. Per my read of FSP architecture specification, I think the post pci needs to initialize some chipset registers that are documented in the BIOS Writer's Guide which are marked as post-enumeration phase tasks. As for enumeration, yes, it will end up doing twice but that's how previously non-dm pci works on the Crown Bay board. Note U-Boot does enumeration twice, but it only calls board_pci_pre_scan() and board_pci_post_scan() after relocation. That means we only call FSP post pci notify routine just once, and actually it works good on the Crown Bay board. I doubt we can call FSP post pci twice.
Regards, Bin
Bin Meng
