[U-Boot] [PATCH v3 0/5] Supporting ARM v8 USB errata for FSL
The patch-set does the following :
1. Adds support for ARM for USB Erratum Checking code for implementing the USB Erratum for fsl. 2. Performs code cleanup to reduce redundancy when adding fsl device tree fixup. 3. Implements Erratum A008751 for LS2 platform.
Sriram Dash (5): arm64: fsl-layerscape: add get_svr and IS_SVR_REV helper usb: xhci: fsl: code cleanup for device tree fixup for fsl usb controllers fsl: usb: make errata function common for PPC and ARM armv8/ls2080: Remove workaround for erratum A008751 usb: xhci: fsl: Add workaround for USB erratum A-008751
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 7 + arch/arm/cpu/armv8/fsl-layerscape/soc.c | 10 -- .../include/asm/arch-fsl-layerscape/immap_lsch2.h | 2 + .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 4 + arch/arm/include/asm/arch-fsl-layerscape/soc.h | 2 + board/freescale/ls2080aqds/ls2080aqds.c | 2 + board/freescale/ls2080ardb/ls2080ardb.c | 2 + drivers/usb/common/Makefile | 4 +- drivers/usb/common/fsl-dt-fixup.c | 94 ++++++---- .../fsl_usb.h => drivers/usb/common/fsl-errata.c | 152 ++++------------ drivers/usb/host/xhci-fsl.c | 24 +++ include/fsl_usb.h | 198 ++------------------- 12 files changed, 153 insertions(+), 348 deletions(-) copy include/fsl_usb.h => drivers/usb/common/fsl-errata.c (50%)
Adds get_svr and IS_SVR_REV helpers for ARMv8 platforms, similar to PPC and ARMv7.
Signed-off-by: Sriram Dash sriram.dash@nxp.com Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com ---
Changes in v1: - Added commit message
Changes in v2: - No update
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 7 +++++++ arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h | 2 ++ arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h | 3 +++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 2 ++ 4 files changed, 14 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index 9a5a6b5..9c575c1 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -528,6 +528,13 @@ u32 fsl_qoriq_core_to_type(unsigned int core) return -1; /* cannot identify the cluster */ }
+uint get_svr(void) +{ + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + + return gur_in32(&gur->svr); +} + #ifdef CONFIG_DISPLAY_CPUINFO int print_cpuinfo(void) { diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h index e98e055..8b8a7c1 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch2.h @@ -596,4 +596,6 @@ struct ccsr_cci400 { #define SCR0_CLIENTPD_MASK 0x00000001 #define SCR0_USFCFG_MASK 0x00000400
+uint get_svr(void); + #endif /* __ARCH_FSL_LSCH2_IMMAP_H__*/ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 65b3357..e48bbaf 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -319,4 +319,7 @@ struct ccsr_reset { u32 ip_rev1; /* 0xbf8 */ u32 ip_rev2; /* 0xbfc */ }; + +uint get_svr(void); + #endif /* __ARCH_FSL_LSCH3_IMMAP_H_ */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index 02ecc62..f244904 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -53,6 +53,8 @@ struct cpu_type { #define SVR_MIN(svr) (((svr) >> 0) & 0xf) #define SVR_SOC_VER(svr) (((svr) >> 8) & SVR_WO_E) #define IS_E_PROCESSOR(svr) (!((svr >> 8) & 0x1)) +#define IS_SVR_REV(svr, maj, min) \ + ((SVR_MAJ(svr) == maj) && (SVR_MIN(svr) == min))
/* ahci port register default value */ #define AHCI_PORT_PHY_1_CFG 0xa003fffe
Changes in v1:
Changes in v2:
- No update
So what changed in V3 here ?
- struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR);
- return gur_in32(&gur->svr);
This is susceptible to macro expansion problems, you need parenthesis around all the macro args: ((SVR_MAJ(svr) == (maj)) && (SVR_MIN(svr) == (min)))
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Thursday, June 09, 2016 6:58 PM To: Sriram Dash sriram.dash@nxp.com; u-boot@lists.denx.de Cc: york sun york.sun@nxp.com; albert.u.boot@aribaud.net; Rajesh Bhagat rajesh.bhagat@nxp.com Subject: Re: [PATCH v3 1/5] arm64: fsl-layerscape: add get_svr and IS_SVR_REV helper
Changes in v1:
Changes in v2:
- No update
Typo mistake. Will take care in v4.
Ok. Will take care in v4.
-- Best regards, Marek Vasut
Performs code cleanup for device tree fixup for fsl usb controllers by making functions to handle these similar errata checking code.
Signed-off-by: Rajesh Bhagat rajesh.bhagat@nxp.com Signed-off-by: Sriram Dash sriram.dash@nxp.com ---
Changes in v3: - Inverted the condition for has_erratum for better readability - If fdt_fixup_usb_erratum fails, return ENOSPC and exit the fixup - Added logic for handling the condition with different controllers with different erratas - first check if the errata is applicable for the SoC - then check if it is applicable for the controller - if both are successful, then fix dt.
Changes in v2: - Added patch description - Removed the MACRO and use fdt_fixup_erratum function instead
drivers/usb/common/fsl-dt-fixup.c | 88 ++++++++++++++++++++++----------------- include/fsl_usb.h | 6 +++ 2 files changed, 56 insertions(+), 38 deletions(-)
diff --git a/drivers/usb/common/fsl-dt-fixup.c b/drivers/usb/common/fsl-dt-fixup.c index 6f31932..9cbd9d2 100644 --- a/drivers/usb/common/fsl-dt-fixup.c +++ b/drivers/usb/common/fsl-dt-fixup.c @@ -20,9 +20,9 @@ #endif
static const char * const compat_usb_fsl[] = { - "fsl-usb2-mph", - "fsl-usb2-dr", - "snps,dwc3", + FSL_USB2_MPH, + FSL_USB2_DR, + SNPS_DWC3, NULL };
@@ -80,16 +80,24 @@ static int fdt_fixup_usb_mode_phy_type(void *blob, const char *mode, }
static int fdt_fixup_usb_erratum(void *blob, const char *prop_erratum, - int start_offset) + const char *controller_type, int start_offset) { int node_offset, err; const char *node_type = NULL; + const char *node_name = NULL;
err = fdt_usb_get_node_type(blob, start_offset, &node_offset, &node_type); if (err < 0) return err;
+ if (!strcmp(node_type, FSL_USB2_MPH) || !strcmp(node_type, FSL_USB2_DR)) + node_name = USB2_CI; + else + node_name = node_type; + if (strcmp(node_name, controller_type)) + return err; + err = fdt_setprop(blob, node_offset, prop_erratum, NULL, 0); if (err < 0) { printf("ERROR: could not set %s for %s: %s.\n", @@ -99,6 +107,23 @@ static int fdt_fixup_usb_erratum(void *blob, const char *prop_erratum, return node_offset; }
+static int fdt_fixup_erratum(int *usb_erratum_off, void *blob, + const char *controller_type, char *str, + bool (*has_erratum)(void)) +{ + char buf[32] = {0}; + + snprintf(buf, sizeof(buf), "fsl,usb-erratum-%s", str); + if (!(has_erratum())) + return -EINVAL; + *usb_erratum_off = fdt_fixup_usb_erratum(blob, buf, controller_type, + *usb_erratum_off); + if (*usb_erratum_off < 0) + return -ENOSPC; + debug("Adding USB erratum %s\n", str); + return 0; +} + void fdt_fixup_dr_usb(void *blob, bd_t *bd) { static const char * const modes[] = { "host", "peripheral", "otg" }; @@ -111,6 +136,7 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) int usb_phy_off = -1; char str[5]; int i, j; + int ret;
for (i = 1; i <= CONFIG_USB_MAX_CONTROLLER_COUNT; i++) { const char *dr_mode_type = NULL; @@ -164,39 +190,25 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) if (usb_phy_off < 0) return;
- if (has_erratum_a006261()) { - usb_erratum_a006261_off = fdt_fixup_usb_erratum - (blob, - "fsl,usb-erratum-a006261", - usb_erratum_a006261_off); - if (usb_erratum_a006261_off < 0) - return; - } - - if (has_erratum_a007075()) { - usb_erratum_a007075_off = fdt_fixup_usb_erratum - (blob, - "fsl,usb-erratum-a007075", - usb_erratum_a007075_off); - if (usb_erratum_a007075_off < 0) - return; - } - - if (has_erratum_a007792()) { - usb_erratum_a007792_off = fdt_fixup_usb_erratum - (blob, - "fsl,usb-erratum-a007792", - usb_erratum_a007792_off); - if (usb_erratum_a007792_off < 0) - return; - } - if (has_erratum_a005697()) { - usb_erratum_a005697_off = fdt_fixup_usb_erratum - (blob, - "fsl,usb-erratum-a005697", - usb_erratum_a005697_off); - if (usb_erratum_a005697_off < 0) - return; - } + ret = fdt_fixup_erratum(&usb_erratum_a006261_off, blob, + USB2_CI, "a006261", + has_erratum_a006261); + if (ret == -ENOSPC) + return; + ret = fdt_fixup_erratum(&usb_erratum_a007075_off, blob, + USB2_CI, "a007075", + has_erratum_a007075); + if (ret == -ENOSPC) + return; + ret = fdt_fixup_erratum(&usb_erratum_a007792_off, blob, + USB2_CI, "a007792", + has_erratum_a007792); + if (ret == -ENOSPC) + return; + ret = fdt_fixup_erratum(&usb_erratum_a005697_off, blob, + USB2_CI, "a005697", + has_erratum_a005697); + if (ret == -ENOSPC) + return; } } diff --git a/include/fsl_usb.h b/include/fsl_usb.h index 187e384..882a5f5 100644 --- a/include/fsl_usb.h +++ b/include/fsl_usb.h @@ -85,6 +85,12 @@ struct ccsr_usb_phy { #define CONFIG_SYS_FSL_USB_SQUELCH_PROG_MASK 0x07 #endif
+/* USB Controllers */ +#define FSL_USB2_MPH "fsl-usb2-mph" +#define FSL_USB2_DR "fsl-usb2-dr" +#define USB2_CI "usb2-ci" +#define SNPS_DWC3 "snps,dwc3" + /* USB Erratum Checking code */ #ifdef CONFIG_PPC static inline bool has_dual_phy(void)
Changes in v3:
Changes in v2:
- "fsl-usb2-mph",
- "fsl-usb2-dr",
- "snps,dwc3",
- FSL_USB2_MPH,
- FSL_USB2_DR,
- SNPS_DWC3, NULL
int start_offset)
else
return err;
- char buf[32] = {0};
- snprintf(buf, sizeof(buf), "fsl,usb-erratum-%s", str);
- if (!(has_erratum()))
No need for the extra parenthesis around has_erratum() .
return -EINVAL;
- *usb_erratum_off = fdt_fixup_usb_erratum(blob, buf, controller_type,
*usb_erratum_off);
- if (*usb_erratum_off < 0)
return -ENOSPC;
- debug("Adding USB erratum %s\n", str);
int ret;
(blob,
return;
(blob,
return;
(blob,
return;
(blob,
return;
USB2_CI, "a006261",
if (ret == -ENOSPC)
return;
USB2_CI, "a007075",
if (ret == -ENOSPC)
return;
USB2_CI, "a007792",
if (ret == -ENOSPC)
return;
USB2_CI, "a005697",
if (ret == -ENOSPC)
}return;
Is this needed as a global macro or can it be local to fsl-dt-fixup.c ?
-----Original Message----- From: Marek Vasut [mailto:marex@denx.de] Sent: Thursday, June 09, 2016 7:01 PM To: Sriram Dash sriram.dash@nxp.com; u-boot@lists.denx.de Cc: york sun york.sun@nxp.com; albert.u.boot@aribaud.net; Rajesh Bhagat rajesh.bhagat@nxp.com Subject: Re: [PATCH v3 2/5] usb: xhci: fsl: code cleanup for device tree fixup for fsl usb controllers
Changes in v3:
Changes in v2:
- "fsl-usb2-mph",
- "fsl-usb2-dr",
- "snps,dwc3",
- FSL_USB2_MPH,
- FSL_USB2_DR,
- SNPS_DWC3, NULL
int start_offset)
FSL_USB2_DR))
- else
- if (strcmp(node_name, controller_type))
return err;
- err = fdt_setprop(blob, node_offset, prop_erratum, NULL, 0); if (err < 0) { printf("ERROR: could not set %s for %s: %s.\n", @@ -99,6 +107,23
Ok. Will remove parenthesis in v4.
return -EINVAL;
*usb_erratum_off);
return -ENOSPC;
int ret;
(blob,
return;
(blob,
return;
(blob,
return;
(blob,
return;
USB2_CI, "a006261",
if (ret == -ENOSPC)
return;
USB2_CI, "a007075",
if (ret == -ENOSPC)
return;
USB2_CI, "a007792",
if (ret == -ENOSPC)
return;
USB2_CI, "a005697",
if (ret == -ENOSPC)
}return;
Currently, the macro are only being used for dt fixup for fsl usb. However, in the near future, they might be needed for some other purpose, for example, board specific settings. So, i think i will stick with the global macro.
Would you please fix your mailer to omit this useless header ?
What is this "usb2-ci" string ? Is this some DT property or DT compatible property or just some random string?
If they will be used for other purpose, then they can be moved. They are local now, so keep them local.
From: Marek Vasut [mailto:marex@denx.de] On 06/10/2016 05:47 AM, Sriram Dash wrote:
Will take care next time onwards.
Currently, for chipidea usb 2 controller, there is no generic DT compatible property. Some names used are "qcom,ci-hdrc", "chipidea,usb2","fsl-usb2-dr","fsl-usb2-mph ". This string "usb2-ci" is not used currently for DT property.
Ok. I will move the global macro to fsl-dt-fixup.c.
Linux kernel documentation says there is "chipidea,usb2":
https://www.kernel.org/doc/Documentation/devicetree/bindings/usb/ci-hdrc-usb...
The "chipidea,usb2" is generic one, all the others are either heritage from the past or more precise specifiers of the IP block. Do not invent yet another new compatible property in this case, it makes zero sense.
From: Marek Vasut [mailto:marex@denx.de] On 06/10/2016 07:20 AM, Sriram Dash wrote:
https://www.kernel.org/doc/Documentation/devicetree/bindings/usb/ci-hdrc- usb2.txt
Ok. Will change the "usb2-ci" into "chipidea,usb2" and "USB2_CI" into CHIPIDEA_USB2 in v4.
This patch does the following things: 1. Makes the errata checking code common for PPC and ARM 2. Moves all these static inline functions into a dedicated C file
Changes in v3: - Rework done according to previous patches.
Changes in v2: - Moves all the static inline functions into a dedicated C file
drivers/usb/common/Makefile | 4 +- drivers/usb/common/fsl-dt-fixup.c | 1 + drivers/usb/common/fsl-errata.c | 178 +++++++++++++++++++++++++++++++++++ include/fsl_usb.h | 191 ++------------------------------------ 4 files changed, 189 insertions(+), 185 deletions(-) create mode 100644 drivers/usb/common/fsl-errata.c
diff --git a/drivers/usb/common/Makefile b/drivers/usb/common/Makefile index 2f46d38..aee7e32 100644 --- a/drivers/usb/common/Makefile +++ b/drivers/usb/common/Makefile @@ -4,5 +4,5 @@ #
obj-$(CONFIG_DM_USB) += common.o -obj-$(CONFIG_USB_EHCI_FSL) += fsl-dt-fixup.o -obj-$(CONFIG_USB_XHCI_FSL) += fsl-dt-fixup.o +obj-$(CONFIG_USB_EHCI_FSL) += fsl-dt-fixup.o fsl-errata.o +obj-$(CONFIG_USB_XHCI_FSL) += fsl-dt-fixup.o fsl-errata.o diff --git a/drivers/usb/common/fsl-dt-fixup.c b/drivers/usb/common/fsl-dt-fixup.c index 9cbd9d2..49d1140 100644 --- a/drivers/usb/common/fsl-dt-fixup.c +++ b/drivers/usb/common/fsl-dt-fixup.c @@ -12,6 +12,7 @@ #include <usb.h> #include <asm/io.h> #include <hwconfig.h> +#include <fsl_errata.h> #include <fsl_usb.h> #include <fdt_support.h>
diff --git a/drivers/usb/common/fsl-errata.c b/drivers/usb/common/fsl-errata.c new file mode 100644 index 0000000..95918fc --- /dev/null +++ b/drivers/usb/common/fsl-errata.c @@ -0,0 +1,178 @@ +/* + * Freescale USB Controller + * + * Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fsl_errata.h> +#include<fsl_usb.h> + +/* USB Erratum Checking code */ +#if defined(CONFIG_PPC) || defined(CONFIG_ARM) +bool has_dual_phy(void) +{ + u32 svr = get_svr(); + u32 soc = SVR_SOC_VER(svr); + + switch (soc) { +#ifdef CONFIG_PPC + case SVR_T1023: + case SVR_T1024: + case SVR_T1013: + case SVR_T1014: + return IS_SVR_REV(svr, 1, 0); + case SVR_T1040: + case SVR_T1042: + case SVR_T1020: + case SVR_T1022: + case SVR_T2080: + case SVR_T2081: + return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 1, 1); + case SVR_T4240: + case SVR_T4160: + case SVR_T4080: + return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); +#endif + } + + return false; +} + +bool has_erratum_a006261(void) +{ + u32 svr = get_svr(); + u32 soc = SVR_SOC_VER(svr); + + switch (soc) { +#ifdef CONFIG_PPC + case SVR_P1010: + return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); + case SVR_P2041: + case SVR_P2040: + return IS_SVR_REV(svr, 1, 0) || + IS_SVR_REV(svr, 1, 1) || IS_SVR_REV(svr, 2, 1); + case SVR_P3041: + return IS_SVR_REV(svr, 1, 0) || + IS_SVR_REV(svr, 1, 1) || + IS_SVR_REV(svr, 2, 0) || IS_SVR_REV(svr, 2, 1); + case SVR_P5010: + case SVR_P5020: + case SVR_P5021: + return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); + case SVR_T4240: + case SVR_T4160: + case SVR_T4080: + return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); + case SVR_T1040: + return IS_SVR_REV(svr, 1, 0); + case SVR_T2080: + case SVR_T2081: + return IS_SVR_REV(svr, 1, 0); + case SVR_P5040: + return IS_SVR_REV(svr, 1, 0); +#endif + } + + return false; +} + +bool has_erratum_a007075(void) +{ + u32 svr = get_svr(); + u32 soc = SVR_SOC_VER(svr); + + switch (soc) { +#ifdef CONFIG_PPC + case SVR_B4860: + case SVR_B4420: + return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); + case SVR_P1010: + return IS_SVR_REV(svr, 1, 0); + case SVR_P4080: + return IS_SVR_REV(svr, 2, 0) || IS_SVR_REV(svr, 3, 0); +#endif + } + return false; +} + +bool has_erratum_a007798(void) +{ +#ifdef CONFIG_PPC + return SVR_SOC_VER(get_svr()) == SVR_T4240 && + IS_SVR_REV(get_svr(), 2, 0); +#endif + return false; +} + +bool has_erratum_a007792(void) +{ + u32 svr = get_svr(); + u32 soc = SVR_SOC_VER(svr); + + switch (soc) { +#ifdef CONFIG_PPC + case SVR_T4240: + case SVR_T4160: + case SVR_T4080: + return IS_SVR_REV(svr, 2, 0); + case SVR_T1024: + case SVR_T1023: + return IS_SVR_REV(svr, 1, 0); + case SVR_T1040: + case SVR_T1042: + case SVR_T1020: + case SVR_T1022: + case SVR_T2080: + case SVR_T2081: + return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 1, 1); +#endif + } + return false; +} + +bool has_erratum_a005697(void) +{ + u32 svr = get_svr(); + u32 soc = SVR_SOC_VER(svr); + + switch (soc) { +#ifdef CONFIG_PPC + case SVR_9131: + case SVR_9132: + return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 1, 1); +#endif + } + return false; +} + +bool has_erratum_a004477(void) +{ + u32 svr = get_svr(); + u32 soc = SVR_SOC_VER(svr); + + switch (soc) { +#ifdef CONFIG_PPC + case SVR_P1010: + return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); + case SVR_P1022: + case SVR_9131: + case SVR_9132: + return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 1, 1); + case SVR_P2020: + return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0) || + IS_SVR_REV(svr, 2, 1); + case SVR_B4860: + case SVR_B4420: + return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); + case SVR_P4080: + return IS_SVR_REV(svr, 2, 0) || IS_SVR_REV(svr, 3, 0); +#endif + } + + return false; +} + +#endif diff --git a/include/fsl_usb.h b/include/fsl_usb.h index 882a5f5..54a5fe3 100644 --- a/include/fsl_usb.h +++ b/include/fsl_usb.h @@ -92,188 +92,13 @@ struct ccsr_usb_phy { #define SNPS_DWC3 "snps,dwc3"
/* USB Erratum Checking code */ -#ifdef CONFIG_PPC -static inline bool has_dual_phy(void) -{ - u32 svr = get_svr(); - u32 soc = SVR_SOC_VER(svr); - - switch (soc) { - case SVR_T1023: - case SVR_T1024: - case SVR_T1013: - case SVR_T1014: - return IS_SVR_REV(svr, 1, 0); - case SVR_T1040: - case SVR_T1042: - case SVR_T1020: - case SVR_T1022: - case SVR_T2080: - case SVR_T2081: - return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 1, 1); - case SVR_T4240: - case SVR_T4160: - case SVR_T4080: - return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); - } - - return false; -} - -static inline bool has_erratum_a006261(void) -{ - u32 svr = get_svr(); - u32 soc = SVR_SOC_VER(svr); - - switch (soc) { - case SVR_P1010: - return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); - case SVR_P2041: - case SVR_P2040: - return IS_SVR_REV(svr, 1, 0) || - IS_SVR_REV(svr, 1, 1) || IS_SVR_REV(svr, 2, 1); - case SVR_P3041: - return IS_SVR_REV(svr, 1, 0) || - IS_SVR_REV(svr, 1, 1) || - IS_SVR_REV(svr, 2, 0) || IS_SVR_REV(svr, 2, 1); - case SVR_P5010: - case SVR_P5020: - case SVR_P5021: - return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); - case SVR_T4240: - case SVR_T4160: - case SVR_T4080: - return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); - case SVR_T1040: - return IS_SVR_REV(svr, 1, 0); - case SVR_T2080: - case SVR_T2081: - return IS_SVR_REV(svr, 1, 0); - case SVR_P5040: - return IS_SVR_REV(svr, 1, 0); - } - - return false; -} - -static inline bool has_erratum_a007075(void) -{ - u32 svr = get_svr(); - u32 soc = SVR_SOC_VER(svr); - - switch (soc) { - case SVR_B4860: - case SVR_B4420: - return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); - case SVR_P1010: - return IS_SVR_REV(svr, 1, 0); - case SVR_P4080: - return IS_SVR_REV(svr, 2, 0) || IS_SVR_REV(svr, 3, 0); - } - return false; -} - -static inline bool has_erratum_a007798(void) -{ - return SVR_SOC_VER(get_svr()) == SVR_T4240 && - IS_SVR_REV(get_svr(), 2, 0); -} - -static inline bool has_erratum_a007792(void) -{ - u32 svr = get_svr(); - u32 soc = SVR_SOC_VER(svr); - - switch (soc) { - case SVR_T4240: - case SVR_T4160: - case SVR_T4080: - return IS_SVR_REV(svr, 2, 0); - case SVR_T1024: - case SVR_T1023: - return IS_SVR_REV(svr, 1, 0); - case SVR_T1040: - case SVR_T1042: - case SVR_T1020: - case SVR_T1022: - case SVR_T2080: - case SVR_T2081: - return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 1, 1); - } - return false; -} - -static inline bool has_erratum_a005697(void) -{ - u32 svr = get_svr(); - u32 soc = SVR_SOC_VER(svr); - - switch (soc) { - case SVR_9131: - case SVR_9132: - return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 1, 1); - } - return false; -} - -static inline bool has_erratum_a004477(void) -{ - u32 svr = get_svr(); - u32 soc = SVR_SOC_VER(svr); - - switch (soc) { - case SVR_P1010: - return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); - case SVR_P1022: - case SVR_9131: - case SVR_9132: - return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 1, 1); - case SVR_P2020: - return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0) || - IS_SVR_REV(svr, 2, 1); - case SVR_B4860: - case SVR_B4420: - return IS_SVR_REV(svr, 1, 0) || IS_SVR_REV(svr, 2, 0); - case SVR_P4080: - return IS_SVR_REV(svr, 2, 0) || IS_SVR_REV(svr, 3, 0); - } - - return false; -} -#else -static inline bool has_dual_phy(void) -{ - return false; -} - -static inline bool has_erratum_a006261(void) -{ - return false; -} - -static inline bool has_erratum_a007075(void) -{ - return false; -} - -static inline bool has_erratum_a007798(void) -{ - return false; -} - -static inline bool has_erratum_a007792(void) -{ - return false; -} - -static inline bool has_erratum_a005697(void) -{ - return false; -} - -static inline bool has_erratum_a004477(void) -{ - return false; -} +#if defined(CONFIG_PPC) || defined(CONFIG_ARM) +bool has_dual_phy(void); +bool has_erratum_a006261(void); +bool has_erratum_a007075(void); +bool has_erratum_a007798(void); +bool has_erratum_a007792(void); +bool has_erratum_a005697(void); +bool has_erratum_a004477(void); #endif #endif /*_ASM_FSL_USB_H_ */
This errata a008751 is applied on Soc specific file currently.This will be moved to a file where all the errata implementation will take place for usb for fsl. This patch removes the errata workaround from soc specific file for LS2080.
Changes in v2: - Modified commit message
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 10 ---------- 1 file changed, 10 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index dd633f3..d8ec426 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -124,15 +124,6 @@ void erratum_a009635(void) } #endif /* CONFIG_SYS_FSL_ERRATUM_A009635 */
-static void erratum_a008751(void) -{ -#ifdef CONFIG_SYS_FSL_ERRATUM_A008751 - u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; - - writel(0x27672b2a, scfg + SCFG_USB3PRM1CR / 4); -#endif -} - static void erratum_rcw_src(void) { #if defined(CONFIG_SPL) @@ -189,7 +180,6 @@ void bypass_smmu(void) } void fsl_lsch3_early_init_f(void) { - erratum_a008751(); erratum_rcw_src(); init_early_memctl_regs(); /* tighten IFC timing */ erratum_a009203();
This patch is doing the following: 1. Implementing the errata for LS2080. 2. Adding fixup for fdt for LS2080.
Changes in v3: - Reworked for changes done in errata checking code. - made inline bool erratum_a008751 as int erratum_a008751 - return 0 for success, 1 for failure for erratum_a008751 - dropped the APPLY_ERRATUM macro.
Changes in v2: - Reworked for changes done in errata checking code.
.../include/asm/arch-fsl-layerscape/immap_lsch3.h | 1 + board/freescale/ls2080aqds/ls2080aqds.c | 2 ++ board/freescale/ls2080ardb/ls2080ardb.c | 2 ++ drivers/usb/common/fsl-dt-fixup.c | 7 +++++++ drivers/usb/common/fsl-errata.c | 15 ++++++++++++++ drivers/usb/host/xhci-fsl.c | 24 ++++++++++++++++++++++ include/fsl_usb.h | 1 + 7 files changed, 52 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index e48bbaf..9b60bd3 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -139,6 +139,7 @@ /* Supplemental Configuration */ #define SCFG_BASE 0x01fc0000 #define SCFG_USB3PRM1CR 0x000 +#define SCFG_USB3PRM1CR_INIT 0x27672b2a
#define TP_ITYP_AV 0x00000001 /* Initiator available */ #define TP_ITYP_TYPE(x) (((x) & 0x6) >> 1) /* Initiator Type */ diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 897793d..479f689 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -298,6 +298,8 @@ int ft_board_setup(void *blob, bd_t *bd)
fdt_fixup_memory_banks(blob, base, size, 2);
+ fdt_fixup_dr_usb(blob, bd); + #ifdef CONFIG_FSL_MC_ENET fdt_fixup_board_enet(blob); err = fsl_mc_ldpaa_exit(bd); diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index 52e5e3f..a65cd4a 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -281,6 +281,8 @@ int ft_board_setup(void *blob, bd_t *bd)
+ fdt_fixup_dr_usb(blob, bd); + #ifdef CONFIG_FSL_MC_ENET fdt_fixup_board_enet(blob); err = fsl_mc_ldpaa_exit(bd); diff --git a/drivers/usb/common/fsl-dt-fixup.c b/drivers/usb/common/fsl-dt-fixup.c index 49d1140..2133b88 100644 --- a/drivers/usb/common/fsl-dt-fixup.c +++ b/drivers/usb/common/fsl-dt-fixup.c @@ -133,6 +133,7 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) int usb_erratum_a007075_off = -1; int usb_erratum_a007792_off = -1; int usb_erratum_a005697_off = -1; + int usb_erratum_a008751_off = -1; int usb_mode_off = -1; int usb_phy_off = -1; char str[5]; @@ -211,5 +212,11 @@ void fdt_fixup_dr_usb(void *blob, bd_t *bd) has_erratum_a005697); if (ret == -ENOSPC) return; + ret = fdt_fixup_erratum(&usb_erratum_a008751_off, blob, + SNPS_DWC3, "a008751", + has_erratum_a008751); + if (ret == -ENOSPC) + return; + } } diff --git a/drivers/usb/common/fsl-errata.c b/drivers/usb/common/fsl-errata.c index 95918fc..ebe60a8 100644 --- a/drivers/usb/common/fsl-errata.c +++ b/drivers/usb/common/fsl-errata.c @@ -175,4 +175,19 @@ bool has_erratum_a004477(void) return false; }
+bool has_erratum_a008751(void) +{ + u32 svr = get_svr(); + u32 soc = SVR_SOC_VER(svr); + + switch (soc) { +#ifdef CONFIG_ARM64 + case SVR_LS2080: + case SVR_LS2085: + return IS_SVR_REV(svr, 1, 0); +#endif + } + return false; +} + #endif diff --git a/drivers/usb/host/xhci-fsl.c b/drivers/usb/host/xhci-fsl.c index 05f09d7..c12a189 100644 --- a/drivers/usb/host/xhci-fsl.c +++ b/drivers/usb/host/xhci-fsl.c @@ -15,6 +15,8 @@ #include <linux/usb/xhci-fsl.h> #include <linux/usb/dwc3.h> #include "xhci.h" +#include <fsl_errata.h> +#include <fsl_usb.h>
/* Declare global data pointer */ DECLARE_GLOBAL_DATA_PTR; @@ -27,6 +29,26 @@ __weak int __board_usb_init(int index, enum usb_init_type init) return 0; }
+static int erratum_a008751(void) +{ +#if defined(CONFIG_TARGET_LS2080AQDS) || defined(CONFIG_TARGET_LS2080ARDB) + u32 __iomem *scfg = (u32 __iomem *)SCFG_BASE; + writel(SCFG_USB3PRM1CR_INIT, scfg + SCFG_USB3PRM1CR / 4); + return 0; +#endif + return 1; +} + +static void fsl_apply_xhci_errata(void) +{ + int ret; + if (has_erratum_a008751()) { + ret = erratum_a008751(); + if (ret != 0) + puts("Failed to apply erratum a008751\n"); + } +} + static int fsl_xhci_core_init(struct fsl_xhci *fsl_xhci) { int ret = 0; @@ -69,6 +91,8 @@ int xhci_hcd_init(int index, struct xhci_hccr **hccr, struct xhci_hcor **hcor) return ret; }
+ fsl_apply_xhci_errata(); + ret = fsl_xhci_core_init(ctx); if (ret < 0) { puts("Failed to initialize xhci\n"); diff --git a/include/fsl_usb.h b/include/fsl_usb.h index 54a5fe3..72f42db 100644 --- a/include/fsl_usb.h +++ b/include/fsl_usb.h @@ -100,5 +100,6 @@ bool has_erratum_a007798(void); bool has_erratum_a007792(void); bool has_erratum_a005697(void); bool has_erratum_a004477(void); +bool has_erratum_a008751(void); #endif #endif /*_ASM_FSL_USB_H_ */
Sriram Dash
