[U-Boot] [PATCH 01/12] ppc/85xx: Clean up MPC8536 DS PCI setup code
Use new fsl_pci_init_port() that reduces amount of duplicated code in the board ports, use IO accessors and clean up printing of status info.
Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com Signed-off-by: Kumar Gala galak@kernel.crashing.org --- V3: * use fsl_setup_hose
board/freescale/mpc8536ds/mpc8536ds.c | 257 +++++++++------------------------ 1 files changed, 66 insertions(+), 191 deletions(-)
diff --git a/board/freescale/mpc8536ds/mpc8536ds.c b/board/freescale/mpc8536ds/mpc8536ds.c index da72916..ce40cdb 100644 --- a/board/freescale/mpc8536ds/mpc8536ds.c +++ b/board/freescale/mpc8536ds/mpc8536ds.c @@ -1,5 +1,5 @@ /* - * Copyright 2008 Freescale Semiconductor. + * Copyright 2008-2009 Freescale Semiconductor, Inc. * * See file CREDITS for list of people who contributed to this * project. @@ -189,20 +189,26 @@ static struct pci_controller pcie2_hose; static struct pci_controller pcie3_hose; #endif
-int first_free_busno=0; - -void -pci_init_board(void) +#ifdef CONFIG_PCI +void pci_init_board(void) { - volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - uint devdisr = gur->devdisr; - uint sdrs2_io_sel = - (gur->pordevsr & MPC85xx_PORDEVSR_SRDS2_IO_SEL) >> 27; - uint io_sel = (gur->pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - uint host_agent = (gur->porbmsr & MPC85xx_PORBMSR_HA) >> 16; + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + struct fsl_pci_info pci_info[4]; + u32 devdisr, pordevsr, io_sel, sdrs2_io_sel; + u32 porpllsr, pci_agent, pci_speed, pci_32, pci_arb, pci_clk_sel; + int first_free_busno = 0; + int num = 0; + + int pcie_ep, pcie_configured;
- debug(" pci_init_board: devdisr=%x, sdrs2_io_sel=%x, io_sel=%x,\ - host_agent=%x\n", devdisr, sdrs2_io_sel, io_sel, host_agent); + devdisr = in_be32(&gur->devdisr); + pordevsr = in_be32(&gur->pordevsr); + porpllsr = in_be32(&gur->porpllsr); + io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; + sdrs2_io_sel = (pordevsr & MPC85xx_PORDEVSR_SRDS2_IO_SEL) >> 27; + + debug(" pci_init_board: devdisr=%x, sdrs2_io_sel=%x, io_sel=%x\n", + devdisr, sdrs2_io_sel, io_sel);
if (sdrs2_io_sel == 7) printf(" Serdes2 disalbed\n"); @@ -212,228 +218,97 @@ pci_init_board(void) } else if (sdrs2_io_sel == 6) printf(" eTSEC1 is in sgmii mode.\n");
+ puts("\n"); #ifdef CONFIG_PCIE3 -{ - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE3_ADDR; - struct pci_controller *hose = &pcie3_hose; - int pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_3, host_agent); - int pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_3, io_sel); - struct pci_region *r = hose->regions; + pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_3, io_sel);
- if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - printf ("\n PCIE3 connected to Slot3 as %s (base address %x)", + if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE3)){ + SET_STD_PCIE_INFO(pci_info[num], 3); + pcie_ep = fsl_setup_hose(&pcie3_hose, pci_info[num].regs); + printf (" PCIE3 connected to Slot3 as %s (base address %lx)\n", pcie_ep ? "End Point" : "Root Complex", - (uint)pci); - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; - debug (" with errors. Clearing. Now 0x%08x",pci->pme_msg_det); - } - printf ("\n"); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE3_MEM_BUS, - CONFIG_SYS_PCIE3_MEM_PHYS, - CONFIG_SYS_PCIE3_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCIE3_IO_BUS, - CONFIG_SYS_PCIE3_IO_PHYS, - CONFIG_SYS_PCIE3_IO_SIZE, - PCI_REGION_IO); - - hose->region_count = r - hose->regions; - - hose->first_busno=first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - - first_free_busno=hose->last_busno+1; - printf (" PCIE3 on bus %02x - %02x\n", - hose->first_busno,hose->last_busno); + pci_info[num].regs); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie3_hose, first_free_busno); } else { printf (" PCIE3: disabled\n"); } -} + + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCIE3; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE3); /* disable */ #endif
#ifdef CONFIG_PCIE1 -{ - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - struct pci_controller *hose = &pcie1_hose; - int pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_1, host_agent); - int pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel); - struct pci_region *r = hose->regions; + pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel);
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - printf ("\n PCIE1 connected to Slot1 as %s (base address %x)", + SET_STD_PCIE_INFO(pci_info[num], 1); + pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); + printf (" PCIE1 connected to Slot1 as %s (base address %lx)\n", pcie_ep ? "End Point" : "Root Complex", - (uint)pci); - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; - debug (" with errors. Clearing. Now 0x%08x",pci->pme_msg_det); - } - printf ("\n"); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_MEM_BUS, - CONFIG_SYS_PCIE1_MEM_PHYS, - CONFIG_SYS_PCIE1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_IO_BUS, - CONFIG_SYS_PCIE1_IO_PHYS, - CONFIG_SYS_PCIE1_IO_SIZE, - PCI_REGION_IO); - -#ifdef CONFIG_SYS_PCIE1_MEM_BUS2 - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_MEM_BUS2, - CONFIG_SYS_PCIE1_MEM_PHYS2, - CONFIG_SYS_PCIE1_MEM_SIZE2, - PCI_REGION_MEM); -#endif - hose->region_count = r - hose->regions; - hose->first_busno=first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - - first_free_busno=hose->last_busno+1; - printf(" PCIE1 on bus %02x - %02x\n", - hose->first_busno,hose->last_busno); - + pci_info[num].regs); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie1_hose, first_free_busno); } else { printf (" PCIE1: disabled\n"); } -} + + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCIE; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ #endif
#ifdef CONFIG_PCIE2 -{ - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE2_ADDR; - struct pci_controller *hose = &pcie2_hose; - int pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_2, host_agent); - int pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_2, io_sel); - struct pci_region *r = hose->regions; + pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_2, io_sel);
- if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - printf ("\n PCIE2 connected to Slot 2 as %s (base address %x)", + if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE2)){ + SET_STD_PCIE_INFO(pci_info[num], 2); + pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); + printf (" PCIE2 connected to Slot 2 as %s (base address %lx)\n", pcie_ep ? "End Point" : "Root Complex", - (uint)pci); - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; - debug (" with errors. Clearing. Now 0x%08x",pci->pme_msg_det); - } - printf ("\n"); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE2_MEM_BUS, - CONFIG_SYS_PCIE2_MEM_PHYS, - CONFIG_SYS_PCIE2_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCIE2_IO_BUS, - CONFIG_SYS_PCIE2_IO_PHYS, - CONFIG_SYS_PCIE2_IO_SIZE, - PCI_REGION_IO); - -#ifdef CONFIG_SYS_PCIE2_MEM_BUS2 - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE2_MEM_BUS2, - CONFIG_SYS_PCIE2_MEM_PHYS2, - CONFIG_SYS_PCIE2_MEM_SIZE2, - PCI_REGION_MEM); -#endif - hose->region_count = r - hose->regions; - hose->first_busno=first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - first_free_busno=hose->last_busno+1; - printf (" PCIE2 on bus %02x - %02x\n", - hose->first_busno,hose->last_busno); - + pci_info[num].regs); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie2_hose, first_free_busno); } else { printf (" PCIE2: disabled\n"); } -} + + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCIE2; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE2); /* disable */ #endif
#ifdef CONFIG_PCI1 -{ - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - struct pci_controller *hose = &pci1_hose; - struct pci_region *r = hose->regions; - - uint pci_agent = is_fsl_pci_agent(LAW_TRGT_IF_PCI, host_agent); - uint pci_speed = 66666000; /*get_clock_freq (); PCI PSPEED in [4:5] */ - uint pci_32 = 1; - uint pci_arb = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; /* PORDEVSR[14] */ - uint pci_clk_sel = gur->porpllsr & MPC85xx_PORDEVSR_PCI1_SPD; /* PORPLLSR[16] */ + pci_speed = 66666000; + pci_32 = 1; + pci_arb = pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; + pci_clk_sel = porpllsr & MPC85xx_PORDEVSR_PCI1_SPD;
if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { - printf ("\n PCI: %d bit, %s MHz, %s, %s, %s (base address %x)\n", + SET_STD_PCI_INFO(pci_info[num], 1); + pci_agent = fsl_setup_hose(&pci1_hose, pci_info[num].regs); + printf ("\n PCI: %d bit, %s MHz, %s, %s, %s (base address %lx)\n", (pci_32) ? 32 : 64, (pci_speed == 33333000) ? "33" : (pci_speed == 66666000) ? "66" : "unknown", pci_clk_sel ? "sync" : "async", pci_agent ? "agent" : "host", pci_arb ? "arbiter" : "external-arbiter", - (uint)pci - ); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCI1_MEM_BUS, - CONFIG_SYS_PCI1_MEM_PHYS, - CONFIG_SYS_PCI1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCI1_IO_BUS, - CONFIG_SYS_PCI1_IO_PHYS, - CONFIG_SYS_PCI1_IO_SIZE, - PCI_REGION_IO); - -#ifdef CONFIG_SYS_PCI1_MEM_BUS2 - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCI1_MEM_BUS2, - CONFIG_SYS_PCI1_MEM_PHYS2, - CONFIG_SYS_PCI1_MEM_SIZE2, - PCI_REGION_MEM); -#endif - hose->region_count = r - hose->regions; - hose->first_busno=first_free_busno; + pci_info[num].regs);
- fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - first_free_busno=hose->last_busno+1; - printf ("PCI on bus %02x - %02x\n", - hose->first_busno,hose->last_busno); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pci1_hose, first_free_busno); } else { printf (" PCI: disabled\n"); } -} + + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCI1; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI1); /* disable */ #endif } +#endif
int board_early_init_r(void) {
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8544ds/mpc8544ds.c | 249 +++++++++----------------------- 1 files changed, 70 insertions(+), 179 deletions(-)
diff --git a/board/freescale/mpc8544ds/mpc8544ds.c b/board/freescale/mpc8544ds/mpc8544ds.c index 244a197..35a8063 100644 --- a/board/freescale/mpc8544ds/mpc8544ds.c +++ b/board/freescale/mpc8544ds/mpc8544ds.c @@ -1,5 +1,5 @@ /* - * Copyright 2007 Freescale Semiconductor, Inc. + * Copyright 2007,2009 Freescale Semiconductor, Inc. * * See file CREDITS for list of people who contributed to this * project. @@ -101,18 +101,23 @@ static struct pci_controller pcie2_hose; static struct pci_controller pcie3_hose; #endif
-int first_free_busno=0; - -void -pci_init_board(void) +void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - uint devdisr = gur->devdisr; - uint io_sel = (gur->pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - uint host_agent = (gur->porbmsr & MPC85xx_PORBMSR_HA) >> 16; + struct fsl_pci_info pci_info[4]; + u32 devdisr, pordevsr, io_sel; + u32 porpllsr, pci_agent, pci_speed, pci_32, pci_arb, pci_clk_sel; + int first_free_busno = 0; + int num = 0; + + int pcie_ep, pcie_configured;
- debug (" pci_init_board: devdisr=%x, io_sel=%x, host_agent=%x\n", - devdisr, io_sel, host_agent); + devdisr = in_be32(&gur->devdisr); + pordevsr = in_be32(&gur->pordevsr); + porpllsr = in_be32(&gur->porpllsr); + io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; + + debug (" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel);
if (io_sel & 1) { if (!(gur->pordevsr & MPC85xx_PORDEVSR_SGMII1_DIS)) @@ -120,55 +125,29 @@ pci_init_board(void) if (!(gur->pordevsr & MPC85xx_PORDEVSR_SGMII3_DIS)) printf (" eTSEC3 is in sgmii mode.\n"); } + puts("\n");
#ifdef CONFIG_PCIE3 -{ - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE3_ADDR; - struct pci_controller *hose = &pcie3_hose; - int pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_3, host_agent); - int pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_3, io_sel); - struct pci_region *r = hose->regions; - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - printf ("\n PCIE3 connected to ULI as %s (base address %x)", - pcie_ep ? "End Point" : "Root Complex", - (uint)pci); - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; - debug (" with errors. Clearing. Now 0x%08x",pci->pme_msg_det); - } - printf ("\n"); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE3_MEM_BUS, - CONFIG_SYS_PCIE3_MEM_PHYS, - CONFIG_SYS_PCIE3_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCIE3_IO_BUS, - CONFIG_SYS_PCIE3_IO_PHYS, - CONFIG_SYS_PCIE3_IO_SIZE, - PCI_REGION_IO); + pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_3, io_sel);
+ if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE3)){ + SET_STD_PCIE_INFO(pci_info[num], 3); + pcie_ep = fsl_setup_hose(&pcie3_hose, pci_info[num].regs); #ifdef CONFIG_SYS_PCIE3_MEM_BUS2 /* outbound memory */ - pci_set_region(r++, + pci_set_region(&pcie3_hose.regions[0], CONFIG_SYS_PCIE3_MEM_BUS2, CONFIG_SYS_PCIE3_MEM_PHYS2, CONFIG_SYS_PCIE3_MEM_SIZE2, PCI_REGION_MEM); -#endif - hose->region_count = r - hose->regions; - hose->first_busno=first_free_busno;
- fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - - first_free_busno=hose->last_busno+1; - printf (" PCIE3 on bus %02x - %02x\n", - hose->first_busno,hose->last_busno); + pcie3_hose.region_count = 1; +#endif + printf (" PCIE3 connected to ULI as %s (base addr %lx)\n", + pcie_ep ? "End Point" : "Root Complex", + pci_info[num].regs); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie3_hose, first_free_busno);
/* * Activate ULI1575 legacy chip by performing a fake @@ -178,187 +157,99 @@ pci_init_board(void) } else { printf (" PCIE3: disabled\n"); } - - } + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCIE3; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE3); /* disable */ #endif
#ifdef CONFIG_PCIE1 - { - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - struct pci_controller *hose = &pcie1_hose; - int pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_1, host_agent); - int pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel); - struct pci_region *r = hose->regions; + pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel);
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - printf ("\n PCIE1 connected to Slot2 as %s (base address %x)", - pcie_ep ? "End Point" : "Root Complex", - (uint)pci); - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; - debug (" with errors. Clearing. Now 0x%08x",pci->pme_msg_det); - } - printf ("\n"); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_MEM_BUS, - CONFIG_SYS_PCIE1_MEM_PHYS, - CONFIG_SYS_PCIE1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_IO_BUS, - CONFIG_SYS_PCIE1_IO_PHYS, - CONFIG_SYS_PCIE1_IO_SIZE, - PCI_REGION_IO); - + SET_STD_PCIE_INFO(pci_info[num], 1); + pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); #ifdef CONFIG_SYS_PCIE1_MEM_BUS2 /* outbound memory */ - pci_set_region(r++, + pci_set_region(&pcie1_hose.regions[0], CONFIG_SYS_PCIE1_MEM_BUS2, CONFIG_SYS_PCIE1_MEM_PHYS2, CONFIG_SYS_PCIE1_MEM_SIZE2, PCI_REGION_MEM); -#endif - hose->region_count = r - hose->regions; - hose->first_busno=first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data);
- first_free_busno=hose->last_busno+1; - printf(" PCIE1 on bus %02x - %02x\n", - hose->first_busno,hose->last_busno); + pcie1_hose.region_count = 1; +#endif + printf (" PCIE1 connected to Slot 2 as %s (base addr %lx)\n", + pcie_ep ? "End Point" : "Root Complex", + pci_info[num].regs);
- } + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCIE; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ #endif
#ifdef CONFIG_PCIE2 - { - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE2_ADDR; - struct pci_controller *hose = &pcie2_hose; - int pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_2, host_agent); - int pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_2, io_sel); - struct pci_region *r = hose->regions; - - if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - printf ("\n PCIE2 connected to Slot 1 as %s (base address %x)", - pcie_ep ? "End Point" : "Root Complex", - (uint)pci); - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; - debug (" with errors. Clearing. Now 0x%08x",pci->pme_msg_det); - } - printf ("\n"); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE2_MEM_BUS, - CONFIG_SYS_PCIE2_MEM_PHYS, - CONFIG_SYS_PCIE2_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCIE2_IO_BUS, - CONFIG_SYS_PCIE2_IO_PHYS, - CONFIG_SYS_PCIE2_IO_SIZE, - PCI_REGION_IO); + pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_2, io_sel);
+ if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE2)){ + SET_STD_PCIE_INFO(pci_info[num], 2); + pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); #ifdef CONFIG_SYS_PCIE2_MEM_BUS2 /* outbound memory */ - pci_set_region(r++, + pci_set_region(&pcie2_hose.regions[0], CONFIG_SYS_PCIE2_MEM_BUS2, CONFIG_SYS_PCIE2_MEM_PHYS2, CONFIG_SYS_PCIE2_MEM_SIZE2, PCI_REGION_MEM); -#endif - hose->region_count = r - hose->regions; - hose->first_busno=first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - first_free_busno=hose->last_busno+1; - printf (" PCIE2 on bus %02x - %02x\n", - hose->first_busno,hose->last_busno);
+ pcie2_hose.region_count = 1; +#endif + printf (" PCIE2 connected to Slot 1 as %s (base addr %lx)\n", + pcie_ep ? "End Point" : "Root Complex", + pci_info[num].regs); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie2_hose, first_free_busno); } else { printf (" PCIE2: disabled\n"); }
- } + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCIE2; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE2); /* disable */ #endif
- #ifdef CONFIG_PCI1 -{ - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - struct pci_controller *hose = &pci1_hose; - struct pci_region *r = hose->regions; - - uint pci_agent = is_fsl_pci_agent(LAW_TRGT_IF_PCI, host_agent); - uint pci_speed = 66666000; /*get_clock_freq (); PCI PSPEED in [4:5] */ - uint pci_32 = 1; - uint pci_arb = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; /* PORDEVSR[14] */ - uint pci_clk_sel = gur->porpllsr & MPC85xx_PORDEVSR_PCI1_SPD; /* PORPLLSR[16] */ - + pci_speed = 66666000; + pci_32 = 1; + pci_arb = pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; + pci_clk_sel = porpllsr & MPC85xx_PORDEVSR_PCI1_SPD;
if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { - printf ("\n PCI: %d bit, %s MHz, %s, %s, %s (base address %x)\n", + SET_STD_PCI_INFO(pci_info[num], 1); + pci_agent = fsl_setup_hose(&pci1_hose, pci_info[num].regs); + printf ("\n PCI: %d bit, %s MHz, %s, %s, %s (base address %lx)\n", (pci_32) ? 32 : 64, (pci_speed == 33333000) ? "33" : (pci_speed == 66666000) ? "66" : "unknown", pci_clk_sel ? "sync" : "async", pci_agent ? "agent" : "host", pci_arb ? "arbiter" : "external-arbiter", - (uint)pci - ); + pci_info[num].regs);
- /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCI1_MEM_BUS, - CONFIG_SYS_PCI1_MEM_PHYS, - CONFIG_SYS_PCI1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCI1_IO_BUS, - CONFIG_SYS_PCI1_IO_PHYS, - CONFIG_SYS_PCI1_IO_SIZE, - PCI_REGION_IO); - -#ifdef CONFIG_SYS_PCIE3_MEM_BUS2 - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE3_MEM_BUS2, - CONFIG_SYS_PCIE3_MEM_PHYS2, - CONFIG_SYS_PCIE3_MEM_SIZE2, - PCI_REGION_MEM); -#endif - hose->region_count = r - hose->regions; - hose->first_busno=first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - first_free_busno=hose->last_busno+1; - printf ("PCI on bus %02x - %02x\n", - hose->first_busno,hose->last_busno); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pci1_hose, first_free_busno); } else { printf (" PCI: disabled\n"); } -} + + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCI1; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI1); /* disable */ #endif }
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8569mds/mpc8569mds.c | 86 +++++++++--------------------- 1 files changed, 26 insertions(+), 60 deletions(-)
diff --git a/board/freescale/mpc8569mds/mpc8569mds.c b/board/freescale/mpc8569mds/mpc8569mds.c index cdd7813..4612d16 100644 --- a/board/freescale/mpc8569mds/mpc8569mds.c +++ b/board/freescale/mpc8569mds/mpc8569mds.c @@ -514,77 +514,43 @@ static void fdt_board_fixup_qe_usb(void *blob, bd_t *bd) static struct pci_controller pcie1_hose; #endif /* CONFIG_PCIE1 */
-int first_free_busno = 0; - #ifdef CONFIG_PCI -void -pci_init_board(void) +void pci_init_board(void) { - volatile ccsr_gur_t *gur; - uint io_sel; - uint host_agent; - - gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - io_sel = (gur->pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - host_agent = (gur->porbmsr & MPC85xx_PORBMSR_HA) >> 16; - -#ifdef CONFIG_PCIE1 -{ - volatile ccsr_fsl_pci_t *pci; - struct pci_controller *hose; - int pcie_ep; - struct pci_region *r; - int pcie_configured; - - pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - hose = &pcie1_hose; - pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_1, host_agent); - r = hose->regions; - pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel); - - if (pcie_configured && !(gur->devdisr & MPC85xx_DEVDISR_PCIE)){ - printf ("\n PCIE connected to slot as %s (base address %x)", - pcie_ep ? "End Point" : "Root Complex", - (uint)pci); - - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; - debug (" with errors. Clearing. Now 0x%08x", - pci->pme_msg_det); - } - printf ("\n"); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_MEM_BUS, - CONFIG_SYS_PCIE1_MEM_PHYS, - CONFIG_SYS_PCIE1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_IO_BUS, - CONFIG_SYS_PCIE1_IO_PHYS, - CONFIG_SYS_PCIE1_IO_SIZE, - PCI_REGION_IO); + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + struct fsl_pci_info pci_info[1]; + u32 devdisr, pordevsr, io_sel; + int first_free_busno = 0; + int num = 0;
- hose->region_count = r - hose->regions; + int pcie_ep, pcie_configured;
- hose->first_busno=first_free_busno; + devdisr = in_be32(&gur->devdisr); + pordevsr = in_be32(&gur->pordevsr); + io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19;
- fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - printf ("PCIE on bus %02x - %02x\n", - hose->first_busno,hose->last_busno); + debug (" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel);
- first_free_busno=hose->last_busno+1; +#ifdef CONFIG_PCIE1 + pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel);
+ if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ + SET_STD_PCIE_INFO(pci_info[num], 1); + pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); + printf (" PCIE1 connected to Slot as %s (base addr %lx)\n", + pcie_ep ? "End Point" : "Root Complex", + pci_info[num].regs); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie1_hose, first_free_busno); } else { - printf (" PCIE: disabled\n"); + printf (" PCIE1: disabled\n"); } -} + + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCIE; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ #endif + } #endif /* CONFIG_PCI */
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8568mds/mpc8568mds.c | 137 ++++++++++--------------------- 1 files changed, 45 insertions(+), 92 deletions(-)
diff --git a/board/freescale/mpc8568mds/mpc8568mds.c b/board/freescale/mpc8568mds/mpc8568mds.c index e2dc69e..60e22de 100644 --- a/board/freescale/mpc8568mds/mpc8568mds.c +++ b/board/freescale/mpc8568mds/mpc8568mds.c @@ -1,5 +1,5 @@ /* - * Copyright 2007 Freescale Semiconductor. + * Copyright 2007,2009 Freescale Semiconductor, Inc. * * (C) Copyright 2002 Scott McNutt smcnutt@artesyncp.com * @@ -311,8 +311,6 @@ static struct pci_controller pci1_hose = { static struct pci_controller pcie1_hose; #endif /* CONFIG_PCIE1 */
-int first_free_busno = 0; - /* * pib_init() -- Initialize the PCA9555 IO expander on the PIB board */ @@ -356,117 +354,72 @@ pib_init(void) }
#ifdef CONFIG_PCI -void -pci_init_board(void) +void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - uint io_sel = (gur->pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - uint host_agent = (gur->porbmsr & MPC85xx_PORBMSR_HA) >> 16; - -#ifdef CONFIG_PCI1 -{ - pib_init(); - - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - struct pci_controller *hose = &pci1_hose; - struct pci_region *r = hose->regions; + struct fsl_pci_info pci_info[2]; + u32 devdisr, pordevsr, io_sel; + u32 porpllsr, pci_agent, pci_speed, pci_32, pci_arb, pci_clk_sel; + int first_free_busno = 0; + int num = 0;
- uint pci_32 = 1; /* PORDEVSR[15] */ - uint pci_arb = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; /* PORDEVSR[14] */ - uint pci_clk_sel = gur->porpllsr & MPC85xx_PORDEVSR_PCI1_SPD; /* PORPLLSR[16] */ + int pcie_ep, pcie_configured;
- uint pci_agent = (host_agent == 3) || (host_agent == 4 ) || (host_agent == 6); + devdisr = in_be32(&gur->devdisr); + pordevsr = in_be32(&gur->pordevsr); + porpllsr = in_be32(&gur->porpllsr); + io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19;
- uint pci_speed = 66666000; + debug (" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel);
- if (!(gur->devdisr & MPC85xx_DEVDISR_PCI1)) { - printf (" PCI: %d bit, %s MHz, %s, %s, %s\n", +#ifdef CONFIG_PCI1 + pci_speed = 66666000; + pci_32 = 1; + pci_arb = pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; + pci_clk_sel = porpllsr & MPC85xx_PORDEVSR_PCI1_SPD; + + if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { + SET_STD_PCI_INFO(pci_info[num], 1); + pci_agent = fsl_setup_hose(&pci1_hose, pci_info[num].regs); + printf ("\n PCI: %d bit, %s MHz, %s, %s, %s (base address %lx)\n", (pci_32) ? 32 : 64, (pci_speed == 33333000) ? "33" : (pci_speed == 66666000) ? "66" : "unknown", pci_clk_sel ? "sync" : "async", pci_agent ? "agent" : "host", - pci_arb ? "arbiter" : "external-arbiter" - ); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCI1_MEM_BUS, - CONFIG_SYS_PCI1_MEM_PHYS, - CONFIG_SYS_PCI1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCI1_IO_BUS, - CONFIG_SYS_PCI1_IO_PHYS, - CONFIG_SYS_PCI1_IO_SIZE, - PCI_REGION_IO); - - hose->region_count = r - hose->regions; - - hose->first_busno = first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - first_free_busno = hose->last_busno+1; - printf ("PCI on bus %02x - %02x\n",hose->first_busno,hose->last_busno); + pci_arb ? "arbiter" : "external-arbiter", + pci_info[num].regs); + + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pci1_hose, first_free_busno); } else { - printf (" PCI: disabled\n"); + printf (" PCI: disabled\n"); } -} + + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCI1; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI1); /* disable */ #endif
#ifdef CONFIG_PCIE1 -{ - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - struct pci_controller *hose = &pcie1_hose; - int pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_1, host_agent); - struct pci_region *r = hose->regions; + pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel);
- int pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel); - - if (pcie_configured && !(gur->devdisr & MPC85xx_DEVDISR_PCIE)){ - printf ("\n PCIE connected to slot as %s (base address %x)", - pcie_ep ? "End Point" : "Root Complex", - (uint)pci); - - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; - debug (" with errors. Clearing. Now 0x%08x",pci->pme_msg_det); - } - printf ("\n"); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_MEM_BUS, - CONFIG_SYS_PCIE1_MEM_PHYS, - CONFIG_SYS_PCIE1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_IO_BUS, - CONFIG_SYS_PCIE1_IO_PHYS, - CONFIG_SYS_PCIE1_IO_SIZE, - PCI_REGION_IO); - - hose->region_count = r - hose->regions; - - hose->first_busno=first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - printf ("PCIE on bus %02x - %02x\n",hose->first_busno,hose->last_busno); - - first_free_busno=hose->last_busno+1; + if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ + SET_STD_PCIE_INFO(pci_info[num], 1); + pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); + printf (" PCIE1 connected to Slot as %s (base addr %lx)\n", + pcie_ep ? "End Point" : "Root Complex", + pci_info[num].regs);
+ first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie1_hose, first_free_busno); } else { - printf (" PCIE: disabled\n"); + printf (" PCIE1: disabled\n"); } -} + + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCIE; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ #endif } #endif /* CONFIG_PCI */
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/atum8548/atum8548.c | 162 ++++++++++++++------------------------------ include/configs/ATUM8548.h | 18 +++--- 2 files changed, 59 insertions(+), 121 deletions(-)
diff --git a/board/atum8548/atum8548.c b/board/atum8548/atum8548.c index a220ad4..da6cf47 100644 --- a/board/atum8548/atum8548.c +++ b/board/atum8548/atum8548.c @@ -170,22 +170,26 @@ static struct pci_controller pci2_hose; static struct pci_controller pcie1_hose; #endif
-int first_free_busno=0; - -void -pci_init_board(void) +void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + struct fsl_pci_info pci_info[3]; + u32 devdisr, pordevsr, io_sel; + u32 porpllsr, pci_agent, pci_speed, pci_32, pci_arb, pci_clk_sel; + int first_free_busno = 0; + int num = 0; + + int pcie_ep, pcie_configured;
- uint devdisr = gur->devdisr; - uint io_sel = (gur->pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - uint host_agent = (gur->porbmsr & MPC85xx_PORBMSR_HA) >> 16; + devdisr = in_be32(&gur->devdisr); + pordevsr = in_be32(&gur->pordevsr); + porpllsr = in_be32(&gur->porpllsr); + io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19;
- debug (" pci_init_board: devdisr=%x, io_sel=%x, host_agent=%x\n", - devdisr, io_sel, host_agent); + debug (" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel);
/* explicitly set 'Clock out select register' to echo SYSCLK input to our CPLD */ - gur->clkocr |= MPC85xx_ATUM_CLKOCR; + setbits_be32(&gur->clkocr, MPC85xx_ATUM_CLKOCR);
if (io_sel & 1) { if (!(gur->pordevsr & MPC85xx_PORDEVSR_SGMII1_DIS)) @@ -199,145 +203,79 @@ pci_init_board(void) }
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ - printf ("\n PCIE1 connected to slot as %s (base address %x)", - pcie_ep ? "End Point" : "Root Complex", - (uint)pci); - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; - debug (" with errors. Clearing. Now 0x%08x",pci->pme_msg_det); - } - printf ("\n"); - + SET_STD_PCIE_INFO(pci_info[num], 1); + pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); +#ifdef CONFIG_SYS_PCIE1_MEM_BUS2 /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_MEM_BASE, - CONFIG_SYS_PCIE1_MEM_PHYS, - CONFIG_SYS_PCIE1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_IO_BASE, - CONFIG_SYS_PCIE1_IO_PHYS, - CONFIG_SYS_PCIE1_IO_SIZE, - PCI_REGION_IO); - -#ifdef CONFIG_SYS_PCIE1_MEM_BASE2 - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_MEM_BASE2, + pci_set_region(&pcie1_hose.regions[0], + CONFIG_SYS_PCIE1_MEM_BUS2, CONFIG_SYS_PCIE1_MEM_PHYS2, CONFIG_SYS_PCIE1_MEM_SIZE2, PCI_REGION_MEM); -#endif - hose->region_count = r - hose->regions; - hose->first_busno=first_free_busno;
- fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - - first_free_busno=hose->last_busno+1; - printf(" PCIE1 on bus %02x - %02x\n", - hose->first_busno,hose->last_busno); + pcie1_hose.region_count = 1; +#endif + printf (" PCIE1 connected to Slot as %s (base addr %lx)\n", + pcie_ep ? "End Point" : "Root Complex", + pci_info[num].regs);
#ifdef CONFIG_PCI1 -{ - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - struct pci_controller *hose = &pci1_hose; - struct pci_region *r = hose->regions; - - uint pci_agent = is_fsl_pci_agent(LAW_TRGT_IF_PCI_1, host_agent); - uint pci_speed = 33333000; /*get_clock_freq (); PCI PSPEED in [4:5] */ - uint pci_32 = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_PCI32; /* PORDEVSR[15] */ - uint pci_arb = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; /* PORDEVSR[14] */ - uint pci_clk_sel = gur->porpllsr & MPC85xx_PORDEVSR_PCI1_SPD; /* PORPLLSR[16] */ + pci_speed = 33333000; /*get_clock_freq (); PCI PSPEED in [4:5] */ + pci_32 = pordevsr & MPC85xx_PORDEVSR_PCI1_PCI32; /* PORDEVSR[15] */ + pci_arb = pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; + pci_clk_sel = porpllsr & MPC85xx_PORDEVSR_PCI1_SPD;
if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { - printf ("\n PCI1: %d bit, %s MHz, %s, %s, %s (base address %x)\n", + SET_STD_PCI_INFO(pci_info[num], 1); + pci_agent = fsl_setup_hose(&pci1_hose, pci_info[num].regs); + printf ("\n PCI1: %d bit, %s MHz, %s, %s, %s (base address %lx)\n", (pci_32) ? 32 : 64, (pci_speed == 33333000) ? "33" : (pci_speed == 66666000) ? "66" : "unknown", pci_clk_sel ? "sync" : "async", pci_agent ? "agent" : "host", pci_arb ? "arbiter" : "external-arbiter", - (uint)pci - ); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCI1_MEM_BASE, - CONFIG_SYS_PCI1_MEM_PHYS, - CONFIG_SYS_PCI1_MEM_SIZE, - PCI_REGION_MEM); + pci_info[num].regs);
- /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCI1_IO_BASE, - CONFIG_SYS_PCI1_IO_PHYS, - CONFIG_SYS_PCI1_IO_SIZE, - PCI_REGION_IO); - hose->region_count = r - hose->regions; - hose->first_busno=first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - first_free_busno=hose->last_busno+1; - printf ("PCI1 on bus %02x - %02x\n", - hose->first_busno,hose->last_busno); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pci1_hose, first_free_busno); } else { - printf (" PCI1: disabled\n"); + printf (" PCI: disabled\n"); } -} + + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCI1; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI1); /* disable */ #endif
#ifdef CONFIG_PCI2 -{ - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI2_ADDR; - struct pci_controller *hose = &pci2_hose; - struct pci_region *r = hose->regions; - if (!(devdisr & MPC85xx_DEVDISR_PCI2)) { - pci_set_region(r++, - CONFIG_SYS_PCI2_MEM_BASE, - CONFIG_SYS_PCI2_MEM_PHYS, - CONFIG_SYS_PCI2_MEM_SIZE, - PCI_REGION_MEM); + SET_STD_PCI_INFO(pci_info[num], 2); + pci_agent = fsl_setup_hose(&pci2_hose, pci_info[num].regs);
- pci_set_region(r++, - CONFIG_SYS_PCI2_IO_BASE, - CONFIG_SYS_PCI2_IO_PHYS, - CONFIG_SYS_PCI2_IO_SIZE, - PCI_REGION_IO); - hose->region_count = r - hose->regions; - hose->first_busno=first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - first_free_busno=hose->last_busno+1; - printf ("PCI2 on bus %02x - %02x\n", - hose->first_busno,hose->last_busno); + puts (" PCI2\n"); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pci1_hose, first_free_busno); } else { printf (" PCI2: disabled\n"); } -} + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCI2; + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI2); /* disable */ #endif }
diff --git a/include/configs/ATUM8548.h b/include/configs/ATUM8548.h index 91369a7..49a86fd 100644 --- a/include/configs/ATUM8548.h +++ b/include/configs/ATUM8548.h @@ -243,27 +243,27 @@ */ #define CONFIG_SYS_PCI_PHYS 0x80000000 /* 1G PCI TLB */
-#define CONFIG_SYS_PCI1_MEM_BASE 0x80000000 -#define CONFIG_SYS_PCI1_MEM_PHYS CONFIG_SYS_PCI1_MEM_BASE +#define CONFIG_SYS_PCI1_MEM_BUS 0x80000000 +#define CONFIG_SYS_PCI1_MEM_PHYS CONFIG_SYS_PCI1_MEM_BUS #define CONFIG_SYS_PCI1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCI1_IO_BASE 0x00000000 +#define CONFIG_SYS_PCI1_IO_BUS 0x00000000 #define CONFIG_SYS_PCI1_IO_PHYS 0xe2000000 #define CONFIG_SYS_PCI1_IO_SIZE 0x00100000 /* 1M */
#ifdef CONFIG_PCI2 -#define CONFIG_SYS_PCI2_MEM_BASE 0xC0000000 -#define CONFIG_SYS_PCI2_MEM_PHYS CONFIG_SYS_PCI2_MEM_BASE +#define CONFIG_SYS_PCI2_MEM_BUS 0xC0000000 +#define CONFIG_SYS_PCI2_MEM_PHYS CONFIG_SYS_PCI2_MEM_BUS #define CONFIG_SYS_PCI2_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCI2_IO_BASE 0x00000000 +#define CONFIG_SYS_PCI2_IO_BUS 0x00000000 #define CONFIG_SYS_PCI2_IO_PHYS 0xe2800000 #define CONFIG_SYS_PCI2_IO_SIZE 0x00100000 /* 1M */ #endif
#ifdef CONFIG_PCIE1 -#define CONFIG_SYS_PCIE1_MEM_BASE 0xa0000000 -#define CONFIG_SYS_PCIE1_MEM_PHYS CONFIG_SYS_PCIE1_MEM_BASE +#define CONFIG_SYS_PCIE1_MEM_BUS 0xa0000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS CONFIG_SYS_PCIE1_MEM_BUS #define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_BASE 0x00000000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 #define CONFIG_SYS_PCIE1_IO_PHYS 0xe3000000 #define CONFIG_SYS_PCIE1_IO_SIZE 0x00100000 /* 1M */ #endif
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8548cds/mpc8548cds.c | 141 +++++++++++-------------------- 1 files changed, 48 insertions(+), 93 deletions(-)
diff --git a/board/freescale/mpc8548cds/mpc8548cds.c b/board/freescale/mpc8548cds/mpc8548cds.c index 73e7c21..38cbc8b 100644 --- a/board/freescale/mpc8548cds/mpc8548cds.c +++ b/board/freescale/mpc8548cds/mpc8548cds.c @@ -1,5 +1,5 @@ /* - * Copyright 2004, 2007 Freescale Semiconductor. + * Copyright 2004, 2007, 200 Freescale Semiconductor, Inc. * * (C) Copyright 2002 Scott McNutt smcnutt@artesyncp.com * @@ -262,62 +262,47 @@ static struct pci_controller pci2_hose; static struct pci_controller pcie1_hose; #endif /* CONFIG_PCIE1 */
-int first_free_busno=0; - -void -pci_init_board(void) +void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - uint io_sel = (gur->pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - uint host_agent = (gur->porbmsr & MPC85xx_PORBMSR_HA) >> 16; - - -#ifdef CONFIG_PCI1 -{ - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - struct pci_controller *hose = &pci1_hose; - struct pci_region *r = hose->regions; + struct fsl_pci_info pci_info[4]; + u32 devdisr, pordevsr, io_sel; + u32 porpllsr, pci_agent, pci_speed, pci_32, pci_arb, pci_clk_sel; + int first_free_busno = 0; + int num = 0;
- uint pci_32 = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_PCI32; /* PORDEVSR[15] */ - uint pci_arb = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; /* PORDEVSR[14] */ - uint pci_clk_sel = gur->porpllsr & MPC85xx_PORDEVSR_PCI1_SPD; /* PORPLLSR[16] */ + int pcie_ep, pcie_configured;
- uint pci_agent = is_fsl_pci_agent(LAW_TRGT_IF_PCI_1, host_agent); + devdisr = in_be32(&gur->devdisr); + pordevsr = in_be32(&gur->pordevsr); + porpllsr = in_be32(&gur->porpllsr); + io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19;
- uint pci_speed = get_clock_freq (); /* PCI PSPEED in [4:5] */ + debug (" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel);
- if (!(gur->devdisr & MPC85xx_DEVDISR_PCI1)) { - printf (" PCI: %d bit, %s MHz, %s, %s, %s\n", +#ifdef CONFIG_PCI1 + pci_speed = get_clock_freq (); /* PCI PSPEED in [4:5] */ + pci_32 = pordevsr & MPC85xx_PORDEVSR_PCI1_PCI32; /* PORDEVSR[15] */ + pci_arb = pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; + pci_clk_sel = porpllsr & MPC85xx_PORDEVSR_PCI1_SPD; + + if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { + SET_STD_PCI_INFO(pci_info[num], 1); + pci_agent = fsl_setup_hose(&pci1_hose, pci_info[num].regs); + printf ("\n PCI: %d bit, %s MHz, %s, %s, %s (base address %lx)\n", (pci_32) ? 32 : 64, (pci_speed == 33333000) ? "33" : (pci_speed == 66666000) ? "66" : "unknown", pci_clk_sel ? "sync" : "async", pci_agent ? "agent" : "host", - pci_arb ? "arbiter" : "external-arbiter" - ); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCI1_MEM_BUS, - CONFIG_SYS_PCI1_MEM_PHYS, - CONFIG_SYS_PCI1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCI1_IO_BUS, - CONFIG_SYS_PCI1_IO_PHYS, - CONFIG_SYS_PCI1_IO_SIZE, - PCI_REGION_IO); - hose->region_count = r - hose->regions; - - hose->first_busno=first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - first_free_busno=hose->last_busno+1; - printf ("PCI on bus %02x - %02x\n",hose->first_busno,hose->last_busno); + pci_arb ? "arbiter" : "external-arbiter", + pci_info[num].regs); + + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pci1_hose, first_free_busno); + #ifdef CONFIG_PCIX_CHECK - if (!(gur->pordevsr & MPC85xx_PORDEVSR_PCI1)) { + if (!(pordevsr & MPC85xx_PORDEVSR_PCI1)) { /* PCI-X init */ if (CONFIG_SYS_CLK_FREQ < 66000000) printf("PCI-X will only work at 66 MHz\n"); @@ -330,14 +315,15 @@ pci_init_board(void) } else { printf (" PCI: disabled\n"); } -} + + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCI1; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI1); /* disable */ #endif
#ifdef CONFIG_PCI2 { - uint pci2_clk_sel = gur->porpllsr & 0x4000; /* PORPLLSR[17] */ + uint pci2_clk_sel = porpllsr & 0x4000; /* PORPLLSR[17] */ uint pci_dual = get_pci_dual (); /* PCI DUAL in CM_PCI[3] */ if (pci_dual) { printf (" PCI2: 32 bit, 66 MHz, %s\n", @@ -347,60 +333,29 @@ pci_init_board(void) } } #else - gur->devdisr |= MPC85xx_DEVDISR_PCI2; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI2); /* disable */ #endif /* CONFIG_PCI2 */
- int pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel); - - if (pcie_configured && !(gur->devdisr & MPC85xx_DEVDISR_PCIE)){ - printf ("\n PCIE connected to slot as %s (base address %x)", - pcie_ep ? "End Point" : "Root Complex", - (uint)pci); - - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; - debug (" with errors. Clearing. Now 0x%08x",pci->pme_msg_det); - } - printf ("\n"); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_MEM_BUS, - CONFIG_SYS_PCIE1_MEM_PHYS, - CONFIG_SYS_PCIE1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_IO_BUS, - CONFIG_SYS_PCIE1_IO_PHYS, - CONFIG_SYS_PCIE1_IO_SIZE, - PCI_REGION_IO); - - hose->region_count = r - hose->regions; - - hose->first_busno=first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - printf ("PCIE on bus %d - %d\n",hose->first_busno,hose->last_busno); - - first_free_busno=hose->last_busno+1; + if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ + SET_STD_PCIE_INFO(pci_info[num], 1); + pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); + printf (" PCIE1 connected to Slot as %s (base addr %lx)\n", + pcie_ep ? "End Point" : "Root Complex", + pci_info[num].regs);
+ first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie1_hose, first_free_busno); } else { - printf (" PCIE: disabled\n"); + printf (" PCIE1: disabled\n"); } - } + + puts("\n"); #else - gur->devdisr |= MPC85xx_DEVDISR_PCIE; /* disable */ + setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCIE); /* disable */ #endif - }
int last_stage_init(void)
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8610hpcd/mpc8610hpcd.c | 199 +++++++++-------------------- 1 files changed, 62 insertions(+), 137 deletions(-)
diff --git a/board/freescale/mpc8610hpcd/mpc8610hpcd.c b/board/freescale/mpc8610hpcd/mpc8610hpcd.c index f42c316..2d4b9ad 100644 --- a/board/freescale/mpc8610hpcd/mpc8610hpcd.c +++ b/board/freescale/mpc8610hpcd/mpc8610hpcd.c @@ -1,5 +1,5 @@ /* - * Copyright 2007 Freescale Semiconductor, Inc. + * Copyright 2007,2009 Freescale Semiconductor, Inc. * * See file CREDITS for list of people who contributed to this * project. @@ -224,158 +224,83 @@ static struct pci_controller pcie1_hose; static struct pci_controller pcie2_hose; #endif
-int first_free_busno = 0; - void pci_init_board(void) { volatile immap_t *immap = (immap_t *) CONFIG_SYS_CCSRBAR; volatile ccsr_gur_t *gur = &immap->im_gur; - uint devdisr = gur->devdisr; - uint io_sel = (gur->pordevsr & MPC8610_PORDEVSR_IO_SEL) - >> MPC8610_PORDEVSR_IO_SEL_SHIFT; - uint host_agent = (gur->porbmsr & MPC8610_PORBMSR_HA) - >> MPC8610_PORBMSR_HA_SHIFT; + struct fsl_pci_info pci_info[3]; + u32 devdisr, pordevsr, io_sel; + int first_free_busno = 0; + int num = 0; + + int pci_agent, pcie_ep, pcie_configured; + + devdisr = in_be32(&gur->devdisr); + pordevsr = in_be32(&gur->pordevsr); + io_sel = (pordevsr & MPC8610_PORDEVSR_IO_SEL) + >> MPC8610_PORDEVSR_IO_SEL_SHIFT;
- printf( " pci_init_board: devdisr=%x, io_sel=%x, host_agent=%x\n", - devdisr, io_sel, host_agent); + debug (" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel);
#ifdef CONFIG_PCIE1 - { - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; - struct pci_controller *hose = &pcie1_hose; - int pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel); - int pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_1, host_agent); - struct pci_region *r = hose->regions; - - if (pcie_configured && !(devdisr & MPC86xx_DEVDISR_PCIE1)) { - printf(" PCIe 1 connected to Uli as %s (base address %x)\n", - pcie_ep ? "End Point" : "Root Complex", - (uint)pci); - if (pci->pme_msg_det) - pci->pme_msg_det = 0xffffffff; - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_MEM_BUS, - CONFIG_SYS_PCIE1_MEM_PHYS, - CONFIG_SYS_PCIE1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCIE1_IO_BUS, - CONFIG_SYS_PCIE1_IO_PHYS, - CONFIG_SYS_PCIE1_IO_SIZE, - PCI_REGION_IO); - - hose->region_count = r - hose->regions; - - hose->first_busno = first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - - first_free_busno = hose->last_busno + 1; - printf(" PCI-Express 1 on bus %02x - %02x\n", - hose->first_busno, hose->last_busno); - - } else - puts(" PCI-Express 1: Disabled\n"); - } -#else - puts("PCI-Express 1: Disabled\n"); -#endif /* CONFIG_PCIE1 */ + pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel); + + if (pcie_configured && !(devdisr & MPC86xx_DEVDISR_PCIE1)){ + SET_STD_PCIE_INFO(pci_info[num], 1); + pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); + printf (" PCIE1 connected to ULI as %s (base addr %lx)\n", + pcie_ep ? "End Point" : "Root Complex", + pci_info[num].regs); + + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie1_hose, first_free_busno); + } else { + printf (" PCIE1: disabled\n"); + }
+ puts("\n"); +#else + setbits_be32(&gur->devdisr, MPC86xx_DEVDISR_PCIE1); /* disable */ +#endif
#ifdef CONFIG_PCIE2 - { - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE2_ADDR; - struct pci_controller *hose = &pcie2_hose; - struct pci_region *r = hose->regions; - - int pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_2, io_sel); - int pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_2, host_agent); - - if (pcie_configured && !(devdisr & MPC86xx_DEVDISR_PCIE2)) { - printf(" PCI-Express 2 connected to slot as %s" \ - " (base address %x)\n", - pcie_ep ? "End Point" : "Root Complex", - (uint)pci); - if (pci->pme_msg_det) - pci->pme_msg_det = 0xffffffff; - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCIE2_MEM_BUS, - CONFIG_SYS_PCIE2_MEM_PHYS, - CONFIG_SYS_PCIE2_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCIE2_IO_BUS, - CONFIG_SYS_PCIE2_IO_PHYS, - CONFIG_SYS_PCIE2_IO_SIZE, - PCI_REGION_IO); - - hose->region_count = r - hose->regions; - - hose->first_busno = first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - - first_free_busno = hose->last_busno + 1; - printf(" PCI-Express 2 on bus %02x - %02x\n", - hose->first_busno, hose->last_busno); - } else - puts(" PCI-Express 2: Disabled\n"); - } -#else - puts("PCI-Express 2: Disabled\n"); -#endif /* CONFIG_PCIE2 */ + pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_2, io_sel); + + if (pcie_configured && !(devdisr & MPC86xx_DEVDISR_PCIE2)){ + SET_STD_PCIE_INFO(pci_info[num], 2); + pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); + printf (" PCIE2 connected to Slot as %s (base addr %lx)\n", + pcie_ep ? "End Point" : "Root Complex", + pci_info[num].regs); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pcie2_hose, first_free_busno); + } else { + printf (" PCIE2: disabled\n"); + }
+ puts("\n"); +#else + setbits_be32(&gur->devdisr, MPC86xx_DEVDISR_PCIE2); /* disable */ +#endif
#ifdef CONFIG_PCI1 - { - volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCI1_ADDR; - struct pci_controller *hose = &pci1_hose; - int pci_agent = is_fsl_pci_agent(LAW_TRGT_IF_PCI_1, host_agent); - struct pci_region *r = hose->regions; - - if ( !(devdisr & MPC86xx_DEVDISR_PCI1)) { + if (!(devdisr & MPC86xx_DEVDISR_PCI1)) { + SET_STD_PCI_INFO(pci_info[num], 1); + pci_agent = fsl_setup_hose(&pci1_hose, pci_info[num].regs); printf(" PCI connected to PCI slots as %s" \ - " (base address %x)\n", + " (base address %lx)\n", pci_agent ? "Agent" : "Host", - (uint)pci); - - /* outbound memory */ - pci_set_region(r++, - CONFIG_SYS_PCI1_MEM_BUS, - CONFIG_SYS_PCI1_MEM_PHYS, - CONFIG_SYS_PCI1_MEM_SIZE, - PCI_REGION_MEM); - - /* outbound io */ - pci_set_region(r++, - CONFIG_SYS_PCI1_IO_BUS, - CONFIG_SYS_PCI1_IO_PHYS, - CONFIG_SYS_PCI1_IO_SIZE, - PCI_REGION_IO); - - hose->region_count = r - hose->regions; - - hose->first_busno = first_free_busno; - - fsl_pci_init(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); - - first_free_busno = hose->last_busno + 1; - printf(" PCI on bus %02x - %02x\n", - hose->first_busno, hose->last_busno); - + pci_info[num].regs); + first_free_busno = fsl_pci_init_port(&pci_info[num++], + &pci1_hose, first_free_busno); + } else { + printf (" PCI: disabled\n"); + }
- } else - puts(" PCI: Disabled\n"); - } -#endif /* CONFIG_PCI1 */ + puts("\n"); +#else + setbits_be32(&gur->devdisr, MPC86xx_DEVDISR_PCI1); /* disable */ +#endif }
#if defined(CONFIG_OF_BOARD_SETUP)
We can use fsl_setup_hose to determine if we are a agent/end-point or a host. Rather than using some SoC specific register we can just look at the PCI cfg space of the host controller to determine this.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/mpc8572ds/mpc8572ds.c | 14 ++++++-------- 1 files changed, 6 insertions(+), 8 deletions(-)
diff --git a/board/freescale/mpc8572ds/mpc8572ds.c b/board/freescale/mpc8572ds/mpc8572ds.c index 933dd12..556846a 100644 --- a/board/freescale/mpc8572ds/mpc8572ds.c +++ b/board/freescale/mpc8572ds/mpc8572ds.c @@ -1,5 +1,5 @@ /* - * Copyright 2007-2008 Freescale Semiconductor, Inc. + * Copyright 2007-2009 Freescale Semiconductor, Inc. * * See file CREDITS for list of people who contributed to this * project. @@ -165,7 +165,7 @@ void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); struct fsl_pci_info pci_info[3]; - u32 devdisr, pordevsr, io_sel, host_agent, temp32; + u32 devdisr, pordevsr, io_sel, temp32; int first_free_busno = 0; int num = 0;
@@ -174,10 +174,8 @@ void pci_init_board(void) devdisr = in_be32(&gur->devdisr); pordevsr = in_be32(&gur->pordevsr); io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - host_agent = (in_be32(&gur->porbmsr) & MPC85xx_PORBMSR_HA) >> 16;
if (!(pordevsr & MPC85xx_PORDEVSR_SGMII1_DIS)) printf (" eTSEC1 is in sgmii mode.\n"); @@ -190,11 +188,11 @@ void pci_init_board(void)
puts("\n"); #ifdef CONFIG_PCIE3 - pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_3, host_agent); pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_3, io_sel);
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE3)){ SET_STD_PCIE_INFO(pci_info[num], 3); + pcie_ep = fsl_setup_hose(&pcie3_hose, pci_info[num].regs); printf (" PCIE3 connected to ULI as %s (base addr %lx)\n", pcie_ep ? "End Point" : "Root Complex", pci_info[num].regs); @@ -222,11 +220,11 @@ void pci_init_board(void) #endif
#ifdef CONFIG_PCIE2 - pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_2, host_agent); pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_2, io_sel);
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE2)){ SET_STD_PCIE_INFO(pci_info[num], 2); + pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); printf (" PCIE2 connected to Slot 1 as %s (base addr %lx)\n", pcie_ep ? "End Point" : "Root Complex", pci_info[num].regs); @@ -242,11 +240,11 @@ void pci_init_board(void) #endif
#ifdef CONFIG_PCIE1 - pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_1, host_agent); pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_1, io_sel);
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ SET_STD_PCIE_INFO(pci_info[num], 1); + pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); printf (" PCIE1 connected to Slot 2 as %s (base addr %lx)\n", pcie_ep ? "End Point" : "Root Complex", pci_info[num].regs);
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/p1_p2_rdb/pci.c | 10 ++++------ 1 files changed, 4 insertions(+), 6 deletions(-)
diff --git a/board/freescale/p1_p2_rdb/pci.c b/board/freescale/p1_p2_rdb/pci.c index 4c08f9e..6fd6963 100644 --- a/board/freescale/p1_p2_rdb/pci.c +++ b/board/freescale/p1_p2_rdb/pci.c @@ -43,7 +43,7 @@ void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); struct fsl_pci_info pci_info[2]; - u32 devdisr, pordevsr, io_sel, host_agent; + u32 devdisr, pordevsr, io_sel; int first_free_busno = 0; int num = 0;
@@ -52,21 +52,19 @@ void pci_init_board(void) devdisr = in_be32(&gur->devdisr); pordevsr = in_be32(&gur->pordevsr); io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - host_agent = (in_be32(&gur->porbmsr) & MPC85xx_PORBMSR_HA) >> 16;
if (!(pordevsr & MPC85xx_PORDEVSR_SGMII2_DIS)) printf (" eTSEC2 is in sgmii mode.\n");
puts("\n"); #ifdef CONFIG_PCIE2 - pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_2, host_agent); pcie_configured = is_fsl_pci_cfg(LAW_TRGT_IF_PCIE_2, io_sel);
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ SET_STD_PCIE_INFO(pci_info[num], 2); + pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); printf(" PCIE2 connected to Slot 1 as %s (base addr %lx)\n", pcie_ep ? "End Point" : "Root Complex", pci_info[num].regs); @@ -81,11 +79,11 @@ void pci_init_board(void) #endif
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)){ SET_STD_PCIE_INFO(pci_info[num], 1); + pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); printf(" PCIE1 connected to Slot 2 as %s (base addr %lx)\n", pcie_ep ? "End Point" : "Root Complex", pci_info[num].regs);
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/freescale/p2020ds/p2020ds.c | 12 +++++------- 1 files changed, 5 insertions(+), 7 deletions(-)
diff --git a/board/freescale/p2020ds/p2020ds.c b/board/freescale/p2020ds/p2020ds.c index e38c014..aecb7aa 100644 --- a/board/freescale/p2020ds/p2020ds.c +++ b/board/freescale/p2020ds/p2020ds.c @@ -197,7 +197,7 @@ void pci_init_board(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); struct fsl_pci_info pci_info[3]; - u32 devdisr, pordevsr, io_sel, host_agent; + u32 devdisr, pordevsr, io_sel; int first_free_busno = 0; int num = 0;
@@ -206,10 +206,8 @@ void pci_init_board(void) devdisr = in_be32(&gur->devdisr); pordevsr = in_be32(&gur->pordevsr); io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - host_agent = (in_be32(&gur->porbmsr) & MPC85xx_PORBMSR_HA) >> 16;
- debug(" pci_init_board: devdisr=%x, io_sel=%x, host_agent=%x\n", - devdisr, io_sel, host_agent); + debug (" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel);
if (!(pordevsr & MPC85xx_PORDEVSR_SGMII2_DIS)) printf(" eTSEC2 is in sgmii mode.\n"); @@ -218,11 +216,11 @@ void pci_init_board(void)
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE2)) { SET_STD_PCIE_INFO(pci_info[num], 2); + pcie_ep = fsl_setup_hose(&pcie2_hose, pci_info[num].regs); printf(" PCIE2 connected to ULI as %s (base addr %lx)\n", pcie_ep ? "End Point" : "Root Complex", pci_info[num].regs); @@ -258,11 +256,11 @@ void pci_init_board(void) #endif
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE3)) { SET_STD_PCIE_INFO(pci_info[num], 3); + pcie_ep = fsl_setup_hose(&pcie3_hose, pci_info[num].regs); printf(" PCIE3 connected to Slot 1 as %s (base addr %lx)\n", pcie_ep ? "End Point" : "Root Complex", pci_info[num].regs); @@ -277,11 +275,11 @@ void pci_init_board(void) #endif
if (pcie_configured && !(devdisr & MPC85xx_DEVDISR_PCIE)) { SET_STD_PCIE_INFO(pci_info[num], 1); + pcie_ep = fsl_setup_hose(&pcie1_hose, pci_info[num].regs); printf(" PCIE1 connected to Slot 2 as %s (base addr %lx)\n", pcie_ep ? "End Point" : "Root Complex", pci_info[num].regs);
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- board/tqc/tqm85xx/tqm85xx.c | 8 ++++---- 1 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/tqc/tqm85xx/tqm85xx.c b/board/tqc/tqm85xx/tqm85xx.c index 3931ec5..aa7827e 100644 --- a/board/tqc/tqm85xx/tqm85xx.c +++ b/board/tqc/tqm85xx/tqm85xx.c @@ -549,7 +549,6 @@ static inline void init_pci1(void) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #ifdef CONFIG_PCI1 - uint host_agent = (gur->porbmsr & MPC85xx_PORBMSR_HA) >> 16; volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *)CONFIG_SYS_PCI1_ADDR; struct pci_controller *hose = &pci1_hose; struct pci_region *r = hose->regions; @@ -561,7 +560,7 @@ static inline void init_pci1(void) /* PORPLLSR[16] */ uint pci_clk_sel = gur->porpllsr & MPC85xx_PORDEVSR_PCI1_SPD;
- uint pci_agent = is_fsl_pci_agent(LAW_TRGT_IF_PCI_1, host_agent); + int pci_agent = fsl_setup_hose(hose, CONFIG_SYS_PCI1_ADDR);
uint pci_speed = CONFIG_SYS_CLK_FREQ; /* PCI PSPEED in [4:5] */
@@ -626,14 +625,15 @@ static inline void init_pcie1(void) volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #ifdef CONFIG_PCIE1 uint io_sel = (gur->pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - uint host_agent = (gur->porbmsr & MPC85xx_PORBMSR_HA) >> 16; volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *)CONFIG_SYS_PCIE1_ADDR; struct pci_controller *hose = &pcie1_hose; - int pcie_ep = is_fsl_pci_agent(LAW_TRGT_IF_PCIE_1, host_agent); + int pcie_ep; struct pci_region *r = hose->regions;
+ pcie_ep = fsl_setup_hose(hose, CONFIG_SYS_PCIE1_ADDR); + if (pcie_configured && !(gur->devdisr & MPC85xx_DEVDISR_PCIE)){ printf ("PCIe: %s, base address %x", pcie_ep ? "End point" : "Root complex", (uint)pci);
All users of is_fsl_pci_agent have been converted to fsl_is_pci_agent that uses the standard PCI programming model to determine host vs agent/end-point.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- cpu/mpc8xxx/pci_cfg.c | 44 +++----------------------------------------- drivers/pci/fsl_pci_init.c | 9 +++++++++ include/asm-ppc/fsl_pci.h | 5 +++-- 3 files changed, 15 insertions(+), 43 deletions(-)
diff --git a/cpu/mpc8xxx/pci_cfg.c b/cpu/mpc8xxx/pci_cfg.c index ea129c5..d53781b 100644 --- a/cpu/mpc8xxx/pci_cfg.c +++ b/cpu/mpc8xxx/pci_cfg.c @@ -25,19 +25,14 @@ #include <pci.h>
struct pci_info { - u16 agent; u16 cfg; };
-/* The agent field is a bit mask in which each bit represents the value of - * cfg_host_agt[] signal and the bit is set of the given interface would be - * in agent/end-point mode for the given interface. - * - * The same idea is true of the cfg field. The bit will be set if the - * interface would be enabled based on the value of cfg_IO_ports[] signal +/* The cfg field is a bit mask in which each bit represents the value of + * cfg_IO_ports[] signal and the bit is set if the interface would be + * enabled based on the value of cfg_IO_ports[] signal * * On MPC86xx/PQ3 based systems: - * we extract cfg_host_agt from GUTS register PORBMSR * we extract cfg_IO_ports from GUTS register PORDEVSR * * cfg_IO_ports only exist on systems w/PCIe (we set cfg 0 for systems @@ -48,7 +43,6 @@ struct pci_info { static struct pci_info pci_config_info[] = { [LAW_TRGT_IF_PCI] = { - .agent = (1 << 0) | (1 << 2), .cfg = 0, }, }; @@ -56,7 +50,6 @@ static struct pci_info pci_config_info[] = static struct pci_info pci_config_info[] = { [LAW_TRGT_IF_PCI] = { - .agent = (1 << 0), .cfg = 0, }, }; @@ -64,19 +57,15 @@ static struct pci_info pci_config_info[] = static struct pci_info pci_config_info[] = { [LAW_TRGT_IF_PCI] = { - .agent = (1 << 6), .cfg = 0, }, [LAW_TRGT_IF_PCIE_1] = { - .agent = (1 << 5), .cfg = (1 << 2) | (1 << 3) | (1 << 5) | (1 << 7), }, [LAW_TRGT_IF_PCIE_2] = { - .agent = (1 << 3), .cfg = (1 << 5) | (1 << 7), }, [LAW_TRGT_IF_PCIE_3] = { - .agent = (1 << 1), .cfg = (1 << 7), }, }; @@ -84,20 +73,16 @@ static struct pci_info pci_config_info[] = static struct pci_info pci_config_info[] = { [LAW_TRGT_IF_PCI] = { - .agent = (1 << 6), .cfg = 0, }, [LAW_TRGT_IF_PCIE_1] = { - .agent = (1 << 5), .cfg = (1 << 2) | (1 << 3) | (1 << 4) | (1 << 5) | (1 << 6) | (1 << 7), }, [LAW_TRGT_IF_PCIE_2] = { - .agent = (1 << 3), .cfg = (1 << 4) | (1 << 5) | (1 << 6) | (1 << 7), }, [LAW_TRGT_IF_PCIE_3] = { - .agent = (1 << 1), .cfg = (1 << 6) | (1 << 7), }, }; @@ -105,16 +90,13 @@ static struct pci_info pci_config_info[] = static struct pci_info pci_config_info[] = { [LAW_TRGT_IF_PCI_1] = { - .agent = (1 << 4) | (1 << 6), .cfg = 0, }, [LAW_TRGT_IF_PCI_2] = { - .agent = (1 << 4) | (1 << 6), .cfg = 0, }, /* PCI_2 is always host and we dont use iosel to determine enable/disable */ [LAW_TRGT_IF_PCIE_1] = { - .agent = (1 << 0) | (1 << 2), .cfg = (1 << 3) | (1 << 4) | (1 << 7), }, }; @@ -122,11 +104,9 @@ static struct pci_info pci_config_info[] = static struct pci_info pci_config_info[] = { [LAW_TRGT_IF_PCI] = { - .agent = (1 << 0) | (1 << 4) | (1 << 6), .cfg = 0, }, [LAW_TRGT_IF_PCIE_1] = { - .agent = (1 << 0) | (1 << 2) | (1 << 4), .cfg = (1 << 3) | (1 << 4) | (1 << 7), }, }; @@ -134,7 +114,6 @@ static struct pci_info pci_config_info[] = static struct pci_info pci_config_info[] = { [LAW_TRGT_IF_PCIE_1] = { - .agent = (1 << 0) | (1 << 6), .cfg = (1 << 0) | (1 << 4) | (1 << 5) | (1 << 6) | (1 << 7) | (1 << 8) | (1 << 0xc) | (1 << 0xf), }, @@ -143,16 +122,13 @@ static struct pci_info pci_config_info[] = static struct pci_info pci_config_info[] = { [LAW_TRGT_IF_PCIE_1] = { - .agent = (1 << 0) | (1 << 1) | (1 << 4) | (1 << 5), .cfg = (1 << 2) | (1 << 3) | (1 << 7) | (1 << 0xb) | (1 << 0xc) | (1 << 0xf), }, [LAW_TRGT_IF_PCIE_2] = { - .agent = (1 << 0) | (1 << 2) | (1 << 4) | (1 << 6), .cfg = (1 << 3) | (1 << 7), }, [LAW_TRGT_IF_PCIE_3] = { - .agent = (1 << 0) | (1 << 3) | (1 << 5) | (1 << 6), .cfg = (1 << 7), }, }; @@ -160,15 +136,12 @@ static struct pci_info pci_config_info[] = static struct pci_info pci_config_info[] = { [LAW_TRGT_IF_PCI_1] = { - .agent = (1 << 4) | (1 << 5) | (1 << 6), .cfg = 0, }, [LAW_TRGT_IF_PCIE_1] = { - .agent = (1 << 0) | (1 << 2) | (1 << 5), .cfg = (1 << 1) | (1 << 4), }, [LAW_TRGT_IF_PCIE_2] = { - .agent = (1 << 0) | (1 << 1) | (1 << 4), .cfg = (1 << 0) | (1 << 4), }, }; @@ -176,7 +149,6 @@ static struct pci_info pci_config_info[] = static struct pci_info pci_config_info[] = { [LAW_TRGT_IF_PCIE_1] = { - .agent = 0, /* we dont use agent on 8641 */ .cfg = (1 << 2) | (1 << 3) | (1 << 5) | (1 << 6) | (1 << 7) | (1 << 0xe) | (1 << 0xf), }, @@ -185,11 +157,9 @@ static struct pci_info pci_config_info[] = static struct pci_info pci_config_info[] = { [LAW_TRGT_IF_PCIE_1] = { - .agent = (1 << 0) | (1 << 1), .cfg = (1 << 0) | (1 << 6) | (1 << 0xe) | (1 << 0xf), }, [LAW_TRGT_IF_PCIE_2] = { - .agent = (1 << 0) | (1 << 2), .cfg = (1 << 0xe), }, }; @@ -197,16 +167,13 @@ static struct pci_info pci_config_info[] = static struct pci_info pci_config_info[] = { [LAW_TRGT_IF_PCIE_1] = { - .agent = (1 << 0) | (1 << 1) | (1 << 4) | (1 << 5), .cfg = (1 << 0) | (1 << 2) | (1 << 4) | (1 << 6) | (1 << 0xd) | (1 << 0xe) | (1 << 0xf), }, [LAW_TRGT_IF_PCIE_2] = { - .agent = (1 << 0) | (1 << 2) | (1 << 4) | (1 << 6), .cfg = (1 << 2) | (1 << 0xe), }, [LAW_TRGT_IF_PCIE_3] = { - .agent = (1 << 0) | (1 << 3) | (1 << 5) | (1 << 6), .cfg = (1 << 2) | (1 << 4), }, }; @@ -216,11 +183,6 @@ static struct pci_info pci_config_info[] = #endif
#ifndef CONFIG_FSL_CORENET -int is_fsl_pci_agent(enum law_trgt_if trgt, u32 host_agent) -{ - return ((1 << host_agent) & pci_config_info[trgt].agent); -} - int is_fsl_pci_cfg(enum law_trgt_if trgt, u32 io_sel) { return ((1 << io_sel) & pci_config_info[trgt].cfg); diff --git a/drivers/pci/fsl_pci_init.c b/drivers/pci/fsl_pci_init.c index 170cc25..fe57926 100644 --- a/drivers/pci/fsl_pci_init.c +++ b/drivers/pci/fsl_pci_init.c @@ -86,6 +86,15 @@ static void set_inbound_window(volatile pit_t *pi, out_be32(&pi->piwar, flag | sz); }
+int fsl_setup_hose(struct pci_controller *hose, unsigned long addr) +{ + volatile ccsr_fsl_pci_t *pci = (ccsr_fsl_pci_t *) addr; + + pci_setup_indirect(hose, (u32)&pci->cfg_addr, (u32)&pci->cfg_data); + + return fsl_is_pci_agent(hose); +} + static int fsl_pci_setup_inbound_windows(struct pci_controller *hose, u64 out_lo, u8 pcie_cap, volatile pit_t *pi) diff --git a/include/asm-ppc/fsl_pci.h b/include/asm-ppc/fsl_pci.h index a5f72f5..db61e7e 100644 --- a/include/asm-ppc/fsl_pci.h +++ b/include/asm-ppc/fsl_pci.h @@ -1,4 +1,5 @@ -/* (C) Copyright 2007 Freescale Semiconductor, Inc. +/* + * Copyright 2007,2009 Freescale Semiconductor, Inc. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as @@ -22,9 +23,9 @@
#include <asm/fsl_law.h>
-int is_fsl_pci_agent(enum law_trgt_if trgt, u32 host_agent); int is_fsl_pci_cfg(enum law_trgt_if trgt, u32 io_sel);
+int fsl_setup_hose(struct pci_controller *hose, unsigned long addr); int fsl_is_pci_agent(struct pci_controller *hose); void fsl_pci_init(struct pci_controller *hose, u32 cfg_addr, u32 cfg_data); void fsl_pci_config_unlock(struct pci_controller *hose);
Kumar Gala
