[U-Boot-Users] [PATCH] notes on cpu/mips/config.mk
Hello,
I have a mips based board and during u-boot support developing I notice that in file «cpu/mips/config.mk»:
* should be replaced this line
-mips-linux-as --version|grep "GNU assembler"|awk '{print $$3}'|awk -F . '{print $$2}') +$(AS) --version|grep "GNU assembler"|awk '{print $$3}'|awk -F . '{print $$2}')
to avoid errors for user not having «mips-linux-as» (I have mipsel-linux-as).
* should be used «allow_branch_to_undefined» or «mips_allow_branch_to_undefined» as GAS option? My toolchain use «allow_branch_to_undefined»...
* Variable MIPSFLAGS is ambiguous, I suggest using MIPSCFLAGS and/or MIPSLDFLAGS.
In the end I suggest the following patch for file cpu/mips/config.mk:
Index: cpu/mips/config.mk =================================================================== RCS file: /home/develop/cvs_private/uboot-mips-exadron/cpu/mips/config.mk,v retrieving revision 1.1.1.1 diff -u -r1.1.1.1 config.mk --- a/cpu/mips/config.mk 16 Sep 2005 12:14:19 -0000 1.1.1.1 +++ b/cpu/mips/config.mk 16 Sep 2005 14:19:29 -0000 @@ -21,20 +21,22 @@ # MA 02111-1307 USA # v=$(shell \ -mips-linux-as --version|grep "GNU assembler"|awk '{print $$3}'|awk -F . '{print $$2}') -MIPSFLAGS=$(shell \ +$(AS) --version|grep "GNU assembler"|awk '{print $$3}'|awk -F . '{print $$2}') +MIPSCFLAGS=$(shell \ if [ "$v" -lt "14" ]; then \ echo "-mcpu=4kc"; \ else \ - echo "-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined"; \ + echo "-march=4kc -mtune=4kc -Wa,-allow_branch_to_undefined"; \ fi)
ifneq (,$(findstring 4KCle,$(CROSS_COMPILE))) -ENDIANNESS = -EL -else -ENDIANNESS = -EB +MIPSCFLAGS += -EL +endif +ifneq (,$(findstring mipsel,$(CROSS_COMPILE))) +MIPSLDFLAGS += -EL endif
-MIPSFLAGS += $(ENDIANNESS) -mabicalls +MIPSCFLAGS += -mabicalls
-PLATFORM_CPPFLAGS += $(MIPSFLAGS) +PLATFORM_CPPFLAGS += $(MIPSCFLAGS) +PLATFORM_LDFLAGS += $(MIPSLDFLAGS)
Ciao,
Rodolfo
Hi
Please, take a look at: http://sourceforge.net/mailarchive/message.php?msg_id=12736269
where we have already discussed about this (A new version of config.mk is also attached.)
- should be used «allow_branch_to_undefined» or
Mine too.
BR, Matej
Hi Rodolfo,
Hello,
OK
fi)
You removed any logical path by which "-EB" would be added to the flags. Your addition of the new flag variables is fine if it works, but it should not break the big endian code. Why don't you rework your patch to not break big endian support?
Chuck Meade The PTR Group
I don't think I'm breaking big endian support with my patch since if you have the ld command:
OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradlittlemips")
you say to the linker that your default endian is "big", please see:
info -f /usr/local/mipsel/info/ld.info -n "Format Commands"
So if you do not specify "-EB" nor "-EL" the linker will use default (big endian in the above example).
The following patch also fixes examples compilations:
Index: examples/mips.lds =================================================================== RCS file: /home/develop/cvs_private/uboot-mips-exadron/examples/mips.lds,v retrieving revision 1.1.1.1 retrieving revision 1.2 diff -u -r1.1.1.1 -r1.2 --- a/examples/mips.lds 16 Sep 2005 12:14:21 -0000 1.1.1.1 +++ b/examples/mips.lds 16 Sep 2005 15:05:08 -0000 1.2 @@ -24,7 +24,7 @@ /* OUTPUT_FORMAT("elf32-bigmips", "elf32-bigmips", "elf32-bigmips") */ -OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradbigmips") +OUTPUT_FORMAT("elf32-tradbigmips", "elf32-tradbigmips", "elf32-tradlittlemips") OUTPUT_ARCH(mips) SECTIONS {
Ciao,
Rodolfo
Hi Rodolfo,
Your patch removes ENDIANNESS from MIPSFLAGS. MIPSFLAGS affects more than just the linker. Your patch removes the -EB flag being sent to all tools that have MIPSFLAGS, including the compiler. Your patch also changes the use of MIPSFLAGS itself, so this may be hard for you to see.
Look at the file after you have applied your patch, and you will see that there is now absolutely no way that PLATFORM_CPPFLAGS would *ever* have "-EB" appended to it. That is what you have removed.
Mmm... I see what you mean. Option «-EB» is used also by the compiler... I thought it was a linker option only.
Ok, I'll fix better the code in my next patch since I'm working on removing «-mips_allow_branch_to_undefined» option from gas.
Thanks,
Rodolfo
Chuck Meade
Matej Kupljen
Rodolfo Giometti
