[U-Boot] [PATCH v5] efi_loader: console: Correctly report modes
Add support for EFI console modes. Mode 0 is always 80x25 and present by EFI specification. Mode 1 is always 80x50 and not mandatory. Mode 2 and above is freely usable.
If the terminal can handle mode 1, we mark it as supported. If the terminal size is greater than mode 0 and different than mode 1, we install it as mode 2.
Modes can be switch with cout_set_mode.
Changes in V5: Correctly detect mode before enabling mode 2.
Changes in V4: Reset cursor positon on mode switch Use local variables in console query code
Changes in V3: Valid mode are 0 to EFIMode-1 Fix style
Changes in V2: Add mode switch Report only the modes that we support
Signed-off-by: Emmanuel Vadot manu@bidouilliste.com --- lib/efi_loader/efi_console.c | 100 ++++++++++++++++++++++++++++++++++++------- 1 file changed, 84 insertions(+), 16 deletions(-)
diff --git a/lib/efi_loader/efi_console.c b/lib/efi_loader/efi_console.c index 2e0228c..8ef7326 100644 --- a/lib/efi_loader/efi_console.c +++ b/lib/efi_loader/efi_console.c @@ -9,11 +9,38 @@ #include <common.h> #include <efi_loader.h>
-/* If we can't determine the console size, default to 80x24 */ -static int console_columns = 80; -static int console_rows = 24; static bool console_size_queried;
+#define EFI_COUT_MODE_2 2 +#define EFI_MAX_COUT_MODE 3 + +struct cout_mode { + unsigned long columns; + unsigned long rows; + int present; +}; + +static struct cout_mode efi_cout_modes[] = { + /* EFI Mode 0 is 80x25 and always present */ + { + .columns = 80, + .rows = 25, + .present = 1, + }, + /* EFI Mode 1 is always 80x50 */ + { + .columns = 80, + .rows = 50, + .present = 0, + }, + /* Value are unknown until we query the console */ + { + .columns = 0, + .rows = 0, + .present = 0, + }, +}; + const efi_guid_t efi_guid_console_control = CONSOLE_CONTROL_GUID;
#define cESC '\x1b' @@ -56,8 +83,9 @@ const struct efi_console_control_protocol efi_console_control = { .lock_std_in = efi_cin_lock_std_in, };
+/* Default to mode 0 */ static struct simple_text_output_mode efi_con_mode = { - .max_mode = 0, + .max_mode = 1, .mode = 0, .attribute = 0, .cursor_column = 0, @@ -131,8 +159,10 @@ static efi_status_t EFIAPI efi_cout_output_string( struct efi_simple_text_output_protocol *this, const unsigned short *string) { + struct cout_mode *mode; u16 ch;
+ mode = &efi_cout_modes[efi_con_mode.mode]; EFI_ENTRY("%p, %p", this, string); for (;(ch = *string); string++) { print_unicode_in_utf8(ch); @@ -140,13 +170,12 @@ static efi_status_t EFIAPI efi_cout_output_string( if (ch == '\n') { efi_con_mode.cursor_column = 1; efi_con_mode.cursor_row++; - } else if (efi_con_mode.cursor_column > console_columns) { + } else if (efi_con_mode.cursor_column > mode->columns) { efi_con_mode.cursor_column = 1; efi_con_mode.cursor_row++; } - if (efi_con_mode.cursor_row > console_rows) { - efi_con_mode.cursor_row = console_rows; - } + if (efi_con_mode.cursor_row > mode->rows) + efi_con_mode.cursor_row = mode->rows; }
return EFI_EXIT(EFI_SUCCESS); @@ -160,6 +189,14 @@ static efi_status_t EFIAPI efi_cout_test_string( return EFI_EXIT(EFI_SUCCESS); }
+static bool cout_mode_matches(struct cout_mode *mode, int rows, int cols) +{ + if (!mode->present) + return false; + + return (mode->rows == rows) && (mode->columns == cols); +} + static efi_status_t EFIAPI efi_cout_query_mode( struct efi_simple_text_output_protocol *this, unsigned long mode_number, unsigned long *columns, @@ -170,6 +207,8 @@ static efi_status_t EFIAPI efi_cout_query_mode( if (!console_size_queried) { /* Ask the terminal about its size */ int n[3]; + int cols; + int rows; u64 timeout;
console_size_queried = true; @@ -191,15 +230,40 @@ static efi_status_t EFIAPI efi_cout_query_mode( goto out; }
- console_columns = n[2]; - console_rows = n[1]; + cols = n[2]; + rows = n[1]; + + /* Test if we can have Mode 1 */ + if (cols >= 80 && rows >= 50) { + efi_cout_modes[1].present = 1; + efi_con_mode.max_mode = 2; + } + + /* + * Install our mode as mode 2 if it is different + * than mode 0 or 1 and set it as the currently selected mode + */ + if (!cout_mode_matches(&efi_cout_modes[0], rows, cols) && + !cout_mode_matches(&efi_cout_modes[1], rows, cols)) { + efi_cout_modes[EFI_COUT_MODE_2].columns = cols; + efi_cout_modes[EFI_COUT_MODE_2].rows = rows; + efi_cout_modes[EFI_COUT_MODE_2].present = 1; + efi_con_mode.max_mode = EFI_MAX_COUT_MODE; + efi_con_mode.mode = EFI_COUT_MODE_2; + } }
+ if (mode_number >= efi_con_mode.max_mode) + return EFI_EXIT(EFI_UNSUPPORTED); + + if (efi_cout_modes[mode_number].present != 1) + return EFI_EXIT(EFI_UNSUPPORTED); + out: if (columns) - *columns = console_columns; + *columns = efi_cout_modes[mode_number].columns; if (rows) - *rows = console_rows; + *rows = efi_cout_modes[mode_number].rows;
return EFI_EXIT(EFI_SUCCESS); } @@ -210,11 +274,15 @@ static efi_status_t EFIAPI efi_cout_set_mode( { EFI_ENTRY("%p, %ld", this, mode_number);
- /* We only support text output for now */ - if (mode_number == EFI_CONSOLE_MODE_TEXT) - return EFI_EXIT(EFI_SUCCESS);
- return EFI_EXIT(EFI_UNSUPPORTED); + if (mode_number > efi_con_mode.max_mode) + return EFI_EXIT(EFI_UNSUPPORTED); + + efi_con_mode.mode = mode_number; + efi_con_mode.cursor_column = 0; + efi_con_mode.cursor_row = 0; + + return EFI_EXIT(EFI_SUCCESS); }
static efi_status_t EFIAPI efi_cout_set_attribute(
Emmanuel Vadot
