[U-Boot] [PATCH] ppc/85xx: Cleanup makefile and related optional files
Cleaned up cpu/mpc85xx/Makefile to use CONFIG_* for those obvious cases we have like PCI, CPM2, QE. Also reworked it to use one line per file for everything and sorted in alphabetical order.
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- cpu/mpc85xx/Makefile | 23 +++++++++++++++++------ cpu/mpc85xx/commproc.c | 3 --- cpu/mpc85xx/ether_fcc.c | 4 ---- cpu/mpc85xx/pci.c | 4 ++-- cpu/mpc85xx/serial_scc.c | 3 --- 5 files changed, 19 insertions(+), 18 deletions(-)
diff --git a/cpu/mpc85xx/Makefile b/cpu/mpc85xx/Makefile index 1bd8f30..a177f42 100644 --- a/cpu/mpc85xx/Makefile +++ b/cpu/mpc85xx/Makefile @@ -29,10 +29,10 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).a
START = start.o resetvec.o -SOBJS-$(CONFIG_MP) += release.o +SOBJS-$(CONFIG_MP) += release.o SOBJS = $(SOBJS-y) -COBJS-$(CONFIG_MP) += mp.o -COBJS-$(CONFIG_OF_LIBFDT) += fdt.o + +COBJS-$(CONFIG_CPM2) += commproc.o
# supports ddr1 COBJS-$(CONFIG_MPC8540) += ddr-gen1.o @@ -54,10 +54,21 @@ COBJS-$(CONFIG_P1020) += ddr-gen3.o COBJS-$(CONFIG_P2010) += ddr-gen3.o COBJS-$(CONFIG_P2020) += ddr-gen3.o
+COBJS-$(CONFIG_CPM2) += ether_fcc.o +COBJS-$(CONFIG_OF_LIBFDT) += fdt.o +COBJS-$(CONFIG_MP) += mp.o COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o -COBJS = traps.o cpu.o cpu_init.o speed.o interrupts.o tlb.o \ - pci.o serial_scc.o commproc.o ether_fcc.o qe_io.o \ - $(COBJS-y) +COBJS-$(CONFIG_PCI) += pci.o +COBJS-$(CONFIG_QE) += qe_io.o +COBJS-$(CONFIG_CPM2) += serial_scc.o + +COBJS = $(COBJS-y) +COBJS += cpu.o +COBJS += cpu_init.o +COBJS += interrupts.o +COBJS += speed.o +COBJS += tlb.o +COBJS += traps.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/cpu/mpc85xx/commproc.c b/cpu/mpc85xx/commproc.c index fff8dff..594aace 100644 --- a/cpu/mpc85xx/commproc.c +++ b/cpu/mpc85xx/commproc.c @@ -26,7 +26,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#if defined(CONFIG_CPM2) /* * because we have stack and init data in dual port ram * we must reduce the size @@ -204,5 +203,3 @@ ulong post_word_load (void) }
#endif /* CONFIG_POST */ - -#endif /* CONFIG_CPM2 */ diff --git a/cpu/mpc85xx/ether_fcc.c b/cpu/mpc85xx/ether_fcc.c index 32ad469..5f1414d 100644 --- a/cpu/mpc85xx/ether_fcc.c +++ b/cpu/mpc85xx/ether_fcc.c @@ -52,8 +52,6 @@ #include <miiphy.h> #endif
-#if defined(CONFIG_CPM2) - #if defined(CONFIG_ETHER_ON_FCC) && defined(CONFIG_CMD_NET) && \ defined(CONFIG_NET_MULTI)
@@ -469,5 +467,3 @@ int fec_initialize(bd_t *bis) }
#endif - -#endif /* CONFIG_CPM2 */ diff --git a/cpu/mpc85xx/pci.c b/cpu/mpc85xx/pci.c index fedf1a5..75d2716 100644 --- a/cpu/mpc85xx/pci.c +++ b/cpu/mpc85xx/pci.c @@ -29,7 +29,7 @@ #include <asm/cpm_85xx.h> #include <pci.h>
-#if defined(CONFIG_PCI) && !defined(CONFIG_FSL_PCI_INIT) +#if !defined(CONFIG_FSL_PCI_INIT)
#ifndef CONFIG_SYS_PCI1_MEM_BUS #define CONFIG_SYS_PCI1_MEM_BUS CONFIG_SYS_PCI1_MEM_BASE @@ -227,4 +227,4 @@ pci_mpc85xx_init(struct pci_controller *board_hose) hose->last_busno = pci_hose_scan(hose); #endif } -#endif /* CONFIG_PCI */ +#endif /* !CONFIG_FSL_PCI_INIT */ diff --git a/cpu/mpc85xx/serial_scc.c b/cpu/mpc85xx/serial_scc.c index 05fb808..2dab212 100644 --- a/cpu/mpc85xx/serial_scc.c +++ b/cpu/mpc85xx/serial_scc.c @@ -37,7 +37,6 @@
-#if defined(CONFIG_CPM2) #if defined(CONFIG_CONS_ON_SCC)
#if CONFIG_CONS_INDEX == 1 /* Console on SCC1 */ @@ -267,5 +266,3 @@ serial_tstc() }
#endif /* CONFIG_CONS_ON_SCC */ - -#endif /* CONFIG_CPM2 */
applied to 85xx
- k
Kumar Gala
