[U-Boot-Users] [PATCH] support for mainstone development board
Attached are files to add support for the Mainstone development board (PXA270 CPU). This work was based on the Lubbock module.
CHANGELOG: * Add support for the Mainstone development board Patch by Frank Agius, 26 Oct 2005
________________________________________ Frank Agius SAMSys Technologies, Inc.
Index: MAKEALL =================================================================== RCS file: /cvsroot/u-boot/u-boot/MAKEALL,v retrieving revision 1.128 diff -p -u -r1.128 MAKEALL --- MAKEALL 21 Oct 2005 20:39:10 -0000 1.128 +++ MAKEALL 26 Oct 2005 13:57:35 -0000 @@ -202,8 +202,8 @@ LIST_ARM11=" \
LIST_pxa=" \ adsvix cerf250 cradle csb226 \ - innokom lubbock pxa255_idp wepep250 \ - xaeniax xm250 xsengine \ + innokom lubbock mainstone pxa255_idp \ + wepep250 xaeniax xm250 xsengine \ "
LIST_ixp="ixdp425" Index: Makefile =================================================================== RCS file: /cvsroot/u-boot/u-boot/Makefile,v retrieving revision 1.212 diff -p -u -r1.212 Makefile --- Makefile 15 Oct 2005 17:08:09 -0000 1.212 +++ Makefile 26 Oct 2005 13:57:36 -0000 @@ -1601,6 +1601,9 @@ lubbock_config : unconfig logodl_config : unconfig @./mkconfig $(@:_config=) arm pxa logodl
+mainstone_config: unconfig + @./mkconfig $(@:_config=) arm pxa mainstone + pxa255_idp_config: unconfig @./mkconfig $(@:_config=) arm pxa pxa255_idp
Index: README =================================================================== RCS file: /cvsroot/u-boot/u-boot/README,v retrieving revision 1.138 diff -p -u -r1.138 README --- README 12 Oct 2005 23:47:18 -0000 1.138 +++ README 26 Oct 2005 13:57:37 -0000 @@ -308,9 +308,9 @@ The following options need to be configu CONFIG_H2_OMAP1610, CONFIG_HHP_CRADLE, CONFIG_IMPA7, CONFIG_INNOVATOROMAP1510, CONFIG_INNOVATOROMAP1610, CONFIG_KB9202, CONFIG_LART, CONFIG_LPD7A400, CONFIG_LUBBOCK, - CONFIG_OSK_OMAP5912, CONFIG_OMAP2420H4, CONFIG_SHANNON, - CONFIG_P2_OMAP730, CONFIG_SMDK2400, CONFIG_SMDK2410, - CONFIG_TRAB, CONFIG_VCMA9 + CONFIG_MAINSTONE, CONFIG_OSK_OMAP5912, CONFIG_OMAP2420H4, + CONFIG_SHANNON, CONFIG_P2_OMAP730, CONFIG_SMDK2400, + CONFIG_SMDK2410, CONFIG_TRAB, CONFIG_VCMA9
MicroBlaze based boards: ------------------------ Index: drivers/smc91111.c =================================================================== RCS file: /cvsroot/u-boot/u-boot/drivers/smc91111.c,v retrieving revision 1.19 diff -p -u -r1.19 smc91111.c --- drivers/smc91111.c 22 Nov 2004 22:20:09 -0000 1.19 +++ drivers/smc91111.c 26 Oct 2005 13:57:40 -0000 @@ -495,7 +495,15 @@ static void smc_enable() SMC_SELECT_BANK( 0 ); /* see the header file for options in TCR/RCR DEFAULT*/ SMC_outw( TCR_DEFAULT, TCR_REG ); +#ifdef CONFIG_SMC_PXA270 + /* The promiscuous bit set because I could not receive ARP reply + * packets from the server when I send a ARP request. It only works + * when I set the promiscuous bit + */ + SMC_outw( RCR_DEFAULT | RCR_PRMS, RCR_REG ); +#else SMC_outw( RCR_DEFAULT, RCR_REG ); +#endif
/* clear MII_DIS */ /* smc_write_phy_register(PHY_CNTL_REG, 0x0000); */ @@ -529,7 +537,6 @@ static void smc_shutdown() SMC_outb( TCR_CLEAR, TCR_REG ); }
- /* . Function: smc_hardware_send_packet(struct net_device * ) . Purpose: @@ -640,7 +647,7 @@ again: }
/* we have a packet address, so tell the card to use it */ -#ifndef CONFIG_XAENIAX +#ifndef SMC_WRITE_32 SMC_outb (packet_no, PN_REG); #else /* On Xaeniax board, we can't use SMC_outb here because that way @@ -654,7 +661,11 @@ again: printf ("Write data fifo not empty!\n");
/* point to the beginning of the packet */ +#ifndef CONFIG_SMC_PXA270 SMC_outw (PTR_AUTOINC, PTR_REG); +#else + SMC_outl (PTR_AUTOINC <<16, PTR_REG-2); +#endif
PRINTK3 ("%s: Trying to xmit packet of length %x\n", SMC_DEV_NAME, length); @@ -683,7 +694,7 @@ again: */ #ifdef USE_32_BIT SMC_outsl (SMC91111_DATA_REG, buf, length >> 2); -#ifndef CONFIG_XAENIAX +#ifndef SMC_WRITE_32 if (length & 0x2) SMC_outw (*((word *) (buf + (length & 0xFFFFFFFC))), SMC91111_DATA_REG); @@ -708,7 +719,7 @@ again: SMC_outsw (SMC91111_DATA_REG, buf, (length) >> 1); #endif /* USE_32_BIT */
-#ifndef CONFIG_XAENIAX +#ifndef CONFIG_SMC_WRITE_32 /* Send the last byte, if there is one. */ if ((length & 1) == 0) { SMC_outw (0, SMC91111_DATA_REG); @@ -716,7 +727,6 @@ again: SMC_outw (buf[length - 1] | 0x2000, SMC91111_DATA_REG); } #endif - /* and let the chipset deal with it */ SMC_outw (MC_ENQUEUE, MMU_CMD_REG);
@@ -729,7 +739,7 @@ again:
/* release packet */ /* no need to release, MMU does that now */ -#ifdef CONFIG_XAENIAX +#ifdef SMC_WRITE_32 SMC_outw (MC_FREEPKT, MMU_CMD_REG); #endif
@@ -743,6 +753,24 @@ again:
return 0; } else { +#ifdef USE_32_BIT + /* ack. int */ + status = SMC_inb (SMC91111_INT_REG); + if (status & IM_TX_INT ) + { + SMC_outb (IM_TX_INT, SMC91111_INT_REG); + } + status = SMC_inb (SMC91111_INT_REG); + if (status & IM_TX_EMPTY_INT ) + SMC_outb (IM_TX_EMPTY_INT, SMC91111_INT_REG); + PRINTK2 ("%s: Sent packet of length %d, int status=0x%08x \n", SMC_DEV_NAME, length, status); + + /* release packet */ + /* auto release now set, no need to release the tx packet + * manually + SMC_outb (LAN91C96_MMUCR_RELEASE_TX, LAN91C96_MMU); + */ +#else /* ack. int */ SMC_outb (IM_TX_EMPTY_INT, SMC91111_INT_REG); /* SMC_outb (IM_TX_INT, SMC91111_INT_REG); */ @@ -751,10 +779,10 @@ again:
/* release packet */ /* no need to release, MMU does that now */ -#ifdef CONFIG_XAENIAX +#ifdef SMC_WRITE_32 SMC_outw (MC_FREEPKT, MMU_CMD_REG); #endif - +#endif /* wait for MMU getting ready (low) */ while (SMC_inw (MMU_CMD_REG) & MC_BUSY) { udelay (10); @@ -766,7 +794,7 @@ again: }
/* restore previously saved registers */ -#ifndef CONFIG_XAENIAX +#ifndef SMC_WRITE_32 SMC_outb( saved_pnr, PN_REG ); #else /* On Xaeniax board, we can't use SMC_outb here because that way @@ -805,7 +833,13 @@ void smc_destructor() */ static int smc_open (bd_t * bd) { - int i, err; + int err; +#ifdef CONFIG_SMC_PXA270 + long addr0_3; + word addr4_5; +#else + int i; +#endif
PRINTK2 ("%s: smc_open\n", SMC_DEV_NAME);
@@ -828,6 +862,18 @@ static int smc_open (bd_t * bd) memset (bd->bi_enetaddr, 0, 6); /* hack to make error stick! upper code will abort if not set */ return (-1); /* upper code ignores this, but NOT bi_enetaddr */ } +#ifdef CONFIG_SMC_PXA270 + /* writes must be on a 32 bit boundary. write first 4 bytes of mac addr, + * then the last 2 bytes. + */ + addr0_3 = smc_mac_addr[3]<<24 | smc_mac_addr[2]<<16 | smc_mac_addr[1] <<8 | smc_mac_addr[0]; + /* write first 4 bytes. write address should be on a 32 bit boundary */ + SMC_outl (addr0_3, ADDR0_REG); + addr4_5 = smc_mac_addr[5]<<8 | smc_mac_addr[4]; + PRINTK2("writing smc_mac_addr=0x%06x%x\n",addr0_3,addr4_5); + /* write last 2 bytes. write address should be on a 32 bit boundary */ + SMC_outw (addr4_5, ADDR0_REG+4); +#else #ifdef USE_32_BIT for (i = 0; i < 6; i += 2) { word address; @@ -840,7 +886,7 @@ static int smc_open (bd_t * bd) for (i = 0; i < 6; i++) SMC_outb (smc_mac_addr[i], (ADDR0_REG + i)); #endif - +#endif /* end CONFIG_SMC_PXA270 */ return 0; }
@@ -882,7 +928,12 @@ static int smc_rcv()
PRINTK3("%s: smc_rcv\n", SMC_DEV_NAME); /* start reading from the start of the packet */ +#ifndef CONFIG_SMC_PXA270 SMC_outw( PTR_READ | PTR_RCV | PTR_AUTOINC, PTR_REG ); +#else + SMC_outl ((PTR_READ | PTR_RCV | + PTR_AUTOINC)<<16, 4); +#endif
/* First two words are status and packet_length */ #ifdef USE_32_BIT @@ -952,7 +1003,7 @@ static int smc_rcv() udelay(1); /* Wait until not busy */
/* restore saved registers */ -#ifndef CONFIG_XAENIAX +#ifndef SMC_WRITE_32 SMC_outb( saved_pnr, PN_REG ); #else /* On Xaeniax board, we can't use SMC_outb here because that way @@ -1381,7 +1432,11 @@ static void smc_phy_configure ()
/* Configure the Receive/Phy Control register */ SMC_SELECT_BANK (0); +#ifdef CONFIG_SMC_PXA270 + SMC_outl (RPC_DEFAULT<<16, RPC_REG-2); +#else SMC_outw (RPC_DEFAULT, RPC_REG); +#endif
/* Copy our capabilities from PHY_STAT_REG to PHY_AD_REG */ my_phy_caps = smc_read_phy_register (PHY_STAT_REG); @@ -1459,7 +1514,11 @@ static void smc_phy_configure () }
/* Re-Configure the Receive/Phy Control register */ +#ifdef CONFIG_SMC_PXA270 + SMC_outl (RPC_DEFAULT<<16, RPC_REG-2); +#else SMC_outw (RPC_DEFAULT, RPC_REG); +#endif
smc_phy_configure_exit: ;
Index: drivers/smc91111.h =================================================================== RCS file: /cvsroot/u-boot/u-boot/drivers/smc91111.h,v retrieving revision 1.11 diff -p -u -r1.11 smc91111.h --- drivers/smc91111.h 2 Nov 2004 13:00:56 -0000 1.11 +++ drivers/smc91111.h 26 Oct 2005 13:57:41 -0000 @@ -74,7 +74,12 @@ typedef unsigned long int dword;
#define SMC_IO_EXTENT 16
-#ifdef CONFIG_PXA250 +/* XANEIAX and other boards can only do 32-bit writes */ +#if defined (CONFIG_XAENIX) || defined (CONFIG_SMC_PXA270) +#define SMC_WRITE_32 +#endif + +#if defined (CONFIG_PXA250) || defined (CONFIG_PXA27X)
#ifdef CONFIG_XSENGINE #define SMC_inl(r) (*((volatile dword *)(SMC_BASE_ADDRESS+(r<<1)))) @@ -176,7 +181,7 @@ typedef unsigned long int dword; }; \ })
-#else /* if not CONFIG_PXA250 */ +#else /* if not (CONFIG_PXA250 || CONFIG_PXA27X) */
#ifndef CONFIG_SMC_USE_IOFUNCS /* these macros don't work on some boards */ /* @@ -678,8 +683,11 @@ enum {
/* select a register bank, 0 to 3 */ - +#ifdef CONFIG_SMC_PXA270 +#define SMC_SELECT_BANK(x) { SMC_outl( (x)<<16, 12 ); } +#else #define SMC_SELECT_BANK(x) { SMC_outw( x, BANK_SELECT ); } +#endif
/* this enables an interrupt in the interrupt mask register */ #define SMC_ENABLE_INT(x) {\
Frank Agius
