How to add eth1 to test device tree?
Hi All,
When running the sandbox tests, I want to know how to enable eth1 in order to be able to test network features.
The following command is used to run sandbox tests.
./test/py/test.py -k testname.py
I am specifically interested in running the network tests.
./test/py/test.py -k test_net.py
These Python tests use test.dts device tree which does not have eth1 in it. I can replace the test.dts file with sandbox.dts to enable eth1 and run the network tests; however, I think there should be a better way to do it.
Can anyone help me with this issue?
When running U-Boot, the -T option could be used to tell it to use the test.dts or -D to use sandbox.dts; however, there is no such option when running test.py.
Eth1 is needed in order to enable the network. Enabling the sandbox network is explained after line 250 in doc/arch/sandbox.rst.
For more information, the following is the list of network interfaces when each device tree is used.
*arch/sandbox/dts/sandbox.dts** *Net: eth0: host_lo, *eth1: host_eth0*, eth2: host_br1, eth3: eth@10002000
*arch/sandbox/dts/test.dts*
Net: eth0: eth@10002000, eth5: eth@10003000, eth3: sbe5, eth6: eth@10004000, eth4: dsa-test-eth, eth2: lan0, eth7: lan1
Hi Ehsan,
On Tue, 28 Mar 2023 at 08:58, Ehsan Mohandesi emohandesi@linux.microsoft.com wrote:
Hi All,
You should write tests in C where possible. See [1].
If you are just trying to try something out locally, then you can run a sandbox test without Python. See [2]. You can use the -D flag as usual. Of course you can't
Network tests should generate their own traffic and check it internally, rather than relying on the real network features of the host machine. You can see test/dm/eth.c for that
For local hacking you can change u_boot_console_sandbox.py.get_spawn() to pass -D instead of the -d xxx it currently does.
So it depends on what you are trying to do.
[1] https://u-boot.readthedocs.io/en/latest/develop/tests_writing.html [2] https://u-boot.readthedocs.io/en/latest/develop/tests_sandbox.html#running-s...
Ehsan Mohandesi
