[U-Boot] [PATCH] SMDK5250: Remove reduntant code
enum boot_mode is defined twice once in spl.h and also in spl_boot.c, hence removing the same from spl_boot.c and including the header file.
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- arch/arm/include/asm/arch-exynos/spl.h | 1 + board/samsung/smdk5250/spl_boot.c | 10 +--------- 2 files changed, 2 insertions(+), 9 deletions(-)
diff --git a/arch/arm/include/asm/arch-exynos/spl.h b/arch/arm/include/asm/arch-exynos/spl.h index 46b25a6..59bb7e0 100644 --- a/arch/arm/include/asm/arch-exynos/spl.h +++ b/arch/arm/include/asm/arch-exynos/spl.h @@ -32,6 +32,7 @@ enum boot_mode { * pin values are the same across Exynos4 and Exynos5. */ BOOT_MODE_MMC = 4, + BOOT_MODE_EMMC = 8, /* EMMC4.4 */ BOOT_MODE_SERIAL = 20, /* Boot based on Operating Mode pin settings */ BOOT_MODE_OM = 32, diff --git a/board/samsung/smdk5250/spl_boot.c b/board/samsung/smdk5250/spl_boot.c index 98f2286..83275f1 100644 --- a/board/samsung/smdk5250/spl_boot.c +++ b/board/samsung/smdk5250/spl_boot.c @@ -26,6 +26,7 @@ #include <asm/arch-exynos/dmc.h> #include <asm/arch/clock.h> #include <asm/arch/clk.h> +#include <asm/arch/spl.h>
#include "clock_init.h"
@@ -48,15 +49,6 @@ u32 irom_ptr_table[] = { [USB_INDEX] = 0x02020070, /* iROM Function Pointer-USB boot*/ };
-enum boot_mode { - BOOT_MODE_MMC = 4, - BOOT_MODE_SERIAL = 20, - BOOT_MODE_EMMC = 8, /* EMMC4.4 */ - /* Boot based on Operating Mode pin settings */ - BOOT_MODE_OM = 32, - BOOT_MODE_USB, /* Boot using USB download */ -}; - void *get_irom_func(int index) { return (void *)*(u32 *)irom_ptr_table[index];
On Tue, Jun 25, 2013 at 6:47 AM, Rajeshwari Shinde <rajeshwari.s@samsung.com
Hi Minkyu,
Please do let me know your coments on the same. If no comments can we get this patch merged.
- BOOT_MODE_EMMC = 8, /* EMMC4.4 */ BOOT_MODE_SERIAL = 20, /* Boot based on Operating Mode pin settings */ BOOT_MODE_OM = 32,
-enum boot_mode {
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Minkyu Kang
Rajeshwari Birje
Rajeshwari Shinde
