Hi There
I added some new commands to the TPM2 command to allow read/writes to nv_memory. I also implemented the nv_define and nv_undefine commands so spaces can be created/deleted. Still need to test with PCR policies, but at least for now we can store values in the TPM.
Here's the patch:
Signed-off-by: Niek Nooijens niek.nooijens@omron.com ================BEGIN OF PATCH============== diff --git a/cmd/tpm-v2.c b/cmd/tpm-v2.c index d93b83ada9..d2a06b9f65 100644 --- a/cmd/tpm-v2.c +++ b/cmd/tpm-v2.c @@ -356,6 +356,133 @@ static int do_tpm_pcr_setauthvalue(struct cmd_tbl *cmdtp, int flag, key, key_sz)); }
+static int do_tpm_nv_define(struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) +{ + struct udevice *dev; + struct tpm_chip_priv *priv; + u32 nv_addr, nv_size,nv_attributes, rc; + void *policy_addr = NULL; + size_t policy_size = 0; + int ret; + + nv_attributes = 0; + + if ((argc < 3 && argc > 6) || argc == 4) + return CMD_RET_USAGE; + + ret = get_tpm(&dev); + if (ret) + return ret; + + priv = dev_get_uclass_priv(dev); + if (!priv) + return -EINVAL; + + nv_addr = simple_strtoul(argv[1], NULL, 0); //tpm_addr + + nv_size = simple_strtoul(argv[2], NULL, 0); //size + + if(argc > 3) { //attributes + nv_attributes = simple_strtoul(argv[3], NULL, 0); + } else { + nv_attributes = TPMA_NV_PLATFORMCREATE|TPMA_NV_OWNERWRITE|TPMA_NV_OWNERREAD|TPMA_NV_PPWRITE|TPMA_NV_PPREAD; + } + + if(argc > 4) {//policy + policy_addr = map_sysmem(simple_strtoul(argv[4], NULL, 0), 0); + if((nv_attributes & (TPMA_NV_POLICYREAD|TPMA_NV_POLICYWRITE)) == 0) { //not sure if I should enforce this or just warn the user? + printf("Warning: policy provided, but TPMA_NV_POLICYREAD and TPMA_NV_POLICYWRITE are NOT set!\n"); + } + policy_size = simple_strtoul(argv[5], NULL, 0); + } + + rc = tpm2_nv_define_space(dev, nv_addr, nv_size, nv_attributes,policy_addr, policy_size); + + if (rc) { + printf("ERROR: nv_define #%u returns: 0x%x\n", nv_addr, rc); + } + if(argc > 4) { + unmap_sysmem(policy_addr); + } + return report_return_code(rc); +} + +static int do_tpm_nv_undefine(struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) +{ + struct udevice *dev; + u32 nv_addr,ret, rc; + + ret = get_tpm(&dev); + if (ret) + return ret; + + if (argc !=2) + return CMD_RET_USAGE; + nv_addr = simple_strtoul(argv[1], NULL, 0); //tpm_addr + rc = tpm2_nv_undefine_space(dev, nv_addr); + + return report_return_code(rc); +} + +static int do_tpm_nv_read_value(struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) +{ + struct udevice *dev; + u32 nv_addr, nv_size, rc; + int ret; + void *out_data; + ret = get_tpm(&dev); + if (ret) + return ret; + + if (argc != 4) + return CMD_RET_USAGE; + + nv_addr = simple_strtoul(argv[1], NULL, 0); //tpm_addr + + nv_size = simple_strtoul(argv[2], NULL, 0); //size + + out_data = map_sysmem(simple_strtoul(argv[3], NULL, 0), 0); + + rc = tpm2_nv_read_value(dev,nv_addr, out_data, nv_size); + + if (rc) { + printf("ERROR: nv_read #%u returns: #%u\n", nv_addr, rc); + } + unmap_sysmem(out_data); + return report_return_code(rc); +} + +static int do_tpm_nv_write_value(struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) +{ + struct udevice *dev; + u32 nv_addr, nv_size, rc; + int ret; + ret = get_tpm(&dev); + if (ret) + return ret; + + if (argc != 4) + return CMD_RET_USAGE; + + nv_addr = simple_strtoul(argv[1], NULL, 0); //tpm_addr + + nv_size = simple_strtoul(argv[2], NULL, 0); //size + + void *data_to_write = map_sysmem(simple_strtoul(argv[3], NULL, 0), 0); + + rc = tpm2_nv_write_value(dev,nv_addr, data_to_write, nv_size); + + if (rc) { + printf("ERROR: nv_read #%u returns: #%u\n", nv_addr, rc); + } + unmap_sysmem(data_to_write); + return report_return_code(rc); +} + static struct cmd_tbl tpm2_commands[] = { U_BOOT_CMD_MKENT(device, 0, 1, do_tpm_device, "", ""), U_BOOT_CMD_MKENT(info, 0, 1, do_tpm_info, "", ""), @@ -374,6 +501,10 @@ static struct cmd_tbl tpm2_commands[] = { do_tpm_pcr_setauthpolicy, "", ""), U_BOOT_CMD_MKENT(pcr_setauthvalue, 0, 1, do_tpm_pcr_setauthvalue, "", ""), + U_BOOT_CMD_MKENT(nv_define, 0, 1, do_tpm_nv_define, "", ""), + U_BOOT_CMD_MKENT(nv_undefine, 0, 1, do_tpm_nv_undefine, "", ""), + U_BOOT_CMD_MKENT(nv_read, 0, 1, do_tpm_nv_read_value, "", ""), + U_BOOT_CMD_MKENT(nv_write, 0, 1, do_tpm_nv_write_value, "", ""), };
struct cmd_tbl *get_tpm2_commands(unsigned int *size) @@ -447,4 +578,22 @@ U_BOOT_CMD(tpm2, CONFIG_SYS_MAXARGS, 1, do_tpm, "Issue a TPMv2.x command", " <pcr>: index of the PCR\n" " <key>: secret to protect the access of PCR #<pcr>\n" " <password>: optional password of the PLATFORM hierarchy\n" +"\n" +"nv_define <tpm_addr> <size> [<attributes>, <policy_digest_addr> <policy_size>]\n" +" Define new nv index in the TPM at <tpm_addr> with size <size>\n" +" <tpm_addr>: the internal address used within the TPM for the NV-index\n" +" <attributes>: is described in tpp-v2.h enum tpm_index_attrs. Note; Always use TPMA_NV_PLATFORMCREATE!\n" +" will default to: TPMA_NV_PLATFORMCREATE|TPMA_NV_OWNERWRITE|TPMA_NV_OWNERREAD|TPMA_NV_PPWRITE|TPMA_NV_PPREAD\n" +"nv_undefine <tpm_addr> \n" +" delete nv index \n" +"nv_read <tpm_addr> <size> <data_addr>\n" +" Read data stored in TPM nv_memory at <tpm_addr> with size <size>\n" +" <tpm_addr>: the internal address used within the TPM for the NV-index\n" +" <size>: datasize in bytes\n" +" <data_addr>: memory address where to store the data read from the TPM\n" +"nv_write <tpm_addr> <size> <data_addr> [<policy_digest_addr> <policy_size>]\n" +" Write data to the TPM's nv_memory at <tpm_addr> with size <size>\n" +" <tpm_addr>: the internal address used within the TPM for the NV-index\n" +" <size>: datasize in bytes\n" +" <data_addr>: memory address of the data to be written to the TPM's NV-index\n" ); diff --git a/include/tpm-v2.h b/include/tpm-v2.h index 737e57551d..b9801e91eb 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -214,6 +214,7 @@ struct tcg_pcr_event2 { u8 event[]; } __packed;
+ /** * TPM2 Structure Tags for command/response buffers. * @@ -286,6 +287,7 @@ enum tpm2_command_codes { TPM2_CC_CLEARCONTROL = 0x0127, TPM2_CC_HIERCHANGEAUTH = 0x0129, TPM2_CC_NV_DEFINE_SPACE = 0x012a, + TPM2_CC_NV_UNDEFINE_SPACE = 0x0122, TPM2_CC_PCR_SETAUTHPOL = 0x012C, TPM2_CC_NV_WRITE = 0x0137, TPM2_CC_NV_WRITELOCK = 0x0138, @@ -469,6 +471,20 @@ u32 tpm2_nv_define_space(struct udevice *dev, u32 space_index, size_t space_size, u32 nv_attributes, const u8 *nv_policy, size_t nv_policy_size);
+ + + +/** + * Issue a TPM_NV_UnDefineSpace command + * + * This allows a space to be removed. Needed because TPM_clear doesn't clear platform entries + * + * @dev TPM device + * @space_index index of the area + * Return: return code of the operation + */ +u32 tpm2_nv_undefine_space(struct udevice *dev, u32 space_index); + /** * Issue a TPM2_PCR_Extend command. * @@ -494,6 +510,7 @@ u32 tpm2_pcr_extend(struct udevice *dev, u32 index, u32 algorithm, */ u32 tpm2_nv_read_value(struct udevice *dev, u32 index, void *data, u32 count);
+ /** * Write data to the secure storage * diff --git a/lib/tpm-common.c b/lib/tpm-common.c index 82ffdc5341..fbb78a941f 100644 --- a/lib/tpm-common.c +++ b/lib/tpm-common.c @@ -3,7 +3,7 @@ * Copyright (c) 2013 The Chromium OS Authors. * Coypright (c) 2013 Guntermann & Drunck GmbH */ - +#define LOG_DEBUG #define LOG_CATEGORY UCLASS_TPM
#include <common.h> @@ -13,6 +13,8 @@ #include <tpm-common.h> #include "tpm-utils.h"
+ + enum tpm_version tpm_get_version(struct udevice *dev) { struct tpm_chip_priv *priv = dev_get_uclass_priv(dev); diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index 697b982e07..9df3968033 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -90,7 +90,7 @@ u32 tpm2_nv_define_space(struct udevice *dev, u32 space_index, * chunks below. */ const int platform_len = sizeof(u32); - const int session_hdr_len = 13; + const int session_hdr_len = 15; const int message_len = 14; uint offset = TPM2_HDR_LEN + platform_len + session_hdr_len + message_len; @@ -103,11 +103,15 @@ u32 tpm2_nv_define_space(struct udevice *dev, u32 space_index, /* handles 4 bytes */ tpm_u32(TPM2_RH_PLATFORM), /* Primary platform seed */
- /* session header 13 bytes */ + + /* session header 15 bytes */ + /*null auth session*/ tpm_u32(9), /* Header size */ tpm_u32(TPM2_RS_PW), /* Password authorisation */ tpm_u16(0), /* nonce_size */ 0, /* session_attrs */ + tpm_u16(0), /* HMAC size */ + /*end auth area*/ tpm_u16(0), /* auth_size */
/* message 14 bytes + policy */ @@ -136,6 +140,35 @@ u32 tpm2_nv_define_space(struct udevice *dev, u32 space_index, return tpm_sendrecv_command(dev, command_v2, NULL, NULL); }
+u32 tpm2_nv_undefine_space(struct udevice *dev, u32 space_index) { + + const int platform_len = sizeof(u32); + const int session_hdr_len = 13; + const int message_len = 4; + u8 command_v2[COMMAND_BUFFER_SIZE] = { + /* header 10 bytes */ + tpm_u16(TPM2_ST_SESSIONS), /* TAG */ + tpm_u32(TPM2_HDR_LEN + platform_len + session_hdr_len + + message_len),/* Length - header + provision + index + auth area*/ + tpm_u32(TPM2_CC_NV_UNDEFINE_SPACE),/* Command code */ + + /* handles 4 bytes */ + tpm_u32(TPM2_RH_PLATFORM), /* Primary platform seed */ + /* nv_index */ + tpm_u32(space_index), + + /*null auth session*/ + tpm_u32(9), /* Header size */ + tpm_u32(TPM2_RS_PW), /* Password authorisation FIXME: allow PCR authorization */ + tpm_u16(0), /* nonce_size */ + 0, /* session_attrs */ + tpm_u16(0), /* HMAC size */ + /*end auth area*/ + + }; + return tpm_sendrecv_command(dev, command_v2, NULL, NULL); +} + u32 tpm2_pcr_extend(struct udevice *dev, u32 index, u32 algorithm, const u8 *digest, u32 digest_len) { @@ -184,22 +217,23 @@ u32 tpm2_nv_read_value(struct udevice *dev, u32 index, void *data, u32 count) u8 command_v2[COMMAND_BUFFER_SIZE] = { /* header 10 bytes */ tpm_u16(TPM2_ST_SESSIONS), /* TAG */ - tpm_u32(10 + 8 + 4 + 9 + 4), /* Length */ + tpm_u32(TPM2_HDR_LEN + 8 + 4 + 9 + 4), /* Length */ tpm_u32(TPM2_CC_NV_READ), /* Command code */
/* handles 8 bytes */ tpm_u32(TPM2_RH_PLATFORM), /* Primary platform seed */ - tpm_u32(HR_NV_INDEX + index), /* Password authorisation */ + tpm_u32(index), /*nv index*/
/* AUTH_SESSION */ - tpm_u32(9), /* Authorization size */ - tpm_u32(TPM2_RS_PW), /* Session handle */ + tpm_u32(9), /* Authorization size - 4 bytes*/ + /*auth handle - 9 bytes */ + tpm_u32(TPM2_RS_PW), /* Password authorisation */ /* Session handle */ tpm_u16(0), /* Size of <nonce> */ /* <nonce> (if any) */ 0, /* Attributes: Cont/Excl/Rst */ tpm_u16(0), /* Size of <hmac/password> */ /* <hmac/password> (if any) */ - + /*end auth handle */ tpm_u16(count), /* Number of bytes */ tpm_u16(0), /* Offset */ }; @@ -220,11 +254,12 @@ u32 tpm2_nv_read_value(struct udevice *dev, u32 index, void *data, u32 count) return 0; }
+ u32 tpm2_nv_write_value(struct udevice *dev, u32 index, const void *data, u32 count) { struct tpm_chip_priv *priv = dev_get_uclass_priv(dev); - uint offset = 10 + 8 + 4 + 9 + 2; + uint offset = TPM2_HDR_LEN + 8 + 4 + 9 + 2; uint len = offset + count + 2; /* Use empty password auth if platform hierarchy is disabled */ u32 auth = priv->plat_hier_disabled ? HR_NV_INDEX + index : @@ -237,18 +272,21 @@ u32 tpm2_nv_write_value(struct udevice *dev, u32 index, const void *data,
/* handles 8 bytes */ tpm_u32(auth), /* Primary platform seed */ - tpm_u32(HR_NV_INDEX + index), /* Password authorisation */ + tpm_u32(index), /*nv index*/
/* AUTH_SESSION */ - tpm_u32(9), /* Authorization size */ - tpm_u32(TPM2_RS_PW), /* Session handle */ + tpm_u32(9), /* Authorization size - 4 bytes */ + /*auth handle - 9 bytes */ + tpm_u32(TPM2_RS_PW), /* Password authorisation */ /* Session handle */ tpm_u16(0), /* Size of <nonce> */ /* <nonce> (if any) */ 0, /* Attributes: Cont/Excl/Rst */ tpm_u16(0), /* Size of <hmac/password> */ /* <hmac/password> (if any) */ - - tpm_u16(count), + /*end auth handle */ + tpm_u16(count),/*size of buffer - 2 bytes*/ + /*data (buffer)*/ + /*offset -> the octet offset into the NV Area*/ }; size_t response_len = COMMAND_BUFFER_SIZE; u8 response[COMMAND_BUFFER_SIZE]; ===================END OF PATCH================
Hi Niek
On Wed, 20 Dec 2023 at 09:11, niek.nooijens@omron.com niek.nooijens@omron.com wrote:
Hi There
Thanks for the patch. There's a standard process for sending patches [0]. Try to follow the guidelines on your next revision, it makes things substantially easier for me. Also, spend some time writing a clear patch description on *why* you need this merged.
Here's the patch:
Ditch the '//' comments throughout the patch. It's pretty clear what's happening
ditto
You don't need {}
Just return an error here.
policy_addr is initialized to NULL, just look at the ptr here instead of argc
You don't need {} in any of the above
Indentation is off
Get rid of {}
- TPM2 Structure Tags for command/response buffers.
- Issue a TPM_NV_UnDefineSpace command
run make htmldocs before the next revision and make sure you get no errors. We usually start with the function name here
- This allows a space to be removed. Needed because TPM_clear doesn't clear platform entries
- @dev TPM device
- @space_index index of the area
- Return: return code of the operation
- Issue a TPM2_PCR_Extend command.
- Write data to the secure storage
- Copyright (c) 2013 The Chromium OS Authors.
- Coypright (c) 2013 Guntermann & Drunck GmbH
I would *really* love to get rid of the magic values (8, 4 etc) and define them to something readable. But this is not a problem of your patch, we can fix it later.
[0] https://docs.u-boot.org/en/latest/develop/sending_patches.html
/Ilias
Hi Ilias
I implemented the feedback and checked the htmldocs build target. no error there. I also applied the patch to the latest github version (was using an older one, but no compatibility issues) and used git format-patch instead of git-diff. The checkpatch script now shows no errors. There's no real reson to "want" this to be merged, but as our company benefits greatly from projects like u-boot, I figured that the least we could do was contribute back to the project. We use the TPM's non-volatile memory to lock away keys and other secrets and I don't think we're the only one needing this.
anyhow here's the new revision. if I can help with more things I would gladly hear from you.
===================BEGIN PATCH================= From afd377e2aba6df46bc991c0f250bf67d4ad036e0 Mon Sep 17 00:00:00 2001 From: Niek Nooijens niek.nooijens@omron.com Date: Thu, 21 Dec 2023 10:56:14 +0900 Subject: [PATCH] add tpm nv_commands
Needed to read and write to the TPM's NV memory, in which you can store keys and other secret information, which can be locked behind PCR policies.
Signed-off-by: Niek Nooijens niek.nooijens@omron.com --- cmd/tpm-v2.c | 152 +++++++++++++++++++++++++++++++++++++++++++++++ include/tpm-v2.h | 15 +++++ lib/tpm-v2.c | 67 ++++++++++++++++----- 3 files changed, 219 insertions(+), 15 deletions(-)
diff --git a/cmd/tpm-v2.c b/cmd/tpm-v2.c index 7e479b9dfe..0d1e9e8e5c 100644 --- a/cmd/tpm-v2.c +++ b/cmd/tpm-v2.c @@ -356,6 +356,136 @@ static int do_tpm_pcr_setauthvalue(struct cmd_tbl *cmdtp, int flag, key, key_sz)); }
+static int do_tpm_nv_define(struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) +{ + struct udevice *dev; + struct tpm_chip_priv *priv; + u32 nv_addr, nv_size, nv_attributes, rc; + void *policy_addr = NULL; + size_t policy_size = 0; + int ret; + + nv_attributes = 0; + + if ((argc < 3 && argc > 6) || argc == 4) + return CMD_RET_USAGE; + + ret = get_tpm(&dev); + if (ret) + return ret; + + priv = dev_get_uclass_priv(dev); + if (!priv) + return -EINVAL; + + nv_addr = simple_strtoul(argv[1], NULL, 0); + + nv_size = simple_strtoul(argv[2], NULL, 0); + + if (argc > 3) + nv_attributes = simple_strtoul(argv[3], NULL, 0); + else + nv_attributes = TPMA_NV_PLATFORMCREATE | TPMA_NV_OWNERWRITE | TPMA_NV_OWNERREAD | TPMA_NV_PPWRITE | TPMA_NV_PPREAD; + + if (argc > 4) { + policy_addr = map_sysmem(simple_strtoul(argv[4], NULL, 0), 0); + if ((nv_attributes & (TPMA_NV_POLICYREAD | TPMA_NV_POLICYWRITE)) == 0) { + printf("ERROR: policy provided, but TPMA_NV_POLICYREAD or TPMA_NV_POLICYWRITE are NOT set!\n"); + return CMD_RET_FAILURE; + } + policy_size = simple_strtoul(argv[5], NULL, 0); + } + + rc = tpm2_nv_define_space(dev, nv_addr, nv_size, nv_attributes, policy_addr, policy_size); + + if (rc) + printf("ERROR: nv_define #%u returns: 0x%x\n", nv_addr, rc); + + if (policy_addr) + unmap_sysmem(policy_addr); + + return report_return_code(rc); +} + +static int do_tpm_nv_undefine(struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) +{ + struct udevice *dev; + u32 nv_addr, ret, rc; + + ret = get_tpm(&dev); + if (ret) + return ret; + + if (argc != 2) + return CMD_RET_USAGE; + + nv_addr = simple_strtoul(argv[1], NULL, 0); + rc = tpm2_nv_undefine_space(dev, nv_addr); + + return report_return_code(rc); +} + +static int do_tpm_nv_read_value(struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) +{ + struct udevice *dev; + u32 nv_addr, nv_size, rc; + int ret; + void *out_data; + + ret = get_tpm(&dev); + if (ret) + return ret; + + if (argc != 4) + return CMD_RET_USAGE; + + nv_addr = simple_strtoul(argv[1], NULL, 0); + + nv_size = simple_strtoul(argv[2], NULL, 0); + + out_data = map_sysmem(simple_strtoul(argv[3], NULL, 0), 0); + + rc = tpm2_nv_read_value(dev, nv_addr, out_data, nv_size); + + if (rc) + printf("ERROR: nv_read #%u returns: #%u\n", nv_addr, rc); + + unmap_sysmem(out_data); + return report_return_code(rc); +} + +static int do_tpm_nv_write_value(struct cmd_tbl *cmdtp, int flag, + int argc, char *const argv[]) +{ + struct udevice *dev; + u32 nv_addr, nv_size, rc; + int ret; + + ret = get_tpm(&dev); + if (ret) + return ret; + + if (argc != 4) + return CMD_RET_USAGE; + + nv_addr = simple_strtoul(argv[1], NULL, 0); //tpm_addr + + nv_size = simple_strtoul(argv[2], NULL, 0); //size + + void *data_to_write = map_sysmem(simple_strtoul(argv[3], NULL, 0), 0); + + rc = tpm2_nv_write_value(dev, nv_addr, data_to_write, nv_size); + + if (rc) + printf("ERROR: nv_read #%u returns: #%u\n", nv_addr, rc); + + unmap_sysmem(data_to_write); + return report_return_code(rc); +} + static struct cmd_tbl tpm2_commands[] = { U_BOOT_CMD_MKENT(device, 0, 1, do_tpm_device, "", ""), U_BOOT_CMD_MKENT(info, 0, 1, do_tpm_info, "", ""), @@ -375,6 +505,10 @@ static struct cmd_tbl tpm2_commands[] = { do_tpm_pcr_setauthpolicy, "", ""), U_BOOT_CMD_MKENT(pcr_setauthvalue, 0, 1, do_tpm_pcr_setauthvalue, "", ""), + U_BOOT_CMD_MKENT(nv_define, 0, 1, do_tpm_nv_define, "", ""), + U_BOOT_CMD_MKENT(nv_undefine, 0, 1, do_tpm_nv_undefine, "", ""), + U_BOOT_CMD_MKENT(nv_read, 0, 1, do_tpm_nv_read_value, "", ""), + U_BOOT_CMD_MKENT(nv_write, 0, 1, do_tpm_nv_write_value, "", ""), };
struct cmd_tbl *get_tpm2_commands(unsigned int *size) @@ -453,4 +587,22 @@ U_BOOT_CMD(tpm2, CONFIG_SYS_MAXARGS, 1, do_tpm, "Issue a TPMv2.x command", " <pcr>: index of the PCR\n" " <key>: secret to protect the access of PCR #<pcr>\n" " <password>: optional password of the PLATFORM hierarchy\n" +"\n" +"nv_define <tpm_addr> <size> [<attributes>, <policy_digest_addr> <policy_size>]\n" +" Define new nv index in the TPM at <tpm_addr> with size <size>\n" +" <tpm_addr>: the internal address used within the TPM for the NV-index\n" +" <attributes>: is described in tpp-v2.h enum tpm_index_attrs. Note; Always use TPMA_NV_PLATFORMCREATE!\n" +" will default to: TPMA_NV_PLATFORMCREATE|TPMA_NV_OWNERWRITE|TPMA_NV_OWNERREAD|TPMA_NV_PPWRITE|TPMA_NV_PPREAD\n" +"nv_undefine <tpm_addr>\n" +" delete nv index\n" +"nv_read <tpm_addr> <size> <data_addr>\n" +" Read data stored in TPM nv_memory at <tpm_addr> with size <size>\n" +" <tpm_addr>: the internal address used within the TPM for the NV-index\n" +" <size>: datasize in bytes\n" +" <data_addr>: memory address where to store the data read from the TPM\n" +"nv_write <tpm_addr> <size> <data_addr> [<policy_digest_addr> <policy_size>]\n" +" Write data to the TPM's nv_memory at <tpm_addr> with size <size>\n" +" <tpm_addr>: the internal address used within the TPM for the NV-index\n" +" <size>: datasize in bytes\n" +" <data_addr>: memory address of the data to be written to the TPM's NV-index\n" ); diff --git a/include/tpm-v2.h b/include/tpm-v2.h index 33dd103767..fd136d6a2a 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -332,6 +332,7 @@ enum tpm2_command_codes { TPM2_CC_CLEARCONTROL = 0x0127, TPM2_CC_HIERCHANGEAUTH = 0x0129, TPM2_CC_NV_DEFINE_SPACE = 0x012a, + TPM2_CC_NV_UNDEFINE_SPACE = 0x0122, TPM2_CC_PCR_SETAUTHPOL = 0x012C, TPM2_CC_NV_WRITE = 0x0137, TPM2_CC_NV_WRITELOCK = 0x0138, @@ -717,6 +718,20 @@ u32 tpm2_nv_define_space(struct udevice *dev, u32 space_index, size_t space_size, u32 nv_attributes, const u8 *nv_policy, size_t nv_policy_size);
+ + + +/** + * Issue a TPM_NV_UnDefineSpace command + * + * This allows a space to be removed. Needed because TPM_clear doesn't clear platform entries + * + * @dev TPM device + * @space_index index of the area + * Return: return code of the operation + */ +u32 tpm2_nv_undefine_space(struct udevice *dev, u32 space_index); + /** * Issue a TPM2_PCR_Extend command. * diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index bd0fb078dc..9b1460b0ad 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -788,15 +788,15 @@ u32 tpm2_clear(struct udevice *dev, u32 handle, const char *pw, }
u32 tpm2_nv_define_space(struct udevice *dev, u32 space_index, - size_t space_size, u32 nv_attributes, - const u8 *nv_policy, size_t nv_policy_size) + size_t space_size, u32 nv_attributes, + const u8 *nv_policy, size_t nv_policy_size) { /* * Calculate the offset of the nv_policy piece by adding each of the * chunks below. */ const int platform_len = sizeof(u32); - const int session_hdr_len = 13; + const int session_hdr_len = 15; const int message_len = 14; uint offset = TPM2_HDR_LEN + platform_len + session_hdr_len + message_len; @@ -809,11 +809,15 @@ u32 tpm2_nv_define_space(struct udevice *dev, u32 space_index, /* handles 4 bytes */ tpm_u32(TPM2_RH_PLATFORM), /* Primary platform seed */
/* message 14 bytes + policy */ @@ -842,6 +846,35 @@ u32 tpm2_nv_define_space(struct udevice *dev, u32 space_index, return tpm_sendrecv_command(dev, command_v2, NULL, NULL); }
+u32 tpm2_nv_undefine_space(struct udevice *dev, u32 space_index) +{ + const int platform_len = sizeof(u32); + const int session_hdr_len = 13; + const int message_len = 4; + u8 command_v2[COMMAND_BUFFER_SIZE] = { + /* header 10 bytes */ + tpm_u16(TPM2_ST_SESSIONS), /* TAG */ + tpm_u32(TPM2_HDR_LEN + platform_len + session_hdr_len + + message_len),/* Length - header + provision + index + auth area*/ + tpm_u32(TPM2_CC_NV_UNDEFINE_SPACE),/* Command code */ + + /* handles 4 bytes */ + tpm_u32(TPM2_RH_PLATFORM), /* Primary platform seed */ + /* nv_index */ + tpm_u32(space_index), + + /*null auth session*/ + tpm_u32(9), /* Header size */ + tpm_u32(TPM2_RS_PW), /* Password authorisation FIXME: allow PCR authorization */ + tpm_u16(0), /* nonce_size */ + 0, /* session_attrs */ + tpm_u16(0), /* HMAC size */ + /*end auth area*/ + + }; + return tpm_sendrecv_command(dev, command_v2, NULL, NULL); +} + u32 tpm2_pcr_extend(struct udevice *dev, u32 index, u32 algorithm, const u8 *digest, u32 digest_len) { @@ -890,22 +923,23 @@ u32 tpm2_nv_read_value(struct udevice *dev, u32 index, void *data, u32 count) u8 command_v2[COMMAND_BUFFER_SIZE] = { /* header 10 bytes */ tpm_u16(TPM2_ST_SESSIONS), /* TAG */ - tpm_u32(10 + 8 + 4 + 9 + 4), /* Length */ + tpm_u32(TPM2_HDR_LEN + 8 + 4 + 9 + 4), /* Length */ tpm_u32(TPM2_CC_NV_READ), /* Command code */
/* AUTH_SESSION */ - tpm_u32(9), /* Authorization size */ - tpm_u32(TPM2_RS_PW), /* Session handle */ + tpm_u32(9), /* Authorization size - 4 bytes*/ + /*auth handle - 9 bytes */ + tpm_u32(TPM2_RS_PW), /* Password authorisation */ tpm_u16(0), /* Size of <nonce> */ /* <nonce> (if any) */ 0, /* Attributes: Cont/Excl/Rst */ tpm_u16(0), /* Size of <hmac/password> */ /* <hmac/password> (if any) */ - + /*end auth handle */ tpm_u16(count), /* Number of bytes */ tpm_u16(0), /* Offset */ }; @@ -930,7 +964,7 @@ u32 tpm2_nv_write_value(struct udevice *dev, u32 index, const void *data, u32 count) { struct tpm_chip_priv *priv = dev_get_uclass_priv(dev); - uint offset = 10 + 8 + 4 + 9 + 2; + uint offset = TPM2_HDR_LEN + 8 + 4 + 9 + 2; uint len = offset + count + 2; /* Use empty password auth if platform hierarchy is disabled */ u32 auth = priv->plat_hier_disabled ? HR_NV_INDEX + index : @@ -943,18 +977,21 @@ u32 tpm2_nv_write_value(struct udevice *dev, u32 index, const void *data,
/* AUTH_SESSION */ - tpm_u32(9), /* Authorization size */ - tpm_u32(TPM2_RS_PW), /* Session handle */ + tpm_u32(9), /* Authorization size - 4 bytes */ + /*auth handle - 9 bytes */ + tpm_u32(TPM2_RS_PW), /* Password authorisation */ /* Session handle */ tpm_u16(0), /* Size of <nonce> */ /* <nonce> (if any) */ 0, /* Attributes: Cont/Excl/Rst */ tpm_u16(0), /* Size of <hmac/password> */ /* <hmac/password> (if any) */ - - tpm_u16(count), + /*end auth handle */ + tpm_u16(count),/*size of buffer - 2 bytes*/ + /*data (buffer)*/ + /*offset -> the octet offset into the NV Area*/ }; size_t response_len = COMMAND_BUFFER_SIZE; u8 response[COMMAND_BUFFER_SIZE]; -- 2.34.1 =======================END PATCH===================
________________________________ 差出人: Ilias Apalodimas ilias.apalodimas@linaro.org 送信日時: 2023年12月20日 17:17 宛先: Niek Nooijens / OC-IAB PBD-C DEVEL 1-1 niek.nooijens@omron.com CC: u-boot@lists.denx.de u-boot@lists.denx.de 件名: Re: New TPM commands.
[ilias.apalodimas@linaro.org からのメールを受け取る頻度は高くありません。これが問題である可能性の理由については、https://aka.ms/LearnAboutSenderIdentification をご覧ください。]
Hi Niek
Hi There
Here's the patch:
ditto
You don't need {}
Indentation is off
Get rid of {}
- @dev TPM device
[0] https://jpn01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.u-boo...https://docs.u-boot.org/en/latest/develop/sending_patches.html
/Ilias
Hi Niek,
On Thu, 21 Dec 2023 at 04:12, niek.nooijens@omron.com niek.nooijens@omron.com wrote:
Hi Ilias
Thanks! With vacation ahead I'll need sometime to review this, but I'll respond here if I need any more changes.
/Ilias
- @dev TPM device
Hi Niek
Hi There
Here's the patch:
ditto
You don't need {}
Indentation is off
Get rid of {}
- @dev TPM device
/Ilias
Hi Niek,
On Thu, Dec 21, 2023 at 02:12:49AM +0000, niek.nooijens@omron.com wrote:
Hi Ilias
This doesn't apply cleanly on -master or -next trees. Can you rebase it on top of either or them and resend it? When you do, please send a new email with the topic set like this: 'tpm: NV memory accesses v2'
Thanks /Ilias
- @dev TPM device
Hi Niek
Hi There
Here's the patch:
ditto
You don't need {}
Indentation is off
Get rid of {}
- @dev TPM device
/Ilias
Ilias Apalodimas
