[U-Boot] [PATCH] arm: exynos: fix set_mmc_clk for exynos4x12
Fix the set_mmc_clk() for exnos4x12. If board is exynos4x12, mmc clock should be set to wrong value.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- arch/arm/cpu/armv7/exynos/clock.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 36fedd6..84a5047 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -1410,7 +1410,8 @@ void set_mmc_clk(int dev_index, unsigned int div) else { if (proid_is_exynos4412()) exynos4x12_set_mmc_clk(dev_index, div); - exynos4_set_mmc_clk(dev_index, div); + else + exynos4_set_mmc_clk(dev_index, div); } }
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Jaehoon Chung
Minkyu Kang
