Re: [U-Boot] sf: Remove spansion_s25fss_disable_4KB_erase
Hi Jagan,
Do you have any comments?
Thanks for your work and you know it's important for QSPI with S25FS512S.
It seems S25FS512S can't support the SECT_4K, right? And it better to retain the disable_4kb, but we can add a flag in dts to select whether enable it.
Best Regards, Yao
From: Yao Yuan Sent: Wednesday, November 30, 2016 3:23 PM To: 'Jagan Teki' jagan@openedev.com Subject: sf: Remove spansion_s25fss_disable_4KB_erase
Hi Jagan,
I have noticed that you have a patch to:
commit 116e005cfd00021424f5f81eeedd355e4ca72f07 Author: Jagan Teki <jagan@amarulasolutions.commailto:jagan@amarulasolutions.com> Date: Tue Nov 15 22:57:42 2016 +0530
- Removed spansion_s25fss_disable_4KB_erase code - Add SECT_4K for S25FS512S chip
Do you have any test for this patch? Because with this patch, my QSPI driver can't working with S25FS512S.
As you said, In spansion S25FS-S family the physical sectors are grouped as normal and parameter sectors. Parameter sectors are 4kB in size with 8 set located at the bottom or top address of a device. Normal sectors are similar to other flash family with sizes of 64kB or 32 kB.
Base on the RM and in my understand, not all the erase sectors are 4-kb.
In my case regions are:
1. 0-32KiB (8*4KiB) - 4K_ERASE (0x20/0x21)
2. 32 - 256 - SE_CMD (0xd8/0xdc)
3. Rest of the flash SE_CMD (0xd8/0xdc)
4. To erase whole flash you can also use CHIP_ERASE_CMD
(0x60/0xC7) command, you just need to add one more mtd
partition that will cover whole flash.
So we can't add SECT_4K for S25FS512S chip. If we add SECT_4K for S25FS512S chip, that means all the erase sectors are 4-kb. But I think it's not right.
And disable 4kb is necessary for me, I also suggestion to add a flag to select whether enable 4-kb.
if (of_property_read_bool(np, "spi-nor, disable-4kb")) {
spansion_s25fs_disable_4kb_erase();
else
In dts:
&qspi {
qflash0: s25fs512s@0 {
compatible = "spansion, s25fs512s";
#address-cells = <1>;
#size-cells = <1>;
spi-max-frequency = <20000000>;
reg = <0>;
Attachment is the RM for S25FS-S.
Thanks.
Best Regards, Yao
On 12/12/2016 09:32 PM, Yao Yuan wrote:
Hi Jagan,
Thanks for your work and you know it’s important for QSPI with S25FS512S.
It seems S25FS512S can’t support the SECT_4K, right?
Jagan,
This is blocking me from using the board with this specific flash chip. Can you take a look? By reverting this single commit 116e005c, my board works again.
York
Hi Jagan,
Jagan,
I will try to work on this.
thanks!
Hi Jagan,
Jagan,
Guys,
Where are we on this issue?
York
Let's start the discussion, if possible we may add linux-mtd ML.
Here is the details: from attached pdf Page no:2
Do we agree till this point?
To erase whole flash using sector erase(D8h or DCh) won't effect the parameter sectors, so in order to erase these we must use 4K sector erase commands (20h or 21h) separately.
So better to erase the whole flash using 4K sector erase instead of detecting these family parts again and do two different erase operations.
On Tue, Dec 13, 2016 at 10:57 AM, Yao Yuan yao.yuan@nxp.com wrote:
Hi Jagan,
Best Regards, Yao
Hi Jagan,
else
In dts:
&qspi {
#size-cells = <1>;
reg = <0>;
thanks!
Ping?
Hi Jagan,
Best Regards, Yao
Hi Jagan,
else
In dts:
&qspi {
#size-cells = <1>;
reg = <0>;
thanks!
Jagan Teki Free Software Engineer | www.openedev.com U-Boot, Linux | Upstream Maintainer Hyderabad, India.
Jagan Teki
Jagan Teki
Yao Yuan
york sun
