[PATCH 1/2 v4] tpm-v2: add support for mapping algorithm names to algos
replace tpm2_supported_algorithms with an array of structures relating algorithm names, to TCG id's, digest length and mask values.
While at it fix the tpm2_algorithm_to_mask to return the proper value.
Fixes: 97707f12fdab ("tpm: Support boot measurements") Signed-off-by: Tim Harvey tharvey@gateworks.com Cc: Eddie James eajames@linux.ibm.com Cc: Ilias Apalodimas ilias.apalodimas@linaro.org --- v4: - new patch --- include/tpm-v2.h | 77 +++++++++++++++++++++++++++++++++++++-- lib/efi_loader/efi_tcg2.c | 4 +- lib/tpm-v2.c | 74 ++++++++++++++++++++++++++----------- 3 files changed, 128 insertions(+), 27 deletions(-)
diff --git a/include/tpm-v2.h b/include/tpm-v2.h index 33dd103767c4..c9d5cb6d3e5a 100644 --- a/include/tpm-v2.h +++ b/include/tpm-v2.h @@ -386,7 +386,54 @@ enum tpm2_algorithms { TPM2_ALG_SM3_256 = 0x12, };
-extern const enum tpm2_algorithms tpm2_supported_algorithms[4]; +/** + * struct digest_info - details of supported digests + * + * @hash_name: hash name + * @hash_alg: hash algorithm id + * @hash_mask: hash registry mask + * @hash_len: hash digest length + */ +struct digest_info { + const char *hash_name; + u16 hash_alg; + u32 hash_mask; + u16 hash_len; +}; + +/* Algorithm Registry */ +#define TCG2_BOOT_HASH_ALG_SHA1 0x00000001 +#define TCG2_BOOT_HASH_ALG_SHA256 0x00000002 +#define TCG2_BOOT_HASH_ALG_SHA384 0x00000004 +#define TCG2_BOOT_HASH_ALG_SHA512 0x00000008 +#define TCG2_BOOT_HASH_ALG_SM3_256 0x00000010 + +static const struct digest_info hash_algo_list[] = { + { + "sha1", + TPM2_ALG_SHA1, + TCG2_BOOT_HASH_ALG_SHA1, + TPM2_SHA1_DIGEST_SIZE, + }, + { + "sha256", + TPM2_ALG_SHA256, + TCG2_BOOT_HASH_ALG_SHA256, + TPM2_SHA256_DIGEST_SIZE, + }, + { + "sha384", + TPM2_ALG_SHA384, + TCG2_BOOT_HASH_ALG_SHA384, + TPM2_SHA384_DIGEST_SIZE, + }, + { + "sha512", + TPM2_ALG_SHA512, + TCG2_BOOT_HASH_ALG_SHA512, + TPM2_SHA512_DIGEST_SIZE, + }, +};
static inline u16 tpm2_algorithm_to_len(enum tpm2_algorithms a) { @@ -404,8 +451,6 @@ static inline u16 tpm2_algorithm_to_len(enum tpm2_algorithms a) } }
-#define tpm2_algorithm_to_mask(a) (1 << (a)) - /* NV index attributes */ enum tpm_index_attrs { TPMA_NV_PPWRITE = 1UL << 0, @@ -965,4 +1010,30 @@ u32 tpm2_enable_nvcommits(struct udevice *dev, uint vendor_cmd, */ u32 tpm2_auto_start(struct udevice *dev);
+/** + * tpm2_name_to_algorithm() - Return an algorithm id given a supported + * algorithm name + * + * @name: algorithm name + * Return: enum tpm2_algorithms or -EINVAL + */ +enum tpm2_algorithms tpm2_name_to_algorithm(const char *name); + +/** + * tpm2_algorithm_name() - Return an algorithm name string for a + * supported algorithm id + * + * @algorithm_id: algorithm defined in enum tpm2_algorithms + * Return: algorithm name string or "" + */ +const char *tpm2_algorithm_name(enum tpm2_algorithms); + +/** + * tpm2_algorithm_to_mask() - Get a TCG hash mask for algorithm + * + * @hash_alg: TCG defined algorithm + * Return: TCG hashing algorithm bitmaps (or 0 if algo not supported) + */ +u32 tpm2_algorithm_to_mask(enum tpm2_algorithms); + #endif /* __TPM_V2_H */ diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index b07e0099c27e..cf5d8de018a7 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -414,8 +414,8 @@ static efi_status_t tcg2_hash_pe_image(void *efi, u64 efi_size, }
digest_list->count = 0; - for (i = 0; i < ARRAY_SIZE(tpm2_supported_algorithms); i++) { - u16 hash_alg = tpm2_supported_algorithms[i]; + for (i = 0; i < ARRAY_SIZE(hash_algo_list); i++) { + u16 hash_alg = hash_algo_list[i].hash_alg;
if (!(active & tpm2_algorithm_to_mask(hash_alg))) continue; diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index 68eaaa639f89..2fc680a8adf8 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -22,13 +22,6 @@
#include "tpm-utils.h"
-const enum tpm2_algorithms tpm2_supported_algorithms[4] = { - TPM2_ALG_SHA1, - TPM2_ALG_SHA256, - TPM2_ALG_SHA384, - TPM2_ALG_SHA512, -}; - int tcg2_get_active_pcr_banks(struct udevice *dev, u32 *active_pcr_banks) { u32 supported = 0; @@ -82,14 +75,14 @@ int tcg2_create_digest(struct udevice *dev, const u8 *input, u32 length, return rc;
digest_list->count = 0; - for (i = 0; i < ARRAY_SIZE(tpm2_supported_algorithms); ++i) { + for (i = 0; i < ARRAY_SIZE(hash_algo_list); ++i) { u32 mask = - tpm2_algorithm_to_mask(tpm2_supported_algorithms[i]); + tpm2_algorithm_to_mask(hash_algo_list[i].hash_alg);
if (!(active & mask)) continue;
- switch (tpm2_supported_algorithms[i]) { + switch (hash_algo_list[i].hash_alg) { case TPM2_ALG_SHA1: sha1_starts(&ctx); sha1_update(&ctx, input, length); @@ -116,12 +109,12 @@ int tcg2_create_digest(struct udevice *dev, const u8 *input, u32 length, break; default: printf("%s: unsupported algorithm %x\n", __func__, - tpm2_supported_algorithms[i]); + hash_algo_list[i].hash_alg); continue; }
digest_list->digests[digest_list->count].hash_alg = - tpm2_supported_algorithms[i]; + hash_algo_list[i].hash_alg; memcpy(&digest_list->digests[digest_list->count].digest, final, len); digest_list->count++; @@ -208,13 +201,13 @@ static int tcg2_log_init(struct udevice *dev, struct tcg2_event_log *elog) return rc;
event_size = offsetof(struct tcg_efi_spec_id_event, digest_sizes); - for (i = 0; i < ARRAY_SIZE(tpm2_supported_algorithms); ++i) { - mask = tpm2_algorithm_to_mask(tpm2_supported_algorithms[i]); + for (i = 0; i < ARRAY_SIZE(hash_algo_list); ++i) { + mask = tpm2_algorithm_to_mask(hash_algo_list[i].hash_alg);
- switch (tpm2_supported_algorithms[i]) { + switch (hash_algo_list[i].hash_alg) { case TPM2_ALG_SHA1: case TPM2_ALG_SHA256: case TPM2_ALG_SHA384: @@ -253,17 +246,17 @@ static int tcg2_log_init(struct udevice *dev, struct tcg2_event_log *elog) put_unaligned_le32(count, &ev->number_of_algorithms);
count = 0; - for (i = 0; i < ARRAY_SIZE(tpm2_supported_algorithms); ++i) { - mask = tpm2_algorithm_to_mask(tpm2_supported_algorithms[i]); + for (i = 0; i < ARRAY_SIZE(hash_algo_list); ++i) { + mask = tpm2_algorithm_to_mask(hash_algo_list[i].hash_alg);
- len = tpm2_algorithm_to_len(tpm2_supported_algorithms[i]); + len = hash_algo_list[i].hash_len; if (!len) continue;
- put_unaligned_le16(tpm2_supported_algorithms[i], + put_unaligned_le16(hash_algo_list[i].hash_alg, &ev->digest_sizes[count].algorithm_id); put_unaligned_le16(len, &ev->digest_sizes[count].digest_size); count++; @@ -304,7 +297,7 @@ static int tcg2_replay_eventlog(struct tcg2_event_log *elog, pos = offsetof(struct tcg_pcr_event2, digests) + offsetof(struct tpml_digest_values, count); count = get_unaligned_le32(log + pos); - if (count > ARRAY_SIZE(tpm2_supported_algorithms) || + if (count > ARRAY_SIZE(hash_algo_list) || (digest_list->count && digest_list->count != count)) return 0;
@@ -407,7 +400,7 @@ static int tcg2_log_parse(struct udevice *dev, struct tcg2_event_log *elog) return 0;
count = get_unaligned_le32(&event->number_of_algorithms); - if (count > ARRAY_SIZE(tpm2_supported_algorithms)) + if (count > ARRAY_SIZE(hash_algo_list)) return 0;
calc_size = offsetof(struct tcg_efi_spec_id_event, digest_sizes) + @@ -1110,7 +1103,7 @@ int tpm2_get_pcr_info(struct udevice *dev, u32 *supported_pcr, u32 *active_pcr, * We only support 5 algorithms for now so check against that * instead of TPM2_NUM_PCR_BANKS */ - if (pcrs.count > ARRAY_SIZE(tpm2_supported_algorithms) || + if (pcrs.count > ARRAY_SIZE(hash_algo_list) || pcrs.count < 1) { printf("%s: too many pcrs: %u\n", __func__, pcrs.count); return -EMSGSIZE; @@ -1555,3 +1548,40 @@ u32 tpm2_enable_nvcommits(struct udevice *dev, uint vendor_cmd,
return 0; } + +enum tpm2_algorithms tpm2_name_to_algorithm(const char *name) +{ + size_t i; + + for (i = 0; i < ARRAY_SIZE(hash_algo_list); ++i) { + if (!strcasecmp(name, hash_algo_list[i].hash_name)) + return hash_algo_list[i].hash_alg; + } + printf("%s: unsupported algorithm %s\n", __func__, name); + + return -EINVAL; +} + +const char *tpm2_algorithm_name(enum tpm2_algorithms algo) +{ + size_t i; + + for (i = 0; i < ARRAY_SIZE(hash_algo_list); ++i) { + if (hash_algo_list[i].hash_alg == algo) + return hash_algo_list[i].hash_name; + } + + return ""; +} + +u32 tpm2_algorithm_to_mask(enum tpm2_algorithms algo) +{ + size_t i; + + for (i = 0; i < ARRAY_SIZE(hash_algo_list); i++) { + if (hash_algo_list[i].hash_alg == algo) + return hash_algo_list[i].hash_mask; + } + + return 0; +}
For pcr_read and pcr_extend commands allow the digest algorithm to be specified by an additional argument. If not specified it will default to SHA256 for backwards compatibility.
Additionally update test_tpm2.py for the changes in output in pcr_read which now shows the algo and algo length in the output.
A follow-on to this could be to extend all PCR banks with the detected algo when the <digest_algo> argument is 'auto'.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- v4: - update test_tpm2.py as required by changes in pcr_read output - split out moving algos to an array of structs to its own patch and encorporate a fix for tpm2_algorithm_to_mask v3: - replace tpm2_supported_algorithms with struct and use this to relate hash algoirthm details v2: - use tpm2_algorithm_to_len - use enum tpm2_algorithms - make function names and parameter names more consistent with existing tpm-v2 functions - fix various spelling errors --- cmd/tpm-v2.c | 49 +++++++++++++++++++++++++++----------- test/py/tests/test_tpm2.py | 2 +- 2 files changed, 36 insertions(+), 15 deletions(-)
diff --git a/cmd/tpm-v2.c b/cmd/tpm-v2.c index 7e479b9dfe36..2343b4d9cb9e 100644 --- a/cmd/tpm-v2.c +++ b/cmd/tpm-v2.c @@ -99,11 +99,19 @@ static int do_tpm2_pcr_extend(struct cmd_tbl *cmdtp, int flag, int argc, struct tpm_chip_priv *priv; u32 index = simple_strtoul(argv[1], NULL, 0); void *digest = map_sysmem(simple_strtoul(argv[2], NULL, 0), 0); + int algo = TPM2_ALG_SHA256; + int algo_len; int ret; u32 rc;
- if (argc != 3) + if (argc < 3 || argc > 4) return CMD_RET_USAGE; + if (argc == 4) { + algo = tpm2_name_to_algorithm(argv[3]); + if (algo < 0) + return CMD_RET_FAILURE; + } + algo_len = tpm2_algorithm_to_len(algo);
ret = get_tpm(&dev); if (ret) @@ -116,8 +124,12 @@ static int do_tpm2_pcr_extend(struct cmd_tbl *cmdtp, int flag, int argc, if (index >= priv->pcr_count) return -EINVAL;
- rc = tpm2_pcr_extend(dev, index, TPM2_ALG_SHA256, digest, - TPM2_DIGEST_LEN); + rc = tpm2_pcr_extend(dev, index, algo, digest, algo_len); + if (!rc) { + printf("PCR #%u extended with %d byte %s digest\n", index, + algo_len, tpm2_algorithm_name(algo)); + print_byte_string(digest, algo_len); + }
unmap_sysmem(digest);
@@ -127,15 +139,23 @@ static int do_tpm2_pcr_extend(struct cmd_tbl *cmdtp, int flag, int argc, static int do_tpm_pcr_read(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { + enum tpm2_algorithms algo = TPM2_ALG_SHA256; struct udevice *dev; struct tpm_chip_priv *priv; u32 index, rc; + int algo_len; unsigned int updates; void *data; int ret;
ret = get_tpm(&dev); if (ret) @@ -151,11 +171,12 @@ static int do_tpm_pcr_read(struct cmd_tbl *cmdtp, int flag, int argc,
data = map_sysmem(simple_strtoul(argv[2], NULL, 0), 0);
- rc = tpm2_pcr_read(dev, index, priv->pcr_select_min, TPM2_ALG_SHA256, - data, TPM2_DIGEST_LEN, &updates); + rc = tpm2_pcr_read(dev, index, priv->pcr_select_min, algo, + data, algo_len, &updates); if (!rc) { - printf("PCR #%u content (%u known updates):\n", index, updates); - print_byte_string(data, TPM2_DIGEST_LEN); + printf("PCR #%u %s %d byte content (%u known updates):\n", index, + tpm2_algorithm_name(algo), algo_len, updates); + print_byte_string(data, algo_len); }
unmap_sysmem(data); @@ -415,14 +436,14 @@ U_BOOT_CMD(tpm2, CONFIG_SYS_MAXARGS, 1, do_tpm, "Issue a TPMv2.x command", " <hierarchy> is one of:\n" " * TPM2_RH_LOCKOUT\n" " * TPM2_RH_PLATFORM\n" -"pcr_extend <pcr> <digest_addr>\n" -" Extend PCR #<pcr> with digest at <digest_addr>.\n" +"pcr_extend <pcr> <digest_addr> [<digest_algo>]\n" +" Extend PCR #<pcr> with digest at <digest_addr> with digest_algo.\n" " <pcr>: index of the PCR\n" -" <digest_addr>: address of a 32-byte SHA256 digest\n" -"pcr_read <pcr> <digest_addr>\n" -" Read PCR #<pcr> to memory address <digest_addr>.\n" +" <digest_addr>: address of digest of digest_algo type (defaults to SHA256)\n" +"pcr_read <pcr> <digest_addr> [<digest_algo>]\n" +" Read PCR #<pcr> to memory address <digest_addr> with <digest_algo>.\n" " <pcr>: index of the PCR\n" -" <digest_addr>: address to store the a 32-byte SHA256 digest\n" +" <digest_addr>: address of digest of digest_algo type (defaults to SHA256)\n" "get_capability <capability> <property> <addr> <count>\n" " Read and display <count> entries indexed by <capability>/<property>.\n" " Values are 4 bytes long and are written at <addr>.\n" diff --git a/test/py/tests/test_tpm2.py b/test/py/tests/test_tpm2.py index 1d654cd4a23b..75f5d31fc675 100644 --- a/test/py/tests/test_tpm2.py +++ b/test/py/tests/test_tpm2.py @@ -257,7 +257,7 @@ def test_tpm2_pcr_read(u_boot_console): updates = int(re.findall(r'\d+', str)[0])
# Check the output value - assert 'PCR #10 content' in read_pcr + assert 'PCR #10 sha256 32 byte content' in read_pcr assert '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' in read_pcr
@pytest.mark.buildconfigspec('cmd_tpm_v2')
Hi Tim,
Minor typo on the commit message. Since there's a small change in patch #1 please fix this as well
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
v4:
v3:
v2:
if (argc != 3)
if (argc == 4) {
if (algo < 0)
algo_len = tpm2_algorithm_to_len(algo); ret = get_tpm(&dev); if (ret)
TPM2_DIGEST_LEN);
if (!rc) {
} unmap_sysmem(digest);
if (argc != 3)
if (argc == 4) {
if (algo < 0)
print_byte_string(data, algo_len); } unmap_sysmem(data);
- assert 'PCR #10 sha256 32 byte content' in read_pcr assert '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' in read_pcr
2.25.1
Hi Tim
Thanks for fixing this.
Can we replace tpm2_algorithm_to_mask() with hash_algo_list[i].hash_mask in - lib/tpm-v2.c lines 80, 205 250 - lib/efi_loader/efi_tcg2.c line 420
With these changes Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
v4:
- new patch
- struct digest_info - details of supported digests
- @hash_name: hash name
- @hash_alg: hash algorithm id
- @hash_mask: hash registry mask
- @hash_len: hash digest length
u16 hash_alg;
u32 hash_mask;
u16 hash_len;
"sha1",
TPM2_ALG_SHA1,
"sha256",
TPM2_ALG_SHA256,
"sha384",
TPM2_ALG_SHA384,
"sha512",
TPM2_ALG_SHA512,
- tpm2_name_to_algorithm() - Return an algorithm id given a supported
algorithm name
- @name: algorithm name
- Return: enum tpm2_algorithms or -EINVAL
- tpm2_algorithm_name() - Return an algorithm name string for a
- @algorithm_id: algorithm defined in enum tpm2_algorithms
- Return: algorithm name string or ""
- tpm2_algorithm_to_mask() - Get a TCG hash mask for algorithm
- @hash_alg: TCG defined algorithm
- Return: TCG hashing algorithm bitmaps (or 0 if algo not supported)
u16 hash_alg = hash_algo_list[i].hash_alg; if (!(active & tpm2_algorithm_to_mask(hash_alg))) continue;
TPM2_ALG_SHA1,
TPM2_ALG_SHA256,
TPM2_ALG_SHA384,
TPM2_ALG_SHA512,
tpm2_algorithm_to_mask(hash_algo_list[i].hash_alg); if (!(active & mask)) continue;
hash_algo_list[i].hash_alg); continue; } digest_list->digests[digest_list->count].hash_alg =
mask = tpm2_algorithm_to_mask(hash_algo_list[i].hash_alg); if (!(active & mask)) continue;
count = 0;
if (count > ARRAY_SIZE(hash_algo_list)) return 0; calc_size = offsetof(struct tcg_efi_spec_id_event, digest_sizes) +
size_t i;
return -EINVAL;
size_t i;
return "";
size_t i;
2.25.1
On Wed, May 22, 2024 at 3:33 AM Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Tim
Yes, that makes sense. I'll also remove the unnecessary variable from the stack in those cases:
diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index cf5d8de018a7..945aafb847d8 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -417,7 +417,7 @@ static efi_status_t tcg2_hash_pe_image(void *efi, u64 efi_size, for (i = 0; i < ARRAY_SIZE(hash_algo_list); i++) { u16 hash_alg = hash_algo_list[i].hash_alg;
- if (!(active & tpm2_algorithm_to_mask(hash_alg))) + if (!(active & hash_algo_list[i].hash_mask)) continue; switch (hash_alg) { case TPM2_ALG_SHA1: diff --git a/lib/tpm-v2.c b/lib/tpm-v2.c index 2fc680a8adf8..a67daed2f3c1 100644 --- a/lib/tpm-v2.c +++ b/lib/tpm-v2.c @@ -76,10 +76,7 @@ int tcg2_create_digest(struct udevice *dev, const u8 *input, u32 length,
digest_list->count = 0; for (i = 0; i < ARRAY_SIZE(hash_algo_list); ++i) { - u32 mask = - tpm2_algorithm_to_mask(hash_algo_list[i].hash_alg); - - if (!(active & mask)) + if (!(active & hash_algo_list[i].hash_mask)) continue;
switch (hash_algo_list[i].hash_alg) { @@ -191,7 +188,6 @@ static int tcg2_log_init(struct udevice *dev, struct tcg2_event_log *elog) u32 count = 0; u32 log_size; u32 active; - u32 mask; size_t i; u16 len; int rc; @@ -202,9 +198,7 @@ static int tcg2_log_init(struct udevice *dev, struct tcg2_event_log *elog)
event_size = offsetof(struct tcg_efi_spec_id_event, digest_sizes); for (i = 0; i < ARRAY_SIZE(hash_algo_list); ++i) { - mask = tpm2_algorithm_to_mask(hash_algo_list[i].hash_alg); - - if (!(active & mask)) + if (!(active & hash_algo_list[i].hash_mask)) continue;
switch (hash_algo_list[i].hash_alg) { @@ -247,9 +241,7 @@ static int tcg2_log_init(struct udevice *dev, struct tcg2_event_log *elog)
count = 0; for (i = 0; i < ARRAY_SIZE(hash_algo_list); ++i) { - mask = tpm2_algorithm_to_mask(hash_algo_list[i].hash_alg); - - if (!(active & mask)) + if (!(active & hash_algo_list[i].hash_mask)) continue;
Thanks,
Tim
v4:
- new patch
u16 hash_alg;
u32 hash_mask;
u16 hash_len;
"sha1",
TPM2_ALG_SHA1,
"sha256",
TPM2_ALG_SHA256,
"sha384",
TPM2_ALG_SHA384,
"sha512",
TPM2_ALG_SHA512,
algorithm name
TPM2_ALG_SHA1,
TPM2_ALG_SHA256,
TPM2_ALG_SHA384,
TPM2_ALG_SHA512,
count = 0;
size_t i;
return -EINVAL;
size_t i;
return "";
size_t i;
2.25.1
Ilias Apalodimas
Tim Harvey
