[PATCH 1/1] Squashed 'dts/upstream/' changes from b35b9bd1d4ee..7e08733c96c8
7e08733c96c8 Merge tag 'v6.9-dts-raw' ccdce3340fc5 Merge tag 'net-6.9-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net cb4ccb79bf49 dt-bindings: net: mediatek: remove wrongly added clocks and SerDes 6bd14595bb37 Merge tag 'soc-fixes-6.9-3' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc a6d12fb4ba6f Merge tag 'qcom-arm64-fixes-for-6.9-2' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into arm/fixes 71c2fe626e53 Merge tag 'v6.9-rc7-dts-raw' 62d74bd1c58f Merge tag 'char-misc-6.9-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc bdc631c5b7eb arm64: dts: mediatek: mt8183-pico6: Fix bluetooth node 9818a367c6b8 Merge tag 'sound-6.9-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound c861ae2b0770 Merge tag 'pinctrl-v6.9-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl c9551dbd4ea4 Merge tag 'v6.9-rc6-dts-raw' 17c632b49122 Merge tag 'i2c-for-6.9-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux a1bf8545a7b4 Merge tag 'soc-fixes-6.9-2' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc d13e05c0fe9b Merge tag 'arc-6.9-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc 83b7bf1bdd47 Merge tag 'imx-fixes-6.9-2' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into for-next 3a940d011934 Merge tag 'mtk-dts64-fixes-for-v6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/mediatek/linux into for-next 6eeb1be299fc Merge tag 'at91-fixes-6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/at91/linux into for-next 733db5273cb7 Merge tag 'qcom-arm64-fixes-for-6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into for-next 76a235f6ef02 Merge branch 'v6.9-armsoc/dtsfixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into for-next a4916498fb4a Merge tag 'at24-fixes-for-v6.9-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/brgl/linux into i2c/for-current 6ee8c2d34ea8 ARM: dts: imx6ull-tarragon: fix USB over-current polarity c3ee365cb940 Merge tag 'iio-fixes-for-6.9a' of https://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into char-misc-linus bb3b0f6bb688 Merge tag 'v6.9-rc5-dts-raw' ca2b45c908c0 arm64: dts: imx8mp: Fix assigned-clocks for second CSI2 b91b30ccdb82 Merge tag 'tty-6.9-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty 9e347843c73f ARM: dts: microchip: at91-sama7g54_curiosity: Replace regulator-suspend-voltage with the valid property a6e3d2cb9d6d ARM: dts: microchip: at91-sama7g5ek: Replace regulator-suspend-voltage with the valid property 01c2febb3cdb arm64: dts: qcom: sa8155p-adp: fix SDHC2 CD pin configuration 460856d18366 arm64: dts: rockchip: Fix USB interface compatible string on kobol-helios64 e91f447c8573 Merge tag 'pwm/for-6.9-rc5-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ukleinek/linux b362458a0941 dt-bindings: eeprom: at24: Fix ST M24C64-D compatible schema 4c77f098d193 ARC: [plat-hsdk]: Remove misplaced interrupt-cells property bc5665bd550f dt-bindings: pwm: mediatek,pwm-disp: Document power-domains property bdb049c4d14f Merge tag 'v6.9-rc4-dts-raw' ea20dda12f5b Merge tag 'soc-fixes-6.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc c43f5bbe57fe arm64: dts: qcom: sc8180x: Fix ss_phy_irq for secondary USB controller 09bbdcd84ac2 arm64: dts: qcom: sm8650: Fix the msi-map entries 864783541376 arm64: dts: qcom: sm8550: Fix the msi-map entries ddedda592d70 arm64: dts: qcom: sm8450: Fix the msi-map entries 960336e0e880 arm64: dts: qcom: sc8280xp: add missing PCIe minimum OPP eb57b8e07fd7 arm64: dts: qcom: x1e80100: Fix the compatible for cluster idle states 64b22344a08d arm64: dts: qcom: Fix type of "wdog" IRQs for remoteprocs 3d4da9353d8a Merge tag 'drm-fixes-2024-04-12' of https://gitlab.freedesktop.org/drm/kernel 94d5ae8ffd5b Merge tag 'drm-msm-next-2024-04-11' of https://gitlab.freedesktop.org/drm/msm into drm-fixes 45ab49b70c99 LoongArch: Update dts for Loongson-2K2000 to support GMAC/GNET e5f2765cdef5 LoongArch: Update dts for Loongson-2K2000 to support PCI-MSI 65d54f215c81 LoongArch: Update dts for Loongson-2K2000 to support ISA/LPC 05bddcf85f2c LoongArch: Update dts for Loongson-2K1000 to support ISA/LPC e32b794a9062 arm64: dts: rockchip: regulator for sd needs to be always on for BPI-R2Pro cf90790de0b2 dt-bindings: rockchip: grf: Add missing type to 'pcie-phy' node ad6402eb7acc arm64: dts: rockchip: drop redundant disable-gpios in Lubancat 2 ace753017ab4 arm64: dts: rockchip: drop redundant disable-gpios in Lubancat 1 24eae3d76a2b arm64: dts: rockchip: drop redundant pcie-reset-suspend in Scarlet Dumo 6ddbc8e4f612 arm64: dts: rockchip: mark system power controller and fix typo on orangepi-5-plus 7d1e92c191e5 arm64: dts: rockchip: Designate the system power controller on QuartzPro64 b2f8ee07aa8e ASoC: dt-bindings: rt5645: add cbj sleeve gpio property 39841e784daa MAINTAINERS: mailmap: update Richard Genoud's email address 10c6631c86d1 Merge tag 'v6.9-rc3-dts-raw' 4ea847a91dd6 Merge tag 'devicetree-fixes-for-6.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux 446b3564a952 arm64: dts: mediatek: mt2712: fix validation errors 65d0eb62f0f1 arm64: dts: mediatek: mt7986: prefix BPI-R3 cooling maps with "map-" a2ac24e9a4dc arm64: dts: mediatek: mt7986: drop invalid thermal block clock 7d65b24f6c7b arm64: dts: mediatek: mt7986: drop "#reset-cells" from Ethernet controller 6674a5ba09ef arm64: dts: mediatek: mt7986: drop invalid properties from ethsys fb0a8e849646 dt-bindings: timer: narrow regex for unit address to hex numbers cb1b6952348f dt-bindings: soc: fsl: narrow regex for unit address to hex numbers 27c8017d28c8 dt-bindings: remoteproc: ti,davinci: remove unstable remark 9095a10d281f dt-bindings: clock: ti: remove unstable remark 3f61301c1488 dt-bindings: clock: keystone: remove unstable remark 31b1ce263042 arm64: dts: imx8qm-ss-dma: fix can lpcg indices 743b20b5d4db arm64: dts: imx8-ss-dma: fix can lpcg indices d8f0818c58bc arm64: dts: imx8-ss-dma: fix adc lpcg indices 2349133feee2 arm64: dts: imx8-ss-dma: fix pwm lpcg indices a18420af419e arm64: dts: imx8-ss-dma: fix spi lpcg indices d6d2add292ae arm64: dts: imx8-ss-conn: fix usb lpcg indices fc19a9596662 arm64: dts: imx8-ss-lsio: fix pwm lpcg indices 64a1c4a72a08 arm64: dts: mediatek: mt7622: drop "reset-names" from thermal block f91467bb0e7c arm64: dts: mediatek: mt7622: fix ethernet controller "compatible" 8e632e3e98df arm64: dts: mediatek: mt7622: fix IR nodename 1472eb8a5653 arm64: dts: mediatek: mt7622: fix clock controllers 5802f95e74db arm64: dts: mediatek: mt8186-corsola: Update min voltage constraint for Vgpu 6cb73d686d58 arm64: dts: mediatek: mt8183-kukui: Use default min voltage for MT6358 cd3a14e0479e arm64: dts: mediatek: mt8195-cherry: Update min voltage constraint for MT6315 2814659a8a80 arm64: dts: mediatek: mt8192-asurada: Update min voltage constraint for MT6315 3ea180fa00c5 arm64: dts: mediatek: cherry: Describe CPU supplies c452106eb835 arm64: dts: mediatek: mt8195: Add missing gce-client-reg to mutex1 5893bd804364 arm64: dts: mediatek: mt8195: Add missing gce-client-reg to mutex ad1660ce46c3 arm64: dts: mediatek: mt8195: Add missing gce-client-reg to vpp/vdosys 744724419d4c arm64: dts: mediatek: mt8192: Add missing gce-client-reg to mutex 902cad91425f arm64: dts: mediatek: mt8183: Add power-domains properity to mfgcfg 7b49bc388147 ARM: dts: imx7s-warp: Pass OV2680 link-frequencies bd5623d08b6c ARM: dts: imx7-mba7: Use 'no-mmc' property 51b8028c7925 arm64: dts: imx8-ss-conn: fix usdhc wrong lpcg clock order 6beeed742637 dt-bindings: display/msm: sm8150-mdss: add DP node 954f369b81da ARC: Fix typos 3d2c4d764916 arm64: dts: rockchip: drop panel port unit address in GRU Scarlet fa6ab1a0c8a1 arm64: dts: rockchip: Remove unsupported node from the Pinebook Pro dts 7f80622495d4 arm64: dts: qcom: sc7180-trogdor: mark bluetooth address as broken 92953647265f dt-bindings: bluetooth: add 'qcom,local-bd-address-broken' 6421f94d75f4 arm64: dts: freescale: imx8mp-venice-gw73xx-2x: fix USB vbus regulator 4bb321df9164 arm64: dts: freescale: imx8mp-venice-gw72xx-2x: fix USB vbus regulator f37161a9cf0c dt-bindings: ufs: qcom: document SM6125 UFS b2a26b71ae7d dt-bindings: ufs: qcom: document SC7180 UFS 1cb1e2605d33 dt-bindings: ufs: qcom: document SC8180X UFS 6bd77a407d2e dt-bindings: pinctrl: renesas,rzg2l-pinctrl: Allow 'input' and 'output-enable' properties 2639a0e2fdbd Merge tag 'v6.9-rc1-dts-raw' 15eca7b21493 docs: dt-bindings: add missing address/size-cells to example 9ace491cae40 arm64: dts: rockchip: Fix the i2c address of es8316 on Cool Pi CM5 d8bdab44b3fe arm64: dts: rockchip: add regulators for PCIe on RK3399 Puma Haikou 1331876fe9c8 arm64: dts: rockchip: enable internal pull-up on PCIE_WAKE# for RK3399 Puma 57878497676a arm64: dts: rockchip: enable internal pull-up on Q7_USB_ID for RK3399 Puma a9686a9d2878 arm64: dts: rockchip: fix alphabetical ordering RK3399 puma 6125abd98f94 arm64: dts: rockchip: enable internal pull-up for Q7_THRM# on RK3399 Puma e51b8871e6a8 arm64: dts: rockchip: set PHY address of MT7531 switch to 0x1f 8c7a1135d13d dt-bindings: iio: health: maxim,max30102: fix compatible check 7eea89692b5a Merge tag 'timers-core-2024-03-23' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip 665795c05a77 Merge tag 'riscv-for-linus-6.9-mw2' of git://git.kernel.org/pub/scm/linux/kernel/git/riscv/linux 9497bb8a116e Merge tag 'spi-fix-v6.9-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi 6aef9b1ef737 Merge tag 'sound-fix2-6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound 17cde028ffcc Merge tag 'i2c-for-6.9-rc1-part2' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux 7bbd20ac15d0 Merge tag 'rtc-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux b2bb86451efb Merge tag 'ubifs-for-linus-6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/ubifs 203aa834e5f2 Merge tag 'char-misc-6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc 9125147fa946 Merge tag 'tty-6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty e5738ce51174 Merge tag 'usb-6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb d4a1391985cc Merge tag 'rproc-v6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/remoteproc/linux b3632b121e0d Merge tag 'asoc-fix-v6.9-merge-window' of https://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus 4a7dcd8c3a18 dt-bindings: i2c: qcom,i2c-cci: Fix OV7251 'data-lanes' entries f76fa412f9a8 Merge tag 'i2c-host-6.9-part2' of git://git.kernel.org/pub/scm/linux/kernel/git/andi.shyti/linux into i2c/for-mergewindow 8cd35b85c4b0 Merge tag 'soc-late-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc f6c32d4a4ede Merge tag 'thermal-6.9-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm 6630f47c5f9a spi: Merge up v6.8 release ec2e44a038f5 Merge tag 'timers-v6.9-rc1' of https://git.linaro.org/people/daniel.lezcano/linux into timers/core ef0c6b10c2da Merge tag 'i3c/for-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/i3c/linux 6defc064e93e Merge tag 'linux-watchdog-6.9-rc1' of git://www.linux-watchdog.org/linux-watchdog 72fe2cde7b8a Merge tag 'input-for-v6.9-rc0' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input a546e7273d2d Merge tag 'phy-for-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/phy/linux-phy 3972e256bfa2 Merge tag 'v6.9-p1' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 a355cc2d4dcb Merge tag 'mips_6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/mips/linux aefedca6e1b1 Merge tag 'devicetree-for-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux 8eb838e35ade Merge tag 'mtd/for-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/mtd/linux 7497080a0eda Merge tag 'dmaengine-6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/vkoul/dmaengine 571f27ef129d Merge tag 'i2c-for-6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux fb60e6d58b2d dt-bindings: input: samsung,s3c6410-keypad: convert to DT Schema 34598dab4724 Merge tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux 9d67b3ce96cb Merge tag 'media/v6.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media 3fe3426bca72 dt-bindings: soc: imx: fsl,imx-anatop: add imx6q regulators 7311bc58c158 Merge tag 'nand/for-6.9' into mtd/next 146d9a6f3ded dt-bindings: atmel-nand: add microchip,sam9x7-pmecc e2a5c7c3959b arm64: dts: broadcom: bcmbca: Update router boards 1bd13f3b7695 arm64: dts: broadcom: bcmbca: Add NAND controller node cc519333e3cf ARM: dts: broadcom: bcmbca: Add NAND controller node c1e4264b6d55 Merge tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux 6371c24fe180 Merge tag 'sound-6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound 98c06b3a9483 Merge tag 'pci-v6.9-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/pci/pci 7fa73443a89b Merge tag 'platform-drivers-x86-v6.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/pdx86/platform-drivers-x86 e76bc30ffbd6 Merge tag 'leds-next-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/leds 19186d59b259 Merge tag 'backlight-next-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight 75c5518e62b1 Merge tag 'mfd-next-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd 099699809967 Merge tag 'pinctrl-v6.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl 8e49bd3cbb58 Merge tag 'auxdisplay-v6.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/andy/linux-auxdisplay a775511def90 Merge tag 'drm-next-2024-03-13' of https://gitlab.freedesktop.org/drm/kernel 4d3acb15ed8a Merge tag 'spi-nor/for-6.9' into mtd/next 51591c70d1ca Merge branches 'clk-samsung', 'clk-imx', 'clk-rockchip', 'clk-clkdev' and 'clk-rate-exclusive' into clk-next 0c05d2bca0f7 Merge tag 'thermal-v6.9-rc1' of ssh://gitolite.kernel.org/pub/scm/linux/kernel/git/thermal/linux a55648d846e7 Merge branches 'clk-remove', 'clk-amlogic', 'clk-qcom', 'clk-parent' and 'clk-microchip' into clk-next 749f625e4547 Merge branches 'clk-aspeed', 'clk-keystone', 'clk-mobileye' and 'clk-allwinner' into clk-next 82d0f90167fc Merge branches 'clk-renesas', 'clk-cleanup', 'clk-hisilicon', 'clk-mediatek' and 'clk-bulk' into clk-next 6526c4a4b4e5 Merge tag 'tpmdd-v6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/jarkko/linux-tpmdd 1da1a2503cbc Merge tag 'mailbox-v6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/jassibrar/mailbox cecb3b4fdac3 Merge tag 'pm-6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm 49c8db52641c Merge tag 'pmdomain-v6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/linux-pm b15efb2ec6a3 Merge tag 'hwmon-for-v6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging 51da5c0be9f6 ASoC: Merge up release 82088fb378a1 Merge tag 'gpio-updates-for-v6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/brgl/linux 08aa0ae1911b Merge tag 'spi-v6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi 4a3bf9f36d1e Merge tag 'regulator-v6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator c77ca2066932 Merge tag 'mmc-v6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc c5d224537c1b Merge tag 'pwm/for-6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/ukleinek/linux 4915b8cd98b1 Merge tag 'ata-6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/libata/linux 087aaa6a3b72 Merge tag 'iommu-updates-v6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu 8a195fe51ba1 Merge tag 'net-next-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net-next 80731b204b02 Merge tag 'soc-drivers-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc ba13a7bc46d2 Merge tag 'soc-dt-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc 8bdef0681554 Merge branch 'pci/controller/qcom' 5ad36cd7e767 riscv: dts: renesas: Add Andes PMU extension for r9a07g043f 8ecbb51f81c3 dt-bindings: riscv: Add Andes PMU extension description 9b464e19669d riscv: dts: renesas: r9a07g043f: Update compatible string to use Andes INTC 7d51e7e2e08f dt-bindings: riscv: Add Andes interrupt controller compatible string 9ff0305a8ca8 ASoC: dt-bindings: cirrus,cs42l43: Fix 'gpio-ranges' schema 9527f40e46b6 Input: allocate keycode for Display refresh rate toggle 62e63d55bebc Merge tag 'i2c-host-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/andi.shyti/linux into i2c/for-mergewindow 9570e92757ae dt-bindings: tpm: Add compatible string atmel,attpm20p 7cfac8b79d64 Merge tag 'irq-core-2024-03-10' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip 432d7edb5952 dt-bindings: thermal: rcar-gen3-thermal: Add r8a779h0 support 338820b14493 dt-bindings: thermal-zones: Don't require polling-delay(-passive) 586ddb37a9a4 dt-bindings: thermal: sun8i: Add H616 THS controller 167b4b5a2247 dt-bindings: thermal: qoriq-thermal: Adjust fsl,tmu-range min/maxItems 97f8ab2a1af7 Merge tag 'opp-updates-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/vireshk/pm into pm 6478cc89c8f9 Merge tag 'asoc-v6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ac6125bb95c2 mips: dts: ralink: mt7621: add cell count properties to usb c5bb691ccc3e mips: dts: ralink: mt7621: add serial1 and serial2 nodes 7b09814959b2 mips: dts: ralink: mt7621: reorder serial0 properties ec836787ded4 mips: dts: ralink: mt7621: associate uart1_pins with serial0 7d9359e47208 Merge tag 'riscv-dt-fixes-for-v6.8-final' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into soc/dt 078fe0b4bda8 Merge tag 'arm-soc/for-6.9/drivers' of https://github.com/Broadcom/stblinux into soc/late a851536f7d1f Merge tag 'arm-soc/for-6.9/devicetree-arm64' of https://github.com/Broadcom/stblinux into soc/late 63fbbfa8e739 dt-bindings: opp: drop maxItems from inner items 54c13b3c325d dt-bindings: mailbox: fsl,mu: add i.MX95 Generic/ELE/V2X MU compatible 4950062963d6 dt-bindings: input: imagis: Document touch keys cfb6e7e4aab8 dt-bindings: PCI: qcom: Document the X1E80100 PCIe Controller c779c938fb22 dt-bindings: pinctrl: qcom: update compatible name for match with driver 98b8ca8bcb74 dt-bindings: input: atmel,captouch: convert bindings to YAML f4627ef4c35c dt-bindings: i2c: nomadik: add mobileye,eyeq5-i2c bindings and example e6a7453cf514 Merge tag 'wireless-next-2024-03-08' of git://git.kernel.org/pub/scm/linux/kernel/git/wireless/wireless-next 826587e76776 dt-bindings: PCI: qcom: Do not require 'msi-map-mask' e776ecb01509 dt-bindings: PCI: qcom: Allow 'required-opps' 41c94df7b508 dt-bindings: auxdisplay: Add bindings for generic 7-segment LED 51ec88485bd0 dt-bindings: rtc: zynqmp: Add support for Versal/Versal NET SoCs 4a0688c342c5 dt-bindings: rtc: abx80x: Improve checks on trickle charger constraints 09ed5b86a7c0 Merge branches 'arm/mediatek', 'arm/renesas', 'arm/smmu', 'x86/vt-d', 'x86/amd' and 'core' into next 1ca49df08091 dt-bindings: net: dp83822: change ti,rmii-mode description 9e691f2ca146 Merge tag 'drm-msm-next-2024-03-07' of https://gitlab.freedesktop.org/drm/msm into drm-next cfe04ff5f8c9 dt-bindings: serial: stm32: add power-domains property b072a75f7faf dt-bindings: nvmem: add common definition of nvmem-cell-cells be64edb74cf7 dt-bindings: nvmem: Convert xlnx,zynqmp-nvmem.txt to yaml baca151add1c nvmem: fixed-cell: Simplify nested if/then schema 1c0b231f57e0 dt-bindings: hwmon: Support Aspeed g6 PWM TACH Control a0c034ed370f dt-bindings: hwmon: fan: Add fan binding to schema 5f3df8a26d1e dt-bindings: hwmon: tda38640: Add interrupt & regulator properties ea5fd00e7566 Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net 1cd0ddec1f0e dt-bindings: timer: mediatek: Convert to json-schema 4a513c9ee434 ASoC: codecs: ES8326: change support for ES8326 9428855666bf dt-bindings: backlight: qcom-wled: Fix bouncing email addresses ded680d1011e dt-bindings: leds: Add NCP5623 multi-LED Controller 36c053ec1940 dt-bindings: leds: qcom-lpg: Narrow nvmem for other variants 86d79b6e9034 dt-bindings: leds: qcom-lpg: Drop redundant qcom,pm8550-pwm in if:then: 0d9351b5397b dt-bindings: leds: Add LED_FUNCTION_WAN_ONLINE for Internet access 00b899276322 dt-bindings: leds: Add FUNCTION defines for per-band WLANs 0d85184c07f6 dt-bindings: leds: leds-qcom-lpg: Add support for LPG PPG b4ab63101636 Merge branches 'ib-qcom-leds-6.9' and 'ib-leds-backlight-6.9' into ibs-for-leds-merged 3555e8d0b9fc dt-bindings: backlight: Add Kinetic KTD2801 binding a8c949969077 Merge branch 'ib-nomadik-gpio' into devel 62c3262f7fe3 dt-bindings: net: renesas,etheravb: Add support for R-Car V4M 918ae23afab4 dt-bindings: interrupt-controller: fsl,intmux: Include power-domains support e53ec66488c1 Merge tag 'icc-6.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/djakov/icc into char-misc-next 1f0e4fc46ee7 Merge tag 'qcom-arm64-for-6.9-2' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt ea75705aeacc Merge tag 'riscv-dt-for-v6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/conor/linux into soc/late 584c83fce20d dt-bindings: remoteproc: qcom,sm8550-pas: document the X1E80100 aDSP & cDSP c04e94fc3b79 dt-bindings: remoteproc: do not override firmware-name $ref 4b39a7e1c39f dt-bindings: remoteproc: qcom,glink-rpm-edge: drop redundant type from label e6ec88170ffc dt-bindings: pinctrl: Add bindings for Awinic AW9523/AW9523B fc76e2ec0af9 spi: dt-bindings: introduce FIFO depth properties 649423f8a081 ASoC: dt-bindings: rt1015: Convert to dtschema 7a4e8175bafb riscv: dts: starfive: jh7100: fix root clock names eed1e7dce0c5 Merge tag 'ath-next-20240305' of git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/ath b77c6d6ecd26 Merge tag 'v6.8-rc7' into gpio/for-next b6f4257e837d dt-bindings: input: allwinner,sun4i-a10-lrad: drop redundant type from label ab13fd756619 dt-bindings: fsl-imx-sdma: fix HDMI audio index 8183e8af3de8 dt-bindings: soc: imx: fsl,imx-iomuxc-gpr: add imx6 364eb93f21bc dt-bindings: soc: imx: fsl,imx-anatop: add binding 0d6b9633b62c dt-bindings: input: touchscreen: fsl,imx6ul-tsc convert to YAML e24d180df3e3 dt-bindings: pinctrl: fsl,imx6ul-pinctrl: convert to YAML c6cb9528755c Merge tag 'v6.9-rockchip-drivers1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt 1541b5f7169a dt-bindings: usb: typec-tcpci: add tcpci fallback binding 30cfb408e45f dt-bindings: usb: Add downstream facing ports to realtek binding ba19f225f401 dt-bindings: usb: Add binding for TI USB8020B hub controller c3251302f8d3 dt-bindings: usb: analogix,anx7411: drop redundant connector properties c6425032f69e dt-bindings: usb: add hisilicon,hi3798mv200-dwc3 a1bd84637b96 dt-bindings: mmc: hisilicon,hi3798cv200-dw-mshc: add Hi3798MV200 binding 7fc53b04c1ea dt-bindings: mmc: dw-mshc-hi3798cv200: convert to YAML f1338ec7ac44 dt-bindings: i2c: mpc: use proper binding for transfer timeouts 78ad26b5f48f dt-bindings: interrupt-controller: Convert Atmel AIC to json-schema 99d17f43c09c Merge tag 'reset-for-v6.9' of git://git.pengutronix.de/pza/linux into soc/late 14c572ddf1f9 Merge tag 'omap-for-v6.9/dt-warnings-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into soc/late 04cdefa63030 Merge tag 'vexpress-update-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/sudeep.holla/linux into soc/dt 8100aecad25e ARM: dts: samsung: exynos4412: decrease memory to account for unusable region 44ffff36c17a Merge tag 'ti-keystone-dt-for-v6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/ti/linux into soc/dt 38d2af77456f Merge tag 'memory-controller-drv-6.9-2' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux-mem-ctrl into soc/drivers 4b3d3727fe21 Merge tag 'qcom-drivers-for-6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/drivers 1390bca92db4 spi: dt-bindings: samsung: make dma properties not required f3f062800bf5 dt-bindings: perf: starfive: Add JH8100 StarLink PMU 8ade2ed03067 dt-bindings: usb: qcom,pmic-typec: add support for the PM4125 block ffd54b03300e dt-bindings: leds: pwm-multicolour: re-allow active-low 2bd3e3e38b19 dt-bindings: imx6q-pcie: Add iMX95 pcie endpoint compatible string a1a33ad5df89 dt-bindings: imx6q-pcie: Add imx95 pcie compatible string d5b3866ee39c dt-bindings: imx6q-pcie: Restruct reg and reg-name 17964120885e dt-bindings: imx6q-pcie: Clean up duplicate clocks check b2e87666166c Merge tag 'qcom-arm32-for-6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt d6f0d6fbd771 Merge tag 'v6.9-rockchip-dts32-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt 9beae6e4f5b2 Merge tag 'v6.9-rockchip-dts64-2' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt bfa16e672f23 Merge tag 'riscv-sophgo-dt-for-v6.9' of https://github.com/sophgo/linux into soc/dt b9a523277cff Merge tag 'mvebu-dt64-6.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/gclement/mvebu into soc/dt 472acadc4b85 Merge tag 'mvebu-dt-6.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/gclement/mvebu into soc/dt a1c9c09fe4c6 Merge tag 'renesas-dt-bindings-for-v6.9-tag3' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into soc/dt ed9768f823d1 Merge tag 'stm32-dt-for-v6.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/atorgue/stm32 into soc/dt a93afb6c68a1 arm64: dts: qcom: sm8250-xiaomi-elish: set rotation c1d25c9b315c arm64: dts: qcom: sm8650: Fix SPMI channels size f203c283f5bb arm64: dts: qcom: sm8550: Fix SPMI channels size 6b3cdc5e247c Merge tag 'drm-misc-next-2024-02-29' into msm-next 0ccaa0050371 dt-bindings: input/touchscreen: imagis: add compatible for IST3032C f4cd9022dce6 dt-bindings: input/touchscreen: Add compatible for IST3038B 147eff3c7cff dt-bindings: watchdog: sama5d4-wdt: add compatible for sam9x7-wdt 3a9200687cf7 dt-bindings: watchdog: sprd,sp9860-wdt: convert to YAML cbe08f41aa59 dt-bindings: watchdog: starfive,jh7100-wdt: Add compatible for JH8100 be02d67086d9 dt-bindings: watchdog: arm,sp805: document the reset signal 201c69876dc6 dt-bindings: watchdog: renesas-wdt: Add support for R-Car V4M 653594df87d5 dt-bindings: serial: convert st,asc to DT schema 1a0b7e8acef8 powerpc: dts: akebono: Harmonize EHCI/OHCI DT nodes name 8d179c0b54fb dt-bindings: usb: qcom,dwc3: fix a typo in interrupts' description c630e9b5a72f arm64: dts: qcom: pm6150: define USB-C related blocks da1d13674619 dt-bindings: usb: qcom,pmic-typec: Add support for the PM6150 PMIC d3864961a639 Merge tag 'w1-drv-6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux-w1 into tty-next 8f130bd54c7b Merge tag 'iio-for-6.9b' of https://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into char-misc-next 20d54e06e2a3 Merge tag 'coresight-next-v6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/coresight/linux into char-misc-next c326cc675c68 arm64: dts: rockchip: Fix name for UART pin header on qnap-ts433 3965a283125e dt-bindings: pwm: amlogic: Add a new binding for meson8 pwm types d397107f4e3a dt-bindings: pwm: amlogic: fix s4 bindings 6d25cc8fd5da dt-bindings: i2c: Remove obsolete i2c.txt 59488a1b3652 dt-bindings: arm: syna: remove unstable remark 1d325ff1ed92 dt-bindings: net: bluetooth: qualcomm: Fix bouncing @codeaurora 9f1d679268ba dt-bindings: watchdog: drop obsolete brcm,bcm2835-pm-wdt bindings 090fc268fac4 dt-bindings: watchdog: qcom-wdt: Update maintainer to Rajendra Nayak 0451b0796a61 dt-bindings: hwmon: lm75: use common hwmon schema 371142306400 Merge tag 'amlogic-arm64-dt-for-v6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/amlogic/linux into soc/dt 0e7fe10bc9e6 Merge tag 'amlogic-arm-dt-for-v6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/amlogic/linux into soc/dt d0cb807cfef4 Merge tag 'omap-for-v6.9/dt-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into soc/dt 3578f1b6dbed Merge tag 'ti-k3-dt-for-v6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/ti/linux into soc/dt d68c28418b67 riscv: dts: starfive: jh7110: Add camera subsystem nodes aa86c303373a arm: dts: marvell: clearfog-gtr-l8: align port numbers with enclosure ae315320f5d1 arm: dts: marvell: clearfog-gtr-l8: add support for second sfp connector 6330d58dd4fe dt-bindings: soc: renesas: renesas-soc: Add pattern for gray-hawk 1a4325f9d215 Merge tag 'arm-smmu-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/will/linux into arm/smmu 6d23cfa8897b Merge tag 'at91-dt-6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/at91/linux into soc/dt 7632a364f33e Merge tag 'zynqmp-dt-for-6.9' of https://github.com/Xilinx/linux-xlnx into soc/dt 02eba1b4512a Merge tag 'sgx-for-v6.9-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into soc/dt c0d63be31667 Merge tag 'imx-dt64-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into soc/dt 0d1bd814646e Merge tag 'imx-dt-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into soc/dt fcd3ba0ec7e6 Merge tag 'imx-bindings-6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into soc/dt 911a0e5da311 Merge tag 'socfpga_dts_updates_for_v6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/dinguyen/linux into soc/dt fec957a967a1 dt-bindings: rng: atmel,at91-trng: add sam9x7 TRNG f25a9445fef8 dt-bindings: crypto: add sam9x7 in Atmel TDES 8790f16edade dt-bindings: crypto: add sam9x7 in Atmel SHA 44266f1d25b2 dt-bindings: crypto: add sam9x7 in Atmel AES 2b1ebc6d769d Merge tag 'qcom-arm64-for-6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/qcom/linux into soc/dt 43a56bf3bdaf Merge tag 'sunxi-dt-for-6.9-1' of https://git.kernel.org/pub/scm/linux/kernel/git/sunxi/linux into soc/dt e19434848bd8 Merge tag 'drm-msm-next-2024-02-29' of https://gitlab.freedesktop.org/drm/msm into drm-next 01321d44f1ec dt-bindings: net: brcm,asp-v2.0: Add asp-v2.2 d5a543a359ce dt-bindings: net: brcm,unimac-mdio: Add asp-v2.2 089e8a0b0394 dt-bindings: gpio: aspeed,ast2400-gpio: Convert to DT schema 925e183d1d3e Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net c44ea78dc972 dt-bindings: rtc: abx80x: convert to yaml 3a25f24b71ce dt-bindings: at91rm9260-rtt: add sam9x7 compatible 6ae5f27fcef7 dt-bindings: rtc: convert MT7622 RTC to the json-schema 8e6eb376128e dt-bindings: rtc: convert MT2717 RTC to the json-schema dffd03e7b3c3 Merge branch 'icc-sm7150' into icc-next f8afb1ebc676 dt-bindings: interconnect: Add Qualcomm SM7150 DT bindings 253a470f5420 dt-bindings: mfd: syscon: Add ti,am62-usb-phy-ctrl compatible f689de1b40f9 dt-bindings: mfd: dlg,da9063: Make #interrupt-cells required a029ec8c35c4 Merge tag 'tegra-for-6.9-arm64-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into soc/dt cbda1f9ca478 Merge tag 'tegra-for-6.9-arm-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into soc/dt 061a7ef8ce88 Merge tag 'tegra-for-6.9-dt-bindings' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into soc/dt 2788cdbbf836 Merge tag 'renesas-dts-for-v6.9-tag2' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into soc/dt af467f28aa2e Merge tag 'renesas-dt-bindings-for-v6.9-tag2' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into soc/dt e422e34ebe7a Merge tag 'v6.9-rockchip-dts32-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt 15643f4b8b71 Merge tag 'v6.9-rockchip-dts64-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into soc/dt 3b71bcf355d9 Merge tag 'versatile-dts-v6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator into soc/dt d73cece0601b Merge tag 'gemini-dts-v6.9' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-integrator into soc/dt d5e822510e6a Merge tag 'mtk-dts64-for-v6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/mediatek/linux into soc/dt 88c6586d8ddc Merge tag 'dt-cleanup-6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux-dt into soc/dt 485c27391cf2 Merge tag 'samsung-dt-6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/dt 9a55de21e5e8 Merge tag 'samsung-dt64-6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into soc/dt 7fe0c3cf50e7 Merge tag 'renesas-dts-for-v6.9-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into soc/dt a28ccc2c8a1e Merge tag 'renesas-dt-bindings-for-v6.9-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-devel into soc/dt 3a1d10b8a7ea dt-bindings: pinctrl: at91: add sam9x7 25fa45a7091a arm64: dts: st: add video encoder support to stm32mp255 374df3f7a69d arm64: dts: st: add video decoder support to stm32mp255 f1523e3d07c3 dt-bindings: gpio: nomadik: add optional reset property 7c456af0e520 dt-bindings: gpio: nomadik: add mobileye,eyeq5-gpio compatible 6412671654fb dt-bindings: gpio: nomadik: add optional ngpios property 33796ff4220d dt-bindings: gpio: nomadik: convert into yaml format e5443d45c0ec ARM: dts: stm32: enable crypto accelerator on stm32mp135f-dk fdf13e6831f2 ARM: dts: stm32: enable CRC on stm32mp135f-dk b5c98471fd1a ARM: dts: stm32: add CRC on stm32mp131 f454b7a85920 dt-bindings: pinctrl: mobileye,eyeq5-pinctrl: add bindings e03c12f18d62 ARM: dts: add stm32f769-disco-mb1166-reva09 690f4c3b681a ARM: dts: stm32: add display support on stm32f769-disco 4cb81b91ac87 ARM: dts: stm32: rename mmc_vcard to vcc-3v3 on stm32f769-disco 82d1ed24df95 ARM: dts: stm32: add DSI support on stm32f769 c8114c09da2c dt-bindings: mfd: stm32f7: Add binding definition for DSI 363d4a9715e5 dt-bindings: nt35510: document 'port' property 9059c18b6d10 dt-bindings: iio: gyroscope: bosch,bmg160: add spi-max-frequency ebcb39d7a66e dt-bindings: iio: adc: imx93: drop the 4th interrupt 2f1ec66e6c94 dt-bindings: iio: adc: drop redundant type from label d24619ffe43c dt-bindings: iio: ti,tmp117: add optional label property 633fffb7c377 dt-bindings: iio: magnetometer: Add Voltafield AF8133J a36a9e62abdf dt-bindings: vendor-prefix: Add prefix for Voltafield 2ef6443e1743 dt-bindings: iio: light: vishay,veml6075: make vdd-supply required c9c055c5470f dt-bindings: iio: adc: adding support for PAC193X a288cab1e5a6 dt-bindings: iio: hmc425a: add entry for LTC6373 43172d694644 dt-bindings: iio: hmc425a: add conditional GPIO array size constraints 42707bcbabe0 dt-bindings: iio: humidity: hdc20x0: add optional interrupts property 49676274cbd7 dt-bindings: iio: ti,tmp117: add vcc supply binding 6dafe28e7298 dt-bindings: mmc: fsl-imx-mmc: Document the required clocks 620fcff9d53c spi: dt-bindings: atmel,at91rm9200-spi: remove 9x60 compatible from list 22502bd8725d dt-bindings: mmc: fsl-imx-esdhc: add default and 100mhz state a3da0bec1dd6 arm64: dts: rockchip: Add basic support for QNAP TS-433 e5d58e2bc9d5 dt-bindings: arm: rockchip: Add QNAP TS-433 78b9bf1a6128 arm64: dts: rockchip: add Haikou baseboard with RK3588-Q7 SoM 2ffa10c5e5ad arm64: dts: rockchip: add RK3588-Q7 (Tiger) SoM 7009dfbb88d7 dt-bindings: arm: rockchip: Add Theobroma-Systems RK3588 Q7 with baseboard 2516daa7bde5 arm64: dts: rockchip: drop rockchip,trcm-sync-tx-only from rk3588 i2s fc876128d301 dt-bindings: net: ethernet-controller: drop redundant type from label 13ab34ef0793 arm64: dts: rockchip: fix reset-names for rk356x i2s2 controller 883bb3a0ffc9 arm64: dts: rockchip: add missing interrupt-names for rk356x vdpu eec8be52f681 arm64: dts: rockchip: add clock to vo1-grf syscon on rk3588 103ec967103c dt-bindings: net: dsa: realtek: add reset controller 3018a826c97d dt-bindings: net: dsa: realtek: reset-gpios is not required 6dc9f167486c dt-bindings: arm: rockchip: Add Toybrick TB-RK3588X a181bc600877 arm64: dts: rockchip: Add devicetree support for TB-RK3588X board cc35d14ce704 ARM: dts: rockchip: Wifi improvements for Sonoff iHost d3e564c6f34a ARM: dts: rockchip: mmc aliases for Sonoff iHost ca5df862ea65 arm64: dts: rockchip: adjust vendor on orangepi rk3399 board ed51c83e418c arm64: dts: rockchip: adjust vendor on Banana Pi R2 Pro board cff456e5f266 dt-bindings: arm: rockchip: Correct vendor for Banana Pi R2 Pro 3522950a8c39 dt-bindings: arm: rockchip: Correct vendor for Orange Pi RK3399 board 82a17c8827d1 arm64: dts: rockchip: Add HDMI0 PHY to rk3588 e66d1e81aed1 arm64: dts: armada-ap807: update thermal compatible 1d32f2a19cc3 arm64: dts: marvell: reorder crypto interrupts on Armada SoCs 35290ca22165 arm64: dts: ac5: add mmc node and clock f5ba7df64a26 arm: dts: marvell: clearfog-gtr: add missing pinctrl for all used gpios a64c072c8b1d arm: dts: marvell: clearfog-gtr: sort pinctrl nodes alphabetically 57a80269cb6c arm: dts: marvell: clearfog-gtr: add board-specific compatible strings 9f7d319ef30b arm: dts: marvell: clearfog: add pro variant compatible in legacy dts ee29a2404550 dt-bindings: marvell: a38x: add solidrun armada 385 clearfog gtr boards a94644e247d1 dt-bindings: marvell: a38x: add kobol helios-4 board 977f211a8ee3 dt-bindings: marvell: a38x: add solidrun armada 388 clearfog boards 6fe97bf74341 dt-bindings: marvell: a38x: convert soc compatibles to yaml 313957b8c112 Merge branch 'v6.9-shared/clkids' into v6.9-armsoc/dts64 e0f54133c394 dt-bindings: clock: rk3588: add missing PCLK_VO1GRF e32d677022ca dt-bindings: clock: rk3588: drop CLK_NR_CLKS 4b58a7ccfd97 Merge tag 'mt76-for-kvalo-2024-02-22' of https://github.com/nbd168/wireless 479c5ca5c8ae dt-bindings: arm: amlogic: add Neil, Martin and Jerome as maintainers 39d812837cdd dt-bindings: arm: amlogic: remove unstable remark 54469d99a2af dt-bindings: mmc: sdhci-of-dwcmhsc: Add Sophgo CV1800B and SG2002 support f4bffe85d2e7 dt-bindings: arm: qcom,coresight-tpdm: Rename qcom,dsb-element-size 7c2c6922effb dt-bindings: memory-controller: st,stm32: add MP25 support b3f6be88f1f5 Merge 6.8-rc6 into tty-next f4288db518a8 dt-bindings: net: cdns,macb: add sam9x7 ethernet interface 5315d5ea1db7 dt-bindings: i2c: at91: Add sam9x7 compatible string b99dd7ccd5b8 dt-bindings: i2c: imx-lpi2c: add i.MX95 LPI2C d377e1b8336c Convert some regulator drivers to GPIO descriptors d5220c4662fe dt-bindings: auxdisplay: Add Maxim MAX6958/6959 2f25ffe9d998 dt-bindings: arm-smmu: Document SM8650 GPU SMMU b4c3aaf580d9 dt-bindings: arm-smmu: fix SM8[45]50 GPU SMMU if condition 0abc1ff2be4e dt-bindings: display/msm/gmu: Document Adreno 750 GMU ec4f0c02c1ec dt-bindings: display/msm: gpu: Allow multiple digits for patchid 49915776f063 dt-bindings: lcdif: Do not require power-domains for i.MX6ULL a2a81ebc850d dt-bindings: timer: Add support for cadence TTC PWM 0a54c5eb5a02 Merge tag 'renesas-pinctrl-for-v6.9-tag2' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-drivers into devel f12177200edc dt-bindings: interrupt-controller: Add starfive,jh8100-intc 99b3211ce73c regulator: dt-bindings: gpio-regulator: Fix "gpios-states" and "states" array bounds ca5cca640867 ARM: dts: omap4-panda-common: Enable powering off the device 6b4a8eca637d ARM: dts: omap-embt2ws: system-power-controller for bt200 87c4cebd8708 ARM: dts: omap: Switch over to https:// url 80adf5afe7f6 ARM: dts: ti: omap: add missing abb_{mpu,ivahd,dspeve,gpu} unit addresses for dra7 SoC a446d52725b5 ARM: dts: ti: omap: add missing sys_32k_ck unit address for dra7 SoC 4d96b742cb3e ARM: dts: ti: omap: add missing phy_gmii_sel unit address for dra7 SoC 7f22c5d06f8d dt-bindings: net: dp83822: support configuring RMII master/slave mode 5a411c0575cc ARM: dts: omap3: Update clksel clocks to use reg instead of ti,bit-shift 43768eba3fa4 ARM: dts: am3: Update clksel clocks to use reg instead of ti,bit-shift 0f8d14846135 Merge v6.8-rc6 into drm-next 5ac99b57e27a dt-bindings: mtd: brcmnand: Add ecc strap property d973f6e60329 dt-bindings: mtd: brcmnand: Add WP pin connection property e8cf96a62e99 dt-bindings: mtd: brcmnand: Updates for bcmbca SoCs 4284b95c3a7d dt-bindings: mtd: st,stm32: add MP25 support 5ffc0c6588e1 dt-bindings: mtd: update references from partition.txt to mtd.yaml 079feabfa500 arm64: dts: ti: hummingboard-t: add overlays for m.2 pci-e and usb-3 77aac4df148c arm64: dts: add description for solidrun am642 som and evaluation board bab419b95c2c dt-bindings: arm: ti: Add bindings for SolidRun AM642 HummingBoard-T bc85817742eb dt-bindings: mtd: spi-nor: add optional interrupts property 201ac0128678 dt-bindings: pwm: opencores: Add compatible for StarFive JH8100 c0aae9685a91 dt-bindings: riscv: cpus: reg matches hart ID 8e0b9c610742 dt-bindings: bus: imx-weim: convert to YAML c622150ed65c Merge v6.8-rc6 into usb-next 09994ac519e2 arm64: dts: imx8mm-kontron-bl-osm-s: Fix Ethernet PHY compatible c8b82b8dd480 arm64: dts: imx8-apalis-v1.1: Remove reset-names from ethernet-phy 20cdb2916423 ARM: dts: nxp: imx: fix weim node name 064185347fff ARM: dts: nxp: imx6ul: fix touchscreen node name 42a236fd930d ARM: dts: nxp: imx6ul: xnur-gpio -> xnur-gpios d9725dc952ee ARM: dts: imx6ul: Remove fsl,anatop from usbotg1 6cc27853e1c4 ARM: dts: imx6ull: fix pinctrl node name c23b15b18c81 ARM: dts: imx1-apf9328: Fix Ethernet node name 7c8b8cf4dd15 ARM: dts: imx28-evk: Use 'eeprom' as the node name 102744f8003d ARM: dts: ls1021a: Enable usb3-lpm-capable for usb3 node 4822eab2af53 Merge branch 'icc-cleanup' into icc-next 0b20018b1dbc dt-bindings: mtd: ubi-volume: allow UBI volumes to provide NVMEM 5d1f49b1b6b0 dt-bindings: mtd: add basic bindings for UBI 9a35e12f4b1a dt-bindings: hwmon: reference common hwmon schema 3d36f23ac624 dt-bindings: hwmon: lltc,ltc4286: use common hwmon schema 798f72d666b8 dt-bindings: hwmon: adi,adm1275: use common hwmon schema 809baabdec34 dt-bindings: hwmon: ti,ina2xx: use common hwmon schema 42d06958b709 dt-bindings: hwmon: add common properties f567e7a0ce93 regulator: dt-bindings: promote infineon buck converters to their own binding b1715c2bbc33 dt-bindings: hwmon/pmbus: ti,lm25066: document regulators 0c5601d53cce dt-bindings: hwmon: nuvoton,nct6775: Add compatible value for NCT6799 fb5eada36609 dt-bindings: trivial-devices: add Astera Labs PT5161L 7d3134823476 dt-bindings: vendor-prefixes: add asteralabs c75f1a591ccd dt-bindings: hwmon: Add Amphenol ChipCap 2 737f7b7c7c23 dt-bindings: vendor-prefixes: add Amphenol 380e45011084 dt-bindings: Add MPQ8785 voltage regulator device adb144c788f3 dt-bindings: clock: exynos850: Add CMU_CPUCLK0 and CMU_CPUCL1 77ced3f45487 dt-bindings: arm: add UNI-T UTi260B 521023b8972b dt-bindings: vendor-prefixes: add UNI-T 10a08d63eb50 arm64: dts: imx8mp-evk: Fix hdmi@3d node 96099eef1a2c arm64: dts: imx93-var-som: Remove phy-supply from eqos 0ee187cdb35f Merge tag 'iio-for-6.9a' of http://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into char-misc-next 9aa0ba8c3e6a arm64: dts: imx8mp-phyboard-pollux: Disable pull-up for CD GPIO 195bcec93c44 arm64: dts: imx8mp-phyboard-pollux: Reduce drive strength for eqos tx lines adb0eb622cec arm64: dts: imx8mp-phyboard-pollux: Set debug uart muxing to 0x140 8032acfdf1a8 arm64: dts: imx8mp-phyboard-pollux: Add and update rtc devicetree node 9ffab265f1ac arm64: dts: imx8mm-evk: Add spdif sound card support 3f1b2e8d9e29 arm64: dts: mba8xx: Add missing #interrupt-cells dd5af1f60a28 arm64: dts: imx8mp: Set SPI NOR to max 40 MHz on Data Modul i.MX8M Plus eDM SBC f461418b3107 ARM: dts: imx6dl-yapp4: Move the internal switch PHYs under the switch node dbaddd2cc383 ARM: dts: imx6dl-yapp4: Fix typo in the QCA switch register address 6a28d56cd75a arm64: dts: imx8mn: tqma8mqnl-mba8mx: Add USB DR overlay 68f02dd7e55f arm64: dts: imx8mq: tqma8mq-mba8mx: Add missing USB vbus supply 06e63f07db24 arm64: dts: freescale: imx8mm/imx8mq: mba8mx: Use PCIe clock generator 65f27cc9ca1b arm64: dts: imx8mn-beacon: Remove unnecessary clock configuration ec091103f662 arm64: dts: imx8mn: Slow default video_pll clock rate f3ed68d12445 arm64: dts: imx8mp-beacon: Configure multiple queues on eqos 825a35212289 arm64: dts: imx8mp-beacon: Enable Bluetooth e32a570a61aa ARM: dts: imx6ul: Set macaddress location in ocotp 48b05a3282bd arm64: dts: freescale: minor whitespace cleanup 4b0cf920e774 arm64: dts: allwinner: h616: Add thermal sensor and zones d0665f60cec0 ARM: dts: sun8i: Open FETA40i-C regulator aldo1 f0c099b60ae3 arm64: dts: allwinner: h616: Add Sipeed Longan SoM 3H and Pi 3H board support 01ae6c03a880 dt-bindings: arm: sunxi: Add Sipeed Longan Module 3H and Longan Pi 3H c763b1cf0ca7 arm64: dts: allwinner: h616: minor whitespace cleanup fba9e58bbd03 arm64: dts: allwinner: use capital "OR" for multiple licenses in SPDX c6b7cf5d4b69 arm64: dts: allwinner: Transpeed 8K618-T: add WiFi nodes 13d73fcac8c9 arm64: dts: allwinner: h616: Add 32K fanout pin 05bdbb1eb3fd arm64: dts: allwinner: Add Jide Remix Mini PC support 0df51b232403 dt-bindings: arm: sunxi: document Remix Mini PC name 898b36322bb2 dt-bindings: vendor-prefixes: add Jide 70e735bb236e arm64: dts: allwinner: h616: Add SPDIF device node 10969c04cb6e arm64: dts: allwinner: h616: Add DMA controller and DMA channels c5182cdc0aa8 arm64: dts: allwinner: h6: Add RX DMA channel for SPDIF e31d5ca612d6 dt-bindings: sram: narrow regex for unit address to hex numbers 013b1096017d ARM: dts: microchip: sama7g5: add sama7g5 compatible 782f527e1b30 ARM: dts: microchip: sam9x60: align dmas to the opening '<' d08950521775 ARM: dts: microchip: sama7g5: align dmas to the opening '<' c9cdb533541e ARM: dts: microchip: sama7g54_curiosity: Add initial device tree of the board 28a13f689e75 ARM: dts: microchip: sama7g5: Add flexcom 10 node 57fb3296fc2d ASoC: dt-bindings: microchip: add sam9x7 81a8f19d991d ASoC: dt-bindings: atmel-classd: add sam9x7 compatible c1e8427eb3df dt-bindings: ARM: at91: Document Microchip SAMA7G54 Curiosity 708077cf30a4 arm64: tegra: Remove Jetson Orin NX and Jetson Orin Nano DTSI 14b1c490371e arm64: tegra: Add audio support for Jetson Orin NX and Jetson Orin Nano 5bdc0a8fed68 arm64: tegra: Define missing IO ports 8ff1bf770a0c arm64: tegra: Move AHUB ports to SoC DTSI 9fd53de0ed30 arm64: tegra: Add USB Type-C controller for Jetson AGX Xavier 6c9a92242095 arm64: tegra: Add USB device support for Jetson AGX Xavier 495a87da7a47 arm64: tegra: Add current monitors for Jetson Xavier 426c1ddbd76b arm64: tegra: Add AXI configuration for Tegra234 MGBE 134b7a20eea2 dt-bindings: mfd: Convert atmel-flexcom to json-schema 7268c6969288 dt-bindings: mfd: cros-ec: Add properties for GPIO controller a5c0c33c25f1 dt-bindings: mfd: ti,twl: Document system-power-controller 507cf9210c91 dt-bindings: net: wireless: qcom: Update maintainers a9219f105d93 dt-bindings: mfd: syscon: Add ti,am654-serdes-ctrl compatible 37c3dbbbca5d dt-bindings: mfd: syscon: Add ti,j784s4-pcie-ctrl compatible ef9712ce90c9 dt-bindings: mfd: atmel,hlcdc: Convert to DT schema format fc3911fb624f dt-bindings: mfd: qcom,tcsr: Add compatibles for QCM2290 and SM6115 bcc7a549de96 dt-bindings: mfd: iqs62x: Do not override firmware-name $ref e3889bfdf9d5 dt-bindings: media: rkisp1: Add i.MX8MP ISP to compatible e7d16b884c9d dt-bindings: timer: add Ralink SoCs system tick counter f4535baea464 dt-bindings: PCI: qcom,pcie-sa8775p: Move SA8775p to dedicated schema 169fa31aecaa dt-bindings: PCI: qcom,pcie-sc7280: Move SC7280 to dedicated schema 9a6e22b46113 dt-bindings: PCI: qcom,pcie-sc8180x: Move SC8180X to dedicated schema e114fb24a186 dt-bindings: PCI: qcom,pcie-sc8280xp: Move SC8280XP to dedicated schema 88e9e05efe99 dt-bindings: PCI: qcom,pcie-sm8350: Move SM8350 to dedicated schema 977832dca6ab dt-bindings: PCI: qcom,pcie-sm8150: Move SM8150 to dedicated schema 53908f6ff54c dt-bindings: PCI: qcom,pcie-sm8250: Move SM8250 to dedicated schema 96931e6b08ab dt-bindings: PCI: qcom,pcie-sm8450: Move SM8450 to dedicated schema 3c9f28bcffc2 dt-bindings: PCI: qcom,pcie-sm8550: Move SM8550 to dedicated schema c2f1d4a9447a arm64: dts: renesas: rzg2l-smarc: Enable DU and link with DSI b39f9a0e920d arm64: dts: renesas: r9a07g054: Add DU node 3ecd2f1980c9 arm64: dts: renesas: r9a07g044: Add DU node 93d319ea783c arm64: dts: lx2160a: Fix DTS for full PL011 UART 8365edf2f65e arm64: dts: ls1088a: Add the PME interrupt for PCIe EP node 084a47a95058 arm64: dts: imx8qm: add i2c1 for imx8qm-mek board d84b45a3c712 arm64: dts: imx8qm: add i2c4 and i2c4_lpcg node 9d3bb1c53622 ASoC: Revert "ASoC: dt-bindings: Update example for enabling USB offload on SM8250" 7ada2cb724f2 riscv: dts: add resets property for uart node a034d20d33af riscv: dts: add reset generator for Sophgo SG2042 SoC b312f7c28451 ARM: dts: imx53-qsb: add support for the HDMI expander 65d763356aad arm64: dts: imx8mp: Enable SAI audio on Data Modul i.MX8M Plus eDM SBC c3b757a52529 arm64: dts: imx8: Fix lpuart DMA channel order a9c570888e1c arm64: dts: freescale: imx8-ss-dma: Fix edma3's location 1880684dfc18 arm64: dts: imx8dxl update edma0 information 95a51114540e arm64: dts: imx8dxl: add fsl-dma.h dt-binding header file 87cc839ce871 Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net 595539769055 dt-bindings: vendor-prefixes: Add missing prefixes used in compatibles 2b8f61f2af78 dt-bindings: display: convert Atmel's HLCDC to DT schema d4e9fb508b98 dt-bindings: display/msm: Document MDSS on X1E80100 26ae54a934e7 dt-bindings: display/msm: Document the DPU for X1E80100 eec4611e4fa5 dt-bindings: arm-smmu: Document SM8650 GPU SMMU 011fc2593f52 dt-bindings: arm-smmu: Fix SM8[45]50 GPU SMMU 'if' condition f45f80911a1e ARM: tegra: Add device-tree for LG Optimus 4X HD (P880) c99ab6147bdd ARM: tegra: Add device-tree for LG Optimus Vu (P895) 9668ead0c4a9 ARM: tegra: nexus7: Add missing clock binding into sound node 1a7c7ca1209d dt-bindings: arm: tegra: Add LG Optimus Vu P895 and Optimus 4X P880 55fa85648879 arm64: dts: Add gpio_intc node for Amlogic-T7 SoCs 3040579f9058 dt-bindings: interrupt-controller: Add support for Amlogic-T7 SoCs ac30a4ade02e dt-bindings: interrupt-controller: renesas,rzg2l-irqc: Update interrupts cf713971ea71 dt-bindings: arm-smmu: Add QCM2290 GPU SMMU cfbcf932a683 arm64: dts: renesas: gray-hawk-single: Add QSPI FLASH support 7b0d1d64e101 arm64: dts: renesas: r8a779h0: Add RPC node cf8ea631a9d7 arm64: dts: renesas: r8a779h0: Add DMA support 44de0122e321 arm64: dts: renesas: gray-hawk-single: Add eMMC support 697c226a4355 arm64: dts: renesas: r8a779h0: Add SD/MMC node bc3ce3810946 ARM: dts: renesas: r8a7778: Add missing reg-names to sound node 59d2898af1c8 arm64: dts: renesas: rzg2ul-smarc: Enable CRU, CSI support e4684cc943fe arm64: dts: renesas: gray-hawk-single: Add Ethernet support 08896ba8e650 arm64: dts: renesas: r8a779h0: Add Ethernet-AVB support fe2d22e4ae91 arm64: dts: renesas: r8a779g0: Correct avb[01] reg sizes 4c2e92819772 arm64: dts: renesas: r8a779a0: Correct avb[01] reg sizes d857aea85b27 arm64: dts: renesas: r9a08g045: Add PSCI support ac45f97b1f9c arm64: dts: renesas: rzg3s-smarc-som: Guard Ethernet IRQ GPIO hogs aef97a58051b arm64: dts: renesas: r9a08g045: Add missing interrupts to IRQC node 68b5a3b20687 arm64: dts: renesas: rzg2l: Add missing interrupts to IRQC nodes 5a4108c215f6 arm64: dts: renesas: r8a779h0: Add CA76 operating points bd25260cfef9 arm64: dts: renesas: r8a779h0: Add CPU core clocks 291552f30777 arm64: dts: renesas: r8a779h0: Add CPUIdle support 20170eff3c40 arm64: dts: renesas: r8a779h0: Add secondary CA76 CPU cores 4c3851d7302a arm64: dts: renesas: r8a779h0: Add L3 cache controller 149125c48481 arm64: dts: renesas: r8a779h0: Add GPIO nodes e6842397bea1 arm64: dts: renesas: gray-hawk-single: Add I2C0 and EEPROMs 4ab7a0fae505 arm64: dts: renesas: r8a779h0: Add I2C nodes 4f678406736f arm64: dts: renesas: ulcb-kf: Adapt sound 5v regulator to schematics ab5123a5fcbb arm64: dts: renesas: ulcb-kf: Adapt 1.8V HDMI regulator to schematics 36bd3f79100c arm64: dts: renesas: ulcb-kf: Add regulators for PCIe ch1 d79c233e5296 arm64: dts: renesas: gray-hawk-single: Add serial console pin control adb055f45503 arm64: dts: renesas: r8a779h0: Add pinctrl device node 393149daa9ec dt-bindings: net: wireless: mt76: allow all 4 interrupts for MT7981 abc93201d108 dt-bindings: net: wireless: mt76: add interrupts description for MT7986 6ff46183ee46 dt-bindings: memory: renesas,rpc-if: Document R-Car V4M support caaf33bab010 dt-bindings: reset: mobileye,eyeq5-reset: add bindings d627a28b5d6f dt-bindings: clock: mobileye,eyeq5-clk: add bindings ebd3bcd073ce dt-bindings: clock: ast2600: Add FSI clock d19d06cdbb21 dt-bindings: reset: mediatek: add MT7988 infracfg reset IDs f907dd749888 dt-bindings: clock: mediatek: convert SSUSBSYS to the json-schema clock 77f559281267 dt-bindings: clock: mediatek: convert PCIESYS to the json-schema clock 5776acd8f40b dt-bindings: clock: mediatek: convert hifsys to the json-schema clock 2b71a4051c65 dt-bindings: arm: realview: Spelling s/ARM 11/Arm11/, s/Cortex A-/Cortex-A/ d5d9be3159cd ARM: dts: integrator: Fix up VGA connector e7ff0fa9dc10 ARM: dts: versatile: Fix up VGA connector 5cc0ca358e86 ARM: dts: arm: realview: Fix development chip ROM compatible value 17690d898c6b arm64: dts: ti: k3-am62p: Add Wave5 Video Encoder/Decoder Node 1a04d9e2ea04 arm64: dts: ti: k3-j721s2-main: Add Wave5 Video Encoder/Decoder Node 037f82133c88 arm64: dts: ti: k3-j784s4: Add Wave5 Video Encoder/Decoder Node b9b4934fd72d arm64: dts: ti: k3-am69-sk: Add support for OSPI flash 54bdd26cd110 arm64: dts: ti: k3-am69-sk: Enable CAN interfaces for AM69 SK board 5ddb529be866 arm64: dts: ti: k3-am62p: Add nodes for CSI-RX 2bc64591456d arm64: dts: ti: k3-am62p: Add DMASS1 for CSI fb6e8cb37b07 arm64: dts: ti: k3-am62p: Fix memory ranges for DMSS 4a664d32a079 arm64: dts: ti: k3-j722s-evm: Enable OSPI NOR support 0a3c08b6205b arm64: dts: ti: k3-j722s-evm: Enable CPSW3G RGMII1 6d9068d2f3e7 arm64: dts: ti: k3-j784s4-main: Fix mux-reg-masks in serdes_ln_ctrl 8f04b7849578 arm64: dts: ti: k3-j721e: Fix mux-reg-masks in hbmc_mux c3982938ea86 dt-bindings: display: renesas,rzg2l-du: Document RZ/V2L DU bindings 62d59754ec63 dt-bindings: display: Document Renesas RZ/G2L DU bindings b9138e8af159 arm64: tegra: Use consistent SD/MMC aliases on Tegra234 dcff839661ba arm64: dts: amlogic: add fbx8am DT overlays 0d16b6bd5803 ARM: dts: gemini: Fix switch node names on Vitesse switches 81e1d1cfd2f9 ARM: dts: gemini: Map reset keys to KEY_RESTART 915ebb1bf1e0 ARM: dts: gemini: Fix wiligear compatible strings d8869f38c863 ARM: dts: gemini: Fix switch node names in the DIR-685 4466332a360b ASoC: dt-bindings: qcom,wsa8840: Add reset-gpios for shared line 8d8332ce62c5 dt-bindings: reset: sophgo: support SG2042 357d5bbac5af ASoC: Intel: avs: Fixes and new platforms support ed4851e1d924 regulator: dt-bindings: qcom,usb-vbus-regulator: add support for PM4125 bcf5ae8600f6 regulator: dt-bindings: qcom,usb-vbus-regulator: add support for PM4125 90ad8fbfa7f9 Merge tag 'memory-controller-drv-6.9' of https://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux-mem-ctrl into soc/drivers 6a8fb7b89e73 arm64: dts: qcom: sm6115: fix USB PHY configuration 0dc3ecab7183 Merge tag 'linux-can-next-for-6.9-20240220' of git://git.kernel.org/pub/scm/linux/kernel/git/mkl/linux-can-next f923d17647b5 MIPS: mobileye: Add EPM5 device tree 885d1e731299 MIPS: mobileye: Add EyeQ5 dtsi 7fb9ce7c1dde dt-bindings: mips: Add bindings for Mobileye SoCs e3797e6a3708 dt-bindings: mips: cpu: Add I-Class I6500 Multiprocessor Core 9a705909b63d dt-bindings: mips: cpus: Sort the entries e0340332869b dt-bindings: Add vendor prefix for Mobileye Vision Technologies Ltd. 011bf078c7bc dt-bindings: pinctrl: renesas,pfc: Document R-Car V4M support 49888873d596 dt-bindings: net: fec: add iommus property 80733980e6ba dt-bindings: iio: adc: ti-ads1298: Add bindings 26a3005ca5c0 dt-bindings: iio: pressure: honeywell,hsc030pa.yaml add spi props d64846638639 dt-bindings: adc: axi-adc: update bindings for backend framework a3fc6ec1428b dt-bindings: adc: ad9467: add new io-backend property c0d436471a5f regulator: Merge up v6.8-rc5 52dcafce5828 dt-bindings: regulator: qcom,usb-vbus-regulator: Add PM6150 compatible 66f7b7966dfc arm64: dts: ti: Add common1 register space for AM62A SoC 6b911cea73bb arm64: dts: ti: Add common1 register space for AM62x SoC bb6e999b30ab arm64: dts: ti: Add common1 register space for AM65x SoC 2a98a4ff884d arm64: dts: mt8195-cherry-tomato: change watchdog reset boot flow b5c66885729f dt-bindings: display: simple: Add boe,bp082wx1-100 8.2" panel 0b9a359a81b7 dt-bindings: display: ti,am65x-dss: Add support for common1 region 0033e16adcd4 dt-bindings: renesas: Document preferred compatible naming 1771fa16d31e dt-bindings: ata: convert MediaTek controller to the json-schema 127ae13f4e5e arm64: dts: mt7986: add port@5 as CPU port 57f255ff84ed arm64: dts: mt7622: add port@5 as CPU port 1e471beb8eea ARM: dts: meson8b: fix &hwrng node compatible string 320da6153b8a ARM: dts: meson8: fix &hwrng node compatible string 9625cfa0c727 ARM: dts: meson: fix bus node names f496b04c1652 arm64: dts: amlogic: add fbx8am board 686e2be425fd dt-bindings: arm: amlogic: add fbx8am binding 48371b0670ac dt-bindings: vendor-prefixes: add freebox 471f9b9dd5e2 arm64: dts: amlogic: replace underscores in node names 6e0fb3cc9b68 arm64: dts: ti: k3-am642-evm: add overlay for ICSSG1 2nd port 7526121625ee dt-bindings: interconnect: qcom,rpmh: Fix bouncing @codeaurora address fcda7c3e7ef7 Merge 6.8-rc5 into usb-next 670cbcdfbb09 arm64: dts: ti: k3-am642-evm: add ICSSG1 Ethernet support cea3277e3b5e arm64: dts: ti: k3-am64-main: Add ICSSG IEP nodes eb0aea3a7c5a Merge 6.8-rc5 into tty-next c07c11c8be59 arm64: dts: ti: k3-am6*: Add bootph-all property in MMC node 59d465b82cb4 arm64: dts: ti: k3-am6*: Fix bus-width property in MMC nodes 16af8c673aff arm64: dts: ti: k3-am6*: Fix ti,clkbuf-sel property in MMC nodes 87f154491e63 arm64: dts: ti: k3-am6*: Remove DLL properties for soft PHYs 722bd88c8fab arm64: dts: ti: k3-am62p: Add ITAP/OTAP values for MMC 18c8263c1ec1 arm64: dts: ti: k3-am64-main: Fix ITAP/OTAP values for MMC 73f1cbbcb198 arm64: dts: ti: k3-am62a7-sk: Enable eMMC support 973681d9002a arm64: dts: ti: k3-am62a-main: Add sdhci2 instance 4430a5c5a0ec arm64: dts: ti: k3-am62a-main: Add sdhci0 instance be340f86aaf1 arm64: dts: sm8650: Add msi-map-mask for PCIe nodes 49cf8bb8b63f arm64: dts: qcom: replace underscores in node names 8f9d0aa368d0 ARM: dts: qcom: samsung-matisse-common: Add UART ce30f2d31d9c ARM: dts: qcom: Add support for Samsung Galaxy Tab 4 10.1 LTE (SM-T535) afbdd6233c4a ARM: dts: qcom: samsung-matisse-common: Add initial common device tree 6a80ca4b242a dt-bindings: arm: qcom: Add Samsung Galaxy Tab 4 10.1 LTE 3cef33d6916c dt-bindings: soc: qcom: qcom,saw2: add msm8226 l2 compatible e4d2d663cf96 arm64: dts: ti: k3-j784s4-evm: Remove Pinmux for CTS and RTS in wkup_uart0 d43ac341179d arm64: dts: ti: k3-j721s2-common-proc-board: Remove Pinmux for CTS and RTS in wkup_uart0 80e20b3b69c9 arm64: dts: ti: k3-j7200-common-proc-board: Remove clock-frequency from mcu_uart0 35877fcaea3a arm64: dts: ti: k3-j7200-common-proc-board: Modify Pinmux for wkup_uart0 and mcu_uart0 cac67785c0a6 arm64: dts: ti: k3-j721e-sk: Add overlay for IMX219 b1d7814ca372 arm64: dts: ti: k3-j784s4-main: Add CSI2RX capture nodes b6b2d86e2411 arm64: dts: ti: k3-j721s2-main: Add CSI2RX capture nodes 58403c60add6 arm64: dts: ti: k3-j721e-main: Add CSI2RX capture nodes 4796014c5f92 arm64: dts: ti: k3-j721e-sk: Model CSI2RX connector mux b599ef1ba8ff arm64: dts: ti: k3-am69-sk: Enable camera peripherals 248c870c7bd6 arm64: dts: ti: k3-am68-sk-base-board: Enable camera peripherals a5f6b550f77b arm64: dts: ti: k3-j784s4-evm: Enable camera peripherals f70c4ae50ecf arm64: dts: ti: k3-j721s2-common-proc-board: Enable camera peripherals 4141c6b09a96 dt-bindings: i3c: drop "master" node name suffix f3ca3a16bd19 dt-bindings: timer: nxp,sysctr-timer: support i.MX95 19b1a141c8dd dt-bindings: usb: qcom,pmic-typec: add support for the PMI632 block 15c348192cc2 dt-bindings: regulator: qcom,usb-vbus-regulator: add support for PMI632 3c201cdbc89a dt-bindings: iio: humidity: hdc3020: add interrupt bindings in example 0fc77339f456 dt-bindings: iio: afe: voltage-divider: Add io-channel-cells 7adf6f669393 dt-bindings: iio: imu: st_lsm6dsx: add asm330lhhxg1 bd37e5428ced dt-bindings: iio: frequency: add admfm2000 f6c7124a3d91 dt-bindings: usb/ti,am62-usb.yaml: Add PHY2 register space 3102faf7d698 dt-bindings: usb: microchip,usb5744: Remove peer-hub as requirement d403cb0d5128 arm64: dts: qcom: qcm6490-fairphone-fp5: Add PMIC GLINK 7ab947b60396 dt-bindings: usb: dwc3: drop 'snps,host-vbus-glitches-quirk' e007ca0c7920 ASoC: dt-bindings: Update example for enabling USB offload on SM8250 14bd5c629408 ASoC: dt-bindings: Add Q6USB backend 86b2f37571d9 arm64: dts: ti: Add reserved memory for watchdog 0ffb30594139 arm64: dts: qcom: pm4125: define USB-C related blocks 437f7c2c748a arm64: dts: qcom: sa8540p-ride: disable pcie2a node ddc97b021a4f arm64: dts: qcom: sc7280: add slimbus DT node 174b19d0a453 dt-bindings: display: ltk500hd1829: add variant compatible for ltk101b4029w 9990fd362767 dt-bindings: display: panel-lvds: Add compatible for admatec 9904370 panel 3a9936a295c2 dt-bindings: vendor-prefixes: add prefix for admatec GmbH 11b2a690403f arm64: dts: qcom: sc7280: Add capacity and DPC properties 23437543023d ARM: dts: qcom: ipq8064: drop 'regulator' property from SAW2 devices cabc075cf325 ARM: dts: qcom: ipq4019: drop 'regulator' property from SAW2 devices 484c003d94ab ARM: dts: qcom: msm8974: drop 'regulator' property from SAW2 device 6445cb8886be ARM: dts: qcom: apq8084: drop 'regulator' property from SAW2 device 98ba5545146c ARM: dts: qcom: msm8960: declare SAW2 regulators b54dea12770f ARM: dts: qcom: apq8064: declare SAW2 regulators 4dce2cf9f83d ARM: dts: qcom: ipq8064: rename SAW nodes to power-manager 5b13a9611268 ARM: dts: qcom: ipq4019: rename SAW nodes to power-manager 0ec0f547bc86 ARM: dts: qcom: msm8974: rename SAW nodes to power-manager 9c6828f9c895 ARM: dts: qcom: msm8960: rename SAW nodes to power-manager d5acf25ed148 ARM: dts: qcom: apq8084: rename SAW nodes to power-manager 643db1cecca9 ARM: dts: qcom: apq8064: rename SAW nodes to power-manager 4de620145e88 ARM: dts: qcom: ipq8064: use SoC-specific compatibles for SAW2 devices c44fb47e47a5 ARM: dts: qcom: ipq4019: use SoC-specific compatibles for SAW2 devices 5e99522aa387 ARM: dts: qcom: msm8960: use SoC-specific compatibles for SAW2 devices 75a6d010f715 ARM: dts: qcom: msm8974: use new compat string for L2 SAW2 unit 9eb4395e3cbc ARM: dts: qcom: apq8084: use new compat string for L2 SAW2 unit 0cc21b045573 arm64: dts: qcom: pmi632: Add PBS client and use in LPG node adaff156bd89 arm64: dts: qcom: sm8550: Use GIC-ITS for PCIe0 and PCIe1 567a4e2c1bfd arm64: dts: qcom: sm8150: correct PCIe wake-gpios aff4851c71af arm64: dts: qcom: sdm845-db845c: correct PCIe wake-gpios d12e2e81b378 dt-bindings: soc: qcom: qcom,saw2: define optional regulator node 87cb0efb080c dt-bindings: soc: qcom: qcom,saw2: add missing compatible strings 78779d5162e9 dt-bindings: soc: qcom: merge qcom,saw2.txt into qcom,spm.yaml 90689200835c arm64: dts: qcom: sm7225-fairphone-fp4: Enable display and GPU 49fc8baa3dd8 arm64: dts: qcom: sm6350: Remove "disabled" state of GMU 3bb88ee4bafc dt-bindings: clk: qcom: drop the SC7180 Modem subsystem clock controller 08488eb0c95c arm64: dts: qcom: msm8916-samsung-fortuna/rossa: Add fuel gauge 9230383364ef arm64: dts: qcom: sm6350: Add interconnect for MDSS 93d1070a237b dt-bindings: can: xilinx_can: Add 'xlnx,has-ecc' optional property 09c2905a6449 dt-bindings: renesas,rcar-dmac: Add r8a779h0 support 8500691f667d dt-bindings: dma: convert MediaTek High-Speed controller to the json-schema 7b382eea018b arm64: tegra: Enable cros-ec-spi as wake source 73f09474de21 ARM: tegra: Enable cros-ec-spi as wake source 9c3c23577ad9 dt-bindings: tegra: pmc: Update scratch as an optional aperture 296aea7e0f2a dt-bindings: display: panel: Add Himax HX83112A 5b0ce634f06d dt-bindings: phy: Add Rockchip HDMI/eDP Combo PHY schema 01f41446bb7f Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net 87dd58b7c6ca dt-bindings: mmc: renesas,sdhi: Document R-Car V4M support ec136bb18fcc arm64: dts: ti: Add support for TI J722S Evaluation Module 4dd9e11aa40f arm64: dts: ti: Introduce J722S family of SoCs 1339c374a4c1 dt-bindings: arm: ti: Add bindings for J722S SoCs 723c10f0bd63 arm64: dts: ti: iot2050: Support IOT2050-SM variant 4a95da5a5df9 arm64: dts: ti: iot2050: Annotate LED nodes a2119b7f92bd arm64: dts: ti: iot2050: Factor out DP related bits a3f672abd86f arm64: dts: ti: iot2050: Factor out enabling of USB3 support 0f7fd425cef9 arm64: dts: ti: iot2050: Factor out arduino connector bits 326a69a3e459 arm64: dts: ti: iot2050: Disable R5 lockstep for all PG2 boards 9f6227cced13 dt-bindings: arm: ti: Add binding for Siemens IOT2050 SM variant 4c8ad6e37e97 arm64: dts: ti: k3-am62-main: disable usb lpm 58003d5a29e5 arm64: dts: ti: verdin-am62: Set VDD CORE minimum voltage to 0.75V 09148e5825bc arm64: dts: ti: k3-am62-wakeup: Configure ti-sysc for wkup_uart0 8d7152a47403 arm64: dts: ti: am62-phyboard-lyra: Add overlay to enable a GPIO fan 16c636f5b152 arm64: dts: ti: k3-j721e-sk: fix PMIC interrupt number 2932b4306805 arm64: dts: ti: k3-am69-sk: fix PMIC interrupt number f6c375e9f85d arm64: dts: ti: verdin-am62: add support for Verdin USB1 interface 309045be68da arm64: dts: ti: Add DT overlay for PCIe + USB3.0 SERDES personality card 2979217a850f arm64: dts: ti: Add DT overlay for PCIe + USB2.0 SERDES personality card b70ff6a5d411 dt-bindings: w1: UART 1-Wire bus 21e00d907bfb dt-bindings: serial: allow onewire as child node 1f162c88f711 dt-bindings: pwm: mediatek,mt2712: add compatible for MT7988 b69225cd6653 dt-bindings: atmel,hlcdc: convert pwm bindings to json-schema 4fc4f31db241 dt-bindings: pxa-pwm: Convert to YAML 61f4ac7c5c90 ARM: dts: vexpress: Set stdout-path to serial0 in the chosen node 199bf4b635e6 arm64: dts: mediatek: Replace deprecated extcon-usb-gpio id-gpio/vbus-gpio properties 73d46717fb3d ARM: dts: qcom: msm8226: Add watchdog node 01815a93d9ab dt-bindings: auxdisplay: hit,hd44780: use defines for GPIO flags 41e657a00f9c dt-bindings: auxdisplay: adjust example indentation and use generic node names 81b0dd090434 arm64: dts: qcom: msm8916-samsung-fortuna/rossa: Add initial device trees 3fa556edfd69 arm64: dts: qcom: sm8550: Switch UFS from opp-table-hz to opp-v2 8761bb9477f3 arm64: dts: qcom: sc8180x: describe all PCI MSI interrupts 3419b50ca541 arm64: dts: qcom: minor whitespace cleanup 1a30651d27f6 arm64: dts: qcom: ssm7125-xiaomi: drop incorrect UFS phy max current 8f644a3c370b arm64: dts: qcom: x1e80100-crd: add sound card 22e29ff5c4c3 arm64: dts: x1e80100: correct DMIC2 and DMIC3 pin config node names b32ccff427b3 arm64: dts: sm8650: correct DMIC2 and DMIC3 pin config node names 8b41c24a5900 arm64: dts: sm8550: correct DMIC2 and DMIC3 pin config node names d0bad83ec278 arm64: dts: sm8450: correct DMIC2 and DMIC3 pin config node names 736ebb0686f6 arm64: dts: sc8280xp: correct DMIC2 and DMIC3 pin config node names 33ef3b7fb778 dt-bindings: can: tcan4x5x: Document the wakeup-source flag 11322433ed0f dt-bindings: net: dp83826: support TX data voltage tuning a745442704dd ARM: dts: stm32: lxa-tac: reduce RGMII interface drive strength bdbd2fbe2a1f arm64: dts: mediatek: replace underscores in node names bb7b4de1613f pmdomain: Merge branch dt into next 20b8bae8b8eb arm64: dts: ti: k3-am62a: Make the main_conf node a simple-bus e42f80bc5bcf arm64: dts: ti: k3-am62: Make the main_conf node a simple-bus 8ba7dd15abdd arm64: dts: ti: k3-j7200: Make the FSS node a simple-bus 42ed47d60a80 arm64: dts: ti: k3-j721s2: Convert serdes_ln_ctrl node into reg-mux bf6f8e6f98e5 arm64: dts: ti: k3-j721s2: Convert usb_serdes_mux node into reg-mux 0167a788d9c5 arm64: dts: ti: k3-j721e: Convert usb_serdes_mux node into reg-mux 124c59a52517 arm64: dts: ti: k3-j721e: Convert serdes_ln_ctrl node into reg-mux ebb5990bd126 arm64: dts: ti: k3-j7200: Convert usb_serdes_mux node into reg-mux c0c92c3b24bd arm64: dts: ti: k3-j7200: Convert serdes_ln_ctrl node into reg-mux 8c7e27a256ed arm64: dts: ti: k3-am64: Convert serdes_ln_ctrl node into reg-mux ecaaf99dee6f arm64: dts: mediatek: mt8186: Add missing xhci clock to usb controllers 546dd2b71775 arm64: dts: mediatek: mt8186: Add missing clocks to ssusb power domains 845392fb2a8c ARM: dts: qcom: msm8960: expressatt: Add mXT224S touchscreen a5fc0fcda8d3 ARM: dts: qcom: msm8960: Add gsbi3 node e5357a45e304 ARM: dts: qcom: msm8226: Add CPU and SAW/ACC nodes df98c13b52f1 ARM: dts: qcom: msm8226: Sort and clean up nodes 4250f1c8ff79 ARM: dts: qcom: msm8974: correct qfprom node size 7d8cff577be7 dt-bindings: arm: qcom,ids: Add IDs for SM8475 family ee8caed03c87 arm64: dts: qcom: sdm845: Enable cros-ec-spi as wake source 6eef1cbc79c9 arm64: dts: qcom: sc7280: Enable cros-ec-spi as wake source 097f3128d091 arm64: dts: qcom: sc7180: Enable cros-ec-spi as wake source 1a1c9101358c arm64: dts: qcom: sdm845: Use the Low Power Island CX/MX for SLPI 292108e317ec arm64: dts: qcom: msm8996: Define UFS UniPro clock limits 71aab956985a arm64: dts: qcom: qcs6490-rb3gen2: Declare GCC clocks protected 5a7b32324b50 arm64: dts: qcom: sc8280xp-pmics: Define adc for temp-alarms c7cdefde3890 arm64: dts: qcom: sc8280xp-crd: Add PMIC die-temp vadc channels fc4657cf641c dt-bindings: net: qca,ar9331: convert to DT schema f8930a53d1df arm64: dts: rockchip: Add USB3.0 to Indiedroid Nova 5e1a3b5538e5 arm64: dts: rockchip: adjust phy-handle name on rock-pi-e 67a655c02d0c arm64: dts: rockchip: fix rk3399 hdmi ports node 1ce4f570403a arm64: dts: rockchip: fix rk3328 hdmi ports node fe75fb3e4156 ARM: dts: rockchip: fix rk322x hdmi ports node d8715fea4366 ARM: dts: rockchip: fix rk3288 hdmi ports node 3693fdfce256 dt-bindings: display: rockchip,dw-hdmi: add power-domains property a3f511793cc1 dt-bindings: display: rockchip: rockchip,dw-hdmi: remove port property fdad3ea0d962 arm64: dts: rockchip: remove redundant cd-gpios from rk3588 sdmmc nodes 1619cbd3e975 arm64: dts: rockchip: add rs485 support on uart5 of px30-ringneck-haikou 2134fa3eaa7f arm64: dts: rockchip: add rs485 support on uart2 of rk3399-puma-haikou 7a4285c5d69e arm64: dts: rockchip: Add Powkiddy RGB10MAX3 b9b257004011 dt-bindings: arm: rockchip: Add Powkiddy RGB10MAX3 a3adfa889806 arm64: dts: rockchip: Update powkiddy rk2023 dtsi for RGB10MAX3 8c24e7309a68 dt-bindings: display: rocktech,jh057n00900: Document panel rotation 46ed672258f7 dt-bindings: display: Add Powkiddy RGB10MAX3 panel 01125f93dff3 dt-bindings: soc: rockchip: add rk3588 USB3 syscon f12733bf8794 dt-bindings: soc: rockchip: add clock to RK3588 VO grf 94e3c5a3f928 docs: dt: writing-schema: document expectations on example DTS fe91d6f4b5e3 docs: dt: writing-schema: explain additional/unevaluatedProperties 4a3d3359c02d docs: dt: writing-schema: clarify that schema should describe hardware d91bf686801b dt-bindings: use capital "OR" for multiple licenses in SPDX 496c29b2e9a6 dt-bindings: vendor-prefixes: add smartrg 24ffa3c14c93 dt-bindings: misc: qcom,fastrpc: Compute callbacks can be DMA coherent 0723544f32df dt-bindings: soc: renesas: Preserve the order of SoCs based on their part numbers a6d969083d23 clk: renesas: r8a779g0: Correct PFC/GPIO parent clocks 1c22386104aa ASoC: dt-bindings: fsl,imx-asrc: convert to YAML 0a4520722599 dt-bindings: timer: renesas: ostm: Document RZ/Five SoC 82515ffc20b0 dt-bindings: mmc: fsl-imx-esdhc: add iommus property 54b4d099b066 dt-bindings: mmc: fsl-imx-esdhc: add i.MX95 compatible string 878060d5ab93 dt-bindings: power: rpmpd: Add MSM8974 power domains ba7f2dd56d71 arm64: dts: amlogic: t7: minor whitespace cleanup 0e3777330164 Merge tag 'renesas-pinctrl-for-v6.9-tag1' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/renesas-drivers into devel 2b637c08d90d arm64: dts: amlogic: axg: initialize default SoC capacitance 56b8815ee298 arm64: dts: amlogic: axg: move cpu cooling-cells to common dtsi 38e9d49495a7 arch: arm64: dts: meson: a1: add assigned-clocks for usb node 04303030d8a7 arm64: dts: amlogic: meson-g12-common: Set the rates of the clocks for the NPU 96f1514933cd arm64: dts: amlogic: add reset controller for Amlogic C3 SoC b6cee0d8e50c dt-bindings: i2c: mux: i2c-demux-pinctrl: Define "i2c-parent" constraints cbcbd116c3bb dt-bindings: i2c: mux: i2c-demux-pinctrl: Drop i2c-mux.yaml reference d21de1b0f205 dt-bindings: can: fsl,flexcan: add i.MX95 compatible string 18dd617a729c ASoC: dt-bindings: cs35l45: Add interrupts d649337cab0d ASoC: dt-bindings: qcom,sm8250: Allow up to 8 codec DAIs 168cf4050131 arm64: dts: fsd: Add fifosize for UART in Device Tree c49f54ab8258 arm64: dts: exynos: gs101: minor whitespace cleanup 761c7555e3a6 arm64: dts: mediatek: mt7622: add missing "device_type" to memory nodes feb82cd75ca1 arm64: dts: mediatek: mt7986: reorder nodes afeb2b683c6a arm64: dts: mediatek: mt7986: reorder properties 1f41c46b7784 arm64: dts: mediatek: Add Acelink EW-7886CAX a9e4cb01cbbd dt-bindings: arm64: dts: mediatek: Add Acelink EW-7886CAX access point a0d0e301bacb dt-bindings: vendor-prefixes: add acelink 6355f4d21fe2 arm64: dts: mediatek: Introduce the MT8395 Radxa NIO 12L board ad8297de07f0 dt-bindings: arm64: mediatek: Add MT8395 Radxa NIO 12L board compatible c878dc2878b8 arm64: dts: mediatek: mt8186: Add video decoder device nodes 86ae11dcbfb0 arm64: dts: mediatek: mt8195: Add MTU3 nodes and correctly describe USB a1bccd014f43 arm64: dts: mediatek: Add MT8186 Magneton Chromebooks f06a044c7c87 arm64: dts: mediatek: Add MT8186 Steelix platform based Rusty 3d00e9da10ee arm64: dts: mediatek: Introduce MT8186 Steelix 2047c128ed63 arm64: dts: mediatek: Add MT8186 Krabby platform based Tentacruel / Tentacool 0526f7bc6fb8 dt-bindings: arm: mediatek: Add MT8186 Magneton Chromebooks 089e49677706 dt-bindings: arm: mediatek: Add MT8186 Rusty Chromebook f9d037124e77 dt-bindings: arm: mediatek: Add MT8186 Steelix Chromebook f5956f4a6314 dt-bindings: arm: mediatek: Add MT8186 Tentacruel / Tentacool Chromebooks 38bba08bb5f5 dt-bindings: arm: mediatek: Sort entries by SoC then board compatibles ae447c85bffd arm64: dts: mediatek: mt8186: Add jpgenc node 2ee45888f0f1 dt-bindings: media: mediatek-jpeg-encoder: change max iommus count 9dd1d78b9108 arm64: dts: mediatek: mt8186: Add venc node 928e533f64ce arm64: dts: mediatek: mt8186: fix VENC power domain clocks 10ccafc6dfc8 dt-bindings: media: mtk-vcodec-encoder: add compatible for mt8186 a26c81acaef4 arm64: dts: mediatek: mt8192: fix vencoder clock name 6d5ecd0c0bf1 dt-bindings: media: mtk-vcodec-encoder: fix non-vp8 clock name 44858bf6309d arm64: dts: mediatek: Add socinfo efuses to MT8173/83/96/92/95 SoCs 87674b38b34a arm64: dts: mediatek: mt8195: Enable cros-ec-spi as wake source a5e0493deb44 arm64: dts: mediatek: mt8192: Enable cros-ec-spi as wake source d8de0db07270 arm64: dts: mediatek: mt8183: Enable cros-ec-spi as wake source e62bf57bf4ce arm64: dts: mediatek: mt8173: Enable cros-ec-spi as wake source 80f419da8e71 arm64: dts: mediatek: mt7988: add clock controllers 0da54052e647 arm64: dts: mediatek: Add initial MT7988A and BPI-R4 17df9b07965f dt-bindings: arm64: mediatek: Add MT7988A and BPI-R4 58b0724c52ef arm64: dts: mediatek: Add initial MT7981B and Xiaomi AX3000T f2654823e7da dt-bindings: arm64: mediatek: Add MT7981B and Xiaomi AX3000T ec60c59a2f5a arm64: dts: mediatek: mt8192-asurada: Remove CrosEC base detection node 4cc812e03139 arm64: dts: mediatek: mt7986: add "#reset-cells" to infracfg a70fe7a32743 arm64: dts: mediatek: mt7986: drop "#clock-cells" from PWM 08e6a51e82bf arm64: dts: mediatek: mt7986: fix SPI nodename 0ce82b652753 arm64: dts: mediatek: mt7986: fix SPI bus width properties 1654679b7b86 arm64: dts: mediatek: mt7986: drop crypto's unneeded/invalid clock name 0db4b3814808 arm64: dts: mediatek: mt7986: fix reference to PWM in fan node e14ff64a492a arm64: dts: mt8183: Move CrosEC base detection node to kukui-based DTs 5af22a48d387 dt-bindings: net: qcom,ethqos: add binding doc for safety IRQ for sa8775p f0efaf410576 dt-bindings: arm: qcom,coresight-tpdm: Add support for TPDM CMB MSR register a31e6ce97f3b dt-bindings: arm: qcom,coresight-tpdm: Add support for CMB element size 42aa700e6b6a Merge tag 'v6.8-rc4' into gpio/for-next 28ff43a9c5cf dt-bindings: hwmon: Add LTC4282 bindings 946976867e95 dt-bindings: hwmon: ina2xx: Describe ina260 chip 60a5255306fa dt-bindings: hwmon: ina2xx: Describe #io-channel-cells property ccda6b1eb4cb dt-bindings: hwmon: ina2xx: Add label property 29abc2d8cf78 dt-bindings: display: msm: sm8650-mdss: Add missing explicit "additionalProperties" ca193aa48798 dt-bindings: msm: qcom, mdss: Include ommited fam-b compatible fb87bba01a93 dt-bindings: dsi-controller-main: Document missing msm8976 compatible 6e32138572e8 dt-bindings: net: Document Qcom QCA807x PHY package d65891d631e7 dt-bindings: net: document ethernet PHY package nodes 05327165c680 arm64: dts: qcom: qrb4210-rb2: enable USB-C port handling c48cf2ca774b arm64: dts: qcom: sm6115: drop pipe clock selection 0529c70be68e arm64: dts: qcom: pmi632: define USB-C related blocks 8f3c2d458408 arm64: dts: qcom: qcs6490-rb3gen2: Correct the voltage setting for vph_pwr f077c9e8cdcc arm64: dts: qcom: qcm6490-idp: Correct the voltage setting for vph_pwr ed36b9e79976 dt-bindings/perf: Add Arm CoreSight PMU 6bea5f945518 dt-bindings: pinctrl: cy8c95x0: Update gpio-reserved-ranges ff6ea0429974 dt-bindings: pinctrl: nvidia,tegra234-pinmux: Restructure common schema f8a5525e9f69 Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net b64c0f80d53a spi: get rid of some legacy macros adfae82db04a spi: dt-bindings: samsung: add google,gs101-spi compatible 7d4159bca342 dt-bindings: mfd: dlg,da9063: Convert da9062 to json-schema 84465d53e06e dt-bindings: mfd: dlg,da9063: Sort child devices a5d5c9ca95f6 dt-bindings: thermal: Convert da906{1,2} thermal to json-schema 9491d890e23c dt-bindings: input: Convert da906{1,2,3} onkey to json-schema bf94a53ad831 dt-bindings: mfd: dlg,da9063: Update watchdog child node 5d2f1ff23c1f dt-bindings: mfd: da9062: Update watchdog description 6d63119dedee dt-bindings: soc: qcom: qcom,pmic-glink: document QCM6490 compatible eadfdbf7cfd7 dt-bindings: i2c: renesas,rcar-i2c: Add r8a779h0 support 506140c4b36b dt-bindings: i2c: pca954x: Add custom properties for MAX7357 a3cf64f59235 arm64: dts: exynos: gs101: enable i2c bus 12 on gs101-oriole 66fd6a721305 arm64: dts: exynos: gs101: define USI12 with I2C configuration bc3a8ffe73f6 arm64: dts: exynos: gs101: enable cmu-peric1 clock controller 85f5d68af4a0 Merge tag 'samsung-dt-bindings-clk-6.9-3' into next/dt64 eff597e8d6d7 Merge branch '20240131-ufs-phy-clock-v3-3-58a49d2f4605@linaro.org' into clk-for-6.9 9d58463252f8 Merge branch '20240125-msm8953-mdss-reset-v2-1-fd7824559426@z3ntu.xyz' into clk-for-6.9 53156f9a9b8b dt-bindings: samsung: exynos-sysreg: gs101-peric0/1 require a clock f0fc02f810bc Merge tag 'samsung-dt-bindings-clk-6.9-3' into next/clk 3a17e325742d dt-bindings: clock: google,gs101-clock: add PERIC1 clock management unit f8f976624cd6 ASoC: dt-bindings: atmel,asoc-wm8904: Convert to json-schema e07e6605bd92 ARM: dts: samsung: exynos5420-galaxy-tab-common: add wifi node 833d20d41eff dt-bindings: phy: add mediatek MIPI CD-PHY module v0.5 0aff1be67191 dt-bindings: phy: cadence-torrent: Add a separate compatible for TI J7200 61354e32b738 dt-bindings: phy: cadence-torrent: Add optional input reference clock for PLL1 0ed441cb60fc Merge drm/drm-next into drm-misc-next fa4e28b76a28 dt-bindings: phy: qmp-ufs: Fix PHY clocks edf14e92f825 dt-bindings: fsl-dma: fsl-edma: add fsl,imx95-edma5 compatible string db56af9d1adc dt-bindings: mmp-dma: convert to YAML 69f5e9afcf9a arm64: dts: qcom: sc8280xp: Introduce additional tsens instances d34aa18b328e arm64: dts: qcom: sm8550-hdk: correct WCD9385 route and port mapping c5ac3bf2b9e9 arm64: dts: qcom: sm8650: Fix UFS PHY clocks 960dc14fb417 arm64: dts: qcom: sm8550: Fix UFS PHY clocks 5b487a71e59a arm64: dts: qcom: sm8350: Fix UFS PHY clocks 1019d3b3dd76 arm64: dts: qcom: sc8280xp: Fix UFS PHY clocks d909cc2c57f0 arm64: dts: qcom: sc8180x: Fix UFS PHY clocks 32798a824479 Merge branch '20240131-ufs-phy-clock-v3-3-58a49d2f4605@linaro.org' into HEAD 647fc2ed0999 dt-bindings: trivial-devices: sort entries alphanumerically d87ada5ab8a5 arm64: dts: qcom: sm8250: Fix UFS PHY clocks 71ea2327fa6f arm64: dts: qcom: sm8150: Fix UFS PHY clocks 64da7648e2cd arm64: dts: qcom: sm6350: Fix UFS PHY clocks fd0f61fefaf5 arm64: dts: qcom: sm6125: Fix UFS PHY clocks 4d7ec8559332 arm64: dts: qcom: sm6115: Fix UFS PHY clocks 1b77533e4915 arm64: dts: qcom: sdm845: Fix UFS PHY clocks 18872b4ddd5f arm64: dts: qcom: msm8998: Fix UFS PHY clocks 9a197a6489bc arm64: dts: qcom: msm8996: Fix UFS PHY clocks 1c92660aee2a dt-bindings: clock: qcom: Add missing UFS QREF clocks a20d2718cc23 arm64: dts: qcom: ipq8074: add clock-frequency to MDIO node 6ed4e54f3d0a arm64: dts: qcom: qrb2210-rb1: disable cluster power domains 1816222d14d0 arm64: dts: qcom: msm8953: Add GPU 289d949a2fa0 arm64: dts: qcom: msm8953: Add GPU IOMMU d8789c7d4887 arm64: dts: qcom: msm8953: add reset for display subsystem e3e73e0578cb Merge branch '20240125-msm8953-mdss-reset-v2-1-fd7824559426@z3ntu.xyz' into arm64-for-6.9 6beb0be6d4fc dt-bindings: clock: gcc-msm8953: add more resets f84a5b88e932 arm64: dts: qcom: sm8650-mtp: add Audio sound card node 92c1bbcc400a arm64: dts: qcom: sm8650-qrd: add Audio nodes b0e0830701c8 arm64: dts: qcom: sm8650: Add dma-coherent property d16840039a98 arm64: dts: qcom: sm8550: Add dma-coherent property f515a57656b3 arm64: dts: qcom: sm8650-qrd: add PM8010 regulators 03371084ea86 arm64: dts: qcom: sm8650-mtp: add PM8010 regulators a5d205597cdb arm64: dts: qcom: ipq6018: add thermal zones a536a392c199 arm64: dts: qcom: ipq6018: add tsens node 93475982136a arm64: dts: qcom: sm8550-mtp: add correct analogue microphones 94d226438171 arm64: dts: qcom: sm8550-qrd: add correct analogue microphones da9e6dd17060 arm64: dts: qcom: sm8550-mtp: correct WCD9385 TX port mapping 19f3548ab2ee arm64: dts: qcom: sm8550-qrd: correct WCD9385 TX port mapping 70387c1a6e20 arm64: dts: qcom: sm6350: Add tsens thermal zones 14a45c7e6691 arm64: dts: qcom: sm6115: declare VLS CLAMP register for USB3 PHY 62ceca9a978f arm64: dts: qcom: qcm2290: declare VLS CLAMP register for USB3 PHY 1243c8cd7c3d arm64: dts: qcom: msm8998: declare VLS CLAMP register for USB3 PHY 41b532e3d8fb arm64: dts: qcom: sc7280: Update domain-idle-states for cluster sleep 9067770d28da arm64: dts: qcom: sdm630-nile: Enable and configure PM660L WLED 59950318f199 dt-bindings: arm: qcom: drop the superfluous device compatibility schema 5906b6dbb4b8 arm64: dts: qcom: sm8650: add missing qlink_logging reserved memory for mpss 1a5594201259 arm64: dts: qcom: ipq9574: Enable Inline Crypto Engine for MMC 6c5dcfe50eeb arm64: dts: qcom: x1e80100-crd: add WSA8845 speakers 641aa52f01a1 arm64: dts: qcom: x1e80100-crd: add WCD9385 Audio Codec adad71a77e32 arm64: dts: qcom: x1e80100: add Soundwire controllers fcb540f3e31d arm64: dts: qcom: x1e80100: add ADSP audio codec macros fe7149ac0fe1 arm64: dts: qcom: x1e80100: add LPASS LPI pin controller 89656eaec676 arm64: dts: qcom: x1e80100: add ADSP GPR a24c8ba00dac dt-bindings: remoteproc: qcom,sm8550-pas: document the SM8650 PAS 552c8b9c51bd riscv: dts: microchip: add specific compatible for mpfs pdma 0359a2873d27 arm64: dts: qcom: ipq6018: add QUP5 I2C node 2109082a047e arm64: dts: qcom: x1e80100-qcp: Fix supplies for LDOs 3E and 2J ad5e70a893a6 arm64: dts: qcom: x1e80100-qcp: Enable more support 70e1e5caf55a arm64: dts: qcom: x1e80100-crd: Enable more support e7f823deb502 arm64: dts: qcom: x1e80100: Add display nodes 09888df4cabf arm64: dts: qcom: x1e80100: Add PCIe nodes 113e1447c4b7 arm64: dts: qcom: x1e80100: Add USB nodes d042016c875e arm64: dts: qcom: x1e80100: Add TCSR node 1e12a915f76a arm64: dts: qcom: x1e80100: Add ADSP/CDSP remoteproc nodes 21784a99d799 arm64: dts: qcom: x1e80100: Add QMP AOSS node adac34e54b92 arm64: dts: qcom: x1e80100: Add SMP2P nodes f6ae972c7d7a arm64: dts: qcom: x1e80100: Add IPCC node f858f5571e59 Merge branch '20240202-x1e80100-clock-controllers-v4-5-7fb08c861c7c@linaro.org' into arm64-for-6.9 16f9c84b0c9a Merge branch '20240202-x1e80100-clock-controllers-v4-5-7fb08c861c7c@linaro.org' into clk-for-6.9 77ff05b89311 dt-bindings: clock: qcom: Document the X1E80100 Camera Clock Controller 9b09558a4d02 dt-bindings: clock: qcom: Document the X1E80100 TCSR Clock Controller 009188ad89c1 dt-bindings: clock: qcom: Document the X1E80100 GPU Clock Controller 619f14d3ee00 dt-bindings: clock: qcom: Document the X1E80100 Display Clock Controller 5c691ea9dfde dt-bindings: clock: Drop the SM8650 DISPCC dedicated schema fd99a9349fc8 dt-bindings: soc: qcom: qcom,pmic-glink: document X1E80100 compatible 3de725e88fb0 arm64: dts: qcom: sa8775p: Add new memory map updates to SA8775P 62872aebbbd8 dt-bindings: soc: imx: add missing clock and power-domains to imx8mp-hdmi-blk-ctrl 4ff28e3e2d94 ASoC: dt-bindings: atmel,sam9x5-wm8731: Convert to json-schema 906cab843596 riscv: dts: microchip: add missing CAN bus clocks 70bee5f22413 dt-bindings: can: mpfs: add missing required clock 91d53111ca13 dt-bindings: clock: mpfs: add more MSSPLL output definitions 7564dfecdf9e Revert "media: ov08x40: Reduce start streaming time" 230eabe62cac arm64: dts: ti: iot2050*: Clarify GPL-2.0 as GPL-2.0-only 81c25598663e arm64: dts: ti: phycore*: Add MIT license along with GPL-2.0 49ad241d7ba0 arm64: dts: ti: beagle*: Add MIT license along with GPL-2.0 af13011bc32a arm64: dts: ti: k3-serdes: Add MIT license along with GPL-2.0 97f615d94c52 arm64: dts: ti: k3-pinctrl: Add MIT license along with GPL-2.0 fb7c92cfa0d7 arm64: dts: ti: k3-j784s4: Add MIT license along with GPL-2.0 ef720a09d820 arm64: dts: ti: k3-j721s2: Add MIT license along with GPL-2.0 b5d3132ac896 arm64: dts: ti: k3-j721e: Add MIT license along with GPL-2.0 a08b6e3c500d arm64: dts: ti: k3-j7200: Add MIT license along with GPL-2.0 67b92cb4a9b8 arm64: dts: ti: k3-am65: Add MIT license along with GPL-2.0 4270ef124316 arm64: dts: ti: k3-am64: Add MIT license along with GPL-2.0 6bbb88ff7998 arm64: dts: ti: k3-am62p: Add MIT license along with GPL-2.0 0ffeaa9662f1 arm64: dts: ti: k3-am625: Add MIT license along with GPL-2.0 5db4fd731c54 arm64: dts: ti: k3-am62a7: Add MIT license along with GPL-2.0 99e9047746eb arm64: dts: ti: Use https for urls 3fa55a728a3d arm64: dts: imx8mn-evk: Add PDM micphone sound card support 8d8a62fd968d arm64: dts: imx8mm-evk: Add PDM micphone sound card support 151935e24c16 arm64: dts: imx8qm: add smmu stream id information 7ca27214673d arm64: dts: imx8qm: add smmu node b9f9b709c278 arm64: dts: imx8dxl-evk: add flexcan2 and flecan3 f42aa20f9119 arm64: dts: imx8dxl-evk: add i2c3 and its children nodes 93d6366b8356 arm64: dts: imx8dxl: update flexcan[1-3] interrupt number c5d90c61def2 arm64: dts: imx8mp-phyboard-pollux-rdk: add etml panel support 16c8d47dc262 arm64: dts: imx8mn-rve-gateway: remove redundant company name b08765c243bb dt-bindings: arm: fsl: remove redundant company name 65cffffa0551 ARM: dts: samsung: exynos5420-galaxy-tab: decrease available memory d01b22a61768 dt-bindings: ata: atmel: remove at91 compact flash documentation d242043d9d60 arm64: dts: renesas: gray-hawk-single: Enable watchdog timer 2e8d8e405f93 arm64: dts: renesas: r8a779h0: Add RWDT node 35665cd38eb8 arm64: dts: renesas: Improve TMU interrupt descriptions 6c5ee3279bcd ARM: dts: renesas: Improve TMU interrupt descriptions 78e358d25cba ARM: dts: imx6ull-dhcom: Remove /omit-if-no-ref/ from node usdhc1-pwrseq f53c235dce4f arm64: dts: freescale: imx8qm: add apalis eval v1.2 carrier board c6a20bf4953d dt-bindings: arm: fsl: add imx8qm apalis eval v1.2 carrier board 4a2797e6299b dt-bindings: display: imx: add binding for i.MX8MP HDMI TX 46daefc82714 arm64: dts: exynos: Add SPI nodes for Exynos850 864d0966e626 ARM: dts: imx: Add support for Apalis Evaluation Board v1.2 ab38fa94e38c dt-bindings: arm: fsl: Add toradex,apalis_imx6q-eval-v1.2 board 79c6446e27a7 ARM: dts: imx6: skov: add aliases for all ethernet nodes 00cba1b18156 arm64: dts: imx93: Add phyBOARD-Segin-i.MX93 support ee42eae10f7a dt-bindings: arm: fsl: Add phyBOARD-Segin-i.MX93 1dcb02c43ac3 arm64: dts: imx8mp: Enable PCIe to Data Modul i.MX8M Plus eDM SBC c35148dd66cc dt-bindings: firmware: xilinx: Describe soc-nvmem subnode e4d158a009f2 arm64: dts: ls1012a: fix DWC3 USB VBUS glitch issue 2cc69dbdcc3b arm64: dts: ls1012a: add gpio for i2c bus recovery 86f029cb9916 arm64: dts: ls1012a: add big-endian property for PCIe nodes 1344dd97c94d arm64: dts: ls1012a: correct the size of dcfg block eebf4e8a4de5 arm64: dts: ti: k3-j7200: use ti,j7200-padconf compatible b2c927e92eb5 arm64: dts: ti: k3-am62p-mcu/wakeup: Disable MCU and wakeup R5FSS nodes 1ed877819eca arm64: dts: ti: k3-am69-sk: remove assigned-clock-parents for unused VP b2e13a92bcd3 dt-bindings: drm/bridge: ti-sn65dsi86: Fix bouncing @codeaurora address 5aafe0eb29a5 dt-bindings: mux: restrict node name suffixes 959645b1cb6f ARM: dts: keystone: Replace http urls with https 9c307f485cc5 arm64: dts: ti: k3-am62a7-sk: Add HDMI support 33aa21cb5f84 arm64: dts: ti: k3-am62a-main: Add node for Display SubSystem (DSS) e197413922a3 arm64: dts: ti: phycore-am64: Add ADC cbb614f03fe0 arm64: dts: ti: k3-j784s4: Fix power domain for VTM node 4979495296af arm64: dts: ti: k3-j721s2: Fix power domain for VTM node 66f98925474a arm64: dts: ti: k3-am62p5-sk: Enable CPSW MDIO node 8af95677c0a4 arm64: dts: ti: k3-j7200: Add support for multiple CAN instances 3416ecb8c84b arm64: dts: ti: k3-j7200-som-p0: Add support for CAN instance 0 in main domain b190cdb39a78 arm64: dts: ti: k3-j7200: Add support for CAN nodes 049925dbe4ef arm64: dts: ti: verdin-am62: mallow: add TPM device d18d4a279eac arm64: dts: ti: k3-am64: Remove PCIe endpoint node 45e8e613d391 arm64: dts: ti: k3-am65: Remove PCIe endpoint nodes 9482566d8484 arm64: dts: ti: k3-j7200: Remove PCIe endpoint node f2db5b44a21b arm64: dts: ti: k3-j7200: Enable PCIe nodes at the board level 1b1b2953ae47 arm64: dts: ti: k3-j721s2-som-p0: Do not split single items 1ab381b19847 arm64: dts: ti: k3-j721e-som-p0: Do not split single items 3bbf314c8e51 arm64: dts: ti: k3-j721e-sk: Do not split single items 9982ca1fa62d arm64: dts: ti: k3-j721e-beagleboneai64: Do not split single items 685e4624960e arm64: dts: ti: k3-j7200-som-p0: Do not split single items bb743de0d3fe arm64: dts: ti: k3-am69-sk: Do not split single items 6081c21a3e9b arm64: dts: ti: k3-am68-sk-som: Do not split single items 7aebe586ccdc arm64: dts: ti: k3-am654-base-board: Do not split single items 756750059f96 arm64: dts: ti: iot2050: Do not split single items 83cac2593e26 arm64: dts: ti: k3-am642-sk: Do not split single items c266381d0608 arm64: dts: ti: k3-am642-evm: Do not split single items ff6e034104fc arm64: dts: ti: k3-am642-phyboard-electra: Add TPM support 986edbf094b5 arm64: dts: ti: Disable clock output of the ethernet PHY 140c5468b668 arm64: dts: ti: Add phase tags for memory node on J784S4 EVM and AM69 SK fb6ffd10b764 arm64: dts: ti: k3-am625-beagleplay: Use the builtin mdio bus abed090f1e99 arm64: dts: ti: k3-am625-beagleplay: Add boot phase tags for USB0 0424a17ecb7a arm64: dts: ti: k3-am625-sk: Add boot phase tags for USB0 ac8143f3b013 dt-bindings: mtd: avoid automatically select from mtd.yaml 828b9467f60f media: dt-bindings: techwell,tw9900: Fix port schema ref 2b2619e4c6c5 dt-bindings: display: imx: add binding for i.MX8MP HDMI PVI 141f2102cc12 ARM: dts: imx6qdl-hummingboard: Add rtc0 and rtc1 aliases to fix hctosys ffe7dc298435 arm64: dts: imx93: drop "master" I3C node name suffix 99af7a0dae65 ARM: dts: imx6dl: Add support for Sielaff i.MX6 Solo board ff6929d462c4 dt-bindings: arm: fsl: Add Sielaff i.MX6 Solo board d3413ad34a12 arm64: dts: freescale: tqma9352: Update I2C eeprom compatible ad2d1ba26a13 arm64: dts: imx8mp: reparent MEDIA_MIPI_PHY1_REF to CLK_24M 3b589ade448f dt-bindings: gpio: pca9570: Add label property 11eb3d98d38b dt-bindings: gpio: mvebu: Fix "unevaluatedProperties" to be false 9c0a4b40a3ac ARM: dts: imx6ul: Add missing #thermal-sensor-cells to tempmon fee43501308a arm64: dts: imx8mp-verdin: Label ldo5 and link to usdhc2 b8d7d5f3690b arm64: dts: imx93-var-som: Add Variscite VAR-SOM-MX93 188a8bb94d35 dt-bindings: arm: fsl: Add VAR-SOM-MX93 with Symphony fecb422bac6a arm64: dts: ls1046a: Remove big-endian from thermal 78343d7acd50 ARM: dts: imx6sl-tolino-shine2hd: fix touchscreen rotation e57037e98946 ARM: dts: imx6ull-dhcor: Remove 900MHz operating point 31d9e29f0d8e Merge tag 'drm-misc-next-2024-01-11' of git://anongit.freedesktop.org/drm/drm-misc into drm-next e6d71526460e dt-bindings: misc: xlnx,sd-fec: convert bindings to yaml 01b5de94aa82 Merge 6.8-rc3 into tty-next 7030aa5067b6 Merge 6.8-rc3 into usb-next 5f856030cc8b arm64: dts: rockchip: Add devicetree for Pine64 PineTab2 c87344c32c61 dt-bindings: arm64: rockchip: Add Pine64 PineTab2 6944e5df2f35 arm64: dts: rockchip: Add Touch to Anbernic RG-ARC D 9a90efccd7ee ARM: dts: microchip: gardena-smart-gateway: Use DMA for USART3 9a2b5d99e0ff ARM: dts: microchip: at91sam9x5ek: Use DMA for DBGU serial port 7051d52cf5b9 arm64: dts: imx8mp-venice-gw71xx: add TPM device 4ecbc5946cc5 arm64: dts: imx8mm-venice-gw71xx: add TPM device 3c805459dfd7 arm64: dts: imx8mm-venice-gw71xx: fix USB OTG VBUS af9118771e3c arm64: dts: imx8mm-venice-gw7901: add TPM device bcc4aff9ee00 arm64: dts: imx8mm-venice-gw7901: add digital I/O direction control GPIO's 6ea0c6a49b64 ARM: dts: imx7-tqma7: Fix PMIC v33 rail voltage range 2482c75bff8e ARM: dts: imx7-mba7: Add missing vcc supply to i2c devices 4d19ec066c6b ARM: dts: imx7-tqma7: Add missing vcc supply to i2c eeproms fda2672c8e68 ARM: dts: imx7d-mba7: Remove USB OTG related properties on USB node f71b70123d20 ARM: dts: imx7-tqma7: rename node for SE97BTP 56382af8168e ARM: dts: imx7-tqma7: mark system data eeprom as read-only 59c9c040a0db ARM: dts: imx7-tqma7: remove superfluous status property ac9f05a3b8ee ARM: dts: imx7-tqma7: restrict usdhc interface modes 54b93adb1393 ARM: dts: imx7-mba7: restrict usdhc interface modes 6980af2d9f17 ARM: dts: imx7-tqma7: Fix iomuxc node names efad19cdde77 ARM: dts: imx7-mba7: Fix iomuxc node names fe330835b74e ARM: dts: imx7-tqma7: fix EEPROM compatible for SE97BTP 77f6e05fdfa1 ARM: dts: imx7-mba7: Add i2c bus recovery 8f9993282d52 ARM: dts: imx7-tqma7: Add i2c bus recovery 4065cdaa82bd ARM: dts: imx7-mba7: Add SPI1_SS0 as chip select 3 10cde7452d93 ARM: dts: imx7-mba7: Add RTC aliases 67c6d0e81520 ARM: dts: imx7-mba7: Enable SNVS power key 2ccae767cb74 ARM: dts: imx7-mba7: Mark gpio-buttons as wakeup-source 235e861d016e ARM: dts: imx7[d]-mba7: hog Mini PCIe signals cd553893ac90 ARM: dts: imx7[d]-mba7: disable PCIe interface 2faa76d25aef ARM: dts: imx7[d]-mba7: disable USB OC on USB host and USB OTG2 f9152233518d ARM: dts: imx7[d]-mba7: Move ethernet PHY reset into PHY node 0d8f0cba144c ARM: dts: imx7-tqma7/mba7: convert fsl,pins to uint32-matrix c09e630c5912 arm64: dts: qcom: qcm6490-idp: Include PM7250B edd0bc8b8d0b arm64: dts: qcom: sm8650: Use GIC-ITS for PCIe0 and PCIe1 4fe52e68f13c arm64: dts: qcom: qcm6490-idp: Add definition for three LEDs cc592e051541 arm64: dts: qcom: sm8650-qrd: add USB-C Altmode Support b789944a89fc arm64: dts: qcom: sm8550-qrd: enable Touchscreen 200b0b3875ef dt-bindings: clock: qcom: Fix @codeaurora email in Q6SSTOP 5eaa8712fb96 dt-bindings: visionox-rm69299: Update maintainers ae0b823f0536 dt-bindings: gpio: renesas,rcar-gpio: Add r8a779h0 support d4458c6492e6 dt-bindings: net: ti: Update maintainers list a3fa7f3f82f7 dt-bindings: net: ipq4019-mdio: document now supported clock-frequency 9c3280cd3020 Merge git://git.kernel.org/pub/scm/linux/kernel/git/netdev/net 19adc3b90590 Merge branch '20240201204421.16992-2-quic_amelende@quicinc.com' into drivers-for-6.9 b5c560279d08 dt-bindings: soc: qcom: Add qcom,pbs bindings 08d014730db7 regulator: dt-bindings: microchip,mcp16502: convert to YAML bdef327947f5 arm64: dts: intel: agilex5: drop "master" I3C node name suffix 1c0d4ea255ee media: ov08x40: Reduce start streaming time 7d92af412d2e arm64: dts: exynos: Add PDMA node for Exynos850 1868ee800d4c arm64: dts: exynos: gs101: use correct clocks for usi_uart 5d5769f28954 arm64: dts: exynos: gs101: use correct clocks for usi8 dc00c7274ea6 dt-bindings: net: dsa: Add KSZ8567 switch support 58475bd50ec5 media: arm64: dts: st: add video encoder support to stm32mp255 380408454fb2 media: arm64: dts: st: add video decoder support to stm32mp255 4eea1b53e82e media: dt-bindings: media: Document STM32MP25 VDEC & VENC video codecs 39ecce7ee54a arm64: dts: imx8qxp: add GPU nodes b206b48e8a91 arm64: dts: imx8qm: Correct edma3 power-domains and interrupt numbers 7a74326b4893 arm64: dts: imx8qm: Align edma3 power-domains resources indentation 0be926d25dbc arm64: dts: imx8qxp: mba8xx: Add analog audio output on MBa8Xx 43aab34e5e0c arm64: dts: imx8qxp: Add mclkout clock gates 8c7666d283be arm64: dts: imx8qxp: Add audio SAI nodes a12fa3d0c150 arm64: dts: imx8qxp: Add audio clock mux node 6c44f7583fd5 arm64: dts: imx8qxp: Add ACM input clock gates cf7ea553fe5a arm64: dts: freescale: add initial device tree for TQMa8Xx 98de130e34e4 dt-bindings: arm: add TQMa8Xx boards dc089f5f4bb0 arm64: dts: imx: add imx8dxp support a5a40554f207 dt-bindings: net: qcom,ipa: do not override firmware-name $ref 927f00767ef5 arm64: dts: imx8mm-kontron: Refactor devicetree for OSM-S module and board dc0c1bca1831 arm64: dts: imx8mm-kontron: Add I2C EEPROM on OSM-S Kontron i.MX8MM 071edd561a01 arm64: dts: imx8mm-kontron: Remove useless trickle-diode-disable from RTC node bc9a25d78a35 arm64: dts: imx8mm-kontron: Disable uneffective PUE bit in SDIO IOMUX 48e6dc42724c arm64: dts: imx8mm-kontron: Fix OSM-S devicetrees to match latest hardware 1749a50ca797 arm64: dts: imx8mm-kontron: Fix interrupt for RTC on OSM-S i.MX8MM module 6985d8cd5c40 arm64: dts: imx8mm-kontron: Disable pull resistors for SD card signals on BL board 688fff06ac4e arm64: dts: imx8mm-kontron: Disable pull resistors for SD card signals on BL OSM-S board 4b8efdb73a46 arm64: dts: imx8mm-kontron: Disable pullups for onboard UART signals on BL board 123efe05e212 arm64: dts: imx8mm-kontron: Disable pullups for onboard UART signals on BL OSM-S board 9f02292756b9 arm64: dts: imx8mm-kontron: Disable pullups for I2C signals on SL/BL i.MX8MM 928dc77f0003 arm64: dts: imx8mm-kontron: Disable pullups for I2C signals on OSM-S i.MX8MM c2b4ecb58452 dt-bindings: fpga: Convert fpga-region binding to yaml 85d6c583d5f5 MAINTAINERS: Drop my "+dt" sub-address 0f6ed4032e99 dt-bindings: timer: renesas,tmu: Document input capture interrupt 05c9f46083ba arm64: dts: renesas: r9a07g043u: Add CSI and CRU nodes aa403cfc2a6c arm64: dts: renesas: Add Gray Hawk Single board support 82a8a0a3e608 arm64: dts: renesas: Add Renesas R8A779H0 SoC support 356004f72bd0 Merge tag 'renesas-r8a779h0-dt-binding-defs-tag' into renesas-dts-for-v6.9 1200029387ce arm64: dts: renesas: rzg3s-smarc-som: Enable the watchdog interface d58eb8846937 arm64: dts: renesas: r9a08g045: Add watchdog node b1de14ce277c arm64: dts: renesas: r8a779g0: Add missing SCIF_CLK2 fe98cda6e099 dt-bindings: soc: renesas: Document R-Car V4M Gray Hawk Single bcdc951ea508 dt-bindings: reset: renesas,rst: Document R-Car V4M support 55647b66aba2 pinctrl: renesas: pinctrl-rzg2l: Add the missing port pins P19 to P28 fc9d9f1cfef8 dt-bindings: interconnect: Remove bogus interconnect nodes 47509af4504a soundwire/SOF: add SoundWire Interface support for f521b204bcd2 dt-bindings: interconnect: Add Qualcomm MSM8909 DT bindings 72ececa06e31 riscv: dts: starfive: beaglev-starlight: Setup phy reset gpio 0279da4a6715 riscv: dts: starfive: visionfive-v1: Setup ethernet phy 19f7725fe372 riscv: dts: starfive: jh7100-common: Setup pinmux and enable gmac d05053a8b239 riscv: dts: starfive: jh7100: Add sysmain and gmac DT nodes 921e5e1327ef dt-bindings: net: starfive,jh7110-dwmac: Add JH7100 SoC compatible 7020ebc26757 dt-bindings: clock: Add R8A779H0 V4M CPG Core Clock Definitions 35d633af4efc dt-bindings: clock: renesas,cpg-mssr: Document R-Car V4M support 1de76ced2497 dt-bindings: soc: xilinx: Add support for KV260 CC c9aeb5c33863 dt-bindings: soc: xilinx: Add support for K26 rev2 SOMs e36f379d8c82 dt-bindings: pinctr: pinctrl-zynq: Fix compatible string c7a574ba2a6c dt-bindings: pinctrl: nuvoton,npcm845: Drop redundant type for "slew-rate" da1b37add707 dt-bindings: pinctrl: Unify "input-debounce" schema 234d836b6a1a dt-bindings: input: document Goodix Berlin Touchscreen IC 8df2aa5a1297 arm64: dts: qcom: Add support for Xiaomi Redmi Note 9S 5c09bd2b6ce1 arm64: dts: qcom: sm7125-xiaomi-common: Add UFS nodes 5c38e796a3a1 arm64: dts: qcom: sc7180: Add UFS nodes 307cdcc3f9c2 dt-bindings: arm: qcom: Add Xiaomi Redmi Note 9S d9eda103eb64 ARM: dts: qcom: apq8026-lg-lenok: Add vibrator support 2590e420cf2c ARM: dts: qcom: msm8960: expressatt: Add gpio-keys 9d906fe262e0 arm64: dts: qcom: sda660-ifc6560: enable USB 3.0 PHY 6b10b59bd1db arm64: dts: qcom: sdm630: add USB QMP PHY support 329fb714e840 arm64: dts: qcom: sc8280xp: camss: Add CAMSS block definition ca14c11bb9a4 arm64: dts: qcom: sc8280xp: camss: Add CCI definitions 5ce7895c7b2b dt-bindings: clock: qcom: Allow VDD_GFX supply to GX 3a9a9247f661 arm64: dts: qcom: sa8295p-adp: Enable GPU 08f93d65d530 arm64: dts: qcom: sa8295p-adp: add max20411 1129eea99cc1 arm64: dts: qcom: sa8540p: Drop gfx.lvl as power-domain for gpucc 14bc12ecdfe3 dt-bindings: interrupt-controller: convert MediaTek sysirq to the json-schema 77a4323bd64f dt-bindings: dma: allwinner,sun50i-a64-dma: Add compatible for H616 82bf0037e8d8 dt-bindings: power: Add r8a779h0 SYSC power domain definitions d98d5e6ce56e dt-bindings: power: renesas,rcar-sysc: Document R-Car V4M support 5ee26dab625b dt-bindings: bus: Document Broadcom GISB arbiter 74165 compatible c6234d82a072 arm64: dts: broadcom: bcmbca: bcm4908: drop invalid switch cells bc4ef25abdc1 arm64: dts: broadcom: bcmbca: bcm4908: use NVMEM layout for Asus GT-AC5300 b6e08822ed8c arm64: dts: renesas: r8a779g2: Add White Hawk Single support 7e3862db4c62 arm64: dts: renesas: Add Renesas R8A779G2 SoC support 51fc2376ba1d arm64: dts: renesas: white-hawk: Factor out common parts a248c1746935 arm64: dts: renesas: white-hawk-cpu: Factor out common parts fdea5d785497 arm64: dts: renesas: white-hawk: Add SoC name to top-level comment a77e323e0dc2 arm64: dts: renesas: white-hawk: Drop SoC parts from sub boards 3e8f05b2b81d arm64: dts: renesas: white-hawk-cpu: Restore sort order e90ffb9d53b7 arm64: dts: renesas: r8a779g0: Add standalone White Hawk CPU support eccddc31dfa9 arm64: dts: renesas: ulcb-kf: Add node for GNSS 3d3e628e12d6 arm64: dts: renesas: ulcb-kf: Drop duplicate 3.3v regulators bf721e67a7fb Merge drm/drm-next into drm-misc-next 351548ba8841 dt-bindings: soc: renesas: Document R-Car V4H White Hawk Single ad352af0d46f dt-bindings: nfc: ti,trf7970a: fix usage example d4d212c5cf34 dt-bindings: display: panel-simple: add ETML1010G3DRA 6aee668021fc arm64: dts: qcom: sm7225-fairphone-fp4: Switch firmware ext to .mbn aa54779772ae arm64: dts: qcom: rename PM2250 to PM4125 dbcb19ed3275 arm64: dts: qcom: qcm6490-fairphone-fp5: Add PMIC GLINK dc376fa4a27c arm64: dts: qcom: sdm845-oneplus-common: improve DAI node naming 048423deb9a5 arm64: dts: qcom: qcm6490-fairphone-fp5: Add missing reserved-memory b4d0c1c61afa arm64: dts: qcom: sc7280: Add static properties to cryptobam f3f780c01899 arm64: dts: qcom: sa8775p: enable safety IRQ fd61cbbd53a9 dt-bindings: clock: qcom,gcc-sm8150: Add gcc video resets for sm8150 30e2fa95b585 dt-bindings: arm: qcom,ids: add SoC ID for QCM8550 and QCS8550 27f4e6aa609c dt-bindings: Add reference to rs485.yaml 5e11848e4c98 dt-bindings: serial: renesas,hscif: Document r8a779h0 bindings c7aaa6160c61 dt-bindings: serial: fsl-lpuart: support i.MX95 3ee8c19304d9 dt-bindings: serial: samsung: do not allow reg-io-width for gs101 d70fdb79f945 arm64: dts: qcom: apq8016-sbc-d3-camera: Use more generic node names 95830229bcb5 ARM: dts: qcom: msm8960: drop 2nd clock frequency from timer 4f433e3e9a04 ARM: dts: qcom: ipq4019-ap.dk01.1: align flash node with bindings 39065990752b ARM: dts: qcom: ipq4019-ap.dk01.1: use existing labels for nodes a6106c8748a7 arm64: dts: qcom: split PCIe interrupt-names entries per lines f1ac2340280d arm64: dts: qcom: sm8650: describe all PCI MSI interrupts 653638c9dceb arm64: dts: qcom: sm8550: describe all PCI MSI interrupts 90840a974369 arm64: dts: qcom: sm8450: describe all PCI MSI interrupts c681c8ad796c arm64: dts: qcom: sm8350: describe all PCI MSI interrupts 9186fa649278 arm64: dts: qcom: sm8250: describe all PCI MSI interrupts a2e5b5e27b91 arm64: dts: qcom: sm8150: describe all PCI MSI interrupts ed0b4f3e69ba ARM: dts: qcom: msm8926-htc-memul: Add rmtfs memory node 3556e0895e7a dt-bindings: usb: dwc3: Add snps,host-vbus-glitches-quirk avoid vbus glitch 75bae0c78ef3 dt-bindings: usb: usb-nop-xceiv: Repurpose vbus-regulator 20e5fb946959 dt-bindings: usb: mtu3: Add MT8195 MTU3 ip-sleep support 0145e6824861 dt-bindings: usb: Clean-up "usb-phy" constraints eb9bdcaff280 dt-bindings: usb: add common Type-C USB Switch schema a67690a90fb9 dt-bindings: usb: Add Marvell ac5 59434babb8e4 arm64: dts: qcom: sm8450: Add missing interconnects to serial 6b60607aa5cc dt-bindings: usb: Introduce ITE IT5205 Alt. Mode Passive MUX fe0ce9c54778 dt-bindings: pinctrl: amlogic: narrow regex for unit address to hex numbers 8c58779baca1 dt-bindings: qcom: Document new msm8916-samsung devices 1438aadecf94 arm64: dts: qcom: sm8450-hdk: correct AMIC4 and AMIC5 microphones b4d502118ad4 arm64: dts: qcom: sm8150: add necessary ref clock to PCIe 018a13d36a57 arm64: dts: qcom: sdm630: Hook up GPU cooling device 2b51fa0934c8 arm64: dts: qcom: sm8550: Hook up GPU cooling device 15018cdc0470 arm64: dts: qcom: sm8450: Hook up GPU cooling device f5906fc26422 arm64: dts: qcom: sm8350: Hook up GPU cooling device 9df3c73a8511 arm64: dts: qcom: sm8250: Hook up GPU cooling device 257e0300ca3a arm64: dts: qcom: sm8150: Hook up GPU cooling device b16301e27866 arm64: dts: qcom: sm6115: Mark GPU @ 125C critical ccc769ffd9fa arm64: dts: qcom: sm6115: Hook up GPU cooling device cf4e80b514f2 arm64: dts: qcom: sdm845: Hook up GPU cooling device 6ddaa894ac00 arm64: dts: qcom: sc8180x: Hook up GPU cooling device 1a13cc6e08c9 arm64: dts: qcom: msm8939: Hook up GPU cooling device 04962e8ee80d arm64: dts: qcom: msm8916: Hook up GPU cooling device de58665d5a86 arm64: dts: qcom: x1e80100: Flush RSC sleep & wake votes 5792135ff692 arm64: dts: qcom: x1e80100: Add missing system-wide PSCI power domain 7dddf3cf2c2d dt-bindings: soc/qcom: Add size constraints on "qcom,rpm-msg-ram" f3e26b603762 arm64: dts: qcom: Add missing interrupts for qcs404/ipq5332 d2eb087d6a3f arm64: dts: qcom: Fix hs_phy_irq for SDM670/SDM845/SM6350 e912f5a885bc arm64: dts: qcom: Fix hs_phy_irq for non-QUSB2 targets cc58f6b02229 arm64: dts: qcom: Fix hs_phy_irq for QUSB2 targets ed2747597b2e arm64: dts: qcom: sm8550: add support for the SM8550-HDK board 0beb12a79761 dt-bindings: arm: qcom: Document the HDK8550 board 1182dc50de01 dt-bindings: net: Document QCA808x PHYs 8869fe2b8c59 dt-bindings: net: phy: Document LED inactive high impedance mode 8a5d470f446f dt-bindings: net: phy: Make LED active-low property common ee170c770dce ASoC: dt-bindings: audio-graph-port: Drop type from "clocks" 52dc7498eed1 ASoC: dt-bindings: samsung,tm2: Correct "audio-codec" constraints 2294f77ec0a5 ARM: dts: sti: minor whitespace cleanup around '=' e8f034522bd8 arm64: dts: exynos: gs101: sysreg_peric0 needs a clock d7849025c947 ARM: dts: da850: add MMD SDIO interrupts f831c925b07a ARM: dts: marvell: dove-cubox: fix si5351 node names 70e16db126d5 arm: dts: marvell: Fix maxium->maxim typo in brownstone dts 29fba2976ec3 dt-bindings: crypto: ice: Document SC7180 inline crypto engine 3d331a17e8c9 dt-bindings: qcom-qce: Add compatible for SM6350 4fd1499f0d02 arm64: dts: ti: k3-am654-main: Add device tree entry for SGX GPU 459e64009a83 ARM: dts: DRA7xx: Add device tree entry for SGX GPU 33828a263695 ARM: dts: AM437x: Add device tree entry for SGX GPU b812a94b3a14 ARM: dts: AM33xx: Add device tree entry for SGX GPU a43b7f4412c3 ARM: dts: omap5: Add device tree entry for SGX GPU 26a571cb3312 ARM: dts: omap4: Add device tree entry for SGX GPU 0590991057c3 ARM: dts: omap3: Add device tree entry for SGX GPU 6cfc912186fd dt-bindings: gpu: Add PowerVR Series5 SGX GPUs ecd5e84cb911 dt-bindings: gpu: Rename img,powervr to img,powervr-rogue 674fba836cdb arm64: dts: rockchip: fix nanopc-t6 sdmmc regulator 33b030710624 arm64: dts: rockchip: remove duplicate SPI aliases for helios64 7c0fd87b35a8 arm64: dts: rockchip: add spi controller aliases on rk3399 774db835de8a arm64: dts: rockchip: Add support for NanoPi R6C 245ed9f66edb arm64: dts: rockchip: Add support for NanoPi R6S 7ed25d8d0d24 dt-bindings: arm: rockchip: Add NanoPi R6 series boards 4fc6e0686faf arm64: dts: rockchip: Increase maximum frequency of SPI flash for ROCK Pi 4A/B/C 47aafd8512e1 arm64: dts: rockchip: add sdmmc card detect to the nanopc-t6 5bdf0ecf003d arm64: dts: rockchip: Add cache information to the SoC dtsi for RK3399 3d67b6c2a2af ARM: dts: rockchip: Enable HDMI output for XPI-3128 8ac6f9cf696a ARM: dts: rockchip: Add HDMI node for RK3128 06cbcacf56ad ARM: dts: rockchip: Add display subsystem for RK3128 9a9dc5b9e06a arm64: dts: rockchip: add rfkill node for M.2 Key E WiFi on rock-5b c7f1c6bb420a arm64: dts: rockchip: enable NanoPC-T6 MiniPCIe power 9604142e6a0d arm64: dts: rockchip: Add LED_GREEN for edgeble-neu6a cbd461ded362 arm64: dts: rockchip: Add Edgeble NCM6A-IO USB2 051aa218e679 arm64: dts: rockchip: Add Edgeble NCM6A-IO M.2 B-Key, E-Key e24b6c90f78b arm64: dts: rockchip: Add Edgeble NCM6A-IO M.2 M-Key c04566174738 arm64: dts: rockchip: Add Edgeble NCM6A-IO 2.5G ETH 1696541973b9 arm64: dts: rockchip: Add vdd_cpu_big reg to rk3588-edgeble-ncm6 fed4b47f48ac arm64: dts: rockchip: Add Edgeble NCM6A WiFi6 Overlay 648060033a16 arm64: dts: rockchip: Add common DT for edgeble-neu6b-io 14b26b2835cb arm64: dts: rockchip: Add edgeble-neu6a-common DT 8360c7a53f95 arm64: dts: rockchip: Drop edgeble-neu6b dcdc-reg4 regulator-init-microvolt e497dc0158dd arm64: dts: rockchip: add missing definition of pmu io domains 1 and 2 on ringneck f1cb710d9302 arm64: dts: rockchip: add Anbernic RG-ARC S and RG-ARC D 351c26e7934f dt-bindings: arm: rockchip: Add Anbernic RG-Arc 294dd835c5d0 arm64: dts: rockchip: Move device specific properties e8f6b6072ce6 dt-bindings: soc: rockchip: Add rk3588 hdptxphy syscon 663d347eb7a7 ARM: dts: stm32: fix DSI peripheral clock on stm32mp15 boards 6e307e6bd72d dt-bindings: memory-controllers: narrow regex for unit address to hex numbers ef93727c9def spi: dt-bindings: samsung: Add Exynos850 SPI c714a4c1273b ARM: dts: qcom: use defines for interrupts 7f37d45ff70d ARM: dts: qcom: apq8026-samsung-matissewifi: Configure touch keys cf76727f86a3 ARM: dts: stm32: lxa-tac: drive powerboard lines as open-drain 19fee3189355 dt-bindings: phy: qcom,sc8280xp-qmp-pcie-phy: Document the X1E80100 QMP PCIe PHYs 899bb26cef2c dt-bindings: iio: adc: rtq6056: add support for the whole RTQ6056 family 09065a127e3c dt-bindings: input: melfas,mms114: add MMS252 compatible ef76ae751c3c dt-bindings: phy: qcom,msm8998-qmp-usb3-phy: support SDM660 97fd9e67ede2 dt-bindings: phy: qcom,msm8998-qmp-usb3-phy: add TCSR registers 25bfbe442a13 dt-bindings: phy: qcom,msm8998-qmp-usb3-phy: support USB-C data 6ec985dff442 dt-bindings: phy: qcom,msm8998-qmp-usb3-phy: split from sc8280xp PHY schema 8b41b5f06d8a arm64: dts: exynos: gs101: enable eeprom on gs101-oriole eb43c96a2716 arm64: dts: exynos: gs101: define USI8 with I2C configuration 688d19a4c1d5 arm64: dts: exynos: gs101: update USI UART to use peric0 clocks c8631c01c9d5 arm64: dts: exynos: gs101: enable cmu-peric0 clock controller 7f078f4efe48 arm64: dts: exynos: gs101: remove reg-io-width from serial dfa299ac5670 arm64: dts: exynos: gs101: define Multi Core Timer (MCT) node dd8d6cdb498f dt-bindings: clock: tesla,fsd: Fix spelling mistake 2a50cd8b4cad Merge tag 'samsung-dt-bindings-clk-6.9-2' into next/clk 1308a1709db2 dt-bindings: clock: exynos850: Add PDMA clocks 5f252cf1954d dt-bindings: clock: google,gs101-clock: add PERIC0 clock management unit b7045107b13d dt-bindings: phy: Add QMP UFS PHY compatible for SC7180 806828c18886 arm64: dts: qcom: sc8180x: Add RPMh sleep stats 8bfa57f18d67 arm64: dts: qcom: sc8180x: Shrink aoss_qmp register space size 39124f597a6a arm64: dts: qcom: sc8180x: Add missing CPU<->MDP_CFG path 076044c5542f arm64: dts: qcom: sc8180x: Require LOW_SVS vote for MMCX if DISPCC is on 76f855a9dca6 arm64: dts: qcom: sc8180x: Don't hold MDP core clock at FMAX 37f3285d146b arm64: dts: qcom: sc8180x: Fix eDP PHY power-domains 5e5b25b16167 arm64: dts: qcom: sc8180x: Add missing CPU off state a971a001fe6a arm64: dts: qcom: sc8180x: Fix up big CPU idle state entry latency d43c023044f1 arm64: dts: qcom: sc8180x: Hook up VDD_CX as GCC parent domain 0a90e0fc5c4b dt-bindings: clock: gcc-sc8180x: Add the missing CX power domain 7d930fbfa6d1 riscv: dts: starfive: jh7110: Add PWM node and pins configuration 98729d5d619d riscv: dts: starfive: jh7100: Add PWM node and pins configuration 2613a64bdc5e dt-bindings: spi: nxp-fspi: support i.MX93 and i.MX95 36d4b81404af dt-bindings: spi: fsl-lpspi: support i.MX95 LPSPI 3ff4d525b9f7 ASoC: dt-bindings: fsl-sai: Support Rx-only SAI fc98068e41fe ASoC: dt-bindings: fsl-sai: Add power-domains 7e4487f7e723 ASoC: Support SAI and MICFIL on i.MX95 platform 170639843215 dt-bindings: iio: pressure: honeywell,mprls0025pa.yaml add spi bus e06b0404e4ef dt-bindings: iio: pressure: honeywell,mprls0025pa.yaml add pressure-triplet cb500c9133ee dt-bindings: iio: pressure: honeywell,mprls0025pa.yaml improvements 0c9fbdab661d dt-bindings: iio: light: as73211: add support for as7331 668faa4c00b6 ARM: dts: qcom: ipq4019: correct clock order in DWC3 node 01f571222843 ARM: dts: qcom: sdx65: correct clock order in DWC3 node f0606dbf1b06 ARM: dts: qcom: ipq8064: drop unused reset-names from DWC3 node 638f430aa2c5 arm64: dts: qcom: qcm6490-fairphone-fp5: Enable venus node 2bf14ff2de89 arm64: dts: qcom: sc7280: Move video-firmware to chrome-common e694053a2504 arm64: dts: qcom: x1e80100: drop qcom,drv-count ae0bc4781d25 arm64: dts: qcom: sc7280: Add additional MSI interrupts fbc40e8570be dt-bindings: pwm: Add bindings for OpenCores PWM Controller f86a5abc5095 ASoC: codecs: add support for WCD939x Codec 0023860e3cd8 dt-bindings: Add DPS310 as trivial device 4d5cba356b2e docs: dt: submitting-patches: add commit subject prefix in reversed format 86c6d04414f3 docs: dt: submitting-patches: drop outdated points to TXT format 20fea215870b dt-bindings: Turn on undocumented compatible checks c15bd0d0ea0d arm64: zynqmp: Align usb clock nodes with binding 506404184883 arm64: zynqmp: Comment all smmu entries 702fb0df1a8d arm64: zynqmp: Rename i2c?-gpio to i2c?-gpio-grp 8dae08d3ef0c arm64: zynqmp: Disable Tri-state for MIO38 Pin 08cee7c9acca arm64: zynqmp: Remove incorrect comment from kv260s c28bc39bcbe4 arm64: zynqmp: Introduce u-boot options node with bootscr-address 346b5266ae26 arm64: zynqmp: Fix comment to be aligned with board name. 69a088e616d5 arm64: zynqmp: Update ECAM size to discover up to 256 buses c78a834d7d85 arm64: zynqmp: Describe assigned-clocks for uarts aab3209386cd arm64: zynqmp: Setup default si570 frequency to 156.25MHz 70d8c607c90e arm64: zynqmp: Add resets property for CAN nodes 1e662bbad32e arm64: zynqmp: Add an OP-TEE node to the device tree b97de3d1f0f1 arm64: zynqmp: Add output-enable pins to SOMs 5149181eb2a0 arm64: zynqmp: Rename zynqmp-power node to power-management 4bbdddd5f137 dt-bindings: firmware: xilinx: Sort node names (clock-controller) bbe26a5d3a74 dt-bindings: firmware: xilinx: Describe missing child nodes 3bb58ba1f178 dt-bindings: firmware: xilinx: Fix versal-fpga node name 552578beff16 dt-bindings: firmware: versal: add versal-net compatible string a1e42c2d1feb dt-bindings: timer: exynos4210-mct: Add google,gs101-mct compatible 793923947260 dt-bindings: i2c: exynos5: add google,gs101-hsi2c compatible e40d0f28e904 ARM: dts: samsung: exynos4412-p4note: add accelerometer and gyro to p4note b0f7ebf9ebb5 ARM: dts: samsung: exynos5800-peach: Enable cros-ec-spi as wake source 7fb70f62fdc1 ARM: dts: samsung: exynos5420-peach: Enable cros-ec-spi as wake source 69ffe89c1f09 ARM: dts: samsung: exynos5422-odroidxu3: disable thermal polling efc6740c2555 arm64: dts: renesas: r8a779g0: Restore sort order 4d29837048f1 ARM: dts: renesas: r8a73a4: Fix thermal parent clock b3b5e2c31a6a ARM: dts: renesas: r8a73a4: Add cp clock 0355cc519d58 ARM: dts: renesas: r8a73a4: Fix external clocks and clock rate c7faddebe0f9 arm64: dts: renesas: rzg3s-smarc: Add gpio keys cf58f575cc98 dt-bindings: regulator: Convert ti,tps65132 to YAML fc588d5d53ae ASoC: dt-bindings: Do not override firmware-name $ref 81002cf24ea5 ASoC: dt-bindings: document WCD939x Audio Codec f47aa77e7a94 ASoC: dt-bindings: qcom,wcd938x: move out common properties d7f07526a034 ASoC: dt-bindings: fsl,micfil: Add compatible string for i.MX95 platform e4fa9d184d78 ASoC: dt-bindings: fsl,sai: Add compatible string for i.MX95 platform 6d65dad20b03 dt-bindings: input: touchscreen: goodix: clarify irq-gpios misleading text 1f08757666ca dt-bindings: input: silead,gsl1680: do not override firmware-name $ref ffc68c88254b dt-bindings: display: panel: Add Novatek NT36672E LCD DSI 22dafcaa7945 dt-bindings: display: panel: Add BOE TH101MB31IG002-28A panel 29e394c3abcd dt-bindings: nt35510: add compatible for FRIDA FRD400B25025-A-CTK c378224488e5 dt-bindings: display: Add SSD133x OLED controllers d4d009fba537 dt-bindings: display: ssd132x: Add vendor prefix to width and height b74c86bcffbc dt-bindings: display: ssd1307fb: Add vendor prefix to width and height 140b66753a95 dt-bindings: panel: lvds: Append edt,etml0700z9ndha in panel-lvds
git-subtree-dir: dts/upstream git-subtree-split: 7e08733c96c84eb323f47e9b248c924e2ac6272a --- This moves OF_UPSTREAM to be tracking the v6.9 release and is for the -next branch. To test these changes yourself locally, either use my "WIP/14May2024-next" branch or run: ./dts/update-dts-subtree.sh pull v6.9-dts yourself locally. I intend to wait a few days to apply this to -next, to give people time to test.
Cc: Adam Ford aford173@gmail.com Cc: Apurva Nandan a-nandan@ti.com Cc: Beniamino Galvani b.galvani@gmail.com Cc: Biju Das biju.das.jz@bp.renesas.com Cc: Bryan Brattlof bb@ti.com Cc: Caleb Connolly caleb.connolly@linaro.org Cc: Christian Hewitt christianshewitt@gmail.com Cc: "Cogent Embedded, Inc." source@cogentembedded.com Cc: Dave Purdy david.c.purdy@gmail.com Cc: Evgeni Dobrev evgeni@studio-punkt.com Cc: Fabio Estevam festevam@gmail.com Cc: Jason Cooper u-boot@lakedaemon.net Cc: Jorge Ramirez-Ortiz jorge.ramirez.ortiz@gmail.com Cc: Lad Prabhakar prabhakar.mahadev-lad.rj@bp.renesas.com Cc: Luka Perkov luka@openwrt.org Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Marek Vasut marek.vasut+renesas@mailbox.org Cc: Masakazu Mochizuki masakazu.mochizuki.wd@hitachi.com Cc: Michael Walle michael@walle.cc Cc: Neil Armstrong neil.armstrong@linaro.org Cc: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com Cc: Paul Barker paul.barker.ct@bp.renesas.com Cc: Peng Fan peng.fan@nxp.com Cc: Ramon Fried rfried.dev@gmail.com Cc: Siddarth Gore gores@marvell.com Cc: Simon Guinot simon.guinot@sequanux.org Cc: Stefan Herbrechtsmeier stefan@herbrechtsmeier.net Cc: Stefan Roese sr@denx.de Cc: Sumit Garg sumit.garg@linaro.org Cc: Tim Harvey tharvey@gateworks.com Cc: Tony Dinh mibodhi@gmail.com Cc: Vignesh Raghavendra vigneshr@ti.com Cc: Vyacheslav Bocharov adeep@lexina.in Cc: Wadim Egorov w.egorov@phytec.de Cc: Walter Schweizer swwa@users.sourceforge.net Cc: u-boot-amlogic@groups.io Cc: u-boot-qcom@groups.io
Bindings/Makefile | 3 - Bindings/arm/amlogic.yaml | 15 +- Bindings/arm/arm,realview.yaml | 6 +- Bindings/arm/atmel-at91.yaml | 6 + Bindings/arm/fsl.yaml | 41 +- Bindings/arm/marvell/armada-38x.txt | 27 - Bindings/arm/marvell/armada-38x.yaml | 70 + Bindings/arm/mediatek.yaml | 198 +- Bindings/arm/mediatek/mediatek,hifsys.txt | 26 - Bindings/arm/mediatek/mediatek,pciesys.txt | 25 - Bindings/arm/mediatek/mediatek,ssusbsys.txt | 25 - Bindings/arm/msm/qcom,saw2.txt | 58 - Bindings/arm/qcom,coresight-tpdm.yaml | 40 +- Bindings/arm/qcom.yaml | 58 +- Bindings/arm/rockchip.yaml | 71 +- Bindings/arm/sunxi.yaml | 12 + Bindings/arm/syna.txt | 12 - Bindings/arm/tegra.yaml | 8 + Bindings/arm/tegra/nvidia,tegra186-pmc.yaml | 58 +- Bindings/arm/ti/k3.yaml | 14 + Bindings/ata/ahci-mtk.txt | 51 - Bindings/ata/atmel-at91_cf.txt | 19 - Bindings/ata/mediatek,mtk-ahci.yaml | 98 + Bindings/auxdisplay/arm,versatile-lcd.yaml | 4 +- Bindings/auxdisplay/gpio-7-segment.yaml | 55 + Bindings/auxdisplay/hit,hd44780.yaml | 68 +- Bindings/auxdisplay/holtek,ht16k33.yaml | 54 +- Bindings/auxdisplay/img,ascii-lcd.yaml | 4 +- Bindings/auxdisplay/maxim,max6959.yaml | 44 + Bindings/bus/brcm,gisb-arb.yaml | 1 + Bindings/bus/imx-weim.txt | 117 - Bindings/clock/google,gs101-clock.yaml | 28 +- Bindings/clock/keystone-gate.txt | 2 - Bindings/clock/keystone-pll.txt | 2 - Bindings/clock/mediatek,mt2701-hifsys.yaml | 50 + Bindings/clock/mediatek,mt7622-pciesys.yaml | 45 + Bindings/clock/mediatek,mt7622-ssusbsys.yaml | 45 + Bindings/clock/mobileye,eyeq5-clk.yaml | 51 + Bindings/clock/qcom,gcc-sc8180x.yaml | 7 + Bindings/clock/qcom,gpucc.yaml | 9 + Bindings/clock/qcom,q6sstopcc.yaml | 2 +- Bindings/clock/qcom,sc7180-mss.yaml | 61 - Bindings/clock/qcom,sm8450-camcc.yaml | 2 + Bindings/clock/qcom,sm8450-gpucc.yaml | 2 + Bindings/clock/qcom,sm8550-dispcc.yaml | 7 +- Bindings/clock/qcom,sm8550-tcsr.yaml | 1 + Bindings/clock/qcom,sm8650-dispcc.yaml | 106 - Bindings/clock/renesas,cpg-mssr.yaml | 1 + Bindings/clock/samsung,exynos850-clock.yaml | 42 + Bindings/clock/tesla,fsd-clock.yaml | 2 +- Bindings/clock/ti/adpll.txt | 2 - Bindings/clock/ti/apll.txt | 2 - Bindings/clock/ti/autoidle.txt | 2 - Bindings/clock/ti/clockdomain.txt | 2 - Bindings/clock/ti/composite.txt | 2 - Bindings/clock/ti/divider.txt | 2 - Bindings/clock/ti/dpll.txt | 2 - Bindings/clock/ti/fapll.txt | 2 - Bindings/clock/ti/fixed-factor-clock.txt | 2 - Bindings/clock/ti/gate.txt | 2 - Bindings/clock/ti/interface.txt | 2 - Bindings/clock/ti/mux.txt | 2 - Bindings/crypto/atmel,at91sam9g46-aes.yaml | 6 +- Bindings/crypto/atmel,at91sam9g46-sha.yaml | 6 +- Bindings/crypto/atmel,at91sam9g46-tdes.yaml | 6 +- .../crypto/qcom,inline-crypto-engine.yaml | 1 + Bindings/crypto/qcom-qce.yaml | 1 + .../atmel/atmel,hlcdc-display-controller.yaml | 63 + Bindings/display/atmel/hlcdc-dc.txt | 75 - .../display/bridge/fsl,imx8mp-hdmi-tx.yaml | 102 + Bindings/display/bridge/ti,sn65dsi86.yaml | 2 +- Bindings/display/fsl,lcdif.yaml | 8 +- Bindings/display/imx/fsl,imx8mp-hdmi-pvi.yaml | 84 + Bindings/display/msm/dsi-controller-main.yaml | 2 + Bindings/display/msm/gmu.yaml | 1 + Bindings/display/msm/gpu.yaml | 6 +- Bindings/display/msm/qcom,mdss.yaml | 1 + Bindings/display/msm/qcom,sm8150-mdss.yaml | 9 + Bindings/display/msm/qcom,sm8650-dpu.yaml | 4 +- Bindings/display/msm/qcom,sm8650-mdss.yaml | 4 + Bindings/display/msm/qcom,x1e80100-mdss.yaml | 251 ++ .../display/panel/boe,th101mb31ig002-28a.yaml | 58 + Bindings/display/panel/himax,hx83112a.yaml | 74 + .../display/panel/leadtek,ltk500hd1829.yaml | 4 +- Bindings/display/panel/novatek,nt35510.yaml | 5 +- Bindings/display/panel/novatek,nt36672e.yaml | 66 + Bindings/display/panel/panel-lvds.yaml | 4 + Bindings/display/panel/panel-simple.yaml | 4 + .../display/panel/rocktech,jh057n00900.yaml | 3 + Bindings/display/panel/visionox,r66451.yaml | 2 +- Bindings/display/panel/visionox,rm69299.yaml | 3 +- Bindings/display/renesas,rzg2l-du.yaml | 126 + .../display/rockchip/rockchip,dw-hdmi.yaml | 33 +- Bindings/display/solomon,ssd1307fb.yaml | 20 +- Bindings/display/solomon,ssd132x.yaml | 12 +- Bindings/display/solomon,ssd133x.yaml | 45 + Bindings/display/ti/ti,am65x-dss.yaml | 7 +- Bindings/dma/allwinner,sun50i-a64-dma.yaml | 12 +- Bindings/dma/fsl,edma.yaml | 2 + Bindings/dma/fsl,imx-sdma.yaml | 3 +- Bindings/dma/marvell,mmp-dma.yaml | 72 + Bindings/dma/mediatek,mt7622-hsdma.yaml | 63 + Bindings/dma/mmp-dma.txt | 81 - Bindings/dma/mtk-hsdma.txt | 33 - Bindings/dma/renesas,rcar-dmac.yaml | 1 + Bindings/dts-coding-style.rst | 2 + Bindings/eeprom/at24.yaml | 5 +- .../firmware/xilinx/xlnx,zynqmp-firmware.yaml | 96 +- Bindings/fpga/fpga-region.txt | 479 ---- Bindings/fpga/fpga-region.yaml | 358 +++ Bindings/fpga/xlnx,versal-fpga.yaml | 2 +- Bindings/gpio/aspeed,ast2400-gpio.yaml | 148 + Bindings/gpio/gateworks,pld-gpio.txt | 3 +- Bindings/gpio/gpio-aspeed.txt | 39 - Bindings/gpio/gpio-mvebu.yaml | 2 +- Bindings/gpio/gpio-nmk.txt | 31 - Bindings/gpio/gpio-pca9570.yaml | 3 + Bindings/gpio/mrvl-gpio.yaml | 2 +- Bindings/gpio/renesas,rcar-gpio.yaml | 1 + Bindings/gpio/st,nomadik-gpio.yaml | 95 + ...mg,powervr.yaml => img,powervr-rogue.yaml} | 4 +- Bindings/gpu/img,powervr-sgx.yaml | 138 + Bindings/hwmon/adi,adm1177.yaml | 5 +- Bindings/hwmon/adi,adm1275.yaml | 7 +- Bindings/hwmon/adi,ltc2945.yaml | 5 +- Bindings/hwmon/adi,ltc4282.yaml | 159 ++ Bindings/hwmon/amphenol,chipcap2.yaml | 77 + Bindings/hwmon/aspeed,g6-pwm-tach.yaml | 71 + Bindings/hwmon/fan-common.yaml | 79 + Bindings/hwmon/hwmon-common.yaml | 19 + Bindings/hwmon/lltc,ltc4151.yaml | 5 +- Bindings/hwmon/lltc,ltc4286.yaml | 9 +- Bindings/hwmon/lm75.yaml | 3 +- Bindings/hwmon/nuvoton,nct6775.yaml | 1 + Bindings/hwmon/pmbus/infineon,tda38640.yaml | 28 + Bindings/hwmon/pmbus/ti,lm25066.yaml | 17 +- Bindings/hwmon/ti,ina2xx.yaml | 11 +- Bindings/hwmon/ti,tmp513.yaml | 5 +- Bindings/hwmon/ti,tps23861.yaml | 5 +- Bindings/i2c/atmel,at91sam-i2c.yaml | 4 +- Bindings/i2c/i2c-demux-pinctrl.yaml | 3 +- Bindings/i2c/i2c-exynos5.yaml | 1 + Bindings/i2c/i2c-imx-lpi2c.yaml | 1 + Bindings/i2c/i2c-mpc.yaml | 2 +- Bindings/i2c/i2c-mux-pca954x.yaml | 30 + Bindings/i2c/i2c-pxa.yaml | 2 +- Bindings/i2c/i2c.txt | 151 - Bindings/i2c/nvidia,tegra186-bpmp-i2c.yaml | 3 +- Bindings/i2c/qcom,i2c-cci.yaml | 2 +- Bindings/i2c/renesas,rcar-i2c.yaml | 1 + Bindings/i2c/st,nomadik-i2c.yaml | 49 +- Bindings/i3c/aspeed,ast2600-i3c.yaml | 2 +- Bindings/i3c/cdns,i3c-master.yaml | 2 +- Bindings/i3c/i3c.yaml | 6 +- Bindings/i3c/mipi-i3c-hci.yaml | 2 +- Bindings/i3c/silvaco,i3c-master.yaml | 2 +- Bindings/i3c/snps,dw-i3c-master.yaml | 2 +- Bindings/iio/adc/adc.yaml | 1 - Bindings/iio/adc/adi,ad9467.yaml | 4 + Bindings/iio/adc/adi,axi-adc.yaml | 8 +- Bindings/iio/adc/microchip,pac1934.yaml | 120 + Bindings/iio/adc/nxp,imx93-adc.yaml | 4 +- Bindings/iio/adc/qcom,spmi-vadc.yaml | 1 - Bindings/iio/adc/richtek,rtq6056.yaml | 9 +- Bindings/iio/adc/ti,ads1298.yaml | 80 + Bindings/iio/afe/voltage-divider.yaml | 11 + Bindings/iio/amplifiers/adi,hmc425a.yaml | 47 +- Bindings/iio/frequency/adi,admfm2000.yaml | 127 + Bindings/iio/gyroscope/bosch,bmg160.yaml | 8 +- Bindings/iio/health/maxim,max30102.yaml | 2 +- Bindings/iio/humidity/ti,hdc2010.yaml | 3 + Bindings/iio/humidity/ti,hdc3020.yaml | 3 + Bindings/iio/imu/st,lsm6dsx.yaml | 4 +- Bindings/iio/light/ams,as73211.yaml | 7 +- Bindings/iio/light/vishay,veml6075.yaml | 1 + .../iio/magnetometer/voltafield,af8133j.yaml | 60 + Bindings/iio/pressure/honeywell,hsc030pa.yaml | 3 + .../iio/pressure/honeywell,mprls0025pa.yaml | 98 +- Bindings/iio/temperature/ti,tmp117.yaml | 8 + .../input/allwinner,sun4i-a10-lradc-keys.yaml | 1 - Bindings/input/atmel,captouch.txt | 36 - Bindings/input/atmel,captouch.yaml | 59 + Bindings/input/da9062-onkey.txt | 47 - Bindings/input/dlg,da9062-onkey.yaml | 38 + Bindings/input/samsung,s3c6410-keypad.yaml | 121 + Bindings/input/samsung-keypad.txt | 77 - .../input/touchscreen/fsl,imx6ul-tsc.yaml | 97 + Bindings/input/touchscreen/goodix,gt9916.yaml | 95 + Bindings/input/touchscreen/goodix.yaml | 5 +- .../input/touchscreen/imagis,ist3038c.yaml | 21 +- Bindings/input/touchscreen/imx6ul_tsc.txt | 38 - Bindings/input/touchscreen/melfas,mms114.yaml | 6 +- .../input/touchscreen/silead,gsl1680.yaml | 2 +- Bindings/interconnect/qcom,rpm.yaml | 3 + Bindings/interconnect/qcom,rpmh.yaml | 2 +- Bindings/interconnect/qcom,sm7150-rpmh.yaml | 84 + .../amlogic,meson-gpio-intc.yaml | 1 + Bindings/interrupt-controller/atmel,aic.txt | 43 - Bindings/interrupt-controller/atmel,aic.yaml | 89 + Bindings/interrupt-controller/fsl,intmux.yaml | 3 + .../mediatek,mt6577-sysirq.yaml | 85 + .../interrupt-controller/mediatek,sysirq.txt | 44 - .../renesas,rzg2l-irqc.yaml | 44 +- .../starfive,jh8100-intc.yaml | 61 + Bindings/iommu/arm,smmu.yaml | 20 +- Bindings/leds/backlight/kinetic,ktd2801.yaml | 46 + Bindings/leds/backlight/qcom-wled.yaml | 4 +- Bindings/leds/common.yaml | 12 + Bindings/leds/leds-bcm63138.yaml | 4 - Bindings/leds/leds-bcm6328.yaml | 4 - Bindings/leds/leds-bcm6358.txt | 2 - Bindings/leds/leds-pwm-multicolor.yaml | 4 +- Bindings/leds/leds-pwm.yaml | 5 - Bindings/leds/leds-qcom-lpg.yaml | 102 +- Bindings/leds/onnn,ncp5623.yaml | 96 + Bindings/mailbox/fsl,mu.yaml | 58 +- Bindings/media/i2c/techwell,tw9900.yaml | 2 +- Bindings/media/mediatek,vcodec-encoder.yaml | 31 +- Bindings/media/mediatek-jpeg-encoder.yaml | 3 +- Bindings/media/rockchip-isp1.yaml | 37 +- Bindings/media/st,stm32mp25-video-codec.yaml | 49 + .../fsl/fsl,imx-weim-peripherals.yaml | 31 + .../memory-controllers/fsl/fsl,imx-weim.yaml | 204 ++ .../mc-peripheral-props.yaml | 1 + .../nvidia,tegra20-emc.yaml | 2 +- .../memory-controllers/renesas,rpc-if.yaml | 1 + .../memory-controllers/st,stm32-fmc2-ebi.yaml | 7 +- Bindings/mfd/atmel,hlcdc.yaml | 99 + Bindings/mfd/atmel,sama5d2-flexcom.yaml | 99 + Bindings/mfd/atmel-flexcom.txt | 64 - Bindings/mfd/atmel-hlcdc.txt | 56 - Bindings/mfd/da9062.txt | 124 - Bindings/mfd/dlg,da9063.yaml | 251 +- Bindings/mfd/google,cros-ec.yaml | 7 + Bindings/mfd/iqs62x.yaml | 2 +- Bindings/mfd/qcom,tcsr.yaml | 2 + Bindings/mfd/syscon.yaml | 3 + Bindings/mfd/ti,twl.yaml | 2 + Bindings/mips/cpus.yaml | 13 +- Bindings/mips/mobileye.yaml | 32 + Bindings/misc/qcom,fastrpc.yaml | 2 + Bindings/misc/xlnx,sd-fec.txt | 58 - Bindings/misc/xlnx,sd-fec.yaml | 140 + Bindings/mmc/fsl-imx-esdhc.yaml | 11 +- Bindings/mmc/fsl-imx-mmc.yaml | 12 + Bindings/mmc/hi3798cv200-dw-mshc.txt | 40 - .../mmc/hisilicon,hi3798cv200-dw-mshc.yaml | 97 + Bindings/mmc/renesas,sdhi.yaml | 1 + Bindings/mmc/snps,dwcmshc-sdhci.yaml | 2 + Bindings/mtd/atmel-nand.txt | 1 + Bindings/mtd/brcm,brcmnand.yaml | 44 +- Bindings/mtd/davinci-nand.txt | 2 +- Bindings/mtd/flctl-nand.txt | 2 +- Bindings/mtd/fsl-upm-nand.txt | 2 +- Bindings/mtd/gpio-control-nand.txt | 2 +- Bindings/mtd/gpmi-nand.yaml | 2 +- Bindings/mtd/hisi504-nand.txt | 2 +- Bindings/mtd/jedec,spi-nor.yaml | 3 + Bindings/mtd/mtd.yaml | 2 + Bindings/mtd/nvidia-tegra20-nand.txt | 2 +- Bindings/mtd/orion-nand.txt | 2 +- Bindings/mtd/partitions/linux,ubi.yaml | 75 + Bindings/mtd/partitions/ubi-volume.yaml | 40 + Bindings/mtd/samsung-s3c2410.txt | 2 +- Bindings/mtd/st,stm32-fmc2-nand.yaml | 25 +- Bindings/mux/mux-controller.yaml | 2 +- .../net/bluetooth/qualcomm-bluetooth.yaml | 8 +- Bindings/net/brcm,asp-v2.0.yaml | 4 + Bindings/net/brcm,unimac-mdio.yaml | 1 + Bindings/net/can/fsl,flexcan.yaml | 3 + Bindings/net/can/microchip,mpfs-can.yaml | 6 +- Bindings/net/can/tcan4x5x.txt | 3 + Bindings/net/can/xilinx,can.yaml | 5 + Bindings/net/cdns,macb.yaml | 5 + Bindings/net/dsa/ar9331.txt | 147 - Bindings/net/dsa/microchip,ksz.yaml | 1 + Bindings/net/dsa/qca,ar9331.yaml | 161 ++ Bindings/net/dsa/realtek.yaml | 4 +- Bindings/net/ethernet-controller.yaml | 1 - Bindings/net/ethernet-phy-package.yaml | 52 + Bindings/net/fsl,fec.yaml | 3 + Bindings/net/mediatek,net.yaml | 22 +- Bindings/net/nfc/ti,trf7970a.yaml | 2 +- Bindings/net/qca,qca808x.yaml | 54 + Bindings/net/qcom,ethqos.yaml | 9 +- Bindings/net/qcom,ipa.yaml | 2 +- Bindings/net/qcom,ipq4019-mdio.yaml | 15 + Bindings/net/qcom,qca807x.yaml | 184 ++ Bindings/net/renesas,etheravb.yaml | 1 + Bindings/net/snps,dwmac.yaml | 17 +- Bindings/net/starfive,jh7110-dwmac.yaml | 72 +- Bindings/net/ti,cpsw-switch.yaml | 5 +- Bindings/net/ti,dp83822.yaml | 34 + Bindings/net/ti,k3-am654-cpsw-nuss.yaml | 5 +- Bindings/net/ti,k3-am654-cpts.yaml | 5 +- Bindings/net/wireless/mediatek,mt76.yaml | 33 +- Bindings/net/wireless/qcom,ath10k.yaml | 1 + Bindings/net/wireless/qcom,ath11k-pci.yaml | 1 + Bindings/net/wireless/qcom,ath11k.yaml | 1 + Bindings/nvmem/layouts/fixed-cell.yaml | 22 +- Bindings/nvmem/nvmem-provider.yaml | 18 + Bindings/nvmem/xlnx,zynqmp-nvmem.txt | 46 - Bindings/nvmem/xlnx,zynqmp-nvmem.yaml | 42 + Bindings/opp/opp-v2-base.yaml | 2 - Bindings/pci/fsl,imx6q-pcie-common.yaml | 17 +- Bindings/pci/fsl,imx6q-pcie-ep.yaml | 46 +- Bindings/pci/fsl,imx6q-pcie.yaml | 49 +- Bindings/pci/qcom,pcie-common.yaml | 100 + Bindings/pci/qcom,pcie-sa8775p.yaml | 166 ++ Bindings/pci/qcom,pcie-sc7280.yaml | 166 ++ Bindings/pci/qcom,pcie-sc8180x.yaml | 170 ++ Bindings/pci/qcom,pcie-sc8280xp.yaml | 180 ++ Bindings/pci/qcom,pcie-sm8150.yaml | 158 + Bindings/pci/qcom,pcie-sm8250.yaml | 173 ++ Bindings/pci/qcom,pcie-sm8350.yaml | 184 ++ Bindings/pci/qcom,pcie-sm8450.yaml | 178 ++ Bindings/pci/qcom,pcie-sm8550.yaml | 171 ++ Bindings/pci/qcom,pcie-x1e80100.yaml | 165 ++ Bindings/pci/qcom,pcie.yaml | 378 +-- Bindings/perf/arm,coresight-pmu.yaml | 39 + .../perf/starfive,jh8100-starlink-pmu.yaml | 46 + Bindings/phy/mediatek,mt8365-csi-rx.yaml | 79 + Bindings/phy/phy-cadence-torrent.yaml | 11 +- Bindings/phy/qcom,msm8998-qmp-usb3-phy.yaml | 184 ++ Bindings/phy/qcom,sc8280xp-qmp-pcie-phy.yaml | 6 + Bindings/phy/qcom,sc8280xp-qmp-ufs-phy.yaml | 48 +- .../phy/qcom,sc8280xp-qmp-usb3-uni-phy.yaml | 22 - Bindings/phy/rockchip,rk3588-hdptx-phy.yaml | 91 + .../pinctrl/amlogic,meson-pinctrl-a1.yaml | 2 +- .../amlogic,meson-pinctrl-g12a-aobus.yaml | 2 +- .../amlogic,meson-pinctrl-g12a-periphs.yaml | 2 +- .../pinctrl/amlogic,meson8-pinctrl-aobus.yaml | 2 +- .../pinctrl/amlogic,meson8-pinctrl-cbus.yaml | 2 +- Bindings/pinctrl/atmel,at91-pinctrl.txt | 2 + Bindings/pinctrl/awinic,aw9523-pinctrl.yaml | 139 + Bindings/pinctrl/cirrus,madera.yaml | 3 +- Bindings/pinctrl/cypress,cy8c95x0.yaml | 24 +- Bindings/pinctrl/fsl,imx6ul-pinctrl.txt | 37 - Bindings/pinctrl/fsl,imx6ul-pinctrl.yaml | 116 + Bindings/pinctrl/mobileye,eyeq5-pinctrl.yaml | 242 ++ Bindings/pinctrl/nuvoton,npcm845-pinctrl.yaml | 2 - Bindings/pinctrl/nuvoton,wpcm450-pinctrl.yaml | 3 +- .../pinctrl/nvidia,tegra234-pinmux-aon.yaml | 7 +- .../nvidia,tegra234-pinmux-common.yaml | 84 +- Bindings/pinctrl/nvidia,tegra234-pinmux.yaml | 7 +- Bindings/pinctrl/pincfg-node.yaml | 2 +- Bindings/pinctrl/qcom,sm4450-tlmm.yaml | 2 +- Bindings/pinctrl/renesas,pfc.yaml | 1 + Bindings/pinctrl/renesas,rzg2l-pinctrl.yaml | 2 + ...nq-pinctrl.yaml => xlnx,pinctrl-zynq.yaml} | 6 +- Bindings/power/qcom,rpmpd.yaml | 2 + Bindings/power/renesas,rcar-sysc.yaml | 1 + Bindings/power/wakeup-source.txt | 2 +- Bindings/pwm/atmel,hlcdc-pwm.yaml | 35 + Bindings/pwm/atmel-hlcdc-pwm.txt | 29 - Bindings/pwm/marvell,pxa-pwm.yaml | 51 + Bindings/pwm/mediatek,mt2712-pwm.yaml | 1 + Bindings/pwm/mediatek,pwm-disp.yaml | 3 + Bindings/pwm/opencores,pwm.yaml | 56 + Bindings/pwm/pwm-amlogic.yaml | 115 +- Bindings/pwm/pxa-pwm.txt | 30 - Bindings/regulator/gpio-regulator.yaml | 4 +- Bindings/regulator/infineon,ir38060.yaml | 45 + Bindings/regulator/mcp16502-regulator.txt | 144 - Bindings/regulator/microchip,mcp16502.yaml | 180 ++ .../regulator/qcom,usb-vbus-regulator.yaml | 11 +- Bindings/regulator/ti,tps65132.yaml | 84 + Bindings/regulator/tps65132-regulator.txt | 46 - Bindings/remoteproc/mtk,scp.yaml | 4 +- Bindings/remoteproc/qcom,glink-rpm-edge.yaml | 1 - Bindings/remoteproc/qcom,qcs404-pas.yaml | 2 +- Bindings/remoteproc/qcom,sc7180-pas.yaml | 2 +- Bindings/remoteproc/qcom,sc7280-wpss-pil.yaml | 2 +- Bindings/remoteproc/qcom,sc8180x-pas.yaml | 2 +- Bindings/remoteproc/qcom,sm6115-pas.yaml | 2 +- Bindings/remoteproc/qcom,sm6350-pas.yaml | 2 +- Bindings/remoteproc/qcom,sm6375-pas.yaml | 2 +- Bindings/remoteproc/qcom,sm8150-pas.yaml | 2 +- Bindings/remoteproc/qcom,sm8350-pas.yaml | 2 +- Bindings/remoteproc/qcom,sm8550-pas.yaml | 51 +- Bindings/remoteproc/qcom,wcnss-pil.yaml | 2 +- Bindings/remoteproc/ti,davinci-rproc.txt | 3 - Bindings/reset/mobileye,eyeq5-reset.yaml | 43 + Bindings/reset/renesas,rst.yaml | 1 + Bindings/reset/sophgo,sg2042-reset.yaml | 35 + Bindings/riscv/cpus.yaml | 10 +- Bindings/riscv/extensions.yaml | 7 + Bindings/rng/atmel,at91-trng.yaml | 4 + Bindings/rtc/abracon,abx80x.txt | 31 - Bindings/rtc/abracon,abx80x.yaml | 98 + Bindings/rtc/atmel,at91sam9260-rtt.yaml | 4 +- Bindings/rtc/mediatek,mt2712-rtc.yaml | 39 + Bindings/rtc/mediatek,mt7622-rtc.yaml | 52 + Bindings/rtc/rtc-mt2712.txt | 14 - Bindings/rtc/rtc-mt7622.txt | 21 - Bindings/rtc/sa1100-rtc.yaml | 2 +- Bindings/rtc/xlnx,zynqmp-rtc.yaml | 11 +- Bindings/serial/atmel,at91-usart.yaml | 2 +- Bindings/serial/cdns,uart.yaml | 1 + Bindings/serial/fsl-lpuart.yaml | 1 + Bindings/serial/renesas,hscif.yaml | 1 + Bindings/serial/samsung_uart.yaml | 2 + Bindings/serial/serial.yaml | 2 +- Bindings/serial/st,asc.yaml | 55 + Bindings/serial/st,stm32-uart.yaml | 3 + Bindings/serial/st-asc.txt | 18 - Bindings/soc/fsl/fsl,layerscape-dcfg.yaml | 2 +- Bindings/soc/fsl/fsl,layerscape-scfg.yaml | 2 +- Bindings/soc/imx/fsl,imx-anatop.yaml | 128 + Bindings/soc/imx/fsl,imx-iomuxc-gpr.yaml | 18 +- .../soc/imx/fsl,imx8mp-hdmi-blk-ctrl.yaml | 22 +- Bindings/soc/qcom/qcom,pbs.yaml | 46 + Bindings/soc/qcom/qcom,pmic-glink.yaml | 3 + Bindings/soc/qcom/qcom,rpm-master-stats.yaml | 2 + .../qcom/{qcom,spm.yaml => qcom,saw2.yaml} | 46 +- Bindings/soc/renesas/renesas-soc.yaml | 73 + Bindings/soc/renesas/renesas.yaml | 25 +- Bindings/soc/rockchip/grf.yaml | 23 + .../soc/samsung/samsung,exynos-sysreg.yaml | 2 + Bindings/soc/xilinx/xilinx.yaml | 70 +- Bindings/sound/atmel,asoc-wm8904.yaml | 84 + Bindings/sound/atmel,sam9x5-wm8731-audio.yaml | 76 + Bindings/sound/atmel,sama5d2-classd.yaml | 7 +- Bindings/sound/atmel-sam9x5-wm8731-audio.txt | 35 - Bindings/sound/atmel-wm8904.txt | 55 - Bindings/sound/audio-graph-port.yaml | 2 +- Bindings/sound/cirrus,cs35l45.yaml | 3 + Bindings/sound/cirrus,cs42l43.yaml | 11 +- Bindings/sound/cs4341.txt | 2 +- Bindings/sound/everest,es8326.yaml | 8 +- Bindings/sound/fsl,asrc.txt | 80 - Bindings/sound/fsl,easrc.yaml | 4 +- Bindings/sound/fsl,imx-asrc.yaml | 162 ++ Bindings/sound/fsl,micfil.yaml | 14 +- Bindings/sound/fsl,sai.yaml | 6 + Bindings/sound/infineon,peb2466.yaml | 2 +- Bindings/sound/microchip,sama7g5-i2smcc.yaml | 11 +- Bindings/sound/qcom,q6usb.yaml | 55 + Bindings/sound/qcom,sm8250.yaml | 2 +- Bindings/sound/qcom,wcd938x.yaml | 81 +- Bindings/sound/qcom,wcd939x-sdw.yaml | 69 + Bindings/sound/qcom,wcd939x.yaml | 96 + Bindings/sound/qcom,wcd93xx-common.yaml | 95 + Bindings/sound/qcom,wsa8840.yaml | 11 +- Bindings/sound/realtek,rt1015.yaml | 41 + Bindings/sound/rt1015.txt | 23 - Bindings/sound/rt5645.txt | 6 + Bindings/sound/samsung,tm2.yaml | 7 +- Bindings/spi/atmel,at91rm9200-spi.yaml | 1 - Bindings/spi/samsung,spi.yaml | 4 +- Bindings/spi/spi-controller.yaml | 27 + Bindings/spi/spi-fsl-lpspi.yaml | 1 + Bindings/spi/spi-nxp-fspi.yaml | 18 +- .../allwinner,sun4i-a10-system-control.yaml | 2 +- Bindings/submitting-patches.rst | 23 +- .../thermal/allwinner,sun8i-a83t-ths.yaml | 34 +- Bindings/thermal/da9062-thermal.txt | 36 - Bindings/thermal/dlg,da9062-thermal.yaml | 35 + Bindings/thermal/qoriq-thermal.yaml | 3 +- Bindings/thermal/rcar-gen3-thermal.yaml | 2 + Bindings/thermal/thermal-zones.yaml | 2 - Bindings/timer/arm,arch_timer_mmio.yaml | 2 +- Bindings/timer/cdns,ttc.yaml | 22 +- Bindings/timer/mediatek,mtk-timer.txt | 48 - Bindings/timer/mediatek,timer.yaml | 84 + Bindings/timer/mrvl,mmp-timer.yaml | 2 +- Bindings/timer/nxp,sysctr-timer.yaml | 4 +- Bindings/timer/ralink,cevt-systick.yaml | 38 + Bindings/timer/renesas,ostm.yaml | 2 +- Bindings/timer/renesas,tmu.yaml | 18 +- Bindings/timer/samsung,exynos4210-mct.yaml | 2 + Bindings/tpm/tcg,tpm_tis-spi.yaml | 1 + Bindings/trivial-devices.yaml | 87 +- Bindings/ufs/qcom,ufs.yaml | 38 +- Bindings/usb/analogix,anx7411.yaml | 13 - Bindings/usb/ci-hdrc-usb2.yaml | 2 +- Bindings/usb/cypress,hx3.yaml | 2 +- Bindings/usb/fcs,fsa4480.yaml | 12 +- Bindings/usb/generic-ehci.yaml | 1 + Bindings/usb/gpio-sbu-mux.yaml | 12 +- Bindings/usb/hisilicon,hi3798mv200-dwc3.yaml | 99 + Bindings/usb/ite,it5205.yaml | 72 + Bindings/usb/mediatek,mtu3.yaml | 5 +- Bindings/usb/microchip,usb5744.yaml | 2 - Bindings/usb/nxp,ptn36502.yaml | 12 +- Bindings/usb/nxp,ptn5110.yaml | 6 +- Bindings/usb/onnn,nb7vpq904m.yaml | 13 +- Bindings/usb/qcom,dwc3.yaml | 2 +- Bindings/usb/qcom,pmic-typec.yaml | 46 +- Bindings/usb/qcom,wcd939x-usbss.yaml | 12 +- Bindings/usb/realtek,rts5411.yaml | 55 + Bindings/usb/ti,am62-usb.yaml | 8 +- Bindings/usb/ti,usb8020b.yaml | 69 + Bindings/usb/usb-nop-xceiv.yaml | 11 +- Bindings/usb/usb-switch.yaml | 67 + Bindings/usb/usb.yaml | 2 + Bindings/vendor-prefixes.yaml | 45 + Bindings/w1/w1-uart.yaml | 59 + Bindings/watchdog/arm,sp805.yaml | 5 + Bindings/watchdog/atmel,sama5d4-wdt.yaml | 12 +- Bindings/watchdog/brcm,bcm2835-pm-wdog.txt | 18 - Bindings/watchdog/qcom-wdt.yaml | 2 +- Bindings/watchdog/renesas,wdt.yaml | 1 + Bindings/watchdog/sprd,sp9860-wdt.yaml | 64 + Bindings/watchdog/sprd-wdt.txt | 19 - Bindings/watchdog/starfive,jh7100-wdt.yaml | 40 +- Bindings/writing-schema.rst | 30 +- include/dt-bindings/arm/qcom,ids.h | 5 + include/dt-bindings/clock/ast2600-clock.h | 1 + include/dt-bindings/clock/exynos850.h | 56 + include/dt-bindings/clock/google,gs101.h | 129 + .../dt-bindings/clock/microchip,mpfs-clock.h | 5 + .../dt-bindings/clock/mobileye,eyeq5-clk.h | 22 + include/dt-bindings/clock/qcom,gcc-msm8953.h | 4 + include/dt-bindings/clock/qcom,gcc-sc8180x.h | 2 + include/dt-bindings/clock/qcom,gcc-sm8150.h | 3 + .../dt-bindings/clock/qcom,x1e80100-camcc.h | 135 + .../dt-bindings/clock/qcom,x1e80100-dispcc.h | 98 + .../dt-bindings/clock/qcom,x1e80100-gpucc.h | 41 + .../dt-bindings/clock/qcom,x1e80100-tcsr.h | 23 + include/dt-bindings/clock/r8a779g0-cpg-mssr.h | 1 + .../clock/renesas,r8a779h0-cpg-mssr.h | 96 + .../dt-bindings/clock/rockchip,rk3588-cru.h | 3 +- include/dt-bindings/input/linux-event-codes.h | 1 + .../dt-bindings/interconnect/qcom,msm8909.h | 93 + .../interconnect/qcom,sm7150-rpmh.h | 150 + .../interconnect/qcom,x1e80100-rpmh.h | 24 - include/dt-bindings/leds/common.h | 4 + include/dt-bindings/mfd/stm32f7-rcc.h | 1 + include/dt-bindings/power/amlogic,c3-pwrc.h | 2 +- include/dt-bindings/power/qcom-rpmpd.h | 7 + .../dt-bindings/power/renesas,r8a779h0-sysc.h | 49 + .../reset/mediatek,mt7988-resets.h | 6 + .../dt-bindings/reset/qcom,x1e80100-gpucc.h | 19 + .../dt-bindings/reset/sophgo,sg2042-reset.h | 87 + src/arc/axc003.dtsi | 4 +- src/arc/hsdk.dts | 1 - src/arc/vdk_axs10x_mb.dtsi | 2 +- src/arm/allwinner/sun8i-r40-feta40i.dtsi | 7 + src/arm/amlogic/meson.dtsi | 6 +- src/arm/amlogic/meson8.dtsi | 1 - src/arm/amlogic/meson8b.dtsi | 1 - src/arm/arm/arm-realview-pb1176.dts | 2 +- src/arm/arm/integratorap-im-pd1.dts | 3 +- src/arm/arm/versatile-ab.dts | 3 +- src/arm/arm/vexpress-v2p-ca9.dts | 4 +- src/arm/broadcom/bcm47622.dtsi | 14 + src/arm/broadcom/bcm63138.dtsi | 7 +- src/arm/broadcom/bcm63148.dtsi | 14 + src/arm/broadcom/bcm63178.dtsi | 14 + src/arm/broadcom/bcm6756.dtsi | 14 + src/arm/broadcom/bcm6846.dtsi | 14 + src/arm/broadcom/bcm6855.dtsi | 14 + src/arm/broadcom/bcm6878.dtsi | 14 + src/arm/broadcom/bcm947622.dts | 10 + src/arm/broadcom/bcm963138.dts | 10 + src/arm/broadcom/bcm963138dvt.dts | 14 +- src/arm/broadcom/bcm963148.dts | 10 + src/arm/broadcom/bcm963178.dts | 10 + src/arm/broadcom/bcm96756.dts | 10 + src/arm/broadcom/bcm96846.dts | 10 + src/arm/broadcom/bcm96855.dts | 10 + src/arm/broadcom/bcm96878.dts | 10 + src/arm/gemini/gemini-dlink-dir-685.dts | 30 +- src/arm/gemini/gemini-dlink-dns-313.dts | 4 +- src/arm/gemini/gemini-sl93512r.dts | 16 +- src/arm/gemini/gemini-sq201.dts | 16 +- src/arm/gemini/gemini-wbd111.dts | 6 +- src/arm/gemini/gemini-wbd222.dts | 6 +- .../marvell/armada-385-clearfog-gtr-l8.dts | 38 +- .../marvell/armada-385-clearfog-gtr-s4.dts | 2 + src/arm/marvell/armada-385-clearfog-gtr.dtsi | 84 +- src/arm/marvell/armada-388-clearfog.dts | 5 +- src/arm/marvell/dove-cubox.dts | 4 +- src/arm/marvell/mmp2-brownstone.dts | 2 +- src/arm/microchip/at91-sama7g54_curiosity.dts | 482 ++++ src/arm/microchip/at91-sama7g5ek.dts | 8 +- .../at91sam9g25-gardena-smart-gateway.dts | 2 + src/arm/microchip/at91sam9x5ek.dtsi | 2 + src/arm/microchip/sam9x60.dtsi | 64 +- src/arm/microchip/sama7g5.dtsi | 56 +- src/arm/nvidia/tegra124-nyan.dtsi | 1 + src/arm/nvidia/tegra124-venice2.dts | 1 + .../tegra30-asus-nexus7-grouper-common.dtsi | 3 + src/arm/nvidia/tegra30-lg-p880.dts | 489 ++++ src/arm/nvidia/tegra30-lg-p895.dts | 496 ++++ src/arm/nvidia/tegra30-lg-x3.dtsi | 1812 ++++++++++++ src/arm/nxp/imx/imx1-apf9328.dts | 2 +- src/arm/nxp/imx/imx1.dtsi | 2 +- src/arm/nxp/imx/imx27.dtsi | 2 +- src/arm/nxp/imx/imx31.dtsi | 2 +- src/arm/nxp/imx/imx35.dtsi | 2 +- src/arm/nxp/imx/imx51.dtsi | 2 +- src/arm/nxp/imx/imx53-qsb-hdmi.dtso | 87 + src/arm/nxp/imx/imx6dl-sielaff.dts | 533 ++++ src/arm/nxp/imx/imx6dl-yapp4-common.dtsi | 25 +- src/arm/nxp/imx/imx6q-apalis-eval-v1.2.dts | 200 ++ src/arm/nxp/imx/imx6q-apalis-eval.dts | 108 +- src/arm/nxp/imx/imx6q-apalis-eval.dtsi | 120 + src/arm/nxp/imx/imx6qdl-hummingboard.dtsi | 7 +- src/arm/nxp/imx/imx6qdl-hummingboard2.dtsi | 5 + src/arm/nxp/imx/imx6qdl-skov-cpu.dtsi | 10 +- src/arm/nxp/imx/imx6qdl.dtsi | 2 +- src/arm/nxp/imx/imx6sl-tolino-shine2hd.dts | 6 +- src/arm/nxp/imx/imx6sl.dtsi | 2 +- src/arm/nxp/imx/imx6sx.dtsi | 2 +- src/arm/nxp/imx/imx6ul-14x14-evk.dtsi | 2 +- src/arm/nxp/imx/imx6ul-geam.dts | 2 +- .../nxp/imx/imx6ul-imx6ull-opos6uldev.dtsi | 2 +- src/arm/nxp/imx/imx6ul.dtsi | 18 +- .../nxp/imx/imx6ull-dhcom-som-cfg-sdcard.dtsi | 4 +- src/arm/nxp/imx/imx6ull-dhcom-som.dtsi | 4 +- src/arm/nxp/imx/imx6ull-dhcor-som.dtsi | 7 +- src/arm/nxp/imx/imx6ull-tarragon-common.dtsi | 1 + src/arm/nxp/imx/imx6ull.dtsi | 2 +- src/arm/nxp/imx/imx7-mba7.dtsi | 325 ++- src/arm/nxp/imx/imx7-tqma7.dtsi | 144 +- src/arm/nxp/imx/imx7d-mba7.dts | 94 +- src/arm/nxp/imx/imx7s-warp.dts | 1 + src/arm/nxp/ls/ls1021a.dtsi | 2 + src/arm/nxp/mxs/imx28-evk.dts | 2 +- src/arm/qcom/qcom-apq8026-lg-lenok.dts | 38 + .../qcom-apq8026-samsung-matisse-wifi.dts | 452 +-- src/arm/qcom/qcom-apq8064.dtsi | 70 +- src/arm/qcom/qcom-apq8084.dtsi | 13 +- src/arm/qcom/qcom-ipq4019-ap.dk01.1.dtsi | 138 +- src/arm/qcom/qcom-ipq4019.dtsi | 35 +- src/arm/qcom/qcom-ipq8064.dtsi | 12 +- .../qcom-msm8226-samsung-matisse-common.dtsi | 457 +++ src/arm/qcom/qcom-msm8226.dtsi | 736 +++-- src/arm/qcom/qcom-msm8660.dtsi | 17 +- src/arm/qcom/qcom-msm8926-htc-memul.dts | 15 +- .../qcom/qcom-msm8926-samsung-matisselte.dts | 37 + src/arm/qcom/qcom-msm8960-pins.dtsi | 21 + .../qcom/qcom-msm8960-samsung-expressatt.dts | 71 +- src/arm/qcom/qcom-msm8960.dtsi | 48 +- src/arm/qcom/qcom-msm8974.dtsi | 33 +- src/arm/qcom/qcom-sdx55.dtsi | 32 +- src/arm/qcom/qcom-sdx65.dtsi | 48 +- src/arm/renesas/r8a73a4-ape6evm.dts | 12 + src/arm/renesas/r8a73a4.dtsi | 23 +- src/arm/renesas/r8a7740.dtsi | 2 + src/arm/renesas/r8a7778.dtsi | 11 +- src/arm/renesas/r8a7779.dtsi | 9 +- src/arm/rockchip/rk3128-xpi-3128.dts | 29 + src/arm/rockchip/rk3128.dtsi | 60 + src/arm/rockchip/rk322x.dtsi | 16 +- src/arm/rockchip/rk3288.dtsi | 16 +- src/arm/rockchip/rv1126-sonoff-ihost.dtsi | 10 +- src/arm/samsung/exynos4412-i9300.dts | 2 +- src/arm/samsung/exynos4412-i9305.dts | 2 +- src/arm/samsung/exynos4412-n710x.dts | 2 +- src/arm/samsung/exynos4412-p4note.dtsi | 53 +- .../samsung/exynos5420-galaxy-tab-common.dtsi | 34 +- src/arm/samsung/exynos5420-peach-pit.dts | 1 + .../samsung/exynos5422-odroidxu3-common.dtsi | 16 +- src/arm/samsung/exynos5800-peach-pi.dts | 1 + src/arm/st/stih407-pinctrl.dtsi | 8 +- src/arm/st/stm32f769-disco-mb1166-reva09.dts | 13 + src/arm/st/stm32f769-disco.dts | 70 +- src/arm/st/stm32f769.dtsi | 20 + src/arm/st/stm32mp131.dtsi | 7 + src/arm/st/stm32mp135f-dk.dts | 8 + src/arm/st/stm32mp157.dtsi | 2 +- src/arm/st/stm32mp157a-dk1-scmi.dts | 2 +- src/arm/st/stm32mp157c-dk2-scmi.dts | 2 +- src/arm/st/stm32mp157c-ed1-scmi.dts | 2 +- src/arm/st/stm32mp157c-ev1-scmi.dts | 2 +- src/arm/st/stm32mp157c-lxa-tac-gen2.dts | 2 +- src/arm/st/stm32mp15xc-lxa-tac.dtsi | 6 +- src/arm/ti/davinci/da850.dtsi | 4 +- src/arm/ti/keystone/keystone-clocks.dtsi | 2 +- src/arm/ti/keystone/keystone-k2e-clocks.dtsi | 2 +- src/arm/ti/keystone/keystone-k2e-evm.dts | 2 +- src/arm/ti/keystone/keystone-k2e-netcp.dtsi | 2 +- src/arm/ti/keystone/keystone-k2e.dtsi | 2 +- src/arm/ti/keystone/keystone-k2g-evm.dts | 2 +- src/arm/ti/keystone/keystone-k2g-ice.dts | 2 +- src/arm/ti/keystone/keystone-k2g-netcp.dtsi | 2 +- src/arm/ti/keystone/keystone-k2g.dtsi | 2 +- src/arm/ti/keystone/keystone-k2hk-clocks.dtsi | 2 +- src/arm/ti/keystone/keystone-k2hk-evm.dts | 2 +- src/arm/ti/keystone/keystone-k2hk-netcp.dtsi | 2 +- src/arm/ti/keystone/keystone-k2hk.dtsi | 2 +- src/arm/ti/keystone/keystone-k2l-clocks.dtsi | 2 +- src/arm/ti/keystone/keystone-k2l-evm.dts | 2 +- src/arm/ti/keystone/keystone-k2l-netcp.dtsi | 2 +- src/arm/ti/keystone/keystone-k2l.dtsi | 2 +- src/arm/ti/keystone/keystone.dtsi | 2 +- src/arm/ti/omap/am335x-baltos-ir2110.dts | 2 +- src/arm/ti/omap/am335x-baltos-ir3220.dts | 2 +- src/arm/ti/omap/am335x-baltos-ir5221.dts | 2 +- src/arm/ti/omap/am335x-baltos-leds.dtsi | 2 +- src/arm/ti/omap/am335x-baltos.dtsi | 2 +- src/arm/ti/omap/am335x-base0033.dts | 2 +- src/arm/ti/omap/am335x-bone-common.dtsi | 4 +- src/arm/ti/omap/am335x-cm-t335.dts | 2 +- src/arm/ti/omap/am335x-evmsk.dts | 2 +- src/arm/ti/omap/am335x-guardian.dts | 4 +- src/arm/ti/omap/am335x-icev2.dts | 2 +- src/arm/ti/omap/am335x-igep0033.dtsi | 2 +- src/arm/ti/omap/am335x-myirtech-myc.dtsi | 2 +- src/arm/ti/omap/am335x-myirtech-myd.dts | 2 +- src/arm/ti/omap/am335x-nano.dts | 2 +- src/arm/ti/omap/am335x-netcan-plus-1xx.dts | 2 +- src/arm/ti/omap/am335x-netcom-plus-2xx.dts | 2 +- src/arm/ti/omap/am335x-netcom-plus-8xx.dts | 2 +- src/arm/ti/omap/am335x-pdu001.dts | 2 +- .../am335x-sancloud-bbe-extended-wifi.dts | 2 +- src/arm/ti/omap/am335x-sancloud-bbe-lite.dts | 2 +- src/arm/ti/omap/am335x-sbc-t335.dts | 2 +- src/arm/ti/omap/am335x-sl50.dts | 3 +- src/arm/ti/omap/am33xx-clocks.dtsi | 39 +- src/arm/ti/omap/am33xx.dtsi | 9 +- src/arm/ti/omap/am3517.dtsi | 11 +- src/arm/ti/omap/am35xx-clocks.dtsi | 18 +- src/arm/ti/omap/am4372.dtsi | 6 + src/arm/ti/omap/am437x-cm-t43.dts | 2 +- src/arm/ti/omap/am437x-sbc-t43.dts | 2 +- src/arm/ti/omap/am5729-beagleboneai.dts | 2 +- src/arm/ti/omap/am57xx-cl-som-am57x.dts | 2 +- src/arm/ti/omap/am57xx-sbc-am57x.dts | 2 +- src/arm/ti/omap/compulab-sb-som.dtsi | 2 +- src/arm/ti/omap/dra7-l4.dtsi | 2 +- src/arm/ti/omap/dra7.dtsi | 17 +- src/arm/ti/omap/dra74x-p.dtsi | 2 +- src/arm/ti/omap/dra7xx-clocks.dtsi | 2 +- src/arm/ti/omap/omap3430es1-clocks.dtsi | 52 +- src/arm/ti/omap/omap34xx-omap36xx-clocks.dtsi | 86 +- src/arm/ti/omap/omap34xx.dtsi | 11 +- ...map36xx-am35xx-omap3430es2plus-clocks.dtsi | 28 +- src/arm/ti/omap/omap36xx-clocks.dtsi | 7 +- .../omap/omap36xx-omap3430es2plus-clocks.dtsi | 46 +- src/arm/ti/omap/omap36xx.dtsi | 9 +- src/arm/ti/omap/omap3xxx-clocks.dtsi | 510 ++-- src/arm/ti/omap/omap4-epson-embt2ws.dts | 1 + src/arm/ti/omap/omap4-panda-common.dtsi | 1 + src/arm/ti/omap/omap4-sdp.dts | 2 +- src/arm/ti/omap/omap4.dtsi | 9 +- src/arm/ti/omap/omap5-igep0050.dts | 2 +- src/arm/ti/omap/omap5.dtsi | 9 +- src/arm/ti/omap/twl4030.dtsi | 2 +- src/arm/ti/omap/twl6030.dtsi | 4 +- src/arm64/allwinner/sun50i-h6-beelink-gs1.dts | 2 + src/arm64/allwinner/sun50i-h6-tanix.dtsi | 2 + src/arm64/allwinner/sun50i-h6.dtsi | 7 +- .../sun50i-h616-bigtreetech-cb1-manta.dts | 2 +- .../sun50i-h616-bigtreetech-cb1.dtsi | 4 +- .../allwinner/sun50i-h616-bigtreetech-pi.dts | 2 +- src/arm64/allwinner/sun50i-h616.dtsi | 155 + .../sun50i-h618-longan-module-3h.dtsi | 75 + .../allwinner/sun50i-h618-longanpi-3h.dts | 144 + .../sun50i-h618-transpeed-8k618-t.dts | 23 + .../allwinner/sun50i-h64-remix-mini-pc.dts | 356 +++ src/arm64/amlogic/amlogic-c3.dtsi | 7 + src/arm64/amlogic/amlogic-t7.dtsi | 12 +- src/arm64/amlogic/meson-a1-ad402.dts | 2 +- src/arm64/amlogic/meson-a1.dtsi | 2 + .../meson-axg-jethome-jethub-j1xx.dtsi | 30 +- src/arm64/amlogic/meson-axg-s400.dts | 16 +- src/arm64/amlogic/meson-axg.dtsi | 8 + src/arm64/amlogic/meson-g12-common.dtsi | 3 + src/arm64/amlogic/meson-g12a-fbx8am-brcm.dtso | 31 + .../amlogic/meson-g12a-fbx8am-realtek.dtso | 21 + src/arm64/amlogic/meson-g12a-fbx8am.dts | 462 +++ src/arm64/amlogic/meson-g12a-radxa-zero.dts | 12 +- src/arm64/amlogic/meson-g12a-sei510.dts | 14 +- src/arm64/amlogic/meson-g12a-u200.dts | 16 +- src/arm64/amlogic/meson-g12a-x96-max.dts | 14 +- src/arm64/amlogic/meson-g12b-odroid-n2.dtsi | 2 +- src/arm64/amlogic/meson-g12b-odroid.dtsi | 20 +- src/arm64/amlogic/meson-g12b-w400.dtsi | 10 +- src/arm64/amlogic/meson-gx-libretech-pc.dtsi | 12 +- src/arm64/amlogic/meson-gx-p23x-q20x.dtsi | 8 +- src/arm64/amlogic/meson-gxbb-nexbox-a95x.dts | 6 +- src/arm64/amlogic/meson-gxbb-odroidc2.dts | 8 +- src/arm64/amlogic/meson-gxbb-p200.dts | 4 +- src/arm64/amlogic/meson-gxbb-p20x.dtsi | 6 +- src/arm64/amlogic/meson-gxbb-vega-s95.dtsi | 8 +- src/arm64/amlogic/meson-gxbb-wetek.dtsi | 8 +- .../amlogic/meson-gxl-s805x-libretech-ac.dts | 8 +- src/arm64/amlogic/meson-gxl-s805x-p241.dts | 8 +- .../meson-gxl-s905w-jethome-jethub-j80.dts | 8 +- .../meson-gxl-s905x-hwacom-amazetv.dts | 6 +- .../meson-gxl-s905x-libretech-cc-v2.dts | 12 +- .../amlogic/meson-gxl-s905x-libretech-cc.dts | 6 +- .../amlogic/meson-gxl-s905x-nexbox-a95x.dts | 6 +- src/arm64/amlogic/meson-gxl-s905x-p212.dtsi | 8 +- src/arm64/amlogic/meson-gxm-khadas-vim2.dts | 8 +- .../amlogic/meson-gxm-s912-libretech-pc.dts | 2 +- src/arm64/amlogic/meson-khadas-vim3.dtsi | 16 +- .../amlogic/meson-libretech-cottonwood.dtsi | 6 +- src/arm64/amlogic/meson-sm1-ac2xx.dtsi | 10 +- src/arm64/amlogic/meson-sm1-bananapi.dtsi | 14 +- src/arm64/amlogic/meson-sm1-odroid-hc4.dts | 4 +- src/arm64/amlogic/meson-sm1-odroid.dtsi | 20 +- src/arm64/amlogic/meson-sm1-sei610.dts | 12 +- .../bcmbca/bcm4906-netgear-r8000p.dts | 5 + .../bcmbca/bcm4906-tplink-archer-c2300-v1.dts | 5 + .../bcmbca/bcm4908-asus-gt-ac5300.dts | 19 +- src/arm64/broadcom/bcmbca/bcm4908.dtsi | 7 +- src/arm64/broadcom/bcmbca/bcm4912.dtsi | 14 + src/arm64/broadcom/bcmbca/bcm63146.dtsi | 14 + src/arm64/broadcom/bcmbca/bcm63158.dtsi | 14 + src/arm64/broadcom/bcmbca/bcm6813.dtsi | 14 + src/arm64/broadcom/bcmbca/bcm6856.dtsi | 14 + src/arm64/broadcom/bcmbca/bcm6858.dtsi | 14 + src/arm64/broadcom/bcmbca/bcm94908.dts | 10 + src/arm64/broadcom/bcmbca/bcm94912.dts | 10 + src/arm64/broadcom/bcmbca/bcm963146.dts | 10 + src/arm64/broadcom/bcmbca/bcm963158.dts | 10 + src/arm64/broadcom/bcmbca/bcm96813.dts | 10 + src/arm64/broadcom/bcmbca/bcm96856.dts | 10 + src/arm64/broadcom/bcmbca/bcm96858.dts | 10 + src/arm64/exynos/exynos850.dtsi | 64 + src/arm64/exynos/google/gs101-oriole.dts | 24 + src/arm64/exynos/google/gs101-pinctrl.dtsi | 2 +- src/arm64/exynos/google/gs101.dtsi | 131 +- src/arm64/freescale/fsl-ls1012a.dtsi | 10 +- src/arm64/freescale/fsl-ls1046a.dtsi | 1 - src/arm64/freescale/fsl-ls1088a.dtsi | 6 + src/arm64/freescale/fsl-lx2160a.dtsi | 32 +- .../freescale/imx8-apalis-eval-v1.1.dtsi | 26 + .../freescale/imx8-apalis-eval-v1.2.dtsi | 124 + src/arm64/freescale/imx8-apalis-eval.dtsi | 22 - src/arm64/freescale/imx8-apalis-v1.1.dtsi | 1 - src/arm64/freescale/imx8-ss-audio.dtsi | 330 +++ src/arm64/freescale/imx8-ss-conn.dtsi | 16 +- src/arm64/freescale/imx8-ss-dma.dtsi | 103 +- src/arm64/freescale/imx8-ss-gpu0.dtsi | 27 + src/arm64/freescale/imx8-ss-lsio.dtsi | 16 +- src/arm64/freescale/imx8dxl-evk.dts | 101 + src/arm64/freescale/imx8dxl-ss-adma.dtsi | 77 + src/arm64/freescale/imx8dxl.dtsi | 1 + .../freescale/imx8dxp-tqma8xdp-mba8xx.dts | 16 + src/arm64/freescale/imx8dxp-tqma8xdp.dtsi | 24 + src/arm64/freescale/imx8dxp.dtsi | 24 + src/arm64/freescale/imx8mm-evk.dtsi | 69 + .../freescale/imx8mm-kontron-bl-osm-s.dts | 294 +- src/arm64/freescale/imx8mm-kontron-bl.dts | 38 +- src/arm64/freescale/imx8mm-kontron-osm-s.dtsi | 567 +++- src/arm64/freescale/imx8mm-kontron-sl.dtsi | 4 +- .../freescale/imx8mm-tqma8mqml-mba8mx.dts | 14 +- src/arm64/freescale/imx8mm-venice-gw71xx.dtsi | 40 +- src/arm64/freescale/imx8mm-venice-gw7901.dts | 14 +- src/arm64/freescale/imx8mn-beacon-kit.dts | 2 - src/arm64/freescale/imx8mn-evk.dtsi | 36 + src/arm64/freescale/imx8mn-rve-gateway.dts | 2 +- .../imx8mn-tqma8mqnl-mba8mx-usbotg.dtso | 64 + .../freescale/imx8mn-tqma8mqnl-mba8mx.dts | 5 +- src/arm64/freescale/imx8mn.dtsi | 2 +- src/arm64/freescale/imx8mp-beacon-som.dtsi | 71 + .../freescale/imx8mp-data-modul-edm-sbc.dts | 82 +- src/arm64/freescale/imx8mp-evk.dts | 33 +- .../freescale/imx8mp-phyboard-pollux-rdk.dts | 107 +- src/arm64/freescale/imx8mp-phycore-som.dtsi | 1 - src/arm64/freescale/imx8mp-venice-gw71xx.dtsi | 10 +- src/arm64/freescale/imx8mp-venice-gw72xx.dtsi | 2 +- src/arm64/freescale/imx8mp-venice-gw73xx.dtsi | 2 +- src/arm64/freescale/imx8mp-verdin.dtsi | 3 +- src/arm64/freescale/imx8mp.dtsi | 12 +- src/arm64/freescale/imx8mq-tqma8mq-mba8mx.dts | 24 +- .../freescale/imx8qm-apalis-eval-v1.2.dts | 16 + src/arm64/freescale/imx8qm-apalis-eval.dts | 2 +- .../imx8qm-apalis-v1.1-eval-v1.2.dts | 26 + .../freescale/imx8qm-apalis-v1.1-eval.dts | 2 +- src/arm64/freescale/imx8qm-mek.dts | 26 + src/arm64/freescale/imx8qm-ss-conn.dtsi | 5 + src/arm64/freescale/imx8qm-ss-dma.dtsi | 63 +- src/arm64/freescale/imx8qm.dtsi | 41 + .../freescale/imx8qxp-tqma8xqp-mba8xx.dts | 16 + src/arm64/freescale/imx8qxp-tqma8xqp.dtsi | 14 + src/arm64/freescale/imx8qxp.dtsi | 8 + src/arm64/freescale/imx8ulp-evk.dts | 2 +- src/arm64/freescale/imx93-phyboard-segin.dts | 117 + src/arm64/freescale/imx93-phycore-som.dtsi | 126 + src/arm64/freescale/imx93-tqma9352.dtsi | 4 +- .../freescale/imx93-var-som-symphony.dts | 351 +++ src/arm64/freescale/imx93-var-som.dtsi | 110 + src/arm64/freescale/imx93.dtsi | 4 +- src/arm64/freescale/mba8mx.dtsi | 21 +- src/arm64/freescale/mba8xx.dtsi | 554 ++++ src/arm64/freescale/tqma8xx.dtsi | 265 ++ src/arm64/intel/socfpga_agilex5.dtsi | 4 +- src/arm64/marvell/ac5-98dx25xx.dtsi | 31 +- src/arm64/marvell/ac5-98dx35xx-rd.dts | 4 + src/arm64/marvell/armada-37xx.dtsi | 10 +- src/arm64/marvell/armada-ap807.dtsi | 3 + src/arm64/marvell/armada-cp11x.dtsi | 10 +- src/arm64/mediatek/mt2712-evb.dts | 12 +- src/arm64/mediatek/mt2712e.dtsi | 5 +- src/arm64/mediatek/mt6797.dtsi | 8 +- .../mediatek/mt7622-bananapi-bpi-r64.dts | 13 + src/arm64/mediatek/mt7622-rfb1.dts | 25 + src/arm64/mediatek/mt7622.dtsi | 34 +- src/arm64/mediatek/mt7981b-xiaomi-ax3000t.dts | 15 + src/arm64/mediatek/mt7981b.dtsi | 105 + .../mediatek/mt7986a-acelink-ew-7886cax.dts | 173 ++ .../mt7986a-bananapi-bpi-r3-nand.dtso | 2 +- .../mediatek/mt7986a-bananapi-bpi-r3.dts | 8 +- src/arm64/mediatek/mt7986a-rfb.dts | 31 +- src/arm64/mediatek/mt7986a.dtsi | 176 +- src/arm64/mediatek/mt7986b-rfb.dts | 31 +- .../mediatek/mt7988a-bananapi-bpi-r4.dts | 11 + src/arm64/mediatek/mt7988a.dtsi | 136 + src/arm64/mediatek/mt8173-elm-hana-rev7.dts | 2 +- src/arm64/mediatek/mt8173-elm.dtsi | 3 +- src/arm64/mediatek/mt8173-evb.dts | 2 +- src/arm64/mediatek/mt8173.dtsi | 19 +- .../mediatek/mt8183-kukui-jacuzzi-pico6.dts | 3 +- src/arm64/mediatek/mt8183-kukui-kakadu.dtsi | 4 + src/arm64/mediatek/mt8183-kukui-kodama.dtsi | 4 + src/arm64/mediatek/mt8183-kukui-krane.dtsi | 4 + src/arm64/mediatek/mt8183-kukui.dtsi | 6 +- src/arm64/mediatek/mt8183-pumpkin.dts | 2 +- src/arm64/mediatek/mt8183.dtsi | 12 +- src/arm64/mediatek/mt8186-corsola-krabby.dtsi | 129 + .../mt8186-corsola-magneton-sku393216.dts | 39 + .../mt8186-corsola-magneton-sku393217.dts | 39 + .../mt8186-corsola-magneton-sku393218.dts | 26 + .../mt8186-corsola-rusty-sku196608.dts | 26 + .../mt8186-corsola-steelix-sku131072.dts | 18 + .../mt8186-corsola-steelix-sku131073.dts | 18 + .../mediatek/mt8186-corsola-steelix.dtsi | 199 ++ .../mt8186-corsola-tentacool-sku327681.dts | 57 + .../mt8186-corsola-tentacool-sku327683.dts | 24 + .../mt8186-corsola-tentacruel-sku262144.dts | 44 + .../mt8186-corsola-tentacruel-sku262148.dts | 26 + src/arm64/mediatek/mt8186-corsola.dtsi | 1681 +++++++++++ src/arm64/mediatek/mt8186.dtsi | 93 +- src/arm64/mediatek/mt8192-asurada.dtsi | 11 +- src/arm64/mediatek/mt8192.dtsi | 11 +- .../mediatek/mt8195-cherry-tomato-r1.dts | 4 + .../mediatek/mt8195-cherry-tomato-r2.dts | 4 + .../mediatek/mt8195-cherry-tomato-r3.dts | 4 + src/arm64/mediatek/mt8195-cherry.dtsi | 63 +- src/arm64/mediatek/mt8195-demo.dts | 18 +- src/arm64/mediatek/mt8195-evb.dts | 12 + src/arm64/mediatek/mt8195.dtsi | 133 +- src/arm64/mediatek/mt8395-genio-1200-evk.dts | 17 +- src/arm64/mediatek/mt8395-radxa-nio-12l.dts | 825 ++++++ src/arm64/nvidia/tegra132-norrin.dts | 1 + src/arm64/nvidia/tegra194-p2888.dtsi | 50 + src/arm64/nvidia/tegra194-p2972-0000.dts | 51 +- src/arm64/nvidia/tegra194-p3668.dtsi | 27 + src/arm64/nvidia/tegra234-p3701.dtsi | 1953 +------------ .../nvidia/tegra234-p3737-0000+p3701-0000.dts | 1 - src/arm64/nvidia/tegra234-p3767-0000.dtsi | 14 - src/arm64/nvidia/tegra234-p3767-0005.dtsi | 14 - src/arm64/nvidia/tegra234-p3767.dtsi | 86 + .../nvidia/tegra234-p3768-0000+p3767-0000.dts | 7 +- .../nvidia/tegra234-p3768-0000+p3767-0005.dts | 12 +- src/arm64/nvidia/tegra234-sim-vdk.dts | 1 - src/arm64/nvidia/tegra234.dtsi | 2544 +++++++++++++++-- .../qcom/apq8016-sbc-d3-camera-mezzanine.dts | 8 +- src/arm64/qcom/ipq5332.dtsi | 8 +- src/arm64/qcom/ipq6018.dtsi | 159 ++ src/arm64/qcom/ipq8074.dtsi | 16 + src/arm64/qcom/ipq9574.dtsi | 12 +- src/arm64/qcom/msm8216-samsung-fortuna3g.dts | 11 + .../qcom/msm8916-samsung-fortuna-common.dtsi | 203 ++ .../qcom/msm8916-samsung-gprimeltecan.dts | 27 + .../qcom/msm8916-samsung-grandprimelte.dts | 16 + .../qcom/msm8916-samsung-rossa-common.dtsi | 16 + src/arm64/qcom/msm8916-samsung-rossa.dts | 16 + src/arm64/qcom/msm8916.dtsi | 9 + src/arm64/qcom/msm8939.dtsi | 11 +- src/arm64/qcom/msm8953.dtsi | 155 +- .../qcom/msm8994-msft-lumia-octagon.dtsi | 2 +- .../qcom/msm8994-sony-xperia-kitakami.dtsi | 2 +- src/arm64/qcom/msm8994.dtsi | 4 +- src/arm64/qcom/msm8996.dtsi | 18 +- src/arm64/qcom/msm8998.dtsi | 26 +- src/arm64/qcom/{pm2250.dtsi => pm4125.dtsi} | 38 +- src/arm64/qcom/pm6150.dtsi | 46 + src/arm64/qcom/pmi632.dtsi | 39 + src/arm64/qcom/qcm2290.dtsi | 7 + src/arm64/qcom/qcm6490-fairphone-fp5.dts | 56 +- src/arm64/qcom/qcm6490-idp.dts | 39 +- src/arm64/qcom/qcs404.dtsi | 16 + src/arm64/qcom/qcs6490-rb3gen2.dts | 23 +- src/arm64/qcom/qrb2210-rb1.dts | 96 +- src/arm64/qcom/qrb4210-rb2.dts | 50 +- src/arm64/qcom/sa8155p-adp.dts | 30 +- src/arm64/qcom/sa8295p-adp.dts | 68 + src/arm64/qcom/sa8540p-ride.dts | 4 +- src/arm64/qcom/sa8540p.dtsi | 3 + src/arm64/qcom/sa8775p.dtsi | 119 +- src/arm64/qcom/sc7180-trogdor.dtsi | 3 + src/arm64/qcom/sc7180.dtsi | 86 +- src/arm64/qcom/sc7280-chrome-common.dtsi | 28 + src/arm64/qcom/sc7280-herobrine.dtsi | 1 + src/arm64/qcom/sc7280-idp-ec-h1.dtsi | 1 + src/arm64/qcom/sc7280.dtsi | 129 +- src/arm64/qcom/sc8180x.dtsi | 143 +- .../qcom/sc8280xp-lenovo-thinkpad-x13s.dts | 39 +- src/arm64/qcom/sc8280xp-pmics.dtsi | 39 +- src/arm64/qcom/sc8280xp.dtsi | 612 +++- src/arm64/qcom/sda660-inforce-ifc6560.dts | 5 + src/arm64/qcom/sdm450-motorola-ali.dts | 2 +- src/arm64/qcom/sdm450.dtsi | 14 + src/arm64/qcom/sdm630-sony-xperia-nile.dtsi | 16 + src/arm64/qcom/sdm630.dtsi | 62 +- src/arm64/qcom/sdm632.dtsi | 8 + src/arm64/qcom/sdm660-xiaomi-lavender.dts | 6 + src/arm64/qcom/sdm670.dtsi | 14 +- src/arm64/qcom/sdm845-cheza.dtsi | 1 + src/arm64/qcom/sdm845-db845c.dts | 2 +- src/arm64/qcom/sdm845-oneplus-common.dtsi | 8 +- src/arm64/qcom/sdm845-shift-axolotl.dts | 2 +- src/arm64/qcom/sdm845.dtsi | 63 +- src/arm64/qcom/sm4450.dtsi | 2 +- src/arm64/qcom/sm6115.dtsi | 95 +- src/arm64/qcom/sm6125.dtsi | 17 +- src/arm64/qcom/sm6350.dtsi | 601 +++- src/arm64/qcom/sm6375.dtsi | 14 +- src/arm64/qcom/sm7125-xiaomi-common.dtsi | 26 + src/arm64/qcom/sm7125-xiaomi-curtana.dts | 16 + src/arm64/qcom/sm7225-fairphone-fp4.dts | 61 +- src/arm64/qcom/sm8150.dtsi | 115 +- .../qcom/sm8250-xiaomi-elish-common.dtsi | 3 +- src/arm64/qcom/sm8250.dtsi | 113 +- src/arm64/qcom/sm8350.dtsi | 87 +- src/arm64/qcom/sm8450-hdk.dts | 6 +- src/arm64/qcom/sm8450.dtsi | 97 +- src/arm64/qcom/sm8550-hdk.dts | 1306 +++++++++ src/arm64/qcom/sm8550-mtp.dts | 11 +- src/arm64/qcom/sm8550-qrd.dts | 53 +- src/arm64/qcom/sm8550.dtsi | 187 +- src/arm64/qcom/sm8650-mtp.dts | 155 + src/arm64/qcom/sm8650-qrd.dts | 439 ++- src/arm64/qcom/sm8650.dtsi | 81 +- src/arm64/qcom/x1e80100-crd.dts | 450 +++ src/arm64/qcom/x1e80100-qcp.dts | 175 +- src/arm64/qcom/x1e80100.dtsi | 1781 +++++++++++- src/arm64/renesas/r8a774a1.dtsi | 11 +- src/arm64/renesas/r8a774b1.dtsi | 11 +- src/arm64/renesas/r8a774c0.dtsi | 11 +- src/arm64/renesas/r8a774e1.dtsi | 11 +- src/arm64/renesas/r8a77951.dtsi | 11 +- src/arm64/renesas/r8a77960.dtsi | 11 +- src/arm64/renesas/r8a77961.dtsi | 11 +- src/arm64/renesas/r8a77965.dtsi | 11 +- src/arm64/renesas/r8a77970.dtsi | 11 +- src/arm64/renesas/r8a77980.dtsi | 17 +- src/arm64/renesas/r8a77990.dtsi | 11 +- src/arm64/renesas/r8a77995.dtsi | 11 +- src/arm64/renesas/r8a779a0.dtsi | 21 +- src/arm64/renesas/r8a779f0.dtsi | 17 +- src/arm64/renesas/r8a779g0-white-hawk-cpu.dts | 13 + .../renesas/r8a779g0-white-hawk-cpu.dtsi | 368 +-- src/arm64/renesas/r8a779g0-white-hawk.dts | 58 +- src/arm64/renesas/r8a779g0.dtsi | 105 +- .../renesas/r8a779g2-white-hawk-single.dts | 26 + src/arm64/renesas/r8a779g2.dtsi | 12 + .../renesas/r8a779h0-gray-hawk-single.dts | 230 ++ src/arm64/renesas/r8a779h0.dtsi | 664 +++++ src/arm64/renesas/r9a07g043u.dtsi | 81 +- .../r9a07g043u11-smarc-cru-csi-ov5645.dtso | 21 + src/arm64/renesas/r9a07g044.dtsi | 68 +- src/arm64/renesas/r9a07g054.dtsi | 69 +- src/arm64/renesas/r9a08g045.dtsi | 27 +- src/arm64/renesas/rzg2l-smarc.dtsi | 14 +- src/arm64/renesas/rzg2lc-smarc.dtsi | 14 +- src/arm64/renesas/rzg3s-smarc-som.dtsi | 9 + src/arm64/renesas/rzg3s-smarc.dtsi | 53 + src/arm64/renesas/ulcb-kf.dtsi | 75 +- src/arm64/renesas/white-hawk-common.dtsi | 65 + src/arm64/renesas/white-hawk-cpu-common.dtsi | 375 +++ ...k-csi-dsi.dtsi => white-hawk-csi-dsi.dtsi} | 2 +- ...ethernet.dtsi => white-hawk-ethernet.dtsi} | 2 +- src/arm64/rockchip/px30-ringneck-haikou.dts | 1 + src/arm64/rockchip/px30-ringneck.dtsi | 6 + src/arm64/rockchip/rk3328-rock-pi-e.dts | 4 +- src/arm64/rockchip/rk3328.dtsi | 11 +- src/arm64/rockchip/rk3399-gru-scarlet.dtsi | 3 +- src/arm64/rockchip/rk3399-kobol-helios64.dts | 5 +- src/arm64/rockchip/rk3399-orangepi.dts | 2 +- src/arm64/rockchip/rk3399-pinebook-pro.dts | 1 - src/arm64/rockchip/rk3399-puma-haikou.dts | 5 +- src/arm64/rockchip/rk3399-puma.dtsi | 53 +- src/arm64/rockchip/rk3399-rock-pi-4a.dts | 2 +- src/arm64/rockchip/rk3399-rock-pi-4b.dts | 2 +- src/arm64/rockchip/rk3399-rock-pi-4c.dts | 2 +- src/arm64/rockchip/rk3399.dtsi | 82 +- .../rockchip/rk3566-anbernic-rg-arc-d.dts | 60 + .../rockchip/rk3566-anbernic-rg-arc-s.dts | 19 + .../rockchip/rk3566-anbernic-rg-arc.dtsi | 237 ++ .../rockchip/rk3566-anbernic-rg353x.dtsi | 74 + src/arm64/rockchip/rk3566-anbernic-rg503.dts | 74 + src/arm64/rockchip/rk3566-anbernic-rgxx3.dtsi | 74 - src/arm64/rockchip/rk3566-lubancat-1.dts | 1 - src/arm64/rockchip/rk3566-pinetab2-v0.1.dts | 28 + src/arm64/rockchip/rk3566-pinetab2-v2.0.dts | 48 + src/arm64/rockchip/rk3566-pinetab2.dtsi | 943 ++++++ .../rockchip/rk3566-powkiddy-rgb10max3.dts | 87 + src/arm64/rockchip/rk3566-powkiddy-rgb30.dts | 18 + src/arm64/rockchip/rk3566-powkiddy-rk2023.dts | 18 + .../rockchip/rk3566-powkiddy-rk2023.dtsi | 18 +- src/arm64/rockchip/rk3568-bpi-r2-pro.dts | 8 +- src/arm64/rockchip/rk3568-lubancat-2.dts | 1 - src/arm64/rockchip/rk3568-qnap-ts433.dts | 86 + src/arm64/rockchip/rk356x.dtsi | 3 +- src/arm64/rockchip/rk3588-coolpi-cm5.dtsi | 4 +- .../rockchip/rk3588-edgeble-neu6a-common.dtsi | 466 +++ .../rockchip/rk3588-edgeble-neu6a-io.dts | 10 +- .../rockchip/rk3588-edgeble-neu6a-io.dtsi | 232 ++ .../rockchip/rk3588-edgeble-neu6a-wifi.dtso | 56 + src/arm64/rockchip/rk3588-edgeble-neu6a.dtsi | 25 +- .../rockchip/rk3588-edgeble-neu6b-io.dts | 76 +- src/arm64/rockchip/rk3588-edgeble-neu6b.dtsi | 383 +-- src/arm64/rockchip/rk3588-nanopc-t6.dts | 31 +- src/arm64/rockchip/rk3588-orangepi-5-plus.dts | 4 +- src/arm64/rockchip/rk3588-quartzpro64.dts | 2 +- src/arm64/rockchip/rk3588-rock-5b.dts | 8 +- src/arm64/rockchip/rk3588-tiger-haikou.dts | 266 ++ src/arm64/rockchip/rk3588-tiger.dtsi | 690 +++++ src/arm64/rockchip/rk3588-toybrick-x0.dts | 688 +++++ .../rockchip/rk3588s-indiedroid-nova.dts | 8 + src/arm64/rockchip/rk3588s-nanopi-r6c.dts | 14 + src/arm64/rockchip/rk3588s-nanopi-r6s.dts | 764 +++++ src/arm64/rockchip/rk3588s-rock-5a.dts | 1 - src/arm64/rockchip/rk3588s.dtsi | 24 +- src/arm64/st/stm32mp251.dtsi | 12 + src/arm64/st/stm32mp255.dtsi | 17 + src/arm64/tesla/fsd.dtsi | 2 + src/arm64/ti/k3-am62-lp-sk.dts | 4 +- src/arm64/ti/k3-am62-main.dtsi | 30 +- src/arm64/ti/k3-am62-mcu.dtsi | 4 +- src/arm64/ti/k3-am62-phycore-som.dtsi | 5 +- src/arm64/ti/k3-am62-thermal.dtsi | 5 +- src/arm64/ti/k3-am62-verdin-dahlia.dtsi | 1 - src/arm64/ti/k3-am62-verdin-dev.dtsi | 1 - src/arm64/ti/k3-am62-verdin-mallow.dtsi | 10 + src/arm64/ti/k3-am62-verdin-wifi.dtsi | 1 - src/arm64/ti/k3-am62-verdin.dtsi | 59 +- src/arm64/ti/k3-am62-wakeup.dtsi | 38 +- src/arm64/ti/k3-am62.dtsi | 4 +- .../ti/k3-am625-beagleplay-csi2-ov5640.dtso | 4 +- .../k3-am625-beagleplay-csi2-tevi-ov5640.dtso | 4 +- src/arm64/ti/k3-am625-beagleplay.dts | 54 +- src/arm64/ti/k3-am625-phyboard-lyra-rdk.dts | 6 +- src/arm64/ti/k3-am625-sk.dts | 4 +- src/arm64/ti/k3-am625.dtsi | 4 +- src/arm64/ti/k3-am62a-main.dtsi | 80 +- src/arm64/ti/k3-am62a-mcu.dtsi | 4 +- src/arm64/ti/k3-am62a-thermal.dtsi | 5 +- src/arm64/ti/k3-am62a-wakeup.dtsi | 4 +- src/arm64/ti/k3-am62a.dtsi | 4 +- src/arm64/ti/k3-am62a7-sk.dts | 123 +- src/arm64/ti/k3-am62a7.dtsi | 4 +- src/arm64/ti/k3-am62p-main.dtsi | 154 +- src/arm64/ti/k3-am62p-mcu.dtsi | 6 +- src/arm64/ti/k3-am62p-thermal.dtsi | 5 +- src/arm64/ti/k3-am62p-wakeup.dtsi | 5 +- src/arm64/ti/k3-am62p.dtsi | 6 +- src/arm64/ti/k3-am62p5-sk.dts | 11 +- src/arm64/ti/k3-am62p5.dtsi | 4 +- .../ti/k3-am62x-phyboard-lyra-gpio-fan.dtso | 50 + src/arm64/ti/k3-am62x-sk-common.dtsi | 8 +- src/arm64/ti/k3-am62x-sk-csi2-imx219.dtso | 4 +- src/arm64/ti/k3-am62x-sk-csi2-ov5640.dtso | 4 +- .../ti/k3-am62x-sk-csi2-tevi-ov5640.dtso | 4 +- src/arm64/ti/k3-am62x-sk-hdmi-audio.dtso | 4 +- src/arm64/ti/k3-am64-main.dtsi | 69 +- src/arm64/ti/k3-am64-mcu.dtsi | 4 +- src/arm64/ti/k3-am64-phycore-som.dtsi | 13 +- src/arm64/ti/k3-am64-thermal.dtsi | 5 +- src/arm64/ti/k3-am64.dtsi | 4 +- .../ti/k3-am642-evm-icssg1-dualemac.dtso | 79 + src/arm64/ti/k3-am642-evm.dts | 119 +- .../ti/k3-am642-hummingboard-t-pcie.dtso | 45 + .../ti/k3-am642-hummingboard-t-usb3.dtso | 44 + src/arm64/ti/k3-am642-hummingboard-t.dts | 292 ++ .../ti/k3-am642-phyboard-electra-rdk.dts | 30 +- src/arm64/ti/k3-am642-sk.dts | 14 +- src/arm64/ti/k3-am642-sr-som.dtsi | 594 ++++ src/arm64/ti/k3-am642-tqma64xxl-mbax4xxl.dts | 1 - src/arm64/ti/k3-am642.dtsi | 4 +- .../ti/k3-am65-iot2050-arduino-connector.dtsi | 768 +++++ src/arm64/ti/k3-am65-iot2050-common-pg1.dtsi | 7 +- src/arm64/ti/k3-am65-iot2050-common-pg2.dtsi | 27 +- src/arm64/ti/k3-am65-iot2050-common.dtsi | 887 +----- src/arm64/ti/k3-am65-iot2050-dp.dtsi | 98 + src/arm64/ti/k3-am65-iot2050-usb3.dtsi | 27 + src/arm64/ti/k3-am65-main.dtsi | 44 +- src/arm64/ti/k3-am65-mcu.dtsi | 4 +- src/arm64/ti/k3-am65-wakeup.dtsi | 4 +- src/arm64/ti/k3-am65.dtsi | 4 +- src/arm64/ti/k3-am652.dtsi | 4 +- .../ti/k3-am6528-iot2050-basic-common.dtsi | 8 +- src/arm64/ti/k3-am6528-iot2050-basic-pg2.dts | 4 +- src/arm64/ti/k3-am6528-iot2050-basic.dts | 7 +- ...am654-base-board-rocktech-rk101-panel.dtso | 4 +- src/arm64/ti/k3-am654-base-board.dts | 8 +- src/arm64/ti/k3-am654-icssg2.dtso | 4 +- src/arm64/ti/k3-am654-idk.dtso | 4 +- src/arm64/ti/k3-am654-industrial-thermal.dtsi | 5 +- src/arm64/ti/k3-am654-pcie-usb2.dtso | 59 + src/arm64/ti/k3-am654-pcie-usb3.dtso | 61 + src/arm64/ti/k3-am654.dtsi | 4 +- .../ti/k3-am6548-iot2050-advanced-common.dtsi | 2 +- .../ti/k3-am6548-iot2050-advanced-m2.dts | 22 +- .../ti/k3-am6548-iot2050-advanced-pg2.dts | 12 +- .../ti/k3-am6548-iot2050-advanced-sm.dts | 189 ++ src/arm64/ti/k3-am6548-iot2050-advanced.dts | 3 +- src/arm64/ti/k3-am68-sk-base-board.dts | 54 +- src/arm64/ti/k3-am68-sk-som.dtsi | 20 +- src/arm64/ti/k3-am69-sk.dts | 253 +- src/arm64/ti/k3-j7200-common-proc-board.dts | 109 +- .../ti/k3-j7200-evm-quad-port-eth-exp.dtso | 4 +- src/arm64/ti/k3-j7200-main.dtsi | 315 +- src/arm64/ti/k3-j7200-mcu-wakeup.dtsi | 57 +- src/arm64/ti/k3-j7200-som-p0.dtsi | 47 +- src/arm64/ti/k3-j7200-thermal.dtsi | 5 +- src/arm64/ti/k3-j7200.dtsi | 4 +- src/arm64/ti/k3-j721e-beagleboneai64.dts | 26 +- src/arm64/ti/k3-j721e-common-proc-board.dts | 4 +- src/arm64/ti/k3-j721e-evm-gesi-exp-board.dtso | 4 +- src/arm64/ti/k3-j721e-evm-pcie0-ep.dtso | 4 +- .../ti/k3-j721e-evm-quad-port-eth-exp.dtso | 4 +- src/arm64/ti/k3-j721e-main.dtsi | 149 +- src/arm64/ti/k3-j721e-mcu-wakeup.dtsi | 8 +- .../ti/k3-j721e-sk-csi2-dual-imx219.dtso | 165 ++ src/arm64/ti/k3-j721e-sk.dts | 45 +- src/arm64/ti/k3-j721e-som-p0.dtsi | 22 +- src/arm64/ti/k3-j721e-thermal.dtsi | 5 +- src/arm64/ti/k3-j721e.dtsi | 4 +- src/arm64/ti/k3-j721s2-common-proc-board.dts | 31 +- .../ti/k3-j721s2-evm-gesi-exp-board.dtso | 4 +- src/arm64/ti/k3-j721s2-evm-pcie1-ep.dtso | 4 +- src/arm64/ti/k3-j721s2-main.dtsi | 143 +- src/arm64/ti/k3-j721s2-mcu-wakeup.dtsi | 6 +- src/arm64/ti/k3-j721s2-som-p0.dtsi | 20 +- src/arm64/ti/k3-j721s2-thermal.dtsi | 5 +- src/arm64/ti/k3-j721s2.dtsi | 4 +- src/arm64/ti/k3-j722s-evm.dts | 383 +++ src/arm64/ti/k3-j722s.dtsi | 89 + src/arm64/ti/k3-j784s4-evm.dts | 32 +- src/arm64/ti/k3-j784s4-main.dtsi | 215 +- src/arm64/ti/k3-j784s4-mcu-wakeup.dtsi | 6 +- src/arm64/ti/k3-j784s4-thermal.dtsi | 5 +- src/arm64/ti/k3-j784s4.dtsi | 6 +- src/arm64/ti/k3-pinctrl.h | 7 +- src/arm64/ti/k3-serdes.h | 4 +- src/arm64/xilinx/zynqmp-clk-ccf.dtsi | 16 +- src/arm64/xilinx/zynqmp-sck-kv-g-revA.dtso | 36 +- src/arm64/xilinx/zynqmp-sck-kv-g-revB.dtso | 37 +- src/arm64/xilinx/zynqmp-zc1751-xm015-dc1.dts | 2 +- src/arm64/xilinx/zynqmp-zc1751-xm016-dc2.dts | 2 +- src/arm64/xilinx/zynqmp-zc1751-xm019-dc5.dts | 4 +- src/arm64/xilinx/zynqmp-zcu100-revC.dts | 2 +- src/arm64/xilinx/zynqmp-zcu102-revA.dts | 6 +- src/arm64/xilinx/zynqmp-zcu104-revA.dts | 2 +- src/arm64/xilinx/zynqmp-zcu104-revC.dts | 2 +- src/arm64/xilinx/zynqmp-zcu106-revA.dts | 6 +- src/arm64/xilinx/zynqmp-zcu111-revA.dts | 4 +- src/arm64/xilinx/zynqmp-zcu1275-revA.dts | 2 +- src/arm64/xilinx/zynqmp.dtsi | 85 +- src/loongarch/loongson-2k1000.dtsi | 7 + src/loongarch/loongson-2k2000-ref.dts | 33 + src/loongarch/loongson-2k2000.dtsi | 24 +- src/mips/mobileye/eyeq5-epm5.dts | 23 + src/mips/mobileye/eyeq5-fixed-clocks.dtsi | 292 ++ src/mips/mobileye/eyeq5.dtsi | 124 + src/mips/ralink/mt7621.dtsi | 47 + src/powerpc/akebono.dts | 6 +- src/riscv/microchip/mpfs.dtsi | 6 +- src/riscv/renesas/r9a07g043f.dtsi | 8 +- src/riscv/sophgo/sg2042.dtsi | 9 + .../starfive/jh7100-beaglev-starlight.dts | 11 + src/riscv/starfive/jh7100-common.dtsi | 108 + .../jh7100-starfive-visionfive-v1.dts | 22 +- src/riscv/starfive/jh7100.dtsi | 49 + .../jh7110-starfive-visionfive-2.dtsi | 71 + src/riscv/starfive/jh7110.dtsi | 76 + 1276 files changed, 55515 insertions(+), 12702 deletions(-) delete mode 100644 Bindings/arm/marvell/armada-38x.txt create mode 100644 Bindings/arm/marvell/armada-38x.yaml delete mode 100644 Bindings/arm/mediatek/mediatek,hifsys.txt delete mode 100644 Bindings/arm/mediatek/mediatek,pciesys.txt delete mode 100644 Bindings/arm/mediatek/mediatek,ssusbsys.txt delete mode 100644 Bindings/arm/msm/qcom,saw2.txt delete mode 100644 Bindings/ata/ahci-mtk.txt delete mode 100644 Bindings/ata/atmel-at91_cf.txt create mode 100644 Bindings/ata/mediatek,mtk-ahci.yaml create mode 100644 Bindings/auxdisplay/gpio-7-segment.yaml create mode 100644 Bindings/auxdisplay/maxim,max6959.yaml delete mode 100644 Bindings/bus/imx-weim.txt create mode 100644 Bindings/clock/mediatek,mt2701-hifsys.yaml create mode 100644 Bindings/clock/mediatek,mt7622-pciesys.yaml create mode 100644 Bindings/clock/mediatek,mt7622-ssusbsys.yaml create mode 100644 Bindings/clock/mobileye,eyeq5-clk.yaml delete mode 100644 Bindings/clock/qcom,sc7180-mss.yaml delete mode 100644 Bindings/clock/qcom,sm8650-dispcc.yaml create mode 100644 Bindings/display/atmel/atmel,hlcdc-display-controller.yaml delete mode 100644 Bindings/display/atmel/hlcdc-dc.txt create mode 100644 Bindings/display/bridge/fsl,imx8mp-hdmi-tx.yaml create mode 100644 Bindings/display/imx/fsl,imx8mp-hdmi-pvi.yaml create mode 100644 Bindings/display/msm/qcom,x1e80100-mdss.yaml create mode 100644 Bindings/display/panel/boe,th101mb31ig002-28a.yaml create mode 100644 Bindings/display/panel/himax,hx83112a.yaml create mode 100644 Bindings/display/panel/novatek,nt36672e.yaml create mode 100644 Bindings/display/renesas,rzg2l-du.yaml create mode 100644 Bindings/display/solomon,ssd133x.yaml create mode 100644 Bindings/dma/marvell,mmp-dma.yaml create mode 100644 Bindings/dma/mediatek,mt7622-hsdma.yaml delete mode 100644 Bindings/dma/mmp-dma.txt delete mode 100644 Bindings/dma/mtk-hsdma.txt delete mode 100644 Bindings/fpga/fpga-region.txt create mode 100644 Bindings/fpga/fpga-region.yaml create mode 100644 Bindings/gpio/aspeed,ast2400-gpio.yaml delete mode 100644 Bindings/gpio/gpio-aspeed.txt delete mode 100644 Bindings/gpio/gpio-nmk.txt create mode 100644 Bindings/gpio/st,nomadik-gpio.yaml rename Bindings/gpu/{img,powervr.yaml => img,powervr-rogue.yaml} (91%) create mode 100644 Bindings/gpu/img,powervr-sgx.yaml create mode 100644 Bindings/hwmon/adi,ltc4282.yaml create mode 100644 Bindings/hwmon/amphenol,chipcap2.yaml create mode 100644 Bindings/hwmon/aspeed,g6-pwm-tach.yaml create mode 100644 Bindings/hwmon/fan-common.yaml create mode 100644 Bindings/hwmon/hwmon-common.yaml delete mode 100644 Bindings/i2c/i2c.txt create mode 100644 Bindings/iio/adc/microchip,pac1934.yaml create mode 100644 Bindings/iio/adc/ti,ads1298.yaml create mode 100644 Bindings/iio/frequency/adi,admfm2000.yaml create mode 100644 Bindings/iio/magnetometer/voltafield,af8133j.yaml delete mode 100644 Bindings/input/atmel,captouch.txt create mode 100644 Bindings/input/atmel,captouch.yaml delete mode 100644 Bindings/input/da9062-onkey.txt create mode 100644 Bindings/input/dlg,da9062-onkey.yaml create mode 100644 Bindings/input/samsung,s3c6410-keypad.yaml delete mode 100644 Bindings/input/samsung-keypad.txt create mode 100644 Bindings/input/touchscreen/fsl,imx6ul-tsc.yaml create mode 100644 Bindings/input/touchscreen/goodix,gt9916.yaml delete mode 100644 Bindings/input/touchscreen/imx6ul_tsc.txt create mode 100644 Bindings/interconnect/qcom,sm7150-rpmh.yaml delete mode 100644 Bindings/interrupt-controller/atmel,aic.txt create mode 100644 Bindings/interrupt-controller/atmel,aic.yaml create mode 100644 Bindings/interrupt-controller/mediatek,mt6577-sysirq.yaml delete mode 100644 Bindings/interrupt-controller/mediatek,sysirq.txt create mode 100644 Bindings/interrupt-controller/starfive,jh8100-intc.yaml create mode 100644 Bindings/leds/backlight/kinetic,ktd2801.yaml create mode 100644 Bindings/leds/onnn,ncp5623.yaml create mode 100644 Bindings/media/st,stm32mp25-video-codec.yaml create mode 100644 Bindings/memory-controllers/fsl/fsl,imx-weim-peripherals.yaml create mode 100644 Bindings/memory-controllers/fsl/fsl,imx-weim.yaml create mode 100644 Bindings/mfd/atmel,hlcdc.yaml create mode 100644 Bindings/mfd/atmel,sama5d2-flexcom.yaml delete mode 100644 Bindings/mfd/atmel-flexcom.txt delete mode 100644 Bindings/mfd/atmel-hlcdc.txt delete mode 100644 Bindings/mfd/da9062.txt create mode 100644 Bindings/mips/mobileye.yaml delete mode 100644 Bindings/misc/xlnx,sd-fec.txt create mode 100644 Bindings/misc/xlnx,sd-fec.yaml delete mode 100644 Bindings/mmc/hi3798cv200-dw-mshc.txt create mode 100644 Bindings/mmc/hisilicon,hi3798cv200-dw-mshc.yaml create mode 100644 Bindings/mtd/partitions/linux,ubi.yaml create mode 100644 Bindings/mtd/partitions/ubi-volume.yaml delete mode 100644 Bindings/net/dsa/ar9331.txt create mode 100644 Bindings/net/dsa/qca,ar9331.yaml create mode 100644 Bindings/net/ethernet-phy-package.yaml create mode 100644 Bindings/net/qca,qca808x.yaml create mode 100644 Bindings/net/qcom,qca807x.yaml create mode 100644 Bindings/nvmem/nvmem-provider.yaml delete mode 100644 Bindings/nvmem/xlnx,zynqmp-nvmem.txt create mode 100644 Bindings/nvmem/xlnx,zynqmp-nvmem.yaml create mode 100644 Bindings/pci/qcom,pcie-common.yaml create mode 100644 Bindings/pci/qcom,pcie-sa8775p.yaml create mode 100644 Bindings/pci/qcom,pcie-sc7280.yaml create mode 100644 Bindings/pci/qcom,pcie-sc8180x.yaml create mode 100644 Bindings/pci/qcom,pcie-sc8280xp.yaml create mode 100644 Bindings/pci/qcom,pcie-sm8150.yaml create mode 100644 Bindings/pci/qcom,pcie-sm8250.yaml create mode 100644 Bindings/pci/qcom,pcie-sm8350.yaml create mode 100644 Bindings/pci/qcom,pcie-sm8450.yaml create mode 100644 Bindings/pci/qcom,pcie-sm8550.yaml create mode 100644 Bindings/pci/qcom,pcie-x1e80100.yaml create mode 100644 Bindings/perf/arm,coresight-pmu.yaml create mode 100644 Bindings/perf/starfive,jh8100-starlink-pmu.yaml create mode 100644 Bindings/phy/mediatek,mt8365-csi-rx.yaml create mode 100644 Bindings/phy/qcom,msm8998-qmp-usb3-phy.yaml create mode 100644 Bindings/phy/rockchip,rk3588-hdptx-phy.yaml create mode 100644 Bindings/pinctrl/awinic,aw9523-pinctrl.yaml delete mode 100644 Bindings/pinctrl/fsl,imx6ul-pinctrl.txt create mode 100644 Bindings/pinctrl/fsl,imx6ul-pinctrl.yaml create mode 100644 Bindings/pinctrl/mobileye,eyeq5-pinctrl.yaml rename Bindings/pinctrl/{xlnx,zynq-pinctrl.yaml => xlnx,pinctrl-zynq.yaml} (98%) create mode 100644 Bindings/pwm/atmel,hlcdc-pwm.yaml delete mode 100644 Bindings/pwm/atmel-hlcdc-pwm.txt create mode 100644 Bindings/pwm/marvell,pxa-pwm.yaml create mode 100644 Bindings/pwm/opencores,pwm.yaml delete mode 100644 Bindings/pwm/pxa-pwm.txt create mode 100644 Bindings/regulator/infineon,ir38060.yaml delete mode 100644 Bindings/regulator/mcp16502-regulator.txt create mode 100644 Bindings/regulator/microchip,mcp16502.yaml create mode 100644 Bindings/regulator/ti,tps65132.yaml delete mode 100644 Bindings/regulator/tps65132-regulator.txt create mode 100644 Bindings/reset/mobileye,eyeq5-reset.yaml create mode 100644 Bindings/reset/sophgo,sg2042-reset.yaml delete mode 100644 Bindings/rtc/abracon,abx80x.txt create mode 100644 Bindings/rtc/abracon,abx80x.yaml create mode 100644 Bindings/rtc/mediatek,mt2712-rtc.yaml create mode 100644 Bindings/rtc/mediatek,mt7622-rtc.yaml delete mode 100644 Bindings/rtc/rtc-mt2712.txt delete mode 100644 Bindings/rtc/rtc-mt7622.txt create mode 100644 Bindings/serial/st,asc.yaml delete mode 100644 Bindings/serial/st-asc.txt create mode 100644 Bindings/soc/imx/fsl,imx-anatop.yaml create mode 100644 Bindings/soc/qcom/qcom,pbs.yaml rename Bindings/soc/qcom/{qcom,spm.yaml => qcom,saw2.yaml} (53%) create mode 100644 Bindings/soc/renesas/renesas-soc.yaml create mode 100644 Bindings/sound/atmel,asoc-wm8904.yaml create mode 100644 Bindings/sound/atmel,sam9x5-wm8731-audio.yaml delete mode 100644 Bindings/sound/atmel-sam9x5-wm8731-audio.txt delete mode 100644 Bindings/sound/atmel-wm8904.txt delete mode 100644 Bindings/sound/fsl,asrc.txt create mode 100644 Bindings/sound/fsl,imx-asrc.yaml create mode 100644 Bindings/sound/qcom,q6usb.yaml create mode 100644 Bindings/sound/qcom,wcd939x-sdw.yaml create mode 100644 Bindings/sound/qcom,wcd939x.yaml create mode 100644 Bindings/sound/qcom,wcd93xx-common.yaml create mode 100644 Bindings/sound/realtek,rt1015.yaml delete mode 100644 Bindings/sound/rt1015.txt delete mode 100644 Bindings/thermal/da9062-thermal.txt create mode 100644 Bindings/thermal/dlg,da9062-thermal.yaml delete mode 100644 Bindings/timer/mediatek,mtk-timer.txt create mode 100644 Bindings/timer/mediatek,timer.yaml create mode 100644 Bindings/timer/ralink,cevt-systick.yaml create mode 100644 Bindings/usb/hisilicon,hi3798mv200-dwc3.yaml create mode 100644 Bindings/usb/ite,it5205.yaml create mode 100644 Bindings/usb/ti,usb8020b.yaml create mode 100644 Bindings/usb/usb-switch.yaml create mode 100644 Bindings/w1/w1-uart.yaml delete mode 100644 Bindings/watchdog/brcm,bcm2835-pm-wdog.txt create mode 100644 Bindings/watchdog/sprd,sp9860-wdt.yaml delete mode 100644 Bindings/watchdog/sprd-wdt.txt create mode 100644 include/dt-bindings/clock/mobileye,eyeq5-clk.h create mode 100644 include/dt-bindings/clock/qcom,x1e80100-camcc.h create mode 100644 include/dt-bindings/clock/qcom,x1e80100-dispcc.h create mode 100644 include/dt-bindings/clock/qcom,x1e80100-gpucc.h create mode 100644 include/dt-bindings/clock/qcom,x1e80100-tcsr.h create mode 100644 include/dt-bindings/clock/renesas,r8a779h0-cpg-mssr.h create mode 100644 include/dt-bindings/interconnect/qcom,msm8909.h create mode 100644 include/dt-bindings/interconnect/qcom,sm7150-rpmh.h create mode 100644 include/dt-bindings/power/renesas,r8a779h0-sysc.h create mode 100644 include/dt-bindings/reset/qcom,x1e80100-gpucc.h create mode 100644 include/dt-bindings/reset/sophgo,sg2042-reset.h create mode 100644 src/arm/microchip/at91-sama7g54_curiosity.dts create mode 100644 src/arm/nvidia/tegra30-lg-p880.dts create mode 100644 src/arm/nvidia/tegra30-lg-p895.dts create mode 100644 src/arm/nvidia/tegra30-lg-x3.dtsi create mode 100644 src/arm/nxp/imx/imx53-qsb-hdmi.dtso create mode 100644 src/arm/nxp/imx/imx6dl-sielaff.dts create mode 100644 src/arm/nxp/imx/imx6q-apalis-eval-v1.2.dts create mode 100644 src/arm/nxp/imx/imx6q-apalis-eval.dtsi create mode 100644 src/arm/qcom/qcom-msm8226-samsung-matisse-common.dtsi create mode 100644 src/arm/qcom/qcom-msm8926-samsung-matisselte.dts create mode 100644 src/arm/qcom/qcom-msm8960-pins.dtsi create mode 100644 src/arm/st/stm32f769-disco-mb1166-reva09.dts create mode 100644 src/arm/st/stm32f769.dtsi create mode 100644 src/arm64/allwinner/sun50i-h618-longan-module-3h.dtsi create mode 100644 src/arm64/allwinner/sun50i-h618-longanpi-3h.dts create mode 100644 src/arm64/allwinner/sun50i-h64-remix-mini-pc.dts create mode 100644 src/arm64/amlogic/meson-g12a-fbx8am-brcm.dtso create mode 100644 src/arm64/amlogic/meson-g12a-fbx8am-realtek.dtso create mode 100644 src/arm64/amlogic/meson-g12a-fbx8am.dts create mode 100644 src/arm64/freescale/imx8-apalis-eval-v1.1.dtsi create mode 100644 src/arm64/freescale/imx8-apalis-eval-v1.2.dtsi create mode 100644 src/arm64/freescale/imx8-ss-gpu0.dtsi create mode 100644 src/arm64/freescale/imx8dxp-tqma8xdp-mba8xx.dts create mode 100644 src/arm64/freescale/imx8dxp-tqma8xdp.dtsi create mode 100644 src/arm64/freescale/imx8dxp.dtsi create mode 100644 src/arm64/freescale/imx8mn-tqma8mqnl-mba8mx-usbotg.dtso create mode 100644 src/arm64/freescale/imx8qm-apalis-eval-v1.2.dts create mode 100644 src/arm64/freescale/imx8qm-apalis-v1.1-eval-v1.2.dts create mode 100644 src/arm64/freescale/imx8qxp-tqma8xqp-mba8xx.dts create mode 100644 src/arm64/freescale/imx8qxp-tqma8xqp.dtsi create mode 100644 src/arm64/freescale/imx93-phyboard-segin.dts create mode 100644 src/arm64/freescale/imx93-phycore-som.dtsi create mode 100644 src/arm64/freescale/imx93-var-som-symphony.dts create mode 100644 src/arm64/freescale/imx93-var-som.dtsi create mode 100644 src/arm64/freescale/mba8xx.dtsi create mode 100644 src/arm64/freescale/tqma8xx.dtsi create mode 100644 src/arm64/mediatek/mt7981b-xiaomi-ax3000t.dts create mode 100644 src/arm64/mediatek/mt7981b.dtsi create mode 100644 src/arm64/mediatek/mt7986a-acelink-ew-7886cax.dts create mode 100644 src/arm64/mediatek/mt7988a-bananapi-bpi-r4.dts create mode 100644 src/arm64/mediatek/mt7988a.dtsi create mode 100644 src/arm64/mediatek/mt8186-corsola-krabby.dtsi create mode 100644 src/arm64/mediatek/mt8186-corsola-magneton-sku393216.dts create mode 100644 src/arm64/mediatek/mt8186-corsola-magneton-sku393217.dts create mode 100644 src/arm64/mediatek/mt8186-corsola-magneton-sku393218.dts create mode 100644 src/arm64/mediatek/mt8186-corsola-rusty-sku196608.dts create mode 100644 src/arm64/mediatek/mt8186-corsola-steelix-sku131072.dts create mode 100644 src/arm64/mediatek/mt8186-corsola-steelix-sku131073.dts create mode 100644 src/arm64/mediatek/mt8186-corsola-steelix.dtsi create mode 100644 src/arm64/mediatek/mt8186-corsola-tentacool-sku327681.dts create mode 100644 src/arm64/mediatek/mt8186-corsola-tentacool-sku327683.dts create mode 100644 src/arm64/mediatek/mt8186-corsola-tentacruel-sku262144.dts create mode 100644 src/arm64/mediatek/mt8186-corsola-tentacruel-sku262148.dts create mode 100644 src/arm64/mediatek/mt8186-corsola.dtsi create mode 100644 src/arm64/mediatek/mt8395-radxa-nio-12l.dts delete mode 100644 src/arm64/nvidia/tegra234-p3767-0000.dtsi delete mode 100644 src/arm64/nvidia/tegra234-p3767-0005.dtsi create mode 100644 src/arm64/qcom/msm8216-samsung-fortuna3g.dts create mode 100644 src/arm64/qcom/msm8916-samsung-fortuna-common.dtsi create mode 100644 src/arm64/qcom/msm8916-samsung-gprimeltecan.dts create mode 100644 src/arm64/qcom/msm8916-samsung-grandprimelte.dts create mode 100644 src/arm64/qcom/msm8916-samsung-rossa-common.dtsi create mode 100644 src/arm64/qcom/msm8916-samsung-rossa.dts rename src/arm64/qcom/{pm2250.dtsi => pm4125.dtsi} (56%) create mode 100644 src/arm64/qcom/sdm450.dtsi create mode 100644 src/arm64/qcom/sm7125-xiaomi-curtana.dts create mode 100644 src/arm64/qcom/sm8550-hdk.dts create mode 100644 src/arm64/renesas/r8a779g0-white-hawk-cpu.dts create mode 100644 src/arm64/renesas/r8a779g2-white-hawk-single.dts create mode 100644 src/arm64/renesas/r8a779g2.dtsi create mode 100644 src/arm64/renesas/r8a779h0-gray-hawk-single.dts create mode 100644 src/arm64/renesas/r8a779h0.dtsi create mode 100644 src/arm64/renesas/r9a07g043u11-smarc-cru-csi-ov5645.dtso create mode 100644 src/arm64/renesas/white-hawk-common.dtsi create mode 100644 src/arm64/renesas/white-hawk-cpu-common.dtsi rename src/arm64/renesas/{r8a779g0-white-hawk-csi-dsi.dtsi => white-hawk-csi-dsi.dtsi} (97%) rename src/arm64/renesas/{r8a779g0-white-hawk-ethernet.dtsi => white-hawk-ethernet.dtsi} (76%) create mode 100644 src/arm64/rockchip/rk3566-anbernic-rg-arc-d.dts create mode 100644 src/arm64/rockchip/rk3566-anbernic-rg-arc-s.dts create mode 100644 src/arm64/rockchip/rk3566-anbernic-rg-arc.dtsi create mode 100644 src/arm64/rockchip/rk3566-pinetab2-v0.1.dts create mode 100644 src/arm64/rockchip/rk3566-pinetab2-v2.0.dts create mode 100644 src/arm64/rockchip/rk3566-pinetab2.dtsi create mode 100644 src/arm64/rockchip/rk3566-powkiddy-rgb10max3.dts create mode 100644 src/arm64/rockchip/rk3568-qnap-ts433.dts create mode 100644 src/arm64/rockchip/rk3588-edgeble-neu6a-common.dtsi create mode 100644 src/arm64/rockchip/rk3588-edgeble-neu6a-io.dtsi create mode 100644 src/arm64/rockchip/rk3588-edgeble-neu6a-wifi.dtso create mode 100644 src/arm64/rockchip/rk3588-tiger-haikou.dts create mode 100644 src/arm64/rockchip/rk3588-tiger.dtsi create mode 100644 src/arm64/rockchip/rk3588-toybrick-x0.dts create mode 100644 src/arm64/rockchip/rk3588s-nanopi-r6c.dts create mode 100644 src/arm64/rockchip/rk3588s-nanopi-r6s.dts create mode 100644 src/arm64/ti/k3-am62x-phyboard-lyra-gpio-fan.dtso create mode 100644 src/arm64/ti/k3-am642-evm-icssg1-dualemac.dtso create mode 100644 src/arm64/ti/k3-am642-hummingboard-t-pcie.dtso create mode 100644 src/arm64/ti/k3-am642-hummingboard-t-usb3.dtso create mode 100644 src/arm64/ti/k3-am642-hummingboard-t.dts create mode 100644 src/arm64/ti/k3-am642-sr-som.dtsi create mode 100644 src/arm64/ti/k3-am65-iot2050-arduino-connector.dtsi create mode 100644 src/arm64/ti/k3-am65-iot2050-dp.dtsi create mode 100644 src/arm64/ti/k3-am65-iot2050-usb3.dtsi create mode 100644 src/arm64/ti/k3-am654-pcie-usb2.dtso create mode 100644 src/arm64/ti/k3-am654-pcie-usb3.dtso create mode 100644 src/arm64/ti/k3-am6548-iot2050-advanced-sm.dts create mode 100644 src/arm64/ti/k3-j721e-sk-csi2-dual-imx219.dtso create mode 100644 src/arm64/ti/k3-j722s-evm.dts create mode 100644 src/arm64/ti/k3-j722s.dtsi create mode 100644 src/mips/mobileye/eyeq5-epm5.dts create mode 100644 src/mips/mobileye/eyeq5-fixed-clocks.dtsi create mode 100644 src/mips/mobileye/eyeq5.dtsi
Hi Tom,
On 2024-05-14 18:42, Tom Rini wrote:>
git-subtree-dir: dts/upstream git-subtree-split: 7e08733c96c84eb323f47e9b248c924e2ac6272a
This moves OF_UPSTREAM to be tracking the v6.9 release and is for the -next branch. To test these changes yourself locally, either use my "WIP/14May2024-next" branch or run: ./dts/update-dts-subtree.sh pull v6.9-dts yourself locally. I intend to wait a few days to apply this to -next, to give people time to test.
There are currently more boards/SoCs that use OF_UPSTREAM in master branch than in next branch, a few Rockchip SoCs and other boards/SoCs. Next dts/upstream sync will probably be good to do together with a merge of master into next :-)
Also what is the expected sync cadence of dts/upstream? Linux v6.10 will probably be released shortly after U-Boot v2024.07. So will next sync be to v6.10-dts if that happens in the U-Boot merge window or do we expect 2024.10 to use v6.9 DTs if the v6.10 release gets delayed and miss the U-Boot merge window?
Linux kernel typically have all major DT changes in -rc1 and fixes in later -rcX, so for next branch I would suggest an early sync to a v6.10-rcX-dts tag, and then sync to the final v6.10-dts tag once v6.10 gets released. That should give more time for testing, migration and cleanup using v6.10 DTs in time for a 2024.10 release.
Regards, Jonas
Hi Jonas,
On Wed, 15 May 2024 at 13:11, Jonas Karlman jonas@kwiboo.se wrote:
Hi Tom,
Glad to see more OF_UPSTREAM adoption.
I don't have any particular opinion here and rather leave it upto Tom how he would like to merge stuff.
I can see the reasoning for an aggressive DT syncing approach, it has been brought up in the past too. And the major reason for the current moderate sync approach [1] is to limit any DT ABI breakages for U-Boot, we are even prone to breakages with syncs against major Linux kernel releases (eg. v6.10-dts etc.). It has been a long time discussion topic where we have been advocating about requirements for DT ABI stability [2].
So having DT syncs done during the merge window will shorten the testing window for developers/maintainers. And more syncs means a multiplicative factor for testing. However, time will tell with more and more platforms adopting OF_UPSTREAM, if there are any real DT ABI breakages seen in the future. But surely if they are very rare then I am open to adopting aggressive DT sync approaches.
[1] https://docs.u-boot.org/en/latest/develop/devicetree/control.html#resyncing-... [2] https://www.mail-archive.com/boot-architecture@lists.linaro.org/msg02162.htm...
-Sumit
Regards, Jonas
Hi Sumit,
On 2024-05-15 10:49, Sumit Garg wrote:
Hi Jonas,
Hi Tom,
I agree that syncing multiple rcX tags may not be that helpful, but an approach where maybe rc1, rc2 or rc3 and then the final tag is merged or something similar. At least when we can foresee when next Linux version will be released close to an U-Boot release. At least early in U-Boot release cycle know what Linux version dts/upstream will be targeted.
My main concern is how to best handle new boards and features/drivers. E.g. for Rockchip the RK3588 SoC is under active development, new boards and features/drivers are actively added/fixed in upstream Linux.
New Rockchip boards have typically been added after board DT have been merged into linux maintainer tree. Now if we wait until merge window to do a dts/upstream sync, the result may be that it may take up to three U-Boot releases until a new board is easily added using dts/upstream.
Another approach could be that we add new boards using !OF_UPSTREAM once they are merged into linux maintainer tree. And then migrate the board to use OF_UPSTREAM once the board finally ends up in dts/upstream.
But that can also be problematic when board .dts-file start referencing nodes/symbols not yet added in the soc .dts-file in dts/upstream. Adding the "missing" but maintainer merged soc nodes to the soc u-boot.dtsi could be one way to work around such issue.
Anyway, some guidance, predictability and earlier sync related to dts/upstream would be much appreciated :-)
Regards, Jonas
-Sumit
Regards, Jonas
On Wed, 15 May 2024 at 15:09, Jonas Karlman jonas@kwiboo.se wrote:
Hi Sumit,
Hi Jonas,
Hi Tom,
I would suggest you to then maintain the under development soc .dts-file in U-Boot too. Since with !OF_UPSTREAM, the soc .dts-file present in the U-Boot DTS tree (arch/${ARCH}/dts/) will be used instead of one from dts/upstream. This was especially done to support use-cases like this via the directory include ordering. You can later switch once you think the board is well supported by dts/upstream.
IMHO, let's try to provide a stable base to encourage further adoption of OF_UPSTREAM and have sufficient data regarding DT ABI stability. IOW, let's stick to the current moderate sync approach for a few more U-Boot releases. My motivation has really been to reduce developers/maintainers' pain regarding DT maintenance in U-Boot.
-Sumit
Regards, Jonas
-Sumit
Regards, Jonas
On Wed, May 15, 2024 at 11:39:08AM +0200, Jonas Karlman wrote:
[snip]
To this question specifically, dts/update-dts-subtree.sh has a "pick" option and in some previous quick testing, it does what one would hope. So for this case you could pick the N commits that need to be brought it, the resulting patch would be small enough to send to the list normally (the resync patch for v6.9 is 2.7MB) and then when I do the next full resync it goes cleanly still.
[snip]
That sounds like a good alternative although it was proposed for any fixes to be incorporated but it's worth giving it a try for new features too. I think as long as the cherry pick is clean with all dependencies being picked up properly, the next sync should work cleanly.
-Sumit
-- Tom
On Wed, May 15, 2024 at 09:29:41AM +0200, Jonas Karlman wrote:
Hi Tom,
Yeah, with -rc3 I'll pull that in to next. And I did this sync now since Quentin reminded me on IRC about it. The massive CC list comes from using qconfig.py to see who enables it, and then a quick one-off to get a list out of get_maintainers.pl.
So, I need to put something in to doc/develop/process.rst about when the full dts/upstream resyncs happen, and where. The plan currently is every Linux kernel release gets pulled in, and master or next depends on if the -next branch is open (which is with -rc2). This should give us the most time to get changes tested, while minimizing drift away from upstream sources. This is also because, and related to, that I try and make sure that nothing breaking comes in to master once next is open, and so if a board maintainer has time to test things at -rc3 or what have you, it should still work in the release proper. More testing is always great, but given our release cadence and generally predictable schedule, I am hopeful this provides the best trade-offs in terms of time demands on board maintainers.
The issue in my mind is that we just don't have a lot of people with time to test things in U-Boot. So I'd rather avoid possible broken upstream and then fixed later upstream problems. And having done it now, I can also say it's really easy to use dts/update-dts-subtree.sh so if someone has time they can do that locally.
Am Dienstag, 14. Mai 2024, 18:42:36 CEST schrieb Tom Rini:
On - rk3588-rock5b - rk3588-jaguar - rk3588-tiger (pending patch)
Tested-by: Heiko Stuebner heiko@sntech.de
Heiko Stübner
Jonas Karlman
Sumit Garg
