[PATCH] timer-uclass: Always use "clock-frequency" property as fallback
Currently the "clock-frequency" DT property is only being considered as an fallback if either there is no clock driver, the clock driver implements the request-op correctly or there is no clock defined for the timer at all.
This patch makes "clock-frequency" also being picked as a fallback if getting the clock-rate fails, since clk_get(_by_index) will return no error, if a clock driver does not implement the request-op and does also not support getting the rate of the clock in question. timer_post_probe will take care if the property does not exist in the DT or is defined as 0.
Signed-off-by: Alex Bee knaerzche@gmail.com --- This is currently an issue for Rockchip RK3188 and potentially also for RK3368: The clock driver does not implement the request-op. Even if we would add it: timer-uclass always picks the first clock and the DT bindings for Rockchip timer requires us to place the pclk first and and the timer source clock second.
drivers/timer/timer-uclass.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index 0c2018bfe3..60ff65529a 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -66,13 +66,13 @@ static int timer_pre_probe(struct udevice *dev) err = clk_get_by_index(dev, 0, &timer_clk); if (!err) { ret = clk_get_rate(&timer_clk); - if (IS_ERR_VALUE(ret)) - return ret; - uc_priv->clock_rate = ret; - } else { - uc_priv->clock_rate = - dev_read_u32_default(dev, "clock-frequency", 0); + if (!IS_ERR_VALUE(ret)) { + uc_priv->clock_rate = ret; + return 0; + } } + + uc_priv->clock_rate = dev_read_u32_default(dev, "clock-frequency", 0); }
Alex Bee
