[PATCH v1] board: toradex: verdin-am62: Remove not needed env variables
From: Francesco Dolcini francesco.dolcini@toradex.com
Remove not needed variables from environment.
- boot_scripts is not needed, the default value is just fine and already includes boot.scr - setup variable used to be executed from some bootscript, however it's not required and there is no point on having this small helper here
Signed-off-by: Francesco Dolcini francesco.dolcini@toradex.com --- include/configs/verdin-am62.h | 3 --- 1 file changed, 3 deletions(-)
diff --git a/include/configs/verdin-am62.h b/include/configs/verdin-am62.h index 9d2e37f2d96d..ac44809fdfa5 100644 --- a/include/configs/verdin-am62.h +++ b/include/configs/verdin-am62.h @@ -39,12 +39,9 @@ #define CFG_EXTRA_ENV_SETTINGS \ BOOTENV \ MEM_LAYOUT_ENV_SETTINGS \ - "boot_scripts=boot.scr\0" \ "boot_script_dhcp=boot.scr\0" \ "console=ttyS2\0" \ "fdt_board=dev\0" \ - "setup=setenv setupargs console=tty1 console=${console},${baudrate} " \ - "consoleblank=0 earlycon=ns16550a,mmio32,0x02800000\0" \ "update_tiboot3=askenv confirm Did you load tiboot3.bin (y/N)?; " \ "if test "$confirm" = "y"; then " \ "setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt " \
Francesco Dolcini
