[U-Boot] [PATCH] net/net.c: correct timeout function
the net/net.c implemenation of timeouts assumes that get_timer() returns values in milliseconds. As this is true for most platforms, it does not apply to PXA3x where the OSCR register increments with more than 3MHz.
The following patch fixes the problem by calculation with the CONFIG_SYS_HZ variable.
Best regards, Daniel
diff --git a/net/net.c b/net/net.c index 77e83b5..b9326de 100644 --- a/net/net.c +++ b/net/net.c @@ -206,6 +206,11 @@ uchar NetArpWaitPacketBuf[PKTSIZE_ALIGN + PKTALIGN]; ulong NetArpWaitTimerStart; int NetArpWaitTry;
+static long net_get_timer(long base) +{ + return get_timer(base) / (CONFIG_SYS_HZ / 1000); +} + void ArpRequest (void) { int i; @@ -256,7 +261,7 @@ void ArpTimeoutCheck(void) if (!NetArpWaitPacketIP) return;
- t = get_timer(0); + t = net_get_timer(0);
/* check for arp timeout */ if ((t - NetArpWaitTimerStart) > ARP_TIMEOUT) { @@ -517,7 +522,7 @@ restart: * Check for a timeout, and run the timeout handler * if we have one. */ - if (timeHandler && ((get_timer(0) - timeStart) > timeDelta)) { + if (timeHandler && ((net_get_timer(0) - timeStart) > timeDelta)) { thand_f *x;
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) @@ -639,7 +644,7 @@ NetSetTimeout(ulong iv, thand_f * f) timeHandler = (thand_f *)0; } else { timeHandler = f; - timeStart = get_timer(0); + timeStart = net_get_timer(0); timeDelta = iv; } } @@ -684,7 +689,7 @@ NetSendUDPPacket(uchar *ether, IPaddr_t dest, int dport, int sport, int len)
/* and do the ARP request */ NetArpWaitTry = 1; - NetArpWaitTimerStart = get_timer(0); + NetArpWaitTimerStart = net_get_timer(0); ArpRequest(); return 1; /* waiting */ } @@ -755,7 +760,7 @@ int PingSend(void)
Just curious - was this patch taken? Same question for the ones sent in mails labeled
[PATCH] ne2000: take MAC address from config if available (+follow-ups) [PATCH] PXA3xx: fix CKEN[AB]
Thanks, Daniel
Hi Daniel,
Sorry, I've been bogged down with other stuff. Some things are missing from your patches, which can mainly be fixed by using 'git format-patch -C': 1. No signed-off-by 2. No diffstat 3. Place text that shouldn't be in the commit message below the '---' line
If you take care of this easy stuff and resubmit I'll take a hard look at the content in the next couple of days. Please understand that the merge window is currently closed, so your code won't make it into the mainline U-boot until January sometime, although it will go in the net tree as soon as it's compliant.
regards, Ben
Hi Ben,
- No signed-off-by
- No diffstat
- Place text that shouldn't be in the commit message below the '---' line
I re-submitted them, thanks.
No offence meant, btw. I was just fearing my mails to be drowning in the flood of emails on this list.
Thanks and best regards, Daniel
Daniel Mack wrote:
Hi Ben,
- No signed-off-by
- No diffstat
No problem, and I'll try to give feedback soon.
regards, Ben
the net/net.c implementation of timeouts assumes that get_timer() returns values in milliseconds. As this is true for most platforms, it does not apply to PXA3x where the OSCR register increments with more than 3MHz.
Signed-off-by: Daniel Mack daniel@caiaq.de
--- net.c | 15 ++++++++++----- 1 file changed, 10 insertions(+), 5 deletions(-)
Hi Daniel,
I apologize for taking so long to respond to this.
- return get_timer(base) / (CONFIG_SYS_HZ / 1000);
Please change this name to something more meaningful, maybe get_timer_ms(). Apart from that, looks good. If you re-submit soon I'll pull it in.
regards, Ben
Make timeout implementation in net/net.c take into account the CONFIG_SYS_HZ variable. This is needed for all CPUs where the default timer is running on anything else than 1000.
Signed-off-by: Daniel Mack daniel@caiaq.de --- net/net.c | 15 ++++++++++----- 1 files changed, 10 insertions(+), 5 deletions(-)
diff --git a/net/net.c b/net/net.c index 77e83b5..1c48236 100644 --- a/net/net.c +++ b/net/net.c @@ -206,6 +206,11 @@ uchar NetArpWaitPacketBuf[PKTSIZE_ALIGN + PKTALIGN]; ulong NetArpWaitTimerStart; int NetArpWaitTry;
+static long get_timer_ms(long base) +{ + return get_timer(base) / (CONFIG_SYS_HZ / 1000); +} + void ArpRequest (void) { int i; @@ -256,7 +261,7 @@ void ArpTimeoutCheck(void) if (!NetArpWaitPacketIP) return;
- t = get_timer(0); + t = get_timer_ms(0);
/* check for arp timeout */ if ((t - NetArpWaitTimerStart) > ARP_TIMEOUT) { @@ -517,7 +522,7 @@ restart: * Check for a timeout, and run the timeout handler * if we have one. */ - if (timeHandler && ((get_timer(0) - timeStart) > timeDelta)) { + if (timeHandler && ((get_timer_ms(0) - timeStart) > timeDelta)) { thand_f *x;
#if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) @@ -639,7 +644,7 @@ NetSetTimeout(ulong iv, thand_f * f) timeHandler = (thand_f *)0; } else { timeHandler = f; - timeStart = get_timer(0); + timeStart = get_timer_ms(0); timeDelta = iv; } } @@ -684,7 +689,7 @@ NetSendUDPPacket(uchar *ether, IPaddr_t dest, int dport, int sport, int len)
/* and do the ARP request */ NetArpWaitTry = 1; - NetArpWaitTimerStart = get_timer(0); + NetArpWaitTimerStart = get_timer_ms(0); ArpRequest(); return 1; /* waiting */ } @@ -755,7 +760,7 @@ int PingSend(void)
Dear Daniel Mack,
I reject this patch.
This is by definition a NO-OP at best, and misleading and wrong otherwise. get_timer() is defined to return millisecond resolution, and CONFIG_SYS_HZ is supposed to be 1000.
So in a correct configuration get_timer_ms() is the same as get_timer(), and if CONFIG_SYS_HZ is (incorrectly) not set to 1000 while get_timer() is implemented correctly, then get_timer_ms() willnot do what it claims to do.
Not to mention what happens if someone has CONFIG_SYS_HZ defined as 999, for example.
The whole aproach is broken - instead of coating bugs we should fix the cause of the bugs.
NAK.
The timer implementation (at least the one for PXA processors) assumes that the OSCR register increments 1000 times a second. Which it doesn't for PXA3xx variants. Hence, all functions from cpu/pxa/interrupts.c will behave entirely differently on a PXA270 compared to a PXA3xx, and so all code using this functions will break.
That's what I've experienced, and as I didn't find a proper place to fix it at a sane level, I fixed the problem locally. I agree that this might not be the best place, so I'll happily accept better proposals.
Why is a CONFIG_SYS_HZ != 1000 considered incorrect? Or let me spin it that way: if that's incorrect, what does this variable exist for at all?
What is get_timer() supposed to return, anyway? I didn't find any documentation about it and assumed that it straightly returns the primary system timer of the CPU (which it perfectly does for PXAs).
Not sure whether I got your point here. If the system timer increments 999 times per second and CONFIG_SYS_HZ is set accordingly, my function does the right thing, doesn't it? I'm not up to any flamewar, I just want to understand where you see the problem.
As fas as I understand the big picture, a function like mine should exist somewhere in the code. Probably not in net/net.c, though.
Dear Daniel Mack,
So this is a bug, and needs to be fixed.
It exists only for historic reasons, I used it to optimize between timer accuracy and overhead on slow (33 MHz) MP8xx systems some 8+ years ago. It has been considered a constant of 1000 ever since. Only some broken ports used it differently. Unfortunately this went unnoticed way too long.
get_timer(base) returns the number of milliseconds since "base".
It doesn't:
gives
return get_timer(base) / (999 / 1000);
which gives
return get_timer(base) / 0;
which gives a problem.
No, it should not exist at all. It is not needed for all correct implementations where get_timer() is already returning milliseconds.
Ok. Do you want me to submit some "#ifdef MONAHANS" patch for the pxa ge_timer() function or is anyone working on major reworks for this anyway?
Dear Daniel Mack,
You best coordinate this with Jean-Christophe, the PXA custodian.
I guess he's reading this list? So I'll just sit and wait for a comment, also about the other ARM specific patches I sent in.
Dear Ben Warren,
Please do not pull this. It just covers bugs elsewhere in the code.
We need to fix the real bugs, not put paint and wallpaper over it.
Dear Ben Warren,
OK
Ben Warren
Daniel Mack
