[U-Boot] [PATCH 1/2] arm: rmobile: configs: Collect up common part of config for R-Car SoCs
The lager, koelsch, alt, gose board supported in rmobile is distinguished as the R-Car Gen2 series and has much common setting. This collect up the common part of config as rcar-gen2-common.h.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- include/configs/rcar-gen2-common.h | 95 ++++++++++++++++++++++++++++++++++++++ 1 file changed, 95 insertions(+) create mode 100644 include/configs/rcar-gen2-common.h
diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h new file mode 100644 index 0000000..46c7526 --- /dev/null +++ b/include/configs/rcar-gen2-common.h @@ -0,0 +1,95 @@ +/* + * include/configs/rcar-gen2-common.h + * + * Copyright (C) 2013,2014 Renesas Electronics Corporation + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef __RCAR_GEN2_COMMON_H +#define __RCAR_GEN2_COMMON_H + +#include <asm/arch/rmobile.h> + +#define CONFIG_CMD_EDITENV +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_DFL +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_RUN +#define CONFIG_CMD_LOADS +#define CONFIG_CMD_NET +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_NFS +#define CONFIG_CMD_BOOTZ +#define CONFIG_CMD_USB +#define CONFIG_CMD_FAT +#define CONFIG_CMD_SF +#define CONFIG_CMD_SPI + +#define CONFIG_SYS_THUMB_BUILD +#define CONFIG_SYS_GENERIC_BOARD + +/* Support File sytems */ +#define CONFIG_FAT_WRITE +#define CONFIG_DOS_PARTITION +#define CONFIG_SUPPORT_VFAT +#define CONFIG_EXT4_WRITE + +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_EDITING +#define CONFIG_OF_LIBFDT + +#define CONFIG_BAUDRATE 38400 +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "" + +#define CONFIG_VERSION_VARIABLE +#undef CONFIG_SHOW_BOOT_PROGRESS + +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_EARLY_INIT_F + +#define CONFIG_TMU_TIMER +#define CONFIG_SH_GPIO_PFC + +/* console */ +#undef CONFIG_SYS_CONSOLE_INFO_QUIET +#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE +#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE + +#define CONFIG_SYS_LONGHELP +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_PBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_BARGSIZE 512 +#define CONFIG_SYS_BAUDRATE_TABLE { 38400, 115200 } + +#define CONFIG_SYS_SDRAM_BASE (RCAR_GEN2_SDRAM_BASE) +#define CONFIG_SYS_SDRAM_SIZE (RCAR_GEN2_UBOOT_SDRAM_SIZE) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fc0) +#define CONFIG_NR_DRAM_BANKS 1 + +#define CONFIG_SYS_MONITOR_BASE 0x00000000 +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) +#define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) +#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) + +/* ENV setting */ +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_ADDR 0xC0000 + +/* Common ENV setting */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_ENV_SECT_SIZE (256 * 1024) +#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) +#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND (CONFIG_SYS_MONITOR_LEN) + +#endif /* __RCAR_GEN2_COMMON_H */
Common part of config for lager, koelsch, alt and gose board will be able to replace rcar-gen2-common.h.
Signed-off-by: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- include/configs/alt.h | 92 ++---------------------------------------- include/configs/gose.h | 93 ++---------------------------------------- include/configs/koelsch.h | 96 ++------------------------------------------ include/configs/lager.h | 100 +++------------------------------------------- 4 files changed, 18 insertions(+), 363 deletions(-)
diff --git a/include/configs/alt.h b/include/configs/alt.h index e99f100..5c8223c 100644 --- a/include/configs/alt.h +++ b/include/configs/alt.h @@ -11,58 +11,16 @@ #define __ALT_H
#undef DEBUG -#define CONFIG_ARMV7 #define CONFIG_R8A7794 #define CONFIG_RMOBILE_BOARD_STRING "Alt" -#define CONFIG_SH_GPIO_PFC
-#include <asm/arch/rmobile.h> - -#define CONFIG_CMD_EDITENV -#define CONFIG_CMD_SAVEENV -#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_DFL -#define CONFIG_CMD_SDRAM -#define CONFIG_CMD_RUN -#define CONFIG_CMD_LOADS -#define CONFIG_CMD_NET -#define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_NFS -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_USB -#define CONFIG_CMD_FAT -#define CONFIG_FAT_WRITE -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI +#include "rcar-gen2-common.h"
#if defined(CONFIG_RMOBILE_EXTRAM_BOOT) #define CONFIG_SYS_TEXT_BASE 0x70000000 #else #define CONFIG_SYS_TEXT_BASE 0xE6304000 #endif -#define CONFIG_SYS_THUMB_BUILD -#define CONFIG_SYS_GENERIC_BOARD - -#define CONFIG_CMDLINE_TAG -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG -#define CONFIG_CMDLINE_EDITING -#define CONFIG_OF_LIBFDT - -#define CONFIG_BAUDRATE 38400 -#define CONFIG_BOOTDELAY 3 -#define CONFIG_BOOTARGS "" - -#define CONFIG_VERSION_VARIABLE -#undef CONFIG_SHOW_BOOT_PROGRESS - -#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO -#define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_TMU_TIMER
#if defined(CONFIG_RMOBILE_EXTRAM_BOOT) #define CONFIG_SYS_INIT_SP_ADDR 0x7003FFFC @@ -74,41 +32,14 @@ (CONFIG_SYS_INIT_SP_ADDR + STACK_AREA_SIZE - 4)
/* MEMORY */ -#define ALT_SDRAM_BASE 0x40000000 -#define ALT_SDRAM_SIZE (1024u * 1024 * 1024) -#define ALT_UBOOT_SDRAM_SIZE (512 * 1024 * 1024) - -#define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_CBSIZE 256 -#define CONFIG_SYS_PBSIZE 256 -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_SYS_BARGSIZE 512 -#define CONFIG_SYS_BAUDRATE_TABLE { 38400, 115200 } +#define RCAR_GEN2_SDRAM_BASE 0x40000000 +#define RCAR_GEN2_SDRAM_SIZE (1024u * 1024 * 1024) +#define RCAR_GEN2_UBOOT_SDRAM_SIZE (512 * 1024 * 1024)
/* SCIF */ #define CONFIG_SCIF_CONSOLE #define CONFIG_CONS_SCIF2 #define CONFIG_SCIF_USE_EXT_CLK -#undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE - -#define CONFIG_SYS_MEMTEST_START (ALT_SDRAM_BASE) -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ - 504 * 1024 * 1024) -#undef CONFIG_SYS_ALT_MEMTEST -#undef CONFIG_SYS_MEMTEST_SCRATCH -#undef CONFIG_SYS_LOADS_BAUD_CHANGE - -#define CONFIG_SYS_SDRAM_BASE (ALT_SDRAM_BASE) -#define CONFIG_SYS_SDRAM_SIZE (ALT_UBOOT_SDRAM_SIZE) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fc0) -#define CONFIG_NR_DRAM_BANKS 1 - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) -#define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) -#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* FLASH */ #define CONFIG_SPI @@ -119,17 +50,6 @@ #define CONFIG_SPI_FLASH_QUAD #define CONFIG_SYS_NO_FLASH
-/* ENV setting */ -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SECT_SIZE (256 * 1024) -#define CONFIG_ENV_ADDR 0xC0000 -#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "bootm_low=0x40e00000\0" \ - "bootm_size=0x100000\0" \ - /* SH Ether */ #define CONFIG_NET_MULTI #define CONFIG_SH_ETHER @@ -169,10 +89,6 @@
#define CONFIG_SYS_I2C_POWERIC_ADDR 0x58 /* da9063 */
-/* Filesystems */ -#define CONFIG_DOS_PARTITION -#define CONFIG_SUPPORT_VFAT - /* USB */ #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI diff --git a/include/configs/gose.h b/include/configs/gose.h index 974df5a..c347e45 100644 --- a/include/configs/gose.h +++ b/include/configs/gose.h @@ -12,28 +12,8 @@ #undef DEBUG #define CONFIG_R8A7793 #define CONFIG_RMOBILE_BOARD_STRING "Gose" -#define CONFIG_SH_GPIO_PFC
-#include <asm/arch/rmobile.h> - -#define CONFIG_CMD_EDITENV -#define CONFIG_CMD_SAVEENV -#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_DFL -#define CONFIG_CMD_SDRAM -#define CONFIG_CMD_RUN -#define CONFIG_CMD_LOADS -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_CMD_I2C -#define CONFIG_CMD_NET -#define CONFIG_CMD_PING -#define CONFIG_CMD_NFS -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_MII -#define CONFIG_CMD_USB -#define CONFIG_CMD_FAT +#include "rcar-gen2-common.h"
#if defined(CONFIG_RMOBILE_EXTRAM_BOOT) #define CONFIG_SYS_TEXT_BASE 0x70000000 @@ -41,29 +21,6 @@ #define CONFIG_SYS_TEXT_BASE 0xE6304000 #endif
-#define CONFIG_SYS_THUMB_BUILD -#define CONFIG_SYS_GENERIC_BOARD - -#define CONFIG_CMDLINE_TAG -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG -#define CONFIG_CMDLINE_EDITING - -#define CONFIG_OF_LIBFDT - -#define CONFIG_BAUDRATE 38400 -#define CONFIG_BOOTDELAY 3 -#define CONFIG_BOOTARGS "" - -#define CONFIG_VERSION_VARIABLE -#undef CONFIG_SHOW_BOOT_PROGRESS - -#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO -#define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_TMU_TIMER - /* STACK */ #if defined(CONFIG_RMOBILE_EXTRAM_BOOT) #define CONFIG_SYS_INIT_SP_ADDR 0x7003FFFC @@ -76,41 +33,14 @@ (CONFIG_SYS_INIT_SP_ADDR + STACK_AREA_SIZE - 4)
/* MEMORY */ -#define GOSE_SDRAM_BASE 0x40000000 -#define GOSE_SDRAM_SIZE 0x40000000 -#define GOSE_UBOOT_SDRAM_SIZE 0x20000000 - -#define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_CBSIZE 256 -#define CONFIG_SYS_PBSIZE 256 -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_SYS_BARGSIZE 512 -#define CONFIG_SYS_BAUDRATE_TABLE { 38400, 115200 } +#define RCAR_GEN2_SDRAM_BASE 0x40000000 +#define RCAR_GEN2_SDRAM_SIZE 0x40000000 +#define RCAR_GEN2_UBOOT_SDRAM_SIZE 0x20000000
/* SCIF */ #define CONFIG_SCIF_CONSOLE #define CONFIG_CONS_SCIF0 #define CONFIG_SCIF_USE_EXT_CLK -#undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE - -#define CONFIG_SYS_MEMTEST_START (GOSE_SDRAM_BASE) -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ - 504 * 1024 * 1024) -#undef CONFIG_SYS_ALT_MEMTEST -#undef CONFIG_SYS_MEMTEST_SCRATCH -#undef CONFIG_SYS_LOADS_BAUD_CHANGE - -#define CONFIG_SYS_SDRAM_BASE (GOSE_SDRAM_BASE) -#define CONFIG_SYS_SDRAM_SIZE (GOSE_UBOOT_SDRAM_SIZE) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fc0) -#define CONFIG_NR_DRAM_BANKS 1 - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) -#define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) -#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* FLASH */ #define CONFIG_SYS_NO_FLASH @@ -119,16 +49,6 @@ #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_BAR #define CONFIG_SPI_FLASH_SPANSION -/* ENV setting */ -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_ADDR 0xC0000 - -/* Common ENV setting */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_SECT_SIZE (256 * 1024) -#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_SYS_MONITOR_LEN)
/* SH Ether */ #define CONFIG_NET_MULTI @@ -171,9 +91,4 @@ #define CONFIG_USB_EHCI_RMOBILE #define CONFIG_USB_MAX_CONTROLLER_COUNT 2
-/* File system */ -#define CONFIG_FAT_WRITE -#define CONFIG_DOS_PARTITION -#define CONFIG_SUPPORT_VFAT - #endif /* __GOSE_H */ diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h index f8294e9..bb98302 100644 --- a/include/configs/koelsch.h +++ b/include/configs/koelsch.h @@ -10,33 +10,10 @@ #define __KOELSCH_H
#undef DEBUG -#define CONFIG_ARMV7 #define CONFIG_R8A7791 #define CONFIG_RMOBILE_BOARD_STRING "Koelsch" -#define CONFIG_SH_GPIO_PFC
-#include <asm/arch/rmobile.h> - -#define CONFIG_CMD_EDITENV -#define CONFIG_CMD_SAVEENV -#define CONFIG_CMD_MEMORY -#define CONFIG_CMD_DFL -#define CONFIG_CMD_SDRAM -#define CONFIG_CMD_RUN -#define CONFIG_CMD_LOADS -#define CONFIG_CMD_NET -#define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_NFS -#define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_USB -#define CONFIG_CMD_FAT -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI - -#define CONFIG_FAT_WRITE -#define CONFIG_EXT4_WRITE +#include "rcar-gen2-common.h"
#if defined(CONFIG_RMOBILE_EXTRAM_BOOT) #define CONFIG_SYS_TEXT_BASE 0x70000000 @@ -44,34 +21,6 @@ #define CONFIG_SYS_TEXT_BASE 0xE6304000 #endif
-#define CONFIG_SYS_THUMB_BUILD -#define CONFIG_SYS_GENERIC_BOARD - -/* Support File sytems */ -#define CONFIG_DOS_PARTITION -#define CONFIG_SUPPORT_VFAT - - -#define CONFIG_CMDLINE_TAG -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG -#define CONFIG_CMDLINE_EDITING - -#define CONFIG_OF_LIBFDT - -#define CONFIG_BAUDRATE 38400 -#define CONFIG_BOOTDELAY 3 -#define CONFIG_BOOTARGS "" - -#define CONFIG_VERSION_VARIABLE -#undef CONFIG_SHOW_BOOT_PROGRESS - -#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO -#define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_TMU_TIMER - /* STACK */ #if defined(CONFIG_RMOBILE_EXTRAM_BOOT) #define CONFIG_SYS_INIT_SP_ADDR 0x7003FFFC @@ -84,41 +33,14 @@ (CONFIG_SYS_INIT_SP_ADDR + STACK_AREA_SIZE - 4)
/* MEMORY */ -#define KOELSCH_SDRAM_BASE 0x40000000 -#define KOELSCH_SDRAM_SIZE (2048u * 1024 * 1024) -#define KOELSCH_UBOOT_SDRAM_SIZE (512 * 1024 * 1024) - -#define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_CBSIZE 256 -#define CONFIG_SYS_PBSIZE 256 -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_SYS_BARGSIZE 512 -#define CONFIG_SYS_BAUDRATE_TABLE { 38400, 115200 } +#define RCAR_GEN2_SDRAM_BASE 0x40000000 +#define RCAR_GEN2_SDRAM_SIZE (2048u * 1024 * 1024) +#define RCAR_GEN2_UBOOT_SDRAM_SIZE (512 * 1024 * 1024)
/* SCIF */ #define CONFIG_SCIF_CONSOLE #define CONFIG_CONS_SCIF0 #define CONFIG_SCIF_USE_EXT_CLK -#undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE - -#define CONFIG_SYS_MEMTEST_START (KOELSCH_SDRAM_BASE) -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ - 504 * 1024 * 1024) -#undef CONFIG_SYS_ALT_MEMTEST -#undef CONFIG_SYS_MEMTEST_SCRATCH -#undef CONFIG_SYS_LOADS_BAUD_CHANGE - -#define CONFIG_SYS_SDRAM_BASE (KOELSCH_SDRAM_BASE) -#define CONFIG_SYS_SDRAM_SIZE (KOELSCH_UBOOT_SDRAM_SIZE) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fc0) -#define CONFIG_NR_DRAM_BANKS 1 - -#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) -#define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) -#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
/* FLASH */ #define CONFIG_SYS_NO_FLASH @@ -127,16 +49,6 @@ #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_BAR #define CONFIG_SPI_FLASH_SPANSION -/* ENV setting */ -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_ADDR 0xC0000 - -/* Common ENV setting */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_SECT_SIZE (256 * 1024) -#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_SYS_MONITOR_LEN)
/* SH Ether */ #define CONFIG_NET_MULTI diff --git a/include/configs/lager.h b/include/configs/lager.h index ae19fc5..37be38f 100644 --- a/include/configs/lager.h +++ b/include/configs/lager.h @@ -2,7 +2,7 @@ * include/configs/lager.h * This file is lager board configuration. * - * Copyright (C) 2013 Renesas Electronics Corporation + * Copyright (C) 2013, 2014 Renesas Electronics Corporation * * SPDX-License-Identifier: GPL-2.0 */ @@ -11,66 +11,16 @@ #define __LAGER_H
#undef DEBUG -#define CONFIG_ARMV7 #define CONFIG_R8A7790 #define CONFIG_RMOBILE_BOARD_STRING "Lager" -#define CONFIG_SH_GPIO_PFC
#if defined(CONFIG_RMOBILE_EXTRAM_BOOT) #define CONFIG_SYS_TEXT_BASE 0xB0000000 #else #define CONFIG_SYS_TEXT_BASE 0xE8080000 #endif -#define CONFIG_SYS_THUMB_BUILD -#define CONFIG_SYS_GENERIC_BOARD - -/* Support File sytems */ -#define CONFIG_DOS_PARTITION -#define CONFIG_SUPPORT_VFAT - -#define CONFIG_CMDLINE_TAG -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG -#define CONFIG_CMDLINE_EDITING -#define CONFIG_OF_LIBFDT - -/* #define CONFIG_OF_LIBFDT */ - -#define CONFIG_BAUDRATE 38400 -#define CONFIG_BOOTDELAY 3 -#define CONFIG_BOOTARGS "" - -#define CONFIG_VERSION_VARIABLE -#undef CONFIG_SHOW_BOOT_PROGRESS - -#define CONFIG_ARCH_CPU_INIT -#define CONFIG_DISPLAY_CPUINFO -#define CONFIG_DISPLAY_BOARDINFO -#define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_TMU_TIMER
/* STACK */ #if defined(CONFIGF_RMOBILE_EXTRAM_BOOT) @@ -83,43 +33,16 @@ (CONFIG_SYS_INIT_SP_ADDR + STACK_AREA_SIZE - 4)
/* MEMORY */ -#define LAGER_SDRAM_BASE 0x40000000 -#define LAGER_SDRAM_SIZE (2048u * 1024 * 1024) -#define LAGER_UBOOT_SDRAM_SIZE (512 * 1024 * 1024) - -#define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_CBSIZE 256 -#define CONFIG_SYS_PBSIZE 256 -#define CONFIG_SYS_MAXARGS 16 -#define CONFIG_SYS_BARGSIZE 512 -#define CONFIG_SYS_BAUDRATE_TABLE { 38400, 115200 } +#define RCAR_GEN2_SDRAM_BASE 0x40000000 +#define RCAR_GEN2_SDRAM_SIZE (2048u * 1024 * 1024) +#define RCAR_GEN2_UBOOT_SDRAM_SIZE (512 * 1024 * 1024)
/* SCIF */ #define CONFIG_SCIF_CONSOLE #define CONFIG_CONS_SCIF0 #define CONFIG_SCIF_USE_EXT_CLK -#undef CONFIG_SYS_CONSOLE_INFO_QUIET -#undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE -#undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE - -#define CONFIG_SYS_MEMTEST_START (LAGER_SDRAM_BASE) -#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ - 504 * 1024 * 1024) -#undef CONFIG_SYS_ALT_MEMTEST -#undef CONFIG_SYS_MEMTEST_SCRATCH -#undef CONFIG_SYS_LOADS_BAUD_CHANGE - -#define CONFIG_SYS_SDRAM_BASE (LAGER_SDRAM_BASE) -#define CONFIG_SYS_SDRAM_SIZE (LAGER_UBOOT_SDRAM_SIZE) -#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fc0) -#define CONFIG_NR_DRAM_BANKS 1
-#define CONFIG_SYS_MONITOR_BASE 0x00000000 -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) -#define CONFIG_SYS_MALLOC_LEN (1 * 1024 * 1024) -#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) - -/* USE SPI */ +/* SPI */ #define CONFIG_SPI #define CONFIG_SPI_FLASH_BAR #define CONFIG_SH_QSPI @@ -127,17 +50,6 @@ #define CONFIG_SPI_FLASH_SPANSION #define CONFIG_SYS_NO_FLASH
-/* ENV setting */ -#define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_ADDR 0xC0000 - -/* Common ENV setting */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_ENV_SECT_SIZE (256 * 1024) -#define CONFIG_ENV_OFFSET (CONFIG_ENV_ADDR) -#define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_SYS_MONITOR_LEN) - /* SH Ether */ #define CONFIG_NET_MULTI #define CONFIG_SH_ETHER
Nobuhiro Iwamatsu
