[PATCH v3] CI: gitlab: Collect pytest artifacts
Copy build artifacts for all test.py tests, so they show up in artifacts storage for later inspection. The test.py tests output in CI is basically useless, but it is far more useful in the html output for analysis and debugging.
Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com Suggested-by: Simon Glass sjg@chromium.org Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- V2: - Drop bogus comment - Add RB from Tom and Simon V3: - Add when:always to always collect artifacts, even in case of failure - Move artifact copy into after_script --- .gitlab-ci.yml | 16 +++++++--------- 1 file changed, 7 insertions(+), 9 deletions(-)
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 52d31a0e4ff..bd4ab576d56 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -30,6 +30,7 @@ stages: fi
after_script: + - cp -v /tmp/${TEST_PY_BD}/*.{html,css} . - rm -rf /tmp/uboot-test-hooks /tmp/venv script: # If we've been asked to use clang only do one configuration. @@ -76,10 +77,12 @@ stages: ./test/py/test.py -ra --bd ${TEST_PY_BD} ${TEST_PY_ID} ${TEST_PY_TEST_SPEC:+"-k ${TEST_PY_TEST_SPEC}"} --build-dir "$UBOOT_TRAVIS_BUILD_DIR" - # It seems that the files in /tmp go away, so copy out what we need - - if [[ "${TEST_PY_BD}" == "coreboot" ]]; then - cp -v /tmp/coreboot/*.{html,css} .; - fi + artifacts: + when: always + paths: + - "*.html" + - "*.css" + expire_in: 1 week
build all 32bit ARM platforms: stage: world build @@ -471,9 +474,4 @@ coreboot test.py: TEST_PY_BD: "coreboot" TEST_PY_TEST_SPEC: "not sleep" TEST_PY_ID: "--id qemu" - artifacts: - paths: - - "*.html" - - "*.css" - expire_in: 1 week <<: *buildman_and_testpy_dfn
