[U-Boot] [PATCH 1/6] Add MS7206SE support.
Hi. This patch series add to Renesas MS7206SE board support. And SH2A targets various update. Please comment.
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- board/renesas/ms7206se/Makefile | 10 +++ board/renesas/ms7206se/lowlevel_init.S | 124 +++++++++++++++++++++++++++++++++ board/renesas/ms7206se/ms7206se.c | 43 ++++++++++++ boards.cfg | 1 + drivers/net/smc91111.h | 31 ++++++++- include/configs/ms7206se.h | 95 +++++++++++++++++++++++++ 6 files changed, 303 insertions(+), 1 deletion(-) create mode 100644 board/renesas/ms7206se/Makefile create mode 100644 board/renesas/ms7206se/lowlevel_init.S create mode 100644 board/renesas/ms7206se/ms7206se.c create mode 100644 include/configs/ms7206se.h
diff --git a/board/renesas/ms7206se/Makefile b/board/renesas/ms7206se/Makefile new file mode 100644 index 0000000..eed3769 --- /dev/null +++ b/board/renesas/ms7206se/Makefile @@ -0,0 +1,10 @@ +# +# Copyright (C) 2013 Yoshinori Sato ysato@users.sourceforge.jp +# +# u-boot/board/renesas/ms7619se/Makefile +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := ms7206se.o +obj-y += lowlevel_init.o diff --git a/board/renesas/ms7206se/lowlevel_init.S b/board/renesas/ms7206se/lowlevel_init.S new file mode 100644 index 0000000..4e1e70c --- /dev/null +++ b/board/renesas/ms7206se/lowlevel_init.S @@ -0,0 +1,124 @@ +/* + * Copyright (C) 2013 Yoshinori Sato ysato@users.sourceforge.jp + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <version.h> + +#include <asm/processor.h> +#include <asm/macro.h> +#define INTMSK0 0x11800000 + + .global lowlevel_init + + .text + .align 2 + +lowlevel_init: + mova CPG_settings_table,r0 +1: mov.l @r0+,r3 // Address (or zero) + tst r3,r3 + bt 2f + mov.l @r0+,r1 // data + bra 1b + mov.w r1,@r3 +2: + mov.l $mclkcr,r0 // MCLKCR setting + mov #0x40,r1 + mov.b r1,@r0 + + // Set up the Bus Controler + mova BSC_settings_table,r0 +5: mov.l @r0+,r3 // Address (or zero) + tst r3,r3 + bt 6f + mov.l @r0+,r1 // data + bra 5b + mov.l r1,@r3 + +6: + mov.l $delay_count,r0 +7: + dt r0 + bf 7b + + mov.l $SDMR,r1 // Turns on SDRAM controller + mov.l $SDMR_val,r2 + mov.l r2,@r1 + + // Set up the Pin Function Controler + mova PFC_settings_table,r0 +3: mov.l @r0+,r3 // Address (or zero) + tst r3,r3 + bt 4f + mov.l @r0+,r1 // data + bra 3b + mov.w r1,@r3 +4: + rts/n + + .align 4 +$delay_count: + .long 2000 +$SDMR: .long 0xfffc5880 +$SDMR_val: + .long 0 + +$mclkcr: + .long MCLKCR + +CPG_settings_table: + .long WTCSR,0xA500 + .long WTCNT,0x5A00 + .long WTCSR,0xA51E + .long FRQCR, 0x120c /* input:33.3333MHz I:B:P=6:2:1=200MHz:66MHz:33MHz */ + .long 0 + +BSC_settings_table: + # Settings from Hitachi docs for SE7206 + .long CMNCR, 0x00001010 + .long CS0BCR, 0x10000600 + .long CS2BCR, 0x10000600 + .long CS4BCR, 0x10000400 + .long CS5BCR, 0x10000400 + .long CS3BCR, 0x10004600 + .long CS0WCR, 0x00000380; /* wait:4cycle */ + .long CS2WCR, 0x00000380; + .long CS4WCR, 0x00000380; + .long CS5WCR, 0x00000380; + .long CS3WCR, 0x00004892; /* pre->actv:1cycle, actv->read/write:2cycle, write->pre:1cycle, ref->actv:4cycle */ + .long SDCR, 0x00000811; + .long RTCNT, 0xa55a0083; + .long RTCOR, 0xa55a0083; + .long RTCSR, 0xa55a0008; /* reflesh count=B��/4 */ + .long 0 + +PFC_settings_table: + .long PACRH3, 0x0022 + .long PACRH2, 0x1111 + .long PACRH1, 0x1115 + .long PACRL4, 0x1111 + .long PACRL3, 0x1125 + .long PACRL2, 0x2255 + .long PACRL1, 0x5500 + .long PBCR3, 0x0022 + .long PBCR2, 0x2244 + .long PBCR1, 0x1111 + .long PCCRL1, 0x1111 + .long PDCRH4, 0x1111 + .long PDCRH3, 0x1111 + .long PDCRH2, 0x1111 + .long PDCRH1, 0x1111 + .long PDCRL4, 0x1111 + .long PDCRL3, 0x1111 + .long PECRH1, 0x0005 + .long PECRL4, 0x3223 + .long PECRL3, 0x3030 + .long PECRL2, 0x3550 + .long IFCR, 0x0003 + .long 0 + +$INTMSK0: + .long INTMSK0 diff --git a/board/renesas/ms7206se/ms7206se.c b/board/renesas/ms7206se/ms7206se.c new file mode 100644 index 0000000..45906fb --- /dev/null +++ b/board/renesas/ms7206se/ms7206se.c @@ -0,0 +1,43 @@ +/* + * Copyright (C) 2013 Yoshinori Sato ysato@users.sourceforge.jp + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <net.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/processor.h> + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + puts("BOARD: Renesas Technology MS7206SE\n"); + return 0; +} + +int board_init(void) +{ + return 0; +} + +int dram_init(void) +{ + gd->bd->bi_memstart = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_memsize = CONFIG_SYS_SDRAM_SIZE; + printf("DRAM: %dMB\n", CONFIG_SYS_SDRAM_SIZE / (1024 * 1024)); + return 0; +} + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_SMC91111 + rc = smc91111_initialize(0, CONFIG_SMC91111_BASE); +#endif + return rc; +} +#endif diff --git a/boards.cfg b/boards.cfg index c97c4bd..a56f196 100644 --- a/boards.cfg +++ b/boards.cfg @@ -1203,6 +1203,7 @@ Active powerpc ppc4xx - xilinx ppc440-generic Active powerpc ppc4xx - xilinx ppc440-generic xilinx-ppc440-generic_flash xilinx-ppc440-generic:SYS_TEXT_BASE=0xF7F60000,RESET_VECTOR_ADDRESS=0xF7FFFFFC Ricardo Ribalda ricardo.ribalda@uam.es Active sandbox sandbox - sandbox sandbox sandbox - Simon Glass sjg@chromium.org Active sh sh2 - renesas rsk7203 rsk7203 - Nobuhiro Iwamatsu iwamatsu.nobuhiro@renesas.com:Nobuhiro Iwamatsu iwamatsu@nigauri.org +Active sh sh2 - renesas ms7206se ms7206se - Yoshinori Sato ysato@users.sourceforge.jp Active sh sh2 - renesas rsk7264 rsk7264 - Phil Edworthy phil.edworthy@renesas.com Active sh sh2 - renesas rsk7269 rsk7269 - - Active sh sh3 - - mpr2 mpr2 - Mark Jonas mark.jonas@de.bosch.com diff --git a/drivers/net/smc91111.h b/drivers/net/smc91111.h index 9deee9b..513a67d 100644 --- a/drivers/net/smc91111.h +++ b/drivers/net/smc91111.h @@ -236,7 +236,36 @@ struct smc91111_priv{ *(__b2 + __i) = SMC_inb((a),(r)); \ }; \ }while(0) - +#elif defined(CONFIG_MS7206SE) +#define SWAB(x) ({ word __x = x; ((__x << 8)|(__x >> 8));}) +#define SMC_inw(a,r) *((volatile word *)((a)->iobase + (r))) +#define SMC_inb(a,r) (*((volatile byte *)((a)->iobase + ((r) ^ 0x01)))) +#define SMC_insw(a,r,b,l) \ + do { \ + int __i; \ + word *__b2 = (word *)(b); \ + for (__i = 0; __i < (l); __i++) { \ + *__b2++ = SWAB(SMC_inw(a, r)); \ + } \ + } while(0); +#define SMC_outw(a,d,r) (*((volatile word *)((a)->iobase+(r))) = d) +#define SMC_outb(a,d,r) ({ word __d = (byte)(d); \ + word __w = SMC_inw((a),((r)&(~1))); \ + if(((r) & 1)) \ + __w = (__w & 0x00ff) | (__d << 8); \ + else \ + __w = (__w & 0xff00) | (__d); \ + SMC_outw((a),__w,((r)&(~1))); \ + }) +#define SMC_outsw(a,r,b,l) \ + do { \ + int __i; \ + word *__b2 = (word *)(b); \ + for (__i = 0; __i < (l); __i++) { \ + SMC_outw(a, SWAB(*__b2), r); \ + __b2++; \ + } \ + } while(0); #else /* if not CONFIG_CPU_PXA25X and not CONFIG_LEON */
#ifndef CONFIG_SMC_USE_IOFUNCS /* these macros don't work on some boards */ diff --git a/include/configs/ms7206se.h b/include/configs/ms7206se.h new file mode 100644 index 0000000..805044c --- /dev/null +++ b/include/configs/ms7206se.h @@ -0,0 +1,95 @@ +/* + * Configuation settings for the Renesas Technology MS7206SE + * + * Copyright (C) 2013 Yoshinori Sato ysato@users.sourceforge.jp + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __MS7206SE_H +#define __MS7206SE + +#undef DEBUG +#define CONFIG_SH 1 +#define CONFIG_SH2 1 +#define CONFIG_SH2A 1 +#define CONFIG_CPU_SH7206 1 +#define CONFIG_MS7206SE 1 + +#define CONFIG_CMD_FLASH +#define CONFIG_CMD_NET +#define CONFIG_CMD_SAVEENV +#define CONFIG_CMD_SDRAM +#define CONFIG_CMD_MEMORY +#define CONFIG_CMD_MEMTEST +#define CONFIG_CMD_CACHE + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTARGS "console=ttySC3,115200" +#define CONFIG_LOADADDR 0x0C100000 /* MS7206SE01_SDRAM_BASE + 1MB */ + +#define CONFIG_VERSION_VARIABLE +#undef CONFIG_SHOW_BOOT_PROGRESS + +/* MEMORY */ +#define MS7206SE_SDRAM_BASE 0x0C000000 +#define MS7206SE_FLASH_BASE_1 0x20000000 /* Non cache */ +#define MS7206SE_FLASH_BANK_SIZE (16 * 1024 * 1024) + +#define CONFIG_SYS_TEXT_BASE 0x0C7C0000 +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 256 /* Buffer size for input from the Console */ +#define CONFIG_SYS_PBSIZE 256 /* Buffer size for Console output */ +#define CONFIG_SYS_MAXARGS 16 /* max args accepted for monitor commands */ +/* Buffer size for Boot Arguments passed to kernel */ +#define CONFIG_SYS_BARGSIZE 512 +/* List of legal baudrate settings for this board */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 3840, 57600, 115200 } + +/* SCIF */ +#define CONFIG_SCIF_CONSOLE 1 +#define CONFIG_CONS_SCIF3 1 + +#define CONFIG_SYS_MEMTEST_START CONFIG_LOADADDR +#define CONFIG_SYS_MEMTEST_END (CONFIG_LOADADDR + (63 * 1024 * 1024)) + +#define CONFIG_SYS_SDRAM_BASE MS7206SE_SDRAM_BASE +#define CONFIG_SYS_SDRAM_SIZE (64 * 1024 * 1024) + +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 1024 * 1024) +#define CONFIG_SYS_MONITOR_BASE MS7206SE_FLASH_BASE_1 +#define CONFIG_SYS_MONITOR_LEN (128 * 1024) +#define CONFIG_SYS_MALLOC_LEN (256 * 1024) +#define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024) + +/* FLASH */ +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#undef CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */ +#define CONFIG_SYS_FLASH_BASE MS7206SE_FLASH_BASE_1 +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } +#define CONFIG_SYS_MAX_FLASH_SECT 142 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 + +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_SECT_SIZE (128 * 1024) +#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_SYS_FLASH_ERASE_TOUT 12000 +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 + +/* Board Clock */ +#define CONFIG_SYS_CLK_FREQ 33333333 +#define CONFIG_SH_TMU_CLK_FREQ CONFIG_SYS_CLK_FREQ +#define CONFIG_SH_SCIF_CLK_FREQ CONFIG_SYS_CLK_FREQ +#define CMT_CLK_DIVIDER 32 /* 8 (default), 32, 128 or 512 */ +#define CONFIG_SH_CMT_CLK_FREQ (CONFIG_SYS_CLK_FREQ / CMT_CLK_DIVIDER) + +/* Network interface */ +#define CONFIG_SMC91111 +#define CONFIG_SMC91111_BASE (0x30000000) + +#endif /* __MS7206SE_H */
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- arch/sh/cpu/sh2/Makefile | 6 ++ arch/sh/cpu/sh2/cache-sh2a.c | 143 ++++++++++++++++++++++++++++++++++++++++++ arch/sh/cpu/sh2/cpu.c | 31 --------- arch/sh/cpu/sh2/nocache.c | 37 +++++++++++ arch/sh/include/asm/cpu_sh2.h | 9 --- 5 files changed, 186 insertions(+), 40 deletions(-) create mode 100644 arch/sh/cpu/sh2/cache-sh2a.c create mode 100644 arch/sh/cpu/sh2/nocache.c
diff --git a/arch/sh/cpu/sh2/Makefile b/arch/sh/cpu/sh2/Makefile index a19ed5e..6a11448 100644 --- a/arch/sh/cpu/sh2/Makefile +++ b/arch/sh/cpu/sh2/Makefile @@ -4,9 +4,15 @@ # # Copyright (C) 2007,2008 Nobuhiro Iwamatsu iwamatsu@nigauri.org # Copyright (C) 2008 Renesas Solutions Corp. +# Copyright (C) 2013 Yoshinori Sato ysato@users.sourceforge.jp # # SPDX-License-Identifier: GPL-2.0+ #
extra-y = start.o obj-y = cpu.o interrupts.o watchdog.o +ifdef CONFIG_SH2A +obj-y += cache-sh2a.o +else +obj-y += nocache.o +endif diff --git a/arch/sh/cpu/sh2/cache-sh2a.c b/arch/sh/cpu/sh2/cache-sh2a.c new file mode 100644 index 0000000..a7bf5bc --- /dev/null +++ b/arch/sh/cpu/sh2/cache-sh2a.c @@ -0,0 +1,143 @@ +/* + * Copyright (C) 2013 Yoshinori Sato ysato@users.sourceforge.jp + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> +#include <asm/processor.h> +#include <asm/io.h> + +/* + * Jump to cache disabled area + * When handling caches, we need to do it from non-cache area. + */ +#define jump_to_uncacheable() \ +do { \ + unsigned long __dummy; \ + __asm__ __volatile__( \ + "mov.l 1f, %0\n\t" \ + "or %1, %0\n\t" \ + "jmp @%0\n\t" \ + " nop\n\t" \ + ".balign 4\n" \ + "1: .long 2f\n" \ + "2:" \ + : "=&r" (__dummy) \ + : "r" (0x20000000)); \ +} while (0) + +/* + * Back to cache area. + */ +#define back_to_cacheable() \ +do { \ + unsigned long __dummy; \ + __asm__ __volatile__( \ + "nop;nop;nop;nop;nop;nop;nop\n\t" \ + "mov.l 1f, %0\n\t" \ + "jmp @%0\n\t" \ + " nop\n\t" \ + ".balign 4\n" \ + "1: .long 2f\n" \ + "2:" \ + : "=&r" (__dummy)); \ +} while (0) + +#define CACHE_OC_NUM_ENTRIES 128 +#define CACHE_OC_NUM_WAYS 4 +#define CACHE_OC_ADDRESS_ARRAY 0xf0800000 +#define CACHE_OC_WAY_SHIFT 11 +#define CACHE_OC_ENTRY_SHIFT 2 +#define CACHE_UPDATED 0x02 + +static inline void cache_wback_all(void) +{ + unsigned long addr, data, i, j; + + for (i = 0; i < CACHE_OC_NUM_ENTRIES; i++){ + for (j = 0; j < CACHE_OC_NUM_WAYS; j++) { + addr = CACHE_OC_ADDRESS_ARRAY | (j << CACHE_OC_WAY_SHIFT) + | (i << CACHE_OC_ENTRY_SHIFT); + data = inl(addr); + if (data & CACHE_UPDATED) { + data &= ~CACHE_UPDATED; + outl(data, addr); + } + } + } +} +void flush_cache(unsigned long addr, unsigned long size) +{ + unsigned long entry; + unsigned long tag; + size = (size + 3) & ~3; + jump_to_uncacheable(); + while(size > 0) { + entry = addr & 0x000003ff0; + tag = addr & 0x1ffff0000; + /* I-Cache flush */ + outl(tag, 0xf0000008 | entry); + /* D-Cache flush with wb */ + outl(tag, 0xf0800008 | entry); + addr += 4; + size -= 4; + } + back_to_cacheable(); +} + +void icache_enable(void) +{ + unsigned long ccr; + ccr = readl(CCR1); + ccr |= 0x00000900; + jump_to_uncacheable(); + writel(ccr, CCR1); + back_to_cacheable(); +} + +void icache_disable(void) +{ + unsigned long ccr; + ccr = readl(CCR1); + ccr &= ~0x00000100; + jump_to_uncacheable(); + writel(ccr, CCR1); + back_to_cacheable(); +} + +int icache_status(void) +{ + unsigned long ccr; + ccr = readl(CCR1); + return ((ccr & 0x00000100) != 0); +} + +void dcache_enable(void) +{ + unsigned long ccr; + ccr = readl(CCR1); + ccr |= 0x00000009; + jump_to_uncacheable(); + writel(ccr, CCR1); + back_to_cacheable(); +} + +void dcache_disable(void) +{ + unsigned long ccr; + ccr = readl(CCR1); + ccr &= ~0x00000001; + jump_to_uncacheable(); + cache_wback_all(); + writel(ccr, CCR1); + back_to_cacheable(); +} + +int dcache_status(void) +{ + unsigned long ccr; + ccr = readl(CCR1); + return ((ccr & 0x00000001) != 0); +} diff --git a/arch/sh/cpu/sh2/cpu.c b/arch/sh/cpu/sh2/cpu.c index a2f856f..b401d08 100644 --- a/arch/sh/cpu/sh2/cpu.c +++ b/arch/sh/cpu/sh2/cpu.c @@ -52,34 +52,3 @@ int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) reset_cpu(0); return 0; } - -void flush_cache(unsigned long addr, unsigned long size) -{ - -} - -void icache_enable(void) -{ -} - -void icache_disable(void) -{ -} - -int icache_status(void) -{ - return 0; -} - -void dcache_enable(void) -{ -} - -void dcache_disable(void) -{ -} - -int dcache_status(void) -{ - return 0; -} diff --git a/arch/sh/cpu/sh2/nocache.c b/arch/sh/cpu/sh2/nocache.c new file mode 100644 index 0000000..06b7f4c --- /dev/null +++ b/arch/sh/cpu/sh2/nocache.c @@ -0,0 +1,37 @@ +/* + * Copyright (C) 2013 Yoshinori Sato ysato@users.sourceforge.jp + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* dummy cache control functions */ +void flush_cache(unsigned long addr, unsigned long size) +{ + +} + +void icache_enable(void) +{ +} + +void icache_disable(void) +{ +} + +int icache_status(void) +{ + return 0; +} + +void dcache_enable(void) +{ +} + +void dcache_disable(void) +{ +} + +int dcache_status(void) +{ + return 0; +} diff --git a/arch/sh/include/asm/cpu_sh2.h b/arch/sh/include/asm/cpu_sh2.h index 18a0f0b..b67c093 100644 --- a/arch/sh/include/asm/cpu_sh2.h +++ b/arch/sh/include/asm/cpu_sh2.h @@ -8,15 +8,6 @@ #ifndef _ASM_CPU_SH2_H_ #define _ASM_CPU_SH2_H_
-/* cache control */ -#define CCR_CACHE_STOP 0x00000008 -#define CCR_CACHE_ENABLE 0x00000005 -#define CCR_CACHE_ICI 0x00000008 - -#define CACHE_OC_ADDRESS_ARRAY 0xf0000000 -#define CACHE_OC_WAY_SHIFT 13 -#define CACHE_OC_NUM_ENTRIES 256 -#define CACHE_OC_ENTRY_SHIFT 4
#if defined(CONFIG_CPU_SH7203) # include <asm/cpu_sh7203.h>
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- arch/sh/cpu/sh2/start.S | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/sh/cpu/sh2/start.S b/arch/sh/cpu/sh2/start.S index 5b92a01..efda8e2 100644 --- a/arch/sh/cpu/sh2/start.S +++ b/arch/sh/cpu/sh2/start.S @@ -14,7 +14,7 @@
.global _start _sh_start: - .long 0x00000010 /* Ppower ON reset PC*/ + .long 0x00000010 /* Power ON reset PC*/ .long 0x00000000 .long 0x00000010 /* Manual reset PC */ .long 0x00000000
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- arch/sh/cpu/sh2/cpu.c | 27 ++++++++++++--------------- arch/sh/include/asm/cpu_sh2.h | 4 +++- arch/sh/include/asm/cpu_sh2a.h | 19 +++++++++++++++++++ 3 files changed, 34 insertions(+), 16 deletions(-) create mode 100644 arch/sh/include/asm/cpu_sh2a.h
diff --git a/arch/sh/cpu/sh2/cpu.c b/arch/sh/cpu/sh2/cpu.c index b401d08..0a6a58b 100644 --- a/arch/sh/cpu/sh2/cpu.c +++ b/arch/sh/cpu/sh2/cpu.c @@ -10,16 +10,17 @@ #include <asm/processor.h> #include <asm/io.h>
-#define STBCR4 0xFFFE040C -#define cmt_clock_enable() do {\ - writeb(readb(STBCR4) & ~0x04, STBCR4);\ - } while (0) -#define scif0_enable() do {\ - writeb(readb(STBCR4) & ~0x80, STBCR4);\ - } while (0) -#define scif3_enable() do {\ - writeb(readb(STBCR4) & ~0x10, STBCR4);\ - } while (0) +#if defined(CONFIG_CONS_SCIF0) +# define CH 0 +#elif defined(CONFIG_CONS_SCIF1) +# define CH 1 +#elif defined(CONFIG_CONS_SCIF2) +# define CH 2 +#elif defined(CONFIG_CONS_SCIF3) +# define CH 3 +#else +# error "Default SCIF doesn't set....." +#endif
int checkcpu(void) { @@ -30,11 +31,7 @@ int checkcpu(void) int cpu_init(void) { /* SCIF enable */ -#if defined(CONFIG_CONS_SCIF3) - scif3_enable(); -#else - scif0_enable(); -#endif + scif_enable(CH); /* CMT clock enable */ cmt_clock_enable() ; return 0; diff --git a/arch/sh/include/asm/cpu_sh2.h b/arch/sh/include/asm/cpu_sh2.h index b67c093..62b5179 100644 --- a/arch/sh/include/asm/cpu_sh2.h +++ b/arch/sh/include/asm/cpu_sh2.h @@ -8,7 +8,9 @@ #ifndef _ASM_CPU_SH2_H_ #define _ASM_CPU_SH2_H_
- +#if defined(CONFIG_SH2A) +# include <asm/cpu_sh2a.h> +#endif #if defined(CONFIG_CPU_SH7203) # include <asm/cpu_sh7203.h> #elif defined(CONFIG_CPU_SH7264) diff --git a/arch/sh/include/asm/cpu_sh2a.h b/arch/sh/include/asm/cpu_sh2a.h new file mode 100644 index 0000000..6de9729 --- /dev/null +++ b/arch/sh/include/asm/cpu_sh2a.h @@ -0,0 +1,19 @@ +#ifndef _ASM_CPU_SH2A_H_ +#define _ASM_CPU_SH2A_H_ + +/* module enable */ +#define STBCR4 0xFFFE040C +#define scif_enable(ch) \ +do { \ + if (ch < 4) { \ + unsigned char mask = 1 << (7 - ch); \ + writeb((readb(STBCR4) & ~mask), STBCR4); \ + } \ +} while (0) + +#define cmt_clock_enable() \ +do { \ + writeb((readb(STBCR4) & ~0x04), STBCR4); \ +} while (0) + +#endif
Hi, Sato-san.
I found some coding mistakes. Could you check by checkpatch.pl?
And please add to subject so that it turns out that it is the patch of sh/sh2, e.g. "sh: sh2: module enabler cleanup"
Best regards, Nobuhiro
2014-02-11 21:24 GMT+09:00 Yoshinori Sato ysato@users.sourceforge.jp:
} while (0)
} while (0)
} while (0)
scif3_enable();
-#else
scif0_enable();
-#endif
if (ch < 4) { \
+} while (0)
+} while (0)
1.8.5.3
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- arch/sh/include/asm/cpu_sh2.h | 2 ++ arch/sh/include/asm/cpu_sh7206.h | 75 ++++++++++++++++++++++++++++++++++++++++ 2 files changed, 77 insertions(+) create mode 100644 arch/sh/include/asm/cpu_sh7206.h
diff --git a/arch/sh/include/asm/cpu_sh2.h b/arch/sh/include/asm/cpu_sh2.h index 62b5179..deadece 100644 --- a/arch/sh/include/asm/cpu_sh2.h +++ b/arch/sh/include/asm/cpu_sh2.h @@ -13,6 +13,8 @@ #endif #if defined(CONFIG_CPU_SH7203) # include <asm/cpu_sh7203.h> +#elif defined(CONFIG_CPU_SH7206) +# include <asm/cpu_sh7206.h> #elif defined(CONFIG_CPU_SH7264) # include <asm/cpu_sh7264.h> #elif defined(CONFIG_CPU_SH7269) diff --git a/arch/sh/include/asm/cpu_sh7206.h b/arch/sh/include/asm/cpu_sh7206.h new file mode 100644 index 0000000..7cfdd31 --- /dev/null +++ b/arch/sh/include/asm/cpu_sh7206.h @@ -0,0 +1,75 @@ +#ifndef _ASM_CPU_SH7206_H_ +#define _ASM_CPU_SH7206_H_ + +/* Cache */ +#define CCR1 0xFFFC1000 +#define CCR2 0xFFFC1004 +#define CCR CCR1 + +#define CMNCR 0xFFFC0000 +#define CS0BCR 0xFFFC0004 +#define CS2BCR 0xFFFC000C +#define CS3BCR 0xFFFC0010 +#define CS4BCR 0xFFFC0014 +#define CS5BCR 0xFFFC0018 +#define CS0WCR 0xFFFC0028 +#define CS2WCR 0xFFFC0030 +#define CS3WCR 0xFFFC0034 +#define CS4WCR 0xFFFC0038 +#define CS5WCR 0xFFFC003C +#define SDCR 0xFFFC004C +#define RTCSR 0xFFFC0050 +#define RTCNT 0xFFFC0054 +#define RTCOR 0xFFFC0058 + +/* SCIF */ +#define SCSMR_0 0xFFFE8000 +#define SCSMR_1 0xFFFE8800 +#define SCSMR_2 0xFFFE9000 +#define SCSMR_3 0xFFFE9800 +#define SCIF0_BASE SCSMR_0 +#define SCIF1_BASE SCSMR_1 +#define SCIF2_BASE SCSMR_2 +#define SCIF3_BASE SCSMR_3 + +/* Timer(CMT) */ +#define CMSTR 0xFFFEC000 +#define CMCSR_0 0xFFFEC002 +#define CMCNT_0 0xFFFEC004 +#define CMCOR_0 0xFFFEC006 +#define CMCSR_1 0xFFFEC008 +#define CMCNT_1 0xFFFEC00A +#define CMCOR_1 0xFFFEC00C + +/* PFC */ +#define PACRH3 0xFFFE380A +#define PACRH2 0xFFFE380C +#define PACRH1 0xFFFE380E +#define PACRL4 0xFFFE3810 +#define PACRL3 0xFFFE3812 +#define PACRL2 0xFFFE3814 +#define PACRL1 0xFFFE3816 +#define PBCR3 0xFFFE3892 +#define PBCR2 0xFFFE3894 +#define PBCR1 0xFFFE3896 +#define PCCRL1 0xFFFE3916 +#define PDCRH4 0xFFFE3988 +#define PDCRH3 0xFFFE398A +#define PDCRH2 0xFFFE398C +#define PDCRH1 0xFFFE398E +#define PDCRL4 0xFFFE3990 +#define PDCRL3 0xFFFE3992 +#define PECRH1 0xFFFE3A0E +#define PECRL4 0xFFFE3A10 +#define PECRL3 0xFFFE3A12 +#define PECRL2 0xFFFE3A14 +#define IFCR 0xFFFE3A22 + +/* On chip oscillator circuits */ +#define FRQCR 0xFFFE0010 +#define MCLKCR 0xFFFE0410 +/* Watchdog timer */ +#define WTCNT 0xFFFE0002 +#define WTCSR 0xFFFE0000 + +#endif /* _ASM_CPU_SH7206_H_ */
Signed-off-by: Yoshinori Sato ysato@users.sourceforge.jp --- arch/sh/config.mk | 3 +++ arch/sh/cpu/sh2/config.mk | 4 +++- 2 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/arch/sh/config.mk b/arch/sh/config.mk index 758c070..abd419a 100644 --- a/arch/sh/config.mk +++ b/arch/sh/config.mk @@ -11,6 +11,9 @@ CONFIG_STANDALONE_LOAD_ADDR ?= 0x8C000000 ifeq ($(CPU),sh2) CONFIG_STANDALONE_LOAD_ADDR += -EB endif +ifeq ($(CPU),sh2a) +CONFIG_STANDALONE_LOAD_ADDR += -m2a-nofpu +endif
PLATFORM_CPPFLAGS += -DCONFIG_SH -D__SH__ PLATFORM_LDFLAGS += -e $(CONFIG_SYS_TEXT_BASE) --defsym reloc_dst=$(CONFIG_SYS_TEXT_BASE) diff --git a/arch/sh/cpu/sh2/config.mk b/arch/sh/cpu/sh2/config.mk index 69273b4..a012162 100644 --- a/arch/sh/cpu/sh2/config.mk +++ b/arch/sh/cpu/sh2/config.mk @@ -8,7 +8,7 @@ ENDIANNESS += -EB
ifdef CONFIG_SH2A -PLATFORM_CPPFLAGS += -m2a -m2a-nofpu -mb -ffreestanding +PLATFORM_CPPFLAGS += -m2a-nofpu -mb -ffreestanding else # SH2 PLATFORM_CPPFLAGS += -m3e -mb endif @@ -16,3 +16,5 @@ PLATFORM_CPPFLAGS += -DCONFIG_SH2 $(call cc-option,-mno-fdpic)
PLATFORM_RELFLAGS += -ffixed-r13 PLATFORM_LDFLAGS += $(ENDIANNESS) + +USE_PRIVATE_LIBGCC = yes
Hi, Sato-san.
Please use cover-letter option of git format-patch.
Please divide a patch by device support and board support. And please send patch of ether part to net maintainer.
- Copyright (C) 2013 Yoshinori Sato ysato@users.sourceforge.jp
.text
.align 2
+lowlevel_init:
tst r3,r3
bt 2f
bra 1b
mov.w r1,@r3
+2:
mov #0x40,r1
mov.b r1,@r0
tst r3,r3
bt 6f
bra 5b
mov.l r1,@r3
+6:
+7:
dt r0
bf 7b
mov.l $SDMR_val,r2
mov.l r2,@r1
tst r3,r3
bt 4f
bra 3b
mov.w r1,@r3
+4:
rts/n
.align 4
+$delay_count:
.long 2000
.long 0
+$mclkcr:
.long MCLKCR
.long WTCSR,0xA500
.long WTCNT,0x5A00
.long WTCSR,0xA51E
.long 0
.long RTCSR, 0xa55a0008; /* reflesh count=B耳/4 */
.long 0
.long PBCR3, 0x0022
.long PBCR2, 0x2244
.long PBCR1, 0x1111
.long IFCR, 0x0003
.long 0
+$INTMSK0:
.long INTMSK0
int rc = 0;
return rc;
do { \
int __i; \
} while(0);
if(((r) & 1)) \
else \
do { \
int __i; \
__b2++; \
} while(0);
- Configuation settings for the Renesas Technology MS7206SE
1.8.5.3
At Wed, 12 Feb 2014 15:50:12 +0900, Nobuhiro Iwamatsu wrote:
Hi, Sato-san.
OK. I'll cleanup code and re-sent.
.text
.align 2
+lowlevel_init:
tst r3,r3
bt 2f
bra 1b
mov.w r1,@r3
+2:
mov #0x40,r1
mov.b r1,@r0
tst r3,r3
bt 6f
bra 5b
mov.l r1,@r3
+6:
+7:
dt r0
bf 7b
mov.l $SDMR_val,r2
mov.l r2,@r1
tst r3,r3
bt 4f
bra 3b
mov.w r1,@r3
+4:
rts/n
.align 4
+$delay_count:
.long 2000
.long 0
+$mclkcr:
.long MCLKCR
.long WTCSR,0xA500
.long WTCNT,0x5A00
.long WTCSR,0xA51E
.long 0
.long 0
.long PBCR3, 0x0022
.long PBCR2, 0x2244
.long PBCR1, 0x1111
.long IFCR, 0x0003
.long 0
+$INTMSK0:
.long INTMSK0
int rc = 0;
return rc;
do { \
int __i; \
} while(0);
if(((r) & 1)) \
else \
do { \
int __i; \
__b2++; \
} while(0);
1.8.5.3
-- Nobuhiro Iwamatsu iwamatsu at {nigauri.org / debian.org} GPG ID: 40AD1FA6 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Nobuhiro Iwamatsu
Yoshinori Sato
