[U-Boot-Users] Booting Standalone App?
Hi there,
So what are the steps to get u-boot to boot the hello_world example? I'm evaluating the PowerPC 440-based AMCC Yosemite board. This is what I have done:
gzip hello_world.bin
mkimage -A ppc -0 linux -T standalone -C gzip -a 40000 -e 40004 -n "Standalone" -d hello_world.bin.gz hello_world.ub
Then I loaded the ub file onto the board at 0x40000. Then when I tried to bootm 40000, it would uncompress the standalone app (Uncompressing Standalone Application ... OK) then stop after showing 2 symbols.
What am I doing wrong?
I'm a complete newbie to u-boot and I've tried to find discussions online and reading the DULG, but I'm not having too much luck...
Thanks!
onyxtape wrote:
Hi there,
Here are the notes I wrote for the Yosemite board, they include how to build the standard standalone example. Perhaps that will help you.
http://www.ovro.caltech.edu/~dwh/powerpc_440ep.pdf
Cheers, Dave
Please RTFM.
Seems you didn't really try.
See http://www.denx.de/wiki/view/DULG/UBootStandalone and http://www.denx.de/wiki/view/DULG/MyStandaloneProgramDoesNotWork
Wolfgang,
Thank you for your reply.
I've already read the documents that you have referenced before posting my first message. I had already gotten hello_world to run in u-boot without problems (by using the go command), so that is not an issue.
My original question was - is it possible to boot a standalone application like the hello_world example like a kernel? I did not see any reference materials which shows how this is done. I have not changed the code in hello_world, so the entry point should not have moved. Did I use mkimage correctly?
Thanks, Randy
Well, that's the documented way to start standalone applications.
The only documented way, IIRC.
Is it a kernel? No. Does any part of the documentation say it could be used like that? No.
This question makes no sense to me.
David Hawkins
onyxtape
