[U-Boot] [PATCH 00/22] U-Boot MMC SPL for OMAP4
This series adds mmc SPL support for OMAP4. This is essentially an up-streaming effort for TI's x-loader for OMAP4 using the SPL framework
This work partly draws upon previous work done for x-loader by: Santosh Shilimkar santosh.shilimkar@ti.com Rajendra Nayak rnayak@ti.com and many others
Features supported: * Clock init - DPLL locking, clock domains/modules enabling * SDRAM/DMM initialization * Mux initialization * MMC raw read support * MMC FAT read support
Improvments over x-loader: * Code completely revamped * DPLL programming that works for all SYS_CLK frequencies * Automatic SDRAM identification and initialization * Board dependent parts(especially mux) deferred to u-boot. So, same SPL will work for Panda and SDP and most likely on any other board that comes along * Determination of u-boot size to avoid reading extra content while loading U-Boot * Modular apporach to enable future addition of support for all OMAP3/4 platforms
Aneesh V (21): omap: add miscellaneous utility macros for bit-field operations omap4: add OMAP4430 revision check armv7: start.S: provide a hook for saving boot params omap4: save parameters passed by ROM code to SPL arm: new labels in the linker script file Add generic spl infrastructure armv7: start.S: add SPL support omap: add spl support omap4: add spl support for OMAP4 SDP omap4: add serial console support to SPL omap4: utility function to identify the context of hw init omap4: separate mux settings into essential and non essential parts omap4: correct mux data for sdp4430 omap4: add clock support omap4: add sdram init support omap4: calculate EMIF register values omap4: automatic sdram detection armv7: embed u-boot size within u-boot for use from SPL omap: add MMC support to SPL omap: spl: add FAT support over MMC omap4: add spl support for OMAP4 Panda
John Rigby (1): mkimage: Add OMAP boot image support
Makefile | 11 + arch/arm/cpu/armv7/cpu.c | 7 + arch/arm/cpu/armv7/omap-common/Makefile | 1 + .../{omap4/lowlevel_init.S => omap-common/utils.c} | 58 +- arch/arm/cpu/armv7/omap4/Makefile | 3 + arch/arm/cpu/armv7/omap4/board.c | 117 ++- arch/arm/cpu/armv7/omap4/clocks.c | 717 +++++++++++ arch/arm/cpu/armv7/omap4/emif.c | 1303 ++++++++++++++++++++ arch/arm/cpu/armv7/omap4/lowlevel_init.S | 31 + arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 76 ++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 267 ++++ arch/arm/cpu/armv7/start.S | 50 +- arch/arm/cpu/armv7/u-boot.lds | 4 + arch/arm/include/asm/arch-omap4/clocks.h | 504 ++++++++ arch/arm/include/asm/arch-omap4/emif.h | 1021 +++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 50 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 60 +- .../omap4/lowlevel_init.S => include/asm/armv7.h} | 32 +- arch/arm/include/asm/global_data.h | 5 + arch/arm/include/asm/omap_common.h | 106 ++ board/ti/panda/panda.c | 25 +- board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} | 76 +- board/ti/sdp4430/config.mk | 3 +- board/ti/sdp4430/sdp.c | 25 +- .../{panda/panda.h => sdp4430/sdp4430_mux_data.h} | 128 +-- common/image.c | 1 + include/configs/omap4_panda.h | 24 + include/configs/omap4_sdp4430.h | 24 + include/image.h | 1 + spl/board/ti/panda/Makefile | 219 ++++ spl/board/ti/sdp4430/Makefile | 219 ++++ spl/board/ti/spl-omap.c | 189 +++ .../armv7/u-boot.lds => spl/board/ti/spl-omap.lds | 70 +- tools/Makefile | 2 + tools/mkimage.c | 2 + tools/mkimage.h | 1 + tools/omapimage.c | 229 ++++ .../omap4/lowlevel_init.S => tools/omapimage.h | 49 +- 38 files changed, 5390 insertions(+), 320 deletions(-) copy arch/arm/cpu/armv7/{omap4/lowlevel_init.S => omap-common/utils.c} (50%) create mode 100644 arch/arm/cpu/armv7/omap4/clocks.c create mode 100644 arch/arm/cpu/armv7/omap4/emif.c create mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h create mode 100644 arch/arm/cpu/armv7/omap4/sdram_elpida.c create mode 100644 arch/arm/include/asm/arch-omap4/clocks.h create mode 100644 arch/arm/include/asm/arch-omap4/emif.h copy arch/arm/{cpu/armv7/omap4/lowlevel_init.S => include/asm/armv7.h} (62%) create mode 100644 arch/arm/include/asm/omap_common.h rename board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} (76%) rename board/ti/{panda/panda.h => sdp4430/sdp4430_mux_data.h} (67%) create mode 100644 spl/board/ti/panda/Makefile create mode 100644 spl/board/ti/sdp4430/Makefile create mode 100644 spl/board/ti/spl-omap.c copy arch/arm/cpu/armv7/u-boot.lds => spl/board/ti/spl-omap.lds (57%) create mode 100644 tools/omapimage.c copy arch/arm/cpu/armv7/omap4/lowlevel_init.S => tools/omapimage.h (53%)
Signed-off-by: John Rigby john.rigby@linaro.org --- common/image.c | 1 + include/image.h | 1 + tools/Makefile | 2 + tools/mkimage.c | 2 + tools/mkimage.h | 1 + tools/omapimage.c | 229 +++++++++++++++++++++++++++++++++++++++++++++++++++++ tools/omapimage.h | 50 ++++++++++++ 7 files changed, 286 insertions(+), 0 deletions(-) create mode 100644 tools/omapimage.c create mode 100644 tools/omapimage.h
diff --git a/common/image.c b/common/image.c index f63a2ff..4198d76 100644 --- a/common/image.c +++ b/common/image.c @@ -141,6 +141,7 @@ static const table_entry_t uimage_type[] = { { IH_TYPE_FLATDT, "flat_dt", "Flat Device Tree", }, { IH_TYPE_KWBIMAGE, "kwbimage", "Kirkwood Boot Image",}, { IH_TYPE_IMXIMAGE, "imximage", "Freescale i.MX Boot Image",}, + { IH_TYPE_OMAPIMAGE, "omapimage", "TI OMAP CH/GP Boot Image",}, { -1, "", "", }, };
diff --git a/include/image.h b/include/image.h index 005e0d2..f74e2b9 100644 --- a/include/image.h +++ b/include/image.h @@ -157,6 +157,7 @@ #define IH_TYPE_FLATDT 8 /* Binary Flat Device Tree Blob */ #define IH_TYPE_KWBIMAGE 9 /* Kirkwood Boot Image */ #define IH_TYPE_IMXIMAGE 10 /* Freescale IMXBoot Image */ +#define IH_TYPE_OMAPIMAGE 11 /* TI OMAP Config Header Image */
/* * Compression Types diff --git a/tools/Makefile b/tools/Makefile index 623f908..a1c4ed7 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -84,6 +84,7 @@ OBJ_FILES-$(CONFIG_CMD_LOADS) += img2srec.o OBJ_FILES-$(CONFIG_INCA_IP) += inca-swap-bytes.o NOPED_OBJ_FILES-y += kwbimage.o NOPED_OBJ_FILES-y += imximage.o +NOPED_OBJ_FILES-y += omapimage.o NOPED_OBJ_FILES-y += mkimage.o OBJ_FILES-$(CONFIG_NETCONSOLE) += ncb.o NOPED_OBJ_FILES-y += os_support.o @@ -180,6 +181,7 @@ $(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)fit_image.o \ $(obj)image.o \ $(obj)imximage.o \ + $(obj)omapimage.o \ $(obj)kwbimage.o \ $(obj)md5.o \ $(obj)mkimage.o \ diff --git a/tools/mkimage.c b/tools/mkimage.c index f5859d7..ec6d75e 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -155,6 +155,8 @@ main (int argc, char **argv) init_imx_image_type (); /* Init FIT image generation/list support */ init_fit_image_type (); + /* Init TI OMAP Boot image generation/list support */ + init_omap_image_type(); /* Init Default image generation/list support */ init_default_image_type ();
diff --git a/tools/mkimage.h b/tools/mkimage.h index 9033a7d..3b49645 100644 --- a/tools/mkimage.h +++ b/tools/mkimage.h @@ -143,5 +143,6 @@ void init_kwb_image_type (void); void init_imx_image_type (void); void init_default_image_type (void); void init_fit_image_type (void); +void init_omap_image_type(void);
#endif /* _MKIIMAGE_H_ */ diff --git a/tools/omapimage.c b/tools/omapimage.c new file mode 100644 index 0000000..67fa056 --- /dev/null +++ b/tools/omapimage.c @@ -0,0 +1,229 @@ +/* + * (C) Copyright 2010 + * Linaro LTD, www.linaro.org + * Author: John Rigby john.rigby@linaro.org + * Based on TI's signGP.c + * + * (C) Copyright 2009 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * (C) Copyright 2008 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* Required to obtain the getline prototype from stdio.h */ +#define _GNU_SOURCE + +#include "mkimage.h" +#include <image.h> +#include "omapimage.h" + +/* Header size is CH header rounded up to 512 bytes plus GP header */ +#define OMAP_CH_HDR_SIZE 512 +#define OMAP_GP_HDR_SIZE (sizeof(struct gp_header)) +#define OMAP_FILE_HDR_SIZE (OMAP_CH_HDR_SIZE+OMAP_GP_HDR_SIZE) + +static uint8_t omapimage_header[OMAP_FILE_HDR_SIZE]; + +static int omapimage_check_image_types(uint8_t type) +{ + if (type == IH_TYPE_OMAPIMAGE) + return EXIT_SUCCESS; + else + return EXIT_FAILURE; +} + +/* + * Only the simplest image type is currently supported: + * TOC pointing to CHSETTINGS + * TOC terminator + * CHSETTINGS + * + * padding to OMAP_CH_HDR_SIZE bytes + * + * gp header + * size + * load_addr + */ +static int valid_gph_size(uint32_t size) +{ + return size; +} + +static int valid_gph_load_addr(uint32_t load_addr) +{ + return load_addr; +} + +static int omapimage_verify_header(unsigned char *ptr, int image_size, + struct mkimage_params *params) +{ + struct ch_toc *toc = (struct ch_toc *)ptr; + struct gp_header *gph = (struct gp_header *)(ptr+OMAP_CH_HDR_SIZE); + uint32_t offset, size; + + while (toc->section_offset != 0xffffffff + && toc->section_size != 0xffffffff) { + offset = toc->section_offset; + size = toc->section_size; + if (!offset || !size) + return -1; + if (offset >= OMAP_CH_HDR_SIZE || + offset+size >= OMAP_CH_HDR_SIZE) + return -1; + toc++; + } + if (!valid_gph_size(gph->size)) + return -1; + if (!valid_gph_load_addr(gph->load_addr)) + return -1; + + return 0; +} + +static void omapimage_print_section(struct ch_settings *chs) +{ + switch (chs->section_key) { + case KEY_CHSETTINGS: + printf("CHSETTINGS (%x) " + "valid:%x " + "version:%x " + "reserved:%x " + "flags:%x\n", + chs->section_key, + chs->valid, + chs->version, + chs->reserved, + chs->flags); + break; + default: + printf("UNKNOWNKEY (%x) " + "valid:%x " + "version:%x " + "reserved:%x " + "flags:%x\n", + chs->section_key, + chs->valid, + chs->version, + chs->reserved, + chs->flags); + break; + } +} + +static void omapimage_print_header(const void *ptr) +{ + struct ch_toc *toc = (struct ch_toc *)ptr; + struct gp_header *gph = (struct gp_header *)(ptr+OMAP_CH_HDR_SIZE); + uint32_t offset, size; + + while (toc->section_offset != 0xffffffff + && toc->section_size != 0xffffffff) { + offset = toc->section_offset; + size = toc->section_size; + + if (offset >= OMAP_CH_HDR_SIZE || + offset+size >= OMAP_CH_HDR_SIZE) + exit(EXIT_FAILURE); + + printf("Section %s offset %x length %x\n", + toc->section_name, + toc->section_offset, + toc->section_size); + + omapimage_print_section((struct ch_settings *)(ptr+offset)); + toc++; + } + + if (!valid_gph_size(gph->size)) { + fprintf(stderr, + "Error: invalid image size %x\n", + gph->size); + exit(EXIT_FAILURE); + } + + if (!valid_gph_load_addr(gph->load_addr)) { + fprintf(stderr, + "Error: invalid image load address %x\n", + gph->size); + exit(EXIT_FAILURE); + } + + printf("GP Header: Size %x LoadAddr %x\n", + gph->size, gph->load_addr); +} + +static int toc_offset(void *hdr, void *member) +{ + return member - hdr; +} + +static void omapimage_set_header(void *ptr, struct stat *sbuf, int ifd, + struct mkimage_params *params) +{ + struct ch_toc *toc = (struct ch_toc *)ptr; + struct ch_settings *chs = (struct ch_settings *) + (ptr + 2 * sizeof(*toc)); + struct gp_header *gph = (struct gp_header *)(ptr + OMAP_CH_HDR_SIZE); + + toc->section_offset = toc_offset(ptr, chs); + toc->section_size = sizeof(struct ch_settings); + strcpy((char *)toc->section_name, "CHSETTINGS"); + + chs->section_key = KEY_CHSETTINGS; + chs->valid = 0; + chs->version = 1; + chs->reserved = 0; + chs->flags = 0; + + toc++; + memset(toc, 0xff, sizeof(*toc)); + + gph->size = sbuf->st_size - OMAP_FILE_HDR_SIZE; + gph->load_addr = params->addr; +} + +int omapimage_check_params(struct mkimage_params *params) +{ + return (params->dflag && (params->fflag || params->lflag)) || + (params->fflag && (params->dflag || params->lflag)) || + (params->lflag && (params->dflag || params->fflag)); +} + +/* + * omapimage parameters + */ +static struct image_type_params omapimage_params = { + .name = "TI OMAP CH/GP Boot Image support", + .header_size = OMAP_FILE_HDR_SIZE, + .hdr = (void *)&omapimage_header, + .check_image_type = omapimage_check_image_types, + .verify_header = omapimage_verify_header, + .print_header = omapimage_print_header, + .set_header = omapimage_set_header, + .check_params = omapimage_check_params, +}; + +void init_omap_image_type(void) +{ + mkimage_register(&omapimage_params); +} diff --git a/tools/omapimage.h b/tools/omapimage.h new file mode 100644 index 0000000..7ff5404 --- /dev/null +++ b/tools/omapimage.h @@ -0,0 +1,50 @@ +/* + * (C) Copyright 2010 + * Linaro LTD, www.linaro.org + * Author John Rigby john.rigby@linaro.org + * Based on TI's signGP.c + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _OMAPIMAGE_H_ +#define _OMAPIMAGE_H_ + +struct ch_toc { + uint32_t section_offset; + uint32_t section_size; + uint8_t unused[12]; + uint8_t section_name[12]; +} __attribute__ ((__packed__)); + +struct ch_settings { + uint32_t section_key; + uint8_t valid; + uint8_t version; + uint16_t reserved; + uint32_t flags; +} __attribute__ ((__packed__)); + +struct gp_header { + uint32_t size; + uint32_t load_addr; +} __attribute__ ((__packed__)); + +#define KEY_CHSETTINGS 0xC0C0C0C1 +#endif /* _OMAPIMAGE_H_ */
Aneesh,
As pointed in the RFC[1] which was posted by John, we should separate out the configuration header part as that is optional. We should also consider renaming it to make it generic. What do you think?
Regards, Vaibhav
[1] http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/91511/focus=91808
On Tue, Mar 1, 2011 at 7:24 AM, Bedia, Vaibhav vaibhav.bedia@ti.com wrote:
Aneesh,
Vaibhav,
If you submit a patch that does this I will gladly ack it.
John
Hi Vaibhav,
On Tuesday 01 March 2011 07:54 PM, Bedia, Vaibhav wrote:
Aneesh,
Signed-off-by: John Rigbyjohn.rigby@linaro.org
For OMAP4: 1. An 8 byte GP header is enough for booting from external MMC FAT partition 2. A dummy CH with a dummy CHSETTINGS is essential for booting from the RAW partition of eMMC or external MMC. This works for FAT booting too. 3. A full configuration with proper CHSETTINGS and CHRAM will help us in directly booting from SDRAM avoiding the SPL, but this is not supported on all revisions of OMAP3/4
IMHO, let's have one image type(what John has created now) for (1) and (2). It doesn't really harm to have 512 bytes of additional header attached to your image when it makes it suitable for different types of booting.
For 3, if that is supported in U-Boot in future, we will need a new image type, maybe something like omapchimage.
Let me know if you had any special considerations for your SoC.
Best regards, Aneesh
On Tuesday, March 01, 2011 8:20 PM, V, Aneesh wrote: [...]
For OMAP4:
- An 8 byte GP header is enough for booting from external MMC FAT partition
- A dummy CH with a dummy CHSETTINGS is essential for booting from the RAW partition of eMMC or external MMC. This works for FAT booting too.
- A full configuration with proper CHSETTINGS and CHRAM will help us in directly booting from SDRAM avoiding the SPL, but this is not supported on all revisions of OMAP3/4
(My response on this yesterday bounced back for some reason)
I will try out this patch and see if the additional 512 bytes works for us also.
Regards, Vaibhav
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/include/asm/omap_common.h | 51 ++++++++++++++++++++++++++++++++++++ 1 files changed, 51 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/omap_common.h
diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h new file mode 100644 index 0000000..03db2f5 --- /dev/null +++ b/arch/arm/include/asm/omap_common.h @@ -0,0 +1,51 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _OMAP_COMMON_H_ +#define _OMAP_COMMON_H_ + +/* extract a bit field from a bit vector */ +#define get_bit_field(nr, start, mask)\ + (((nr) & (mask)) >> (start)) + +/* Set a field in a bit vector */ +#define set_bit_field(nr, start, mask, val)\ + do { \ + (nr) = ((nr) & ~(mask)) | (((val) << (start)) & (mask));\ + } while (0); + +/* + * Utility macro for read-modify-write of a hardware register + * addr - address of the register + * shift - starting bit position of the field to be modified + * msk - mask for the field + * val - value to be shifted masked and written to the field + */ +#define modify_reg_32(addr, shift, msk, val) \ + do {\ + writel(((readl(addr) & ~(msk))|(((val) << (shift)) & (msk))),\ + (addr));\ + } while (0); + +#endif /* _OMAP_COMMON_H_ */
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap4/board.c | 35 +++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 17 +++++++++----- arch/arm/include/asm/armv7.h | 31 +++++++++++++++++++++++++++ 3 files changed, 77 insertions(+), 6 deletions(-) create mode 100644 arch/arm/include/asm/armv7.h
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index fcd29a7..7583a0d 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -28,6 +28,7 @@ * MA 02111-1307 USA */ #include <common.h> +#include <asm/armv7.h> #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> @@ -127,3 +128,37 @@ int arch_cpu_init(void) set_muxconf_regs(); return 0; } + +static u32 cortex_a9_rev(void) +{ + + unsigned int rev; + + /* Read Main ID Register (MIDR) */ + asm ("mrc p15, 0, %0, c0, c0, 0" : "=r" (rev)); + + return rev; +} + +u32 omap4_revision(void) +{ + if (readl(CONTROL_ID_CODE) == OMAP4_CONTROL_ID_CODE_ES2_1) + return OMAP4430_ES2_1; + else if (readl(CONTROL_ID_CODE) == OMAP4_CONTROL_ID_CODE_ES2_2) + return OMAP4430_ES2_2; + /* + * For some of the ES2/ES1 boards ID_CODE is not reliable: + * Also, ES1 and ES2 have different ARM revisions + * So use ARM revision for identification + */ + unsigned int rev = cortex_a9_rev(); + + switch (rev) { + case MIDR_CORTEX_A9_R0P1: + return OMAP4430_ES1_0; + case MIDR_CORTEX_A9_R1P2: + return OMAP4430_ES2_0; + default: + return OMAP4430_SILICON_ID_INVALID; + } +} diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index a30bb33..1f88732 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -51,6 +51,11 @@ #define CONTROL_PADCONF_CORE (OMAP44XX_L4_CORE_BASE + 0x100000) #define CONTROL_PADCONF_WKUP (OMAP44XX_L4_CORE_BASE + 0x31E000)
+/* CONTROL_ID_CODE */ +#define CONTROL_ID_CODE (CTRL_BASE + 0x204) + +#define OMAP4_CONTROL_ID_CODE_ES2_1 0x3B95C02F +#define OMAP4_CONTROL_ID_CODE_ES2_2 0x4B95C02F /* UART */ #define UART1_BASE (OMAP44XX_L4_PER_BASE + 0x6a000) #define UART2_BASE (OMAP44XX_L4_PER_BASE + 0x6c000) @@ -121,11 +126,11 @@ struct s32ktimer { /* Temporary SRAM stack used while low level init is done */ #define LOW_LEVEL_SRAM_STACK NON_SECURE_SRAM_END
-/* - * OMAP4 real hardware: - * TODO: Change this to the IDCODE in the hw regsiter - */ -#define CPU_OMAP4430_ES10 1 -#define CPU_OMAP4430_ES20 2 +/* Silicon revisions */ +#define OMAP4430_SILICON_ID_INVALID 0 +#define OMAP4430_ES1_0 1 +#define OMAP4430_ES2_0 2 +#define OMAP4430_ES2_1 3 +#define OMAP4430_ES2_2 4
#endif diff --git a/arch/arm/include/asm/armv7.h b/arch/arm/include/asm/armv7.h new file mode 100644 index 0000000..6c24a80 --- /dev/null +++ b/arch/arm/include/asm/armv7.h @@ -0,0 +1,31 @@ +/* + * (C) Copyright 2010 + * Texas Instruments Incorporated - http://www.ti.com/ + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef ARMV7_H +#define ARMV7_H + +#define MIDR_CORTEX_A9_R0P1 0x410FC091 +#define MIDR_CORTEX_A9_R1P2 0x411FC092 + +#endif /* ARMV7_H */
Provide a means by which u-boot/SPL can save parameters passed to it by ROM code or the pre-loader.
A new function 'save_boot_params' has been defined and a default implentation provided. Please note that we do not have a stack yet. So, any implementation of this function should not use stack.
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/cpu.c | 7 +++++++ arch/arm/cpu/armv7/start.S | 1 + 2 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/cpu.c b/arch/arm/cpu/armv7/cpu.c index a01e0d6..54533fc 100644 --- a/arch/arm/cpu/armv7/cpu.c +++ b/arch/arm/cpu/armv7/cpu.c @@ -41,6 +41,13 @@
static void cache_flush(void);
+void save_boot_params_default(u32 r0, u32 r1, u32 r2, u32 r3) +{ +} + +void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) + __attribute__((weak, alias("save_boot_params_default"))); + int cleanup_before_linux(void) { unsigned int i; diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index cb4f92f..3618190 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -103,6 +103,7 @@ IRQ_STACK_START_IN: */
reset: + bl save_boot_params /* * set the cpu to SVC32 mode */
This is an essential feature when there no x-loader in the picture. Thanks for posting a patch for this :)
Regards, Vaibhav
Save boot device information passed by OMAP4 rom code
ROM code in OMAP4 passes information such as the media from which it picked up the first boot image(SPL in our case), the mode(raw mode/FAT mode) etc.
Save this information in SPL so that we can use the same media and mode to bootload u-boot.
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap4/board.c | 14 ++++++++++++ arch/arm/cpu/armv7/omap4/lowlevel_init.S | 31 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 8 +++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + arch/arm/include/asm/omap_common.h | 20 +++++++++++++++++ 5 files changed, 74 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 7583a0d..a5d585b 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -35,6 +35,20 @@
DECLARE_GLOBAL_DATA_PTR;
+#ifdef CONFIG_PRELOADER +u32 omap4_boot_device = BOOT_DEVICE_MMC1; +u32 omap4_boot_mode = MMCSD_MODE_FAT; +u32 omap_boot_device(void) +{ + return omap4_boot_device; +} + +u32 omap_boot_mode(void) +{ + return omap4_boot_mode; +} +#endif + /* * Routine: s_init * Description: Does early system init of muxing and clocks. diff --git a/arch/arm/cpu/armv7/omap4/lowlevel_init.S b/arch/arm/cpu/armv7/omap4/lowlevel_init.S index 026dfa4..250c73d 100644 --- a/arch/arm/cpu/armv7/omap4/lowlevel_init.S +++ b/arch/arm/cpu/armv7/omap4/lowlevel_init.S @@ -27,6 +27,37 @@ */
#include <asm/arch/omap4.h> +#ifdef CONFIG_PRELOADER +.global save_boot_params +save_boot_params: + /* + * See if the rom code passed pointer is valid: + * It is not valid if it is not in non-secure SRAM + * This may happen if you are booting with the help of + * debugger + */ + ldr r2, =NON_SECURE_SRAM_START + cmp r2, r0 + bgt 1f + ldr r2, =NON_SECURE_SRAM_END + cmp r2, r0 + blt 1f + + /* Store the boot device in omap4_boot_device */ + ldr r2, [r0, #BOOT_DEVICE_OFFSET] @ r1 <- value of boot device + and r2, #BOOT_DEVICE_MASK + ldr r3, =omap4_boot_device + str r2, [r3] @ omap4_boot_device <- r1 + + /* Store the boot mode (raw/FAT) in omap4_boot_mode */ + ldr r2, [r0, #DEV_DESC_PTR_OFFSET] @ get the device descriptor ptr + ldr r2, [r2, #DEV_DATA_PTR_OFFSET] @ get the pDeviceData ptr + ldr r2, [r2, #BOOT_MODE_OFFSET] @ get the boot mode + ldr r3, =omap4_boot_mode + str r2, [r3] +1: + bx lr +#endif
.globl lowlevel_init lowlevel_init: diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index 1f88732..740ca9d 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -133,4 +133,12 @@ struct s32ktimer { #define OMAP4430_ES2_1 3 #define OMAP4430_ES2_2 4
+/* ROM code defines */ +/* Boot device */ +#define BOOT_DEVICE_MASK 0xFF +#define BOOT_DEVICE_OFFSET 0x8 +#define DEV_DESC_PTR_OFFSET 0x4 +#define DEV_DATA_PTR_OFFSET 0x18 +#define BOOT_MODE_OFFSET 0x8 + #endif diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 4813e9e..ce86b36 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -23,6 +23,7 @@
#include <asm/arch/omap4.h> #include <asm/io.h> +#include <asm/omap_common.h>
struct omap_sysinfo { char *board_string; diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 03db2f5..06c511c 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -48,4 +48,24 @@ (addr));\ } while (0);
+/* Boot device */ +#define BOOT_DEVICE_NONE 0 +#define BOOT_DEVICE_XIP 1 +#define BOOT_DEVICE_XIPWAIT 2 +#define BOOT_DEVICE_NAND 3 +#define BOOT_DEVICE_ONE_NAND 4 +#define BOOT_DEVICE_MMC1 5 +#define BOOT_DEVICE_MMC2 6 + +/* Boot type */ +#define MMCSD_MODE_UNDEFINED 0 +#define MMCSD_MODE_RAW 1 +#define MMCSD_MODE_FAT 2 + +/* Magic number passed from SPL to U-Boot */ +#define OMAP_SPL_TO_UBOOT_MAGIC_NUMBER 0xDEADBEEF + +u32 omap_boot_device(void); +u32 omap_boot_mode(void); + #endif /* _OMAP_COMMON_H_ */
_bss_start_ofs is used in start.S to indicate end of copied image. This may not be correct when we have a discontiguous memory map. For instance, .bss may be placed in SDRAM for some SPLS while rest of the image is placed in SRAM.
Define a new label in linker script to indicate the end of the image copied during relocation and use it appropriately in start.S.
Also, add a new label to indicate the end of flash image. This will be useful in identifying the size of flash image
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/start.S | 6 +++++- arch/arm/cpu/armv7/u-boot.lds | 4 ++++ 2 files changed, 9 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 3618190..8215d26 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -77,6 +77,10 @@ _TEXT_BASE: _bss_start_ofs: .word __bss_start - _start
+.global _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word _end - _start @@ -172,7 +176,7 @@ stack_setup: beq clear_bss /* skip relocation */ #endif mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: diff --git a/arch/arm/cpu/armv7/u-boot.lds b/arch/arm/cpu/armv7/u-boot.lds index 5725c30..c3ad587 100644 --- a/arch/arm/cpu/armv7/u-boot.lds +++ b/arch/arm/cpu/armv7/u-boot.lds @@ -55,6 +55,8 @@ SECTIONS
. = ALIGN(4);
+ __image_copy_end = .; + .rel.dyn : { __rel_dyn_start = .; *(.rel*) @@ -66,6 +68,8 @@ SECTIONS *(.dynsym) }
+ __flash_image_end = .; + .bss __rel_dyn_start (OVERLAY) : { __bss_start = .; *(.bss)
Hi Aneesh,
- .word __image_copy_end - _start
- ldr r3, _image_copy_end_ofs
. = ALIGN(4);
- __image_copy_end = .;
- __flash_image_end = .;
There is a patch series which makes _end as end of image and has been applied to arm branch.
[U-Boot] [PATCH 1/2 v2] rename _end to __bss_end__ http://lists.denx.de/pipermail/u-boot/2011-March/088166.html
[U-Boot] [PATCH 2/2 v2] arm: fix incorrect monitor protection region in FLASH http://lists.denx.de/pipermail/u-boot/2011-March/088139.html
You can use the newly added symbol _end_ofs to replace your __flash_image_end here.
best regards, Po-Yu Chuang
On Tuesday 08 March 2011 03:42 PM, Po-Yu Chuang wrote:
Hi Aneesh,
[snip ..]
Thanks for the pointer. I will do that in v2.
best regards, Aneesh
Define a new type of SPL that is not tied to any particular media. - Create a top level directory 'spl' that has a structure similar to the existing 'nand_spl' - Make necessary changes to top-level Makefile to build such an spl
Rationale for this approach: - There may be SPLs(like the OMAP x-loader) that support booting from multiple media. - Also, there is no harm in keeping SPLs specific to a particular media also under this directory. In fact it makes sense to merge all the different spl directories into this one.
Signed-off-by: Aneesh V aneesh@ti.com --- Makefile | 11 +++++++++++ arch/arm/include/asm/global_data.h | 5 +++++ 2 files changed, 16 insertions(+), 0 deletions(-)
diff --git a/Makefile b/Makefile index dc2e3d8..21e51c8 100644 --- a/Makefile +++ b/Makefile @@ -293,6 +293,11 @@ NAND_SPL = nand_spl U_BOOT_NAND = $(obj)u-boot-nand.bin endif
+ifeq ($(CONFIG_SPL),y) +.PHONEY : SPL +ALL += SPL +endif + ifeq ($(CONFIG_ONENAND_U_BOOT),y) ONENAND_IPL = onenand_ipl U_BOOT_ONENAND = $(obj)u-boot-onenand.bin @@ -402,6 +407,9 @@ $(LDSCRIPT): depend $(obj)u-boot.lds: $(LDSCRIPT) $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@
+SPL :$(TIMESTAMP_FILE) $(VERSION_FILE) depend tools + $(MAKE) -C spl/board/$(BOARDDIR) all + $(NAND_SPL): $(TIMESTAMP_FILE) $(VERSION_FILE) depend $(MAKE) -C nand_spl/board/$(BOARDDIR) all
@@ -1138,6 +1146,7 @@ clean: @rm -f $(obj)include/bmp_logo.h @rm -f $(obj)lib/asm-offsets.s @rm -f $(obj)nand_spl/{u-boot.lds,u-boot-spl,u-boot-spl.map,System.map} + @rm -f $(obj)spl/{u-boot-spl-generated.lds,u-boot-spl,u-boot-spl.map} @rm -f $(obj)onenand_ipl/onenand-{ipl,ipl.bin,ipl.map} @rm -f $(ONENAND_BIN) @rm -f $(obj)onenand_ipl/u-boot.lds @@ -1157,12 +1166,14 @@ clobber: clean @rm -f $(obj)u-boot $(obj)u-boot.map $(obj)u-boot.hex $(ALL) @rm -f $(obj)u-boot.kwb @rm -f $(obj)u-boot.imx + @rm -f $(obj)MLO @rm -f $(obj)tools/{env/crc32.c,inca-swap-bytes} @rm -f $(obj)arch/powerpc/cpu/mpc824x/bedbug_603e.c @rm -fr $(obj)include/asm/proc $(obj)include/asm/arch $(obj)include/asm @rm -fr $(obj)include/generated @[ ! -d $(obj)nand_spl ] || find $(obj)nand_spl -name "*" -type l -print | xargs rm -f @[ ! -d $(obj)onenand_ipl ] || find $(obj)onenand_ipl -name "*" -type l -print | xargs rm -f + @[ ! -d $(obj)spl ] || find $(obj)spl -name "*" -type l -print | xargs rm -f
ifeq ($(OBJTREE),$(SRCTREE)) mrproper \ diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index 2a84d27..2ce020e 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -89,6 +89,11 @@ typedef struct global_data { #define GD_FLG_DISABLE_CONSOLE 0x00040 /* Disable console (in & out) */ #define GD_FLG_ENV_READY 0x00080 /* Environment imported into hash table */
+#ifdef CONFIG_PRELOADER +/* SPL works from internal RAM. gd pointer can be in .data section */ +#define DECLARE_GLOBAL_DATA_PTR extern gd_t *gd +#else #define DECLARE_GLOBAL_DATA_PTR register volatile gd_t *gd asm ("r8") +#endif
#endif /* __ASM_GBL_DATA_H */
Changes for supporting SPL
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/start.S | 36 +++++++++++++++++++++++++----------- 1 files changed, 25 insertions(+), 11 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 8215d26..f5f08d9 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -42,7 +42,16 @@ _start: b reset ldr pc, _not_used ldr pc, _irq ldr pc, _fiq - +#ifdef CONFIG_PRELOADER +_undefined_instruction: .word _undefined_instruction +_software_interrupt: .word _software_interrupt +_prefetch_abort: .word _prefetch_abort +_data_abort: .word _data_abort +_not_used: .word _not_used +_irq: .word _irq +_fiq: .word _fiq +_pad: .word 0x12345678 /* now 16*4=64 */ +#else _undefined_instruction: .word undefined_instruction _software_interrupt: .word software_interrupt _prefetch_abort: .word prefetch_abort @@ -51,6 +60,8 @@ _not_used: .word not_used _irq: .word irq _fiq: .word fiq _pad: .word 0x12345678 /* now 16*4=64 */ +#endif /* CONFIG_PRELOADER */ + .global _end_vect _end_vect:
@@ -171,10 +182,9 @@ stack_setup: mov sp, r4
adr r0, _start -#ifndef CONFIG_PRELOADER cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ -#endif mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -224,6 +234,15 @@ fixnext: add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ cmp r2, r3 blo fixloop + b clear_bss +_rel_dyn_start_ofs: + .word __rel_dyn_start - _start +_rel_dyn_end_ofs: + .word __rel_dyn_end - _start +_dynsym_start_ofs: + .word __dynsym_start - _start + +#endif /* #ifndef CONFIG_PRELOADER */
clear_bss: ldr r0, _bss_start_ofs @@ -237,7 +256,6 @@ clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 bne clbss_l -#endif /* #ifndef CONFIG_PRELOADER */
/* * We are done. Do not return, instead branch to second part of board @@ -257,13 +275,6 @@ jump_2_ram: _board_init_r_ofs: .word board_init_r - _start
-_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - /************************************************************************* * * CPU_init_critical registers @@ -300,6 +311,8 @@ cpu_init_crit: bl lowlevel_init @ go setup pll,mux,memory mov lr, ip @ restore link mov pc, lr @ back to my caller + +#ifndef CONFIG_PRELOADER /* ************************************************************************* * @@ -488,3 +501,4 @@ fiq: bl do_fiq
#endif +#endif /* CONFIG_PRELOADER */
Add the basic spl framework and linker script common for OMAP3/4 platforms.
Signed-off-by: Aneesh V aneesh@ti.com --- spl/board/ti/spl-omap.c | 47 ++++++++++++++++++++++++++++++++++ spl/board/ti/spl-omap.lds | 62 +++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 109 insertions(+), 0 deletions(-) create mode 100644 spl/board/ti/spl-omap.c create mode 100644 spl/board/ti/spl-omap.lds
diff --git a/spl/board/ti/spl-omap.c b/spl/board/ti/spl-omap.c new file mode 100644 index 0000000..0e08f4f --- /dev/null +++ b/spl/board/ti/spl-omap.c @@ -0,0 +1,47 @@ +/* + * + * Clock initialization for OMAP4 + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/u-boot.h> +#include <asm/arch/sys_proto.h> +#include <timestamp_autogenerated.h> + +/* Define global data structure pointer to it*/ +gd_t gdata __attribute__ ((section(".data"))); +bd_t bdata __attribute__ ((section(".data"))); +gd_t *gd = &gdata; + +void board_init_f(ulong dummy) +{ + relocate_code(CONFIG_SYS_SPL_STACK, &gdata, CONFIG_SYS_SPL_TEXT_BASE); +} + +void board_init_r(gd_t *id, ulong dummy) +{ + for (;;) + ; +} diff --git a/spl/board/ti/spl-omap.lds b/spl/board/ti/spl-omap.lds new file mode 100644 index 0000000..27b5295 --- /dev/null +++ b/spl/board/ti/spl-omap.lds @@ -0,0 +1,62 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +MEMORY { .sram : ORIGIN = CONFIG_SYS_SPL_TEXT_BASE,\ + LENGTH = CONFIG_SYS_SPL_MAX_SIZE } +MEMORY { .sdram : ORIGIN = CONFIG_SYS_SPL_BSS_START_ADDR, \ + LENGTH = CONFIG_SYS_SPL_BSS_MAX_SIZE } + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + .text : + { + . = ALIGN(32); + __start = .; + start.o (.text) + *(.text*) + } >.sram + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(.rodata*)) } >.sram + + . = ALIGN(4); + .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram + . = ALIGN(4); + __image_copy_end = .; + + .bss : + { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + _end = .; + } >.sdram +}
Adapted from: nand_spl/board/samsung/smdk6400/Makefile
- Add the SPL makefile for OMAP4430 SDP - Add the necessary CONFIG flags in the board config file
Signed-off-by: Aneesh V aneesh@ti.com --- board/ti/sdp4430/config.mk | 3 +- include/configs/omap4_sdp4430.h | 19 ++++++ spl/board/ti/sdp4430/Makefile | 120 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 141 insertions(+), 1 deletions(-) create mode 100644 spl/board/ti/sdp4430/Makefile
diff --git a/board/ti/sdp4430/config.mk b/board/ti/sdp4430/config.mk index 33901a7..c62965d 100644 --- a/board/ti/sdp4430/config.mk +++ b/board/ti/sdp4430/config.mk @@ -28,4 +28,5 @@ # Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 # (mem base + reserved)
-CONFIG_SYS_TEXT_BASE = 0x80e80000 +# 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM +CONFIG_SYS_TEXT_BASE = 0x80100000 diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 9a8bb73..5b20841 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -122,7 +122,9 @@
/* USB device configuration */ #define CONFIG_USB_DEVICE 1 +#ifndef CONFIG_PRELOADER #define CONFIG_USB_TTY 1 +#endif #define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* Flash */ @@ -240,4 +242,21 @@ CONFIG_SYS_INIT_RAM_SIZE - \ GENERATED_GBL_DATA_SIZE)
+/* Defines for Clock init */ +#define CONFIG_SYS_OMAP4_ABE_SYSCK + +/* Defines for SDRAM init */ +#define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION 1 +#define CONFIG_SYS_EMIF_UPDATE_TIMINGS 1 +#define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS 1 + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SYS_SPL_TEXT_BASE 0x40304360 +#define CONFIG_SYS_SPL_MAX_SIZE 0x7800 /* 30 K */ +#define CONFIG_SYS_SPL_STACK LOW_LEVEL_SRAM_STACK + +#define CONFIG_SYS_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SYS_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + #endif /* __CONFIG_H */ diff --git a/spl/board/ti/sdp4430/Makefile b/spl/board/ti/sdp4430/Makefile new file mode 100644 index 0000000..dd56a40 --- /dev/null +++ b/spl/board/ti/sdp4430/Makefile @@ -0,0 +1,120 @@ +# +# (C) Copyright 2006-2007 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +splobj := $(OBJTREE)/spl/ +include $(TOPDIR)/config.mk +SOBJS = +COBJS = + +# armv7 +$(obj)start.S: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/start.S $@ + +$(obj)syslib.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/syslib.c $@ + +SOBJS += start.o +COBJS += syslib.o + +# omap-common +$(obj)timer.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap-common/timer.c $@ + +$(obj)reset.S: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap-common/reset.S $@ + +$(obj)spl-omap.c: + @rm -f $@ + @ln -s $(TOPDIR)/spl/board/ti/spl-omap.c $@ + +SOBJS += reset.o +COBJS += timer.o spl-omap.o + +$(OBJTREE)/MLO: $(splobj)u-boot-spl.bin + $(OBJTREE)/tools/mkimage -T omapimage \ + -a $(CONFIG_SYS_SPL_TEXT_BASE) -d $< $@ + +LDSCRIPT_SOURCE = $(TOPDIR)/spl/board/ti/spl-omap.lds + +# omap4 +$(obj)lowlevel_init.S: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/lowlevel_init.S $@ + +$(obj)omap4_mux_data.h: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/omap4_mux_data.h $@ + +$(obj)board.c:$(obj)omap4_mux_data.h + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/board.c $@ + +SOBJS += lowlevel_init.o +COBJS += board.o + +# rules +LDPPFLAGS += -include $(TOPDIR)/include/config.h +LDSCRIPT = $(splobj)u-boot-spl-generated.lds +$(LDSCRIPT): $(LDSCRIPT_SOURCE) + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@ +LDFLAGS = -Bstatic -T $(LDSCRIPT) \ + $(PLATFORM_LDFLAGS) --gc-sections +AFLAGS += -DCONFIG_PRELOADER -Os -ffixed-r8 +CFLAGS += -DCONFIG_PRELOADER -Os -ffixed-r8 -ffunction-sections \ + -fdata-sections -march=armv7-a -mthumb +PLATFORM_LIBGCC = -L $(shell dirname `$(CC) $(CFLAGS) \ + -print-libgcc-file-name`) -lgcc + +$(obj)%.o: $(obj)%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(obj)%.c + $(CC) $(CFLAGS) -c -o $@ $< + +SRCS := $(addprefix $(obj),$(SOBJS:.o=.S) $(COBJS:.o=.c)) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(OBJTREE)/spl/board/$(BOARDDIR) + +$(splobj)u-boot-spl.bin: $(splobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(splobj)u-boot-spl: $(OBJS) $(LDSCRIPT) + cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ + $(PLATFORM_LIBGCC) \ + -Map $(splobj)u-boot-spl.map \ + -o $(splobj)u-boot-spl + +ALL = $(OBJTREE)/MLO +all: $(obj).depend $(ALL) + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap4/board.c | 3 ++ arch/arm/include/asm/omap_common.h | 1 + spl/board/ti/sdp4430/Makefile | 40 ++++++++++++++++++++++++++++++++++++ spl/board/ti/spl-omap.c | 10 +++++++++ 4 files changed, 54 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index a5d585b..da79669 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -57,6 +57,9 @@ u32 omap_boot_mode(void) void s_init(void) { watchdog_init(); +#ifdef CONFIG_PRELOADER + preloader_console_init(); +#endif }
/* diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 06c511c..95116f4 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -67,5 +67,6 @@
u32 omap_boot_device(void); u32 omap_boot_mode(void); +void preloader_console_init(void);
#endif /* _OMAP_COMMON_H_ */ diff --git a/spl/board/ti/sdp4430/Makefile b/spl/board/ti/sdp4430/Makefile index dd56a40..6a6aa42 100644 --- a/spl/board/ti/sdp4430/Makefile +++ b/spl/board/ti/sdp4430/Makefile @@ -28,6 +28,46 @@ include $(TOPDIR)/config.mk SOBJS = COBJS =
+# serial console +$(obj)eabi_compat.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/lib/eabi_compat.c $@ + +$(obj)string.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/string.c $@ + +$(obj)vsprintf.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/vsprintf.c $@ + +$(obj)console.c: + @rm -f $@ + @ln -s $(TOPDIR)/common/console.c $@ + +$(obj)stdio.c: + @rm -f $@ + @ln -s $(TOPDIR)/common/stdio.c $@ + +$(obj)serial.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/serial/serial.c $@ + +$(obj)ns16550.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/serial/ns16550.c $@ + +$(obj)div64.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/div64.c $@ + +$(obj)ctype.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/ctype.c $@ + +COBJS += serial.o ns16550.o string.o vsprintf.o console.o stdio.o +COBJS += ctype.o eabi_compat.o div64.o + # armv7 $(obj)start.S: @rm -f $@ diff --git a/spl/board/ti/spl-omap.c b/spl/board/ti/spl-omap.c index 0e08f4f..57ddb7d 100644 --- a/spl/board/ti/spl-omap.c +++ b/spl/board/ti/spl-omap.c @@ -45,3 +45,13 @@ void board_init_r(gd_t *id, ulong dummy) for (;;) ; } + +void preloader_console_init(void) +{ + gd->bd = &bdata; + gd->flags |= GD_FLG_RELOC; + gd->baudrate = CONFIG_BAUDRATE; + serial_init(); /* serial communications setup */ + printf("\nU-Boot SPL for Texas Instruments OMAP4 (%s - %s)\n", + U_BOOT_DATE, U_BOOT_TIME); +}
The basic hardware init of OMAP4(s_init()) can happen in 4 different contexts: 1. SPL running from SRAM 2. U-Boot running from FLASH 3. Non-XIP U-Boot loaded to SDRAM by SPL 4. Non-XIP U-Boot loaded to SDRAM by ROM code using the Configuration Header feature
What level of hw initialization gets done depends on this context. Add a utility function to find this context.
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/include/asm/arch-omap4/sys_proto.h | 47 +++++++++++++++++++++++++++ arch/arm/include/asm/omap_common.h | 6 +++ 2 files changed, 53 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index ce86b36..19da2e1 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -38,6 +38,53 @@ void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long);
+static inline u32 running_from_sdram(void) +{ + u32 pc; + asm volatile ("mov %0, pc" : "=r" (pc)); + return ((pc >= OMAP44XX_DRAM_ADDR_SPACE_START) && + (pc < OMAP44XX_DRAM_ADDR_SPACE_END)); +} + +static inline u8 uboot_loaded_by_spl(void) +{ + /* + * Configuration Header is not supported yet, so u-boot init running + * from SDRAM implies that it was loaded by SPL. When this situation + * changes one of these approaches could be taken: + * i. Pass a magic from SPL to U-Boot and U-Boot save it at a known + * location. + * ii. Check the OPP. CH can support only 50% OPP while SPL initializes + * the DPLLs at 100% OPP. + */ + return running_from_sdram(); +} +/* + * The basic hardware init of OMAP(s_init()) can happen in 4 + * different contexts: + * 1. SPL running from SRAM + * 2. U-Boot running from FLASH + * 3. Non-XIP U-Boot loaded to SDRAM by SPL + * 4. Non-XIP U-Boot loaded to SDRAM by ROM code using the + * Configuration Header feature + * + * This function finds this context. + * Defining as inline may help in compiling out unused functions in SPL + */ +static inline u32 omap4_hw_init_context(void) +{ +#ifdef CONFIG_PRELOADER + return OMAP_INIT_CONTEXT_SPL; +#else + if (uboot_loaded_by_spl()) + return OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_SPL; + else if (running_from_sdram()) + return OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_CH; + else + return OMAP_INIT_CONTEXT_XIP_UBOOT; +#endif +} + extern const struct omap_sysinfo sysinfo;
#endif diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 95116f4..50247af 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -65,6 +65,12 @@ /* Magic number passed from SPL to U-Boot */ #define OMAP_SPL_TO_UBOOT_MAGIC_NUMBER 0xDEADBEEF
+/* HW Init Context */ +#define OMAP_INIT_CONTEXT_SPL 0 +#define OMAP_INIT_CONTEXT_XIP_UBOOT 1 +#define OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_SPL 2 +#define OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_CH 3 + u32 omap_boot_device(void); u32 omap_boot_mode(void); void preloader_console_init(void);
Do the essential part from SPL and non-essential part from U-Boot - Essential part is what is essential for u-boot to function - Essential part is also largely board independent(at least as of now) - So essential part is moved out to SoC directory instead of keeping in board directory. This helps in having single SPL that works for Panda and SDP. - Non-essential part is what is set by u-boot for kernel to function correctly - Ideally non-essential part should be phased out eventually
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap4/board.c | 53 ++++++++++++++++- arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 76 ++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 4 +- board/ti/panda/panda.c | 25 ++------ board/ti/panda/{panda.h => panda_mux_data.h} | 45 ++------------ board/ti/sdp4430/sdp.c | 25 ++------ board/ti/sdp4430/{sdp.h => sdp4430_mux_data.h} | 47 ++------------- 7 files changed, 151 insertions(+), 124 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h rename board/ti/panda/{panda.h => panda_mux_data.h} (83%) rename board/ti/sdp4430/{sdp.h => sdp4430_mux_data.h} (83%)
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index da79669..95b6a96 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -32,9 +32,30 @@ #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> +#include "omap4_mux_data.h"
+void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) +{ + int i; + struct pad_conf_entry *pad = (struct pad_conf_entry *) array; + + for (i = 0; i < size; i++, pad++) + writew(pad->val, base + pad->offset); +} + +static void set_muxconf_regs_essential(void) +{ + do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_essential, + sizeof(core_padconf_array_essential) / + sizeof(struct pad_conf_entry)); + + do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_essential, + sizeof(wkup_padconf_array_essential) / + sizeof(struct pad_conf_entry)); +} + #ifdef CONFIG_PRELOADER u32 omap4_boot_device = BOOT_DEVICE_MMC1; u32 omap4_boot_mode = MMCSD_MODE_FAT; @@ -49,14 +70,41 @@ u32 omap_boot_mode(void) } #endif
+static void set_mux_conf_regs(void) +{ + switch (omap4_hw_init_context()) { + case OMAP_INIT_CONTEXT_SPL: + set_muxconf_regs_essential(); + break; + case OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_SPL: + set_muxconf_regs_non_essential(); + break; + case OMAP_INIT_CONTEXT_XIP_UBOOT: + case OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_CH: + set_muxconf_regs_essential(); + set_muxconf_regs_non_essential(); + break; + } +} + /* * Routine: s_init - * Description: Does early system init of muxing and clocks. - * - Called path is with SRAM stack. + * Description: Does early system init of watchdog, muxing, clocks, and + * sdram. Watchdog disable is done always. For the rest what gets done + * depends on the boot mode in which this function is executed + * 1. s_init of SPL running from SRAM + * 2. s_init of U-Boot running from FLASH + * 3. s_init of U-Boot loaded to SDRAM by SPL + * 4. s_init of U-Boot loaded to SDRAM by ROM code using the Configuration + * Header feature + * Please have a look at the respective functions to see what gets done in + * each of these cases + * This function is called with SRAM stack. */ void s_init(void) { watchdog_init(); + set_mux_conf_regs(); #ifdef CONFIG_PRELOADER preloader_console_init(); #endif @@ -142,7 +190,6 @@ int checkboard(void) */ int arch_cpu_init(void) { - set_muxconf_regs(); return 0; }
diff --git a/arch/arm/cpu/armv7/omap4/omap4_mux_data.h b/arch/arm/cpu/armv7/omap4/omap4_mux_data.h new file mode 100644 index 0000000..00c52f8 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/omap4_mux_data.h @@ -0,0 +1,76 @@ + /* + * (C) Copyright 2010 + * Texas Instruments Incorporated, <www.ti.com> + * + * Balaji Krishnamoorthy balajitk@ti.com + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _OMAP4_MUX_DATA_H_ +#define _OMAP4_MUX_DATA_H_ + +#include <asm/arch/mux_omap4.h> + +const struct pad_conf_entry core_padconf_array_essential[] = { + +{GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ +{GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ +{GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ +{GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ +{GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ +{GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ +{GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ +{GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +{GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ +{GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ +{SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ +{SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ +{SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ +{SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ +{SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ +{SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ +{SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ +{SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ +{SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ +{SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ +{I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ +{I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ +{I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ +{I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ +{I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ +{I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ +{I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ +{I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ +{UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ +{UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ +{UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ +{UART3_TX_IRTX, (M0)} /* uart3_tx */ + +}; + +const struct pad_conf_entry wkup_padconf_array_essential[] = { + +{PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ +{PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ +{PAD1_SYS_32K, (IEN | M0)} /* sys_32k */ + +}; + +#endif /* _OMAP4_MUX_DATA_H_ */ diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 19da2e1..33a1666 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -24,6 +24,7 @@ #include <asm/arch/omap4.h> #include <asm/io.h> #include <asm/omap_common.h> +#include <asm/arch/mux_omap4.h>
struct omap_sysinfo { char *board_string; @@ -33,7 +34,8 @@ void gpmc_init(void); void watchdog_init(void); u32 get_device_type(void); void invalidate_dcache(u32); -void set_muxconf_regs(void); +void do_set_mux(u32 base, struct pad_conf_entry const *array, int size); +void set_muxconf_regs_non_essential(void); void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c index 78e1910..9afed80 100644 --- a/board/ti/panda/panda.c +++ b/board/ti/panda/panda.c @@ -25,7 +25,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h>
-#include "panda.h" +#include "panda_mux_data.h"
@@ -65,27 +65,14 @@ int misc_init_r(void) return 0; }
-void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) +void set_muxconf_regs_non_essential(void) { - int i; - struct pad_conf_entry *pad = (struct pad_conf_entry *) array; - - for (i = 0; i < size; i++, pad++) - writew(pad->val, base + pad->offset); -} - -/** - * @brief set_muxconf_regs Setting up the configuration Mux registers - * specific to the board. - */ -void set_muxconf_regs(void) -{ - do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array, - sizeof(core_padconf_array) / + do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_non_essential, + sizeof(core_padconf_array_non_essential) / sizeof(struct pad_conf_entry));
- do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array, - sizeof(wkup_padconf_array) / + do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_non_essential, + sizeof(wkup_padconf_array_non_essential) / sizeof(struct pad_conf_entry)); }
diff --git a/board/ti/panda/panda.h b/board/ti/panda/panda_mux_data.h similarity index 83% rename from board/ti/panda/panda.h rename to board/ti/panda/panda_mux_data.h index e3d090e..8bb7fe5 100644 --- a/board/ti/panda/panda.h +++ b/board/ti/panda/panda_mux_data.h @@ -24,21 +24,13 @@ * MA 02111-1307 USA */
-#ifndef _PANDA_H_ -#define _PANDA_H_ +#ifndef _PANDA_MUX_DATA_H_ +#define _PANDA_MUX_DATA_H_
#include <asm/io.h> #include <asm/arch/mux_omap4.h>
-const struct pad_conf_entry core_padconf_array[] = { - {GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ - {GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ - {GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ - {GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ - {GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ - {GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ - {GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ - {GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_AD8, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* gpio_32 */ {GPMC_AD9, (PTU | IEN | M3)}, /* gpio_33 */ {GPMC_AD10, (PTU | IEN | M3)}, /* gpio_34 */ @@ -64,8 +56,6 @@ const struct pad_conf_entry core_padconf_array[] = { {GPMC_NWP, (M3)}, /* gpio_54 */ {GPMC_CLK, (PTD | M3)}, /* gpio_55 */ {GPMC_NADV_ALE, (M3)}, /* gpio_56 */ - {GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ - {GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ @@ -112,16 +102,6 @@ const struct pad_conf_entry core_padconf_array[] = { {USBB1_HSIC_STROBE, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_strobe */ {USBC1_ICUSB_DP, (IEN | M0)}, /* usbc1_icusb_dp */ {USBC1_ICUSB_DM, (IEN | M0)}, /* usbc1_icusb_dm */ - {SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ - {SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ - {SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ - {SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ - {SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ - {SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ - {SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ - {SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ - {SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ - {SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ {ABE_MCBSP2_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_clkx */ {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ @@ -144,14 +124,6 @@ const struct pad_conf_entry core_padconf_array[] = { {UART2_RX, (PTU | IEN | M0)}, /* uart2_rx */ {UART2_TX, (M0)}, /* uart2_tx */ {HDQ_SIO, (M3)}, /* gpio_127 */ - {I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ - {I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ - {I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ - {I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ - {I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ - {I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ - {I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ - {I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ {MCSPI1_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_clk */ {MCSPI1_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_somi */ {MCSPI1_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_simo */ @@ -159,10 +131,6 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI1_CS1, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* mcspi1_cs1 */ {MCSPI1_CS2, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_139 */ {MCSPI1_CS3, (PTU | IEN | M3)}, /* gpio_140 */ - {UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ - {UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ - {UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ - {UART3_TX_IRTX, (M0)}, /* uart3_tx */ {SDMMC5_CLK, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc5_clk */ {SDMMC5_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_cmd */ {SDMMC5_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat0 */ @@ -236,14 +204,12 @@ const struct pad_conf_entry core_padconf_array[] = { {DPM_EMU19, (IEN | M5)}, /* dispc2_data0 */ };
-const struct pad_conf_entry wkup_padconf_array[] = { +const struct pad_conf_entry wkup_padconf_array_non_essential[] = { {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ {PAD1_SIM_CLK, (M0)}, /* sim_clk */ {PAD0_SIM_RESET, (M0)}, /* sim_reset */ {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ - {PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ {PAD1_FREF_XTAL_IN, (M0)}, /* # */ {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ @@ -252,7 +218,6 @@ const struct pad_conf_entry wkup_padconf_array[] = { {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ {PAD1_FREF_CLK4_REQ, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_1 */ {PAD0_FREF_CLK4_OUT, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_2 */ - {PAD1_SYS_32K, (IEN | M0)}, /* sys_32k */ {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ @@ -261,4 +226,4 @@ const struct pad_conf_entry wkup_padconf_array[] = { {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ };
-#endif +#endif /* _PANDA_MUX_DATA_H_ */ diff --git a/board/ti/sdp4430/sdp.c b/board/ti/sdp4430/sdp.c index b13c4c5..a5ea682 100644 --- a/board/ti/sdp4430/sdp.c +++ b/board/ti/sdp4430/sdp.c @@ -27,7 +27,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h>
-#include "sdp.h" +#include "sdp4430_mux_data.h"
@@ -70,27 +70,14 @@ int misc_init_r(void) return 0; }
diff --git a/board/ti/sdp4430/sdp.h b/board/ti/sdp4430/sdp4430_mux_data.h similarity index 83% rename from board/ti/sdp4430/sdp.h rename to board/ti/sdp4430/sdp4430_mux_data.h index bf41067..e6081dc 100644 --- a/board/ti/sdp4430/sdp.h +++ b/board/ti/sdp4430/sdp4430_mux_data.h @@ -23,22 +23,12 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ +#ifndef _SDP4430_MUX_DATA_H +#define _SDP4430_MUX_DATA_H
-#ifndef _SDP_H_ -#define _SDP_H_ - -#include <asm/io.h> #include <asm/arch/mux_omap4.h>
-const struct pad_conf_entry core_padconf_array[] = { - {GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ - {GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ - {GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ - {GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ - {GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ - {GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ - {GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ - {GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_AD8, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* gpio_32 */ {GPMC_AD9, (PTU | IEN | M3)}, /* gpio_33 */ {GPMC_AD10, (PTU | IEN | M3)}, /* gpio_34 */ @@ -64,8 +54,6 @@ const struct pad_conf_entry core_padconf_array[] = { {GPMC_NWP, (M3)}, /* gpio_54 */ {GPMC_CLK, (PTD | M3)}, /* gpio_55 */ {GPMC_NADV_ALE, (M3)}, /* gpio_56 */ - {GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ - {GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ @@ -112,16 +100,6 @@ const struct pad_conf_entry core_padconf_array[] = { {USBB1_HSIC_STROBE, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_strobe */ {USBC1_ICUSB_DP, (IEN | M0)}, /* usbc1_icusb_dp */ {USBC1_ICUSB_DM, (IEN | M0)}, /* usbc1_icusb_dm */ - {SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ - {SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ - {SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ - {SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ - {SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ - {SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ - {SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ - {SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ - {SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ - {SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ {ABE_MCBSP2_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_clkx */ {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ @@ -144,14 +122,6 @@ const struct pad_conf_entry core_padconf_array[] = { {UART2_RX, (PTU | IEN | M0)}, /* uart2_rx */ {UART2_TX, (M0)}, /* uart2_tx */ {HDQ_SIO, (M3)}, /* gpio_127 */ - {I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ - {I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ - {I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ - {I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ - {I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ - {I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ - {I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ - {I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ {MCSPI1_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_clk */ {MCSPI1_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_somi */ {MCSPI1_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_simo */ @@ -159,10 +129,6 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI1_CS1, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* mcspi1_cs1 */ {MCSPI1_CS2, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_139 */ {MCSPI1_CS3, (PTU | IEN | M3)}, /* gpio_140 */ - {UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ - {UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ - {UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ - {UART3_TX_IRTX, (M0)}, /* uart3_tx */ {SDMMC5_CLK, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc5_clk */ {SDMMC5_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_cmd */ {SDMMC5_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat0 */ @@ -236,14 +202,12 @@ const struct pad_conf_entry core_padconf_array[] = { {DPM_EMU19, (IEN | M5)}, /* dispc2_data0 */ };
-const struct pad_conf_entry wkup_padconf_array[] = { +const struct pad_conf_entry wkup_padconf_array_non_essential[] = { {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ {PAD1_SIM_CLK, (M0)}, /* sim_clk */ {PAD0_SIM_RESET, (M0)}, /* sim_reset */ {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ - {PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ {PAD1_FREF_XTAL_IN, (M0)}, /* # */ {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ @@ -252,7 +216,6 @@ const struct pad_conf_entry wkup_padconf_array[] = { {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ {PAD1_FREF_CLK4_REQ, (PTU | IEN | M0)}, /* # */ {PAD0_FREF_CLK4_OUT, (M0)}, /* # */ - {PAD1_SYS_32K, (IEN | M0)}, /* sys_32k */ {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ @@ -261,4 +224,4 @@ const struct pad_conf_entry wkup_padconf_array[] = { {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ };
-#endif +#endif /* _SDP4430_MUX_DATA_H */
sync up mux settings with the latest in x-loader
Signed-off-by: Aneesh V aneesh@ti.com --- board/ti/panda/panda_mux_data.h | 89 ++++++++++++++++++----------------- board/ti/sdp4430/sdp4430_mux_data.h | 29 ++++++----- 2 files changed, 61 insertions(+), 57 deletions(-)
diff --git a/board/ti/panda/panda_mux_data.h b/board/ti/panda/panda_mux_data.h index 8bb7fe5..16cc0ad 100644 --- a/board/ti/panda/panda_mux_data.h +++ b/board/ti/panda/panda_mux_data.h @@ -23,11 +23,9 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ +#ifndef _SDP4430_MUX_DATA_H +#define _SDP4430_MUX_DATA_H
-#ifndef _PANDA_MUX_DATA_H_ -#define _PANDA_MUX_DATA_H_ - -#include <asm/io.h> #include <asm/arch/mux_omap4.h>
const struct pad_conf_entry core_padconf_array_non_essential[] = { @@ -45,7 +43,7 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_A19, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row7 */ {GPMC_A20, (IEN | M3)}, /* gpio_44 */ {GPMC_A21, (M3)}, /* gpio_45 */ - {GPMC_A22, (M3)}, /* gpio_46 */ + {GPMC_A22, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col6 */ {GPMC_A23, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col7 */ {GPMC_A24, (PTD | M3)}, /* gpio_48 */ {GPMC_A25, (PTD | M3)}, /* gpio_49 */ @@ -59,9 +57,9 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ - {GPMC_WAIT1, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_62 */ + {GPMC_WAIT1, (IEN | M3)}, /* gpio_62 */ {C2C_DATA11, (PTD | M3)}, /* gpio_100 */ - {C2C_DATA12, (PTU | IEN | M3)}, /* gpio_101 */ + {C2C_DATA12, (M1)}, /* dsi1_te0 */ {C2C_DATA13, (PTD | M3)}, /* gpio_102 */ {C2C_DATA14, (M1)}, /* dsi2_te0 */ {C2C_DATA15, (PTD | M3)}, /* gpio_104 */ @@ -86,14 +84,14 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {CAM_SHUTTER, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_shutter */ {CAM_STROBE, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_strobe */ {CAM_GLOBALRESET, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_83 */ - {USBB1_ULPITLL_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M4)},/* usbb1_ulpiphy_clk */ - {USBB1_ULPITLL_STP, (OFF_EN | OFF_OUT_PTD | M4)}, /* usbb1_ulpiphy_stp */ - {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dir */ - {USBB1_ULPITLL_NXT, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_nxt */ - {USBB1_ULPITLL_DAT0, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat0 */ - {USBB1_ULPITLL_DAT1, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat1 */ - {USBB1_ULPITLL_DAT2, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat2 */ - {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat3 */ + {USBB1_ULPITLL_CLK, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cawake */ + {USBB1_ULPITLL_STP, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cadata */ + {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caflag */ + {USBB1_ULPITLL_NXT, (OFF_EN | M1)}, /* hsi1_acready */ + {USBB1_ULPITLL_DAT0, (OFF_EN | M1)}, /* hsi1_acwake */ + {USBB1_ULPITLL_DAT1, (OFF_EN | M1)}, /* hsi1_acdata */ + {USBB1_ULPITLL_DAT2, (OFF_EN | M1)}, /* hsi1_acflag */ + {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caready */ {USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ {USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ {USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ @@ -106,8 +104,8 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ {ABE_MCBSP2_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_fsx */ - {ABE_MCBSP1_CLKX, (IEN | M1)}, /* abe_slimbus1_clock */ - {ABE_MCBSP1_DR, (IEN | M1)}, /* abe_slimbus1_data */ + {ABE_MCBSP1_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_clkx */ + {ABE_MCBSP1_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dr */ {ABE_MCBSP1_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dx */ {ABE_MCBSP1_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_fsx */ {ABE_PDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_ul_data */ @@ -143,7 +141,7 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {MCSPI4_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_cs0 */ {UART4_RX, (IEN | M0)}, /* uart4_rx */ {UART4_TX, (M0)}, /* uart4_tx */ - {USBB2_ULPITLL_CLK, (IEN | M3)}, /* gpio_157 */ + {USBB2_ULPITLL_CLK, (PTD | IEN | M3)}, /* gpio_157 */ {USBB2_ULPITLL_STP, (IEN | M5)}, /* dispc2_data23 */ {USBB2_ULPITLL_DIR, (IEN | M5)}, /* dispc2_data22 */ {USBB2_ULPITLL_NXT, (IEN | M5)}, /* dispc2_data21 */ @@ -157,12 +155,12 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {USBB2_ULPITLL_DAT7, (IEN | M5)}, /* dispc2_data11 */ {USBB2_HSIC_DATA, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_169 */ {USBB2_HSIC_STROBE, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_170 */ - {UNIPRO_TX0, (PTD | IEN | M3)}, /* gpio_171 */ + {UNIPRO_TX0, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col0 */ {UNIPRO_TY0, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col1 */ {UNIPRO_TX1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col2 */ {UNIPRO_TY1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col3 */ - {UNIPRO_TX2, (PTU | IEN | M3)}, /* gpio_0 */ - {UNIPRO_TY2, (PTU | IEN | M3)}, /* gpio_1 */ + {UNIPRO_TX2, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col4 */ + {UNIPRO_TY2, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col5 */ {UNIPRO_RX0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row0 */ {UNIPRO_RY0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row1 */ {UNIPRO_RX1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row2 */ @@ -173,13 +171,13 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {USBA0_OTG_DP, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dp */ {USBA0_OTG_DM, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dm */ {FREF_CLK1_OUT, (M0)}, /* fref_clk1_out */ - {FREF_CLK2_OUT, (PTU | IEN | M3)}, /* gpio_182 */ + {FREF_CLK2_OUT, (M0)}, /* fref_clk2_out */ {SYS_NIRQ1, (PTU | IEN | M0)}, /* sys_nirq1 */ - {SYS_NIRQ2, (PTU | IEN | M0)}, /* sys_nirq2 */ + {SYS_NIRQ2, (M7)}, /* sys_nirq2 */ {SYS_BOOT0, (PTU | IEN | M3)}, /* gpio_184 */ {SYS_BOOT1, (M3)}, /* gpio_185 */ {SYS_BOOT2, (PTD | IEN | M3)}, /* gpio_186 */ - {SYS_BOOT3, (M3)}, /* gpio_187 */ + {SYS_BOOT3, (PTD | IEN | M3)}, /* gpio_187 */ {SYS_BOOT4, (M3)}, /* gpio_188 */ {SYS_BOOT5, (PTD | IEN | M3)}, /* gpio_189 */ {DPM_EMU0, (IEN | M0)}, /* dpm_emu0 */ @@ -205,25 +203,28 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { };
const struct pad_conf_entry wkup_padconf_array_non_essential[] = { - {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ - {PAD1_SIM_CLK, (M0)}, /* sim_clk */ - {PAD0_SIM_RESET, (M0)}, /* sim_reset */ - {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ - {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_FREF_XTAL_IN, (M0)}, /* # */ - {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ - {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ - {PAD0_FREF_CLK0_OUT, (M2)}, /* sys_drm_msecure */ - {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ - {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ - {PAD1_FREF_CLK4_REQ, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_1 */ - {PAD0_FREF_CLK4_OUT, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_2 */ - {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ - {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ - {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ - {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ - {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ - {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ + {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ + {PAD1_SIM_CLK, (M0)}, /* sim_clk */ + {PAD0_SIM_RESET, (M0)}, /* sim_reset */ + {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ + {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ + {PAD1_FREF_XTAL_IN, (M0)}, /* # */ + {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ + {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ + {PAD0_FREF_CLK0_OUT, (M2)}, /* sys_drm_msecure */ + {PAD1_FREF_CLK3_REQ, (PTU | IEN | M0)}, /* # */ + {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ + {PAD1_FREF_CLK4_REQ, (PTU | IEN | M0)}, /* # */ + {PAD0_FREF_CLK4_OUT, (M0)}, /* # */ + {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ + {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ + {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ + {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ + {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ + {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ + {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ + {PAD1_FREF_CLK4_REQ, (M3)}, /* gpio_wk7 */ + {PAD0_FREF_CLK4_OUT, (M3)}, /* gpio_wk8 */ };
-#endif /* _PANDA_MUX_DATA_H_ */ +#endif /* _SDP4430_MUX_DATA_H */ diff --git a/board/ti/sdp4430/sdp4430_mux_data.h b/board/ti/sdp4430/sdp4430_mux_data.h index e6081dc..16cc0ad 100644 --- a/board/ti/sdp4430/sdp4430_mux_data.h +++ b/board/ti/sdp4430/sdp4430_mux_data.h @@ -84,14 +84,14 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {CAM_SHUTTER, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_shutter */ {CAM_STROBE, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_strobe */ {CAM_GLOBALRESET, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_83 */ - {USBB1_ULPITLL_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M4)},/* usbb1_ulpiphy_clk */ - {USBB1_ULPITLL_STP, (OFF_EN | OFF_OUT_PTD | M4)}, /* usbb1_ulpiphy_stp */ - {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dir */ - {USBB1_ULPITLL_NXT, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_nxt */ - {USBB1_ULPITLL_DAT0, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat0 */ - {USBB1_ULPITLL_DAT1, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat1 */ - {USBB1_ULPITLL_DAT2, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat2 */ - {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat3 */ + {USBB1_ULPITLL_CLK, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cawake */ + {USBB1_ULPITLL_STP, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cadata */ + {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caflag */ + {USBB1_ULPITLL_NXT, (OFF_EN | M1)}, /* hsi1_acready */ + {USBB1_ULPITLL_DAT0, (OFF_EN | M1)}, /* hsi1_acwake */ + {USBB1_ULPITLL_DAT1, (OFF_EN | M1)}, /* hsi1_acdata */ + {USBB1_ULPITLL_DAT2, (OFF_EN | M1)}, /* hsi1_acflag */ + {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caready */ {USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ {USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ {USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ @@ -104,8 +104,8 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ {ABE_MCBSP2_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_fsx */ - {ABE_MCBSP1_CLKX, (IEN | M1)}, /* abe_slimbus1_clock */ - {ABE_MCBSP1_DR, (IEN | M1)}, /* abe_slimbus1_data */ + {ABE_MCBSP1_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_clkx */ + {ABE_MCBSP1_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dr */ {ABE_MCBSP1_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dx */ {ABE_MCBSP1_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_fsx */ {ABE_PDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_ul_data */ @@ -141,7 +141,7 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {MCSPI4_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_cs0 */ {UART4_RX, (IEN | M0)}, /* uart4_rx */ {UART4_TX, (M0)}, /* uart4_tx */ - {USBB2_ULPITLL_CLK, (IEN | M3)}, /* gpio_157 */ + {USBB2_ULPITLL_CLK, (PTD | IEN | M3)}, /* gpio_157 */ {USBB2_ULPITLL_STP, (IEN | M5)}, /* dispc2_data23 */ {USBB2_ULPITLL_DIR, (IEN | M5)}, /* dispc2_data22 */ {USBB2_ULPITLL_NXT, (IEN | M5)}, /* dispc2_data21 */ @@ -173,11 +173,11 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {FREF_CLK1_OUT, (M0)}, /* fref_clk1_out */ {FREF_CLK2_OUT, (M0)}, /* fref_clk2_out */ {SYS_NIRQ1, (PTU | IEN | M0)}, /* sys_nirq1 */ - {SYS_NIRQ2, (PTU | IEN | M0)}, /* sys_nirq2 */ + {SYS_NIRQ2, (M7)}, /* sys_nirq2 */ {SYS_BOOT0, (PTU | IEN | M3)}, /* gpio_184 */ {SYS_BOOT1, (M3)}, /* gpio_185 */ {SYS_BOOT2, (PTD | IEN | M3)}, /* gpio_186 */ - {SYS_BOOT3, (M3)}, /* gpio_187 */ + {SYS_BOOT3, (PTD | IEN | M3)}, /* gpio_187 */ {SYS_BOOT4, (M3)}, /* gpio_188 */ {SYS_BOOT5, (PTD | IEN | M3)}, /* gpio_189 */ {DPM_EMU0, (IEN | M0)}, /* dpm_emu0 */ @@ -222,6 +222,9 @@ const struct pad_conf_entry wkup_padconf_array_non_essential[] = { {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ + {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ + {PAD1_FREF_CLK4_REQ, (M3)}, /* gpio_wk7 */ + {PAD0_FREF_CLK4_OUT, (M3)}, /* gpio_wk8 */ };
Add support for: 1. DPLL locking 2. Initialization of clock domains and clock modules
This work draws upon previous work done for x-loader mainly by: Santosh Shilimkar santosh.shilimkar@ti.com Rajendra Nayak rnayak@ti.com
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap4/Makefile | 1 + arch/arm/cpu/armv7/omap4/board.c | 1 + arch/arm/cpu/armv7/omap4/clocks.c | 717 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/clocks.h | 504 +++++++++++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 6 + arch/arm/include/asm/omap_common.h | 3 + spl/board/ti/sdp4430/Makefile | 6 +- 7 files changed, 1237 insertions(+), 1 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/clocks.c create mode 100644 arch/arm/include/asm/arch-omap4/clocks.h
diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index 987dc9d..6154e86 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -30,6 +30,7 @@ SOBJS += lowlevel_init.o COBJS += board.o COBJS += mem.o COBJS += sys_info.o +COBJS += clocks.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 95b6a96..62a59ad 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -105,6 +105,7 @@ void s_init(void) { watchdog_init(); set_mux_conf_regs(); + prcm_init(); #ifdef CONFIG_PRELOADER preloader_console_init(); #endif diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c new file mode 100644 index 0000000..317f30f --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/clocks.c @@ -0,0 +1,717 @@ +/* + * + * Clock initialization for OMAP4 + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * Based on previous work by: + * Santosh Shilimkar santosh.shilimkar@ti.com + * Rajendra Nayak rnayak@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/omap_common.h> +#include <asm/arch/clocks.h> +#include <asm/arch/sys_proto.h> + +#define abs(x) (((x) < 0) ? ((x)*-1) : (x)) + +static const u32 sys_clk_array[8] = { + 0, /* Uninitialized */ + 12000000, /* 12 MHz */ + 13000000, /* 13 MHz */ + 16800000, /* 16.8 MHz */ + 19200000, /* 19.2 MHz */ + 26000000, /* 26 MHz */ + 27000000, /* 27 MHz */ + 38400000, /* 38.4 MHz */ +}; + +static const struct dpll_params core_dpll_params_opp100 = { + 0, 0, 1600000, 1, 5, 8, 4, 6, 5 +}; + +static const struct dpll_params core_dpll_params_opp100_ddr200 = { + 0, 0, 1600000, 2, 5, 8, 4, 6, 5 +}; + +static const struct dpll_params core_dpll_params_es1_l3_190 = { + 0, 0, 1523712, 1, 5, 8, 4, 6, 5 +}; + +static const struct dpll_params per_dpll_params_opp100 = { + 0, 0, 1536000, 8, 6, 12, 9, 4, 5 +}; + +/* TODO - fix MPU mult */ +static const struct dpll_params mpu_dpll_params_600mhz = { + 0, 0, 1200000, 1, -1, -1, -1, -1, -1 +}; + +static const struct dpll_params mpu_dpll_params_1000mhz = { + 0, 0, 2000000, 1, -1, -1, -1, -1, -1 +}; + +static const struct dpll_params usb_dpll_params = { + 0, 0, 1920000, 2, -1, -1, -1, -1, -1 +}; + +static const struct dpll_params iva_dpll_params = { + 0, 0, 1862000, -1, -1, 4, 7, -1, -1 +}; + +static const struct dpll_params abe_dpll_params = { + 0, 0, 196608, 1, 1, -1, -1, -1, -1 +}; + +static const u32 clk_domains_essential[] = { + CM_L4PER_CLKSTCTRL, + CM_L3INIT_CLKSTCTRL, + CM_MEMIF_CLKSTCTRL, + CM_L4CFG_CLKSTCTRL, + 0 +}; + +static const u32 clk_domains_non_essential[] = { + CM_MPU_M3_CLKSTCTRL, + CM_IVAHD_CLKSTCTRL, + CM_DSP_CLKSTCTRL, + CM_DSS_CLKSTCTRL, + CM_SGX_CLKSTCTRL, + CM1_ABE_CLKSTCTRL, + CM_C2C_CLKSTCTRL, + CM_CAM_CLKSTCTRL, + CM_DSS_CLKSTCTRL, + CM_SDMA_CLKSTCTRL, + 0 +}; + +static const u32 clk_modules_hw_auto_essential[] = { + CM_WKUP_GPIO1_CLKCTRL, + CM_L4PER_GPIO2_CLKCTRL, + CM_L4PER_GPIO3_CLKCTRL, + CM_L4PER_GPIO4_CLKCTRL, + CM_L4PER_GPIO5_CLKCTRL, + CM_L4PER_GPIO6_CLKCTRL, + CM_MEMIF_EMIF_1_CLKCTRL, + CM_MEMIF_EMIF_2_CLKCTRL, + CM_L3INIT_HSUSBOTG_CLKCTRL, + CM_L3INIT_USBPHY_CLKCTRL, + CM_L4CFG_L4_CFG_CLKCTRL, + 0 +}; + +static const u32 clk_modules_hw_auto_non_essential[] = { + CM_MPU_M3_MPU_M3_CLKCTRL, + CM_IVAHD_IVAHD_CLKCTRL, + CM_IVAHD_SL2_CLKCTRL, + CM_DSP_DSP_CLKCTRL, + CM_L3_2_GPMC_CLKCTRL, + CM_L3INSTR_L3_3_CLKCTRL, + CM_L3INSTR_L3_INSTR_CLKCTRL, + CM_L3INSTR_INTRCONN_WP1_CLKCTRL, + CM_L3INIT_HSI_CLKCTRL, + CM_L3INIT_HSUSBTLL_CLKCTRL, + 0 +}; + +static const u32 clk_modules_explicit_en_essential[] = { + CM_L4PER_GPTIMER2_CLKCTRL, + CM_L3INIT_HSMMC1_CLKCTRL, + CM_L3INIT_HSMMC2_CLKCTRL, + CM_L4PER_MCSPI1_CLKCTRL, + CM_WKUP_GPTIMER1_CLKCTRL, + CM_L4PER_I2C1_CLKCTRL, + CM_L4PER_I2C2_CLKCTRL, + CM_L4PER_I2C3_CLKCTRL, + CM_L4PER_I2C4_CLKCTRL, + CM_WKUP_WDTIMER2_CLKCTRL, + CM_L4PER_UART3_CLKCTRL, + 0 +}; + +static const u32 clk_modules_explicit_en_non_essential[] = { + CM1_ABE_AESS_CLKCTRL, + CM1_ABE_PDM_CLKCTRL, + CM1_ABE_DMIC_CLKCTRL, + CM1_ABE_MCASP_CLKCTRL, + CM1_ABE_MCBSP1_CLKCTRL, + CM1_ABE_MCBSP2_CLKCTRL, + CM1_ABE_MCBSP3_CLKCTRL, + CM1_ABE_SLIMBUS_CLKCTRL, + CM1_ABE_TIMER5_CLKCTRL, + CM1_ABE_TIMER6_CLKCTRL, + CM1_ABE_TIMER7_CLKCTRL, + CM1_ABE_TIMER8_CLKCTRL, + CM1_ABE_WDT3_CLKCTRL, + CM_L4PER_GPTIMER9_CLKCTRL, + CM_L4PER_GPTIMER10_CLKCTRL, + CM_L4PER_GPTIMER11_CLKCTRL, + CM_L4PER_GPTIMER3_CLKCTRL, + CM_L4PER_GPTIMER4_CLKCTRL, + CM_L4PER_HDQ1W_CLKCTRL, + CM_L4PER_MCBSP4_CLKCTRL, + CM_L4PER_MCSPI2_CLKCTRL, + CM_L4PER_MCSPI3_CLKCTRL, + CM_L4PER_MCSPI4_CLKCTRL, + CM_L4PER_MMCSD3_CLKCTRL, + CM_L4PER_MMCSD4_CLKCTRL, + CM_L4PER_MMCSD5_CLKCTRL, + CM_L4PER_UART1_CLKCTRL, + CM_L4PER_UART2_CLKCTRL, + CM_L4PER_UART4_CLKCTRL, + CM_WKUP_KEYBOARD_CLKCTRL, + CM_WKUP_WDTIMER2_CLKCTRL, + CM_CAM_ISS_CLKCTRL, + CM_CAM_FDIF_CLKCTRL, + CM_DSS_DSS_CLKCTRL, + CM_SGX_SGX_CLKCTRL, + CM_L3INIT_HSUSBHOST_CLKCTRL, + CM_L3INIT_FSUSB_CLKCTRL, + 0 +}; + +static u32 get_m_n(u32 target_freq_khz, u32 ref_freq_khz, u32 *m, u32 *n, + u32 tolerance_khz) +{ + u32 min_freq = target_freq_khz - tolerance_khz; + u32 max_freq = target_freq_khz; + u32 freq, freq_old; + *n = 1; + while (1) { + *m = min_freq / ref_freq_khz / 2 * (*n); + freq_old = 0; + while (1) { + freq = ref_freq_khz * 2 * (*m) / (*n); + if (abs(target_freq_khz - freq_old) <= + abs(target_freq_khz - freq)) { + freq = freq_old; + (*m)--; + break; + } + (*m)++; + freq_old = freq; + } + if (freq >= min_freq && freq <= max_freq) + break; + (*n)++; + if ((*n) > OMAP_DPLL_MAX_N + 1) + return 1; + } + (*n)--; + return 0; +} + +static u32 __get_syc_clk_freq(void) +{ + /* + * For ES1 the ROM code calibration of sys clock is not reliable + * due to hw issue. So, use hard-coded value. If this value is not + * correct for any board over-ride this function in board file + * From ES2.0 onwards you will get this information from + * CM_SYS_CLKSEL + */ + if (omap4_revision() == OMAP4430_ES1_0) + return OMAP_SYS_CLK_FREQ_38_4_MHZ; + else { + u32 sys_clk_ind = readl(CM_SYS_CLKSEL) & + CM_SYS_CLKSEL_SYS_CLKSEL_MASK; + return sys_clk_array[sys_clk_ind]; + } +} + +static inline void do_bypass_dpll(u32 base) +{ + struct dpll_regs *dpll_regs = (struct dpll_regs *)base; + + modify_reg_32(&dpll_regs->cm_clkmode_dpll, + CM_CLKMODE_DPLL_DPLL_EN_SHIFT, + CM_CLKMODE_DPLL_DPLL_EN_MASK, DPLL_EN_FAST_RELOCK_BYPASS); +} + +static inline void wait_for_bypass(u32 base) +{ + struct dpll_regs *dpll_regs = (struct dpll_regs *)base; + + while (readl(&dpll_regs->cm_idlest_dpll) & ST_DPLL_CLK_MASK) + ; +} + +static inline void do_lock_dpll(u32 base) +{ + struct dpll_regs *dpll_regs = (struct dpll_regs *)base; + + modify_reg_32(&dpll_regs->cm_clkmode_dpll, + CM_CLKMODE_DPLL_DPLL_EN_SHIFT, + CM_CLKMODE_DPLL_DPLL_EN_MASK, DPLL_EN_LOCK); +} + +static inline void wait_for_lock(u32 base) +{ + struct dpll_regs *dpll_regs = (struct dpll_regs *)base; + + while (!(readl(&dpll_regs->cm_idlest_dpll) & ST_DPLL_CLK_MASK)) + ; +} + +static void do_setup_dpll(u32 base, const struct dpll_params *params, + u32 ref_clk_khz, u32 tolerance, u8 lock) +{ + u32 temp, m, n; + struct dpll_regs *dpll_regs = (struct dpll_regs *)base; + + do_bypass_dpll(base); + + /* Get the M & N values */ + m = params->m; + n = params->n; + /* if m & n are not specified calculate them */ + if (!(m && n)) { + if (get_m_n(params->locked_freq_khz, ref_clk_khz, + &m, &n, tolerance)) { + /* DPLL locking is critical if it fails just hang */ + for (;;) + ; + return; + } + } + + /* Wait till the DPLL is in BYPASS */ + wait_for_bypass(base); + + /* Set M & N */ + temp = readl(&dpll_regs->cm_clksel_dpll); + set_bit_field(temp, CM_CLKSEL_DPLL_M_SHIFT, CM_CLKSEL_DPLL_M_MASK, m); + set_bit_field(temp, CM_CLKSEL_DPLL_N_SHIFT, CM_CLKSEL_DPLL_N_MASK, n); + writel(temp, &dpll_regs->cm_clksel_dpll); + + /* Lock */ + if (lock) + do_lock_dpll(base); + + /* Setup post-dividers */ + if (params->m2 >= 0) + writel(params->m2, &dpll_regs->cm_div_m2_dpll); + if (params->m3 >= 0) + writel(params->m3, &dpll_regs->cm_div_m3_dpll); + if (params->m4 >= 0) + writel(params->m4, &dpll_regs->cm_div_m4_dpll); + if (params->m5 >= 0) + writel(params->m5, &dpll_regs->cm_div_m5_dpll); + if (params->m6 >= 0) + writel(params->m6, &dpll_regs->cm_div_m6_dpll); + if (params->m7 >= 0) + writel(params->m7, &dpll_regs->cm_div_m7_dpll); + + /* Wait till the DPLL locks */ + if (lock) + wait_for_lock(base); +} + +const struct dpll_params *get_core_dpll_params(void) +{ + switch (omap4_revision()) { + case OMAP4430_ES1_0: + return &core_dpll_params_es1_l3_190; + case OMAP4430_ES2_0: + case OMAP4430_SILICON_ID_INVALID: + return &core_dpll_params_opp100_ddr200; /* safest */ + case OMAP4430_ES2_1: + case OMAP4430_ES2_2: + return &core_dpll_params_opp100; + default: + return NULL; + } +} + +u32 omap4_ddr_clk(void) +{ + u32 ddr_clk; + const struct dpll_params *core_dpll_params; + + core_dpll_params = get_core_dpll_params(); + /* + * DDR frequency is PHY_ROOT_CLK/2 + * PHY_ROOT_CLK = Fdpll/2/M2 + */ + ddr_clk = core_dpll_params->locked_freq_khz / 4 / core_dpll_params->m2; + ddr_clk *= 1000; /* convert to Hz */ + return ddr_clk; +} + +static void setup_dplls(void) +{ + u32 sys_clk_khz, temp; + const struct dpll_params *params; + + sys_clk_khz = get_syc_clk_freq() / 1000; + + /* CORE dpll */ + params = get_core_dpll_params(); /* default - safest */ + /* + * Do not lock the core DPLL now. Just set it up. + * Core DPLL will be locked after setting up EMIF + * using the FREQ_UPDATE method(freq_update_core()) + */ + do_setup_dpll(CM_CLKMODE_DPLL_CORE, params, sys_clk_khz, + DPLL_LOCKED_FREQ_TOLERANCE_0, CONFIGURE_NO_LOCK); + /* Set the ratios for CORE_CLK, L3_CLK, L4_CLK */ + temp = (CLKSEL_CORE_X2_DIV_1 << CLKSEL_CORE_SHIFT) | + (CLKSEL_L3_CORE_DIV_2 << CLKSEL_L3_SHIFT) | + (CLKSEL_L4_L3_DIV_2 << CLKSEL_L4_SHIFT); + writel(temp, CM_CLKSEL_CORE); + + /* lock PER dpll */ + do_setup_dpll(CM_CLKMODE_DPLL_PER, &per_dpll_params_opp100, sys_clk_khz, + DPLL_LOCKED_FREQ_TOLERANCE_0, CONFIGURE_AND_LOCK); + + /* MPU dpll */ + if (omap4_revision() == OMAP4430_ES1_0) + params = &mpu_dpll_params_600mhz; + else + params = &mpu_dpll_params_1000mhz; + do_setup_dpll(CM_CLKMODE_DPLL_MPU, params, sys_clk_khz, + DPLL_LOCKED_FREQ_TOLERANCE_0, CONFIGURE_AND_LOCK); +} + +static void setup_non_essential_dplls(void) +{ + u32 sys_clk_khz, temp, abe_ref_clk; + u32 m, n, sd_div, num, den; + struct dpll_params tmp_params; + + sys_clk_khz = get_syc_clk_freq() / 1000; + + /* IVA */ + do_setup_dpll(CM_CLKMODE_DPLL_IVA, &iva_dpll_params, sys_clk_khz, + DPLL_LOCKED_FREQ_TOLERANCE_500_KHZ, CONFIGURE_AND_LOCK); + + /* USB */ + tmp_params = usb_dpll_params; + get_m_n(tmp_params.locked_freq_khz, sys_clk_khz, &m, &n, + DPLL_LOCKED_FREQ_TOLERANCE_0); + /* + * USB dpll is J-type. Need to set DPLL_SD_DIV for jitter correction + * DPLL_SD_DIV = CEILING ([DPLL_MULT/(DPLL_DIV+1)]* CLKINP / 250) + * - where CLKINP is sys_clk in MHz + * Use CLKINP in KHz and adjust the denominator accordingly so + * that we have enough accuracy and at the same time no overflow + */ + num = m * sys_clk_khz; + den = (n + 1) * 250 * 1000; + num += den - 1; + sd_div = num / den; + temp = readl(CM_CLKSEL_DPLL_USB); + set_bit_field(temp, CM_CLKSEL_DPLL_DPLL_SD_DIV_SHIFT, + CM_CLKSEL_DPLL_DPLL_SD_DIV_MASK, sd_div); + writel(temp, CM_CLKSEL_DPLL_USB); + /* Now setup the dpll with the regular function */ + tmp_params.m = m; + tmp_params.n = n; + do_setup_dpll(CM_CLKMODE_DPLL_USB, &tmp_params, sys_clk_khz, + DPLL_LOCKED_FREQ_TOLERANCE_0, CONFIGURE_AND_LOCK); + + /* ABE dpll */ + tmp_params = abe_dpll_params; +#ifdef CONFIG_SYS_OMAP4_ABE_SYSCK + abe_ref_clk = sys_clk_khz; +#else + /* Enable REGM4XEN to achieve 196.608MHz from 32768 Hz */ + writel(readl(CM_CLKMODE_DPLL_ABE) | CM_CLKMODE_DPLL_DPLL_REGM4XEN_MASK, + CM_CLKMODE_DPLL_ABE); + + /* + * Converting the input clock 32768 Hz to KHz would result in accuracy + * loss. Instead make both target frequency and reference clock to be + * in terms of Hz. + * + * Also, REGM4XEN is enabled so there is an additional + * multiplier of 4 for M. So adjust for this while passing target + * frequency to get_m_n() + */ + tmp_params.locked_freq_khz = tmp_params.locked_freq_khz * 1000 / 4; + abe_ref_clk = OMAP_32K_CLK_FREQ; +#endif + temp = (abe_ref_clk == OMAP_32K_CLK_FREQ) ? + CM_ABE_PLL_REF_CLKSEL_CLKSEL_32KCLK : + CM_ABE_PLL_REF_CLKSEL_CLKSEL_SYSCLK; + /* Select the right reference clk */ + modify_reg_32(CM_ABE_PLL_REF_CLKSEL, + CM_ABE_PLL_REF_CLKSEL_CLKSEL_SHIFT, + CM_ABE_PLL_REF_CLKSEL_CLKSEL_MASK, + temp); + /* Lock the dpll */ + do_setup_dpll(CM_CLKMODE_DPLL_ABE, &tmp_params, abe_ref_clk, + DPLL_LOCKED_FREQ_TOLERANCE_0, CONFIGURE_AND_LOCK); +} + +static void do_scale_vcore(u32 vcore_reg, u32 volt) +{ + u32 temp; + + temp = SMPS_I2C_SLAVE_ADDR | + (vcore_reg << PRM_VC_VAL_BYPASS_REGADDR_SHIFT) | + (volt << PRM_VC_VAL_BYPASS_DATA_SHIFT) | + PRM_VC_VAL_BYPASS_VALID_BIT; + writel(temp, PRM_VC_VAL_BYPASS); + while (readl(PRM_VC_VAL_BYPASS) & PRM_VC_VAL_BYPASS_VALID_BIT) + ; +} + +static void scale_vcores(void) +{ + u32 volt, sys_clk_khz, cycles_hi, cycles_low, temp; + u32 omap4_rev = omap4_revision(); + + sys_clk_khz = get_syc_clk_freq() / 1000; + + /* + * Setup the dedicated I2C controller for Voltage Control + * I2C clk - high period 40% low period 60% + */ + cycles_hi = sys_clk_khz * 4 / PRM_VC_I2C_CHANNEL_FREQ_KHZ / 10; + cycles_low = sys_clk_khz * 6 / PRM_VC_I2C_CHANNEL_FREQ_KHZ / 10; + /* values to be set in register - less by 5 & 7 respectively */ + cycles_hi -= 5; + cycles_low -= 7; + temp = (cycles_hi << PRM_VC_CFG_I2C_CLK_SCLH_SHIFT) | + (cycles_low << PRM_VC_CFG_I2C_CLK_SCLL_SHIFT); + writel(temp, PRM_VC_CFG_I2C_CLK); + + /* Disable high speed mode and all advanced features */ + writel(0x0, PRM_VC_CFG_I2C_MODE); + + /* VCORE 1 */ + if ((omap4_rev == OMAP4430_ES2_0) || (omap4_rev == OMAP4430_ES2_1)) + volt = SMPS_VOLT_1_3500_V; + else + volt = SMPS_VOLT_1_5000_V; + do_scale_vcore(SMPS_REG_ADDR_VCORE1, volt); + + /* VCORE 2 */ + if ((omap4_rev == OMAP4430_ES2_0) || (omap4_rev == OMAP4430_ES2_1)) + volt = SMPS_VOLT_1_1000_V; + else + volt = SMPS_VOLT_1_2000_V; + do_scale_vcore(SMPS_REG_ADDR_VCORE2, volt); + + /* VCORE 3 */ + if (omap4_rev == OMAP4430_ES2_0) + volt = SMPS_VOLT_1_1000_V; + else if (omap4_rev == OMAP4430_ES2_1) + volt = SMPS_VOLT_1_1125_V; + else + volt = SMPS_VOLT_1_2000_V; + + do_scale_vcore(SMPS_REG_ADDR_VCORE3, volt); +} + +static void enable_clock_domain(u32 clkctrl_reg, u32 enable_mode) +{ + modify_reg_32(clkctrl_reg, CD_CLKCTRL_CLKTRCTRL_SHIFT, + CD_CLKCTRL_CLKTRCTRL_MASK, enable_mode); +} + +static inline void wait_for_clk_enable(u32 clkctrl_addr) +{ + u32 idlest = MODULE_CLKCTRL_IDLEST_DISABLED; + + while ((idlest == MODULE_CLKCTRL_IDLEST_DISABLED) || + (idlest == MODULE_CLKCTRL_IDLEST_TRANSITIONING)) { + idlest = readl(clkctrl_addr); + idlest = get_bit_field(idlest, MODULE_CLKCTRL_IDLEST_SHIFT, + MODULE_CLKCTRL_IDLEST_MASK); + } +} + +static void enable_clock_module(u32 clkctrl_addr, u32 enable_mode, + u32 wait_for_enable) +{ + modify_reg_32(clkctrl_addr, MODULE_CLKCTRL_MODULEMODE_SHIFT, + MODULE_CLKCTRL_MODULEMODE_MASK, enable_mode); + if (wait_for_enable) + wait_for_clk_enable(clkctrl_addr); +} + +/* + * Enable a set of clock domains and clock modules associated with them + */ +static void enable_clocks(const u32 *clock_domains, + const u32 *clock_modules_hw_auto, + const u32 *clock_modules_explicit_en, + u32 wait_for_enable) +{ + int i = 0, max = 100; + /* Put the clock domains in SW_WKUP mode */ + for (i = 0; (i < max) && clock_domains[i]; i++) { + enable_clock_domain(clock_domains[i], + CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + } + + /* Clock modules that need to be put in HW_AUTO */ + for (i = 0; (i < max) && clock_modules_hw_auto[i]; i++) { + enable_clock_module(clock_modules_hw_auto[i], + MODULE_CLKCTRL_MODULEMODE_HW_AUTO, + wait_for_enable); + }; + + /* Clock modules that need to be put in SW_EXPLICIT_EN mode */ + for (i = 0; (i < max) && clock_modules_explicit_en[i]; i++) { + enable_clock_module(clock_modules_explicit_en[i], + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN, + wait_for_enable); + }; + + /* Put the clock domains in HW_AUTO mode now */ + for (i = 0; (i < max) && clock_domains[i]; i++) { + enable_clock_domain(clock_domains[i], + CD_CLKCTRL_CLKTRCTRL_HW_AUTO); + } +} + +/* + * Enable essential clock domains, modules and + * do some additional special settings needed + */ +static void enable_basic_clocks(void) +{ + /* Enable optional additional functional clock for GPIO4 */ + writel(readl(CM_L4PER_GPIO4_CLKCTRL) | GPIO4_CLKCTRL_OPTFCLKEN_SHIFT, + CM_L4PER_GPIO4_CLKCTRL); + + /* Enable 96 MHz clock for MMC1 & MMC2 */ + writel(readl(CM_L3INIT_HSMMC1_CLKCTRL) | HSMMC_CLKCTRL_CLKSEL_SHIFT, + CM_L3INIT_HSMMC1_CLKCTRL); + writel(readl(CM_L3INIT_HSMMC2_CLKCTRL) | HSMMC_CLKCTRL_CLKSEL_SHIFT, + CM_L3INIT_HSMMC2_CLKCTRL); + + /* Select 32KHz clock as the source of GPTIMER1 */ + writel(readl(CM_WKUP_GPTIMER1_CLKCTRL) | GPTIMER1_CLKCTRL_CLKSEL_SHIFT, + CM_WKUP_GPTIMER1_CLKCTRL); + + /* Enable optional 48M functional clock for USB PHY */ + writel(readl(CM_L3INIT_USBPHY_CLKCTRL) | + USBPHY_CLKCTRL_OPTFCLKEN_PHY_48M_MASK, CM_L3INIT_USBPHY_CLKCTRL); + + /* Enable all essential clock domains and modules */ + enable_clocks(clk_domains_essential, + clk_modules_hw_auto_essential, + clk_modules_explicit_en_essential, 1); +} + +/* + * Enable non-essential clock domains, modules and + * do some additional special settings needed + */ +static void enable_non_essential_clocks(void) +{ + u32 tmp; + /* Enable optional functional clock for ISS */ + writel(readl(CM_CAM_ISS_CLKCTRL) | ISS_CLKCTRL_OPTFCLKEN_SHIFT, + CM_CAM_ISS_CLKCTRL); + + /* Enable all optional functional clocks of DSS */ + writel(readl(CM_DSS_DSS_CLKCTRL) | DSS_CLKCTRL_OPTFCLKEN_MASK, + CM_DSS_DSS_CLKCTRL); + + /* Enable all non-essential clock domains and modules */ + enable_clocks(clk_domains_non_essential, + clk_modules_hw_auto_non_essential, + clk_modules_explicit_en_non_essential, 0); + + /* Put camera module in no sleep mode */ + tmp = readl(CM_CAM_CLKSTCTRL); + set_bit_field(tmp, MODULE_CLKCTRL_MODULEMODE_SHIFT, + MODULE_CLKCTRL_MODULEMODE_MASK, + CD_CLKCTRL_CLKTRCTRL_NO_SLEEP); + writel(tmp, CM_CAM_CLKSTCTRL); +} + +void freq_update_core(void) +{ + u32 freq_config1 = 0; + const struct dpll_params *core_dpll_params; + + core_dpll_params = get_core_dpll_params(); + /* Put EMIF clock domain in sw wakeup mode */ + enable_clock_domain(CM_MEMIF_CLKSTCTRL, CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + wait_for_clk_enable(CM_MEMIF_EMIF_1_CLKCTRL); + wait_for_clk_enable(CM_MEMIF_EMIF_2_CLKCTRL); + + freq_config1 = SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK | + SHADOW_FREQ_CONFIG1_DLL_RESET_MASK; + + set_bit_field(freq_config1, SHADOW_FREQ_CONFIG1_DPLL_EN_SHIFT, + SHADOW_FREQ_CONFIG1_DPLL_EN_MASK, DPLL_EN_LOCK); + + set_bit_field(freq_config1, SHADOW_FREQ_CONFIG1_M2_DIV_SHIFT, + SHADOW_FREQ_CONFIG1_M2_DIV_MASK, core_dpll_params->m2); + + writel(freq_config1, CM_SHADOW_FREQ_CONFIG1); + while (readl(CM_SHADOW_FREQ_CONFIG1) & + SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK) + ; + + /* Put EMIF clock domain back in hw auto mode */ + enable_clock_domain(CM_MEMIF_CLKSTCTRL, CD_CLKCTRL_CLKTRCTRL_HW_AUTO); + wait_for_clk_enable(CM_MEMIF_EMIF_1_CLKCTRL); + wait_for_clk_enable(CM_MEMIF_EMIF_2_CLKCTRL); +} + +void bypass_dpll(u32 base) +{ + do_bypass_dpll(base); + wait_for_bypass(base); +} + +void lock_dpll(u32 base) +{ + do_lock_dpll(base); + wait_for_lock(base); +} + +u32 get_syc_clk_freq(void) + __attribute__ ((weak, alias("__get_syc_clk_freq"))); + +void prcm_init(void) +{ + switch (omap4_hw_init_context()) { + case OMAP_INIT_CONTEXT_SPL: + scale_vcores(); + setup_dplls(); + enable_basic_clocks(); + break; + case OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_SPL: + setup_non_essential_dplls(); + enable_non_essential_clocks(); + break; + case OMAP_INIT_CONTEXT_XIP_UBOOT: + case OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_CH: + scale_vcores(); + setup_dplls(); + enable_basic_clocks(); + setup_non_essential_dplls(); + enable_non_essential_clocks(); + break; + } +} diff --git a/arch/arm/include/asm/arch-omap4/clocks.h b/arch/arm/include/asm/arch-omap4/clocks.h new file mode 100644 index 0000000..fdbe632 --- /dev/null +++ b/arch/arm/include/asm/arch-omap4/clocks.h @@ -0,0 +1,504 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _CLOCKS_OMAP4_H_ +#define _CLOCKS_OMAP4_H_ +#include <common.h> + +#define CM_CLKMODE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4120) +#define CM_CLKMODE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8140) +#define CM_CLKMODE_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4160) +#define CM_CLKSEL_CORE (OMAP44XX_L4_CORE_BASE + 0x4100) + +/* PRM.CKGEN module registers */ +#define CM_ABE_PLL_REF_CLKSEL (OMAP44XX_L4_WKUP_BASE + 0x610C) +#define CM_SYS_CLKSEL (OMAP44XX_L4_WKUP_BASE + 0x6110) + +/* PRM.WKUP_CM module registers */ +#define CM_WKUP_CLKSTCTRL (OMAP44XX_L4_WKUP_BASE + 0x7800) +#define CM_WKUP_L4WKUP_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7820) +#define CM_WKUP_WDTIMER1_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7828) +#define CM_WKUP_WDTIMER2_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7830) +#define CM_WKUP_GPIO1_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7838) +#define CM_WKUP_GPTIMER1_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7840) +#define CM_WKUP_GPTIMER12_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7848) +#define CM_WKUP_SYNCTIMER_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7850) +#define CM_WKUP_USIM_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7858) +#define CM_WKUP_SARRAM_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7860) +#define CM_WKUP_KEYBOARD_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7878) +#define CM_WKUP_RTC_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7880) +#define CM_WKUP_BANDGAP_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7888) + +/* DEVICE_PRM Registers */ +#define PRM_VC_VAL_BYPASS (OMAP44XX_L4_WKUP_BASE + 0x7BA0) +#define PRM_VC_CFG_CHANNEL (OMAP44XX_L4_WKUP_BASE + 0x7BA4) +#define PRM_VC_CFG_I2C_MODE (OMAP44XX_L4_WKUP_BASE + 0x7BA8) +#define PRM_VC_CFG_I2C_CLK (OMAP44XX_L4_WKUP_BASE + 0x7BAC) + +/* CM1.CKGEN module registers */ +#define CM_CLKSEL_CORE (OMAP44XX_L4_CORE_BASE + 0x4100) +#define CM_CLKSEL_ABE (OMAP44XX_L4_CORE_BASE + 0x4108) +#define CM_DLL_CTRL (OMAP44XX_L4_CORE_BASE + 0x4110) +#define CM_CLKMODE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4120) +#define CM_IDLEST_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4124) +#define CM_AUTOIDLE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4128) +#define CM_CLKSEL_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x412c) +#define CM_DIV_M2_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4130) +#define CM_DIV_M3_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4134) +#define CM_DIV_M4_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4138) +#define CM_DIV_M5_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x413c) +#define CM_DIV_M6_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4140) +#define CM_DIV_M7_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4144) +#define CM_SSC_DELTAMSTEP_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4148) +#define CM_SSC_MODFREQDIV_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x414c) +#define CM_EMU_OVERRIDE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4150) +#define CM_CLKMODE_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4160) +#define CM_IDLEST_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4164) +#define CM_AUTOIDLE_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4168) +#define CM_CLKSEL_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x416c) +#define CM_DIV_M2_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4170) +#define CM_SSC_DELTAMSTEP_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4188) +#define CM_SSC_MODFREQDIV_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x418c) +#define CM_BYPCLK_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x419c) +#define CM_CLKMODE_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41a0) +#define CM_IDLEST_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41a4) +#define CM_AUTOIDLE_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41a8) +#define CM_CLKSEL_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41ac) +#define CM_DIV_M4_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41b8) +#define CM_DIV_M5_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41bc) +#define CM_SSC_DELTAMSTEP_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41c8) +#define CM_SSC_MODFREQDIV_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41cc) +#define CM_BYPCLK_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41dc) +#define CM_CLKMODE_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x41e0) +#define CM_IDLEST_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x41e4) +#define CM_AUTOIDLE_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x41e8) +#define CM_CLKSEL_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x41ec) +#define CM_DIV_M2_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x41f0) +#define CM_DIV_M3_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x41f4) +#define CM_SSC_DELTAMSTEP_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x4208) +#define CM_SSC_MODFREQDIV_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x420c) +#define CM_CLKMODE_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4220) +#define CM_IDLEST_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4224) +#define CM_AUTOIDLE_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4228) +#define CM_CLKSEL_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x422c) +#define CM_DIV_M2_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4230) +#define CM_DIV_M4_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4238) +#define CM_DIV_M5_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x423c) +#define CM_DIV_M6_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4240) +#define CM_SSC_DELTAMSTEP_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4248) +#define CM_SHADOW_FREQ_CONFIG1 (OMAP44XX_L4_CORE_BASE + 0x4260) + +/* CM1.ABE register offsets */ +#define CM1_ABE_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x4500) +#define CM1_ABE_L4ABE_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4520) +#define CM1_ABE_AESS_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4528) +#define CM1_ABE_PDM_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4530) +#define CM1_ABE_DMIC_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4538) +#define CM1_ABE_MCASP_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4540) +#define CM1_ABE_MCBSP1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4548) +#define CM1_ABE_MCBSP2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4550) +#define CM1_ABE_MCBSP3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4558) +#define CM1_ABE_SLIMBUS_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4560) +#define CM1_ABE_TIMER5_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4568) +#define CM1_ABE_TIMER6_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4570) +#define CM1_ABE_TIMER7_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4578) +#define CM1_ABE_TIMER8_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4580) +#define CM1_ABE_WDT3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4588) + +/* CM1.DSP register offsets */ +#define CM_DSP_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x4400) +#define CM_DSP_DSP_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4420) + +/* CM2.CKGEN module registers */ +#define CM_CLKSEL_MPU_M3_ISS_ROOT (OMAP44XX_L4_CORE_BASE + 0x8100) +#define CM_CLKSEL_USB_60MHz (OMAP44XX_L4_CORE_BASE + 0x8104) +#define CM_SCALE_FCLK (OMAP44XX_L4_CORE_BASE + 0x8108) +#define CM_CORE_DVFS_PERF1 (OMAP44XX_L4_CORE_BASE + 0x8110) +#define CM_CORE_DVFS_PERF2 (OMAP44XX_L4_CORE_BASE + 0x8114) +#define CM_CORE_DVFS_PERF3 (OMAP44XX_L4_CORE_BASE + 0x8118) +#define CM_CORE_DVFS_PERF4 (OMAP44XX_L4_CORE_BASE + 0x811c) +#define CM_CORE_DVFS_CURRENT (OMAP44XX_L4_CORE_BASE + 0x8124) +#define CM_IVA_DVFS_PERF_TESLA (OMAP44XX_L4_CORE_BASE + 0x8128) +#define CM_IVA_DVFS_PERF_IVAHD (OMAP44XX_L4_CORE_BASE + 0x812c) +#define CM_IVA_DVFS_PERF_ABE (OMAP44XX_L4_CORE_BASE + 0x8130) +#define CM_IVA_DVFS_CURRENT (OMAP44XX_L4_CORE_BASE + 0x8138) +#define CM_CLKMODE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8140) +#define CM_IDLEST_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8144) +#define CM_AUTOIDLE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8148) +#define CM_CLKSEL_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x814c) +#define CM_DIV_M2_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8150) +#define CM_DIV_M3_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8154) +#define CM_DIV_M4_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8158) +#define CM_DIV_M5_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x815c) +#define CM_DIV_M6_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8160) +#define CM_DIV_M7_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8164) +#define CM_SSC_DELTAMSTEP_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8168) +#define CM_SSC_MODFREQDIV_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x816c) +#define CM_EMU_OVERRIDE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8170) +#define CM_CLKMODE_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x8180) +#define CM_IDLEST_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x8184) +#define CM_AUTOIDLE_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x8188) +#define CM_CLKSEL_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x818c) +#define CM_DIV_M2_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x8190) +#define CM_SSC_DELTAMSTEP_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x81a8) +#define CM_SSC_MODFREQDIV_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x81ac) +#define CM_CLKDCOLDO_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x81b4) +#define CM_CLKMODE_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81c0) +#define CM_IDLEST_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81c4) +#define CM_AUTOIDLE_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81c8) +#define CM_CLKSEL_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81cc) +#define CM_DIV_M2_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81d0) +#define CM_SSC_DELTAMSTEP_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81e8) +#define CM_SSC_MODFREQDIV_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81ec) + +/* CM2.CORE module registers */ +#define CM_L3_1_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8700) +#define CM_L3_1_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x8708) +#define CM_L3_1_L3_1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8720) +#define CM_L3_2_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8800) +#define CM_L3_2_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x8808) +#define CM_L3_2_L3_2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8820) +#define CM_L3_2_GPMC_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8828) +#define CM_L3_2_OCMC_RAM_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8830) +#define CM_MPU_M3_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8900) +#define CM_MPU_M3_STATICDEP (OMAP44XX_L4_CORE_BASE + 0x8904) +#define CM_MPU_M3_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x8908) +#define CM_MPU_M3_MPU_M3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8920) +#define CM_SDMA_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8a00) +#define CM_SDMA_STATICDEP (OMAP44XX_L4_CORE_BASE + 0x8a04) +#define CM_SDMA_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x8a08) +#define CM_SDMA_SDMA_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8a20) +#define CM_MEMIF_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8b00) +#define CM_MEMIF_DMM_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b20) +#define CM_MEMIF_EMIF_FW_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b28) +#define CM_MEMIF_EMIF_1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b30) +#define CM_MEMIF_EMIF_2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b38) +#define CM_MEMIF_DLL_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b40) +#define CM_MEMIF_EMIF_H1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b50) +#define CM_MEMIF_EMIF_H2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b58) +#define CM_MEMIF_DLL_H_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b60) +#define CM_C2C_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8c00) +#define CM_C2C_STATICDEP (OMAP44XX_L4_CORE_BASE + 0x8c04) +#define CM_C2C_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x8c08) +#define CM_C2C_SAD2D_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8c20) +#define CM_C2C_MODEM_ICR_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8c28) +#define CM_C2C_SAD2D_FW_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8c30) +#define CM_L4CFG_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8d00) +#define CM_L4CFG_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x8d08) +#define CM_L4CFG_L4_CFG_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8d20) +#define CM_L4CFG_HW_SEM_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8d28) +#define CM_L4CFG_MAILBOX_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8d30) +#define CM_L4CFG_SAR_ROM_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8d38) +#define CM_L3INSTR_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8e00) +#define CM_L3INSTR_L3_3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8e20) +#define CM_L3INSTR_L3_INSTR_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8e28) +#define CM_L3INSTR_INTRCONN_WP1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8e40) + +/* CM2.L3INIT register offsets */ +#define CM_L3INIT_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x9300) + +/* CM2.L4PER register offsets */ +#define CM_L4PER_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x9400) +#define CM_L4PER_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x9408) +#define CM_L4PER_ADC_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9420) +#define CM_L4PER_GPTIMER10_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9428) +#define CM_L4PER_GPTIMER11_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9430) +#define CM_L4PER_GPTIMER2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9438) +#define CM_L4PER_GPTIMER3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9440) +#define CM_L4PER_GPTIMER4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9448) +#define CM_L4PER_GPTIMER9_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9450) +#define CM_L4PER_ELM_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9458) +#define CM_L4PER_GPIO2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9460) +#define CM_L4PER_GPIO3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9468) +#define CM_L4PER_GPIO4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9470) +#define CM_L4PER_GPIO5_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9478) +#define CM_L4PER_GPIO6_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9480) +#define CM_L4PER_HDQ1W_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9488) +#define CM_L4PER_HECC1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9490) +#define CM_L4PER_HECC2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9498) +#define CM_L4PER_I2C1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94a0) +#define CM_L4PER_I2C2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94a8) +#define CM_L4PER_I2C3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94b0) +#define CM_L4PER_I2C4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94b8) +#define CM_L4PER_L4PER_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94c0) +#define CM_L4PER_MCASP2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94d0) +#define CM_L4PER_MCASP3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94d8) +#define CM_L4PER_MCBSP4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94e0) +#define CM_L4PER_MGATE_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94e8) +#define CM_L4PER_MCSPI1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94f0) +#define CM_L4PER_MCSPI2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94f8) +#define CM_L4PER_MCSPI3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9500) +#define CM_L4PER_MCSPI4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9508) +#define CM_L4PER_MMCSD3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9520) +#define CM_L4PER_MMCSD4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9528) +#define CM_L4PER_MSPROHG_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9530) +#define CM_L4PER_SLIMBUS2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9538) +#define CM_L4PER_UART1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9540) +#define CM_L4PER_UART2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9548) +#define CM_L4PER_UART3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9550) +#define CM_L4PER_UART4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9558) +#define CM_L4PER_MMCSD5_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9560) +#define CM_L4PER_I2C5_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9568) +#define CM_L4SEC_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x9580) +#define CM_L4SEC_STATICDEP (OMAP44XX_L4_CORE_BASE + 0x9584) +#define CM_L4SEC_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x9588) +#define CM_L4SEC_AES1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95a0) +#define CM_L4SEC_AES2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95a8) +#define CM_L4SEC_DES3DES_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95b0) +#define CM_L4SEC_PKAEIP29_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95b8) +#define CM_L4SEC_RNG_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95c0) +#define CM_L4SEC_SHA2MD51_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95c8) +#define CM_L4SEC_CRYPTODMA_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95d8) + +/* CM2.IVAHD */ +#define CM_IVAHD_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8f00) +#define CM_IVAHD_IVAHD_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8f20) +#define CM_IVAHD_SL2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8f28) + +/* CM2.L3INIT */ +#define CM_L3INIT_HSMMC1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9328) +#define CM_L3INIT_HSMMC2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9330) +#define CM_L3INIT_HSI_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9338) +#define CM_L3INIT_HSUSBHOST_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9358) +#define CM_L3INIT_HSUSBOTG_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9360) +#define CM_L3INIT_HSUSBTLL_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9368) +#define CM_L3INIT_P1500_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9378) +#define CM_L3INIT_FSUSB_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x93d0) +#define CM_L3INIT_USBPHY_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x93e0) + +/* CM2.CAM */ +#define CM_CAM_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x9000) +#define CM_CAM_ISS_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9020) +#define CM_CAM_FDIF_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9028) + +/* CM2.DSS */ +#define CM_DSS_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x9100) +#define CM_DSS_DSS_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9120) + +/* CM2.SGX */ +#define CM_SGX_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x9200) +#define CM_SGX_SGX_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9220) + +/* DPLL register offsets */ +#define CM_CLKMODE_DPLL 0 +#define CM_IDLEST_DPLL 0x4 +#define CM_AUTOIDLE_DPLL 0x8 +#define CM_CLKSEL_DPLL 0xC +#define CM_DIV_M2_DPLL 0x10 +#define CM_DIV_M3_DPLL 0x14 +#define CM_DIV_M4_DPLL 0x18 +#define CM_DIV_M5_DPLL 0x1C +#define CM_DIV_M6_DPLL 0x20 +#define CM_DIV_M7_DPLL 0x24 + +#define DPLL_CLKOUT_DIV_MASK 0x1F /* post-divider mask */ + +/* CM_CLKMODE_DPLL */ +#define CM_CLKMODE_DPLL_DPLL_REGM4XEN_MASK 11 +#define CM_CLKMODE_DPLL_DPLL_EN_SHIFT 0 +#define CM_CLKMODE_DPLL_DPLL_EN_SHIFT 0 +#define CM_CLKMODE_DPLL_DPLL_EN_MASK 7 + +#define DPLL_EN_STOP 1 +#define DPLL_EN_MN_BYPASS 4 +#define DPLL_EN_LOW_POWER_BYPASS 5 +#define DPLL_EN_FAST_RELOCK_BYPASS 6 +#define DPLL_EN_LOCK 7 + +/* CM_IDLEST_DPLL fields */ +#define ST_DPLL_CLK_MASK 1 + +/* CM_CLKSEL_DPLL */ +#define CM_CLKSEL_DPLL_DPLL_SD_DIV_SHIFT 24 +#define CM_CLKSEL_DPLL_DPLL_SD_DIV_MASK (0xFF << 24) +#define CM_CLKSEL_DPLL_M_SHIFT 8 +#define CM_CLKSEL_DPLL_M_MASK (0x7FF << 8) +#define CM_CLKSEL_DPLL_N_SHIFT 0 +#define CM_CLKSEL_DPLL_N_MASK 0x7F + +#define OMAP4_DPLL_MAX_N 127 + +/* CM_SYS_CLKSEL */ +#define CM_SYS_CLKSEL_SYS_CLKSEL_MASK 7 + +/* CM_CLKSEL_CORE */ +#define CLKSEL_CORE_SHIFT 0 +#define CLKSEL_L3_SHIFT 4 +#define CLKSEL_L4_SHIFT 8 + +#define CLKSEL_CORE_X2_DIV_1 0 +#define CLKSEL_L3_CORE_DIV_2 1 +#define CLKSEL_L4_L3_DIV_2 1 + +/* CM_ABE_PLL_REF_CLKSEL */ +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_SHIFT 0 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_MASK 1 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_SYSCLK 0 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_32KCLK 1 + + +/* CM_SHADOW_FREQ_CONFIG1 */ +#define SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK 1 +#define SHADOW_FREQ_CONFIG1_DLL_OVERRIDE_MASK 4 +#define SHADOW_FREQ_CONFIG1_DLL_RESET_MASK 8 + +#define SHADOW_FREQ_CONFIG1_DPLL_EN_SHIFT 8 +#define SHADOW_FREQ_CONFIG1_DPLL_EN_MASK (7 << 8) + +#define SHADOW_FREQ_CONFIG1_M2_DIV_SHIFT 11 +#define SHADOW_FREQ_CONFIG1_M2_DIV_MASK (0x1F << 11) + +/*CM_<clock_domain>__CLKCTRL */ +#define CD_CLKCTRL_CLKTRCTRL_SHIFT 0 +#define CD_CLKCTRL_CLKTRCTRL_MASK 3 + +#define CD_CLKCTRL_CLKTRCTRL_NO_SLEEP 0 +#define CD_CLKCTRL_CLKTRCTRL_SW_SLEEP 1 +#define CD_CLKCTRL_CLKTRCTRL_SW_WKUP 2 +#define CD_CLKCTRL_CLKTRCTRL_HW_AUTO 3 + + +/* CM_<clock_domain>_<module>_CLKCTRL */ +#define MODULE_CLKCTRL_MODULEMODE_SHIFT 0 +#define MODULE_CLKCTRL_MODULEMODE_MASK 3 +#define MODULE_CLKCTRL_IDLEST_SHIFT 16 +#define MODULE_CLKCTRL_IDLEST_MASK (3 << 16) + +#define MODULE_CLKCTRL_MODULEMODE_SW_DISABLE 0 +#define MODULE_CLKCTRL_MODULEMODE_HW_AUTO 1 +#define MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN 2 + +#define MODULE_CLKCTRL_IDLEST_FULLY_FUNCTIONAL 0 +#define MODULE_CLKCTRL_IDLEST_TRANSITIONING 1 +#define MODULE_CLKCTRL_IDLEST_IDLE 2 +#define MODULE_CLKCTRL_IDLEST_DISABLED 3 + +/* CM_L4PER_GPIO4_CLKCTRL */ +#define GPIO4_CLKCTRL_OPTFCLKEN_SHIFT 8 + +/* CM_L3INIT_HSMMCn_CLKCTRL */ +#define HSMMC_CLKCTRL_CLKSEL_SHIFT 24 + +/* CM_WKUP_GPTIMER1_CLKCTRL */ +#define GPTIMER1_CLKCTRL_CLKSEL_SHIFT 24 + +/* CM_CAM_ISS_CLKCTRL */ +#define ISS_CLKCTRL_OPTFCLKEN_SHIFT 8 + +/* CM_DSS_DSS_CLKCTRL */ +#define DSS_CLKCTRL_OPTFCLKEN_MASK 0xF00 + +/* CM_L3INIT_USBPHY_CLKCTRL */ +#define USBPHY_CLKCTRL_OPTFCLKEN_PHY_48M_MASK 8 + +/* Clock frequencies */ +#define OMAP_SYS_CLK_FREQ_38_4_MHZ 38400000 +#define OMAP_32K_CLK_FREQ 32768 + +/* PRM_VC_CFG_I2C_CLK */ +#define PRM_VC_CFG_I2C_CLK_SCLH_SHIFT 0 +#define PRM_VC_CFG_I2C_CLK_SCLH_MASK 0xFF +#define PRM_VC_CFG_I2C_CLK_SCLL_SHIFT 8 +#define PRM_VC_CFG_I2C_CLK_SCLL_MASK (0xFF << 8) + +/* PRM_VC_VAL_BYPASS */ +#define PRM_VC_I2C_CHANNEL_FREQ_KHZ 400 + +#define PRM_VC_VAL_BYPASS_VALID_BIT 0x1000000 +#define PRM_VC_VAL_BYPASS_SLAVEADDR_SHIFT 0 +#define PRM_VC_VAL_BYPASS_SLAVEADDR_MASK 0x7F +#define PRM_VC_VAL_BYPASS_REGADDR_SHIFT 8 +#define PRM_VC_VAL_BYPASS_REGADDR_MASK 0xFF +#define PRM_VC_VAL_BYPASS_DATA_SHIFT 16 +#define PRM_VC_VAL_BYPASS_DATA_MASK 0xFF + +#define SMPS_I2C_SLAVE_ADDR 0x12 +#define SMPS_REG_ADDR_VCORE1 0x55 +#define SMPS_REG_ADDR_VCORE2 0x5B +#define SMPS_REG_ADDR_VCORE3 0x61 + +#define SMPS_VOLT_1_0000_V 0x21 +#define SMPS_VOLT_1_0125_V 0x22 +#define SMPS_VOLT_1_0250_V 0x23 +#define SMPS_VOLT_1_0375_V 0x24 +#define SMPS_VOLT_1_0500_V 0x25 +#define SMPS_VOLT_1_0625_V 0x26 +#define SMPS_VOLT_1_0750_V 0x27 +#define SMPS_VOLT_1_0875_V 0x28 +#define SMPS_VOLT_1_1000_V 0x29 +#define SMPS_VOLT_1_1125_V 0x2A +#define SMPS_VOLT_1_1250_V 0x2B +#define SMPS_VOLT_1_1375_V 0x2C +#define SMPS_VOLT_1_1500_V 0x2D +#define SMPS_VOLT_1_1625_V 0x2E +#define SMPS_VOLT_1_1750_V 0x2F +#define SMPS_VOLT_1_1875_V 0x30 +#define SMPS_VOLT_1_2000_V 0x31 +#define SMPS_VOLT_1_2125_V 0x32 +#define SMPS_VOLT_1_2250_V 0x33 +#define SMPS_VOLT_1_2375_V 0x34 +#define SMPS_VOLT_1_2500_V 0x35 +#define SMPS_VOLT_1_2625_V 0x36 +#define SMPS_VOLT_1_2750_V 0x37 +#define SMPS_VOLT_1_2875_V 0x38 +#define SMPS_VOLT_1_3000_V 0x39 +#define SMPS_VOLT_1_3500_V 0x3A +#define SMPS_VOLT_1_5000_V 0x3B +#define SMPS_VOLT_1_5000_V 0x3B + +/* Defines for DPLL setup */ +#define DPLL_LOCKED_FREQ_TOLERANCE_0 0 +#define DPLL_LOCKED_FREQ_TOLERANCE_500_KHZ 500 +#define DPLL_LOCKED_FREQ_TOLERANCE_1_MHZ 1000 + +#define CONFIGURE_NO_LOCK 0 +#define CONFIGURE_AND_LOCK 1 + +struct dpll_regs { + u32 cm_clkmode_dpll; + u32 cm_idlest_dpll; + u32 cm_autoidle_dpll; + u32 cm_clksel_dpll; + u32 cm_div_m2_dpll; + u32 cm_div_m3_dpll; + u32 cm_div_m4_dpll; + u32 cm_div_m5_dpll; + u32 cm_div_m6_dpll; + u32 cm_div_m7_dpll; +}; + +/* DPLL parameter table */ +struct dpll_params { + s32 m; + s32 n; + u32 locked_freq_khz; + s32 m2; + s32 m3; + s32 m4; + s32 m5; + s32 m6; + s32 m7; +}; + +#endif /* _CLOCKS_OMAP4_H_ */ diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 33a1666..fd21afd 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -39,6 +39,12 @@ void set_muxconf_regs_non_essential(void); void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); +void prcm_init(void); +void bypass_dpll(u32 base); +void freq_update_core(void); +u32 get_syc_clk_freq(void); +u32 omap4_ddr_clk(void); +u32 omap4_revision(void);
static inline u32 running_from_sdram(void) { diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 50247af..49daa85 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -25,6 +25,9 @@ #ifndef _OMAP_COMMON_H_ #define _OMAP_COMMON_H_
+/* Max value for DPLL multiplier M */ +#define OMAP_DPLL_MAX_N 127 + /* extract a bit field from a bit vector */ #define get_bit_field(nr, start, mask)\ (((nr) & (mask)) >> (start)) diff --git a/spl/board/ti/sdp4430/Makefile b/spl/board/ti/sdp4430/Makefile index 6a6aa42..40e3e79 100644 --- a/spl/board/ti/sdp4430/Makefile +++ b/spl/board/ti/sdp4430/Makefile @@ -115,8 +115,12 @@ $(obj)board.c:$(obj)omap4_mux_data.h @rm -f $@ @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/board.c $@
+$(obj)clocks.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/clocks.c $@ + SOBJS += lowlevel_init.o -COBJS += board.o +COBJS += board.o clocks.o
# rules LDPPFLAGS += -include $(TOPDIR)/include/config.h
Add support for the SDRAM controller (EMIF).
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap4/Makefile | 3 + arch/arm/cpu/armv7/omap4/board.c | 2 +- arch/arm/cpu/armv7/omap4/emif.c | 281 +++++++++++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 118 +++++ arch/arm/include/asm/arch-omap4/emif.h | 719 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 11 + arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + include/configs/omap4_sdp4430.h | 5 - spl/board/ti/sdp4430/Makefile | 10 +- 9 files changed, 1143 insertions(+), 7 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/emif.c create mode 100644 arch/arm/cpu/armv7/omap4/sdram_elpida.c create mode 100644 arch/arm/include/asm/arch-omap4/emif.h
diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index 6154e86..d9714fe 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -31,6 +31,9 @@ COBJS += board.o COBJS += mem.o COBJS += sys_info.o COBJS += clocks.o +COBJS += emif.o +COBJS += sdram_elpida.o +
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 62a59ad..89b1213 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -109,6 +109,7 @@ void s_init(void) #ifdef CONFIG_PRELOADER preloader_console_init(); #endif + sdram_init(); }
/* @@ -169,7 +170,6 @@ u32 sdram_size(void) */ int dram_init(void) { - gd->ram_size = sdram_size();
return 0; diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c new file mode 100644 index 0000000..ee77743 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -0,0 +1,281 @@ +/* + * EMIF programming + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/emif.h> +#include <asm/arch/clocks.h> +#include <asm/arch/sys_proto.h> +#include <asm/omap_common.h> + +static inline u32 emif_num(u32 base) +{ + if (base == OMAP44XX_EMIF1) + return 1; + else if (base == OMAP44XX_EMIF2) + return 2; + else + return 0; +} + +static inline u32 get_mr(u32 base, u32 cs, u32 mr_addr) +{ + u32 mr; + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + mr_addr |= cs << OMAP44XX_REG_CS_SHIFT; + writel(mr_addr, &emif->emif_lpddr2_mode_reg_cfg); + if (omap4_revision() == OMAP4430_ES2_0) + mr = readl(&emif->emif_lpddr2_mode_reg_data_es2); + else + mr = readl(&emif->emif_lpddr2_mode_reg_data); + debug("get_mr: EMIF%d cs %d mr %08x val 0x%x\n", emif_num(base), + cs, mr_addr, mr); + return mr; +} + +static inline void set_mr(u32 base, u32 cs, u32 mr_addr, u32 mr_val) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + mr_addr |= cs << OMAP44XX_REG_CS_SHIFT; + writel(mr_addr, &emif->emif_lpddr2_mode_reg_cfg); + writel(mr_val, &emif->emif_lpddr2_mode_reg_data); +} +void emif_reset_phy(u32 base) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + u32 iodft; + + iodft = readl(&emif->emif_iodft_tlgc); + iodft |= OMAP44XX_REG_RESET_PHY_MASK; + writel(iodft, &emif->emif_iodft_tlgc); +} + +static void do_lpddr2_init(u32 base, u32 cs) +{ + u32 mr_addr; + + /* Wait till device auto initialization is complete */ + while (get_mr(base, cs, LPDDR2_MR0) & LPDDR2_MR0_DAI_MASK) + ; + set_mr(base, cs, LPDDR2_MR10, MR10_ZQ_ZQINIT); + sdelay(10); + set_mr(base, cs, LPDDR2_MR1, MR1_BL_8_BT_SEQ_WRAP_EN_NWR_3); + set_mr(base, cs, LPDDR2_MR16, MR16_REF_FULL_ARRAY); + /* + * Enable refresh along with writing MR2 + * Encoding of RL in MR2 is (RL - 2) + */ + mr_addr = LPDDR2_MR2 | OMAP44XX_REG_REFRESH_EN_MASK; + set_mr(base, cs, mr_addr, RL_FINAL - 2); +} + +static void lpddr2_init(u32 base, const struct emif_regs *regs) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + u32 nvm; + + /* Not NVM */ + nvm = readl(&emif->emif_lpddr2_nvm_config); + nvm &= (~OMAP44XX_REG_CS1NVMEN_MASK); + writel(nvm, &emif->emif_lpddr2_nvm_config); + /* + * Set the SDRAM_CONFIG and PHY_CTRL for the + * un-locked frequency & default RL + */ + writel(regs->sdram_config_init, &emif->emif_sdram_config); + writel(regs->emif_ddr_phy_ctlr_1_init, &emif->emif_ddr_phy_ctrl_1); + + do_lpddr2_init(base, CS0); + if (regs->sdram_config & OMAP44XX_REG_EBANK_MASK) + do_lpddr2_init(base, CS1); + + writel(regs->sdram_config, &emif->emif_sdram_config); + writel(regs->emif_ddr_phy_ctlr_1, &emif->emif_ddr_phy_ctrl_1); +} + +static void emif_update_timings(u32 base, const struct emif_regs *regs) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + writel(regs->ref_ctrl, &emif->emif_sdram_ref_ctrl_shdw); + writel(regs->sdram_tim1, &emif->emif_sdram_tim_1_shdw); + writel(regs->sdram_tim2, &emif->emif_sdram_tim_2_shdw); + writel(regs->sdram_tim3, &emif->emif_sdram_tim_3_shdw); + if (omap4_revision() == OMAP4430_ES1_0) { + /* ES1 bug EMIF should be in force idle during freq_update */ + writel(0, &emif->emif_pwr_mgmt_ctrl); + } else { + writel(EMIF_PWR_MGMT_CTRL, &emif->emif_pwr_mgmt_ctrl); + writel(EMIF_PWR_MGMT_CTRL_SHDW, &emif->emif_pwr_mgmt_ctrl_shdw); + } + writel(regs->read_idle_ctrl, &emif->emif_read_idlectrl_shdw); + writel(regs->zq_config, &emif->emif_zq_config); + writel(regs->temp_alert_config, &emif->emif_temp_alert_config); + writel(regs->emif_ddr_phy_ctlr_1, &emif->emif_ddr_phy_ctrl_1_shdw); + /* + * Workaround: + * In a specific situation, the OCP interface between the DMM and + * EMIF may hang. + * 1. A TILER port is used to perform 2D burst writes of + * width 1 and height 8 + * 2. ELLAn port is used to perform reads + * 3. All accesses are routed to the same EMIF controller + * + * Work around to avoid this issue REG_SYS_THRESH_MAX value should + * be kept higher than default 0x7. As per recommondation 0x0A will + * be used for better performance with REG_LL_THRESH_MAX = 0x00 + */ + if (omap4_revision() == OMAP4430_ES1_0) { + writel(EMIF_L3_CONFIG_VAL_SYS_THRESH_0A_LL_THRESH_00, + &emif->emif_l3_config); + } +} + +static void do_sdram_init(u32 base) +{ + const struct emif_regs *regs, *tmp_regs; + u32 in_sdram, emif_nr; + + in_sdram = running_from_sdram(); + emif_nr = (base == OMAP44XX_EMIF1) ? 1 : 2; + + emif_get_reg_dump(®s, &tmp_regs); + regs = (emif_nr == 1) ? regs : tmp_regs; + + /* + * Initializing the LPDDR2 device can not happen from SDRAM. + * Changing the timing registers in EMIF can happen(going from one + * OPP to another) + */ + if (!in_sdram) + lpddr2_init(base, regs); + + /* Write to the shadow registers */ + emif_update_timings(base, regs); +} + +void sdram_init_pads(void) +{ + u32 lpddr2io; + u32 omap4_rev = omap4_revision(); + + if (omap4_rev == OMAP4430_ES1_0) + lpddr2io = CONTROL_LPDDR2IO_SLEW_125PS_DRV8_PULL_DOWN; + else if (omap4_rev == OMAP4430_ES2_0) + lpddr2io = CONTROL_LPDDR2IO_SLEW_325PS_DRV8_GATE_KEEPER; + else + return; /* Post ES2.1 reset values will work */ + + writel(lpddr2io, CONTROL_LPDDR2IO1_0); + writel(lpddr2io, CONTROL_LPDDR2IO1_1); + writel(lpddr2io, CONTROL_LPDDR2IO1_2); + writel(lpddr2io, CONTROL_LPDDR2IO2_0); + writel(lpddr2io, CONTROL_LPDDR2IO2_1); + writel(lpddr2io, CONTROL_LPDDR2IO2_2); + + writel(CONTROL_EFUSE_2_NMOS_PMOS_PTV_CODE_1, CONTROL_EFUSE_2); +} + +static void emif_post_init_config(u32 base) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + u32 omap4_rev = omap4_revision(); + + /* reset phy on ES2.0 */ + if (omap4_rev == OMAP4430_ES2_0) + emif_reset_phy(base); + + /* Put EMIF back in smart idle on ES1.0 */ + if (omap4_rev == OMAP4430_ES1_0) + writel(0x80000000, &emif->emif_pwr_mgmt_ctrl); +} + +static void dmm_init(u32 base) +{ + const struct dmm_lisa_map_regs *lisa_map_regs; + + emif_get_dmm_regs(&lisa_map_regs); + + struct dmm_lisa_map_regs *hw_lisa_map_regs = + (struct dmm_lisa_map_regs *)base; + + writel(0, &hw_lisa_map_regs->dmm_lisa_map_3); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_2); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_1); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_0); + + writel(lisa_map_regs->dmm_lisa_map_3, + &hw_lisa_map_regs->dmm_lisa_map_3); + writel(lisa_map_regs->dmm_lisa_map_2, + &hw_lisa_map_regs->dmm_lisa_map_2); + writel(lisa_map_regs->dmm_lisa_map_1, + &hw_lisa_map_regs->dmm_lisa_map_1); + writel(lisa_map_regs->dmm_lisa_map_0, + &hw_lisa_map_regs->dmm_lisa_map_0); +} + +/* + * SDRAM initialization: + * SDRAM initialization has two parts: + * 1. Configuring the SDRAM device + * 2. Update the AC timings related parameters in the EMIF module + * (1) should be done only once and should not be done while we are + * running from SDRAM. + * (2) can and should be done more than once if OPP changes. + * Particularly, this may be needed when we boot without SPL and + * and using Configuration Header(CH). ROM code supports only at 50% OPP + * at boot (low power boot). So u-boot has to switch to OPP100 and update + * the frequency. So, + * Doing (1) and (2) makes sense - first time initialization + * Doing (2) and not (1) makes sense - OPP change (when using CH) + * Doing (1) and not (2) doen't make sense + * See do_sdram_init() for the details + */ +void sdram_init(void) +{ + u32 in_sdram; + + in_sdram = running_from_sdram(); + + if (!in_sdram) { + sdram_init_pads(); + bypass_dpll(CM_CLKMODE_DPLL_CORE); + } + + do_sdram_init(OMAP44XX_EMIF1); + do_sdram_init(OMAP44XX_EMIF2); + + if (!in_sdram) { + dmm_init(OMAP44XX_DMM_LISA_MAP_BASE); + emif_post_init_config(OMAP44XX_EMIF1); + emif_post_init_config(OMAP44XX_EMIF2); + } + + /* for the shadow registers to take effect */ + freq_update_core(); +} diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c new file mode 100644 index 0000000..37e808c --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -0,0 +1,118 @@ +/* + * Timing and Organization details of the Elpida parts used in OMAP4 + * SDPs and Panda + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/arch/emif.h> +#include <asm/arch/sys_proto.h> + +static const struct emif_regs emif_regs_elpida_200_mhz_2cs = { + .sdram_config_init = 0x80000eb9, + .sdram_config = 0x80001ab9, + .ref_ctrl = 0x0000030c, + .sdram_tim1 = 0x08648311, + .sdram_tim2 = 0x101b06ca, + .sdram_tim3 = 0x0048a19f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0x500b3214, + .temp_alert_config = 0xd8016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff808 +}; + +static const struct emif_regs emif_regs_elpida_380_mhz_1cs = { + .sdram_config_init = 0x80000eb1, + .sdram_config = 0x80001ab1, + .ref_ctrl = 0x000005cd, + .sdram_tim1 = 0x10cb0622, + .sdram_tim2 = 0x20350d52, + .sdram_tim3 = 0x00b1431f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0x500b3214, + .temp_alert_config = 0x58016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff418 +}; + +const struct emif_regs emif_regs_elpida_400_mhz_2cs = { + .sdram_config_init = 0x80000eb9, + .sdram_config = 0x80001ab9, + .ref_ctrl = 0x00000618, + .sdram_tim1 = 0x10eb0662, + .sdram_tim2 = 0x20370dd2, + .sdram_tim3 = 0x00b1c33f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0xd00b3214, + .temp_alert_config = 0xd8016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff418 +}; +const struct dmm_lisa_map_regs lisa_map_2G_x_1_x_2 = { + .dmm_lisa_map_0 = 0xFF020100, + .dmm_lisa_map_1 = 0, + .dmm_lisa_map_2 = 0, + .dmm_lisa_map_3 = 0x80540300 +}; + +const struct dmm_lisa_map_regs lisa_map_2G_x_2_x_2 = { + .dmm_lisa_map_0 = 0xFF020100, + .dmm_lisa_map_1 = 0, + .dmm_lisa_map_2 = 0, + .dmm_lisa_map_3 = 0x80640300 +}; + +void emif_get_reg_dump_sdp(const struct emif_regs **emif1_regs, + const struct emif_regs **emif2_regs) +{ + u32 omap4_rev = omap4_revision(); + + if (omap4_rev == OMAP4430_ES1_0) { + *emif1_regs = &emif_regs_elpida_380_mhz_1cs; + *emif2_regs = &emif_regs_elpida_380_mhz_1cs; + } else if (omap4_rev == OMAP4430_ES2_0) { + *emif1_regs = &emif_regs_elpida_200_mhz_2cs; + *emif2_regs = &emif_regs_elpida_200_mhz_2cs; + } else { + *emif1_regs = &emif_regs_elpida_400_mhz_2cs; + *emif2_regs = &emif_regs_elpida_400_mhz_2cs; + } +} +void emif_get_reg_dump(const struct emif_regs **emif1_regs, + const struct emif_regs **emif2_regs) + __attribute__((weak, alias("emif_get_reg_dump_sdp"))); + +void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs **dmm_lisa_regs) +{ + u32 omap_rev = omap4_revision(); + + if (omap_rev == OMAP4430_ES1_0) + *dmm_lisa_regs = &lisa_map_2G_x_1_x_2; + else + *dmm_lisa_regs = &lisa_map_2G_x_2_x_2; +} + +void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) + __attribute__((weak, alias("emif_get_dmm_regs_sdp"))); diff --git a/arch/arm/include/asm/arch-omap4/emif.h b/arch/arm/include/asm/arch-omap4/emif.h new file mode 100644 index 0000000..f2d54cb --- /dev/null +++ b/arch/arm/include/asm/arch-omap4/emif.h @@ -0,0 +1,719 @@ +/* + * OMAP44xx EMIF header + * + * Copyright (C) 2009-2010 Texas Instruments, Inc. + * + * Aneesh V aneesh@ti.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#ifndef _EMIF_H_ +#define _EMIF_H_ +#include <asm/types.h> +#include <common.h> + +/* Base address */ +#define OMAP44XX_EMIF1 0x4c000000 +#define OMAP44XX_EMIF2 0x4d000000 + +/* Registers shifts and masks */ + +/* EMIF_MOD_ID_REV */ +#define OMAP44XX_REG_SCHEME_SHIFT 30 +#define OMAP44XX_REG_SCHEME_MASK (0x3 << 30) +#define OMAP44XX_REG_MODULE_ID_SHIFT 16 +#define OMAP44XX_REG_MODULE_ID_MASK (0xfff << 16) +#define OMAP44XX_REG_RTL_VERSION_SHIFT 11 +#define OMAP44XX_REG_RTL_VERSION_MASK (0x1f << 11) +#define OMAP44XX_REG_MAJOR_REVISION_SHIFT 8 +#define OMAP44XX_REG_MAJOR_REVISION_MASK (0x7 << 8) +#define OMAP44XX_REG_MINOR_REVISION_SHIFT 0 +#define OMAP44XX_REG_MINOR_REVISION_MASK (0x3f << 0) + +/* STATUS */ +#define OMAP44XX_REG_BE_SHIFT 31 +#define OMAP44XX_REG_BE_MASK (1 << 31) +#define OMAP44XX_REG_DUAL_CLK_MODE_SHIFT 30 +#define OMAP44XX_REG_DUAL_CLK_MODE_MASK (1 << 30) +#define OMAP44XX_REG_FAST_INIT_SHIFT 29 +#define OMAP44XX_REG_FAST_INIT_MASK (1 << 29) +#define OMAP44XX_REG_PHY_DLL_READY_SHIFT 2 +#define OMAP44XX_REG_PHY_DLL_READY_MASK (1 << 2) + +/* SDRAM_CONFIG */ +#define OMAP44XX_REG_SDRAM_TYPE_SHIFT 29 +#define OMAP44XX_REG_SDRAM_TYPE_MASK (0x7 << 29) +#define OMAP44XX_REG_IBANK_POS_SHIFT 27 +#define OMAP44XX_REG_IBANK_POS_MASK (0x3 << 27) +#define OMAP44XX_REG_DDR_TERM_SHIFT 24 +#define OMAP44XX_REG_DDR_TERM_MASK (0x7 << 24) +#define OMAP44XX_REG_DDR2_DDQS_SHIFT 23 +#define OMAP44XX_REG_DDR2_DDQS_MASK (1 << 23) +#define OMAP44XX_REG_DYN_ODT_SHIFT 21 +#define OMAP44XX_REG_DYN_ODT_MASK (0x3 << 21) +#define OMAP44XX_REG_DDR_DISABLE_DLL_SHIFT 20 +#define OMAP44XX_REG_DDR_DISABLE_DLL_MASK (1 << 20) +#define OMAP44XX_REG_SDRAM_DRIVE_SHIFT 18 +#define OMAP44XX_REG_SDRAM_DRIVE_MASK (0x3 << 18) +#define OMAP44XX_REG_CWL_SHIFT 16 +#define OMAP44XX_REG_CWL_MASK (0x3 << 16) +#define OMAP44XX_REG_NARROW_MODE_SHIFT 14 +#define OMAP44XX_REG_NARROW_MODE_MASK (0x3 << 14) +#define OMAP44XX_REG_CL_SHIFT 10 +#define OMAP44XX_REG_CL_MASK (0xf << 10) +#define OMAP44XX_REG_ROWSIZE_SHIFT 7 +#define OMAP44XX_REG_ROWSIZE_MASK (0x7 << 7) +#define OMAP44XX_REG_IBANK_SHIFT 4 +#define OMAP44XX_REG_IBANK_MASK (0x7 << 4) +#define OMAP44XX_REG_EBANK_SHIFT 3 +#define OMAP44XX_REG_EBANK_MASK (1 << 3) +#define OMAP44XX_REG_PAGESIZE_SHIFT 0 +#define OMAP44XX_REG_PAGESIZE_MASK (0x7 << 0) + +/* SDRAM_CONFIG_2 */ +#define OMAP44XX_REG_CS1NVMEN_SHIFT 30 +#define OMAP44XX_REG_CS1NVMEN_MASK (1 << 30) +#define OMAP44XX_REG_EBANK_POS_SHIFT 27 +#define OMAP44XX_REG_EBANK_POS_MASK (1 << 27) +#define OMAP44XX_REG_RDBNUM_SHIFT 4 +#define OMAP44XX_REG_RDBNUM_MASK (0x3 << 4) +#define OMAP44XX_REG_RDBSIZE_SHIFT 0 +#define OMAP44XX_REG_RDBSIZE_MASK (0x7 << 0) + +/* SDRAM_REF_CTRL */ +#define OMAP44XX_REG_INITREF_DIS_SHIFT 31 +#define OMAP44XX_REG_INITREF_DIS_MASK (1 << 31) +#define OMAP44XX_REG_SRT_SHIFT 29 +#define OMAP44XX_REG_SRT_MASK (1 << 29) +#define OMAP44XX_REG_ASR_SHIFT 28 +#define OMAP44XX_REG_ASR_MASK (1 << 28) +#define OMAP44XX_REG_PASR_SHIFT 24 +#define OMAP44XX_REG_PASR_MASK (0x7 << 24) +#define OMAP44XX_REG_REFRESH_RATE_SHIFT 0 +#define OMAP44XX_REG_REFRESH_RATE_MASK (0xffff << 0) + +/* SDRAM_REF_CTRL_SHDW */ +#define OMAP44XX_REG_REFRESH_RATE_SHDW_SHIFT 0 +#define OMAP44XX_REG_REFRESH_RATE_SHDW_MASK (0xffff << 0) + +/* SDRAM_TIM_1 */ +#define OMAP44XX_REG_T_RP_SHIFT 25 +#define OMAP44XX_REG_T_RP_MASK (0xf << 25) +#define OMAP44XX_REG_T_RCD_SHIFT 21 +#define OMAP44XX_REG_T_RCD_MASK (0xf << 21) +#define OMAP44XX_REG_T_WR_SHIFT 17 +#define OMAP44XX_REG_T_WR_MASK (0xf << 17) +#define OMAP44XX_REG_T_RAS_SHIFT 12 +#define OMAP44XX_REG_T_RAS_MASK (0x1f << 12) +#define OMAP44XX_REG_T_RC_SHIFT 6 +#define OMAP44XX_REG_T_RC_MASK (0x3f << 6) +#define OMAP44XX_REG_T_RRD_SHIFT 3 +#define OMAP44XX_REG_T_RRD_MASK (0x7 << 3) +#define OMAP44XX_REG_T_WTR_SHIFT 0 +#define OMAP44XX_REG_T_WTR_MASK (0x7 << 0) + +/* SDRAM_TIM_1_SHDW */ +#define OMAP44XX_REG_T_RP_SHDW_SHIFT 25 +#define OMAP44XX_REG_T_RP_SHDW_MASK (0xf << 25) +#define OMAP44XX_REG_T_RCD_SHDW_SHIFT 21 +#define OMAP44XX_REG_T_RCD_SHDW_MASK (0xf << 21) +#define OMAP44XX_REG_T_WR_SHDW_SHIFT 17 +#define OMAP44XX_REG_T_WR_SHDW_MASK (0xf << 17) +#define OMAP44XX_REG_T_RAS_SHDW_SHIFT 12 +#define OMAP44XX_REG_T_RAS_SHDW_MASK (0x1f << 12) +#define OMAP44XX_REG_T_RC_SHDW_SHIFT 6 +#define OMAP44XX_REG_T_RC_SHDW_MASK (0x3f << 6) +#define OMAP44XX_REG_T_RRD_SHDW_SHIFT 3 +#define OMAP44XX_REG_T_RRD_SHDW_MASK (0x7 << 3) +#define OMAP44XX_REG_T_WTR_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_WTR_SHDW_MASK (0x7 << 0) + +/* SDRAM_TIM_2 */ +#define OMAP44XX_REG_T_XP_SHIFT 28 +#define OMAP44XX_REG_T_XP_MASK (0x7 << 28) +#define OMAP44XX_REG_T_ODT_SHIFT 25 +#define OMAP44XX_REG_T_ODT_MASK (0x7 << 25) +#define OMAP44XX_REG_T_XSNR_SHIFT 16 +#define OMAP44XX_REG_T_XSNR_MASK (0x1ff << 16) +#define OMAP44XX_REG_T_XSRD_SHIFT 6 +#define OMAP44XX_REG_T_XSRD_MASK (0x3ff << 6) +#define OMAP44XX_REG_T_RTP_SHIFT 3 +#define OMAP44XX_REG_T_RTP_MASK (0x7 << 3) +#define OMAP44XX_REG_T_CKE_SHIFT 0 +#define OMAP44XX_REG_T_CKE_MASK (0x7 << 0) + +/* SDRAM_TIM_2_SHDW */ +#define OMAP44XX_REG_T_XP_SHDW_SHIFT 28 +#define OMAP44XX_REG_T_XP_SHDW_MASK (0x7 << 28) +#define OMAP44XX_REG_T_ODT_SHDW_SHIFT 25 +#define OMAP44XX_REG_T_ODT_SHDW_MASK (0x7 << 25) +#define OMAP44XX_REG_T_XSNR_SHDW_SHIFT 16 +#define OMAP44XX_REG_T_XSNR_SHDW_MASK (0x1ff << 16) +#define OMAP44XX_REG_T_XSRD_SHDW_SHIFT 6 +#define OMAP44XX_REG_T_XSRD_SHDW_MASK (0x3ff << 6) +#define OMAP44XX_REG_T_RTP_SHDW_SHIFT 3 +#define OMAP44XX_REG_T_RTP_SHDW_MASK (0x7 << 3) +#define OMAP44XX_REG_T_CKE_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_CKE_SHDW_MASK (0x7 << 0) + +/* SDRAM_TIM_3 */ +#define OMAP44XX_REG_T_CKESR_SHIFT 21 +#define OMAP44XX_REG_T_CKESR_MASK (0x7 << 21) +#define OMAP44XX_REG_ZQ_ZQCS_SHIFT 15 +#define OMAP44XX_REG_ZQ_ZQCS_MASK (0x3f << 15) +#define OMAP44XX_REG_T_TDQSCKMAX_SHIFT 13 +#define OMAP44XX_REG_T_TDQSCKMAX_MASK (0x3 << 13) +#define OMAP44XX_REG_T_RFC_SHIFT 4 +#define OMAP44XX_REG_T_RFC_MASK (0x1ff << 4) +#define OMAP44XX_REG_T_RAS_MAX_SHIFT 0 +#define OMAP44XX_REG_T_RAS_MAX_MASK (0xf << 0) + +/* SDRAM_TIM_3_SHDW */ +#define OMAP44XX_REG_T_CKESR_SHDW_SHIFT 21 +#define OMAP44XX_REG_T_CKESR_SHDW_MASK (0x7 << 21) +#define OMAP44XX_REG_ZQ_ZQCS_SHDW_SHIFT 15 +#define OMAP44XX_REG_ZQ_ZQCS_SHDW_MASK (0x3f << 15) +#define OMAP44XX_REG_T_TDQSCKMAX_SHDW_SHIFT 13 +#define OMAP44XX_REG_T_TDQSCKMAX_SHDW_MASK (0x3 << 13) +#define OMAP44XX_REG_T_RFC_SHDW_SHIFT 4 +#define OMAP44XX_REG_T_RFC_SHDW_MASK (0x1ff << 4) +#define OMAP44XX_REG_T_RAS_MAX_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_RAS_MAX_SHDW_MASK (0xf << 0) + +/* LPDDR2_NVM_TIM */ +#define OMAP44XX_REG_NVM_T_XP_SHIFT 28 +#define OMAP44XX_REG_NVM_T_XP_MASK (0x7 << 28) +#define OMAP44XX_REG_NVM_T_WTR_SHIFT 24 +#define OMAP44XX_REG_NVM_T_WTR_MASK (0x7 << 24) +#define OMAP44XX_REG_NVM_T_RP_SHIFT 20 +#define OMAP44XX_REG_NVM_T_RP_MASK (0xf << 20) +#define OMAP44XX_REG_NVM_T_WRA_SHIFT 16 +#define OMAP44XX_REG_NVM_T_WRA_MASK (0xf << 16) +#define OMAP44XX_REG_NVM_T_RRD_SHIFT 8 +#define OMAP44XX_REG_NVM_T_RRD_MASK (0xff << 8) +#define OMAP44XX_REG_NVM_T_RCDMIN_SHIFT 0 +#define OMAP44XX_REG_NVM_T_RCDMIN_MASK (0xff << 0) + +/* LPDDR2_NVM_TIM_SHDW */ +#define OMAP44XX_REG_NVM_T_XP_SHDW_SHIFT 28 +#define OMAP44XX_REG_NVM_T_XP_SHDW_MASK (0x7 << 28) +#define OMAP44XX_REG_NVM_T_WTR_SHDW_SHIFT 24 +#define OMAP44XX_REG_NVM_T_WTR_SHDW_MASK (0x7 << 24) +#define OMAP44XX_REG_NVM_T_RP_SHDW_SHIFT 20 +#define OMAP44XX_REG_NVM_T_RP_SHDW_MASK (0xf << 20) +#define OMAP44XX_REG_NVM_T_WRA_SHDW_SHIFT 16 +#define OMAP44XX_REG_NVM_T_WRA_SHDW_MASK (0xf << 16) +#define OMAP44XX_REG_NVM_T_RRD_SHDW_SHIFT 8 +#define OMAP44XX_REG_NVM_T_RRD_SHDW_MASK (0xff << 8) +#define OMAP44XX_REG_NVM_T_RCDMIN_SHDW_SHIFT 0 +#define OMAP44XX_REG_NVM_T_RCDMIN_SHDW_MASK (0xff << 0) + +/* PWR_MGMT_CTRL */ +#define OMAP44XX_REG_IDLEMODE_SHIFT 30 +#define OMAP44XX_REG_IDLEMODE_MASK (0x3 << 30) +#define OMAP44XX_REG_PD_TIM_SHIFT 12 +#define OMAP44XX_REG_PD_TIM_MASK (0xf << 12) +#define OMAP44XX_REG_DPD_EN_SHIFT 11 +#define OMAP44XX_REG_DPD_EN_MASK (1 << 11) +#define OMAP44XX_REG_LP_MODE_SHIFT 8 +#define OMAP44XX_REG_LP_MODE_MASK (0x7 << 8) +#define OMAP44XX_REG_SR_TIM_SHIFT 4 +#define OMAP44XX_REG_SR_TIM_MASK (0xf << 4) +#define OMAP44XX_REG_CS_TIM_SHIFT 0 +#define OMAP44XX_REG_CS_TIM_MASK (0xf << 0) + +/* PWR_MGMT_CTRL_SHDW */ +#define OMAP44XX_REG_PD_TIM_SHDW_SHIFT 8 +#define OMAP44XX_REG_PD_TIM_SHDW_MASK (0xf << 8) +#define OMAP44XX_REG_SR_TIM_SHDW_SHIFT 4 +#define OMAP44XX_REG_SR_TIM_SHDW_MASK (0xf << 4) +#define OMAP44XX_REG_CS_TIM_SHDW_SHIFT 0 +#define OMAP44XX_REG_CS_TIM_SHDW_MASK (0xf << 0) + +/* LPDDR2_MODE_REG_DATA */ +#define OMAP44XX_REG_VALUE_0_SHIFT 0 +#define OMAP44XX_REG_VALUE_0_MASK (0x7f << 0) + +/* LPDDR2_MODE_REG_CFG */ +#define OMAP44XX_REG_CS_SHIFT 31 +#define OMAP44XX_REG_CS_MASK (1 << 31) +#define OMAP44XX_REG_REFRESH_EN_SHIFT 30 +#define OMAP44XX_REG_REFRESH_EN_MASK (1 << 30) +#define OMAP44XX_REG_ADDRESS_SHIFT 0 +#define OMAP44XX_REG_ADDRESS_MASK (0xff << 0) + +/* OCP_CONFIG */ +#define OMAP44XX_REG_SYS_THRESH_MAX_SHIFT 24 +#define OMAP44XX_REG_SYS_THRESH_MAX_MASK (0xf << 24) +#define OMAP44XX_REG_LL_THRESH_MAX_SHIFT 16 +#define OMAP44XX_REG_LL_THRESH_MAX_MASK (0xf << 16) +#define OMAP44XX_REG_PR_OLD_COUNT_SHIFT 0 +#define OMAP44XX_REG_PR_OLD_COUNT_MASK (0xff << 0) + +/* OCP_CFG_VAL_1 */ +#define OMAP44XX_REG_SYS_BUS_WIDTH_SHIFT 30 +#define OMAP44XX_REG_SYS_BUS_WIDTH_MASK (0x3 << 30) +#define OMAP44XX_REG_LL_BUS_WIDTH_SHIFT 28 +#define OMAP44XX_REG_LL_BUS_WIDTH_MASK (0x3 << 28) +#define OMAP44XX_REG_WR_FIFO_DEPTH_SHIFT 8 +#define OMAP44XX_REG_WR_FIFO_DEPTH_MASK (0xff << 8) +#define OMAP44XX_REG_CMD_FIFO_DEPTH_SHIFT 0 +#define OMAP44XX_REG_CMD_FIFO_DEPTH_MASK (0xff << 0) + +/* OCP_CFG_VAL_2 */ +#define OMAP44XX_REG_RREG_FIFO_DEPTH_SHIFT 16 +#define OMAP44XX_REG_RREG_FIFO_DEPTH_MASK (0xff << 16) +#define OMAP44XX_REG_RSD_FIFO_DEPTH_SHIFT 8 +#define OMAP44XX_REG_RSD_FIFO_DEPTH_MASK (0xff << 8) +#define OMAP44XX_REG_RCMD_FIFO_DEPTH_SHIFT 0 +#define OMAP44XX_REG_RCMD_FIFO_DEPTH_MASK (0xff << 0) + +/* IODFT_TLGC */ +#define OMAP44XX_REG_TLEC_SHIFT 16 +#define OMAP44XX_REG_TLEC_MASK (0xffff << 16) +#define OMAP44XX_REG_MT_SHIFT 14 +#define OMAP44XX_REG_MT_MASK (1 << 14) +#define OMAP44XX_REG_ACT_CAP_EN_SHIFT 13 +#define OMAP44XX_REG_ACT_CAP_EN_MASK (1 << 13) +#define OMAP44XX_REG_OPG_LD_SHIFT 12 +#define OMAP44XX_REG_OPG_LD_MASK (1 << 12) +#define OMAP44XX_REG_RESET_PHY_SHIFT 10 +#define OMAP44XX_REG_RESET_PHY_MASK (1 << 10) +#define OMAP44XX_REG_MMS_SHIFT 8 +#define OMAP44XX_REG_MMS_MASK (1 << 8) +#define OMAP44XX_REG_MC_SHIFT 4 +#define OMAP44XX_REG_MC_MASK (0x3 << 4) +#define OMAP44XX_REG_PC_SHIFT 1 +#define OMAP44XX_REG_PC_MASK (0x7 << 1) +#define OMAP44XX_REG_TM_SHIFT 0 +#define OMAP44XX_REG_TM_MASK (1 << 0) + +/* IODFT_CTRL_MISR_RSLT */ +#define OMAP44XX_REG_DQM_TLMR_SHIFT 16 +#define OMAP44XX_REG_DQM_TLMR_MASK (0x3ff << 16) +#define OMAP44XX_REG_CTL_TLMR_SHIFT 0 +#define OMAP44XX_REG_CTL_TLMR_MASK (0x7ff << 0) + +/* IODFT_ADDR_MISR_RSLT */ +#define OMAP44XX_REG_ADDR_TLMR_SHIFT 0 +#define OMAP44XX_REG_ADDR_TLMR_MASK (0x1fffff << 0) + +/* IODFT_DATA_MISR_RSLT_1 */ +#define OMAP44XX_REG_DATA_TLMR_31_0_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_31_0_MASK (0xffffffff << 0) + +/* IODFT_DATA_MISR_RSLT_2 */ +#define OMAP44XX_REG_DATA_TLMR_63_32_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_63_32_MASK (0xffffffff << 0) + +/* IODFT_DATA_MISR_RSLT_3 */ +#define OMAP44XX_REG_DATA_TLMR_66_64_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_66_64_MASK (0x7 << 0) + +/* PERF_CNT_1 */ +#define OMAP44XX_REG_COUNTER1_SHIFT 0 +#define OMAP44XX_REG_COUNTER1_MASK (0xffffffff << 0) + +/* PERF_CNT_2 */ +#define OMAP44XX_REG_COUNTER2_SHIFT 0 +#define OMAP44XX_REG_COUNTER2_MASK (0xffffffff << 0) + +/* PERF_CNT_CFG */ +#define OMAP44XX_REG_CNTR2_MCONNID_EN_SHIFT 31 +#define OMAP44XX_REG_CNTR2_MCONNID_EN_MASK (1 << 31) +#define OMAP44XX_REG_CNTR2_REGION_EN_SHIFT 30 +#define OMAP44XX_REG_CNTR2_REGION_EN_MASK (1 << 30) +#define OMAP44XX_REG_CNTR2_CFG_SHIFT 16 +#define OMAP44XX_REG_CNTR2_CFG_MASK (0xf << 16) +#define OMAP44XX_REG_CNTR1_MCONNID_EN_SHIFT 15 +#define OMAP44XX_REG_CNTR1_MCONNID_EN_MASK (1 << 15) +#define OMAP44XX_REG_CNTR1_REGION_EN_SHIFT 14 +#define OMAP44XX_REG_CNTR1_REGION_EN_MASK (1 << 14) +#define OMAP44XX_REG_CNTR1_CFG_SHIFT 0 +#define OMAP44XX_REG_CNTR1_CFG_MASK (0xf << 0) + +/* PERF_CNT_SEL */ +#define OMAP44XX_REG_MCONNID2_SHIFT 24 +#define OMAP44XX_REG_MCONNID2_MASK (0xff << 24) +#define OMAP44XX_REG_REGION_SEL2_SHIFT 16 +#define OMAP44XX_REG_REGION_SEL2_MASK (0x3 << 16) +#define OMAP44XX_REG_MCONNID1_SHIFT 8 +#define OMAP44XX_REG_MCONNID1_MASK (0xff << 8) +#define OMAP44XX_REG_REGION_SEL1_SHIFT 0 +#define OMAP44XX_REG_REGION_SEL1_MASK (0x3 << 0) + +/* PERF_CNT_TIM */ +#define OMAP44XX_REG_TOTAL_TIME_SHIFT 0 +#define OMAP44XX_REG_TOTAL_TIME_MASK (0xffffffff << 0) + +/* READ_IDLE_CTRL */ +#define OMAP44XX_REG_READ_IDLE_LEN_SHIFT 16 +#define OMAP44XX_REG_READ_IDLE_LEN_MASK (0xf << 16) +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHIFT 0 +#define OMAP44XX_REG_READ_IDLE_INTERVAL_MASK (0x1ff << 0) + +/* READ_IDLE_CTRL_SHDW */ +#define OMAP44XX_REG_READ_IDLE_LEN_SHDW_SHIFT 16 +#define OMAP44XX_REG_READ_IDLE_LEN_SHDW_MASK (0xf << 16) +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHDW_SHIFT 0 +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHDW_MASK (0x1ff << 0) + +/* IRQ_EOI */ +#define OMAP44XX_REG_EOI_SHIFT 0 +#define OMAP44XX_REG_EOI_MASK (1 << 0) + +/* IRQSTATUS_RAW_SYS */ +#define OMAP44XX_REG_DNV_SYS_SHIFT 2 +#define OMAP44XX_REG_DNV_SYS_MASK (1 << 2) +#define OMAP44XX_REG_TA_SYS_SHIFT 1 +#define OMAP44XX_REG_TA_SYS_MASK (1 << 1) +#define OMAP44XX_REG_ERR_SYS_SHIFT 0 +#define OMAP44XX_REG_ERR_SYS_MASK (1 << 0) + +/* IRQSTATUS_RAW_LL */ +#define OMAP44XX_REG_DNV_LL_SHIFT 2 +#define OMAP44XX_REG_DNV_LL_MASK (1 << 2) +#define OMAP44XX_REG_TA_LL_SHIFT 1 +#define OMAP44XX_REG_TA_LL_MASK (1 << 1) +#define OMAP44XX_REG_ERR_LL_SHIFT 0 +#define OMAP44XX_REG_ERR_LL_MASK (1 << 0) + +/* IRQSTATUS_SYS */ + +/* IRQSTATUS_LL */ + +/* IRQENABLE_SET_SYS */ +#define OMAP44XX_REG_EN_DNV_SYS_SHIFT 2 +#define OMAP44XX_REG_EN_DNV_SYS_MASK (1 << 2) +#define OMAP44XX_REG_EN_TA_SYS_SHIFT 1 +#define OMAP44XX_REG_EN_TA_SYS_MASK (1 << 1) +#define OMAP44XX_REG_EN_ERR_SYS_SHIFT 0 +#define OMAP44XX_REG_EN_ERR_SYS_MASK (1 << 0) + +/* IRQENABLE_SET_LL */ +#define OMAP44XX_REG_EN_DNV_LL_SHIFT 2 +#define OMAP44XX_REG_EN_DNV_LL_MASK (1 << 2) +#define OMAP44XX_REG_EN_TA_LL_SHIFT 1 +#define OMAP44XX_REG_EN_TA_LL_MASK (1 << 1) +#define OMAP44XX_REG_EN_ERR_LL_SHIFT 0 +#define OMAP44XX_REG_EN_ERR_LL_MASK (1 << 0) + +/* IRQENABLE_CLR_SYS */ + +/* IRQENABLE_CLR_LL */ + +/* ZQ_CONFIG */ +#define OMAP44XX_REG_ZQ_CS1EN_SHIFT 31 +#define OMAP44XX_REG_ZQ_CS1EN_MASK (1 << 31) +#define OMAP44XX_REG_ZQ_CS0EN_SHIFT 30 +#define OMAP44XX_REG_ZQ_CS0EN_MASK (1 << 30) +#define OMAP44XX_REG_ZQ_DUALCALEN_SHIFT 29 +#define OMAP44XX_REG_ZQ_DUALCALEN_MASK (1 << 29) +#define OMAP44XX_REG_ZQ_SFEXITEN_SHIFT 28 +#define OMAP44XX_REG_ZQ_SFEXITEN_MASK (1 << 28) +#define OMAP44XX_REG_ZQ_ZQINIT_MULT_SHIFT 18 +#define OMAP44XX_REG_ZQ_ZQINIT_MULT_MASK (0x3 << 18) +#define OMAP44XX_REG_ZQ_ZQCL_MULT_SHIFT 16 +#define OMAP44XX_REG_ZQ_ZQCL_MULT_MASK (0x3 << 16) +#define OMAP44XX_REG_ZQ_REFINTERVAL_SHIFT 0 +#define OMAP44XX_REG_ZQ_REFINTERVAL_MASK (0xffff << 0) + +/* TEMP_ALERT_CONFIG */ +#define OMAP44XX_REG_TA_CS1EN_SHIFT 31 +#define OMAP44XX_REG_TA_CS1EN_MASK (1 << 31) +#define OMAP44XX_REG_TA_CS0EN_SHIFT 30 +#define OMAP44XX_REG_TA_CS0EN_MASK (1 << 30) +#define OMAP44XX_REG_TA_SFEXITEN_SHIFT 28 +#define OMAP44XX_REG_TA_SFEXITEN_MASK (1 << 28) +#define OMAP44XX_REG_TA_DEVWDT_SHIFT 26 +#define OMAP44XX_REG_TA_DEVWDT_MASK (0x3 << 26) +#define OMAP44XX_REG_TA_DEVCNT_SHIFT 24 +#define OMAP44XX_REG_TA_DEVCNT_MASK (0x3 << 24) +#define OMAP44XX_REG_TA_REFINTERVAL_SHIFT 0 +#define OMAP44XX_REG_TA_REFINTERVAL_MASK (0x3fffff << 0) + +/* OCP_ERR_LOG */ +#define OMAP44XX_REG_MADDRSPACE_SHIFT 14 +#define OMAP44XX_REG_MADDRSPACE_MASK (0x3 << 14) +#define OMAP44XX_REG_MBURSTSEQ_SHIFT 11 +#define OMAP44XX_REG_MBURSTSEQ_MASK (0x7 << 11) +#define OMAP44XX_REG_MCMD_SHIFT 8 +#define OMAP44XX_REG_MCMD_MASK (0x7 << 8) +#define OMAP44XX_REG_MCONNID_SHIFT 0 +#define OMAP44XX_REG_MCONNID_MASK (0xff << 0) + +/* DDR_PHY_CTRL_1 */ +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHIFT 4 +#define OMAP44XX_REG_DDR_PHY_CTRL_1_MASK (0xfffffff << 4) +#define OMAP44XX_REG_READ_LATENCY_SHIFT 0 +#define OMAP44XX_REG_READ_LATENCY_MASK (0xf << 0) +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHIFT 4 +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_MASK (0xFF << 4) +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHIFT 12 +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_MASK (0xFFFFF << 12) + +/* DDR_PHY_CTRL_1_SHDW */ +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHDW_SHIFT 4 +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHDW_MASK (0xfffffff << 4) +#define OMAP44XX_REG_READ_LATENCY_SHDW_SHIFT 0 +#define OMAP44XX_REG_READ_LATENCY_SHDW_MASK (0xf << 0) +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHDW_SHIFT 4 +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHDW_MASK (0xFF << 4) +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHDW_SHIFT 12 +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHDW_MASK (0xFFFFF << 12) + +/* DDR_PHY_CTRL_2 */ +#define OMAP44XX_REG_DDR_PHY_CTRL_2_SHIFT 0 +#define OMAP44XX_REG_DDR_PHY_CTRL_2_MASK (0xffffffff << 0) + +/* DMM */ +#define OMAP44XX_DMM_BASE 0x4E000000 +#define OMAP44XX_DMM_LISA_MAP_BASE (0x4E000000 + 0x40) + +/* DMM_LISA_MAP */ +#define OMAP44XX_SYS_ADDR_SHIFT 24 +#define OMAP44XX_SYS_ADDR_MASK (0xff << 24) +#define OMAP44XX_SYS_SIZE_SHIFT 20 +#define OMAP44XX_SYS_SIZE_MASK (0x7 << 20) +#define OMAP44XX_SDRC_INTL_SHIFT 18 +#define OMAP44XX_SDRC_INTL_MASK (0x3 << 18) +#define OMAP44XX_SDRC_ADDRSPC_SHIFT 16 +#define OMAP44XX_SDRC_ADDRSPC_MASK (0x3 << 16) +#define OMAP44XX_SDRC_MAP_SHIFT 8 +#define OMAP44XX_SDRC_MAP_MASK (0x3 << 8) +#define OMAP44XX_SDRC_ADDR_SHIFT 0 +#define OMAP44XX_SDRC_ADDR_MASK (0xff << 0) + +/* DMM_LISA_MAP fields */ +#define DMM_SDRC_MAP_UNMAPPED 0 +#define DMM_SDRC_MAP_EMIF1_ONLY 1 +#define DMM_SDRC_MAP_EMIF2_ONLY 2 +#define DMM_SDRC_MAP_EMIF1_AND_EMIF2 3 + +#define DMM_SDRC_INTL_NONE 0 +#define DMM_SDRC_INTL_128B 1 +#define DMM_SDRC_INTL_256B 2 +#define DMM_SDRC_INTL_512 3 + +#define DMM_SDRC_ADDR_SPC_SDRAM 0 +#define DMM_SDRC_ADDR_SPC_NVM 1 +#define DMM_SDRC_ADDR_SPC_INVALID 2 + +#define DMM_LISA_MAP_INTERLEAVED_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF1_AND_EMIF2 << OMAP44XX_SDRC_MAP_SHIFT) |\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT) |\ + (DMM_SDRC_INTL_128B << OMAP44XX_SDRC_INTL_SHIFT) |\ + (CONFIG_SYS_SDRAM_BASE << OMAP44XX_SYS_ADDR_SHIFT)) + +#define DMM_LISA_MAP_EMIF1_ONLY_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)) + +#define DMM_LISA_MAP_EMIF2_ONLY_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF2_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)) + +/* Trap for invalid TILER PAT entries */ +#define DMM_LISA_MAP_0_INVAL_ADDR_TRAP (\ + (0 << OMAP44XX_SDRC_ADDR_SHIFT) |\ + (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_INVALID << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)|\ + (0xFF << OMAP44XX_SYS_ADDR_SHIFT)) + + +/* Reg mapping structure */ +struct __attribute__ ((__packed__)) emif_reg_struct{ + u32 emif_mod_id_rev; + u32 emif_status; + u32 emif_sdram_config; + u32 emif_lpddr2_nvm_config; + u32 emif_sdram_ref_ctrl; + u32 emif_sdram_ref_ctrl_shdw; + u32 emif_sdram_tim_1; + u32 emif_sdram_tim_1_shdw; + u32 emif_sdram_tim_2; + u32 emif_sdram_tim_2_shdw; + u32 emif_sdram_tim_3; + u32 emif_sdram_tim_3_shdw; + u32 emif_lpddr2_nvm_tim; + u32 emif_lpddr2_nvm_tim_shdw; + u32 emif_pwr_mgmt_ctrl; + u32 emif_pwr_mgmt_ctrl_shdw; + u32 emif_lpddr2_mode_reg_data; + u32 padding1[1]; + u32 emif_lpddr2_mode_reg_data_es2; + u32 padding11[1]; + u32 emif_lpddr2_mode_reg_cfg; + u32 emif_l3_config; + u32 emif_l3_cfg_val_1; + u32 emif_l3_cfg_val_2; + u32 emif_iodft_tlgc; + u32 padding2[7]; + u32 emif_perf_cnt_1; + u32 emif_perf_cnt_2; + u32 emif_perf_cnt_cfg; + u32 emif_perf_cnt_sel; + u32 emif_perf_cnt_tim; + u32 padding3; + u32 emif_read_idlectrl; + u32 emif_read_idlectrl_shdw; + u32 padding4; + u32 emif_irqstatus_raw_sys; + u32 emif_irqstatus_raw_ll; + u32 emif_irqstatus_sys; + u32 emif_irqstatus_ll; + u32 emif_irqenable_set_sys; + u32 emif_irqenable_set_ll; + u32 emif_irqenable_clr_sys; + u32 emif_irqenable_clr_ll; + u32 padding5; + u32 emif_zq_config; + u32 emif_temp_alert_config; + u32 emif_l3_err_log; + u32 padding6[4]; + u32 emif_ddr_phy_ctrl_1; + u32 emif_ddr_phy_ctrl_1_shdw; + u32 emif_ddr_phy_ctrl_2; +}; + +struct __attribute__ ((__packed__)) dmm_lisa_map_regs { + u32 dmm_lisa_map_0; + u32 dmm_lisa_map_1; + u32 dmm_lisa_map_2; + u32 dmm_lisa_map_3; +}; + +#define CS0 0 +#define CS1 1 +/* Read Latency used by the device at reset */ +#define RL_BOOT 3 +/* Read Latency for the highest frequency you want to use */ +#define RL_FINAL 6 +/* EMIF_PWR_MGMT_CTRL register */ +/* Low power modes */ +#define LP_MODE_DISABLE 0 +#define LP_MODE_CLOCK_STOP 1 +#define LP_MODE_SELF_REFRESH 2 +#define LP_MODE_PWR_DN 3 + +/* REG_DPD_EN */ +#define DPD_DISABLE 0 +#define DPD_ENABLE 1 + +/* Maximum delay before Low Power Modes */ +#define REG_CS_TIM 0xF +#define REG_SR_TIM 0xF +#define REG_PD_TIM 0xF + +/* EMIF_PWR_MGMT_CTRL register */ +#define EMIF_PWR_MGMT_CTRL (\ + ((REG_CS_TIM << OMAP44XX_REG_CS_TIM_SHIFT) & OMAP44XX_REG_CS_TIM_MASK)|\ + ((REG_SR_TIM << OMAP44XX_REG_SR_TIM_SHIFT) & OMAP44XX_REG_SR_TIM_MASK)|\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHIFT) & OMAP44XX_REG_PD_TIM_MASK)|\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHIFT) & OMAP44XX_REG_PD_TIM_MASK)|\ + ((LP_MODE_DISABLE << OMAP44XX_REG_LP_MODE_SHIFT)\ + & OMAP44XX_REG_LP_MODE_MASK) |\ + ((DPD_DISABLE << OMAP44XX_REG_DPD_EN_SHIFT)\ + & OMAP44XX_REG_DPD_EN_MASK))\ + +#define EMIF_PWR_MGMT_CTRL_SHDW (\ + ((REG_CS_TIM << OMAP44XX_REG_CS_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_CS_TIM_SHDW_MASK) |\ + ((REG_SR_TIM << OMAP44XX_REG_SR_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_SR_TIM_SHDW_MASK) |\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_PD_TIM_SHDW_MASK) |\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_PD_TIM_SHDW_MASK)) + +/* EMIF_L3_CONFIG register value for ES1*/ +#define EMIF_L3_CONFIG_VAL_SYS_THRESH_0A_LL_THRESH_00 0x0A0000FF + +/* +* MR1 value: +* Burst length : 8 +* Burst type : sequential +* Wrap : enabled +* nWR : 3(default). EMIF does not do pre-charge. +* : So nWR is don't care +*/ +#define MR1_BL_8_BT_SEQ_WRAP_EN_NWR_3 0x23 + +/* MR2 */ +#define MR2_RL3_WL1 1 +#define MR2_RL4_WL2 2 +#define MR2_RL5_WL2 3 +#define MR2_RL6_WL3 4 + +/* MR10: ZQ calibration codes */ +#define MR10_ZQ_ZQCS 0x56 +#define MR10_ZQ_ZQCL 0xAB +#define MR10_ZQ_ZQINIT 0xFF +#define MR10_ZQ_ZQRESET 0xC3 + +/* MR16 value: refresh full array(no partial array self refresh) */ +#define MR16_REF_FULL_ARRAY 0 + +/* LPDDR2 IO reg values */ +#define CONTROL_LPDDR2IO_SLEW_125PS_DRV8_PULL_DOWN 0x1C1C1C1C +#define CONTROL_LPDDR2IO_SLEW_325PS_DRV8_GATE_KEEPER 0x9E9E9E9E + +/* CONTROL_EFUSE_2 */ +#define CONTROL_EFUSE_2_NMOS_PMOS_PTV_CODE_1 0x00ffc000 + +/* Mode register numbers */ +#define LPDDR2_MR0 0 +#define LPDDR2_MR1 1 +#define LPDDR2_MR2 2 +#define LPDDR2_MR3 3 +#define LPDDR2_MR4 4 +#define LPDDR2_MR5 5 +#define LPDDR2_MR6 6 +#define LPDDR2_MR7 7 +#define LPDDR2_MR8 8 +#define LPDDR2_MR9 9 +#define LPDDR2_MR10 10 +#define LPDDR2_MR11 11 +#define LPDDR2_MR16 16 +#define LPDDR2_MR17 17 +#define LPDDR2_MR18 18 + +/* MR0 */ +#define LPDDR2_MR0_DAI_SHIFT 0 +#define LPDDR2_MR0_DAI_MASK 1 +#define LPDDR2_MR0_DI_SHIFT 1 +#define LPDDR2_MR0_DI_MASK (1 << 1) +#define LPDDR2_MR0_DNVI_SHIFT 2 +#define LPDDR2_MR0_DNVI_MASK (1 << 2) + +/* + * Structure containing shadow of important registers in EMIF + * The calculation function fills in this structure to be later used for + * initialization and DVFS + */ +struct emif_regs { + u32 freq; + u32 sdram_config_init; + u32 sdram_config; + u32 ref_ctrl; + u32 sdram_tim1; + u32 sdram_tim2; + u32 sdram_tim3; + u32 read_idle_ctrl; + u32 zq_config; + u32 temp_alert_config; + u32 emif_ddr_phy_ctlr_1_init; + u32 emif_ddr_phy_ctlr_1; +}; + +void emif_get_reg_dump(const struct emif_regs **emif1_regs, + const struct emif_regs **emif2_regs); +void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs); + +#endif diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index 740ca9d..a1c4883 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -51,6 +51,17 @@ #define CONTROL_PADCONF_CORE (OMAP44XX_L4_CORE_BASE + 0x100000) #define CONTROL_PADCONF_WKUP (OMAP44XX_L4_CORE_BASE + 0x31E000)
+/* LPDDR2 IO regs */ +#define CONTROL_LPDDR2IO1_0 (CONTROL_PADCONF_CORE + 0x0638) +#define CONTROL_LPDDR2IO1_1 (CONTROL_PADCONF_CORE + 0x063C) +#define CONTROL_LPDDR2IO1_2 (CONTROL_PADCONF_CORE + 0x0640) +#define CONTROL_LPDDR2IO1_3 (CONTROL_PADCONF_CORE + 0x0644) +#define CONTROL_LPDDR2IO2_0 (CONTROL_PADCONF_CORE + 0x0648) +#define CONTROL_LPDDR2IO2_1 (CONTROL_PADCONF_CORE + 0x064C) +#define CONTROL_LPDDR2IO2_2 (CONTROL_PADCONF_CORE + 0x0650) +#define CONTROL_LPDDR2IO2_3 (CONTROL_PADCONF_CORE + 0x0654) +#define CONTROL_EFUSE_2 (CONTROL_PADCONF_CORE + 0x0704) + /* CONTROL_ID_CODE */ #define CONTROL_ID_CODE (CTRL_BASE + 0x204)
diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index fd21afd..4beff42 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -44,6 +44,7 @@ void bypass_dpll(u32 base); void freq_update_core(void); u32 get_syc_clk_freq(void); u32 omap4_ddr_clk(void); +void sdram_init(void); u32 omap4_revision(void);
static inline u32 running_from_sdram(void) diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 5b20841..07d45a0 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -245,11 +245,6 @@ /* Defines for Clock init */ #define CONFIG_SYS_OMAP4_ABE_SYSCK
-/* Defines for SDRAM init */ -#define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION 1 -#define CONFIG_SYS_EMIF_UPDATE_TIMINGS 1 -#define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS 1 - /* Defines for SPL */ #define CONFIG_SPL #define CONFIG_SYS_SPL_TEXT_BASE 0x40304360 diff --git a/spl/board/ti/sdp4430/Makefile b/spl/board/ti/sdp4430/Makefile index 40e3e79..1f25f77 100644 --- a/spl/board/ti/sdp4430/Makefile +++ b/spl/board/ti/sdp4430/Makefile @@ -115,12 +115,20 @@ $(obj)board.c:$(obj)omap4_mux_data.h @rm -f $@ @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/board.c $@
+$(obj)emif.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/emif.c $@ + +$(obj)sdram_elpida.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/sdram_elpida.c $@ + $(obj)clocks.c: @rm -f $@ @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/clocks.c $@
SOBJS += lowlevel_init.o -COBJS += board.o clocks.o +COBJS += board.o clocks.o emif.o sdram_elpida.o
Calculate EMIF register values based on AC timing parameters from the SDRAM datasheet and the DDR frequency rather than using the hard-coded values.
For a new board the user doen't have to go through the tedious process of calculating the register values. Instead, just provide the AC timings from the device data sheet as input and the driver will automatically calculate the register values.
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap-common/Makefile | 1 + arch/arm/cpu/armv7/omap-common/utils.c | 61 ++ arch/arm/cpu/armv7/omap4/Makefile | 1 - arch/arm/cpu/armv7/omap4/board.c | 9 +- arch/arm/cpu/armv7/omap4/emif.c | 861 ++++++++++++++++++++++++++- arch/arm/cpu/armv7/omap4/sdram_elpida.c | 152 +++++- arch/arm/include/asm/arch-omap4/emif.h | 304 ++++++++++- arch/arm/include/asm/arch-omap4/omap4.h | 18 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + arch/arm/include/asm/omap_common.h | 21 + include/configs/omap4_sdp4430.h | 5 + spl/board/ti/sdp4430/Makefile | 6 +- 12 files changed, 1424 insertions(+), 16 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/utils.c
diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index dc01ee5..8f698f8 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -28,6 +28,7 @@ LIB = $(obj)libomap-common.o SOBJS := reset.o
COBJS := timer.o +COBJS += utils.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/arch/arm/cpu/armv7/omap-common/utils.c b/arch/arm/cpu/armv7/omap-common/utils.c new file mode 100644 index 0000000..7dce7f1 --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/utils.c @@ -0,0 +1,61 @@ +/* + * Utility functions for OMAP4 + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +static void do_cancel_out(u32 *num, u32 *den, u32 factor) +{ + while (1) { + if (((*num)/factor*factor == (*num)) && + ((*den)/factor*factor == (*den))) { + (*num) /= factor; + (*den) /= factor; + } else + break; + } +} + +/* + * Cancel out the denominator and numerator of a fraction + * to get smaller numerator and denominator. + */ +void cancel_out(u32 *num, u32 *den, u32 den_limit) +{ + do_cancel_out(num, den, 2); + do_cancel_out(num, den, 3); + do_cancel_out(num, den, 5); + do_cancel_out(num, den, 7); + do_cancel_out(num, den, 11); + do_cancel_out(num, den, 13); + do_cancel_out(num, den, 17); + while ((*den) > den_limit) { + *num /= 2; + /* + * Round up the denominator so that the final fraction + * (num/den) is always <= the desired value + */ + *den = (*den + 1) / 2; + } +} diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index d9714fe..0b525e1 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -34,7 +34,6 @@ COBJS += clocks.o COBJS += emif.o COBJS += sdram_elpida.o
- SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS))
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 89b1213..925601d 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -32,6 +32,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> +#include <asm/arch/emif.h> #include "omap4_mux_data.h"
DECLARE_GLOBAL_DATA_PTR; @@ -148,13 +149,13 @@ u32 sdram_size(void) { u32 section, i, total_size = 0, size, addr; for (i = 0; i < 4; i++) { - section = __raw_readl(DMM_LISA_MAP_BASE + i*4); - addr = section & DMM_LISA_MAP_SYS_ADDR_MASK; + section = __raw_readl(OMAP44XX_DMM_LISA_MAP_BASE + i*4); + addr = section & OMAP44XX_SYS_ADDR_MASK; /* See if the address is valid */ if ((addr >= OMAP44XX_DRAM_ADDR_SPACE_START) && (addr < OMAP44XX_DRAM_ADDR_SPACE_END)) { - size = ((section & DMM_LISA_MAP_SYS_SIZE_MASK) >> - DMM_LISA_MAP_SYS_SIZE_SHIFT); + size = ((section & OMAP44XX_SYS_SIZE_MASK) >> + OMAP44XX_SYS_SIZE_SHIFT); size = 1 << size; size *= SZ_16M; total_size += size; diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index ee77743..1bdb1d2 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -31,6 +31,589 @@ #include <asm/arch/sys_proto.h> #include <asm/omap_common.h>
+DECLARE_GLOBAL_DATA_PTR; + +#define print_timing_reg(reg) debug(#reg" - 0x%08x\n", (reg)) + +static u32 *const T_num = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_NUM; +static u32 *const T_den = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_DEN; +static u32 *const emif_sizes = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_SIZE; + +/* + * Organization and refresh requirements for LPDDR2 devices of different + * types and densities. Derived from JESD209-2 section 2.4 + */ +const struct lpddr2_addressing addressing_table[] = { + /* Banks tREFIx10 rowx32,rowx16 colx32,colx16 density */ + {BANKS4, T_REFI_15_6, {ROW_12, ROW_12}, {COL_7, COL_8} },/*64M */ + {BANKS4, T_REFI_15_6, {ROW_12, ROW_12}, {COL_8, COL_9} },/*128M */ + {BANKS4, T_REFI_7_8, {ROW_13, ROW_13}, {COL_8, COL_9} },/*256M */ + {BANKS4, T_REFI_7_8, {ROW_13, ROW_13}, {COL_9, COL_10} },/*512M */ + {BANKS8, T_REFI_7_8, {ROW_13, ROW_13}, {COL_9, COL_10} },/*1GS4 */ + {BANKS8, T_REFI_3_9, {ROW_14, ROW_14}, {COL_9, COL_10} },/*2GS4 */ + {BANKS8, T_REFI_3_9, {ROW_14, ROW_14}, {COL_10, COL_11} },/*4G */ + {BANKS8, T_REFI_3_9, {ROW_15, ROW_15}, {COL_10, COL_11} },/*8G */ + {BANKS4, T_REFI_7_8, {ROW_14, ROW_14}, {COL_9, COL_10} },/*1GS2 */ + {BANKS4, T_REFI_3_9, {ROW_15, ROW_15}, {COL_9, COL_10} },/*2GS2 */ +}; + +static const u32 lpddr2_density_2_size_in_mbytes[] = { + 8, /* 64Mb */ + 16, /* 128Mb */ + 32, /* 256Mb */ + 64, /* 512Mb */ + 128, /* 1Gb */ + 256, /* 2Gb */ + 512, /* 4Gb */ + 1024, /* 8Gb */ + 2048, /* 16Gb */ + 4096 /* 32Gb */ +}; + +#ifdef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS +/* Base AC Timing values specified by JESD209-2 for 400MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_400_mhz = { + .max_freq = 400000000, + .RL = 6, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* Base AC Timing values specified by JESD209-2 for 333 MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_333_mhz = { + .max_freq = 333000000, + .RL = 5, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* Base AC Timing values specified by JESD209-2 for 200 MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_200_mhz = { + .max_freq = 200000000, + .RL = 3, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 20, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* + * Min tCK values specified by JESD209-2 + * Min tCK specifies the minimum duration of some AC timing parameters in terms + * of the number of cycles. If the calculated number of cycles based on the + * absolute time value is less than the min tCK value, min tCK value should + * be used instead. This typically happens at low frequencies. + */ +static const struct lpddr2_min_tck min_tck_jedec = { + .tRL = 3, + .tRP_AB = 3, + .tRCD = 3, + .tWR = 3, + .tRAS_MIN = 3, + .tRRD = 2, + .tWTR = 2, + .tXP = 2, + .tRTP = 2, + .tCKE = 3, + .tCKESR = 3, + .tFAW = 8 +}; + +static const struct lpddr2_ac_timings *jedec_ac_timings[MAX_NUM_SPEEDBINS] = { + &timings_jedec_200_mhz, + &timings_jedec_333_mhz, + &timings_jedec_400_mhz +}; + +static const struct lpddr2_device_timings jedec_default_timings = { + .ac_timings = jedec_ac_timings, + .min_tck = &min_tck_jedec +}; +#endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */ + +/* + * Calculate the period of DDR clock from frequency value and set the + * denominator and numerator in global variables for easy access later + */ +static void set_ddr_clk_period(u32 freq) +{ + /* + * period = 1/freq + * period_in_ns = 10^9/freq + */ + *T_num = 1000000000; + *T_den = freq; + cancel_out(T_num, T_den, 200); + +} + +/* + * Convert time in nano seconds to number of cycles of DDR clock + */ +static inline u32 ns_2_cycles(u32 ns) +{ + return ((ns * (*T_den)) + (*T_num) - 1) / (*T_num); +} + +/* + * ns_2_cycles with the difference that the time passed is 2 times the actual + * value(to avoid fractions). The cycles returned is for the original value of + * the timing parameter + */ +static inline u32 ns_x2_2_cycles(u32 ns) +{ + return ((ns * (*T_den)) + (*T_num) * 2 - 1) / ((*T_num) * 2); +} + +/* + * Find addressing table index based on the device's type(S2 or S4) and + * density + */ +s8 addressing_table_index(u8 type, u8 density, u8 width) +{ + u8 index; + if ((density > LPDDR2_DENSITY_8Gb) || (width == LPDDR2_IO_WIDTH_8)) + return -1; + + /* + * Look at the way ADDR_TABLE_INDEX* values have been defined + * in emif.h compared to LPDDR2_DENSITY_* values + * The table is layed out in the increasing order of density + * (ignoring type). The exceptions 1GS2 and 2GS2 have been placed + * at the end + */ + if ((type == LPDDR2_TYPE_S2) && (density == LPDDR2_DENSITY_1Gb)) + index = ADDR_TABLE_INDEX1GS2; + else if ((type == LPDDR2_TYPE_S2) && (density == LPDDR2_DENSITY_2Gb)) + index = ADDR_TABLE_INDEX2GS2; + else + index = density; + + debug("emif: addressing table index %d\n", index); + + return index; +} + +/* + * Find the the right timing table from the array of timing + * tables of the device using DDR clock frequency + */ +static const struct lpddr2_ac_timings *get_timings_table(const struct + lpddr2_ac_timings const *const *device_timings, + u32 freq) +{ + u32 i, temp, freq_nearest; + const struct lpddr2_ac_timings *timings = 0; + + emif_assert(freq <= MAX_LPDDR2_FREQ); + emif_assert(device_timings); + + /* + * Start with the maximum allowed frequency - that is always safe + */ + freq_nearest = MAX_LPDDR2_FREQ; + /* + * Find the timings table that has the max frequency value: + * i. Above or equal to the DDR frequency - safe + * ii. The lowest that satisfies condition (i) - optimal + */ + for (i = 0; (i < MAX_NUM_SPEEDBINS) && device_timings[i]; i++) { + temp = device_timings[i]->max_freq; + if ((temp >= freq) && (temp <= freq_nearest)) { + freq_nearest = temp; + timings = device_timings[i]; + } + } + debug("emif: timings table: %d\n", freq_nearest); + return timings; +} + +/* + * Finds the value of emif_sdram_config_reg + * All parameters are programmed based on the device on CS0. + * If there is a device on CS1, it will be same as that on CS0 or + * it will be NVM. We don't support NVM yet. + * If cs1_device pointer is NULL it is assumed that there is no device + * on CS1 + */ +static u32 get_sdram_config_reg(const struct lpddr2_device_details *cs0_device, + const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 RL) +{ + u32 config_reg = 0; + + set_bit_field(config_reg, OMAP44XX_REG_SDRAM_TYPE_SHIFT, + OMAP44XX_REG_SDRAM_TYPE_MASK, cs0_device->type + 4); + + set_bit_field(config_reg, OMAP44XX_REG_IBANK_POS_SHIFT, + OMAP44XX_REG_IBANK_POS_MASK, + EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING); + + set_bit_field(config_reg, OMAP44XX_REG_NARROW_MODE_SHIFT, + OMAP44XX_REG_NARROW_MODE_MASK, cs0_device->io_width); + + set_bit_field(config_reg, OMAP44XX_REG_CL_SHIFT, OMAP44XX_REG_CL_MASK, + RL); + + set_bit_field(config_reg, OMAP44XX_REG_ROWSIZE_SHIFT, + OMAP44XX_REG_ROWSIZE_MASK, + addressing->row_sz[cs0_device->io_width]); + + set_bit_field(config_reg, OMAP44XX_REG_IBANK_SHIFT, + OMAP44XX_REG_IBANK_MASK, addressing->num_banks); + + set_bit_field(config_reg, OMAP44XX_REG_EBANK_SHIFT, + OMAP44XX_REG_EBANK_MASK, + (cs1_device ? EBANK_CS1_EN : EBANK_CS1_DIS)); + + set_bit_field(config_reg, OMAP44XX_REG_PAGESIZE_SHIFT, + OMAP44XX_REG_PAGESIZE_MASK, + addressing->col_sz[cs0_device->io_width]); + + return config_reg; +} + +static u32 get_sdram_ref_ctrl(u32 freq, + const struct lpddr2_addressing *addressing) +{ + u32 ref_ctrl = 0, val = 0, freq_khz; + freq_khz = freq / 1000; + /* + * refresh rate to be set is 'tREFI * freq in MHz + * division by 10000 to account for khz and x10 in t_REFI_us_x10 + */ + val = addressing->t_REFI_us_x10 * freq_khz / 10000; + set_bit_field(ref_ctrl, OMAP44XX_REG_REFRESH_RATE_SHIFT, + OMAP44XX_REG_REFRESH_RATE_MASK, val); + + return ref_ctrl; +} + +static u32 get_sdram_tim_1_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck, + const struct lpddr2_addressing *addressing) +{ + u32 tim1 = 0, val = 0; + val = max(min_tck->tWTR, ns_x2_2_cycles(timings->tWTRx2)) - 1; + set_bit_field(tim1, OMAP44XX_REG_T_WTR_SHIFT, OMAP44XX_REG_T_WTR_MASK, + val); + + if (addressing->num_banks == BANKS8) + val = (timings->tFAW * (*T_den) + 4 * (*T_num) - 1) / + (4 * (*T_num)) - 1; + else + val = max(min_tck->tRRD, ns_2_cycles(timings->tRRD)) - 1; + + set_bit_field(tim1, OMAP44XX_REG_T_RRD_SHIFT, OMAP44XX_REG_T_RRD_MASK, + val); + + val = ns_2_cycles(timings->tRASmin + timings->tRPab) - 1; + set_bit_field(tim1, OMAP44XX_REG_T_RC_SHIFT, OMAP44XX_REG_T_RC_MASK, + val); + + val = max(min_tck->tRAS_MIN, ns_2_cycles(timings->tRASmin)) - 1; + set_bit_field(tim1, OMAP44XX_REG_T_RAS_SHIFT, OMAP44XX_REG_T_RAS_MASK, + val); + + val = max(min_tck->tWR, ns_2_cycles(timings->tWR)) - 1; + set_bit_field(tim1, OMAP44XX_REG_T_WR_SHIFT, OMAP44XX_REG_T_WR_MASK, + val); + + val = max(min_tck->tRCD, ns_2_cycles(timings->tRCD)) - 1; + set_bit_field(tim1, OMAP44XX_REG_T_RCD_SHIFT, OMAP44XX_REG_T_RCD_MASK, + val); + val = max(min_tck->tRP_AB, ns_2_cycles(timings->tRPab)) - 1; + set_bit_field(tim1, OMAP44XX_REG_T_RP_SHIFT, OMAP44XX_REG_T_RP_MASK, + val); + + return tim1; +} + +static u32 get_sdram_tim_2_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck) +{ + u32 tim2 = 0, val = 0; + val = max(min_tck->tCKE, timings->tCKE) - 1; + set_bit_field(tim2, OMAP44XX_REG_T_CKE_SHIFT, OMAP44XX_REG_T_CKE_MASK, + val); + + val = max(min_tck->tRTP, ns_x2_2_cycles(timings->tRTPx2)) - 1; + set_bit_field(tim2, OMAP44XX_REG_T_RTP_SHIFT, OMAP44XX_REG_T_RTP_MASK, + val); + + /* + * tXSRD = tRFCab + 10 ns. XSRD and XSNR should have the + * same value + */ + val = ns_2_cycles(timings->tXSR) - 1; + set_bit_field(tim2, OMAP44XX_REG_T_XSRD_SHIFT, OMAP44XX_REG_T_XSRD_MASK, + val); + set_bit_field(tim2, OMAP44XX_REG_T_XSNR_SHIFT, OMAP44XX_REG_T_XSNR_MASK, + val); + + val = max(min_tck->tXP, ns_x2_2_cycles(timings->tXPx2)) - 1; + set_bit_field(tim2, OMAP44XX_REG_T_XP_SHIFT, OMAP44XX_REG_T_XP_MASK, + val); + + return tim2; +} + +static u32 get_sdram_tim_3_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck, + const struct lpddr2_addressing *addressing) +{ + u32 tim3 = 0, val = 0; + val = min(timings->tRASmax * 10 / addressing->t_REFI_us_x10 - 1, 0xF); + set_bit_field(tim3, OMAP44XX_REG_T_RAS_MAX_SHIFT, + OMAP44XX_REG_T_RAS_MAX_MASK, val); + + val = ns_2_cycles(timings->tRFCab) - 1; + set_bit_field(tim3, OMAP44XX_REG_T_RFC_SHIFT, OMAP44XX_REG_T_RFC_MASK, + val); + + val = ns_x2_2_cycles(timings->tDQSCKMAXx2) - 1; + set_bit_field(tim3, OMAP44XX_REG_T_TDQSCKMAX_SHIFT, + OMAP44XX_REG_T_TDQSCKMAX_MASK, val); + + val = ns_2_cycles(timings->tZQCS) - 1; + set_bit_field(tim3, OMAP44XX_REG_ZQ_ZQCS_SHIFT, + OMAP44XX_REG_ZQ_ZQCS_MASK, val); + + val = max(min_tck->tCKESR, ns_2_cycles(timings->tCKESR)) - 1; + set_bit_field(tim3, OMAP44XX_REG_T_CKESR_SHIFT, + OMAP44XX_REG_T_CKESR_MASK, val); + + return tim3; +} + +static u32 get_zq_config_reg(const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 volt_ramp) +{ + u32 zq = 0, val = 0; + if (volt_ramp) + val = + EMIF_ZQCS_INTERVAL_DVFS_IN_US * 10 / + addressing->t_REFI_us_x10; + else + val = + EMIF_ZQCS_INTERVAL_NORMAL_IN_US * 10 / + addressing->t_REFI_us_x10; + set_bit_field(zq, OMAP44XX_REG_ZQ_REFINTERVAL_SHIFT, + OMAP44XX_REG_ZQ_REFINTERVAL_MASK, val); + + set_bit_field(zq, OMAP44XX_REG_ZQ_ZQCL_MULT_SHIFT, + OMAP44XX_REG_ZQ_ZQCL_MULT_MASK, REG_ZQ_ZQCL_MULT - 1); + + set_bit_field(zq, OMAP44XX_REG_ZQ_ZQINIT_MULT_SHIFT, + OMAP44XX_REG_ZQ_ZQINIT_MULT_MASK, REG_ZQ_ZQINIT_MULT - 1); + + set_bit_field(zq, OMAP44XX_REG_ZQ_SFEXITEN_SHIFT, + OMAP44XX_REG_ZQ_SFEXITEN_MASK, REG_ZQ_SFEXITEN_ENABLE); + + /* + * Assuming that two chipselects have a single calibration resistor + * If there are indeed two calibration resistors, then this flag should + * be enabled to take advantage of dual calibration feature. + * This data should ideally come from board files. But considering + * that none of the boards today have calibration resistors per CS, + * it would be an unnecessary overhead. + */ + set_bit_field(zq, OMAP44XX_REG_ZQ_DUALCALEN_SHIFT, + OMAP44XX_REG_ZQ_DUALCALEN_MASK, REG_ZQ_DUALCALEN_DISABLE); + + set_bit_field(zq, OMAP44XX_REG_ZQ_CS0EN_SHIFT, + OMAP44XX_REG_ZQ_CS0EN_MASK, REG_ZQ_CS0EN_ENABLE); + + set_bit_field(zq, OMAP44XX_REG_ZQ_CS1EN_SHIFT, + OMAP44XX_REG_ZQ_CS1EN_MASK, (cs1_device ? 1 : 0)); + + return zq; +} + +static u32 get_temp_alert_config(const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 is_derated) +{ + u32 alert = 0, interval; + interval = + TEMP_ALERT_POLL_INTERVAL_MS * 10000 / addressing->t_REFI_us_x10; + if (is_derated) + interval *= 4; + set_bit_field(alert, OMAP44XX_REG_TA_REFINTERVAL_SHIFT, + OMAP44XX_REG_TA_REFINTERVAL_MASK, interval); + + set_bit_field(alert, OMAP44XX_REG_TA_DEVCNT_SHIFT, + OMAP44XX_REG_TA_DEVCNT_MASK, TEMP_ALERT_CONFIG_DEVCT_1); + + set_bit_field(alert, OMAP44XX_REG_TA_DEVWDT_SHIFT, + OMAP44XX_REG_TA_DEVWDT_MASK, TEMP_ALERT_CONFIG_DEVWDT_32); + + set_bit_field(alert, OMAP44XX_REG_TA_SFEXITEN_SHIFT, + OMAP44XX_REG_TA_SFEXITEN_MASK, 1); + + set_bit_field(alert, OMAP44XX_REG_TA_CS0EN_SHIFT, + OMAP44XX_REG_TA_CS0EN_MASK, 1); + + set_bit_field(alert, OMAP44XX_REG_TA_CS1EN_SHIFT, + OMAP44XX_REG_TA_CS1EN_MASK, (cs1_device ? 1 : 0)); + + return alert; +} + +static u32 get_read_idle_ctrl_reg(u8 volt_ramp) +{ + u32 idle = 0, val = 0; + if (volt_ramp) + val = ns_2_cycles(READ_IDLE_INTERVAL_DVFS) / 64 + 1; + else + /*Maximum value in normal conditions - suggested by hw team */ + val = 0x1FF; + set_bit_field(idle, OMAP44XX_REG_READ_IDLE_INTERVAL_SHIFT, + OMAP44XX_REG_READ_IDLE_INTERVAL_MASK, val); + + set_bit_field(idle, OMAP44XX_REG_READ_IDLE_LEN_SHIFT, + OMAP44XX_REG_READ_IDLE_LEN_MASK, + EMIF_REG_READ_IDLE_LEN_VAL); + + return idle; +} + +static u32 get_ddr_phy_ctrl_1(u32 freq, u8 RL) +{ + u32 phy = 0, val = 0; + + set_bit_field(phy, OMAP44XX_REG_READ_LATENCY_SHIFT, + OMAP44XX_REG_READ_LATENCY_MASK, RL + 2); + + if (freq <= 100000000) + val = EMIF_DLL_SLAVE_DLY_CTRL_100_MHZ_AND_LESS; + else if (freq <= 200000000) + val = EMIF_DLL_SLAVE_DLY_CTRL_200_MHZ; + else + val = EMIF_DLL_SLAVE_DLY_CTRL_400_MHZ; + set_bit_field(phy, OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHIFT, + OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_MASK, val); + + /* Other fields are constant magic values. Hardcode them together */ + set_bit_field(phy, OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHIFT, + OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_MASK, + EMIF_DDR_PHY_CTRL_1_BASE_VAL); + + return phy; +} + +const char *get_lpddr2_type(u8 type_id) +{ + switch (type_id) { + case LPDDR2_TYPE_S4: + return "LPDDR2-S4"; + case LPDDR2_TYPE_S2: + return "LPDDR2-S2"; + default: + return NULL; + } +} + +const char *get_lpddr2_io_width(u8 width_id) +{ + switch (width_id) { + case LPDDR2_IO_WIDTH_8: + return "x8"; + case LPDDR2_IO_WIDTH_16: + return "x16"; + case LPDDR2_IO_WIDTH_32: + return "x32"; + default: + return NULL; + } +} + +const char *get_lpddr2_manufacturer(u32 manufacturer) +{ + switch (manufacturer) { + case LPDDR2_MANUFACTURER_SAMSUNG: + return "Samsung"; + case LPDDR2_MANUFACTURER_QIMONDA: + return "Qimonda"; + case LPDDR2_MANUFACTURER_ELPIDA: + return "Elpida"; + case LPDDR2_MANUFACTURER_ETRON: + return "Etron"; + case LPDDR2_MANUFACTURER_NANYA: + return "Nanya"; + case LPDDR2_MANUFACTURER_HYNIX: + return "Hynix"; + case LPDDR2_MANUFACTURER_MOSEL: + return "Mosel"; + case LPDDR2_MANUFACTURER_WINBOND: + return "Winbond"; + case LPDDR2_MANUFACTURER_ESMT: + return "ESMT"; + case LPDDR2_MANUFACTURER_SPANSION: + return "Spansion"; + case LPDDR2_MANUFACTURER_SST: + return "SST"; + case LPDDR2_MANUFACTURER_ZMOS: + return "ZMOS"; + case LPDDR2_MANUFACTURER_INTEL: + return "Intel"; + case LPDDR2_MANUFACTURER_NUMONYX: + return "Numonyx"; + case LPDDR2_MANUFACTURER_MICRON: + return "Micron"; + default: + return NULL; + } +} + static inline u32 emif_num(u32 base) { if (base == OMAP44XX_EMIF1) @@ -65,6 +648,127 @@ static inline void set_mr(u32 base, u32 cs, u32 mr_addr, u32 mr_val) writel(mr_addr, &emif->emif_lpddr2_mode_reg_cfg); writel(mr_val, &emif->emif_lpddr2_mode_reg_data); } + +static void emif_calculate_regs( + const struct emif_device_details *emif_dev_details, + u32 freq, struct emif_regs *regs) +{ + u32 temp, sys_freq; + const struct lpddr2_addressing *addressing; + const struct lpddr2_ac_timings *timings; + const struct lpddr2_min_tck *min_tck; + const struct lpddr2_device_details *cs0_dev_details = + emif_dev_details->cs0_device_details; + const struct lpddr2_device_details *cs1_dev_details = + emif_dev_details->cs1_device_details; + const struct lpddr2_device_timings *cs0_dev_timings = + emif_dev_details->cs0_device_timings; + + emif_assert(emif_dev_details); + emif_assert(regs); + /* + * You can not have a device on CS1 without one on CS0 + * So configuring EMIF without a device on CS0 doesn't + * make sense + */ + emif_assert(cs0_dev_details); + emif_assert(cs0_dev_details->type != LPDDR2_TYPE_NVM); + /* + * If there is a device on CS1 it should be same type as CS0 + * (or NVM. But NVM is not supported in this driver yet) + */ + emif_assert((cs1_dev_details == NULL) || + (cs1_dev_details->type == LPDDR2_TYPE_NVM) || + (cs0_dev_details->type == cs1_dev_details->type)); + emif_assert(freq <= MAX_LPDDR2_FREQ); + + set_ddr_clk_period(freq); + + /* + * The device on CS0 is used for all timing calculations + * There is only one set of registers for timings per EMIF. So, if the + * second CS(CS1) has a device, it should have the same timings as the + * device on CS0 + */ + timings = get_timings_table(cs0_dev_timings->ac_timings, freq); + emif_assert(timings); + min_tck = cs0_dev_timings->min_tck; + + temp = addressing_table_index(cs0_dev_details->type, + cs0_dev_details->density, + cs0_dev_details->io_width); + + emif_assert((temp >= 0)); + addressing = &(addressing_table[temp]); + emif_assert(addressing); + + sys_freq = get_syc_clk_freq(); + + regs->sdram_config_init = get_sdram_config_reg(cs0_dev_details, + cs1_dev_details, + addressing, RL_BOOT); + + regs->sdram_config = get_sdram_config_reg(cs0_dev_details, + cs1_dev_details, + addressing, RL_FINAL); + + regs->ref_ctrl = get_sdram_ref_ctrl(freq, addressing); + + regs->sdram_tim1 = get_sdram_tim_1_reg(timings, min_tck, addressing); + + regs->sdram_tim2 = get_sdram_tim_2_reg(timings, min_tck); + + regs->sdram_tim3 = get_sdram_tim_3_reg(timings, min_tck, addressing); + + regs->read_idle_ctrl = get_read_idle_ctrl_reg(LPDDR2_VOLTAGE_STABLE); + + regs->temp_alert_config = + get_temp_alert_config(cs1_dev_details, addressing, 0); + + regs->zq_config = get_zq_config_reg(cs1_dev_details, addressing, + LPDDR2_VOLTAGE_STABLE); + + regs->emif_ddr_phy_ctlr_1_init = + get_ddr_phy_ctrl_1(sys_freq / 2, RL_BOOT); + + regs->emif_ddr_phy_ctlr_1 = + get_ddr_phy_ctrl_1(freq, RL_FINAL); + + regs->freq = freq; + + print_timing_reg(regs->sdram_config_init); + print_timing_reg(regs->sdram_config); + print_timing_reg(regs->ref_ctrl); + print_timing_reg(regs->sdram_tim1); + print_timing_reg(regs->sdram_tim2); + print_timing_reg(regs->sdram_tim3); + print_timing_reg(regs->read_idle_ctrl); + print_timing_reg(regs->temp_alert_config); + print_timing_reg(regs->zq_config); + print_timing_reg(regs->emif_ddr_phy_ctlr_1); + print_timing_reg(regs->emif_ddr_phy_ctlr_1_init); +} + +static u32 get_emif_mem_size(struct emif_device_details *devices) +{ + u32 size_mbytes = 0, temp; + + if (!devices) + return 0; + + if (devices->cs0_device_details) { + temp = devices->cs0_device_details->density; + size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; + } + + if (devices->cs1_device_details) { + temp = devices->cs1_device_details->density; + size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; + } + /* convert to bytes */ + return size_mbytes << 20; +} + void emif_reset_phy(u32 base) { struct emif_reg_struct *emif = (struct emif_reg_struct *)base; @@ -158,14 +862,66 @@ static void emif_update_timings(u32 base, const struct emif_regs *regs)
static void do_sdram_init(u32 base) { - const struct emif_regs *regs, *tmp_regs; + struct emif_device_details dev_details; + const struct emif_regs *regs; + u32 in_sdram, emif_nr;
in_sdram = running_from_sdram(); emif_nr = (base == OMAP44XX_EMIF1) ? 1 : 2;
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS + const struct emif_regs *tmp_regs; emif_get_reg_dump(®s, &tmp_regs); regs = (emif_nr == 1) ? regs : tmp_regs; +#else + /* + * The user has not provided the register values. We need to + * calculate it based on the timings and the DDR frequency + */ + + const struct emif_device_details *dev_details_user_provided; + const struct emif_device_details *tmp_details; + struct emif_regs calculated_regs; + + /* We need some input about the devices from the user */ + emif_get_device_details(&dev_details_user_provided, &tmp_details); + dev_details_user_provided = (emif_nr == 1) ? dev_details_user_provided + : tmp_details; + if (!dev_details_user_provided) + return; + + dev_details.cs0_device_details = + dev_details_user_provided->cs0_device_details; + dev_details.cs1_device_details = + dev_details_user_provided->cs1_device_details; + + /* Return if no devices on this EMIF */ + if (!dev_details.cs0_device_details && + !dev_details.cs1_device_details) { + emif_sizes[emif_nr - 1] = 0; + return; + } + + if (!in_sdram) + emif_sizes[emif_nr - 1] = get_emif_mem_size(&dev_details); + +#ifdef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS + /* Use the base timings specified by JESD209-2 */ + dev_details.cs0_device_timings = &jedec_default_timings; + dev_details.cs1_device_timings = &jedec_default_timings; + +#else /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */ + dev_details.cs0_device_timings = + dev_details_user_provided->cs0_device_timings; + dev_details.cs1_device_timings = + dev_details_user_provided->cs1_device_timings; +#endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */ + /* Calculate the register values */ + emif_calculate_regs(&dev_details, omap4_ddr_clk(), &calculated_regs); + regs = &calculated_regs; + +#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */
/* * Initializing the LPDDR2 device can not happen from SDRAM. @@ -215,12 +971,111 @@ static void emif_post_init_config(u32 base) writel(0x80000000, &emif->emif_pwr_mgmt_ctrl); }
+/* Gets the encoding corresponding to a given DMM section size */ +u32 get_dmm_section_size_map(u32 section_size) +{ + /* + * Section size mapping: + * 0x0: 16-MiB section + * 0x1: 32-MiB section + * 0x2: 64-MiB section + * 0x3: 128-MiB section + * 0x4: 256-MiB section + * 0x5: 512-MiB section + * 0x6: 1-GiB section + * 0x7: 2-GiB section + */ + section_size >>= 24; /* divide by 16 MB */ + return log_2_n_round_down(section_size); +} + static void dmm_init(u32 base) { const struct dmm_lisa_map_regs *lisa_map_regs;
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS emif_get_dmm_regs(&lisa_map_regs); +#else + u32 emif1_size, emif2_size, mapped_size, section_map; + u32 section_cnt, sys_addr; + struct dmm_lisa_map_regs lis_map_regs_calculated; + + mapped_size = 0; + section_cnt = 3; + sys_addr = CONFIG_SYS_SDRAM_BASE; + emif1_size = emif_sizes[0]; + emif2_size = emif_sizes[1]; + debug("emif1_size 0x%x emif2_size 0x%x\n", emif1_size, emif2_size);
+ if (!emif1_size && !emif2_size) + return; + + /* symmetric interleaved section */ + if (emif1_size && emif2_size) { + mapped_size = min(emif1_size, emif2_size); + section_map = DMM_LISA_MAP_INTERLEAVED_BASE_VAL; + set_bit_field(section_map, OMAP44XX_SDRC_ADDR_SHIFT, + OMAP44XX_SDRC_ADDR_MASK, + 0); + set_bit_field(section_map, OMAP44XX_SYS_ADDR_SHIFT, + OMAP44XX_SYS_ADDR_MASK, + sys_addr >> 24); /* only MSB */ + set_bit_field(section_map, OMAP44XX_SYS_SIZE_SHIFT, + OMAP44XX_SYS_SIZE_MASK, + get_dmm_section_size_map(mapped_size * 2)); + lis_map_regs_calculated.dmm_lisa_map_3 = section_map; + emif1_size -= mapped_size; + emif2_size -= mapped_size; + sys_addr += (mapped_size * 2); + section_cnt--; + } + + /* + * Single EMIF section(we can have a maximum of 1 single EMIF + * section- either EMIF1 or EMIF2 or none, but not both) + */ + if (emif1_size) { + section_map = DMM_LISA_MAP_EMIF1_ONLY_BASE_VAL; + set_bit_field(section_map, OMAP44XX_SYS_SIZE_SHIFT, + OMAP44XX_SYS_SIZE_MASK, + get_dmm_section_size_map(emif1_size)); + set_bit_field(section_map, OMAP44XX_SDRC_ADDR_SHIFT, + OMAP44XX_SDRC_ADDR_MASK, + mapped_size >> 24); /* only MSB */ + set_bit_field(section_map, OMAP44XX_SYS_ADDR_SHIFT, + OMAP44XX_SYS_ADDR_MASK, + sys_addr >> 24); /* only MSB */ + section_cnt--; + } + if (emif2_size) { + section_map = DMM_LISA_MAP_EMIF2_ONLY_BASE_VAL; + set_bit_field(section_map, OMAP44XX_SYS_SIZE_SHIFT, + OMAP44XX_SYS_SIZE_MASK, + get_dmm_section_size_map(emif2_size)); + set_bit_field(section_map, OMAP44XX_SDRC_ADDR_SHIFT, + OMAP44XX_SDRC_ADDR_MASK, + mapped_size >> 24); /* only MSB */ + set_bit_field(section_map, OMAP44XX_SYS_ADDR_SHIFT, + OMAP44XX_SYS_ADDR_MASK, + sys_addr >> 24); /* only MSB */ + section_cnt--; + } + + if (section_cnt == 2) { + /* Only 1 section - either symmetric or single EMIF */ + lis_map_regs_calculated.dmm_lisa_map_3 = section_map; + lis_map_regs_calculated.dmm_lisa_map_2 = 0; + lis_map_regs_calculated.dmm_lisa_map_1 = 0; + } else { + /* 2 sections - 1 symmetric, 1 single EMIF */ + lis_map_regs_calculated.dmm_lisa_map_2 = section_map; + lis_map_regs_calculated.dmm_lisa_map_1 = 0; + } + /* TRAP for invalid TILER mappings in section 0 */ + lis_map_regs_calculated.dmm_lisa_map_0 = DMM_LISA_MAP_0_INVAL_ADDR_TRAP; + + lisa_map_regs = &lis_map_regs_calculated; +#endif struct dmm_lisa_map_regs *hw_lisa_map_regs = (struct dmm_lisa_map_regs *)base;
@@ -258,8 +1113,10 @@ static void dmm_init(u32 base) */ void sdram_init(void) { - u32 in_sdram; + if (omap4_hw_init_context() == OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_SPL) + return;
+ u32 in_sdram; in_sdram = running_from_sdram();
if (!in_sdram) { diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c index 37e808c..e7d2bd5 100644 --- a/arch/arm/cpu/armv7/omap4/sdram_elpida.c +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -29,6 +29,8 @@ #include <asm/arch/emif.h> #include <asm/arch/sys_proto.h>
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS + static const struct emif_regs emif_regs_elpida_200_mhz_2cs = { .sdram_config_init = 0x80000eb9, .sdram_config = 0x80001ab9, @@ -86,6 +88,131 @@ const struct dmm_lisa_map_regs lisa_map_2G_x_2_x_2 = {
void emif_get_reg_dump_sdp(const struct emif_regs **emif1_regs, const struct emif_regs **emif2_regs) + +#else + +static const struct lpddr2_ac_timings timings_elpida_400_mhz = { + .max_freq = 400000000, + .RL = 6, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_ac_timings timings_elpida_333_mhz = { + .max_freq = 333000000, + .RL = 5, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_ac_timings timings_elpida_200_mhz = { + .max_freq = 200000000, + .RL = 3, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 20, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_min_tck min_tck_elpida = { + .tRL = 3, + .tRP_AB = 3, + .tRCD = 3, + .tWR = 3, + .tRAS_MIN = 3, + .tRRD = 2, + .tWTR = 2, + .tXP = 2, + .tRTP = 2, + .tCKE = 3, + .tCKESR = 3, + .tFAW = 8 +}; + +static const struct lpddr2_ac_timings *elpida_ac_timings[MAX_NUM_SPEEDBINS] = { + &timings_elpida_200_mhz, + &timings_elpida_333_mhz, + &timings_elpida_400_mhz, +}; + +static const struct lpddr2_device_details elpida_2G_S4_details = { + .type = LPDDR2_TYPE_S4, + .density = LPDDR2_DENSITY_2Gb, + .io_width = LPDDR2_IO_WIDTH_32, + .manufacturer = LPDDR2_MANUFACTURER_ELPIDA +}; + +static const struct lpddr2_device_timings elpida_2G_S4_timings = { + .ac_timings = elpida_ac_timings, + .min_tck = &min_tck_elpida, +}; + +static const struct emif_device_details elpida_2G_S4_x_2 = { + .cs0_device_details = &elpida_2G_S4_details, + .cs1_device_details = &elpida_2G_S4_details, + .cs0_device_timings = &elpida_2G_S4_timings, + .cs1_device_timings = &elpida_2G_S4_timings +}; + +static const struct emif_device_details elpida_2G_S4_x_1 = { + .cs0_device_details = &elpida_2G_S4_details, + .cs1_device_details = NULL, + .cs0_device_timings = &elpida_2G_S4_timings, + .cs1_device_timings = NULL +}; + +#endif /* ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */ + +#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS + +static void emif_get_reg_dump_sdp(const struct emif_regs **emif1_regs, + const struct emif_regs **emif2_regs) { u32 omap4_rev = omap4_revision();
@@ -104,7 +231,8 @@ void emif_get_reg_dump(const struct emif_regs **emif1_regs, const struct emif_regs **emif2_regs) __attribute__((weak, alias("emif_get_reg_dump_sdp")));
-void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs **dmm_lisa_regs) +static void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs + **dmm_lisa_regs) { u32 omap_rev = omap4_revision();
@@ -116,3 +244,25 @@ void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs **dmm_lisa_regs)
void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) __attribute__((weak, alias("emif_get_dmm_regs_sdp"))); + +#else + +static void emif_get_device_details_sdp( + const struct emif_device_details **emif1_details, + const struct emif_device_details **emif2_details) +{ + u32 omap_rev = omap4_revision(); + + if (omap_rev == OMAP4430_ES1_0) { + *emif1_details = &elpida_2G_S4_x_1; + *emif2_details = &elpida_2G_S4_x_1; + } else { + *emif1_details = &elpida_2G_S4_x_2; + *emif2_details = &elpida_2G_S4_x_2; + } +} + +void emif_get_device_details(const struct emif_device_details **emif1_details, + const struct emif_device_details **emif2_details) + __attribute__((weak, alias("emif_get_device_details_sdp"))); +#endif diff --git a/arch/arm/include/asm/arch-omap4/emif.h b/arch/arm/include/asm/arch-omap4/emif.h index f2d54cb..8cc3230 100644 --- a/arch/arm/include/asm/arch-omap4/emif.h +++ b/arch/arm/include/asm/arch-omap4/emif.h @@ -591,10 +591,142 @@ struct __attribute__ ((__packed__)) dmm_lisa_map_regs {
#define CS0 0 #define CS1 1 +/* The maximum frequency at which the LPDDR2 interface can operate in Hz*/ +#define MAX_LPDDR2_FREQ 400000000 /* 400 MHz */ + +/* + * The period of DDR clk is represented as numerator and denominator for + * better accuracy in integer based calculations. However, if the numerator + * and denominator are very huge there may be chances of overflow in + * calculations. So, as a trade-off keep denominator(and consequently + * numerator) within a limit sacrificing some accuracy - but not much + * If denominator and numerator are already small (such as at 400 MHz) + * no adjustment is needed + */ +#define EMIF_PERIOD_DEN_LIMIT 1000 +/* + * Maximum number of different frequencies supported by EMIF driver + * Determines the number of entries in the pointer array for register + * cache + */ +#define EMIF_MAX_NUM_FREQUENCIES 6 +/* + * Indices into the Addressing Table array. + * One entry each for all the different types of devices with different + * addressing schemes + */ +#define ADDR_TABLE_INDEX64M 0 +#define ADDR_TABLE_INDEX128M 1 +#define ADDR_TABLE_INDEX256M 2 +#define ADDR_TABLE_INDEX512M 3 +#define ADDR_TABLE_INDEX1GS4 4 +#define ADDR_TABLE_INDEX2GS4 5 +#define ADDR_TABLE_INDEX4G 6 +#define ADDR_TABLE_INDEX8G 7 +#define ADDR_TABLE_INDEX1GS2 8 +#define ADDR_TABLE_INDEX2GS2 9 +#define ADDR_TABLE_INDEXMAX 10 + +/* Number of Row bits */ +#define ROW_9 0 +#define ROW_10 1 +#define ROW_11 2 +#define ROW_12 3 +#define ROW_13 4 +#define ROW_14 5 +#define ROW_15 6 +#define ROW_16 7 + +/* Number of Column bits */ +#define COL_8 0 +#define COL_9 1 +#define COL_10 2 +#define COL_11 3 +#define COL_7 4 /*Not supported by OMAP included for completeness */ + +/* Number of Banks*/ +#define BANKS1 0 +#define BANKS2 1 +#define BANKS4 2 +#define BANKS8 3 + +/* Refresh rate in micro seconds x 10 */ +#define T_REFI_15_6 156 +#define T_REFI_7_8 78 +#define T_REFI_3_9 39 + +#define EBANK_CS1_DIS 0 +#define EBANK_CS1_EN 1 + /* Read Latency used by the device at reset */ #define RL_BOOT 3 /* Read Latency for the highest frequency you want to use */ #define RL_FINAL 6 + +/* Interleaving policies at EMIF level- between banks and Chip Selects */ +#define EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING 0 +#define EMIF_INTERLEAVING_POLICY_NO_BANK_INTERLEAVING 3 + +/* + * Interleaving policy to be used + * Currently set to MAX interleaving for better performance + */ +#define EMIF_INTERLEAVING_POLICY EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING + +/* State of the core voltage: + * This is important for some parameters such as read idle control and + * ZQ calibration timings. Timings are much stricter when voltage ramp + * is happening compared to when the voltage is stable. + * We need to calculate two sets of values for these parameters and use + * them accordingly + */ +#define LPDDR2_VOLTAGE_STABLE 0 +#define LPDDR2_VOLTAGE_RAMPING 1 + +/* Length of the forced read idle period in terms of cycles */ +#define EMIF_REG_READ_IDLE_LEN_VAL 5 + +/* Interval between forced 'read idles' */ +/* To be used when voltage is changed for DPS/DVFS - 1us */ +#define READ_IDLE_INTERVAL_DVFS (1*1000) +/* + * To be used when voltage is not scaled except by Smart Reflex + * 50us - or maximum value will do + */ +#define READ_IDLE_INTERVAL_NORMAL (50*1000) + + +/* + * Unless voltage is changing due to DVFS one ZQCS command every 50ms should + * be enough. This shoule be enough also in the case when voltage is changing + * due to smart-reflex. + */ +#define EMIF_ZQCS_INTERVAL_NORMAL_IN_US (50*1000) +/* + * If voltage is changing due to DVFS ZQCS should be performed more + * often(every 50us) + */ +#define EMIF_ZQCS_INTERVAL_DVFS_IN_US 50 + +/* The interval between ZQCL commands as a multiple of ZQCS interval */ +#define REG_ZQ_ZQCL_MULT 4 +/* The interval between ZQINIT commands as a multiple of ZQCL interval */ +#define REG_ZQ_ZQINIT_MULT 3 +/* Enable ZQ Calibration on exiting Self-refresh */ +#define REG_ZQ_SFEXITEN_ENABLE 1 +/* + * ZQ Calibration simultaneously on both chip-selects: + * Needs one calibration resistor per CS + * None of the boards that we know of have this capability + * So disabled by default + */ +#define REG_ZQ_DUALCALEN_DISABLE 0 +/* + * Enable ZQ Calibration by default on CS0. If we are asked to program + * the EMIF there will be something connected to CS0 for sure + */ +#define REG_ZQ_CS0EN_ENABLE 1 + /* EMIF_PWR_MGMT_CTRL register */ /* Low power modes */ #define LP_MODE_DISABLE 0 @@ -634,6 +766,16 @@ struct __attribute__ ((__packed__)) dmm_lisa_map_regs {
/* EMIF_L3_CONFIG register value for ES1*/ #define EMIF_L3_CONFIG_VAL_SYS_THRESH_0A_LL_THRESH_00 0x0A0000FF +/* + * Value of bits 12:31 of DDR_PHY_CTRL_1 register: + * All these fields have magic values dependent on frequency and + * determined by PHY and DLL integration with EMIF. Setting the magic + * values suggested by hw team. + */ +#define EMIF_DDR_PHY_CTRL_1_BASE_VAL 0x049FF +#define EMIF_DLL_SLAVE_DLY_CTRL_400_MHZ 0x41 +#define EMIF_DLL_SLAVE_DLY_CTRL_200_MHZ 0x80 +#define EMIF_DLL_SLAVE_DLY_CTRL_100_MHZ_AND_LESS 0xFF
/* * MR1 value: @@ -657,16 +799,51 @@ struct __attribute__ ((__packed__)) dmm_lisa_map_regs { #define MR10_ZQ_ZQINIT 0xFF #define MR10_ZQ_ZQRESET 0xC3
+/* TEMP_ALERT_CONFIG */ +#define TEMP_ALERT_POLL_INTERVAL_MS 360 /* for temp gradient - 5 C/s */ +#define TEMP_ALERT_CONFIG_DEVCT_1 0 +#define TEMP_ALERT_CONFIG_DEVWDT_32 2 + /* MR16 value: refresh full array(no partial array self refresh) */ #define MR16_REF_FULL_ARRAY 0
-/* LPDDR2 IO reg values */ +/* LPDDR2 IO regs */ #define CONTROL_LPDDR2IO_SLEW_125PS_DRV8_PULL_DOWN 0x1C1C1C1C #define CONTROL_LPDDR2IO_SLEW_325PS_DRV8_GATE_KEEPER 0x9E9E9E9E
/* CONTROL_EFUSE_2 */ #define CONTROL_EFUSE_2_NMOS_PMOS_PTV_CODE_1 0x00ffc000
+/* + * Maximum number of entries we keep in our array of timing tables + * We need not keep all the speed bins supported by the device + * We need to keep timing tables for only the speed bins that we + * are interested in + */ +#define MAX_NUM_SPEEDBINS 4 + +/* LPDDR2 Densities */ +#define LPDDR2_DENSITY_64Mb 0 +#define LPDDR2_DENSITY_128Mb 1 +#define LPDDR2_DENSITY_256Mb 2 +#define LPDDR2_DENSITY_512Mb 3 +#define LPDDR2_DENSITY_1Gb 4 +#define LPDDR2_DENSITY_2Gb 5 +#define LPDDR2_DENSITY_4Gb 6 +#define LPDDR2_DENSITY_8Gb 7 +#define LPDDR2_DENSITY_16Gb 8 +#define LPDDR2_DENSITY_32Gb 9 + +/* LPDDR2 type */ +#define LPDDR2_TYPE_S4 0 +#define LPDDR2_TYPE_S2 1 +#define LPDDR2_TYPE_NVM 2 + +/* LPDDR2 IO width */ +#define LPDDR2_IO_WIDTH_32 0 +#define LPDDR2_IO_WIDTH_16 1 +#define LPDDR2_IO_WIDTH_8 2 + /* Mode register numbers */ #define LPDDR2_MR0 0 #define LPDDR2_MR1 1 @@ -692,6 +869,119 @@ struct __attribute__ ((__packed__)) dmm_lisa_map_regs { #define LPDDR2_MR0_DNVI_SHIFT 2 #define LPDDR2_MR0_DNVI_MASK (1 << 2)
+/* MR4 */ +#define MR4_SDRAM_REF_RATE_SHIFT 0 +#define MR4_SDRAM_REF_RATE_MASK 7 +#define MR4_TUF_SHIFT 7 +#define MR4_TUF_MASK (1 << 7) + +/* MR4 SDRAM Refresh Rate field values */ +#define SDRAM_TEMP_LESS_LOW_SHUTDOWN 0x0 +#define SDRAM_TEMP_LESS_4X_REFRESH_AND_TIMINGS 0x1 +#define SDRAM_TEMP_LESS_2X_REFRESH_AND_TIMINGS 0x2 +#define SDRAM_TEMP_NOMINAL 0x3 +#define SDRAM_TEMP_RESERVED_4 0x4 +#define SDRAM_TEMP_HIGH_DERATE_REFRESH 0x5 +#define SDRAM_TEMP_HIGH_DERATE_REFRESH_AND_TIMINGS 0x6 +#define SDRAM_TEMP_VERY_HIGH_SHUTDOWN 0x7 + +#define LPDDR2_MANUFACTURER_SAMSUNG 1 +#define LPDDR2_MANUFACTURER_QIMONDA 2 +#define LPDDR2_MANUFACTURER_ELPIDA 3 +#define LPDDR2_MANUFACTURER_ETRON 4 +#define LPDDR2_MANUFACTURER_NANYA 5 +#define LPDDR2_MANUFACTURER_HYNIX 6 +#define LPDDR2_MANUFACTURER_MOSEL 7 +#define LPDDR2_MANUFACTURER_WINBOND 8 +#define LPDDR2_MANUFACTURER_ESMT 9 +#define LPDDR2_MANUFACTURER_SPANSION 11 +#define LPDDR2_MANUFACTURER_SST 12 +#define LPDDR2_MANUFACTURER_ZMOS 13 +#define LPDDR2_MANUFACTURER_INTEL 14 +#define LPDDR2_MANUFACTURER_NUMONYX 254 +#define LPDDR2_MANUFACTURER_MICRON 255 + +/* MR8 register fields */ +#define MR8_TYPE_SHIFT 0x0 +#define MR8_TYPE_MASK 0x3 +#define MR8_DENSITY_SHIFT 0x2 +#define MR8_DENSITY_MASK (0xF << 0x2) +#define MR8_IO_WIDTH_SHIFT 0x6 +#define MR8_IO_WIDTH_MASK (0x3 << 0x6) + +struct lpddr2_addressing { + u8 num_banks; + u8 t_REFI_us_x10; + u8 row_sz[2]; /* One entry each for x32 and x16 */ + u8 col_sz[2]; /* One entry each for x32 and x16 */ +}; + +/* Structure for timings from the DDR datasheet */ +struct lpddr2_ac_timings { + u32 max_freq; + u8 RL; + u8 tRPab; + u8 tRCD; + u8 tWR; + u8 tRASmin; + u8 tRRD; + u8 tWTRx2; + u8 tXSR; + u8 tXPx2; + u8 tRFCab; + u8 tRTPx2; + u8 tCKE; + u8 tCKESR; + u8 tZQCS; + u32 tZQCL; + u32 tZQINIT; + u8 tDQSCKMAXx2; + u8 tRASmax; + u8 tFAW; + +}; + +/* + * Min tCK values for some of the parameters: + * If the calculated clock cycles for the respective parameter is + * less than the corresponding min tCK value, we need to set the min + * tCK value. This may happen at lower frequencies. + */ +struct lpddr2_min_tck { + u32 tRL; + u32 tRP_AB; + u32 tRCD; + u32 tWR; + u32 tRAS_MIN; + u32 tRRD; + u32 tWTR; + u32 tXP; + u32 tRTP; + u8 tCKE; + u32 tCKESR; + u32 tFAW; +}; + +struct lpddr2_device_details { + u8 type; + u8 density; + u8 io_width; + u8 manufacturer; +}; + +struct lpddr2_device_timings { + const struct lpddr2_ac_timings **ac_timings; + const struct lpddr2_min_tck *min_tck; +}; + +/* Details of the devices connected to each chip-select of an EMIF instance */ +struct emif_device_details { + const struct lpddr2_device_details *cs0_device_details; + const struct lpddr2_device_details *cs1_device_details; + const struct lpddr2_device_timings *cs0_device_timings; + const struct lpddr2_device_timings *cs1_device_timings; +}; + /* * Structure containing shadow of important registers in EMIF * The calculation function fills in this structure to be later used for @@ -712,8 +1002,20 @@ struct emif_regs { u32 emif_ddr_phy_ctlr_1; };
+/* assert macros */ +#if defined(DEBUG) +#define emif_assert(c) ({ if (!(c)) for (;;); }) +#else +#define emif_assert(c) ({ if (0) hang(); }) +#endif + +#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS void emif_get_reg_dump(const struct emif_regs **emif1_regs, const struct emif_regs **emif2_regs); void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs); +#else +void emif_get_device_details(const struct emif_device_details **emif1_details, + const struct emif_device_details **emif2_details); +#endif
#endif diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index a1c4883..fd8fb10 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -86,12 +86,7 @@ /* GPMC */ #define OMAP44XX_GPMC_BASE 0x50000000
-/* DMM */ -#define OMAP44XX_DMM_BASE 0x4E000000 -#define DMM_LISA_MAP_BASE (OMAP44XX_DMM_BASE + 0x40) -#define DMM_LISA_MAP_SYS_SIZE_MASK (7 << 20) -#define DMM_LISA_MAP_SYS_SIZE_SHIFT 20 -#define DMM_LISA_MAP_SYS_ADDR_MASK (0xFF << 24) + /* * Hardware Register Details */ @@ -137,6 +132,17 @@ struct s32ktimer { /* Temporary SRAM stack used while low level init is done */ #define LOW_LEVEL_SRAM_STACK NON_SECURE_SRAM_END
+#define SRAM_SCRATCH_SPACE_ADDR NON_SECURE_SRAM_START + +/* + * SRAM scratch space entries + */ + +/* Boot parameter passed from SPL to U-Boot */ +#define OMAP4_SRAM_SCRATCH_EMIF_SIZE SRAM_SCRATCH_SPACE_ADDR +#define OMAP4_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0x8) +#define OMAP4_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0xC) + /* Silicon revisions */ #define OMAP4430_SILICON_ID_INVALID 0 #define OMAP4430_ES1_0 1 diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 4beff42..211d3b8 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -44,6 +44,7 @@ void bypass_dpll(u32 base); void freq_update_core(void); u32 get_syc_clk_freq(void); u32 omap4_ddr_clk(void); +void cancel_out(u32 *num, u32 *den, u32 den_limit); void sdram_init(void); u32 omap4_revision(void);
diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 49daa85..9f2616c 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -51,6 +51,27 @@ (addr));\ } while (0);
+/* find log2 of number n - rounded up */ +static inline u32 log_2_n_round_up(u32 n) +{ + u32 clz; + /* count leading zeros */ + asm volatile ("CLZ %0, %1" : "=r" (clz) : "r" (n)); + if (n & (n - 1)) + return 31 - clz; /* power of 2 */ + else + return 32 - clz; /* not power of 2 - round up */ +} + +/* find log2 of number n - rounded down */ +static inline u32 log_2_n_round_down(u32 n) +{ + u32 clz; + /* count leading zeros */ + asm volatile ("CLZ %0, %1" : "=r" (clz) : "r" (n)); + return 31 - clz; +} + /* Boot device */ #define BOOT_DEVICE_NONE 0 #define BOOT_DEVICE_XIP 1 diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 07d45a0..c29b184 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -245,6 +245,11 @@ /* Defines for Clock init */ #define CONFIG_SYS_OMAP4_ABE_SYSCK
+/* Defines for SDRAM init */ +#ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS 1 +#endif + /* Defines for SPL */ #define CONFIG_SPL #define CONFIG_SYS_SPL_TEXT_BASE 0x40304360 diff --git a/spl/board/ti/sdp4430/Makefile b/spl/board/ti/sdp4430/Makefile index 1f25f77..d89dea0 100644 --- a/spl/board/ti/sdp4430/Makefile +++ b/spl/board/ti/sdp4430/Makefile @@ -81,6 +81,10 @@ SOBJS += start.o COBJS += syslib.o
# omap-common +$(obj)utils.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap-common/utils.c $@ + $(obj)timer.c: @rm -f $@ @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap-common/timer.c $@ @@ -94,7 +98,7 @@ $(obj)spl-omap.c: @ln -s $(TOPDIR)/spl/board/ti/spl-omap.c $@
SOBJS += reset.o -COBJS += timer.o spl-omap.o +COBJS += utils.o timer.o spl-omap.o
$(OBJTREE)/MLO: $(splobj)u-boot-spl.bin $(OBJTREE)/tools/mkimage -T omapimage \
I get some warnings from arch/arm/cpu/armv7/omap4/emif.c: emif.c: In function ‘sdram_init’: emif.c:1164:43: warning: ‘section_map’ may be used uninitialized in this function emif.c:1166:27: warning: ‘lis_map_regs_calculated$dmm_lisa_map_3’ may be used uninitialized in this function emif.c: In function ‘sdram_init’: emif.c:1166:27: warning: ‘lis_map_regs_calculated$dmm_lisa_map_3’ may be used uninitialized in this function
Looking at the code I see that these are initialized but the compiler can't firgure that out.
John
Signed-off-by: Aneesh Vaneesh@ti.com
I don't see the warnings with my tool-chain ((Sourcery G++ Lite 2010q1-202) GCC 4.4.1)
I tried immediately after this patch and also after applying all the patches. Which compiler are you using?
best regards, Aneesh
The latest Linaro cross toolchain:
$ arm-linux-gnueabi-gcc --version arm-linux-gnueabi-gcc (Ubuntu/Linaro 4.5.2-1ubuntu3ppa1) 4.5.2
I installed Linaro GCC 4.5.2 and I see these warnings now.
Technically, I think this is a false alarm. Although section_map is initialized conditionally the use is also conditional. So, if the compiler had done proper data flow analysis it could see that this won't happen (I don't know if compilers do that kind of analysis) Nevertheless, we could avoid it. I will fix it in v2.
This is genuine. In one path it may be used uninitialized(this path is not expected in real scenarios). I will fix this.
Thanks, Aneesh
Identify SDRAM devices connected to EMIF automatically: LPDDR2 devices have some Mode Registers that provide details about the device such as the type, density, bus width etc. EMIF has the capability to read these registers. If there are not devices connected to a given chip-select reading mode registers will return junk values. After reading as many such registers as possible and matching with expected ranges of values the driver can identify if there is a device connected to the respective CS. If we identify that a device is connected the values read give us complete details about the device.
This along with the base AC timings specified by JESD209-2 allows us to do a complete automatic initialization of SDRAM that works on all boards.
Please note that the default AC timings specified by JESD209-2 will be safe for all devices but not necessarily optimal. However, for the Elpida devices used on Panda and SDP the default timings are both safe and optimal.
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap4/emif.c | 177 +++++++++++++++++++++++++++++- arch/arm/cpu/armv7/omap4/sdram_elpida.c | 9 +- include/configs/omap4_sdp4430.h | 1 + 3 files changed, 176 insertions(+), 11 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index 1bdb1d2..006d065 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -165,7 +165,8 @@ static const struct lpddr2_min_tck min_tck_jedec = { .tFAW = 8 };
-static const struct lpddr2_ac_timings *jedec_ac_timings[MAX_NUM_SPEEDBINS] = { +static const struct lpddr2_ac_timings const* + jedec_ac_timings[MAX_NUM_SPEEDBINS] = { &timings_jedec_200_mhz, &timings_jedec_333_mhz, &timings_jedec_400_mhz @@ -779,6 +780,146 @@ void emif_reset_phy(u32 base) writel(iodft, &emif->emif_iodft_tlgc); }
+#ifdef CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION +static void display_sdram_details(u32 emif_nr, u32 cs, + struct lpddr2_device_details *device) +{ + const char *mfg_str; + const char *type_str; + char density_str[10]; + u32 density; + + debug("EMIF%d CS%d\t", emif_nr, cs); + + if (!device) { + debug("None\n"); + return; + } + + mfg_str = get_lpddr2_manufacturer(device->manufacturer); + type_str = get_lpddr2_type(device->type); + + density = lpddr2_density_2_size_in_mbytes[device->density]; + if ((density / 1024 * 1024) == density) { + density /= 1024; + sprintf(density_str, "%d GB", density); + } else + sprintf(density_str, "%d MB", density); + if (mfg_str && type_str) + debug("%s\t\t%s\t%s\n", mfg_str, type_str, density_str); +} + +static u8 is_lpddr2_sdram_present(u32 base, u32 cs, + struct lpddr2_device_details *lpddr2_device) +{ + u32 mr = 0, temp; + + mr = get_mr(base, cs, LPDDR2_MR0); + if (mr > 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + temp = get_bit_field(mr, LPDDR2_MR0_DI_SHIFT, LPDDR2_MR0_DI_MASK); + if (temp) { + /* Not SDRAM */ + return 0; + } + temp = get_bit_field(mr, LPDDR2_MR0_DNVI_SHIFT, LPDDR2_MR0_DNVI_MASK); + + if (temp) { + /* DNV supported - But DNV is only supported for NVM */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR4); + if (mr > 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR5); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + if (!get_lpddr2_manufacturer(mr)) { + /* Manufacturer not identified */ + return 0; + } + lpddr2_device->manufacturer = mr; + + mr = get_mr(base, cs, LPDDR2_MR6); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR7); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR8); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + temp = get_bit_field(mr, MR8_TYPE_SHIFT, MR8_TYPE_MASK); + if (!get_lpddr2_type(temp)) { + /* Not SDRAM */ + return 0; + } + lpddr2_device->type = temp; + + temp = get_bit_field(mr, MR8_DENSITY_SHIFT, MR8_DENSITY_MASK); + if (temp > LPDDR2_DENSITY_32Gb) { + /* Density not supported */ + return 0; + } + lpddr2_device->density = temp; + + temp = get_bit_field(mr, MR8_IO_WIDTH_SHIFT, MR8_IO_WIDTH_MASK); + if (!get_lpddr2_io_width(temp)) { + /* IO width unsupported value */ + return 0; + } + lpddr2_device->io_width = temp; + + /* + * If all the above tests pass we should + * have a device on this chip-select + */ + return 1; +} + +static struct lpddr2_device_details *get_lpddr2_details(u32 base, u8 cs, + struct lpddr2_device_details *lpddr2_dev_details) +{ + u32 phy; + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + if (!lpddr2_dev_details) + return NULL; + + /* Do the minimum init for mode register accesses */ + if (!running_from_sdram()) { + phy = get_ddr_phy_ctrl_1(get_syc_clk_freq() / 2, RL_BOOT); + writel(phy, &emif->emif_ddr_phy_ctrl_1); + } + + if (!(is_lpddr2_sdram_present(base, cs, lpddr2_dev_details))) + return NULL; + + display_sdram_details(emif_num(base), cs, lpddr2_dev_details); + + return lpddr2_dev_details; +} +#endif /* CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION */ + static void do_lpddr2_init(u32 base, u32 cs) { u32 mr_addr; @@ -862,9 +1003,7 @@ static void emif_update_timings(u32 base, const struct emif_regs *regs)
static void do_sdram_init(u32 base) { - struct emif_device_details dev_details; const struct emif_regs *regs; - u32 in_sdram, emif_nr;
in_sdram = running_from_sdram(); @@ -872,6 +1011,7 @@ static void do_sdram_init(u32 base)
#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS const struct emif_regs *tmp_regs; + emif_get_reg_dump(®s, &tmp_regs); regs = (emif_nr == 1) ? regs : tmp_regs; #else @@ -879,23 +1019,48 @@ static void do_sdram_init(u32 base) * The user has not provided the register values. We need to * calculate it based on the timings and the DDR frequency */ + struct emif_device_details dev_details = { NULL, NULL }; + struct emif_regs calculated_regs;
+#if !defined(CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION) || \ + !defined(CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS) + + /* We need some input about the devices from the user */ const struct emif_device_details *dev_details_user_provided; const struct emif_device_details *tmp_details; - struct emif_regs calculated_regs;
- /* We need some input about the devices from the user */ emif_get_device_details(&dev_details_user_provided, &tmp_details); dev_details_user_provided = (emif_nr == 1) ? dev_details_user_provided : tmp_details; if (!dev_details_user_provided) return; +#endif
+#ifdef CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION + struct lpddr2_device_details cs0_dev_details, cs1_dev_details; + + /* Automatically find the device details */ + if (!in_sdram) { + dev_details.cs0_device_details = + get_lpddr2_details(base, CS0, &cs0_dev_details); + dev_details.cs1_device_details = + get_lpddr2_details(base, CS1, &cs1_dev_details); + /* + * Reset the PHY - if there is nothing connected on any + * of the chip selects(typically CS1) mode register reads + * will mess up with the PHY state and subsequent + * initialization won't work. PHY reset brings back PHY to + * a good state. + */ + emif_reset_phy(base); + } +#else dev_details.cs0_device_details = dev_details_user_provided->cs0_device_details; dev_details.cs1_device_details = dev_details_user_provided->cs1_device_details;
+#endif /* Return if no devices on this EMIF */ if (!dev_details.cs0_device_details && !dev_details.cs1_device_details) { diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c index e7d2bd5..8dfe6f9 100644 --- a/arch/arm/cpu/armv7/omap4/sdram_elpida.c +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -86,10 +86,8 @@ const struct dmm_lisa_map_regs lisa_map_2G_x_2_x_2 = { .dmm_lisa_map_3 = 0x80640300 };
-void emif_get_reg_dump_sdp(const struct emif_regs **emif1_regs, - const struct emif_regs **emif2_regs) - -#else +#elif !defined(CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION) || \ + !defined(CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS)
static const struct lpddr2_ac_timings timings_elpida_400_mhz = { .max_freq = 400000000, @@ -245,7 +243,8 @@ static void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) __attribute__((weak, alias("emif_get_dmm_regs_sdp")));
static void emif_get_device_details_sdp( const struct emif_device_details **emif1_details, diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index c29b184..a4332b7 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -247,6 +247,7 @@
/* Defines for SDRAM init */ #ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION 1 #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS 1 #endif
Embed the u-boot flash image size at a known offset from the start of u-boot so that SPL can use it while loading u-boot from a non-XIP media.
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/start.S | 6 +++++- spl/board/ti/spl-omap.lds | 1 + 2 files changed, 6 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index f5f08d9..1cbd128 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -64,8 +64,12 @@ _pad: .word 0x12345678 /* now 16*4=64 */
.global _end_vect _end_vect: +.global _u_boot_size +_u_boot_size: + .word 0xDEADBEEF + .word __flash_image_end - _start
- .balignl 16,0xdeadbeef +.balignl 16,0xdeadbeef /************************************************************************* * * Startup Code (reset vector) diff --git a/spl/board/ti/spl-omap.lds b/spl/board/ti/spl-omap.lds index 27b5295..64eb4c9 100644 --- a/spl/board/ti/spl-omap.lds +++ b/spl/board/ti/spl-omap.lds @@ -50,6 +50,7 @@ SECTIONS .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram . = ALIGN(4); __image_copy_end = .; + __flash_image_end = .;
.bss : {
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/start.S | 1 + arch/arm/include/asm/omap_common.h | 4 + include/configs/omap4_sdp4430.h | 7 ++- spl/board/ti/sdp4430/Makefile | 35 +++++++++++ spl/board/ti/spl-omap.c | 112 +++++++++++++++++++++++++++++++++++- 5 files changed, 156 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 1cbd128..927476c 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -64,6 +64,7 @@ _pad: .word 0x12345678 /* now 16*4=64 */
.global _end_vect _end_vect: +/* This label should be at the same location for SPL and U-Boot */ .global _u_boot_size _u_boot_size: .word 0xDEADBEEF diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 9f2616c..c2efa7c 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -99,4 +99,8 @@ u32 omap_boot_device(void); u32 omap_boot_mode(void); void preloader_console_init(void);
+/* symbols from start.S */ +extern u32 _u_boot_size; +extern u32 _start; + #endif /* _OMAP_COMMON_H_ */ diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index a4332b7..0ed474d 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -257,7 +257,10 @@ #define CONFIG_SYS_SPL_MAX_SIZE 0x7800 /* 30 K */ #define CONFIG_SYS_SPL_STACK LOW_LEVEL_SRAM_STACK
-#define CONFIG_SYS_SPL_BSS_START_ADDR 0x80000000 -#define CONFIG_SYS_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ + +#define CONFIG_SYS_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SYS_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */
#endif /* __CONFIG_H */ diff --git a/spl/board/ti/sdp4430/Makefile b/spl/board/ti/sdp4430/Makefile index d89dea0..18c5b8e 100644 --- a/spl/board/ti/sdp4430/Makefile +++ b/spl/board/ti/sdp4430/Makefile @@ -68,6 +68,41 @@ $(obj)ctype.c: COBJS += serial.o ns16550.o string.o vsprintf.o console.o stdio.o COBJS += ctype.o eabi_compat.o div64.o
+ +# mmc +$(obj)mmc.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/mmc/mmc.c $@ + +$(obj)omap_hsmmc.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/mmc/omap_hsmmc.c $@ + +$(obj)omap24xx_i2c.c: $(obj)omap24xx_i2c.h + @rm -f $@ + @ln -s $(TOPDIR)/drivers/i2c/omap24xx_i2c.c $@ + +$(obj)omap24xx_i2c.h: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/i2c/omap24xx_i2c.h $@ + +$(obj)time.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/time.c $@ + +$(obj)part.c: + @rm -f $@ + @ln -s $(TOPDIR)/disk/part.c $@ + +$(obj)part_dos.c: $(obj)part_dos.h + @rm -f $@ + @ln -s $(TOPDIR)/disk/part_dos.c $@ + +$(obj)part_dos.h: + @rm -f $@ + @ln -s $(TOPDIR)/disk/part_dos.h $@ + +COBJS += omap_hsmmc.o omap24xx_i2c.o mmc.o time.o part.o part_dos.o # armv7 $(obj)start.S: @rm -f $@ diff --git a/spl/board/ti/spl-omap.c b/spl/board/ti/spl-omap.c index 57ddb7d..b64eac9 100644 --- a/spl/board/ti/spl-omap.c +++ b/spl/board/ti/spl-omap.c @@ -28,24 +28,134 @@ #include <common.h> #include <asm/u-boot.h> #include <asm/arch/sys_proto.h> +#include <mmc.h> #include <timestamp_autogenerated.h> +#include <asm/omap_common.h> +#include <asm/arch/mmc_host_def.h> +#include <i2c.h>
/* Define global data structure pointer to it*/ gd_t gdata __attribute__ ((section(".data"))); bd_t bdata __attribute__ ((section(".data"))); gd_t *gd = &gdata;
+typedef void (*u_boot_entry_t)(void)__attribute__ ((noreturn)); + void board_init_f(ulong dummy) { relocate_code(CONFIG_SYS_SPL_STACK, &gdata, CONFIG_SYS_SPL_TEXT_BASE); }
-void board_init_r(gd_t *id, ulong dummy) +inline void hang(void) { + puts("### ERROR ### Please RESET the board ###\n"); for (;;) ; }
+#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + omap_mmc_init(0); + omap_mmc_init(1); + return 0; +} +#endif + +static void mmc_load_uboot_raw(struct mmc *mmc, u32 mmc_dev) +{ + u32 u_boot_size_sectors, err; + u32 *u_boot_size = (u32 *)(CONFIG_SYS_TEXT_BASE + + (u32) &_u_boot_size - (u32) &_start); + + /* read one sector first to find u-boot size */ + err = mmc->block_dev.block_read(mmc_dev, + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR, 1, + (void *)CONFIG_SYS_TEXT_BASE); + if (err <= 0) + goto end; + + if (*u_boot_size != 0xDEADBEEF) { + err = 0xDEADBEEF; + goto end; + } + + /* move to the next word that has size */ + u_boot_size++; + + /* + * convert size to sectors - round down is fine because we have + * already read 1 sector + */ + u_boot_size_sectors = *u_boot_size/MMCSD_SECTOR_SIZE; + debug("spl: u-boot raw sectors - %d\n", u_boot_size_sectors + 1); + /* read one sector first to find u-boot size */ + err = mmc->block_dev.block_read(mmc_dev, + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR + 1, + u_boot_size_sectors, + (void *)(CONFIG_SYS_TEXT_BASE + MMCSD_SECTOR_SIZE)); +end: + if (err <= 0) { + printf("spl: mmc blk read err - %d\n", err); + hang(); + } +} + +static void mmc_load_uboot(u32 mmc_dev) +{ + struct mmc *mmc; + int err; + u32 boot_mode; + + mmc_initialize(gd->bd); + mmc = find_mmc_device(mmc_dev); + if (!mmc) { + puts("spl: mmc device not found!!\n"); + hang(); + } + + err = mmc_init(mmc); + if (err) { + printf("spl: mmc init failed: mmc_dev - %d err - %d\n", + mmc_dev, err); + hang(); + } + + boot_mode = omap_boot_mode(); + if (boot_mode == MMCSD_MODE_RAW) + mmc_load_uboot_raw(mmc, mmc_dev); + else { + puts("spl: wrong MMC boot mode\n"); + hang(); + } +} + +void board_init_r(gd_t *id, ulong dummy) +{ + u32 boot_device; + u_boot_entry_t u_boot_entry = (u_boot_entry_t) CONFIG_SYS_TEXT_BASE; + + timer_init(); + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + boot_device = omap_boot_device(); + switch (boot_device) { + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: + mmc_load_uboot(boot_device - BOOT_DEVICE_MMC1); + break; + default: + printf("SPL: Un-supported Boot Device - %d!!!\n", boot_device); + hang(); + break; + } + + /* + * Jump to u-boot with magic number as input to indicate that it + * was loaded by SPL + */ + u_boot_entry(); +} + void preloader_console_init(void) { gd->bd = &bdata;
Signed-off-by: Aneesh V aneesh@ti.com --- include/configs/omap4_sdp4430.h | 1 + spl/board/ti/sdp4430/Makefile | 8 ++++++++ spl/board/ti/spl-omap.c | 22 ++++++++++++++++++++++ 3 files changed, 31 insertions(+), 0 deletions(-)
diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 0ed474d..dcc9e39 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -259,6 +259,7 @@
#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ #define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1
#define CONFIG_SYS_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SYS_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ diff --git a/spl/board/ti/sdp4430/Makefile b/spl/board/ti/sdp4430/Makefile index 18c5b8e..8310db9 100644 --- a/spl/board/ti/sdp4430/Makefile +++ b/spl/board/ti/sdp4430/Makefile @@ -103,6 +103,14 @@ $(obj)part_dos.h: @ln -s $(TOPDIR)/disk/part_dos.h $@
COBJS += omap_hsmmc.o omap24xx_i2c.o mmc.o time.o part.o part_dos.o + +# fat +$(obj)fat.c: + @rm -f $@ + @ln -s $(TOPDIR)/fs/fat/fat.c $@ + +COBJS += fat.o + # armv7 $(obj)start.S: @rm -f $@ diff --git a/spl/board/ti/spl-omap.c b/spl/board/ti/spl-omap.c index b64eac9..3612434 100644 --- a/spl/board/ti/spl-omap.c +++ b/spl/board/ti/spl-omap.c @@ -29,6 +29,7 @@ #include <asm/u-boot.h> #include <asm/arch/sys_proto.h> #include <mmc.h> +#include <fat.h> #include <timestamp_autogenerated.h> #include <asm/omap_common.h> #include <asm/arch/mmc_host_def.h> @@ -101,6 +102,25 @@ end: } }
+static void mmc_load_uboot_fat(struct mmc *mmc) +{ + s32 err; + + err = fat_register_device(&mmc->block_dev, + CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION); + if (err) { + printf("spl: fat register err - %d\n", err); + hang(); + } + + err = file_fat_read("u-boot.bin", (u8 *)CONFIG_SYS_TEXT_BASE, 0); + + if (err <= 0) { + printf("spl: error reading u-boot.bin - %d\n", err); + hang(); + } +} + static void mmc_load_uboot(u32 mmc_dev) { struct mmc *mmc; @@ -124,6 +144,8 @@ static void mmc_load_uboot(u32 mmc_dev) boot_mode = omap_boot_mode(); if (boot_mode == MMCSD_MODE_RAW) mmc_load_uboot_raw(mmc, mmc_dev); + else if (boot_mode == MMCSD_MODE_FAT) + mmc_load_uboot_fat(mmc); else { puts("spl: wrong MMC boot mode\n"); hang();
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/include/asm/arch-omap4/emif.h | 10 +- include/configs/omap4_panda.h | 24 ++++ spl/board/ti/panda/Makefile | 219 ++++++++++++++++++++++++++++++++ 3 files changed, 248 insertions(+), 5 deletions(-) create mode 100644 spl/board/ti/panda/Makefile
diff --git a/arch/arm/include/asm/arch-omap4/emif.h b/arch/arm/include/asm/arch-omap4/emif.h index 8cc3230..b95e545 100644 --- a/arch/arm/include/asm/arch-omap4/emif.h +++ b/arch/arm/include/asm/arch-omap4/emif.h @@ -520,11 +520,11 @@
/* Trap for invalid TILER PAT entries */ #define DMM_LISA_MAP_0_INVAL_ADDR_TRAP (\ - (0 << OMAP44XX_SDRC_ADDR_SHIFT) |\ - (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ - (DMM_SDRC_ADDR_SPC_INVALID << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ - (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)|\ - (0xFF << OMAP44XX_SYS_ADDR_SHIFT)) + (0 << OMAP44XX_SDRC_ADDR_SHIFT) |\ + (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_INVALID << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)|\ + (0xFF << OMAP44XX_SYS_ADDR_SHIFT))
/* Reg mapping structure */ diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 2b03b0f..b389035 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -117,7 +117,9 @@
/* USB device configuration */ #define CONFIG_USB_DEVICE 1 +#ifndef CONFIG_PRELOADER #define CONFIG_USB_TTY 1 +#endif #define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* Flash */ @@ -234,4 +236,26 @@ CONFIG_SYS_INIT_RAM_SIZE - \ GENERATED_GBL_DATA_SIZE)
+/* Defines for Clock init */ +#define CONFIG_SYS_OMAP4_ABE_SYSCK + +/* Defines for SDRAM init */ +#ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION 1 +#define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS 1 +#endif + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SYS_SPL_TEXT_BASE 0x40304360 +#define CONFIG_SYS_SPL_MAX_SIZE 0x7800 /* 30 K */ +#define CONFIG_SYS_SPL_STACK LOW_LEVEL_SRAM_STACK + +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 + +#define CONFIG_SYS_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SYS_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + #endif /* __CONFIG_H */ diff --git a/spl/board/ti/panda/Makefile b/spl/board/ti/panda/Makefile new file mode 100644 index 0000000..8310db9 --- /dev/null +++ b/spl/board/ti/panda/Makefile @@ -0,0 +1,219 @@ +# +# (C) Copyright 2006-2007 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +splobj := $(OBJTREE)/spl/ +include $(TOPDIR)/config.mk +SOBJS = +COBJS = + +# serial console +$(obj)eabi_compat.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/lib/eabi_compat.c $@ + +$(obj)string.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/string.c $@ + +$(obj)vsprintf.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/vsprintf.c $@ + +$(obj)console.c: + @rm -f $@ + @ln -s $(TOPDIR)/common/console.c $@ + +$(obj)stdio.c: + @rm -f $@ + @ln -s $(TOPDIR)/common/stdio.c $@ + +$(obj)serial.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/serial/serial.c $@ + +$(obj)ns16550.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/serial/ns16550.c $@ + +$(obj)div64.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/div64.c $@ + +$(obj)ctype.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/ctype.c $@ + +COBJS += serial.o ns16550.o string.o vsprintf.o console.o stdio.o +COBJS += ctype.o eabi_compat.o div64.o + + +# mmc +$(obj)mmc.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/mmc/mmc.c $@ + +$(obj)omap_hsmmc.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/mmc/omap_hsmmc.c $@ + +$(obj)omap24xx_i2c.c: $(obj)omap24xx_i2c.h + @rm -f $@ + @ln -s $(TOPDIR)/drivers/i2c/omap24xx_i2c.c $@ + +$(obj)omap24xx_i2c.h: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/i2c/omap24xx_i2c.h $@ + +$(obj)time.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/time.c $@ + +$(obj)part.c: + @rm -f $@ + @ln -s $(TOPDIR)/disk/part.c $@ + +$(obj)part_dos.c: $(obj)part_dos.h + @rm -f $@ + @ln -s $(TOPDIR)/disk/part_dos.c $@ + +$(obj)part_dos.h: + @rm -f $@ + @ln -s $(TOPDIR)/disk/part_dos.h $@ + +COBJS += omap_hsmmc.o omap24xx_i2c.o mmc.o time.o part.o part_dos.o + +# fat +$(obj)fat.c: + @rm -f $@ + @ln -s $(TOPDIR)/fs/fat/fat.c $@ + +COBJS += fat.o + +# armv7 +$(obj)start.S: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/start.S $@ + +$(obj)syslib.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/syslib.c $@ + +SOBJS += start.o +COBJS += syslib.o + +# omap-common +$(obj)utils.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap-common/utils.c $@ + +$(obj)timer.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap-common/timer.c $@ + +$(obj)reset.S: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap-common/reset.S $@ + +$(obj)spl-omap.c: + @rm -f $@ + @ln -s $(TOPDIR)/spl/board/ti/spl-omap.c $@ + +SOBJS += reset.o +COBJS += utils.o timer.o spl-omap.o + +$(OBJTREE)/MLO: $(splobj)u-boot-spl.bin + $(OBJTREE)/tools/mkimage -T omapimage \ + -a $(CONFIG_SYS_SPL_TEXT_BASE) -d $< $@ + +LDSCRIPT_SOURCE = $(TOPDIR)/spl/board/ti/spl-omap.lds + +# omap4 +$(obj)lowlevel_init.S: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/lowlevel_init.S $@ + +$(obj)omap4_mux_data.h: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/omap4_mux_data.h $@ + +$(obj)board.c:$(obj)omap4_mux_data.h + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/board.c $@ + +$(obj)emif.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/emif.c $@ + +$(obj)sdram_elpida.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/sdram_elpida.c $@ + +$(obj)clocks.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/clocks.c $@ + +SOBJS += lowlevel_init.o +COBJS += board.o clocks.o emif.o sdram_elpida.o + +# rules +LDPPFLAGS += -include $(TOPDIR)/include/config.h +LDSCRIPT = $(splobj)u-boot-spl-generated.lds +$(LDSCRIPT): $(LDSCRIPT_SOURCE) + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@ +LDFLAGS = -Bstatic -T $(LDSCRIPT) \ + $(PLATFORM_LDFLAGS) --gc-sections +AFLAGS += -DCONFIG_PRELOADER -Os -ffixed-r8 +CFLAGS += -DCONFIG_PRELOADER -Os -ffixed-r8 -ffunction-sections \ + -fdata-sections -march=armv7-a -mthumb +PLATFORM_LIBGCC = -L $(shell dirname `$(CC) $(CFLAGS) \ + -print-libgcc-file-name`) -lgcc + +$(obj)%.o: $(obj)%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(obj)%.c + $(CC) $(CFLAGS) -c -o $@ $< + +SRCS := $(addprefix $(obj),$(SOBJS:.o=.S) $(COBJS:.o=.c)) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(OBJTREE)/spl/board/$(BOARDDIR) + +$(splobj)u-boot-spl.bin: $(splobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(splobj)u-boot-spl: $(OBJS) $(LDSCRIPT) + cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ + $(PLATFORM_LIBGCC) \ + -Map $(splobj)u-boot-spl.map \ + -o $(splobj)u-boot-spl + +ALL = $(OBJTREE)/MLO +all: $(obj).depend $(ALL) + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend
Are there anymore comments on this series?
On Monday 28 February 2011 05:16 PM, Aneesh V wrote:
This series adds mmc SPL support for OMAP4. This is essentially an up-streaming effort for TI's x-loader for OMAP4 using the SPL framework
This work partly draws upon previous work done for x-loader by: Santosh Shilimkarsantosh.shilimkar@ti.com Rajendra Nayakrnayak@ti.com and many others
Features supported:
- Clock init - DPLL locking, clock domains/modules enabling
- SDRAM/DMM initialization
- Mux initialization
- MMC raw read support
- MMC FAT read support
Improvments over x-loader:
- Code completely revamped
- DPLL programming that works for all SYS_CLK frequencies
- Automatic SDRAM identification and initialization
- Board dependent parts(especially mux) deferred to u-boot. So, same SPL will work for Panda and SDP and most likely on any other board that comes along
- Determination of u-boot size to avoid reading extra content while loading U-Boot
- Modular apporach to enable future addition of support for all OMAP3/4 platforms
Aneesh V (21): omap: add miscellaneous utility macros for bit-field operations omap4: add OMAP4430 revision check armv7: start.S: provide a hook for saving boot params omap4: save parameters passed by ROM code to SPL arm: new labels in the linker script file Add generic spl infrastructure armv7: start.S: add SPL support omap: add spl support omap4: add spl support for OMAP4 SDP omap4: add serial console support to SPL omap4: utility function to identify the context of hw init omap4: separate mux settings into essential and non essential parts omap4: correct mux data for sdp4430 omap4: add clock support omap4: add sdram init support omap4: calculate EMIF register values omap4: automatic sdram detection armv7: embed u-boot size within u-boot for use from SPL omap: add MMC support to SPL omap: spl: add FAT support over MMC omap4: add spl support for OMAP4 Panda
John Rigby (1): mkimage: Add OMAP boot image support
Makefile | 11 + arch/arm/cpu/armv7/cpu.c | 7 + arch/arm/cpu/armv7/omap-common/Makefile | 1 + .../{omap4/lowlevel_init.S => omap-common/utils.c} | 58 +- arch/arm/cpu/armv7/omap4/Makefile | 3 + arch/arm/cpu/armv7/omap4/board.c | 117 ++- arch/arm/cpu/armv7/omap4/clocks.c | 717 +++++++++++ arch/arm/cpu/armv7/omap4/emif.c | 1303 ++++++++++++++++++++ arch/arm/cpu/armv7/omap4/lowlevel_init.S | 31 + arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 76 ++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 267 ++++ arch/arm/cpu/armv7/start.S | 50 +- arch/arm/cpu/armv7/u-boot.lds | 4 + arch/arm/include/asm/arch-omap4/clocks.h | 504 ++++++++ arch/arm/include/asm/arch-omap4/emif.h | 1021 +++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 50 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 60 +- .../omap4/lowlevel_init.S => include/asm/armv7.h} | 32 +- arch/arm/include/asm/global_data.h | 5 + arch/arm/include/asm/omap_common.h | 106 ++ board/ti/panda/panda.c | 25 +- board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} | 76 +- board/ti/sdp4430/config.mk | 3 +- board/ti/sdp4430/sdp.c | 25 +- .../{panda/panda.h => sdp4430/sdp4430_mux_data.h} | 128 +-- common/image.c | 1 + include/configs/omap4_panda.h | 24 + include/configs/omap4_sdp4430.h | 24 + include/image.h | 1 + spl/board/ti/panda/Makefile | 219 ++++ spl/board/ti/sdp4430/Makefile | 219 ++++ spl/board/ti/spl-omap.c | 189 +++ .../armv7/u-boot.lds => spl/board/ti/spl-omap.lds | 70 +- tools/Makefile | 2 + tools/mkimage.c | 2 + tools/mkimage.h | 1 + tools/omapimage.c | 229 ++++ .../omap4/lowlevel_init.S => tools/omapimage.h | 49 +- 38 files changed, 5390 insertions(+), 320 deletions(-) copy arch/arm/cpu/armv7/{omap4/lowlevel_init.S => omap-common/utils.c} (50%) create mode 100644 arch/arm/cpu/armv7/omap4/clocks.c create mode 100644 arch/arm/cpu/armv7/omap4/emif.c create mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h create mode 100644 arch/arm/cpu/armv7/omap4/sdram_elpida.c create mode 100644 arch/arm/include/asm/arch-omap4/clocks.h create mode 100644 arch/arm/include/asm/arch-omap4/emif.h copy arch/arm/{cpu/armv7/omap4/lowlevel_init.S => include/asm/armv7.h} (62%) create mode 100644 arch/arm/include/asm/omap_common.h rename board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} (76%) rename board/ti/{panda/panda.h => sdp4430/sdp4430_mux_data.h} (67%) create mode 100644 spl/board/ti/panda/Makefile create mode 100644 spl/board/ti/sdp4430/Makefile create mode 100644 spl/board/ti/spl-omap.c copy arch/arm/cpu/armv7/u-boot.lds => spl/board/ti/spl-omap.lds (57%) create mode 100644 tools/omapimage.c copy arch/arm/cpu/armv7/omap4/lowlevel_init.S => tools/omapimage.h (53%)
Hi, 1. Please change spl directory name to mmc_spl in line with nand_spl. regards, chander
Features supported:
(50%)
(62%)
(53%)
Chander,
On Tuesday 22 March 2011 02:20 PM, Chander M. Kashyap wrote:
- Please change spl directory name to mmc_spl in line with nand_spl.
regards, chander
Please have a look at the commit message of 07/22. This is done intentionally to be generic enough to be used for any media. We intend to add NAND support to the same SPL for OMAP3/4. You can potentially have the same SPL support MMC *and* NAND. Where it loads the U-Boot from will depend on a switch setting on the board.
On Mon, Mar 21, 2011 at 1:51 PM, Aneesh V <aneesh@ti.com mailto:aneesh@ti.com> wrote:
Hi, Are there anymore comments on this series? On Monday 28 February 2011 05:16 PM, Aneesh V wrote: > This series adds mmc SPL support for OMAP4. This is essentially > an up-streaming effort for TI's x-loader for OMAP4 using the SPL > framework > > This work partly draws upon previous work done for x-loader by: > Santosh Shilimkar<santosh.shilimkar@ti.com <mailto:santosh.shilimkar@ti.com>> > Rajendra Nayak<rnayak@ti.com <mailto:rnayak@ti.com>> > and many others > > Features supported: > * Clock init - DPLL locking, clock domains/modules enabling > * SDRAM/DMM initialization > * Mux initialization > * MMC raw read support > * MMC FAT read support > > Improvments over x-loader: > * Code completely revamped > * DPLL programming that works for all SYS_CLK frequencies > * Automatic SDRAM identification and initialization > * Board dependent parts(especially mux) deferred to u-boot. So, same > SPL will work for Panda and SDP and most likely on any other board > that comes along > * Determination of u-boot size to avoid reading extra content while > loading U-Boot > * Modular apporach to enable future addition of support for all OMAP3/4 > platforms > > Aneesh V (21): > omap: add miscellaneous utility macros for bit-field operations > omap4: add OMAP4430 revision check > armv7: start.S: provide a hook for saving boot params > omap4: save parameters passed by ROM code to SPL > arm: new labels in the linker script file > Add generic spl infrastructure > armv7: start.S: add SPL support > omap: add spl support > omap4: add spl support for OMAP4 SDP > omap4: add serial console support to SPL > omap4: utility function to identify the context of hw init > omap4: separate mux settings into essential and non essential parts > omap4: correct mux data for sdp4430 > omap4: add clock support > omap4: add sdram init support > omap4: calculate EMIF register values > omap4: automatic sdram detection > armv7: embed u-boot size within u-boot for use from SPL > omap: add MMC support to SPL > omap: spl: add FAT support over MMC > omap4: add spl support for OMAP4 Panda > > John Rigby (1): > mkimage: Add OMAP boot image support > > Makefile | 11 + > arch/arm/cpu/armv7/cpu.c | 7 + > arch/arm/cpu/armv7/omap-common/Makefile | 1 + > .../{omap4/lowlevel_init.S => omap-common/utils.c} | 58 +- > arch/arm/cpu/armv7/omap4/Makefile | 3 + > arch/arm/cpu/armv7/omap4/board.c | 117 ++- > arch/arm/cpu/armv7/omap4/clocks.c | 717 +++++++++++ > arch/arm/cpu/armv7/omap4/emif.c | 1303 ++++++++++++++++++++ > arch/arm/cpu/armv7/omap4/lowlevel_init.S | 31 + > arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 76 ++ > arch/arm/cpu/armv7/omap4/sdram_elpida.c | 267 ++++ > arch/arm/cpu/armv7/start.S | 50 +- > arch/arm/cpu/armv7/u-boot.lds | 4 + > arch/arm/include/asm/arch-omap4/clocks.h | 504 ++++++++ > arch/arm/include/asm/arch-omap4/emif.h | 1021 +++++++++++++++ > arch/arm/include/asm/arch-omap4/omap4.h | 50 +- > arch/arm/include/asm/arch-omap4/sys_proto.h | 60 +- > .../omap4/lowlevel_init.S => include/asm/armv7.h} | 32 +- > arch/arm/include/asm/global_data.h | 5 + > arch/arm/include/asm/omap_common.h | 106 ++ > board/ti/panda/panda.c | 25 +- > board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} | 76 +- > board/ti/sdp4430/config.mk <http://config.mk> | 3 +- > board/ti/sdp4430/sdp.c | 25 +- > .../{panda/panda.h => sdp4430/sdp4430_mux_data.h} | 128 +-- > common/image.c | 1 + > include/configs/omap4_panda.h | 24 + > include/configs/omap4_sdp4430.h | 24 + > include/image.h | 1 + > spl/board/ti/panda/Makefile | 219 ++++ > spl/board/ti/sdp4430/Makefile | 219 ++++ > spl/board/ti/spl-omap.c | 189 +++ > .../armv7/u-boot.lds => spl/board/ti/spl-omap.lds | 70 +- > tools/Makefile | 2 + > tools/mkimage.c | 2 + > tools/mkimage.h | 1 + > tools/omapimage.c | 229 ++++ > .../omap4/lowlevel_init.S => tools/omapimage.h | 49 +- > 38 files changed, 5390 insertions(+), 320 deletions(-) > copy arch/arm/cpu/armv7/{omap4/lowlevel_init.S => omap-common/utils.c} (50%) > create mode 100644 arch/arm/cpu/armv7/omap4/clocks.c > create mode 100644 arch/arm/cpu/armv7/omap4/emif.c > create mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h > create mode 100644 arch/arm/cpu/armv7/omap4/sdram_elpida.c > create mode 100644 arch/arm/include/asm/arch-omap4/clocks.h > create mode 100644 arch/arm/include/asm/arch-omap4/emif.h > copy arch/arm/{cpu/armv7/omap4/lowlevel_init.S => include/asm/armv7.h} (62%) > create mode 100644 arch/arm/include/asm/omap_common.h > rename board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} (76%) > rename board/ti/{panda/panda.h => sdp4430/sdp4430_mux_data.h} (67%) > create mode 100644 spl/board/ti/panda/Makefile > create mode 100644 spl/board/ti/sdp4430/Makefile > create mode 100644 spl/board/ti/spl-omap.c > copy arch/arm/cpu/armv7/u-boot.lds => spl/board/ti/spl-omap.lds (57%) > create mode 100644 tools/omapimage.c > copy arch/arm/cpu/armv7/omap4/lowlevel_init.S => tools/omapimage.h (53%) > _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de <mailto:U-Boot@lists.denx.de> http://lists.denx.de/mailman/listinfo/u-boot
-- thanks and regards, Chander M. Kashyap Contact Number: +919740798700 ------- TENSION LENE KA NAHI, DENE KE-----
This work partly draws upon previous work done for x-loader by: Santosh Shilimkar santosh.shilimkar@ti.com Rajendra Nayak rnayak@ti.com and many others
This series is depedent on the following series: http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/95550
Features supported: * Clock init - DPLL locking, clock domains/modules enabling * SDRAM/DMM initialization * Mux initialization * MMC raw read support * MMC FAT read support
Improvments over x-loader: * Code completely revamped * DPLL programming that works for all SYS_CLK frequencies * Automatic SDRAM identification and initialization * Board dependent parts(especially mux) deferred to u-boot. So, same SPL will work for Panda and SDP and most likely on any other board that comes along * Determination of u-boot size to avoid reading extra content while loading U-Boot * Modular apporach to enable future addition of support for all OMAP3/4 platforms
V2: * Some fixes in SDRAM init, clock init * Use of pre-calculated M & N values for DPLL locking instead run-time calculation * Change in make files to allow reuse of common rules between boards * Console initialization moved further earlier in the boot allowing traces from even clock initialization code * Reuse utility macros from a previous series
Aneesh V (21): omap4: add OMAP4430 revision check armv7: start.S: provide a hook for saving boot params omap4: save parameters passed by ROM code to SPL arm: new labels in the linker script file Add generic spl infrastructure armv7: start.S: add SPL support omap: add spl support omap4: add spl support for OMAP4 SDP omap4: utility function to identify the context of hw init omap4: separate mux settings into essential and non essential parts omap4: correct mux data for sdp4430 omap4: add clock support omap4: add serial console support to SPL omap4: add sdram init support omap4: calculate EMIF register values omap4: automatic sdram detection armv7: embed u-boot size within u-boot for use from SPL omap: add MMC support to SPL omap: spl: add FAT support over MMC omap4: add spl support for OMAP4 Panda omap: spl: add more debug traces
Makefile | 24 + arch/arm/cpu/armv7/cpu.c | 7 + arch/arm/cpu/armv7/omap-common/Makefile | 1 + .../{omap4/lowlevel_init.S => omap-common/utils.c} | 76 +- arch/arm/cpu/armv7/omap4/Makefile | 3 + arch/arm/cpu/armv7/omap4/board.c | 140 ++- arch/arm/cpu/armv7/omap4/clocks.c | 764 +++++++++++ arch/arm/cpu/armv7/omap4/clocks_get_m_n.c | 154 +++ arch/arm/cpu/armv7/omap4/emif.c | 1340 ++++++++++++++++++++ arch/arm/cpu/armv7/omap4/lowlevel_init.S | 31 + arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 76 ++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 267 ++++ arch/arm/cpu/armv7/start.S | 50 +- arch/arm/cpu/armv7/u-boot.lds | 2 + arch/arm/include/asm/arch-omap4/clocks.h | 506 ++++++++ arch/arm/include/asm/arch-omap4/emif.h | 1021 +++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 50 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 62 +- arch/arm/include/asm/armv7.h | 6 +- arch/arm/include/asm/global_data.h | 5 + arch/arm/include/asm/omap_common.h | 62 + arch/arm/include/asm/utils.h | 6 + board/ti/panda/panda.c | 25 +- board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} | 76 +- board/ti/sdp4430/config.mk | 3 +- board/ti/sdp4430/sdp.c | 25 +- .../{panda/panda.h => sdp4430/sdp4430_mux_data.h} | 128 +-- common/image.c | 1 + include/configs/omap4_panda.h | 24 + include/configs/omap4_sdp4430.h | 24 + include/image.h | 1 + spl/board/ti/omap4.mk | 176 +++ .../config.mk => spl/board/ti/panda/Makefile | 21 +- spl/board/ti/rules-omap.mk | 74 ++ .../config.mk => spl/board/ti/sdp4430/Makefile | 21 +- spl/board/ti/spl-omap.c | 206 +++ .../armv7/u-boot.lds => spl/board/ti/spl-omap.lds | 69 +- tools/Makefile | 2 + tools/mkimage.c | 2 + tools/mkimage.h | 1 + tools/omapimage.c | 229 ++++ tools/omapimage.h | 50 + 42 files changed, 5498 insertions(+), 313 deletions(-) copy arch/arm/cpu/armv7/{omap4/lowlevel_init.S => omap-common/utils.c} (50%) create mode 100644 arch/arm/cpu/armv7/omap4/clocks.c create mode 100644 arch/arm/cpu/armv7/omap4/clocks_get_m_n.c create mode 100644 arch/arm/cpu/armv7/omap4/emif.c create mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h create mode 100644 arch/arm/cpu/armv7/omap4/sdram_elpida.c create mode 100644 arch/arm/include/asm/arch-omap4/clocks.h create mode 100644 arch/arm/include/asm/arch-omap4/emif.h create mode 100644 arch/arm/include/asm/omap_common.h rename board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} (76%) rename board/ti/{panda/panda.h => sdp4430/sdp4430_mux_data.h} (67%) create mode 100644 spl/board/ti/omap4.mk copy board/ti/sdp4430/config.mk => spl/board/ti/panda/Makefile (63%) create mode 100644 spl/board/ti/rules-omap.mk copy board/ti/sdp4430/config.mk => spl/board/ti/sdp4430/Makefile (63%) create mode 100644 spl/board/ti/spl-omap.c copy arch/arm/cpu/armv7/u-boot.lds => spl/board/ti/spl-omap.lds (57%) create mode 100644 tools/omapimage.c create mode 100644 tools/omapimage.h
Dear Wolfgang,
Features supported:
V2:
- Some fixes in SDRAM init, clock init
- Use of pre-calculated M& N values for DPLL locking instead run-time calculation
- Change in make files to allow reuse of common rules between boards
- Console initialization moved further earlier in the boot allowing traces from even clock initialization code
- Reuse utility macros from a previous series
This work has mainly two parts: 1. Add the missing hardware support for OMAP4 such as clock init, sdram init etc (OMAP4 u-boot worked without these because it was always prececeded by x-loader) 2. Addd SPL support.
Now that SPL framework design is taking time, I was wondering whether I should split the series into two based on the two main tasks above.
That is, I can send out the hw initialization part immediately without waiting for the SPL design to be finalized and send out the SPL support once we concluded the SPL design discussions.
The patches themselves will not change much. Just that they will be separated into two different series. The reviews done so far will not be wasted.
Are you Ok with this approach?
Signed-off-by: John Rigby john.rigby@linaro.org --- common/image.c | 1 + include/image.h | 1 + tools/Makefile | 2 + tools/mkimage.c | 2 + tools/mkimage.h | 1 + tools/omapimage.c | 229 +++++++++++++++++++++++++++++++++++++++++++++++++++++ tools/omapimage.h | 50 ++++++++++++ 7 files changed, 286 insertions(+), 0 deletions(-) create mode 100644 tools/omapimage.c create mode 100644 tools/omapimage.h
diff --git a/common/image.c b/common/image.c index e542a57..7f6fe1c 100644 --- a/common/image.c +++ b/common/image.c @@ -141,6 +141,7 @@ static const table_entry_t uimage_type[] = { { IH_TYPE_FLATDT, "flat_dt", "Flat Device Tree", }, { IH_TYPE_KWBIMAGE, "kwbimage", "Kirkwood Boot Image",}, { IH_TYPE_IMXIMAGE, "imximage", "Freescale i.MX Boot Image",}, + { IH_TYPE_OMAPIMAGE, "omapimage", "TI OMAP CH/GP Boot Image",}, { -1, "", "", }, };
diff --git a/include/image.h b/include/image.h index c31e862..c606644 100644 --- a/include/image.h +++ b/include/image.h @@ -157,6 +157,7 @@ #define IH_TYPE_FLATDT 8 /* Binary Flat Device Tree Blob */ #define IH_TYPE_KWBIMAGE 9 /* Kirkwood Boot Image */ #define IH_TYPE_IMXIMAGE 10 /* Freescale IMXBoot Image */ +#define IH_TYPE_OMAPIMAGE 11 /* TI OMAP Config Header Image */
/* * Compression Types diff --git a/tools/Makefile b/tools/Makefile index 623f908..a1c4ed7 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -84,6 +84,7 @@ OBJ_FILES-$(CONFIG_CMD_LOADS) += img2srec.o OBJ_FILES-$(CONFIG_INCA_IP) += inca-swap-bytes.o NOPED_OBJ_FILES-y += kwbimage.o NOPED_OBJ_FILES-y += imximage.o +NOPED_OBJ_FILES-y += omapimage.o NOPED_OBJ_FILES-y += mkimage.o OBJ_FILES-$(CONFIG_NETCONSOLE) += ncb.o NOPED_OBJ_FILES-y += os_support.o @@ -180,6 +181,7 @@ $(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)fit_image.o \ $(obj)image.o \ $(obj)imximage.o \ + $(obj)omapimage.o \ $(obj)kwbimage.o \ $(obj)md5.o \ $(obj)mkimage.o \ diff --git a/tools/mkimage.c b/tools/mkimage.c index 60f7263..b6a7cb7 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -156,6 +156,8 @@ main (int argc, char **argv) init_imx_image_type (); /* Init FIT image generation/list support */ init_fit_image_type (); + /* Init TI OMAP Boot image generation/list support */ + init_omap_image_type(); /* Init Default image generation/list support */ init_default_image_type ();
diff --git a/tools/mkimage.h b/tools/mkimage.h index 9033a7d..3b49645 100644 --- a/tools/mkimage.h +++ b/tools/mkimage.h @@ -143,5 +143,6 @@ void init_kwb_image_type (void); void init_imx_image_type (void); void init_default_image_type (void); void init_fit_image_type (void); +void init_omap_image_type(void);
#endif /* _MKIIMAGE_H_ */ diff --git a/tools/omapimage.c b/tools/omapimage.c new file mode 100644 index 0000000..67fa056 --- /dev/null +++ b/tools/omapimage.c @@ -0,0 +1,229 @@ +/* + * (C) Copyright 2010 + * Linaro LTD, www.linaro.org + * Author: John Rigby john.rigby@linaro.org + * Based on TI's signGP.c + * + * (C) Copyright 2009 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * (C) Copyright 2008 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* Required to obtain the getline prototype from stdio.h */ +#define _GNU_SOURCE + +#include "mkimage.h" +#include <image.h> +#include "omapimage.h" + +/* Header size is CH header rounded up to 512 bytes plus GP header */ +#define OMAP_CH_HDR_SIZE 512 +#define OMAP_GP_HDR_SIZE (sizeof(struct gp_header)) +#define OMAP_FILE_HDR_SIZE (OMAP_CH_HDR_SIZE+OMAP_GP_HDR_SIZE) + +static uint8_t omapimage_header[OMAP_FILE_HDR_SIZE]; + +static int omapimage_check_image_types(uint8_t type) +{ + if (type == IH_TYPE_OMAPIMAGE) + return EXIT_SUCCESS; + else + return EXIT_FAILURE; +} + +/* + * Only the simplest image type is currently supported: + * TOC pointing to CHSETTINGS + * TOC terminator + * CHSETTINGS + * + * padding to OMAP_CH_HDR_SIZE bytes + * + * gp header + * size + * load_addr + */ +static int valid_gph_size(uint32_t size) +{ + return size; +} + +static int valid_gph_load_addr(uint32_t load_addr) +{ + return load_addr; +} + +static int omapimage_verify_header(unsigned char *ptr, int image_size, + struct mkimage_params *params) +{ + struct ch_toc *toc = (struct ch_toc *)ptr; + struct gp_header *gph = (struct gp_header *)(ptr+OMAP_CH_HDR_SIZE); + uint32_t offset, size; + + while (toc->section_offset != 0xffffffff + && toc->section_size != 0xffffffff) { + offset = toc->section_offset; + size = toc->section_size; + if (!offset || !size) + return -1; + if (offset >= OMAP_CH_HDR_SIZE || + offset+size >= OMAP_CH_HDR_SIZE) + return -1; + toc++; + } + if (!valid_gph_size(gph->size)) + return -1; + if (!valid_gph_load_addr(gph->load_addr)) + return -1; + + return 0; +} + +static void omapimage_print_section(struct ch_settings *chs) +{ + switch (chs->section_key) { + case KEY_CHSETTINGS: + printf("CHSETTINGS (%x) " + "valid:%x " + "version:%x " + "reserved:%x " + "flags:%x\n", + chs->section_key, + chs->valid, + chs->version, + chs->reserved, + chs->flags); + break; + default: + printf("UNKNOWNKEY (%x) " + "valid:%x " + "version:%x " + "reserved:%x " + "flags:%x\n", + chs->section_key, + chs->valid, + chs->version, + chs->reserved, + chs->flags); + break; + } +} + +static void omapimage_print_header(const void *ptr) +{ + struct ch_toc *toc = (struct ch_toc *)ptr; + struct gp_header *gph = (struct gp_header *)(ptr+OMAP_CH_HDR_SIZE); + uint32_t offset, size; + + while (toc->section_offset != 0xffffffff + && toc->section_size != 0xffffffff) { + offset = toc->section_offset; + size = toc->section_size; + + if (offset >= OMAP_CH_HDR_SIZE || + offset+size >= OMAP_CH_HDR_SIZE) + exit(EXIT_FAILURE); + + printf("Section %s offset %x length %x\n", + toc->section_name, + toc->section_offset, + toc->section_size); + + omapimage_print_section((struct ch_settings *)(ptr+offset)); + toc++; + } + + if (!valid_gph_size(gph->size)) { + fprintf(stderr, + "Error: invalid image size %x\n", + gph->size); + exit(EXIT_FAILURE); + } + + if (!valid_gph_load_addr(gph->load_addr)) { + fprintf(stderr, + "Error: invalid image load address %x\n", + gph->size); + exit(EXIT_FAILURE); + } + + printf("GP Header: Size %x LoadAddr %x\n", + gph->size, gph->load_addr); +} + +static int toc_offset(void *hdr, void *member) +{ + return member - hdr; +} + +static void omapimage_set_header(void *ptr, struct stat *sbuf, int ifd, + struct mkimage_params *params) +{ + struct ch_toc *toc = (struct ch_toc *)ptr; + struct ch_settings *chs = (struct ch_settings *) + (ptr + 2 * sizeof(*toc)); + struct gp_header *gph = (struct gp_header *)(ptr + OMAP_CH_HDR_SIZE); + + toc->section_offset = toc_offset(ptr, chs); + toc->section_size = sizeof(struct ch_settings); + strcpy((char *)toc->section_name, "CHSETTINGS"); + + chs->section_key = KEY_CHSETTINGS; + chs->valid = 0; + chs->version = 1; + chs->reserved = 0; + chs->flags = 0; + + toc++; + memset(toc, 0xff, sizeof(*toc)); + + gph->size = sbuf->st_size - OMAP_FILE_HDR_SIZE; + gph->load_addr = params->addr; +} + +int omapimage_check_params(struct mkimage_params *params) +{ + return (params->dflag && (params->fflag || params->lflag)) || + (params->fflag && (params->dflag || params->lflag)) || + (params->lflag && (params->dflag || params->fflag)); +} + +/* + * omapimage parameters + */ +static struct image_type_params omapimage_params = { + .name = "TI OMAP CH/GP Boot Image support", + .header_size = OMAP_FILE_HDR_SIZE, + .hdr = (void *)&omapimage_header, + .check_image_type = omapimage_check_image_types, + .verify_header = omapimage_verify_header, + .print_header = omapimage_print_header, + .set_header = omapimage_set_header, + .check_params = omapimage_check_params, +}; + +void init_omap_image_type(void) +{ + mkimage_register(&omapimage_params); +} diff --git a/tools/omapimage.h b/tools/omapimage.h new file mode 100644 index 0000000..7ff5404 --- /dev/null +++ b/tools/omapimage.h @@ -0,0 +1,50 @@ +/* + * (C) Copyright 2010 + * Linaro LTD, www.linaro.org + * Author John Rigby john.rigby@linaro.org + * Based on TI's signGP.c + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _OMAPIMAGE_H_ +#define _OMAPIMAGE_H_ + +struct ch_toc { + uint32_t section_offset; + uint32_t section_size; + uint8_t unused[12]; + uint8_t section_name[12]; +} __attribute__ ((__packed__)); + +struct ch_settings { + uint32_t section_key; + uint8_t valid; + uint8_t version; + uint16_t reserved; + uint32_t flags; +} __attribute__ ((__packed__)); + +struct gp_header { + uint32_t size; + uint32_t load_addr; +} __attribute__ ((__packed__)); + +#define KEY_CHSETTINGS 0xC0C0C0C1 +#endif /* _OMAPIMAGE_H_ */
Dear Aneesh V,
- { IH_TYPE_OMAPIMAGE, "omapimage", "TI OMAP CH/GP Boot Image",}, { -1, "", "", },
Please keep list sorted / sort list.
Please keep lists sorted.
- (C) Copyright 2010
- Linaro LTD, www.linaro.org
- Author: John Rigby john.rigby@linaro.org
- Based on TI's signGP.c
- (C) Copyright 2009
- Stefano Babic, DENX Software Engineering, sbabic@denx.de.
- (C) Copyright 2008
- Marvell Semiconductor <www.marvell.com>
- Written-by: Prafulla Wadaskar prafulla@marvell.com
- project.
- MA 02111-1307 USA
- if (type == IH_TYPE_OMAPIMAGE)
- else
Maybe an error message would be helpful?
- switch (chs->section_key) {
- case KEY_CHSETTINGS:
"valid:%x "
"version:%x "
"reserved:%x "
"flags:%x\n",
chs->section_key,
chs->valid,
chs->version,
chs->reserved,
chs->flags);
break;
- default:
"valid:%x "
"version:%x "
"reserved:%x "
"flags:%x\n",
chs->section_key,
chs->valid,
chs->version,
chs->reserved,
chs->flags);
break;
How about unifying these cases, and passing "CHSETTINGS" resp. "UNKNOWNKEY" as argument?
+struct ch_toc {
- uint32_t section_offset;
- uint32_t section_size;
- uint8_t unused[12];
- uint8_t section_name[12];
- uint32_t section_key;
- uint8_t valid;
- uint8_t version;
- uint16_t reserved;
- uint32_t flags;
+struct gp_header {
- uint32_t size;
- uint32_t load_addr;
Is there any good reason to have these "__attribute__ ((__packed__))" here? In general, these are only known to cause trouble and pain, and I cannot see a need here.
Hi Wolfgang,
On Monday 16 May 2011 12:36 AM, Wolfgang Denk wrote:
Dear Aneesh V,
In message1305472900-4004-2-git-send-email-aneesh@ti.com you wrote:
Signed-off-by: John Rigbyjohn.rigby@linaro.org
Sort by the second field(kwbimage, omapimage etc), right?
Ok.
+struct ch_toc {
- uint8_t valid;
- uint8_t version;
- uint32_t flags;
+struct gp_header {
- uint32_t size;
ROM code expects the header in a precise format. I think it will not be safe to leave it to the compiler to decide the field layout. For instance, the compiler may align the uint8_t or uint16_t to 32 bit boundary and that will break the Configuration Header.
Just curious, what are the issues caused by "__packed__"?
Dear Aneesh V,
First field, but the result is the same.
+struct ch_toc {
- uint8_t valid;
- uint8_t version;
- uint32_t flags;
+struct gp_header {
- uint32_t size;
No. Not in the structs listed above.
For example, 32 bit data may be accessed in 4 8-bit operations which may be fatal when accessing device registers.
Hi Wolfgang,
On Monday 16 May 2011 05:18 PM, Wolfgang Denk wrote:
Dear Aneesh V,
+struct ch_toc {
- uint8_t valid;
- uint8_t version;
- uint32_t flags;
+struct gp_header {
- uint32_t size;
You mean "__packed__" should be removed from "struct gp_header" alone, not from the other structs?
Dear Aneesh V,
From all of them.
Hi Wolfgang,
Dear Aneesh V,
+struct ch_toc {
- uint8_t valid;
- uint8_t version;
- uint32_t flags;
+struct gp_header {
- uint32_t size;
Why do you think it will not create any problems. For instance, what if the field "uint8_t version" in "struct ch_settings" is aligned to a 32 bit boundary by the compiler for faster access? That is not the intended layout.
Dear Aneesh V,
In message 4DD2657F.3020708@ti.com you wrote:
+struct ch_toc {
- uint8_t valid;
- uint8_t version;
- uint32_t flags;
+struct gp_header {
- uint32_t size;
If the compiler did such a thing, this would indeed be bad. But I have never seen a compiler doing this, nor is there a reason to do so. The naturla alignment requirement for a uint8_t is a byte; ther eis no need to align it on 4 byte boundary.
- struct ch_toc *toc = (struct ch_toc *)ptr;
you're casting away the void. something is fundamentally broken here. -mike
err, obviously i meant "const" instead of "void" ... -mike
Hi Mike,
This is not my code. But I don't think it was intentional. The following didn't seem to cause any trouble. I shall add this fix in the next revision if this looks ok.
static void omapimage_print_header(const void *ptr) { - struct ch_toc *toc = (struct ch_toc *)ptr; + const struct ch_toc *toc = (const struct ch_toc *)ptr;
you're submitting the patch with only your s-o-b on it. that means you're responsible for it all.
- const struct ch_toc *toc = (const struct ch_toc *)ptr;
drop the cast entirely ... this isnt C++ after all: const struct ch_toc *toc = ptr; -mike
Hi Mike,
No. both From and s-o-b are John's on this patch.
ok.
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Added a revision string in addition to the revision number Helps in printing out the OMAP revision at bootup --- arch/arm/cpu/armv7/omap4/board.c | 58 +++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 17 ++++++--- arch/arm/include/asm/armv7.h | 6 +++- 3 files changed, 74 insertions(+), 7 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index fcd29a7..8ab7306 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -28,6 +28,7 @@ * MA 02111-1307 USA */ #include <common.h> +#include <asm/armv7.h> #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> @@ -127,3 +128,60 @@ int arch_cpu_init(void) set_muxconf_regs(); return 0; } + +static u32 cortex_a9_rev(void) +{ + + unsigned int rev; + + /* Read Main ID Register (MIDR) */ + asm ("mrc p15, 0, %0, c0, c0, 0" : "=r" (rev)); + + return rev; +} + +u32 omap4_revision(void) +{ + if (readl(CONTROL_ID_CODE) == OMAP4_CONTROL_ID_CODE_ES2_1) + return OMAP4430_ES2_1; + else if (readl(CONTROL_ID_CODE) == OMAP4_CONTROL_ID_CODE_ES2_2) + return OMAP4430_ES2_2; + /* + * For some of the ES2/ES1 boards ID_CODE is not reliable: + * Also, ES1 and ES2 have different ARM revisions + * So use ARM revision for identification + */ + unsigned int rev = cortex_a9_rev(); + + switch (rev) { + case MIDR_CORTEX_A9_R0P1: + return OMAP4430_ES1_0; + case MIDR_CORTEX_A9_R1P2: + return OMAP4430_ES2_0; + default: + return OMAP4430_SILICON_ID_INVALID; + } +} + +const char *omap4_rev_string(void) +{ + const char *omap4_rev = NULL; + switch (omap4_revision()) { + case OMAP4430_ES1_0: + omap4_rev = "OMAP4430 ES1.0"; + break; + case OMAP4430_ES2_0: + omap4_rev = "OMAP4430 ES2.0"; + break; + case OMAP4430_ES2_1: + omap4_rev = "OMAP4430 ES2.1"; + break; + case OMAP4430_ES2_2: + omap4_rev = "OMAP4430 ES2.2"; + break; + default: + omap4_rev = "OMAP4 - Unknown Rev"; + break; + } + return omap4_rev; +} diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index a30bb33..1f88732 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -51,6 +51,11 @@ #define CONTROL_PADCONF_CORE (OMAP44XX_L4_CORE_BASE + 0x100000) #define CONTROL_PADCONF_WKUP (OMAP44XX_L4_CORE_BASE + 0x31E000)
+/* CONTROL_ID_CODE */ +#define CONTROL_ID_CODE (CTRL_BASE + 0x204) + +#define OMAP4_CONTROL_ID_CODE_ES2_1 0x3B95C02F +#define OMAP4_CONTROL_ID_CODE_ES2_2 0x4B95C02F /* UART */ #define UART1_BASE (OMAP44XX_L4_PER_BASE + 0x6a000) #define UART2_BASE (OMAP44XX_L4_PER_BASE + 0x6c000) @@ -121,11 +126,11 @@ struct s32ktimer { /* Temporary SRAM stack used while low level init is done */ #define LOW_LEVEL_SRAM_STACK NON_SECURE_SRAM_END
-/* - * OMAP4 real hardware: - * TODO: Change this to the IDCODE in the hw regsiter - */ -#define CPU_OMAP4430_ES10 1 -#define CPU_OMAP4430_ES20 2 +/* Silicon revisions */ +#define OMAP4430_SILICON_ID_INVALID 0 +#define OMAP4430_ES1_0 1 +#define OMAP4430_ES2_0 2 +#define OMAP4430_ES2_1 3 +#define OMAP4430_ES2_2 4
#endif diff --git a/arch/arm/include/asm/armv7.h b/arch/arm/include/asm/armv7.h index 50cc167..772435b 100644 --- a/arch/arm/include/asm/armv7.h +++ b/arch/arm/include/asm/armv7.h @@ -26,6 +26,10 @@ #define ARMV7_H #include <linux/types.h>
+/* Cortex-A9 revisions */ +#define MIDR_CORTEX_A9_R0P1 0x410FC091 +#define MIDR_CORTEX_A9_R1P2 0x411FC092 + /* CCSIDR */ #define CCSIDR_LINE_SIZE_OFFSET 0 #define CCSIDR_LINE_SIZE_MASK 0x7 @@ -65,4 +69,4 @@ void v7_outer_cache_inval_all(void); void v7_outer_cache_flush_range(u32 start, u32 end); void v7_outer_cache_inval_range(u32 start, u32 end);
-#endif +#endif /* ARMV7_H */
Dear Aneesh V,
V2:
- Added a revision string in addition to the revision number Helps in printing out the OMAP revision at bootup
- const char *omap4_rev = NULL;
- switch (omap4_revision()) {
- case OMAP4430_ES1_0:
break;
- case OMAP4430_ES2_0:
break;
- case OMAP4430_ES2_1:
break;
- case OMAP4430_ES2_2:
break;
Such code does not really scale well. Can this not be improved? I think we just had similar discussions for i.MX5x - please check what the result of these was.
- default:
break;
Please also output what the unknown revision was - this saves at least one debug round if you ever run into this case.
C struct?
Hi Wolfgang,
On Monday 16 May 2011 12:39 AM, Wolfgang Denk wrote:
Dear Aneesh V,
In message1305472900-4004-3-git-send-email-aneesh@ti.com you wrote:
Signed-off-by: Aneesh Vaneesh@ti.com
V2:
break;
break;
break;
break;
Are you referring to this one? http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/98522
If so, it may not work for us:
1. Please note that the above function is just for getting the string not for the revision itself. To get the revision we have omap4_revision().
2. In our case we do not have a 1:1 mapping between the revisions(monotonically increasing numbers) we need in the U-Boot and the value obtained from the ID_CODE register. So, a translation is inevitable.
3. We need increasing numbers for subsequent revisions so that we can have something like:
if (omap4_revision() >= OMAP4430_ES2_0) do_something();
- default:
break;
This function should be in sync with omap4_revision() function(unless there is a bug). So, the rev will be OMAP4430_SILICON_ID_INVALID in that case.
I shall print out the ARM revision and OMAP revision registers when I get into OMAP4430_SILICON_ID_INVALID situation in omap4_revision()
C struct?
Ok. I shall convert defines to C structs globally for register addressing.
Dear Aneesh V,
break;
break;
break;
break;
- Please note that the above function is just for getting the string
Well, when you already have such a funxction, then why cannot it be made to return useful values that are well-suited for formatting?
Instead of
#define OMAP4430_ES1_0 1 #define OMAP4430_ES2_0 2 #define OMAP4430_ES2_1 3 #define OMAP4430_ES2_2 4
you could use
#define OMAP4430_ES1_0 10 #define OMAP4430_ES2_0 20 #define OMAP4430_ES2_1 21 #define OMAP4430_ES2_2 22
And then use a plain
sprintf(omap4_rev, "OMAP4430 ES%d.%d", rev/10, rev%10);
or similar.
- In our case we do not have a 1:1 mapping between the
This is not needed. See above. Any form of table driven approach would be suitable, too.
- We need increasing numbers for subsequent revisions so that we can
Should be no problem, see above. Just define your number scheme. Instead of decimal packing you could also adapt something like the major/minor numbers for devices, and use the existing macros to extract the parts.
There are tons of existing solutions for this type of problem, just pick one that fits.
- default:
break;
In this case omap4_revision() should print the value it is reading. Whenever you are reading "unexpected? numbers the first thing you will do during debugging is to check _what_ exactly you are reawding - so you can help and safe one step by just printing thei information which you have ready in your hands.
Thanks.
Hi Wolfgang,
On Monday 16 May 2011 09:05 PM, Wolfgang Denk wrote:
Dear Aneesh V,
Instead of
you could use
or similar.
This is a good idea. The only minor hitch is that OMAP4460 will come into picture in near future, again having at least ES1_0. But I think that can be worked out.
best regards, Aneesh
Dear Aneesh V,
In message 4DD21843.4060000@ti.com you wrote:
you could use
or similar.
Then go for something like
#define OMAP4430_ES1_0 0x44300100 #define OMAP4430_ES2_0 0x44300200 #define OMAP4430_ES2_1 0x44300201 #define OMAP4430_ES2_2 0x44300202
sprintf(omap4_rev, "OMAP%x ES%x.%x", (rev >> 16) & 0xFFFF, (rev >> 8) & 0xFF, rev & 0xFF);
or so.
Provide a means by which u-boot/SPL can save parameters passed to it by ROM code or the pre-loader.
A new function 'save_boot_params' has been defined and a default implentation provided. Please note that we do not have a stack yet. So, any implementation of this function should not use stack.
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/cpu.c | 7 +++++++ arch/arm/cpu/armv7/start.S | 1 + 2 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/cpu.c b/arch/arm/cpu/armv7/cpu.c index 5c69d04..1c9e297 100644 --- a/arch/arm/cpu/armv7/cpu.c +++ b/arch/arm/cpu/armv7/cpu.c @@ -36,6 +36,13 @@ #include <asm/system.h> #include <asm/armv7.h>
+void save_boot_params_default(u32 r0, u32 r1, u32 r2, u32 r3) +{ +} + +void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) + __attribute__((weak, alias("save_boot_params_default"))); + int cleanup_before_linux(void) { /* diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 13e2d44..e6e05e9 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -119,6 +119,7 @@ IRQ_STACK_START_IN: */
reset: + bl save_boot_params /* * set the cpu to SVC32 mode */
Dear Aneesh V,
As is, this is dead code. Please squash with next patch that uses this.
Save boot device information passed by OMAP4 rom code
ROM code in OMAP4 passes information such as the media from which it picked up the first boot image(SPL in our case), the mode(raw mode/FAT mode) etc.
Save this information in SPL so that we can use the same media and mode to bootload u-boot.
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap4/board.c | 14 +++++++ arch/arm/cpu/armv7/omap4/lowlevel_init.S | 31 +++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 8 ++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + .../asm/{arch-omap4/sys_proto.h => omap_common.h} | 41 +++++++++++-------- 5 files changed, 78 insertions(+), 17 deletions(-) copy arch/arm/include/asm/{arch-omap4/sys_proto.h => omap_common.h} (54%)
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 8ab7306..046e3bf 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -35,6 +35,20 @@
DECLARE_GLOBAL_DATA_PTR;
+#ifdef CONFIG_PRELOADER +u32 omap4_boot_device = BOOT_DEVICE_MMC1; +u32 omap4_boot_mode = MMCSD_MODE_FAT; +u32 omap_boot_device(void) +{ + return omap4_boot_device; +} + +u32 omap_boot_mode(void) +{ + return omap4_boot_mode; +} +#endif + /* * Routine: s_init * Description: Does early system init of muxing and clocks. diff --git a/arch/arm/cpu/armv7/omap4/lowlevel_init.S b/arch/arm/cpu/armv7/omap4/lowlevel_init.S index 5e6c16f..d26d6e6 100644 --- a/arch/arm/cpu/armv7/omap4/lowlevel_init.S +++ b/arch/arm/cpu/armv7/omap4/lowlevel_init.S @@ -27,6 +27,37 @@ */
#include <asm/arch/omap4.h> +#ifdef CONFIG_PRELOADER +.global save_boot_params +save_boot_params: + /* + * See if the rom code passed pointer is valid: + * It is not valid if it is not in non-secure SRAM + * This may happen if you are booting with the help of + * debugger + */ + ldr r2, =NON_SECURE_SRAM_START + cmp r2, r0 + bgt 1f + ldr r2, =NON_SECURE_SRAM_END + cmp r2, r0 + blt 1f + + /* Store the boot device in omap4_boot_device */ + ldr r2, [r0, #BOOT_DEVICE_OFFSET] @ r1 <- value of boot device + and r2, #BOOT_DEVICE_MASK + ldr r3, =omap4_boot_device + str r2, [r3] @ omap4_boot_device <- r1 + + /* Store the boot mode (raw/FAT) in omap4_boot_mode */ + ldr r2, [r0, #DEV_DESC_PTR_OFFSET] @ get the device descriptor ptr + ldr r2, [r2, #DEV_DATA_PTR_OFFSET] @ get the pDeviceData ptr + ldr r2, [r2, #BOOT_MODE_OFFSET] @ get the boot mode + ldr r3, =omap4_boot_mode + str r2, [r3] +1: + bx lr +#endif
.globl lowlevel_init lowlevel_init: diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index 1f88732..740ca9d 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -133,4 +133,12 @@ struct s32ktimer { #define OMAP4430_ES2_1 3 #define OMAP4430_ES2_2 4
+/* ROM code defines */ +/* Boot device */ +#define BOOT_DEVICE_MASK 0xFF +#define BOOT_DEVICE_OFFSET 0x8 +#define DEV_DESC_PTR_OFFSET 0x4 +#define DEV_DATA_PTR_OFFSET 0x18 +#define BOOT_MODE_OFFSET 0x8 + #endif diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 017f216..0026b75 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -23,6 +23,7 @@
#include <asm/arch/omap4.h> #include <asm/io.h> +#include <asm/omap_common.h>
struct omap_sysinfo { char *board_string; diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/omap_common.h similarity index 54% copy from arch/arm/include/asm/arch-omap4/sys_proto.h copy to arch/arm/include/asm/omap_common.h index 017f216..7e28e28 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/omap_common.h @@ -2,6 +2,11 @@ * (C) Copyright 2010 * Texas Instruments, <www.ti.com> * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of @@ -17,25 +22,27 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ +#ifndef _OMAP_COMMON_H_ +#define _OMAP_COMMON_H_
-#ifndef _SYS_PROTO_H_ -#define _SYS_PROTO_H_ - -#include <asm/arch/omap4.h> -#include <asm/io.h> +/* Boot device */ +#define BOOT_DEVICE_NONE 0 +#define BOOT_DEVICE_XIP 1 +#define BOOT_DEVICE_XIPWAIT 2 +#define BOOT_DEVICE_NAND 3 +#define BOOT_DEVICE_ONE_NAND 4 +#define BOOT_DEVICE_MMC1 5 +#define BOOT_DEVICE_MMC2 6
-struct omap_sysinfo { - char *board_string; -}; +/* Boot type */ +#define MMCSD_MODE_UNDEFINED 0 +#define MMCSD_MODE_RAW 1 +#define MMCSD_MODE_FAT 2
-void gpmc_init(void); -void watchdog_init(void); -u32 get_device_type(void); -void set_muxconf_regs(void); -void sr32(void *, u32, u32, u32); -u32 wait_on_value(u32, u32, void *, u32); -void sdelay(unsigned long); +/* Magic number passed from SPL to U-Boot */ +#define OMAP_SPL_TO_UBOOT_MAGIC_NUMBER 0xDEADBEEF
-extern const struct omap_sysinfo sysinfo; +u32 omap_boot_device(void); +u32 omap_boot_mode(void);
-#endif +#endif /* _OMAP_COMMON_H_ */
Dear Aneesh V,
- /* Store the boot device in omap4_boot_device */
- ldr r2, [r0, #BOOT_DEVICE_OFFSET] @ r1 <- value of boot device
- and r2, #BOOT_DEVICE_MASK
- ldr r3, =omap4_boot_device
- str r2, [r3] @ omap4_boot_device <- r1
Why don't you use stadard global data here?
Hi Wolfgang,
On Monday 16 May 2011 12:44 AM, Wolfgang Denk wrote:
Dear Aneesh V,
- ldr r2, [r0, #BOOT_DEVICE_OFFSET] @ r1<- value of boot device
- str r2, [r3] @ omap4_boot_device<- r1
SPL has access to .data right from the beginning. Besides this is too early. global data is not initialized yet.
Dear Aneesh V,
Please keep in mind that this is a special situation then. The code will not work as intended for example when running form NOR flash.
Hi Wolfgang,
On Monday 16 May 2011 09:07 PM, Wolfgang Denk wrote:
Dear Aneesh V,
Yes, I realize that. The values passed in the ARM registers need to be saved before they are lost. At the moment only SPL needs them. We do not have a board with NOR flash yet. If there is a need in the future we may have to save it in some predefined special purpose memory such as the scratchpad memory of OMAP or some location in the internal RAM that is not used. But there is no such need at the moment.
Dear Aneesh V,
OK. Maybe you can add a comment that explains this situation.
_bss_start_ofs is used in start.S to indicate end of copied image. This may not be correct when we have a discontiguous memory map. For instance, .bss may be placed in SDRAM for some SPLS while rest of the image is placed in SRAM.
Define a new label in linker script to indicate the end of the image copied during relocation and use it appropriately in start.S.
Also, add a new label to indicate the end of flash image. This will be useful in identifying the size of flash image
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Removed the label __flash_image_end because _end serves the same purpose after rebasing to latest mainline --- arch/arm/cpu/armv7/start.S | 6 +++++- arch/arm/cpu/armv7/u-boot.lds | 2 ++ 2 files changed, 7 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index e6e05e9..13178cd 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -89,6 +89,10 @@ _armboot_start: _bss_start_ofs: .word __bss_start - _start
+.global _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -188,7 +192,7 @@ stack_setup: beq clear_bss /* skip relocation */ #endif mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: diff --git a/arch/arm/cpu/armv7/u-boot.lds b/arch/arm/cpu/armv7/u-boot.lds index dbae54d..40ecf78 100644 --- a/arch/arm/cpu/armv7/u-boot.lds +++ b/arch/arm/cpu/armv7/u-boot.lds @@ -55,6 +55,8 @@ SECTIONS
. = ALIGN(4);
+ __image_copy_end = .; + .rel.dyn : { __rel_dyn_start = .; *(.rel*)
Define a new type of SPL that is not tied to any particular media. - Create a top level directory 'spl' that has a structure similar to the existing 'nand_spl' - Make necessary changes to top-level Makefile to build such an spl
Rationale for this approach: - There may be SPLs(like the OMAP x-loader) that support booting from multiple media. - Also, there is no harm in keeping SPLs specific to a particular media also under this directory. In fact it makes sense to merge all the different spl directories into this one.
Signed-off-by: Aneesh V aneesh@ti.com --- This patch generates 1 checkpatch warning due to declaration of DECLARE_GLOBAL_DATA_PTR. This is un-avoidable --- Makefile | 24 ++++++++++++++++++++++++ arch/arm/include/asm/global_data.h | 5 +++++ 2 files changed, 29 insertions(+), 0 deletions(-)
diff --git a/Makefile b/Makefile index 384a59e..d3f4bef 100644 --- a/Makefile +++ b/Makefile @@ -289,6 +289,22 @@ LDPPFLAGS += \ $(shell $(LD) --version | \ sed -ne 's/GNU ld version ([0-9][0-9]*).([0-9][0-9]*).*/-DLD_MAJOR=\1 -DLD_MINOR=\2/p')
+ifeq ($(CONFIG_NAND_U_BOOT),y) +NAND_SPL = nand_spl +U_BOOT_NAND = $(obj)u-boot-nand.bin +endif + +ifeq ($(CONFIG_SPL),y) +.PHONEY : SPL +ALL += SPL +endif + +ifeq ($(CONFIG_ONENAND_U_BOOT),y) +ONENAND_IPL = onenand_ipl +U_BOOT_ONENAND = $(obj)u-boot-onenand.bin +ONENAND_BIN ?= $(obj)onenand_ipl/onenand-ipl-2k.bin +endif + __OBJS := $(subst $(obj),,$(OBJS)) __LIBS := $(subst $(obj),,$(LIBS)) $(subst $(obj),,$(LIBBOARD))
@@ -402,8 +418,13 @@ $(obj)u-boot.lds: $(LDSCRIPT) $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@
nand_spl: $(TIMESTAMP_FILE) $(VERSION_FILE) depend + +$(NAND_SPL): $(TIMESTAMP_FILE) $(VERSION_FILE) depend $(MAKE) -C nand_spl/board/$(BOARDDIR) all
+SPL :$(TIMESTAMP_FILE) $(VERSION_FILE) depend tools + $(MAKE) -C spl/board/$(BOARDDIR) all + $(obj)u-boot-nand.bin: nand_spl $(obj)u-boot.bin cat $(obj)nand_spl/u-boot-spl-16k.bin $(obj)u-boot.bin > $(obj)u-boot-nand.bin
@@ -1122,6 +1143,7 @@ clean: @rm -f $(obj)include/bmp_logo.h @rm -f $(obj)lib/asm-offsets.s @rm -f $(obj)nand_spl/{u-boot.lds,u-boot-spl,u-boot-spl.map,System.map} + @rm -f $(obj)spl/{u-boot-spl-generated.lds,u-boot-spl,u-boot-spl.map} @rm -f $(obj)onenand_ipl/onenand-{ipl,ipl.bin,ipl.map} @rm -f $(ONENAND_BIN) @rm -f $(obj)onenand_ipl/u-boot.lds @@ -1141,12 +1163,14 @@ clobber: clean @rm -f $(obj)u-boot $(obj)u-boot.map $(obj)u-boot.hex $(ALL) @rm -f $(obj)u-boot.kwb @rm -f $(obj)u-boot.imx + @rm -f $(obj)MLO @rm -f $(obj)tools/{env/crc32.c,inca-swap-bytes} @rm -f $(obj)arch/powerpc/cpu/mpc824x/bedbug_603e.c @rm -fr $(obj)include/asm/proc $(obj)include/asm/arch $(obj)include/asm @rm -fr $(obj)include/generated @[ ! -d $(obj)nand_spl ] || find $(obj)nand_spl -name "*" -type l -print | xargs rm -f @[ ! -d $(obj)onenand_ipl ] || find $(obj)onenand_ipl -name "*" -type l -print | xargs rm -f + @[ ! -d $(obj)spl ] || find $(obj)spl -name "*" -type l -print | xargs rm -f
ifeq ($(OBJTREE),$(SRCTREE)) mrproper \ diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index 2a84d27..2ce020e 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -89,6 +89,11 @@ typedef struct global_data { #define GD_FLG_DISABLE_CONSOLE 0x00040 /* Disable console (in & out) */ #define GD_FLG_ENV_READY 0x00080 /* Environment imported into hash table */
+#ifdef CONFIG_PRELOADER +/* SPL works from internal RAM. gd pointer can be in .data section */ +#define DECLARE_GLOBAL_DATA_PTR extern gd_t *gd +#else #define DECLARE_GLOBAL_DATA_PTR register volatile gd_t *gd asm ("r8") +#endif
#endif /* __ASM_GBL_DATA_H */
Dear Aneesh V,
Thanks a lot for addressing this. This is an area that has long been on my mind, and I'm really happy to see someone starting to work on this.
In addition to booting from different types of media, I see at least two more topics that scould and should addressed by this work:
- Get rid of xloader. I cannot see any good reasons why we need it, i. e. which functions if performs that cannot be as well (and eventually even more efficiently) be performed in the U-Boot SPL code.
- Become more flexible regarding the kind of second stage payload. It is definitely very powerful and convenient during development to be able to load U-Boot with all it's capabilities as payload of the SPL, but then, except for image size and parameter passing, there is little or no difference to loading a Linux kernel directly instead (and actually this is what most of the super-fast booting approaches do). If done right, we may even have the flexibility to do both, just by providing different images as payload.
Here the commit message and the implementation do not agree. You wrote "Create a top level directory 'spl'" - but I don't see any of that here?
I think this should be split into a separate patch series, and care should be taken that commit messages and implementaiton match.
Hi Wolfgang,
On Monday 16 May 2011 01:18 AM, Wolfgang Denk wrote:
Dear Aneesh V,
Indeed, SPL is seen as a replacement for x-loader.
How do we handle the differences you just mentioned, namely the size, parameter passing etc. Maybe, we should have special handling for each and define config flags like CONFIG_SPL_PAYLOAD_UBOOT, CONFIG_SPL_PAYLOAD_LINUX_KERNEL etc?
In this patch, I just created the makefile infrastructure that expects this directory structure. The files are created later in an OMAP specific patch.
I think I should have used something like "define a directory structure" instead of "create".
Ok.
Dear Aneesh V,
Excellent.
None of this. Ideally, the code should not even see such a difference. U-Boot does not need any special arguments for booting, so we calways pass Linux-compatible args. And things like image size should be read from the image itself, or form other available meta information (like file size when reading from a FAT file system, etc.).
Such a definition should include the rename / moving of the other, already existing code.
You are reverting part of e935a374dbe5c745fdde05b2b07ced0bbe70887f. Merge accident?
- @rm -f $(obj)MLO
What is MLO?
Is this appropriate for all ARM boards (e.g. those currently using nand_spl)?
-Scott
Hi Scott,
- __OBJS := $(subst $(obj),,$(OBJS)) __LIBS := $(subst $(obj),,$(LIBS)) $(subst $(obj),,$(LIBBOARD))
@@ -402,8 +418,13 @@ $(obj)u-boot.lds: $(LDSCRIPT) $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P -<$^>$@
Oops! That indeed seems like a merge accident. I will correct it in the next version.
- @rm -f $(obj)MLO
What is MLO?
MLO is the name of SPL created for OMAP. ROM code expects a file with this name as the first image when it boots from FAT.
diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index 2a84d27..2ce020e 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -89,6 +89,11 @@ typedef struct global_data { #define GD_FLG_DISABLE_CONSOLE 0x00040 /* Disable console (in& out) */ #define GD_FLG_ENV_READY 0x00080 /* Environment imported into hash table */
None of the SPL's other than this one seems to be using global data today. If anybody wants to use it this seems to be the logical option for me because by definition SPL runs from some kind of RAM so global data can be placed in the .data section of SPL.
Dear Aneesh V,
In message 4DD21BAA.6000601@ti.com you wrote:
What is MLO?
What does MLO mean?
But that's not what you are doing. You are not changing the storage of the global data itself, you are changing the storage of the POINTER TO the global data - and this makes no sense to me. The pointer can certainly remain in a register even if the data itself is somewhere else.
This will save us this #ifdef here.
Hi Aneesh,
On Tuesday 17 May 2011 01:45 PM, Wolfgang Denk wrote:
Dear Aneesh V,
In message4DD21BAA.6000601@ti.com you wrote:
What is MLO?
What does MLO mean?
On looking up ROM code spec, this seems to stand for "MMC/SD Loader"
Why do we want to waste a register in the entire SPL when global data can be accessed directly from .data section?
Dear Aneesh V,
Because the resulting code is smaller?
I did not measure it on your hardware with your compiler, but IIRC this was the result on some other processors.
Hi Wolfgang,
On Tuesday 17 May 2011 04:47 PM, Wolfgang Denk wrote:
Dear Aneesh V,
I was thinking that it may be faster. More number of registers at disposal may mean less number of pushes to the stack, right? I am not sure if this will make a significant difference.
Dear Aneesh V,
It does not make a significant difference. Which is the reason I vote for avoiding the #ifdef.
Hi Wolfgang,
On Tuesday 17 May 2011 06:03 PM, Wolfgang Denk wrote:
Dear Aneesh V,
Ok. I shall change it.
There is nand_spl code, including ARM, that uses gd. E.g. putc() in board/davinci/da8xxevm/hawkboard_nand_spl.c.
This comment also applies to the other uses of CONFIG_PRELOADER -- are all of those changes appropriate for the existing nand_spl users?
-Scott
Hi Scott,
I would probably revert the change as advised by Wolfgang.
Changes for supporting SPL
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/start.S | 36 +++++++++++++++++++++++++----------- 1 files changed, 25 insertions(+), 11 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 13178cd..f92c6d9 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -42,7 +42,16 @@ _start: b reset ldr pc, _not_used ldr pc, _irq ldr pc, _fiq - +#ifdef CONFIG_PRELOADER +_undefined_instruction: .word _undefined_instruction +_software_interrupt: .word _software_interrupt +_prefetch_abort: .word _prefetch_abort +_data_abort: .word _data_abort +_not_used: .word _not_used +_irq: .word _irq +_fiq: .word _fiq +_pad: .word 0x12345678 /* now 16*4=64 */ +#else _undefined_instruction: .word undefined_instruction _software_interrupt: .word software_interrupt _prefetch_abort: .word prefetch_abort @@ -51,6 +60,8 @@ _not_used: .word not_used _irq: .word irq _fiq: .word fiq _pad: .word 0x12345678 /* now 16*4=64 */ +#endif /* CONFIG_PRELOADER */ + .global _end_vect _end_vect:
@@ -187,10 +198,9 @@ stack_setup: mov sp, r4
adr r0, _start -#ifndef CONFIG_PRELOADER cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ -#endif mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */ @@ -240,6 +250,15 @@ fixnext: add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ cmp r2, r3 blo fixloop + b clear_bss +_rel_dyn_start_ofs: + .word __rel_dyn_start - _start +_rel_dyn_end_ofs: + .word __rel_dyn_end - _start +_dynsym_start_ofs: + .word __dynsym_start - _start + +#endif /* #ifndef CONFIG_PRELOADER */
clear_bss: ldr r0, _bss_start_ofs @@ -253,7 +272,6 @@ clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 bne clbss_l -#endif /* #ifndef CONFIG_PRELOADER */
/* * We are done. Do not return, instead branch to second part of board @@ -281,13 +299,6 @@ jump_2_ram: _board_init_r_ofs: .word board_init_r - _start
-_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - /************************************************************************* * * CPU_init_critical registers @@ -332,6 +343,8 @@ cpu_init_crit: bl lowlevel_init @ go setup pll,mux,memory mov lr, ip @ restore link mov pc, lr @ back to my caller + +#ifndef CONFIG_PRELOADER /* ************************************************************************* * @@ -520,3 +533,4 @@ fiq: bl do_fiq
#endif +#endif /* CONFIG_PRELOADER */
Dear Aneesh V,
As is, this is dead code. I think this patch should be much later in this patch series.
Add the basic spl framework and linker script common for OMAP3/4 platforms.
Signed-off-by: Aneesh V aneesh@ti.com --- spl/board/ti/spl-omap.c | 47 ++++++++++++++++++++++++++++++++++ spl/board/ti/spl-omap.lds | 62 +++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 109 insertions(+), 0 deletions(-) create mode 100644 spl/board/ti/spl-omap.c create mode 100644 spl/board/ti/spl-omap.lds
diff --git a/spl/board/ti/spl-omap.c b/spl/board/ti/spl-omap.c new file mode 100644 index 0000000..0e08f4f --- /dev/null +++ b/spl/board/ti/spl-omap.c @@ -0,0 +1,47 @@ +/* + * + * Clock initialization for OMAP4 + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/u-boot.h> +#include <asm/arch/sys_proto.h> +#include <timestamp_autogenerated.h> + +/* Define global data structure pointer to it*/ +gd_t gdata __attribute__ ((section(".data"))); +bd_t bdata __attribute__ ((section(".data"))); +gd_t *gd = &gdata; + +void board_init_f(ulong dummy) +{ + relocate_code(CONFIG_SYS_SPL_STACK, &gdata, CONFIG_SYS_SPL_TEXT_BASE); +} + +void board_init_r(gd_t *id, ulong dummy) +{ + for (;;) + ; +} diff --git a/spl/board/ti/spl-omap.lds b/spl/board/ti/spl-omap.lds new file mode 100644 index 0000000..674ef05 --- /dev/null +++ b/spl/board/ti/spl-omap.lds @@ -0,0 +1,62 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +MEMORY { .sram : ORIGIN = CONFIG_SYS_SPL_TEXT_BASE,\ + LENGTH = CONFIG_SYS_SPL_MAX_SIZE } +MEMORY { .sdram : ORIGIN = CONFIG_SYS_SPL_BSS_START_ADDR, \ + LENGTH = CONFIG_SYS_SPL_BSS_MAX_SIZE } + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + .text : + { + __start = .; + start.o (.text) + *(.text*) + } >.sram + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(.rodata*)) } >.sram + + . = ALIGN(4); + .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram + . = ALIGN(4); + __image_copy_end = .; + _end = .; + + .bss : + { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + __bss_end__ = .; + } >.sdram +}
Dear Aneesh V,
Again, this appears to be not the right order.
I think, in the first step of this series, we should move the existing code from nand_spl and onenand_ipl into something like spl/nand and spl/onenand, respectivly, and make sure all teh existing systems still build. The we can add more such support.
Hi Wolfgang,
On Monday 16 May 2011 01:22 AM, Wolfgang Denk wrote:
Dear Aneesh V,
IMHO, we should just have spl/board/<vendor>/<board>/ .
Let spl/board/<vendor>/<board>/Makefile decide what it wants to build.
I mean something like this(similar changes for ONENAND):
+.PHONEY : SPL +SPL :$(TIMESTAMP_FILE) $(VERSION_FILE) depend tools + $(MAKE) -C spl/board/$(BOARDDIR) all + +ifeq ($(CONFIG_SPL),y) +ALL += SPL +endif + __OBJS := $(subst $(obj),,$(OBJS)) __LIBS := $(subst $(obj),,$(LIBS)) $(subst $(obj),,$(LIBBOARD))
@@ -401,11 +409,8 @@ $(LDSCRIPT): depend $(obj)u-boot.lds: $(LDSCRIPT) $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@
-nand_spl: $(TIMESTAMP_FILE) $(VERSION_FILE) depend - $(MAKE) -C nand_spl/board/$(BOARDDIR) all - -$(obj)u-boot-nand.bin: nand_spl $(obj)u-boot.bin - cat $(obj)nand_spl/u-boot-spl-16k.bin $(obj)u-boot.bin > $(obj)u-boot-nand.bin +$(obj)u-boot-nand.bin: SPL $(obj)u-boot.bin + cat $(obj)spl/u-boot-spl-16k.bin $(obj)u-boot.bin > $(obj)u-boot-nand.bin
Dear Aneesh V,
There are common, board independent parts both in spl/nand and spl/onenand.
Hi Wolfgang,
On Monday 16 May 2011 09:13 PM, Wolfgang Denk wrote:
Dear Aneesh V,
How about having them at the root level in 'spl/' ?
Dear Aneesh V,
Why? It seems more logical to me to group nand and onenand related files in their own subdirectories.
Hi Wolfgang, On Tuesday 17 May 2011 01:46 PM, Wolfgang Denk wrote:
Dear Aneesh V,
I do not have any issue in having media specific files in their respective directories. However, I would like to see the 'Makefile's coming from the same directory tree irrespective of the media. So, how about something like this:
spl/ mmc/ nand/ one-nand/ board/<vendor>/<board>/Makefile
The idea is to have the board level Makefile in 'spl/board/<vendor> /<board>/' no matter what the SPL type is. This will help in better consolidation of SPLs.
I see 3 SPL use-cases in general: 1. A single SPL that supports multiple media(suitable for SoCs with large internal RAM) 2. A single SPL supporting a single media(the board supports only one media) 3. Multiple SPLs for the same board each supporting a different memory device(maybe preferred over 1 to keep the foot-print of each small).
Supporting (1) and (2) is straight forward with the above directory structure.
To support (3) the board level Makefile should conditionally include the respective image file in the target 'all' based on CONFIG options. For instance 'all' may include 'onenand-ipl-2k.bin' if CONFIG_ONENAND_U_BOOT is defined and so on.
Please let me know if any of you have better ideas. I would like to finalize on this before re-working on my patch-set.
Hi Wolfgang,
Dear Aneesh V,
- A single SPL that supports multiple media(suitable for SoCs with
What's your views on the above scheme.
Hi Wolfgang,
Dear Aneesh V,
Are you fine with this scheme. Appreciate if you could let me know your thoughts on this. I am waiting for your inputs to start the re-work.
Dear Aneesh V,
Actually that would be
board/[<vendor>/]<board>/
OK.
1. and 2. are actually the same (2. being the special case of N=1)
- Multiple SPLs for the same board each supporting a different
I don't get this. Why don't we just pass the required make target from the top level Makefile? If we want to build "onenand-ipl-2k.bin" then this would result in running "make onenand-ipl-2k.bin" in the respective directory - this is then also independent of whether this image contains support for one specific boot device or for any set of different devices.
Dear Wolfgang,
On Wednesday 15 June 2011 03:43 PM, Wolfgang Denk wrote:
Dear Aneesh V,
OK.
- and 2. are actually the same (2. being the special case of N=1)
Then you will have to deal with many such images in the top-level Makefile(u-boot/Makefile). Instead why not have just one rule like the below in the top-level Makefile for all the different spl's:
SPL :$(TIMESTAMP_FILE) $(VERSION_FILE) depend tools $(MAKE) -C spl/board/$(BOARDDIR) all
And leave the rest to the board level Makefiles
Of course, this is assuming the existing Makefile structure. With the new Makefile structure you are suggesting this may not hold good.
Dear Aneesh,
We just discussed that there are cases where there may be no board level Makefile be needed at all, because there is no board specific code to handle.
Also, why would there be many such images? We might just want to use more reasonable names. We have "u-boot.bin", and this works fine for all boards, so why cannot we make it that "u-boot-nand.bin" works for all boards booting from NAND, and in general "u-boot-<DEV>.bin" works for all boards booting from a <DEV> boot device?
Instead of "onenand-ipl-2k.bin", we would just have a generic "u-boot-onenand.bin"
Why not?
Dear Wolfgang,
On Wednesday 15 June 2011 05:34 PM, Wolfgang Denk wrote:
Dear Aneesh,
Also, why would there be many such images? We might just want to use more reasonable names. We have "u-boot.bin", and this works fine for all boards, so why cannot we make it that "u-boot-nand.bin" works for all boards booting from NAND, and in general "u-boot-<DEV>.bin" works for all boards booting from a<DEV> boot device?
Why not?
I was saying that my suggestion of delegating everything to board level Makefile will not work with the new top-down approach you are suggesting in the other mail-chain.
Dear Aneesh V,
Why not?
I did not suggest this. On contrary, I think I pointed out that we might have cases where no board directory (and thus no board specific Makefile) will be needed at all.
On Mon, 16 May 2011 19:40:30 +0530 Aneesh V aneesh@ti.com wrote:
Hi Wolfgang,
That's what we do in nand_spl/onenand_spl -- the common files are more like libraries that the board makefile may or may not pull in (e.g. many Freescale boards use nand_boot_fsl_elbc.c or nand_boot_fsl_nfc.c instead of nand_boot.c).
Renaming nand_spl seems like it should be the first step.
+.PHONEY : SPL
.PHONY
-Scott
Hi Scott,
On Tuesday 17 May 2011 12:09 AM, Scott Wood wrote:
On Mon, 16 May 2011 19:40:30 +0530 Aneesh Vaneesh@ti.com wrote:
Hi Wolfgang,
+.PHONEY : SPL
.PHONY
Oops! I wonder how it was working then. My real patch too had the same mistake!
+.PHONEY : SPL
.PHONY
Well, .PHONY is mainly a performance hint if there's no actual file or rule with that name.
-Scott
Dear Aneesh V,
- for (;;)
Also, this cannot be right.
Hi Wolfgang,
On Monday 16 May 2011 01:23 AM, Wolfgang Denk wrote:
Dear Aneesh V,
- for (;;)
I added the features one by one in the subsequent patches and removed that loop. Maybe I should squash some patches here too.
Hi Aneesh,
I recently started to work on a similar topic: omap3 (devkit8000) nand_spl support. So I'am really interested in your OMAP4/common work here ;)
In this patch comment you say its common for OMAP3/4 but in preloader_console_init() is a call to omap4_rev_string()):
printf("Texas Instruments %s\n", omap4_rev_string());
Regards Simon
2011/5/15 Aneesh V aneesh@ti.com
- Clock initialization for OMAP4
- Texas Instruments, <www.ti.com>
- Aneesh V aneesh@ti.com
- project.
- MA 02111-1307 USA
for (;;)
- (C) Copyright 2002
- Gary Jennejohn, DENX Software Engineering, garyj@denx.de
Aneesh V <aneesh@ti.com>
- project.
- MA 02111-1307 USA
.text :
__start = .;
start.o (.text)
*(.text*)
} >.sram
. = ALIGN(4);
. = ALIGN(4);
. = ALIGN(4);
_end = .;
.bss :
. = ALIGN(4);
__bss_start = .;
*(.bss*)
. = ALIGN(4);
__bss_end__ = .;
} >.sdram
1.7.0.4
Hi Simon,
On Monday 16 May 2011 03:18 PM, Simon Schwarz wrote:
Hi Aneesh,
Thank you for pointing it out. I will change it to omap_rev_string()
Adapted from: nand_spl/board/samsung/smdk6400/Makefile
- Add the SPL makefile for OMAP4430 SDP - Add the necessary CONFIG flags in the board config file
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Changed CONFIG_SYS_SPL_TEXT_BASE to 0x40304350 from 0x40304360. This exact address is needed for EMU devices. * Removed un-necessary compiler options from CFLAGS and AFLAGS. These are already set by .mk files in U-Boot * Reorganize the make files to re-use common rules between boards --- board/ti/sdp4430/config.mk | 3 +- include/configs/omap4_sdp4430.h | 19 +++++ spl/board/ti/omap4.mk | 77 ++++++++++++++++++++ spl/board/ti/rules-omap.mk | 74 +++++++++++++++++++ .../config.mk => spl/board/ti/sdp4430/Makefile | 21 +++--- 5 files changed, 183 insertions(+), 11 deletions(-) create mode 100644 spl/board/ti/omap4.mk create mode 100644 spl/board/ti/rules-omap.mk copy board/ti/sdp4430/config.mk => spl/board/ti/sdp4430/Makefile (63%)
diff --git a/board/ti/sdp4430/config.mk b/board/ti/sdp4430/config.mk index 33901a7..c62965d 100644 --- a/board/ti/sdp4430/config.mk +++ b/board/ti/sdp4430/config.mk @@ -28,4 +28,5 @@ # Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 # (mem base + reserved)
-CONFIG_SYS_TEXT_BASE = 0x80e80000 +# 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM +CONFIG_SYS_TEXT_BASE = 0x80100000 diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 0fd08b3..99247df 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -121,7 +121,9 @@
/* USB device configuration */ #define CONFIG_USB_DEVICE 1 +#ifndef CONFIG_PRELOADER #define CONFIG_USB_TTY 1 +#endif #define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* Flash */ @@ -244,4 +246,21 @@ #define CONFIG_SYS_PL310_BASE 0x48242000 #endif
+/* Defines for Clock init */ +#define CONFIG_SYS_OMAP4_ABE_SYSCK + +/* Defines for SDRAM init */ +#define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION 1 +#define CONFIG_SYS_EMIF_UPDATE_TIMINGS 1 +#define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS 1 + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SYS_SPL_TEXT_BASE 0x40304350 +#define CONFIG_SYS_SPL_MAX_SIZE 0x7800 /* 30 K */ +#define CONFIG_SYS_SPL_STACK LOW_LEVEL_SRAM_STACK + +#define CONFIG_SYS_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SYS_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + #endif /* __CONFIG_H */ diff --git a/spl/board/ti/omap4.mk b/spl/board/ti/omap4.mk new file mode 100644 index 0000000..dffb53b --- /dev/null +++ b/spl/board/ti/omap4.mk @@ -0,0 +1,77 @@ +# +# (C) Copyright 2006-2007 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# (C) Copyright 2010 +# Texas Instruments, <www.ti.com> +# Aneesh V aneesh@ti.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +splobj := $(OBJTREE)/spl/ +include $(TOPDIR)/config.mk +SOBJS = +COBJS = + +# armv7 +$(obj)start.S: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/start.S $@ + +$(obj)syslib.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/syslib.c $@ + +SOBJS += start.o +COBJS += syslib.o + +# omap-common +$(obj)timer.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap-common/timer.c $@ + +$(obj)reset.S: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap-common/reset.S $@ + +$(obj)spl-omap.c: + @rm -f $@ + @ln -s $(TOPDIR)/spl/board/ti/spl-omap.c $@ + +SOBJS += reset.o +COBJS += timer.o spl-omap.o + +# omap4 +$(obj)lowlevel_init.S: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/lowlevel_init.S $@ + +$(obj)omap4_mux_data.h: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/omap4_mux_data.h $@ + +$(obj)board.c:$(obj)omap4_mux_data.h + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/board.c $@ + +SOBJS += lowlevel_init.o +COBJS += board.o diff --git a/spl/board/ti/rules-omap.mk b/spl/board/ti/rules-omap.mk new file mode 100644 index 0000000..b1d0ae6 --- /dev/null +++ b/spl/board/ti/rules-omap.mk @@ -0,0 +1,74 @@ +# +# (C) Copyright 2006-2007 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# (C) Copyright 2010 +# Texas Instruments, <www.ti.com> +# Aneesh V aneesh@ti.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +LDSCRIPT_SOURCE = $(TOPDIR)/spl/board/ti/spl-omap.lds +LDPPFLAGS += -include $(TOPDIR)/include/config.h +LDSCRIPT = $(splobj)u-boot-spl-generated.lds +$(LDSCRIPT): $(LDSCRIPT_SOURCE) + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@ +LDFLAGS = -Bstatic -T $(LDSCRIPT) \ + $(PLATFORM_LDFLAGS) --gc-sections +AFLAGS += -DCONFIG_PRELOADER +CFLAGS += -DCONFIG_PRELOADER -ffunction-sections -fdata-sections \ + $(call cc-option,-march=armv7-a -mthumb -mthumb-interwork,) +PLATFORM_LIBGCC = -L $(shell dirname `$(CC) $(CFLAGS) \ + -print-libgcc-file-name`) -lgcc + +$(obj)%.o: $(obj)%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(obj)%.c + $(CC) $(CFLAGS) -c -o $@ $< + +SRCS := $(addprefix $(obj),$(SOBJS:.o=.S) $(COBJS:.o=.c)) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(OBJTREE)/spl/board/$(BOARDDIR) + +$(splobj)u-boot-spl.bin: $(splobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(splobj)u-boot-spl: $(OBJS) $(LDSCRIPT) + cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ + $(PLATFORM_LIBGCC) \ + -Map $(splobj)u-boot-spl.map \ + -o $(splobj)u-boot-spl + +$(OBJTREE)/MLO: $(splobj)u-boot-spl.bin + $(OBJTREE)/tools/mkimage -T omapimage \ + -a $(CONFIG_SYS_SPL_TEXT_BASE) -d $< $@ + +ALL = $(OBJTREE)/MLO +all: $(obj).depend $(ALL) + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend diff --git a/board/ti/sdp4430/config.mk b/spl/board/ti/sdp4430/Makefile similarity index 63% copy from board/ti/sdp4430/config.mk copy to spl/board/ti/sdp4430/Makefile index 33901a7..81bf51c 100644 --- a/board/ti/sdp4430/config.mk +++ b/spl/board/ti/sdp4430/Makefile @@ -1,9 +1,13 @@ # -# (C) Copyright 2006-2009 -# Texas Instruments Incorporated, <www.ti.com> +# (C) Copyright 2006-2007 +# Stefan Roese, DENX Software Engineering, sr@denx.de. # -# OMAP 4430 SDP -# see http://www.ti.com/ for more information on Texas Instruments +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# (C) Copyright 2010 +# Texas Instruments, <www.ti.com> +# Aneesh V aneesh@ti.com # # See file CREDITS for list of people who contributed to this # project. @@ -15,7 +19,7 @@ # # This program is distributed in the hope that it will be useful, # but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the # GNU General Public License for more details. # # You should have received a copy of the GNU General Public License @@ -23,9 +27,6 @@ # Foundation, Inc., 59 Temple Place, Suite 330, Boston, # MA 02111-1307 USA # -# SDRAM Address Space: -# 8000'0000 - 9fff'ffff (512 MB) -# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 -# (mem base + reserved)
-CONFIG_SYS_TEXT_BASE = 0x80e80000 +include $(SRCTREE)/spl/board/$(VENDOR)/omap4.mk +include $(SRCTREE)/spl/board/$(VENDOR)/rules-omap.mk
Dear Aneesh V,
V2:
- Changed CONFIG_SYS_SPL_TEXT_BASE to 0x40304350 from 0x40304360. This exact address is needed for EMU devices.
- Removed un-necessary compiler options from CFLAGS and AFLAGS. These are already set by .mk files in U-Boot
- Reorganize the make files to re-use common rules between boards
We do you introduce these files? Please omit them, and use a plain Makefile instead.
NAK. Please define in board config header, and get rid of the config.mk file.
NAK. Move the code into the Makefile, and dump these two files.
Hi wolfgang,
On Monday 16 May 2011 12:03 AM, Wolfgang Denk wrote:
Dear Aneesh V,
V2:
I introduced them because 'spl/board/ti/sdp4430/Makefile' and 'spl/board /ti/panda/Makefile' were exactly same and wanted to re-use the make rules.
I indeed wanted to abstract it out even further in future so that the make rules can be shared between OMAP3 and OMAP4 too. This way the changes needed to support a new board will be lesser and maintenance will be easier while adding new features.
For instance, if I have to add NAND support today I just need to update omap4.mk instead of updating the Makefile of both panda and SDP.
This re-use will be evident when you see a later patch that replicates the same Makefile for panda.
ok.
Dear Aneesh V,
But in the result, the Makefiles are still the same, aren't they?
Can you please rather try and move this to a common directory level, then?
I have a bad feeling about this. If the Makefiles are the same, then the code is probably more or less the same, also. Eventually larger parts of the code should be moved to a common directory, too?
Hi Wolfgang,
On Monday 16 May 2011 09:18 PM, Wolfgang Denk wrote:
Dear Aneesh V,
Yes, but the contents are not duplicated in two files. Easier for maintenance.
The top-level make rule being the following, we will need a Makefile in the board directory, right?
In fact, code is already common. All OMAP code specific to SPL comes from spl/board/ti/spl-omap.c . All OMAP code shared with OMAP U-Boot comes from the respective directory within arch/arm/cpu/armv7/*
In the interest of simplicity I deferred all board specific initialization of OMAP4(mainly mux) to U-Boot. So, SPL is board independent today for OMAP4.
Dear Aneesh V,
- $(MAKE) -C spl/board/$(BOARDDIR) all
Maybe this needs to be tweaked to allow for boards that don;t require board specific code.
Then we should adapt the directory and Makefile structure and allow for such common code without need for separate spl/board/ directories.
Hi Wolfgang,
On Tuesday 17 May 2011 01:49 PM, Wolfgang Denk wrote:
Dear Aneesh V,
And how do you distinguish between the two cases at the top level Makefile? Using a CONFIG flag or on a per platform basis?
Why not just invoke the board level Makefile from the top-level Makefile and let it decide about the code-reuse by doing something like I did?
Do you have any specific proposals? I have a feeling that this may get un-necessarily complicated.
Best regards, Aneesh
Dear Aneesh V,
The decision should not be make in the top level makefile, but in spl/Makefile. And this can simply check if a board directory exists in the first place.
Because then we need board specific directories and board specific Makefiles even for those boards where no board specific code exists, and all these Makefiles will be semi-identical copies of each other.
Having to maintain multiple copies of identical Makefiles is more complicated and error prone in the long run. Let's rather spoend a few thoughts initially and solve this problem before it spreads.
Hi Wolfgang,
On Tuesday 17 May 2011 06:23 PM, Wolfgang Denk wrote:
Dear Aneesh V,
1. How about the case where there is some board dependent code but also code shared by the boards(SoC based code). Will we have different 'Makefile's then - one for board and one for SoC. Will we then build different libraries at each leavel and link them together etc?
2. I think one key thing that you are perhaps missing is that in SPL the board level Makefile is not just meant for board level files. Instead it is used to pull together files from all the layers and make a custom image. IMHO, we will get into un-necessary complexities if we lose this property of SPL. We may rather spend efforts on making the regular U-Boot more configurable.
Considering point 2 above I think this is logical.
The board level Makefile needs to have all the files. For the SoC level selection of files and the SoC level rules, include the respective *.mk files. Because in this case there are no board specific files there is nothing more in the Makefile. Please note that this may not be the case in general. Most boards, I suspect, may have some board specific files too.
I wouldn't really consider the include statements as duplication of code. Instead, that was a way of avoiding duplication of code "given the constraints of the SPL model".
Hi Wolfgang,
What's your final view on the Makefile structure of SPL.
On Thursday 26 May 2011 06:55 PM, Aneesh V wrote:
Hi Wolfgang,
Dear Aneesh V,
- How about the case where there is some board dependent code but also
- I think one key thing that you are perhaps missing is that in SPL
Hi Wolfgang,
Hi Wolfgang,
Dear Aneesh V,
Do you have any thoughts on this yet.
Is it ok if I continue to use the current SPL Makefile structure and abstract out common content from board level 'Makefile's to something like omap4.mk
Dear Aneesh V,
Yes. If a board directory exists the code there gets built and then linked.
This probably should be reworked. We should have a Makefile in nand_spl/ which covers the general code and then runs the respective SoC and/or board specific sub-makes.
Yes, but most of thisis actually not board specific, but more SoC specific, if not general at all.
Indeed we should allow for more fine granular selection.
No. It needs only those files that are actually board specific.
I don;t think that this is actually board specific - if we follow that route, we will duplicate the same stuff for all boards that use the same SoC.
That's why I suggest to separate common, SoC specific and board specific stuff .
Dear Aneesh V,
V2:
See previous comments. Please comine into plain Makefile.
Please move #define into board header and get rid of the config.mk
The basic hardware init of OMAP4(s_init()) can happen in 4 different contexts: 1. SPL running from SRAM 2. U-Boot running from FLASH 3. Non-XIP U-Boot loaded to SDRAM by SPL 4. Non-XIP U-Boot loaded to SDRAM by ROM code using the Configuration Header feature
What level of hw initialization gets done depends on this context. Add a utility function to find this context.
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/include/asm/arch-omap4/sys_proto.h | 47 +++++++++++++++++++++++++++ arch/arm/include/asm/omap_common.h | 6 +++ 2 files changed, 53 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 0026b75..fb4c72f 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -37,6 +37,53 @@ void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long);
+static inline u32 running_from_sdram(void) +{ + u32 pc; + asm volatile ("mov %0, pc" : "=r" (pc)); + return ((pc >= OMAP44XX_DRAM_ADDR_SPACE_START) && + (pc < OMAP44XX_DRAM_ADDR_SPACE_END)); +} + +static inline u8 uboot_loaded_by_spl(void) +{ + /* + * Configuration Header is not supported yet, so u-boot init running + * from SDRAM implies that it was loaded by SPL. When this situation + * changes one of these approaches could be taken: + * i. Pass a magic from SPL to U-Boot and U-Boot save it at a known + * location. + * ii. Check the OPP. CH can support only 50% OPP while SPL initializes + * the DPLLs at 100% OPP. + */ + return running_from_sdram(); +} +/* + * The basic hardware init of OMAP(s_init()) can happen in 4 + * different contexts: + * 1. SPL running from SRAM + * 2. U-Boot running from FLASH + * 3. Non-XIP U-Boot loaded to SDRAM by SPL + * 4. Non-XIP U-Boot loaded to SDRAM by ROM code using the + * Configuration Header feature + * + * This function finds this context. + * Defining as inline may help in compiling out unused functions in SPL + */ +static inline u32 omap4_hw_init_context(void) +{ +#ifdef CONFIG_PRELOADER + return OMAP_INIT_CONTEXT_SPL; +#else + if (uboot_loaded_by_spl()) + return OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_SPL; + else if (running_from_sdram()) + return OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_CH; + else + return OMAP_INIT_CONTEXT_XIP_UBOOT; +#endif +} + extern const struct omap_sysinfo sysinfo;
#endif diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 7e28e28..2063c36 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -42,6 +42,12 @@ /* Magic number passed from SPL to U-Boot */ #define OMAP_SPL_TO_UBOOT_MAGIC_NUMBER 0xDEADBEEF
+/* HW Init Context */ +#define OMAP_INIT_CONTEXT_SPL 0 +#define OMAP_INIT_CONTEXT_XIP_UBOOT 1 +#define OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_SPL 2 +#define OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_CH 3 + u32 omap_boot_device(void); u32 omap_boot_mode(void);
Dear Aneesh V,
- SPL running from SRAM
- U-Boot running from FLASH
- Non-XIP U-Boot loaded to SDRAM by SPL
- Non-XIP U-Boot loaded to SDRAM by ROM code using the Configuration Header feature
- if (uboot_loaded_by_spl())
- else if (running_from_sdram())
For reasons of consistency, should this not better be OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_ROM ?
What exactly is OMAP_INIT_CONTEXT_XIP_UBOOT?
Do you mean the situation when booting from NOR flash, before relocation?
Eventually the "loaded by" definition is not so good, as it does not really cover the NOR boot case.
Boot from NOR?
Do the essential part from SPL and non-essential part from U-Boot - Essential part is what is essential for u-boot to function - Essential part is also largely board independent(at least as of now) - So essential part is moved out to SoC directory instead of keeping in board directory. This helps in having single SPL that works for Panda and SDP. - Non-essential part is what is set by u-boot for kernel to function correctly - Ideally non-essential part should be phased out eventually
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap4/board.c | 53 ++++++++++++++++- arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 76 ++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 4 +- board/ti/panda/panda.c | 25 ++------ board/ti/panda/{panda.h => panda_mux_data.h} | 45 ++------------ board/ti/sdp4430/sdp.c | 25 ++------ board/ti/sdp4430/{sdp.h => sdp4430_mux_data.h} | 47 ++------------- 7 files changed, 151 insertions(+), 124 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h rename board/ti/panda/{panda.h => panda_mux_data.h} (83%) rename board/ti/sdp4430/{sdp.h => sdp4430_mux_data.h} (83%)
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 046e3bf..30bf801 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -32,9 +32,30 @@ #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> +#include "omap4_mux_data.h"
+void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) +{ + int i; + struct pad_conf_entry *pad = (struct pad_conf_entry *) array; + + for (i = 0; i < size; i++, pad++) + writew(pad->val, base + pad->offset); +} + +static void set_muxconf_regs_essential(void) +{ + do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_essential, + sizeof(core_padconf_array_essential) / + sizeof(struct pad_conf_entry)); + + do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_essential, + sizeof(wkup_padconf_array_essential) / + sizeof(struct pad_conf_entry)); +} + #ifdef CONFIG_PRELOADER u32 omap4_boot_device = BOOT_DEVICE_MMC1; u32 omap4_boot_mode = MMCSD_MODE_FAT; @@ -49,14 +70,41 @@ u32 omap_boot_mode(void) } #endif
+static void set_mux_conf_regs(void) +{ + switch (omap4_hw_init_context()) { + case OMAP_INIT_CONTEXT_SPL: + set_muxconf_regs_essential(); + break; + case OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_SPL: + set_muxconf_regs_non_essential(); + break; + case OMAP_INIT_CONTEXT_XIP_UBOOT: + case OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_CH: + set_muxconf_regs_essential(); + set_muxconf_regs_non_essential(); + break; + } +} + /* * Routine: s_init - * Description: Does early system init of muxing and clocks. - * - Called path is with SRAM stack. + * Description: Does early system init of watchdog, muxing, clocks, and + * sdram. Watchdog disable is done always. For the rest what gets done + * depends on the boot mode in which this function is executed + * 1. s_init of SPL running from SRAM + * 2. s_init of U-Boot running from FLASH + * 3. s_init of U-Boot loaded to SDRAM by SPL + * 4. s_init of U-Boot loaded to SDRAM by ROM code using the Configuration + * Header feature + * Please have a look at the respective functions to see what gets done in + * each of these cases + * This function is called with SRAM stack. */ void s_init(void) { watchdog_init(); + set_mux_conf_regs(); }
/* @@ -139,7 +187,6 @@ int checkboard(void) */ int arch_cpu_init(void) { - set_muxconf_regs(); return 0; }
diff --git a/arch/arm/cpu/armv7/omap4/omap4_mux_data.h b/arch/arm/cpu/armv7/omap4/omap4_mux_data.h new file mode 100644 index 0000000..00c52f8 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/omap4_mux_data.h @@ -0,0 +1,76 @@ + /* + * (C) Copyright 2010 + * Texas Instruments Incorporated, <www.ti.com> + * + * Balaji Krishnamoorthy balajitk@ti.com + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _OMAP4_MUX_DATA_H_ +#define _OMAP4_MUX_DATA_H_ + +#include <asm/arch/mux_omap4.h> + +const struct pad_conf_entry core_padconf_array_essential[] = { + +{GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ +{GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ +{GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ +{GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ +{GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ +{GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ +{GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ +{GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +{GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ +{GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ +{SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ +{SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ +{SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ +{SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ +{SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ +{SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ +{SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ +{SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ +{SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ +{SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ +{I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ +{I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ +{I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ +{I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ +{I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ +{I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ +{I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ +{I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ +{UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ +{UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ +{UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ +{UART3_TX_IRTX, (M0)} /* uart3_tx */ + +}; + +const struct pad_conf_entry wkup_padconf_array_essential[] = { + +{PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ +{PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ +{PAD1_SYS_32K, (IEN | M0)} /* sys_32k */ + +}; + +#endif /* _OMAP4_MUX_DATA_H_ */ diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index fb4c72f..ebd5b7a 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -24,6 +24,7 @@ #include <asm/arch/omap4.h> #include <asm/io.h> #include <asm/omap_common.h> +#include <asm/arch/mux_omap4.h>
struct omap_sysinfo { char *board_string; @@ -32,7 +33,8 @@ struct omap_sysinfo { void gpmc_init(void); void watchdog_init(void); u32 get_device_type(void); -void set_muxconf_regs(void); +void do_set_mux(u32 base, struct pad_conf_entry const *array, int size); +void set_muxconf_regs_non_essential(void); void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c index 78e1910..9afed80 100644 --- a/board/ti/panda/panda.c +++ b/board/ti/panda/panda.c @@ -25,7 +25,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h>
-#include "panda.h" +#include "panda_mux_data.h"
DECLARE_GLOBAL_DATA_PTR;
@@ -65,27 +65,14 @@ int misc_init_r(void) return 0; }
-void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) +void set_muxconf_regs_non_essential(void) { - int i; - struct pad_conf_entry *pad = (struct pad_conf_entry *) array; - - for (i = 0; i < size; i++, pad++) - writew(pad->val, base + pad->offset); -} - -/** - * @brief set_muxconf_regs Setting up the configuration Mux registers - * specific to the board. - */ -void set_muxconf_regs(void) -{ - do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array, - sizeof(core_padconf_array) / + do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_non_essential, + sizeof(core_padconf_array_non_essential) / sizeof(struct pad_conf_entry));
- do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array, - sizeof(wkup_padconf_array) / + do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_non_essential, + sizeof(wkup_padconf_array_non_essential) / sizeof(struct pad_conf_entry)); }
diff --git a/board/ti/panda/panda.h b/board/ti/panda/panda_mux_data.h similarity index 83% rename from board/ti/panda/panda.h rename to board/ti/panda/panda_mux_data.h index e3d090e..8bb7fe5 100644 --- a/board/ti/panda/panda.h +++ b/board/ti/panda/panda_mux_data.h @@ -24,21 +24,13 @@ * MA 02111-1307 USA */
-#ifndef _PANDA_H_ -#define _PANDA_H_ +#ifndef _PANDA_MUX_DATA_H_ +#define _PANDA_MUX_DATA_H_
#include <asm/io.h> #include <asm/arch/mux_omap4.h>
-const struct pad_conf_entry core_padconf_array[] = { - {GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ - {GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ - {GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ - {GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ - {GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ - {GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ - {GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ - {GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_AD8, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* gpio_32 */ {GPMC_AD9, (PTU | IEN | M3)}, /* gpio_33 */ {GPMC_AD10, (PTU | IEN | M3)}, /* gpio_34 */ @@ -64,8 +56,6 @@ const struct pad_conf_entry core_padconf_array[] = { {GPMC_NWP, (M3)}, /* gpio_54 */ {GPMC_CLK, (PTD | M3)}, /* gpio_55 */ {GPMC_NADV_ALE, (M3)}, /* gpio_56 */ - {GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ - {GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ @@ -112,16 +102,6 @@ const struct pad_conf_entry core_padconf_array[] = { {USBB1_HSIC_STROBE, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_strobe */ {USBC1_ICUSB_DP, (IEN | M0)}, /* usbc1_icusb_dp */ {USBC1_ICUSB_DM, (IEN | M0)}, /* usbc1_icusb_dm */ - {SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ - {SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ - {SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ - {SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ - {SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ - {SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ - {SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ - {SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ - {SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ - {SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ {ABE_MCBSP2_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_clkx */ {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ @@ -144,14 +124,6 @@ const struct pad_conf_entry core_padconf_array[] = { {UART2_RX, (PTU | IEN | M0)}, /* uart2_rx */ {UART2_TX, (M0)}, /* uart2_tx */ {HDQ_SIO, (M3)}, /* gpio_127 */ - {I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ - {I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ - {I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ - {I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ - {I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ - {I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ - {I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ - {I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ {MCSPI1_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_clk */ {MCSPI1_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_somi */ {MCSPI1_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_simo */ @@ -159,10 +131,6 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI1_CS1, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* mcspi1_cs1 */ {MCSPI1_CS2, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_139 */ {MCSPI1_CS3, (PTU | IEN | M3)}, /* gpio_140 */ - {UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ - {UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ - {UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ - {UART3_TX_IRTX, (M0)}, /* uart3_tx */ {SDMMC5_CLK, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc5_clk */ {SDMMC5_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_cmd */ {SDMMC5_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat0 */ @@ -236,14 +204,12 @@ const struct pad_conf_entry core_padconf_array[] = { {DPM_EMU19, (IEN | M5)}, /* dispc2_data0 */ };
-const struct pad_conf_entry wkup_padconf_array[] = { +const struct pad_conf_entry wkup_padconf_array_non_essential[] = { {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ {PAD1_SIM_CLK, (M0)}, /* sim_clk */ {PAD0_SIM_RESET, (M0)}, /* sim_reset */ {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ - {PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ {PAD1_FREF_XTAL_IN, (M0)}, /* # */ {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ @@ -252,7 +218,6 @@ const struct pad_conf_entry wkup_padconf_array[] = { {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ {PAD1_FREF_CLK4_REQ, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_1 */ {PAD0_FREF_CLK4_OUT, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_2 */ - {PAD1_SYS_32K, (IEN | M0)}, /* sys_32k */ {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ @@ -261,4 +226,4 @@ const struct pad_conf_entry wkup_padconf_array[] = { {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ };
-#endif +#endif /* _PANDA_MUX_DATA_H_ */ diff --git a/board/ti/sdp4430/sdp.c b/board/ti/sdp4430/sdp.c index b13c4c5..a5ea682 100644 --- a/board/ti/sdp4430/sdp.c +++ b/board/ti/sdp4430/sdp.c @@ -27,7 +27,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h>
-#include "sdp.h" +#include "sdp4430_mux_data.h"
@@ -70,27 +70,14 @@ int misc_init_r(void) return 0; }
diff --git a/board/ti/sdp4430/sdp.h b/board/ti/sdp4430/sdp4430_mux_data.h similarity index 83% rename from board/ti/sdp4430/sdp.h rename to board/ti/sdp4430/sdp4430_mux_data.h index bf41067..e6081dc 100644 --- a/board/ti/sdp4430/sdp.h +++ b/board/ti/sdp4430/sdp4430_mux_data.h @@ -23,22 +23,12 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ +#ifndef _SDP4430_MUX_DATA_H +#define _SDP4430_MUX_DATA_H
-#ifndef _SDP_H_ -#define _SDP_H_ - -#include <asm/io.h> #include <asm/arch/mux_omap4.h>
-const struct pad_conf_entry core_padconf_array[] = { - {GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ - {GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ - {GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ - {GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ - {GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ - {GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ - {GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ - {GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_AD8, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* gpio_32 */ {GPMC_AD9, (PTU | IEN | M3)}, /* gpio_33 */ {GPMC_AD10, (PTU | IEN | M3)}, /* gpio_34 */ @@ -64,8 +54,6 @@ const struct pad_conf_entry core_padconf_array[] = { {GPMC_NWP, (M3)}, /* gpio_54 */ {GPMC_CLK, (PTD | M3)}, /* gpio_55 */ {GPMC_NADV_ALE, (M3)}, /* gpio_56 */ - {GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ - {GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ @@ -112,16 +100,6 @@ const struct pad_conf_entry core_padconf_array[] = { {USBB1_HSIC_STROBE, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_strobe */ {USBC1_ICUSB_DP, (IEN | M0)}, /* usbc1_icusb_dp */ {USBC1_ICUSB_DM, (IEN | M0)}, /* usbc1_icusb_dm */ - {SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ - {SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ - {SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ - {SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ - {SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ - {SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ - {SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ - {SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ - {SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ - {SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ {ABE_MCBSP2_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_clkx */ {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ @@ -144,14 +122,6 @@ const struct pad_conf_entry core_padconf_array[] = { {UART2_RX, (PTU | IEN | M0)}, /* uart2_rx */ {UART2_TX, (M0)}, /* uart2_tx */ {HDQ_SIO, (M3)}, /* gpio_127 */ - {I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ - {I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ - {I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ - {I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ - {I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ - {I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ - {I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ - {I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ {MCSPI1_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_clk */ {MCSPI1_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_somi */ {MCSPI1_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_simo */ @@ -159,10 +129,6 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI1_CS1, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* mcspi1_cs1 */ {MCSPI1_CS2, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_139 */ {MCSPI1_CS3, (PTU | IEN | M3)}, /* gpio_140 */ - {UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ - {UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ - {UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ - {UART3_TX_IRTX, (M0)}, /* uart3_tx */ {SDMMC5_CLK, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc5_clk */ {SDMMC5_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_cmd */ {SDMMC5_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat0 */ @@ -236,14 +202,12 @@ const struct pad_conf_entry core_padconf_array[] = { {DPM_EMU19, (IEN | M5)}, /* dispc2_data0 */ };
-const struct pad_conf_entry wkup_padconf_array[] = { +const struct pad_conf_entry wkup_padconf_array_non_essential[] = { {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ {PAD1_SIM_CLK, (M0)}, /* sim_clk */ {PAD0_SIM_RESET, (M0)}, /* sim_reset */ {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ - {PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ {PAD1_FREF_XTAL_IN, (M0)}, /* # */ {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ @@ -252,7 +216,6 @@ const struct pad_conf_entry wkup_padconf_array[] = { {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ {PAD1_FREF_CLK4_REQ, (PTU | IEN | M0)}, /* # */ {PAD0_FREF_CLK4_OUT, (M0)}, /* # */ - {PAD1_SYS_32K, (IEN | M0)}, /* sys_32k */ {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ @@ -261,4 +224,4 @@ const struct pad_conf_entry wkup_padconf_array[] = { {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ };
-#endif +#endif /* _SDP4430_MUX_DATA_H */
sync up mux settings with the latest in x-loader
Signed-off-by: Aneesh V aneesh@ti.com --- Several checkpatch warnings of lines over 80 characters in this patch. These are due to formatting of mux data array, which only makes it more readable. --- board/ti/panda/panda_mux_data.h | 89 ++++++++++++++++++----------------- board/ti/sdp4430/sdp4430_mux_data.h | 29 ++++++----- 2 files changed, 61 insertions(+), 57 deletions(-)
diff --git a/board/ti/panda/panda_mux_data.h b/board/ti/panda/panda_mux_data.h index 8bb7fe5..16cc0ad 100644 --- a/board/ti/panda/panda_mux_data.h +++ b/board/ti/panda/panda_mux_data.h @@ -23,11 +23,9 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ +#ifndef _SDP4430_MUX_DATA_H +#define _SDP4430_MUX_DATA_H
-#ifndef _PANDA_MUX_DATA_H_ -#define _PANDA_MUX_DATA_H_ - -#include <asm/io.h> #include <asm/arch/mux_omap4.h>
const struct pad_conf_entry core_padconf_array_non_essential[] = { @@ -45,7 +43,7 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_A19, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row7 */ {GPMC_A20, (IEN | M3)}, /* gpio_44 */ {GPMC_A21, (M3)}, /* gpio_45 */ - {GPMC_A22, (M3)}, /* gpio_46 */ + {GPMC_A22, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col6 */ {GPMC_A23, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col7 */ {GPMC_A24, (PTD | M3)}, /* gpio_48 */ {GPMC_A25, (PTD | M3)}, /* gpio_49 */ @@ -59,9 +57,9 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ - {GPMC_WAIT1, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_62 */ + {GPMC_WAIT1, (IEN | M3)}, /* gpio_62 */ {C2C_DATA11, (PTD | M3)}, /* gpio_100 */ - {C2C_DATA12, (PTU | IEN | M3)}, /* gpio_101 */ + {C2C_DATA12, (M1)}, /* dsi1_te0 */ {C2C_DATA13, (PTD | M3)}, /* gpio_102 */ {C2C_DATA14, (M1)}, /* dsi2_te0 */ {C2C_DATA15, (PTD | M3)}, /* gpio_104 */ @@ -86,14 +84,14 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {CAM_SHUTTER, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_shutter */ {CAM_STROBE, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_strobe */ {CAM_GLOBALRESET, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_83 */ - {USBB1_ULPITLL_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M4)},/* usbb1_ulpiphy_clk */ - {USBB1_ULPITLL_STP, (OFF_EN | OFF_OUT_PTD | M4)}, /* usbb1_ulpiphy_stp */ - {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dir */ - {USBB1_ULPITLL_NXT, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_nxt */ - {USBB1_ULPITLL_DAT0, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat0 */ - {USBB1_ULPITLL_DAT1, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat1 */ - {USBB1_ULPITLL_DAT2, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat2 */ - {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat3 */ + {USBB1_ULPITLL_CLK, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cawake */ + {USBB1_ULPITLL_STP, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cadata */ + {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caflag */ + {USBB1_ULPITLL_NXT, (OFF_EN | M1)}, /* hsi1_acready */ + {USBB1_ULPITLL_DAT0, (OFF_EN | M1)}, /* hsi1_acwake */ + {USBB1_ULPITLL_DAT1, (OFF_EN | M1)}, /* hsi1_acdata */ + {USBB1_ULPITLL_DAT2, (OFF_EN | M1)}, /* hsi1_acflag */ + {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caready */ {USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ {USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ {USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ @@ -106,8 +104,8 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ {ABE_MCBSP2_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_fsx */ - {ABE_MCBSP1_CLKX, (IEN | M1)}, /* abe_slimbus1_clock */ - {ABE_MCBSP1_DR, (IEN | M1)}, /* abe_slimbus1_data */ + {ABE_MCBSP1_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_clkx */ + {ABE_MCBSP1_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dr */ {ABE_MCBSP1_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dx */ {ABE_MCBSP1_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_fsx */ {ABE_PDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_ul_data */ @@ -143,7 +141,7 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {MCSPI4_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_cs0 */ {UART4_RX, (IEN | M0)}, /* uart4_rx */ {UART4_TX, (M0)}, /* uart4_tx */ - {USBB2_ULPITLL_CLK, (IEN | M3)}, /* gpio_157 */ + {USBB2_ULPITLL_CLK, (PTD | IEN | M3)}, /* gpio_157 */ {USBB2_ULPITLL_STP, (IEN | M5)}, /* dispc2_data23 */ {USBB2_ULPITLL_DIR, (IEN | M5)}, /* dispc2_data22 */ {USBB2_ULPITLL_NXT, (IEN | M5)}, /* dispc2_data21 */ @@ -157,12 +155,12 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {USBB2_ULPITLL_DAT7, (IEN | M5)}, /* dispc2_data11 */ {USBB2_HSIC_DATA, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_169 */ {USBB2_HSIC_STROBE, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_170 */ - {UNIPRO_TX0, (PTD | IEN | M3)}, /* gpio_171 */ + {UNIPRO_TX0, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col0 */ {UNIPRO_TY0, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col1 */ {UNIPRO_TX1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col2 */ {UNIPRO_TY1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col3 */ - {UNIPRO_TX2, (PTU | IEN | M3)}, /* gpio_0 */ - {UNIPRO_TY2, (PTU | IEN | M3)}, /* gpio_1 */ + {UNIPRO_TX2, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col4 */ + {UNIPRO_TY2, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col5 */ {UNIPRO_RX0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row0 */ {UNIPRO_RY0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row1 */ {UNIPRO_RX1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row2 */ @@ -173,13 +171,13 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {USBA0_OTG_DP, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dp */ {USBA0_OTG_DM, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dm */ {FREF_CLK1_OUT, (M0)}, /* fref_clk1_out */ - {FREF_CLK2_OUT, (PTU | IEN | M3)}, /* gpio_182 */ + {FREF_CLK2_OUT, (M0)}, /* fref_clk2_out */ {SYS_NIRQ1, (PTU | IEN | M0)}, /* sys_nirq1 */ - {SYS_NIRQ2, (PTU | IEN | M0)}, /* sys_nirq2 */ + {SYS_NIRQ2, (M7)}, /* sys_nirq2 */ {SYS_BOOT0, (PTU | IEN | M3)}, /* gpio_184 */ {SYS_BOOT1, (M3)}, /* gpio_185 */ {SYS_BOOT2, (PTD | IEN | M3)}, /* gpio_186 */ - {SYS_BOOT3, (M3)}, /* gpio_187 */ + {SYS_BOOT3, (PTD | IEN | M3)}, /* gpio_187 */ {SYS_BOOT4, (M3)}, /* gpio_188 */ {SYS_BOOT5, (PTD | IEN | M3)}, /* gpio_189 */ {DPM_EMU0, (IEN | M0)}, /* dpm_emu0 */ @@ -205,25 +203,28 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { };
const struct pad_conf_entry wkup_padconf_array_non_essential[] = { - {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ - {PAD1_SIM_CLK, (M0)}, /* sim_clk */ - {PAD0_SIM_RESET, (M0)}, /* sim_reset */ - {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ - {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_FREF_XTAL_IN, (M0)}, /* # */ - {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ - {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ - {PAD0_FREF_CLK0_OUT, (M2)}, /* sys_drm_msecure */ - {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ - {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ - {PAD1_FREF_CLK4_REQ, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_1 */ - {PAD0_FREF_CLK4_OUT, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_2 */ - {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ - {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ - {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ - {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ - {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ - {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ + {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ + {PAD1_SIM_CLK, (M0)}, /* sim_clk */ + {PAD0_SIM_RESET, (M0)}, /* sim_reset */ + {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ + {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ + {PAD1_FREF_XTAL_IN, (M0)}, /* # */ + {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ + {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ + {PAD0_FREF_CLK0_OUT, (M2)}, /* sys_drm_msecure */ + {PAD1_FREF_CLK3_REQ, (PTU | IEN | M0)}, /* # */ + {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ + {PAD1_FREF_CLK4_REQ, (PTU | IEN | M0)}, /* # */ + {PAD0_FREF_CLK4_OUT, (M0)}, /* # */ + {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ + {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ + {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ + {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ + {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ + {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ + {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ + {PAD1_FREF_CLK4_REQ, (M3)}, /* gpio_wk7 */ + {PAD0_FREF_CLK4_OUT, (M3)}, /* gpio_wk8 */ };
-#endif /* _PANDA_MUX_DATA_H_ */ +#endif /* _SDP4430_MUX_DATA_H */ diff --git a/board/ti/sdp4430/sdp4430_mux_data.h b/board/ti/sdp4430/sdp4430_mux_data.h index e6081dc..16cc0ad 100644 --- a/board/ti/sdp4430/sdp4430_mux_data.h +++ b/board/ti/sdp4430/sdp4430_mux_data.h @@ -84,14 +84,14 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {CAM_SHUTTER, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_shutter */ {CAM_STROBE, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_strobe */ {CAM_GLOBALRESET, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_83 */ - {USBB1_ULPITLL_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M4)},/* usbb1_ulpiphy_clk */ - {USBB1_ULPITLL_STP, (OFF_EN | OFF_OUT_PTD | M4)}, /* usbb1_ulpiphy_stp */ - {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dir */ - {USBB1_ULPITLL_NXT, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_nxt */ - {USBB1_ULPITLL_DAT0, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat0 */ - {USBB1_ULPITLL_DAT1, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat1 */ - {USBB1_ULPITLL_DAT2, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat2 */ - {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat3 */ + {USBB1_ULPITLL_CLK, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cawake */ + {USBB1_ULPITLL_STP, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cadata */ + {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caflag */ + {USBB1_ULPITLL_NXT, (OFF_EN | M1)}, /* hsi1_acready */ + {USBB1_ULPITLL_DAT0, (OFF_EN | M1)}, /* hsi1_acwake */ + {USBB1_ULPITLL_DAT1, (OFF_EN | M1)}, /* hsi1_acdata */ + {USBB1_ULPITLL_DAT2, (OFF_EN | M1)}, /* hsi1_acflag */ + {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caready */ {USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ {USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ {USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ @@ -104,8 +104,8 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ {ABE_MCBSP2_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_fsx */ - {ABE_MCBSP1_CLKX, (IEN | M1)}, /* abe_slimbus1_clock */ - {ABE_MCBSP1_DR, (IEN | M1)}, /* abe_slimbus1_data */ + {ABE_MCBSP1_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_clkx */ + {ABE_MCBSP1_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dr */ {ABE_MCBSP1_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dx */ {ABE_MCBSP1_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_fsx */ {ABE_PDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_ul_data */ @@ -141,7 +141,7 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {MCSPI4_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_cs0 */ {UART4_RX, (IEN | M0)}, /* uart4_rx */ {UART4_TX, (M0)}, /* uart4_tx */ - {USBB2_ULPITLL_CLK, (IEN | M3)}, /* gpio_157 */ + {USBB2_ULPITLL_CLK, (PTD | IEN | M3)}, /* gpio_157 */ {USBB2_ULPITLL_STP, (IEN | M5)}, /* dispc2_data23 */ {USBB2_ULPITLL_DIR, (IEN | M5)}, /* dispc2_data22 */ {USBB2_ULPITLL_NXT, (IEN | M5)}, /* dispc2_data21 */ @@ -173,11 +173,11 @@ const struct pad_conf_entry core_padconf_array_non_essential[] = { {FREF_CLK1_OUT, (M0)}, /* fref_clk1_out */ {FREF_CLK2_OUT, (M0)}, /* fref_clk2_out */ {SYS_NIRQ1, (PTU | IEN | M0)}, /* sys_nirq1 */ - {SYS_NIRQ2, (PTU | IEN | M0)}, /* sys_nirq2 */ + {SYS_NIRQ2, (M7)}, /* sys_nirq2 */ {SYS_BOOT0, (PTU | IEN | M3)}, /* gpio_184 */ {SYS_BOOT1, (M3)}, /* gpio_185 */ {SYS_BOOT2, (PTD | IEN | M3)}, /* gpio_186 */ - {SYS_BOOT3, (M3)}, /* gpio_187 */ + {SYS_BOOT3, (PTD | IEN | M3)}, /* gpio_187 */ {SYS_BOOT4, (M3)}, /* gpio_188 */ {SYS_BOOT5, (PTD | IEN | M3)}, /* gpio_189 */ {DPM_EMU0, (IEN | M0)}, /* dpm_emu0 */ @@ -222,6 +222,9 @@ const struct pad_conf_entry wkup_padconf_array_non_essential[] = { {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ + {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ + {PAD1_FREF_CLK4_REQ, (M3)}, /* gpio_wk7 */ + {PAD0_FREF_CLK4_OUT, (M3)}, /* gpio_wk8 */ };
Add support for: 1. DPLL locking 2. Initialization of clock domains and clock modules
This work draws upon previous work done for x-loader mainly by: Santosh Shilimkar santosh.shilimkar@ti.com Rajendra Nayak rnayak@ti.com
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Use pre-calculated M & N values instead of calculated ones * Changes due to make file changes * Some corrections * Do all clock initialization in SPL itself instead of differing some work to u-boot --- arch/arm/cpu/armv7/omap4/Makefile | 1 + arch/arm/cpu/armv7/omap4/board.c | 1 + arch/arm/cpu/armv7/omap4/clocks.c | 731 +++++++++++++++++++++++++++ arch/arm/cpu/armv7/omap4/clocks_get_m_n.c | 154 ++++++ arch/arm/include/asm/arch-omap4/clocks.h | 506 ++++++++++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 6 + arch/arm/include/asm/omap_common.h | 3 + spl/board/ti/omap4.mk | 7 +- 8 files changed, 1408 insertions(+), 1 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/clocks.c create mode 100644 arch/arm/cpu/armv7/omap4/clocks_get_m_n.c create mode 100644 arch/arm/include/asm/arch-omap4/clocks.h
diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index 987dc9d..6154e86 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -30,6 +30,7 @@ SOBJS += lowlevel_init.o COBJS += board.o COBJS += mem.o COBJS += sys_info.o +COBJS += clocks.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 30bf801..f83b6d7 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -105,6 +105,7 @@ void s_init(void) { watchdog_init(); set_mux_conf_regs(); + prcm_init(); }
/* diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c new file mode 100644 index 0000000..802917f --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/clocks.c @@ -0,0 +1,731 @@ +/* + * + * Clock initialization for OMAP4 + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * Based on previous work by: + * Santosh Shilimkar santosh.shilimkar@ti.com + * Rajendra Nayak rnayak@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/omap_common.h> +#include <asm/arch/clocks.h> +#include <asm/arch/sys_proto.h> +#include <asm/utils.h> + +#define abs(x) (((x) < 0) ? ((x)*-1) : (x)) + +static const u32 sys_clk_array[8] = { + 12000000, /* 12 MHz */ + 13000000, /* 13 MHz */ + 16800000, /* 16.8 MHz */ + 19200000, /* 19.2 MHz */ + 26000000, /* 26 MHz */ + 27000000, /* 27 MHz */ + 38400000, /* 38.4 MHz */ +}; + +static const struct dpll_params mpu_dpll_params_1ghz[NUM_SYS_CLKS] = { + {250, 2, 1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {1000, 12, 1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {119, 1, 1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {625, 11, 1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {500, 12, 1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {1000, 26, 1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {625, 23, 1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params mpu_dpll_params_es1_600mhz[NUM_SYS_CLKS] = { + {50, 0, 1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {600, 12, 1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {250, 6, 1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {125, 3, 1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {300, 12, 1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {200, 8, 1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {125, 7, 1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params core_dpll_params_1600mhz[NUM_SYS_CLKS] = { + {200, 2, 1, 5, 8, 4, 6, 5}, /* 12 MHz */ + {800, 12, 1, 5, 8, 4, 6, 5}, /* 13 MHz */ + {619, 12, 1, 5, 8, 4, 6, 5}, /* 16.8 MHz */ + {125, 2, 1, 5, 8, 4, 6, 5}, /* 19.2 MHz */ + {400, 12, 1, 5, 8, 4, 6, 5}, /* 26 MHz */ + {800, 26, 1, 5, 8, 4, 6, 5}, /* 27 MHz */ + {125, 5, 1, 5, 8, 4, 6, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params core_dpll_params_es1_1524mhz[NUM_SYS_CLKS] = { + {127, 1, 1, 5, 8, 4, 6, 5}, /* 12 MHz */ + {762, 12, 1, 5, 8, 4, 6, 5}, /* 13 MHz */ + {635, 13, 1, 5, 8, 4, 6, 5}, /* 16.8 MHz */ + {635, 15, 1, 5, 8, 4, 6, 5}, /* 19.2 MHz */ + {381, 12, 1, 5, 8, 4, 6, 5}, /* 26 MHz */ + {254, 8, 1, 5, 8, 4, 6, 5}, /* 27 MHz */ + {496, 24, 1, 5, 8, 4, 6, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params + core_dpll_params_es2_1600mhz_ddr200mhz[NUM_SYS_CLKS] = { + {200, 2, 2, 5, 8, 4, 6, 5}, /* 12 MHz */ + {800, 12, 2, 5, 8, 4, 6, 5}, /* 13 MHz */ + {619, 12, 2, 5, 8, 4, 6, 5}, /* 16.8 MHz */ + {125, 2, 2, 5, 8, 4, 6, 5}, /* 19.2 MHz */ + {400, 12, 2, 5, 8, 4, 6, 5}, /* 26 MHz */ + {800, 26, 2, 5, 8, 4, 6, 5}, /* 27 MHz */ + {125, 5, 2, 5, 8, 4, 6, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params per_dpll_params_1536mhz[NUM_SYS_CLKS] = { + {64, 0, 8, 6, 12, 9, 4, 5}, /* 12 MHz */ + {768, 12, 8, 6, 12, 9, 4, 5}, /* 13 MHz */ + {320, 6, 8, 6, 12, 9, 4, 5}, /* 16.8 MHz */ + {40, 0, 8, 6, 12, 9, 4, 5}, /* 19.2 MHz */ + {384, 12, 8, 6, 12, 9, 4, 5}, /* 26 MHz */ + {256, 8, 8, 6, 12, 9, 4, 5}, /* 27 MHz */ + {20, 0, 8, 6, 12, 9, 4, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params iva_dpll_params_1862mhz[NUM_SYS_CLKS] = { + {931, 11, -1, -1, 4, 7, -1, -1}, /* 12 MHz */ + {931, 12, -1, -1, 4, 7, -1, -1}, /* 13 MHz */ + {665, 11, -1, -1, 4, 7, -1, -1}, /* 16.8 MHz */ + {727, 14, -1, -1, 4, 7, -1, -1}, /* 19.2 MHz */ + {931, 25, -1, -1, 4, 7, -1, -1}, /* 26 MHz */ + {931, 26, -1, -1, 4, 7, -1, -1}, /* 27 MHz */ + {412, 16, -1, -1, 4, 7, -1, -1} /* 38.4 MHz */ +}; + +/* ABE M & N values with sys_clk as source */ +static const struct dpll_params + abe_dpll_params_sysclk_196608khz[NUM_SYS_CLKS] = { + {49, 5, 1, 1, -1, -1, -1, -1}, /* 12 MHz */ + {68, 8, 1, 1, -1, -1, -1, -1}, /* 13 MHz */ + {35, 5, 1, 1, -1, -1, -1, -1}, /* 16.8 MHz */ + {46, 8, 1, 1, -1, -1, -1, -1}, /* 19.2 MHz */ + {34, 8, 1, 1, -1, -1, -1, -1}, /* 26 MHz */ + {29, 7, 1, 1, -1, -1, -1, -1}, /* 27 MHz */ + {64, 24, 1, 1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +/* ABE M & N values with 32K clock as source */ +static const struct dpll_params abe_dpll_params_32k_196608khz = { + 750, 0, 1, 1, -1, -1, -1, -1 +}; + + +static const struct dpll_params usb_dpll_params_1920mhz[NUM_SYS_CLKS] = { + {80, 0, 2, -1, -1, -1, -1, -1}, /* 12 MHz */ + {960, 12, 2, -1, -1, -1, -1, -1}, /* 13 MHz */ + {400, 6, 2, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {50, 0, 2, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {480, 12, 2, -1, -1, -1, -1, -1}, /* 26 MHz */ + {320, 8, 2, -1, -1, -1, -1, -1}, /* 27 MHz */ + {25, 0, 2, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static const u32 clk_domains_essential[] = { + CM_L4PER_CLKSTCTRL, + CM_L3INIT_CLKSTCTRL, + CM_MEMIF_CLKSTCTRL, + CM_L4CFG_CLKSTCTRL, + 0 +}; + +static const u32 clk_domains_non_essential[] = { + CM_MPU_M3_CLKSTCTRL, + CM_IVAHD_CLKSTCTRL, + CM_DSP_CLKSTCTRL, + CM_DSS_CLKSTCTRL, + CM_SGX_CLKSTCTRL, + CM1_ABE_CLKSTCTRL, + CM_C2C_CLKSTCTRL, + CM_CAM_CLKSTCTRL, + CM_DSS_CLKSTCTRL, + CM_SDMA_CLKSTCTRL, + 0 +}; + +static const u32 clk_modules_hw_auto_essential[] = { + CM_WKUP_GPIO1_CLKCTRL, + CM_L4PER_GPIO2_CLKCTRL, + CM_L4PER_GPIO3_CLKCTRL, + CM_L4PER_GPIO4_CLKCTRL, + CM_L4PER_GPIO5_CLKCTRL, + CM_L4PER_GPIO6_CLKCTRL, + CM_MEMIF_EMIF_1_CLKCTRL, + CM_MEMIF_EMIF_2_CLKCTRL, + CM_L3INIT_HSUSBOTG_CLKCTRL, + CM_L3INIT_USBPHY_CLKCTRL, + CM_L4CFG_L4_CFG_CLKCTRL, + 0 +}; + +static const u32 clk_modules_hw_auto_non_essential[] = { + CM_MPU_M3_MPU_M3_CLKCTRL, + CM_IVAHD_IVAHD_CLKCTRL, + CM_IVAHD_SL2_CLKCTRL, + CM_DSP_DSP_CLKCTRL, + CM_L3_2_GPMC_CLKCTRL, + CM_L3INSTR_L3_3_CLKCTRL, + CM_L3INSTR_L3_INSTR_CLKCTRL, + CM_L3INSTR_INTRCONN_WP1_CLKCTRL, + CM_L3INIT_HSI_CLKCTRL, + CM_L3INIT_HSUSBTLL_CLKCTRL, + 0 +}; + +static const u32 clk_modules_explicit_en_essential[] = { + CM_L4PER_GPTIMER2_CLKCTRL, + CM_L3INIT_HSMMC1_CLKCTRL, + CM_L3INIT_HSMMC2_CLKCTRL, + CM_L4PER_MCSPI1_CLKCTRL, + CM_WKUP_GPTIMER1_CLKCTRL, + CM_L4PER_I2C1_CLKCTRL, + CM_L4PER_I2C2_CLKCTRL, + CM_L4PER_I2C3_CLKCTRL, + CM_L4PER_I2C4_CLKCTRL, + CM_WKUP_WDTIMER2_CLKCTRL, + CM_L4PER_UART3_CLKCTRL, + 0 +}; + +static const u32 clk_modules_explicit_en_non_essential[] = { + CM1_ABE_AESS_CLKCTRL, + CM1_ABE_PDM_CLKCTRL, + CM1_ABE_DMIC_CLKCTRL, + CM1_ABE_MCASP_CLKCTRL, + CM1_ABE_MCBSP1_CLKCTRL, + CM1_ABE_MCBSP2_CLKCTRL, + CM1_ABE_MCBSP3_CLKCTRL, + CM1_ABE_SLIMBUS_CLKCTRL, + CM1_ABE_TIMER5_CLKCTRL, + CM1_ABE_TIMER6_CLKCTRL, + CM1_ABE_TIMER7_CLKCTRL, + CM1_ABE_TIMER8_CLKCTRL, + CM1_ABE_WDT3_CLKCTRL, + CM_L4PER_GPTIMER9_CLKCTRL, + CM_L4PER_GPTIMER10_CLKCTRL, + CM_L4PER_GPTIMER11_CLKCTRL, + CM_L4PER_GPTIMER3_CLKCTRL, + CM_L4PER_GPTIMER4_CLKCTRL, + CM_L4PER_HDQ1W_CLKCTRL, + CM_L4PER_MCBSP4_CLKCTRL, + CM_L4PER_MCSPI2_CLKCTRL, + CM_L4PER_MCSPI3_CLKCTRL, + CM_L4PER_MCSPI4_CLKCTRL, + CM_L4PER_MMCSD3_CLKCTRL, + CM_L4PER_MMCSD4_CLKCTRL, + CM_L4PER_MMCSD5_CLKCTRL, + CM_L4PER_UART1_CLKCTRL, + CM_L4PER_UART2_CLKCTRL, + CM_L4PER_UART4_CLKCTRL, + CM_WKUP_KEYBOARD_CLKCTRL, + CM_WKUP_WDTIMER2_CLKCTRL, + CM_CAM_ISS_CLKCTRL, + CM_CAM_FDIF_CLKCTRL, + CM_DSS_DSS_CLKCTRL, + CM_SGX_SGX_CLKCTRL, + CM_L3INIT_HSUSBHOST_CLKCTRL, + CM_L3INIT_FSUSB_CLKCTRL, + 0 +}; + +static inline u32 __get_sys_clk_index(void) +{ + u32 ind; + /* + * For ES1 the ROM code calibration of sys clock is not reliable + * due to hw issue. So, use hard-coded value. If this value is not + * correct for any board over-ride this function in board file + * From ES2.0 onwards you will get this information from + * CM_SYS_CLKSEL + */ + if (omap4_revision() == OMAP4430_ES1_0) + ind = OMAP_SYS_CLK_IND_38_4_MHZ; + else { + /* SYS_CLKSEL - 1 to match the dpll param array indices */ + ind = (readl(CM_SYS_CLKSEL) & CM_SYS_CLKSEL_SYS_CLKSEL_MASK) + - 1; + } + return ind; +} + +u32 get_sys_clk_index(void) + __attribute__ ((weak, alias("__get_sys_clk_index"))); + +u32 get_sys_clk_freq(void) +{ + u8 index = get_sys_clk_index(); + return sys_clk_array[index]; +} + +static inline void do_bypass_dpll(u32 base) +{ + struct dpll_regs *dpll_regs = (struct dpll_regs *)base; + + modify_reg_32(&dpll_regs->cm_clkmode_dpll, + CM_CLKMODE_DPLL_DPLL_EN_SHIFT, + CM_CLKMODE_DPLL_DPLL_EN_MASK, DPLL_EN_FAST_RELOCK_BYPASS); +} + +static inline void wait_for_bypass(u32 base) +{ + struct dpll_regs *dpll_regs = (struct dpll_regs *)base; + + while (readl(&dpll_regs->cm_idlest_dpll) & ST_DPLL_CLK_MASK) + ; +} + +static inline void do_lock_dpll(u32 base) +{ + struct dpll_regs *dpll_regs = (struct dpll_regs *)base; + + modify_reg_32(&dpll_regs->cm_clkmode_dpll, + CM_CLKMODE_DPLL_DPLL_EN_SHIFT, + CM_CLKMODE_DPLL_DPLL_EN_MASK, DPLL_EN_LOCK); +} + +static inline void wait_for_lock(u32 base) +{ + struct dpll_regs *dpll_regs = (struct dpll_regs *)base; + + while (!(readl(&dpll_regs->cm_idlest_dpll) & ST_DPLL_CLK_MASK)) + ; +} + +static void do_setup_dpll(u32 base, const struct dpll_params *params, u8 lock) +{ + u32 temp; + struct dpll_regs *dpll_regs = (struct dpll_regs *)base; + + bypass_dpll(base); + + /* Set M & N */ + temp = readl(&dpll_regs->cm_clksel_dpll); + set_bit_field(temp, CM_CLKSEL_DPLL_M_SHIFT, CM_CLKSEL_DPLL_M_MASK, + params->m); + set_bit_field(temp, CM_CLKSEL_DPLL_N_SHIFT, CM_CLKSEL_DPLL_N_MASK, + params->n); + writel(temp, &dpll_regs->cm_clksel_dpll); + + /* Lock */ + if (lock) + do_lock_dpll(base); + + /* Setup post-dividers */ + if (params->m2 >= 0) + writel(params->m2, &dpll_regs->cm_div_m2_dpll); + if (params->m3 >= 0) + writel(params->m3, &dpll_regs->cm_div_m3_dpll); + if (params->m4 >= 0) + writel(params->m4, &dpll_regs->cm_div_m4_dpll); + if (params->m5 >= 0) + writel(params->m5, &dpll_regs->cm_div_m5_dpll); + if (params->m6 >= 0) + writel(params->m6, &dpll_regs->cm_div_m6_dpll); + if (params->m7 >= 0) + writel(params->m7, &dpll_regs->cm_div_m7_dpll); + + /* Wait till the DPLL locks */ + if (lock) + wait_for_lock(base); +} + +const struct dpll_params *get_core_dpll_params(void) +{ + u32 sysclk_ind = get_sys_clk_index(); + + switch (omap4_revision()) { + case OMAP4430_ES1_0: + return &core_dpll_params_es1_1524mhz[sysclk_ind]; + case OMAP4430_ES2_0: + case OMAP4430_SILICON_ID_INVALID: + /* safest */ + return &core_dpll_params_es2_1600mhz_ddr200mhz[sysclk_ind]; + default: + return &core_dpll_params_1600mhz[sysclk_ind]; + } +} + +u32 omap4_ddr_clk(void) +{ + u32 ddr_clk, sys_clk_khz; + const struct dpll_params *core_dpll_params; + + sys_clk_khz = get_sys_clk_freq() / 1000; + + core_dpll_params = get_core_dpll_params(); + + debug("sys_clk %d\n ", sys_clk_khz * 1000); + + /* Find Core DPLL locked frequency first */ + ddr_clk = sys_clk_khz * 2 * core_dpll_params->m / + (core_dpll_params->n + 1); + /* + * DDR frequency is PHY_ROOT_CLK/2 + * PHY_ROOT_CLK = Fdpll/2/M2 + */ + ddr_clk = ddr_clk / 4 / core_dpll_params->m2; + + ddr_clk *= 1000; /* convert to Hz */ + debug("ddr_clk %d\n ", ddr_clk); + + return ddr_clk; +} + +static void setup_dplls(void) +{ + u32 sysclk_ind, temp; + const struct dpll_params *params; + + sysclk_ind = get_sys_clk_index(); + + /* CORE dpll */ + params = get_core_dpll_params(); /* default - safest */ + /* + * Do not lock the core DPLL now. Just set it up. + * Core DPLL will be locked after setting up EMIF + * using the FREQ_UPDATE method(freq_update_core()) + */ + do_setup_dpll(CM_CLKMODE_DPLL_CORE, params, DPLL_NO_LOCK); + /* Set the ratios for CORE_CLK, L3_CLK, L4_CLK */ + temp = (CLKSEL_CORE_X2_DIV_1 << CLKSEL_CORE_SHIFT) | + (CLKSEL_L3_CORE_DIV_2 << CLKSEL_L3_SHIFT) | + (CLKSEL_L4_L3_DIV_2 << CLKSEL_L4_SHIFT); + writel(temp, CM_CLKSEL_CORE); + + /* lock PER dpll */ + do_setup_dpll(CM_CLKMODE_DPLL_PER, + &per_dpll_params_1536mhz[sysclk_ind], DPLL_LOCK); + + /* MPU dpll */ + if (omap4_revision() == OMAP4430_ES1_0) + params = &mpu_dpll_params_es1_600mhz[sysclk_ind]; + else + params = &mpu_dpll_params_1ghz[sysclk_ind]; + do_setup_dpll(CM_CLKMODE_DPLL_MPU, params, DPLL_LOCK); +} + +static void setup_non_essential_dplls(void) +{ + u32 sys_clk_khz, temp, abe_ref_clk; + u32 sysclk_ind, sd_div, num, den; + const struct dpll_params *params; + + sysclk_ind = get_sys_clk_index(); + sys_clk_khz = get_sys_clk_freq() / 1000; + + /* IVA */ + do_setup_dpll(CM_CLKMODE_DPLL_IVA, &iva_dpll_params_1862mhz[sysclk_ind], + DPLL_LOCK); + + /* + * USB: + * USB dpll is J-type. Need to set DPLL_SD_DIV for jitter correction + * DPLL_SD_DIV = CEILING ([DPLL_MULT/(DPLL_DIV+1)]* CLKINP / 250) + * - where CLKINP is sys_clk in MHz + * Use CLKINP in KHz and adjust the denominator accordingly so + * that we have enough accuracy and at the same time no overflow + */ + params = &usb_dpll_params_1920mhz[sysclk_ind]; + num = params->m * sys_clk_khz; + den = (params->n + 1) * 250 * 1000; + num += den - 1; + sd_div = num / den; + temp = readl(CM_CLKSEL_DPLL_USB); + set_bit_field(temp, CM_CLKSEL_DPLL_DPLL_SD_DIV_SHIFT, + CM_CLKSEL_DPLL_DPLL_SD_DIV_MASK, sd_div); + writel(temp, CM_CLKSEL_DPLL_USB); + + /* Now setup the dpll with the regular function */ + do_setup_dpll(CM_CLKMODE_DPLL_USB, params, DPLL_LOCK); + +#ifdef CONFIG_SYS_OMAP4_ABE_SYSCK + params = &abe_dpll_params_sysclk_196608khz[sysclk_ind]; + abe_ref_clk = CM_ABE_PLL_REF_CLKSEL_CLKSEL_SYSCLK; +#else + params = &abe_dpll_params_32k_196608khz; + abe_ref_clk = CM_ABE_PLL_REF_CLKSEL_CLKSEL_32KCLK; + + /* + * Enable REGM4XEN to achieve 196.608MHz from 32768 Hz + * We need an additional multiplier of 4 on the input frequency + * since the input frequency is very low + */ + writel(readl(CM_CLKMODE_DPLL_ABE) | CM_CLKMODE_DPLL_DPLL_REGM4XEN_MASK, + CM_CLKMODE_DPLL_ABE); +#endif + + /* Select the right reference clk */ + modify_reg_32(CM_ABE_PLL_REF_CLKSEL, + CM_ABE_PLL_REF_CLKSEL_CLKSEL_SHIFT, + CM_ABE_PLL_REF_CLKSEL_CLKSEL_MASK, + abe_ref_clk); + /* Lock the dpll */ + do_setup_dpll(CM_CLKMODE_DPLL_ABE, params, DPLL_LOCK); +} + +static void do_scale_vcore(u32 vcore_reg, u32 volt) +{ + u32 temp; + + temp = SMPS_I2C_SLAVE_ADDR | + (vcore_reg << PRM_VC_VAL_BYPASS_REGADDR_SHIFT) | + (volt << PRM_VC_VAL_BYPASS_DATA_SHIFT) | + PRM_VC_VAL_BYPASS_VALID_BIT; + writel(temp, PRM_VC_VAL_BYPASS); + while (readl(PRM_VC_VAL_BYPASS) & PRM_VC_VAL_BYPASS_VALID_BIT) + ; +} + +static void scale_vcores(void) +{ + u32 volt, sys_clk_khz, cycles_hi, cycles_low, temp; + u32 omap4_rev = omap4_revision(); + + sys_clk_khz = get_sys_clk_freq() / 1000; + + /* + * Setup the dedicated I2C controller for Voltage Control + * I2C clk - high period 40% low period 60% + */ + cycles_hi = sys_clk_khz * 4 / PRM_VC_I2C_CHANNEL_FREQ_KHZ / 10; + cycles_low = sys_clk_khz * 6 / PRM_VC_I2C_CHANNEL_FREQ_KHZ / 10; + /* values to be set in register - less by 5 & 7 respectively */ + cycles_hi -= 5; + cycles_low -= 7; + temp = (cycles_hi << PRM_VC_CFG_I2C_CLK_SCLH_SHIFT) | + (cycles_low << PRM_VC_CFG_I2C_CLK_SCLL_SHIFT); + writel(temp, PRM_VC_CFG_I2C_CLK); + + /* Disable high speed mode and all advanced features */ + writel(0x0, PRM_VC_CFG_I2C_MODE); + + /* VCORE 1 */ + if ((omap4_rev == OMAP4430_ES2_0) || (omap4_rev == OMAP4430_ES2_1)) + volt = SMPS_VOLT_1_3500_V; + else + volt = SMPS_VOLT_1_5000_V; + do_scale_vcore(SMPS_REG_ADDR_VCORE1, volt); + + /* VCORE 2 */ + if ((omap4_rev == OMAP4430_ES2_0) || (omap4_rev == OMAP4430_ES2_1)) + volt = SMPS_VOLT_1_1000_V; + else + volt = SMPS_VOLT_1_2000_V; + do_scale_vcore(SMPS_REG_ADDR_VCORE2, volt); + + /* VCORE 3 */ + if (omap4_rev == OMAP4430_ES2_0) + volt = SMPS_VOLT_1_1000_V; + else if (omap4_rev == OMAP4430_ES2_1) + volt = SMPS_VOLT_1_1125_V; + else + volt = SMPS_VOLT_1_2000_V; + + do_scale_vcore(SMPS_REG_ADDR_VCORE3, volt); +} + +static void enable_clock_domain(u32 clkctrl_reg, u32 enable_mode) +{ + modify_reg_32(clkctrl_reg, CD_CLKCTRL_CLKTRCTRL_SHIFT, + CD_CLKCTRL_CLKTRCTRL_MASK, enable_mode); +} + +static inline void wait_for_clk_enable(u32 clkctrl_addr) +{ + u32 idlest = MODULE_CLKCTRL_IDLEST_DISABLED; + + while ((idlest == MODULE_CLKCTRL_IDLEST_DISABLED) || + (idlest == MODULE_CLKCTRL_IDLEST_TRANSITIONING)) { + idlest = readl(clkctrl_addr); + idlest = get_bit_field(idlest, MODULE_CLKCTRL_IDLEST_SHIFT, + MODULE_CLKCTRL_IDLEST_MASK); + } +} + +static void enable_clock_module(u32 clkctrl_addr, u32 enable_mode, + u32 wait_for_enable) +{ + modify_reg_32(clkctrl_addr, MODULE_CLKCTRL_MODULEMODE_SHIFT, + MODULE_CLKCTRL_MODULEMODE_MASK, enable_mode); + if (wait_for_enable) + wait_for_clk_enable(clkctrl_addr); +} + +/* + * Enable a set of clock domains and clock modules associated with them + */ +static void enable_clocks(const u32 *clock_domains, + const u32 *clock_modules_hw_auto, + const u32 *clock_modules_explicit_en, + u32 wait_for_enable) +{ + int i = 0, max = 100; + /* Put the clock domains in SW_WKUP mode */ + for (i = 0; (i < max) && clock_domains[i]; i++) { + enable_clock_domain(clock_domains[i], + CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + } + + /* Clock modules that need to be put in HW_AUTO */ + for (i = 0; (i < max) && clock_modules_hw_auto[i]; i++) { + enable_clock_module(clock_modules_hw_auto[i], + MODULE_CLKCTRL_MODULEMODE_HW_AUTO, + wait_for_enable); + }; + + /* Clock modules that need to be put in SW_EXPLICIT_EN mode */ + for (i = 0; (i < max) && clock_modules_explicit_en[i]; i++) { + enable_clock_module(clock_modules_explicit_en[i], + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN, + wait_for_enable); + }; + + /* Put the clock domains in HW_AUTO mode now */ + for (i = 0; (i < max) && clock_domains[i]; i++) { + enable_clock_domain(clock_domains[i], + CD_CLKCTRL_CLKTRCTRL_HW_AUTO); + } +} + +/* + * Enable essential clock domains, modules and + * do some additional special settings needed + */ +static void enable_basic_clocks(void) +{ + /* Enable optional additional functional clock for GPIO4 */ + writel(readl(CM_L4PER_GPIO4_CLKCTRL) | GPIO4_CLKCTRL_OPTFCLKEN_MASK, + CM_L4PER_GPIO4_CLKCTRL); + + /* Enable 96 MHz clock for MMC1 & MMC2 */ + writel(readl(CM_L3INIT_HSMMC1_CLKCTRL) | HSMMC_CLKCTRL_CLKSEL_MASK, + CM_L3INIT_HSMMC1_CLKCTRL); + writel(readl(CM_L3INIT_HSMMC2_CLKCTRL) | HSMMC_CLKCTRL_CLKSEL_MASK, + CM_L3INIT_HSMMC2_CLKCTRL); + + /* Select 32KHz clock as the source of GPTIMER1 */ + writel(readl(CM_WKUP_GPTIMER1_CLKCTRL) | GPTIMER1_CLKCTRL_CLKSEL_MASK, + CM_WKUP_GPTIMER1_CLKCTRL); + + /* Enable optional 48M functional clock for USB PHY */ + writel(readl(CM_L3INIT_USBPHY_CLKCTRL) | + USBPHY_CLKCTRL_OPTFCLKEN_PHY_48M_MASK, CM_L3INIT_USBPHY_CLKCTRL); + + /* Enable all essential clock domains and modules */ + enable_clocks(clk_domains_essential, + clk_modules_hw_auto_essential, + clk_modules_explicit_en_essential, 1); +} + +/* + * Enable non-essential clock domains, modules and + * do some additional special settings needed + */ +static void enable_non_essential_clocks(void) +{ + u32 tmp; + /* Enable optional functional clock for ISS */ + writel(readl(CM_CAM_ISS_CLKCTRL) | ISS_CLKCTRL_OPTFCLKEN_MASK, + CM_CAM_ISS_CLKCTRL); + + /* Enable all optional functional clocks of DSS */ + writel(readl(CM_DSS_DSS_CLKCTRL) | DSS_CLKCTRL_OPTFCLKEN_MASK, + CM_DSS_DSS_CLKCTRL); + + /* Enable all non-essential clock domains and modules */ + enable_clocks(clk_domains_non_essential, + clk_modules_hw_auto_non_essential, + clk_modules_explicit_en_non_essential, 0); + + /* Put camera module in no sleep mode */ + tmp = readl(CM_CAM_CLKSTCTRL); + set_bit_field(tmp, MODULE_CLKCTRL_MODULEMODE_SHIFT, + MODULE_CLKCTRL_MODULEMODE_MASK, + CD_CLKCTRL_CLKTRCTRL_NO_SLEEP); + writel(tmp, CM_CAM_CLKSTCTRL); +} + +void freq_update_core(void) +{ + u32 freq_config1 = 0; + const struct dpll_params *core_dpll_params; + + core_dpll_params = get_core_dpll_params(); + /* Put EMIF clock domain in sw wakeup mode */ + enable_clock_domain(CM_MEMIF_CLKSTCTRL, CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + wait_for_clk_enable(CM_MEMIF_EMIF_1_CLKCTRL); + wait_for_clk_enable(CM_MEMIF_EMIF_2_CLKCTRL); + + freq_config1 = SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK | + SHADOW_FREQ_CONFIG1_DLL_RESET_MASK; + + set_bit_field(freq_config1, SHADOW_FREQ_CONFIG1_DPLL_EN_SHIFT, + SHADOW_FREQ_CONFIG1_DPLL_EN_MASK, DPLL_EN_LOCK); + + set_bit_field(freq_config1, SHADOW_FREQ_CONFIG1_M2_DIV_SHIFT, + SHADOW_FREQ_CONFIG1_M2_DIV_MASK, core_dpll_params->m2); + + writel(freq_config1, CM_SHADOW_FREQ_CONFIG1); + while (readl(CM_SHADOW_FREQ_CONFIG1) & + SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK) + ; + + /* Put EMIF clock domain back in hw auto mode */ + enable_clock_domain(CM_MEMIF_CLKSTCTRL, CD_CLKCTRL_CLKTRCTRL_HW_AUTO); + wait_for_clk_enable(CM_MEMIF_EMIF_1_CLKCTRL); + wait_for_clk_enable(CM_MEMIF_EMIF_2_CLKCTRL); +} + +void bypass_dpll(u32 base) +{ + do_bypass_dpll(base); + wait_for_bypass(base); +} + +void lock_dpll(u32 base) +{ + do_lock_dpll(base); + wait_for_lock(base); +} + +void prcm_init(void) +{ + switch (omap4_hw_init_context()) { + case OMAP_INIT_CONTEXT_SPL: + case OMAP_INIT_CONTEXT_XIP_UBOOT: + case OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_CH: + scale_vcores(); + setup_dplls(); + enable_basic_clocks(); + setup_non_essential_dplls(); + enable_non_essential_clocks(); + break; + default: + break; + } +} diff --git a/arch/arm/cpu/armv7/omap4/clocks_get_m_n.c b/arch/arm/cpu/armv7/omap4/clocks_get_m_n.c new file mode 100644 index 0000000..777ec11 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/clocks_get_m_n.c @@ -0,0 +1,154 @@ +/* + * Program for finding M & N values for DPLLs + * To be run on Host PC + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <stdlib.h> +#include <stdio.h> +typedef unsigned int u32; +#define MAX_N 127 +int get_m_n_optimized(u32 target_freq_khz, u32 ref_freq_khz, u32 *m, u32 *n, + u32 n_max_limit, u32 tolerance_khz) +{ + u32 min_freq = target_freq_khz - tolerance_khz; + u32 max_freq = target_freq_khz; + u32 freq, freq_old; + *n = 1; + while (1) { + *m = min_freq / ref_freq_khz / 2 * (*n) ; + freq_old = 0; + while (1) { + freq = ref_freq_khz * 2 * (*m) / (*n); + if (abs(target_freq_khz - freq_old) <= + abs(target_freq_khz - freq)) { + freq = freq_old; + (*m)--; + break; + } + (*m)++; + freq_old = freq; + } + if (freq >= min_freq && freq <= max_freq) + break; + (*n)++; + if ((*n) > MAX_N + 1) { + printf("ref %d m %d n %d target %d : ", + ref_freq_khz, *m, *n, target_freq_khz); + printf("can not find m & n - please consider" + " increasing tolerance\n"); + return -1; + } + } + (*n)--; + printf("ref %d m %d n %d target %d locked %d\n", + ref_freq_khz, *m, *n, target_freq_khz, freq); + if ((ref_freq_khz / (*n + 1)) < 1000) { + printf("\tREFCLK - CLKINP/(N+1) is less than 1 MHz - less than" + " ideal, locking time will be high!\n"); + } + return 0; +} + +void main(void) +{ + u32 m, n; + printf("\nMPU - 2000000\n"); + get_m_n_optimized(2000000, 12000, &m, &n, 128, 0); + get_m_n_optimized(2000000, 13000, &m, &n, 128, 0); + get_m_n_optimized(2000000, 16800, &m, &n, 128, 800); + get_m_n_optimized(2000000, 19200, &m, &n, 128, 0); + get_m_n_optimized(2000000, 26000, &m, &n, 128, 0); + get_m_n_optimized(2000000, 27000, &m, &n, 128, 0); + get_m_n_optimized(2000000, 38400, &m, &n, 128, 0); + + printf("\nMPU - 1200000\n"); + get_m_n_optimized(1200000, 12000, &m, &n, 128, 0); + get_m_n_optimized(1200000, 13000, &m, &n, 128, 0); + get_m_n_optimized(1200000, 16800, &m, &n, 128, 800); + get_m_n_optimized(1200000, 19200, &m, &n, 128, 0); + get_m_n_optimized(1200000, 26000, &m, &n, 128, 0); + get_m_n_optimized(1200000, 27000, &m, &n, 128, 0); + get_m_n_optimized(1200000, 38400, &m, &n, 128, 0); + + printf("\nCore 1600000\n"); + get_m_n_optimized(1600000, 12000, &m, &n, 128, 0); + get_m_n_optimized(1600000, 13000, &m, &n, 128, 0); + get_m_n_optimized(1600000, 16800, &m, &n, 128, 200); + get_m_n_optimized(1600000, 19200, &m, &n, 128, 0); + get_m_n_optimized(1600000, 26000, &m, &n, 128, 0); + get_m_n_optimized(1600000, 27000, &m, &n, 128, 0); + get_m_n_optimized(1600000, 38400, &m, &n, 128, 0); + + printf("\nPER 1536000\n"); + get_m_n_optimized(1536000, 12000, &m, &n, 128, 0); + get_m_n_optimized(1536000, 13000, &m, &n, 128, 0); + get_m_n_optimized(1536000, 16800, &m, &n, 128, 0); + get_m_n_optimized(1536000, 19200, &m, &n, 128, 0); + get_m_n_optimized(1536000, 26000, &m, &n, 128, 0); + get_m_n_optimized(1536000, 27000, &m, &n, 128, 0); + get_m_n_optimized(1536000, 38400, &m, &n, 128, 0); + + printf("\nIVA 1862000\n"); + get_m_n_optimized(1862000, 12000, &m, &n, 128, 0); + get_m_n_optimized(1862000, 13000, &m, &n, 128, 0); + get_m_n_optimized(1862000, 16800, &m, &n, 128, 0); + get_m_n_optimized(1862000, 19200, &m, &n, 128, 900); + get_m_n_optimized(1862000, 26000, &m, &n, 128, 0); + get_m_n_optimized(1862000, 27000, &m, &n, 128, 0); + get_m_n_optimized(1862000, 38400, &m, &n, 128, 800); + + printf("\nABE 196608 sys clk\n"); + get_m_n_optimized(196608, 12000, &m, &n, 128, 700); + get_m_n_optimized(196608, 13000, &m, &n, 128, 200); + get_m_n_optimized(196608, 16800, &m, &n, 128, 700); + get_m_n_optimized(196608, 19200, &m, &n, 128, 400); + get_m_n_optimized(196608, 26000, &m, &n, 128, 200); + get_m_n_optimized(196608, 27000, &m, &n, 128, 900); + get_m_n_optimized(196608, 38400, &m, &n, 128, 0); + + printf("\nABE 196608 32K\n"); + get_m_n_optimized(196608000/4, 32768, &m, &n, 128, 0); + + printf("\nUSB 1920000\n"); + get_m_n_optimized(1920000, 12000, &m, &n, 128, 0); + get_m_n_optimized(1920000, 13000, &m, &n, 128, 0); + get_m_n_optimized(1920000, 16800, &m, &n, 128, 0); + get_m_n_optimized(1920000, 19200, &m, &n, 128, 0); + get_m_n_optimized(1920000, 26000, &m, &n, 128, 0); + get_m_n_optimized(1920000, 27000, &m, &n, 128, 0); + get_m_n_optimized(1920000, 38400, &m, &n, 128, 0); + + printf("\nCore ES1 1523712\n"); + get_m_n_optimized(1524000, 12000, &m, &n, 128, 100); + get_m_n_optimized(1524000, 13000, &m, &n, 128, 0); + get_m_n_optimized(1524000, 16800, &m, &n, 128, 0); + get_m_n_optimized(1524000, 19200, &m, &n, 128, 0); + get_m_n_optimized(1524000, 26000, &m, &n, 128, 0); + get_m_n_optimized(1524000, 27000, &m, &n, 128, 0); + + /* exact recommendation for SDPs */ + get_m_n_optimized(1523712, 38400, &m, &n, 128, 0); + +} diff --git a/arch/arm/include/asm/arch-omap4/clocks.h b/arch/arm/include/asm/arch-omap4/clocks.h new file mode 100644 index 0000000..aec1241 --- /dev/null +++ b/arch/arm/include/asm/arch-omap4/clocks.h @@ -0,0 +1,506 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _CLOCKS_OMAP4_H_ +#define _CLOCKS_OMAP4_H_ +#include <common.h> + +#define CM_CLKMODE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4120) +#define CM_CLKMODE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8140) +#define CM_CLKMODE_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4160) +#define CM_CLKSEL_CORE (OMAP44XX_L4_CORE_BASE + 0x4100) + +/* PRM.CKGEN module registers */ +#define CM_ABE_PLL_REF_CLKSEL (OMAP44XX_L4_WKUP_BASE + 0x610C) +#define CM_SYS_CLKSEL (OMAP44XX_L4_WKUP_BASE + 0x6110) + +/* PRM.WKUP_CM module registers */ +#define CM_WKUP_CLKSTCTRL (OMAP44XX_L4_WKUP_BASE + 0x7800) +#define CM_WKUP_L4WKUP_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7820) +#define CM_WKUP_WDTIMER1_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7828) +#define CM_WKUP_WDTIMER2_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7830) +#define CM_WKUP_GPIO1_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7838) +#define CM_WKUP_GPTIMER1_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7840) +#define CM_WKUP_GPTIMER12_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7848) +#define CM_WKUP_SYNCTIMER_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7850) +#define CM_WKUP_USIM_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7858) +#define CM_WKUP_SARRAM_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7860) +#define CM_WKUP_KEYBOARD_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7878) +#define CM_WKUP_RTC_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7880) +#define CM_WKUP_BANDGAP_CLKCTRL (OMAP44XX_L4_WKUP_BASE + 0x7888) + +/* DEVICE_PRM Registers */ +#define PRM_VC_VAL_BYPASS (OMAP44XX_L4_WKUP_BASE + 0x7BA0) +#define PRM_VC_CFG_CHANNEL (OMAP44XX_L4_WKUP_BASE + 0x7BA4) +#define PRM_VC_CFG_I2C_MODE (OMAP44XX_L4_WKUP_BASE + 0x7BA8) +#define PRM_VC_CFG_I2C_CLK (OMAP44XX_L4_WKUP_BASE + 0x7BAC) + +/* CM1.CKGEN module registers */ +#define CM_CLKSEL_CORE (OMAP44XX_L4_CORE_BASE + 0x4100) +#define CM_CLKSEL_ABE (OMAP44XX_L4_CORE_BASE + 0x4108) +#define CM_DLL_CTRL (OMAP44XX_L4_CORE_BASE + 0x4110) +#define CM_CLKMODE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4120) +#define CM_IDLEST_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4124) +#define CM_AUTOIDLE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4128) +#define CM_CLKSEL_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x412c) +#define CM_DIV_M2_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4130) +#define CM_DIV_M3_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4134) +#define CM_DIV_M4_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4138) +#define CM_DIV_M5_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x413c) +#define CM_DIV_M6_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4140) +#define CM_DIV_M7_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4144) +#define CM_SSC_DELTAMSTEP_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4148) +#define CM_SSC_MODFREQDIV_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x414c) +#define CM_EMU_OVERRIDE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4150) +#define CM_CLKMODE_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4160) +#define CM_IDLEST_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4164) +#define CM_AUTOIDLE_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4168) +#define CM_CLKSEL_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x416c) +#define CM_DIV_M2_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4170) +#define CM_SSC_DELTAMSTEP_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4188) +#define CM_SSC_MODFREQDIV_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x418c) +#define CM_BYPCLK_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x419c) +#define CM_CLKMODE_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41a0) +#define CM_IDLEST_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41a4) +#define CM_AUTOIDLE_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41a8) +#define CM_CLKSEL_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41ac) +#define CM_DIV_M4_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41b8) +#define CM_DIV_M5_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41bc) +#define CM_SSC_DELTAMSTEP_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41c8) +#define CM_SSC_MODFREQDIV_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41cc) +#define CM_BYPCLK_DPLL_IVA (OMAP44XX_L4_CORE_BASE + 0x41dc) +#define CM_CLKMODE_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x41e0) +#define CM_IDLEST_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x41e4) +#define CM_AUTOIDLE_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x41e8) +#define CM_CLKSEL_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x41ec) +#define CM_DIV_M2_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x41f0) +#define CM_DIV_M3_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x41f4) +#define CM_SSC_DELTAMSTEP_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x4208) +#define CM_SSC_MODFREQDIV_DPLL_ABE (OMAP44XX_L4_CORE_BASE + 0x420c) +#define CM_CLKMODE_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4220) +#define CM_IDLEST_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4224) +#define CM_AUTOIDLE_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4228) +#define CM_CLKSEL_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x422c) +#define CM_DIV_M2_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4230) +#define CM_DIV_M4_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4238) +#define CM_DIV_M5_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x423c) +#define CM_DIV_M6_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4240) +#define CM_SSC_DELTAMSTEP_DPLL_DDRPHY (OMAP44XX_L4_CORE_BASE + 0x4248) +#define CM_SHADOW_FREQ_CONFIG1 (OMAP44XX_L4_CORE_BASE + 0x4260) + +/* CM1.ABE register offsets */ +#define CM1_ABE_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x4500) +#define CM1_ABE_L4ABE_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4520) +#define CM1_ABE_AESS_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4528) +#define CM1_ABE_PDM_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4530) +#define CM1_ABE_DMIC_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4538) +#define CM1_ABE_MCASP_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4540) +#define CM1_ABE_MCBSP1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4548) +#define CM1_ABE_MCBSP2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4550) +#define CM1_ABE_MCBSP3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4558) +#define CM1_ABE_SLIMBUS_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4560) +#define CM1_ABE_TIMER5_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4568) +#define CM1_ABE_TIMER6_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4570) +#define CM1_ABE_TIMER7_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4578) +#define CM1_ABE_TIMER8_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4580) +#define CM1_ABE_WDT3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4588) + +/* CM1.DSP register offsets */ +#define CM_DSP_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x4400) +#define CM_DSP_DSP_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x4420) + +/* CM2.CKGEN module registers */ +#define CM_CLKSEL_MPU_M3_ISS_ROOT (OMAP44XX_L4_CORE_BASE + 0x8100) +#define CM_CLKSEL_USB_60MHz (OMAP44XX_L4_CORE_BASE + 0x8104) +#define CM_SCALE_FCLK (OMAP44XX_L4_CORE_BASE + 0x8108) +#define CM_CORE_DVFS_PERF1 (OMAP44XX_L4_CORE_BASE + 0x8110) +#define CM_CORE_DVFS_PERF2 (OMAP44XX_L4_CORE_BASE + 0x8114) +#define CM_CORE_DVFS_PERF3 (OMAP44XX_L4_CORE_BASE + 0x8118) +#define CM_CORE_DVFS_PERF4 (OMAP44XX_L4_CORE_BASE + 0x811c) +#define CM_CORE_DVFS_CURRENT (OMAP44XX_L4_CORE_BASE + 0x8124) +#define CM_IVA_DVFS_PERF_TESLA (OMAP44XX_L4_CORE_BASE + 0x8128) +#define CM_IVA_DVFS_PERF_IVAHD (OMAP44XX_L4_CORE_BASE + 0x812c) +#define CM_IVA_DVFS_PERF_ABE (OMAP44XX_L4_CORE_BASE + 0x8130) +#define CM_IVA_DVFS_CURRENT (OMAP44XX_L4_CORE_BASE + 0x8138) +#define CM_CLKMODE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8140) +#define CM_IDLEST_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8144) +#define CM_AUTOIDLE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8148) +#define CM_CLKSEL_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x814c) +#define CM_DIV_M2_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8150) +#define CM_DIV_M3_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8154) +#define CM_DIV_M4_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8158) +#define CM_DIV_M5_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x815c) +#define CM_DIV_M6_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8160) +#define CM_DIV_M7_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8164) +#define CM_SSC_DELTAMSTEP_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8168) +#define CM_SSC_MODFREQDIV_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x816c) +#define CM_EMU_OVERRIDE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8170) +#define CM_CLKMODE_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x8180) +#define CM_IDLEST_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x8184) +#define CM_AUTOIDLE_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x8188) +#define CM_CLKSEL_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x818c) +#define CM_DIV_M2_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x8190) +#define CM_SSC_DELTAMSTEP_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x81a8) +#define CM_SSC_MODFREQDIV_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x81ac) +#define CM_CLKDCOLDO_DPLL_USB (OMAP44XX_L4_CORE_BASE + 0x81b4) +#define CM_CLKMODE_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81c0) +#define CM_IDLEST_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81c4) +#define CM_AUTOIDLE_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81c8) +#define CM_CLKSEL_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81cc) +#define CM_DIV_M2_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81d0) +#define CM_SSC_DELTAMSTEP_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81e8) +#define CM_SSC_MODFREQDIV_DPLL_UNIPRO (OMAP44XX_L4_CORE_BASE + 0x81ec) + +/* CM2.CORE module registers */ +#define CM_L3_1_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8700) +#define CM_L3_1_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x8708) +#define CM_L3_1_L3_1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8720) +#define CM_L3_2_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8800) +#define CM_L3_2_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x8808) +#define CM_L3_2_L3_2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8820) +#define CM_L3_2_GPMC_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8828) +#define CM_L3_2_OCMC_RAM_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8830) +#define CM_MPU_M3_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8900) +#define CM_MPU_M3_STATICDEP (OMAP44XX_L4_CORE_BASE + 0x8904) +#define CM_MPU_M3_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x8908) +#define CM_MPU_M3_MPU_M3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8920) +#define CM_SDMA_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8a00) +#define CM_SDMA_STATICDEP (OMAP44XX_L4_CORE_BASE + 0x8a04) +#define CM_SDMA_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x8a08) +#define CM_SDMA_SDMA_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8a20) +#define CM_MEMIF_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8b00) +#define CM_MEMIF_DMM_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b20) +#define CM_MEMIF_EMIF_FW_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b28) +#define CM_MEMIF_EMIF_1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b30) +#define CM_MEMIF_EMIF_2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b38) +#define CM_MEMIF_DLL_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b40) +#define CM_MEMIF_EMIF_H1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b50) +#define CM_MEMIF_EMIF_H2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b58) +#define CM_MEMIF_DLL_H_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8b60) +#define CM_C2C_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8c00) +#define CM_C2C_STATICDEP (OMAP44XX_L4_CORE_BASE + 0x8c04) +#define CM_C2C_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x8c08) +#define CM_C2C_SAD2D_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8c20) +#define CM_C2C_MODEM_ICR_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8c28) +#define CM_C2C_SAD2D_FW_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8c30) +#define CM_L4CFG_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8d00) +#define CM_L4CFG_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x8d08) +#define CM_L4CFG_L4_CFG_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8d20) +#define CM_L4CFG_HW_SEM_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8d28) +#define CM_L4CFG_MAILBOX_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8d30) +#define CM_L4CFG_SAR_ROM_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8d38) +#define CM_L3INSTR_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8e00) +#define CM_L3INSTR_L3_3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8e20) +#define CM_L3INSTR_L3_INSTR_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8e28) +#define CM_L3INSTR_INTRCONN_WP1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8e40) + +/* CM2.L3INIT register offsets */ +#define CM_L3INIT_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x9300) + +/* CM2.L4PER register offsets */ +#define CM_L4PER_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x9400) +#define CM_L4PER_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x9408) +#define CM_L4PER_ADC_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9420) +#define CM_L4PER_GPTIMER10_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9428) +#define CM_L4PER_GPTIMER11_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9430) +#define CM_L4PER_GPTIMER2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9438) +#define CM_L4PER_GPTIMER3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9440) +#define CM_L4PER_GPTIMER4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9448) +#define CM_L4PER_GPTIMER9_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9450) +#define CM_L4PER_ELM_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9458) +#define CM_L4PER_GPIO2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9460) +#define CM_L4PER_GPIO3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9468) +#define CM_L4PER_GPIO4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9470) +#define CM_L4PER_GPIO5_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9478) +#define CM_L4PER_GPIO6_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9480) +#define CM_L4PER_HDQ1W_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9488) +#define CM_L4PER_HECC1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9490) +#define CM_L4PER_HECC2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9498) +#define CM_L4PER_I2C1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94a0) +#define CM_L4PER_I2C2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94a8) +#define CM_L4PER_I2C3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94b0) +#define CM_L4PER_I2C4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94b8) +#define CM_L4PER_L4PER_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94c0) +#define CM_L4PER_MCASP2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94d0) +#define CM_L4PER_MCASP3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94d8) +#define CM_L4PER_MCBSP4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94e0) +#define CM_L4PER_MGATE_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94e8) +#define CM_L4PER_MCSPI1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94f0) +#define CM_L4PER_MCSPI2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x94f8) +#define CM_L4PER_MCSPI3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9500) +#define CM_L4PER_MCSPI4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9508) +#define CM_L4PER_MMCSD3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9520) +#define CM_L4PER_MMCSD4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9528) +#define CM_L4PER_MSPROHG_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9530) +#define CM_L4PER_SLIMBUS2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9538) +#define CM_L4PER_UART1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9540) +#define CM_L4PER_UART2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9548) +#define CM_L4PER_UART3_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9550) +#define CM_L4PER_UART4_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9558) +#define CM_L4PER_MMCSD5_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9560) +#define CM_L4PER_I2C5_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9568) +#define CM_L4SEC_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x9580) +#define CM_L4SEC_STATICDEP (OMAP44XX_L4_CORE_BASE + 0x9584) +#define CM_L4SEC_DYNAMICDEP (OMAP44XX_L4_CORE_BASE + 0x9588) +#define CM_L4SEC_AES1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95a0) +#define CM_L4SEC_AES2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95a8) +#define CM_L4SEC_DES3DES_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95b0) +#define CM_L4SEC_PKAEIP29_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95b8) +#define CM_L4SEC_RNG_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95c0) +#define CM_L4SEC_SHA2MD51_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95c8) +#define CM_L4SEC_CRYPTODMA_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x95d8) + +/* CM2.IVAHD */ +#define CM_IVAHD_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x8f00) +#define CM_IVAHD_IVAHD_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8f20) +#define CM_IVAHD_SL2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x8f28) + +/* CM2.L3INIT */ +#define CM_L3INIT_HSMMC1_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9328) +#define CM_L3INIT_HSMMC2_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9330) +#define CM_L3INIT_HSI_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9338) +#define CM_L3INIT_HSUSBHOST_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9358) +#define CM_L3INIT_HSUSBOTG_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9360) +#define CM_L3INIT_HSUSBTLL_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9368) +#define CM_L3INIT_P1500_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9378) +#define CM_L3INIT_FSUSB_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x93d0) +#define CM_L3INIT_USBPHY_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x93e0) + +/* CM2.CAM */ +#define CM_CAM_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x9000) +#define CM_CAM_ISS_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9020) +#define CM_CAM_FDIF_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9028) + +/* CM2.DSS */ +#define CM_DSS_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x9100) +#define CM_DSS_DSS_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9120) + +/* CM2.SGX */ +#define CM_SGX_CLKSTCTRL (OMAP44XX_L4_CORE_BASE + 0x9200) +#define CM_SGX_SGX_CLKCTRL (OMAP44XX_L4_CORE_BASE + 0x9220) + +/* DPLL register offsets */ +#define CM_CLKMODE_DPLL 0 +#define CM_IDLEST_DPLL 0x4 +#define CM_AUTOIDLE_DPLL 0x8 +#define CM_CLKSEL_DPLL 0xC +#define CM_DIV_M2_DPLL 0x10 +#define CM_DIV_M3_DPLL 0x14 +#define CM_DIV_M4_DPLL 0x18 +#define CM_DIV_M5_DPLL 0x1C +#define CM_DIV_M6_DPLL 0x20 +#define CM_DIV_M7_DPLL 0x24 + +#define DPLL_CLKOUT_DIV_MASK 0x1F /* post-divider mask */ + +/* CM_CLKMODE_DPLL */ +#define CM_CLKMODE_DPLL_DPLL_REGM4XEN_MASK 11 +#define CM_CLKMODE_DPLL_DPLL_EN_SHIFT 0 +#define CM_CLKMODE_DPLL_DPLL_EN_SHIFT 0 +#define CM_CLKMODE_DPLL_DPLL_EN_MASK 7 + +#define DPLL_EN_STOP 1 +#define DPLL_EN_MN_BYPASS 4 +#define DPLL_EN_LOW_POWER_BYPASS 5 +#define DPLL_EN_FAST_RELOCK_BYPASS 6 +#define DPLL_EN_LOCK 7 + +/* CM_IDLEST_DPLL fields */ +#define ST_DPLL_CLK_MASK 1 + +/* CM_CLKSEL_DPLL */ +#define CM_CLKSEL_DPLL_DPLL_SD_DIV_SHIFT 24 +#define CM_CLKSEL_DPLL_DPLL_SD_DIV_MASK (0xFF << 24) +#define CM_CLKSEL_DPLL_M_SHIFT 8 +#define CM_CLKSEL_DPLL_M_MASK (0x7FF << 8) +#define CM_CLKSEL_DPLL_N_SHIFT 0 +#define CM_CLKSEL_DPLL_N_MASK 0x7F + +#define OMAP4_DPLL_MAX_N 127 + +/* CM_SYS_CLKSEL */ +#define CM_SYS_CLKSEL_SYS_CLKSEL_MASK 7 + +/* CM_CLKSEL_CORE */ +#define CLKSEL_CORE_SHIFT 0 +#define CLKSEL_L3_SHIFT 4 +#define CLKSEL_L4_SHIFT 8 + +#define CLKSEL_CORE_X2_DIV_1 0 +#define CLKSEL_L3_CORE_DIV_2 1 +#define CLKSEL_L4_L3_DIV_2 1 + +/* CM_ABE_PLL_REF_CLKSEL */ +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_SHIFT 0 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_MASK 1 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_SYSCLK 0 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_32KCLK 1 + + +/* CM_SHADOW_FREQ_CONFIG1 */ +#define SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK 1 +#define SHADOW_FREQ_CONFIG1_DLL_OVERRIDE_MASK 4 +#define SHADOW_FREQ_CONFIG1_DLL_RESET_MASK 8 + +#define SHADOW_FREQ_CONFIG1_DPLL_EN_SHIFT 8 +#define SHADOW_FREQ_CONFIG1_DPLL_EN_MASK (7 << 8) + +#define SHADOW_FREQ_CONFIG1_M2_DIV_SHIFT 11 +#define SHADOW_FREQ_CONFIG1_M2_DIV_MASK (0x1F << 11) + +/*CM_<clock_domain>__CLKCTRL */ +#define CD_CLKCTRL_CLKTRCTRL_SHIFT 0 +#define CD_CLKCTRL_CLKTRCTRL_MASK 3 + +#define CD_CLKCTRL_CLKTRCTRL_NO_SLEEP 0 +#define CD_CLKCTRL_CLKTRCTRL_SW_SLEEP 1 +#define CD_CLKCTRL_CLKTRCTRL_SW_WKUP 2 +#define CD_CLKCTRL_CLKTRCTRL_HW_AUTO 3 + + +/* CM_<clock_domain>_<module>_CLKCTRL */ +#define MODULE_CLKCTRL_MODULEMODE_SHIFT 0 +#define MODULE_CLKCTRL_MODULEMODE_MASK 3 +#define MODULE_CLKCTRL_IDLEST_SHIFT 16 +#define MODULE_CLKCTRL_IDLEST_MASK (3 << 16) + +#define MODULE_CLKCTRL_MODULEMODE_SW_DISABLE 0 +#define MODULE_CLKCTRL_MODULEMODE_HW_AUTO 1 +#define MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN 2 + +#define MODULE_CLKCTRL_IDLEST_FULLY_FUNCTIONAL 0 +#define MODULE_CLKCTRL_IDLEST_TRANSITIONING 1 +#define MODULE_CLKCTRL_IDLEST_IDLE 2 +#define MODULE_CLKCTRL_IDLEST_DISABLED 3 + +/* CM_L4PER_GPIO4_CLKCTRL */ +#define GPIO4_CLKCTRL_OPTFCLKEN_MASK (1 << 8) + +/* CM_L3INIT_HSMMCn_CLKCTRL */ +#define HSMMC_CLKCTRL_CLKSEL_MASK (1 << 24) + +/* CM_WKUP_GPTIMER1_CLKCTRL */ +#define GPTIMER1_CLKCTRL_CLKSEL_MASK (1 << 24) + +/* CM_CAM_ISS_CLKCTRL */ +#define ISS_CLKCTRL_OPTFCLKEN_MASK (1 << 8) + +/* CM_DSS_DSS_CLKCTRL */ +#define DSS_CLKCTRL_OPTFCLKEN_MASK 0xF00 + +/* CM_L3INIT_USBPHY_CLKCTRL */ +#define USBPHY_CLKCTRL_OPTFCLKEN_PHY_48M_MASK 8 + +/* Clock frequencies */ +#define OMAP_SYS_CLK_FREQ_38_4_MHZ 38400000 +#define OMAP_SYS_CLK_IND_38_4_MHZ 6 +#define OMAP_32K_CLK_FREQ 32768 + +/* PRM_VC_CFG_I2C_CLK */ +#define PRM_VC_CFG_I2C_CLK_SCLH_SHIFT 0 +#define PRM_VC_CFG_I2C_CLK_SCLH_MASK 0xFF +#define PRM_VC_CFG_I2C_CLK_SCLL_SHIFT 8 +#define PRM_VC_CFG_I2C_CLK_SCLL_MASK (0xFF << 8) + +/* PRM_VC_VAL_BYPASS */ +#define PRM_VC_I2C_CHANNEL_FREQ_KHZ 400 + +#define PRM_VC_VAL_BYPASS_VALID_BIT 0x1000000 +#define PRM_VC_VAL_BYPASS_SLAVEADDR_SHIFT 0 +#define PRM_VC_VAL_BYPASS_SLAVEADDR_MASK 0x7F +#define PRM_VC_VAL_BYPASS_REGADDR_SHIFT 8 +#define PRM_VC_VAL_BYPASS_REGADDR_MASK 0xFF +#define PRM_VC_VAL_BYPASS_DATA_SHIFT 16 +#define PRM_VC_VAL_BYPASS_DATA_MASK 0xFF + +#define SMPS_I2C_SLAVE_ADDR 0x12 +#define SMPS_REG_ADDR_VCORE1 0x55 +#define SMPS_REG_ADDR_VCORE2 0x5B +#define SMPS_REG_ADDR_VCORE3 0x61 + +#define SMPS_VOLT_1_0000_V 0x21 +#define SMPS_VOLT_1_0125_V 0x22 +#define SMPS_VOLT_1_0250_V 0x23 +#define SMPS_VOLT_1_0375_V 0x24 +#define SMPS_VOLT_1_0500_V 0x25 +#define SMPS_VOLT_1_0625_V 0x26 +#define SMPS_VOLT_1_0750_V 0x27 +#define SMPS_VOLT_1_0875_V 0x28 +#define SMPS_VOLT_1_1000_V 0x29 +#define SMPS_VOLT_1_1125_V 0x2A +#define SMPS_VOLT_1_1250_V 0x2B +#define SMPS_VOLT_1_1375_V 0x2C +#define SMPS_VOLT_1_1500_V 0x2D +#define SMPS_VOLT_1_1625_V 0x2E +#define SMPS_VOLT_1_1750_V 0x2F +#define SMPS_VOLT_1_1875_V 0x30 +#define SMPS_VOLT_1_2000_V 0x31 +#define SMPS_VOLT_1_2125_V 0x32 +#define SMPS_VOLT_1_2250_V 0x33 +#define SMPS_VOLT_1_2375_V 0x34 +#define SMPS_VOLT_1_2500_V 0x35 +#define SMPS_VOLT_1_2625_V 0x36 +#define SMPS_VOLT_1_2750_V 0x37 +#define SMPS_VOLT_1_2875_V 0x38 +#define SMPS_VOLT_1_3000_V 0x39 +#define SMPS_VOLT_1_3500_V 0x3A +#define SMPS_VOLT_1_5000_V 0x3B +#define SMPS_VOLT_1_5000_V 0x3B + +/* Defines for DPLL setup */ +#define DPLL_LOCKED_FREQ_TOLERANCE_0 0 +#define DPLL_LOCKED_FREQ_TOLERANCE_500_KHZ 500 +#define DPLL_LOCKED_FREQ_TOLERANCE_1_MHZ 1000 + +#define DPLL_NO_LOCK 0 +#define DPLL_LOCK 1 + +#define NUM_SYS_CLKS 7 + +struct dpll_regs { + u32 cm_clkmode_dpll; + u32 cm_idlest_dpll; + u32 cm_autoidle_dpll; + u32 cm_clksel_dpll; + u32 cm_div_m2_dpll; + u32 cm_div_m3_dpll; + u32 cm_div_m4_dpll; + u32 cm_div_m5_dpll; + u32 cm_div_m6_dpll; + u32 cm_div_m7_dpll; +}; + +/* DPLL parameter table */ +struct dpll_params { + u32 m; + u32 n; + u8 m2; + u8 m3; + u8 m4; + u8 m5; + u8 m6; + u8 m7; +}; + +#endif /* _CLOCKS_OMAP4_H_ */ diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index ebd5b7a..4ba0ee0 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -38,6 +38,12 @@ void set_muxconf_regs_non_essential(void); void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); +void prcm_init(void); +void bypass_dpll(u32 base); +void freq_update_core(void); +u32 get_sys_clk_freq(void); +u32 omap4_ddr_clk(void); +u32 omap4_revision(void);
static inline u32 running_from_sdram(void) { diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 2063c36..787dd88 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -25,6 +25,9 @@ #ifndef _OMAP_COMMON_H_ #define _OMAP_COMMON_H_
+/* Max value for DPLL multiplier M */ +#define OMAP_DPLL_MAX_N 127 + /* Boot device */ #define BOOT_DEVICE_NONE 0 #define BOOT_DEVICE_XIP 1 diff --git a/spl/board/ti/omap4.mk b/spl/board/ti/omap4.mk index dffb53b..0374534 100644 --- a/spl/board/ti/omap4.mk +++ b/spl/board/ti/omap4.mk @@ -73,5 +73,10 @@ $(obj)board.c:$(obj)omap4_mux_data.h @rm -f $@ @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/board.c $@
+$(obj)clocks.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/clocks.c $@ + + SOBJS += lowlevel_init.o -COBJS += board.o +COBJS += board.o clocks.o
Dear Aneesh V,
In message 1305472900-4004-14-git-send-email-aneesh@ti.com you wrote:
Add support for:
- DPLL locking
- Initialization of clock domains and clock modules
V2:
- Use pre-calculated M & N values instead of calculated ones
- Changes due to make file changes
- Some corrections
- Do all clock initialization in SPL itself instead of differing some work to u-boot
It appears this might be part of or taken from some bigger scope clocks framework. Otherwise it's diffcult for me to understand why OMAP4 needs 1400+ lines of code, when other SoCs appear to do with considerably less. Please comment.
Please keep lists sorted.
- struct dpll_regs *dpll_regs = (struct dpll_regs *)base;
- modify_reg_32(&dpll_regs->cm_clkmode_dpll,
NAK, please use standard macros (see previous messages).
- u32 temp;
- bypass_dpll(base);
- /* Set M & N */
- temp = readl(&dpll_regs->cm_clksel_dpll);
- set_bit_field(temp, CM_CLKSEL_DPLL_M_SHIFT, CM_CLKSEL_DPLL_M_MASK,
params->m);
- set_bit_field(temp, CM_CLKSEL_DPLL_N_SHIFT, CM_CLKSEL_DPLL_N_MASK,
params->n);
- writel(temp, &dpll_regs->cm_clksel_dpll);
+void main(void)
It appears this is a host program, not part of U-Boot. I don't think that arch/arm/cpu/armv7/omap4/ is the right place for this program.
NAK. We do not accept base address plus offset notation. Please declare C structs instead.
Hi Wolfgang,
On Monday 16 May 2011 12:30 AM, Wolfgang Denk wrote:
Dear Aneesh V,
In message1305472900-4004-14-git-send-email-aneesh@ti.com you wrote:
Add support for:
- DPLL locking
This work draws upon previous work done for x-loader mainly by: Santosh Shilimkarsantosh.shilimkar@ti.com Rajendra Nayakrnayak@ti.com
Signed-off-by: Aneesh Vaneesh@ti.com
V2:
- Use pre-calculated M& N values instead of calculated ones
- Some corrections
No. This code was written for SPL. Please note that a lot of it is tables used for PLL locking, clock enabling etc. OMAP4 supports different crystal frequencies. So, more entries in each table. Also, there are some special handling based on the OMAP4 revisions because of some frequency limitations. So, more number of tables.
ok.
- u32 temp;
- /* Set M& N */
params->m);
params->n);
- writel(temp,&dpll_regs->cm_clksel_dpll);
+void main(void)
Ok. will do.
Again just curious, what's the reasoning behind this policy? Is it just aesthetics or something more?
best regards, Aneesh
Dear Aneesh V,
hm... is this really a type of selection that has to be done at runtime? In the real system, the frequencies will probably pretty much fixed, and not dynamically adjusted in U-Boot. So maybe we can compile at least poarts of this at build time?
Ok. will do.
It's more. When using base+offset, the compiler will know nothing about the data type, so it canot warn you if you use a 32 bit accessor on a 8 bit register, or vice versa. When you pass a struct element, it can check type information.
Dear Wolfgang,
On Wednesday 18 May 2011 03:14 AM, Wolfgang Denk wrote:
Dear Aneesh V,
[snip ...]
Ok. will do.
Is this really valid in our context? readl()/writel() and friends just cast the address to the target type pointer. I tried writeb() on my 32 bit register represented using the struct approach and the compiler didn't give any warning (as expected)!
Dear Aneesh V,
Yes, we should fix the I/O accessors definitons on ARM to provide strict type checking.
Dear Wolfgang,
On Sunday 15 May 2011 08:51 PM, Aneesh V wrote: [snip ..]
- CM_WKUP_GPIO1_CLKCTRL,
- CM_L4PER_GPIO2_CLKCTRL,
- CM_L4PER_GPIO3_CLKCTRL,
- CM_L4PER_GPIO4_CLKCTRL,
- CM_L4PER_GPIO5_CLKCTRL,
- CM_L4PER_GPIO6_CLKCTRL,
- CM_MEMIF_EMIF_1_CLKCTRL,
- CM_MEMIF_EMIF_2_CLKCTRL,
- CM_L3INIT_HSUSBOTG_CLKCTRL,
- CM_L3INIT_USBPHY_CLKCTRL,
- CM_L4CFG_L4_CFG_CLKCTRL,
- 0
In this series you asked me to convert the base + offset mode of register address definition to struct based register address definition. While doing this I am facing a problem. Please note the above array that contain register addresses. This is a group of registers that control our clock modules. All these registers have similar bit fields and they can be programmed in same manner. So, I keep them in an array and pass the array to a function that iterates through array and does similar processing on all the registers(see below).
I am finding it difficult to implement this using the struct based approach. I tried the sample code below:
struct my_regs_struct { const unsigned int reg1; const unsigned int reg2; const unsigned int reg3; };
static struct my_regs_struct *const my_regs = (struct my_regs_struct *)0x1000;
static unsigned int *const reg_arr[] = { &my_regs->reg1, &my_regs->reg3 };
void main(void) { printf("regs %x %x \n", reg_arr[0], reg_arr[1]); }
I am getting the following errors on compiling this: main.c:10: error: initializer element is not constant main.c:10: error: (near initialization for ‘reg_arr[0]’) main.c:12: error: initializer element is not constant main.c:12: error: (near initialization for ‘reg_arr[1]’)
I can't make it work unless I make my_regs a statically defined structure itself and not a pointer - like this:
static struct my_regs_struct my_regs;
This seems quite strange(behavior is the same with gcc and Microsoft compiler). Am I missing something?
Any ideas to make it work? If not, can I go back to defines for the addresses. All the registers we have are 32 bit long and we always use u32 for them and use readl/writel for accessor functions. Using the wrong accessor function is highly unlikely.
[snip ...]
- /* Clock modules that need to be put in HW_AUTO */
- for (i = 0; (i< max)&& clock_modules_hw_auto[i]; i++) {
wait_for_enable);
Dear Wolfgang,
On Tuesday 21 June 2011 11:19 AM, Aneesh V wrote:
Dear Wolfgang,
- 0
Apologies for the hasty mail. Looks like I can solve it by doing something like:
static unsigned int *const reg_arr[] = { &(((struct my_regs_struct *)0x1000)->reg1), &(((struct my_regs_struct *)0x1000)->reg3), };
Analyzing this further right now. Hopefully, the issue can be solved cleanly.
On Tuesday 21 June 2011 11:55 AM, Aneesh V wrote:
Dear Wolfgang,
Dear Wolfgang,
- 0
Some more interesting information:
I can reproduce the problem with something as simple as this:
main.c: const int const1 = 10; const int const2 = 11;
int arr[] = { const1, const2 };
$ gcc main.c main.c:5: error: initializer element is not constant main.c:5: error: (near initialization for ‘arr[0]’) main.c:7: error: initializer element is not constant main.c:7: error: (near initialization for ‘arr[1]’)
The ARM compiler RVCT happily compiles this without an issue. GCC and Visual C++ compilers fail!
As a result, I will have to do something like this to populate my array:
static unsigned int *const reg_arr[] = { &(((struct my_regs_struct *const)OMAP4_PRCM_REG_BASE)->uart_clkctrl), &(((struct my_regs_struct *const)OMAP4_PRCM_REG_BASE)->i2c_clkctrl), };
Is this acceptable?
Dear Aneesh,
In message 4E00447B.9070804@ti.com you wrote:
$ gcc main.c main.c:5: error: initializer element is not constant main.c:5: error: (near initialization for arr[0]) main.c:7: error: initializer element is not constant main.c:7: error: (near initialization for arr[1])
I have to admit that I don't understand either why this error is raised here; after all, from our understanding of the code these _are_ constant addresses.
You may want to ask this in a compiler group...
Is this acceptable?
No, please don't.
Note that the following code compiles fine:
----------------------------- snip ----------------------------- #include <stdio.h>
struct my_regs_struct { unsigned int reg1; unsigned int reg2; unsigned int reg3; };
static struct my_regs_struct *const my_regs = (struct my_regs_struct *) 0x1000;
static void print_regs(void) { unsigned int *const reg_arr[] = { &my_regs->reg1, &my_regs->reg3, }; printf("regs %p %p \n", (void *)reg_arr[0], (void *)reg_arr[1]); }
int main(void) { print_regs(); return 0; } ----------------------------- snip -----------------------------
With "gcc -Wall -pedantic" you will get warnings "initializer element is not computable at load time [enabled by default]", but this can be avoided by adding "--std=c99" to the compiler options.
On Tuesday 21 June 2011 01:50 PM, Wolfgang Denk wrote:
Dear Aneesh,
Yes. I will.
Is this acceptable?
No, please don't.
----------------------------- snip ----------------------------- #include<stdio.h>
In my function I am using 3 such arrays with quite a few entries in them. Won't it look ugly besides increasing the stack footprint.
Of course, I can try to break them down to different functions, if need be.
Or, how about using a utility macro and make it look better like this:
#define OMAP4_PRCM_REG_ADDR(reg)\ (&(((struct my_regs_struct *)OMAP4_PRCM_BASE)->reg))
static unsigned int *const reg_arr[] = { OMAP4_PRCM_REG_ADDR(uart_clkctrl), OMAP4_PRCM_REG_ADDR(i2c_clkctrl) };
This one doesn't generate any warning even with 'gcc -Wall -pedantic'.
Are you not comfortable with getting the address in this manner at all?
Dear Aneesh V,
I don;t see a significant difference whether you declare these arrays inside a function or with file scope.
Regarding the stack footprint: this would actually even be preferrable (assuming this code is run after relocation to RAM), and from what I've seen in the example, the compiler actually optimizes the code and does not really allocate such an array if you don't use it otherwise (like passing it to other functions).
I consider this code too ugly.
On Tuesday 21 June 2011 03:52 PM, Wolfgang Denk wrote:
Dear Aneesh V,
Indeed this runs before relocation. But I think I can keep the array size to a reasonable level by splitting the function. Also, as you said if the array is optimized out there should not be any problem.
Dear Aneesh,
Yes. I will.
I asked in the GCC mailing list and got this reply. That also seems to explain why the array as a local variable worked.
http://gcc.gnu.org/ml/gcc/2011-06/msg00291.html
Dear Aneesh V,
Sorry, but I fail to understand the problem. Why is reg_arr[] needed? Why don't you use
struct my_regs_struct { const unsigned int reg[3]; }; ?
On Tuesday 21 June 2011 12:35 PM, Wolfgang Denk wrote:
Dear Aneesh V,
The const for structure fields above were not intended. I put them while debugging this issue and forgot to remove later.
I want a number of register addresses in an array - an array of constant pointers. The array is populated at compile time with the addresses of all the modules that need to be initialized. At run-time I do a specific operation on all the registers given in this array.
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap4/board.c | 3 ++ arch/arm/cpu/armv7/omap4/clocks.c | 27 ++++++++++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 2 + arch/arm/include/asm/omap_common.h | 1 + spl/board/ti/omap4.mk | 40 +++++++++++++++++++++++++++ spl/board/ti/spl-omap.c | 20 +++++++++++++ 6 files changed, 93 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index f83b6d7..4a37171 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -105,6 +105,9 @@ void s_init(void) { watchdog_init(); set_mux_conf_regs(); +#ifdef CONFIG_PRELOADER + preloader_console_init(); +#endif prcm_init(); }
diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c index 802917f..c405b5c 100644 --- a/arch/arm/cpu/armv7/omap4/clocks.c +++ b/arch/arm/cpu/armv7/omap4/clocks.c @@ -713,6 +713,33 @@ void lock_dpll(u32 base) wait_for_lock(base); }
+void setup_clocks_for_console(void) +{ + /* Do not add any spl_debug prints in this function */ + modify_reg_32(CM_L4PER_CLKSTCTRL, CD_CLKCTRL_CLKTRCTRL_SHIFT, + CD_CLKCTRL_CLKTRCTRL_MASK, CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + + /* Enable all UARTs - console will be on one of them */ + modify_reg_32(CM_L4PER_UART1_CLKCTRL, MODULE_CLKCTRL_MODULEMODE_SHIFT, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN); + + modify_reg_32(CM_L4PER_UART2_CLKCTRL, MODULE_CLKCTRL_MODULEMODE_SHIFT, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN); + + modify_reg_32(CM_L4PER_UART3_CLKCTRL, MODULE_CLKCTRL_MODULEMODE_SHIFT, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN); + + modify_reg_32(CM_L4PER_UART3_CLKCTRL, MODULE_CLKCTRL_MODULEMODE_SHIFT, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN); + + modify_reg_32(CM_L4PER_CLKSTCTRL, CD_CLKCTRL_CLKTRCTRL_SHIFT, + CD_CLKCTRL_CLKTRCTRL_MASK, CD_CLKCTRL_CLKTRCTRL_HW_AUTO); +} + void prcm_init(void) { switch (omap4_hw_init_context()) { diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 4ba0ee0..3ac972d 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -38,12 +38,14 @@ void set_muxconf_regs_non_essential(void); void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); +void setup_clocks_for_console(void); void prcm_init(void); void bypass_dpll(u32 base); void freq_update_core(void); u32 get_sys_clk_freq(void); u32 omap4_ddr_clk(void); u32 omap4_revision(void); +const char *omap4_rev_string(void);
static inline u32 running_from_sdram(void) { diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 787dd88..10fc9c8 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -53,5 +53,6 @@
u32 omap_boot_device(void); u32 omap_boot_mode(void); +void preloader_console_init(void);
#endif /* _OMAP_COMMON_H_ */ diff --git a/spl/board/ti/omap4.mk b/spl/board/ti/omap4.mk index 0374534..508dc3b 100644 --- a/spl/board/ti/omap4.mk +++ b/spl/board/ti/omap4.mk @@ -32,6 +32,46 @@ include $(TOPDIR)/config.mk SOBJS = COBJS =
+# serial console +$(obj)eabi_compat.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/lib/eabi_compat.c $@ + +$(obj)string.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/string.c $@ + +$(obj)vsprintf.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/vsprintf.c $@ + +$(obj)console.c: + @rm -f $@ + @ln -s $(TOPDIR)/common/console.c $@ + +$(obj)stdio.c: + @rm -f $@ + @ln -s $(TOPDIR)/common/stdio.c $@ + +$(obj)serial.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/serial/serial.c $@ + +$(obj)ns16550.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/serial/ns16550.c $@ + +$(obj)div64.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/div64.c $@ + +$(obj)ctype.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/ctype.c $@ + +COBJS += serial.o ns16550.o string.o vsprintf.o console.o stdio.o +COBJS += ctype.o eabi_compat.o div64.o + # armv7 $(obj)start.S: @rm -f $@ diff --git a/spl/board/ti/spl-omap.c b/spl/board/ti/spl-omap.c index 0e08f4f..855572f 100644 --- a/spl/board/ti/spl-omap.c +++ b/spl/board/ti/spl-omap.c @@ -29,6 +29,7 @@ #include <asm/u-boot.h> #include <asm/arch/sys_proto.h> #include <timestamp_autogenerated.h> +#include <version_autogenerated.h>
/* Define global data structure pointer to it*/ gd_t gdata __attribute__ ((section(".data"))); @@ -45,3 +46,22 @@ void board_init_r(gd_t *id, ulong dummy) for (;;) ; } + +void preloader_console_init(void) +{ + const char *u_boot_rev = U_BOOT_VERSION; + + gd->bd = &bdata; + gd->flags |= GD_FLG_RELOC; + gd->baudrate = CONFIG_BAUDRATE; + + setup_clocks_for_console(); + serial_init(); /* serial communications setup */ + + /* Avoid a second "U-Boot" coming from this string */ + u_boot_rev = &u_boot_rev[7]; + + printf("\nU-Boot SPL %s (%s - %s)\n", u_boot_rev, U_BOOT_DATE, + U_BOOT_TIME); + printf("Texas Instruments %s\n", omap4_rev_string()); +}
Add support for the SDRAM controller (EMIF).
Signed-off-by: Aneesh V aneesh@ti.com V2: * Changes for makefile changes * Minor corrections in do_lpddr2_init() * Minor corrections to read_idle interval calculation * Sanity test of memory after doing the initialization * Fixed warnings reported with with latest GCC compilers --- arch/arm/cpu/armv7/omap4/Makefile | 3 + arch/arm/cpu/armv7/omap4/board.c | 2 +- arch/arm/cpu/armv7/omap4/emif.c | 298 +++++++++++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 118 +++++ arch/arm/include/asm/arch-omap4/emif.h | 719 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 11 + arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + include/configs/omap4_sdp4430.h | 5 - spl/board/ti/omap4.mk | 9 +- 9 files changed, 1159 insertions(+), 7 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/emif.c create mode 100644 arch/arm/cpu/armv7/omap4/sdram_elpida.c create mode 100644 arch/arm/include/asm/arch-omap4/emif.h
diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index 6154e86..d9714fe 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -31,6 +31,9 @@ COBJS += board.o COBJS += mem.o COBJS += sys_info.o COBJS += clocks.o +COBJS += emif.o +COBJS += sdram_elpida.o +
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 4a37171..7add46b 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -109,6 +109,7 @@ void s_init(void) preloader_console_init(); #endif prcm_init(); + sdram_init(); }
/* @@ -169,7 +170,6 @@ u32 sdram_size(void) */ int dram_init(void) { - gd->ram_size = sdram_size();
return 0; diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c new file mode 100644 index 0000000..9591fb0 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -0,0 +1,298 @@ +/* + * EMIF programming + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/emif.h> +#include <asm/arch/clocks.h> +#include <asm/arch/sys_proto.h> +#include <asm/omap_common.h> +#include <asm/utils.h> + +static inline u32 emif_num(u32 base) +{ + if (base == OMAP44XX_EMIF1) + return 1; + else if (base == OMAP44XX_EMIF2) + return 2; + else + return 0; +} + +static inline u32 get_mr(u32 base, u32 cs, u32 mr_addr) +{ + u32 mr; + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + mr_addr |= cs << OMAP44XX_REG_CS_SHIFT; + writel(mr_addr, &emif->emif_lpddr2_mode_reg_cfg); + if (omap4_revision() == OMAP4430_ES2_0) + mr = readl(&emif->emif_lpddr2_mode_reg_data_es2); + else + mr = readl(&emif->emif_lpddr2_mode_reg_data); + debug("get_mr: EMIF%d cs %d mr %08x val 0x%x\n", emif_num(base), + cs, mr_addr, mr); + return mr; +} + +static inline void set_mr(u32 base, u32 cs, u32 mr_addr, u32 mr_val) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + mr_addr |= cs << OMAP44XX_REG_CS_SHIFT; + writel(mr_addr, &emif->emif_lpddr2_mode_reg_cfg); + writel(mr_val, &emif->emif_lpddr2_mode_reg_data); +} +void emif_reset_phy(u32 base) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + u32 iodft; + + iodft = readl(&emif->emif_iodft_tlgc); + iodft |= OMAP44XX_REG_RESET_PHY_MASK; + writel(iodft, &emif->emif_iodft_tlgc); +} + +static void do_lpddr2_init(u32 base, u32 cs) +{ + u32 mr_addr; + + /* Wait till device auto initialization is complete */ + while (get_mr(base, cs, LPDDR2_MR0) & LPDDR2_MR0_DAI_MASK) + ; + set_mr(base, cs, LPDDR2_MR10, MR10_ZQ_ZQINIT); + /* + * tZQINIT = 1 us + * Enough loops assuming a maximum of 2GHz + */ + sdelay(2000); + set_mr(base, cs, LPDDR2_MR1, MR1_BL_8_BT_SEQ_WRAP_EN_NWR_3); + set_mr(base, cs, LPDDR2_MR16, MR16_REF_FULL_ARRAY); + /* + * Enable refresh along with writing MR2 + * Encoding of RL in MR2 is (RL - 2) + */ + mr_addr = LPDDR2_MR2 | OMAP44XX_REG_REFRESH_EN_MASK; + set_mr(base, cs, mr_addr, RL_FINAL - 2); +} + +static void lpddr2_init(u32 base, const struct emif_regs *regs) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + /* Not NVM */ + modify_reg_32(&emif->emif_lpddr2_nvm_config, + OMAP44XX_REG_CS1NVMEN_SHIFT, OMAP44XX_REG_CS1NVMEN_MASK, 0); + /* + * Keep REG_INITREF_DIS = 1 to prevent re-initialization of SDRAM + * when EMIF_SDRAM_CONFIG register is written + */ + modify_reg_32(&emif->emif_sdram_ref_ctrl, + OMAP44XX_REG_INITREF_DIS_SHIFT, + OMAP44XX_REG_INITREF_DIS_MASK, 1); + + /* + * Set the SDRAM_CONFIG and PHY_CTRL for the + * un-locked frequency & default RL + */ + writel(regs->sdram_config_init, &emif->emif_sdram_config); + writel(regs->emif_ddr_phy_ctlr_1_init, &emif->emif_ddr_phy_ctrl_1); + + do_lpddr2_init(base, CS0); + if (regs->sdram_config & OMAP44XX_REG_EBANK_MASK) + do_lpddr2_init(base, CS1); + + writel(regs->sdram_config, &emif->emif_sdram_config); + writel(regs->emif_ddr_phy_ctlr_1, &emif->emif_ddr_phy_ctrl_1); + + /* Enable refresh now */ + modify_reg_32(&emif->emif_sdram_ref_ctrl, + OMAP44XX_REG_INITREF_DIS_SHIFT, + OMAP44XX_REG_INITREF_DIS_MASK, 0); + +} + +static void emif_update_timings(u32 base, const struct emif_regs *regs) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + writel(regs->ref_ctrl, &emif->emif_sdram_ref_ctrl_shdw); + writel(regs->sdram_tim1, &emif->emif_sdram_tim_1_shdw); + writel(regs->sdram_tim2, &emif->emif_sdram_tim_2_shdw); + writel(regs->sdram_tim3, &emif->emif_sdram_tim_3_shdw); + if (omap4_revision() == OMAP4430_ES1_0) { + /* ES1 bug EMIF should be in force idle during freq_update */ + writel(0, &emif->emif_pwr_mgmt_ctrl); + } else { + writel(EMIF_PWR_MGMT_CTRL, &emif->emif_pwr_mgmt_ctrl); + writel(EMIF_PWR_MGMT_CTRL_SHDW, &emif->emif_pwr_mgmt_ctrl_shdw); + } + writel(regs->read_idle_ctrl, &emif->emif_read_idlectrl_shdw); + writel(regs->zq_config, &emif->emif_zq_config); + writel(regs->temp_alert_config, &emif->emif_temp_alert_config); + writel(regs->emif_ddr_phy_ctlr_1, &emif->emif_ddr_phy_ctrl_1_shdw); + /* + * Workaround: + * In a specific situation, the OCP interface between the DMM and + * EMIF may hang. + * 1. A TILER port is used to perform 2D burst writes of + * width 1 and height 8 + * 2. ELLAn port is used to perform reads + * 3. All accesses are routed to the same EMIF controller + * + * Work around to avoid this issue REG_SYS_THRESH_MAX value should + * be kept higher than default 0x7. As per recommondation 0x0A will + * be used for better performance with REG_LL_THRESH_MAX = 0x00 + */ + if (omap4_revision() == OMAP4430_ES1_0) { + writel(EMIF_L3_CONFIG_VAL_SYS_THRESH_0A_LL_THRESH_00, + &emif->emif_l3_config); + } +} + +static void do_sdram_init(u32 base) +{ + const struct emif_regs *regs, *tmp_regs; + u32 in_sdram, emif_nr; + + in_sdram = running_from_sdram(); + emif_nr = (base == OMAP44XX_EMIF1) ? 1 : 2; + + emif_get_reg_dump(®s, &tmp_regs); + regs = (emif_nr == 1) ? regs : tmp_regs; + + /* + * Initializing the LPDDR2 device can not happen from SDRAM. + * Changing the timing registers in EMIF can happen(going from one + * OPP to another) + */ + if (!in_sdram) + lpddr2_init(base, regs); + + /* Write to the shadow registers */ + emif_update_timings(base, regs); +} + +void sdram_init_pads(void) +{ + u32 lpddr2io; + u32 omap4_rev = omap4_revision(); + + if (omap4_rev == OMAP4430_ES1_0) + lpddr2io = CONTROL_LPDDR2IO_SLEW_125PS_DRV8_PULL_DOWN; + else if (omap4_rev == OMAP4430_ES2_0) + lpddr2io = CONTROL_LPDDR2IO_SLEW_325PS_DRV8_GATE_KEEPER; + else + return; /* Post ES2.1 reset values will work */ + + writel(lpddr2io, CONTROL_LPDDR2IO1_0); + writel(lpddr2io, CONTROL_LPDDR2IO1_1); + writel(lpddr2io, CONTROL_LPDDR2IO1_2); + writel(lpddr2io, CONTROL_LPDDR2IO2_0); + writel(lpddr2io, CONTROL_LPDDR2IO2_1); + writel(lpddr2io, CONTROL_LPDDR2IO2_2); + + writel(CONTROL_EFUSE_2_NMOS_PMOS_PTV_CODE_1, CONTROL_EFUSE_2); +} + +static void emif_post_init_config(u32 base) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + u32 omap4_rev = omap4_revision(); + + /* reset phy on ES2.0 */ + if (omap4_rev == OMAP4430_ES2_0) + emif_reset_phy(base); + + /* Put EMIF back in smart idle on ES1.0 */ + if (omap4_rev == OMAP4430_ES1_0) + writel(0x80000000, &emif->emif_pwr_mgmt_ctrl); +} + +static void dmm_init(u32 base) +{ + const struct dmm_lisa_map_regs *lisa_map_regs; + + emif_get_dmm_regs(&lisa_map_regs); + + struct dmm_lisa_map_regs *hw_lisa_map_regs = + (struct dmm_lisa_map_regs *)base; + + writel(0, &hw_lisa_map_regs->dmm_lisa_map_3); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_2); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_1); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_0); + + writel(lisa_map_regs->dmm_lisa_map_3, + &hw_lisa_map_regs->dmm_lisa_map_3); + writel(lisa_map_regs->dmm_lisa_map_2, + &hw_lisa_map_regs->dmm_lisa_map_2); + writel(lisa_map_regs->dmm_lisa_map_1, + &hw_lisa_map_regs->dmm_lisa_map_1); + writel(lisa_map_regs->dmm_lisa_map_0, + &hw_lisa_map_regs->dmm_lisa_map_0); +} + +/* + * SDRAM initialization: + * SDRAM initialization has two parts: + * 1. Configuring the SDRAM device + * 2. Update the AC timings related parameters in the EMIF module + * (1) should be done only once and should not be done while we are + * running from SDRAM. + * (2) can and should be done more than once if OPP changes. + * Particularly, this may be needed when we boot without SPL and + * and using Configuration Header(CH). ROM code supports only at 50% OPP + * at boot (low power boot). So u-boot has to switch to OPP100 and update + * the frequency. So, + * Doing (1) and (2) makes sense - first time initialization + * Doing (2) and not (1) makes sense - OPP change (when using CH) + * Doing (1) and not (2) doen't make sense + * See do_sdram_init() for the details + */ +void sdram_init(void) +{ + u32 in_sdram; + + in_sdram = running_from_sdram(); + + if (!in_sdram) { + sdram_init_pads(); + bypass_dpll(CM_CLKMODE_DPLL_CORE); + } + + do_sdram_init(OMAP44XX_EMIF1); + do_sdram_init(OMAP44XX_EMIF2); + + if (!in_sdram) { + dmm_init(OMAP44XX_DMM_LISA_MAP_BASE); + emif_post_init_config(OMAP44XX_EMIF1); + emif_post_init_config(OMAP44XX_EMIF2); + } + + /* for the shadow registers to take effect */ + freq_update_core(); +} diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c new file mode 100644 index 0000000..37e808c --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -0,0 +1,118 @@ +/* + * Timing and Organization details of the Elpida parts used in OMAP4 + * SDPs and Panda + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/arch/emif.h> +#include <asm/arch/sys_proto.h> + +static const struct emif_regs emif_regs_elpida_200_mhz_2cs = { + .sdram_config_init = 0x80000eb9, + .sdram_config = 0x80001ab9, + .ref_ctrl = 0x0000030c, + .sdram_tim1 = 0x08648311, + .sdram_tim2 = 0x101b06ca, + .sdram_tim3 = 0x0048a19f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0x500b3214, + .temp_alert_config = 0xd8016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff808 +}; + +static const struct emif_regs emif_regs_elpida_380_mhz_1cs = { + .sdram_config_init = 0x80000eb1, + .sdram_config = 0x80001ab1, + .ref_ctrl = 0x000005cd, + .sdram_tim1 = 0x10cb0622, + .sdram_tim2 = 0x20350d52, + .sdram_tim3 = 0x00b1431f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0x500b3214, + .temp_alert_config = 0x58016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff418 +}; + +const struct emif_regs emif_regs_elpida_400_mhz_2cs = { + .sdram_config_init = 0x80000eb9, + .sdram_config = 0x80001ab9, + .ref_ctrl = 0x00000618, + .sdram_tim1 = 0x10eb0662, + .sdram_tim2 = 0x20370dd2, + .sdram_tim3 = 0x00b1c33f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0xd00b3214, + .temp_alert_config = 0xd8016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff418 +}; +const struct dmm_lisa_map_regs lisa_map_2G_x_1_x_2 = { + .dmm_lisa_map_0 = 0xFF020100, + .dmm_lisa_map_1 = 0, + .dmm_lisa_map_2 = 0, + .dmm_lisa_map_3 = 0x80540300 +}; + +const struct dmm_lisa_map_regs lisa_map_2G_x_2_x_2 = { + .dmm_lisa_map_0 = 0xFF020100, + .dmm_lisa_map_1 = 0, + .dmm_lisa_map_2 = 0, + .dmm_lisa_map_3 = 0x80640300 +}; + +void emif_get_reg_dump_sdp(const struct emif_regs **emif1_regs, + const struct emif_regs **emif2_regs) +{ + u32 omap4_rev = omap4_revision(); + + if (omap4_rev == OMAP4430_ES1_0) { + *emif1_regs = &emif_regs_elpida_380_mhz_1cs; + *emif2_regs = &emif_regs_elpida_380_mhz_1cs; + } else if (omap4_rev == OMAP4430_ES2_0) { + *emif1_regs = &emif_regs_elpida_200_mhz_2cs; + *emif2_regs = &emif_regs_elpida_200_mhz_2cs; + } else { + *emif1_regs = &emif_regs_elpida_400_mhz_2cs; + *emif2_regs = &emif_regs_elpida_400_mhz_2cs; + } +} +void emif_get_reg_dump(const struct emif_regs **emif1_regs, + const struct emif_regs **emif2_regs) + __attribute__((weak, alias("emif_get_reg_dump_sdp"))); + +void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs **dmm_lisa_regs) +{ + u32 omap_rev = omap4_revision(); + + if (omap_rev == OMAP4430_ES1_0) + *dmm_lisa_regs = &lisa_map_2G_x_1_x_2; + else + *dmm_lisa_regs = &lisa_map_2G_x_2_x_2; +} + +void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) + __attribute__((weak, alias("emif_get_dmm_regs_sdp"))); diff --git a/arch/arm/include/asm/arch-omap4/emif.h b/arch/arm/include/asm/arch-omap4/emif.h new file mode 100644 index 0000000..f2d54cb --- /dev/null +++ b/arch/arm/include/asm/arch-omap4/emif.h @@ -0,0 +1,719 @@ +/* + * OMAP44xx EMIF header + * + * Copyright (C) 2009-2010 Texas Instruments, Inc. + * + * Aneesh V aneesh@ti.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#ifndef _EMIF_H_ +#define _EMIF_H_ +#include <asm/types.h> +#include <common.h> + +/* Base address */ +#define OMAP44XX_EMIF1 0x4c000000 +#define OMAP44XX_EMIF2 0x4d000000 + +/* Registers shifts and masks */ + +/* EMIF_MOD_ID_REV */ +#define OMAP44XX_REG_SCHEME_SHIFT 30 +#define OMAP44XX_REG_SCHEME_MASK (0x3 << 30) +#define OMAP44XX_REG_MODULE_ID_SHIFT 16 +#define OMAP44XX_REG_MODULE_ID_MASK (0xfff << 16) +#define OMAP44XX_REG_RTL_VERSION_SHIFT 11 +#define OMAP44XX_REG_RTL_VERSION_MASK (0x1f << 11) +#define OMAP44XX_REG_MAJOR_REVISION_SHIFT 8 +#define OMAP44XX_REG_MAJOR_REVISION_MASK (0x7 << 8) +#define OMAP44XX_REG_MINOR_REVISION_SHIFT 0 +#define OMAP44XX_REG_MINOR_REVISION_MASK (0x3f << 0) + +/* STATUS */ +#define OMAP44XX_REG_BE_SHIFT 31 +#define OMAP44XX_REG_BE_MASK (1 << 31) +#define OMAP44XX_REG_DUAL_CLK_MODE_SHIFT 30 +#define OMAP44XX_REG_DUAL_CLK_MODE_MASK (1 << 30) +#define OMAP44XX_REG_FAST_INIT_SHIFT 29 +#define OMAP44XX_REG_FAST_INIT_MASK (1 << 29) +#define OMAP44XX_REG_PHY_DLL_READY_SHIFT 2 +#define OMAP44XX_REG_PHY_DLL_READY_MASK (1 << 2) + +/* SDRAM_CONFIG */ +#define OMAP44XX_REG_SDRAM_TYPE_SHIFT 29 +#define OMAP44XX_REG_SDRAM_TYPE_MASK (0x7 << 29) +#define OMAP44XX_REG_IBANK_POS_SHIFT 27 +#define OMAP44XX_REG_IBANK_POS_MASK (0x3 << 27) +#define OMAP44XX_REG_DDR_TERM_SHIFT 24 +#define OMAP44XX_REG_DDR_TERM_MASK (0x7 << 24) +#define OMAP44XX_REG_DDR2_DDQS_SHIFT 23 +#define OMAP44XX_REG_DDR2_DDQS_MASK (1 << 23) +#define OMAP44XX_REG_DYN_ODT_SHIFT 21 +#define OMAP44XX_REG_DYN_ODT_MASK (0x3 << 21) +#define OMAP44XX_REG_DDR_DISABLE_DLL_SHIFT 20 +#define OMAP44XX_REG_DDR_DISABLE_DLL_MASK (1 << 20) +#define OMAP44XX_REG_SDRAM_DRIVE_SHIFT 18 +#define OMAP44XX_REG_SDRAM_DRIVE_MASK (0x3 << 18) +#define OMAP44XX_REG_CWL_SHIFT 16 +#define OMAP44XX_REG_CWL_MASK (0x3 << 16) +#define OMAP44XX_REG_NARROW_MODE_SHIFT 14 +#define OMAP44XX_REG_NARROW_MODE_MASK (0x3 << 14) +#define OMAP44XX_REG_CL_SHIFT 10 +#define OMAP44XX_REG_CL_MASK (0xf << 10) +#define OMAP44XX_REG_ROWSIZE_SHIFT 7 +#define OMAP44XX_REG_ROWSIZE_MASK (0x7 << 7) +#define OMAP44XX_REG_IBANK_SHIFT 4 +#define OMAP44XX_REG_IBANK_MASK (0x7 << 4) +#define OMAP44XX_REG_EBANK_SHIFT 3 +#define OMAP44XX_REG_EBANK_MASK (1 << 3) +#define OMAP44XX_REG_PAGESIZE_SHIFT 0 +#define OMAP44XX_REG_PAGESIZE_MASK (0x7 << 0) + +/* SDRAM_CONFIG_2 */ +#define OMAP44XX_REG_CS1NVMEN_SHIFT 30 +#define OMAP44XX_REG_CS1NVMEN_MASK (1 << 30) +#define OMAP44XX_REG_EBANK_POS_SHIFT 27 +#define OMAP44XX_REG_EBANK_POS_MASK (1 << 27) +#define OMAP44XX_REG_RDBNUM_SHIFT 4 +#define OMAP44XX_REG_RDBNUM_MASK (0x3 << 4) +#define OMAP44XX_REG_RDBSIZE_SHIFT 0 +#define OMAP44XX_REG_RDBSIZE_MASK (0x7 << 0) + +/* SDRAM_REF_CTRL */ +#define OMAP44XX_REG_INITREF_DIS_SHIFT 31 +#define OMAP44XX_REG_INITREF_DIS_MASK (1 << 31) +#define OMAP44XX_REG_SRT_SHIFT 29 +#define OMAP44XX_REG_SRT_MASK (1 << 29) +#define OMAP44XX_REG_ASR_SHIFT 28 +#define OMAP44XX_REG_ASR_MASK (1 << 28) +#define OMAP44XX_REG_PASR_SHIFT 24 +#define OMAP44XX_REG_PASR_MASK (0x7 << 24) +#define OMAP44XX_REG_REFRESH_RATE_SHIFT 0 +#define OMAP44XX_REG_REFRESH_RATE_MASK (0xffff << 0) + +/* SDRAM_REF_CTRL_SHDW */ +#define OMAP44XX_REG_REFRESH_RATE_SHDW_SHIFT 0 +#define OMAP44XX_REG_REFRESH_RATE_SHDW_MASK (0xffff << 0) + +/* SDRAM_TIM_1 */ +#define OMAP44XX_REG_T_RP_SHIFT 25 +#define OMAP44XX_REG_T_RP_MASK (0xf << 25) +#define OMAP44XX_REG_T_RCD_SHIFT 21 +#define OMAP44XX_REG_T_RCD_MASK (0xf << 21) +#define OMAP44XX_REG_T_WR_SHIFT 17 +#define OMAP44XX_REG_T_WR_MASK (0xf << 17) +#define OMAP44XX_REG_T_RAS_SHIFT 12 +#define OMAP44XX_REG_T_RAS_MASK (0x1f << 12) +#define OMAP44XX_REG_T_RC_SHIFT 6 +#define OMAP44XX_REG_T_RC_MASK (0x3f << 6) +#define OMAP44XX_REG_T_RRD_SHIFT 3 +#define OMAP44XX_REG_T_RRD_MASK (0x7 << 3) +#define OMAP44XX_REG_T_WTR_SHIFT 0 +#define OMAP44XX_REG_T_WTR_MASK (0x7 << 0) + +/* SDRAM_TIM_1_SHDW */ +#define OMAP44XX_REG_T_RP_SHDW_SHIFT 25 +#define OMAP44XX_REG_T_RP_SHDW_MASK (0xf << 25) +#define OMAP44XX_REG_T_RCD_SHDW_SHIFT 21 +#define OMAP44XX_REG_T_RCD_SHDW_MASK (0xf << 21) +#define OMAP44XX_REG_T_WR_SHDW_SHIFT 17 +#define OMAP44XX_REG_T_WR_SHDW_MASK (0xf << 17) +#define OMAP44XX_REG_T_RAS_SHDW_SHIFT 12 +#define OMAP44XX_REG_T_RAS_SHDW_MASK (0x1f << 12) +#define OMAP44XX_REG_T_RC_SHDW_SHIFT 6 +#define OMAP44XX_REG_T_RC_SHDW_MASK (0x3f << 6) +#define OMAP44XX_REG_T_RRD_SHDW_SHIFT 3 +#define OMAP44XX_REG_T_RRD_SHDW_MASK (0x7 << 3) +#define OMAP44XX_REG_T_WTR_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_WTR_SHDW_MASK (0x7 << 0) + +/* SDRAM_TIM_2 */ +#define OMAP44XX_REG_T_XP_SHIFT 28 +#define OMAP44XX_REG_T_XP_MASK (0x7 << 28) +#define OMAP44XX_REG_T_ODT_SHIFT 25 +#define OMAP44XX_REG_T_ODT_MASK (0x7 << 25) +#define OMAP44XX_REG_T_XSNR_SHIFT 16 +#define OMAP44XX_REG_T_XSNR_MASK (0x1ff << 16) +#define OMAP44XX_REG_T_XSRD_SHIFT 6 +#define OMAP44XX_REG_T_XSRD_MASK (0x3ff << 6) +#define OMAP44XX_REG_T_RTP_SHIFT 3 +#define OMAP44XX_REG_T_RTP_MASK (0x7 << 3) +#define OMAP44XX_REG_T_CKE_SHIFT 0 +#define OMAP44XX_REG_T_CKE_MASK (0x7 << 0) + +/* SDRAM_TIM_2_SHDW */ +#define OMAP44XX_REG_T_XP_SHDW_SHIFT 28 +#define OMAP44XX_REG_T_XP_SHDW_MASK (0x7 << 28) +#define OMAP44XX_REG_T_ODT_SHDW_SHIFT 25 +#define OMAP44XX_REG_T_ODT_SHDW_MASK (0x7 << 25) +#define OMAP44XX_REG_T_XSNR_SHDW_SHIFT 16 +#define OMAP44XX_REG_T_XSNR_SHDW_MASK (0x1ff << 16) +#define OMAP44XX_REG_T_XSRD_SHDW_SHIFT 6 +#define OMAP44XX_REG_T_XSRD_SHDW_MASK (0x3ff << 6) +#define OMAP44XX_REG_T_RTP_SHDW_SHIFT 3 +#define OMAP44XX_REG_T_RTP_SHDW_MASK (0x7 << 3) +#define OMAP44XX_REG_T_CKE_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_CKE_SHDW_MASK (0x7 << 0) + +/* SDRAM_TIM_3 */ +#define OMAP44XX_REG_T_CKESR_SHIFT 21 +#define OMAP44XX_REG_T_CKESR_MASK (0x7 << 21) +#define OMAP44XX_REG_ZQ_ZQCS_SHIFT 15 +#define OMAP44XX_REG_ZQ_ZQCS_MASK (0x3f << 15) +#define OMAP44XX_REG_T_TDQSCKMAX_SHIFT 13 +#define OMAP44XX_REG_T_TDQSCKMAX_MASK (0x3 << 13) +#define OMAP44XX_REG_T_RFC_SHIFT 4 +#define OMAP44XX_REG_T_RFC_MASK (0x1ff << 4) +#define OMAP44XX_REG_T_RAS_MAX_SHIFT 0 +#define OMAP44XX_REG_T_RAS_MAX_MASK (0xf << 0) + +/* SDRAM_TIM_3_SHDW */ +#define OMAP44XX_REG_T_CKESR_SHDW_SHIFT 21 +#define OMAP44XX_REG_T_CKESR_SHDW_MASK (0x7 << 21) +#define OMAP44XX_REG_ZQ_ZQCS_SHDW_SHIFT 15 +#define OMAP44XX_REG_ZQ_ZQCS_SHDW_MASK (0x3f << 15) +#define OMAP44XX_REG_T_TDQSCKMAX_SHDW_SHIFT 13 +#define OMAP44XX_REG_T_TDQSCKMAX_SHDW_MASK (0x3 << 13) +#define OMAP44XX_REG_T_RFC_SHDW_SHIFT 4 +#define OMAP44XX_REG_T_RFC_SHDW_MASK (0x1ff << 4) +#define OMAP44XX_REG_T_RAS_MAX_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_RAS_MAX_SHDW_MASK (0xf << 0) + +/* LPDDR2_NVM_TIM */ +#define OMAP44XX_REG_NVM_T_XP_SHIFT 28 +#define OMAP44XX_REG_NVM_T_XP_MASK (0x7 << 28) +#define OMAP44XX_REG_NVM_T_WTR_SHIFT 24 +#define OMAP44XX_REG_NVM_T_WTR_MASK (0x7 << 24) +#define OMAP44XX_REG_NVM_T_RP_SHIFT 20 +#define OMAP44XX_REG_NVM_T_RP_MASK (0xf << 20) +#define OMAP44XX_REG_NVM_T_WRA_SHIFT 16 +#define OMAP44XX_REG_NVM_T_WRA_MASK (0xf << 16) +#define OMAP44XX_REG_NVM_T_RRD_SHIFT 8 +#define OMAP44XX_REG_NVM_T_RRD_MASK (0xff << 8) +#define OMAP44XX_REG_NVM_T_RCDMIN_SHIFT 0 +#define OMAP44XX_REG_NVM_T_RCDMIN_MASK (0xff << 0) + +/* LPDDR2_NVM_TIM_SHDW */ +#define OMAP44XX_REG_NVM_T_XP_SHDW_SHIFT 28 +#define OMAP44XX_REG_NVM_T_XP_SHDW_MASK (0x7 << 28) +#define OMAP44XX_REG_NVM_T_WTR_SHDW_SHIFT 24 +#define OMAP44XX_REG_NVM_T_WTR_SHDW_MASK (0x7 << 24) +#define OMAP44XX_REG_NVM_T_RP_SHDW_SHIFT 20 +#define OMAP44XX_REG_NVM_T_RP_SHDW_MASK (0xf << 20) +#define OMAP44XX_REG_NVM_T_WRA_SHDW_SHIFT 16 +#define OMAP44XX_REG_NVM_T_WRA_SHDW_MASK (0xf << 16) +#define OMAP44XX_REG_NVM_T_RRD_SHDW_SHIFT 8 +#define OMAP44XX_REG_NVM_T_RRD_SHDW_MASK (0xff << 8) +#define OMAP44XX_REG_NVM_T_RCDMIN_SHDW_SHIFT 0 +#define OMAP44XX_REG_NVM_T_RCDMIN_SHDW_MASK (0xff << 0) + +/* PWR_MGMT_CTRL */ +#define OMAP44XX_REG_IDLEMODE_SHIFT 30 +#define OMAP44XX_REG_IDLEMODE_MASK (0x3 << 30) +#define OMAP44XX_REG_PD_TIM_SHIFT 12 +#define OMAP44XX_REG_PD_TIM_MASK (0xf << 12) +#define OMAP44XX_REG_DPD_EN_SHIFT 11 +#define OMAP44XX_REG_DPD_EN_MASK (1 << 11) +#define OMAP44XX_REG_LP_MODE_SHIFT 8 +#define OMAP44XX_REG_LP_MODE_MASK (0x7 << 8) +#define OMAP44XX_REG_SR_TIM_SHIFT 4 +#define OMAP44XX_REG_SR_TIM_MASK (0xf << 4) +#define OMAP44XX_REG_CS_TIM_SHIFT 0 +#define OMAP44XX_REG_CS_TIM_MASK (0xf << 0) + +/* PWR_MGMT_CTRL_SHDW */ +#define OMAP44XX_REG_PD_TIM_SHDW_SHIFT 8 +#define OMAP44XX_REG_PD_TIM_SHDW_MASK (0xf << 8) +#define OMAP44XX_REG_SR_TIM_SHDW_SHIFT 4 +#define OMAP44XX_REG_SR_TIM_SHDW_MASK (0xf << 4) +#define OMAP44XX_REG_CS_TIM_SHDW_SHIFT 0 +#define OMAP44XX_REG_CS_TIM_SHDW_MASK (0xf << 0) + +/* LPDDR2_MODE_REG_DATA */ +#define OMAP44XX_REG_VALUE_0_SHIFT 0 +#define OMAP44XX_REG_VALUE_0_MASK (0x7f << 0) + +/* LPDDR2_MODE_REG_CFG */ +#define OMAP44XX_REG_CS_SHIFT 31 +#define OMAP44XX_REG_CS_MASK (1 << 31) +#define OMAP44XX_REG_REFRESH_EN_SHIFT 30 +#define OMAP44XX_REG_REFRESH_EN_MASK (1 << 30) +#define OMAP44XX_REG_ADDRESS_SHIFT 0 +#define OMAP44XX_REG_ADDRESS_MASK (0xff << 0) + +/* OCP_CONFIG */ +#define OMAP44XX_REG_SYS_THRESH_MAX_SHIFT 24 +#define OMAP44XX_REG_SYS_THRESH_MAX_MASK (0xf << 24) +#define OMAP44XX_REG_LL_THRESH_MAX_SHIFT 16 +#define OMAP44XX_REG_LL_THRESH_MAX_MASK (0xf << 16) +#define OMAP44XX_REG_PR_OLD_COUNT_SHIFT 0 +#define OMAP44XX_REG_PR_OLD_COUNT_MASK (0xff << 0) + +/* OCP_CFG_VAL_1 */ +#define OMAP44XX_REG_SYS_BUS_WIDTH_SHIFT 30 +#define OMAP44XX_REG_SYS_BUS_WIDTH_MASK (0x3 << 30) +#define OMAP44XX_REG_LL_BUS_WIDTH_SHIFT 28 +#define OMAP44XX_REG_LL_BUS_WIDTH_MASK (0x3 << 28) +#define OMAP44XX_REG_WR_FIFO_DEPTH_SHIFT 8 +#define OMAP44XX_REG_WR_FIFO_DEPTH_MASK (0xff << 8) +#define OMAP44XX_REG_CMD_FIFO_DEPTH_SHIFT 0 +#define OMAP44XX_REG_CMD_FIFO_DEPTH_MASK (0xff << 0) + +/* OCP_CFG_VAL_2 */ +#define OMAP44XX_REG_RREG_FIFO_DEPTH_SHIFT 16 +#define OMAP44XX_REG_RREG_FIFO_DEPTH_MASK (0xff << 16) +#define OMAP44XX_REG_RSD_FIFO_DEPTH_SHIFT 8 +#define OMAP44XX_REG_RSD_FIFO_DEPTH_MASK (0xff << 8) +#define OMAP44XX_REG_RCMD_FIFO_DEPTH_SHIFT 0 +#define OMAP44XX_REG_RCMD_FIFO_DEPTH_MASK (0xff << 0) + +/* IODFT_TLGC */ +#define OMAP44XX_REG_TLEC_SHIFT 16 +#define OMAP44XX_REG_TLEC_MASK (0xffff << 16) +#define OMAP44XX_REG_MT_SHIFT 14 +#define OMAP44XX_REG_MT_MASK (1 << 14) +#define OMAP44XX_REG_ACT_CAP_EN_SHIFT 13 +#define OMAP44XX_REG_ACT_CAP_EN_MASK (1 << 13) +#define OMAP44XX_REG_OPG_LD_SHIFT 12 +#define OMAP44XX_REG_OPG_LD_MASK (1 << 12) +#define OMAP44XX_REG_RESET_PHY_SHIFT 10 +#define OMAP44XX_REG_RESET_PHY_MASK (1 << 10) +#define OMAP44XX_REG_MMS_SHIFT 8 +#define OMAP44XX_REG_MMS_MASK (1 << 8) +#define OMAP44XX_REG_MC_SHIFT 4 +#define OMAP44XX_REG_MC_MASK (0x3 << 4) +#define OMAP44XX_REG_PC_SHIFT 1 +#define OMAP44XX_REG_PC_MASK (0x7 << 1) +#define OMAP44XX_REG_TM_SHIFT 0 +#define OMAP44XX_REG_TM_MASK (1 << 0) + +/* IODFT_CTRL_MISR_RSLT */ +#define OMAP44XX_REG_DQM_TLMR_SHIFT 16 +#define OMAP44XX_REG_DQM_TLMR_MASK (0x3ff << 16) +#define OMAP44XX_REG_CTL_TLMR_SHIFT 0 +#define OMAP44XX_REG_CTL_TLMR_MASK (0x7ff << 0) + +/* IODFT_ADDR_MISR_RSLT */ +#define OMAP44XX_REG_ADDR_TLMR_SHIFT 0 +#define OMAP44XX_REG_ADDR_TLMR_MASK (0x1fffff << 0) + +/* IODFT_DATA_MISR_RSLT_1 */ +#define OMAP44XX_REG_DATA_TLMR_31_0_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_31_0_MASK (0xffffffff << 0) + +/* IODFT_DATA_MISR_RSLT_2 */ +#define OMAP44XX_REG_DATA_TLMR_63_32_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_63_32_MASK (0xffffffff << 0) + +/* IODFT_DATA_MISR_RSLT_3 */ +#define OMAP44XX_REG_DATA_TLMR_66_64_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_66_64_MASK (0x7 << 0) + +/* PERF_CNT_1 */ +#define OMAP44XX_REG_COUNTER1_SHIFT 0 +#define OMAP44XX_REG_COUNTER1_MASK (0xffffffff << 0) + +/* PERF_CNT_2 */ +#define OMAP44XX_REG_COUNTER2_SHIFT 0 +#define OMAP44XX_REG_COUNTER2_MASK (0xffffffff << 0) + +/* PERF_CNT_CFG */ +#define OMAP44XX_REG_CNTR2_MCONNID_EN_SHIFT 31 +#define OMAP44XX_REG_CNTR2_MCONNID_EN_MASK (1 << 31) +#define OMAP44XX_REG_CNTR2_REGION_EN_SHIFT 30 +#define OMAP44XX_REG_CNTR2_REGION_EN_MASK (1 << 30) +#define OMAP44XX_REG_CNTR2_CFG_SHIFT 16 +#define OMAP44XX_REG_CNTR2_CFG_MASK (0xf << 16) +#define OMAP44XX_REG_CNTR1_MCONNID_EN_SHIFT 15 +#define OMAP44XX_REG_CNTR1_MCONNID_EN_MASK (1 << 15) +#define OMAP44XX_REG_CNTR1_REGION_EN_SHIFT 14 +#define OMAP44XX_REG_CNTR1_REGION_EN_MASK (1 << 14) +#define OMAP44XX_REG_CNTR1_CFG_SHIFT 0 +#define OMAP44XX_REG_CNTR1_CFG_MASK (0xf << 0) + +/* PERF_CNT_SEL */ +#define OMAP44XX_REG_MCONNID2_SHIFT 24 +#define OMAP44XX_REG_MCONNID2_MASK (0xff << 24) +#define OMAP44XX_REG_REGION_SEL2_SHIFT 16 +#define OMAP44XX_REG_REGION_SEL2_MASK (0x3 << 16) +#define OMAP44XX_REG_MCONNID1_SHIFT 8 +#define OMAP44XX_REG_MCONNID1_MASK (0xff << 8) +#define OMAP44XX_REG_REGION_SEL1_SHIFT 0 +#define OMAP44XX_REG_REGION_SEL1_MASK (0x3 << 0) + +/* PERF_CNT_TIM */ +#define OMAP44XX_REG_TOTAL_TIME_SHIFT 0 +#define OMAP44XX_REG_TOTAL_TIME_MASK (0xffffffff << 0) + +/* READ_IDLE_CTRL */ +#define OMAP44XX_REG_READ_IDLE_LEN_SHIFT 16 +#define OMAP44XX_REG_READ_IDLE_LEN_MASK (0xf << 16) +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHIFT 0 +#define OMAP44XX_REG_READ_IDLE_INTERVAL_MASK (0x1ff << 0) + +/* READ_IDLE_CTRL_SHDW */ +#define OMAP44XX_REG_READ_IDLE_LEN_SHDW_SHIFT 16 +#define OMAP44XX_REG_READ_IDLE_LEN_SHDW_MASK (0xf << 16) +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHDW_SHIFT 0 +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHDW_MASK (0x1ff << 0) + +/* IRQ_EOI */ +#define OMAP44XX_REG_EOI_SHIFT 0 +#define OMAP44XX_REG_EOI_MASK (1 << 0) + +/* IRQSTATUS_RAW_SYS */ +#define OMAP44XX_REG_DNV_SYS_SHIFT 2 +#define OMAP44XX_REG_DNV_SYS_MASK (1 << 2) +#define OMAP44XX_REG_TA_SYS_SHIFT 1 +#define OMAP44XX_REG_TA_SYS_MASK (1 << 1) +#define OMAP44XX_REG_ERR_SYS_SHIFT 0 +#define OMAP44XX_REG_ERR_SYS_MASK (1 << 0) + +/* IRQSTATUS_RAW_LL */ +#define OMAP44XX_REG_DNV_LL_SHIFT 2 +#define OMAP44XX_REG_DNV_LL_MASK (1 << 2) +#define OMAP44XX_REG_TA_LL_SHIFT 1 +#define OMAP44XX_REG_TA_LL_MASK (1 << 1) +#define OMAP44XX_REG_ERR_LL_SHIFT 0 +#define OMAP44XX_REG_ERR_LL_MASK (1 << 0) + +/* IRQSTATUS_SYS */ + +/* IRQSTATUS_LL */ + +/* IRQENABLE_SET_SYS */ +#define OMAP44XX_REG_EN_DNV_SYS_SHIFT 2 +#define OMAP44XX_REG_EN_DNV_SYS_MASK (1 << 2) +#define OMAP44XX_REG_EN_TA_SYS_SHIFT 1 +#define OMAP44XX_REG_EN_TA_SYS_MASK (1 << 1) +#define OMAP44XX_REG_EN_ERR_SYS_SHIFT 0 +#define OMAP44XX_REG_EN_ERR_SYS_MASK (1 << 0) + +/* IRQENABLE_SET_LL */ +#define OMAP44XX_REG_EN_DNV_LL_SHIFT 2 +#define OMAP44XX_REG_EN_DNV_LL_MASK (1 << 2) +#define OMAP44XX_REG_EN_TA_LL_SHIFT 1 +#define OMAP44XX_REG_EN_TA_LL_MASK (1 << 1) +#define OMAP44XX_REG_EN_ERR_LL_SHIFT 0 +#define OMAP44XX_REG_EN_ERR_LL_MASK (1 << 0) + +/* IRQENABLE_CLR_SYS */ + +/* IRQENABLE_CLR_LL */ + +/* ZQ_CONFIG */ +#define OMAP44XX_REG_ZQ_CS1EN_SHIFT 31 +#define OMAP44XX_REG_ZQ_CS1EN_MASK (1 << 31) +#define OMAP44XX_REG_ZQ_CS0EN_SHIFT 30 +#define OMAP44XX_REG_ZQ_CS0EN_MASK (1 << 30) +#define OMAP44XX_REG_ZQ_DUALCALEN_SHIFT 29 +#define OMAP44XX_REG_ZQ_DUALCALEN_MASK (1 << 29) +#define OMAP44XX_REG_ZQ_SFEXITEN_SHIFT 28 +#define OMAP44XX_REG_ZQ_SFEXITEN_MASK (1 << 28) +#define OMAP44XX_REG_ZQ_ZQINIT_MULT_SHIFT 18 +#define OMAP44XX_REG_ZQ_ZQINIT_MULT_MASK (0x3 << 18) +#define OMAP44XX_REG_ZQ_ZQCL_MULT_SHIFT 16 +#define OMAP44XX_REG_ZQ_ZQCL_MULT_MASK (0x3 << 16) +#define OMAP44XX_REG_ZQ_REFINTERVAL_SHIFT 0 +#define OMAP44XX_REG_ZQ_REFINTERVAL_MASK (0xffff << 0) + +/* TEMP_ALERT_CONFIG */ +#define OMAP44XX_REG_TA_CS1EN_SHIFT 31 +#define OMAP44XX_REG_TA_CS1EN_MASK (1 << 31) +#define OMAP44XX_REG_TA_CS0EN_SHIFT 30 +#define OMAP44XX_REG_TA_CS0EN_MASK (1 << 30) +#define OMAP44XX_REG_TA_SFEXITEN_SHIFT 28 +#define OMAP44XX_REG_TA_SFEXITEN_MASK (1 << 28) +#define OMAP44XX_REG_TA_DEVWDT_SHIFT 26 +#define OMAP44XX_REG_TA_DEVWDT_MASK (0x3 << 26) +#define OMAP44XX_REG_TA_DEVCNT_SHIFT 24 +#define OMAP44XX_REG_TA_DEVCNT_MASK (0x3 << 24) +#define OMAP44XX_REG_TA_REFINTERVAL_SHIFT 0 +#define OMAP44XX_REG_TA_REFINTERVAL_MASK (0x3fffff << 0) + +/* OCP_ERR_LOG */ +#define OMAP44XX_REG_MADDRSPACE_SHIFT 14 +#define OMAP44XX_REG_MADDRSPACE_MASK (0x3 << 14) +#define OMAP44XX_REG_MBURSTSEQ_SHIFT 11 +#define OMAP44XX_REG_MBURSTSEQ_MASK (0x7 << 11) +#define OMAP44XX_REG_MCMD_SHIFT 8 +#define OMAP44XX_REG_MCMD_MASK (0x7 << 8) +#define OMAP44XX_REG_MCONNID_SHIFT 0 +#define OMAP44XX_REG_MCONNID_MASK (0xff << 0) + +/* DDR_PHY_CTRL_1 */ +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHIFT 4 +#define OMAP44XX_REG_DDR_PHY_CTRL_1_MASK (0xfffffff << 4) +#define OMAP44XX_REG_READ_LATENCY_SHIFT 0 +#define OMAP44XX_REG_READ_LATENCY_MASK (0xf << 0) +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHIFT 4 +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_MASK (0xFF << 4) +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHIFT 12 +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_MASK (0xFFFFF << 12) + +/* DDR_PHY_CTRL_1_SHDW */ +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHDW_SHIFT 4 +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHDW_MASK (0xfffffff << 4) +#define OMAP44XX_REG_READ_LATENCY_SHDW_SHIFT 0 +#define OMAP44XX_REG_READ_LATENCY_SHDW_MASK (0xf << 0) +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHDW_SHIFT 4 +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHDW_MASK (0xFF << 4) +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHDW_SHIFT 12 +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHDW_MASK (0xFFFFF << 12) + +/* DDR_PHY_CTRL_2 */ +#define OMAP44XX_REG_DDR_PHY_CTRL_2_SHIFT 0 +#define OMAP44XX_REG_DDR_PHY_CTRL_2_MASK (0xffffffff << 0) + +/* DMM */ +#define OMAP44XX_DMM_BASE 0x4E000000 +#define OMAP44XX_DMM_LISA_MAP_BASE (0x4E000000 + 0x40) + +/* DMM_LISA_MAP */ +#define OMAP44XX_SYS_ADDR_SHIFT 24 +#define OMAP44XX_SYS_ADDR_MASK (0xff << 24) +#define OMAP44XX_SYS_SIZE_SHIFT 20 +#define OMAP44XX_SYS_SIZE_MASK (0x7 << 20) +#define OMAP44XX_SDRC_INTL_SHIFT 18 +#define OMAP44XX_SDRC_INTL_MASK (0x3 << 18) +#define OMAP44XX_SDRC_ADDRSPC_SHIFT 16 +#define OMAP44XX_SDRC_ADDRSPC_MASK (0x3 << 16) +#define OMAP44XX_SDRC_MAP_SHIFT 8 +#define OMAP44XX_SDRC_MAP_MASK (0x3 << 8) +#define OMAP44XX_SDRC_ADDR_SHIFT 0 +#define OMAP44XX_SDRC_ADDR_MASK (0xff << 0) + +/* DMM_LISA_MAP fields */ +#define DMM_SDRC_MAP_UNMAPPED 0 +#define DMM_SDRC_MAP_EMIF1_ONLY 1 +#define DMM_SDRC_MAP_EMIF2_ONLY 2 +#define DMM_SDRC_MAP_EMIF1_AND_EMIF2 3 + +#define DMM_SDRC_INTL_NONE 0 +#define DMM_SDRC_INTL_128B 1 +#define DMM_SDRC_INTL_256B 2 +#define DMM_SDRC_INTL_512 3 + +#define DMM_SDRC_ADDR_SPC_SDRAM 0 +#define DMM_SDRC_ADDR_SPC_NVM 1 +#define DMM_SDRC_ADDR_SPC_INVALID 2 + +#define DMM_LISA_MAP_INTERLEAVED_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF1_AND_EMIF2 << OMAP44XX_SDRC_MAP_SHIFT) |\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT) |\ + (DMM_SDRC_INTL_128B << OMAP44XX_SDRC_INTL_SHIFT) |\ + (CONFIG_SYS_SDRAM_BASE << OMAP44XX_SYS_ADDR_SHIFT)) + +#define DMM_LISA_MAP_EMIF1_ONLY_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)) + +#define DMM_LISA_MAP_EMIF2_ONLY_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF2_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)) + +/* Trap for invalid TILER PAT entries */ +#define DMM_LISA_MAP_0_INVAL_ADDR_TRAP (\ + (0 << OMAP44XX_SDRC_ADDR_SHIFT) |\ + (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_INVALID << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)|\ + (0xFF << OMAP44XX_SYS_ADDR_SHIFT)) + + +/* Reg mapping structure */ +struct __attribute__ ((__packed__)) emif_reg_struct{ + u32 emif_mod_id_rev; + u32 emif_status; + u32 emif_sdram_config; + u32 emif_lpddr2_nvm_config; + u32 emif_sdram_ref_ctrl; + u32 emif_sdram_ref_ctrl_shdw; + u32 emif_sdram_tim_1; + u32 emif_sdram_tim_1_shdw; + u32 emif_sdram_tim_2; + u32 emif_sdram_tim_2_shdw; + u32 emif_sdram_tim_3; + u32 emif_sdram_tim_3_shdw; + u32 emif_lpddr2_nvm_tim; + u32 emif_lpddr2_nvm_tim_shdw; + u32 emif_pwr_mgmt_ctrl; + u32 emif_pwr_mgmt_ctrl_shdw; + u32 emif_lpddr2_mode_reg_data; + u32 padding1[1]; + u32 emif_lpddr2_mode_reg_data_es2; + u32 padding11[1]; + u32 emif_lpddr2_mode_reg_cfg; + u32 emif_l3_config; + u32 emif_l3_cfg_val_1; + u32 emif_l3_cfg_val_2; + u32 emif_iodft_tlgc; + u32 padding2[7]; + u32 emif_perf_cnt_1; + u32 emif_perf_cnt_2; + u32 emif_perf_cnt_cfg; + u32 emif_perf_cnt_sel; + u32 emif_perf_cnt_tim; + u32 padding3; + u32 emif_read_idlectrl; + u32 emif_read_idlectrl_shdw; + u32 padding4; + u32 emif_irqstatus_raw_sys; + u32 emif_irqstatus_raw_ll; + u32 emif_irqstatus_sys; + u32 emif_irqstatus_ll; + u32 emif_irqenable_set_sys; + u32 emif_irqenable_set_ll; + u32 emif_irqenable_clr_sys; + u32 emif_irqenable_clr_ll; + u32 padding5; + u32 emif_zq_config; + u32 emif_temp_alert_config; + u32 emif_l3_err_log; + u32 padding6[4]; + u32 emif_ddr_phy_ctrl_1; + u32 emif_ddr_phy_ctrl_1_shdw; + u32 emif_ddr_phy_ctrl_2; +}; + +struct __attribute__ ((__packed__)) dmm_lisa_map_regs { + u32 dmm_lisa_map_0; + u32 dmm_lisa_map_1; + u32 dmm_lisa_map_2; + u32 dmm_lisa_map_3; +}; + +#define CS0 0 +#define CS1 1 +/* Read Latency used by the device at reset */ +#define RL_BOOT 3 +/* Read Latency for the highest frequency you want to use */ +#define RL_FINAL 6 +/* EMIF_PWR_MGMT_CTRL register */ +/* Low power modes */ +#define LP_MODE_DISABLE 0 +#define LP_MODE_CLOCK_STOP 1 +#define LP_MODE_SELF_REFRESH 2 +#define LP_MODE_PWR_DN 3 + +/* REG_DPD_EN */ +#define DPD_DISABLE 0 +#define DPD_ENABLE 1 + +/* Maximum delay before Low Power Modes */ +#define REG_CS_TIM 0xF +#define REG_SR_TIM 0xF +#define REG_PD_TIM 0xF + +/* EMIF_PWR_MGMT_CTRL register */ +#define EMIF_PWR_MGMT_CTRL (\ + ((REG_CS_TIM << OMAP44XX_REG_CS_TIM_SHIFT) & OMAP44XX_REG_CS_TIM_MASK)|\ + ((REG_SR_TIM << OMAP44XX_REG_SR_TIM_SHIFT) & OMAP44XX_REG_SR_TIM_MASK)|\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHIFT) & OMAP44XX_REG_PD_TIM_MASK)|\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHIFT) & OMAP44XX_REG_PD_TIM_MASK)|\ + ((LP_MODE_DISABLE << OMAP44XX_REG_LP_MODE_SHIFT)\ + & OMAP44XX_REG_LP_MODE_MASK) |\ + ((DPD_DISABLE << OMAP44XX_REG_DPD_EN_SHIFT)\ + & OMAP44XX_REG_DPD_EN_MASK))\ + +#define EMIF_PWR_MGMT_CTRL_SHDW (\ + ((REG_CS_TIM << OMAP44XX_REG_CS_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_CS_TIM_SHDW_MASK) |\ + ((REG_SR_TIM << OMAP44XX_REG_SR_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_SR_TIM_SHDW_MASK) |\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_PD_TIM_SHDW_MASK) |\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_PD_TIM_SHDW_MASK)) + +/* EMIF_L3_CONFIG register value for ES1*/ +#define EMIF_L3_CONFIG_VAL_SYS_THRESH_0A_LL_THRESH_00 0x0A0000FF + +/* +* MR1 value: +* Burst length : 8 +* Burst type : sequential +* Wrap : enabled +* nWR : 3(default). EMIF does not do pre-charge. +* : So nWR is don't care +*/ +#define MR1_BL_8_BT_SEQ_WRAP_EN_NWR_3 0x23 + +/* MR2 */ +#define MR2_RL3_WL1 1 +#define MR2_RL4_WL2 2 +#define MR2_RL5_WL2 3 +#define MR2_RL6_WL3 4 + +/* MR10: ZQ calibration codes */ +#define MR10_ZQ_ZQCS 0x56 +#define MR10_ZQ_ZQCL 0xAB +#define MR10_ZQ_ZQINIT 0xFF +#define MR10_ZQ_ZQRESET 0xC3 + +/* MR16 value: refresh full array(no partial array self refresh) */ +#define MR16_REF_FULL_ARRAY 0 + +/* LPDDR2 IO reg values */ +#define CONTROL_LPDDR2IO_SLEW_125PS_DRV8_PULL_DOWN 0x1C1C1C1C +#define CONTROL_LPDDR2IO_SLEW_325PS_DRV8_GATE_KEEPER 0x9E9E9E9E + +/* CONTROL_EFUSE_2 */ +#define CONTROL_EFUSE_2_NMOS_PMOS_PTV_CODE_1 0x00ffc000 + +/* Mode register numbers */ +#define LPDDR2_MR0 0 +#define LPDDR2_MR1 1 +#define LPDDR2_MR2 2 +#define LPDDR2_MR3 3 +#define LPDDR2_MR4 4 +#define LPDDR2_MR5 5 +#define LPDDR2_MR6 6 +#define LPDDR2_MR7 7 +#define LPDDR2_MR8 8 +#define LPDDR2_MR9 9 +#define LPDDR2_MR10 10 +#define LPDDR2_MR11 11 +#define LPDDR2_MR16 16 +#define LPDDR2_MR17 17 +#define LPDDR2_MR18 18 + +/* MR0 */ +#define LPDDR2_MR0_DAI_SHIFT 0 +#define LPDDR2_MR0_DAI_MASK 1 +#define LPDDR2_MR0_DI_SHIFT 1 +#define LPDDR2_MR0_DI_MASK (1 << 1) +#define LPDDR2_MR0_DNVI_SHIFT 2 +#define LPDDR2_MR0_DNVI_MASK (1 << 2) + +/* + * Structure containing shadow of important registers in EMIF + * The calculation function fills in this structure to be later used for + * initialization and DVFS + */ +struct emif_regs { + u32 freq; + u32 sdram_config_init; + u32 sdram_config; + u32 ref_ctrl; + u32 sdram_tim1; + u32 sdram_tim2; + u32 sdram_tim3; + u32 read_idle_ctrl; + u32 zq_config; + u32 temp_alert_config; + u32 emif_ddr_phy_ctlr_1_init; + u32 emif_ddr_phy_ctlr_1; +}; + +void emif_get_reg_dump(const struct emif_regs **emif1_regs, + const struct emif_regs **emif2_regs); +void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs); + +#endif diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index 740ca9d..a1c4883 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -51,6 +51,17 @@ #define CONTROL_PADCONF_CORE (OMAP44XX_L4_CORE_BASE + 0x100000) #define CONTROL_PADCONF_WKUP (OMAP44XX_L4_CORE_BASE + 0x31E000)
+/* LPDDR2 IO regs */ +#define CONTROL_LPDDR2IO1_0 (CONTROL_PADCONF_CORE + 0x0638) +#define CONTROL_LPDDR2IO1_1 (CONTROL_PADCONF_CORE + 0x063C) +#define CONTROL_LPDDR2IO1_2 (CONTROL_PADCONF_CORE + 0x0640) +#define CONTROL_LPDDR2IO1_3 (CONTROL_PADCONF_CORE + 0x0644) +#define CONTROL_LPDDR2IO2_0 (CONTROL_PADCONF_CORE + 0x0648) +#define CONTROL_LPDDR2IO2_1 (CONTROL_PADCONF_CORE + 0x064C) +#define CONTROL_LPDDR2IO2_2 (CONTROL_PADCONF_CORE + 0x0650) +#define CONTROL_LPDDR2IO2_3 (CONTROL_PADCONF_CORE + 0x0654) +#define CONTROL_EFUSE_2 (CONTROL_PADCONF_CORE + 0x0704) + /* CONTROL_ID_CODE */ #define CONTROL_ID_CODE (CTRL_BASE + 0x204)
diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 3ac972d..3fce576 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -44,6 +44,7 @@ void bypass_dpll(u32 base); void freq_update_core(void); u32 get_sys_clk_freq(void); u32 omap4_ddr_clk(void); +void sdram_init(void); u32 omap4_revision(void); const char *omap4_rev_string(void);
diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 99247df..ae009d6 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -249,11 +249,6 @@ /* Defines for Clock init */ #define CONFIG_SYS_OMAP4_ABE_SYSCK
-/* Defines for SDRAM init */ -#define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION 1 -#define CONFIG_SYS_EMIF_UPDATE_TIMINGS 1 -#define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS 1 - /* Defines for SPL */ #define CONFIG_SPL #define CONFIG_SYS_SPL_TEXT_BASE 0x40304350 diff --git a/spl/board/ti/omap4.mk b/spl/board/ti/omap4.mk index 508dc3b..85b40ca 100644 --- a/spl/board/ti/omap4.mk +++ b/spl/board/ti/omap4.mk @@ -117,6 +117,13 @@ $(obj)clocks.c: @rm -f $@ @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/clocks.c $@
+$(obj)emif.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/emif.c $@ + +$(obj)sdram_elpida.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap4/sdram_elpida.c $@
SOBJS += lowlevel_init.o -COBJS += board.o clocks.o +COBJS += board.o clocks.o emif.o sdram_elpida.o
Dear Aneesh V,
- Changes for makefile changes
- Minor corrections in do_lpddr2_init()
- Minor corrections to read_idle interval calculation
- Sanity test of memory after doing the initialization
- Fixed warnings reported with with latest GCC compilers
I'm really surprised to see this patch at this position in the middle of this patch series.
Can you please explain why you think this is the right place for it?
On Monday 16 May 2011 01:31 AM, Wolfgang Denk wrote:
Dear Aneesh V,
Signed-off-by: Aneesh Vaneesh@ti.com V2:
This is roughly the sequence I followed. 1. Make the basic infrastructure. 2. Have a working skeleton of SPL(Just boots but doesn't do the loading part yet) 3. Add mux support. 4. Add clock initialization 5. Add SDRAM initialization(clock patch is a pre-requisite for this) 6. Add support for MMC initialization and loading of U-Boot 7. Add FAT mode boot support. 8. Add support for Panda
I think this will change a bit when I do some squashing as you suggested.
Dear Aneesh V,
- Make the basic infrastructure.
- Have a working skeleton of SPL(Just boots but doesn't do the loading part yet)
- Add mux support.
- Add clock initialization
- Add SDRAM initialization(clock patch is a pre-requisite for this)
- Add support for MMC initialization and loading of U-Boot
- Add FAT mode boot support.
- Add support for Panda
Thanks for the explanation. It was really helpful.
Dear Aneesh V,
Note that this needs to be fixed anyway to use standard macros (get rid of modify_reg_32() etc.)
Calculate EMIF register values based on AC timing parameters from the SDRAM datasheet and the DDR frequency rather than using the hard-coded values.
For a new board the user doen't have to go through the tedious process of calculating the register values. Instead, just provide the AC timings from the device data sheet as input and the driver will automatically calculate the register values.
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Changes for the make file changes --- arch/arm/cpu/armv7/omap-common/Makefile | 1 + arch/arm/cpu/armv7/omap-common/utils.c | 61 ++ arch/arm/cpu/armv7/omap4/Makefile | 1 - arch/arm/cpu/armv7/omap4/board.c | 9 +- arch/arm/cpu/armv7/omap4/emif.c | 861 ++++++++++++++++++++++++++- arch/arm/cpu/armv7/omap4/sdram_elpida.c | 152 +++++- arch/arm/include/asm/arch-omap4/emif.h | 304 ++++++++++- arch/arm/include/asm/arch-omap4/omap4.h | 18 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + include/configs/omap4_sdp4430.h | 5 + spl/board/ti/omap4.mk | 7 +- 11 files changed, 1404 insertions(+), 16 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/utils.c
diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index dc01ee5..8f698f8 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -28,6 +28,7 @@ LIB = $(obj)libomap-common.o SOBJS := reset.o
COBJS := timer.o +COBJS += utils.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/arch/arm/cpu/armv7/omap-common/utils.c b/arch/arm/cpu/armv7/omap-common/utils.c new file mode 100644 index 0000000..7dce7f1 --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/utils.c @@ -0,0 +1,61 @@ +/* + * Utility functions for OMAP4 + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +static void do_cancel_out(u32 *num, u32 *den, u32 factor) +{ + while (1) { + if (((*num)/factor*factor == (*num)) && + ((*den)/factor*factor == (*den))) { + (*num) /= factor; + (*den) /= factor; + } else + break; + } +} + +/* + * Cancel out the denominator and numerator of a fraction + * to get smaller numerator and denominator. + */ +void cancel_out(u32 *num, u32 *den, u32 den_limit) +{ + do_cancel_out(num, den, 2); + do_cancel_out(num, den, 3); + do_cancel_out(num, den, 5); + do_cancel_out(num, den, 7); + do_cancel_out(num, den, 11); + do_cancel_out(num, den, 13); + do_cancel_out(num, den, 17); + while ((*den) > den_limit) { + *num /= 2; + /* + * Round up the denominator so that the final fraction + * (num/den) is always <= the desired value + */ + *den = (*den + 1) / 2; + } +} diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index d9714fe..0b525e1 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -34,7 +34,6 @@ COBJS += clocks.o COBJS += emif.o COBJS += sdram_elpida.o
- SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS))
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 7add46b..a51d1bb 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -32,6 +32,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> +#include <asm/arch/emif.h> #include "omap4_mux_data.h"
DECLARE_GLOBAL_DATA_PTR; @@ -148,13 +149,13 @@ u32 sdram_size(void) { u32 section, i, total_size = 0, size, addr; for (i = 0; i < 4; i++) { - section = __raw_readl(DMM_LISA_MAP_BASE + i*4); - addr = section & DMM_LISA_MAP_SYS_ADDR_MASK; + section = __raw_readl(OMAP44XX_DMM_LISA_MAP_BASE + i*4); + addr = section & OMAP44XX_SYS_ADDR_MASK; /* See if the address is valid */ if ((addr >= OMAP44XX_DRAM_ADDR_SPACE_START) && (addr < OMAP44XX_DRAM_ADDR_SPACE_END)) { - size = ((section & DMM_LISA_MAP_SYS_SIZE_MASK) >> - DMM_LISA_MAP_SYS_SIZE_SHIFT); + size = ((section & OMAP44XX_SYS_SIZE_MASK) >> + OMAP44XX_SYS_SIZE_SHIFT); size = 1 << size; size *= SZ_16M; total_size += size; diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index 9591fb0..baa5ed6 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -32,6 +32,589 @@ #include <asm/omap_common.h> #include <asm/utils.h>
+DECLARE_GLOBAL_DATA_PTR; + +#define print_timing_reg(reg) debug(#reg" - 0x%08x\n", (reg)) + +static u32 *const T_num = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_NUM; +static u32 *const T_den = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_DEN; +static u32 *const emif_sizes = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_SIZE; + +/* + * Organization and refresh requirements for LPDDR2 devices of different + * types and densities. Derived from JESD209-2 section 2.4 + */ +const struct lpddr2_addressing addressing_table[] = { + /* Banks tREFIx10 rowx32,rowx16 colx32,colx16 density */ + {BANKS4, T_REFI_15_6, {ROW_12, ROW_12}, {COL_7, COL_8} },/*64M */ + {BANKS4, T_REFI_15_6, {ROW_12, ROW_12}, {COL_8, COL_9} },/*128M */ + {BANKS4, T_REFI_7_8, {ROW_13, ROW_13}, {COL_8, COL_9} },/*256M */ + {BANKS4, T_REFI_7_8, {ROW_13, ROW_13}, {COL_9, COL_10} },/*512M */ + {BANKS8, T_REFI_7_8, {ROW_13, ROW_13}, {COL_9, COL_10} },/*1GS4 */ + {BANKS8, T_REFI_3_9, {ROW_14, ROW_14}, {COL_9, COL_10} },/*2GS4 */ + {BANKS8, T_REFI_3_9, {ROW_14, ROW_14}, {COL_10, COL_11} },/*4G */ + {BANKS8, T_REFI_3_9, {ROW_15, ROW_15}, {COL_10, COL_11} },/*8G */ + {BANKS4, T_REFI_7_8, {ROW_14, ROW_14}, {COL_9, COL_10} },/*1GS2 */ + {BANKS4, T_REFI_3_9, {ROW_15, ROW_15}, {COL_9, COL_10} },/*2GS2 */ +}; + +static const u32 lpddr2_density_2_size_in_mbytes[] = { + 8, /* 64Mb */ + 16, /* 128Mb */ + 32, /* 256Mb */ + 64, /* 512Mb */ + 128, /* 1Gb */ + 256, /* 2Gb */ + 512, /* 4Gb */ + 1024, /* 8Gb */ + 2048, /* 16Gb */ + 4096 /* 32Gb */ +}; + +#ifdef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS +/* Base AC Timing values specified by JESD209-2 for 400MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_400_mhz = { + .max_freq = 400000000, + .RL = 6, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* Base AC Timing values specified by JESD209-2 for 333 MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_333_mhz = { + .max_freq = 333000000, + .RL = 5, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* Base AC Timing values specified by JESD209-2 for 200 MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_200_mhz = { + .max_freq = 200000000, + .RL = 3, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 20, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* + * Min tCK values specified by JESD209-2 + * Min tCK specifies the minimum duration of some AC timing parameters in terms + * of the number of cycles. If the calculated number of cycles based on the + * absolute time value is less than the min tCK value, min tCK value should + * be used instead. This typically happens at low frequencies. + */ +static const struct lpddr2_min_tck min_tck_jedec = { + .tRL = 3, + .tRP_AB = 3, + .tRCD = 3, + .tWR = 3, + .tRAS_MIN = 3, + .tRRD = 2, + .tWTR = 2, + .tXP = 2, + .tRTP = 2, + .tCKE = 3, + .tCKESR = 3, + .tFAW = 8 +}; + +static const struct lpddr2_ac_timings *jedec_ac_timings[MAX_NUM_SPEEDBINS] = { + &timings_jedec_200_mhz, + &timings_jedec_333_mhz, + &timings_jedec_400_mhz +}; + +static const struct lpddr2_device_timings jedec_default_timings = { + .ac_timings = jedec_ac_timings, + .min_tck = &min_tck_jedec +}; +#endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */ + +/* + * Calculate the period of DDR clock from frequency value and set the + * denominator and numerator in global variables for easy access later + */ +static void set_ddr_clk_period(u32 freq) +{ + /* + * period = 1/freq + * period_in_ns = 10^9/freq + */ + *T_num = 1000000000; + *T_den = freq; + cancel_out(T_num, T_den, 200); + +} + +/* + * Convert time in nano seconds to number of cycles of DDR clock + */ +static inline u32 ns_2_cycles(u32 ns) +{ + return ((ns * (*T_den)) + (*T_num) - 1) / (*T_num); +} + +/* + * ns_2_cycles with the difference that the time passed is 2 times the actual + * value(to avoid fractions). The cycles returned is for the original value of + * the timing parameter + */ +static inline u32 ns_x2_2_cycles(u32 ns) +{ + return ((ns * (*T_den)) + (*T_num) * 2 - 1) / ((*T_num) * 2); +} + +/* + * Find addressing table index based on the device's type(S2 or S4) and + * density + */ +s8 addressing_table_index(u8 type, u8 density, u8 width) +{ + u8 index; + if ((density > LPDDR2_DENSITY_8Gb) || (width == LPDDR2_IO_WIDTH_8)) + return -1; + + /* + * Look at the way ADDR_TABLE_INDEX* values have been defined + * in emif.h compared to LPDDR2_DENSITY_* values + * The table is layed out in the increasing order of density + * (ignoring type). The exceptions 1GS2 and 2GS2 have been placed + * at the end + */ + if ((type == LPDDR2_TYPE_S2) && (density == LPDDR2_DENSITY_1Gb)) + index = ADDR_TABLE_INDEX1GS2; + else if ((type == LPDDR2_TYPE_S2) && (density == LPDDR2_DENSITY_2Gb)) + index = ADDR_TABLE_INDEX2GS2; + else + index = density; + + debug("emif: addressing table index %d\n", index); + + return index; +} + +/* + * Find the the right timing table from the array of timing + * tables of the device using DDR clock frequency + */ +static const struct lpddr2_ac_timings *get_timings_table(const struct + lpddr2_ac_timings const *const *device_timings, + u32 freq) +{ + u32 i, temp, freq_nearest; + const struct lpddr2_ac_timings *timings = 0; + + emif_assert(freq <= MAX_LPDDR2_FREQ); + emif_assert(device_timings); + + /* + * Start with the maximum allowed frequency - that is always safe + */ + freq_nearest = MAX_LPDDR2_FREQ; + /* + * Find the timings table that has the max frequency value: + * i. Above or equal to the DDR frequency - safe + * ii. The lowest that satisfies condition (i) - optimal + */ + for (i = 0; (i < MAX_NUM_SPEEDBINS) && device_timings[i]; i++) { + temp = device_timings[i]->max_freq; + if ((temp >= freq) && (temp <= freq_nearest)) { + freq_nearest = temp; + timings = device_timings[i]; + } + } + debug("emif: timings table: %d\n", freq_nearest); + return timings; +} + +/* + * Finds the value of emif_sdram_config_reg + * All parameters are programmed based on the device on CS0. + * If there is a device on CS1, it will be same as that on CS0 or + * it will be NVM. We don't support NVM yet. + * If cs1_device pointer is NULL it is assumed that there is no device + * on CS1 + */ +static u32 get_sdram_config_reg(const struct lpddr2_device_details *cs0_device, + const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 RL) +{ + u32 config_reg = 0; + + set_bit_field(config_reg, OMAP44XX_REG_SDRAM_TYPE_SHIFT, + OMAP44XX_REG_SDRAM_TYPE_MASK, cs0_device->type + 4); + + set_bit_field(config_reg, OMAP44XX_REG_IBANK_POS_SHIFT, + OMAP44XX_REG_IBANK_POS_MASK, + EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING); + + set_bit_field(config_reg, OMAP44XX_REG_NARROW_MODE_SHIFT, + OMAP44XX_REG_NARROW_MODE_MASK, cs0_device->io_width); + + set_bit_field(config_reg, OMAP44XX_REG_CL_SHIFT, OMAP44XX_REG_CL_MASK, + RL); + + set_bit_field(config_reg, OMAP44XX_REG_ROWSIZE_SHIFT, + OMAP44XX_REG_ROWSIZE_MASK, + addressing->row_sz[cs0_device->io_width]); + + set_bit_field(config_reg, OMAP44XX_REG_IBANK_SHIFT, + OMAP44XX_REG_IBANK_MASK, addressing->num_banks); + + set_bit_field(config_reg, OMAP44XX_REG_EBANK_SHIFT, + OMAP44XX_REG_EBANK_MASK, + (cs1_device ? EBANK_CS1_EN : EBANK_CS1_DIS)); + + set_bit_field(config_reg, OMAP44XX_REG_PAGESIZE_SHIFT, + OMAP44XX_REG_PAGESIZE_MASK, + addressing->col_sz[cs0_device->io_width]); + + return config_reg; +} + +static u32 get_sdram_ref_ctrl(u32 freq, + const struct lpddr2_addressing *addressing) +{ + u32 ref_ctrl = 0, val = 0, freq_khz; + freq_khz = freq / 1000; + /* + * refresh rate to be set is 'tREFI * freq in MHz + * division by 10000 to account for khz and x10 in t_REFI_us_x10 + */ + val = addressing->t_REFI_us_x10 * freq_khz / 10000; + set_bit_field(ref_ctrl, OMAP44XX_REG_REFRESH_RATE_SHIFT, + OMAP44XX_REG_REFRESH_RATE_MASK, val); + + return ref_ctrl; +} + +static u32 get_sdram_tim_1_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck, + const struct lpddr2_addressing *addressing) +{ + u32 tim1 = 0, val = 0; + val = max(min_tck->tWTR, ns_x2_2_cycles(timings->tWTRx2)) - 1; + set_bit_field(tim1, OMAP44XX_REG_T_WTR_SHIFT, OMAP44XX_REG_T_WTR_MASK, + val); + + if (addressing->num_banks == BANKS8) + val = (timings->tFAW * (*T_den) + 4 * (*T_num) - 1) / + (4 * (*T_num)) - 1; + else + val = max(min_tck->tRRD, ns_2_cycles(timings->tRRD)) - 1; + + set_bit_field(tim1, OMAP44XX_REG_T_RRD_SHIFT, OMAP44XX_REG_T_RRD_MASK, + val); + + val = ns_2_cycles(timings->tRASmin + timings->tRPab) - 1; + set_bit_field(tim1, OMAP44XX_REG_T_RC_SHIFT, OMAP44XX_REG_T_RC_MASK, + val); + + val = max(min_tck->tRAS_MIN, ns_2_cycles(timings->tRASmin)) - 1; + set_bit_field(tim1, OMAP44XX_REG_T_RAS_SHIFT, OMAP44XX_REG_T_RAS_MASK, + val); + + val = max(min_tck->tWR, ns_2_cycles(timings->tWR)) - 1; + set_bit_field(tim1, OMAP44XX_REG_T_WR_SHIFT, OMAP44XX_REG_T_WR_MASK, + val); + + val = max(min_tck->tRCD, ns_2_cycles(timings->tRCD)) - 1; + set_bit_field(tim1, OMAP44XX_REG_T_RCD_SHIFT, OMAP44XX_REG_T_RCD_MASK, + val); + val = max(min_tck->tRP_AB, ns_2_cycles(timings->tRPab)) - 1; + set_bit_field(tim1, OMAP44XX_REG_T_RP_SHIFT, OMAP44XX_REG_T_RP_MASK, + val); + + return tim1; +} + +static u32 get_sdram_tim_2_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck) +{ + u32 tim2 = 0, val = 0; + val = max(min_tck->tCKE, timings->tCKE) - 1; + set_bit_field(tim2, OMAP44XX_REG_T_CKE_SHIFT, OMAP44XX_REG_T_CKE_MASK, + val); + + val = max(min_tck->tRTP, ns_x2_2_cycles(timings->tRTPx2)) - 1; + set_bit_field(tim2, OMAP44XX_REG_T_RTP_SHIFT, OMAP44XX_REG_T_RTP_MASK, + val); + + /* + * tXSRD = tRFCab + 10 ns. XSRD and XSNR should have the + * same value + */ + val = ns_2_cycles(timings->tXSR) - 1; + set_bit_field(tim2, OMAP44XX_REG_T_XSRD_SHIFT, OMAP44XX_REG_T_XSRD_MASK, + val); + set_bit_field(tim2, OMAP44XX_REG_T_XSNR_SHIFT, OMAP44XX_REG_T_XSNR_MASK, + val); + + val = max(min_tck->tXP, ns_x2_2_cycles(timings->tXPx2)) - 1; + set_bit_field(tim2, OMAP44XX_REG_T_XP_SHIFT, OMAP44XX_REG_T_XP_MASK, + val); + + return tim2; +} + +static u32 get_sdram_tim_3_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck, + const struct lpddr2_addressing *addressing) +{ + u32 tim3 = 0, val = 0; + val = min(timings->tRASmax * 10 / addressing->t_REFI_us_x10 - 1, 0xF); + set_bit_field(tim3, OMAP44XX_REG_T_RAS_MAX_SHIFT, + OMAP44XX_REG_T_RAS_MAX_MASK, val); + + val = ns_2_cycles(timings->tRFCab) - 1; + set_bit_field(tim3, OMAP44XX_REG_T_RFC_SHIFT, OMAP44XX_REG_T_RFC_MASK, + val); + + val = ns_x2_2_cycles(timings->tDQSCKMAXx2) - 1; + set_bit_field(tim3, OMAP44XX_REG_T_TDQSCKMAX_SHIFT, + OMAP44XX_REG_T_TDQSCKMAX_MASK, val); + + val = ns_2_cycles(timings->tZQCS) - 1; + set_bit_field(tim3, OMAP44XX_REG_ZQ_ZQCS_SHIFT, + OMAP44XX_REG_ZQ_ZQCS_MASK, val); + + val = max(min_tck->tCKESR, ns_2_cycles(timings->tCKESR)) - 1; + set_bit_field(tim3, OMAP44XX_REG_T_CKESR_SHIFT, + OMAP44XX_REG_T_CKESR_MASK, val); + + return tim3; +} + +static u32 get_zq_config_reg(const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 volt_ramp) +{ + u32 zq = 0, val = 0; + if (volt_ramp) + val = + EMIF_ZQCS_INTERVAL_DVFS_IN_US * 10 / + addressing->t_REFI_us_x10; + else + val = + EMIF_ZQCS_INTERVAL_NORMAL_IN_US * 10 / + addressing->t_REFI_us_x10; + set_bit_field(zq, OMAP44XX_REG_ZQ_REFINTERVAL_SHIFT, + OMAP44XX_REG_ZQ_REFINTERVAL_MASK, val); + + set_bit_field(zq, OMAP44XX_REG_ZQ_ZQCL_MULT_SHIFT, + OMAP44XX_REG_ZQ_ZQCL_MULT_MASK, REG_ZQ_ZQCL_MULT - 1); + + set_bit_field(zq, OMAP44XX_REG_ZQ_ZQINIT_MULT_SHIFT, + OMAP44XX_REG_ZQ_ZQINIT_MULT_MASK, REG_ZQ_ZQINIT_MULT - 1); + + set_bit_field(zq, OMAP44XX_REG_ZQ_SFEXITEN_SHIFT, + OMAP44XX_REG_ZQ_SFEXITEN_MASK, REG_ZQ_SFEXITEN_ENABLE); + + /* + * Assuming that two chipselects have a single calibration resistor + * If there are indeed two calibration resistors, then this flag should + * be enabled to take advantage of dual calibration feature. + * This data should ideally come from board files. But considering + * that none of the boards today have calibration resistors per CS, + * it would be an unnecessary overhead. + */ + set_bit_field(zq, OMAP44XX_REG_ZQ_DUALCALEN_SHIFT, + OMAP44XX_REG_ZQ_DUALCALEN_MASK, REG_ZQ_DUALCALEN_DISABLE); + + set_bit_field(zq, OMAP44XX_REG_ZQ_CS0EN_SHIFT, + OMAP44XX_REG_ZQ_CS0EN_MASK, REG_ZQ_CS0EN_ENABLE); + + set_bit_field(zq, OMAP44XX_REG_ZQ_CS1EN_SHIFT, + OMAP44XX_REG_ZQ_CS1EN_MASK, (cs1_device ? 1 : 0)); + + return zq; +} + +static u32 get_temp_alert_config(const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 is_derated) +{ + u32 alert = 0, interval; + interval = + TEMP_ALERT_POLL_INTERVAL_MS * 10000 / addressing->t_REFI_us_x10; + if (is_derated) + interval *= 4; + set_bit_field(alert, OMAP44XX_REG_TA_REFINTERVAL_SHIFT, + OMAP44XX_REG_TA_REFINTERVAL_MASK, interval); + + set_bit_field(alert, OMAP44XX_REG_TA_DEVCNT_SHIFT, + OMAP44XX_REG_TA_DEVCNT_MASK, TEMP_ALERT_CONFIG_DEVCT_1); + + set_bit_field(alert, OMAP44XX_REG_TA_DEVWDT_SHIFT, + OMAP44XX_REG_TA_DEVWDT_MASK, TEMP_ALERT_CONFIG_DEVWDT_32); + + set_bit_field(alert, OMAP44XX_REG_TA_SFEXITEN_SHIFT, + OMAP44XX_REG_TA_SFEXITEN_MASK, 1); + + set_bit_field(alert, OMAP44XX_REG_TA_CS0EN_SHIFT, + OMAP44XX_REG_TA_CS0EN_MASK, 1); + + set_bit_field(alert, OMAP44XX_REG_TA_CS1EN_SHIFT, + OMAP44XX_REG_TA_CS1EN_MASK, (cs1_device ? 1 : 0)); + + return alert; +} + +static u32 get_read_idle_ctrl_reg(u8 volt_ramp) +{ + u32 idle = 0, val = 0; + if (volt_ramp) + val = ns_2_cycles(READ_IDLE_INTERVAL_DVFS) / 64 + 1; + else + /*Maximum value in normal conditions - suggested by hw team */ + val = 0x1FF; + set_bit_field(idle, OMAP44XX_REG_READ_IDLE_INTERVAL_SHIFT, + OMAP44XX_REG_READ_IDLE_INTERVAL_MASK, val); + + set_bit_field(idle, OMAP44XX_REG_READ_IDLE_LEN_SHIFT, + OMAP44XX_REG_READ_IDLE_LEN_MASK, + EMIF_REG_READ_IDLE_LEN_VAL); + + return idle; +} + +static u32 get_ddr_phy_ctrl_1(u32 freq, u8 RL) +{ + u32 phy = 0, val = 0; + + set_bit_field(phy, OMAP44XX_REG_READ_LATENCY_SHIFT, + OMAP44XX_REG_READ_LATENCY_MASK, RL + 2); + + if (freq <= 100000000) + val = EMIF_DLL_SLAVE_DLY_CTRL_100_MHZ_AND_LESS; + else if (freq <= 200000000) + val = EMIF_DLL_SLAVE_DLY_CTRL_200_MHZ; + else + val = EMIF_DLL_SLAVE_DLY_CTRL_400_MHZ; + set_bit_field(phy, OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHIFT, + OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_MASK, val); + + /* Other fields are constant magic values. Hardcode them together */ + set_bit_field(phy, OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHIFT, + OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_MASK, + EMIF_DDR_PHY_CTRL_1_BASE_VAL); + + return phy; +} + +const char *get_lpddr2_type(u8 type_id) +{ + switch (type_id) { + case LPDDR2_TYPE_S4: + return "LPDDR2-S4"; + case LPDDR2_TYPE_S2: + return "LPDDR2-S2"; + default: + return NULL; + } +} + +const char *get_lpddr2_io_width(u8 width_id) +{ + switch (width_id) { + case LPDDR2_IO_WIDTH_8: + return "x8"; + case LPDDR2_IO_WIDTH_16: + return "x16"; + case LPDDR2_IO_WIDTH_32: + return "x32"; + default: + return NULL; + } +} + +const char *get_lpddr2_manufacturer(u32 manufacturer) +{ + switch (manufacturer) { + case LPDDR2_MANUFACTURER_SAMSUNG: + return "Samsung"; + case LPDDR2_MANUFACTURER_QIMONDA: + return "Qimonda"; + case LPDDR2_MANUFACTURER_ELPIDA: + return "Elpida"; + case LPDDR2_MANUFACTURER_ETRON: + return "Etron"; + case LPDDR2_MANUFACTURER_NANYA: + return "Nanya"; + case LPDDR2_MANUFACTURER_HYNIX: + return "Hynix"; + case LPDDR2_MANUFACTURER_MOSEL: + return "Mosel"; + case LPDDR2_MANUFACTURER_WINBOND: + return "Winbond"; + case LPDDR2_MANUFACTURER_ESMT: + return "ESMT"; + case LPDDR2_MANUFACTURER_SPANSION: + return "Spansion"; + case LPDDR2_MANUFACTURER_SST: + return "SST"; + case LPDDR2_MANUFACTURER_ZMOS: + return "ZMOS"; + case LPDDR2_MANUFACTURER_INTEL: + return "Intel"; + case LPDDR2_MANUFACTURER_NUMONYX: + return "Numonyx"; + case LPDDR2_MANUFACTURER_MICRON: + return "Micron"; + default: + return NULL; + } +} + static inline u32 emif_num(u32 base) { if (base == OMAP44XX_EMIF1) @@ -66,6 +649,127 @@ static inline void set_mr(u32 base, u32 cs, u32 mr_addr, u32 mr_val) writel(mr_addr, &emif->emif_lpddr2_mode_reg_cfg); writel(mr_val, &emif->emif_lpddr2_mode_reg_data); } + +static void emif_calculate_regs( + const struct emif_device_details *emif_dev_details, + u32 freq, struct emif_regs *regs) +{ + u32 temp, sys_freq; + const struct lpddr2_addressing *addressing; + const struct lpddr2_ac_timings *timings; + const struct lpddr2_min_tck *min_tck; + const struct lpddr2_device_details *cs0_dev_details = + emif_dev_details->cs0_device_details; + const struct lpddr2_device_details *cs1_dev_details = + emif_dev_details->cs1_device_details; + const struct lpddr2_device_timings *cs0_dev_timings = + emif_dev_details->cs0_device_timings; + + emif_assert(emif_dev_details); + emif_assert(regs); + /* + * You can not have a device on CS1 without one on CS0 + * So configuring EMIF without a device on CS0 doesn't + * make sense + */ + emif_assert(cs0_dev_details); + emif_assert(cs0_dev_details->type != LPDDR2_TYPE_NVM); + /* + * If there is a device on CS1 it should be same type as CS0 + * (or NVM. But NVM is not supported in this driver yet) + */ + emif_assert((cs1_dev_details == NULL) || + (cs1_dev_details->type == LPDDR2_TYPE_NVM) || + (cs0_dev_details->type == cs1_dev_details->type)); + emif_assert(freq <= MAX_LPDDR2_FREQ); + + set_ddr_clk_period(freq); + + /* + * The device on CS0 is used for all timing calculations + * There is only one set of registers for timings per EMIF. So, if the + * second CS(CS1) has a device, it should have the same timings as the + * device on CS0 + */ + timings = get_timings_table(cs0_dev_timings->ac_timings, freq); + emif_assert(timings); + min_tck = cs0_dev_timings->min_tck; + + temp = addressing_table_index(cs0_dev_details->type, + cs0_dev_details->density, + cs0_dev_details->io_width); + + emif_assert((temp >= 0)); + addressing = &(addressing_table[temp]); + emif_assert(addressing); + + sys_freq = get_sys_clk_freq(); + + regs->sdram_config_init = get_sdram_config_reg(cs0_dev_details, + cs1_dev_details, + addressing, RL_BOOT); + + regs->sdram_config = get_sdram_config_reg(cs0_dev_details, + cs1_dev_details, + addressing, RL_FINAL); + + regs->ref_ctrl = get_sdram_ref_ctrl(freq, addressing); + + regs->sdram_tim1 = get_sdram_tim_1_reg(timings, min_tck, addressing); + + regs->sdram_tim2 = get_sdram_tim_2_reg(timings, min_tck); + + regs->sdram_tim3 = get_sdram_tim_3_reg(timings, min_tck, addressing); + + regs->read_idle_ctrl = get_read_idle_ctrl_reg(LPDDR2_VOLTAGE_STABLE); + + regs->temp_alert_config = + get_temp_alert_config(cs1_dev_details, addressing, 0); + + regs->zq_config = get_zq_config_reg(cs1_dev_details, addressing, + LPDDR2_VOLTAGE_STABLE); + + regs->emif_ddr_phy_ctlr_1_init = + get_ddr_phy_ctrl_1(sys_freq / 2, RL_BOOT); + + regs->emif_ddr_phy_ctlr_1 = + get_ddr_phy_ctrl_1(freq, RL_FINAL); + + regs->freq = freq; + + print_timing_reg(regs->sdram_config_init); + print_timing_reg(regs->sdram_config); + print_timing_reg(regs->ref_ctrl); + print_timing_reg(regs->sdram_tim1); + print_timing_reg(regs->sdram_tim2); + print_timing_reg(regs->sdram_tim3); + print_timing_reg(regs->read_idle_ctrl); + print_timing_reg(regs->temp_alert_config); + print_timing_reg(regs->zq_config); + print_timing_reg(regs->emif_ddr_phy_ctlr_1); + print_timing_reg(regs->emif_ddr_phy_ctlr_1_init); +} + +static u32 get_emif_mem_size(struct emif_device_details *devices) +{ + u32 size_mbytes = 0, temp; + + if (!devices) + return 0; + + if (devices->cs0_device_details) { + temp = devices->cs0_device_details->density; + size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; + } + + if (devices->cs1_device_details) { + temp = devices->cs1_device_details->density; + size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; + } + /* convert to bytes */ + return size_mbytes << 20; +} + void emif_reset_phy(u32 base) { struct emif_reg_struct *emif = (struct emif_reg_struct *)base; @@ -175,14 +879,66 @@ static void emif_update_timings(u32 base, const struct emif_regs *regs)
static void do_sdram_init(u32 base) { - const struct emif_regs *regs, *tmp_regs; + struct emif_device_details dev_details; + const struct emif_regs *regs; + u32 in_sdram, emif_nr;
in_sdram = running_from_sdram(); emif_nr = (base == OMAP44XX_EMIF1) ? 1 : 2;
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS + const struct emif_regs *tmp_regs; emif_get_reg_dump(®s, &tmp_regs); regs = (emif_nr == 1) ? regs : tmp_regs; +#else + /* + * The user has not provided the register values. We need to + * calculate it based on the timings and the DDR frequency + */ + + const struct emif_device_details *dev_details_user_provided; + const struct emif_device_details *tmp_details; + struct emif_regs calculated_regs; + + /* We need some input about the devices from the user */ + emif_get_device_details(&dev_details_user_provided, &tmp_details); + dev_details_user_provided = (emif_nr == 1) ? dev_details_user_provided + : tmp_details; + if (!dev_details_user_provided) + return; + + dev_details.cs0_device_details = + dev_details_user_provided->cs0_device_details; + dev_details.cs1_device_details = + dev_details_user_provided->cs1_device_details; + + /* Return if no devices on this EMIF */ + if (!dev_details.cs0_device_details && + !dev_details.cs1_device_details) { + emif_sizes[emif_nr - 1] = 0; + return; + } + + if (!in_sdram) + emif_sizes[emif_nr - 1] = get_emif_mem_size(&dev_details); + +#ifdef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS + /* Use the base timings specified by JESD209-2 */ + dev_details.cs0_device_timings = &jedec_default_timings; + dev_details.cs1_device_timings = &jedec_default_timings; + +#else /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */ + dev_details.cs0_device_timings = + dev_details_user_provided->cs0_device_timings; + dev_details.cs1_device_timings = + dev_details_user_provided->cs1_device_timings; +#endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */ + /* Calculate the register values */ + emif_calculate_regs(&dev_details, omap4_ddr_clk(), &calculated_regs); + regs = &calculated_regs; + +#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */
/* * Initializing the LPDDR2 device can not happen from SDRAM. @@ -232,12 +988,111 @@ static void emif_post_init_config(u32 base) writel(0x80000000, &emif->emif_pwr_mgmt_ctrl); }
+/* Gets the encoding corresponding to a given DMM section size */ +u32 get_dmm_section_size_map(u32 section_size) +{ + /* + * Section size mapping: + * 0x0: 16-MiB section + * 0x1: 32-MiB section + * 0x2: 64-MiB section + * 0x3: 128-MiB section + * 0x4: 256-MiB section + * 0x5: 512-MiB section + * 0x6: 1-GiB section + * 0x7: 2-GiB section + */ + section_size >>= 24; /* divide by 16 MB */ + return log_2_n_round_down(section_size); +} + static void dmm_init(u32 base) { const struct dmm_lisa_map_regs *lisa_map_regs;
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS emif_get_dmm_regs(&lisa_map_regs); +#else + u32 emif1_size, emif2_size, mapped_size, section_map; + u32 section_cnt, sys_addr; + struct dmm_lisa_map_regs lis_map_regs_calculated; + + mapped_size = 0; + section_cnt = 3; + sys_addr = CONFIG_SYS_SDRAM_BASE; + emif1_size = emif_sizes[0]; + emif2_size = emif_sizes[1]; + debug("emif1_size 0x%x emif2_size 0x%x\n", emif1_size, emif2_size);
+ if (!emif1_size && !emif2_size) + return; + + /* symmetric interleaved section */ + if (emif1_size && emif2_size) { + mapped_size = min(emif1_size, emif2_size); + section_map = DMM_LISA_MAP_INTERLEAVED_BASE_VAL; + set_bit_field(section_map, OMAP44XX_SDRC_ADDR_SHIFT, + OMAP44XX_SDRC_ADDR_MASK, + 0); + set_bit_field(section_map, OMAP44XX_SYS_ADDR_SHIFT, + OMAP44XX_SYS_ADDR_MASK, + sys_addr >> 24); /* only MSB */ + set_bit_field(section_map, OMAP44XX_SYS_SIZE_SHIFT, + OMAP44XX_SYS_SIZE_MASK, + get_dmm_section_size_map(mapped_size * 2)); + lis_map_regs_calculated.dmm_lisa_map_3 = section_map; + emif1_size -= mapped_size; + emif2_size -= mapped_size; + sys_addr += (mapped_size * 2); + section_cnt--; + } + + /* + * Single EMIF section(we can have a maximum of 1 single EMIF + * section- either EMIF1 or EMIF2 or none, but not both) + */ + if (emif1_size) { + section_map = DMM_LISA_MAP_EMIF1_ONLY_BASE_VAL; + set_bit_field(section_map, OMAP44XX_SYS_SIZE_SHIFT, + OMAP44XX_SYS_SIZE_MASK, + get_dmm_section_size_map(emif1_size)); + set_bit_field(section_map, OMAP44XX_SDRC_ADDR_SHIFT, + OMAP44XX_SDRC_ADDR_MASK, + mapped_size >> 24); /* only MSB */ + set_bit_field(section_map, OMAP44XX_SYS_ADDR_SHIFT, + OMAP44XX_SYS_ADDR_MASK, + sys_addr >> 24); /* only MSB */ + section_cnt--; + } + if (emif2_size) { + section_map = DMM_LISA_MAP_EMIF2_ONLY_BASE_VAL; + set_bit_field(section_map, OMAP44XX_SYS_SIZE_SHIFT, + OMAP44XX_SYS_SIZE_MASK, + get_dmm_section_size_map(emif2_size)); + set_bit_field(section_map, OMAP44XX_SDRC_ADDR_SHIFT, + OMAP44XX_SDRC_ADDR_MASK, + mapped_size >> 24); /* only MSB */ + set_bit_field(section_map, OMAP44XX_SYS_ADDR_SHIFT, + OMAP44XX_SYS_ADDR_MASK, + sys_addr >> 24); /* only MSB */ + section_cnt--; + } + + if (section_cnt == 2) { + /* Only 1 section - either symmetric or single EMIF */ + lis_map_regs_calculated.dmm_lisa_map_3 = section_map; + lis_map_regs_calculated.dmm_lisa_map_2 = 0; + lis_map_regs_calculated.dmm_lisa_map_1 = 0; + } else { + /* 2 sections - 1 symmetric, 1 single EMIF */ + lis_map_regs_calculated.dmm_lisa_map_2 = section_map; + lis_map_regs_calculated.dmm_lisa_map_1 = 0; + } + /* TRAP for invalid TILER mappings in section 0 */ + lis_map_regs_calculated.dmm_lisa_map_0 = DMM_LISA_MAP_0_INVAL_ADDR_TRAP; + + lisa_map_regs = &lis_map_regs_calculated; +#endif struct dmm_lisa_map_regs *hw_lisa_map_regs = (struct dmm_lisa_map_regs *)base;
@@ -275,8 +1130,10 @@ static void dmm_init(u32 base) */ void sdram_init(void) { - u32 in_sdram; + if (omap4_hw_init_context() == OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_SPL) + return;
+ u32 in_sdram; in_sdram = running_from_sdram();
if (!in_sdram) { diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c index 37e808c..e7d2bd5 100644 --- a/arch/arm/cpu/armv7/omap4/sdram_elpida.c +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -29,6 +29,8 @@ #include <asm/arch/emif.h> #include <asm/arch/sys_proto.h>
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS + static const struct emif_regs emif_regs_elpida_200_mhz_2cs = { .sdram_config_init = 0x80000eb9, .sdram_config = 0x80001ab9, @@ -86,6 +88,131 @@ const struct dmm_lisa_map_regs lisa_map_2G_x_2_x_2 = {
void emif_get_reg_dump_sdp(const struct emif_regs **emif1_regs, const struct emif_regs **emif2_regs) + +#else + +static const struct lpddr2_ac_timings timings_elpida_400_mhz = { + .max_freq = 400000000, + .RL = 6, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_ac_timings timings_elpida_333_mhz = { + .max_freq = 333000000, + .RL = 5, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_ac_timings timings_elpida_200_mhz = { + .max_freq = 200000000, + .RL = 3, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 20, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_min_tck min_tck_elpida = { + .tRL = 3, + .tRP_AB = 3, + .tRCD = 3, + .tWR = 3, + .tRAS_MIN = 3, + .tRRD = 2, + .tWTR = 2, + .tXP = 2, + .tRTP = 2, + .tCKE = 3, + .tCKESR = 3, + .tFAW = 8 +}; + +static const struct lpddr2_ac_timings *elpida_ac_timings[MAX_NUM_SPEEDBINS] = { + &timings_elpida_200_mhz, + &timings_elpida_333_mhz, + &timings_elpida_400_mhz, +}; + +static const struct lpddr2_device_details elpida_2G_S4_details = { + .type = LPDDR2_TYPE_S4, + .density = LPDDR2_DENSITY_2Gb, + .io_width = LPDDR2_IO_WIDTH_32, + .manufacturer = LPDDR2_MANUFACTURER_ELPIDA +}; + +static const struct lpddr2_device_timings elpida_2G_S4_timings = { + .ac_timings = elpida_ac_timings, + .min_tck = &min_tck_elpida, +}; + +static const struct emif_device_details elpida_2G_S4_x_2 = { + .cs0_device_details = &elpida_2G_S4_details, + .cs1_device_details = &elpida_2G_S4_details, + .cs0_device_timings = &elpida_2G_S4_timings, + .cs1_device_timings = &elpida_2G_S4_timings +}; + +static const struct emif_device_details elpida_2G_S4_x_1 = { + .cs0_device_details = &elpida_2G_S4_details, + .cs1_device_details = NULL, + .cs0_device_timings = &elpida_2G_S4_timings, + .cs1_device_timings = NULL +}; + +#endif /* ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */ + +#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS + +static void emif_get_reg_dump_sdp(const struct emif_regs **emif1_regs, + const struct emif_regs **emif2_regs) { u32 omap4_rev = omap4_revision();
@@ -104,7 +231,8 @@ void emif_get_reg_dump(const struct emif_regs **emif1_regs, const struct emif_regs **emif2_regs) __attribute__((weak, alias("emif_get_reg_dump_sdp")));
-void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs **dmm_lisa_regs) +static void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs + **dmm_lisa_regs) { u32 omap_rev = omap4_revision();
@@ -116,3 +244,25 @@ void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs **dmm_lisa_regs)
void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) __attribute__((weak, alias("emif_get_dmm_regs_sdp"))); + +#else + +static void emif_get_device_details_sdp( + const struct emif_device_details **emif1_details, + const struct emif_device_details **emif2_details) +{ + u32 omap_rev = omap4_revision(); + + if (omap_rev == OMAP4430_ES1_0) { + *emif1_details = &elpida_2G_S4_x_1; + *emif2_details = &elpida_2G_S4_x_1; + } else { + *emif1_details = &elpida_2G_S4_x_2; + *emif2_details = &elpida_2G_S4_x_2; + } +} + +void emif_get_device_details(const struct emif_device_details **emif1_details, + const struct emif_device_details **emif2_details) + __attribute__((weak, alias("emif_get_device_details_sdp"))); +#endif diff --git a/arch/arm/include/asm/arch-omap4/emif.h b/arch/arm/include/asm/arch-omap4/emif.h index f2d54cb..8cc3230 100644 --- a/arch/arm/include/asm/arch-omap4/emif.h +++ b/arch/arm/include/asm/arch-omap4/emif.h @@ -591,10 +591,142 @@ struct __attribute__ ((__packed__)) dmm_lisa_map_regs {
#define CS0 0 #define CS1 1 +/* The maximum frequency at which the LPDDR2 interface can operate in Hz*/ +#define MAX_LPDDR2_FREQ 400000000 /* 400 MHz */ + +/* + * The period of DDR clk is represented as numerator and denominator for + * better accuracy in integer based calculations. However, if the numerator + * and denominator are very huge there may be chances of overflow in + * calculations. So, as a trade-off keep denominator(and consequently + * numerator) within a limit sacrificing some accuracy - but not much + * If denominator and numerator are already small (such as at 400 MHz) + * no adjustment is needed + */ +#define EMIF_PERIOD_DEN_LIMIT 1000 +/* + * Maximum number of different frequencies supported by EMIF driver + * Determines the number of entries in the pointer array for register + * cache + */ +#define EMIF_MAX_NUM_FREQUENCIES 6 +/* + * Indices into the Addressing Table array. + * One entry each for all the different types of devices with different + * addressing schemes + */ +#define ADDR_TABLE_INDEX64M 0 +#define ADDR_TABLE_INDEX128M 1 +#define ADDR_TABLE_INDEX256M 2 +#define ADDR_TABLE_INDEX512M 3 +#define ADDR_TABLE_INDEX1GS4 4 +#define ADDR_TABLE_INDEX2GS4 5 +#define ADDR_TABLE_INDEX4G 6 +#define ADDR_TABLE_INDEX8G 7 +#define ADDR_TABLE_INDEX1GS2 8 +#define ADDR_TABLE_INDEX2GS2 9 +#define ADDR_TABLE_INDEXMAX 10 + +/* Number of Row bits */ +#define ROW_9 0 +#define ROW_10 1 +#define ROW_11 2 +#define ROW_12 3 +#define ROW_13 4 +#define ROW_14 5 +#define ROW_15 6 +#define ROW_16 7 + +/* Number of Column bits */ +#define COL_8 0 +#define COL_9 1 +#define COL_10 2 +#define COL_11 3 +#define COL_7 4 /*Not supported by OMAP included for completeness */ + +/* Number of Banks*/ +#define BANKS1 0 +#define BANKS2 1 +#define BANKS4 2 +#define BANKS8 3 + +/* Refresh rate in micro seconds x 10 */ +#define T_REFI_15_6 156 +#define T_REFI_7_8 78 +#define T_REFI_3_9 39 + +#define EBANK_CS1_DIS 0 +#define EBANK_CS1_EN 1 + /* Read Latency used by the device at reset */ #define RL_BOOT 3 /* Read Latency for the highest frequency you want to use */ #define RL_FINAL 6 + +/* Interleaving policies at EMIF level- between banks and Chip Selects */ +#define EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING 0 +#define EMIF_INTERLEAVING_POLICY_NO_BANK_INTERLEAVING 3 + +/* + * Interleaving policy to be used + * Currently set to MAX interleaving for better performance + */ +#define EMIF_INTERLEAVING_POLICY EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING + +/* State of the core voltage: + * This is important for some parameters such as read idle control and + * ZQ calibration timings. Timings are much stricter when voltage ramp + * is happening compared to when the voltage is stable. + * We need to calculate two sets of values for these parameters and use + * them accordingly + */ +#define LPDDR2_VOLTAGE_STABLE 0 +#define LPDDR2_VOLTAGE_RAMPING 1 + +/* Length of the forced read idle period in terms of cycles */ +#define EMIF_REG_READ_IDLE_LEN_VAL 5 + +/* Interval between forced 'read idles' */ +/* To be used when voltage is changed for DPS/DVFS - 1us */ +#define READ_IDLE_INTERVAL_DVFS (1*1000) +/* + * To be used when voltage is not scaled except by Smart Reflex + * 50us - or maximum value will do + */ +#define READ_IDLE_INTERVAL_NORMAL (50*1000) + + +/* + * Unless voltage is changing due to DVFS one ZQCS command every 50ms should + * be enough. This shoule be enough also in the case when voltage is changing + * due to smart-reflex. + */ +#define EMIF_ZQCS_INTERVAL_NORMAL_IN_US (50*1000) +/* + * If voltage is changing due to DVFS ZQCS should be performed more + * often(every 50us) + */ +#define EMIF_ZQCS_INTERVAL_DVFS_IN_US 50 + +/* The interval between ZQCL commands as a multiple of ZQCS interval */ +#define REG_ZQ_ZQCL_MULT 4 +/* The interval between ZQINIT commands as a multiple of ZQCL interval */ +#define REG_ZQ_ZQINIT_MULT 3 +/* Enable ZQ Calibration on exiting Self-refresh */ +#define REG_ZQ_SFEXITEN_ENABLE 1 +/* + * ZQ Calibration simultaneously on both chip-selects: + * Needs one calibration resistor per CS + * None of the boards that we know of have this capability + * So disabled by default + */ +#define REG_ZQ_DUALCALEN_DISABLE 0 +/* + * Enable ZQ Calibration by default on CS0. If we are asked to program + * the EMIF there will be something connected to CS0 for sure + */ +#define REG_ZQ_CS0EN_ENABLE 1 + /* EMIF_PWR_MGMT_CTRL register */ /* Low power modes */ #define LP_MODE_DISABLE 0 @@ -634,6 +766,16 @@ struct __attribute__ ((__packed__)) dmm_lisa_map_regs {
/* EMIF_L3_CONFIG register value for ES1*/ #define EMIF_L3_CONFIG_VAL_SYS_THRESH_0A_LL_THRESH_00 0x0A0000FF +/* + * Value of bits 12:31 of DDR_PHY_CTRL_1 register: + * All these fields have magic values dependent on frequency and + * determined by PHY and DLL integration with EMIF. Setting the magic + * values suggested by hw team. + */ +#define EMIF_DDR_PHY_CTRL_1_BASE_VAL 0x049FF +#define EMIF_DLL_SLAVE_DLY_CTRL_400_MHZ 0x41 +#define EMIF_DLL_SLAVE_DLY_CTRL_200_MHZ 0x80 +#define EMIF_DLL_SLAVE_DLY_CTRL_100_MHZ_AND_LESS 0xFF
/* * MR1 value: @@ -657,16 +799,51 @@ struct __attribute__ ((__packed__)) dmm_lisa_map_regs { #define MR10_ZQ_ZQINIT 0xFF #define MR10_ZQ_ZQRESET 0xC3
+/* TEMP_ALERT_CONFIG */ +#define TEMP_ALERT_POLL_INTERVAL_MS 360 /* for temp gradient - 5 C/s */ +#define TEMP_ALERT_CONFIG_DEVCT_1 0 +#define TEMP_ALERT_CONFIG_DEVWDT_32 2 + /* MR16 value: refresh full array(no partial array self refresh) */ #define MR16_REF_FULL_ARRAY 0
-/* LPDDR2 IO reg values */ +/* LPDDR2 IO regs */ #define CONTROL_LPDDR2IO_SLEW_125PS_DRV8_PULL_DOWN 0x1C1C1C1C #define CONTROL_LPDDR2IO_SLEW_325PS_DRV8_GATE_KEEPER 0x9E9E9E9E
/* CONTROL_EFUSE_2 */ #define CONTROL_EFUSE_2_NMOS_PMOS_PTV_CODE_1 0x00ffc000
+/* + * Maximum number of entries we keep in our array of timing tables + * We need not keep all the speed bins supported by the device + * We need to keep timing tables for only the speed bins that we + * are interested in + */ +#define MAX_NUM_SPEEDBINS 4 + +/* LPDDR2 Densities */ +#define LPDDR2_DENSITY_64Mb 0 +#define LPDDR2_DENSITY_128Mb 1 +#define LPDDR2_DENSITY_256Mb 2 +#define LPDDR2_DENSITY_512Mb 3 +#define LPDDR2_DENSITY_1Gb 4 +#define LPDDR2_DENSITY_2Gb 5 +#define LPDDR2_DENSITY_4Gb 6 +#define LPDDR2_DENSITY_8Gb 7 +#define LPDDR2_DENSITY_16Gb 8 +#define LPDDR2_DENSITY_32Gb 9 + +/* LPDDR2 type */ +#define LPDDR2_TYPE_S4 0 +#define LPDDR2_TYPE_S2 1 +#define LPDDR2_TYPE_NVM 2 + +/* LPDDR2 IO width */ +#define LPDDR2_IO_WIDTH_32 0 +#define LPDDR2_IO_WIDTH_16 1 +#define LPDDR2_IO_WIDTH_8 2 + /* Mode register numbers */ #define LPDDR2_MR0 0 #define LPDDR2_MR1 1 @@ -692,6 +869,119 @@ struct __attribute__ ((__packed__)) dmm_lisa_map_regs { #define LPDDR2_MR0_DNVI_SHIFT 2 #define LPDDR2_MR0_DNVI_MASK (1 << 2)
+/* MR4 */ +#define MR4_SDRAM_REF_RATE_SHIFT 0 +#define MR4_SDRAM_REF_RATE_MASK 7 +#define MR4_TUF_SHIFT 7 +#define MR4_TUF_MASK (1 << 7) + +/* MR4 SDRAM Refresh Rate field values */ +#define SDRAM_TEMP_LESS_LOW_SHUTDOWN 0x0 +#define SDRAM_TEMP_LESS_4X_REFRESH_AND_TIMINGS 0x1 +#define SDRAM_TEMP_LESS_2X_REFRESH_AND_TIMINGS 0x2 +#define SDRAM_TEMP_NOMINAL 0x3 +#define SDRAM_TEMP_RESERVED_4 0x4 +#define SDRAM_TEMP_HIGH_DERATE_REFRESH 0x5 +#define SDRAM_TEMP_HIGH_DERATE_REFRESH_AND_TIMINGS 0x6 +#define SDRAM_TEMP_VERY_HIGH_SHUTDOWN 0x7 + +#define LPDDR2_MANUFACTURER_SAMSUNG 1 +#define LPDDR2_MANUFACTURER_QIMONDA 2 +#define LPDDR2_MANUFACTURER_ELPIDA 3 +#define LPDDR2_MANUFACTURER_ETRON 4 +#define LPDDR2_MANUFACTURER_NANYA 5 +#define LPDDR2_MANUFACTURER_HYNIX 6 +#define LPDDR2_MANUFACTURER_MOSEL 7 +#define LPDDR2_MANUFACTURER_WINBOND 8 +#define LPDDR2_MANUFACTURER_ESMT 9 +#define LPDDR2_MANUFACTURER_SPANSION 11 +#define LPDDR2_MANUFACTURER_SST 12 +#define LPDDR2_MANUFACTURER_ZMOS 13 +#define LPDDR2_MANUFACTURER_INTEL 14 +#define LPDDR2_MANUFACTURER_NUMONYX 254 +#define LPDDR2_MANUFACTURER_MICRON 255 + +/* MR8 register fields */ +#define MR8_TYPE_SHIFT 0x0 +#define MR8_TYPE_MASK 0x3 +#define MR8_DENSITY_SHIFT 0x2 +#define MR8_DENSITY_MASK (0xF << 0x2) +#define MR8_IO_WIDTH_SHIFT 0x6 +#define MR8_IO_WIDTH_MASK (0x3 << 0x6) + +struct lpddr2_addressing { + u8 num_banks; + u8 t_REFI_us_x10; + u8 row_sz[2]; /* One entry each for x32 and x16 */ + u8 col_sz[2]; /* One entry each for x32 and x16 */ +}; + +/* Structure for timings from the DDR datasheet */ +struct lpddr2_ac_timings { + u32 max_freq; + u8 RL; + u8 tRPab; + u8 tRCD; + u8 tWR; + u8 tRASmin; + u8 tRRD; + u8 tWTRx2; + u8 tXSR; + u8 tXPx2; + u8 tRFCab; + u8 tRTPx2; + u8 tCKE; + u8 tCKESR; + u8 tZQCS; + u32 tZQCL; + u32 tZQINIT; + u8 tDQSCKMAXx2; + u8 tRASmax; + u8 tFAW; + +}; + +/* + * Min tCK values for some of the parameters: + * If the calculated clock cycles for the respective parameter is + * less than the corresponding min tCK value, we need to set the min + * tCK value. This may happen at lower frequencies. + */ +struct lpddr2_min_tck { + u32 tRL; + u32 tRP_AB; + u32 tRCD; + u32 tWR; + u32 tRAS_MIN; + u32 tRRD; + u32 tWTR; + u32 tXP; + u32 tRTP; + u8 tCKE; + u32 tCKESR; + u32 tFAW; +}; + +struct lpddr2_device_details { + u8 type; + u8 density; + u8 io_width; + u8 manufacturer; +}; + +struct lpddr2_device_timings { + const struct lpddr2_ac_timings **ac_timings; + const struct lpddr2_min_tck *min_tck; +}; + +/* Details of the devices connected to each chip-select of an EMIF instance */ +struct emif_device_details { + const struct lpddr2_device_details *cs0_device_details; + const struct lpddr2_device_details *cs1_device_details; + const struct lpddr2_device_timings *cs0_device_timings; + const struct lpddr2_device_timings *cs1_device_timings; +}; + /* * Structure containing shadow of important registers in EMIF * The calculation function fills in this structure to be later used for @@ -712,8 +1002,20 @@ struct emif_regs { u32 emif_ddr_phy_ctlr_1; };
+/* assert macros */ +#if defined(DEBUG) +#define emif_assert(c) ({ if (!(c)) for (;;); }) +#else +#define emif_assert(c) ({ if (0) hang(); }) +#endif + +#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS void emif_get_reg_dump(const struct emif_regs **emif1_regs, const struct emif_regs **emif2_regs); void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs); +#else +void emif_get_device_details(const struct emif_device_details **emif1_details, + const struct emif_device_details **emif2_details); +#endif
#endif diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index a1c4883..fd8fb10 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -86,12 +86,7 @@ /* GPMC */ #define OMAP44XX_GPMC_BASE 0x50000000
-/* DMM */ -#define OMAP44XX_DMM_BASE 0x4E000000 -#define DMM_LISA_MAP_BASE (OMAP44XX_DMM_BASE + 0x40) -#define DMM_LISA_MAP_SYS_SIZE_MASK (7 << 20) -#define DMM_LISA_MAP_SYS_SIZE_SHIFT 20 -#define DMM_LISA_MAP_SYS_ADDR_MASK (0xFF << 24) + /* * Hardware Register Details */ @@ -137,6 +132,17 @@ struct s32ktimer { /* Temporary SRAM stack used while low level init is done */ #define LOW_LEVEL_SRAM_STACK NON_SECURE_SRAM_END
+#define SRAM_SCRATCH_SPACE_ADDR NON_SECURE_SRAM_START + +/* + * SRAM scratch space entries + */ + +/* Boot parameter passed from SPL to U-Boot */ +#define OMAP4_SRAM_SCRATCH_EMIF_SIZE SRAM_SCRATCH_SPACE_ADDR +#define OMAP4_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0x8) +#define OMAP4_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0xC) + /* Silicon revisions */ #define OMAP4430_SILICON_ID_INVALID 0 #define OMAP4430_ES1_0 1 diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 3fce576..46064f1 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -44,6 +44,7 @@ void bypass_dpll(u32 base); void freq_update_core(void); u32 get_sys_clk_freq(void); u32 omap4_ddr_clk(void); +void cancel_out(u32 *num, u32 *den, u32 den_limit); void sdram_init(void); u32 omap4_revision(void); const char *omap4_rev_string(void); diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index ae009d6..d5f98dc 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -249,6 +249,11 @@ /* Defines for Clock init */ #define CONFIG_SYS_OMAP4_ABE_SYSCK
+/* Defines for SDRAM init */ +#ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS 1 +#endif + /* Defines for SPL */ #define CONFIG_SPL #define CONFIG_SYS_SPL_TEXT_BASE 0x40304350 diff --git a/spl/board/ti/omap4.mk b/spl/board/ti/omap4.mk index 85b40ca..a0e2142 100644 --- a/spl/board/ti/omap4.mk +++ b/spl/board/ti/omap4.mk @@ -97,8 +97,13 @@ $(obj)spl-omap.c: @rm -f $@ @ln -s $(TOPDIR)/spl/board/ti/spl-omap.c $@
+$(obj)utils.c: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/omap-common/utils.c $@ + + SOBJS += reset.o -COBJS += timer.o spl-omap.o +COBJS += timer.o spl-omap.o utils.o
# omap4 $(obj)lowlevel_init.S:
Dear Aneesh V,
Does it make sense to do this in the driver code? These parameters will never change, so why can we not rather perform the computation only once, at build time, and feed in the respective parameters to the driver?
Reasons why I am concerned about such an approach are code size and boot time. Both suffer ...
Wolfgang Denk wd@denx.de writes:
Dear Aneesh V,
I agree, there should be no reason for doing this at runtime. I would think it possible to do with some C macros.
Hi Mans,
On Monday 16 May 2011 02:12 AM, Måns Rullgård wrote:
Wolfgang Denkwd@denx.de writes:
Dear Aneesh V,
I had a C macro version earlier. But as I have mentioned in my reply to Wolfgang some of the inputs vary between different revisions of our silicon. I am doing a run-time identification of the revision and doing the settings accordingly.
Besides, the forest of MACROs was really ugly.
best regards, Aneesh
Hi Wolfgang,
On Monday 16 May 2011 01:35 AM, Wolfgang Denk wrote:
Dear Aneesh V,
Some of the parameters do change. For instance on one of the OMAP4 revisions the DDR runs at 200MHz, on another one at 380MHz and for the rest at 400MHz. Also, on ES1 we have 512 MB of memory where as on others we have 1GB. This driver is also doing discovery of SDRAM geometry, type, etc.
I had the same concerns too. So, I have provided a CONFIG option - CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS - by which the user can provide the register values, so no computation will be done.
So, if somebody is concerned about the performance they can just compute the values using this driver and print them out by enabling the debug traces, fill it up in the structs provided for it and enable CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS. That should work.
Also, please note that I had measured the time taken for the entire SDRAM initialization and it was not at all significant(IIRC, it was less than 1ms).
Dear Aneesh V,
Ah, great. Sorry, I have missed this.
Will this also comment out the respective code, so we don't waste the memory for it?
Thanks!
Hi Wolfgang,
On Wednesday 18 May 2011 03:24 AM, Wolfgang Denk wrote:
Dear Aneesh V,
In SPL yes, because I am using -ffunction-sections -fdata-sections along with --gc-sections, but not in U-Boot. I shall take care of this in the next revision.
BTW, I was thinking that I should enable -ffunction-sections -fdata-sections in OMAP U-Boot too. What do you think?
Identify SDRAM devices connected to EMIF automatically: LPDDR2 devices have some Mode Registers that provide details about the device such as the type, density, bus width etc. EMIF has the capability to read these registers. If there are not devices connected to a given chip-select reading mode registers will return junk values. After reading as many such registers as possible and matching with expected ranges of values the driver can identify if there is a device connected to the respective CS. If we identify that a device is connected the values read give us complete details about the device.
This along with the base AC timings specified by JESD209-2 allows us to do a complete automatic initialization of SDRAM that works on all boards.
Please note that the default AC timings specified by JESD209-2 will be safe for all devices but not necessarily optimal. However, for the Elpida devices used on Panda and SDP the default timings are both safe and optimal.
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap4/emif.c | 177 +++++++++++++++++++++++++++++- arch/arm/cpu/armv7/omap4/sdram_elpida.c | 9 +- include/configs/omap4_sdp4430.h | 1 + 3 files changed, 176 insertions(+), 11 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index baa5ed6..b09aa8f 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -166,7 +166,8 @@ static const struct lpddr2_min_tck min_tck_jedec = { .tFAW = 8 };
-static const struct lpddr2_ac_timings *jedec_ac_timings[MAX_NUM_SPEEDBINS] = { +static const struct lpddr2_ac_timings const* + jedec_ac_timings[MAX_NUM_SPEEDBINS] = { &timings_jedec_200_mhz, &timings_jedec_333_mhz, &timings_jedec_400_mhz @@ -780,6 +781,146 @@ void emif_reset_phy(u32 base) writel(iodft, &emif->emif_iodft_tlgc); }
+#ifdef CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION +static void display_sdram_details(u32 emif_nr, u32 cs, + struct lpddr2_device_details *device) +{ + const char *mfg_str; + const char *type_str; + char density_str[10]; + u32 density; + + debug("EMIF%d CS%d\t", emif_nr, cs); + + if (!device) { + debug("None\n"); + return; + } + + mfg_str = get_lpddr2_manufacturer(device->manufacturer); + type_str = get_lpddr2_type(device->type); + + density = lpddr2_density_2_size_in_mbytes[device->density]; + if ((density / 1024 * 1024) == density) { + density /= 1024; + sprintf(density_str, "%d GB", density); + } else + sprintf(density_str, "%d MB", density); + if (mfg_str && type_str) + debug("%s\t\t%s\t%s\n", mfg_str, type_str, density_str); +} + +static u8 is_lpddr2_sdram_present(u32 base, u32 cs, + struct lpddr2_device_details *lpddr2_device) +{ + u32 mr = 0, temp; + + mr = get_mr(base, cs, LPDDR2_MR0); + if (mr > 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + temp = get_bit_field(mr, LPDDR2_MR0_DI_SHIFT, LPDDR2_MR0_DI_MASK); + if (temp) { + /* Not SDRAM */ + return 0; + } + temp = get_bit_field(mr, LPDDR2_MR0_DNVI_SHIFT, LPDDR2_MR0_DNVI_MASK); + + if (temp) { + /* DNV supported - But DNV is only supported for NVM */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR4); + if (mr > 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR5); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + if (!get_lpddr2_manufacturer(mr)) { + /* Manufacturer not identified */ + return 0; + } + lpddr2_device->manufacturer = mr; + + mr = get_mr(base, cs, LPDDR2_MR6); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR7); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR8); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + temp = get_bit_field(mr, MR8_TYPE_SHIFT, MR8_TYPE_MASK); + if (!get_lpddr2_type(temp)) { + /* Not SDRAM */ + return 0; + } + lpddr2_device->type = temp; + + temp = get_bit_field(mr, MR8_DENSITY_SHIFT, MR8_DENSITY_MASK); + if (temp > LPDDR2_DENSITY_32Gb) { + /* Density not supported */ + return 0; + } + lpddr2_device->density = temp; + + temp = get_bit_field(mr, MR8_IO_WIDTH_SHIFT, MR8_IO_WIDTH_MASK); + if (!get_lpddr2_io_width(temp)) { + /* IO width unsupported value */ + return 0; + } + lpddr2_device->io_width = temp; + + /* + * If all the above tests pass we should + * have a device on this chip-select + */ + return 1; +} + +static struct lpddr2_device_details *get_lpddr2_details(u32 base, u8 cs, + struct lpddr2_device_details *lpddr2_dev_details) +{ + u32 phy; + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + if (!lpddr2_dev_details) + return NULL; + + /* Do the minimum init for mode register accesses */ + if (!running_from_sdram()) { + phy = get_ddr_phy_ctrl_1(get_sys_clk_freq() / 2, RL_BOOT); + writel(phy, &emif->emif_ddr_phy_ctrl_1); + } + + if (!(is_lpddr2_sdram_present(base, cs, lpddr2_dev_details))) + return NULL; + + display_sdram_details(emif_num(base), cs, lpddr2_dev_details); + + return lpddr2_dev_details; +} +#endif /* CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION */ + static void do_lpddr2_init(u32 base, u32 cs) { u32 mr_addr; @@ -879,9 +1020,7 @@ static void emif_update_timings(u32 base, const struct emif_regs *regs)
static void do_sdram_init(u32 base) { - struct emif_device_details dev_details; const struct emif_regs *regs; - u32 in_sdram, emif_nr;
in_sdram = running_from_sdram(); @@ -889,6 +1028,7 @@ static void do_sdram_init(u32 base)
#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS const struct emif_regs *tmp_regs; + emif_get_reg_dump(®s, &tmp_regs); regs = (emif_nr == 1) ? regs : tmp_regs; #else @@ -896,23 +1036,48 @@ static void do_sdram_init(u32 base) * The user has not provided the register values. We need to * calculate it based on the timings and the DDR frequency */ + struct emif_device_details dev_details = { NULL, NULL }; + struct emif_regs calculated_regs;
+#if !defined(CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION) || \ + !defined(CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS) + + /* We need some input about the devices from the user */ const struct emif_device_details *dev_details_user_provided; const struct emif_device_details *tmp_details; - struct emif_regs calculated_regs;
- /* We need some input about the devices from the user */ emif_get_device_details(&dev_details_user_provided, &tmp_details); dev_details_user_provided = (emif_nr == 1) ? dev_details_user_provided : tmp_details; if (!dev_details_user_provided) return; +#endif
+#ifdef CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION + struct lpddr2_device_details cs0_dev_details, cs1_dev_details; + + /* Automatically find the device details */ + if (!in_sdram) { + dev_details.cs0_device_details = + get_lpddr2_details(base, CS0, &cs0_dev_details); + dev_details.cs1_device_details = + get_lpddr2_details(base, CS1, &cs1_dev_details); + /* + * Reset the PHY - if there is nothing connected on any + * of the chip selects(typically CS1) mode register reads + * will mess up with the PHY state and subsequent + * initialization won't work. PHY reset brings back PHY to + * a good state. + */ + emif_reset_phy(base); + } +#else dev_details.cs0_device_details = dev_details_user_provided->cs0_device_details; dev_details.cs1_device_details = dev_details_user_provided->cs1_device_details;
+#endif /* Return if no devices on this EMIF */ if (!dev_details.cs0_device_details && !dev_details.cs1_device_details) { diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c index e7d2bd5..8dfe6f9 100644 --- a/arch/arm/cpu/armv7/omap4/sdram_elpida.c +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -86,10 +86,8 @@ const struct dmm_lisa_map_regs lisa_map_2G_x_2_x_2 = { .dmm_lisa_map_3 = 0x80640300 };
-void emif_get_reg_dump_sdp(const struct emif_regs **emif1_regs, - const struct emif_regs **emif2_regs) - -#else +#elif !defined(CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION) || \ + !defined(CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS)
static const struct lpddr2_ac_timings timings_elpida_400_mhz = { .max_freq = 400000000, @@ -245,7 +243,8 @@ static void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) __attribute__((weak, alias("emif_get_dmm_regs_sdp")));
static void emif_get_device_details_sdp( const struct emif_device_details **emif1_details, diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index d5f98dc..13e7623 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -251,6 +251,7 @@
/* Defines for SDRAM init */ #ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION 1 #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS 1 #endif
Dear Aneesh V,
How much of this is OMAP4 specific, and how much can be reused onother SoCs as well?
Hi Wolfgang,
On Monday 16 May 2011 01:36 AM, Wolfgang Denk wrote:
Dear Aneesh V,
Signed-off-by: Aneesh Vaneesh@ti.com
LPDDR2 provides registers. But OMAP4 EMIF controller provides the means to read them. In that sense it is closely tied to EMIF.
Embed the u-boot flash image size at a known offset from the start of u-boot so that SPL can use it while loading u-boot from a non-XIP media.
Signed-off-by: Aneesh V aneesh@ti.com V2: * Removed the linker script label '__flash_image_end' and its usage. Instead '_end' is used now --- arch/arm/cpu/armv7/start.S | 6 +++++- 1 files changed, 5 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index f92c6d9..f676d7d 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -64,8 +64,12 @@ _pad: .word 0x12345678 /* now 16*4=64 */
.global _end_vect _end_vect: +.global _u_boot_size +_u_boot_size: + .word 0xDEADBEEF + .word _end - _start
- .balignl 16,0xdeadbeef +.balignl 16,0xdeadbeef /************************************************************************* * * Startup Code (reset vector)
Dear Aneesh V,
I don't think this is a good idea.
What you are doing here is defining an image format. Such an image format must be good enough not only for OMAP4 and for loading U-Boot as second stage, but for all other architectures and use cases as well.
We therefore should be very careful not to oversimplify things here. I suggest NOT to pot this information into the image itself, but rather to prepend it (for example, using the mkimage tool), so the actual payload image needs not to be modified.
Hi Wolfgang,
On Monday 16 May 2011 01:39 AM, Wolfgang Denk wrote:
Dear Aneesh V,
I am not defining and publishing a format for the external world. It's just an internal information much like any other info embedded in start.S such as _bss_end_ofs, _end_ofs etc. It's just that SPL, being an insider, can take advantage of it.
I feel creating a new mkimage target just for this will be an overkill. I will be happy loading the maximum image size always.
Dear Aneesh V,
In the essence this is what you are doing: you are defining an interface how the payload has to look like. Anything not meeting this "specification" or "image format" or "ABI" or whatever you call it will not be directly loadable by the SPL.
But I want to make sure that we can load arbitrary payloads as second stage, not only U-Boot images. Because we cannot guarantee that we can embed such information into other payloads we may want to load, we must prepend or append such information, but not embed it somewhere within the image itself.
This is not quite correct. SPL needs this information. We are defining an API here, and we should make sure it fits the use cases we can see now (and ideally is flexible enough so we can adjust/extend it for future use).
We don't have to create a new format. We can, for example, use the existing format with a prepended 64 byte header. The only thing that needs changes is that we now have to consider the header when loading the image, but the same problem will always exist when we accept that we cannot embed the information within the payload. We don't need any new code to implement this solution. We can easily create the images using "mkimage -T firmware -O u-boot".
This makes no sense. What is "the maximum image size always"? 4 MB, so we can also load a Linux kernel as payload? 8 MB, so we can stil do this in a year from now?
Hi Wolfgang,
On Wednesday 18 May 2011 11:36 AM, Wolfgang Denk wrote:
Dear Aneesh V,
This is not exactly true. I had implemented a fall-back option albeit with a maximum size assumed for U-Boot.
Agree that mkimage approach works better for different types of payloads.
The existing target u-boot.img works for me. Just a couple of questions:
1. I see that size is at offset 0xC in this header. Is this a standard? 2. I see that the header is 64 bytes. Is that again a standard for mkimage. 3. Is it ok to add u-boot.img to the target "ALL"? 4. If not, is it ok to add it to "ALL" when CONFIG_SPL is defined? Something like this:
ifeq ($(CONFIG_SPL),y) .PHONEY : SPL -ALL += SPL +ALL += SPL u-boot.img endif
Is it ok to add support for kernel payload as a subsequent incremental step. That's, right now I intend to parse the mkimage header, find the size and load address and load the image and pass control to it, but *without* passing any parameters. Is that ok?
Dear Aneesh V,
In message 4DDE34C5.1050407@ti.com you wrote:
- I see that size is at offset 0xC in this header. Is this a standard?
- I see that the header is 64 bytes. Is that again a standard for
mkimage.
Both are not really "standards" in the sense that any standardization group like ANSI or IEEE has approved this, but these are standard within U-Boot context. The header (struct image_header) is defined in "include/image.h"
- Is it ok to add u-boot.img to the target "ALL"?
No, because in the general case this is not needed, so it's just a waste of build time and disk space.
- If not, is it ok to add it to "ALL" when CONFIG_SPL is defined?
IN principle this should be OK, but please pay attention not to break out-of-tree builds (You have to prefext target names with "$(obj)").
That's perfectly fine.
- Removed the linker script label '__flash_image_end' and its usage. Instead '_end' is used now
- .word 0xDEADBEEF
- .word _end - _start
0xdeadbeef does not seem like a good magic value to identify this header format -- especially since it looks like that may have been the value present in the older images that don't have this header (depending on whether the .balignl needed to pad).
-Scott
Hi Scott,
On Tuesday 17 May 2011 12:26 AM, Scott Wood wrote:
Signed-off-by: Aneesh Vaneesh@ti.com V2:
- .word 0xDEADBEEF
Thanks for pointing this out. I will change it to something different.
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Changes for make file changes --- arch/arm/cpu/armv7/start.S | 1 + arch/arm/include/asm/omap_common.h | 4 + include/configs/omap4_sdp4430.h | 7 ++- spl/board/ti/omap4.mk | 35 +++++++++++ spl/board/ti/spl-omap.c | 112 +++++++++++++++++++++++++++++++++++- 5 files changed, 156 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index f676d7d..351276a 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -64,6 +64,7 @@ _pad: .word 0x12345678 /* now 16*4=64 */
.global _end_vect _end_vect: +/* This label should be at the same location for SPL and U-Boot */ .global _u_boot_size _u_boot_size: .word 0xDEADBEEF diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 10fc9c8..efd3b3c 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -55,4 +55,8 @@ u32 omap_boot_device(void); u32 omap_boot_mode(void); void preloader_console_init(void);
+/* symbols from start.S */ +extern u32 _u_boot_size; +extern u32 _start; + #endif /* _OMAP_COMMON_H_ */ diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 13e7623..0b67345 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -261,7 +261,10 @@ #define CONFIG_SYS_SPL_MAX_SIZE 0x7800 /* 30 K */ #define CONFIG_SYS_SPL_STACK LOW_LEVEL_SRAM_STACK
-#define CONFIG_SYS_SPL_BSS_START_ADDR 0x80000000 -#define CONFIG_SYS_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ + +#define CONFIG_SYS_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SYS_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */
#endif /* __CONFIG_H */ diff --git a/spl/board/ti/omap4.mk b/spl/board/ti/omap4.mk index a0e2142..ecf605e 100644 --- a/spl/board/ti/omap4.mk +++ b/spl/board/ti/omap4.mk @@ -72,6 +72,41 @@ $(obj)ctype.c: COBJS += serial.o ns16550.o string.o vsprintf.o console.o stdio.o COBJS += ctype.o eabi_compat.o div64.o
+# mmc +$(obj)mmc.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/mmc/mmc.c $@ + +$(obj)omap_hsmmc.c: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/mmc/omap_hsmmc.c $@ + +$(obj)omap24xx_i2c.c: $(obj)omap24xx_i2c.h + @rm -f $@ + @ln -s $(TOPDIR)/drivers/i2c/omap24xx_i2c.c $@ + +$(obj)omap24xx_i2c.h: + @rm -f $@ + @ln -s $(TOPDIR)/drivers/i2c/omap24xx_i2c.h $@ + +$(obj)time.c: + @rm -f $@ + @ln -s $(TOPDIR)/lib/time.c $@ + +$(obj)part.c: + @rm -f $@ + @ln -s $(TOPDIR)/disk/part.c $@ + +$(obj)part_dos.c: $(obj)part_dos.h + @rm -f $@ + @ln -s $(TOPDIR)/disk/part_dos.c $@ + +$(obj)part_dos.h: + @rm -f $@ + @ln -s $(TOPDIR)/disk/part_dos.h $@ + +COBJS += omap_hsmmc.o omap24xx_i2c.o mmc.o time.o part.o part_dos.o + # armv7 $(obj)start.S: @rm -f $@ diff --git a/spl/board/ti/spl-omap.c b/spl/board/ti/spl-omap.c index 855572f..2174c55 100644 --- a/spl/board/ti/spl-omap.c +++ b/spl/board/ti/spl-omap.c @@ -28,25 +28,135 @@ #include <common.h> #include <asm/u-boot.h> #include <asm/arch/sys_proto.h> +#include <mmc.h> #include <timestamp_autogenerated.h> #include <version_autogenerated.h> +#include <asm/omap_common.h> +#include <asm/arch/mmc_host_def.h> +#include <i2c.h>
/* Define global data structure pointer to it*/ gd_t gdata __attribute__ ((section(".data"))); bd_t bdata __attribute__ ((section(".data"))); gd_t *gd = &gdata;
+typedef void (*u_boot_entry_t)(void)__attribute__ ((noreturn)); + void board_init_f(ulong dummy) { relocate_code(CONFIG_SYS_SPL_STACK, &gdata, CONFIG_SYS_SPL_TEXT_BASE); }
-void board_init_r(gd_t *id, ulong dummy) +inline void hang(void) { + puts("### ERROR ### Please RESET the board ###\n"); for (;;) ; }
+#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + omap_mmc_init(0); + omap_mmc_init(1); + return 0; +} +#endif + +static void mmc_load_uboot_raw(struct mmc *mmc, u32 mmc_dev) +{ + u32 u_boot_size, u_boot_size_sectors, err; + u32 *magic_loc = (u32 *)(CONFIG_SYS_TEXT_BASE + + (u32) &_u_boot_size - (u32) &_start); + + /* read one sector first to find u-boot size */ + err = mmc->block_dev.block_read(mmc_dev, + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR, 1, + (void *)CONFIG_SYS_TEXT_BASE); + if (err <= 0) + goto end; + + if (*magic_loc++ == 0xDEADBEEF) { + /* Signature found - get the size saved in the next word */ + u_boot_size = *magic_loc; + } else { + /* Signature not found - however continue to load U-Boot */ + debug("U-Boot signature not found!\n"); + /* Let's assume U-Boot will not be more than 200 KB */ + u_boot_size = 200 * 1024; + } + + /* + * convert size to sectors - round down is fine because we have + * already read 1 sector + */ + u_boot_size_sectors = u_boot_size/MMCSD_SECTOR_SIZE; + debug("spl: u-boot raw sectors - %d\n", u_boot_size_sectors + 1); + /* read the remaining sectors */ + err = mmc->block_dev.block_read(mmc_dev, + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR + 1, + u_boot_size_sectors, + (void *)(CONFIG_SYS_TEXT_BASE + MMCSD_SECTOR_SIZE)); +end: + if (err <= 0) { + printf("spl: mmc blk read err - %d\n", err); + hang(); + } +} + +static void mmc_load_uboot(u32 mmc_dev) +{ + struct mmc *mmc; + int err; + u32 boot_mode; + + mmc_initialize(gd->bd); + mmc = find_mmc_device(mmc_dev); + if (!mmc) { + puts("spl: mmc device not found!!\n"); + hang(); + } + + err = mmc_init(mmc); + if (err) { + printf("spl: mmc init failed: mmc_dev - %d err - %d\n", + mmc_dev, err); + hang(); + } + + boot_mode = omap_boot_mode(); + if (boot_mode == MMCSD_MODE_RAW) + mmc_load_uboot_raw(mmc, mmc_dev); + else { + puts("spl: wrong MMC boot mode\n"); + hang(); + } +} + +void board_init_r(gd_t *id, ulong dummy) +{ + u32 boot_device; + u_boot_entry_t u_boot_entry = (u_boot_entry_t) CONFIG_SYS_TEXT_BASE; + + timer_init(); + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + boot_device = omap_boot_device(); + switch (boot_device) { + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: + mmc_load_uboot(boot_device - BOOT_DEVICE_MMC1); + break; + default: + printf("SPL: Un-supported Boot Device - %d!!!\n", boot_device); + hang(); + break; + } + + /* Jump to u-boot */ + debug("Jumping to U-Boot\n"); + u_boot_entry(); +} + void preloader_console_init(void) { const char *u_boot_rev = U_BOOT_VERSION;
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Changes for make file changes --- include/configs/omap4_sdp4430.h | 1 + spl/board/ti/omap4.mk | 7 +++++++ spl/board/ti/spl-omap.c | 22 ++++++++++++++++++++++ 3 files changed, 30 insertions(+), 0 deletions(-)
diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 0b67345..cc64671 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -263,6 +263,7 @@
#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ #define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1
#define CONFIG_SYS_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SYS_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ diff --git a/spl/board/ti/omap4.mk b/spl/board/ti/omap4.mk index ecf605e..e66a532 100644 --- a/spl/board/ti/omap4.mk +++ b/spl/board/ti/omap4.mk @@ -107,6 +107,13 @@ $(obj)part_dos.h:
+# fat +$(obj)fat.c: + @rm -f $@ + @ln -s $(TOPDIR)/fs/fat/fat.c $@ + +COBJS += fat.o + # armv7 $(obj)start.S: @rm -f $@ diff --git a/spl/board/ti/spl-omap.c b/spl/board/ti/spl-omap.c index 2174c55..81ca0d3 100644 --- a/spl/board/ti/spl-omap.c +++ b/spl/board/ti/spl-omap.c @@ -29,6 +29,7 @@ #include <asm/u-boot.h> #include <asm/arch/sys_proto.h> #include <mmc.h> +#include <fat.h> #include <timestamp_autogenerated.h> #include <version_autogenerated.h> #include <asm/omap_common.h> @@ -104,6 +105,25 @@ end: } }
+static void mmc_load_uboot_fat(struct mmc *mmc) +{ + s32 err; + + err = fat_register_device(&mmc->block_dev, + CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION); + if (err) { + printf("spl: fat register err - %d\n", err); + hang(); + } + + err = file_fat_read("u-boot.bin", (u8 *)CONFIG_SYS_TEXT_BASE, 0); + + if (err <= 0) { + printf("spl: error reading u-boot.bin - %d\n", err); + hang(); + } +} + static void mmc_load_uboot(u32 mmc_dev) { struct mmc *mmc; @@ -127,6 +147,8 @@ static void mmc_load_uboot(u32 mmc_dev) boot_mode = omap_boot_mode(); if (boot_mode == MMCSD_MODE_RAW) mmc_load_uboot_raw(mmc, mmc_dev); + else if (boot_mode == MMCSD_MODE_FAT) + mmc_load_uboot_fat(mmc); else { puts("spl: wrong MMC boot mode\n"); hang();
Dear Aneesh V,
V2:
- Changes for make file changes
- err = file_fat_read("u-boot.bin", (u8 *)CONFIG_SYS_TEXT_BASE, 0);
Please do not hard code the file name here. Keep the code flexible and allow for other possibilities, too. At the very least, make this compile-time selectable.
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Changed CONFIG_SYS_SPL_TEXT_BASE to 0x40304350 for Panda This is required for EMU devices * Changes due to make file changes --- arch/arm/cpu/armv7/omap4/emif.c | 5 +++-- arch/arm/include/asm/arch-omap4/emif.h | 10 +++++----- include/configs/omap4_panda.h | 24 ++++++++++++++++++++++++ spl/board/ti/panda/Makefile | 32 ++++++++++++++++++++++++++++++++ 4 files changed, 64 insertions(+), 7 deletions(-) create mode 100644 spl/board/ti/panda/Makefile
diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index b09aa8f..699a545 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -1178,9 +1178,9 @@ static void dmm_init(u32 base) #ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS emif_get_dmm_regs(&lisa_map_regs); #else - u32 emif1_size, emif2_size, mapped_size, section_map; + u32 emif1_size, emif2_size, mapped_size, section_map = 0; u32 section_cnt, sys_addr; - struct dmm_lisa_map_regs lis_map_regs_calculated; + struct dmm_lisa_map_regs lis_map_regs_calculated = {0};
mapped_size = 0; section_cnt = 3; @@ -1253,6 +1253,7 @@ static void dmm_init(u32 base) lis_map_regs_calculated.dmm_lisa_map_2 = section_map; lis_map_regs_calculated.dmm_lisa_map_1 = 0; } + /* TRAP for invalid TILER mappings in section 0 */ lis_map_regs_calculated.dmm_lisa_map_0 = DMM_LISA_MAP_0_INVAL_ADDR_TRAP;
diff --git a/arch/arm/include/asm/arch-omap4/emif.h b/arch/arm/include/asm/arch-omap4/emif.h index 8cc3230..b95e545 100644 --- a/arch/arm/include/asm/arch-omap4/emif.h +++ b/arch/arm/include/asm/arch-omap4/emif.h @@ -520,11 +520,11 @@
/* Trap for invalid TILER PAT entries */ #define DMM_LISA_MAP_0_INVAL_ADDR_TRAP (\ - (0 << OMAP44XX_SDRC_ADDR_SHIFT) |\ - (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ - (DMM_SDRC_ADDR_SPC_INVALID << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ - (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)|\ - (0xFF << OMAP44XX_SYS_ADDR_SHIFT)) + (0 << OMAP44XX_SDRC_ADDR_SHIFT) |\ + (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_INVALID << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)|\ + (0xFF << OMAP44XX_SYS_ADDR_SHIFT))
/* Reg mapping structure */ diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 9acd340..e28b916 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -116,7 +116,9 @@
/* USB device configuration */ #define CONFIG_USB_DEVICE 1 +#ifndef CONFIG_PRELOADER #define CONFIG_USB_TTY 1 +#endif #define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
/* Flash */ @@ -238,4 +240,26 @@ #define CONFIG_SYS_PL310_BASE 0x48242000 #endif
+/* Defines for Clock init */ +#define CONFIG_SYS_OMAP4_ABE_SYSCK + +/* Defines for SDRAM init */ +#ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION 1 +#define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS 1 +#endif + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SYS_SPL_TEXT_BASE 0x40304350 +#define CONFIG_SYS_SPL_MAX_SIZE 0x7800 /* 30 K */ +#define CONFIG_SYS_SPL_STACK LOW_LEVEL_SRAM_STACK + +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 + +#define CONFIG_SYS_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SYS_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + #endif /* __CONFIG_H */ diff --git a/spl/board/ti/panda/Makefile b/spl/board/ti/panda/Makefile new file mode 100644 index 0000000..81bf51c --- /dev/null +++ b/spl/board/ti/panda/Makefile @@ -0,0 +1,32 @@ +# +# (C) Copyright 2006-2007 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# (C) Copyright 2010 +# Texas Instruments, <www.ti.com> +# Aneesh V aneesh@ti.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(SRCTREE)/spl/board/$(VENDOR)/omap4.mk +include $(SRCTREE)/spl/board/$(VENDOR)/rules-omap.mk
Dear Aneesh V,
V2:
- Changed CONFIG_SYS_SPL_TEXT_BASE to 0x40304350 for Panda This is required for EMU devices
- Changes due to make file changes
- u32 emif1_size, emif2_size, mapped_size, section_map = 0; u32 section_cnt, sys_addr;
- struct dmm_lisa_map_regs lis_map_regs_calculated = {0};
This iseems to be an unrelated change. Please split into separate patch.
Ditto.
Ditto.
NAK, see previous messages.
In SPL console is enabled very early where as in U-Boot it's not. So, SPL can have traces in early init code while U-Boot can not have it in the same shared code.
Adding a debug print macro that will be defined in SPL but compiled out in U-Boot.
Also add some useful debug traces throughout SPL
Signed-off-by: Aneesh V aneesh@ti.com --- arch/arm/cpu/armv7/omap4/clocks.c | 10 ++++++++-- arch/arm/cpu/armv7/omap4/emif.c | 35 +++++++++++++++++++++++++++-------- arch/arm/include/asm/utils.h | 6 ++++++ spl/board/ti/spl-omap.c | 13 ++++++++++--- 4 files changed, 51 insertions(+), 13 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c index c405b5c..720e60f 100644 --- a/arch/arm/cpu/armv7/omap4/clocks.c +++ b/arch/arm/cpu/armv7/omap4/clocks.c @@ -379,7 +379,7 @@ u32 omap4_ddr_clk(void)
core_dpll_params = get_core_dpll_params();
- debug("sys_clk %d\n ", sys_clk_khz * 1000); + spl_debug("sys_clk %d\n ", sys_clk_khz * 1000);
/* Find Core DPLL locked frequency first */ ddr_clk = sys_clk_khz * 2 * core_dpll_params->m / @@ -391,7 +391,7 @@ u32 omap4_ddr_clk(void) ddr_clk = ddr_clk / 4 / core_dpll_params->m2;
ddr_clk *= 1000; /* convert to Hz */ - debug("ddr_clk %d\n ", ddr_clk); + spl_debug("ddr_clk %d\n ", ddr_clk);
return ddr_clk; } @@ -400,6 +400,7 @@ static void setup_dplls(void) { u32 sysclk_ind, temp; const struct dpll_params *params; + spl_debug("setup_dplls\n");
sysclk_ind = get_sys_clk_index();
@@ -416,10 +417,12 @@ static void setup_dplls(void) (CLKSEL_L3_CORE_DIV_2 << CLKSEL_L3_SHIFT) | (CLKSEL_L4_L3_DIV_2 << CLKSEL_L4_SHIFT); writel(temp, CM_CLKSEL_CORE); + spl_debug("Core DPLL configured\n");
/* lock PER dpll */ do_setup_dpll(CM_CLKMODE_DPLL_PER, &per_dpll_params_1536mhz[sysclk_ind], DPLL_LOCK); + spl_debug("PER DPLL locked\n");
/* MPU dpll */ if (omap4_revision() == OMAP4430_ES1_0) @@ -427,6 +430,7 @@ static void setup_dplls(void) else params = &mpu_dpll_params_1ghz[sysclk_ind]; do_setup_dpll(CM_CLKMODE_DPLL_MPU, params, DPLL_LOCK); + spl_debug("MPU DPLL locked\n"); }
static void setup_non_essential_dplls(void) @@ -551,6 +555,7 @@ static void scale_vcores(void)
static void enable_clock_domain(u32 clkctrl_reg, u32 enable_mode) { + spl_debug("Enable clock domain - 0x%08x\n", clkctrl_reg); modify_reg_32(clkctrl_reg, CD_CLKCTRL_CLKTRCTRL_SHIFT, CD_CLKCTRL_CLKTRCTRL_MASK, enable_mode); } @@ -570,6 +575,7 @@ static inline void wait_for_clk_enable(u32 clkctrl_addr) static void enable_clock_module(u32 clkctrl_addr, u32 enable_mode, u32 wait_for_enable) { + spl_debug("Enable clock module - 0x%08x\n", clkctrl_addr); modify_reg_32(clkctrl_addr, MODULE_CLKCTRL_MODULEMODE_SHIFT, MODULE_CLKCTRL_MODULEMODE_MASK, enable_mode); if (wait_for_enable) diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index 699a545..fcb6d47 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -34,7 +34,7 @@
DECLARE_GLOBAL_DATA_PTR;
-#define print_timing_reg(reg) debug(#reg" - 0x%08x\n", (reg)) +#define print_timing_reg(reg) spl_debug(#reg" - 0x%08x\n", (reg))
static u32 *const T_num = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_NUM; static u32 *const T_den = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_DEN; @@ -237,7 +237,7 @@ s8 addressing_table_index(u8 type, u8 density, u8 width) else index = density;
- debug("emif: addressing table index %d\n", index); + spl_debug("emif: addressing table index %d\n", index);
return index; } @@ -272,7 +272,7 @@ static const struct lpddr2_ac_timings *get_timings_table(const struct timings = device_timings[i]; } } - debug("emif: timings table: %d\n", freq_nearest); + spl_debug("emif: timings table: %d\n", freq_nearest); return timings; }
@@ -637,7 +637,7 @@ static inline u32 get_mr(u32 base, u32 cs, u32 mr_addr) mr = readl(&emif->emif_lpddr2_mode_reg_data_es2); else mr = readl(&emif->emif_lpddr2_mode_reg_data); - debug("get_mr: EMIF%d cs %d mr %08x val 0x%x\n", emif_num(base), + spl_debug("get_mr: EMIF%d cs %d mr %08x val 0x%x\n", emif_num(base), cs, mr_addr, mr); return mr; } @@ -790,10 +790,10 @@ static void display_sdram_details(u32 emif_nr, u32 cs, char density_str[10]; u32 density;
- debug("EMIF%d CS%d\t", emif_nr, cs); + spl_debug("EMIF%d CS%d\t", emif_nr, cs);
if (!device) { - debug("None\n"); + spl_debug("None\n"); return; }
@@ -807,7 +807,7 @@ static void display_sdram_details(u32 emif_nr, u32 cs, } else sprintf(density_str, "%d MB", density); if (mfg_str && type_str) - debug("%s\t\t%s\t%s\n", mfg_str, type_str, density_str); + spl_debug("%s\t\t%s\t%s\n", mfg_str, type_str, density_str); }
static u8 is_lpddr2_sdram_present(u32 base, u32 cs, @@ -948,6 +948,8 @@ static void lpddr2_init(u32 base, const struct emif_regs *regs) { struct emif_reg_struct *emif = (struct emif_reg_struct *)base;
+ spl_debug(">>lpddr2_init() %x\n", base); + /* Not NVM */ modify_reg_32(&emif->emif_lpddr2_nvm_config, OMAP44XX_REG_CS1NVMEN_SHIFT, OMAP44XX_REG_CS1NVMEN_MASK, 0); @@ -978,6 +980,7 @@ static void lpddr2_init(u32 base, const struct emif_regs *regs) OMAP44XX_REG_INITREF_DIS_SHIFT, OMAP44XX_REG_INITREF_DIS_MASK, 0);
+ spl_debug("<<lpddr2_init()\n"); }
static void emif_update_timings(u32 base, const struct emif_regs *regs) @@ -1023,6 +1026,8 @@ static void do_sdram_init(u32 base) const struct emif_regs *regs; u32 in_sdram, emif_nr;
+ spl_debug(">>do_sdram_init() %x\n", base); + in_sdram = running_from_sdram(); emif_nr = (base == OMAP44XX_EMIF1) ? 1 : 2;
@@ -1115,6 +1120,8 @@ static void do_sdram_init(u32 base)
/* Write to the shadow registers */ emif_update_timings(base, regs); + + spl_debug("<<do_sdram_init() %x\n", base); }
void sdram_init_pads(void) @@ -1187,7 +1194,7 @@ static void dmm_init(u32 base) sys_addr = CONFIG_SYS_SDRAM_BASE; emif1_size = emif_sizes[0]; emif2_size = emif_sizes[1]; - debug("emif1_size 0x%x emif2_size 0x%x\n", emif1_size, emif2_size); + spl_debug("emif1_size 0x%x emif2_size 0x%x\n", emif1_size, emif2_size);
if (!emif1_size && !emif2_size) return; @@ -1296,11 +1303,14 @@ static void dmm_init(u32 base) */ void sdram_init(void) { + spl_debug(">>sdram_init()\n"); + if (omap4_hw_init_context() == OMAP_INIT_CONTEXT_UBOOT_LOADED_BY_SPL) return;
u32 in_sdram; in_sdram = running_from_sdram(); + spl_debug("in_sdram = %d\n", in_sdram);
if (!in_sdram) { sdram_init_pads(); @@ -1318,4 +1328,13 @@ void sdram_init(void)
/* for the shadow registers to take effect */ freq_update_core(); + + /* Do some basic testing */ + writel(0xDEADBEEF, CONFIG_SYS_SDRAM_BASE); + if (readl(CONFIG_SYS_SDRAM_BASE) == 0xDEADBEEF) + spl_debug("SDRAM Init success!\n"); + else + printf("SDRAM Init failed!!\n"); + + spl_debug("<<sdram_init()\n"); } diff --git a/arch/arm/include/asm/utils.h b/arch/arm/include/asm/utils.h index d581539..3e847c1 100644 --- a/arch/arm/include/asm/utils.h +++ b/arch/arm/include/asm/utils.h @@ -25,6 +25,12 @@ #ifndef _UTILS_H_ #define _UTILS_H_
+#if defined(DEBUG) && defined(CONFIG_PRELOADER) +#define spl_debug(fmt, args...) printf(fmt, ##args) +#else +#define spl_debug(fmt, args...) +#endif + /* extract a bit field from a bit vector */ #define get_bit_field(nr, start, mask)\ (((nr) & (mask)) >> (start)) diff --git a/spl/board/ti/spl-omap.c b/spl/board/ti/spl-omap.c index 81ca0d3..6db3675 100644 --- a/spl/board/ti/spl-omap.c +++ b/spl/board/ti/spl-omap.c @@ -27,6 +27,7 @@ */ #include <common.h> #include <asm/u-boot.h> +#include <asm/utils.h> #include <asm/arch/sys_proto.h> #include <mmc.h> #include <fat.h> @@ -45,7 +46,9 @@ typedef void (*u_boot_entry_t)(void)__attribute__ ((noreturn));
void board_init_f(ulong dummy) { + debug(">>board_init_f()\n"); relocate_code(CONFIG_SYS_SPL_STACK, &gdata, CONFIG_SYS_SPL_TEXT_BASE); + debug("<<board_init_f()\n"); }
inline void hang(void) @@ -145,11 +148,13 @@ static void mmc_load_uboot(u32 mmc_dev) }
boot_mode = omap_boot_mode(); - if (boot_mode == MMCSD_MODE_RAW) + if (boot_mode == MMCSD_MODE_RAW) { + spl_debug("boot mode - RAW\n"); mmc_load_uboot_raw(mmc, mmc_dev); - else if (boot_mode == MMCSD_MODE_FAT) + } else if (boot_mode == MMCSD_MODE_FAT) { + spl_debug("boot mode - FAT\n"); mmc_load_uboot_fat(mmc); - else { + } else { puts("spl: wrong MMC boot mode\n"); hang(); } @@ -159,6 +164,7 @@ void board_init_r(gd_t *id, ulong dummy) { u32 boot_device; u_boot_entry_t u_boot_entry = (u_boot_entry_t) CONFIG_SYS_TEXT_BASE; + spl_debug(">>spl:board_init_r()\n");
timer_init(); i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); @@ -166,6 +172,7 @@ void board_init_r(gd_t *id, ulong dummy) switch (boot_device) { case BOOT_DEVICE_MMC1: case BOOT_DEVICE_MMC2: + spl_debug("boot device - MMC2\n"); mmc_load_uboot(boot_device - BOOT_DEVICE_MMC1); break; default:
Dear Aneesh V,
Console should _always_ be enabled as early as possible,
Can we not rather change the code so both configurations behave the same?
- spl_debug("sys_clk %d\n ", sys_clk_khz * 1000);
Do we really need a new macro name? Can this not be the same debug() macro, just generating different code (if really needed) when building the SPL code?
- /* Do some basic testing */
- writel(0xDEADBEEF, CONFIG_SYS_SDRAM_BASE);
- if (readl(CONFIG_SYS_SDRAM_BASE) == 0xDEADBEEF)
- else
- spl_debug("<<sdram_init()\n");
This is beyond the scope of "adding debug traces". it must be split into separate patch.
Also, please do not mess witrhout need with the RAM content - at the very least, restore the previous values.
But then - I wonder why this is needed at all. Are you not using get_ram_size()? Maybe you should fix your code to using it!
NAK. This is neither the right place for such a definition, nor do I want to see this addressed like that.
I recommend to unify the code, so both SPL and non-SPL configurations can use teh same early console behaviour.
- debug(">>board_init_f()\n"); relocate_code(CONFIG_SYS_SPL_STACK, &gdata, CONFIG_SYS_SPL_TEXT_BASE);
- debug("<<board_init_f()\n");
This is overkill, isn't it?
mmc_load_uboot(boot_device - BOOT_DEVICE_MMC1);spl_debug("boot device - MMC2\n");
This is wrong in the BOOT_DEVICE_MMC1 case.
Dear Wolfgang,
I just realized that I had not responded to this message.
On Monday 16 May 2011 01:51 AM, Wolfgang Denk wrote:
Dear Aneesh V,
Unfortunately this is not the case with U-Boot today. Console initialization happens in board_init_f(). Before board_init_f() typically a lot of(in fact most of) low level initialization happens through the lowlevel_init() function called from start.S and the initial part of init_sequence()
In SPL I had more flexibility, so I do a simplified init of console right at the beginning of lowlevel_init(), so I can use debug prints in lowlevel_init(). Some part of our lowlevel_init() that is executed in SPL path may also be executed by U-Boot if it runs from NOR flash, but in this case console wouldn't be ready. That's why I made the macro.
No. That wouldn't serve the purpose. I need two macros to distinguish between the two cases. 1. 'debug()' - can be used in all places at which console is guaranteed to be initialized whether executed as part of U-Boot or SPL. 2. 'spl_debug()' to be used at places where console is initialized for SPL but not for U-Boot (eg. lowlevel_init()) - so emit no code for U-Boot.
- else
will do.
Will do.
It may make sense for us to do this as a memory test. For discovering the amount of memory installed we are using a technique based on reading of LPDDR2 mode registers.
The above was intended as a simple sanity testing.
+#if defined(DEBUG)&& defined(CONFIG_PRELOADER) +#define spl_debug(fmt, args...) printf(fmt, ##args) +#else +#define spl_debug(fmt, args...) +#endif
I always thought this is a serious issue with U-Boot. I gave it a quick shot like below:
--- diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index fcd29a7..56902e3 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -41,6 +41,7 @@ DECLARE_GLOBAL_DATA_PTR; */ void s_init(void) { + printf("Hello World!!\n"); watchdog_init(); }
diff --git a/arch/arm/cpu/armv7/omap4/lowlevel_init.S b/arch/arm/cpu/armv7/omap4/lowlevel_init.S index 026dfa4..42264b2 100644 --- a/arch/arm/cpu/armv7/omap4/lowlevel_init.S +++ b/arch/arm/cpu/armv7/omap4/lowlevel_init.S @@ -31,17 +31,6 @@ .globl lowlevel_init lowlevel_init: /* - * Setup a temporary stack - */ - ldr sp, =LOW_LEVEL_SRAM_STACK - - /* - * Save the old lr(passed in ip) and the current lr to stack - */ - push {ip, lr} - - /* * go setup pll, mux, memory */ - bl s_init - pop {ip, pc} + b s_init diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index d91ae12..4a9251f 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -307,10 +307,11 @@ cpu_init_crit: * basic memory. Go here to bump up clock rate and handle * wake up conditions. */ - mov ip, lr @ persevere link reg across call + ldr sp, =CONFIG_SYS_INIT_SP_ADDR + push {lr} + bl early_console_init bl lowlevel_init @ go setup pll,mux,memory - mov lr, ip @ restore link - mov pc, lr @ back to my caller + pop {pc} /* ************************************************************************* * diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 1a784a1..0c696c2 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -248,9 +248,6 @@ init_fnc_t *init_sequence[] = { get_clocks, #endif env_init, /* initialize environment */ - init_baudrate, /* initialze baudrate settings */ - serial_init, /* serial communications setup */ - console_init_f, /* stage 1 init of console */ display_banner, /* say that we are here */ #if defined(CONFIG_DISPLAY_CPUINFO) print_cpuinfo, /* display cpu info (and speed) */ @@ -268,6 +265,13 @@ init_fnc_t *init_sequence[] = { NULL, };
+void early_console_init(void) +{ + init_baudrate(); /* initialze baudrate settings */ + serial_init(); /* serial communications setup */ + console_init_f(); /* stage 1 init of console */ +} + void board_init_f (ulong bootflag) { bd_t *bd; ---
But this didn't work. It crashes at the first printf(). The reason is init_baudrate() needs global data and global data is initialized in board_init_f(). Further, we can not move global data initialization earlier because for global data we reuse low level stack used by lowlevel_init().
gd = (gd_t *) ((CONFIG_SYS_INIT_SP_ADDR) & ~0x07);
So, we have an egg-and-chicken problem unless we find different spaces for low-level stack and global data(that should not be a problem for our board, but I am not sure of other boards).
Also, perhaps this needs to be done for all CPUs/archs.
IMHO, this will need a major overhaul and is not in the scope of my current activity. Please suggest how to go about this.
Do you think re-naming spl_debug to omap_spl_debug() and putting it in an OMAP header will help?:-) I am not sure if everybody has the same situation as we have(that is, U-Boot and SPL sharing low-level init code and console being initialized in one case while not in the other)
Dear Wolfgang, Heiko,
On Monday 13 June 2011 07:29 PM, Aneesh V wrote:
Dear Wolfgang,
[snip ...]
On second thoughts I realize that the stack in internal RAM is still in use in board_init_f(). So, how does this work at all? The global data and the stack seems to be overlapping!
Please note the register dump after the above instruction. Note that R8(gd) and R13(sp) are very close.
N _ R0 0 R8 4030DF80 SP> 12345678 Z Z R1 0A R9 12345678 -04 80E80078 C C R2 4030DED4 R10 40304350 FP> D78772CA V _ R3 5555 R11 0002FE40 +04 4049A39E I I R4 0 R12 80E80068 +08 F5A73CF4 F F R5 10 R13 4030DF78 +0C 7B317D39 T _ R6 12345678 R14 80E80078 +10 ED3CFCF0 J _ R7 12345678 PC 80E80880 +14 FEECEC6A svc SPSR 0 CPSR 600001D3 +18 6DB22EB2
Am I missing something?
Dear Aneesh V,
As the name LOWLEVEL_init() suggests, this is suppoed to contain always only the bare minimum of initialization that is necessary to get the CPU running. All more complex initializations should be delayed and only be run when we have a proper environment, including debug output on the console.
I do not understand this. How can you have more flexibility in the more restricted environment?
We definitely should unify this.
- 'debug()' - can be used in all places at which console is guaranteed
You see - this distinction is becoming a mess. Let's get rid of this and use common code for both cases.
Dear Wolfgang,
On Wednesday 15 June 2011 03:48 PM, Wolfgang Denk wrote:
Dear Aneesh V,
[snip ..]
I replaced spl_debug() with debug() now. I moved sdram_init() out of lowlevel_init() for u-boot so that console is available by the time sdram_init() runs.
However, clock init needs to remain in lowlevel_init() and I still feel that some debug traces from this module will be a good debugging tool for SPL, so I retained the traces and added something like this in arch/arm/cpu/armv7/omap4/clocks.c:
/* * printing to console doesn't work unless * this code is executed from SPL */ #ifndef CONFIG_PRELOADER #define printf(fmt, args...) #define puts(s) #endif
Is that fine?
This series adds mmc SPL support for OMAP4. This is essentially an up-streaming effort for TI's x-loader for OMAP4 using the SPL framework
This work partly draws upon previous work done for x-loader by: Santosh Shilimkar santosh.shilimkar@ti.com Rajendra Nayak rnayak@ti.com and many others
This series depends on the following series for the new SPL framework: http://marc.info/?l=u-boot&m=131056990001719&w=2
Features supported: * Clock init - DPLL locking, clock domains/modules enabling * SDRAM/DMM initialization * Mux initialization * MMC raw read support * MMC FAT read support
Improvments over x-loader: * Code completely revamped * DPLL programming that works for all SYS_CLK frequencies * Automatic SDRAM identification and initialization * Board dependent parts(especially mux) deferred to u-boot. So, same SPL will work for Panda and SDP and most likely on any other board that comes along * Flexible about the payload. Any image with a mkimage header can be loaded. * The core SPL logic is generic and available for OMAP3/4. So, OMAP3 platforms can easily extend this work to add SPL support for the respective boards.
V2: * Some fixes in SDRAM init, clock init * Use of pre-calculated M & N values for DPLL locking instead run-time calculation * Change in make files to allow reuse of common rules between boards * Console initialization moved further earlier in the boot allowing traces from even clock initialization code * Reuse utility macros from a previous series
V3: * Moved to the new SPL framework * struct based register access for clock init * Squashed together related patches as per Wolfgang's suggestions * Re-organization of code in sdram init for better readability * SPL loading the payload using mkimage header * Avoided using custom bit-field accessor macros * Several other minor changes(documented in respective patches)
Aneesh V (11): omap4: utility function to identify the context of hw init omap4: cleanup pin mux data omap4: add OMAP4430 revision check omap4: add clock support omap4: add sdram init support omap4: calculate EMIF register values omap4: automatic sdram detection armv7: start.S: fixes and enhancements for SPL omap: add basic SPL support Correct ih_os for u-boot.img omap: add MMC and FAT support to SPL
John Rigby (1): mkimage: Add OMAP boot image support
Makefile | 2 +- arch/arm/cpu/armv7/Makefile | 7 +- arch/arm/cpu/armv7/cpu.c | 7 + arch/arm/cpu/armv7/omap-common/Makefile | 5 + arch/arm/cpu/armv7/omap-common/spl.c | 272 ++++ arch/arm/cpu/armv7/omap-common/u-boot-spl.lds | 62 + arch/arm/cpu/armv7/omap-common/utils.c | 57 + arch/arm/cpu/armv7/omap4/Makefile | 6 + arch/arm/cpu/armv7/omap4/board.c | 161 +++- arch/arm/cpu/armv7/omap4/clocks.c | 842 +++++++++++++ .../panda => arch/arm/cpu/armv7/omap4}/config.mk | 25 +- arch/arm/cpu/armv7/omap4/emif.c | 1305 ++++++++++++++++++++ arch/arm/cpu/armv7/omap4/lowlevel_init.S | 31 + arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 76 ++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 282 +++++ arch/arm/cpu/armv7/start.S | 51 +- arch/arm/cpu/armv7/u-boot.lds | 2 + arch/arm/include/asm/arch-omap4/clocks.h | 664 ++++++++++ arch/arm/include/asm/arch-omap4/emif.h | 1034 ++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 52 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 72 ++- arch/arm/include/asm/armv7.h | 5 + arch/arm/include/asm/omap_common.h | 56 + board/ti/panda/Makefile | 2 + board/ti/panda/panda.c | 25 +- board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} | 76 +- board/ti/sdp4430/Makefile | 2 + board/ti/sdp4430/config.mk | 31 - board/ti/sdp4430/sdp.c | 25 +- .../{panda/panda.h => sdp4430/sdp4430_mux_data.h} | 128 +-- common/image.c | 9 +- include/configs/omap4_panda.h | 37 + include/configs/omap4_sdp4430.h | 37 + include/image.h | 1 + spl/Makefile | 6 + tools/Makefile | 2 + tools/mkimage.c | 2 + tools/mkimage.h | 1 + tools/omap/clocks_get_m_n.c | 197 +++ tools/omapimage.c | 224 ++++ tools/omapimage.h | 50 + 41 files changed, 5668 insertions(+), 263 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/spl.c create mode 100644 arch/arm/cpu/armv7/omap-common/u-boot-spl.lds create mode 100644 arch/arm/cpu/armv7/omap-common/utils.c create mode 100644 arch/arm/cpu/armv7/omap4/clocks.c rename {board/ti/panda => arch/arm/cpu/armv7/omap4}/config.mk (64%) create mode 100644 arch/arm/cpu/armv7/omap4/emif.c create mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h create mode 100644 arch/arm/cpu/armv7/omap4/sdram_elpida.c create mode 100644 arch/arm/include/asm/arch-omap4/clocks.h create mode 100644 arch/arm/include/asm/arch-omap4/emif.h create mode 100644 arch/arm/include/asm/omap_common.h rename board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} (76%) delete mode 100644 board/ti/sdp4430/config.mk rename board/ti/{panda/panda.h => sdp4430/sdp4430_mux_data.h} (67%) create mode 100644 tools/omap/clocks_get_m_n.c create mode 100644 tools/omapimage.c create mode 100644 tools/omapimage.h
Dear Wolfgang,
This work partly draws upon previous work done for x-loader by: Santosh Shilimkarsantosh.shilimkar@ti.com Rajendra Nayakrnayak@ti.com and many others
Features supported:
- Clock init - DPLL locking, clock domains/modules enabling
- SDRAM/DMM initialization
- Mux initialization
- MMC raw read support
- MMC FAT read support
- Code completely revamped
- DPLL programming that works for all SYS_CLK frequencies
- Automatic SDRAM identification and initialization
- Board dependent parts(especially mux) deferred to u-boot. So, same SPL will work for Panda and SDP and most likely on any other board that comes along
- Flexible about the payload. Any image with a mkimage header can be loaded.
- The core SPL logic is generic and available for OMAP3/4. So, OMAP3 platforms can easily extend this work to add SPL support for the respective boards.
V2:
- Some fixes in SDRAM init, clock init
- Use of pre-calculated M& N values for DPLL locking instead run-time calculation
- Change in make files to allow reuse of common rules between boards
- Console initialization moved further earlier in the boot allowing traces from even clock initialization code
- Reuse utility macros from a previous series
V3:
- Moved to the new SPL framework
- struct based register access for clock init
- Squashed together related patches as per Wolfgang's suggestions
- Re-organization of code in sdram init for better readability
- SPL loading the payload using mkimage header
- Avoided using custom bit-field accessor macros
- Several other minor changes(documented in respective patches)
I think I have addressed all the comments you and others had on the previous series and adapted it to the new SPL framework.
There are just two comments for this series so far. I have to omit the 'SYS' from CONFIG_SYS_SPL_TEXT_BASE and a minor comment by Simon.
If I fix these two, is it ready to go. Do you have any other comments. If not, shall I re-spin the next revision?
br, Aneesh
Dear Aneesh V,
Yes, I agree.
That's my understanding, too.
Please feel free to send the next version, without the RFC part in the subject now. If no complaints come in, I want to pull this in soon.
Dear Wolfgang,
On Monday 18 July 2011 07:20 PM, Wolfgang Denk wrote:
Dear Aneesh V,
Yes, I agree.
One minor question. For the OMAP spl I have some cofig flags like
CONFIG_SYS_SPL_STACK, CONFIG_SYS_SPL_BSS_START_ADDR etc.
Is it ok to omit the 'SYS' part of these too?
Thanks. Will send in the next revision soon.
Dear Aneesh V,
Yes, please. I think we should make this consistently.
The basic hardware init of OMAP4(s_init()) can happen in 4 different contexts: 1. SPL running from SRAM 2. U-Boot running from FLASH 3. Non-XIP U-Boot loaded to SDRAM by SPL 4. Non-XIP U-Boot loaded to SDRAM by ROM code using the Configuration Header feature
What level of hw initialization gets done depends on this context. Add a utility function to find this context.
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Changed the context names to more meaningful names as suggested by WD --- arch/arm/include/asm/arch-omap4/sys_proto.h | 49 ++++++++++++++++++++++++++- arch/arm/include/asm/omap_common.h | 34 ++++++++++++++++++ 2 files changed, 82 insertions(+), 1 deletions(-) create mode 100644 arch/arm/include/asm/omap_common.h
diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 4fa4f4b..6b596b4 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -23,10 +23,12 @@
#include <asm/arch/omap4.h> #include <asm/io.h> +#include <asm/omap_common.h>
struct omap_sysinfo { char *board_string; }; +extern const struct omap_sysinfo sysinfo;
void gpmc_init(void); void watchdog_init(void); @@ -37,6 +39,51 @@ u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); void set_pl310_ctrl_reg(u32 val);
-extern const struct omap_sysinfo sysinfo; +static inline u32 running_from_sdram(void) +{ + u32 pc; + asm volatile ("mov %0, pc" : "=r" (pc)); + return ((pc >= OMAP44XX_DRAM_ADDR_SPACE_START) && + (pc < OMAP44XX_DRAM_ADDR_SPACE_END)); +} + +static inline u8 uboot_loaded_by_spl(void) +{ + /* + * Configuration Header is not supported yet, so u-boot init running + * from SDRAM implies that it was loaded by SPL. When this situation + * changes one of these approaches could be taken: + * i. Pass a magic from SPL to U-Boot and U-Boot save it at a known + * location. + * ii. Check the OPP. CH can support only 50% OPP while SPL initializes + * the DPLLs at 100% OPP. + */ + return running_from_sdram(); +} +/* + * The basic hardware init of OMAP(s_init()) can happen in 4 + * different contexts: + * 1. SPL running from SRAM + * 2. U-Boot running from FLASH + * 3. Non-XIP U-Boot loaded to SDRAM by SPL + * 4. Non-XIP U-Boot loaded to SDRAM by ROM code using the + * Configuration Header feature + * + * This function finds this context. + * Defining as inline may help in compiling out unused functions in SPL + */ +static inline u32 omap4_hw_init_context(void) +{ +#ifdef CONFIG_SPL_BUILD + return OMAP_INIT_CONTEXT_SPL; +#else + if (uboot_loaded_by_spl()) + return OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL; + else if (running_from_sdram()) + return OMAP_INIT_CONTEXT_UBOOT_AFTER_CH; + else + return OMAP_INIT_CONTEXT_UBOOT_FROM_NOR; +#endif +}
#endif diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h new file mode 100644 index 0000000..d80f665 --- /dev/null +++ b/arch/arm/include/asm/omap_common.h @@ -0,0 +1,34 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _OMAP_COMMON_H_ +#define _OMAP_COMMON_H_ + +/* HW Init Context */ +#define OMAP_INIT_CONTEXT_SPL 0 +#define OMAP_INIT_CONTEXT_UBOOT_FROM_NOR 1 +#define OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL 2 +#define OMAP_INIT_CONTEXT_UBOOT_AFTER_CH 3 + +#endif /* _OMAP_COMMON_H_ */
- separate mux settings into essential and non essential parts - essential part is board independent as of now(so move it to SoC directory). Will help in having single SPL for all boards. - Non-essential part(the pins not essential for u-boot to function) need to be phased out eventually. - Correct mux data by aligning to the latest settings in x-loader
Signed-off-by: Aneesh V aneesh@ti.com --- This patch add 33 warnings for lines over 80 characters. However, this for the mux table and improves readability.
V3: * Squashed two mux related patches into one --- arch/arm/cpu/armv7/omap4/board.c | 53 ++++++++- arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 76 ++++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 4 +- board/ti/panda/panda.c | 25 +--- board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} | 76 +++--------- board/ti/sdp4430/sdp.c | 25 +--- .../{panda/panda.h => sdp4430/sdp4430_mux_data.h} | 128 +++++++------------ 7 files changed, 209 insertions(+), 178 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h rename board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} (76%) rename board/ti/{panda/panda.h => sdp4430/sdp4430_mux_data.h} (67%)
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index de4cc2a..3fd6f84 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -31,17 +31,65 @@ #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> +#include "omap4_mux_data.h"
+void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) +{ + int i; + struct pad_conf_entry *pad = (struct pad_conf_entry *) array; + + for (i = 0; i < size; i++, pad++) + writew(pad->val, base + pad->offset); +} + +static void set_muxconf_regs_essential(void) +{ + do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_essential, + sizeof(core_padconf_array_essential) / + sizeof(struct pad_conf_entry)); + + do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_essential, + sizeof(wkup_padconf_array_essential) / + sizeof(struct pad_conf_entry)); +} + +static void set_mux_conf_regs(void) +{ + switch (omap4_hw_init_context()) { + case OMAP_INIT_CONTEXT_SPL: + set_muxconf_regs_essential(); + break; + case OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL: + set_muxconf_regs_non_essential(); + break; + case OMAP_INIT_CONTEXT_UBOOT_FROM_NOR: + case OMAP_INIT_CONTEXT_UBOOT_AFTER_CH: + set_muxconf_regs_essential(); + set_muxconf_regs_non_essential(); + break; + } +} + /* * Routine: s_init - * Description: Does early system init of muxing and clocks. - * - Called path is with SRAM stack. + * Description: Does early system init of watchdog, muxing, andclocks + * Watchdog disable is done always. For the rest what gets done + * depends on the boot mode in which this function is executed + * 1. s_init of SPL running from SRAM + * 2. s_init of U-Boot running from FLASH + * 3. s_init of U-Boot loaded to SDRAM by SPL + * 4. s_init of U-Boot loaded to SDRAM by ROM code using the + * Configuration Header feature + * Please have a look at the respective functions to see what gets + * done in each of these cases + * This function is called with SRAM stack. */ void s_init(void) { watchdog_init(); + set_mux_conf_regs(); }
/* @@ -124,7 +172,6 @@ int checkboard(void) */ int arch_cpu_init(void) { - set_muxconf_regs(); return 0; }
diff --git a/arch/arm/cpu/armv7/omap4/omap4_mux_data.h b/arch/arm/cpu/armv7/omap4/omap4_mux_data.h new file mode 100644 index 0000000..00c52f8 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/omap4_mux_data.h @@ -0,0 +1,76 @@ + /* + * (C) Copyright 2010 + * Texas Instruments Incorporated, <www.ti.com> + * + * Balaji Krishnamoorthy balajitk@ti.com + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _OMAP4_MUX_DATA_H_ +#define _OMAP4_MUX_DATA_H_ + +#include <asm/arch/mux_omap4.h> + +const struct pad_conf_entry core_padconf_array_essential[] = { + +{GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ +{GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ +{GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ +{GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ +{GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ +{GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ +{GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ +{GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +{GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ +{GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ +{SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ +{SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ +{SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ +{SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ +{SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ +{SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ +{SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ +{SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ +{SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ +{SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ +{I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ +{I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ +{I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ +{I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ +{I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ +{I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ +{I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ +{I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ +{UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ +{UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ +{UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ +{UART3_TX_IRTX, (M0)} /* uart3_tx */ + +}; + +const struct pad_conf_entry wkup_padconf_array_essential[] = { + +{PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ +{PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ +{PAD1_SYS_32K, (IEN | M0)} /* sys_32k */ + +}; + +#endif /* _OMAP4_MUX_DATA_H_ */ diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 6b596b4..3624378 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -24,6 +24,7 @@ #include <asm/arch/omap4.h> #include <asm/io.h> #include <asm/omap_common.h> +#include <asm/arch/mux_omap4.h>
struct omap_sysinfo { char *board_string; @@ -33,7 +34,8 @@ extern const struct omap_sysinfo sysinfo; void gpmc_init(void); void watchdog_init(void); u32 get_device_type(void); -void set_muxconf_regs(void); +void do_set_mux(u32 base, struct pad_conf_entry const *array, int size); +void set_muxconf_regs_non_essential(void); void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c index 78e1910..9afed80 100644 --- a/board/ti/panda/panda.c +++ b/board/ti/panda/panda.c @@ -25,7 +25,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h>
-#include "panda.h" +#include "panda_mux_data.h"
@@ -65,27 +65,14 @@ int misc_init_r(void) return 0; }
-void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) +void set_muxconf_regs_non_essential(void) { - int i; - struct pad_conf_entry *pad = (struct pad_conf_entry *) array; - - for (i = 0; i < size; i++, pad++) - writew(pad->val, base + pad->offset); -} - -/** - * @brief set_muxconf_regs Setting up the configuration Mux registers - * specific to the board. - */ -void set_muxconf_regs(void) -{ - do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array, - sizeof(core_padconf_array) / + do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_non_essential, + sizeof(core_padconf_array_non_essential) / sizeof(struct pad_conf_entry));
- do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array, - sizeof(wkup_padconf_array) / + do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_non_essential, + sizeof(wkup_padconf_array_non_essential) / sizeof(struct pad_conf_entry)); }
diff --git a/board/ti/sdp4430/sdp.h b/board/ti/panda/panda_mux_data.h similarity index 76% rename from board/ti/sdp4430/sdp.h rename to board/ti/panda/panda_mux_data.h index bf41067..16cc0ad 100644 --- a/board/ti/sdp4430/sdp.h +++ b/board/ti/panda/panda_mux_data.h @@ -23,22 +23,12 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ +#ifndef _SDP4430_MUX_DATA_H +#define _SDP4430_MUX_DATA_H
-#ifndef _SDP_H_ -#define _SDP_H_ - -#include <asm/io.h> #include <asm/arch/mux_omap4.h>
-const struct pad_conf_entry core_padconf_array[] = { - {GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ - {GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ - {GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ - {GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ - {GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ - {GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ - {GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ - {GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_AD8, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* gpio_32 */ {GPMC_AD9, (PTU | IEN | M3)}, /* gpio_33 */ {GPMC_AD10, (PTU | IEN | M3)}, /* gpio_34 */ @@ -64,8 +54,6 @@ const struct pad_conf_entry core_padconf_array[] = { {GPMC_NWP, (M3)}, /* gpio_54 */ {GPMC_CLK, (PTD | M3)}, /* gpio_55 */ {GPMC_NADV_ALE, (M3)}, /* gpio_56 */ - {GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ - {GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ @@ -96,14 +84,14 @@ const struct pad_conf_entry core_padconf_array[] = { {CAM_SHUTTER, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_shutter */ {CAM_STROBE, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_strobe */ {CAM_GLOBALRESET, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_83 */ - {USBB1_ULPITLL_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M4)},/* usbb1_ulpiphy_clk */ - {USBB1_ULPITLL_STP, (OFF_EN | OFF_OUT_PTD | M4)}, /* usbb1_ulpiphy_stp */ - {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dir */ - {USBB1_ULPITLL_NXT, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_nxt */ - {USBB1_ULPITLL_DAT0, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat0 */ - {USBB1_ULPITLL_DAT1, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat1 */ - {USBB1_ULPITLL_DAT2, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat2 */ - {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat3 */ + {USBB1_ULPITLL_CLK, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cawake */ + {USBB1_ULPITLL_STP, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cadata */ + {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caflag */ + {USBB1_ULPITLL_NXT, (OFF_EN | M1)}, /* hsi1_acready */ + {USBB1_ULPITLL_DAT0, (OFF_EN | M1)}, /* hsi1_acwake */ + {USBB1_ULPITLL_DAT1, (OFF_EN | M1)}, /* hsi1_acdata */ + {USBB1_ULPITLL_DAT2, (OFF_EN | M1)}, /* hsi1_acflag */ + {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caready */ {USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ {USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ {USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ @@ -112,22 +100,12 @@ const struct pad_conf_entry core_padconf_array[] = { {USBB1_HSIC_STROBE, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_strobe */ {USBC1_ICUSB_DP, (IEN | M0)}, /* usbc1_icusb_dp */ {USBC1_ICUSB_DM, (IEN | M0)}, /* usbc1_icusb_dm */ - {SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ - {SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ - {SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ - {SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ - {SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ - {SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ - {SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ - {SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ - {SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ - {SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ {ABE_MCBSP2_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_clkx */ {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ {ABE_MCBSP2_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_fsx */ - {ABE_MCBSP1_CLKX, (IEN | M1)}, /* abe_slimbus1_clock */ - {ABE_MCBSP1_DR, (IEN | M1)}, /* abe_slimbus1_data */ + {ABE_MCBSP1_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_clkx */ + {ABE_MCBSP1_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dr */ {ABE_MCBSP1_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dx */ {ABE_MCBSP1_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_fsx */ {ABE_PDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_ul_data */ @@ -144,14 +122,6 @@ const struct pad_conf_entry core_padconf_array[] = { {UART2_RX, (PTU | IEN | M0)}, /* uart2_rx */ {UART2_TX, (M0)}, /* uart2_tx */ {HDQ_SIO, (M3)}, /* gpio_127 */ - {I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ - {I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ - {I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ - {I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ - {I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ - {I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ - {I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ - {I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ {MCSPI1_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_clk */ {MCSPI1_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_somi */ {MCSPI1_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_simo */ @@ -159,10 +129,6 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI1_CS1, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* mcspi1_cs1 */ {MCSPI1_CS2, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_139 */ {MCSPI1_CS3, (PTU | IEN | M3)}, /* gpio_140 */ - {UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ - {UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ - {UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ - {UART3_TX_IRTX, (M0)}, /* uart3_tx */ {SDMMC5_CLK, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc5_clk */ {SDMMC5_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_cmd */ {SDMMC5_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat0 */ @@ -175,7 +141,7 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI4_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_cs0 */ {UART4_RX, (IEN | M0)}, /* uart4_rx */ {UART4_TX, (M0)}, /* uart4_tx */ - {USBB2_ULPITLL_CLK, (IEN | M3)}, /* gpio_157 */ + {USBB2_ULPITLL_CLK, (PTD | IEN | M3)}, /* gpio_157 */ {USBB2_ULPITLL_STP, (IEN | M5)}, /* dispc2_data23 */ {USBB2_ULPITLL_DIR, (IEN | M5)}, /* dispc2_data22 */ {USBB2_ULPITLL_NXT, (IEN | M5)}, /* dispc2_data21 */ @@ -207,11 +173,11 @@ const struct pad_conf_entry core_padconf_array[] = { {FREF_CLK1_OUT, (M0)}, /* fref_clk1_out */ {FREF_CLK2_OUT, (M0)}, /* fref_clk2_out */ {SYS_NIRQ1, (PTU | IEN | M0)}, /* sys_nirq1 */ - {SYS_NIRQ2, (PTU | IEN | M0)}, /* sys_nirq2 */ + {SYS_NIRQ2, (M7)}, /* sys_nirq2 */ {SYS_BOOT0, (PTU | IEN | M3)}, /* gpio_184 */ {SYS_BOOT1, (M3)}, /* gpio_185 */ {SYS_BOOT2, (PTD | IEN | M3)}, /* gpio_186 */ - {SYS_BOOT3, (M3)}, /* gpio_187 */ + {SYS_BOOT3, (PTD | IEN | M3)}, /* gpio_187 */ {SYS_BOOT4, (M3)}, /* gpio_188 */ {SYS_BOOT5, (PTD | IEN | M3)}, /* gpio_189 */ {DPM_EMU0, (IEN | M0)}, /* dpm_emu0 */ @@ -236,14 +202,12 @@ const struct pad_conf_entry core_padconf_array[] = { {DPM_EMU19, (IEN | M5)}, /* dispc2_data0 */ };
-const struct pad_conf_entry wkup_padconf_array[] = { +const struct pad_conf_entry wkup_padconf_array_non_essential[] = { {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ {PAD1_SIM_CLK, (M0)}, /* sim_clk */ {PAD0_SIM_RESET, (M0)}, /* sim_reset */ {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ - {PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ {PAD1_FREF_XTAL_IN, (M0)}, /* # */ {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ @@ -252,13 +216,15 @@ const struct pad_conf_entry wkup_padconf_array[] = { {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ {PAD1_FREF_CLK4_REQ, (PTU | IEN | M0)}, /* # */ {PAD0_FREF_CLK4_OUT, (M0)}, /* # */ - {PAD1_SYS_32K, (IEN | M0)}, /* sys_32k */ {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ + {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ + {PAD1_FREF_CLK4_REQ, (M3)}, /* gpio_wk7 */ + {PAD0_FREF_CLK4_OUT, (M3)}, /* gpio_wk8 */ };
-#endif +#endif /* _SDP4430_MUX_DATA_H */ diff --git a/board/ti/sdp4430/sdp.c b/board/ti/sdp4430/sdp.c index b13c4c5..a5ea682 100644 --- a/board/ti/sdp4430/sdp.c +++ b/board/ti/sdp4430/sdp.c @@ -27,7 +27,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h>
-#include "sdp.h" +#include "sdp4430_mux_data.h"
@@ -70,27 +70,14 @@ int misc_init_r(void) return 0; }
diff --git a/board/ti/panda/panda.h b/board/ti/sdp4430/sdp4430_mux_data.h similarity index 67% rename from board/ti/panda/panda.h rename to board/ti/sdp4430/sdp4430_mux_data.h index e3d090e..16cc0ad 100644 --- a/board/ti/panda/panda.h +++ b/board/ti/sdp4430/sdp4430_mux_data.h @@ -23,22 +23,12 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ +#ifndef _SDP4430_MUX_DATA_H +#define _SDP4430_MUX_DATA_H
-#ifndef _PANDA_H_ -#define _PANDA_H_ - -#include <asm/io.h> #include <asm/arch/mux_omap4.h>
-const struct pad_conf_entry core_padconf_array[] = { - {GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ - {GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ - {GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ - {GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ - {GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ - {GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ - {GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ - {GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_AD8, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* gpio_32 */ {GPMC_AD9, (PTU | IEN | M3)}, /* gpio_33 */ {GPMC_AD10, (PTU | IEN | M3)}, /* gpio_34 */ @@ -53,7 +43,7 @@ const struct pad_conf_entry core_padconf_array[] = { {GPMC_A19, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row7 */ {GPMC_A20, (IEN | M3)}, /* gpio_44 */ {GPMC_A21, (M3)}, /* gpio_45 */ - {GPMC_A22, (M3)}, /* gpio_46 */ + {GPMC_A22, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col6 */ {GPMC_A23, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col7 */ {GPMC_A24, (PTD | M3)}, /* gpio_48 */ {GPMC_A25, (PTD | M3)}, /* gpio_49 */ @@ -64,14 +54,12 @@ const struct pad_conf_entry core_padconf_array[] = { {GPMC_NWP, (M3)}, /* gpio_54 */ {GPMC_CLK, (PTD | M3)}, /* gpio_55 */ {GPMC_NADV_ALE, (M3)}, /* gpio_56 */ - {GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ - {GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ - {GPMC_WAIT1, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_62 */ + {GPMC_WAIT1, (IEN | M3)}, /* gpio_62 */ {C2C_DATA11, (PTD | M3)}, /* gpio_100 */ - {C2C_DATA12, (PTU | IEN | M3)}, /* gpio_101 */ + {C2C_DATA12, (M1)}, /* dsi1_te0 */ {C2C_DATA13, (PTD | M3)}, /* gpio_102 */ {C2C_DATA14, (M1)}, /* dsi2_te0 */ {C2C_DATA15, (PTD | M3)}, /* gpio_104 */ @@ -96,14 +84,14 @@ const struct pad_conf_entry core_padconf_array[] = { {CAM_SHUTTER, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_shutter */ {CAM_STROBE, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_strobe */ {CAM_GLOBALRESET, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_83 */ - {USBB1_ULPITLL_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M4)},/* usbb1_ulpiphy_clk */ - {USBB1_ULPITLL_STP, (OFF_EN | OFF_OUT_PTD | M4)}, /* usbb1_ulpiphy_stp */ - {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dir */ - {USBB1_ULPITLL_NXT, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_nxt */ - {USBB1_ULPITLL_DAT0, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat0 */ - {USBB1_ULPITLL_DAT1, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat1 */ - {USBB1_ULPITLL_DAT2, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat2 */ - {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat3 */ + {USBB1_ULPITLL_CLK, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cawake */ + {USBB1_ULPITLL_STP, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cadata */ + {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caflag */ + {USBB1_ULPITLL_NXT, (OFF_EN | M1)}, /* hsi1_acready */ + {USBB1_ULPITLL_DAT0, (OFF_EN | M1)}, /* hsi1_acwake */ + {USBB1_ULPITLL_DAT1, (OFF_EN | M1)}, /* hsi1_acdata */ + {USBB1_ULPITLL_DAT2, (OFF_EN | M1)}, /* hsi1_acflag */ + {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caready */ {USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ {USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ {USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ @@ -112,22 +100,12 @@ const struct pad_conf_entry core_padconf_array[] = { {USBB1_HSIC_STROBE, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_strobe */ {USBC1_ICUSB_DP, (IEN | M0)}, /* usbc1_icusb_dp */ {USBC1_ICUSB_DM, (IEN | M0)}, /* usbc1_icusb_dm */ - {SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ - {SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ - {SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ - {SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ - {SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ - {SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ - {SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ - {SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ - {SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ - {SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ {ABE_MCBSP2_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_clkx */ {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ {ABE_MCBSP2_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_fsx */ - {ABE_MCBSP1_CLKX, (IEN | M1)}, /* abe_slimbus1_clock */ - {ABE_MCBSP1_DR, (IEN | M1)}, /* abe_slimbus1_data */ + {ABE_MCBSP1_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_clkx */ + {ABE_MCBSP1_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dr */ {ABE_MCBSP1_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dx */ {ABE_MCBSP1_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_fsx */ {ABE_PDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_ul_data */ @@ -144,14 +122,6 @@ const struct pad_conf_entry core_padconf_array[] = { {UART2_RX, (PTU | IEN | M0)}, /* uart2_rx */ {UART2_TX, (M0)}, /* uart2_tx */ {HDQ_SIO, (M3)}, /* gpio_127 */ - {I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ - {I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ - {I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ - {I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ - {I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ - {I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ - {I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ - {I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ {MCSPI1_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_clk */ {MCSPI1_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_somi */ {MCSPI1_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_simo */ @@ -159,10 +129,6 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI1_CS1, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* mcspi1_cs1 */ {MCSPI1_CS2, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_139 */ {MCSPI1_CS3, (PTU | IEN | M3)}, /* gpio_140 */ - {UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ - {UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ - {UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ - {UART3_TX_IRTX, (M0)}, /* uart3_tx */ {SDMMC5_CLK, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc5_clk */ {SDMMC5_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_cmd */ {SDMMC5_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat0 */ @@ -175,7 +141,7 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI4_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_cs0 */ {UART4_RX, (IEN | M0)}, /* uart4_rx */ {UART4_TX, (M0)}, /* uart4_tx */ - {USBB2_ULPITLL_CLK, (IEN | M3)}, /* gpio_157 */ + {USBB2_ULPITLL_CLK, (PTD | IEN | M3)}, /* gpio_157 */ {USBB2_ULPITLL_STP, (IEN | M5)}, /* dispc2_data23 */ {USBB2_ULPITLL_DIR, (IEN | M5)}, /* dispc2_data22 */ {USBB2_ULPITLL_NXT, (IEN | M5)}, /* dispc2_data21 */ @@ -189,12 +155,12 @@ const struct pad_conf_entry core_padconf_array[] = { {USBB2_ULPITLL_DAT7, (IEN | M5)}, /* dispc2_data11 */ {USBB2_HSIC_DATA, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_169 */ {USBB2_HSIC_STROBE, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_170 */ - {UNIPRO_TX0, (PTD | IEN | M3)}, /* gpio_171 */ + {UNIPRO_TX0, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col0 */ {UNIPRO_TY0, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col1 */ {UNIPRO_TX1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col2 */ {UNIPRO_TY1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col3 */ - {UNIPRO_TX2, (PTU | IEN | M3)}, /* gpio_0 */ - {UNIPRO_TY2, (PTU | IEN | M3)}, /* gpio_1 */ + {UNIPRO_TX2, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col4 */ + {UNIPRO_TY2, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col5 */ {UNIPRO_RX0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row0 */ {UNIPRO_RY0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row1 */ {UNIPRO_RX1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row2 */ @@ -205,13 +171,13 @@ const struct pad_conf_entry core_padconf_array[] = { {USBA0_OTG_DP, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dp */ {USBA0_OTG_DM, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dm */ {FREF_CLK1_OUT, (M0)}, /* fref_clk1_out */ - {FREF_CLK2_OUT, (PTU | IEN | M3)}, /* gpio_182 */ + {FREF_CLK2_OUT, (M0)}, /* fref_clk2_out */ {SYS_NIRQ1, (PTU | IEN | M0)}, /* sys_nirq1 */ - {SYS_NIRQ2, (PTU | IEN | M0)}, /* sys_nirq2 */ + {SYS_NIRQ2, (M7)}, /* sys_nirq2 */ {SYS_BOOT0, (PTU | IEN | M3)}, /* gpio_184 */ {SYS_BOOT1, (M3)}, /* gpio_185 */ {SYS_BOOT2, (PTD | IEN | M3)}, /* gpio_186 */ - {SYS_BOOT3, (M3)}, /* gpio_187 */ + {SYS_BOOT3, (PTD | IEN | M3)}, /* gpio_187 */ {SYS_BOOT4, (M3)}, /* gpio_188 */ {SYS_BOOT5, (PTD | IEN | M3)}, /* gpio_189 */ {DPM_EMU0, (IEN | M0)}, /* dpm_emu0 */ @@ -236,29 +202,29 @@ const struct pad_conf_entry core_padconf_array[] = { {DPM_EMU19, (IEN | M5)}, /* dispc2_data0 */ };
-const struct pad_conf_entry wkup_padconf_array[] = { - {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ - {PAD1_SIM_CLK, (M0)}, /* sim_clk */ - {PAD0_SIM_RESET, (M0)}, /* sim_reset */ - {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ - {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ - {PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ - {PAD1_FREF_XTAL_IN, (M0)}, /* # */ - {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ - {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ - {PAD0_FREF_CLK0_OUT, (M2)}, /* sys_drm_msecure */ - {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ - {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ - {PAD1_FREF_CLK4_REQ, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_1 */ - {PAD0_FREF_CLK4_OUT, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_2 */ - {PAD1_SYS_32K, (IEN | M0)}, /* sys_32k */ - {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ - {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ - {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ - {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ - {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ - {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ +const struct pad_conf_entry wkup_padconf_array_non_essential[] = { + {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ + {PAD1_SIM_CLK, (M0)}, /* sim_clk */ + {PAD0_SIM_RESET, (M0)}, /* sim_reset */ + {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ + {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ + {PAD1_FREF_XTAL_IN, (M0)}, /* # */ + {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ + {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ + {PAD0_FREF_CLK0_OUT, (M2)}, /* sys_drm_msecure */ + {PAD1_FREF_CLK3_REQ, (PTU | IEN | M0)}, /* # */ + {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ + {PAD1_FREF_CLK4_REQ, (PTU | IEN | M0)}, /* # */ + {PAD0_FREF_CLK4_OUT, (M0)}, /* # */ + {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ + {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ + {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ + {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ + {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ + {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ + {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ + {PAD1_FREF_CLK4_REQ, (M3)}, /* gpio_wk7 */ + {PAD0_FREF_CLK4_OUT, (M3)}, /* gpio_wk8 */ };
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Added a revision string in addition to the revision number Helps in printing out the OMAP revision at bootup
V3: * Improved the revision check function by saving the value instead of finding it every time. * Improved revision string function by generating it from the revision rather than hard-coding the string per revision --- arch/arm/cpu/armv7/omap4/board.c | 64 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 29 +++++++++--- arch/arm/include/asm/arch-omap4/sys_proto.h | 7 +++ arch/arm/include/asm/armv7.h | 5 ++ 4 files changed, 97 insertions(+), 8 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 3fd6f84..09861a9 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -28,6 +28,7 @@ * MA 02111-1307 USA */ #include <common.h> +#include <asm/armv7.h> #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> @@ -35,6 +36,8 @@
+u32 *const omap4_revision = (u32 *)OMAP4_SRAM_SCRATCH_OMAP4_REV; + void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) { int i; @@ -72,6 +75,66 @@ static void set_mux_conf_regs(void) } }
+static u32 cortex_a9_rev(void) +{ + + unsigned int rev; + + /* Read Main ID Register (MIDR) */ + asm ("mrc p15, 0, %0, c0, c0, 0" : "=r" (rev)); + + return rev; +} + +static void init_omap4_revision(void) +{ + /* + * For some of the ES2/ES1 boards ID_CODE is not reliable: + * Also, ES1 and ES2 have different ARM revisions + * So use ARM revision for identification + */ + unsigned int arm_rev = cortex_a9_rev(); + + switch (arm_rev) { + case MIDR_CORTEX_A9_R0P1: + *omap4_revision = OMAP4430_ES1_0; + break; + case MIDR_CORTEX_A9_R1P2: + switch (readl(CONTROL_ID_CODE)) { + case OMAP4_CONTROL_ID_CODE_ES2_0: + *omap4_revision = OMAP4430_ES2_0; + break; + case OMAP4_CONTROL_ID_CODE_ES2_1: + *omap4_revision = OMAP4430_ES2_1; + break; + case OMAP4_CONTROL_ID_CODE_ES2_2: + *omap4_revision = OMAP4430_ES2_2; + break; + default: + *omap4_revision = OMAP4430_ES2_0; + break; + } + break; + case MIDR_CORTEX_A9_R1P3: + *omap4_revision = OMAP4430_ES2_3; + break; + default: + *omap4_revision = OMAP4430_SILICON_ID_INVALID; + break; + } +} + +void omap_rev_string(char *omap4_rev_string) +{ + u32 omap4_rev = omap_revision(); + u32 omap4_variant = (omap4_rev & 0xFFFF0000) >> 16; + u32 major_rev = (omap4_rev & 0x00000F00) >> 8; + u32 minor_rev = (omap4_rev & 0x000000F0) >> 4; + + sprintf(omap4_rev_string, "OMAP%x ES%x.%x", omap4_variant, major_rev, + minor_rev); +} + /* * Routine: s_init * Description: Does early system init of watchdog, muxing, andclocks @@ -88,6 +151,7 @@ static void set_mux_conf_regs(void) */ void s_init(void) { + init_omap4_revision(); watchdog_init(); set_mux_conf_regs(); } diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index a30bb33..76b06c2 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -51,6 +51,15 @@ #define CONTROL_PADCONF_CORE (OMAP44XX_L4_CORE_BASE + 0x100000) #define CONTROL_PADCONF_WKUP (OMAP44XX_L4_CORE_BASE + 0x31E000)
+/* CONTROL_ID_CODE */ +#define CONTROL_ID_CODE 0x4A002204 + +#define OMAP4_CONTROL_ID_CODE_ES1_0 0x0B85202F +#define OMAP4_CONTROL_ID_CODE_ES2_0 0x1B85202F +#define OMAP4_CONTROL_ID_CODE_ES2_1 0x3B95C02F +#define OMAP4_CONTROL_ID_CODE_ES2_2 0x4B95C02F +#define OMAP4_CONTROL_ID_CODE_ES2_3 0x6B95C02F + /* UART */ #define UART1_BASE (OMAP44XX_L4_PER_BASE + 0x6a000) #define UART2_BASE (OMAP44XX_L4_PER_BASE + 0x6c000) @@ -119,13 +128,17 @@ struct s32ktimer { /* base address for indirect vectors (internal boot mode) */ #define SRAM_ROM_VECT_BASE 0x4030D000 /* Temporary SRAM stack used while low level init is done */ -#define LOW_LEVEL_SRAM_STACK NON_SECURE_SRAM_END - -/* - * OMAP4 real hardware: - * TODO: Change this to the IDCODE in the hw regsiter - */ -#define CPU_OMAP4430_ES10 1 -#define CPU_OMAP4430_ES20 2 +#define LOW_LEVEL_SRAM_STACK NON_SECURE_SRAM_END +#define SRAM_SCRATCH_SPACE_ADDR NON_SECURE_SRAM_START +/* SRAM scratch space entries */ +#define OMAP4_SRAM_SCRATCH_OMAP4_REV SRAM_SCRATCH_SPACE_ADDR + +/* Silicon revisions */ +#define OMAP4430_SILICON_ID_INVALID 0xFFFFFFFF +#define OMAP4430_ES1_0 0x44300100 +#define OMAP4430_ES2_0 0x44300200 +#define OMAP4430_ES2_1 0x44300210 +#define OMAP4430_ES2_2 0x44300220 +#define OMAP4430_ES2_3 0x44300230
#endif diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 3624378..c10fa18 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -40,6 +40,7 @@ void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); void set_pl310_ctrl_reg(u32 val); +void omap_rev_string(char *omap4_rev_string);
static inline u32 running_from_sdram(void) { @@ -88,4 +89,10 @@ static inline u32 omap4_hw_init_context(void) #endif }
+static inline u32 omap_revision(void) +{ + extern u32 *const omap4_revision; + return *omap4_revision; +} + #endif diff --git a/arch/arm/include/asm/armv7.h b/arch/arm/include/asm/armv7.h index 88b9c62..b5784d8 100644 --- a/arch/arm/include/asm/armv7.h +++ b/arch/arm/include/asm/armv7.h @@ -25,6 +25,11 @@ #define ARMV7_H #include <linux/types.h>
+/* Cortex-A9 revisions */ +#define MIDR_CORTEX_A9_R0P1 0x410FC091 +#define MIDR_CORTEX_A9_R1P2 0x411FC092 +#define MIDR_CORTEX_A9_R1P3 0x411FC093 + /* CCSIDR */ #define CCSIDR_LINE_SIZE_OFFSET 0 #define CCSIDR_LINE_SIZE_MASK 0x7
Add support for: 1. DPLL locking 2. Initialization of clock domains and clock modules 3. Setting up the right voltage on voltage rails
This work draws upon previous work done for x-loader by: Santosh Shilimkar santosh.shilimkar@ti.com Rajendra Nayak rnayak@ti.com
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Use pre-calculated M & N values instead of calculated ones * Changes due to make file changes * Some corrections * Do all clock initialization in SPL itself instead of differing some work to u-boot
V3: * Use struct for register addressing * Support only Turbo OPP for MPU. OPP's above this need Smart Reflex enabled * Cleaned up the scale_vcore(). Now takes into account the differing voltage offsets for different revisions of Phoenix. * Removed references to deprecated utility functions - modify_reg_32() etc. * Changed all spl_debug() to debug() * Moved the host-program for calculating DPLL multiplier/divider to tools/omap/ directory. Added more documentation * Replaced calls to omap4_revision() with omap_revision() * Some changes to IVA and ABE dpll locking code --- arch/arm/cpu/armv7/omap4/Makefile | 1 + arch/arm/cpu/armv7/omap4/board.c | 1 + arch/arm/cpu/armv7/omap4/clocks.c | 809 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/clocks.h | 664 ++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 8 + arch/arm/include/asm/omap_common.h | 3 + tools/omap/clocks_get_m_n.c | 197 +++++++ 7 files changed, 1683 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/clocks.c create mode 100644 arch/arm/include/asm/arch-omap4/clocks.h create mode 100644 tools/omap/clocks_get_m_n.c
diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index 987dc9d..ac4b2a6 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -28,6 +28,7 @@ LIB = $(obj)lib$(SOC).o SOBJS += lowlevel_init.o
COBJS += board.o +COBJS += clocks.o COBJS += mem.o COBJS += sys_info.o
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 09861a9..1c26a66 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -154,6 +154,7 @@ void s_init(void) init_omap4_revision(); watchdog_init(); set_mux_conf_regs(); + prcm_init(); }
/* diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c new file mode 100644 index 0000000..e8d3a52 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/clocks.c @@ -0,0 +1,809 @@ +/* + * + * Clock initialization for OMAP4 + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * Based on previous work by: + * Santosh Shilimkar santosh.shilimkar@ti.com + * Rajendra Nayak rnayak@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/omap_common.h> +#include <asm/arch/clocks.h> +#include <asm/arch/sys_proto.h> +#include <asm/utils.h> + +#ifndef CONFIG_SPL_BUILD +/* + * printing to console doesn't work unless + * this code is executed from SPL + */ +#define printf(fmt, args...) +#define puts(s) +#endif + +#define abs(x) (((x) < 0) ? ((x)*-1) : (x)) + +struct omap4_prcm_regs *const prcm = (struct omap4_prcm_regs *)0x4A004100; + +static const u32 sys_clk_array[8] = { + 12000000, /* 12 MHz */ + 13000000, /* 13 MHz */ + 16800000, /* 16.8 MHz */ + 19200000, /* 19.2 MHz */ + 26000000, /* 26 MHz */ + 27000000, /* 27 MHz */ + 38400000, /* 38.4 MHz */ +}; + +/* + * The M & N values in the following tables are created using the + * following tool: + * tools/omap/clocks_get_m_n.c + * Please use this tool for creating the table for any new frequency. + */ + +/* dpll locked at 1584 MHz - MPU clk at 792 MHz(OPP Turbo) */ +static const struct dpll_params mpu_dpll_params_1584mhz[NUM_SYS_CLKS] = { + {66, 0, 1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {792, 12, 1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {330, 6, 1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {165, 3, 1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {396, 12, 1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {88, 2, 1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {165, 7, 1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +/* dpll locked at 1200 MHz - MPU clk at 600 MHz */ +static const struct dpll_params mpu_dpll_params_1200mhz[NUM_SYS_CLKS] = { + {50, 0, 1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {600, 12, 1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {250, 6, 1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {125, 3, 1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {300, 12, 1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {200, 8, 1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {125, 7, 1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params core_dpll_params_1600mhz[NUM_SYS_CLKS] = { + {200, 2, 1, 5, 8, 4, 6, 5}, /* 12 MHz */ + {800, 12, 1, 5, 8, 4, 6, 5}, /* 13 MHz */ + {619, 12, 1, 5, 8, 4, 6, 5}, /* 16.8 MHz */ + {125, 2, 1, 5, 8, 4, 6, 5}, /* 19.2 MHz */ + {400, 12, 1, 5, 8, 4, 6, 5}, /* 26 MHz */ + {800, 26, 1, 5, 8, 4, 6, 5}, /* 27 MHz */ + {125, 5, 1, 5, 8, 4, 6, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params core_dpll_params_es1_1524mhz[NUM_SYS_CLKS] = { + {127, 1, 1, 5, 8, 4, 6, 5}, /* 12 MHz */ + {762, 12, 1, 5, 8, 4, 6, 5}, /* 13 MHz */ + {635, 13, 1, 5, 8, 4, 6, 5}, /* 16.8 MHz */ + {635, 15, 1, 5, 8, 4, 6, 5}, /* 19.2 MHz */ + {381, 12, 1, 5, 8, 4, 6, 5}, /* 26 MHz */ + {254, 8, 1, 5, 8, 4, 6, 5}, /* 27 MHz */ + {496, 24, 1, 5, 8, 4, 6, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params + core_dpll_params_es2_1600mhz_ddr200mhz[NUM_SYS_CLKS] = { + {200, 2, 2, 5, 8, 4, 6, 5}, /* 12 MHz */ + {800, 12, 2, 5, 8, 4, 6, 5}, /* 13 MHz */ + {619, 12, 2, 5, 8, 4, 6, 5}, /* 16.8 MHz */ + {125, 2, 2, 5, 8, 4, 6, 5}, /* 19.2 MHz */ + {400, 12, 2, 5, 8, 4, 6, 5}, /* 26 MHz */ + {800, 26, 2, 5, 8, 4, 6, 5}, /* 27 MHz */ + {125, 5, 2, 5, 8, 4, 6, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params per_dpll_params_1536mhz[NUM_SYS_CLKS] = { + {64, 0, 8, 6, 12, 9, 4, 5}, /* 12 MHz */ + {768, 12, 8, 6, 12, 9, 4, 5}, /* 13 MHz */ + {320, 6, 8, 6, 12, 9, 4, 5}, /* 16.8 MHz */ + {40, 0, 8, 6, 12, 9, 4, 5}, /* 19.2 MHz */ + {384, 12, 8, 6, 12, 9, 4, 5}, /* 26 MHz */ + {256, 8, 8, 6, 12, 9, 4, 5}, /* 27 MHz */ + {20, 0, 8, 6, 12, 9, 4, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params iva_dpll_params_1862mhz[NUM_SYS_CLKS] = { + {931, 11, -1, -1, 4, 7, -1, -1}, /* 12 MHz */ + {931, 12, -1, -1, 4, 7, -1, -1}, /* 13 MHz */ + {665, 11, -1, -1, 4, 7, -1, -1}, /* 16.8 MHz */ + {727, 14, -1, -1, 4, 7, -1, -1}, /* 19.2 MHz */ + {931, 25, -1, -1, 4, 7, -1, -1}, /* 26 MHz */ + {931, 26, -1, -1, 4, 7, -1, -1}, /* 27 MHz */ + {412, 16, -1, -1, 4, 7, -1, -1} /* 38.4 MHz */ +}; + +/* ABE M & N values with sys_clk as source */ +static const struct dpll_params + abe_dpll_params_sysclk_196608khz[NUM_SYS_CLKS] = { + {49, 5, 1, 1, -1, -1, -1, -1}, /* 12 MHz */ + {68, 8, 1, 1, -1, -1, -1, -1}, /* 13 MHz */ + {35, 5, 1, 1, -1, -1, -1, -1}, /* 16.8 MHz */ + {46, 8, 1, 1, -1, -1, -1, -1}, /* 19.2 MHz */ + {34, 8, 1, 1, -1, -1, -1, -1}, /* 26 MHz */ + {29, 7, 1, 1, -1, -1, -1, -1}, /* 27 MHz */ + {64, 24, 1, 1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +/* ABE M & N values with 32K clock as source */ +static const struct dpll_params abe_dpll_params_32k_196608khz = { + 750, 0, 1, 1, -1, -1, -1, -1 +}; + + +static const struct dpll_params usb_dpll_params_1920mhz[NUM_SYS_CLKS] = { + {80, 0, 2, -1, -1, -1, -1, -1}, /* 12 MHz */ + {960, 12, 2, -1, -1, -1, -1, -1}, /* 13 MHz */ + {400, 6, 2, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {50, 0, 2, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {480, 12, 2, -1, -1, -1, -1, -1}, /* 26 MHz */ + {320, 8, 2, -1, -1, -1, -1, -1}, /* 27 MHz */ + {25, 0, 2, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static inline u32 __get_sys_clk_index(void) +{ + u32 ind; + /* + * For ES1 the ROM code calibration of sys clock is not reliable + * due to hw issue. So, use hard-coded value. If this value is not + * correct for any board over-ride this function in board file + * From ES2.0 onwards you will get this information from + * CM_SYS_CLKSEL + */ + if (omap_revision() == OMAP4430_ES1_0) + ind = OMAP_SYS_CLK_IND_38_4_MHZ; + else { + /* SYS_CLKSEL - 1 to match the dpll param array indices */ + ind = (readl(&prcm->cm_sys_clksel) & + CM_SYS_CLKSEL_SYS_CLKSEL_MASK) - 1; + } + return ind; +} + +u32 get_sys_clk_index(void) + __attribute__ ((weak, alias("__get_sys_clk_index"))); + +u32 get_sys_clk_freq(void) +{ + u8 index = get_sys_clk_index(); + return sys_clk_array[index]; +} + +static inline void do_bypass_dpll(u32 *const base) +{ + struct dpll_regs *dpll_regs = (struct dpll_regs *)base; + + clrsetbits_le32(&dpll_regs->cm_clkmode_dpll, + CM_CLKMODE_DPLL_DPLL_EN_MASK, + DPLL_EN_FAST_RELOCK_BYPASS << + CM_CLKMODE_DPLL_EN_SHIFT); +} + +static inline void wait_for_bypass(u32 *const base) +{ + struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; + + if (!wait_on_value(ST_DPLL_CLK_MASK, 0, &dpll_regs->cm_idlest_dpll, + LDELAY)) { + printf("Bypassing DPLL failed %p\n", base); + } +} + +static inline void do_lock_dpll(u32 *const base) +{ + struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; + + clrsetbits_le32(&dpll_regs->cm_clkmode_dpll, + CM_CLKMODE_DPLL_DPLL_EN_MASK, + DPLL_EN_LOCK << CM_CLKMODE_DPLL_EN_SHIFT); +} + +static inline void wait_for_lock(u32 *const base) +{ + struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; + + if (!wait_on_value(ST_DPLL_CLK_MASK, ST_DPLL_CLK_MASK, + &dpll_regs->cm_idlest_dpll, LDELAY)) { + printf("DPLL locking failed for %p\n", base); + hang(); + } +} + +static void do_setup_dpll(u32 *const base, const struct dpll_params *params, + u8 lock) +{ + u32 temp; + struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; + + bypass_dpll(base); + + /* Set M & N */ + temp = readl(&dpll_regs->cm_clksel_dpll); + + temp &= ~CM_CLKSEL_DPLL_M_MASK; + temp |= (params->m << CM_CLKSEL_DPLL_M_SHIFT) & CM_CLKSEL_DPLL_M_MASK; + + temp &= ~CM_CLKSEL_DPLL_N_MASK; + temp |= (params->n << CM_CLKSEL_DPLL_N_SHIFT) & CM_CLKSEL_DPLL_N_MASK; + + writel(temp, &dpll_regs->cm_clksel_dpll); + + /* Lock */ + if (lock) + do_lock_dpll(base); + + /* Setup post-dividers */ + if (params->m2 >= 0) + writel(params->m2, &dpll_regs->cm_div_m2_dpll); + if (params->m3 >= 0) + writel(params->m3, &dpll_regs->cm_div_m3_dpll); + if (params->m4 >= 0) + writel(params->m4, &dpll_regs->cm_div_m4_dpll); + if (params->m5 >= 0) + writel(params->m5, &dpll_regs->cm_div_m5_dpll); + if (params->m6 >= 0) + writel(params->m6, &dpll_regs->cm_div_m6_dpll); + if (params->m7 >= 0) + writel(params->m7, &dpll_regs->cm_div_m7_dpll); + + /* Wait till the DPLL locks */ + if (lock) + wait_for_lock(base); +} + +const struct dpll_params *get_core_dpll_params(void) +{ + u32 sysclk_ind = get_sys_clk_index(); + + switch (omap_revision()) { + case OMAP4430_ES1_0: + return &core_dpll_params_es1_1524mhz[sysclk_ind]; + case OMAP4430_ES2_0: + case OMAP4430_SILICON_ID_INVALID: + /* safest */ + return &core_dpll_params_es2_1600mhz_ddr200mhz[sysclk_ind]; + default: + return &core_dpll_params_1600mhz[sysclk_ind]; + } +} + +u32 omap4_ddr_clk(void) +{ + u32 ddr_clk, sys_clk_khz; + const struct dpll_params *core_dpll_params; + + sys_clk_khz = get_sys_clk_freq() / 1000; + + core_dpll_params = get_core_dpll_params(); + + debug("sys_clk %d\n ", sys_clk_khz * 1000); + + /* Find Core DPLL locked frequency first */ + ddr_clk = sys_clk_khz * 2 * core_dpll_params->m / + (core_dpll_params->n + 1); + /* + * DDR frequency is PHY_ROOT_CLK/2 + * PHY_ROOT_CLK = Fdpll/2/M2 + */ + ddr_clk = ddr_clk / 4 / core_dpll_params->m2; + + ddr_clk *= 1000; /* convert to Hz */ + debug("ddr_clk %d\n ", ddr_clk); + + return ddr_clk; +} + +static void setup_dplls(void) +{ + u32 sysclk_ind, temp; + const struct dpll_params *params; + debug("setup_dplls\n"); + + sysclk_ind = get_sys_clk_index(); + + /* CORE dpll */ + params = get_core_dpll_params(); /* default - safest */ + /* + * Do not lock the core DPLL now. Just set it up. + * Core DPLL will be locked after setting up EMIF + * using the FREQ_UPDATE method(freq_update_core()) + */ + do_setup_dpll(&prcm->cm_clkmode_dpll_core, params, DPLL_NO_LOCK); + /* Set the ratios for CORE_CLK, L3_CLK, L4_CLK */ + temp = (CLKSEL_CORE_X2_DIV_1 << CLKSEL_CORE_SHIFT) | + (CLKSEL_L3_CORE_DIV_2 << CLKSEL_L3_SHIFT) | + (CLKSEL_L4_L3_DIV_2 << CLKSEL_L4_SHIFT); + writel(temp, &prcm->cm_clksel_core); + debug("Core DPLL configured\n"); + + /* lock PER dpll */ + do_setup_dpll(&prcm->cm_clkmode_dpll_per, + &per_dpll_params_1536mhz[sysclk_ind], DPLL_LOCK); + debug("PER DPLL locked\n"); + + /* MPU dpll */ + if (omap_revision() == OMAP4430_ES1_0) + params = &mpu_dpll_params_1200mhz[sysclk_ind]; + else + params = &mpu_dpll_params_1584mhz[sysclk_ind]; + do_setup_dpll(&prcm->cm_clkmode_dpll_mpu, params, DPLL_LOCK); + debug("MPU DPLL locked\n"); +} + +static void setup_non_essential_dplls(void) +{ + u32 sys_clk_khz, abe_ref_clk; + u32 sysclk_ind, sd_div, num, den; + const struct dpll_params *params; + + sysclk_ind = get_sys_clk_index(); + sys_clk_khz = get_sys_clk_freq() / 1000; + + /* IVA */ + clrsetbits_le32(&prcm->cm_bypclk_dpll_iva, + CM_BYPCLK_DPLL_IVA_CLKSEL_MASK, DPLL_IVA_CLKSEL_CORE_X2_DIV_2); + + do_setup_dpll(&prcm->cm_clkmode_dpll_iva, + &iva_dpll_params_1862mhz[sysclk_ind], DPLL_LOCK); + + /* + * USB: + * USB dpll is J-type. Need to set DPLL_SD_DIV for jitter correction + * DPLL_SD_DIV = CEILING ([DPLL_MULT/(DPLL_DIV+1)]* CLKINP / 250) + * - where CLKINP is sys_clk in MHz + * Use CLKINP in KHz and adjust the denominator accordingly so + * that we have enough accuracy and at the same time no overflow + */ + params = &usb_dpll_params_1920mhz[sysclk_ind]; + num = params->m * sys_clk_khz; + den = (params->n + 1) * 250 * 1000; + num += den - 1; + sd_div = num / den; + clrsetbits_le32(&prcm->cm_clksel_dpll_usb, + CM_CLKSEL_DPLL_DPLL_SD_DIV_MASK, + sd_div << CM_CLKSEL_DPLL_DPLL_SD_DIV_SHIFT); + + /* Now setup the dpll with the regular function */ + do_setup_dpll(&prcm->cm_clkmode_dpll_usb, params, DPLL_LOCK); + +#ifdef CONFIG_SYS_OMAP4_ABE_SYSCK + params = &abe_dpll_params_sysclk_196608khz[sysclk_ind]; + abe_ref_clk = CM_ABE_PLL_REF_CLKSEL_CLKSEL_SYSCLK; +#else + params = &abe_dpll_params_32k_196608khz; + abe_ref_clk = CM_ABE_PLL_REF_CLKSEL_CLKSEL_32KCLK; + /* + * We need to enable some additional options to achieve + * 196.608MHz from 32768 Hz + */ + setbits_le32(&prcm->cm_clkmode_dpll_abe, + CM_CLKMODE_DPLL_DRIFTGUARD_EN_MASK| + CM_CLKMODE_DPLL_RELOCK_RAMP_EN_MASK| + CM_CLKMODE_DPLL_LPMODE_EN_MASK| + CM_CLKMODE_DPLL_REGM4XEN_MASK); + /* Spend 4 REFCLK cycles at each stage */ + clrsetbits_le32(&prcm->cm_clkmode_dpll_abe, + CM_CLKMODE_DPLL_RAMP_RATE_MASK, + 1 << CM_CLKMODE_DPLL_RAMP_RATE_SHIFT); +#endif + + /* Select the right reference clk */ + clrsetbits_le32(&prcm->cm_abe_pll_ref_clksel, + CM_ABE_PLL_REF_CLKSEL_CLKSEL_MASK, + abe_ref_clk << CM_ABE_PLL_REF_CLKSEL_CLKSEL_SHIFT); + /* Lock the dpll */ + do_setup_dpll(&prcm->cm_clkmode_dpll_abe, params, DPLL_LOCK); +} + +static void do_scale_vcore(u32 vcore_reg, u32 volt_mv) +{ + u32 temp, offset_code; + u32 step = 12660; /* 12.66 mV represented in uV */ + u32 offset = volt_mv; + + /* convert to uV for better accuracy in the calculations */ + offset *= 1000; + + if (omap_revision() == OMAP4430_ES1_0) + offset -= PHOENIX_SMPS_BASE_VOLT_STD_MODE_UV; + else + offset -= PHOENIX_SMPS_BASE_VOLT_STD_MODE_WITH_OFFSET_UV; + + offset_code = (offset + step - 1) / step; + /* The code starts at 1 not 0 */ + offset_code++; + + debug("do_scale_vcore: volt - %d offset_code - 0x%x\n", volt_mv, + offset_code); + + temp = SMPS_I2C_SLAVE_ADDR | + (vcore_reg << PRM_VC_VAL_BYPASS_REGADDR_SHIFT) | + (offset_code << PRM_VC_VAL_BYPASS_DATA_SHIFT) | + PRM_VC_VAL_BYPASS_VALID_BIT; + writel(temp, &prcm->prm_vc_val_bypass); + if (!wait_on_value(PRM_VC_VAL_BYPASS_VALID_BIT, 0, + &prcm->prm_vc_val_bypass, LDELAY)) { + printf("Scaling voltage failed for 0x%x\n", vcore_reg); + } +} + +/* + * Setup the voltages for vdd_mpu, vdd_core, and vdd_iva + * We set the maximum voltages allowed here because Smart-Reflex is not + * enabled in bootloader. Voltage initialization in the kernel will set + * these to the nominal values after enabling Smart-Reflex + */ +static void scale_vcores(void) +{ + u32 volt, sys_clk_khz, cycles_hi, cycles_low, temp; + + sys_clk_khz = get_sys_clk_freq() / 1000; + + /* + * Setup the dedicated I2C controller for Voltage Control + * I2C clk - high period 40% low period 60% + */ + cycles_hi = sys_clk_khz * 4 / PRM_VC_I2C_CHANNEL_FREQ_KHZ / 10; + cycles_low = sys_clk_khz * 6 / PRM_VC_I2C_CHANNEL_FREQ_KHZ / 10; + /* values to be set in register - less by 5 & 7 respectively */ + cycles_hi -= 5; + cycles_low -= 7; + temp = (cycles_hi << PRM_VC_CFG_I2C_CLK_SCLH_SHIFT) | + (cycles_low << PRM_VC_CFG_I2C_CLK_SCLL_SHIFT); + writel(temp, &prcm->prm_vc_cfg_i2c_clk); + + /* Disable high speed mode and all advanced features */ + writel(0x0, &prcm->prm_vc_cfg_i2c_mode); + + /* + * VCORE 1 - 4430 : supplies vdd_mpu + * Setting a high voltage for Nitro mode as smart reflex is not enabled. + * We use the maximum possible value in the AVS range because the next + * higher voltage in the discrete range (code >= 0b111010) is way too + * high + */ + volt = 1417; + do_scale_vcore(SMPS_REG_ADDR_VCORE1, volt); + + /* VCORE 2 - supplies vdd_iva */ + volt = 1200; + do_scale_vcore(SMPS_REG_ADDR_VCORE2, volt); + + /* VCORE 3 - supplies vdd_core */ + volt = 1200; + do_scale_vcore(SMPS_REG_ADDR_VCORE3, volt); +} + +static inline void enable_clock_domain(u32 *const clkctrl_reg, u32 enable_mode) +{ + clrsetbits_le32(clkctrl_reg, CD_CLKCTRL_CLKTRCTRL_MASK, + enable_mode << CD_CLKCTRL_CLKTRCTRL_SHIFT); + debug("Enable clock domain - 0x%08x\n", clkctrl_reg); +} + +static inline void wait_for_clk_enable(u32 *clkctrl_addr) +{ + u32 clkctrl, idlest = MODULE_CLKCTRL_IDLEST_DISABLED; + u32 bound = LDELAY; + + while ((idlest == MODULE_CLKCTRL_IDLEST_DISABLED) || + (idlest == MODULE_CLKCTRL_IDLEST_TRANSITIONING)) { + + clkctrl = readl(clkctrl_addr); + idlest = (clkctrl & MODULE_CLKCTRL_IDLEST_MASK) >> + MODULE_CLKCTRL_IDLEST_SHIFT; + if (--bound == 0) { + printf("Clock enable failed for 0x%p idlest 0x%x\n", + clkctrl_addr, clkctrl); + return; + } + } +} + +static inline void enable_clock_module(u32 *const clkctrl_addr, u32 enable_mode, + u32 wait_for_enable) +{ + clrsetbits_le32(clkctrl_addr, MODULE_CLKCTRL_MODULEMODE_MASK, + enable_mode << MODULE_CLKCTRL_MODULEMODE_SHIFT); + debug("Enable clock module - 0x%08x\n", clkctrl_addr); + if (wait_for_enable) + wait_for_clk_enable(clkctrl_addr); +} + +/* + * Enable essential clock domains, modules and + * do some additional special settings needed + */ +static void enable_basic_clocks(void) +{ + u32 i, max = 100, wait_for_enable = 1; + u32 *const clk_domains_essential[] = { + &prcm->cm_l4per_clkstctrl, + &prcm->cm_l3init_clkstctrl, + &prcm->cm_memif_clkstctrl, + &prcm->cm_l4cfg_clkstctrl, + 0 + }; + + u32 *const clk_modules_hw_auto_essential[] = { + &prcm->cm_wkup_gpio1_clkctrl, + &prcm->cm_l4per_gpio2_clkctrl, + &prcm->cm_l4per_gpio3_clkctrl, + &prcm->cm_l4per_gpio4_clkctrl, + &prcm->cm_l4per_gpio5_clkctrl, + &prcm->cm_l4per_gpio6_clkctrl, + &prcm->cm_memif_emif_1_clkctrl, + &prcm->cm_memif_emif_2_clkctrl, + &prcm->cm_l3init_hsusbotg_clkctrl, + &prcm->cm_l3init_usbphy_clkctrl, + &prcm->cm_l4cfg_l4_cfg_clkctrl, + 0 + }; + + u32 *const clk_modules_explicit_en_essential[] = { + &prcm->cm_l4per_gptimer2_clkctrl, + &prcm->cm_l3init_hsmmc1_clkctrl, + &prcm->cm_l3init_hsmmc2_clkctrl, + &prcm->cm_l4per_mcspi1_clkctrl, + &prcm->cm_wkup_gptimer1_clkctrl, + &prcm->cm_l4per_i2c1_clkctrl, + &prcm->cm_l4per_i2c2_clkctrl, + &prcm->cm_l4per_i2c3_clkctrl, + &prcm->cm_l4per_i2c4_clkctrl, + &prcm->cm_wkup_wdtimer2_clkctrl, + &prcm->cm_l4per_uart3_clkctrl, + 0 + }; + + /* Enable optional additional functional clock for GPIO4 */ + setbits_le32(&prcm->cm_l4per_gpio4_clkctrl, + GPIO4_CLKCTRL_OPTFCLKEN_MASK); + + /* Enable 96 MHz clock for MMC1 & MMC2 */ + setbits_le32(&prcm->cm_l3init_hsmmc1_clkctrl, + HSMMC_CLKCTRL_CLKSEL_MASK); + setbits_le32(&prcm->cm_l3init_hsmmc2_clkctrl, + HSMMC_CLKCTRL_CLKSEL_MASK); + + /* Select 32KHz clock as the source of GPTIMER1 */ + setbits_le32(&prcm->cm_wkup_gptimer1_clkctrl, + GPTIMER1_CLKCTRL_CLKSEL_MASK); + + /* Enable optional 48M functional clock for USB PHY */ + setbits_le32(&prcm->cm_l3init_usbphy_clkctrl, + USBPHY_CLKCTRL_OPTFCLKEN_PHY_48M_MASK); + + /* Put the clock domains in SW_WKUP mode */ + for (i = 0; (i < max) && clk_domains_essential[i]; i++) { + enable_clock_domain(clk_domains_essential[i], + CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + } + + /* Clock modules that need to be put in HW_AUTO */ + for (i = 0; (i < max) && clk_modules_hw_auto_essential[i]; i++) { + enable_clock_module(clk_modules_hw_auto_essential[i], + MODULE_CLKCTRL_MODULEMODE_HW_AUTO, + wait_for_enable); + }; + + /* Clock modules that need to be put in SW_EXPLICIT_EN mode */ + for (i = 0; (i < max) && clk_modules_explicit_en_essential[i]; i++) { + enable_clock_module(clk_modules_explicit_en_essential[i], + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN, + wait_for_enable); + }; + + /* Put the clock domains in HW_AUTO mode now */ + for (i = 0; (i < max) && clk_domains_essential[i]; i++) { + enable_clock_domain(clk_domains_essential[i], + CD_CLKCTRL_CLKTRCTRL_HW_AUTO); + } +} + +/* + * Enable non-essential clock domains, modules and + * do some additional special settings needed + */ +static void enable_non_essential_clocks(void) +{ + u32 i, max = 100, wait_for_enable = 0; + u32 *const clk_domains_non_essential[] = { + &prcm->cm_mpu_m3_clkstctrl, + &prcm->cm_ivahd_clkstctrl, + &prcm->cm_dsp_clkstctrl, + &prcm->cm_dss_clkstctrl, + &prcm->cm_sgx_clkstctrl, + &prcm->cm1_abe_clkstctrl, + &prcm->cm_c2c_clkstctrl, + &prcm->cm_cam_clkstctrl, + &prcm->cm_dss_clkstctrl, + &prcm->cm_sdma_clkstctrl, + 0 + }; + + u32 *const clk_modules_hw_auto_non_essential[] = { + &prcm->cm_mpu_m3_mpu_m3_clkctrl, + &prcm->cm_ivahd_ivahd_clkctrl, + &prcm->cm_ivahd_sl2_clkctrl, + &prcm->cm_dsp_dsp_clkctrl, + &prcm->cm_l3_2_gpmc_clkctrl, + &prcm->cm_l3instr_l3_3_clkctrl, + &prcm->cm_l3instr_l3_instr_clkctrl, + &prcm->cm_l3instr_intrconn_wp1_clkctrl, + &prcm->cm_l3init_hsi_clkctrl, + &prcm->cm_l3init_hsusbtll_clkctrl, + 0 + }; + + u32 *const clk_modules_explicit_en_non_essential[] = { + &prcm->cm1_abe_aess_clkctrl, + &prcm->cm1_abe_pdm_clkctrl, + &prcm->cm1_abe_dmic_clkctrl, + &prcm->cm1_abe_mcasp_clkctrl, + &prcm->cm1_abe_mcbsp1_clkctrl, + &prcm->cm1_abe_mcbsp2_clkctrl, + &prcm->cm1_abe_mcbsp3_clkctrl, + &prcm->cm1_abe_slimbus_clkctrl, + &prcm->cm1_abe_timer5_clkctrl, + &prcm->cm1_abe_timer6_clkctrl, + &prcm->cm1_abe_timer7_clkctrl, + &prcm->cm1_abe_timer8_clkctrl, + &prcm->cm1_abe_wdt3_clkctrl, + &prcm->cm_l4per_gptimer9_clkctrl, + &prcm->cm_l4per_gptimer10_clkctrl, + &prcm->cm_l4per_gptimer11_clkctrl, + &prcm->cm_l4per_gptimer3_clkctrl, + &prcm->cm_l4per_gptimer4_clkctrl, + &prcm->cm_l4per_hdq1w_clkctrl, + &prcm->cm_l4per_mcbsp4_clkctrl, + &prcm->cm_l4per_mcspi2_clkctrl, + &prcm->cm_l4per_mcspi3_clkctrl, + &prcm->cm_l4per_mcspi4_clkctrl, + &prcm->cm_l4per_mmcsd3_clkctrl, + &prcm->cm_l4per_mmcsd4_clkctrl, + &prcm->cm_l4per_mmcsd5_clkctrl, + &prcm->cm_l4per_uart1_clkctrl, + &prcm->cm_l4per_uart2_clkctrl, + &prcm->cm_l4per_uart4_clkctrl, + &prcm->cm_wkup_keyboard_clkctrl, + &prcm->cm_wkup_wdtimer2_clkctrl, + &prcm->cm_cam_iss_clkctrl, + &prcm->cm_cam_fdif_clkctrl, + &prcm->cm_dss_dss_clkctrl, + &prcm->cm_sgx_sgx_clkctrl, + &prcm->cm_l3init_hsusbhost_clkctrl, + &prcm->cm_l3init_fsusb_clkctrl, + 0 + }; + + /* Enable optional functional clock for ISS */ + setbits_le32(&prcm->cm_cam_iss_clkctrl, ISS_CLKCTRL_OPTFCLKEN_MASK); + + /* Enable all optional functional clocks of DSS */ + setbits_le32(&prcm->cm_dss_dss_clkctrl, DSS_CLKCTRL_OPTFCLKEN_MASK); + + + /* Put the clock domains in SW_WKUP mode */ + for (i = 0; (i < max) && clk_domains_non_essential[i]; i++) { + enable_clock_domain(clk_domains_non_essential[i], + CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + } + + /* Clock modules that need to be put in HW_AUTO */ + for (i = 0; (i < max) && clk_modules_hw_auto_non_essential[i]; i++) { + enable_clock_module(clk_modules_hw_auto_non_essential[i], + MODULE_CLKCTRL_MODULEMODE_HW_AUTO, + wait_for_enable); + }; + + /* Clock modules that need to be put in SW_EXPLICIT_EN mode */ + for (i = 0; (i < max) && clk_modules_explicit_en_non_essential[i]; + i++) { + enable_clock_module(clk_modules_explicit_en_non_essential[i], + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN, + wait_for_enable); + }; + + /* Put the clock domains in HW_AUTO mode now */ + for (i = 0; (i < max) && clk_domains_non_essential[i]; i++) { + enable_clock_domain(clk_domains_non_essential[i], + CD_CLKCTRL_CLKTRCTRL_HW_AUTO); + } + + /* Put camera module in no sleep mode */ + clrsetbits_le32(&prcm->cm_cam_clkstctrl, MODULE_CLKCTRL_MODULEMODE_MASK, + CD_CLKCTRL_CLKTRCTRL_NO_SLEEP << + MODULE_CLKCTRL_MODULEMODE_SHIFT); +} + + +void freq_update_core(void) +{ + u32 freq_config1 = 0; + const struct dpll_params *core_dpll_params; + + core_dpll_params = get_core_dpll_params(); + /* Put EMIF clock domain in sw wakeup mode */ + enable_clock_domain(&prcm->cm_memif_clkstctrl, + CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + wait_for_clk_enable(&prcm->cm_memif_emif_1_clkctrl); + wait_for_clk_enable(&prcm->cm_memif_emif_2_clkctrl); + + freq_config1 = SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK | + SHADOW_FREQ_CONFIG1_DLL_RESET_MASK; + + freq_config1 |= (DPLL_EN_LOCK << SHADOW_FREQ_CONFIG1_DPLL_EN_SHIFT) & + SHADOW_FREQ_CONFIG1_DPLL_EN_MASK; + + freq_config1 |= (core_dpll_params->m2 << + SHADOW_FREQ_CONFIG1_M2_DIV_SHIFT) & + SHADOW_FREQ_CONFIG1_M2_DIV_MASK; + + writel(freq_config1, &prcm->cm_shadow_freq_config1); + if (!wait_on_value(SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK, 0, + &prcm->cm_shadow_freq_config1, LDELAY)) { + puts("FREQ UPDATE procedure failed!!"); + hang(); + } + + /* Put EMIF clock domain back in hw auto mode */ + enable_clock_domain(&prcm->cm_memif_clkstctrl, + CD_CLKCTRL_CLKTRCTRL_HW_AUTO); + wait_for_clk_enable(&prcm->cm_memif_emif_1_clkctrl); + wait_for_clk_enable(&prcm->cm_memif_emif_2_clkctrl); +} + +void bypass_dpll(u32 *const base) +{ + do_bypass_dpll(base); + wait_for_bypass(base); +} + +void lock_dpll(u32 *const base) +{ + do_lock_dpll(base); + wait_for_lock(base); +} + +void prcm_init(void) +{ + switch (omap4_hw_init_context()) { + case OMAP_INIT_CONTEXT_SPL: + case OMAP_INIT_CONTEXT_UBOOT_FROM_NOR: + case OMAP_INIT_CONTEXT_UBOOT_AFTER_CH: + scale_vcores(); + setup_dplls(); + enable_basic_clocks(); + setup_non_essential_dplls(); + enable_non_essential_clocks(); + break; + default: + break; + } +} diff --git a/arch/arm/include/asm/arch-omap4/clocks.h b/arch/arm/include/asm/arch-omap4/clocks.h new file mode 100644 index 0000000..71db39c --- /dev/null +++ b/arch/arm/include/asm/arch-omap4/clocks.h @@ -0,0 +1,664 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _CLOCKS_OMAP4_H_ +#define _CLOCKS_OMAP4_H_ +#include <common.h> + +/* + * Assuming a maximum of 1.5 GHz ARM speed and a minimum of 2 cycles per + * loop, allow for a minimum of 2 ms wait (in reality the wait will be + * much more than that) + */ +#define LDELAY 1000000 + +#define CM_CLKMODE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4120) +#define CM_CLKMODE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8140) +#define CM_CLKMODE_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4160) +#define CM_CLKSEL_CORE (OMAP44XX_L4_CORE_BASE + 0x4100) + +struct omap4_prcm_regs { + /* cm1.ckgen */ + u32 cm_clksel_core; + u32 pad001[1]; + u32 cm_clksel_abe; + u32 pad002[1]; + u32 cm_dll_ctrl; + u32 pad003[3]; + u32 cm_clkmode_dpll_core; + u32 cm_idlest_dpll_core; + u32 cm_autoidle_dpll_core; + u32 cm_clksel_dpll_core; + u32 cm_div_m2_dpll_core; + u32 cm_div_m3_dpll_core; + u32 cm_div_m4_dpll_core; + u32 cm_div_m5_dpll_core; + u32 cm_div_m6_dpll_core; + u32 cm_div_m7_dpll_core; + u32 cm_ssc_deltamstep_dpll_core; + u32 cm_ssc_modfreqdiv_dpll_core; + u32 cm_emu_override_dpll_core; + u32 pad004[3]; + u32 cm_clkmode_dpll_mpu; + u32 cm_idlest_dpll_mpu; + u32 cm_autoidle_dpll_mpu; + u32 cm_clksel_dpll_mpu; + u32 cm_div_m2_dpll_mpu; + u32 pad005[5]; + u32 cm_ssc_deltamstep_dpll_mpu; + u32 cm_ssc_modfreqdiv_dpll_mpu; + u32 pad006[3]; + u32 cm_bypclk_dpll_mpu; + u32 cm_clkmode_dpll_iva; + u32 cm_idlest_dpll_iva; + u32 cm_autoidle_dpll_iva; + u32 cm_clksel_dpll_iva; + u32 pad007[2]; + u32 cm_div_m4_dpll_iva; + u32 cm_div_m5_dpll_iva; + u32 pad008[2]; + u32 cm_ssc_deltamstep_dpll_iva; + u32 cm_ssc_modfreqdiv_dpll_iva; + u32 pad009[3]; + u32 cm_bypclk_dpll_iva; + u32 cm_clkmode_dpll_abe; + u32 cm_idlest_dpll_abe; + u32 cm_autoidle_dpll_abe; + u32 cm_clksel_dpll_abe; + u32 cm_div_m2_dpll_abe; + u32 cm_div_m3_dpll_abe; + u32 pad010[4]; + u32 cm_ssc_deltamstep_dpll_abe; + u32 cm_ssc_modfreqdiv_dpll_abe; + u32 pad011[4]; + u32 cm_clkmode_dpll_ddrphy; + u32 cm_idlest_dpll_ddrphy; + u32 cm_autoidle_dpll_ddrphy; + u32 cm_clksel_dpll_ddrphy; + u32 cm_div_m2_dpll_ddrphy; + u32 pad012[1]; + u32 cm_div_m4_dpll_ddrphy; + u32 cm_div_m5_dpll_ddrphy; + u32 cm_div_m6_dpll_ddrphy; + u32 pad013[1]; + u32 cm_ssc_deltamstep_dpll_ddrphy; + u32 pad014[5]; + u32 cm_shadow_freq_config1; + + /* cm1.dsp */ + u32 pad015[103]; + u32 cm_dsp_clkstctrl; + u32 pad016[7]; + u32 cm_dsp_dsp_clkctrl; + + /* cm1.abe */ + u32 pad017[55]; + u32 cm1_abe_clkstctrl; + u32 pad018[7]; + u32 cm1_abe_l4abe_clkctrl; + u32 pad019[1]; + u32 cm1_abe_aess_clkctrl; + u32 pad020[1]; + u32 cm1_abe_pdm_clkctrl; + u32 pad021[1]; + u32 cm1_abe_dmic_clkctrl; + u32 pad022[1]; + u32 cm1_abe_mcasp_clkctrl; + u32 pad023[1]; + u32 cm1_abe_mcbsp1_clkctrl; + u32 pad024[1]; + u32 cm1_abe_mcbsp2_clkctrl; + u32 pad025[1]; + u32 cm1_abe_mcbsp3_clkctrl; + u32 pad026[1]; + u32 cm1_abe_slimbus_clkctrl; + u32 pad027[1]; + u32 cm1_abe_timer5_clkctrl; + u32 pad028[1]; + u32 cm1_abe_timer6_clkctrl; + u32 pad029[1]; + u32 cm1_abe_timer7_clkctrl; + u32 pad030[1]; + u32 cm1_abe_timer8_clkctrl; + u32 pad031[1]; + u32 cm1_abe_wdt3_clkctrl; + + /* cm2.ckgen */ + u32 pad032[3805]; + u32 cm_clksel_mpu_m3_iss_root; + u32 cm_clksel_usb_60mhz; + u32 cm_scale_fclk; + u32 pad033[1]; + u32 cm_core_dvfs_perf1; + u32 cm_core_dvfs_perf2; + u32 cm_core_dvfs_perf3; + u32 cm_core_dvfs_perf4; + u32 pad034[1]; + u32 cm_core_dvfs_current; + u32 cm_iva_dvfs_perf_tesla; + u32 cm_iva_dvfs_perf_ivahd; + u32 cm_iva_dvfs_perf_abe; + u32 pad035[1]; + u32 cm_iva_dvfs_current; + u32 pad036[1]; + u32 cm_clkmode_dpll_per; + u32 cm_idlest_dpll_per; + u32 cm_autoidle_dpll_per; + u32 cm_clksel_dpll_per; + u32 cm_div_m2_dpll_per; + u32 cm_div_m3_dpll_per; + u32 cm_div_m4_dpll_per; + u32 cm_div_m5_dpll_per; + u32 cm_div_m6_dpll_per; + u32 cm_div_m7_dpll_per; + u32 cm_ssc_deltamstep_dpll_per; + u32 cm_ssc_modfreqdiv_dpll_per; + u32 cm_emu_override_dpll_per; + u32 pad037[3]; + u32 cm_clkmode_dpll_usb; + u32 cm_idlest_dpll_usb; + u32 cm_autoidle_dpll_usb; + u32 cm_clksel_dpll_usb; + u32 cm_div_m2_dpll_usb; + u32 pad038[5]; + u32 cm_ssc_deltamstep_dpll_usb; + u32 cm_ssc_modfreqdiv_dpll_usb; + u32 pad039[1]; + u32 cm_clkdcoldo_dpll_usb; + u32 pad040[2]; + u32 cm_clkmode_dpll_unipro; + u32 cm_idlest_dpll_unipro; + u32 cm_autoidle_dpll_unipro; + u32 cm_clksel_dpll_unipro; + u32 cm_div_m2_dpll_unipro; + u32 pad041[5]; + u32 cm_ssc_deltamstep_dpll_unipro; + u32 cm_ssc_modfreqdiv_dpll_unipro; + + /* cm2.core */ + u32 pad0411[324]; + u32 cm_l3_1_clkstctrl; + u32 pad042[1]; + u32 cm_l3_1_dynamicdep; + u32 pad043[5]; + u32 cm_l3_1_l3_1_clkctrl; + u32 pad044[55]; + u32 cm_l3_2_clkstctrl; + u32 pad045[1]; + u32 cm_l3_2_dynamicdep; + u32 pad046[5]; + u32 cm_l3_2_l3_2_clkctrl; + u32 pad047[1]; + u32 cm_l3_2_gpmc_clkctrl; + u32 pad048[1]; + u32 cm_l3_2_ocmc_ram_clkctrl; + u32 pad049[51]; + u32 cm_mpu_m3_clkstctrl; + u32 cm_mpu_m3_staticdep; + u32 cm_mpu_m3_dynamicdep; + u32 pad050[5]; + u32 cm_mpu_m3_mpu_m3_clkctrl; + u32 pad051[55]; + u32 cm_sdma_clkstctrl; + u32 cm_sdma_staticdep; + u32 cm_sdma_dynamicdep; + u32 pad052[5]; + u32 cm_sdma_sdma_clkctrl; + u32 pad053[55]; + u32 cm_memif_clkstctrl; + u32 pad054[7]; + u32 cm_memif_dmm_clkctrl; + u32 pad055[1]; + u32 cm_memif_emif_fw_clkctrl; + u32 pad056[1]; + u32 cm_memif_emif_1_clkctrl; + u32 pad057[1]; + u32 cm_memif_emif_2_clkctrl; + u32 pad058[1]; + u32 cm_memif_dll_clkctrl; + u32 pad059[3]; + u32 cm_memif_emif_h1_clkctrl; + u32 pad060[1]; + u32 cm_memif_emif_h2_clkctrl; + u32 pad061[1]; + u32 cm_memif_dll_h_clkctrl; + u32 pad062[39]; + u32 cm_c2c_clkstctrl; + u32 cm_c2c_staticdep; + u32 cm_c2c_dynamicdep; + u32 pad063[5]; + u32 cm_c2c_sad2d_clkctrl; + u32 pad064[1]; + u32 cm_c2c_modem_icr_clkctrl; + u32 pad065[1]; + u32 cm_c2c_sad2d_fw_clkctrl; + u32 pad066[51]; + u32 cm_l4cfg_clkstctrl; + u32 pad067[1]; + u32 cm_l4cfg_dynamicdep; + u32 pad068[5]; + u32 cm_l4cfg_l4_cfg_clkctrl; + u32 pad069[1]; + u32 cm_l4cfg_hw_sem_clkctrl; + u32 pad070[1]; + u32 cm_l4cfg_mailbox_clkctrl; + u32 pad071[1]; + u32 cm_l4cfg_sar_rom_clkctrl; + u32 pad072[49]; + u32 cm_l3instr_clkstctrl; + u32 pad073[7]; + u32 cm_l3instr_l3_3_clkctrl; + u32 pad074[1]; + u32 cm_l3instr_l3_instr_clkctrl; + u32 pad075[5]; + u32 cm_l3instr_intrconn_wp1_clkctrl; + + + /* cm2.ivahd */ + u32 pad076[47]; + u32 cm_ivahd_clkstctrl; + u32 pad077[7]; + u32 cm_ivahd_ivahd_clkctrl; + u32 pad078[1]; + u32 cm_ivahd_sl2_clkctrl; + + /* cm2.cam */ + u32 pad079[53]; + u32 cm_cam_clkstctrl; + u32 pad080[7]; + u32 cm_cam_iss_clkctrl; + u32 pad081[1]; + u32 cm_cam_fdif_clkctrl; + + /* cm2.dss */ + u32 pad082[53]; + u32 cm_dss_clkstctrl; + u32 pad083[7]; + u32 cm_dss_dss_clkctrl; + + /* cm2.sgx */ + u32 pad084[55]; + u32 cm_sgx_clkstctrl; + u32 pad085[7]; + u32 cm_sgx_sgx_clkctrl; + + /* cm2.l3init */ + u32 pad086[55]; + u32 cm_l3init_clkstctrl; + + /* cm2.l3init */ + u32 pad087[9]; + u32 cm_l3init_hsmmc1_clkctrl; + u32 pad088[1]; + u32 cm_l3init_hsmmc2_clkctrl; + u32 pad089[1]; + u32 cm_l3init_hsi_clkctrl; + u32 pad090[7]; + u32 cm_l3init_hsusbhost_clkctrl; + u32 pad091[1]; + u32 cm_l3init_hsusbotg_clkctrl; + u32 pad092[1]; + u32 cm_l3init_hsusbtll_clkctrl; + u32 pad093[3]; + u32 cm_l3init_p1500_clkctrl; + u32 pad094[21]; + u32 cm_l3init_fsusb_clkctrl; + u32 pad095[3]; + u32 cm_l3init_usbphy_clkctrl; + + /* cm2.l4per */ + u32 pad096[7]; + u32 cm_l4per_clkstctrl; + u32 pad097[1]; + u32 cm_l4per_dynamicdep; + u32 pad098[5]; + u32 cm_l4per_adc_clkctrl; + u32 pad100[1]; + u32 cm_l4per_gptimer10_clkctrl; + u32 pad101[1]; + u32 cm_l4per_gptimer11_clkctrl; + u32 pad102[1]; + u32 cm_l4per_gptimer2_clkctrl; + u32 pad103[1]; + u32 cm_l4per_gptimer3_clkctrl; + u32 pad104[1]; + u32 cm_l4per_gptimer4_clkctrl; + u32 pad105[1]; + u32 cm_l4per_gptimer9_clkctrl; + u32 pad106[1]; + u32 cm_l4per_elm_clkctrl; + u32 pad107[1]; + u32 cm_l4per_gpio2_clkctrl; + u32 pad108[1]; + u32 cm_l4per_gpio3_clkctrl; + u32 pad109[1]; + u32 cm_l4per_gpio4_clkctrl; + u32 pad110[1]; + u32 cm_l4per_gpio5_clkctrl; + u32 pad111[1]; + u32 cm_l4per_gpio6_clkctrl; + u32 pad112[1]; + u32 cm_l4per_hdq1w_clkctrl; + u32 pad113[1]; + u32 cm_l4per_hecc1_clkctrl; + u32 pad114[1]; + u32 cm_l4per_hecc2_clkctrl; + u32 pad115[1]; + u32 cm_l4per_i2c1_clkctrl; + u32 pad116[1]; + u32 cm_l4per_i2c2_clkctrl; + u32 pad117[1]; + u32 cm_l4per_i2c3_clkctrl; + u32 pad118[1]; + u32 cm_l4per_i2c4_clkctrl; + u32 pad119[1]; + u32 cm_l4per_l4per_clkctrl; + u32 pad1191[3]; + u32 cm_l4per_mcasp2_clkctrl; + u32 pad120[1]; + u32 cm_l4per_mcasp3_clkctrl; + u32 pad121[1]; + u32 cm_l4per_mcbsp4_clkctrl; + u32 pad122[1]; + u32 cm_l4per_mgate_clkctrl; + u32 pad123[1]; + u32 cm_l4per_mcspi1_clkctrl; + u32 pad124[1]; + u32 cm_l4per_mcspi2_clkctrl; + u32 pad125[1]; + u32 cm_l4per_mcspi3_clkctrl; + u32 pad126[1]; + u32 cm_l4per_mcspi4_clkctrl; + u32 pad127[5]; + u32 cm_l4per_mmcsd3_clkctrl; + u32 pad128[1]; + u32 cm_l4per_mmcsd4_clkctrl; + u32 pad129[1]; + u32 cm_l4per_msprohg_clkctrl; + u32 pad130[1]; + u32 cm_l4per_slimbus2_clkctrl; + u32 pad131[1]; + u32 cm_l4per_uart1_clkctrl; + u32 pad132[1]; + u32 cm_l4per_uart2_clkctrl; + u32 pad133[1]; + u32 cm_l4per_uart3_clkctrl; + u32 pad134[1]; + u32 cm_l4per_uart4_clkctrl; + u32 pad135[1]; + u32 cm_l4per_mmcsd5_clkctrl; + u32 pad136[1]; + u32 cm_l4per_i2c5_clkctrl; + u32 pad137[5]; + u32 cm_l4sec_clkstctrl; + u32 cm_l4sec_staticdep; + u32 cm_l4sec_dynamicdep; + u32 pad138[5]; + u32 cm_l4sec_aes1_clkctrl; + u32 pad139[1]; + u32 cm_l4sec_aes2_clkctrl; + u32 pad140[1]; + u32 cm_l4sec_des3des_clkctrl; + u32 pad141[1]; + u32 cm_l4sec_pkaeip29_clkctrl; + u32 pad142[1]; + u32 cm_l4sec_rng_clkctrl; + u32 pad143[1]; + u32 cm_l4sec_sha2md51_clkctrl; + u32 pad144[3]; + u32 cm_l4sec_cryptodma_clkctrl; + u32 pad145[776841]; + + /* l4 wkup regs */ + u32 pad201[6211]; + u32 cm_abe_pll_ref_clksel; + u32 cm_sys_clksel; + u32 pad202[1467]; + u32 cm_wkup_clkstctrl; + u32 pad203[7]; + u32 cm_wkup_l4wkup_clkctrl; + u32 pad204; + u32 cm_wkup_wdtimer1_clkctrl; + u32 pad205; + u32 cm_wkup_wdtimer2_clkctrl; + u32 pad206; + u32 cm_wkup_gpio1_clkctrl; + u32 pad207; + u32 cm_wkup_gptimer1_clkctrl; + u32 pad208; + u32 cm_wkup_gptimer12_clkctrl; + u32 pad209; + u32 cm_wkup_synctimer_clkctrl; + u32 pad210; + u32 cm_wkup_usim_clkctrl; + u32 pad211; + u32 cm_wkup_sarram_clkctrl; + u32 pad212[5]; + u32 cm_wkup_keyboard_clkctrl; + u32 pad213; + u32 cm_wkup_rtc_clkctrl; + u32 pad214; + u32 cm_wkup_bandgap_clkctrl; + u32 pad215[197]; + u32 prm_vc_val_bypass; + u32 prm_vc_cfg_channel; + u32 prm_vc_cfg_i2c_mode; + u32 prm_vc_cfg_i2c_clk; + +}; + +/* DPLL register offsets */ +#define CM_CLKMODE_DPLL 0 +#define CM_IDLEST_DPLL 0x4 +#define CM_AUTOIDLE_DPLL 0x8 +#define CM_CLKSEL_DPLL 0xC +#define CM_DIV_M2_DPLL 0x10 +#define CM_DIV_M3_DPLL 0x14 +#define CM_DIV_M4_DPLL 0x18 +#define CM_DIV_M5_DPLL 0x1C +#define CM_DIV_M6_DPLL 0x20 +#define CM_DIV_M7_DPLL 0x24 + +#define DPLL_CLKOUT_DIV_MASK 0x1F /* post-divider mask */ + +/* CM_CLKMODE_DPLL */ +#define CM_CLKMODE_DPLL_REGM4XEN_SHIFT 11 +#define CM_CLKMODE_DPLL_REGM4XEN_MASK (1 << 11) +#define CM_CLKMODE_DPLL_LPMODE_EN_SHIFT 10 +#define CM_CLKMODE_DPLL_LPMODE_EN_MASK (1 << 10) +#define CM_CLKMODE_DPLL_RELOCK_RAMP_EN_SHIFT 9 +#define CM_CLKMODE_DPLL_RELOCK_RAMP_EN_MASK (1 << 9) +#define CM_CLKMODE_DPLL_DRIFTGUARD_EN_SHIFT 8 +#define CM_CLKMODE_DPLL_DRIFTGUARD_EN_MASK (1 << 8) +#define CM_CLKMODE_DPLL_RAMP_RATE_SHIFT 5 +#define CM_CLKMODE_DPLL_RAMP_RATE_MASK (0x7 << 5) +#define CM_CLKMODE_DPLL_EN_SHIFT 0 +#define CM_CLKMODE_DPLL_EN_MASK (0x7 << 0) + +#define CM_CLKMODE_DPLL_DPLL_EN_SHIFT 0 +#define CM_CLKMODE_DPLL_DPLL_EN_MASK 7 + +#define DPLL_EN_STOP 1 +#define DPLL_EN_MN_BYPASS 4 +#define DPLL_EN_LOW_POWER_BYPASS 5 +#define DPLL_EN_FAST_RELOCK_BYPASS 6 +#define DPLL_EN_LOCK 7 + +/* CM_IDLEST_DPLL fields */ +#define ST_DPLL_CLK_MASK 1 + +/* CM_CLKSEL_DPLL */ +#define CM_CLKSEL_DPLL_DPLL_SD_DIV_SHIFT 24 +#define CM_CLKSEL_DPLL_DPLL_SD_DIV_MASK (0xFF << 24) +#define CM_CLKSEL_DPLL_M_SHIFT 8 +#define CM_CLKSEL_DPLL_M_MASK (0x7FF << 8) +#define CM_CLKSEL_DPLL_N_SHIFT 0 +#define CM_CLKSEL_DPLL_N_MASK 0x7F + +#define OMAP4_DPLL_MAX_N 127 + +/* CM_SYS_CLKSEL */ +#define CM_SYS_CLKSEL_SYS_CLKSEL_MASK 7 + +/* CM_CLKSEL_CORE */ +#define CLKSEL_CORE_SHIFT 0 +#define CLKSEL_L3_SHIFT 4 +#define CLKSEL_L4_SHIFT 8 + +#define CLKSEL_CORE_X2_DIV_1 0 +#define CLKSEL_L3_CORE_DIV_2 1 +#define CLKSEL_L4_L3_DIV_2 1 + +/* CM_ABE_PLL_REF_CLKSEL */ +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_SHIFT 0 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_MASK 1 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_SYSCLK 0 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_32KCLK 1 + +/* CM_BYPCLK_DPLL_IVA */ +#define CM_BYPCLK_DPLL_IVA_CLKSEL_SHIFT 0 +#define CM_BYPCLK_DPLL_IVA_CLKSEL_MASK 3 + +#define DPLL_IVA_CLKSEL_CORE_X2_DIV_2 1 + +/* CM_SHADOW_FREQ_CONFIG1 */ +#define SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK 1 +#define SHADOW_FREQ_CONFIG1_DLL_OVERRIDE_MASK 4 +#define SHADOW_FREQ_CONFIG1_DLL_RESET_MASK 8 + +#define SHADOW_FREQ_CONFIG1_DPLL_EN_SHIFT 8 +#define SHADOW_FREQ_CONFIG1_DPLL_EN_MASK (7 << 8) + +#define SHADOW_FREQ_CONFIG1_M2_DIV_SHIFT 11 +#define SHADOW_FREQ_CONFIG1_M2_DIV_MASK (0x1F << 11) + +/*CM_<clock_domain>__CLKCTRL */ +#define CD_CLKCTRL_CLKTRCTRL_SHIFT 0 +#define CD_CLKCTRL_CLKTRCTRL_MASK 3 + +#define CD_CLKCTRL_CLKTRCTRL_NO_SLEEP 0 +#define CD_CLKCTRL_CLKTRCTRL_SW_SLEEP 1 +#define CD_CLKCTRL_CLKTRCTRL_SW_WKUP 2 +#define CD_CLKCTRL_CLKTRCTRL_HW_AUTO 3 + + +/* CM_<clock_domain>_<module>_CLKCTRL */ +#define MODULE_CLKCTRL_MODULEMODE_SHIFT 0 +#define MODULE_CLKCTRL_MODULEMODE_MASK 3 +#define MODULE_CLKCTRL_IDLEST_SHIFT 16 +#define MODULE_CLKCTRL_IDLEST_MASK (3 << 16) + +#define MODULE_CLKCTRL_MODULEMODE_SW_DISABLE 0 +#define MODULE_CLKCTRL_MODULEMODE_HW_AUTO 1 +#define MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN 2 + +#define MODULE_CLKCTRL_IDLEST_FULLY_FUNCTIONAL 0 +#define MODULE_CLKCTRL_IDLEST_TRANSITIONING 1 +#define MODULE_CLKCTRL_IDLEST_IDLE 2 +#define MODULE_CLKCTRL_IDLEST_DISABLED 3 + +/* CM_L4PER_GPIO4_CLKCTRL */ +#define GPIO4_CLKCTRL_OPTFCLKEN_MASK (1 << 8) + +/* CM_L3INIT_HSMMCn_CLKCTRL */ +#define HSMMC_CLKCTRL_CLKSEL_MASK (1 << 24) + +/* CM_WKUP_GPTIMER1_CLKCTRL */ +#define GPTIMER1_CLKCTRL_CLKSEL_MASK (1 << 24) + +/* CM_CAM_ISS_CLKCTRL */ +#define ISS_CLKCTRL_OPTFCLKEN_MASK (1 << 8) + +/* CM_DSS_DSS_CLKCTRL */ +#define DSS_CLKCTRL_OPTFCLKEN_MASK 0xF00 + +/* CM_L3INIT_USBPHY_CLKCTRL */ +#define USBPHY_CLKCTRL_OPTFCLKEN_PHY_48M_MASK 8 + +/* Clock frequencies */ +#define OMAP_SYS_CLK_FREQ_38_4_MHZ 38400000 +#define OMAP_SYS_CLK_IND_38_4_MHZ 6 +#define OMAP_32K_CLK_FREQ 32768 + +/* PRM_VC_CFG_I2C_CLK */ +#define PRM_VC_CFG_I2C_CLK_SCLH_SHIFT 0 +#define PRM_VC_CFG_I2C_CLK_SCLH_MASK 0xFF +#define PRM_VC_CFG_I2C_CLK_SCLL_SHIFT 8 +#define PRM_VC_CFG_I2C_CLK_SCLL_MASK (0xFF << 8) + +/* PRM_VC_VAL_BYPASS */ +#define PRM_VC_I2C_CHANNEL_FREQ_KHZ 400 + +#define PRM_VC_VAL_BYPASS_VALID_BIT 0x1000000 +#define PRM_VC_VAL_BYPASS_SLAVEADDR_SHIFT 0 +#define PRM_VC_VAL_BYPASS_SLAVEADDR_MASK 0x7F +#define PRM_VC_VAL_BYPASS_REGADDR_SHIFT 8 +#define PRM_VC_VAL_BYPASS_REGADDR_MASK 0xFF +#define PRM_VC_VAL_BYPASS_DATA_SHIFT 16 +#define PRM_VC_VAL_BYPASS_DATA_MASK 0xFF + +#define SMPS_I2C_SLAVE_ADDR 0x12 +#define SMPS_REG_ADDR_VCORE1 0x55 +#define SMPS_REG_ADDR_VCORE2 0x5B +#define SMPS_REG_ADDR_VCORE3 0x61 + +#define PHOENIX_SMPS_BASE_VOLT_STD_MODE_UV 607700 +#define PHOENIX_SMPS_BASE_VOLT_STD_MODE_WITH_OFFSET_UV 709000 + +/* Defines for DPLL setup */ +#define DPLL_LOCKED_FREQ_TOLERANCE_0 0 +#define DPLL_LOCKED_FREQ_TOLERANCE_500_KHZ 500 +#define DPLL_LOCKED_FREQ_TOLERANCE_1_MHZ 1000 + +#define DPLL_NO_LOCK 0 +#define DPLL_LOCK 1 + +#define NUM_SYS_CLKS 7 + +struct dpll_regs { + u32 cm_clkmode_dpll; + u32 cm_idlest_dpll; + u32 cm_autoidle_dpll; + u32 cm_clksel_dpll; + u32 cm_div_m2_dpll; + u32 cm_div_m3_dpll; + u32 cm_div_m4_dpll; + u32 cm_div_m5_dpll; + u32 cm_div_m6_dpll; + u32 cm_div_m7_dpll; +}; + +/* DPLL parameter table */ +struct dpll_params { + u32 m; + u32 n; + u8 m2; + u8 m3; + u8 m4; + u8 m5; + u8 m6; + u8 m7; +}; + +#endif /* _CLOCKS_OMAP4_H_ */ diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index c10fa18..f871921 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -22,6 +22,7 @@ #define _SYS_PROTO_H_
#include <asm/arch/omap4.h> +#include <asm/arch/clocks.h> #include <asm/io.h> #include <asm/omap_common.h> #include <asm/arch/mux_omap4.h> @@ -31,6 +32,8 @@ struct omap_sysinfo { }; extern const struct omap_sysinfo sysinfo;
+extern struct omap4_prcm_regs *const prcm; + void gpmc_init(void); void watchdog_init(void); u32 get_device_type(void); @@ -41,6 +44,11 @@ u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); void set_pl310_ctrl_reg(u32 val); void omap_rev_string(char *omap4_rev_string); +void prcm_init(void); +void bypass_dpll(u32 *const base); +void freq_update_core(void); +u32 get_sys_clk_freq(void); +u32 omap4_ddr_clk(void);
static inline u32 running_from_sdram(void) { diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index d80f665..33caa4e 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -25,6 +25,9 @@ #ifndef _OMAP_COMMON_H_ #define _OMAP_COMMON_H_
+/* Max value for DPLL multiplier M */ +#define OMAP_DPLL_MAX_N 127 + /* HW Init Context */ #define OMAP_INIT_CONTEXT_SPL 0 #define OMAP_INIT_CONTEXT_UBOOT_FROM_NOR 1 diff --git a/tools/omap/clocks_get_m_n.c b/tools/omap/clocks_get_m_n.c new file mode 100644 index 0000000..cfc1760 --- /dev/null +++ b/tools/omap/clocks_get_m_n.c @@ -0,0 +1,197 @@ +/* + * Program for finding M & N values for DPLLs + * To be run on Host PC + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <stdlib.h> +#include <stdio.h> +typedef unsigned int u32; +#define MAX_N 127 + +/* + * get_m_n_optimized() - Finds optimal DPLL multiplier(M) and divider(N) + * values based on the reference frequency, required output frequency, + * maximum tolerance for output frequency etc. + * + * target_freq_khz - output frequency required in KHz + * ref_freq_khz - reference(input) frequency in KHz + * m - pointer to computed M value + * n - pointer to computed N value + * tolerance_khz - tolerance for the output frequency. When the algorithm + * succeeds in finding vialble M and N values the corresponding output + * frequency will be in the range: + * [target_freq_khz - tolerance_khz, target_freq_khz] + * + * Formula: + * Fdpll = (2 * M * Fref) / (N + 1) + * + * Considerations for lock-time: + * - Smaller the N, better lock-time, especially lock-time will be + * - For acceptable lock-times: + * Fref / (M + 1) >= 1 MHz + * + * Considerations for power: + * - The difference in power for different N values giving the same + * output is negligible. So, we optimize for lock-time + * + * Hard-constraints: + * - N can not be greater than 127(7 bit field for representing N) + * + * Usage: + * $ gcc clocks_get_m_n.c + * $ ./a.out + */ +int get_m_n_optimized(u32 target_freq_khz, u32 ref_freq_khz, u32 *m, u32 *n, + u32 tolerance_khz) +{ + u32 min_freq = target_freq_khz - tolerance_khz; + u32 max_freq = target_freq_khz; + u32 freq, freq_old; + *n = 1; + while (1) { + *m = min_freq / ref_freq_khz / 2 * (*n) ; + freq_old = 0; + while (1) { + freq = ref_freq_khz * 2 * (*m) / (*n); + if (abs(target_freq_khz - freq_old) <= + abs(target_freq_khz - freq)) { + freq = freq_old; + (*m)--; + break; + } + (*m)++; + freq_old = freq; + } + if (freq >= min_freq && freq <= max_freq) + break; + (*n)++; + if ((*n) > MAX_N + 1) { + printf("ref %d m %d n %d target %d : ", + ref_freq_khz, *m, *n, target_freq_khz); + printf("can not find m & n - please consider" + " increasing tolerance\n"); + return -1; + } + } + (*n)--; + printf("ref %d m %d n %d target %d locked %d\n", + ref_freq_khz, *m, *n, target_freq_khz, freq); + if ((ref_freq_khz / (*n + 1)) < 1000) { + printf("\tREFCLK - CLKINP/(N+1) is less than 1 MHz - less than" + " ideal, locking time will be high!\n"); + } + return 0; +} + +void main(void) +{ + u32 m, n; + printf("\nMPU - 2000000\n"); + get_m_n_optimized(2000000, 12000, &m, &n, 0); + get_m_n_optimized(2000000, 13000, &m, &n, 0); + get_m_n_optimized(2000000, 16800, &m, &n, 800); + get_m_n_optimized(2000000, 19200, &m, &n, 0); + get_m_n_optimized(2000000, 26000, &m, &n, 0); + get_m_n_optimized(2000000, 27000, &m, &n, 0); + get_m_n_optimized(2000000, 38400, &m, &n, 0); + + printf("\nMPU - 1200000\n"); + get_m_n_optimized(1200000, 12000, &m, &n, 0); + get_m_n_optimized(1200000, 13000, &m, &n, 0); + get_m_n_optimized(1200000, 16800, &m, &n, 800); + get_m_n_optimized(1200000, 19200, &m, &n, 0); + get_m_n_optimized(1200000, 26000, &m, &n, 0); + get_m_n_optimized(1200000, 27000, &m, &n, 0); + get_m_n_optimized(1200000, 38400, &m, &n, 0); + + printf("\nMPU - 1584000\n"); + get_m_n_optimized(1584000, 12000, &m, &n, 0); + get_m_n_optimized(1584000, 13000, &m, &n, 0); + get_m_n_optimized(1584000, 16800, &m, &n, 400); + get_m_n_optimized(1584000, 19200, &m, &n, 0); + get_m_n_optimized(1584000, 26000, &m, &n, 0); + get_m_n_optimized(1584000, 27000, &m, &n, 0); + get_m_n_optimized(1584000, 38400, &m, &n, 0); + + printf("\nCore 1600000\n"); + get_m_n_optimized(1600000, 12000, &m, &n, 0); + get_m_n_optimized(1600000, 13000, &m, &n, 0); + get_m_n_optimized(1600000, 16800, &m, &n, 200); + get_m_n_optimized(1600000, 19200, &m, &n, 0); + get_m_n_optimized(1600000, 26000, &m, &n, 0); + get_m_n_optimized(1600000, 27000, &m, &n, 0); + get_m_n_optimized(1600000, 38400, &m, &n, 0); + + printf("\nPER 1536000\n"); + get_m_n_optimized(1536000, 12000, &m, &n, 0); + get_m_n_optimized(1536000, 13000, &m, &n, 0); + get_m_n_optimized(1536000, 16800, &m, &n, 0); + get_m_n_optimized(1536000, 19200, &m, &n, 0); + get_m_n_optimized(1536000, 26000, &m, &n, 0); + get_m_n_optimized(1536000, 27000, &m, &n, 0); + get_m_n_optimized(1536000, 38400, &m, &n, 0); + + printf("\nIVA 1862000\n"); + get_m_n_optimized(1862000, 12000, &m, &n, 0); + get_m_n_optimized(1862000, 13000, &m, &n, 0); + get_m_n_optimized(1862000, 16800, &m, &n, 0); + get_m_n_optimized(1862000, 19200, &m, &n, 900); + get_m_n_optimized(1862000, 26000, &m, &n, 0); + get_m_n_optimized(1862000, 27000, &m, &n, 0); + get_m_n_optimized(1862000, 38400, &m, &n, 800); + + printf("\nABE 196608 sys clk\n"); + get_m_n_optimized(196608, 12000, &m, &n, 700); + get_m_n_optimized(196608, 13000, &m, &n, 200); + get_m_n_optimized(196608, 16800, &m, &n, 700); + get_m_n_optimized(196608, 19200, &m, &n, 400); + get_m_n_optimized(196608, 26000, &m, &n, 200); + get_m_n_optimized(196608, 27000, &m, &n, 900); + get_m_n_optimized(196608, 38400, &m, &n, 0); + + printf("\nABE 196608 32K\n"); + get_m_n_optimized(196608000/4, 32768, &m, &n, 0); + + printf("\nUSB 1920000\n"); + get_m_n_optimized(1920000, 12000, &m, &n, 0); + get_m_n_optimized(1920000, 13000, &m, &n, 0); + get_m_n_optimized(1920000, 16800, &m, &n, 0); + get_m_n_optimized(1920000, 19200, &m, &n, 0); + get_m_n_optimized(1920000, 26000, &m, &n, 0); + get_m_n_optimized(1920000, 27000, &m, &n, 0); + get_m_n_optimized(1920000, 38400, &m, &n, 0); + + printf("\nCore ES1 1523712\n"); + get_m_n_optimized(1524000, 12000, &m, &n, 100); + get_m_n_optimized(1524000, 13000, &m, &n, 0); + get_m_n_optimized(1524000, 16800, &m, &n, 0); + get_m_n_optimized(1524000, 19200, &m, &n, 0); + get_m_n_optimized(1524000, 26000, &m, &n, 0); + get_m_n_optimized(1524000, 27000, &m, &n, 0); + + /* exact recommendation for SDPs */ + get_m_n_optimized(1523712, 38400, &m, &n, 0); + +}
Add support for the SDRAM controller (EMIF).
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Minor corrections in do_lpddr2_init() * Minor corrections to read_idle interval calculation * Sanity test of memory after doing the initialization * Fixed warnings reported with with latest GCC compilers V3: * Removed references to modify_reg_32() * Updated references to OMAP_INIT_CONTEXT_* flags * Replaced calls to omap4_revision() with omap_revision() * Replaced sanity test with get_ram_size() --- arch/arm/cpu/armv7/omap4/Makefile | 2 + arch/arm/cpu/armv7/omap4/board.c | 6 +- arch/arm/cpu/armv7/omap4/emif.c | 328 +++++++++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 131 ++++ arch/arm/include/asm/arch-omap4/clocks.h | 8 +- arch/arm/include/asm/arch-omap4/emif.h | 1025 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 5 + arch/arm/include/asm/arch-omap4/sys_proto.h | 2 + 8 files changed, 1500 insertions(+), 7 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/emif.c create mode 100644 arch/arm/cpu/armv7/omap4/sdram_elpida.c create mode 100644 arch/arm/include/asm/arch-omap4/emif.h
diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index ac4b2a6..e1ccd68 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -29,7 +29,9 @@ SOBJS += lowlevel_init.o
COBJS += board.o COBJS += clocks.o +COBJS += emif.o COBJS += mem.o +COBJS += sdram_elpida.o COBJS += sys_info.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 1c26a66..ca107f7 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -189,7 +189,7 @@ void watchdog_init(void) * This is needed because the size of memory installed may be * different on different versions of the board */ -u32 sdram_size(void) +u32 omap4_sdram_size(void) { u32 section, i, total_size = 0, size, addr; for (i = 0; i < 4; i++) { @@ -215,8 +215,8 @@ u32 sdram_size(void) */ int dram_init(void) { - - gd->ram_size = sdram_size(); + sdram_init(); + gd->ram_size = omap4_sdram_size();
return 0; } diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c new file mode 100644 index 0000000..b25c1ee --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -0,0 +1,328 @@ +/* + * EMIF programming + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/emif.h> +#include <asm/arch/clocks.h> +#include <asm/arch/sys_proto.h> +#include <asm/omap_common.h> +#include <asm/utils.h> + +static inline u32 emif_num(u32 base) +{ + if (base == OMAP44XX_EMIF1) + return 1; + else if (base == OMAP44XX_EMIF2) + return 2; + else + return 0; +} + +static inline u32 get_mr(u32 base, u32 cs, u32 mr_addr) +{ + u32 mr; + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + mr_addr |= cs << OMAP44XX_REG_CS_SHIFT; + writel(mr_addr, &emif->emif_lpddr2_mode_reg_cfg); + if (omap_revision() == OMAP4430_ES2_0) + mr = readl(&emif->emif_lpddr2_mode_reg_data_es2); + else + mr = readl(&emif->emif_lpddr2_mode_reg_data); + debug("get_mr: EMIF%d cs %d mr %08x val 0x%x\n", emif_num(base), + cs, mr_addr, mr); + return mr; +} + +static inline void set_mr(u32 base, u32 cs, u32 mr_addr, u32 mr_val) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + mr_addr |= cs << OMAP44XX_REG_CS_SHIFT; + writel(mr_addr, &emif->emif_lpddr2_mode_reg_cfg); + writel(mr_val, &emif->emif_lpddr2_mode_reg_data); +} + +void emif_reset_phy(u32 base) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + u32 iodft; + + iodft = readl(&emif->emif_iodft_tlgc); + iodft |= OMAP44XX_REG_RESET_PHY_MASK; + writel(iodft, &emif->emif_iodft_tlgc); +} + +static void do_lpddr2_init(u32 base, u32 cs) +{ + u32 mr_addr; + + /* Wait till device auto initialization is complete */ + while (get_mr(base, cs, LPDDR2_MR0) & LPDDR2_MR0_DAI_MASK) + ; + set_mr(base, cs, LPDDR2_MR10, MR10_ZQ_ZQINIT); + /* + * tZQINIT = 1 us + * Enough loops assuming a maximum of 2GHz + */ + sdelay(2000); + set_mr(base, cs, LPDDR2_MR1, MR1_BL_8_BT_SEQ_WRAP_EN_NWR_3); + set_mr(base, cs, LPDDR2_MR16, MR16_REF_FULL_ARRAY); + /* + * Enable refresh along with writing MR2 + * Encoding of RL in MR2 is (RL - 2) + */ + mr_addr = LPDDR2_MR2 | OMAP44XX_REG_REFRESH_EN_MASK; + set_mr(base, cs, mr_addr, RL_FINAL - 2); +} + +static void lpddr2_init(u32 base, const struct emif_regs *regs) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + /* Not NVM */ + clrbits_le32(&emif->emif_lpddr2_nvm_config, OMAP44XX_REG_CS1NVMEN_MASK); + + /* + * Keep REG_INITREF_DIS = 1 to prevent re-initialization of SDRAM + * when EMIF_SDRAM_CONFIG register is written + */ + setbits_le32(&emif->emif_sdram_ref_ctrl, OMAP44XX_REG_INITREF_DIS_MASK); + + /* + * Set the SDRAM_CONFIG and PHY_CTRL for the + * un-locked frequency & default RL + */ + writel(regs->sdram_config_init, &emif->emif_sdram_config); + writel(regs->emif_ddr_phy_ctlr_1_init, &emif->emif_ddr_phy_ctrl_1); + + do_lpddr2_init(base, CS0); + if (regs->sdram_config & OMAP44XX_REG_EBANK_MASK) + do_lpddr2_init(base, CS1); + + writel(regs->sdram_config, &emif->emif_sdram_config); + writel(regs->emif_ddr_phy_ctlr_1, &emif->emif_ddr_phy_ctrl_1); + + /* Enable refresh now */ + clrbits_le32(&emif->emif_sdram_ref_ctrl, OMAP44XX_REG_INITREF_DIS_MASK); + +} + +static void emif_update_timings(u32 base, const struct emif_regs *regs) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + writel(regs->ref_ctrl, &emif->emif_sdram_ref_ctrl_shdw); + writel(regs->sdram_tim1, &emif->emif_sdram_tim_1_shdw); + writel(regs->sdram_tim2, &emif->emif_sdram_tim_2_shdw); + writel(regs->sdram_tim3, &emif->emif_sdram_tim_3_shdw); + if (omap_revision() == OMAP4430_ES1_0) { + /* ES1 bug EMIF should be in force idle during freq_update */ + writel(0, &emif->emif_pwr_mgmt_ctrl); + } else { + writel(EMIF_PWR_MGMT_CTRL, &emif->emif_pwr_mgmt_ctrl); + writel(EMIF_PWR_MGMT_CTRL_SHDW, &emif->emif_pwr_mgmt_ctrl_shdw); + } + writel(regs->read_idle_ctrl, &emif->emif_read_idlectrl_shdw); + writel(regs->zq_config, &emif->emif_zq_config); + writel(regs->temp_alert_config, &emif->emif_temp_alert_config); + writel(regs->emif_ddr_phy_ctlr_1, &emif->emif_ddr_phy_ctrl_1_shdw); + /* + * Workaround: + * In a specific situation, the OCP interface between the DMM and + * EMIF may hang. + * 1. A TILER port is used to perform 2D burst writes of + * width 1 and height 8 + * 2. ELLAn port is used to perform reads + * 3. All accesses are routed to the same EMIF controller + * + * Work around to avoid this issue REG_SYS_THRESH_MAX value should + * be kept higher than default 0x7. As per recommondation 0x0A will + * be used for better performance with REG_LL_THRESH_MAX = 0x00 + */ + if (omap_revision() == OMAP4430_ES1_0) { + writel(EMIF_L3_CONFIG_VAL_SYS_THRESH_0A_LL_THRESH_00, + &emif->emif_l3_config); + } +} + +static void do_sdram_init(u32 base) +{ + const struct emif_regs *regs; + u32 in_sdram, emif_nr; + + debug(">>do_sdram_init() %x\n", base); + + in_sdram = running_from_sdram(); + emif_nr = (base == OMAP44XX_EMIF1) ? 1 : 2; + + emif_get_reg_dump(emif_nr, ®s); + if (!regs) { + debug("EMIF: reg dump not provided\n"); + return; + } + + /* + * Initializing the LPDDR2 device can not happen from SDRAM. + * Changing the timing registers in EMIF can happen(going from one + * OPP to another) + */ + if (!in_sdram) + lpddr2_init(base, regs); + + /* Write to the shadow registers */ + emif_update_timings(base, regs); + + debug("<<do_sdram_init() %x\n", base); +} + +void sdram_init_pads(void) +{ + u32 lpddr2io; + struct control_lpddr2io_regs *lpddr2io_regs = + (struct control_lpddr2io_regs *)LPDDR2_IO_REGS_BASE; + u32 omap4_rev = omap_revision(); + + if (omap4_rev == OMAP4430_ES1_0) + lpddr2io = CONTROL_LPDDR2IO_SLEW_125PS_DRV8_PULL_DOWN; + else if (omap4_rev == OMAP4430_ES2_0) + lpddr2io = CONTROL_LPDDR2IO_SLEW_325PS_DRV8_GATE_KEEPER; + else + return; /* Post ES2.1 reset values will work */ + + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io1_0); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io1_1); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io1_2); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io2_0); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io2_1); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io2_2); + + writel(CONTROL_EFUSE_2_NMOS_PMOS_PTV_CODE_1, CONTROL_EFUSE_2); +} + +static void emif_post_init_config(u32 base) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + u32 omap4_rev = omap_revision(); + + /* reset phy on ES2.0 */ + if (omap4_rev == OMAP4430_ES2_0) + emif_reset_phy(base); + + /* Put EMIF back in smart idle on ES1.0 */ + if (omap4_rev == OMAP4430_ES1_0) + writel(0x80000000, &emif->emif_pwr_mgmt_ctrl); +} + +static void dmm_init(u32 base) +{ + const struct dmm_lisa_map_regs *lisa_map_regs; + + emif_get_dmm_regs(&lisa_map_regs); + + struct dmm_lisa_map_regs *hw_lisa_map_regs = + (struct dmm_lisa_map_regs *)base; + + writel(0, &hw_lisa_map_regs->dmm_lisa_map_3); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_2); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_1); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_0); + + writel(lisa_map_regs->dmm_lisa_map_3, + &hw_lisa_map_regs->dmm_lisa_map_3); + writel(lisa_map_regs->dmm_lisa_map_2, + &hw_lisa_map_regs->dmm_lisa_map_2); + writel(lisa_map_regs->dmm_lisa_map_1, + &hw_lisa_map_regs->dmm_lisa_map_1); + writel(lisa_map_regs->dmm_lisa_map_0, + &hw_lisa_map_regs->dmm_lisa_map_0); +} + +/* + * SDRAM initialization: + * SDRAM initialization has two parts: + * 1. Configuring the SDRAM device + * 2. Update the AC timings related parameters in the EMIF module + * (1) should be done only once and should not be done while we are + * running from SDRAM. + * (2) can and should be done more than once if OPP changes. + * Particularly, this may be needed when we boot without SPL and + * and using Configuration Header(CH). ROM code supports only at 50% OPP + * at boot (low power boot). So u-boot has to switch to OPP100 and update + * the frequency. So, + * Doing (1) and (2) makes sense - first time initialization + * Doing (2) and not (1) makes sense - OPP change (when using CH) + * Doing (1) and not (2) doen't make sense + * See do_sdram_init() for the details + */ +void sdram_init(void) +{ + u32 in_sdram, size_prog, size_detect; + + debug(">>sdram_init()\n"); + + if (omap4_hw_init_context() == OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL) + return; + + in_sdram = running_from_sdram(); + debug("in_sdram = %d\n", in_sdram); + + if (!in_sdram) { + sdram_init_pads(); + bypass_dpll(&prcm->cm_clkmode_dpll_core); + } + + do_sdram_init(OMAP44XX_EMIF1); + do_sdram_init(OMAP44XX_EMIF2); + + if (!in_sdram) { + dmm_init(OMAP44XX_DMM_LISA_MAP_BASE); + emif_post_init_config(OMAP44XX_EMIF1); + emif_post_init_config(OMAP44XX_EMIF2); + + } + + /* for the shadow registers to take effect */ + freq_update_core(); + + /* Do some testing after the init */ + if (!in_sdram) { + size_prog = omap4_sdram_size(); + size_detect = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, + size_prog); + /* Compare with the size programmed */ + if (size_detect != size_prog) { + printf("SDRAM: identified size not same as expected" + " size identified: %x expected: %x\n", + size_detect, + size_prog); + } else + debug("get_ram_size() successful"); + } + + debug("<<sdram_init()\n"); +} diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c new file mode 100644 index 0000000..c950c87 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -0,0 +1,131 @@ +/* + * Timing and Organization details of the Elpida parts used in OMAP4 + * SDPs and Panda + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/arch/emif.h> +#include <asm/arch/sys_proto.h> + +/* + * This file provides details of the LPDDR2 SDRAM parts used on OMAP4430 + * SDP and Panda. Since the parts used and geometry are identical for + * SDP and Panda for a given OMAP4 revision, this information is kept + * here instead of being in board directory. However the key functions + * exported are weakly linked so that they can be over-ridden in the board + * directory if there is a OMAP4 board in the future that uses a different + * memory device or geometry. + * + * For any new board with different memory devices over-ride one or more + * of the following functions as per the CONFIG flags you intend to enable: + * - emif_get_reg_dump() + * - emif_get_dmm_regs() + * - emif_get_device_details() + * - emif_get_device_timings() + */ + +static const struct emif_regs emif_regs_elpida_200_mhz_2cs = { + .sdram_config_init = 0x80000eb9, + .sdram_config = 0x80001ab9, + .ref_ctrl = 0x0000030c, + .sdram_tim1 = 0x08648311, + .sdram_tim2 = 0x101b06ca, + .sdram_tim3 = 0x0048a19f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0x500b3214, + .temp_alert_config = 0xd8016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff808 +}; + +static const struct emif_regs emif_regs_elpida_380_mhz_1cs = { + .sdram_config_init = 0x80000eb1, + .sdram_config = 0x80001ab1, + .ref_ctrl = 0x000005cd, + .sdram_tim1 = 0x10cb0622, + .sdram_tim2 = 0x20350d52, + .sdram_tim3 = 0x00b1431f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0x500b3214, + .temp_alert_config = 0x58016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff418 +}; + +const struct emif_regs emif_regs_elpida_400_mhz_2cs = { + .sdram_config_init = 0x80000eb9, + .sdram_config = 0x80001ab9, + .ref_ctrl = 0x00000618, + .sdram_tim1 = 0x10eb0662, + .sdram_tim2 = 0x20370dd2, + .sdram_tim3 = 0x00b1c33f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0xd00b3214, + .temp_alert_config = 0xd8016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff418 +}; +const struct dmm_lisa_map_regs lisa_map_2G_x_1_x_2 = { + .dmm_lisa_map_0 = 0xFF020100, + .dmm_lisa_map_1 = 0, + .dmm_lisa_map_2 = 0, + .dmm_lisa_map_3 = 0x80540300 +}; + +const struct dmm_lisa_map_regs lisa_map_2G_x_2_x_2 = { + .dmm_lisa_map_0 = 0xFF020100, + .dmm_lisa_map_1 = 0, + .dmm_lisa_map_2 = 0, + .dmm_lisa_map_3 = 0x80640300 +}; + +static void emif_get_reg_dump_sdp(u32 emif_nr, const struct emif_regs **regs) +{ + u32 omap4_rev = omap_revision(); + + /* Same devices and geometry on both EMIFs */ + if (omap4_rev == OMAP4430_ES1_0) + *regs = &emif_regs_elpida_380_mhz_1cs; + else if (omap4_rev == OMAP4430_ES2_0) + *regs = &emif_regs_elpida_200_mhz_2cs; + else + *regs = &emif_regs_elpida_400_mhz_2cs; +} +void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs) + __attribute__((weak, alias("emif_get_reg_dump_sdp"))); + +static void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs + **dmm_lisa_regs) +{ + u32 omap_rev = omap_revision(); + + if (omap_rev == OMAP4430_ES1_0) + *dmm_lisa_regs = &lisa_map_2G_x_1_x_2; + else + *dmm_lisa_regs = &lisa_map_2G_x_2_x_2; +} + +void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) + __attribute__((weak, alias("emif_get_dmm_regs_sdp"))); diff --git a/arch/arm/include/asm/arch-omap4/clocks.h b/arch/arm/include/asm/arch-omap4/clocks.h index 71db39c..37bdcee 100644 --- a/arch/arm/include/asm/arch-omap4/clocks.h +++ b/arch/arm/include/asm/arch-omap4/clocks.h @@ -33,10 +33,10 @@ */ #define LDELAY 1000000
-#define CM_CLKMODE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4120) -#define CM_CLKMODE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8140) -#define CM_CLKMODE_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4160) -#define CM_CLKSEL_CORE (OMAP44XX_L4_CORE_BASE + 0x4100) +#define CM_CLKMODE_DPLL_CORE 0x4A004120 +#define CM_CLKMODE_DPLL_PER 0x4A008140 +#define CM_CLKMODE_DPLL_MPU 0x4A004160 +#define CM_CLKSEL_CORE 0x4A004100
struct omap4_prcm_regs { /* cm1.ckgen */ diff --git a/arch/arm/include/asm/arch-omap4/emif.h b/arch/arm/include/asm/arch-omap4/emif.h new file mode 100644 index 0000000..09e9baa --- /dev/null +++ b/arch/arm/include/asm/arch-omap4/emif.h @@ -0,0 +1,1025 @@ +/* + * OMAP44xx EMIF header + * + * Copyright (C) 2009-2010 Texas Instruments, Inc. + * + * Aneesh V aneesh@ti.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#ifndef _EMIF_H_ +#define _EMIF_H_ +#include <asm/types.h> +#include <common.h> + +/* Base address */ +#define OMAP44XX_EMIF1 0x4c000000 +#define OMAP44XX_EMIF2 0x4d000000 + +/* Registers shifts and masks */ + +/* EMIF_MOD_ID_REV */ +#define OMAP44XX_REG_SCHEME_SHIFT 30 +#define OMAP44XX_REG_SCHEME_MASK (0x3 << 30) +#define OMAP44XX_REG_MODULE_ID_SHIFT 16 +#define OMAP44XX_REG_MODULE_ID_MASK (0xfff << 16) +#define OMAP44XX_REG_RTL_VERSION_SHIFT 11 +#define OMAP44XX_REG_RTL_VERSION_MASK (0x1f << 11) +#define OMAP44XX_REG_MAJOR_REVISION_SHIFT 8 +#define OMAP44XX_REG_MAJOR_REVISION_MASK (0x7 << 8) +#define OMAP44XX_REG_MINOR_REVISION_SHIFT 0 +#define OMAP44XX_REG_MINOR_REVISION_MASK (0x3f << 0) + +/* STATUS */ +#define OMAP44XX_REG_BE_SHIFT 31 +#define OMAP44XX_REG_BE_MASK (1 << 31) +#define OMAP44XX_REG_DUAL_CLK_MODE_SHIFT 30 +#define OMAP44XX_REG_DUAL_CLK_MODE_MASK (1 << 30) +#define OMAP44XX_REG_FAST_INIT_SHIFT 29 +#define OMAP44XX_REG_FAST_INIT_MASK (1 << 29) +#define OMAP44XX_REG_PHY_DLL_READY_SHIFT 2 +#define OMAP44XX_REG_PHY_DLL_READY_MASK (1 << 2) + +/* SDRAM_CONFIG */ +#define OMAP44XX_REG_SDRAM_TYPE_SHIFT 29 +#define OMAP44XX_REG_SDRAM_TYPE_MASK (0x7 << 29) +#define OMAP44XX_REG_IBANK_POS_SHIFT 27 +#define OMAP44XX_REG_IBANK_POS_MASK (0x3 << 27) +#define OMAP44XX_REG_DDR_TERM_SHIFT 24 +#define OMAP44XX_REG_DDR_TERM_MASK (0x7 << 24) +#define OMAP44XX_REG_DDR2_DDQS_SHIFT 23 +#define OMAP44XX_REG_DDR2_DDQS_MASK (1 << 23) +#define OMAP44XX_REG_DYN_ODT_SHIFT 21 +#define OMAP44XX_REG_DYN_ODT_MASK (0x3 << 21) +#define OMAP44XX_REG_DDR_DISABLE_DLL_SHIFT 20 +#define OMAP44XX_REG_DDR_DISABLE_DLL_MASK (1 << 20) +#define OMAP44XX_REG_SDRAM_DRIVE_SHIFT 18 +#define OMAP44XX_REG_SDRAM_DRIVE_MASK (0x3 << 18) +#define OMAP44XX_REG_CWL_SHIFT 16 +#define OMAP44XX_REG_CWL_MASK (0x3 << 16) +#define OMAP44XX_REG_NARROW_MODE_SHIFT 14 +#define OMAP44XX_REG_NARROW_MODE_MASK (0x3 << 14) +#define OMAP44XX_REG_CL_SHIFT 10 +#define OMAP44XX_REG_CL_MASK (0xf << 10) +#define OMAP44XX_REG_ROWSIZE_SHIFT 7 +#define OMAP44XX_REG_ROWSIZE_MASK (0x7 << 7) +#define OMAP44XX_REG_IBANK_SHIFT 4 +#define OMAP44XX_REG_IBANK_MASK (0x7 << 4) +#define OMAP44XX_REG_EBANK_SHIFT 3 +#define OMAP44XX_REG_EBANK_MASK (1 << 3) +#define OMAP44XX_REG_PAGESIZE_SHIFT 0 +#define OMAP44XX_REG_PAGESIZE_MASK (0x7 << 0) + +/* SDRAM_CONFIG_2 */ +#define OMAP44XX_REG_CS1NVMEN_SHIFT 30 +#define OMAP44XX_REG_CS1NVMEN_MASK (1 << 30) +#define OMAP44XX_REG_EBANK_POS_SHIFT 27 +#define OMAP44XX_REG_EBANK_POS_MASK (1 << 27) +#define OMAP44XX_REG_RDBNUM_SHIFT 4 +#define OMAP44XX_REG_RDBNUM_MASK (0x3 << 4) +#define OMAP44XX_REG_RDBSIZE_SHIFT 0 +#define OMAP44XX_REG_RDBSIZE_MASK (0x7 << 0) + +/* SDRAM_REF_CTRL */ +#define OMAP44XX_REG_INITREF_DIS_SHIFT 31 +#define OMAP44XX_REG_INITREF_DIS_MASK (1 << 31) +#define OMAP44XX_REG_SRT_SHIFT 29 +#define OMAP44XX_REG_SRT_MASK (1 << 29) +#define OMAP44XX_REG_ASR_SHIFT 28 +#define OMAP44XX_REG_ASR_MASK (1 << 28) +#define OMAP44XX_REG_PASR_SHIFT 24 +#define OMAP44XX_REG_PASR_MASK (0x7 << 24) +#define OMAP44XX_REG_REFRESH_RATE_SHIFT 0 +#define OMAP44XX_REG_REFRESH_RATE_MASK (0xffff << 0) + +/* SDRAM_REF_CTRL_SHDW */ +#define OMAP44XX_REG_REFRESH_RATE_SHDW_SHIFT 0 +#define OMAP44XX_REG_REFRESH_RATE_SHDW_MASK (0xffff << 0) + +/* SDRAM_TIM_1 */ +#define OMAP44XX_REG_T_RP_SHIFT 25 +#define OMAP44XX_REG_T_RP_MASK (0xf << 25) +#define OMAP44XX_REG_T_RCD_SHIFT 21 +#define OMAP44XX_REG_T_RCD_MASK (0xf << 21) +#define OMAP44XX_REG_T_WR_SHIFT 17 +#define OMAP44XX_REG_T_WR_MASK (0xf << 17) +#define OMAP44XX_REG_T_RAS_SHIFT 12 +#define OMAP44XX_REG_T_RAS_MASK (0x1f << 12) +#define OMAP44XX_REG_T_RC_SHIFT 6 +#define OMAP44XX_REG_T_RC_MASK (0x3f << 6) +#define OMAP44XX_REG_T_RRD_SHIFT 3 +#define OMAP44XX_REG_T_RRD_MASK (0x7 << 3) +#define OMAP44XX_REG_T_WTR_SHIFT 0 +#define OMAP44XX_REG_T_WTR_MASK (0x7 << 0) + +/* SDRAM_TIM_1_SHDW */ +#define OMAP44XX_REG_T_RP_SHDW_SHIFT 25 +#define OMAP44XX_REG_T_RP_SHDW_MASK (0xf << 25) +#define OMAP44XX_REG_T_RCD_SHDW_SHIFT 21 +#define OMAP44XX_REG_T_RCD_SHDW_MASK (0xf << 21) +#define OMAP44XX_REG_T_WR_SHDW_SHIFT 17 +#define OMAP44XX_REG_T_WR_SHDW_MASK (0xf << 17) +#define OMAP44XX_REG_T_RAS_SHDW_SHIFT 12 +#define OMAP44XX_REG_T_RAS_SHDW_MASK (0x1f << 12) +#define OMAP44XX_REG_T_RC_SHDW_SHIFT 6 +#define OMAP44XX_REG_T_RC_SHDW_MASK (0x3f << 6) +#define OMAP44XX_REG_T_RRD_SHDW_SHIFT 3 +#define OMAP44XX_REG_T_RRD_SHDW_MASK (0x7 << 3) +#define OMAP44XX_REG_T_WTR_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_WTR_SHDW_MASK (0x7 << 0) + +/* SDRAM_TIM_2 */ +#define OMAP44XX_REG_T_XP_SHIFT 28 +#define OMAP44XX_REG_T_XP_MASK (0x7 << 28) +#define OMAP44XX_REG_T_ODT_SHIFT 25 +#define OMAP44XX_REG_T_ODT_MASK (0x7 << 25) +#define OMAP44XX_REG_T_XSNR_SHIFT 16 +#define OMAP44XX_REG_T_XSNR_MASK (0x1ff << 16) +#define OMAP44XX_REG_T_XSRD_SHIFT 6 +#define OMAP44XX_REG_T_XSRD_MASK (0x3ff << 6) +#define OMAP44XX_REG_T_RTP_SHIFT 3 +#define OMAP44XX_REG_T_RTP_MASK (0x7 << 3) +#define OMAP44XX_REG_T_CKE_SHIFT 0 +#define OMAP44XX_REG_T_CKE_MASK (0x7 << 0) + +/* SDRAM_TIM_2_SHDW */ +#define OMAP44XX_REG_T_XP_SHDW_SHIFT 28 +#define OMAP44XX_REG_T_XP_SHDW_MASK (0x7 << 28) +#define OMAP44XX_REG_T_ODT_SHDW_SHIFT 25 +#define OMAP44XX_REG_T_ODT_SHDW_MASK (0x7 << 25) +#define OMAP44XX_REG_T_XSNR_SHDW_SHIFT 16 +#define OMAP44XX_REG_T_XSNR_SHDW_MASK (0x1ff << 16) +#define OMAP44XX_REG_T_XSRD_SHDW_SHIFT 6 +#define OMAP44XX_REG_T_XSRD_SHDW_MASK (0x3ff << 6) +#define OMAP44XX_REG_T_RTP_SHDW_SHIFT 3 +#define OMAP44XX_REG_T_RTP_SHDW_MASK (0x7 << 3) +#define OMAP44XX_REG_T_CKE_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_CKE_SHDW_MASK (0x7 << 0) + +/* SDRAM_TIM_3 */ +#define OMAP44XX_REG_T_CKESR_SHIFT 21 +#define OMAP44XX_REG_T_CKESR_MASK (0x7 << 21) +#define OMAP44XX_REG_ZQ_ZQCS_SHIFT 15 +#define OMAP44XX_REG_ZQ_ZQCS_MASK (0x3f << 15) +#define OMAP44XX_REG_T_TDQSCKMAX_SHIFT 13 +#define OMAP44XX_REG_T_TDQSCKMAX_MASK (0x3 << 13) +#define OMAP44XX_REG_T_RFC_SHIFT 4 +#define OMAP44XX_REG_T_RFC_MASK (0x1ff << 4) +#define OMAP44XX_REG_T_RAS_MAX_SHIFT 0 +#define OMAP44XX_REG_T_RAS_MAX_MASK (0xf << 0) + +/* SDRAM_TIM_3_SHDW */ +#define OMAP44XX_REG_T_CKESR_SHDW_SHIFT 21 +#define OMAP44XX_REG_T_CKESR_SHDW_MASK (0x7 << 21) +#define OMAP44XX_REG_ZQ_ZQCS_SHDW_SHIFT 15 +#define OMAP44XX_REG_ZQ_ZQCS_SHDW_MASK (0x3f << 15) +#define OMAP44XX_REG_T_TDQSCKMAX_SHDW_SHIFT 13 +#define OMAP44XX_REG_T_TDQSCKMAX_SHDW_MASK (0x3 << 13) +#define OMAP44XX_REG_T_RFC_SHDW_SHIFT 4 +#define OMAP44XX_REG_T_RFC_SHDW_MASK (0x1ff << 4) +#define OMAP44XX_REG_T_RAS_MAX_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_RAS_MAX_SHDW_MASK (0xf << 0) + +/* LPDDR2_NVM_TIM */ +#define OMAP44XX_REG_NVM_T_XP_SHIFT 28 +#define OMAP44XX_REG_NVM_T_XP_MASK (0x7 << 28) +#define OMAP44XX_REG_NVM_T_WTR_SHIFT 24 +#define OMAP44XX_REG_NVM_T_WTR_MASK (0x7 << 24) +#define OMAP44XX_REG_NVM_T_RP_SHIFT 20 +#define OMAP44XX_REG_NVM_T_RP_MASK (0xf << 20) +#define OMAP44XX_REG_NVM_T_WRA_SHIFT 16 +#define OMAP44XX_REG_NVM_T_WRA_MASK (0xf << 16) +#define OMAP44XX_REG_NVM_T_RRD_SHIFT 8 +#define OMAP44XX_REG_NVM_T_RRD_MASK (0xff << 8) +#define OMAP44XX_REG_NVM_T_RCDMIN_SHIFT 0 +#define OMAP44XX_REG_NVM_T_RCDMIN_MASK (0xff << 0) + +/* LPDDR2_NVM_TIM_SHDW */ +#define OMAP44XX_REG_NVM_T_XP_SHDW_SHIFT 28 +#define OMAP44XX_REG_NVM_T_XP_SHDW_MASK (0x7 << 28) +#define OMAP44XX_REG_NVM_T_WTR_SHDW_SHIFT 24 +#define OMAP44XX_REG_NVM_T_WTR_SHDW_MASK (0x7 << 24) +#define OMAP44XX_REG_NVM_T_RP_SHDW_SHIFT 20 +#define OMAP44XX_REG_NVM_T_RP_SHDW_MASK (0xf << 20) +#define OMAP44XX_REG_NVM_T_WRA_SHDW_SHIFT 16 +#define OMAP44XX_REG_NVM_T_WRA_SHDW_MASK (0xf << 16) +#define OMAP44XX_REG_NVM_T_RRD_SHDW_SHIFT 8 +#define OMAP44XX_REG_NVM_T_RRD_SHDW_MASK (0xff << 8) +#define OMAP44XX_REG_NVM_T_RCDMIN_SHDW_SHIFT 0 +#define OMAP44XX_REG_NVM_T_RCDMIN_SHDW_MASK (0xff << 0) + +/* PWR_MGMT_CTRL */ +#define OMAP44XX_REG_IDLEMODE_SHIFT 30 +#define OMAP44XX_REG_IDLEMODE_MASK (0x3 << 30) +#define OMAP44XX_REG_PD_TIM_SHIFT 12 +#define OMAP44XX_REG_PD_TIM_MASK (0xf << 12) +#define OMAP44XX_REG_DPD_EN_SHIFT 11 +#define OMAP44XX_REG_DPD_EN_MASK (1 << 11) +#define OMAP44XX_REG_LP_MODE_SHIFT 8 +#define OMAP44XX_REG_LP_MODE_MASK (0x7 << 8) +#define OMAP44XX_REG_SR_TIM_SHIFT 4 +#define OMAP44XX_REG_SR_TIM_MASK (0xf << 4) +#define OMAP44XX_REG_CS_TIM_SHIFT 0 +#define OMAP44XX_REG_CS_TIM_MASK (0xf << 0) + +/* PWR_MGMT_CTRL_SHDW */ +#define OMAP44XX_REG_PD_TIM_SHDW_SHIFT 8 +#define OMAP44XX_REG_PD_TIM_SHDW_MASK (0xf << 8) +#define OMAP44XX_REG_SR_TIM_SHDW_SHIFT 4 +#define OMAP44XX_REG_SR_TIM_SHDW_MASK (0xf << 4) +#define OMAP44XX_REG_CS_TIM_SHDW_SHIFT 0 +#define OMAP44XX_REG_CS_TIM_SHDW_MASK (0xf << 0) + +/* LPDDR2_MODE_REG_DATA */ +#define OMAP44XX_REG_VALUE_0_SHIFT 0 +#define OMAP44XX_REG_VALUE_0_MASK (0x7f << 0) + +/* LPDDR2_MODE_REG_CFG */ +#define OMAP44XX_REG_CS_SHIFT 31 +#define OMAP44XX_REG_CS_MASK (1 << 31) +#define OMAP44XX_REG_REFRESH_EN_SHIFT 30 +#define OMAP44XX_REG_REFRESH_EN_MASK (1 << 30) +#define OMAP44XX_REG_ADDRESS_SHIFT 0 +#define OMAP44XX_REG_ADDRESS_MASK (0xff << 0) + +/* OCP_CONFIG */ +#define OMAP44XX_REG_SYS_THRESH_MAX_SHIFT 24 +#define OMAP44XX_REG_SYS_THRESH_MAX_MASK (0xf << 24) +#define OMAP44XX_REG_LL_THRESH_MAX_SHIFT 16 +#define OMAP44XX_REG_LL_THRESH_MAX_MASK (0xf << 16) +#define OMAP44XX_REG_PR_OLD_COUNT_SHIFT 0 +#define OMAP44XX_REG_PR_OLD_COUNT_MASK (0xff << 0) + +/* OCP_CFG_VAL_1 */ +#define OMAP44XX_REG_SYS_BUS_WIDTH_SHIFT 30 +#define OMAP44XX_REG_SYS_BUS_WIDTH_MASK (0x3 << 30) +#define OMAP44XX_REG_LL_BUS_WIDTH_SHIFT 28 +#define OMAP44XX_REG_LL_BUS_WIDTH_MASK (0x3 << 28) +#define OMAP44XX_REG_WR_FIFO_DEPTH_SHIFT 8 +#define OMAP44XX_REG_WR_FIFO_DEPTH_MASK (0xff << 8) +#define OMAP44XX_REG_CMD_FIFO_DEPTH_SHIFT 0 +#define OMAP44XX_REG_CMD_FIFO_DEPTH_MASK (0xff << 0) + +/* OCP_CFG_VAL_2 */ +#define OMAP44XX_REG_RREG_FIFO_DEPTH_SHIFT 16 +#define OMAP44XX_REG_RREG_FIFO_DEPTH_MASK (0xff << 16) +#define OMAP44XX_REG_RSD_FIFO_DEPTH_SHIFT 8 +#define OMAP44XX_REG_RSD_FIFO_DEPTH_MASK (0xff << 8) +#define OMAP44XX_REG_RCMD_FIFO_DEPTH_SHIFT 0 +#define OMAP44XX_REG_RCMD_FIFO_DEPTH_MASK (0xff << 0) + +/* IODFT_TLGC */ +#define OMAP44XX_REG_TLEC_SHIFT 16 +#define OMAP44XX_REG_TLEC_MASK (0xffff << 16) +#define OMAP44XX_REG_MT_SHIFT 14 +#define OMAP44XX_REG_MT_MASK (1 << 14) +#define OMAP44XX_REG_ACT_CAP_EN_SHIFT 13 +#define OMAP44XX_REG_ACT_CAP_EN_MASK (1 << 13) +#define OMAP44XX_REG_OPG_LD_SHIFT 12 +#define OMAP44XX_REG_OPG_LD_MASK (1 << 12) +#define OMAP44XX_REG_RESET_PHY_SHIFT 10 +#define OMAP44XX_REG_RESET_PHY_MASK (1 << 10) +#define OMAP44XX_REG_MMS_SHIFT 8 +#define OMAP44XX_REG_MMS_MASK (1 << 8) +#define OMAP44XX_REG_MC_SHIFT 4 +#define OMAP44XX_REG_MC_MASK (0x3 << 4) +#define OMAP44XX_REG_PC_SHIFT 1 +#define OMAP44XX_REG_PC_MASK (0x7 << 1) +#define OMAP44XX_REG_TM_SHIFT 0 +#define OMAP44XX_REG_TM_MASK (1 << 0) + +/* IODFT_CTRL_MISR_RSLT */ +#define OMAP44XX_REG_DQM_TLMR_SHIFT 16 +#define OMAP44XX_REG_DQM_TLMR_MASK (0x3ff << 16) +#define OMAP44XX_REG_CTL_TLMR_SHIFT 0 +#define OMAP44XX_REG_CTL_TLMR_MASK (0x7ff << 0) + +/* IODFT_ADDR_MISR_RSLT */ +#define OMAP44XX_REG_ADDR_TLMR_SHIFT 0 +#define OMAP44XX_REG_ADDR_TLMR_MASK (0x1fffff << 0) + +/* IODFT_DATA_MISR_RSLT_1 */ +#define OMAP44XX_REG_DATA_TLMR_31_0_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_31_0_MASK (0xffffffff << 0) + +/* IODFT_DATA_MISR_RSLT_2 */ +#define OMAP44XX_REG_DATA_TLMR_63_32_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_63_32_MASK (0xffffffff << 0) + +/* IODFT_DATA_MISR_RSLT_3 */ +#define OMAP44XX_REG_DATA_TLMR_66_64_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_66_64_MASK (0x7 << 0) + +/* PERF_CNT_1 */ +#define OMAP44XX_REG_COUNTER1_SHIFT 0 +#define OMAP44XX_REG_COUNTER1_MASK (0xffffffff << 0) + +/* PERF_CNT_2 */ +#define OMAP44XX_REG_COUNTER2_SHIFT 0 +#define OMAP44XX_REG_COUNTER2_MASK (0xffffffff << 0) + +/* PERF_CNT_CFG */ +#define OMAP44XX_REG_CNTR2_MCONNID_EN_SHIFT 31 +#define OMAP44XX_REG_CNTR2_MCONNID_EN_MASK (1 << 31) +#define OMAP44XX_REG_CNTR2_REGION_EN_SHIFT 30 +#define OMAP44XX_REG_CNTR2_REGION_EN_MASK (1 << 30) +#define OMAP44XX_REG_CNTR2_CFG_SHIFT 16 +#define OMAP44XX_REG_CNTR2_CFG_MASK (0xf << 16) +#define OMAP44XX_REG_CNTR1_MCONNID_EN_SHIFT 15 +#define OMAP44XX_REG_CNTR1_MCONNID_EN_MASK (1 << 15) +#define OMAP44XX_REG_CNTR1_REGION_EN_SHIFT 14 +#define OMAP44XX_REG_CNTR1_REGION_EN_MASK (1 << 14) +#define OMAP44XX_REG_CNTR1_CFG_SHIFT 0 +#define OMAP44XX_REG_CNTR1_CFG_MASK (0xf << 0) + +/* PERF_CNT_SEL */ +#define OMAP44XX_REG_MCONNID2_SHIFT 24 +#define OMAP44XX_REG_MCONNID2_MASK (0xff << 24) +#define OMAP44XX_REG_REGION_SEL2_SHIFT 16 +#define OMAP44XX_REG_REGION_SEL2_MASK (0x3 << 16) +#define OMAP44XX_REG_MCONNID1_SHIFT 8 +#define OMAP44XX_REG_MCONNID1_MASK (0xff << 8) +#define OMAP44XX_REG_REGION_SEL1_SHIFT 0 +#define OMAP44XX_REG_REGION_SEL1_MASK (0x3 << 0) + +/* PERF_CNT_TIM */ +#define OMAP44XX_REG_TOTAL_TIME_SHIFT 0 +#define OMAP44XX_REG_TOTAL_TIME_MASK (0xffffffff << 0) + +/* READ_IDLE_CTRL */ +#define OMAP44XX_REG_READ_IDLE_LEN_SHIFT 16 +#define OMAP44XX_REG_READ_IDLE_LEN_MASK (0xf << 16) +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHIFT 0 +#define OMAP44XX_REG_READ_IDLE_INTERVAL_MASK (0x1ff << 0) + +/* READ_IDLE_CTRL_SHDW */ +#define OMAP44XX_REG_READ_IDLE_LEN_SHDW_SHIFT 16 +#define OMAP44XX_REG_READ_IDLE_LEN_SHDW_MASK (0xf << 16) +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHDW_SHIFT 0 +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHDW_MASK (0x1ff << 0) + +/* IRQ_EOI */ +#define OMAP44XX_REG_EOI_SHIFT 0 +#define OMAP44XX_REG_EOI_MASK (1 << 0) + +/* IRQSTATUS_RAW_SYS */ +#define OMAP44XX_REG_DNV_SYS_SHIFT 2 +#define OMAP44XX_REG_DNV_SYS_MASK (1 << 2) +#define OMAP44XX_REG_TA_SYS_SHIFT 1 +#define OMAP44XX_REG_TA_SYS_MASK (1 << 1) +#define OMAP44XX_REG_ERR_SYS_SHIFT 0 +#define OMAP44XX_REG_ERR_SYS_MASK (1 << 0) + +/* IRQSTATUS_RAW_LL */ +#define OMAP44XX_REG_DNV_LL_SHIFT 2 +#define OMAP44XX_REG_DNV_LL_MASK (1 << 2) +#define OMAP44XX_REG_TA_LL_SHIFT 1 +#define OMAP44XX_REG_TA_LL_MASK (1 << 1) +#define OMAP44XX_REG_ERR_LL_SHIFT 0 +#define OMAP44XX_REG_ERR_LL_MASK (1 << 0) + +/* IRQSTATUS_SYS */ + +/* IRQSTATUS_LL */ + +/* IRQENABLE_SET_SYS */ +#define OMAP44XX_REG_EN_DNV_SYS_SHIFT 2 +#define OMAP44XX_REG_EN_DNV_SYS_MASK (1 << 2) +#define OMAP44XX_REG_EN_TA_SYS_SHIFT 1 +#define OMAP44XX_REG_EN_TA_SYS_MASK (1 << 1) +#define OMAP44XX_REG_EN_ERR_SYS_SHIFT 0 +#define OMAP44XX_REG_EN_ERR_SYS_MASK (1 << 0) + +/* IRQENABLE_SET_LL */ +#define OMAP44XX_REG_EN_DNV_LL_SHIFT 2 +#define OMAP44XX_REG_EN_DNV_LL_MASK (1 << 2) +#define OMAP44XX_REG_EN_TA_LL_SHIFT 1 +#define OMAP44XX_REG_EN_TA_LL_MASK (1 << 1) +#define OMAP44XX_REG_EN_ERR_LL_SHIFT 0 +#define OMAP44XX_REG_EN_ERR_LL_MASK (1 << 0) + +/* IRQENABLE_CLR_SYS */ + +/* IRQENABLE_CLR_LL */ + +/* ZQ_CONFIG */ +#define OMAP44XX_REG_ZQ_CS1EN_SHIFT 31 +#define OMAP44XX_REG_ZQ_CS1EN_MASK (1 << 31) +#define OMAP44XX_REG_ZQ_CS0EN_SHIFT 30 +#define OMAP44XX_REG_ZQ_CS0EN_MASK (1 << 30) +#define OMAP44XX_REG_ZQ_DUALCALEN_SHIFT 29 +#define OMAP44XX_REG_ZQ_DUALCALEN_MASK (1 << 29) +#define OMAP44XX_REG_ZQ_SFEXITEN_SHIFT 28 +#define OMAP44XX_REG_ZQ_SFEXITEN_MASK (1 << 28) +#define OMAP44XX_REG_ZQ_ZQINIT_MULT_SHIFT 18 +#define OMAP44XX_REG_ZQ_ZQINIT_MULT_MASK (0x3 << 18) +#define OMAP44XX_REG_ZQ_ZQCL_MULT_SHIFT 16 +#define OMAP44XX_REG_ZQ_ZQCL_MULT_MASK (0x3 << 16) +#define OMAP44XX_REG_ZQ_REFINTERVAL_SHIFT 0 +#define OMAP44XX_REG_ZQ_REFINTERVAL_MASK (0xffff << 0) + +/* TEMP_ALERT_CONFIG */ +#define OMAP44XX_REG_TA_CS1EN_SHIFT 31 +#define OMAP44XX_REG_TA_CS1EN_MASK (1 << 31) +#define OMAP44XX_REG_TA_CS0EN_SHIFT 30 +#define OMAP44XX_REG_TA_CS0EN_MASK (1 << 30) +#define OMAP44XX_REG_TA_SFEXITEN_SHIFT 28 +#define OMAP44XX_REG_TA_SFEXITEN_MASK (1 << 28) +#define OMAP44XX_REG_TA_DEVWDT_SHIFT 26 +#define OMAP44XX_REG_TA_DEVWDT_MASK (0x3 << 26) +#define OMAP44XX_REG_TA_DEVCNT_SHIFT 24 +#define OMAP44XX_REG_TA_DEVCNT_MASK (0x3 << 24) +#define OMAP44XX_REG_TA_REFINTERVAL_SHIFT 0 +#define OMAP44XX_REG_TA_REFINTERVAL_MASK (0x3fffff << 0) + +/* OCP_ERR_LOG */ +#define OMAP44XX_REG_MADDRSPACE_SHIFT 14 +#define OMAP44XX_REG_MADDRSPACE_MASK (0x3 << 14) +#define OMAP44XX_REG_MBURSTSEQ_SHIFT 11 +#define OMAP44XX_REG_MBURSTSEQ_MASK (0x7 << 11) +#define OMAP44XX_REG_MCMD_SHIFT 8 +#define OMAP44XX_REG_MCMD_MASK (0x7 << 8) +#define OMAP44XX_REG_MCONNID_SHIFT 0 +#define OMAP44XX_REG_MCONNID_MASK (0xff << 0) + +/* DDR_PHY_CTRL_1 */ +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHIFT 4 +#define OMAP44XX_REG_DDR_PHY_CTRL_1_MASK (0xfffffff << 4) +#define OMAP44XX_REG_READ_LATENCY_SHIFT 0 +#define OMAP44XX_REG_READ_LATENCY_MASK (0xf << 0) +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHIFT 4 +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_MASK (0xFF << 4) +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHIFT 12 +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_MASK (0xFFFFF << 12) + +/* DDR_PHY_CTRL_1_SHDW */ +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHDW_SHIFT 4 +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHDW_MASK (0xfffffff << 4) +#define OMAP44XX_REG_READ_LATENCY_SHDW_SHIFT 0 +#define OMAP44XX_REG_READ_LATENCY_SHDW_MASK (0xf << 0) +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHDW_SHIFT 4 +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHDW_MASK (0xFF << 4) +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHDW_SHIFT 12 +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHDW_MASK (0xFFFFF << 12) + +/* DDR_PHY_CTRL_2 */ +#define OMAP44XX_REG_DDR_PHY_CTRL_2_SHIFT 0 +#define OMAP44XX_REG_DDR_PHY_CTRL_2_MASK (0xffffffff << 0) + +/* DMM */ +#define OMAP44XX_DMM_LISA_MAP_BASE 0x4E000040 + +/* DMM_LISA_MAP */ +#define OMAP44XX_SYS_ADDR_SHIFT 24 +#define OMAP44XX_SYS_ADDR_MASK (0xff << 24) +#define OMAP44XX_SYS_SIZE_SHIFT 20 +#define OMAP44XX_SYS_SIZE_MASK (0x7 << 20) +#define OMAP44XX_SDRC_INTL_SHIFT 18 +#define OMAP44XX_SDRC_INTL_MASK (0x3 << 18) +#define OMAP44XX_SDRC_ADDRSPC_SHIFT 16 +#define OMAP44XX_SDRC_ADDRSPC_MASK (0x3 << 16) +#define OMAP44XX_SDRC_MAP_SHIFT 8 +#define OMAP44XX_SDRC_MAP_MASK (0x3 << 8) +#define OMAP44XX_SDRC_ADDR_SHIFT 0 +#define OMAP44XX_SDRC_ADDR_MASK (0xff << 0) + +/* DMM_LISA_MAP fields */ +#define DMM_SDRC_MAP_UNMAPPED 0 +#define DMM_SDRC_MAP_EMIF1_ONLY 1 +#define DMM_SDRC_MAP_EMIF2_ONLY 2 +#define DMM_SDRC_MAP_EMIF1_AND_EMIF2 3 + +#define DMM_SDRC_INTL_NONE 0 +#define DMM_SDRC_INTL_128B 1 +#define DMM_SDRC_INTL_256B 2 +#define DMM_SDRC_INTL_512 3 + +#define DMM_SDRC_ADDR_SPC_SDRAM 0 +#define DMM_SDRC_ADDR_SPC_NVM 1 +#define DMM_SDRC_ADDR_SPC_INVALID 2 + +#define DMM_LISA_MAP_INTERLEAVED_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF1_AND_EMIF2 << OMAP44XX_SDRC_MAP_SHIFT) |\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT) |\ + (DMM_SDRC_INTL_128B << OMAP44XX_SDRC_INTL_SHIFT) |\ + (CONFIG_SYS_SDRAM_BASE << OMAP44XX_SYS_ADDR_SHIFT)) + +#define DMM_LISA_MAP_EMIF1_ONLY_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)) + +#define DMM_LISA_MAP_EMIF2_ONLY_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF2_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)) + +/* Trap for invalid TILER PAT entries */ +#define DMM_LISA_MAP_0_INVAL_ADDR_TRAP (\ + (0 << OMAP44XX_SDRC_ADDR_SHIFT) |\ + (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_INVALID << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)|\ + (0xFF << OMAP44XX_SYS_ADDR_SHIFT)) + + +/* Reg mapping structure */ +struct emif_reg_struct { + u32 emif_mod_id_rev; + u32 emif_status; + u32 emif_sdram_config; + u32 emif_lpddr2_nvm_config; + u32 emif_sdram_ref_ctrl; + u32 emif_sdram_ref_ctrl_shdw; + u32 emif_sdram_tim_1; + u32 emif_sdram_tim_1_shdw; + u32 emif_sdram_tim_2; + u32 emif_sdram_tim_2_shdw; + u32 emif_sdram_tim_3; + u32 emif_sdram_tim_3_shdw; + u32 emif_lpddr2_nvm_tim; + u32 emif_lpddr2_nvm_tim_shdw; + u32 emif_pwr_mgmt_ctrl; + u32 emif_pwr_mgmt_ctrl_shdw; + u32 emif_lpddr2_mode_reg_data; + u32 padding1[1]; + u32 emif_lpddr2_mode_reg_data_es2; + u32 padding11[1]; + u32 emif_lpddr2_mode_reg_cfg; + u32 emif_l3_config; + u32 emif_l3_cfg_val_1; + u32 emif_l3_cfg_val_2; + u32 emif_iodft_tlgc; + u32 padding2[7]; + u32 emif_perf_cnt_1; + u32 emif_perf_cnt_2; + u32 emif_perf_cnt_cfg; + u32 emif_perf_cnt_sel; + u32 emif_perf_cnt_tim; + u32 padding3; + u32 emif_read_idlectrl; + u32 emif_read_idlectrl_shdw; + u32 padding4; + u32 emif_irqstatus_raw_sys; + u32 emif_irqstatus_raw_ll; + u32 emif_irqstatus_sys; + u32 emif_irqstatus_ll; + u32 emif_irqenable_set_sys; + u32 emif_irqenable_set_ll; + u32 emif_irqenable_clr_sys; + u32 emif_irqenable_clr_ll; + u32 padding5; + u32 emif_zq_config; + u32 emif_temp_alert_config; + u32 emif_l3_err_log; + u32 padding6[4]; + u32 emif_ddr_phy_ctrl_1; + u32 emif_ddr_phy_ctrl_1_shdw; + u32 emif_ddr_phy_ctrl_2; +}; + +struct dmm_lisa_map_regs { + u32 dmm_lisa_map_0; + u32 dmm_lisa_map_1; + u32 dmm_lisa_map_2; + u32 dmm_lisa_map_3; +}; + +struct control_lpddr2io_regs { + u32 control_lpddr2io1_0; + u32 control_lpddr2io1_1; + u32 control_lpddr2io1_2; + u32 control_lpddr2io1_3; + u32 control_lpddr2io2_0; + u32 control_lpddr2io2_1; + u32 control_lpddr2io2_2; + u32 control_lpddr2io2_3; +}; + +#define CS0 0 +#define CS1 1 +/* The maximum frequency at which the LPDDR2 interface can operate in Hz*/ +#define MAX_LPDDR2_FREQ 400000000 /* 400 MHz */ + +/* + * The period of DDR clk is represented as numerator and denominator for + * better accuracy in integer based calculations. However, if the numerator + * and denominator are very huge there may be chances of overflow in + * calculations. So, as a trade-off keep denominator(and consequently + * numerator) within a limit sacrificing some accuracy - but not much + * If denominator and numerator are already small (such as at 400 MHz) + * no adjustment is needed + */ +#define EMIF_PERIOD_DEN_LIMIT 1000 +/* + * Maximum number of different frequencies supported by EMIF driver + * Determines the number of entries in the pointer array for register + * cache + */ +#define EMIF_MAX_NUM_FREQUENCIES 6 +/* + * Indices into the Addressing Table array. + * One entry each for all the different types of devices with different + * addressing schemes + */ +#define ADDR_TABLE_INDEX64M 0 +#define ADDR_TABLE_INDEX128M 1 +#define ADDR_TABLE_INDEX256M 2 +#define ADDR_TABLE_INDEX512M 3 +#define ADDR_TABLE_INDEX1GS4 4 +#define ADDR_TABLE_INDEX2GS4 5 +#define ADDR_TABLE_INDEX4G 6 +#define ADDR_TABLE_INDEX8G 7 +#define ADDR_TABLE_INDEX1GS2 8 +#define ADDR_TABLE_INDEX2GS2 9 +#define ADDR_TABLE_INDEXMAX 10 + +/* Number of Row bits */ +#define ROW_9 0 +#define ROW_10 1 +#define ROW_11 2 +#define ROW_12 3 +#define ROW_13 4 +#define ROW_14 5 +#define ROW_15 6 +#define ROW_16 7 + +/* Number of Column bits */ +#define COL_8 0 +#define COL_9 1 +#define COL_10 2 +#define COL_11 3 +#define COL_7 4 /*Not supported by OMAP included for completeness */ + +/* Number of Banks*/ +#define BANKS1 0 +#define BANKS2 1 +#define BANKS4 2 +#define BANKS8 3 + +/* Refresh rate in micro seconds x 10 */ +#define T_REFI_15_6 156 +#define T_REFI_7_8 78 +#define T_REFI_3_9 39 + +#define EBANK_CS1_DIS 0 +#define EBANK_CS1_EN 1 + +/* Read Latency used by the device at reset */ +#define RL_BOOT 3 +/* Read Latency for the highest frequency you want to use */ +#define RL_FINAL 6 + +/* Interleaving policies at EMIF level- between banks and Chip Selects */ +#define EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING 0 +#define EMIF_INTERLEAVING_POLICY_NO_BANK_INTERLEAVING 3 + +/* + * Interleaving policy to be used + * Currently set to MAX interleaving for better performance + */ +#define EMIF_INTERLEAVING_POLICY EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING + +/* State of the core voltage: + * This is important for some parameters such as read idle control and + * ZQ calibration timings. Timings are much stricter when voltage ramp + * is happening compared to when the voltage is stable. + * We need to calculate two sets of values for these parameters and use + * them accordingly + */ +#define LPDDR2_VOLTAGE_STABLE 0 +#define LPDDR2_VOLTAGE_RAMPING 1 + +/* Length of the forced read idle period in terms of cycles */ +#define EMIF_REG_READ_IDLE_LEN_VAL 5 + +/* Interval between forced 'read idles' */ +/* To be used when voltage is changed for DPS/DVFS - 1us */ +#define READ_IDLE_INTERVAL_DVFS (1*1000) +/* + * To be used when voltage is not scaled except by Smart Reflex + * 50us - or maximum value will do + */ +#define READ_IDLE_INTERVAL_NORMAL (50*1000) + + +/* + * Unless voltage is changing due to DVFS one ZQCS command every 50ms should + * be enough. This shoule be enough also in the case when voltage is changing + * due to smart-reflex. + */ +#define EMIF_ZQCS_INTERVAL_NORMAL_IN_US (50*1000) +/* + * If voltage is changing due to DVFS ZQCS should be performed more + * often(every 50us) + */ +#define EMIF_ZQCS_INTERVAL_DVFS_IN_US 50 + +/* The interval between ZQCL commands as a multiple of ZQCS interval */ +#define REG_ZQ_ZQCL_MULT 4 +/* The interval between ZQINIT commands as a multiple of ZQCL interval */ +#define REG_ZQ_ZQINIT_MULT 3 +/* Enable ZQ Calibration on exiting Self-refresh */ +#define REG_ZQ_SFEXITEN_ENABLE 1 +/* + * ZQ Calibration simultaneously on both chip-selects: + * Needs one calibration resistor per CS + * None of the boards that we know of have this capability + * So disabled by default + */ +#define REG_ZQ_DUALCALEN_DISABLE 0 +/* + * Enable ZQ Calibration by default on CS0. If we are asked to program + * the EMIF there will be something connected to CS0 for sure + */ +#define REG_ZQ_CS0EN_ENABLE 1 + +/* EMIF_PWR_MGMT_CTRL register */ +/* Low power modes */ +#define LP_MODE_DISABLE 0 +#define LP_MODE_CLOCK_STOP 1 +#define LP_MODE_SELF_REFRESH 2 +#define LP_MODE_PWR_DN 3 + +/* REG_DPD_EN */ +#define DPD_DISABLE 0 +#define DPD_ENABLE 1 + +/* Maximum delay before Low Power Modes */ +#define REG_CS_TIM 0xF +#define REG_SR_TIM 0xF +#define REG_PD_TIM 0xF + +/* EMIF_PWR_MGMT_CTRL register */ +#define EMIF_PWR_MGMT_CTRL (\ + ((REG_CS_TIM << OMAP44XX_REG_CS_TIM_SHIFT) & OMAP44XX_REG_CS_TIM_MASK)|\ + ((REG_SR_TIM << OMAP44XX_REG_SR_TIM_SHIFT) & OMAP44XX_REG_SR_TIM_MASK)|\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHIFT) & OMAP44XX_REG_PD_TIM_MASK)|\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHIFT) & OMAP44XX_REG_PD_TIM_MASK)|\ + ((LP_MODE_DISABLE << OMAP44XX_REG_LP_MODE_SHIFT)\ + & OMAP44XX_REG_LP_MODE_MASK) |\ + ((DPD_DISABLE << OMAP44XX_REG_DPD_EN_SHIFT)\ + & OMAP44XX_REG_DPD_EN_MASK))\ + +#define EMIF_PWR_MGMT_CTRL_SHDW (\ + ((REG_CS_TIM << OMAP44XX_REG_CS_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_CS_TIM_SHDW_MASK) |\ + ((REG_SR_TIM << OMAP44XX_REG_SR_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_SR_TIM_SHDW_MASK) |\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_PD_TIM_SHDW_MASK) |\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_PD_TIM_SHDW_MASK)) + +/* EMIF_L3_CONFIG register value for ES1*/ +#define EMIF_L3_CONFIG_VAL_SYS_THRESH_0A_LL_THRESH_00 0x0A0000FF +/* + * Value of bits 12:31 of DDR_PHY_CTRL_1 register: + * All these fields have magic values dependent on frequency and + * determined by PHY and DLL integration with EMIF. Setting the magic + * values suggested by hw team. + */ +#define EMIF_DDR_PHY_CTRL_1_BASE_VAL 0x049FF +#define EMIF_DLL_SLAVE_DLY_CTRL_400_MHZ 0x41 +#define EMIF_DLL_SLAVE_DLY_CTRL_200_MHZ 0x80 +#define EMIF_DLL_SLAVE_DLY_CTRL_100_MHZ_AND_LESS 0xFF + +/* +* MR1 value: +* Burst length : 8 +* Burst type : sequential +* Wrap : enabled +* nWR : 3(default). EMIF does not do pre-charge. +* : So nWR is don't care +*/ +#define MR1_BL_8_BT_SEQ_WRAP_EN_NWR_3 0x23 + +/* MR2 */ +#define MR2_RL3_WL1 1 +#define MR2_RL4_WL2 2 +#define MR2_RL5_WL2 3 +#define MR2_RL6_WL3 4 + +/* MR10: ZQ calibration codes */ +#define MR10_ZQ_ZQCS 0x56 +#define MR10_ZQ_ZQCL 0xAB +#define MR10_ZQ_ZQINIT 0xFF +#define MR10_ZQ_ZQRESET 0xC3 + +/* TEMP_ALERT_CONFIG */ +#define TEMP_ALERT_POLL_INTERVAL_MS 360 /* for temp gradient - 5 C/s */ +#define TEMP_ALERT_CONFIG_DEVCT_1 0 +#define TEMP_ALERT_CONFIG_DEVWDT_32 2 + +/* MR16 value: refresh full array(no partial array self refresh) */ +#define MR16_REF_FULL_ARRAY 0 + +/* LPDDR2 IO regs */ +#define CONTROL_LPDDR2IO_SLEW_125PS_DRV8_PULL_DOWN 0x1C1C1C1C +#define CONTROL_LPDDR2IO_SLEW_325PS_DRV8_GATE_KEEPER 0x9E9E9E9E + +/* CONTROL_EFUSE_2 */ +#define CONTROL_EFUSE_2_NMOS_PMOS_PTV_CODE_1 0x00ffc000 + +/* + * Maximum number of entries we keep in our array of timing tables + * We need not keep all the speed bins supported by the device + * We need to keep timing tables for only the speed bins that we + * are interested in + */ +#define MAX_NUM_SPEEDBINS 4 + +/* LPDDR2 Densities */ +#define LPDDR2_DENSITY_64Mb 0 +#define LPDDR2_DENSITY_128Mb 1 +#define LPDDR2_DENSITY_256Mb 2 +#define LPDDR2_DENSITY_512Mb 3 +#define LPDDR2_DENSITY_1Gb 4 +#define LPDDR2_DENSITY_2Gb 5 +#define LPDDR2_DENSITY_4Gb 6 +#define LPDDR2_DENSITY_8Gb 7 +#define LPDDR2_DENSITY_16Gb 8 +#define LPDDR2_DENSITY_32Gb 9 + +/* LPDDR2 type */ +#define LPDDR2_TYPE_S4 0 +#define LPDDR2_TYPE_S2 1 +#define LPDDR2_TYPE_NVM 2 + +/* LPDDR2 IO width */ +#define LPDDR2_IO_WIDTH_32 0 +#define LPDDR2_IO_WIDTH_16 1 +#define LPDDR2_IO_WIDTH_8 2 + +/* Mode register numbers */ +#define LPDDR2_MR0 0 +#define LPDDR2_MR1 1 +#define LPDDR2_MR2 2 +#define LPDDR2_MR3 3 +#define LPDDR2_MR4 4 +#define LPDDR2_MR5 5 +#define LPDDR2_MR6 6 +#define LPDDR2_MR7 7 +#define LPDDR2_MR8 8 +#define LPDDR2_MR9 9 +#define LPDDR2_MR10 10 +#define LPDDR2_MR11 11 +#define LPDDR2_MR16 16 +#define LPDDR2_MR17 17 +#define LPDDR2_MR18 18 + +/* MR0 */ +#define LPDDR2_MR0_DAI_SHIFT 0 +#define LPDDR2_MR0_DAI_MASK 1 +#define LPDDR2_MR0_DI_SHIFT 1 +#define LPDDR2_MR0_DI_MASK (1 << 1) +#define LPDDR2_MR0_DNVI_SHIFT 2 +#define LPDDR2_MR0_DNVI_MASK (1 << 2) + +/* MR4 */ +#define MR4_SDRAM_REF_RATE_SHIFT 0 +#define MR4_SDRAM_REF_RATE_MASK 7 +#define MR4_TUF_SHIFT 7 +#define MR4_TUF_MASK (1 << 7) + +/* MR4 SDRAM Refresh Rate field values */ +#define SDRAM_TEMP_LESS_LOW_SHUTDOWN 0x0 +#define SDRAM_TEMP_LESS_4X_REFRESH_AND_TIMINGS 0x1 +#define SDRAM_TEMP_LESS_2X_REFRESH_AND_TIMINGS 0x2 +#define SDRAM_TEMP_NOMINAL 0x3 +#define SDRAM_TEMP_RESERVED_4 0x4 +#define SDRAM_TEMP_HIGH_DERATE_REFRESH 0x5 +#define SDRAM_TEMP_HIGH_DERATE_REFRESH_AND_TIMINGS 0x6 +#define SDRAM_TEMP_VERY_HIGH_SHUTDOWN 0x7 + +#define LPDDR2_MANUFACTURER_SAMSUNG 1 +#define LPDDR2_MANUFACTURER_QIMONDA 2 +#define LPDDR2_MANUFACTURER_ELPIDA 3 +#define LPDDR2_MANUFACTURER_ETRON 4 +#define LPDDR2_MANUFACTURER_NANYA 5 +#define LPDDR2_MANUFACTURER_HYNIX 6 +#define LPDDR2_MANUFACTURER_MOSEL 7 +#define LPDDR2_MANUFACTURER_WINBOND 8 +#define LPDDR2_MANUFACTURER_ESMT 9 +#define LPDDR2_MANUFACTURER_SPANSION 11 +#define LPDDR2_MANUFACTURER_SST 12 +#define LPDDR2_MANUFACTURER_ZMOS 13 +#define LPDDR2_MANUFACTURER_INTEL 14 +#define LPDDR2_MANUFACTURER_NUMONYX 254 +#define LPDDR2_MANUFACTURER_MICRON 255 + +/* MR8 register fields */ +#define MR8_TYPE_SHIFT 0x0 +#define MR8_TYPE_MASK 0x3 +#define MR8_DENSITY_SHIFT 0x2 +#define MR8_DENSITY_MASK (0xF << 0x2) +#define MR8_IO_WIDTH_SHIFT 0x6 +#define MR8_IO_WIDTH_MASK (0x3 << 0x6) + +struct lpddr2_addressing { + u8 num_banks; + u8 t_REFI_us_x10; + u8 row_sz[2]; /* One entry each for x32 and x16 */ + u8 col_sz[2]; /* One entry each for x32 and x16 */ +}; + +/* Structure for timings from the DDR datasheet */ +struct lpddr2_ac_timings { + u32 max_freq; + u8 RL; + u8 tRPab; + u8 tRCD; + u8 tWR; + u8 tRASmin; + u8 tRRD; + u8 tWTRx2; + u8 tXSR; + u8 tXPx2; + u8 tRFCab; + u8 tRTPx2; + u8 tCKE; + u8 tCKESR; + u8 tZQCS; + u32 tZQCL; + u32 tZQINIT; + u8 tDQSCKMAXx2; + u8 tRASmax; + u8 tFAW; + +}; + +/* + * Min tCK values for some of the parameters: + * If the calculated clock cycles for the respective parameter is + * less than the corresponding min tCK value, we need to set the min + * tCK value. This may happen at lower frequencies. + */ +struct lpddr2_min_tck { + u32 tRL; + u32 tRP_AB; + u32 tRCD; + u32 tWR; + u32 tRAS_MIN; + u32 tRRD; + u32 tWTR; + u32 tXP; + u32 tRTP; + u8 tCKE; + u32 tCKESR; + u32 tFAW; +}; + +struct lpddr2_device_details { + u8 type; + u8 density; + u8 io_width; + u8 manufacturer; +}; + +struct lpddr2_device_timings { + const struct lpddr2_ac_timings **ac_timings; + const struct lpddr2_min_tck *min_tck; +}; + +/* Details of the devices connected to each chip-select of an EMIF instance */ +struct emif_device_details { + const struct lpddr2_device_details *cs0_device_details; + const struct lpddr2_device_details *cs1_device_details; + const struct lpddr2_device_timings *cs0_device_timings; + const struct lpddr2_device_timings *cs1_device_timings; +}; + +/* + * Structure containing shadow of important registers in EMIF + * The calculation function fills in this structure to be later used for + * initialization and DVFS + */ +struct emif_regs { + u32 freq; + u32 sdram_config_init; + u32 sdram_config; + u32 ref_ctrl; + u32 sdram_tim1; + u32 sdram_tim2; + u32 sdram_tim3; + u32 read_idle_ctrl; + u32 zq_config; + u32 temp_alert_config; + u32 emif_ddr_phy_ctlr_1_init; + u32 emif_ddr_phy_ctlr_1; +}; + +/* assert macros */ +#if defined(DEBUG) +#define emif_assert(c) ({ if (!(c)) for (;;); }) +#else +#define emif_assert(c) ({ if (0) hang(); }) +#endif + +void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs); +void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs); + +#endif diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index 76b06c2..c9c86e1 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -51,6 +51,11 @@ #define CONTROL_PADCONF_CORE (OMAP44XX_L4_CORE_BASE + 0x100000) #define CONTROL_PADCONF_WKUP (OMAP44XX_L4_CORE_BASE + 0x31E000)
+/* LPDDR2 IO regs */ +#define LPDDR2_IO_REGS_BASE 0x4A100638 + +#define CONTROL_EFUSE_2 0x4A100704 + /* CONTROL_ID_CODE */ #define CONTROL_ID_CODE 0x4A002204
diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index f871921..7183a90 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -49,6 +49,8 @@ void bypass_dpll(u32 *const base); void freq_update_core(void); u32 get_sys_clk_freq(void); u32 omap4_ddr_clk(void); +void sdram_init(void); +u32 omap4_sdram_size(void);
Calculate EMIF register values based on AC timing parameters from the SDRAM datasheet and the DDR frequency rather than using the hard-coded values.
For a new board the user doen't have to go through the tedious process of calculating the register values. Instead, just provide the AC timings from the device data sheet as input and the driver will automatically calculate the register values.
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Added SDRAM init related CONFIG flags for Panda too. Earlier Panda support for everything was added in a single patch at the end * Replaced calls to omap4_revision() with omap_revision() * Reorganization of code for better readability * Some code re-organization to reduce #ifdef complexities - cleanly separated out functions for getting device details (geometry) vs timings * Ensured un-necessary code is compiled out if CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REG is defined --- arch/arm/cpu/armv7/omap-common/Makefile | 1 + arch/arm/cpu/armv7/omap-common/utils.c | 57 ++ arch/arm/cpu/armv7/omap4/board.c | 9 +- arch/arm/cpu/armv7/omap4/emif.c | 739 +++++++++++++++++++++++++++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 151 ++++++ arch/arm/include/asm/arch-omap4/emif.h | 9 + arch/arm/include/asm/arch-omap4/omap4.h | 10 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + include/configs/omap4_panda.h | 5 + include/configs/omap4_sdp4430.h | 5 + 10 files changed, 977 insertions(+), 10 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/utils.c
diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index dc01ee5..8f698f8 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -28,6 +28,7 @@ LIB = $(obj)libomap-common.o SOBJS := reset.o
COBJS := timer.o +COBJS += utils.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/arch/arm/cpu/armv7/omap-common/utils.c b/arch/arm/cpu/armv7/omap-common/utils.c new file mode 100644 index 0000000..ea935da --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/utils.c @@ -0,0 +1,57 @@ +/* + * Copyright 2011 Linaro Limited + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +static void do_cancel_out(u32 *num, u32 *den, u32 factor) +{ + while (1) { + if (((*num)/factor*factor == (*num)) && + ((*den)/factor*factor == (*den))) { + (*num) /= factor; + (*den) /= factor; + } else + break; + } +} + +/* + * Cancel out the denominator and numerator of a fraction + * to get smaller numerator and denominator. + */ +void cancel_out(u32 *num, u32 *den, u32 den_limit) +{ + do_cancel_out(num, den, 2); + do_cancel_out(num, den, 3); + do_cancel_out(num, den, 5); + do_cancel_out(num, den, 7); + do_cancel_out(num, den, 11); + do_cancel_out(num, den, 13); + do_cancel_out(num, den, 17); + while ((*den) > den_limit) { + *num /= 2; + /* + * Round up the denominator so that the final fraction + * (num/den) is always <= the desired value + */ + *den = (*den + 1) / 2; + } +} diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index ca107f7..786c239 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -32,6 +32,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> +#include <asm/arch/emif.h> #include "omap4_mux_data.h"
DECLARE_GLOBAL_DATA_PTR; @@ -193,13 +194,13 @@ u32 omap4_sdram_size(void) { u32 section, i, total_size = 0, size, addr; for (i = 0; i < 4; i++) { - section = __raw_readl(DMM_LISA_MAP_BASE + i*4); - addr = section & DMM_LISA_MAP_SYS_ADDR_MASK; + section = __raw_readl(OMAP44XX_DMM_LISA_MAP_BASE + i*4); + addr = section & OMAP44XX_SYS_ADDR_MASK; /* See if the address is valid */ if ((addr >= OMAP44XX_DRAM_ADDR_SPACE_START) && (addr < OMAP44XX_DRAM_ADDR_SPACE_END)) { - size = ((section & DMM_LISA_MAP_SYS_SIZE_MASK) >> - DMM_LISA_MAP_SYS_SIZE_SHIFT); + size = ((section & OMAP44XX_SYS_SIZE_MASK) >> + OMAP44XX_SYS_SIZE_SHIFT); size = 1 << size; size *= SZ_16M; total_size += size; diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index b25c1ee..ceead9e 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -170,6 +170,628 @@ static void emif_update_timings(u32 base, const struct emif_regs *regs) } }
+#ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define print_timing_reg(reg) debug(#reg" - 0x%08x\n", (reg)) + +static u32 *const T_num = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_NUM; +static u32 *const T_den = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_DEN; +static u32 *const emif_sizes = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_SIZE; + +/* + * Organization and refresh requirements for LPDDR2 devices of different + * types and densities. Derived from JESD209-2 section 2.4 + */ +const struct lpddr2_addressing addressing_table[] = { + /* Banks tREFIx10 rowx32,rowx16 colx32,colx16 density */ + {BANKS4, T_REFI_15_6, {ROW_12, ROW_12}, {COL_7, COL_8} },/*64M */ + {BANKS4, T_REFI_15_6, {ROW_12, ROW_12}, {COL_8, COL_9} },/*128M */ + {BANKS4, T_REFI_7_8, {ROW_13, ROW_13}, {COL_8, COL_9} },/*256M */ + {BANKS4, T_REFI_7_8, {ROW_13, ROW_13}, {COL_9, COL_10} },/*512M */ + {BANKS8, T_REFI_7_8, {ROW_13, ROW_13}, {COL_9, COL_10} },/*1GS4 */ + {BANKS8, T_REFI_3_9, {ROW_14, ROW_14}, {COL_9, COL_10} },/*2GS4 */ + {BANKS8, T_REFI_3_9, {ROW_14, ROW_14}, {COL_10, COL_11} },/*4G */ + {BANKS8, T_REFI_3_9, {ROW_15, ROW_15}, {COL_10, COL_11} },/*8G */ + {BANKS4, T_REFI_7_8, {ROW_14, ROW_14}, {COL_9, COL_10} },/*1GS2 */ + {BANKS4, T_REFI_3_9, {ROW_15, ROW_15}, {COL_9, COL_10} },/*2GS2 */ +}; + +static const u32 lpddr2_density_2_size_in_mbytes[] = { + 8, /* 64Mb */ + 16, /* 128Mb */ + 32, /* 256Mb */ + 64, /* 512Mb */ + 128, /* 1Gb */ + 256, /* 2Gb */ + 512, /* 4Gb */ + 1024, /* 8Gb */ + 2048, /* 16Gb */ + 4096 /* 32Gb */ +}; + +/* + * Calculate the period of DDR clock from frequency value and set the + * denominator and numerator in global variables for easy access later + */ +static void set_ddr_clk_period(u32 freq) +{ + /* + * period = 1/freq + * period_in_ns = 10^9/freq + */ + *T_num = 1000000000; + *T_den = freq; + cancel_out(T_num, T_den, 200); + +} + +/* + * Convert time in nano seconds to number of cycles of DDR clock + */ +static inline u32 ns_2_cycles(u32 ns) +{ + return ((ns * (*T_den)) + (*T_num) - 1) / (*T_num); +} + +/* + * ns_2_cycles with the difference that the time passed is 2 times the actual + * value(to avoid fractions). The cycles returned is for the original value of + * the timing parameter + */ +static inline u32 ns_x2_2_cycles(u32 ns) +{ + return ((ns * (*T_den)) + (*T_num) * 2 - 1) / ((*T_num) * 2); +} + +/* + * Find addressing table index based on the device's type(S2 or S4) and + * density + */ +s8 addressing_table_index(u8 type, u8 density, u8 width) +{ + u8 index; + if ((density > LPDDR2_DENSITY_8Gb) || (width == LPDDR2_IO_WIDTH_8)) + return -1; + + /* + * Look at the way ADDR_TABLE_INDEX* values have been defined + * in emif.h compared to LPDDR2_DENSITY_* values + * The table is layed out in the increasing order of density + * (ignoring type). The exceptions 1GS2 and 2GS2 have been placed + * at the end + */ + if ((type == LPDDR2_TYPE_S2) && (density == LPDDR2_DENSITY_1Gb)) + index = ADDR_TABLE_INDEX1GS2; + else if ((type == LPDDR2_TYPE_S2) && (density == LPDDR2_DENSITY_2Gb)) + index = ADDR_TABLE_INDEX2GS2; + else + index = density; + + debug("emif: addressing table index %d\n", index); + + return index; +} + +/* + * Find the the right timing table from the array of timing + * tables of the device using DDR clock frequency + */ +static const struct lpddr2_ac_timings *get_timings_table(const struct + lpddr2_ac_timings const *const *device_timings, + u32 freq) +{ + u32 i, temp, freq_nearest; + const struct lpddr2_ac_timings *timings = 0; + + emif_assert(freq <= MAX_LPDDR2_FREQ); + emif_assert(device_timings); + + /* + * Start with the maximum allowed frequency - that is always safe + */ + freq_nearest = MAX_LPDDR2_FREQ; + /* + * Find the timings table that has the max frequency value: + * i. Above or equal to the DDR frequency - safe + * ii. The lowest that satisfies condition (i) - optimal + */ + for (i = 0; (i < MAX_NUM_SPEEDBINS) && device_timings[i]; i++) { + temp = device_timings[i]->max_freq; + if ((temp >= freq) && (temp <= freq_nearest)) { + freq_nearest = temp; + timings = device_timings[i]; + } + } + debug("emif: timings table: %d\n", freq_nearest); + return timings; +} + +/* + * Finds the value of emif_sdram_config_reg + * All parameters are programmed based on the device on CS0. + * If there is a device on CS1, it will be same as that on CS0 or + * it will be NVM. We don't support NVM yet. + * If cs1_device pointer is NULL it is assumed that there is no device + * on CS1 + */ +static u32 get_sdram_config_reg(const struct lpddr2_device_details *cs0_device, + const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 RL) +{ + u32 config_reg = 0; + + config_reg |= (cs0_device->type + 4) << OMAP44XX_REG_SDRAM_TYPE_SHIFT; + config_reg |= EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING << + OMAP44XX_REG_IBANK_POS_SHIFT; + + config_reg |= cs0_device->io_width << OMAP44XX_REG_NARROW_MODE_SHIFT; + + config_reg |= RL << OMAP44XX_REG_CL_SHIFT; + + config_reg |= addressing->row_sz[cs0_device->io_width] << + OMAP44XX_REG_ROWSIZE_SHIFT; + + config_reg |= addressing->num_banks << OMAP44XX_REG_IBANK_SHIFT; + + config_reg |= (cs1_device ? EBANK_CS1_EN : EBANK_CS1_DIS) << + OMAP44XX_REG_EBANK_SHIFT; + + config_reg |= addressing->col_sz[cs0_device->io_width] << + OMAP44XX_REG_PAGESIZE_SHIFT; + + return config_reg; +} + +static u32 get_sdram_ref_ctrl(u32 freq, + const struct lpddr2_addressing *addressing) +{ + u32 ref_ctrl = 0, val = 0, freq_khz; + freq_khz = freq / 1000; + /* + * refresh rate to be set is 'tREFI * freq in MHz + * division by 10000 to account for khz and x10 in t_REFI_us_x10 + */ + val = addressing->t_REFI_us_x10 * freq_khz / 10000; + ref_ctrl |= val << OMAP44XX_REG_REFRESH_RATE_SHIFT; + + return ref_ctrl; +} + +static u32 get_sdram_tim_1_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck, + const struct lpddr2_addressing *addressing) +{ + u32 tim1 = 0, val = 0; + val = max(min_tck->tWTR, ns_x2_2_cycles(timings->tWTRx2)) - 1; + tim1 |= val << OMAP44XX_REG_T_WTR_SHIFT; + + if (addressing->num_banks == BANKS8) + val = (timings->tFAW * (*T_den) + 4 * (*T_num) - 1) / + (4 * (*T_num)) - 1; + else + val = max(min_tck->tRRD, ns_2_cycles(timings->tRRD)) - 1; + + tim1 |= val << OMAP44XX_REG_T_RRD_SHIFT; + + val = ns_2_cycles(timings->tRASmin + timings->tRPab) - 1; + tim1 |= val << OMAP44XX_REG_T_RC_SHIFT; + + val = max(min_tck->tRAS_MIN, ns_2_cycles(timings->tRASmin)) - 1; + tim1 |= val << OMAP44XX_REG_T_RAS_SHIFT; + + val = max(min_tck->tWR, ns_2_cycles(timings->tWR)) - 1; + tim1 |= val << OMAP44XX_REG_T_WR_SHIFT; + + val = max(min_tck->tRCD, ns_2_cycles(timings->tRCD)) - 1; + tim1 |= val << OMAP44XX_REG_T_RCD_SHIFT; + + val = max(min_tck->tRP_AB, ns_2_cycles(timings->tRPab)) - 1; + tim1 |= val << OMAP44XX_REG_T_RP_SHIFT; + + return tim1; +} + +static u32 get_sdram_tim_2_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck) +{ + u32 tim2 = 0, val = 0; + val = max(min_tck->tCKE, timings->tCKE) - 1; + tim2 |= val << OMAP44XX_REG_T_CKE_SHIFT; + + val = max(min_tck->tRTP, ns_x2_2_cycles(timings->tRTPx2)) - 1; + tim2 |= val << OMAP44XX_REG_T_RTP_SHIFT; + + /* + * tXSRD = tRFCab + 10 ns. XSRD and XSNR should have the + * same value + */ + val = ns_2_cycles(timings->tXSR) - 1; + tim2 |= val << OMAP44XX_REG_T_XSRD_SHIFT; + tim2 |= val << OMAP44XX_REG_T_XSNR_SHIFT; + + val = max(min_tck->tXP, ns_x2_2_cycles(timings->tXPx2)) - 1; + tim2 |= val << OMAP44XX_REG_T_XP_SHIFT; + + return tim2; +} + +static u32 get_sdram_tim_3_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck, + const struct lpddr2_addressing *addressing) +{ + u32 tim3 = 0, val = 0; + val = min(timings->tRASmax * 10 / addressing->t_REFI_us_x10 - 1, 0xF); + tim3 |= val << OMAP44XX_REG_T_RAS_MAX_SHIFT; + + val = ns_2_cycles(timings->tRFCab) - 1; + tim3 |= val << OMAP44XX_REG_T_RFC_SHIFT; + + val = ns_x2_2_cycles(timings->tDQSCKMAXx2) - 1; + tim3 |= val << OMAP44XX_REG_T_TDQSCKMAX_SHIFT; + + val = ns_2_cycles(timings->tZQCS) - 1; + tim3 |= val << OMAP44XX_REG_ZQ_ZQCS_SHIFT; + + val = max(min_tck->tCKESR, ns_2_cycles(timings->tCKESR)) - 1; + tim3 |= val << OMAP44XX_REG_T_CKESR_SHIFT; + + return tim3; +} + +static u32 get_zq_config_reg(const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 volt_ramp) +{ + u32 zq = 0, val = 0; + if (volt_ramp) + val = + EMIF_ZQCS_INTERVAL_DVFS_IN_US * 10 / + addressing->t_REFI_us_x10; + else + val = + EMIF_ZQCS_INTERVAL_NORMAL_IN_US * 10 / + addressing->t_REFI_us_x10; + zq |= val << OMAP44XX_REG_ZQ_REFINTERVAL_SHIFT; + + zq |= (REG_ZQ_ZQCL_MULT - 1) << OMAP44XX_REG_ZQ_ZQCL_MULT_SHIFT; + + zq |= (REG_ZQ_ZQINIT_MULT - 1) << OMAP44XX_REG_ZQ_ZQINIT_MULT_SHIFT; + + zq |= REG_ZQ_SFEXITEN_ENABLE << OMAP44XX_REG_ZQ_SFEXITEN_SHIFT; + + /* + * Assuming that two chipselects have a single calibration resistor + * If there are indeed two calibration resistors, then this flag should + * be enabled to take advantage of dual calibration feature. + * This data should ideally come from board files. But considering + * that none of the boards today have calibration resistors per CS, + * it would be an unnecessary overhead. + */ + zq |= REG_ZQ_DUALCALEN_DISABLE << OMAP44XX_REG_ZQ_DUALCALEN_SHIFT; + + zq |= REG_ZQ_CS0EN_ENABLE << OMAP44XX_REG_ZQ_CS0EN_SHIFT; + + zq |= (cs1_device ? 1 : 0) << OMAP44XX_REG_ZQ_CS1EN_SHIFT; + + return zq; +} + +static u32 get_temp_alert_config(const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 is_derated) +{ + u32 alert = 0, interval; + interval = + TEMP_ALERT_POLL_INTERVAL_MS * 10000 / addressing->t_REFI_us_x10; + if (is_derated) + interval *= 4; + alert |= interval << OMAP44XX_REG_TA_REFINTERVAL_SHIFT; + + alert |= TEMP_ALERT_CONFIG_DEVCT_1 << OMAP44XX_REG_TA_DEVCNT_SHIFT; + + alert |= TEMP_ALERT_CONFIG_DEVWDT_32 << OMAP44XX_REG_TA_DEVWDT_SHIFT; + + alert |= 1 << OMAP44XX_REG_TA_SFEXITEN_SHIFT; + + alert |= 1 << OMAP44XX_REG_TA_CS0EN_SHIFT; + + alert |= (cs1_device ? 1 : 0) << OMAP44XX_REG_TA_CS1EN_SHIFT; + + return alert; +} + +static u32 get_read_idle_ctrl_reg(u8 volt_ramp) +{ + u32 idle = 0, val = 0; + if (volt_ramp) + val = ns_2_cycles(READ_IDLE_INTERVAL_DVFS) / 64 + 1; + else + /*Maximum value in normal conditions - suggested by hw team */ + val = 0x1FF; + idle |= val << OMAP44XX_REG_READ_IDLE_INTERVAL_SHIFT; + + idle |= EMIF_REG_READ_IDLE_LEN_VAL << OMAP44XX_REG_READ_IDLE_LEN_SHIFT; + + return idle; +} + +static u32 get_ddr_phy_ctrl_1(u32 freq, u8 RL) +{ + u32 phy = 0, val = 0; + + phy |= (RL + 2) << OMAP44XX_REG_READ_LATENCY_SHIFT; + + if (freq <= 100000000) + val = EMIF_DLL_SLAVE_DLY_CTRL_100_MHZ_AND_LESS; + else if (freq <= 200000000) + val = EMIF_DLL_SLAVE_DLY_CTRL_200_MHZ; + else + val = EMIF_DLL_SLAVE_DLY_CTRL_400_MHZ; + phy |= val << OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHIFT; + + /* Other fields are constant magic values. Hardcode them together */ + phy |= EMIF_DDR_PHY_CTRL_1_BASE_VAL << + OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHIFT; + + return phy; +} + +static u32 get_emif_mem_size(struct emif_device_details *devices) +{ + u32 size_mbytes = 0, temp; + + if (!devices) + return 0; + + if (devices->cs0_device_details) { + temp = devices->cs0_device_details->density; + size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; + } + + if (devices->cs1_device_details) { + temp = devices->cs1_device_details->density; + size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; + } + /* convert to bytes */ + return size_mbytes << 20; +} + +/* Gets the encoding corresponding to a given DMM section size */ +u32 get_dmm_section_size_map(u32 section_size) +{ + /* + * Section size mapping: + * 0x0: 16-MiB section + * 0x1: 32-MiB section + * 0x2: 64-MiB section + * 0x3: 128-MiB section + * 0x4: 256-MiB section + * 0x5: 512-MiB section + * 0x6: 1-GiB section + * 0x7: 2-GiB section + */ + section_size >>= 24; /* divide by 16 MB */ + return log_2_n_round_down(section_size); +} + +static void emif_calculate_regs( + const struct emif_device_details *emif_dev_details, + u32 freq, struct emif_regs *regs) +{ + u32 temp, sys_freq; + const struct lpddr2_addressing *addressing; + const struct lpddr2_ac_timings *timings; + const struct lpddr2_min_tck *min_tck; + const struct lpddr2_device_details *cs0_dev_details = + emif_dev_details->cs0_device_details; + const struct lpddr2_device_details *cs1_dev_details = + emif_dev_details->cs1_device_details; + const struct lpddr2_device_timings *cs0_dev_timings = + emif_dev_details->cs0_device_timings; + + emif_assert(emif_dev_details); + emif_assert(regs); + /* + * You can not have a device on CS1 without one on CS0 + * So configuring EMIF without a device on CS0 doesn't + * make sense + */ + emif_assert(cs0_dev_details); + emif_assert(cs0_dev_details->type != LPDDR2_TYPE_NVM); + /* + * If there is a device on CS1 it should be same type as CS0 + * (or NVM. But NVM is not supported in this driver yet) + */ + emif_assert((cs1_dev_details == NULL) || + (cs1_dev_details->type == LPDDR2_TYPE_NVM) || + (cs0_dev_details->type == cs1_dev_details->type)); + emif_assert(freq <= MAX_LPDDR2_FREQ); + + set_ddr_clk_period(freq); + + /* + * The device on CS0 is used for all timing calculations + * There is only one set of registers for timings per EMIF. So, if the + * second CS(CS1) has a device, it should have the same timings as the + * device on CS0 + */ + timings = get_timings_table(cs0_dev_timings->ac_timings, freq); + emif_assert(timings); + min_tck = cs0_dev_timings->min_tck; + + temp = addressing_table_index(cs0_dev_details->type, + cs0_dev_details->density, + cs0_dev_details->io_width); + + emif_assert((temp >= 0)); + addressing = &(addressing_table[temp]); + emif_assert(addressing); + + sys_freq = get_sys_clk_freq(); + + regs->sdram_config_init = get_sdram_config_reg(cs0_dev_details, + cs1_dev_details, + addressing, RL_BOOT); + + regs->sdram_config = get_sdram_config_reg(cs0_dev_details, + cs1_dev_details, + addressing, RL_FINAL); + + regs->ref_ctrl = get_sdram_ref_ctrl(freq, addressing); + + regs->sdram_tim1 = get_sdram_tim_1_reg(timings, min_tck, addressing); + + regs->sdram_tim2 = get_sdram_tim_2_reg(timings, min_tck); + + regs->sdram_tim3 = get_sdram_tim_3_reg(timings, min_tck, addressing); + + regs->read_idle_ctrl = get_read_idle_ctrl_reg(LPDDR2_VOLTAGE_STABLE); + + regs->temp_alert_config = + get_temp_alert_config(cs1_dev_details, addressing, 0); + + regs->zq_config = get_zq_config_reg(cs1_dev_details, addressing, + LPDDR2_VOLTAGE_STABLE); + + regs->emif_ddr_phy_ctlr_1_init = + get_ddr_phy_ctrl_1(sys_freq / 2, RL_BOOT); + + regs->emif_ddr_phy_ctlr_1 = + get_ddr_phy_ctrl_1(freq, RL_FINAL); + + regs->freq = freq; + + print_timing_reg(regs->sdram_config_init); + print_timing_reg(regs->sdram_config); + print_timing_reg(regs->ref_ctrl); + print_timing_reg(regs->sdram_tim1); + print_timing_reg(regs->sdram_tim2); + print_timing_reg(regs->sdram_tim3); + print_timing_reg(regs->read_idle_ctrl); + print_timing_reg(regs->temp_alert_config); + print_timing_reg(regs->zq_config); + print_timing_reg(regs->emif_ddr_phy_ctlr_1); + print_timing_reg(regs->emif_ddr_phy_ctlr_1_init); +} +#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */ + +#ifdef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS +/* Base AC Timing values specified by JESD209-2 for 400MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_400_mhz = { + .max_freq = 400000000, + .RL = 6, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* Base AC Timing values specified by JESD209-2 for 333 MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_333_mhz = { + .max_freq = 333000000, + .RL = 5, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* Base AC Timing values specified by JESD209-2 for 200 MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_200_mhz = { + .max_freq = 200000000, + .RL = 3, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 20, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* + * Min tCK values specified by JESD209-2 + * Min tCK specifies the minimum duration of some AC timing parameters in terms + * of the number of cycles. If the calculated number of cycles based on the + * absolute time value is less than the min tCK value, min tCK value should + * be used instead. This typically happens at low frequencies. + */ +static const struct lpddr2_min_tck min_tck_jedec = { + .tRL = 3, + .tRP_AB = 3, + .tRCD = 3, + .tWR = 3, + .tRAS_MIN = 3, + .tRRD = 2, + .tWTR = 2, + .tXP = 2, + .tRTP = 2, + .tCKE = 3, + .tCKESR = 3, + .tFAW = 8 +}; + +static const struct lpddr2_ac_timings const* + jedec_ac_timings[MAX_NUM_SPEEDBINS] = { + &timings_jedec_200_mhz, + &timings_jedec_333_mhz, + &timings_jedec_400_mhz +}; + +static const struct lpddr2_device_timings jedec_default_timings = { + .ac_timings = jedec_ac_timings, + .min_tck = &min_tck_jedec +}; + +void emif_get_device_timings(u32 emif_nr, + const struct lpddr2_device_timings **cs0_device_timings, + const struct lpddr2_device_timings **cs1_device_timings) +{ + /* Assume Identical devices on EMIF1 & EMIF2 */ + *cs0_device_timings = &jedec_default_timings; + *cs1_device_timings = &jedec_default_timings; +} +#endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */ + static void do_sdram_init(u32 base) { const struct emif_regs *regs; @@ -180,11 +802,54 @@ static void do_sdram_init(u32 base) in_sdram = running_from_sdram(); emif_nr = (base == OMAP44XX_EMIF1) ? 1 : 2;
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS emif_get_reg_dump(emif_nr, ®s); if (!regs) { debug("EMIF: reg dump not provided\n"); return; } +#else + /* + * The user has not provided the register values. We need to + * calculate it based on the timings and the DDR frequency + */ + struct emif_device_details dev_details; + struct emif_regs calculated_regs; + + /* + * Get device details: + * - Discovered if CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION is set + * - Obtained from user otherwise + */ + struct lpddr2_device_details cs0_dev_details, cs1_dev_details; + emif_get_device_details(emif_nr, &cs0_dev_details, + &cs1_dev_details); + dev_details.cs0_device_details = &cs0_dev_details; + dev_details.cs1_device_details = &cs1_dev_details; + + /* Return if no devices on this EMIF */ + if (!dev_details.cs0_device_details && + !dev_details.cs1_device_details) { + emif_sizes[emif_nr - 1] = 0; + return; + } + + if (!in_sdram) + emif_sizes[emif_nr - 1] = get_emif_mem_size(&dev_details); + + /* + * Get device timings: + * - Default timings specified by JESD209-2 if + * CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS is set + * - Obtained from user otherwise + */ + emif_get_device_timings(emif_nr, &dev_details.cs0_device_timings, + &dev_details.cs1_device_timings); + + /* Calculate the register values */ + emif_calculate_regs(&dev_details, omap4_ddr_clk(), &calculated_regs); + regs = &calculated_regs; +#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */
/* * Initializing the LPDDR2 device can not happen from SDRAM. @@ -242,8 +907,82 @@ static void dmm_init(u32 base) { const struct dmm_lisa_map_regs *lisa_map_regs;
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS emif_get_dmm_regs(&lisa_map_regs); +#else + u32 emif1_size, emif2_size, mapped_size, section_map = 0; + u32 section_cnt, sys_addr; + struct dmm_lisa_map_regs lis_map_regs_calculated = {0}; + + mapped_size = 0; + section_cnt = 3; + sys_addr = CONFIG_SYS_SDRAM_BASE; + emif1_size = emif_sizes[0]; + emif2_size = emif_sizes[1]; + debug("emif1_size 0x%x emif2_size 0x%x\n", emif1_size, emif2_size); + + if (!emif1_size && !emif2_size) + return; + + /* symmetric interleaved section */ + if (emif1_size && emif2_size) { + mapped_size = min(emif1_size, emif2_size); + section_map = DMM_LISA_MAP_INTERLEAVED_BASE_VAL; + section_map |= 0 << OMAP44XX_SDRC_ADDR_SHIFT; + /* only MSB */ + section_map |= (sys_addr >> 24) << + OMAP44XX_SYS_ADDR_SHIFT; + section_map |= get_dmm_section_size_map(mapped_size * 2) + << OMAP44XX_SYS_SIZE_SHIFT; + lis_map_regs_calculated.dmm_lisa_map_3 = section_map; + emif1_size -= mapped_size; + emif2_size -= mapped_size; + sys_addr += (mapped_size * 2); + section_cnt--; + } + + /* + * Single EMIF section(we can have a maximum of 1 single EMIF + * section- either EMIF1 or EMIF2 or none, but not both) + */ + if (emif1_size) { + section_map = DMM_LISA_MAP_EMIF1_ONLY_BASE_VAL; + section_map |= get_dmm_section_size_map(emif1_size) + << OMAP44XX_SYS_SIZE_SHIFT; + /* only MSB */ + section_map |= (mapped_size >> 24) << + OMAP44XX_SDRC_ADDR_SHIFT; + /* only MSB */ + section_map |= (sys_addr >> 24) << OMAP44XX_SYS_ADDR_SHIFT; + section_cnt--; + } + if (emif2_size) { + section_map = DMM_LISA_MAP_EMIF2_ONLY_BASE_VAL; + section_map |= get_dmm_section_size_map(emif2_size) << + OMAP44XX_SYS_SIZE_SHIFT; + /* only MSB */ + section_map |= mapped_size >> 24 << OMAP44XX_SDRC_ADDR_SHIFT; + /* only MSB */ + section_map |= sys_addr >> 24 << OMAP44XX_SYS_ADDR_SHIFT; + section_cnt--; + } + + if (section_cnt == 2) { + /* Only 1 section - either symmetric or single EMIF */ + lis_map_regs_calculated.dmm_lisa_map_3 = section_map; + lis_map_regs_calculated.dmm_lisa_map_2 = 0; + lis_map_regs_calculated.dmm_lisa_map_1 = 0; + } else { + /* 2 sections - 1 symmetric, 1 single EMIF */ + lis_map_regs_calculated.dmm_lisa_map_2 = section_map; + lis_map_regs_calculated.dmm_lisa_map_1 = 0; + } + + /* TRAP for invalid TILER mappings in section 0 */ + lis_map_regs_calculated.dmm_lisa_map_0 = DMM_LISA_MAP_0_INVAL_ADDR_TRAP;
+ lisa_map_regs = &lis_map_regs_calculated; +#endif struct dmm_lisa_map_regs *hw_lisa_map_regs = (struct dmm_lisa_map_regs *)base;
diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c index c950c87..7757aad 100644 --- a/arch/arm/cpu/armv7/omap4/sdram_elpida.c +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -46,6 +46,8 @@ * - emif_get_device_timings() */
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS + static const struct emif_regs emif_regs_elpida_200_mhz_2cs = { .sdram_config_init = 0x80000eb9, .sdram_config = 0x80001ab9, @@ -129,3 +131,152 @@ static void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs
void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) __attribute__((weak, alias("emif_get_dmm_regs_sdp"))); + +#else + +static const struct lpddr2_device_details elpida_2G_S4_details = { + .type = LPDDR2_TYPE_S4, + .density = LPDDR2_DENSITY_2Gb, + .io_width = LPDDR2_IO_WIDTH_32, + .manufacturer = LPDDR2_MANUFACTURER_ELPIDA +}; + +static void emif_get_device_details_sdp(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details) +{ + u32 omap_rev = omap_revision(); + + /* EMIF1 & EMIF2 have identical configuration */ + *cs0_device_details = elpida_2G_S4_details; + + if (omap_rev == OMAP4430_ES1_0) + cs1_device_details = NULL; + else + *cs1_device_details = elpida_2G_S4_details; +} + +void emif_get_device_details(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details) + __attribute__((weak, alias("emif_get_device_details_sdp"))); + +#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */ + +#ifndef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS +static const struct lpddr2_ac_timings timings_elpida_400_mhz = { + .max_freq = 400000000, + .RL = 6, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_ac_timings timings_elpida_333_mhz = { + .max_freq = 333000000, + .RL = 5, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_ac_timings timings_elpida_200_mhz = { + .max_freq = 200000000, + .RL = 3, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 20, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_min_tck min_tck_elpida = { + .tRL = 3, + .tRP_AB = 3, + .tRCD = 3, + .tWR = 3, + .tRAS_MIN = 3, + .tRRD = 2, + .tWTR = 2, + .tXP = 2, + .tRTP = 2, + .tCKE = 3, + .tCKESR = 3, + .tFAW = 8 +}; + +static const struct lpddr2_ac_timings *elpida_ac_timings[MAX_NUM_SPEEDBINS] = { + &timings_elpida_200_mhz, + &timings_elpida_333_mhz, + &timings_elpida_400_mhz +}; + +static const struct lpddr2_device_timings elpida_2G_S4_timings = { + .ac_timings = elpida_ac_timings, + .min_tck = &min_tck_elpida, +}; + +void emif_get_device_timings_sdp(u32 emif_nr, + const struct lpddr2_device_timings **cs0_device_timings, + const struct lpddr2_device_timings **cs1_device_timings) +{ + u32 omap_rev = omap_revision(); + + /* Identical devices on EMIF1 & EMIF2 */ + *cs0_device_timings = &elpida_2G_S4_timings; + + if (omap_rev == OMAP4430_ES1_0) + *cs1_device_timings = NULL; + else + *cs1_device_timings = &elpida_2G_S4_timings; +} + +void emif_get_device_timings(u32 emif_nr, + const struct lpddr2_device_timings **cs0_device_timings, + const struct lpddr2_device_timings **cs1_device_timings) + __attribute__((weak, alias("emif_get_device_timings_sdp"))); + +#endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */ diff --git a/arch/arm/include/asm/arch-omap4/emif.h b/arch/arm/include/asm/arch-omap4/emif.h index 09e9baa..a167508 100644 --- a/arch/arm/include/asm/arch-omap4/emif.h +++ b/arch/arm/include/asm/arch-omap4/emif.h @@ -1019,7 +1019,16 @@ struct emif_regs { #define emif_assert(c) ({ if (0) hang(); }) #endif
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs); void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs); +#else +void emif_get_device_details(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details); +void emif_get_device_timings(u32 emif_nr, + const struct lpddr2_device_timings **cs0_device_timings, + const struct lpddr2_device_timings **cs1_device_timings); +#endif
#endif diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index c9c86e1..a8dbedb 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -84,12 +84,6 @@ /* GPMC */ #define OMAP44XX_GPMC_BASE 0x50000000
-/* DMM */ -#define OMAP44XX_DMM_BASE 0x4E000000 -#define DMM_LISA_MAP_BASE (OMAP44XX_DMM_BASE + 0x40) -#define DMM_LISA_MAP_SYS_SIZE_MASK (7 << 20) -#define DMM_LISA_MAP_SYS_SIZE_SHIFT 20 -#define DMM_LISA_MAP_SYS_ADDR_MASK (0xFF << 24) /* * Hardware Register Details */ @@ -137,6 +131,10 @@ struct s32ktimer { #define SRAM_SCRATCH_SPACE_ADDR NON_SECURE_SRAM_START /* SRAM scratch space entries */ #define OMAP4_SRAM_SCRATCH_OMAP4_REV SRAM_SCRATCH_SPACE_ADDR +#define OMAP4_SRAM_SCRATCH_EMIF_SIZE (SRAM_SCRATCH_SPACE_ADDR + 0x4) +#define OMAP4_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0xC) +#define OMAP4_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) +#define OMAP4_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x14)
/* Silicon revisions */ #define OMAP4430_SILICON_ID_INVALID 0xFFFFFFFF diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 7183a90..1e62878 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -49,6 +49,7 @@ void bypass_dpll(u32 *const base); void freq_update_core(void); u32 get_sys_clk_freq(void); u32 omap4_ddr_clk(void); +void cancel_out(u32 *num, u32 *den, u32 den_limit); void sdram_init(void); u32 omap4_sdram_size(void);
diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 1daffb7..9f82ef4 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -237,4 +237,9 @@ #define CONFIG_SYS_PL310_BASE 0x48242000 #endif
+/* Defines for SDRAM init */ +#ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS +#endif + #endif /* __CONFIG_H */ diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 68ffa87..6df1c3d 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -243,4 +243,9 @@ #define CONFIG_SYS_PL310_BASE 0x48242000 #endif
Identify SDRAM devices connected to EMIF automatically: LPDDR2 devices have some Mode Registers that provide details about the device such as the type, density, bus width etc. EMIF has the capability to read these registers. If there are no devices connected to a given chip-select reading mode registers will return junk values. After reading as many such registers as possible and matching with expected ranges of values the driver can identify if there is a device connected to the respective CS. If we identify that a device is connected the values read give us complete details about the device.
This along with the base AC timings specified by JESD209-2 allows us to do a complete automatic initialization of SDRAM that works on all boards.
Please note that the default AC timings specified by JESD209-2 will be safe for all devices but not necessarily optimal. However, for the Elpida devices used on Panda and SDP the default timings are both safe and optimal.
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Code re-organization for better readability * Ensured that un-necessary code is compiled out when CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION is not defined --- arch/arm/cpu/armv7/omap4/emif.c | 238 +++++++++++++++++++++++++++++++++++++++ include/configs/omap4_panda.h | 1 + include/configs/omap4_sdp4430.h | 1 + 3 files changed, 240 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index ceead9e..1234a7e 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -792,6 +792,244 @@ void emif_get_device_timings(u32 emif_nr, } #endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */
+#ifdef CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION +const char *get_lpddr2_type(u8 type_id) +{ + switch (type_id) { + case LPDDR2_TYPE_S4: + return "LPDDR2-S4"; + case LPDDR2_TYPE_S2: + return "LPDDR2-S2"; + default: + return NULL; + } +} + +const char *get_lpddr2_io_width(u8 width_id) +{ + switch (width_id) { + case LPDDR2_IO_WIDTH_8: + return "x8"; + case LPDDR2_IO_WIDTH_16: + return "x16"; + case LPDDR2_IO_WIDTH_32: + return "x32"; + default: + return NULL; + } +} + +const char *get_lpddr2_manufacturer(u32 manufacturer) +{ + switch (manufacturer) { + case LPDDR2_MANUFACTURER_SAMSUNG: + return "Samsung"; + case LPDDR2_MANUFACTURER_QIMONDA: + return "Qimonda"; + case LPDDR2_MANUFACTURER_ELPIDA: + return "Elpida"; + case LPDDR2_MANUFACTURER_ETRON: + return "Etron"; + case LPDDR2_MANUFACTURER_NANYA: + return "Nanya"; + case LPDDR2_MANUFACTURER_HYNIX: + return "Hynix"; + case LPDDR2_MANUFACTURER_MOSEL: + return "Mosel"; + case LPDDR2_MANUFACTURER_WINBOND: + return "Winbond"; + case LPDDR2_MANUFACTURER_ESMT: + return "ESMT"; + case LPDDR2_MANUFACTURER_SPANSION: + return "Spansion"; + case LPDDR2_MANUFACTURER_SST: + return "SST"; + case LPDDR2_MANUFACTURER_ZMOS: + return "ZMOS"; + case LPDDR2_MANUFACTURER_INTEL: + return "Intel"; + case LPDDR2_MANUFACTURER_NUMONYX: + return "Numonyx"; + case LPDDR2_MANUFACTURER_MICRON: + return "Micron"; + default: + return NULL; + } +} + +static void display_sdram_details(u32 emif_nr, u32 cs, + struct lpddr2_device_details *device) +{ + const char *mfg_str; + const char *type_str; + char density_str[10]; + u32 density; + + debug("EMIF%d CS%d\t", emif_nr, cs); + + if (!device) { + debug("None\n"); + return; + } + + mfg_str = get_lpddr2_manufacturer(device->manufacturer); + type_str = get_lpddr2_type(device->type); + + density = lpddr2_density_2_size_in_mbytes[device->density]; + if ((density / 1024 * 1024) == density) { + density /= 1024; + sprintf(density_str, "%d GB", density); + } else + sprintf(density_str, "%d MB", density); + if (mfg_str && type_str) + debug("%s\t\t%s\t%s\n", mfg_str, type_str, density_str); +} + +static u8 is_lpddr2_sdram_present(u32 base, u32 cs, + struct lpddr2_device_details *lpddr2_device) +{ + u32 mr = 0, temp; + + mr = get_mr(base, cs, LPDDR2_MR0); + if (mr > 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + temp = (mr & LPDDR2_MR0_DI_MASK) >> LPDDR2_MR0_DI_SHIFT; + if (temp) { + /* Not SDRAM */ + return 0; + } + temp = (mr & LPDDR2_MR0_DNVI_MASK) >> LPDDR2_MR0_DNVI_SHIFT; + + if (temp) { + /* DNV supported - But DNV is only supported for NVM */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR4); + if (mr > 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR5); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + if (!get_lpddr2_manufacturer(mr)) { + /* Manufacturer not identified */ + return 0; + } + lpddr2_device->manufacturer = mr; + + mr = get_mr(base, cs, LPDDR2_MR6); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR7); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR8); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + temp = (mr & MR8_TYPE_MASK) >> MR8_TYPE_SHIFT; + if (!get_lpddr2_type(temp)) { + /* Not SDRAM */ + return 0; + } + lpddr2_device->type = temp; + + temp = (mr & MR8_DENSITY_MASK) >> MR8_DENSITY_SHIFT; + if (temp > LPDDR2_DENSITY_32Gb) { + /* Density not supported */ + return 0; + } + lpddr2_device->density = temp; + + temp = (mr & MR8_IO_WIDTH_MASK) >> MR8_IO_WIDTH_SHIFT; + if (!get_lpddr2_io_width(temp)) { + /* IO width unsupported value */ + return 0; + } + lpddr2_device->io_width = temp; + + /* + * If all the above tests pass we should + * have a device on this chip-select + */ + return 1; +} + +static struct lpddr2_device_details *get_lpddr2_details(u32 base, u8 cs, + struct lpddr2_device_details *lpddr2_dev_details) +{ + u32 phy; + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + if (!lpddr2_dev_details) + return NULL; + + /* Do the minimum init for mode register accesses */ + if (!running_from_sdram()) { + phy = get_ddr_phy_ctrl_1(get_sys_clk_freq() / 2, RL_BOOT); + writel(phy, &emif->emif_ddr_phy_ctrl_1); + } + + if (!(is_lpddr2_sdram_present(base, cs, lpddr2_dev_details))) + return NULL; + + display_sdram_details(emif_num(base), cs, lpddr2_dev_details); + + return lpddr2_dev_details; +} + +void emif_get_device_details(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details) +{ + u32 base = (emif_nr == 1) ? OMAP44XX_EMIF1 : OMAP44XX_EMIF2; + + if (running_from_sdram()) { + /* + * We can not do automatic discovery running from SDRAM + * Most likely we came here by mistake. Indicate error + * by returning NULL + */ + cs0_device_details = NULL; + cs1_device_details = NULL; + } else { + /* + * Automatically find the device details: + * + * Reset the PHY after each call to get_lpddr2_details(). + * If there is nothing connected to a given chip select + * (typically CS1) mode register reads will mess up with + * the PHY state and subsequent initialization won't work. + * PHY reset brings back PHY to a good state. + */ + cs0_device_details = + get_lpddr2_details(base, CS0, cs0_device_details); + emif_reset_phy(base); + + cs1_device_details = + get_lpddr2_details(base, CS1, cs1_device_details); + emif_reset_phy(base); + } +} +#endif /* CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION */ + static void do_sdram_init(u32 base) { const struct emif_regs *regs; diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 9f82ef4..a8dd861 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -239,6 +239,7 @@
/* Defines for SDRAM init */ #ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS #endif
diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 6df1c3d..534f89a 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -245,6 +245,7 @@
- Allow SPL to have .bss disjoint from rest of the image - Allow for .bss setup in CONFIG_SPL_BUILD case too. - Take care of the special case where relocation offset = 0. - Compile out exception handling code and install a simpler vector
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Taken care of the case where .bss is at a lower address comapred to _start --- arch/arm/cpu/armv7/start.S | 50 ++++++++++++++++++++++++++++++---------- arch/arm/cpu/armv7/u-boot.lds | 2 + 2 files changed, 39 insertions(+), 13 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index d2a6207..5be436f 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -42,7 +42,16 @@ _start: b reset ldr pc, _not_used ldr pc, _irq ldr pc, _fiq - +#ifdef CONFIG_SPL_BUILD +_undefined_instruction: .word _undefined_instruction +_software_interrupt: .word _software_interrupt +_prefetch_abort: .word _prefetch_abort +_data_abort: .word _data_abort +_not_used: .word _not_used +_irq: .word _irq +_fiq: .word _fiq +_pad: .word 0x12345678 /* now 16*4=64 */ +#else _undefined_instruction: .word undefined_instruction _software_interrupt: .word software_interrupt _prefetch_abort: .word prefetch_abort @@ -51,6 +60,8 @@ _not_used: .word not_used _irq: .word irq _fiq: .word fiq _pad: .word 0x12345678 /* now 16*4=64 */ +#endif /* CONFIG_SPL_BUILD */ + .global _end_vect _end_vect:
@@ -89,6 +100,10 @@ _armboot_start: _bss_start_ofs: .word __bss_start - _start
+.global _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -182,12 +197,11 @@ stack_setup: mov sp, r4
adr r0, _start -#ifndef CONFIG_SPL_BUILD cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ -#endif mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: @@ -235,20 +249,34 @@ fixnext: add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ cmp r2, r3 blo fixloop + b clear_bss +_rel_dyn_start_ofs: + .word __rel_dyn_start - _start +_rel_dyn_end_ofs: + .word __rel_dyn_end - _start +_dynsym_start_ofs: + .word __dynsym_start - _start + +#endif /* #ifndef CONFIG_SPL_BUILD */
clear_bss: +#ifdef CONFIG_SPL_BUILD + /* No relocation for SPL */ + ldr r0, =__bss_start + ldr r1, =__bss_end__ +#else ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 +#endif mov r2, #0x00000000 /* clear */
clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 bne clbss_l -#endif /* #ifndef CONFIG_SPL_BUILD */
/* * We are done. Do not return, instead branch to second part of board @@ -276,13 +304,6 @@ jump_2_ram: _board_init_r_ofs: .word board_init_r - _start
-_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - /************************************************************************* * * CPU_init_critical registers @@ -327,6 +348,8 @@ cpu_init_crit: bl lowlevel_init @ go setup pll,mux,memory mov lr, ip @ restore link mov pc, lr @ back to my caller + +#ifndef CONFIG_SPL_BUILD /* ************************************************************************* * @@ -514,4 +537,5 @@ fiq: bad_save_user_regs bl do_fiq
-#endif +#endif /* CONFIG_USE_IRQ */ +#endif /* CONFIG_SPL_BUILD */ diff --git a/arch/arm/cpu/armv7/u-boot.lds b/arch/arm/cpu/armv7/u-boot.lds index dbae54d..40ecf78 100644 --- a/arch/arm/cpu/armv7/u-boot.lds +++ b/arch/arm/cpu/armv7/u-boot.lds @@ -55,6 +55,8 @@ SECTIONS
. = ALIGN(4);
+ __image_copy_end = .; + .rel.dyn : { __rel_dyn_start = .; *(.rel*)
- Provide alternate implementations of board_init_f() board_init_r() for OMAP spl. - Provide linker script - Initialize global data - Add serial console support - Update CONFIG_SYS_TEXT_BASE to allow for SPL's bss and move it to board config header from config.mk
This patch adds two checkpatch warnings that look like false positives. Reported these to checkpatch maintainer.
V2: * Removed the label __flash_image_end because _end serves the same purpose after rebasing to latest mainline
V3: * Moved CONFIG_SYS_TEXT_BASE to board config header and deleted config.mk * Changes for the struct based register accesses * Removed usage of modify_reg_32() macro * omap4_rev_string() reference changed to omap_rev_string() * Folded the patches for linker script changes and console support into this patch * Improved commit message --- arch/arm/cpu/armv7/Makefile | 7 ++- arch/arm/cpu/armv7/omap-common/Makefile | 4 + arch/arm/cpu/armv7/omap-common/spl.c | 82 +++++++++++++++++++++++++ arch/arm/cpu/armv7/omap-common/u-boot-spl.lds | 62 +++++++++++++++++++ arch/arm/cpu/armv7/omap4/Makefile | 5 +- arch/arm/cpu/armv7/omap4/board.c | 7 ++ arch/arm/cpu/armv7/omap4/clocks.c | 33 ++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + arch/arm/include/asm/omap_common.h | 2 + board/ti/panda/Makefile | 2 + board/ti/panda/config.mk | 31 --------- board/ti/sdp4430/Makefile | 2 + board/ti/sdp4430/config.mk | 31 --------- include/configs/omap4_panda.h | 26 ++++++++ include/configs/omap4_sdp4430.h | 26 ++++++++ 15 files changed, 257 insertions(+), 64 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/spl.c create mode 100644 arch/arm/cpu/armv7/omap-common/u-boot-spl.lds delete mode 100644 board/ti/panda/config.mk delete mode 100644 board/ti/sdp4430/config.mk
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index 299792a..92a5a96 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -26,7 +26,12 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).o
START := start.o -COBJS := cpu.o cache_v7.o + +ifndef CONFIG_SPL_BUILD +COBJS += cache_v7.o +COBJS += cpu.o +endif + COBJS += syslib.o
SRCS := $(START:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index 8f698f8..0708796 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -30,6 +30,10 @@ SOBJS := reset.o COBJS := timer.o COBJS += utils.o
+ifdef CONFIG_SPL_BUILD +COBJS += spl.o +endif + SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS))
diff --git a/arch/arm/cpu/armv7/omap-common/spl.c b/arch/arm/cpu/armv7/omap-common/spl.c new file mode 100644 index 0000000..166d7eb --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/spl.c @@ -0,0 +1,82 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/u-boot.h> +#include <asm/arch/sys_proto.h> +#include <timestamp_autogenerated.h> +#include <version_autogenerated.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Define global data structure pointer to it*/ +static gd_t gdata __attribute__ ((section(".data"))); +static bd_t bdata __attribute__ ((section(".data"))); + +inline void hang(void) +{ + puts("### ERROR ### Please RESET the board ###\n"); + for (;;) + ; +} + +void board_init_f(ulong dummy) +{ + /* + * We call relocate_code() with relocation target same as the + * CONFIG_SYS_SPL_TEXT_BASE. This will result in relocation getting + * skipped. Instead, only .bss initialization will happen. That's + * all we need + */ + debug(">>board_init_f()\n"); + relocate_code(CONFIG_SYS_SPL_STACK, &gdata, CONFIG_SYS_SPL_TEXT_BASE); +} + +void board_init_r(gd_t *id, ulong dummy) +{ + for (;;) + ; +} + +void preloader_console_init(void) +{ + const char *u_boot_rev = U_BOOT_VERSION; + char omap4_rev_string[50]; + + gd = &gdata; + gd->bd = &bdata; + gd->flags |= GD_FLG_RELOC; + gd->baudrate = CONFIG_BAUDRATE; + + setup_clocks_for_console(); + serial_init(); /* serial communications setup */ + + /* Avoid a second "U-Boot" coming from this string */ + u_boot_rev = &u_boot_rev[7]; + + printf("\nU-Boot SPL %s (%s - %s)\n", u_boot_rev, U_BOOT_DATE, + U_BOOT_TIME); + omap_rev_string(omap4_rev_string); + printf("Texas Instruments %s\n", omap4_rev_string); +} diff --git a/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds b/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds new file mode 100644 index 0000000..1f944a7 --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds @@ -0,0 +1,62 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +MEMORY { .sram : ORIGIN = CONFIG_SYS_SPL_TEXT_BASE,\ + LENGTH = CONFIG_SYS_SPL_MAX_SIZE } +MEMORY { .sdram : ORIGIN = CONFIG_SYS_SPL_BSS_START_ADDR, \ + LENGTH = CONFIG_SYS_SPL_BSS_MAX_SIZE } + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + .text : + { + __start = .; + arch/arm/cpu/armv7/start.o (.text) + *(.text*) + } >.sram + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(.rodata*)) } >.sram + + . = ALIGN(4); + .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram + . = ALIGN(4); + __image_copy_end = .; + _end = .; + + .bss : + { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + __bss_end__ = .; + } >.sdram +} diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index e1ccd68..e7ee0b8 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -30,9 +30,12 @@ SOBJS += lowlevel_init.o COBJS += board.o COBJS += clocks.o COBJS += emif.o -COBJS += mem.o COBJS += sdram_elpida.o + +ifndef CONFIG_SPL_BUILD +COBJS += mem.o COBJS += sys_info.o +endif
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 786c239..54dd509 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -155,7 +155,14 @@ void s_init(void) init_omap4_revision(); watchdog_init(); set_mux_conf_regs(); +#ifdef CONFIG_SPL_BUILD + preloader_console_init(); +#endif prcm_init(); +#ifdef CONFIG_SPL_BUILD + /* For regular u-boot sdram_init() is called from dram_init() */ + sdram_init(); +#endif }
/* diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c index e8d3a52..f1e233a 100644 --- a/arch/arm/cpu/armv7/omap4/clocks.c +++ b/arch/arm/cpu/armv7/omap4/clocks.c @@ -791,6 +791,39 @@ void lock_dpll(u32 *const base) wait_for_lock(base); }
+void setup_clocks_for_console(void) +{ + /* Do not add any spl_debug prints in this function */ + clrsetbits_le32(&prcm->cm_l4per_clkstctrl, CD_CLKCTRL_CLKTRCTRL_MASK, + CD_CLKCTRL_CLKTRCTRL_SW_WKUP << + CD_CLKCTRL_CLKTRCTRL_SHIFT); + + /* Enable all UARTs - console will be on one of them */ + clrsetbits_le32(&prcm->cm_l4per_uart1_clkctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + + clrsetbits_le32(&prcm->cm_l4per_uart2_clkctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + + clrsetbits_le32(&prcm->cm_l4per_uart3_clkctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + + clrsetbits_le32(&prcm->cm_l4per_uart3_clkctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + + clrsetbits_le32(&prcm->cm_l4per_clkstctrl, CD_CLKCTRL_CLKTRCTRL_MASK, + CD_CLKCTRL_CLKTRCTRL_HW_AUTO << + CD_CLKCTRL_CLKTRCTRL_SHIFT); +} + void prcm_init(void) { switch (omap4_hw_init_context()) { diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 1e62878..a81f8e5 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -44,6 +44,7 @@ u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); void set_pl310_ctrl_reg(u32 val); void omap_rev_string(char *omap4_rev_string); +void setup_clocks_for_console(void); void prcm_init(void); void bypass_dpll(u32 *const base); void freq_update_core(void); diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 33caa4e..69d53d2 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -34,4 +34,6 @@ #define OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL 2 #define OMAP_INIT_CONTEXT_UBOOT_AFTER_CH 3
+void preloader_console_init(void); + #endif /* _OMAP_COMMON_H_ */ diff --git a/board/ti/panda/Makefile b/board/ti/panda/Makefile index 2186403..09f88ee 100644 --- a/board/ti/panda/Makefile +++ b/board/ti/panda/Makefile @@ -25,7 +25,9 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
+ifndef CONFIG_SPL_BUILD COBJS := panda.o +endif
SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/ti/panda/config.mk b/board/ti/panda/config.mk deleted file mode 100644 index 33901a7..0000000 --- a/board/ti/panda/config.mk +++ /dev/null @@ -1,31 +0,0 @@ -# -# (C) Copyright 2006-2009 -# Texas Instruments Incorporated, <www.ti.com> -# -# OMAP 4430 SDP -# see http://www.ti.com/ for more information on Texas Instruments -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -# SDRAM Address Space: -# 8000'0000 - 9fff'ffff (512 MB) -# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 -# (mem base + reserved) - -CONFIG_SYS_TEXT_BASE = 0x80e80000 diff --git a/board/ti/sdp4430/Makefile b/board/ti/sdp4430/Makefile index f1ee544..12f2743 100644 --- a/board/ti/sdp4430/Makefile +++ b/board/ti/sdp4430/Makefile @@ -25,7 +25,9 @@ include $(TOPDIR)/config.mk
+ifndef CONFIG_SPL_BUILD COBJS := sdp.o cmd_bat.o +endif
SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/ti/sdp4430/config.mk b/board/ti/sdp4430/config.mk deleted file mode 100644 index 33901a7..0000000 --- a/board/ti/sdp4430/config.mk +++ /dev/null @@ -1,31 +0,0 @@ -# -# (C) Copyright 2006-2009 -# Texas Instruments Incorporated, <www.ti.com> -# -# OMAP 4430 SDP -# see http://www.ti.com/ for more information on Texas Instruments -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -# SDRAM Address Space: -# 8000'0000 - 9fff'ffff (512 MB) -# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 -# (mem base + reserved) - -CONFIG_SYS_TEXT_BASE = 0x80e80000 diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index a8dd861..3244fc1 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -243,4 +243,30 @@ #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS #endif
+/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SYS_SPL_TEXT_BASE 0x40304350 +#define CONFIG_SYS_SPL_MAX_SIZE 0x8000 /* 32 K */ +#define CONFIG_SYS_SPL_STACK LOW_LEVEL_SRAM_STACK + +#define CONFIG_SYS_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SYS_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SYS_SPL_LDSCRIPT "arch/arm/cpu/armv7/omap-common/u-boot-spl.lds" + +/* + * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM + * 64 bytes before this address should be set aside for u-boot.img's + * header. That is 0x800FFFC0--0x80100000 should not be used for any + * other needs. + */ +#define CONFIG_SYS_TEXT_BASE 0x80100000 + #endif /* __CONFIG_H */ diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 534f89a..5c486c3 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -249,4 +249,30 @@ #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS #endif
Hi Aneesh,
Does this work? The SPL framework patches currently use
ifneq ($(CONFIG_SPL_TEXT_BASE),) CPPFLAGS += -DCONFIG_SPL_TEXT_BASE=$(CONFIG_SPL_TEXT_BASE) endif
But CONFIG_SYS_SPL_TEXT_BASE seems to be the right name for this option. Shall I fix it in the SPL framework patches?
- 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM
- 64 bytes before this address should be set aside for u-boot.img's
- header. That is 0x800FFFC0--0x80100000 should not be used for any
- other needs.
- #endif /* __CONFIG_H */
- other needs.
On Saturday 16 July 2011 07:06 PM, Daniel Schwierzeck wrote:
Hi Aneesh,
Hmm.. Good catch. I think it was still working for me because I had this in my linker script:
MEMORY { .sram : ORIGIN = CONFIG_SYS_SPL_TEXT_BASE,\ LENGTH = CONFIG_SYS_SPL_MAX_SIZE }
And then I was using the .sram region for rest of the script.
I think this over-rides the -Ttext on the linker command line.
Yes, looks like CONFIG_SYS_SPL_TEXT_BASE is the right name. For u-boot we have CONFIG_SYS_TEXT_BASE
I don't know if Daniel wants to do this himself. As long as you are working on omap and use my linker script, you may still be able to work without any compilation error.
If the framework is going to retain CONFIG_SPL_TEXT_BASE I shall re-submit my patch.
best regards, Aneesh
Hi Aneesh,
Oops! Terrible mix-up!! I took your mail to be from Simon and hence the above confusion:-)
Yes, fixing this in the framework series seems to be the right thing. Thanks.
Dear Daniel Schwierzeck,
This is getting a very long name - and if we do this, we probably have to rename a few other CONFIG_SPL_* into CONFIG_SYS_SPL_* as well.
If you are not really, really convinced this must be renamed I suggest we stick with the shorter CONFIG_SPL_TEXT_BASE instead...
Thanks.
Dear Wolfgang,
ok I won't change the SPL patches. So CONFIG_SPL_* is the new prefix for all SPL specific config options?
Best regards, Daniel
On Monday 18 July 2011 03:12 PM, Daniel Schwierzeck wrote:
Dear Wolfgang,
Ok. I will change my patch to use CONFIG_SPL_TEXT_BASE then.
br, Aneesh
In message CACUy__WZKkYGB9PWu7hTBqBSFV5FD43+E78nD1JQA9pdqoFbPA@mail.gmail.com you wrote:
I'm fine with that.
Hi Aneesh,
On Sat, 16 Jul 2011 18:23:19 +0530 Aneesh V aneesh@ti.com wrote:
- omap4_rev_string() reference changed to omap_rev_string()
- char omap4_rev_string[50];
[snip]
- printf("\nU-Boot SPL %s (%s - %s)\n", u_boot_rev,
U_BOOT_DATE,
U_BOOT_TIME);
- omap_rev_string(omap4_rev_string);
- printf("Texas Instruments %s\n", omap4_rev_string);
Shouldn't also the omap4_rev_string be renamed to omap_rev_string?
Regards Simon
Hi Simon,
On Monday 18 July 2011 06:51 PM, Simon Schwarz wrote:
Hi Aneesh,
[snip]
U_BOOT_DATE,
U_BOOT_TIME);
Just the name of the local variable. But will fix it anyway in the next revision.
br, Aneesh
Provide appropriate '-O u-boot' while doing mkimage for u-boot.img
Signed-off-by: Aneesh V aneesh@ti.com --- Makefile | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/Makefile b/Makefile index 0707036..f8ae883 100644 --- a/Makefile +++ b/Makefile @@ -375,7 +375,7 @@ $(obj)u-boot.ldr.srec: $(obj)u-boot.ldr
$(obj)u-boot.img: $(obj)u-boot.bin $(obj)tools/mkimage -A $(ARCH) -T firmware -C none \ - -a $(CONFIG_SYS_TEXT_BASE) -e 0 \ + -O u-boot -a $(CONFIG_SYS_TEXT_BASE) -e 0 \ -n $(shell sed -n -e 's/.*U_BOOT_VERSION//p' $(VERSION_FILE) | \ sed -e 's/"[ ]*$$/ for $(BOARD) board"/') \ -d $< $@
- Add MMC raw and FAT mode boot support for OMAP - Provide a means by which parameters passed by ROM-code can be saved in u-boot. - Save boot mode related information passed by OMAP4 ROM-code and use it to determine where to load the u-boot from - Assumes that the image has a mkimage header. Gets the payload size and load address from this header. If the header is not detected assume u-boot.bin as payload
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Squashed the patches that provided MMC support, FAT support, start.S hook for saving parameters, and OMAP4 patch for saving the parameters all into this patch. * Removed the assumption that payload is u-boot.bin. Payload size and address --- arch/arm/cpu/armv7/cpu.c | 7 + arch/arm/cpu/armv7/omap-common/spl.c | 194 +++++++++++++++++++++++++++++- arch/arm/cpu/armv7/omap4/board.c | 21 ++++ arch/arm/cpu/armv7/omap4/lowlevel_init.S | 31 +++++ arch/arm/cpu/armv7/start.S | 1 + arch/arm/include/asm/arch-omap4/omap4.h | 8 ++ arch/arm/include/asm/omap_common.h | 17 +++ include/configs/omap4_panda.h | 5 + include/configs/omap4_sdp4430.h | 5 + 9 files changed, 287 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/cpu.c b/arch/arm/cpu/armv7/cpu.c index def9ced..091e3e0 100644 --- a/arch/arm/cpu/armv7/cpu.c +++ b/arch/arm/cpu/armv7/cpu.c @@ -37,6 +37,13 @@ #include <asm/cache.h> #include <asm/armv7.h>
+void save_boot_params_default(u32 r0, u32 r1, u32 r2, u32 r3) +{ +} + +void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) + __attribute__((weak, alias("save_boot_params_default"))); + int cleanup_before_linux(void) { /* diff --git a/arch/arm/cpu/armv7/omap-common/spl.c b/arch/arm/cpu/armv7/omap-common/spl.c index 166d7eb..f326f9a 100644 --- a/arch/arm/cpu/armv7/omap-common/spl.c +++ b/arch/arm/cpu/armv7/omap-common/spl.c @@ -24,15 +24,27 @@ */ #include <common.h> #include <asm/u-boot.h> +#include <asm/utils.h> #include <asm/arch/sys_proto.h> +#include <mmc.h> +#include <fat.h> #include <timestamp_autogenerated.h> #include <version_autogenerated.h> +#include <asm/omap_common.h> +#include <asm/arch/mmc_host_def.h> +#include <i2c.h> +#include <image.h>
/* Define global data structure pointer to it*/ static gd_t gdata __attribute__ ((section(".data"))); static bd_t bdata __attribute__ ((section(".data"))); +static const char *image_name; +static u8 image_os; +static u32 image_load_addr; +static u32 image_entry_point; +static u32 image_size;
inline void hang(void) { @@ -53,10 +65,188 @@ void board_init_f(ulong dummy) relocate_code(CONFIG_SYS_SPL_STACK, &gdata, CONFIG_SYS_SPL_TEXT_BASE); }
+#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + switch (omap_boot_device()) { + case BOOT_DEVICE_MMC1: + omap_mmc_init(0); + break; + case BOOT_DEVICE_MMC2: + omap_mmc_init(1); + break; + } + return 0; +} +#endif + +static void parse_image_header(const struct image_header *header) +{ + u32 header_size = sizeof(struct image_header); + + if (__be32_to_cpu(header->ih_magic) == IH_MAGIC) { + image_size = __be32_to_cpu(header->ih_size) + header_size; + image_entry_point = __be32_to_cpu(header->ih_load); + /* Load including the header */ + image_load_addr = image_entry_point - header_size; + image_os = header->ih_os; + image_name = (const char *)&header->ih_name; + debug("spl: payload image: %s load addr: 0x%x size: %d\n", + image_name, image_load_addr, image_size); + } else { + /* Signature not found - assume u-boot.bin */ + printf("mkimage signature not found - ih_magic = %x\n", + header->ih_magic); + puts("Assuming u-boot.bin ..\n"); + /* Let's assume U-Boot will not be more than 200 KB */ + image_size = 200 * 1024; + image_entry_point = CONFIG_SYS_TEXT_BASE; + image_load_addr = CONFIG_SYS_TEXT_BASE; + image_os = IH_OS_U_BOOT; + image_name = "U-Boot"; + } +} + +static void mmc_load_image_raw(struct mmc *mmc) +{ + u32 image_size_sectors, err; + const struct image_header *header; + + header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - + sizeof(struct image_header)); + + /* read image header to find the image size & load address */ + err = mmc->block_dev.block_read(0, + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR, 1, + (void *)header); + + if (err <= 0) + goto end; + + parse_image_header(header); + + /* convert size to sectors - round up */ + image_size_sectors = (image_size + MMCSD_SECTOR_SIZE - 1) / + MMCSD_SECTOR_SIZE; + + /* Read the header too to avoid extra memcpy */ + err = mmc->block_dev.block_read(0, + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR, + image_size_sectors, (void *)image_load_addr); + +end: + if (err <= 0) { + printf("spl: mmc blk read err - %d\n", err); + hang(); + } +} + +static void mmc_load_image_fat(struct mmc *mmc) +{ + s32 err; + struct image_header *header; + + header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - + sizeof(struct image_header)); + + err = fat_register_device(&mmc->block_dev, + CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION); + if (err) { + printf("spl: fat register err - %d\n", err); + hang(); + } + + err = file_fat_read(CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, + (u8 *)header, sizeof(struct image_header)); + if (err <= 0) + goto end; + + parse_image_header(header); + + err = file_fat_read(CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, + (u8 *)image_load_addr, 0); + +end: + if (err <= 0) { + printf("spl: error reading image %s, err - %d\n", + CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, err); + hang(); + } +} + +static void mmc_load_image(void) +{ + struct mmc *mmc; + int err; + u32 boot_mode; + + mmc_initialize(gd->bd); + /* We register only one device. So, the dev id is always 0 */ + mmc = find_mmc_device(0); + if (!mmc) { + puts("spl: mmc device not found!!\n"); + hang(); + } + + err = mmc_init(mmc); + if (err) { + printf("spl: mmc init failed: err - %d\n", err); + hang(); + } + + boot_mode = omap_boot_mode(); + if (boot_mode == MMCSD_MODE_RAW) { + debug("boot mode - RAW\n"); + mmc_load_image_raw(mmc); + } else if (boot_mode == MMCSD_MODE_FAT) { + debug("boot mode - FAT\n"); + mmc_load_image_fat(mmc); + } else { + puts("spl: wrong MMC boot mode\n"); + hang(); + } +} + +void jump_to_image_no_args(void) +{ + typedef void (*image_entry_noargs_t)(void)__attribute__ ((noreturn)); + image_entry_noargs_t image_entry = + (image_entry_noargs_t) image_entry_point; + + image_entry(); +} + +void jump_to_image_no_args(void) __attribute__ ((noreturn)); void board_init_r(gd_t *id, ulong dummy) { - for (;;) - ; + u32 boot_device; + debug(">>spl:board_init_r()\n"); + + timer_init(); + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + + boot_device = omap_boot_device(); + debug("boot device - %d\n", boot_device); + switch (boot_device) { + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: + mmc_load_image(); + break; + default: + printf("SPL: Un-supported Boot Device - %d!!!\n", boot_device); + hang(); + break; + } + + switch (image_os) { + case IH_OS_U_BOOT: + debug("Jumping to U-Boot\n"); + jump_to_image_no_args(); + break; + default: + puts("Unsupported OS image.. Jumping nevertheless..\n"); + jump_to_image_no_args(); + } }
void preloader_console_init(void) diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 54dd509..2e5739a 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -39,6 +39,27 @@ DECLARE_GLOBAL_DATA_PTR;
u32 *const omap4_revision = (u32 *)OMAP4_SRAM_SCRATCH_OMAP4_REV;
+#ifdef CONFIG_SPL_BUILD +/* + * We use static variables because global data is not ready yet. + * Initialized data is available in SPL right from the beginning. + * We would not typically need to save these parameters in regular + * U-Boot. This is needed only in SPL at the moment. + */ +u32 omap4_boot_device = BOOT_DEVICE_MMC1; +u32 omap4_boot_mode = MMCSD_MODE_FAT; + +u32 omap_boot_device(void) +{ + return omap4_boot_device; +} + +u32 omap_boot_mode(void) +{ + return omap4_boot_mode; +} +#endif + void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) { int i; diff --git a/arch/arm/cpu/armv7/omap4/lowlevel_init.S b/arch/arm/cpu/armv7/omap4/lowlevel_init.S index 6abfbba..91525ec 100644 --- a/arch/arm/cpu/armv7/omap4/lowlevel_init.S +++ b/arch/arm/cpu/armv7/omap4/lowlevel_init.S @@ -27,6 +27,37 @@ */
#include <asm/arch/omap4.h> +#ifdef CONFIG_SPL_BUILD +.global save_boot_params +save_boot_params: + /* + * See if the rom code passed pointer is valid: + * It is not valid if it is not in non-secure SRAM + * This may happen if you are booting with the help of + * debugger + */ + ldr r2, =NON_SECURE_SRAM_START + cmp r2, r0 + bgt 1f + ldr r2, =NON_SECURE_SRAM_END + cmp r2, r0 + blt 1f + + /* Store the boot device in omap4_boot_device */ + ldr r2, [r0, #BOOT_DEVICE_OFFSET] @ r1 <- value of boot device + and r2, #BOOT_DEVICE_MASK + ldr r3, =omap4_boot_device + str r2, [r3] @ omap4_boot_device <- r1 + + /* Store the boot mode (raw/FAT) in omap4_boot_mode */ + ldr r2, [r0, #DEV_DESC_PTR_OFFSET] @ get the device descriptor ptr + ldr r2, [r2, #DEV_DATA_PTR_OFFSET] @ get the pDeviceData ptr + ldr r2, [r2, #BOOT_MODE_OFFSET] @ get the boot mode + ldr r3, =omap4_boot_mode + str r2, [r3] +1: + bx lr +#endif
.globl lowlevel_init lowlevel_init: diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 5be436f..89ea01f 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -134,6 +134,7 @@ IRQ_STACK_START_IN: */
reset: + bl save_boot_params /* * set the cpu to SVC32 mode */ diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index a8dbedb..563544f 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -144,4 +144,12 @@ struct s32ktimer { #define OMAP4430_ES2_2 0x44300220 #define OMAP4430_ES2_3 0x44300230
+/* ROM code defines */ +/* Boot device */ +#define BOOT_DEVICE_MASK 0xFF +#define BOOT_DEVICE_OFFSET 0x8 +#define DEV_DESC_PTR_OFFSET 0x4 +#define DEV_DATA_PTR_OFFSET 0x18 +#define BOOT_MODE_OFFSET 0x8 + #endif diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 69d53d2..d3cb857 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -36,4 +36,21 @@
+/* Boot device */ +#define BOOT_DEVICE_NONE 0 +#define BOOT_DEVICE_XIP 1 +#define BOOT_DEVICE_XIPWAIT 2 +#define BOOT_DEVICE_NAND 3 +#define BOOT_DEVICE_ONE_NAND 4 +#define BOOT_DEVICE_MMC1 5 +#define BOOT_DEVICE_MMC2 6 + +/* Boot type */ +#define MMCSD_MODE_UNDEFINED 0 +#define MMCSD_MODE_RAW 1 +#define MMCSD_MODE_FAT 2 + +u32 omap_boot_device(void); +u32 omap_boot_mode(void); + #endif /* _OMAP_COMMON_H_ */ diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 3244fc1..310c353 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -252,6 +252,11 @@ #define CONFIG_SYS_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SYS_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */
+#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" + #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBDISK_SUPPORT #define CONFIG_SPL_I2C_SUPPORT diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 5c486c3..57ffb3c 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -258,6 +258,11 @@ #define CONFIG_SYS_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SYS_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */
- Add mkimage support for OMAP boot image - Add support for OMAP boot image(MLO) generation in the new SPL framework
Signed-off-by: John Rigby john.rigby@linaro.org Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Fixed minor issue with casting away 'const'ness of pointers * Ensure lists are sorted alphabetically * Added an error message * Removed 'packed' attribute from structs * Fixed some other minor comments on V2 --- arch/arm/cpu/armv7/omap4/config.mk | 30 +++++ common/image.c | 9 +- include/image.h | 1 + spl/Makefile | 6 + tools/Makefile | 2 + tools/mkimage.c | 2 + tools/mkimage.h | 1 + tools/omapimage.c | 224 ++++++++++++++++++++++++++++++++++++ tools/omapimage.h | 50 ++++++++ 9 files changed, 321 insertions(+), 4 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/config.mk create mode 100644 tools/omapimage.c create mode 100644 tools/omapimage.h
diff --git a/arch/arm/cpu/armv7/omap4/config.mk b/arch/arm/cpu/armv7/omap4/config.mk new file mode 100644 index 0000000..b34fa64 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/config.mk @@ -0,0 +1,30 @@ +# +# Copyright 2011 Linaro Limited +# See file CREDITS for list of people who contributed to this +# project. +# +# (C) Copyright 2010 +# Texas Instruments, <www.ti.com> +# +# Aneesh V aneesh@ti.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +ifdef CONFIG_SPL_BUILD +ALL-y += $(OBJTREE)/MLO +else +ALL-y += $(obj)u-boot.img +endif diff --git a/common/image.c b/common/image.c index e542a57..a141904 100644 --- a/common/image.c +++ b/common/image.c @@ -130,17 +130,18 @@ static const table_entry_t uimage_os[] = { };
static const table_entry_t uimage_type[] = { - { IH_TYPE_INVALID, NULL, "Invalid Image", }, { IH_TYPE_FILESYSTEM, "filesystem", "Filesystem Image", }, { IH_TYPE_FIRMWARE, "firmware", "Firmware", }, + { IH_TYPE_FLATDT, "flat_dt", "Flat Device Tree", }, + { IH_TYPE_INVALID, NULL, "Invalid Image", }, + { IH_TYPE_IMXIMAGE, "imximage", "Freescale i.MX Boot Image",}, { IH_TYPE_KERNEL, "kernel", "Kernel Image", }, + { IH_TYPE_KWBIMAGE, "kwbimage", "Kirkwood Boot Image",}, { IH_TYPE_MULTI, "multi", "Multi-File Image", }, + { IH_TYPE_OMAPIMAGE, "omapimage", "TI OMAP SPL With GP CH",}, { IH_TYPE_RAMDISK, "ramdisk", "RAMDisk Image", }, { IH_TYPE_SCRIPT, "script", "Script", }, { IH_TYPE_STANDALONE, "standalone", "Standalone Program", }, - { IH_TYPE_FLATDT, "flat_dt", "Flat Device Tree", }, - { IH_TYPE_KWBIMAGE, "kwbimage", "Kirkwood Boot Image",}, - { IH_TYPE_IMXIMAGE, "imximage", "Freescale i.MX Boot Image",}, { -1, "", "", }, };
diff --git a/include/image.h b/include/image.h index c31e862..c606644 100644 --- a/include/image.h +++ b/include/image.h @@ -157,6 +157,7 @@ #define IH_TYPE_FLATDT 8 /* Binary Flat Device Tree Blob */ #define IH_TYPE_KWBIMAGE 9 /* Kirkwood Boot Image */ #define IH_TYPE_IMXIMAGE 10 /* Freescale IMXBoot Image */ +#define IH_TYPE_OMAPIMAGE 11 /* TI OMAP Config Header Image */
/* * Compression Types diff --git a/spl/Makefile b/spl/Makefile index fda4049..b9f4232 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -85,6 +85,12 @@ LDPPFLAGS += \ $(shell $(LD) --version | \ sed -ne 's/GNU ld version ([0-9][0-9]*).([0-9][0-9]*).*/-DLD_MAJOR=\1 -DLD_MINOR=\2/p')
+ifdef CONFIG_OMAP +$(OBJTREE)/MLO: $(obj)u-boot-spl.bin + $(OBJTREE)/tools/mkimage -T omapimage \ + -a $(CONFIG_SYS_SPL_TEXT_BASE) -d $< $@ +endif + ALL-y += $(obj)u-boot-spl.bin
all: $(ALL-y) diff --git a/tools/Makefile b/tools/Makefile index 97f83f8..cb7f92d 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -88,6 +88,7 @@ OBJ_FILES-$(CONFIG_CMD_LOADS) += img2srec.o OBJ_FILES-$(CONFIG_INCA_IP) += inca-swap-bytes.o NOPED_OBJ_FILES-y += kwbimage.o NOPED_OBJ_FILES-y += imximage.o +NOPED_OBJ_FILES-y += omapimage.o NOPED_OBJ_FILES-y += mkimage.o OBJ_FILES-$(CONFIG_NETCONSOLE) += ncb.o NOPED_OBJ_FILES-y += os_support.o @@ -188,6 +189,7 @@ $(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)md5.o \ $(obj)mkimage.o \ $(obj)os_support.o \ + $(obj)omapimage.o \ $(obj)sha1.o \ $(LIBFDT_OBJS) $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ diff --git a/tools/mkimage.c b/tools/mkimage.c index 60f7263..b6a7cb7 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -156,6 +156,8 @@ main (int argc, char **argv) init_imx_image_type (); /* Init FIT image generation/list support */ init_fit_image_type (); + /* Init TI OMAP Boot image generation/list support */ + init_omap_image_type(); /* Init Default image generation/list support */ init_default_image_type ();
diff --git a/tools/mkimage.h b/tools/mkimage.h index 9033a7d..3b49645 100644 --- a/tools/mkimage.h +++ b/tools/mkimage.h @@ -143,5 +143,6 @@ void init_kwb_image_type (void); void init_imx_image_type (void); void init_default_image_type (void); void init_fit_image_type (void); +void init_omap_image_type(void);
#endif /* _MKIIMAGE_H_ */ diff --git a/tools/omapimage.c b/tools/omapimage.c new file mode 100644 index 0000000..29d91cc --- /dev/null +++ b/tools/omapimage.c @@ -0,0 +1,224 @@ +/* + * (C) Copyright 2010 + * Linaro LTD, www.linaro.org + * Author: John Rigby john.rigby@linaro.org + * Based on TI's signGP.c + * + * (C) Copyright 2009 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * (C) Copyright 2008 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* Required to obtain the getline prototype from stdio.h */ +#define _GNU_SOURCE + +#include "mkimage.h" +#include <image.h> +#include "omapimage.h" + +/* Header size is CH header rounded up to 512 bytes plus GP header */ +#define OMAP_CH_HDR_SIZE 512 +#define OMAP_GP_HDR_SIZE (sizeof(struct gp_header)) +#define OMAP_FILE_HDR_SIZE (OMAP_CH_HDR_SIZE+OMAP_GP_HDR_SIZE) + +static uint8_t omapimage_header[OMAP_FILE_HDR_SIZE]; + +static int omapimage_check_image_types(uint8_t type) +{ + if (type == IH_TYPE_OMAPIMAGE) + return EXIT_SUCCESS; + else { + fprintf(stderr, "Unknown OMAP image type - %x", type); + return EXIT_FAILURE; + } +} + +/* + * Only the simplest image type is currently supported: + * TOC pointing to CHSETTINGS + * TOC terminator + * CHSETTINGS + * + * padding to OMAP_CH_HDR_SIZE bytes + * + * gp header + * size + * load_addr + */ +static int valid_gph_size(uint32_t size) +{ + return size; +} + +static int valid_gph_load_addr(uint32_t load_addr) +{ + return load_addr; +} + +static int omapimage_verify_header(unsigned char *ptr, int image_size, + struct mkimage_params *params) +{ + struct ch_toc *toc = (struct ch_toc *)ptr; + struct gp_header *gph = (struct gp_header *)(ptr+OMAP_CH_HDR_SIZE); + uint32_t offset, size; + + while (toc->section_offset != 0xffffffff + && toc->section_size != 0xffffffff) { + offset = toc->section_offset; + size = toc->section_size; + if (!offset || !size) + return -1; + if (offset >= OMAP_CH_HDR_SIZE || + offset+size >= OMAP_CH_HDR_SIZE) + return -1; + toc++; + } + if (!valid_gph_size(gph->size)) + return -1; + if (!valid_gph_load_addr(gph->load_addr)) + return -1; + + return 0; +} + +static void omapimage_print_section(struct ch_settings *chs) +{ + const char *section_name; + + if (chs->section_key) + section_name = "CHSETTINGS"; + else + section_name = "UNKNOWNKEY"; + + printf("%s (%x) " + "valid:%x " + "version:%x " + "reserved:%x " + "flags:%x\n", + section_name, + chs->section_key, + chs->valid, + chs->version, + chs->reserved, + chs->flags); +} + +static void omapimage_print_header(const void *ptr) +{ + const struct ch_toc *toc = (struct ch_toc *)ptr; + const struct gp_header *gph = + (struct gp_header *)(ptr+OMAP_CH_HDR_SIZE); + uint32_t offset, size; + + while (toc->section_offset != 0xffffffff + && toc->section_size != 0xffffffff) { + offset = toc->section_offset; + size = toc->section_size; + + if (offset >= OMAP_CH_HDR_SIZE || + offset+size >= OMAP_CH_HDR_SIZE) + exit(EXIT_FAILURE); + + printf("Section %s offset %x length %x\n", + toc->section_name, + toc->section_offset, + toc->section_size); + + omapimage_print_section((struct ch_settings *)(ptr+offset)); + toc++; + } + + if (!valid_gph_size(gph->size)) { + fprintf(stderr, + "Error: invalid image size %x\n", + gph->size); + exit(EXIT_FAILURE); + } + + if (!valid_gph_load_addr(gph->load_addr)) { + fprintf(stderr, + "Error: invalid image load address %x\n", + gph->size); + exit(EXIT_FAILURE); + } + + printf("GP Header: Size %x LoadAddr %x\n", + gph->size, gph->load_addr); +} + +static int toc_offset(void *hdr, void *member) +{ + return member - hdr; +} + +static void omapimage_set_header(void *ptr, struct stat *sbuf, int ifd, + struct mkimage_params *params) +{ + struct ch_toc *toc = (struct ch_toc *)ptr; + struct ch_settings *chs = (struct ch_settings *) + (ptr + 2 * sizeof(*toc)); + struct gp_header *gph = (struct gp_header *)(ptr + OMAP_CH_HDR_SIZE); + + toc->section_offset = toc_offset(ptr, chs); + toc->section_size = sizeof(struct ch_settings); + strcpy((char *)toc->section_name, "CHSETTINGS"); + + chs->section_key = KEY_CHSETTINGS; + chs->valid = 0; + chs->version = 1; + chs->reserved = 0; + chs->flags = 0; + + toc++; + memset(toc, 0xff, sizeof(*toc)); + + gph->size = sbuf->st_size - OMAP_FILE_HDR_SIZE; + gph->load_addr = params->addr; +} + +int omapimage_check_params(struct mkimage_params *params) +{ + return (params->dflag && (params->fflag || params->lflag)) || + (params->fflag && (params->dflag || params->lflag)) || + (params->lflag && (params->dflag || params->fflag)); +} + +/* + * omapimage parameters + */ +static struct image_type_params omapimage_params = { + .name = "TI OMAP CH/GP Boot Image support", + .header_size = OMAP_FILE_HDR_SIZE, + .hdr = (void *)&omapimage_header, + .check_image_type = omapimage_check_image_types, + .verify_header = omapimage_verify_header, + .print_header = omapimage_print_header, + .set_header = omapimage_set_header, + .check_params = omapimage_check_params, +}; + +void init_omap_image_type(void) +{ + mkimage_register(&omapimage_params); +} diff --git a/tools/omapimage.h b/tools/omapimage.h new file mode 100644 index 0000000..719db00 --- /dev/null +++ b/tools/omapimage.h @@ -0,0 +1,50 @@ +/* + * (C) Copyright 2010 + * Linaro LTD, www.linaro.org + * Author John Rigby john.rigby@linaro.org + * Based on TI's signGP.c + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _OMAPIMAGE_H_ +#define _OMAPIMAGE_H_ + +struct ch_toc { + uint32_t section_offset; + uint32_t section_size; + uint8_t unused[12]; + uint8_t section_name[12]; +}; + +struct ch_settings { + uint32_t section_key; + uint8_t valid; + uint8_t version; + uint16_t reserved; + uint32_t flags; +}; + +struct gp_header { + uint32_t size; + uint32_t load_addr; +}; + +#define KEY_CHSETTINGS 0xC0C0C0C1 +#endif /* _OMAPIMAGE_H_ */
This series adds mmc SPL support for OMAP4. This is essentially an up-streaming effort for TI's x-loader for OMAP4 using the SPL framework
This work partly draws upon previous work done for x-loader by: Santosh Shilimkar santosh.shilimkar@ti.com Rajendra Nayak rnayak@ti.com and many others
This series depends on the following series for the new SPL framework: http://marc.info/?l=u-boot&m=131056990001719&w=2
Features supported: * Clock init - DPLL locking, clock domains/modules enabling * SDRAM/DMM initialization * Mux initialization * MMC raw read support * MMC FAT read support
Improvments over x-loader: * Code completely revamped * DPLL programming that works for all SYS_CLK frequencies * Automatic SDRAM identification and initialization * Board dependent parts(especially mux) deferred to u-boot. So, same SPL will work for Panda and SDP and most likely on any other board that comes along * Flexible about the payload. Any image with a mkimage header can be loaded. * The core SPL logic is generic and available for OMAP3/4. So, OMAP3 platforms can easily extend this work to add SPL support for the respective boards.
V2: * Some fixes in SDRAM init, clock init * Use of pre-calculated M & N values for DPLL locking instead run-time calculation * Change in make files to allow reuse of common rules between boards * Console initialization moved further earlier in the boot allowing traces from even clock initialization code * Reuse utility macros from a previous series
V3: * Moved to the new SPL framework * struct based register access for clock init * Squashed together related patches as per Wolfgang's suggestions * Re-organization of code in sdram init for better readability * SPL loading the payload using mkimage header * Avoided using custom bit-field accessor macros * Several other minor changes(documented in respective patches)
V4: * Changed the CONFIG_SYS_SPL_* config flags to CONFIG_SPL_* * Changed the name omap4_rev_string used in spl.c as this file is common for OMAP3/4
Aneesh V (11): omap4: utility function to identify the context of hw init omap4: cleanup pin mux data omap4: add OMAP4430 revision check omap4: add clock support omap4: add sdram init support omap4: calculate EMIF register values omap4: automatic sdram detection armv7: start.S: fixes and enhancements for SPL omap: add basic SPL support Correct ih_os for u-boot.img omap: add MMC and FAT support to SPL
John Rigby (1): mkimage: Add OMAP boot image support
Makefile | 2 +- arch/arm/cpu/armv7/Makefile | 7 +- arch/arm/cpu/armv7/cpu.c | 7 + arch/arm/cpu/armv7/omap-common/Makefile | 5 + arch/arm/cpu/armv7/omap-common/spl.c | 272 ++++ arch/arm/cpu/armv7/omap-common/u-boot-spl.lds | 62 + arch/arm/cpu/armv7/omap-common/utils.c | 57 + arch/arm/cpu/armv7/omap4/Makefile | 6 + arch/arm/cpu/armv7/omap4/board.c | 161 +++- arch/arm/cpu/armv7/omap4/clocks.c | 842 +++++++++++++ .../panda => arch/arm/cpu/armv7/omap4}/config.mk | 25 +- arch/arm/cpu/armv7/omap4/emif.c | 1305 ++++++++++++++++++++ arch/arm/cpu/armv7/omap4/lowlevel_init.S | 31 + arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 76 ++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 282 +++++ arch/arm/cpu/armv7/start.S | 51 +- arch/arm/cpu/armv7/u-boot.lds | 2 + arch/arm/include/asm/arch-omap4/clocks.h | 664 ++++++++++ arch/arm/include/asm/arch-omap4/emif.h | 1034 ++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 52 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 72 ++- arch/arm/include/asm/armv7.h | 5 + arch/arm/include/asm/omap_common.h | 56 + board/ti/panda/Makefile | 2 + board/ti/panda/panda.c | 25 +- board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} | 76 +- board/ti/sdp4430/Makefile | 2 + board/ti/sdp4430/config.mk | 31 - board/ti/sdp4430/sdp.c | 25 +- .../{panda/panda.h => sdp4430/sdp4430_mux_data.h} | 128 +-- common/image.c | 9 +- include/configs/omap4_panda.h | 37 + include/configs/omap4_sdp4430.h | 37 + include/image.h | 1 + spl/Makefile | 6 + tools/Makefile | 2 + tools/mkimage.c | 2 + tools/mkimage.h | 1 + tools/omap/clocks_get_m_n.c | 197 +++ tools/omapimage.c | 224 ++++ tools/omapimage.h | 50 + 41 files changed, 5668 insertions(+), 263 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/spl.c create mode 100644 arch/arm/cpu/armv7/omap-common/u-boot-spl.lds create mode 100644 arch/arm/cpu/armv7/omap-common/utils.c create mode 100644 arch/arm/cpu/armv7/omap4/clocks.c rename {board/ti/panda => arch/arm/cpu/armv7/omap4}/config.mk (64%) create mode 100644 arch/arm/cpu/armv7/omap4/emif.c create mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h create mode 100644 arch/arm/cpu/armv7/omap4/sdram_elpida.c create mode 100644 arch/arm/include/asm/arch-omap4/clocks.h create mode 100644 arch/arm/include/asm/arch-omap4/emif.h create mode 100644 arch/arm/include/asm/omap_common.h rename board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} (76%) delete mode 100644 board/ti/sdp4430/config.mk rename board/ti/{panda/panda.h => sdp4430/sdp4430_mux_data.h} (67%) create mode 100644 tools/omap/clocks_get_m_n.c create mode 100644 tools/omapimage.c create mode 100644 tools/omapimage.h
Patch #8 of this seires does not apply on the current u-boot-ti U-boot-ti now has the updated SPL framework
Please rebase with u-boot-ti and send updated patch sets for both your series.
Regards, Sandeep
Hi Sandeep,
There was v4 for just two of the patches of the framework series: 2/9 and 5/9.
I think you missed them. Can you correct this?
Sure. I will do that.
Thanks, Aneesh
Hi Sandeep,
I have done my re-basing. Will send out my series shortly. However, please note that u-boot-ti/master is not building for me. You will need this fix:
Fix typo from 'mb_alloc' -> 'lmb_alloc http://patchwork.ozlabs.org/patch/105364/
The basic hardware init of OMAP4(s_init()) can happen in 4 different contexts: 1. SPL running from SRAM 2. U-Boot running from FLASH 3. Non-XIP U-Boot loaded to SDRAM by SPL 4. Non-XIP U-Boot loaded to SDRAM by ROM code using the Configuration Header feature
What level of hw initialization gets done depends on this context. Add a utility function to find this context.
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Changed the context names to more meaningful names as suggested by WD --- arch/arm/include/asm/arch-omap4/sys_proto.h | 49 ++++++++++++++++++++++++++- arch/arm/include/asm/omap_common.h | 34 ++++++++++++++++++ 2 files changed, 82 insertions(+), 1 deletions(-) create mode 100644 arch/arm/include/asm/omap_common.h
diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 4fa4f4b..6b596b4 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -23,10 +23,12 @@
#include <asm/arch/omap4.h> #include <asm/io.h> +#include <asm/omap_common.h>
struct omap_sysinfo { char *board_string; }; +extern const struct omap_sysinfo sysinfo;
void gpmc_init(void); void watchdog_init(void); @@ -37,6 +39,51 @@ u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); void set_pl310_ctrl_reg(u32 val);
-extern const struct omap_sysinfo sysinfo; +static inline u32 running_from_sdram(void) +{ + u32 pc; + asm volatile ("mov %0, pc" : "=r" (pc)); + return ((pc >= OMAP44XX_DRAM_ADDR_SPACE_START) && + (pc < OMAP44XX_DRAM_ADDR_SPACE_END)); +} + +static inline u8 uboot_loaded_by_spl(void) +{ + /* + * Configuration Header is not supported yet, so u-boot init running + * from SDRAM implies that it was loaded by SPL. When this situation + * changes one of these approaches could be taken: + * i. Pass a magic from SPL to U-Boot and U-Boot save it at a known + * location. + * ii. Check the OPP. CH can support only 50% OPP while SPL initializes + * the DPLLs at 100% OPP. + */ + return running_from_sdram(); +} +/* + * The basic hardware init of OMAP(s_init()) can happen in 4 + * different contexts: + * 1. SPL running from SRAM + * 2. U-Boot running from FLASH + * 3. Non-XIP U-Boot loaded to SDRAM by SPL + * 4. Non-XIP U-Boot loaded to SDRAM by ROM code using the + * Configuration Header feature + * + * This function finds this context. + * Defining as inline may help in compiling out unused functions in SPL + */ +static inline u32 omap4_hw_init_context(void) +{ +#ifdef CONFIG_SPL_BUILD + return OMAP_INIT_CONTEXT_SPL; +#else + if (uboot_loaded_by_spl()) + return OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL; + else if (running_from_sdram()) + return OMAP_INIT_CONTEXT_UBOOT_AFTER_CH; + else + return OMAP_INIT_CONTEXT_UBOOT_FROM_NOR; +#endif +}
#endif diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h new file mode 100644 index 0000000..d80f665 --- /dev/null +++ b/arch/arm/include/asm/omap_common.h @@ -0,0 +1,34 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _OMAP_COMMON_H_ +#define _OMAP_COMMON_H_ + +/* HW Init Context */ +#define OMAP_INIT_CONTEXT_SPL 0 +#define OMAP_INIT_CONTEXT_UBOOT_FROM_NOR 1 +#define OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL 2 +#define OMAP_INIT_CONTEXT_UBOOT_AFTER_CH 3 + +#endif /* _OMAP_COMMON_H_ */
- separate mux settings into essential and non essential parts - essential part is board independent as of now(so move it to SoC directory). Will help in having single SPL for all boards. - Non-essential part(the pins not essential for u-boot to function) need to be phased out eventually. - Correct mux data by aligning to the latest settings in x-loader
Signed-off-by: Aneesh V aneesh@ti.com --- This patch add 33 warnings for lines over 80 characters. However, this for the mux table and improves readability.
V3: * Squashed two mux related patches into one --- arch/arm/cpu/armv7/omap4/board.c | 53 ++++++++- arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 76 ++++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 4 +- board/ti/panda/panda.c | 25 +--- board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} | 76 +++--------- board/ti/sdp4430/sdp.c | 25 +--- .../{panda/panda.h => sdp4430/sdp4430_mux_data.h} | 128 +++++++------------ 7 files changed, 209 insertions(+), 178 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h rename board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} (76%) rename board/ti/{panda/panda.h => sdp4430/sdp4430_mux_data.h} (67%)
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index de4cc2a..3fd6f84 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -31,17 +31,65 @@ #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> +#include "omap4_mux_data.h"
+void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) +{ + int i; + struct pad_conf_entry *pad = (struct pad_conf_entry *) array; + + for (i = 0; i < size; i++, pad++) + writew(pad->val, base + pad->offset); +} + +static void set_muxconf_regs_essential(void) +{ + do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_essential, + sizeof(core_padconf_array_essential) / + sizeof(struct pad_conf_entry)); + + do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_essential, + sizeof(wkup_padconf_array_essential) / + sizeof(struct pad_conf_entry)); +} + +static void set_mux_conf_regs(void) +{ + switch (omap4_hw_init_context()) { + case OMAP_INIT_CONTEXT_SPL: + set_muxconf_regs_essential(); + break; + case OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL: + set_muxconf_regs_non_essential(); + break; + case OMAP_INIT_CONTEXT_UBOOT_FROM_NOR: + case OMAP_INIT_CONTEXT_UBOOT_AFTER_CH: + set_muxconf_regs_essential(); + set_muxconf_regs_non_essential(); + break; + } +} + /* * Routine: s_init - * Description: Does early system init of muxing and clocks. - * - Called path is with SRAM stack. + * Description: Does early system init of watchdog, muxing, andclocks + * Watchdog disable is done always. For the rest what gets done + * depends on the boot mode in which this function is executed + * 1. s_init of SPL running from SRAM + * 2. s_init of U-Boot running from FLASH + * 3. s_init of U-Boot loaded to SDRAM by SPL + * 4. s_init of U-Boot loaded to SDRAM by ROM code using the + * Configuration Header feature + * Please have a look at the respective functions to see what gets + * done in each of these cases + * This function is called with SRAM stack. */ void s_init(void) { watchdog_init(); + set_mux_conf_regs(); }
/* @@ -124,7 +172,6 @@ int checkboard(void) */ int arch_cpu_init(void) { - set_muxconf_regs(); return 0; }
diff --git a/arch/arm/cpu/armv7/omap4/omap4_mux_data.h b/arch/arm/cpu/armv7/omap4/omap4_mux_data.h new file mode 100644 index 0000000..00c52f8 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/omap4_mux_data.h @@ -0,0 +1,76 @@ + /* + * (C) Copyright 2010 + * Texas Instruments Incorporated, <www.ti.com> + * + * Balaji Krishnamoorthy balajitk@ti.com + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _OMAP4_MUX_DATA_H_ +#define _OMAP4_MUX_DATA_H_ + +#include <asm/arch/mux_omap4.h> + +const struct pad_conf_entry core_padconf_array_essential[] = { + +{GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ +{GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ +{GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ +{GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ +{GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ +{GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ +{GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ +{GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +{GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ +{GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ +{SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ +{SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ +{SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ +{SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ +{SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ +{SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ +{SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ +{SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ +{SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ +{SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ +{I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ +{I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ +{I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ +{I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ +{I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ +{I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ +{I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ +{I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ +{UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ +{UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ +{UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ +{UART3_TX_IRTX, (M0)} /* uart3_tx */ + +}; + +const struct pad_conf_entry wkup_padconf_array_essential[] = { + +{PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ +{PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ +{PAD1_SYS_32K, (IEN | M0)} /* sys_32k */ + +}; + +#endif /* _OMAP4_MUX_DATA_H_ */ diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 6b596b4..3624378 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -24,6 +24,7 @@ #include <asm/arch/omap4.h> #include <asm/io.h> #include <asm/omap_common.h> +#include <asm/arch/mux_omap4.h>
struct omap_sysinfo { char *board_string; @@ -33,7 +34,8 @@ extern const struct omap_sysinfo sysinfo; void gpmc_init(void); void watchdog_init(void); u32 get_device_type(void); -void set_muxconf_regs(void); +void do_set_mux(u32 base, struct pad_conf_entry const *array, int size); +void set_muxconf_regs_non_essential(void); void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c index 78e1910..9afed80 100644 --- a/board/ti/panda/panda.c +++ b/board/ti/panda/panda.c @@ -25,7 +25,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h>
-#include "panda.h" +#include "panda_mux_data.h"
@@ -65,27 +65,14 @@ int misc_init_r(void) return 0; }
-void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) +void set_muxconf_regs_non_essential(void) { - int i; - struct pad_conf_entry *pad = (struct pad_conf_entry *) array; - - for (i = 0; i < size; i++, pad++) - writew(pad->val, base + pad->offset); -} - -/** - * @brief set_muxconf_regs Setting up the configuration Mux registers - * specific to the board. - */ -void set_muxconf_regs(void) -{ - do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array, - sizeof(core_padconf_array) / + do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_non_essential, + sizeof(core_padconf_array_non_essential) / sizeof(struct pad_conf_entry));
- do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array, - sizeof(wkup_padconf_array) / + do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_non_essential, + sizeof(wkup_padconf_array_non_essential) / sizeof(struct pad_conf_entry)); }
diff --git a/board/ti/sdp4430/sdp.h b/board/ti/panda/panda_mux_data.h similarity index 76% rename from board/ti/sdp4430/sdp.h rename to board/ti/panda/panda_mux_data.h index bf41067..16cc0ad 100644 --- a/board/ti/sdp4430/sdp.h +++ b/board/ti/panda/panda_mux_data.h @@ -23,22 +23,12 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ +#ifndef _SDP4430_MUX_DATA_H +#define _SDP4430_MUX_DATA_H
-#ifndef _SDP_H_ -#define _SDP_H_ - -#include <asm/io.h> #include <asm/arch/mux_omap4.h>
-const struct pad_conf_entry core_padconf_array[] = { - {GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ - {GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ - {GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ - {GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ - {GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ - {GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ - {GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ - {GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_AD8, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* gpio_32 */ {GPMC_AD9, (PTU | IEN | M3)}, /* gpio_33 */ {GPMC_AD10, (PTU | IEN | M3)}, /* gpio_34 */ @@ -64,8 +54,6 @@ const struct pad_conf_entry core_padconf_array[] = { {GPMC_NWP, (M3)}, /* gpio_54 */ {GPMC_CLK, (PTD | M3)}, /* gpio_55 */ {GPMC_NADV_ALE, (M3)}, /* gpio_56 */ - {GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ - {GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ @@ -96,14 +84,14 @@ const struct pad_conf_entry core_padconf_array[] = { {CAM_SHUTTER, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_shutter */ {CAM_STROBE, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_strobe */ {CAM_GLOBALRESET, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_83 */ - {USBB1_ULPITLL_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M4)},/* usbb1_ulpiphy_clk */ - {USBB1_ULPITLL_STP, (OFF_EN | OFF_OUT_PTD | M4)}, /* usbb1_ulpiphy_stp */ - {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dir */ - {USBB1_ULPITLL_NXT, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_nxt */ - {USBB1_ULPITLL_DAT0, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat0 */ - {USBB1_ULPITLL_DAT1, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat1 */ - {USBB1_ULPITLL_DAT2, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat2 */ - {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat3 */ + {USBB1_ULPITLL_CLK, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cawake */ + {USBB1_ULPITLL_STP, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cadata */ + {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caflag */ + {USBB1_ULPITLL_NXT, (OFF_EN | M1)}, /* hsi1_acready */ + {USBB1_ULPITLL_DAT0, (OFF_EN | M1)}, /* hsi1_acwake */ + {USBB1_ULPITLL_DAT1, (OFF_EN | M1)}, /* hsi1_acdata */ + {USBB1_ULPITLL_DAT2, (OFF_EN | M1)}, /* hsi1_acflag */ + {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caready */ {USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ {USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ {USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ @@ -112,22 +100,12 @@ const struct pad_conf_entry core_padconf_array[] = { {USBB1_HSIC_STROBE, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_strobe */ {USBC1_ICUSB_DP, (IEN | M0)}, /* usbc1_icusb_dp */ {USBC1_ICUSB_DM, (IEN | M0)}, /* usbc1_icusb_dm */ - {SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ - {SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ - {SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ - {SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ - {SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ - {SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ - {SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ - {SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ - {SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ - {SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ {ABE_MCBSP2_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_clkx */ {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ {ABE_MCBSP2_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_fsx */ - {ABE_MCBSP1_CLKX, (IEN | M1)}, /* abe_slimbus1_clock */ - {ABE_MCBSP1_DR, (IEN | M1)}, /* abe_slimbus1_data */ + {ABE_MCBSP1_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_clkx */ + {ABE_MCBSP1_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dr */ {ABE_MCBSP1_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dx */ {ABE_MCBSP1_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_fsx */ {ABE_PDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_ul_data */ @@ -144,14 +122,6 @@ const struct pad_conf_entry core_padconf_array[] = { {UART2_RX, (PTU | IEN | M0)}, /* uart2_rx */ {UART2_TX, (M0)}, /* uart2_tx */ {HDQ_SIO, (M3)}, /* gpio_127 */ - {I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ - {I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ - {I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ - {I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ - {I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ - {I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ - {I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ - {I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ {MCSPI1_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_clk */ {MCSPI1_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_somi */ {MCSPI1_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_simo */ @@ -159,10 +129,6 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI1_CS1, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* mcspi1_cs1 */ {MCSPI1_CS2, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_139 */ {MCSPI1_CS3, (PTU | IEN | M3)}, /* gpio_140 */ - {UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ - {UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ - {UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ - {UART3_TX_IRTX, (M0)}, /* uart3_tx */ {SDMMC5_CLK, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc5_clk */ {SDMMC5_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_cmd */ {SDMMC5_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat0 */ @@ -175,7 +141,7 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI4_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_cs0 */ {UART4_RX, (IEN | M0)}, /* uart4_rx */ {UART4_TX, (M0)}, /* uart4_tx */ - {USBB2_ULPITLL_CLK, (IEN | M3)}, /* gpio_157 */ + {USBB2_ULPITLL_CLK, (PTD | IEN | M3)}, /* gpio_157 */ {USBB2_ULPITLL_STP, (IEN | M5)}, /* dispc2_data23 */ {USBB2_ULPITLL_DIR, (IEN | M5)}, /* dispc2_data22 */ {USBB2_ULPITLL_NXT, (IEN | M5)}, /* dispc2_data21 */ @@ -207,11 +173,11 @@ const struct pad_conf_entry core_padconf_array[] = { {FREF_CLK1_OUT, (M0)}, /* fref_clk1_out */ {FREF_CLK2_OUT, (M0)}, /* fref_clk2_out */ {SYS_NIRQ1, (PTU | IEN | M0)}, /* sys_nirq1 */ - {SYS_NIRQ2, (PTU | IEN | M0)}, /* sys_nirq2 */ + {SYS_NIRQ2, (M7)}, /* sys_nirq2 */ {SYS_BOOT0, (PTU | IEN | M3)}, /* gpio_184 */ {SYS_BOOT1, (M3)}, /* gpio_185 */ {SYS_BOOT2, (PTD | IEN | M3)}, /* gpio_186 */ - {SYS_BOOT3, (M3)}, /* gpio_187 */ + {SYS_BOOT3, (PTD | IEN | M3)}, /* gpio_187 */ {SYS_BOOT4, (M3)}, /* gpio_188 */ {SYS_BOOT5, (PTD | IEN | M3)}, /* gpio_189 */ {DPM_EMU0, (IEN | M0)}, /* dpm_emu0 */ @@ -236,14 +202,12 @@ const struct pad_conf_entry core_padconf_array[] = { {DPM_EMU19, (IEN | M5)}, /* dispc2_data0 */ };
-const struct pad_conf_entry wkup_padconf_array[] = { +const struct pad_conf_entry wkup_padconf_array_non_essential[] = { {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ {PAD1_SIM_CLK, (M0)}, /* sim_clk */ {PAD0_SIM_RESET, (M0)}, /* sim_reset */ {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ - {PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ {PAD1_FREF_XTAL_IN, (M0)}, /* # */ {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ @@ -252,13 +216,15 @@ const struct pad_conf_entry wkup_padconf_array[] = { {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ {PAD1_FREF_CLK4_REQ, (PTU | IEN | M0)}, /* # */ {PAD0_FREF_CLK4_OUT, (M0)}, /* # */ - {PAD1_SYS_32K, (IEN | M0)}, /* sys_32k */ {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ + {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ + {PAD1_FREF_CLK4_REQ, (M3)}, /* gpio_wk7 */ + {PAD0_FREF_CLK4_OUT, (M3)}, /* gpio_wk8 */ };
-#endif +#endif /* _SDP4430_MUX_DATA_H */ diff --git a/board/ti/sdp4430/sdp.c b/board/ti/sdp4430/sdp.c index b13c4c5..a5ea682 100644 --- a/board/ti/sdp4430/sdp.c +++ b/board/ti/sdp4430/sdp.c @@ -27,7 +27,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h>
-#include "sdp.h" +#include "sdp4430_mux_data.h"
@@ -70,27 +70,14 @@ int misc_init_r(void) return 0; }
diff --git a/board/ti/panda/panda.h b/board/ti/sdp4430/sdp4430_mux_data.h similarity index 67% rename from board/ti/panda/panda.h rename to board/ti/sdp4430/sdp4430_mux_data.h index e3d090e..16cc0ad 100644 --- a/board/ti/panda/panda.h +++ b/board/ti/sdp4430/sdp4430_mux_data.h @@ -23,22 +23,12 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ +#ifndef _SDP4430_MUX_DATA_H +#define _SDP4430_MUX_DATA_H
-#ifndef _PANDA_H_ -#define _PANDA_H_ - -#include <asm/io.h> #include <asm/arch/mux_omap4.h>
-const struct pad_conf_entry core_padconf_array[] = { - {GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ - {GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ - {GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ - {GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ - {GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ - {GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ - {GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ - {GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_AD8, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* gpio_32 */ {GPMC_AD9, (PTU | IEN | M3)}, /* gpio_33 */ {GPMC_AD10, (PTU | IEN | M3)}, /* gpio_34 */ @@ -53,7 +43,7 @@ const struct pad_conf_entry core_padconf_array[] = { {GPMC_A19, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row7 */ {GPMC_A20, (IEN | M3)}, /* gpio_44 */ {GPMC_A21, (M3)}, /* gpio_45 */ - {GPMC_A22, (M3)}, /* gpio_46 */ + {GPMC_A22, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col6 */ {GPMC_A23, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col7 */ {GPMC_A24, (PTD | M3)}, /* gpio_48 */ {GPMC_A25, (PTD | M3)}, /* gpio_49 */ @@ -64,14 +54,12 @@ const struct pad_conf_entry core_padconf_array[] = { {GPMC_NWP, (M3)}, /* gpio_54 */ {GPMC_CLK, (PTD | M3)}, /* gpio_55 */ {GPMC_NADV_ALE, (M3)}, /* gpio_56 */ - {GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ - {GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ - {GPMC_WAIT1, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_62 */ + {GPMC_WAIT1, (IEN | M3)}, /* gpio_62 */ {C2C_DATA11, (PTD | M3)}, /* gpio_100 */ - {C2C_DATA12, (PTU | IEN | M3)}, /* gpio_101 */ + {C2C_DATA12, (M1)}, /* dsi1_te0 */ {C2C_DATA13, (PTD | M3)}, /* gpio_102 */ {C2C_DATA14, (M1)}, /* dsi2_te0 */ {C2C_DATA15, (PTD | M3)}, /* gpio_104 */ @@ -96,14 +84,14 @@ const struct pad_conf_entry core_padconf_array[] = { {CAM_SHUTTER, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_shutter */ {CAM_STROBE, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_strobe */ {CAM_GLOBALRESET, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_83 */ - {USBB1_ULPITLL_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M4)},/* usbb1_ulpiphy_clk */ - {USBB1_ULPITLL_STP, (OFF_EN | OFF_OUT_PTD | M4)}, /* usbb1_ulpiphy_stp */ - {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dir */ - {USBB1_ULPITLL_NXT, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_nxt */ - {USBB1_ULPITLL_DAT0, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat0 */ - {USBB1_ULPITLL_DAT1, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat1 */ - {USBB1_ULPITLL_DAT2, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat2 */ - {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat3 */ + {USBB1_ULPITLL_CLK, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cawake */ + {USBB1_ULPITLL_STP, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cadata */ + {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caflag */ + {USBB1_ULPITLL_NXT, (OFF_EN | M1)}, /* hsi1_acready */ + {USBB1_ULPITLL_DAT0, (OFF_EN | M1)}, /* hsi1_acwake */ + {USBB1_ULPITLL_DAT1, (OFF_EN | M1)}, /* hsi1_acdata */ + {USBB1_ULPITLL_DAT2, (OFF_EN | M1)}, /* hsi1_acflag */ + {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caready */ {USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ {USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ {USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ @@ -112,22 +100,12 @@ const struct pad_conf_entry core_padconf_array[] = { {USBB1_HSIC_STROBE, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_strobe */ {USBC1_ICUSB_DP, (IEN | M0)}, /* usbc1_icusb_dp */ {USBC1_ICUSB_DM, (IEN | M0)}, /* usbc1_icusb_dm */ - {SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ - {SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ - {SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ - {SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ - {SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ - {SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ - {SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ - {SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ - {SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ - {SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ {ABE_MCBSP2_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_clkx */ {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ {ABE_MCBSP2_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_fsx */ - {ABE_MCBSP1_CLKX, (IEN | M1)}, /* abe_slimbus1_clock */ - {ABE_MCBSP1_DR, (IEN | M1)}, /* abe_slimbus1_data */ + {ABE_MCBSP1_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_clkx */ + {ABE_MCBSP1_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dr */ {ABE_MCBSP1_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dx */ {ABE_MCBSP1_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_fsx */ {ABE_PDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_ul_data */ @@ -144,14 +122,6 @@ const struct pad_conf_entry core_padconf_array[] = { {UART2_RX, (PTU | IEN | M0)}, /* uart2_rx */ {UART2_TX, (M0)}, /* uart2_tx */ {HDQ_SIO, (M3)}, /* gpio_127 */ - {I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ - {I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ - {I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ - {I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ - {I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ - {I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ - {I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ - {I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ {MCSPI1_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_clk */ {MCSPI1_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_somi */ {MCSPI1_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_simo */ @@ -159,10 +129,6 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI1_CS1, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* mcspi1_cs1 */ {MCSPI1_CS2, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_139 */ {MCSPI1_CS3, (PTU | IEN | M3)}, /* gpio_140 */ - {UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ - {UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ - {UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ - {UART3_TX_IRTX, (M0)}, /* uart3_tx */ {SDMMC5_CLK, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc5_clk */ {SDMMC5_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_cmd */ {SDMMC5_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat0 */ @@ -175,7 +141,7 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI4_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_cs0 */ {UART4_RX, (IEN | M0)}, /* uart4_rx */ {UART4_TX, (M0)}, /* uart4_tx */ - {USBB2_ULPITLL_CLK, (IEN | M3)}, /* gpio_157 */ + {USBB2_ULPITLL_CLK, (PTD | IEN | M3)}, /* gpio_157 */ {USBB2_ULPITLL_STP, (IEN | M5)}, /* dispc2_data23 */ {USBB2_ULPITLL_DIR, (IEN | M5)}, /* dispc2_data22 */ {USBB2_ULPITLL_NXT, (IEN | M5)}, /* dispc2_data21 */ @@ -189,12 +155,12 @@ const struct pad_conf_entry core_padconf_array[] = { {USBB2_ULPITLL_DAT7, (IEN | M5)}, /* dispc2_data11 */ {USBB2_HSIC_DATA, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_169 */ {USBB2_HSIC_STROBE, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_170 */ - {UNIPRO_TX0, (PTD | IEN | M3)}, /* gpio_171 */ + {UNIPRO_TX0, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col0 */ {UNIPRO_TY0, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col1 */ {UNIPRO_TX1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col2 */ {UNIPRO_TY1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col3 */ - {UNIPRO_TX2, (PTU | IEN | M3)}, /* gpio_0 */ - {UNIPRO_TY2, (PTU | IEN | M3)}, /* gpio_1 */ + {UNIPRO_TX2, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col4 */ + {UNIPRO_TY2, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col5 */ {UNIPRO_RX0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row0 */ {UNIPRO_RY0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row1 */ {UNIPRO_RX1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row2 */ @@ -205,13 +171,13 @@ const struct pad_conf_entry core_padconf_array[] = { {USBA0_OTG_DP, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dp */ {USBA0_OTG_DM, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dm */ {FREF_CLK1_OUT, (M0)}, /* fref_clk1_out */ - {FREF_CLK2_OUT, (PTU | IEN | M3)}, /* gpio_182 */ + {FREF_CLK2_OUT, (M0)}, /* fref_clk2_out */ {SYS_NIRQ1, (PTU | IEN | M0)}, /* sys_nirq1 */ - {SYS_NIRQ2, (PTU | IEN | M0)}, /* sys_nirq2 */ + {SYS_NIRQ2, (M7)}, /* sys_nirq2 */ {SYS_BOOT0, (PTU | IEN | M3)}, /* gpio_184 */ {SYS_BOOT1, (M3)}, /* gpio_185 */ {SYS_BOOT2, (PTD | IEN | M3)}, /* gpio_186 */ - {SYS_BOOT3, (M3)}, /* gpio_187 */ + {SYS_BOOT3, (PTD | IEN | M3)}, /* gpio_187 */ {SYS_BOOT4, (M3)}, /* gpio_188 */ {SYS_BOOT5, (PTD | IEN | M3)}, /* gpio_189 */ {DPM_EMU0, (IEN | M0)}, /* dpm_emu0 */ @@ -236,29 +202,29 @@ const struct pad_conf_entry core_padconf_array[] = { {DPM_EMU19, (IEN | M5)}, /* dispc2_data0 */ };
-const struct pad_conf_entry wkup_padconf_array[] = { - {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ - {PAD1_SIM_CLK, (M0)}, /* sim_clk */ - {PAD0_SIM_RESET, (M0)}, /* sim_reset */ - {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ - {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ - {PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ - {PAD1_FREF_XTAL_IN, (M0)}, /* # */ - {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ - {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ - {PAD0_FREF_CLK0_OUT, (M2)}, /* sys_drm_msecure */ - {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ - {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ - {PAD1_FREF_CLK4_REQ, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_1 */ - {PAD0_FREF_CLK4_OUT, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_2 */ - {PAD1_SYS_32K, (IEN | M0)}, /* sys_32k */ - {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ - {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ - {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ - {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ - {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ - {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ +const struct pad_conf_entry wkup_padconf_array_non_essential[] = { + {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ + {PAD1_SIM_CLK, (M0)}, /* sim_clk */ + {PAD0_SIM_RESET, (M0)}, /* sim_reset */ + {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ + {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ + {PAD1_FREF_XTAL_IN, (M0)}, /* # */ + {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ + {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ + {PAD0_FREF_CLK0_OUT, (M2)}, /* sys_drm_msecure */ + {PAD1_FREF_CLK3_REQ, (PTU | IEN | M0)}, /* # */ + {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ + {PAD1_FREF_CLK4_REQ, (PTU | IEN | M0)}, /* # */ + {PAD0_FREF_CLK4_OUT, (M0)}, /* # */ + {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ + {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ + {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ + {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ + {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ + {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ + {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ + {PAD1_FREF_CLK4_REQ, (M3)}, /* gpio_wk7 */ + {PAD0_FREF_CLK4_OUT, (M3)}, /* gpio_wk8 */ };
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Added a revision string in addition to the revision number Helps in printing out the OMAP revision at bootup
V3: * Improved the revision check function by saving the value instead of finding it every time. * Improved revision string function by generating it from the revision rather than hard-coding the string per revision --- arch/arm/cpu/armv7/omap4/board.c | 64 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 29 +++++++++--- arch/arm/include/asm/arch-omap4/sys_proto.h | 7 +++ arch/arm/include/asm/armv7.h | 5 ++ 4 files changed, 97 insertions(+), 8 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 3fd6f84..09861a9 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -28,6 +28,7 @@ * MA 02111-1307 USA */ #include <common.h> +#include <asm/armv7.h> #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> @@ -35,6 +36,8 @@
+u32 *const omap4_revision = (u32 *)OMAP4_SRAM_SCRATCH_OMAP4_REV; + void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) { int i; @@ -72,6 +75,66 @@ static void set_mux_conf_regs(void) } }
+static u32 cortex_a9_rev(void) +{ + + unsigned int rev; + + /* Read Main ID Register (MIDR) */ + asm ("mrc p15, 0, %0, c0, c0, 0" : "=r" (rev)); + + return rev; +} + +static void init_omap4_revision(void) +{ + /* + * For some of the ES2/ES1 boards ID_CODE is not reliable: + * Also, ES1 and ES2 have different ARM revisions + * So use ARM revision for identification + */ + unsigned int arm_rev = cortex_a9_rev(); + + switch (arm_rev) { + case MIDR_CORTEX_A9_R0P1: + *omap4_revision = OMAP4430_ES1_0; + break; + case MIDR_CORTEX_A9_R1P2: + switch (readl(CONTROL_ID_CODE)) { + case OMAP4_CONTROL_ID_CODE_ES2_0: + *omap4_revision = OMAP4430_ES2_0; + break; + case OMAP4_CONTROL_ID_CODE_ES2_1: + *omap4_revision = OMAP4430_ES2_1; + break; + case OMAP4_CONTROL_ID_CODE_ES2_2: + *omap4_revision = OMAP4430_ES2_2; + break; + default: + *omap4_revision = OMAP4430_ES2_0; + break; + } + break; + case MIDR_CORTEX_A9_R1P3: + *omap4_revision = OMAP4430_ES2_3; + break; + default: + *omap4_revision = OMAP4430_SILICON_ID_INVALID; + break; + } +} + +void omap_rev_string(char *omap4_rev_string) +{ + u32 omap4_rev = omap_revision(); + u32 omap4_variant = (omap4_rev & 0xFFFF0000) >> 16; + u32 major_rev = (omap4_rev & 0x00000F00) >> 8; + u32 minor_rev = (omap4_rev & 0x000000F0) >> 4; + + sprintf(omap4_rev_string, "OMAP%x ES%x.%x", omap4_variant, major_rev, + minor_rev); +} + /* * Routine: s_init * Description: Does early system init of watchdog, muxing, andclocks @@ -88,6 +151,7 @@ static void set_mux_conf_regs(void) */ void s_init(void) { + init_omap4_revision(); watchdog_init(); set_mux_conf_regs(); } diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index a30bb33..76b06c2 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -51,6 +51,15 @@ #define CONTROL_PADCONF_CORE (OMAP44XX_L4_CORE_BASE + 0x100000) #define CONTROL_PADCONF_WKUP (OMAP44XX_L4_CORE_BASE + 0x31E000)
+/* CONTROL_ID_CODE */ +#define CONTROL_ID_CODE 0x4A002204 + +#define OMAP4_CONTROL_ID_CODE_ES1_0 0x0B85202F +#define OMAP4_CONTROL_ID_CODE_ES2_0 0x1B85202F +#define OMAP4_CONTROL_ID_CODE_ES2_1 0x3B95C02F +#define OMAP4_CONTROL_ID_CODE_ES2_2 0x4B95C02F +#define OMAP4_CONTROL_ID_CODE_ES2_3 0x6B95C02F + /* UART */ #define UART1_BASE (OMAP44XX_L4_PER_BASE + 0x6a000) #define UART2_BASE (OMAP44XX_L4_PER_BASE + 0x6c000) @@ -119,13 +128,17 @@ struct s32ktimer { /* base address for indirect vectors (internal boot mode) */ #define SRAM_ROM_VECT_BASE 0x4030D000 /* Temporary SRAM stack used while low level init is done */ -#define LOW_LEVEL_SRAM_STACK NON_SECURE_SRAM_END - -/* - * OMAP4 real hardware: - * TODO: Change this to the IDCODE in the hw regsiter - */ -#define CPU_OMAP4430_ES10 1 -#define CPU_OMAP4430_ES20 2 +#define LOW_LEVEL_SRAM_STACK NON_SECURE_SRAM_END +#define SRAM_SCRATCH_SPACE_ADDR NON_SECURE_SRAM_START +/* SRAM scratch space entries */ +#define OMAP4_SRAM_SCRATCH_OMAP4_REV SRAM_SCRATCH_SPACE_ADDR + +/* Silicon revisions */ +#define OMAP4430_SILICON_ID_INVALID 0xFFFFFFFF +#define OMAP4430_ES1_0 0x44300100 +#define OMAP4430_ES2_0 0x44300200 +#define OMAP4430_ES2_1 0x44300210 +#define OMAP4430_ES2_2 0x44300220 +#define OMAP4430_ES2_3 0x44300230
#endif diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 3624378..c10fa18 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -40,6 +40,7 @@ void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); void set_pl310_ctrl_reg(u32 val); +void omap_rev_string(char *omap4_rev_string);
static inline u32 running_from_sdram(void) { @@ -88,4 +89,10 @@ static inline u32 omap4_hw_init_context(void) #endif }
+static inline u32 omap_revision(void) +{ + extern u32 *const omap4_revision; + return *omap4_revision; +} + #endif diff --git a/arch/arm/include/asm/armv7.h b/arch/arm/include/asm/armv7.h index 88b9c62..b5784d8 100644 --- a/arch/arm/include/asm/armv7.h +++ b/arch/arm/include/asm/armv7.h @@ -25,6 +25,11 @@ #define ARMV7_H #include <linux/types.h>
+/* Cortex-A9 revisions */ +#define MIDR_CORTEX_A9_R0P1 0x410FC091 +#define MIDR_CORTEX_A9_R1P2 0x411FC092 +#define MIDR_CORTEX_A9_R1P3 0x411FC093 + /* CCSIDR */ #define CCSIDR_LINE_SIZE_OFFSET 0 #define CCSIDR_LINE_SIZE_MASK 0x7
Add support for: 1. DPLL locking 2. Initialization of clock domains and clock modules 3. Setting up the right voltage on voltage rails
This work draws upon previous work done for x-loader by: Santosh Shilimkar santosh.shilimkar@ti.com Rajendra Nayak rnayak@ti.com
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Use pre-calculated M & N values instead of calculated ones * Changes due to make file changes * Some corrections * Do all clock initialization in SPL itself instead of differing some work to u-boot
V3: * Use struct for register addressing * Support only Turbo OPP for MPU. OPP's above this need Smart Reflex enabled * Cleaned up the scale_vcore(). Now takes into account the differing voltage offsets for different revisions of Phoenix. * Removed references to deprecated utility functions - modify_reg_32() etc. * Changed all spl_debug() to debug() * Moved the host-program for calculating DPLL multiplier/divider to tools/omap/ directory. Added more documentation * Replaced calls to omap4_revision() with omap_revision() * Some changes to IVA and ABE dpll locking code --- arch/arm/cpu/armv7/omap4/Makefile | 1 + arch/arm/cpu/armv7/omap4/board.c | 1 + arch/arm/cpu/armv7/omap4/clocks.c | 809 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/clocks.h | 664 ++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 8 + arch/arm/include/asm/omap_common.h | 3 + tools/omap/clocks_get_m_n.c | 197 +++++++ 7 files changed, 1683 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/clocks.c create mode 100644 arch/arm/include/asm/arch-omap4/clocks.h create mode 100644 tools/omap/clocks_get_m_n.c
diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index 987dc9d..ac4b2a6 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -28,6 +28,7 @@ LIB = $(obj)lib$(SOC).o SOBJS += lowlevel_init.o
COBJS += board.o +COBJS += clocks.o COBJS += mem.o COBJS += sys_info.o
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 09861a9..1c26a66 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -154,6 +154,7 @@ void s_init(void) init_omap4_revision(); watchdog_init(); set_mux_conf_regs(); + prcm_init(); }
/* diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c new file mode 100644 index 0000000..e8d3a52 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/clocks.c @@ -0,0 +1,809 @@ +/* + * + * Clock initialization for OMAP4 + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * Based on previous work by: + * Santosh Shilimkar santosh.shilimkar@ti.com + * Rajendra Nayak rnayak@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/omap_common.h> +#include <asm/arch/clocks.h> +#include <asm/arch/sys_proto.h> +#include <asm/utils.h> + +#ifndef CONFIG_SPL_BUILD +/* + * printing to console doesn't work unless + * this code is executed from SPL + */ +#define printf(fmt, args...) +#define puts(s) +#endif + +#define abs(x) (((x) < 0) ? ((x)*-1) : (x)) + +struct omap4_prcm_regs *const prcm = (struct omap4_prcm_regs *)0x4A004100; + +static const u32 sys_clk_array[8] = { + 12000000, /* 12 MHz */ + 13000000, /* 13 MHz */ + 16800000, /* 16.8 MHz */ + 19200000, /* 19.2 MHz */ + 26000000, /* 26 MHz */ + 27000000, /* 27 MHz */ + 38400000, /* 38.4 MHz */ +}; + +/* + * The M & N values in the following tables are created using the + * following tool: + * tools/omap/clocks_get_m_n.c + * Please use this tool for creating the table for any new frequency. + */ + +/* dpll locked at 1584 MHz - MPU clk at 792 MHz(OPP Turbo) */ +static const struct dpll_params mpu_dpll_params_1584mhz[NUM_SYS_CLKS] = { + {66, 0, 1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {792, 12, 1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {330, 6, 1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {165, 3, 1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {396, 12, 1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {88, 2, 1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {165, 7, 1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +/* dpll locked at 1200 MHz - MPU clk at 600 MHz */ +static const struct dpll_params mpu_dpll_params_1200mhz[NUM_SYS_CLKS] = { + {50, 0, 1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {600, 12, 1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {250, 6, 1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {125, 3, 1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {300, 12, 1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {200, 8, 1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {125, 7, 1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params core_dpll_params_1600mhz[NUM_SYS_CLKS] = { + {200, 2, 1, 5, 8, 4, 6, 5}, /* 12 MHz */ + {800, 12, 1, 5, 8, 4, 6, 5}, /* 13 MHz */ + {619, 12, 1, 5, 8, 4, 6, 5}, /* 16.8 MHz */ + {125, 2, 1, 5, 8, 4, 6, 5}, /* 19.2 MHz */ + {400, 12, 1, 5, 8, 4, 6, 5}, /* 26 MHz */ + {800, 26, 1, 5, 8, 4, 6, 5}, /* 27 MHz */ + {125, 5, 1, 5, 8, 4, 6, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params core_dpll_params_es1_1524mhz[NUM_SYS_CLKS] = { + {127, 1, 1, 5, 8, 4, 6, 5}, /* 12 MHz */ + {762, 12, 1, 5, 8, 4, 6, 5}, /* 13 MHz */ + {635, 13, 1, 5, 8, 4, 6, 5}, /* 16.8 MHz */ + {635, 15, 1, 5, 8, 4, 6, 5}, /* 19.2 MHz */ + {381, 12, 1, 5, 8, 4, 6, 5}, /* 26 MHz */ + {254, 8, 1, 5, 8, 4, 6, 5}, /* 27 MHz */ + {496, 24, 1, 5, 8, 4, 6, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params + core_dpll_params_es2_1600mhz_ddr200mhz[NUM_SYS_CLKS] = { + {200, 2, 2, 5, 8, 4, 6, 5}, /* 12 MHz */ + {800, 12, 2, 5, 8, 4, 6, 5}, /* 13 MHz */ + {619, 12, 2, 5, 8, 4, 6, 5}, /* 16.8 MHz */ + {125, 2, 2, 5, 8, 4, 6, 5}, /* 19.2 MHz */ + {400, 12, 2, 5, 8, 4, 6, 5}, /* 26 MHz */ + {800, 26, 2, 5, 8, 4, 6, 5}, /* 27 MHz */ + {125, 5, 2, 5, 8, 4, 6, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params per_dpll_params_1536mhz[NUM_SYS_CLKS] = { + {64, 0, 8, 6, 12, 9, 4, 5}, /* 12 MHz */ + {768, 12, 8, 6, 12, 9, 4, 5}, /* 13 MHz */ + {320, 6, 8, 6, 12, 9, 4, 5}, /* 16.8 MHz */ + {40, 0, 8, 6, 12, 9, 4, 5}, /* 19.2 MHz */ + {384, 12, 8, 6, 12, 9, 4, 5}, /* 26 MHz */ + {256, 8, 8, 6, 12, 9, 4, 5}, /* 27 MHz */ + {20, 0, 8, 6, 12, 9, 4, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params iva_dpll_params_1862mhz[NUM_SYS_CLKS] = { + {931, 11, -1, -1, 4, 7, -1, -1}, /* 12 MHz */ + {931, 12, -1, -1, 4, 7, -1, -1}, /* 13 MHz */ + {665, 11, -1, -1, 4, 7, -1, -1}, /* 16.8 MHz */ + {727, 14, -1, -1, 4, 7, -1, -1}, /* 19.2 MHz */ + {931, 25, -1, -1, 4, 7, -1, -1}, /* 26 MHz */ + {931, 26, -1, -1, 4, 7, -1, -1}, /* 27 MHz */ + {412, 16, -1, -1, 4, 7, -1, -1} /* 38.4 MHz */ +}; + +/* ABE M & N values with sys_clk as source */ +static const struct dpll_params + abe_dpll_params_sysclk_196608khz[NUM_SYS_CLKS] = { + {49, 5, 1, 1, -1, -1, -1, -1}, /* 12 MHz */ + {68, 8, 1, 1, -1, -1, -1, -1}, /* 13 MHz */ + {35, 5, 1, 1, -1, -1, -1, -1}, /* 16.8 MHz */ + {46, 8, 1, 1, -1, -1, -1, -1}, /* 19.2 MHz */ + {34, 8, 1, 1, -1, -1, -1, -1}, /* 26 MHz */ + {29, 7, 1, 1, -1, -1, -1, -1}, /* 27 MHz */ + {64, 24, 1, 1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +/* ABE M & N values with 32K clock as source */ +static const struct dpll_params abe_dpll_params_32k_196608khz = { + 750, 0, 1, 1, -1, -1, -1, -1 +}; + + +static const struct dpll_params usb_dpll_params_1920mhz[NUM_SYS_CLKS] = { + {80, 0, 2, -1, -1, -1, -1, -1}, /* 12 MHz */ + {960, 12, 2, -1, -1, -1, -1, -1}, /* 13 MHz */ + {400, 6, 2, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {50, 0, 2, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {480, 12, 2, -1, -1, -1, -1, -1}, /* 26 MHz */ + {320, 8, 2, -1, -1, -1, -1, -1}, /* 27 MHz */ + {25, 0, 2, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static inline u32 __get_sys_clk_index(void) +{ + u32 ind; + /* + * For ES1 the ROM code calibration of sys clock is not reliable + * due to hw issue. So, use hard-coded value. If this value is not + * correct for any board over-ride this function in board file + * From ES2.0 onwards you will get this information from + * CM_SYS_CLKSEL + */ + if (omap_revision() == OMAP4430_ES1_0) + ind = OMAP_SYS_CLK_IND_38_4_MHZ; + else { + /* SYS_CLKSEL - 1 to match the dpll param array indices */ + ind = (readl(&prcm->cm_sys_clksel) & + CM_SYS_CLKSEL_SYS_CLKSEL_MASK) - 1; + } + return ind; +} + +u32 get_sys_clk_index(void) + __attribute__ ((weak, alias("__get_sys_clk_index"))); + +u32 get_sys_clk_freq(void) +{ + u8 index = get_sys_clk_index(); + return sys_clk_array[index]; +} + +static inline void do_bypass_dpll(u32 *const base) +{ + struct dpll_regs *dpll_regs = (struct dpll_regs *)base; + + clrsetbits_le32(&dpll_regs->cm_clkmode_dpll, + CM_CLKMODE_DPLL_DPLL_EN_MASK, + DPLL_EN_FAST_RELOCK_BYPASS << + CM_CLKMODE_DPLL_EN_SHIFT); +} + +static inline void wait_for_bypass(u32 *const base) +{ + struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; + + if (!wait_on_value(ST_DPLL_CLK_MASK, 0, &dpll_regs->cm_idlest_dpll, + LDELAY)) { + printf("Bypassing DPLL failed %p\n", base); + } +} + +static inline void do_lock_dpll(u32 *const base) +{ + struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; + + clrsetbits_le32(&dpll_regs->cm_clkmode_dpll, + CM_CLKMODE_DPLL_DPLL_EN_MASK, + DPLL_EN_LOCK << CM_CLKMODE_DPLL_EN_SHIFT); +} + +static inline void wait_for_lock(u32 *const base) +{ + struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; + + if (!wait_on_value(ST_DPLL_CLK_MASK, ST_DPLL_CLK_MASK, + &dpll_regs->cm_idlest_dpll, LDELAY)) { + printf("DPLL locking failed for %p\n", base); + hang(); + } +} + +static void do_setup_dpll(u32 *const base, const struct dpll_params *params, + u8 lock) +{ + u32 temp; + struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; + + bypass_dpll(base); + + /* Set M & N */ + temp = readl(&dpll_regs->cm_clksel_dpll); + + temp &= ~CM_CLKSEL_DPLL_M_MASK; + temp |= (params->m << CM_CLKSEL_DPLL_M_SHIFT) & CM_CLKSEL_DPLL_M_MASK; + + temp &= ~CM_CLKSEL_DPLL_N_MASK; + temp |= (params->n << CM_CLKSEL_DPLL_N_SHIFT) & CM_CLKSEL_DPLL_N_MASK; + + writel(temp, &dpll_regs->cm_clksel_dpll); + + /* Lock */ + if (lock) + do_lock_dpll(base); + + /* Setup post-dividers */ + if (params->m2 >= 0) + writel(params->m2, &dpll_regs->cm_div_m2_dpll); + if (params->m3 >= 0) + writel(params->m3, &dpll_regs->cm_div_m3_dpll); + if (params->m4 >= 0) + writel(params->m4, &dpll_regs->cm_div_m4_dpll); + if (params->m5 >= 0) + writel(params->m5, &dpll_regs->cm_div_m5_dpll); + if (params->m6 >= 0) + writel(params->m6, &dpll_regs->cm_div_m6_dpll); + if (params->m7 >= 0) + writel(params->m7, &dpll_regs->cm_div_m7_dpll); + + /* Wait till the DPLL locks */ + if (lock) + wait_for_lock(base); +} + +const struct dpll_params *get_core_dpll_params(void) +{ + u32 sysclk_ind = get_sys_clk_index(); + + switch (omap_revision()) { + case OMAP4430_ES1_0: + return &core_dpll_params_es1_1524mhz[sysclk_ind]; + case OMAP4430_ES2_0: + case OMAP4430_SILICON_ID_INVALID: + /* safest */ + return &core_dpll_params_es2_1600mhz_ddr200mhz[sysclk_ind]; + default: + return &core_dpll_params_1600mhz[sysclk_ind]; + } +} + +u32 omap4_ddr_clk(void) +{ + u32 ddr_clk, sys_clk_khz; + const struct dpll_params *core_dpll_params; + + sys_clk_khz = get_sys_clk_freq() / 1000; + + core_dpll_params = get_core_dpll_params(); + + debug("sys_clk %d\n ", sys_clk_khz * 1000); + + /* Find Core DPLL locked frequency first */ + ddr_clk = sys_clk_khz * 2 * core_dpll_params->m / + (core_dpll_params->n + 1); + /* + * DDR frequency is PHY_ROOT_CLK/2 + * PHY_ROOT_CLK = Fdpll/2/M2 + */ + ddr_clk = ddr_clk / 4 / core_dpll_params->m2; + + ddr_clk *= 1000; /* convert to Hz */ + debug("ddr_clk %d\n ", ddr_clk); + + return ddr_clk; +} + +static void setup_dplls(void) +{ + u32 sysclk_ind, temp; + const struct dpll_params *params; + debug("setup_dplls\n"); + + sysclk_ind = get_sys_clk_index(); + + /* CORE dpll */ + params = get_core_dpll_params(); /* default - safest */ + /* + * Do not lock the core DPLL now. Just set it up. + * Core DPLL will be locked after setting up EMIF + * using the FREQ_UPDATE method(freq_update_core()) + */ + do_setup_dpll(&prcm->cm_clkmode_dpll_core, params, DPLL_NO_LOCK); + /* Set the ratios for CORE_CLK, L3_CLK, L4_CLK */ + temp = (CLKSEL_CORE_X2_DIV_1 << CLKSEL_CORE_SHIFT) | + (CLKSEL_L3_CORE_DIV_2 << CLKSEL_L3_SHIFT) | + (CLKSEL_L4_L3_DIV_2 << CLKSEL_L4_SHIFT); + writel(temp, &prcm->cm_clksel_core); + debug("Core DPLL configured\n"); + + /* lock PER dpll */ + do_setup_dpll(&prcm->cm_clkmode_dpll_per, + &per_dpll_params_1536mhz[sysclk_ind], DPLL_LOCK); + debug("PER DPLL locked\n"); + + /* MPU dpll */ + if (omap_revision() == OMAP4430_ES1_0) + params = &mpu_dpll_params_1200mhz[sysclk_ind]; + else + params = &mpu_dpll_params_1584mhz[sysclk_ind]; + do_setup_dpll(&prcm->cm_clkmode_dpll_mpu, params, DPLL_LOCK); + debug("MPU DPLL locked\n"); +} + +static void setup_non_essential_dplls(void) +{ + u32 sys_clk_khz, abe_ref_clk; + u32 sysclk_ind, sd_div, num, den; + const struct dpll_params *params; + + sysclk_ind = get_sys_clk_index(); + sys_clk_khz = get_sys_clk_freq() / 1000; + + /* IVA */ + clrsetbits_le32(&prcm->cm_bypclk_dpll_iva, + CM_BYPCLK_DPLL_IVA_CLKSEL_MASK, DPLL_IVA_CLKSEL_CORE_X2_DIV_2); + + do_setup_dpll(&prcm->cm_clkmode_dpll_iva, + &iva_dpll_params_1862mhz[sysclk_ind], DPLL_LOCK); + + /* + * USB: + * USB dpll is J-type. Need to set DPLL_SD_DIV for jitter correction + * DPLL_SD_DIV = CEILING ([DPLL_MULT/(DPLL_DIV+1)]* CLKINP / 250) + * - where CLKINP is sys_clk in MHz + * Use CLKINP in KHz and adjust the denominator accordingly so + * that we have enough accuracy and at the same time no overflow + */ + params = &usb_dpll_params_1920mhz[sysclk_ind]; + num = params->m * sys_clk_khz; + den = (params->n + 1) * 250 * 1000; + num += den - 1; + sd_div = num / den; + clrsetbits_le32(&prcm->cm_clksel_dpll_usb, + CM_CLKSEL_DPLL_DPLL_SD_DIV_MASK, + sd_div << CM_CLKSEL_DPLL_DPLL_SD_DIV_SHIFT); + + /* Now setup the dpll with the regular function */ + do_setup_dpll(&prcm->cm_clkmode_dpll_usb, params, DPLL_LOCK); + +#ifdef CONFIG_SYS_OMAP4_ABE_SYSCK + params = &abe_dpll_params_sysclk_196608khz[sysclk_ind]; + abe_ref_clk = CM_ABE_PLL_REF_CLKSEL_CLKSEL_SYSCLK; +#else + params = &abe_dpll_params_32k_196608khz; + abe_ref_clk = CM_ABE_PLL_REF_CLKSEL_CLKSEL_32KCLK; + /* + * We need to enable some additional options to achieve + * 196.608MHz from 32768 Hz + */ + setbits_le32(&prcm->cm_clkmode_dpll_abe, + CM_CLKMODE_DPLL_DRIFTGUARD_EN_MASK| + CM_CLKMODE_DPLL_RELOCK_RAMP_EN_MASK| + CM_CLKMODE_DPLL_LPMODE_EN_MASK| + CM_CLKMODE_DPLL_REGM4XEN_MASK); + /* Spend 4 REFCLK cycles at each stage */ + clrsetbits_le32(&prcm->cm_clkmode_dpll_abe, + CM_CLKMODE_DPLL_RAMP_RATE_MASK, + 1 << CM_CLKMODE_DPLL_RAMP_RATE_SHIFT); +#endif + + /* Select the right reference clk */ + clrsetbits_le32(&prcm->cm_abe_pll_ref_clksel, + CM_ABE_PLL_REF_CLKSEL_CLKSEL_MASK, + abe_ref_clk << CM_ABE_PLL_REF_CLKSEL_CLKSEL_SHIFT); + /* Lock the dpll */ + do_setup_dpll(&prcm->cm_clkmode_dpll_abe, params, DPLL_LOCK); +} + +static void do_scale_vcore(u32 vcore_reg, u32 volt_mv) +{ + u32 temp, offset_code; + u32 step = 12660; /* 12.66 mV represented in uV */ + u32 offset = volt_mv; + + /* convert to uV for better accuracy in the calculations */ + offset *= 1000; + + if (omap_revision() == OMAP4430_ES1_0) + offset -= PHOENIX_SMPS_BASE_VOLT_STD_MODE_UV; + else + offset -= PHOENIX_SMPS_BASE_VOLT_STD_MODE_WITH_OFFSET_UV; + + offset_code = (offset + step - 1) / step; + /* The code starts at 1 not 0 */ + offset_code++; + + debug("do_scale_vcore: volt - %d offset_code - 0x%x\n", volt_mv, + offset_code); + + temp = SMPS_I2C_SLAVE_ADDR | + (vcore_reg << PRM_VC_VAL_BYPASS_REGADDR_SHIFT) | + (offset_code << PRM_VC_VAL_BYPASS_DATA_SHIFT) | + PRM_VC_VAL_BYPASS_VALID_BIT; + writel(temp, &prcm->prm_vc_val_bypass); + if (!wait_on_value(PRM_VC_VAL_BYPASS_VALID_BIT, 0, + &prcm->prm_vc_val_bypass, LDELAY)) { + printf("Scaling voltage failed for 0x%x\n", vcore_reg); + } +} + +/* + * Setup the voltages for vdd_mpu, vdd_core, and vdd_iva + * We set the maximum voltages allowed here because Smart-Reflex is not + * enabled in bootloader. Voltage initialization in the kernel will set + * these to the nominal values after enabling Smart-Reflex + */ +static void scale_vcores(void) +{ + u32 volt, sys_clk_khz, cycles_hi, cycles_low, temp; + + sys_clk_khz = get_sys_clk_freq() / 1000; + + /* + * Setup the dedicated I2C controller for Voltage Control + * I2C clk - high period 40% low period 60% + */ + cycles_hi = sys_clk_khz * 4 / PRM_VC_I2C_CHANNEL_FREQ_KHZ / 10; + cycles_low = sys_clk_khz * 6 / PRM_VC_I2C_CHANNEL_FREQ_KHZ / 10; + /* values to be set in register - less by 5 & 7 respectively */ + cycles_hi -= 5; + cycles_low -= 7; + temp = (cycles_hi << PRM_VC_CFG_I2C_CLK_SCLH_SHIFT) | + (cycles_low << PRM_VC_CFG_I2C_CLK_SCLL_SHIFT); + writel(temp, &prcm->prm_vc_cfg_i2c_clk); + + /* Disable high speed mode and all advanced features */ + writel(0x0, &prcm->prm_vc_cfg_i2c_mode); + + /* + * VCORE 1 - 4430 : supplies vdd_mpu + * Setting a high voltage for Nitro mode as smart reflex is not enabled. + * We use the maximum possible value in the AVS range because the next + * higher voltage in the discrete range (code >= 0b111010) is way too + * high + */ + volt = 1417; + do_scale_vcore(SMPS_REG_ADDR_VCORE1, volt); + + /* VCORE 2 - supplies vdd_iva */ + volt = 1200; + do_scale_vcore(SMPS_REG_ADDR_VCORE2, volt); + + /* VCORE 3 - supplies vdd_core */ + volt = 1200; + do_scale_vcore(SMPS_REG_ADDR_VCORE3, volt); +} + +static inline void enable_clock_domain(u32 *const clkctrl_reg, u32 enable_mode) +{ + clrsetbits_le32(clkctrl_reg, CD_CLKCTRL_CLKTRCTRL_MASK, + enable_mode << CD_CLKCTRL_CLKTRCTRL_SHIFT); + debug("Enable clock domain - 0x%08x\n", clkctrl_reg); +} + +static inline void wait_for_clk_enable(u32 *clkctrl_addr) +{ + u32 clkctrl, idlest = MODULE_CLKCTRL_IDLEST_DISABLED; + u32 bound = LDELAY; + + while ((idlest == MODULE_CLKCTRL_IDLEST_DISABLED) || + (idlest == MODULE_CLKCTRL_IDLEST_TRANSITIONING)) { + + clkctrl = readl(clkctrl_addr); + idlest = (clkctrl & MODULE_CLKCTRL_IDLEST_MASK) >> + MODULE_CLKCTRL_IDLEST_SHIFT; + if (--bound == 0) { + printf("Clock enable failed for 0x%p idlest 0x%x\n", + clkctrl_addr, clkctrl); + return; + } + } +} + +static inline void enable_clock_module(u32 *const clkctrl_addr, u32 enable_mode, + u32 wait_for_enable) +{ + clrsetbits_le32(clkctrl_addr, MODULE_CLKCTRL_MODULEMODE_MASK, + enable_mode << MODULE_CLKCTRL_MODULEMODE_SHIFT); + debug("Enable clock module - 0x%08x\n", clkctrl_addr); + if (wait_for_enable) + wait_for_clk_enable(clkctrl_addr); +} + +/* + * Enable essential clock domains, modules and + * do some additional special settings needed + */ +static void enable_basic_clocks(void) +{ + u32 i, max = 100, wait_for_enable = 1; + u32 *const clk_domains_essential[] = { + &prcm->cm_l4per_clkstctrl, + &prcm->cm_l3init_clkstctrl, + &prcm->cm_memif_clkstctrl, + &prcm->cm_l4cfg_clkstctrl, + 0 + }; + + u32 *const clk_modules_hw_auto_essential[] = { + &prcm->cm_wkup_gpio1_clkctrl, + &prcm->cm_l4per_gpio2_clkctrl, + &prcm->cm_l4per_gpio3_clkctrl, + &prcm->cm_l4per_gpio4_clkctrl, + &prcm->cm_l4per_gpio5_clkctrl, + &prcm->cm_l4per_gpio6_clkctrl, + &prcm->cm_memif_emif_1_clkctrl, + &prcm->cm_memif_emif_2_clkctrl, + &prcm->cm_l3init_hsusbotg_clkctrl, + &prcm->cm_l3init_usbphy_clkctrl, + &prcm->cm_l4cfg_l4_cfg_clkctrl, + 0 + }; + + u32 *const clk_modules_explicit_en_essential[] = { + &prcm->cm_l4per_gptimer2_clkctrl, + &prcm->cm_l3init_hsmmc1_clkctrl, + &prcm->cm_l3init_hsmmc2_clkctrl, + &prcm->cm_l4per_mcspi1_clkctrl, + &prcm->cm_wkup_gptimer1_clkctrl, + &prcm->cm_l4per_i2c1_clkctrl, + &prcm->cm_l4per_i2c2_clkctrl, + &prcm->cm_l4per_i2c3_clkctrl, + &prcm->cm_l4per_i2c4_clkctrl, + &prcm->cm_wkup_wdtimer2_clkctrl, + &prcm->cm_l4per_uart3_clkctrl, + 0 + }; + + /* Enable optional additional functional clock for GPIO4 */ + setbits_le32(&prcm->cm_l4per_gpio4_clkctrl, + GPIO4_CLKCTRL_OPTFCLKEN_MASK); + + /* Enable 96 MHz clock for MMC1 & MMC2 */ + setbits_le32(&prcm->cm_l3init_hsmmc1_clkctrl, + HSMMC_CLKCTRL_CLKSEL_MASK); + setbits_le32(&prcm->cm_l3init_hsmmc2_clkctrl, + HSMMC_CLKCTRL_CLKSEL_MASK); + + /* Select 32KHz clock as the source of GPTIMER1 */ + setbits_le32(&prcm->cm_wkup_gptimer1_clkctrl, + GPTIMER1_CLKCTRL_CLKSEL_MASK); + + /* Enable optional 48M functional clock for USB PHY */ + setbits_le32(&prcm->cm_l3init_usbphy_clkctrl, + USBPHY_CLKCTRL_OPTFCLKEN_PHY_48M_MASK); + + /* Put the clock domains in SW_WKUP mode */ + for (i = 0; (i < max) && clk_domains_essential[i]; i++) { + enable_clock_domain(clk_domains_essential[i], + CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + } + + /* Clock modules that need to be put in HW_AUTO */ + for (i = 0; (i < max) && clk_modules_hw_auto_essential[i]; i++) { + enable_clock_module(clk_modules_hw_auto_essential[i], + MODULE_CLKCTRL_MODULEMODE_HW_AUTO, + wait_for_enable); + }; + + /* Clock modules that need to be put in SW_EXPLICIT_EN mode */ + for (i = 0; (i < max) && clk_modules_explicit_en_essential[i]; i++) { + enable_clock_module(clk_modules_explicit_en_essential[i], + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN, + wait_for_enable); + }; + + /* Put the clock domains in HW_AUTO mode now */ + for (i = 0; (i < max) && clk_domains_essential[i]; i++) { + enable_clock_domain(clk_domains_essential[i], + CD_CLKCTRL_CLKTRCTRL_HW_AUTO); + } +} + +/* + * Enable non-essential clock domains, modules and + * do some additional special settings needed + */ +static void enable_non_essential_clocks(void) +{ + u32 i, max = 100, wait_for_enable = 0; + u32 *const clk_domains_non_essential[] = { + &prcm->cm_mpu_m3_clkstctrl, + &prcm->cm_ivahd_clkstctrl, + &prcm->cm_dsp_clkstctrl, + &prcm->cm_dss_clkstctrl, + &prcm->cm_sgx_clkstctrl, + &prcm->cm1_abe_clkstctrl, + &prcm->cm_c2c_clkstctrl, + &prcm->cm_cam_clkstctrl, + &prcm->cm_dss_clkstctrl, + &prcm->cm_sdma_clkstctrl, + 0 + }; + + u32 *const clk_modules_hw_auto_non_essential[] = { + &prcm->cm_mpu_m3_mpu_m3_clkctrl, + &prcm->cm_ivahd_ivahd_clkctrl, + &prcm->cm_ivahd_sl2_clkctrl, + &prcm->cm_dsp_dsp_clkctrl, + &prcm->cm_l3_2_gpmc_clkctrl, + &prcm->cm_l3instr_l3_3_clkctrl, + &prcm->cm_l3instr_l3_instr_clkctrl, + &prcm->cm_l3instr_intrconn_wp1_clkctrl, + &prcm->cm_l3init_hsi_clkctrl, + &prcm->cm_l3init_hsusbtll_clkctrl, + 0 + }; + + u32 *const clk_modules_explicit_en_non_essential[] = { + &prcm->cm1_abe_aess_clkctrl, + &prcm->cm1_abe_pdm_clkctrl, + &prcm->cm1_abe_dmic_clkctrl, + &prcm->cm1_abe_mcasp_clkctrl, + &prcm->cm1_abe_mcbsp1_clkctrl, + &prcm->cm1_abe_mcbsp2_clkctrl, + &prcm->cm1_abe_mcbsp3_clkctrl, + &prcm->cm1_abe_slimbus_clkctrl, + &prcm->cm1_abe_timer5_clkctrl, + &prcm->cm1_abe_timer6_clkctrl, + &prcm->cm1_abe_timer7_clkctrl, + &prcm->cm1_abe_timer8_clkctrl, + &prcm->cm1_abe_wdt3_clkctrl, + &prcm->cm_l4per_gptimer9_clkctrl, + &prcm->cm_l4per_gptimer10_clkctrl, + &prcm->cm_l4per_gptimer11_clkctrl, + &prcm->cm_l4per_gptimer3_clkctrl, + &prcm->cm_l4per_gptimer4_clkctrl, + &prcm->cm_l4per_hdq1w_clkctrl, + &prcm->cm_l4per_mcbsp4_clkctrl, + &prcm->cm_l4per_mcspi2_clkctrl, + &prcm->cm_l4per_mcspi3_clkctrl, + &prcm->cm_l4per_mcspi4_clkctrl, + &prcm->cm_l4per_mmcsd3_clkctrl, + &prcm->cm_l4per_mmcsd4_clkctrl, + &prcm->cm_l4per_mmcsd5_clkctrl, + &prcm->cm_l4per_uart1_clkctrl, + &prcm->cm_l4per_uart2_clkctrl, + &prcm->cm_l4per_uart4_clkctrl, + &prcm->cm_wkup_keyboard_clkctrl, + &prcm->cm_wkup_wdtimer2_clkctrl, + &prcm->cm_cam_iss_clkctrl, + &prcm->cm_cam_fdif_clkctrl, + &prcm->cm_dss_dss_clkctrl, + &prcm->cm_sgx_sgx_clkctrl, + &prcm->cm_l3init_hsusbhost_clkctrl, + &prcm->cm_l3init_fsusb_clkctrl, + 0 + }; + + /* Enable optional functional clock for ISS */ + setbits_le32(&prcm->cm_cam_iss_clkctrl, ISS_CLKCTRL_OPTFCLKEN_MASK); + + /* Enable all optional functional clocks of DSS */ + setbits_le32(&prcm->cm_dss_dss_clkctrl, DSS_CLKCTRL_OPTFCLKEN_MASK); + + + /* Put the clock domains in SW_WKUP mode */ + for (i = 0; (i < max) && clk_domains_non_essential[i]; i++) { + enable_clock_domain(clk_domains_non_essential[i], + CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + } + + /* Clock modules that need to be put in HW_AUTO */ + for (i = 0; (i < max) && clk_modules_hw_auto_non_essential[i]; i++) { + enable_clock_module(clk_modules_hw_auto_non_essential[i], + MODULE_CLKCTRL_MODULEMODE_HW_AUTO, + wait_for_enable); + }; + + /* Clock modules that need to be put in SW_EXPLICIT_EN mode */ + for (i = 0; (i < max) && clk_modules_explicit_en_non_essential[i]; + i++) { + enable_clock_module(clk_modules_explicit_en_non_essential[i], + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN, + wait_for_enable); + }; + + /* Put the clock domains in HW_AUTO mode now */ + for (i = 0; (i < max) && clk_domains_non_essential[i]; i++) { + enable_clock_domain(clk_domains_non_essential[i], + CD_CLKCTRL_CLKTRCTRL_HW_AUTO); + } + + /* Put camera module in no sleep mode */ + clrsetbits_le32(&prcm->cm_cam_clkstctrl, MODULE_CLKCTRL_MODULEMODE_MASK, + CD_CLKCTRL_CLKTRCTRL_NO_SLEEP << + MODULE_CLKCTRL_MODULEMODE_SHIFT); +} + + +void freq_update_core(void) +{ + u32 freq_config1 = 0; + const struct dpll_params *core_dpll_params; + + core_dpll_params = get_core_dpll_params(); + /* Put EMIF clock domain in sw wakeup mode */ + enable_clock_domain(&prcm->cm_memif_clkstctrl, + CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + wait_for_clk_enable(&prcm->cm_memif_emif_1_clkctrl); + wait_for_clk_enable(&prcm->cm_memif_emif_2_clkctrl); + + freq_config1 = SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK | + SHADOW_FREQ_CONFIG1_DLL_RESET_MASK; + + freq_config1 |= (DPLL_EN_LOCK << SHADOW_FREQ_CONFIG1_DPLL_EN_SHIFT) & + SHADOW_FREQ_CONFIG1_DPLL_EN_MASK; + + freq_config1 |= (core_dpll_params->m2 << + SHADOW_FREQ_CONFIG1_M2_DIV_SHIFT) & + SHADOW_FREQ_CONFIG1_M2_DIV_MASK; + + writel(freq_config1, &prcm->cm_shadow_freq_config1); + if (!wait_on_value(SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK, 0, + &prcm->cm_shadow_freq_config1, LDELAY)) { + puts("FREQ UPDATE procedure failed!!"); + hang(); + } + + /* Put EMIF clock domain back in hw auto mode */ + enable_clock_domain(&prcm->cm_memif_clkstctrl, + CD_CLKCTRL_CLKTRCTRL_HW_AUTO); + wait_for_clk_enable(&prcm->cm_memif_emif_1_clkctrl); + wait_for_clk_enable(&prcm->cm_memif_emif_2_clkctrl); +} + +void bypass_dpll(u32 *const base) +{ + do_bypass_dpll(base); + wait_for_bypass(base); +} + +void lock_dpll(u32 *const base) +{ + do_lock_dpll(base); + wait_for_lock(base); +} + +void prcm_init(void) +{ + switch (omap4_hw_init_context()) { + case OMAP_INIT_CONTEXT_SPL: + case OMAP_INIT_CONTEXT_UBOOT_FROM_NOR: + case OMAP_INIT_CONTEXT_UBOOT_AFTER_CH: + scale_vcores(); + setup_dplls(); + enable_basic_clocks(); + setup_non_essential_dplls(); + enable_non_essential_clocks(); + break; + default: + break; + } +} diff --git a/arch/arm/include/asm/arch-omap4/clocks.h b/arch/arm/include/asm/arch-omap4/clocks.h new file mode 100644 index 0000000..71db39c --- /dev/null +++ b/arch/arm/include/asm/arch-omap4/clocks.h @@ -0,0 +1,664 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _CLOCKS_OMAP4_H_ +#define _CLOCKS_OMAP4_H_ +#include <common.h> + +/* + * Assuming a maximum of 1.5 GHz ARM speed and a minimum of 2 cycles per + * loop, allow for a minimum of 2 ms wait (in reality the wait will be + * much more than that) + */ +#define LDELAY 1000000 + +#define CM_CLKMODE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4120) +#define CM_CLKMODE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8140) +#define CM_CLKMODE_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4160) +#define CM_CLKSEL_CORE (OMAP44XX_L4_CORE_BASE + 0x4100) + +struct omap4_prcm_regs { + /* cm1.ckgen */ + u32 cm_clksel_core; + u32 pad001[1]; + u32 cm_clksel_abe; + u32 pad002[1]; + u32 cm_dll_ctrl; + u32 pad003[3]; + u32 cm_clkmode_dpll_core; + u32 cm_idlest_dpll_core; + u32 cm_autoidle_dpll_core; + u32 cm_clksel_dpll_core; + u32 cm_div_m2_dpll_core; + u32 cm_div_m3_dpll_core; + u32 cm_div_m4_dpll_core; + u32 cm_div_m5_dpll_core; + u32 cm_div_m6_dpll_core; + u32 cm_div_m7_dpll_core; + u32 cm_ssc_deltamstep_dpll_core; + u32 cm_ssc_modfreqdiv_dpll_core; + u32 cm_emu_override_dpll_core; + u32 pad004[3]; + u32 cm_clkmode_dpll_mpu; + u32 cm_idlest_dpll_mpu; + u32 cm_autoidle_dpll_mpu; + u32 cm_clksel_dpll_mpu; + u32 cm_div_m2_dpll_mpu; + u32 pad005[5]; + u32 cm_ssc_deltamstep_dpll_mpu; + u32 cm_ssc_modfreqdiv_dpll_mpu; + u32 pad006[3]; + u32 cm_bypclk_dpll_mpu; + u32 cm_clkmode_dpll_iva; + u32 cm_idlest_dpll_iva; + u32 cm_autoidle_dpll_iva; + u32 cm_clksel_dpll_iva; + u32 pad007[2]; + u32 cm_div_m4_dpll_iva; + u32 cm_div_m5_dpll_iva; + u32 pad008[2]; + u32 cm_ssc_deltamstep_dpll_iva; + u32 cm_ssc_modfreqdiv_dpll_iva; + u32 pad009[3]; + u32 cm_bypclk_dpll_iva; + u32 cm_clkmode_dpll_abe; + u32 cm_idlest_dpll_abe; + u32 cm_autoidle_dpll_abe; + u32 cm_clksel_dpll_abe; + u32 cm_div_m2_dpll_abe; + u32 cm_div_m3_dpll_abe; + u32 pad010[4]; + u32 cm_ssc_deltamstep_dpll_abe; + u32 cm_ssc_modfreqdiv_dpll_abe; + u32 pad011[4]; + u32 cm_clkmode_dpll_ddrphy; + u32 cm_idlest_dpll_ddrphy; + u32 cm_autoidle_dpll_ddrphy; + u32 cm_clksel_dpll_ddrphy; + u32 cm_div_m2_dpll_ddrphy; + u32 pad012[1]; + u32 cm_div_m4_dpll_ddrphy; + u32 cm_div_m5_dpll_ddrphy; + u32 cm_div_m6_dpll_ddrphy; + u32 pad013[1]; + u32 cm_ssc_deltamstep_dpll_ddrphy; + u32 pad014[5]; + u32 cm_shadow_freq_config1; + + /* cm1.dsp */ + u32 pad015[103]; + u32 cm_dsp_clkstctrl; + u32 pad016[7]; + u32 cm_dsp_dsp_clkctrl; + + /* cm1.abe */ + u32 pad017[55]; + u32 cm1_abe_clkstctrl; + u32 pad018[7]; + u32 cm1_abe_l4abe_clkctrl; + u32 pad019[1]; + u32 cm1_abe_aess_clkctrl; + u32 pad020[1]; + u32 cm1_abe_pdm_clkctrl; + u32 pad021[1]; + u32 cm1_abe_dmic_clkctrl; + u32 pad022[1]; + u32 cm1_abe_mcasp_clkctrl; + u32 pad023[1]; + u32 cm1_abe_mcbsp1_clkctrl; + u32 pad024[1]; + u32 cm1_abe_mcbsp2_clkctrl; + u32 pad025[1]; + u32 cm1_abe_mcbsp3_clkctrl; + u32 pad026[1]; + u32 cm1_abe_slimbus_clkctrl; + u32 pad027[1]; + u32 cm1_abe_timer5_clkctrl; + u32 pad028[1]; + u32 cm1_abe_timer6_clkctrl; + u32 pad029[1]; + u32 cm1_abe_timer7_clkctrl; + u32 pad030[1]; + u32 cm1_abe_timer8_clkctrl; + u32 pad031[1]; + u32 cm1_abe_wdt3_clkctrl; + + /* cm2.ckgen */ + u32 pad032[3805]; + u32 cm_clksel_mpu_m3_iss_root; + u32 cm_clksel_usb_60mhz; + u32 cm_scale_fclk; + u32 pad033[1]; + u32 cm_core_dvfs_perf1; + u32 cm_core_dvfs_perf2; + u32 cm_core_dvfs_perf3; + u32 cm_core_dvfs_perf4; + u32 pad034[1]; + u32 cm_core_dvfs_current; + u32 cm_iva_dvfs_perf_tesla; + u32 cm_iva_dvfs_perf_ivahd; + u32 cm_iva_dvfs_perf_abe; + u32 pad035[1]; + u32 cm_iva_dvfs_current; + u32 pad036[1]; + u32 cm_clkmode_dpll_per; + u32 cm_idlest_dpll_per; + u32 cm_autoidle_dpll_per; + u32 cm_clksel_dpll_per; + u32 cm_div_m2_dpll_per; + u32 cm_div_m3_dpll_per; + u32 cm_div_m4_dpll_per; + u32 cm_div_m5_dpll_per; + u32 cm_div_m6_dpll_per; + u32 cm_div_m7_dpll_per; + u32 cm_ssc_deltamstep_dpll_per; + u32 cm_ssc_modfreqdiv_dpll_per; + u32 cm_emu_override_dpll_per; + u32 pad037[3]; + u32 cm_clkmode_dpll_usb; + u32 cm_idlest_dpll_usb; + u32 cm_autoidle_dpll_usb; + u32 cm_clksel_dpll_usb; + u32 cm_div_m2_dpll_usb; + u32 pad038[5]; + u32 cm_ssc_deltamstep_dpll_usb; + u32 cm_ssc_modfreqdiv_dpll_usb; + u32 pad039[1]; + u32 cm_clkdcoldo_dpll_usb; + u32 pad040[2]; + u32 cm_clkmode_dpll_unipro; + u32 cm_idlest_dpll_unipro; + u32 cm_autoidle_dpll_unipro; + u32 cm_clksel_dpll_unipro; + u32 cm_div_m2_dpll_unipro; + u32 pad041[5]; + u32 cm_ssc_deltamstep_dpll_unipro; + u32 cm_ssc_modfreqdiv_dpll_unipro; + + /* cm2.core */ + u32 pad0411[324]; + u32 cm_l3_1_clkstctrl; + u32 pad042[1]; + u32 cm_l3_1_dynamicdep; + u32 pad043[5]; + u32 cm_l3_1_l3_1_clkctrl; + u32 pad044[55]; + u32 cm_l3_2_clkstctrl; + u32 pad045[1]; + u32 cm_l3_2_dynamicdep; + u32 pad046[5]; + u32 cm_l3_2_l3_2_clkctrl; + u32 pad047[1]; + u32 cm_l3_2_gpmc_clkctrl; + u32 pad048[1]; + u32 cm_l3_2_ocmc_ram_clkctrl; + u32 pad049[51]; + u32 cm_mpu_m3_clkstctrl; + u32 cm_mpu_m3_staticdep; + u32 cm_mpu_m3_dynamicdep; + u32 pad050[5]; + u32 cm_mpu_m3_mpu_m3_clkctrl; + u32 pad051[55]; + u32 cm_sdma_clkstctrl; + u32 cm_sdma_staticdep; + u32 cm_sdma_dynamicdep; + u32 pad052[5]; + u32 cm_sdma_sdma_clkctrl; + u32 pad053[55]; + u32 cm_memif_clkstctrl; + u32 pad054[7]; + u32 cm_memif_dmm_clkctrl; + u32 pad055[1]; + u32 cm_memif_emif_fw_clkctrl; + u32 pad056[1]; + u32 cm_memif_emif_1_clkctrl; + u32 pad057[1]; + u32 cm_memif_emif_2_clkctrl; + u32 pad058[1]; + u32 cm_memif_dll_clkctrl; + u32 pad059[3]; + u32 cm_memif_emif_h1_clkctrl; + u32 pad060[1]; + u32 cm_memif_emif_h2_clkctrl; + u32 pad061[1]; + u32 cm_memif_dll_h_clkctrl; + u32 pad062[39]; + u32 cm_c2c_clkstctrl; + u32 cm_c2c_staticdep; + u32 cm_c2c_dynamicdep; + u32 pad063[5]; + u32 cm_c2c_sad2d_clkctrl; + u32 pad064[1]; + u32 cm_c2c_modem_icr_clkctrl; + u32 pad065[1]; + u32 cm_c2c_sad2d_fw_clkctrl; + u32 pad066[51]; + u32 cm_l4cfg_clkstctrl; + u32 pad067[1]; + u32 cm_l4cfg_dynamicdep; + u32 pad068[5]; + u32 cm_l4cfg_l4_cfg_clkctrl; + u32 pad069[1]; + u32 cm_l4cfg_hw_sem_clkctrl; + u32 pad070[1]; + u32 cm_l4cfg_mailbox_clkctrl; + u32 pad071[1]; + u32 cm_l4cfg_sar_rom_clkctrl; + u32 pad072[49]; + u32 cm_l3instr_clkstctrl; + u32 pad073[7]; + u32 cm_l3instr_l3_3_clkctrl; + u32 pad074[1]; + u32 cm_l3instr_l3_instr_clkctrl; + u32 pad075[5]; + u32 cm_l3instr_intrconn_wp1_clkctrl; + + + /* cm2.ivahd */ + u32 pad076[47]; + u32 cm_ivahd_clkstctrl; + u32 pad077[7]; + u32 cm_ivahd_ivahd_clkctrl; + u32 pad078[1]; + u32 cm_ivahd_sl2_clkctrl; + + /* cm2.cam */ + u32 pad079[53]; + u32 cm_cam_clkstctrl; + u32 pad080[7]; + u32 cm_cam_iss_clkctrl; + u32 pad081[1]; + u32 cm_cam_fdif_clkctrl; + + /* cm2.dss */ + u32 pad082[53]; + u32 cm_dss_clkstctrl; + u32 pad083[7]; + u32 cm_dss_dss_clkctrl; + + /* cm2.sgx */ + u32 pad084[55]; + u32 cm_sgx_clkstctrl; + u32 pad085[7]; + u32 cm_sgx_sgx_clkctrl; + + /* cm2.l3init */ + u32 pad086[55]; + u32 cm_l3init_clkstctrl; + + /* cm2.l3init */ + u32 pad087[9]; + u32 cm_l3init_hsmmc1_clkctrl; + u32 pad088[1]; + u32 cm_l3init_hsmmc2_clkctrl; + u32 pad089[1]; + u32 cm_l3init_hsi_clkctrl; + u32 pad090[7]; + u32 cm_l3init_hsusbhost_clkctrl; + u32 pad091[1]; + u32 cm_l3init_hsusbotg_clkctrl; + u32 pad092[1]; + u32 cm_l3init_hsusbtll_clkctrl; + u32 pad093[3]; + u32 cm_l3init_p1500_clkctrl; + u32 pad094[21]; + u32 cm_l3init_fsusb_clkctrl; + u32 pad095[3]; + u32 cm_l3init_usbphy_clkctrl; + + /* cm2.l4per */ + u32 pad096[7]; + u32 cm_l4per_clkstctrl; + u32 pad097[1]; + u32 cm_l4per_dynamicdep; + u32 pad098[5]; + u32 cm_l4per_adc_clkctrl; + u32 pad100[1]; + u32 cm_l4per_gptimer10_clkctrl; + u32 pad101[1]; + u32 cm_l4per_gptimer11_clkctrl; + u32 pad102[1]; + u32 cm_l4per_gptimer2_clkctrl; + u32 pad103[1]; + u32 cm_l4per_gptimer3_clkctrl; + u32 pad104[1]; + u32 cm_l4per_gptimer4_clkctrl; + u32 pad105[1]; + u32 cm_l4per_gptimer9_clkctrl; + u32 pad106[1]; + u32 cm_l4per_elm_clkctrl; + u32 pad107[1]; + u32 cm_l4per_gpio2_clkctrl; + u32 pad108[1]; + u32 cm_l4per_gpio3_clkctrl; + u32 pad109[1]; + u32 cm_l4per_gpio4_clkctrl; + u32 pad110[1]; + u32 cm_l4per_gpio5_clkctrl; + u32 pad111[1]; + u32 cm_l4per_gpio6_clkctrl; + u32 pad112[1]; + u32 cm_l4per_hdq1w_clkctrl; + u32 pad113[1]; + u32 cm_l4per_hecc1_clkctrl; + u32 pad114[1]; + u32 cm_l4per_hecc2_clkctrl; + u32 pad115[1]; + u32 cm_l4per_i2c1_clkctrl; + u32 pad116[1]; + u32 cm_l4per_i2c2_clkctrl; + u32 pad117[1]; + u32 cm_l4per_i2c3_clkctrl; + u32 pad118[1]; + u32 cm_l4per_i2c4_clkctrl; + u32 pad119[1]; + u32 cm_l4per_l4per_clkctrl; + u32 pad1191[3]; + u32 cm_l4per_mcasp2_clkctrl; + u32 pad120[1]; + u32 cm_l4per_mcasp3_clkctrl; + u32 pad121[1]; + u32 cm_l4per_mcbsp4_clkctrl; + u32 pad122[1]; + u32 cm_l4per_mgate_clkctrl; + u32 pad123[1]; + u32 cm_l4per_mcspi1_clkctrl; + u32 pad124[1]; + u32 cm_l4per_mcspi2_clkctrl; + u32 pad125[1]; + u32 cm_l4per_mcspi3_clkctrl; + u32 pad126[1]; + u32 cm_l4per_mcspi4_clkctrl; + u32 pad127[5]; + u32 cm_l4per_mmcsd3_clkctrl; + u32 pad128[1]; + u32 cm_l4per_mmcsd4_clkctrl; + u32 pad129[1]; + u32 cm_l4per_msprohg_clkctrl; + u32 pad130[1]; + u32 cm_l4per_slimbus2_clkctrl; + u32 pad131[1]; + u32 cm_l4per_uart1_clkctrl; + u32 pad132[1]; + u32 cm_l4per_uart2_clkctrl; + u32 pad133[1]; + u32 cm_l4per_uart3_clkctrl; + u32 pad134[1]; + u32 cm_l4per_uart4_clkctrl; + u32 pad135[1]; + u32 cm_l4per_mmcsd5_clkctrl; + u32 pad136[1]; + u32 cm_l4per_i2c5_clkctrl; + u32 pad137[5]; + u32 cm_l4sec_clkstctrl; + u32 cm_l4sec_staticdep; + u32 cm_l4sec_dynamicdep; + u32 pad138[5]; + u32 cm_l4sec_aes1_clkctrl; + u32 pad139[1]; + u32 cm_l4sec_aes2_clkctrl; + u32 pad140[1]; + u32 cm_l4sec_des3des_clkctrl; + u32 pad141[1]; + u32 cm_l4sec_pkaeip29_clkctrl; + u32 pad142[1]; + u32 cm_l4sec_rng_clkctrl; + u32 pad143[1]; + u32 cm_l4sec_sha2md51_clkctrl; + u32 pad144[3]; + u32 cm_l4sec_cryptodma_clkctrl; + u32 pad145[776841]; + + /* l4 wkup regs */ + u32 pad201[6211]; + u32 cm_abe_pll_ref_clksel; + u32 cm_sys_clksel; + u32 pad202[1467]; + u32 cm_wkup_clkstctrl; + u32 pad203[7]; + u32 cm_wkup_l4wkup_clkctrl; + u32 pad204; + u32 cm_wkup_wdtimer1_clkctrl; + u32 pad205; + u32 cm_wkup_wdtimer2_clkctrl; + u32 pad206; + u32 cm_wkup_gpio1_clkctrl; + u32 pad207; + u32 cm_wkup_gptimer1_clkctrl; + u32 pad208; + u32 cm_wkup_gptimer12_clkctrl; + u32 pad209; + u32 cm_wkup_synctimer_clkctrl; + u32 pad210; + u32 cm_wkup_usim_clkctrl; + u32 pad211; + u32 cm_wkup_sarram_clkctrl; + u32 pad212[5]; + u32 cm_wkup_keyboard_clkctrl; + u32 pad213; + u32 cm_wkup_rtc_clkctrl; + u32 pad214; + u32 cm_wkup_bandgap_clkctrl; + u32 pad215[197]; + u32 prm_vc_val_bypass; + u32 prm_vc_cfg_channel; + u32 prm_vc_cfg_i2c_mode; + u32 prm_vc_cfg_i2c_clk; + +}; + +/* DPLL register offsets */ +#define CM_CLKMODE_DPLL 0 +#define CM_IDLEST_DPLL 0x4 +#define CM_AUTOIDLE_DPLL 0x8 +#define CM_CLKSEL_DPLL 0xC +#define CM_DIV_M2_DPLL 0x10 +#define CM_DIV_M3_DPLL 0x14 +#define CM_DIV_M4_DPLL 0x18 +#define CM_DIV_M5_DPLL 0x1C +#define CM_DIV_M6_DPLL 0x20 +#define CM_DIV_M7_DPLL 0x24 + +#define DPLL_CLKOUT_DIV_MASK 0x1F /* post-divider mask */ + +/* CM_CLKMODE_DPLL */ +#define CM_CLKMODE_DPLL_REGM4XEN_SHIFT 11 +#define CM_CLKMODE_DPLL_REGM4XEN_MASK (1 << 11) +#define CM_CLKMODE_DPLL_LPMODE_EN_SHIFT 10 +#define CM_CLKMODE_DPLL_LPMODE_EN_MASK (1 << 10) +#define CM_CLKMODE_DPLL_RELOCK_RAMP_EN_SHIFT 9 +#define CM_CLKMODE_DPLL_RELOCK_RAMP_EN_MASK (1 << 9) +#define CM_CLKMODE_DPLL_DRIFTGUARD_EN_SHIFT 8 +#define CM_CLKMODE_DPLL_DRIFTGUARD_EN_MASK (1 << 8) +#define CM_CLKMODE_DPLL_RAMP_RATE_SHIFT 5 +#define CM_CLKMODE_DPLL_RAMP_RATE_MASK (0x7 << 5) +#define CM_CLKMODE_DPLL_EN_SHIFT 0 +#define CM_CLKMODE_DPLL_EN_MASK (0x7 << 0) + +#define CM_CLKMODE_DPLL_DPLL_EN_SHIFT 0 +#define CM_CLKMODE_DPLL_DPLL_EN_MASK 7 + +#define DPLL_EN_STOP 1 +#define DPLL_EN_MN_BYPASS 4 +#define DPLL_EN_LOW_POWER_BYPASS 5 +#define DPLL_EN_FAST_RELOCK_BYPASS 6 +#define DPLL_EN_LOCK 7 + +/* CM_IDLEST_DPLL fields */ +#define ST_DPLL_CLK_MASK 1 + +/* CM_CLKSEL_DPLL */ +#define CM_CLKSEL_DPLL_DPLL_SD_DIV_SHIFT 24 +#define CM_CLKSEL_DPLL_DPLL_SD_DIV_MASK (0xFF << 24) +#define CM_CLKSEL_DPLL_M_SHIFT 8 +#define CM_CLKSEL_DPLL_M_MASK (0x7FF << 8) +#define CM_CLKSEL_DPLL_N_SHIFT 0 +#define CM_CLKSEL_DPLL_N_MASK 0x7F + +#define OMAP4_DPLL_MAX_N 127 + +/* CM_SYS_CLKSEL */ +#define CM_SYS_CLKSEL_SYS_CLKSEL_MASK 7 + +/* CM_CLKSEL_CORE */ +#define CLKSEL_CORE_SHIFT 0 +#define CLKSEL_L3_SHIFT 4 +#define CLKSEL_L4_SHIFT 8 + +#define CLKSEL_CORE_X2_DIV_1 0 +#define CLKSEL_L3_CORE_DIV_2 1 +#define CLKSEL_L4_L3_DIV_2 1 + +/* CM_ABE_PLL_REF_CLKSEL */ +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_SHIFT 0 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_MASK 1 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_SYSCLK 0 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_32KCLK 1 + +/* CM_BYPCLK_DPLL_IVA */ +#define CM_BYPCLK_DPLL_IVA_CLKSEL_SHIFT 0 +#define CM_BYPCLK_DPLL_IVA_CLKSEL_MASK 3 + +#define DPLL_IVA_CLKSEL_CORE_X2_DIV_2 1 + +/* CM_SHADOW_FREQ_CONFIG1 */ +#define SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK 1 +#define SHADOW_FREQ_CONFIG1_DLL_OVERRIDE_MASK 4 +#define SHADOW_FREQ_CONFIG1_DLL_RESET_MASK 8 + +#define SHADOW_FREQ_CONFIG1_DPLL_EN_SHIFT 8 +#define SHADOW_FREQ_CONFIG1_DPLL_EN_MASK (7 << 8) + +#define SHADOW_FREQ_CONFIG1_M2_DIV_SHIFT 11 +#define SHADOW_FREQ_CONFIG1_M2_DIV_MASK (0x1F << 11) + +/*CM_<clock_domain>__CLKCTRL */ +#define CD_CLKCTRL_CLKTRCTRL_SHIFT 0 +#define CD_CLKCTRL_CLKTRCTRL_MASK 3 + +#define CD_CLKCTRL_CLKTRCTRL_NO_SLEEP 0 +#define CD_CLKCTRL_CLKTRCTRL_SW_SLEEP 1 +#define CD_CLKCTRL_CLKTRCTRL_SW_WKUP 2 +#define CD_CLKCTRL_CLKTRCTRL_HW_AUTO 3 + + +/* CM_<clock_domain>_<module>_CLKCTRL */ +#define MODULE_CLKCTRL_MODULEMODE_SHIFT 0 +#define MODULE_CLKCTRL_MODULEMODE_MASK 3 +#define MODULE_CLKCTRL_IDLEST_SHIFT 16 +#define MODULE_CLKCTRL_IDLEST_MASK (3 << 16) + +#define MODULE_CLKCTRL_MODULEMODE_SW_DISABLE 0 +#define MODULE_CLKCTRL_MODULEMODE_HW_AUTO 1 +#define MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN 2 + +#define MODULE_CLKCTRL_IDLEST_FULLY_FUNCTIONAL 0 +#define MODULE_CLKCTRL_IDLEST_TRANSITIONING 1 +#define MODULE_CLKCTRL_IDLEST_IDLE 2 +#define MODULE_CLKCTRL_IDLEST_DISABLED 3 + +/* CM_L4PER_GPIO4_CLKCTRL */ +#define GPIO4_CLKCTRL_OPTFCLKEN_MASK (1 << 8) + +/* CM_L3INIT_HSMMCn_CLKCTRL */ +#define HSMMC_CLKCTRL_CLKSEL_MASK (1 << 24) + +/* CM_WKUP_GPTIMER1_CLKCTRL */ +#define GPTIMER1_CLKCTRL_CLKSEL_MASK (1 << 24) + +/* CM_CAM_ISS_CLKCTRL */ +#define ISS_CLKCTRL_OPTFCLKEN_MASK (1 << 8) + +/* CM_DSS_DSS_CLKCTRL */ +#define DSS_CLKCTRL_OPTFCLKEN_MASK 0xF00 + +/* CM_L3INIT_USBPHY_CLKCTRL */ +#define USBPHY_CLKCTRL_OPTFCLKEN_PHY_48M_MASK 8 + +/* Clock frequencies */ +#define OMAP_SYS_CLK_FREQ_38_4_MHZ 38400000 +#define OMAP_SYS_CLK_IND_38_4_MHZ 6 +#define OMAP_32K_CLK_FREQ 32768 + +/* PRM_VC_CFG_I2C_CLK */ +#define PRM_VC_CFG_I2C_CLK_SCLH_SHIFT 0 +#define PRM_VC_CFG_I2C_CLK_SCLH_MASK 0xFF +#define PRM_VC_CFG_I2C_CLK_SCLL_SHIFT 8 +#define PRM_VC_CFG_I2C_CLK_SCLL_MASK (0xFF << 8) + +/* PRM_VC_VAL_BYPASS */ +#define PRM_VC_I2C_CHANNEL_FREQ_KHZ 400 + +#define PRM_VC_VAL_BYPASS_VALID_BIT 0x1000000 +#define PRM_VC_VAL_BYPASS_SLAVEADDR_SHIFT 0 +#define PRM_VC_VAL_BYPASS_SLAVEADDR_MASK 0x7F +#define PRM_VC_VAL_BYPASS_REGADDR_SHIFT 8 +#define PRM_VC_VAL_BYPASS_REGADDR_MASK 0xFF +#define PRM_VC_VAL_BYPASS_DATA_SHIFT 16 +#define PRM_VC_VAL_BYPASS_DATA_MASK 0xFF + +#define SMPS_I2C_SLAVE_ADDR 0x12 +#define SMPS_REG_ADDR_VCORE1 0x55 +#define SMPS_REG_ADDR_VCORE2 0x5B +#define SMPS_REG_ADDR_VCORE3 0x61 + +#define PHOENIX_SMPS_BASE_VOLT_STD_MODE_UV 607700 +#define PHOENIX_SMPS_BASE_VOLT_STD_MODE_WITH_OFFSET_UV 709000 + +/* Defines for DPLL setup */ +#define DPLL_LOCKED_FREQ_TOLERANCE_0 0 +#define DPLL_LOCKED_FREQ_TOLERANCE_500_KHZ 500 +#define DPLL_LOCKED_FREQ_TOLERANCE_1_MHZ 1000 + +#define DPLL_NO_LOCK 0 +#define DPLL_LOCK 1 + +#define NUM_SYS_CLKS 7 + +struct dpll_regs { + u32 cm_clkmode_dpll; + u32 cm_idlest_dpll; + u32 cm_autoidle_dpll; + u32 cm_clksel_dpll; + u32 cm_div_m2_dpll; + u32 cm_div_m3_dpll; + u32 cm_div_m4_dpll; + u32 cm_div_m5_dpll; + u32 cm_div_m6_dpll; + u32 cm_div_m7_dpll; +}; + +/* DPLL parameter table */ +struct dpll_params { + u32 m; + u32 n; + u8 m2; + u8 m3; + u8 m4; + u8 m5; + u8 m6; + u8 m7; +}; + +#endif /* _CLOCKS_OMAP4_H_ */ diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index c10fa18..f871921 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -22,6 +22,7 @@ #define _SYS_PROTO_H_
#include <asm/arch/omap4.h> +#include <asm/arch/clocks.h> #include <asm/io.h> #include <asm/omap_common.h> #include <asm/arch/mux_omap4.h> @@ -31,6 +32,8 @@ struct omap_sysinfo { }; extern const struct omap_sysinfo sysinfo;
+extern struct omap4_prcm_regs *const prcm; + void gpmc_init(void); void watchdog_init(void); u32 get_device_type(void); @@ -41,6 +44,11 @@ u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); void set_pl310_ctrl_reg(u32 val); void omap_rev_string(char *omap4_rev_string); +void prcm_init(void); +void bypass_dpll(u32 *const base); +void freq_update_core(void); +u32 get_sys_clk_freq(void); +u32 omap4_ddr_clk(void);
static inline u32 running_from_sdram(void) { diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index d80f665..33caa4e 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -25,6 +25,9 @@ #ifndef _OMAP_COMMON_H_ #define _OMAP_COMMON_H_
+/* Max value for DPLL multiplier M */ +#define OMAP_DPLL_MAX_N 127 + /* HW Init Context */ #define OMAP_INIT_CONTEXT_SPL 0 #define OMAP_INIT_CONTEXT_UBOOT_FROM_NOR 1 diff --git a/tools/omap/clocks_get_m_n.c b/tools/omap/clocks_get_m_n.c new file mode 100644 index 0000000..cfc1760 --- /dev/null +++ b/tools/omap/clocks_get_m_n.c @@ -0,0 +1,197 @@ +/* + * Program for finding M & N values for DPLLs + * To be run on Host PC + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <stdlib.h> +#include <stdio.h> +typedef unsigned int u32; +#define MAX_N 127 + +/* + * get_m_n_optimized() - Finds optimal DPLL multiplier(M) and divider(N) + * values based on the reference frequency, required output frequency, + * maximum tolerance for output frequency etc. + * + * target_freq_khz - output frequency required in KHz + * ref_freq_khz - reference(input) frequency in KHz + * m - pointer to computed M value + * n - pointer to computed N value + * tolerance_khz - tolerance for the output frequency. When the algorithm + * succeeds in finding vialble M and N values the corresponding output + * frequency will be in the range: + * [target_freq_khz - tolerance_khz, target_freq_khz] + * + * Formula: + * Fdpll = (2 * M * Fref) / (N + 1) + * + * Considerations for lock-time: + * - Smaller the N, better lock-time, especially lock-time will be + * - For acceptable lock-times: + * Fref / (M + 1) >= 1 MHz + * + * Considerations for power: + * - The difference in power for different N values giving the same + * output is negligible. So, we optimize for lock-time + * + * Hard-constraints: + * - N can not be greater than 127(7 bit field for representing N) + * + * Usage: + * $ gcc clocks_get_m_n.c + * $ ./a.out + */ +int get_m_n_optimized(u32 target_freq_khz, u32 ref_freq_khz, u32 *m, u32 *n, + u32 tolerance_khz) +{ + u32 min_freq = target_freq_khz - tolerance_khz; + u32 max_freq = target_freq_khz; + u32 freq, freq_old; + *n = 1; + while (1) { + *m = min_freq / ref_freq_khz / 2 * (*n) ; + freq_old = 0; + while (1) { + freq = ref_freq_khz * 2 * (*m) / (*n); + if (abs(target_freq_khz - freq_old) <= + abs(target_freq_khz - freq)) { + freq = freq_old; + (*m)--; + break; + } + (*m)++; + freq_old = freq; + } + if (freq >= min_freq && freq <= max_freq) + break; + (*n)++; + if ((*n) > MAX_N + 1) { + printf("ref %d m %d n %d target %d : ", + ref_freq_khz, *m, *n, target_freq_khz); + printf("can not find m & n - please consider" + " increasing tolerance\n"); + return -1; + } + } + (*n)--; + printf("ref %d m %d n %d target %d locked %d\n", + ref_freq_khz, *m, *n, target_freq_khz, freq); + if ((ref_freq_khz / (*n + 1)) < 1000) { + printf("\tREFCLK - CLKINP/(N+1) is less than 1 MHz - less than" + " ideal, locking time will be high!\n"); + } + return 0; +} + +void main(void) +{ + u32 m, n; + printf("\nMPU - 2000000\n"); + get_m_n_optimized(2000000, 12000, &m, &n, 0); + get_m_n_optimized(2000000, 13000, &m, &n, 0); + get_m_n_optimized(2000000, 16800, &m, &n, 800); + get_m_n_optimized(2000000, 19200, &m, &n, 0); + get_m_n_optimized(2000000, 26000, &m, &n, 0); + get_m_n_optimized(2000000, 27000, &m, &n, 0); + get_m_n_optimized(2000000, 38400, &m, &n, 0); + + printf("\nMPU - 1200000\n"); + get_m_n_optimized(1200000, 12000, &m, &n, 0); + get_m_n_optimized(1200000, 13000, &m, &n, 0); + get_m_n_optimized(1200000, 16800, &m, &n, 800); + get_m_n_optimized(1200000, 19200, &m, &n, 0); + get_m_n_optimized(1200000, 26000, &m, &n, 0); + get_m_n_optimized(1200000, 27000, &m, &n, 0); + get_m_n_optimized(1200000, 38400, &m, &n, 0); + + printf("\nMPU - 1584000\n"); + get_m_n_optimized(1584000, 12000, &m, &n, 0); + get_m_n_optimized(1584000, 13000, &m, &n, 0); + get_m_n_optimized(1584000, 16800, &m, &n, 400); + get_m_n_optimized(1584000, 19200, &m, &n, 0); + get_m_n_optimized(1584000, 26000, &m, &n, 0); + get_m_n_optimized(1584000, 27000, &m, &n, 0); + get_m_n_optimized(1584000, 38400, &m, &n, 0); + + printf("\nCore 1600000\n"); + get_m_n_optimized(1600000, 12000, &m, &n, 0); + get_m_n_optimized(1600000, 13000, &m, &n, 0); + get_m_n_optimized(1600000, 16800, &m, &n, 200); + get_m_n_optimized(1600000, 19200, &m, &n, 0); + get_m_n_optimized(1600000, 26000, &m, &n, 0); + get_m_n_optimized(1600000, 27000, &m, &n, 0); + get_m_n_optimized(1600000, 38400, &m, &n, 0); + + printf("\nPER 1536000\n"); + get_m_n_optimized(1536000, 12000, &m, &n, 0); + get_m_n_optimized(1536000, 13000, &m, &n, 0); + get_m_n_optimized(1536000, 16800, &m, &n, 0); + get_m_n_optimized(1536000, 19200, &m, &n, 0); + get_m_n_optimized(1536000, 26000, &m, &n, 0); + get_m_n_optimized(1536000, 27000, &m, &n, 0); + get_m_n_optimized(1536000, 38400, &m, &n, 0); + + printf("\nIVA 1862000\n"); + get_m_n_optimized(1862000, 12000, &m, &n, 0); + get_m_n_optimized(1862000, 13000, &m, &n, 0); + get_m_n_optimized(1862000, 16800, &m, &n, 0); + get_m_n_optimized(1862000, 19200, &m, &n, 900); + get_m_n_optimized(1862000, 26000, &m, &n, 0); + get_m_n_optimized(1862000, 27000, &m, &n, 0); + get_m_n_optimized(1862000, 38400, &m, &n, 800); + + printf("\nABE 196608 sys clk\n"); + get_m_n_optimized(196608, 12000, &m, &n, 700); + get_m_n_optimized(196608, 13000, &m, &n, 200); + get_m_n_optimized(196608, 16800, &m, &n, 700); + get_m_n_optimized(196608, 19200, &m, &n, 400); + get_m_n_optimized(196608, 26000, &m, &n, 200); + get_m_n_optimized(196608, 27000, &m, &n, 900); + get_m_n_optimized(196608, 38400, &m, &n, 0); + + printf("\nABE 196608 32K\n"); + get_m_n_optimized(196608000/4, 32768, &m, &n, 0); + + printf("\nUSB 1920000\n"); + get_m_n_optimized(1920000, 12000, &m, &n, 0); + get_m_n_optimized(1920000, 13000, &m, &n, 0); + get_m_n_optimized(1920000, 16800, &m, &n, 0); + get_m_n_optimized(1920000, 19200, &m, &n, 0); + get_m_n_optimized(1920000, 26000, &m, &n, 0); + get_m_n_optimized(1920000, 27000, &m, &n, 0); + get_m_n_optimized(1920000, 38400, &m, &n, 0); + + printf("\nCore ES1 1523712\n"); + get_m_n_optimized(1524000, 12000, &m, &n, 100); + get_m_n_optimized(1524000, 13000, &m, &n, 0); + get_m_n_optimized(1524000, 16800, &m, &n, 0); + get_m_n_optimized(1524000, 19200, &m, &n, 0); + get_m_n_optimized(1524000, 26000, &m, &n, 0); + get_m_n_optimized(1524000, 27000, &m, &n, 0); + + /* exact recommendation for SDPs */ + get_m_n_optimized(1523712, 38400, &m, &n, 0); + +}
Add support for the SDRAM controller (EMIF).
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Minor corrections in do_lpddr2_init() * Minor corrections to read_idle interval calculation * Sanity test of memory after doing the initialization * Fixed warnings reported with with latest GCC compilers V3: * Removed references to modify_reg_32() * Updated references to OMAP_INIT_CONTEXT_* flags * Replaced calls to omap4_revision() with omap_revision() * Replaced sanity test with get_ram_size() --- arch/arm/cpu/armv7/omap4/Makefile | 2 + arch/arm/cpu/armv7/omap4/board.c | 6 +- arch/arm/cpu/armv7/omap4/emif.c | 328 +++++++++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 131 ++++ arch/arm/include/asm/arch-omap4/clocks.h | 8 +- arch/arm/include/asm/arch-omap4/emif.h | 1025 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 5 + arch/arm/include/asm/arch-omap4/sys_proto.h | 2 + 8 files changed, 1500 insertions(+), 7 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/emif.c create mode 100644 arch/arm/cpu/armv7/omap4/sdram_elpida.c create mode 100644 arch/arm/include/asm/arch-omap4/emif.h
diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index ac4b2a6..e1ccd68 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -29,7 +29,9 @@ SOBJS += lowlevel_init.o
COBJS += board.o COBJS += clocks.o +COBJS += emif.o COBJS += mem.o +COBJS += sdram_elpida.o COBJS += sys_info.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 1c26a66..ca107f7 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -189,7 +189,7 @@ void watchdog_init(void) * This is needed because the size of memory installed may be * different on different versions of the board */ -u32 sdram_size(void) +u32 omap4_sdram_size(void) { u32 section, i, total_size = 0, size, addr; for (i = 0; i < 4; i++) { @@ -215,8 +215,8 @@ u32 sdram_size(void) */ int dram_init(void) { - - gd->ram_size = sdram_size(); + sdram_init(); + gd->ram_size = omap4_sdram_size();
return 0; } diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c new file mode 100644 index 0000000..b25c1ee --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -0,0 +1,328 @@ +/* + * EMIF programming + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/emif.h> +#include <asm/arch/clocks.h> +#include <asm/arch/sys_proto.h> +#include <asm/omap_common.h> +#include <asm/utils.h> + +static inline u32 emif_num(u32 base) +{ + if (base == OMAP44XX_EMIF1) + return 1; + else if (base == OMAP44XX_EMIF2) + return 2; + else + return 0; +} + +static inline u32 get_mr(u32 base, u32 cs, u32 mr_addr) +{ + u32 mr; + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + mr_addr |= cs << OMAP44XX_REG_CS_SHIFT; + writel(mr_addr, &emif->emif_lpddr2_mode_reg_cfg); + if (omap_revision() == OMAP4430_ES2_0) + mr = readl(&emif->emif_lpddr2_mode_reg_data_es2); + else + mr = readl(&emif->emif_lpddr2_mode_reg_data); + debug("get_mr: EMIF%d cs %d mr %08x val 0x%x\n", emif_num(base), + cs, mr_addr, mr); + return mr; +} + +static inline void set_mr(u32 base, u32 cs, u32 mr_addr, u32 mr_val) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + mr_addr |= cs << OMAP44XX_REG_CS_SHIFT; + writel(mr_addr, &emif->emif_lpddr2_mode_reg_cfg); + writel(mr_val, &emif->emif_lpddr2_mode_reg_data); +} + +void emif_reset_phy(u32 base) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + u32 iodft; + + iodft = readl(&emif->emif_iodft_tlgc); + iodft |= OMAP44XX_REG_RESET_PHY_MASK; + writel(iodft, &emif->emif_iodft_tlgc); +} + +static void do_lpddr2_init(u32 base, u32 cs) +{ + u32 mr_addr; + + /* Wait till device auto initialization is complete */ + while (get_mr(base, cs, LPDDR2_MR0) & LPDDR2_MR0_DAI_MASK) + ; + set_mr(base, cs, LPDDR2_MR10, MR10_ZQ_ZQINIT); + /* + * tZQINIT = 1 us + * Enough loops assuming a maximum of 2GHz + */ + sdelay(2000); + set_mr(base, cs, LPDDR2_MR1, MR1_BL_8_BT_SEQ_WRAP_EN_NWR_3); + set_mr(base, cs, LPDDR2_MR16, MR16_REF_FULL_ARRAY); + /* + * Enable refresh along with writing MR2 + * Encoding of RL in MR2 is (RL - 2) + */ + mr_addr = LPDDR2_MR2 | OMAP44XX_REG_REFRESH_EN_MASK; + set_mr(base, cs, mr_addr, RL_FINAL - 2); +} + +static void lpddr2_init(u32 base, const struct emif_regs *regs) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + /* Not NVM */ + clrbits_le32(&emif->emif_lpddr2_nvm_config, OMAP44XX_REG_CS1NVMEN_MASK); + + /* + * Keep REG_INITREF_DIS = 1 to prevent re-initialization of SDRAM + * when EMIF_SDRAM_CONFIG register is written + */ + setbits_le32(&emif->emif_sdram_ref_ctrl, OMAP44XX_REG_INITREF_DIS_MASK); + + /* + * Set the SDRAM_CONFIG and PHY_CTRL for the + * un-locked frequency & default RL + */ + writel(regs->sdram_config_init, &emif->emif_sdram_config); + writel(regs->emif_ddr_phy_ctlr_1_init, &emif->emif_ddr_phy_ctrl_1); + + do_lpddr2_init(base, CS0); + if (regs->sdram_config & OMAP44XX_REG_EBANK_MASK) + do_lpddr2_init(base, CS1); + + writel(regs->sdram_config, &emif->emif_sdram_config); + writel(regs->emif_ddr_phy_ctlr_1, &emif->emif_ddr_phy_ctrl_1); + + /* Enable refresh now */ + clrbits_le32(&emif->emif_sdram_ref_ctrl, OMAP44XX_REG_INITREF_DIS_MASK); + +} + +static void emif_update_timings(u32 base, const struct emif_regs *regs) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + writel(regs->ref_ctrl, &emif->emif_sdram_ref_ctrl_shdw); + writel(regs->sdram_tim1, &emif->emif_sdram_tim_1_shdw); + writel(regs->sdram_tim2, &emif->emif_sdram_tim_2_shdw); + writel(regs->sdram_tim3, &emif->emif_sdram_tim_3_shdw); + if (omap_revision() == OMAP4430_ES1_0) { + /* ES1 bug EMIF should be in force idle during freq_update */ + writel(0, &emif->emif_pwr_mgmt_ctrl); + } else { + writel(EMIF_PWR_MGMT_CTRL, &emif->emif_pwr_mgmt_ctrl); + writel(EMIF_PWR_MGMT_CTRL_SHDW, &emif->emif_pwr_mgmt_ctrl_shdw); + } + writel(regs->read_idle_ctrl, &emif->emif_read_idlectrl_shdw); + writel(regs->zq_config, &emif->emif_zq_config); + writel(regs->temp_alert_config, &emif->emif_temp_alert_config); + writel(regs->emif_ddr_phy_ctlr_1, &emif->emif_ddr_phy_ctrl_1_shdw); + /* + * Workaround: + * In a specific situation, the OCP interface between the DMM and + * EMIF may hang. + * 1. A TILER port is used to perform 2D burst writes of + * width 1 and height 8 + * 2. ELLAn port is used to perform reads + * 3. All accesses are routed to the same EMIF controller + * + * Work around to avoid this issue REG_SYS_THRESH_MAX value should + * be kept higher than default 0x7. As per recommondation 0x0A will + * be used for better performance with REG_LL_THRESH_MAX = 0x00 + */ + if (omap_revision() == OMAP4430_ES1_0) { + writel(EMIF_L3_CONFIG_VAL_SYS_THRESH_0A_LL_THRESH_00, + &emif->emif_l3_config); + } +} + +static void do_sdram_init(u32 base) +{ + const struct emif_regs *regs; + u32 in_sdram, emif_nr; + + debug(">>do_sdram_init() %x\n", base); + + in_sdram = running_from_sdram(); + emif_nr = (base == OMAP44XX_EMIF1) ? 1 : 2; + + emif_get_reg_dump(emif_nr, ®s); + if (!regs) { + debug("EMIF: reg dump not provided\n"); + return; + } + + /* + * Initializing the LPDDR2 device can not happen from SDRAM. + * Changing the timing registers in EMIF can happen(going from one + * OPP to another) + */ + if (!in_sdram) + lpddr2_init(base, regs); + + /* Write to the shadow registers */ + emif_update_timings(base, regs); + + debug("<<do_sdram_init() %x\n", base); +} + +void sdram_init_pads(void) +{ + u32 lpddr2io; + struct control_lpddr2io_regs *lpddr2io_regs = + (struct control_lpddr2io_regs *)LPDDR2_IO_REGS_BASE; + u32 omap4_rev = omap_revision(); + + if (omap4_rev == OMAP4430_ES1_0) + lpddr2io = CONTROL_LPDDR2IO_SLEW_125PS_DRV8_PULL_DOWN; + else if (omap4_rev == OMAP4430_ES2_0) + lpddr2io = CONTROL_LPDDR2IO_SLEW_325PS_DRV8_GATE_KEEPER; + else + return; /* Post ES2.1 reset values will work */ + + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io1_0); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io1_1); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io1_2); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io2_0); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io2_1); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io2_2); + + writel(CONTROL_EFUSE_2_NMOS_PMOS_PTV_CODE_1, CONTROL_EFUSE_2); +} + +static void emif_post_init_config(u32 base) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + u32 omap4_rev = omap_revision(); + + /* reset phy on ES2.0 */ + if (omap4_rev == OMAP4430_ES2_0) + emif_reset_phy(base); + + /* Put EMIF back in smart idle on ES1.0 */ + if (omap4_rev == OMAP4430_ES1_0) + writel(0x80000000, &emif->emif_pwr_mgmt_ctrl); +} + +static void dmm_init(u32 base) +{ + const struct dmm_lisa_map_regs *lisa_map_regs; + + emif_get_dmm_regs(&lisa_map_regs); + + struct dmm_lisa_map_regs *hw_lisa_map_regs = + (struct dmm_lisa_map_regs *)base; + + writel(0, &hw_lisa_map_regs->dmm_lisa_map_3); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_2); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_1); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_0); + + writel(lisa_map_regs->dmm_lisa_map_3, + &hw_lisa_map_regs->dmm_lisa_map_3); + writel(lisa_map_regs->dmm_lisa_map_2, + &hw_lisa_map_regs->dmm_lisa_map_2); + writel(lisa_map_regs->dmm_lisa_map_1, + &hw_lisa_map_regs->dmm_lisa_map_1); + writel(lisa_map_regs->dmm_lisa_map_0, + &hw_lisa_map_regs->dmm_lisa_map_0); +} + +/* + * SDRAM initialization: + * SDRAM initialization has two parts: + * 1. Configuring the SDRAM device + * 2. Update the AC timings related parameters in the EMIF module + * (1) should be done only once and should not be done while we are + * running from SDRAM. + * (2) can and should be done more than once if OPP changes. + * Particularly, this may be needed when we boot without SPL and + * and using Configuration Header(CH). ROM code supports only at 50% OPP + * at boot (low power boot). So u-boot has to switch to OPP100 and update + * the frequency. So, + * Doing (1) and (2) makes sense - first time initialization + * Doing (2) and not (1) makes sense - OPP change (when using CH) + * Doing (1) and not (2) doen't make sense + * See do_sdram_init() for the details + */ +void sdram_init(void) +{ + u32 in_sdram, size_prog, size_detect; + + debug(">>sdram_init()\n"); + + if (omap4_hw_init_context() == OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL) + return; + + in_sdram = running_from_sdram(); + debug("in_sdram = %d\n", in_sdram); + + if (!in_sdram) { + sdram_init_pads(); + bypass_dpll(&prcm->cm_clkmode_dpll_core); + } + + do_sdram_init(OMAP44XX_EMIF1); + do_sdram_init(OMAP44XX_EMIF2); + + if (!in_sdram) { + dmm_init(OMAP44XX_DMM_LISA_MAP_BASE); + emif_post_init_config(OMAP44XX_EMIF1); + emif_post_init_config(OMAP44XX_EMIF2); + + } + + /* for the shadow registers to take effect */ + freq_update_core(); + + /* Do some testing after the init */ + if (!in_sdram) { + size_prog = omap4_sdram_size(); + size_detect = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, + size_prog); + /* Compare with the size programmed */ + if (size_detect != size_prog) { + printf("SDRAM: identified size not same as expected" + " size identified: %x expected: %x\n", + size_detect, + size_prog); + } else + debug("get_ram_size() successful"); + } + + debug("<<sdram_init()\n"); +} diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c new file mode 100644 index 0000000..c950c87 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -0,0 +1,131 @@ +/* + * Timing and Organization details of the Elpida parts used in OMAP4 + * SDPs and Panda + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/arch/emif.h> +#include <asm/arch/sys_proto.h> + +/* + * This file provides details of the LPDDR2 SDRAM parts used on OMAP4430 + * SDP and Panda. Since the parts used and geometry are identical for + * SDP and Panda for a given OMAP4 revision, this information is kept + * here instead of being in board directory. However the key functions + * exported are weakly linked so that they can be over-ridden in the board + * directory if there is a OMAP4 board in the future that uses a different + * memory device or geometry. + * + * For any new board with different memory devices over-ride one or more + * of the following functions as per the CONFIG flags you intend to enable: + * - emif_get_reg_dump() + * - emif_get_dmm_regs() + * - emif_get_device_details() + * - emif_get_device_timings() + */ + +static const struct emif_regs emif_regs_elpida_200_mhz_2cs = { + .sdram_config_init = 0x80000eb9, + .sdram_config = 0x80001ab9, + .ref_ctrl = 0x0000030c, + .sdram_tim1 = 0x08648311, + .sdram_tim2 = 0x101b06ca, + .sdram_tim3 = 0x0048a19f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0x500b3214, + .temp_alert_config = 0xd8016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff808 +}; + +static const struct emif_regs emif_regs_elpida_380_mhz_1cs = { + .sdram_config_init = 0x80000eb1, + .sdram_config = 0x80001ab1, + .ref_ctrl = 0x000005cd, + .sdram_tim1 = 0x10cb0622, + .sdram_tim2 = 0x20350d52, + .sdram_tim3 = 0x00b1431f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0x500b3214, + .temp_alert_config = 0x58016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff418 +}; + +const struct emif_regs emif_regs_elpida_400_mhz_2cs = { + .sdram_config_init = 0x80000eb9, + .sdram_config = 0x80001ab9, + .ref_ctrl = 0x00000618, + .sdram_tim1 = 0x10eb0662, + .sdram_tim2 = 0x20370dd2, + .sdram_tim3 = 0x00b1c33f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0xd00b3214, + .temp_alert_config = 0xd8016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff418 +}; +const struct dmm_lisa_map_regs lisa_map_2G_x_1_x_2 = { + .dmm_lisa_map_0 = 0xFF020100, + .dmm_lisa_map_1 = 0, + .dmm_lisa_map_2 = 0, + .dmm_lisa_map_3 = 0x80540300 +}; + +const struct dmm_lisa_map_regs lisa_map_2G_x_2_x_2 = { + .dmm_lisa_map_0 = 0xFF020100, + .dmm_lisa_map_1 = 0, + .dmm_lisa_map_2 = 0, + .dmm_lisa_map_3 = 0x80640300 +}; + +static void emif_get_reg_dump_sdp(u32 emif_nr, const struct emif_regs **regs) +{ + u32 omap4_rev = omap_revision(); + + /* Same devices and geometry on both EMIFs */ + if (omap4_rev == OMAP4430_ES1_0) + *regs = &emif_regs_elpida_380_mhz_1cs; + else if (omap4_rev == OMAP4430_ES2_0) + *regs = &emif_regs_elpida_200_mhz_2cs; + else + *regs = &emif_regs_elpida_400_mhz_2cs; +} +void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs) + __attribute__((weak, alias("emif_get_reg_dump_sdp"))); + +static void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs + **dmm_lisa_regs) +{ + u32 omap_rev = omap_revision(); + + if (omap_rev == OMAP4430_ES1_0) + *dmm_lisa_regs = &lisa_map_2G_x_1_x_2; + else + *dmm_lisa_regs = &lisa_map_2G_x_2_x_2; +} + +void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) + __attribute__((weak, alias("emif_get_dmm_regs_sdp"))); diff --git a/arch/arm/include/asm/arch-omap4/clocks.h b/arch/arm/include/asm/arch-omap4/clocks.h index 71db39c..37bdcee 100644 --- a/arch/arm/include/asm/arch-omap4/clocks.h +++ b/arch/arm/include/asm/arch-omap4/clocks.h @@ -33,10 +33,10 @@ */ #define LDELAY 1000000
-#define CM_CLKMODE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4120) -#define CM_CLKMODE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8140) -#define CM_CLKMODE_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4160) -#define CM_CLKSEL_CORE (OMAP44XX_L4_CORE_BASE + 0x4100) +#define CM_CLKMODE_DPLL_CORE 0x4A004120 +#define CM_CLKMODE_DPLL_PER 0x4A008140 +#define CM_CLKMODE_DPLL_MPU 0x4A004160 +#define CM_CLKSEL_CORE 0x4A004100
struct omap4_prcm_regs { /* cm1.ckgen */ diff --git a/arch/arm/include/asm/arch-omap4/emif.h b/arch/arm/include/asm/arch-omap4/emif.h new file mode 100644 index 0000000..09e9baa --- /dev/null +++ b/arch/arm/include/asm/arch-omap4/emif.h @@ -0,0 +1,1025 @@ +/* + * OMAP44xx EMIF header + * + * Copyright (C) 2009-2010 Texas Instruments, Inc. + * + * Aneesh V aneesh@ti.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#ifndef _EMIF_H_ +#define _EMIF_H_ +#include <asm/types.h> +#include <common.h> + +/* Base address */ +#define OMAP44XX_EMIF1 0x4c000000 +#define OMAP44XX_EMIF2 0x4d000000 + +/* Registers shifts and masks */ + +/* EMIF_MOD_ID_REV */ +#define OMAP44XX_REG_SCHEME_SHIFT 30 +#define OMAP44XX_REG_SCHEME_MASK (0x3 << 30) +#define OMAP44XX_REG_MODULE_ID_SHIFT 16 +#define OMAP44XX_REG_MODULE_ID_MASK (0xfff << 16) +#define OMAP44XX_REG_RTL_VERSION_SHIFT 11 +#define OMAP44XX_REG_RTL_VERSION_MASK (0x1f << 11) +#define OMAP44XX_REG_MAJOR_REVISION_SHIFT 8 +#define OMAP44XX_REG_MAJOR_REVISION_MASK (0x7 << 8) +#define OMAP44XX_REG_MINOR_REVISION_SHIFT 0 +#define OMAP44XX_REG_MINOR_REVISION_MASK (0x3f << 0) + +/* STATUS */ +#define OMAP44XX_REG_BE_SHIFT 31 +#define OMAP44XX_REG_BE_MASK (1 << 31) +#define OMAP44XX_REG_DUAL_CLK_MODE_SHIFT 30 +#define OMAP44XX_REG_DUAL_CLK_MODE_MASK (1 << 30) +#define OMAP44XX_REG_FAST_INIT_SHIFT 29 +#define OMAP44XX_REG_FAST_INIT_MASK (1 << 29) +#define OMAP44XX_REG_PHY_DLL_READY_SHIFT 2 +#define OMAP44XX_REG_PHY_DLL_READY_MASK (1 << 2) + +/* SDRAM_CONFIG */ +#define OMAP44XX_REG_SDRAM_TYPE_SHIFT 29 +#define OMAP44XX_REG_SDRAM_TYPE_MASK (0x7 << 29) +#define OMAP44XX_REG_IBANK_POS_SHIFT 27 +#define OMAP44XX_REG_IBANK_POS_MASK (0x3 << 27) +#define OMAP44XX_REG_DDR_TERM_SHIFT 24 +#define OMAP44XX_REG_DDR_TERM_MASK (0x7 << 24) +#define OMAP44XX_REG_DDR2_DDQS_SHIFT 23 +#define OMAP44XX_REG_DDR2_DDQS_MASK (1 << 23) +#define OMAP44XX_REG_DYN_ODT_SHIFT 21 +#define OMAP44XX_REG_DYN_ODT_MASK (0x3 << 21) +#define OMAP44XX_REG_DDR_DISABLE_DLL_SHIFT 20 +#define OMAP44XX_REG_DDR_DISABLE_DLL_MASK (1 << 20) +#define OMAP44XX_REG_SDRAM_DRIVE_SHIFT 18 +#define OMAP44XX_REG_SDRAM_DRIVE_MASK (0x3 << 18) +#define OMAP44XX_REG_CWL_SHIFT 16 +#define OMAP44XX_REG_CWL_MASK (0x3 << 16) +#define OMAP44XX_REG_NARROW_MODE_SHIFT 14 +#define OMAP44XX_REG_NARROW_MODE_MASK (0x3 << 14) +#define OMAP44XX_REG_CL_SHIFT 10 +#define OMAP44XX_REG_CL_MASK (0xf << 10) +#define OMAP44XX_REG_ROWSIZE_SHIFT 7 +#define OMAP44XX_REG_ROWSIZE_MASK (0x7 << 7) +#define OMAP44XX_REG_IBANK_SHIFT 4 +#define OMAP44XX_REG_IBANK_MASK (0x7 << 4) +#define OMAP44XX_REG_EBANK_SHIFT 3 +#define OMAP44XX_REG_EBANK_MASK (1 << 3) +#define OMAP44XX_REG_PAGESIZE_SHIFT 0 +#define OMAP44XX_REG_PAGESIZE_MASK (0x7 << 0) + +/* SDRAM_CONFIG_2 */ +#define OMAP44XX_REG_CS1NVMEN_SHIFT 30 +#define OMAP44XX_REG_CS1NVMEN_MASK (1 << 30) +#define OMAP44XX_REG_EBANK_POS_SHIFT 27 +#define OMAP44XX_REG_EBANK_POS_MASK (1 << 27) +#define OMAP44XX_REG_RDBNUM_SHIFT 4 +#define OMAP44XX_REG_RDBNUM_MASK (0x3 << 4) +#define OMAP44XX_REG_RDBSIZE_SHIFT 0 +#define OMAP44XX_REG_RDBSIZE_MASK (0x7 << 0) + +/* SDRAM_REF_CTRL */ +#define OMAP44XX_REG_INITREF_DIS_SHIFT 31 +#define OMAP44XX_REG_INITREF_DIS_MASK (1 << 31) +#define OMAP44XX_REG_SRT_SHIFT 29 +#define OMAP44XX_REG_SRT_MASK (1 << 29) +#define OMAP44XX_REG_ASR_SHIFT 28 +#define OMAP44XX_REG_ASR_MASK (1 << 28) +#define OMAP44XX_REG_PASR_SHIFT 24 +#define OMAP44XX_REG_PASR_MASK (0x7 << 24) +#define OMAP44XX_REG_REFRESH_RATE_SHIFT 0 +#define OMAP44XX_REG_REFRESH_RATE_MASK (0xffff << 0) + +/* SDRAM_REF_CTRL_SHDW */ +#define OMAP44XX_REG_REFRESH_RATE_SHDW_SHIFT 0 +#define OMAP44XX_REG_REFRESH_RATE_SHDW_MASK (0xffff << 0) + +/* SDRAM_TIM_1 */ +#define OMAP44XX_REG_T_RP_SHIFT 25 +#define OMAP44XX_REG_T_RP_MASK (0xf << 25) +#define OMAP44XX_REG_T_RCD_SHIFT 21 +#define OMAP44XX_REG_T_RCD_MASK (0xf << 21) +#define OMAP44XX_REG_T_WR_SHIFT 17 +#define OMAP44XX_REG_T_WR_MASK (0xf << 17) +#define OMAP44XX_REG_T_RAS_SHIFT 12 +#define OMAP44XX_REG_T_RAS_MASK (0x1f << 12) +#define OMAP44XX_REG_T_RC_SHIFT 6 +#define OMAP44XX_REG_T_RC_MASK (0x3f << 6) +#define OMAP44XX_REG_T_RRD_SHIFT 3 +#define OMAP44XX_REG_T_RRD_MASK (0x7 << 3) +#define OMAP44XX_REG_T_WTR_SHIFT 0 +#define OMAP44XX_REG_T_WTR_MASK (0x7 << 0) + +/* SDRAM_TIM_1_SHDW */ +#define OMAP44XX_REG_T_RP_SHDW_SHIFT 25 +#define OMAP44XX_REG_T_RP_SHDW_MASK (0xf << 25) +#define OMAP44XX_REG_T_RCD_SHDW_SHIFT 21 +#define OMAP44XX_REG_T_RCD_SHDW_MASK (0xf << 21) +#define OMAP44XX_REG_T_WR_SHDW_SHIFT 17 +#define OMAP44XX_REG_T_WR_SHDW_MASK (0xf << 17) +#define OMAP44XX_REG_T_RAS_SHDW_SHIFT 12 +#define OMAP44XX_REG_T_RAS_SHDW_MASK (0x1f << 12) +#define OMAP44XX_REG_T_RC_SHDW_SHIFT 6 +#define OMAP44XX_REG_T_RC_SHDW_MASK (0x3f << 6) +#define OMAP44XX_REG_T_RRD_SHDW_SHIFT 3 +#define OMAP44XX_REG_T_RRD_SHDW_MASK (0x7 << 3) +#define OMAP44XX_REG_T_WTR_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_WTR_SHDW_MASK (0x7 << 0) + +/* SDRAM_TIM_2 */ +#define OMAP44XX_REG_T_XP_SHIFT 28 +#define OMAP44XX_REG_T_XP_MASK (0x7 << 28) +#define OMAP44XX_REG_T_ODT_SHIFT 25 +#define OMAP44XX_REG_T_ODT_MASK (0x7 << 25) +#define OMAP44XX_REG_T_XSNR_SHIFT 16 +#define OMAP44XX_REG_T_XSNR_MASK (0x1ff << 16) +#define OMAP44XX_REG_T_XSRD_SHIFT 6 +#define OMAP44XX_REG_T_XSRD_MASK (0x3ff << 6) +#define OMAP44XX_REG_T_RTP_SHIFT 3 +#define OMAP44XX_REG_T_RTP_MASK (0x7 << 3) +#define OMAP44XX_REG_T_CKE_SHIFT 0 +#define OMAP44XX_REG_T_CKE_MASK (0x7 << 0) + +/* SDRAM_TIM_2_SHDW */ +#define OMAP44XX_REG_T_XP_SHDW_SHIFT 28 +#define OMAP44XX_REG_T_XP_SHDW_MASK (0x7 << 28) +#define OMAP44XX_REG_T_ODT_SHDW_SHIFT 25 +#define OMAP44XX_REG_T_ODT_SHDW_MASK (0x7 << 25) +#define OMAP44XX_REG_T_XSNR_SHDW_SHIFT 16 +#define OMAP44XX_REG_T_XSNR_SHDW_MASK (0x1ff << 16) +#define OMAP44XX_REG_T_XSRD_SHDW_SHIFT 6 +#define OMAP44XX_REG_T_XSRD_SHDW_MASK (0x3ff << 6) +#define OMAP44XX_REG_T_RTP_SHDW_SHIFT 3 +#define OMAP44XX_REG_T_RTP_SHDW_MASK (0x7 << 3) +#define OMAP44XX_REG_T_CKE_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_CKE_SHDW_MASK (0x7 << 0) + +/* SDRAM_TIM_3 */ +#define OMAP44XX_REG_T_CKESR_SHIFT 21 +#define OMAP44XX_REG_T_CKESR_MASK (0x7 << 21) +#define OMAP44XX_REG_ZQ_ZQCS_SHIFT 15 +#define OMAP44XX_REG_ZQ_ZQCS_MASK (0x3f << 15) +#define OMAP44XX_REG_T_TDQSCKMAX_SHIFT 13 +#define OMAP44XX_REG_T_TDQSCKMAX_MASK (0x3 << 13) +#define OMAP44XX_REG_T_RFC_SHIFT 4 +#define OMAP44XX_REG_T_RFC_MASK (0x1ff << 4) +#define OMAP44XX_REG_T_RAS_MAX_SHIFT 0 +#define OMAP44XX_REG_T_RAS_MAX_MASK (0xf << 0) + +/* SDRAM_TIM_3_SHDW */ +#define OMAP44XX_REG_T_CKESR_SHDW_SHIFT 21 +#define OMAP44XX_REG_T_CKESR_SHDW_MASK (0x7 << 21) +#define OMAP44XX_REG_ZQ_ZQCS_SHDW_SHIFT 15 +#define OMAP44XX_REG_ZQ_ZQCS_SHDW_MASK (0x3f << 15) +#define OMAP44XX_REG_T_TDQSCKMAX_SHDW_SHIFT 13 +#define OMAP44XX_REG_T_TDQSCKMAX_SHDW_MASK (0x3 << 13) +#define OMAP44XX_REG_T_RFC_SHDW_SHIFT 4 +#define OMAP44XX_REG_T_RFC_SHDW_MASK (0x1ff << 4) +#define OMAP44XX_REG_T_RAS_MAX_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_RAS_MAX_SHDW_MASK (0xf << 0) + +/* LPDDR2_NVM_TIM */ +#define OMAP44XX_REG_NVM_T_XP_SHIFT 28 +#define OMAP44XX_REG_NVM_T_XP_MASK (0x7 << 28) +#define OMAP44XX_REG_NVM_T_WTR_SHIFT 24 +#define OMAP44XX_REG_NVM_T_WTR_MASK (0x7 << 24) +#define OMAP44XX_REG_NVM_T_RP_SHIFT 20 +#define OMAP44XX_REG_NVM_T_RP_MASK (0xf << 20) +#define OMAP44XX_REG_NVM_T_WRA_SHIFT 16 +#define OMAP44XX_REG_NVM_T_WRA_MASK (0xf << 16) +#define OMAP44XX_REG_NVM_T_RRD_SHIFT 8 +#define OMAP44XX_REG_NVM_T_RRD_MASK (0xff << 8) +#define OMAP44XX_REG_NVM_T_RCDMIN_SHIFT 0 +#define OMAP44XX_REG_NVM_T_RCDMIN_MASK (0xff << 0) + +/* LPDDR2_NVM_TIM_SHDW */ +#define OMAP44XX_REG_NVM_T_XP_SHDW_SHIFT 28 +#define OMAP44XX_REG_NVM_T_XP_SHDW_MASK (0x7 << 28) +#define OMAP44XX_REG_NVM_T_WTR_SHDW_SHIFT 24 +#define OMAP44XX_REG_NVM_T_WTR_SHDW_MASK (0x7 << 24) +#define OMAP44XX_REG_NVM_T_RP_SHDW_SHIFT 20 +#define OMAP44XX_REG_NVM_T_RP_SHDW_MASK (0xf << 20) +#define OMAP44XX_REG_NVM_T_WRA_SHDW_SHIFT 16 +#define OMAP44XX_REG_NVM_T_WRA_SHDW_MASK (0xf << 16) +#define OMAP44XX_REG_NVM_T_RRD_SHDW_SHIFT 8 +#define OMAP44XX_REG_NVM_T_RRD_SHDW_MASK (0xff << 8) +#define OMAP44XX_REG_NVM_T_RCDMIN_SHDW_SHIFT 0 +#define OMAP44XX_REG_NVM_T_RCDMIN_SHDW_MASK (0xff << 0) + +/* PWR_MGMT_CTRL */ +#define OMAP44XX_REG_IDLEMODE_SHIFT 30 +#define OMAP44XX_REG_IDLEMODE_MASK (0x3 << 30) +#define OMAP44XX_REG_PD_TIM_SHIFT 12 +#define OMAP44XX_REG_PD_TIM_MASK (0xf << 12) +#define OMAP44XX_REG_DPD_EN_SHIFT 11 +#define OMAP44XX_REG_DPD_EN_MASK (1 << 11) +#define OMAP44XX_REG_LP_MODE_SHIFT 8 +#define OMAP44XX_REG_LP_MODE_MASK (0x7 << 8) +#define OMAP44XX_REG_SR_TIM_SHIFT 4 +#define OMAP44XX_REG_SR_TIM_MASK (0xf << 4) +#define OMAP44XX_REG_CS_TIM_SHIFT 0 +#define OMAP44XX_REG_CS_TIM_MASK (0xf << 0) + +/* PWR_MGMT_CTRL_SHDW */ +#define OMAP44XX_REG_PD_TIM_SHDW_SHIFT 8 +#define OMAP44XX_REG_PD_TIM_SHDW_MASK (0xf << 8) +#define OMAP44XX_REG_SR_TIM_SHDW_SHIFT 4 +#define OMAP44XX_REG_SR_TIM_SHDW_MASK (0xf << 4) +#define OMAP44XX_REG_CS_TIM_SHDW_SHIFT 0 +#define OMAP44XX_REG_CS_TIM_SHDW_MASK (0xf << 0) + +/* LPDDR2_MODE_REG_DATA */ +#define OMAP44XX_REG_VALUE_0_SHIFT 0 +#define OMAP44XX_REG_VALUE_0_MASK (0x7f << 0) + +/* LPDDR2_MODE_REG_CFG */ +#define OMAP44XX_REG_CS_SHIFT 31 +#define OMAP44XX_REG_CS_MASK (1 << 31) +#define OMAP44XX_REG_REFRESH_EN_SHIFT 30 +#define OMAP44XX_REG_REFRESH_EN_MASK (1 << 30) +#define OMAP44XX_REG_ADDRESS_SHIFT 0 +#define OMAP44XX_REG_ADDRESS_MASK (0xff << 0) + +/* OCP_CONFIG */ +#define OMAP44XX_REG_SYS_THRESH_MAX_SHIFT 24 +#define OMAP44XX_REG_SYS_THRESH_MAX_MASK (0xf << 24) +#define OMAP44XX_REG_LL_THRESH_MAX_SHIFT 16 +#define OMAP44XX_REG_LL_THRESH_MAX_MASK (0xf << 16) +#define OMAP44XX_REG_PR_OLD_COUNT_SHIFT 0 +#define OMAP44XX_REG_PR_OLD_COUNT_MASK (0xff << 0) + +/* OCP_CFG_VAL_1 */ +#define OMAP44XX_REG_SYS_BUS_WIDTH_SHIFT 30 +#define OMAP44XX_REG_SYS_BUS_WIDTH_MASK (0x3 << 30) +#define OMAP44XX_REG_LL_BUS_WIDTH_SHIFT 28 +#define OMAP44XX_REG_LL_BUS_WIDTH_MASK (0x3 << 28) +#define OMAP44XX_REG_WR_FIFO_DEPTH_SHIFT 8 +#define OMAP44XX_REG_WR_FIFO_DEPTH_MASK (0xff << 8) +#define OMAP44XX_REG_CMD_FIFO_DEPTH_SHIFT 0 +#define OMAP44XX_REG_CMD_FIFO_DEPTH_MASK (0xff << 0) + +/* OCP_CFG_VAL_2 */ +#define OMAP44XX_REG_RREG_FIFO_DEPTH_SHIFT 16 +#define OMAP44XX_REG_RREG_FIFO_DEPTH_MASK (0xff << 16) +#define OMAP44XX_REG_RSD_FIFO_DEPTH_SHIFT 8 +#define OMAP44XX_REG_RSD_FIFO_DEPTH_MASK (0xff << 8) +#define OMAP44XX_REG_RCMD_FIFO_DEPTH_SHIFT 0 +#define OMAP44XX_REG_RCMD_FIFO_DEPTH_MASK (0xff << 0) + +/* IODFT_TLGC */ +#define OMAP44XX_REG_TLEC_SHIFT 16 +#define OMAP44XX_REG_TLEC_MASK (0xffff << 16) +#define OMAP44XX_REG_MT_SHIFT 14 +#define OMAP44XX_REG_MT_MASK (1 << 14) +#define OMAP44XX_REG_ACT_CAP_EN_SHIFT 13 +#define OMAP44XX_REG_ACT_CAP_EN_MASK (1 << 13) +#define OMAP44XX_REG_OPG_LD_SHIFT 12 +#define OMAP44XX_REG_OPG_LD_MASK (1 << 12) +#define OMAP44XX_REG_RESET_PHY_SHIFT 10 +#define OMAP44XX_REG_RESET_PHY_MASK (1 << 10) +#define OMAP44XX_REG_MMS_SHIFT 8 +#define OMAP44XX_REG_MMS_MASK (1 << 8) +#define OMAP44XX_REG_MC_SHIFT 4 +#define OMAP44XX_REG_MC_MASK (0x3 << 4) +#define OMAP44XX_REG_PC_SHIFT 1 +#define OMAP44XX_REG_PC_MASK (0x7 << 1) +#define OMAP44XX_REG_TM_SHIFT 0 +#define OMAP44XX_REG_TM_MASK (1 << 0) + +/* IODFT_CTRL_MISR_RSLT */ +#define OMAP44XX_REG_DQM_TLMR_SHIFT 16 +#define OMAP44XX_REG_DQM_TLMR_MASK (0x3ff << 16) +#define OMAP44XX_REG_CTL_TLMR_SHIFT 0 +#define OMAP44XX_REG_CTL_TLMR_MASK (0x7ff << 0) + +/* IODFT_ADDR_MISR_RSLT */ +#define OMAP44XX_REG_ADDR_TLMR_SHIFT 0 +#define OMAP44XX_REG_ADDR_TLMR_MASK (0x1fffff << 0) + +/* IODFT_DATA_MISR_RSLT_1 */ +#define OMAP44XX_REG_DATA_TLMR_31_0_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_31_0_MASK (0xffffffff << 0) + +/* IODFT_DATA_MISR_RSLT_2 */ +#define OMAP44XX_REG_DATA_TLMR_63_32_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_63_32_MASK (0xffffffff << 0) + +/* IODFT_DATA_MISR_RSLT_3 */ +#define OMAP44XX_REG_DATA_TLMR_66_64_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_66_64_MASK (0x7 << 0) + +/* PERF_CNT_1 */ +#define OMAP44XX_REG_COUNTER1_SHIFT 0 +#define OMAP44XX_REG_COUNTER1_MASK (0xffffffff << 0) + +/* PERF_CNT_2 */ +#define OMAP44XX_REG_COUNTER2_SHIFT 0 +#define OMAP44XX_REG_COUNTER2_MASK (0xffffffff << 0) + +/* PERF_CNT_CFG */ +#define OMAP44XX_REG_CNTR2_MCONNID_EN_SHIFT 31 +#define OMAP44XX_REG_CNTR2_MCONNID_EN_MASK (1 << 31) +#define OMAP44XX_REG_CNTR2_REGION_EN_SHIFT 30 +#define OMAP44XX_REG_CNTR2_REGION_EN_MASK (1 << 30) +#define OMAP44XX_REG_CNTR2_CFG_SHIFT 16 +#define OMAP44XX_REG_CNTR2_CFG_MASK (0xf << 16) +#define OMAP44XX_REG_CNTR1_MCONNID_EN_SHIFT 15 +#define OMAP44XX_REG_CNTR1_MCONNID_EN_MASK (1 << 15) +#define OMAP44XX_REG_CNTR1_REGION_EN_SHIFT 14 +#define OMAP44XX_REG_CNTR1_REGION_EN_MASK (1 << 14) +#define OMAP44XX_REG_CNTR1_CFG_SHIFT 0 +#define OMAP44XX_REG_CNTR1_CFG_MASK (0xf << 0) + +/* PERF_CNT_SEL */ +#define OMAP44XX_REG_MCONNID2_SHIFT 24 +#define OMAP44XX_REG_MCONNID2_MASK (0xff << 24) +#define OMAP44XX_REG_REGION_SEL2_SHIFT 16 +#define OMAP44XX_REG_REGION_SEL2_MASK (0x3 << 16) +#define OMAP44XX_REG_MCONNID1_SHIFT 8 +#define OMAP44XX_REG_MCONNID1_MASK (0xff << 8) +#define OMAP44XX_REG_REGION_SEL1_SHIFT 0 +#define OMAP44XX_REG_REGION_SEL1_MASK (0x3 << 0) + +/* PERF_CNT_TIM */ +#define OMAP44XX_REG_TOTAL_TIME_SHIFT 0 +#define OMAP44XX_REG_TOTAL_TIME_MASK (0xffffffff << 0) + +/* READ_IDLE_CTRL */ +#define OMAP44XX_REG_READ_IDLE_LEN_SHIFT 16 +#define OMAP44XX_REG_READ_IDLE_LEN_MASK (0xf << 16) +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHIFT 0 +#define OMAP44XX_REG_READ_IDLE_INTERVAL_MASK (0x1ff << 0) + +/* READ_IDLE_CTRL_SHDW */ +#define OMAP44XX_REG_READ_IDLE_LEN_SHDW_SHIFT 16 +#define OMAP44XX_REG_READ_IDLE_LEN_SHDW_MASK (0xf << 16) +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHDW_SHIFT 0 +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHDW_MASK (0x1ff << 0) + +/* IRQ_EOI */ +#define OMAP44XX_REG_EOI_SHIFT 0 +#define OMAP44XX_REG_EOI_MASK (1 << 0) + +/* IRQSTATUS_RAW_SYS */ +#define OMAP44XX_REG_DNV_SYS_SHIFT 2 +#define OMAP44XX_REG_DNV_SYS_MASK (1 << 2) +#define OMAP44XX_REG_TA_SYS_SHIFT 1 +#define OMAP44XX_REG_TA_SYS_MASK (1 << 1) +#define OMAP44XX_REG_ERR_SYS_SHIFT 0 +#define OMAP44XX_REG_ERR_SYS_MASK (1 << 0) + +/* IRQSTATUS_RAW_LL */ +#define OMAP44XX_REG_DNV_LL_SHIFT 2 +#define OMAP44XX_REG_DNV_LL_MASK (1 << 2) +#define OMAP44XX_REG_TA_LL_SHIFT 1 +#define OMAP44XX_REG_TA_LL_MASK (1 << 1) +#define OMAP44XX_REG_ERR_LL_SHIFT 0 +#define OMAP44XX_REG_ERR_LL_MASK (1 << 0) + +/* IRQSTATUS_SYS */ + +/* IRQSTATUS_LL */ + +/* IRQENABLE_SET_SYS */ +#define OMAP44XX_REG_EN_DNV_SYS_SHIFT 2 +#define OMAP44XX_REG_EN_DNV_SYS_MASK (1 << 2) +#define OMAP44XX_REG_EN_TA_SYS_SHIFT 1 +#define OMAP44XX_REG_EN_TA_SYS_MASK (1 << 1) +#define OMAP44XX_REG_EN_ERR_SYS_SHIFT 0 +#define OMAP44XX_REG_EN_ERR_SYS_MASK (1 << 0) + +/* IRQENABLE_SET_LL */ +#define OMAP44XX_REG_EN_DNV_LL_SHIFT 2 +#define OMAP44XX_REG_EN_DNV_LL_MASK (1 << 2) +#define OMAP44XX_REG_EN_TA_LL_SHIFT 1 +#define OMAP44XX_REG_EN_TA_LL_MASK (1 << 1) +#define OMAP44XX_REG_EN_ERR_LL_SHIFT 0 +#define OMAP44XX_REG_EN_ERR_LL_MASK (1 << 0) + +/* IRQENABLE_CLR_SYS */ + +/* IRQENABLE_CLR_LL */ + +/* ZQ_CONFIG */ +#define OMAP44XX_REG_ZQ_CS1EN_SHIFT 31 +#define OMAP44XX_REG_ZQ_CS1EN_MASK (1 << 31) +#define OMAP44XX_REG_ZQ_CS0EN_SHIFT 30 +#define OMAP44XX_REG_ZQ_CS0EN_MASK (1 << 30) +#define OMAP44XX_REG_ZQ_DUALCALEN_SHIFT 29 +#define OMAP44XX_REG_ZQ_DUALCALEN_MASK (1 << 29) +#define OMAP44XX_REG_ZQ_SFEXITEN_SHIFT 28 +#define OMAP44XX_REG_ZQ_SFEXITEN_MASK (1 << 28) +#define OMAP44XX_REG_ZQ_ZQINIT_MULT_SHIFT 18 +#define OMAP44XX_REG_ZQ_ZQINIT_MULT_MASK (0x3 << 18) +#define OMAP44XX_REG_ZQ_ZQCL_MULT_SHIFT 16 +#define OMAP44XX_REG_ZQ_ZQCL_MULT_MASK (0x3 << 16) +#define OMAP44XX_REG_ZQ_REFINTERVAL_SHIFT 0 +#define OMAP44XX_REG_ZQ_REFINTERVAL_MASK (0xffff << 0) + +/* TEMP_ALERT_CONFIG */ +#define OMAP44XX_REG_TA_CS1EN_SHIFT 31 +#define OMAP44XX_REG_TA_CS1EN_MASK (1 << 31) +#define OMAP44XX_REG_TA_CS0EN_SHIFT 30 +#define OMAP44XX_REG_TA_CS0EN_MASK (1 << 30) +#define OMAP44XX_REG_TA_SFEXITEN_SHIFT 28 +#define OMAP44XX_REG_TA_SFEXITEN_MASK (1 << 28) +#define OMAP44XX_REG_TA_DEVWDT_SHIFT 26 +#define OMAP44XX_REG_TA_DEVWDT_MASK (0x3 << 26) +#define OMAP44XX_REG_TA_DEVCNT_SHIFT 24 +#define OMAP44XX_REG_TA_DEVCNT_MASK (0x3 << 24) +#define OMAP44XX_REG_TA_REFINTERVAL_SHIFT 0 +#define OMAP44XX_REG_TA_REFINTERVAL_MASK (0x3fffff << 0) + +/* OCP_ERR_LOG */ +#define OMAP44XX_REG_MADDRSPACE_SHIFT 14 +#define OMAP44XX_REG_MADDRSPACE_MASK (0x3 << 14) +#define OMAP44XX_REG_MBURSTSEQ_SHIFT 11 +#define OMAP44XX_REG_MBURSTSEQ_MASK (0x7 << 11) +#define OMAP44XX_REG_MCMD_SHIFT 8 +#define OMAP44XX_REG_MCMD_MASK (0x7 << 8) +#define OMAP44XX_REG_MCONNID_SHIFT 0 +#define OMAP44XX_REG_MCONNID_MASK (0xff << 0) + +/* DDR_PHY_CTRL_1 */ +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHIFT 4 +#define OMAP44XX_REG_DDR_PHY_CTRL_1_MASK (0xfffffff << 4) +#define OMAP44XX_REG_READ_LATENCY_SHIFT 0 +#define OMAP44XX_REG_READ_LATENCY_MASK (0xf << 0) +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHIFT 4 +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_MASK (0xFF << 4) +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHIFT 12 +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_MASK (0xFFFFF << 12) + +/* DDR_PHY_CTRL_1_SHDW */ +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHDW_SHIFT 4 +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHDW_MASK (0xfffffff << 4) +#define OMAP44XX_REG_READ_LATENCY_SHDW_SHIFT 0 +#define OMAP44XX_REG_READ_LATENCY_SHDW_MASK (0xf << 0) +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHDW_SHIFT 4 +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHDW_MASK (0xFF << 4) +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHDW_SHIFT 12 +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHDW_MASK (0xFFFFF << 12) + +/* DDR_PHY_CTRL_2 */ +#define OMAP44XX_REG_DDR_PHY_CTRL_2_SHIFT 0 +#define OMAP44XX_REG_DDR_PHY_CTRL_2_MASK (0xffffffff << 0) + +/* DMM */ +#define OMAP44XX_DMM_LISA_MAP_BASE 0x4E000040 + +/* DMM_LISA_MAP */ +#define OMAP44XX_SYS_ADDR_SHIFT 24 +#define OMAP44XX_SYS_ADDR_MASK (0xff << 24) +#define OMAP44XX_SYS_SIZE_SHIFT 20 +#define OMAP44XX_SYS_SIZE_MASK (0x7 << 20) +#define OMAP44XX_SDRC_INTL_SHIFT 18 +#define OMAP44XX_SDRC_INTL_MASK (0x3 << 18) +#define OMAP44XX_SDRC_ADDRSPC_SHIFT 16 +#define OMAP44XX_SDRC_ADDRSPC_MASK (0x3 << 16) +#define OMAP44XX_SDRC_MAP_SHIFT 8 +#define OMAP44XX_SDRC_MAP_MASK (0x3 << 8) +#define OMAP44XX_SDRC_ADDR_SHIFT 0 +#define OMAP44XX_SDRC_ADDR_MASK (0xff << 0) + +/* DMM_LISA_MAP fields */ +#define DMM_SDRC_MAP_UNMAPPED 0 +#define DMM_SDRC_MAP_EMIF1_ONLY 1 +#define DMM_SDRC_MAP_EMIF2_ONLY 2 +#define DMM_SDRC_MAP_EMIF1_AND_EMIF2 3 + +#define DMM_SDRC_INTL_NONE 0 +#define DMM_SDRC_INTL_128B 1 +#define DMM_SDRC_INTL_256B 2 +#define DMM_SDRC_INTL_512 3 + +#define DMM_SDRC_ADDR_SPC_SDRAM 0 +#define DMM_SDRC_ADDR_SPC_NVM 1 +#define DMM_SDRC_ADDR_SPC_INVALID 2 + +#define DMM_LISA_MAP_INTERLEAVED_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF1_AND_EMIF2 << OMAP44XX_SDRC_MAP_SHIFT) |\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT) |\ + (DMM_SDRC_INTL_128B << OMAP44XX_SDRC_INTL_SHIFT) |\ + (CONFIG_SYS_SDRAM_BASE << OMAP44XX_SYS_ADDR_SHIFT)) + +#define DMM_LISA_MAP_EMIF1_ONLY_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)) + +#define DMM_LISA_MAP_EMIF2_ONLY_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF2_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)) + +/* Trap for invalid TILER PAT entries */ +#define DMM_LISA_MAP_0_INVAL_ADDR_TRAP (\ + (0 << OMAP44XX_SDRC_ADDR_SHIFT) |\ + (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_INVALID << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)|\ + (0xFF << OMAP44XX_SYS_ADDR_SHIFT)) + + +/* Reg mapping structure */ +struct emif_reg_struct { + u32 emif_mod_id_rev; + u32 emif_status; + u32 emif_sdram_config; + u32 emif_lpddr2_nvm_config; + u32 emif_sdram_ref_ctrl; + u32 emif_sdram_ref_ctrl_shdw; + u32 emif_sdram_tim_1; + u32 emif_sdram_tim_1_shdw; + u32 emif_sdram_tim_2; + u32 emif_sdram_tim_2_shdw; + u32 emif_sdram_tim_3; + u32 emif_sdram_tim_3_shdw; + u32 emif_lpddr2_nvm_tim; + u32 emif_lpddr2_nvm_tim_shdw; + u32 emif_pwr_mgmt_ctrl; + u32 emif_pwr_mgmt_ctrl_shdw; + u32 emif_lpddr2_mode_reg_data; + u32 padding1[1]; + u32 emif_lpddr2_mode_reg_data_es2; + u32 padding11[1]; + u32 emif_lpddr2_mode_reg_cfg; + u32 emif_l3_config; + u32 emif_l3_cfg_val_1; + u32 emif_l3_cfg_val_2; + u32 emif_iodft_tlgc; + u32 padding2[7]; + u32 emif_perf_cnt_1; + u32 emif_perf_cnt_2; + u32 emif_perf_cnt_cfg; + u32 emif_perf_cnt_sel; + u32 emif_perf_cnt_tim; + u32 padding3; + u32 emif_read_idlectrl; + u32 emif_read_idlectrl_shdw; + u32 padding4; + u32 emif_irqstatus_raw_sys; + u32 emif_irqstatus_raw_ll; + u32 emif_irqstatus_sys; + u32 emif_irqstatus_ll; + u32 emif_irqenable_set_sys; + u32 emif_irqenable_set_ll; + u32 emif_irqenable_clr_sys; + u32 emif_irqenable_clr_ll; + u32 padding5; + u32 emif_zq_config; + u32 emif_temp_alert_config; + u32 emif_l3_err_log; + u32 padding6[4]; + u32 emif_ddr_phy_ctrl_1; + u32 emif_ddr_phy_ctrl_1_shdw; + u32 emif_ddr_phy_ctrl_2; +}; + +struct dmm_lisa_map_regs { + u32 dmm_lisa_map_0; + u32 dmm_lisa_map_1; + u32 dmm_lisa_map_2; + u32 dmm_lisa_map_3; +}; + +struct control_lpddr2io_regs { + u32 control_lpddr2io1_0; + u32 control_lpddr2io1_1; + u32 control_lpddr2io1_2; + u32 control_lpddr2io1_3; + u32 control_lpddr2io2_0; + u32 control_lpddr2io2_1; + u32 control_lpddr2io2_2; + u32 control_lpddr2io2_3; +}; + +#define CS0 0 +#define CS1 1 +/* The maximum frequency at which the LPDDR2 interface can operate in Hz*/ +#define MAX_LPDDR2_FREQ 400000000 /* 400 MHz */ + +/* + * The period of DDR clk is represented as numerator and denominator for + * better accuracy in integer based calculations. However, if the numerator + * and denominator are very huge there may be chances of overflow in + * calculations. So, as a trade-off keep denominator(and consequently + * numerator) within a limit sacrificing some accuracy - but not much + * If denominator and numerator are already small (such as at 400 MHz) + * no adjustment is needed + */ +#define EMIF_PERIOD_DEN_LIMIT 1000 +/* + * Maximum number of different frequencies supported by EMIF driver + * Determines the number of entries in the pointer array for register + * cache + */ +#define EMIF_MAX_NUM_FREQUENCIES 6 +/* + * Indices into the Addressing Table array. + * One entry each for all the different types of devices with different + * addressing schemes + */ +#define ADDR_TABLE_INDEX64M 0 +#define ADDR_TABLE_INDEX128M 1 +#define ADDR_TABLE_INDEX256M 2 +#define ADDR_TABLE_INDEX512M 3 +#define ADDR_TABLE_INDEX1GS4 4 +#define ADDR_TABLE_INDEX2GS4 5 +#define ADDR_TABLE_INDEX4G 6 +#define ADDR_TABLE_INDEX8G 7 +#define ADDR_TABLE_INDEX1GS2 8 +#define ADDR_TABLE_INDEX2GS2 9 +#define ADDR_TABLE_INDEXMAX 10 + +/* Number of Row bits */ +#define ROW_9 0 +#define ROW_10 1 +#define ROW_11 2 +#define ROW_12 3 +#define ROW_13 4 +#define ROW_14 5 +#define ROW_15 6 +#define ROW_16 7 + +/* Number of Column bits */ +#define COL_8 0 +#define COL_9 1 +#define COL_10 2 +#define COL_11 3 +#define COL_7 4 /*Not supported by OMAP included for completeness */ + +/* Number of Banks*/ +#define BANKS1 0 +#define BANKS2 1 +#define BANKS4 2 +#define BANKS8 3 + +/* Refresh rate in micro seconds x 10 */ +#define T_REFI_15_6 156 +#define T_REFI_7_8 78 +#define T_REFI_3_9 39 + +#define EBANK_CS1_DIS 0 +#define EBANK_CS1_EN 1 + +/* Read Latency used by the device at reset */ +#define RL_BOOT 3 +/* Read Latency for the highest frequency you want to use */ +#define RL_FINAL 6 + +/* Interleaving policies at EMIF level- between banks and Chip Selects */ +#define EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING 0 +#define EMIF_INTERLEAVING_POLICY_NO_BANK_INTERLEAVING 3 + +/* + * Interleaving policy to be used + * Currently set to MAX interleaving for better performance + */ +#define EMIF_INTERLEAVING_POLICY EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING + +/* State of the core voltage: + * This is important for some parameters such as read idle control and + * ZQ calibration timings. Timings are much stricter when voltage ramp + * is happening compared to when the voltage is stable. + * We need to calculate two sets of values for these parameters and use + * them accordingly + */ +#define LPDDR2_VOLTAGE_STABLE 0 +#define LPDDR2_VOLTAGE_RAMPING 1 + +/* Length of the forced read idle period in terms of cycles */ +#define EMIF_REG_READ_IDLE_LEN_VAL 5 + +/* Interval between forced 'read idles' */ +/* To be used when voltage is changed for DPS/DVFS - 1us */ +#define READ_IDLE_INTERVAL_DVFS (1*1000) +/* + * To be used when voltage is not scaled except by Smart Reflex + * 50us - or maximum value will do + */ +#define READ_IDLE_INTERVAL_NORMAL (50*1000) + + +/* + * Unless voltage is changing due to DVFS one ZQCS command every 50ms should + * be enough. This shoule be enough also in the case when voltage is changing + * due to smart-reflex. + */ +#define EMIF_ZQCS_INTERVAL_NORMAL_IN_US (50*1000) +/* + * If voltage is changing due to DVFS ZQCS should be performed more + * often(every 50us) + */ +#define EMIF_ZQCS_INTERVAL_DVFS_IN_US 50 + +/* The interval between ZQCL commands as a multiple of ZQCS interval */ +#define REG_ZQ_ZQCL_MULT 4 +/* The interval between ZQINIT commands as a multiple of ZQCL interval */ +#define REG_ZQ_ZQINIT_MULT 3 +/* Enable ZQ Calibration on exiting Self-refresh */ +#define REG_ZQ_SFEXITEN_ENABLE 1 +/* + * ZQ Calibration simultaneously on both chip-selects: + * Needs one calibration resistor per CS + * None of the boards that we know of have this capability + * So disabled by default + */ +#define REG_ZQ_DUALCALEN_DISABLE 0 +/* + * Enable ZQ Calibration by default on CS0. If we are asked to program + * the EMIF there will be something connected to CS0 for sure + */ +#define REG_ZQ_CS0EN_ENABLE 1 + +/* EMIF_PWR_MGMT_CTRL register */ +/* Low power modes */ +#define LP_MODE_DISABLE 0 +#define LP_MODE_CLOCK_STOP 1 +#define LP_MODE_SELF_REFRESH 2 +#define LP_MODE_PWR_DN 3 + +/* REG_DPD_EN */ +#define DPD_DISABLE 0 +#define DPD_ENABLE 1 + +/* Maximum delay before Low Power Modes */ +#define REG_CS_TIM 0xF +#define REG_SR_TIM 0xF +#define REG_PD_TIM 0xF + +/* EMIF_PWR_MGMT_CTRL register */ +#define EMIF_PWR_MGMT_CTRL (\ + ((REG_CS_TIM << OMAP44XX_REG_CS_TIM_SHIFT) & OMAP44XX_REG_CS_TIM_MASK)|\ + ((REG_SR_TIM << OMAP44XX_REG_SR_TIM_SHIFT) & OMAP44XX_REG_SR_TIM_MASK)|\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHIFT) & OMAP44XX_REG_PD_TIM_MASK)|\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHIFT) & OMAP44XX_REG_PD_TIM_MASK)|\ + ((LP_MODE_DISABLE << OMAP44XX_REG_LP_MODE_SHIFT)\ + & OMAP44XX_REG_LP_MODE_MASK) |\ + ((DPD_DISABLE << OMAP44XX_REG_DPD_EN_SHIFT)\ + & OMAP44XX_REG_DPD_EN_MASK))\ + +#define EMIF_PWR_MGMT_CTRL_SHDW (\ + ((REG_CS_TIM << OMAP44XX_REG_CS_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_CS_TIM_SHDW_MASK) |\ + ((REG_SR_TIM << OMAP44XX_REG_SR_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_SR_TIM_SHDW_MASK) |\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_PD_TIM_SHDW_MASK) |\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_PD_TIM_SHDW_MASK)) + +/* EMIF_L3_CONFIG register value for ES1*/ +#define EMIF_L3_CONFIG_VAL_SYS_THRESH_0A_LL_THRESH_00 0x0A0000FF +/* + * Value of bits 12:31 of DDR_PHY_CTRL_1 register: + * All these fields have magic values dependent on frequency and + * determined by PHY and DLL integration with EMIF. Setting the magic + * values suggested by hw team. + */ +#define EMIF_DDR_PHY_CTRL_1_BASE_VAL 0x049FF +#define EMIF_DLL_SLAVE_DLY_CTRL_400_MHZ 0x41 +#define EMIF_DLL_SLAVE_DLY_CTRL_200_MHZ 0x80 +#define EMIF_DLL_SLAVE_DLY_CTRL_100_MHZ_AND_LESS 0xFF + +/* +* MR1 value: +* Burst length : 8 +* Burst type : sequential +* Wrap : enabled +* nWR : 3(default). EMIF does not do pre-charge. +* : So nWR is don't care +*/ +#define MR1_BL_8_BT_SEQ_WRAP_EN_NWR_3 0x23 + +/* MR2 */ +#define MR2_RL3_WL1 1 +#define MR2_RL4_WL2 2 +#define MR2_RL5_WL2 3 +#define MR2_RL6_WL3 4 + +/* MR10: ZQ calibration codes */ +#define MR10_ZQ_ZQCS 0x56 +#define MR10_ZQ_ZQCL 0xAB +#define MR10_ZQ_ZQINIT 0xFF +#define MR10_ZQ_ZQRESET 0xC3 + +/* TEMP_ALERT_CONFIG */ +#define TEMP_ALERT_POLL_INTERVAL_MS 360 /* for temp gradient - 5 C/s */ +#define TEMP_ALERT_CONFIG_DEVCT_1 0 +#define TEMP_ALERT_CONFIG_DEVWDT_32 2 + +/* MR16 value: refresh full array(no partial array self refresh) */ +#define MR16_REF_FULL_ARRAY 0 + +/* LPDDR2 IO regs */ +#define CONTROL_LPDDR2IO_SLEW_125PS_DRV8_PULL_DOWN 0x1C1C1C1C +#define CONTROL_LPDDR2IO_SLEW_325PS_DRV8_GATE_KEEPER 0x9E9E9E9E + +/* CONTROL_EFUSE_2 */ +#define CONTROL_EFUSE_2_NMOS_PMOS_PTV_CODE_1 0x00ffc000 + +/* + * Maximum number of entries we keep in our array of timing tables + * We need not keep all the speed bins supported by the device + * We need to keep timing tables for only the speed bins that we + * are interested in + */ +#define MAX_NUM_SPEEDBINS 4 + +/* LPDDR2 Densities */ +#define LPDDR2_DENSITY_64Mb 0 +#define LPDDR2_DENSITY_128Mb 1 +#define LPDDR2_DENSITY_256Mb 2 +#define LPDDR2_DENSITY_512Mb 3 +#define LPDDR2_DENSITY_1Gb 4 +#define LPDDR2_DENSITY_2Gb 5 +#define LPDDR2_DENSITY_4Gb 6 +#define LPDDR2_DENSITY_8Gb 7 +#define LPDDR2_DENSITY_16Gb 8 +#define LPDDR2_DENSITY_32Gb 9 + +/* LPDDR2 type */ +#define LPDDR2_TYPE_S4 0 +#define LPDDR2_TYPE_S2 1 +#define LPDDR2_TYPE_NVM 2 + +/* LPDDR2 IO width */ +#define LPDDR2_IO_WIDTH_32 0 +#define LPDDR2_IO_WIDTH_16 1 +#define LPDDR2_IO_WIDTH_8 2 + +/* Mode register numbers */ +#define LPDDR2_MR0 0 +#define LPDDR2_MR1 1 +#define LPDDR2_MR2 2 +#define LPDDR2_MR3 3 +#define LPDDR2_MR4 4 +#define LPDDR2_MR5 5 +#define LPDDR2_MR6 6 +#define LPDDR2_MR7 7 +#define LPDDR2_MR8 8 +#define LPDDR2_MR9 9 +#define LPDDR2_MR10 10 +#define LPDDR2_MR11 11 +#define LPDDR2_MR16 16 +#define LPDDR2_MR17 17 +#define LPDDR2_MR18 18 + +/* MR0 */ +#define LPDDR2_MR0_DAI_SHIFT 0 +#define LPDDR2_MR0_DAI_MASK 1 +#define LPDDR2_MR0_DI_SHIFT 1 +#define LPDDR2_MR0_DI_MASK (1 << 1) +#define LPDDR2_MR0_DNVI_SHIFT 2 +#define LPDDR2_MR0_DNVI_MASK (1 << 2) + +/* MR4 */ +#define MR4_SDRAM_REF_RATE_SHIFT 0 +#define MR4_SDRAM_REF_RATE_MASK 7 +#define MR4_TUF_SHIFT 7 +#define MR4_TUF_MASK (1 << 7) + +/* MR4 SDRAM Refresh Rate field values */ +#define SDRAM_TEMP_LESS_LOW_SHUTDOWN 0x0 +#define SDRAM_TEMP_LESS_4X_REFRESH_AND_TIMINGS 0x1 +#define SDRAM_TEMP_LESS_2X_REFRESH_AND_TIMINGS 0x2 +#define SDRAM_TEMP_NOMINAL 0x3 +#define SDRAM_TEMP_RESERVED_4 0x4 +#define SDRAM_TEMP_HIGH_DERATE_REFRESH 0x5 +#define SDRAM_TEMP_HIGH_DERATE_REFRESH_AND_TIMINGS 0x6 +#define SDRAM_TEMP_VERY_HIGH_SHUTDOWN 0x7 + +#define LPDDR2_MANUFACTURER_SAMSUNG 1 +#define LPDDR2_MANUFACTURER_QIMONDA 2 +#define LPDDR2_MANUFACTURER_ELPIDA 3 +#define LPDDR2_MANUFACTURER_ETRON 4 +#define LPDDR2_MANUFACTURER_NANYA 5 +#define LPDDR2_MANUFACTURER_HYNIX 6 +#define LPDDR2_MANUFACTURER_MOSEL 7 +#define LPDDR2_MANUFACTURER_WINBOND 8 +#define LPDDR2_MANUFACTURER_ESMT 9 +#define LPDDR2_MANUFACTURER_SPANSION 11 +#define LPDDR2_MANUFACTURER_SST 12 +#define LPDDR2_MANUFACTURER_ZMOS 13 +#define LPDDR2_MANUFACTURER_INTEL 14 +#define LPDDR2_MANUFACTURER_NUMONYX 254 +#define LPDDR2_MANUFACTURER_MICRON 255 + +/* MR8 register fields */ +#define MR8_TYPE_SHIFT 0x0 +#define MR8_TYPE_MASK 0x3 +#define MR8_DENSITY_SHIFT 0x2 +#define MR8_DENSITY_MASK (0xF << 0x2) +#define MR8_IO_WIDTH_SHIFT 0x6 +#define MR8_IO_WIDTH_MASK (0x3 << 0x6) + +struct lpddr2_addressing { + u8 num_banks; + u8 t_REFI_us_x10; + u8 row_sz[2]; /* One entry each for x32 and x16 */ + u8 col_sz[2]; /* One entry each for x32 and x16 */ +}; + +/* Structure for timings from the DDR datasheet */ +struct lpddr2_ac_timings { + u32 max_freq; + u8 RL; + u8 tRPab; + u8 tRCD; + u8 tWR; + u8 tRASmin; + u8 tRRD; + u8 tWTRx2; + u8 tXSR; + u8 tXPx2; + u8 tRFCab; + u8 tRTPx2; + u8 tCKE; + u8 tCKESR; + u8 tZQCS; + u32 tZQCL; + u32 tZQINIT; + u8 tDQSCKMAXx2; + u8 tRASmax; + u8 tFAW; + +}; + +/* + * Min tCK values for some of the parameters: + * If the calculated clock cycles for the respective parameter is + * less than the corresponding min tCK value, we need to set the min + * tCK value. This may happen at lower frequencies. + */ +struct lpddr2_min_tck { + u32 tRL; + u32 tRP_AB; + u32 tRCD; + u32 tWR; + u32 tRAS_MIN; + u32 tRRD; + u32 tWTR; + u32 tXP; + u32 tRTP; + u8 tCKE; + u32 tCKESR; + u32 tFAW; +}; + +struct lpddr2_device_details { + u8 type; + u8 density; + u8 io_width; + u8 manufacturer; +}; + +struct lpddr2_device_timings { + const struct lpddr2_ac_timings **ac_timings; + const struct lpddr2_min_tck *min_tck; +}; + +/* Details of the devices connected to each chip-select of an EMIF instance */ +struct emif_device_details { + const struct lpddr2_device_details *cs0_device_details; + const struct lpddr2_device_details *cs1_device_details; + const struct lpddr2_device_timings *cs0_device_timings; + const struct lpddr2_device_timings *cs1_device_timings; +}; + +/* + * Structure containing shadow of important registers in EMIF + * The calculation function fills in this structure to be later used for + * initialization and DVFS + */ +struct emif_regs { + u32 freq; + u32 sdram_config_init; + u32 sdram_config; + u32 ref_ctrl; + u32 sdram_tim1; + u32 sdram_tim2; + u32 sdram_tim3; + u32 read_idle_ctrl; + u32 zq_config; + u32 temp_alert_config; + u32 emif_ddr_phy_ctlr_1_init; + u32 emif_ddr_phy_ctlr_1; +}; + +/* assert macros */ +#if defined(DEBUG) +#define emif_assert(c) ({ if (!(c)) for (;;); }) +#else +#define emif_assert(c) ({ if (0) hang(); }) +#endif + +void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs); +void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs); + +#endif diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index 76b06c2..c9c86e1 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -51,6 +51,11 @@ #define CONTROL_PADCONF_CORE (OMAP44XX_L4_CORE_BASE + 0x100000) #define CONTROL_PADCONF_WKUP (OMAP44XX_L4_CORE_BASE + 0x31E000)
+/* LPDDR2 IO regs */ +#define LPDDR2_IO_REGS_BASE 0x4A100638 + +#define CONTROL_EFUSE_2 0x4A100704 + /* CONTROL_ID_CODE */ #define CONTROL_ID_CODE 0x4A002204
diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index f871921..7183a90 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -49,6 +49,8 @@ void bypass_dpll(u32 *const base); void freq_update_core(void); u32 get_sys_clk_freq(void); u32 omap4_ddr_clk(void); +void sdram_init(void); +u32 omap4_sdram_size(void);
Calculate EMIF register values based on AC timing parameters from the SDRAM datasheet and the DDR frequency rather than using the hard-coded values.
For a new board the user doen't have to go through the tedious process of calculating the register values. Instead, just provide the AC timings from the device data sheet as input and the driver will automatically calculate the register values.
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Added SDRAM init related CONFIG flags for Panda too. Earlier Panda support for everything was added in a single patch at the end * Replaced calls to omap4_revision() with omap_revision() * Reorganization of code for better readability * Some code re-organization to reduce #ifdef complexities - cleanly separated out functions for getting device details (geometry) vs timings * Ensured un-necessary code is compiled out if CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REG is defined --- arch/arm/cpu/armv7/omap-common/Makefile | 1 + arch/arm/cpu/armv7/omap-common/utils.c | 57 ++ arch/arm/cpu/armv7/omap4/board.c | 9 +- arch/arm/cpu/armv7/omap4/emif.c | 739 +++++++++++++++++++++++++++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 151 ++++++ arch/arm/include/asm/arch-omap4/emif.h | 9 + arch/arm/include/asm/arch-omap4/omap4.h | 10 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + include/configs/omap4_panda.h | 5 + include/configs/omap4_sdp4430.h | 5 + 10 files changed, 977 insertions(+), 10 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/utils.c
diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index dc01ee5..8f698f8 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -28,6 +28,7 @@ LIB = $(obj)libomap-common.o SOBJS := reset.o
COBJS := timer.o +COBJS += utils.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/arch/arm/cpu/armv7/omap-common/utils.c b/arch/arm/cpu/armv7/omap-common/utils.c new file mode 100644 index 0000000..ea935da --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/utils.c @@ -0,0 +1,57 @@ +/* + * Copyright 2011 Linaro Limited + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +static void do_cancel_out(u32 *num, u32 *den, u32 factor) +{ + while (1) { + if (((*num)/factor*factor == (*num)) && + ((*den)/factor*factor == (*den))) { + (*num) /= factor; + (*den) /= factor; + } else + break; + } +} + +/* + * Cancel out the denominator and numerator of a fraction + * to get smaller numerator and denominator. + */ +void cancel_out(u32 *num, u32 *den, u32 den_limit) +{ + do_cancel_out(num, den, 2); + do_cancel_out(num, den, 3); + do_cancel_out(num, den, 5); + do_cancel_out(num, den, 7); + do_cancel_out(num, den, 11); + do_cancel_out(num, den, 13); + do_cancel_out(num, den, 17); + while ((*den) > den_limit) { + *num /= 2; + /* + * Round up the denominator so that the final fraction + * (num/den) is always <= the desired value + */ + *den = (*den + 1) / 2; + } +} diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index ca107f7..786c239 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -32,6 +32,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> +#include <asm/arch/emif.h> #include "omap4_mux_data.h"
DECLARE_GLOBAL_DATA_PTR; @@ -193,13 +194,13 @@ u32 omap4_sdram_size(void) { u32 section, i, total_size = 0, size, addr; for (i = 0; i < 4; i++) { - section = __raw_readl(DMM_LISA_MAP_BASE + i*4); - addr = section & DMM_LISA_MAP_SYS_ADDR_MASK; + section = __raw_readl(OMAP44XX_DMM_LISA_MAP_BASE + i*4); + addr = section & OMAP44XX_SYS_ADDR_MASK; /* See if the address is valid */ if ((addr >= OMAP44XX_DRAM_ADDR_SPACE_START) && (addr < OMAP44XX_DRAM_ADDR_SPACE_END)) { - size = ((section & DMM_LISA_MAP_SYS_SIZE_MASK) >> - DMM_LISA_MAP_SYS_SIZE_SHIFT); + size = ((section & OMAP44XX_SYS_SIZE_MASK) >> + OMAP44XX_SYS_SIZE_SHIFT); size = 1 << size; size *= SZ_16M; total_size += size; diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index b25c1ee..ceead9e 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -170,6 +170,628 @@ static void emif_update_timings(u32 base, const struct emif_regs *regs) } }
+#ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define print_timing_reg(reg) debug(#reg" - 0x%08x\n", (reg)) + +static u32 *const T_num = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_NUM; +static u32 *const T_den = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_DEN; +static u32 *const emif_sizes = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_SIZE; + +/* + * Organization and refresh requirements for LPDDR2 devices of different + * types and densities. Derived from JESD209-2 section 2.4 + */ +const struct lpddr2_addressing addressing_table[] = { + /* Banks tREFIx10 rowx32,rowx16 colx32,colx16 density */ + {BANKS4, T_REFI_15_6, {ROW_12, ROW_12}, {COL_7, COL_8} },/*64M */ + {BANKS4, T_REFI_15_6, {ROW_12, ROW_12}, {COL_8, COL_9} },/*128M */ + {BANKS4, T_REFI_7_8, {ROW_13, ROW_13}, {COL_8, COL_9} },/*256M */ + {BANKS4, T_REFI_7_8, {ROW_13, ROW_13}, {COL_9, COL_10} },/*512M */ + {BANKS8, T_REFI_7_8, {ROW_13, ROW_13}, {COL_9, COL_10} },/*1GS4 */ + {BANKS8, T_REFI_3_9, {ROW_14, ROW_14}, {COL_9, COL_10} },/*2GS4 */ + {BANKS8, T_REFI_3_9, {ROW_14, ROW_14}, {COL_10, COL_11} },/*4G */ + {BANKS8, T_REFI_3_9, {ROW_15, ROW_15}, {COL_10, COL_11} },/*8G */ + {BANKS4, T_REFI_7_8, {ROW_14, ROW_14}, {COL_9, COL_10} },/*1GS2 */ + {BANKS4, T_REFI_3_9, {ROW_15, ROW_15}, {COL_9, COL_10} },/*2GS2 */ +}; + +static const u32 lpddr2_density_2_size_in_mbytes[] = { + 8, /* 64Mb */ + 16, /* 128Mb */ + 32, /* 256Mb */ + 64, /* 512Mb */ + 128, /* 1Gb */ + 256, /* 2Gb */ + 512, /* 4Gb */ + 1024, /* 8Gb */ + 2048, /* 16Gb */ + 4096 /* 32Gb */ +}; + +/* + * Calculate the period of DDR clock from frequency value and set the + * denominator and numerator in global variables for easy access later + */ +static void set_ddr_clk_period(u32 freq) +{ + /* + * period = 1/freq + * period_in_ns = 10^9/freq + */ + *T_num = 1000000000; + *T_den = freq; + cancel_out(T_num, T_den, 200); + +} + +/* + * Convert time in nano seconds to number of cycles of DDR clock + */ +static inline u32 ns_2_cycles(u32 ns) +{ + return ((ns * (*T_den)) + (*T_num) - 1) / (*T_num); +} + +/* + * ns_2_cycles with the difference that the time passed is 2 times the actual + * value(to avoid fractions). The cycles returned is for the original value of + * the timing parameter + */ +static inline u32 ns_x2_2_cycles(u32 ns) +{ + return ((ns * (*T_den)) + (*T_num) * 2 - 1) / ((*T_num) * 2); +} + +/* + * Find addressing table index based on the device's type(S2 or S4) and + * density + */ +s8 addressing_table_index(u8 type, u8 density, u8 width) +{ + u8 index; + if ((density > LPDDR2_DENSITY_8Gb) || (width == LPDDR2_IO_WIDTH_8)) + return -1; + + /* + * Look at the way ADDR_TABLE_INDEX* values have been defined + * in emif.h compared to LPDDR2_DENSITY_* values + * The table is layed out in the increasing order of density + * (ignoring type). The exceptions 1GS2 and 2GS2 have been placed + * at the end + */ + if ((type == LPDDR2_TYPE_S2) && (density == LPDDR2_DENSITY_1Gb)) + index = ADDR_TABLE_INDEX1GS2; + else if ((type == LPDDR2_TYPE_S2) && (density == LPDDR2_DENSITY_2Gb)) + index = ADDR_TABLE_INDEX2GS2; + else + index = density; + + debug("emif: addressing table index %d\n", index); + + return index; +} + +/* + * Find the the right timing table from the array of timing + * tables of the device using DDR clock frequency + */ +static const struct lpddr2_ac_timings *get_timings_table(const struct + lpddr2_ac_timings const *const *device_timings, + u32 freq) +{ + u32 i, temp, freq_nearest; + const struct lpddr2_ac_timings *timings = 0; + + emif_assert(freq <= MAX_LPDDR2_FREQ); + emif_assert(device_timings); + + /* + * Start with the maximum allowed frequency - that is always safe + */ + freq_nearest = MAX_LPDDR2_FREQ; + /* + * Find the timings table that has the max frequency value: + * i. Above or equal to the DDR frequency - safe + * ii. The lowest that satisfies condition (i) - optimal + */ + for (i = 0; (i < MAX_NUM_SPEEDBINS) && device_timings[i]; i++) { + temp = device_timings[i]->max_freq; + if ((temp >= freq) && (temp <= freq_nearest)) { + freq_nearest = temp; + timings = device_timings[i]; + } + } + debug("emif: timings table: %d\n", freq_nearest); + return timings; +} + +/* + * Finds the value of emif_sdram_config_reg + * All parameters are programmed based on the device on CS0. + * If there is a device on CS1, it will be same as that on CS0 or + * it will be NVM. We don't support NVM yet. + * If cs1_device pointer is NULL it is assumed that there is no device + * on CS1 + */ +static u32 get_sdram_config_reg(const struct lpddr2_device_details *cs0_device, + const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 RL) +{ + u32 config_reg = 0; + + config_reg |= (cs0_device->type + 4) << OMAP44XX_REG_SDRAM_TYPE_SHIFT; + config_reg |= EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING << + OMAP44XX_REG_IBANK_POS_SHIFT; + + config_reg |= cs0_device->io_width << OMAP44XX_REG_NARROW_MODE_SHIFT; + + config_reg |= RL << OMAP44XX_REG_CL_SHIFT; + + config_reg |= addressing->row_sz[cs0_device->io_width] << + OMAP44XX_REG_ROWSIZE_SHIFT; + + config_reg |= addressing->num_banks << OMAP44XX_REG_IBANK_SHIFT; + + config_reg |= (cs1_device ? EBANK_CS1_EN : EBANK_CS1_DIS) << + OMAP44XX_REG_EBANK_SHIFT; + + config_reg |= addressing->col_sz[cs0_device->io_width] << + OMAP44XX_REG_PAGESIZE_SHIFT; + + return config_reg; +} + +static u32 get_sdram_ref_ctrl(u32 freq, + const struct lpddr2_addressing *addressing) +{ + u32 ref_ctrl = 0, val = 0, freq_khz; + freq_khz = freq / 1000; + /* + * refresh rate to be set is 'tREFI * freq in MHz + * division by 10000 to account for khz and x10 in t_REFI_us_x10 + */ + val = addressing->t_REFI_us_x10 * freq_khz / 10000; + ref_ctrl |= val << OMAP44XX_REG_REFRESH_RATE_SHIFT; + + return ref_ctrl; +} + +static u32 get_sdram_tim_1_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck, + const struct lpddr2_addressing *addressing) +{ + u32 tim1 = 0, val = 0; + val = max(min_tck->tWTR, ns_x2_2_cycles(timings->tWTRx2)) - 1; + tim1 |= val << OMAP44XX_REG_T_WTR_SHIFT; + + if (addressing->num_banks == BANKS8) + val = (timings->tFAW * (*T_den) + 4 * (*T_num) - 1) / + (4 * (*T_num)) - 1; + else + val = max(min_tck->tRRD, ns_2_cycles(timings->tRRD)) - 1; + + tim1 |= val << OMAP44XX_REG_T_RRD_SHIFT; + + val = ns_2_cycles(timings->tRASmin + timings->tRPab) - 1; + tim1 |= val << OMAP44XX_REG_T_RC_SHIFT; + + val = max(min_tck->tRAS_MIN, ns_2_cycles(timings->tRASmin)) - 1; + tim1 |= val << OMAP44XX_REG_T_RAS_SHIFT; + + val = max(min_tck->tWR, ns_2_cycles(timings->tWR)) - 1; + tim1 |= val << OMAP44XX_REG_T_WR_SHIFT; + + val = max(min_tck->tRCD, ns_2_cycles(timings->tRCD)) - 1; + tim1 |= val << OMAP44XX_REG_T_RCD_SHIFT; + + val = max(min_tck->tRP_AB, ns_2_cycles(timings->tRPab)) - 1; + tim1 |= val << OMAP44XX_REG_T_RP_SHIFT; + + return tim1; +} + +static u32 get_sdram_tim_2_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck) +{ + u32 tim2 = 0, val = 0; + val = max(min_tck->tCKE, timings->tCKE) - 1; + tim2 |= val << OMAP44XX_REG_T_CKE_SHIFT; + + val = max(min_tck->tRTP, ns_x2_2_cycles(timings->tRTPx2)) - 1; + tim2 |= val << OMAP44XX_REG_T_RTP_SHIFT; + + /* + * tXSRD = tRFCab + 10 ns. XSRD and XSNR should have the + * same value + */ + val = ns_2_cycles(timings->tXSR) - 1; + tim2 |= val << OMAP44XX_REG_T_XSRD_SHIFT; + tim2 |= val << OMAP44XX_REG_T_XSNR_SHIFT; + + val = max(min_tck->tXP, ns_x2_2_cycles(timings->tXPx2)) - 1; + tim2 |= val << OMAP44XX_REG_T_XP_SHIFT; + + return tim2; +} + +static u32 get_sdram_tim_3_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck, + const struct lpddr2_addressing *addressing) +{ + u32 tim3 = 0, val = 0; + val = min(timings->tRASmax * 10 / addressing->t_REFI_us_x10 - 1, 0xF); + tim3 |= val << OMAP44XX_REG_T_RAS_MAX_SHIFT; + + val = ns_2_cycles(timings->tRFCab) - 1; + tim3 |= val << OMAP44XX_REG_T_RFC_SHIFT; + + val = ns_x2_2_cycles(timings->tDQSCKMAXx2) - 1; + tim3 |= val << OMAP44XX_REG_T_TDQSCKMAX_SHIFT; + + val = ns_2_cycles(timings->tZQCS) - 1; + tim3 |= val << OMAP44XX_REG_ZQ_ZQCS_SHIFT; + + val = max(min_tck->tCKESR, ns_2_cycles(timings->tCKESR)) - 1; + tim3 |= val << OMAP44XX_REG_T_CKESR_SHIFT; + + return tim3; +} + +static u32 get_zq_config_reg(const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 volt_ramp) +{ + u32 zq = 0, val = 0; + if (volt_ramp) + val = + EMIF_ZQCS_INTERVAL_DVFS_IN_US * 10 / + addressing->t_REFI_us_x10; + else + val = + EMIF_ZQCS_INTERVAL_NORMAL_IN_US * 10 / + addressing->t_REFI_us_x10; + zq |= val << OMAP44XX_REG_ZQ_REFINTERVAL_SHIFT; + + zq |= (REG_ZQ_ZQCL_MULT - 1) << OMAP44XX_REG_ZQ_ZQCL_MULT_SHIFT; + + zq |= (REG_ZQ_ZQINIT_MULT - 1) << OMAP44XX_REG_ZQ_ZQINIT_MULT_SHIFT; + + zq |= REG_ZQ_SFEXITEN_ENABLE << OMAP44XX_REG_ZQ_SFEXITEN_SHIFT; + + /* + * Assuming that two chipselects have a single calibration resistor + * If there are indeed two calibration resistors, then this flag should + * be enabled to take advantage of dual calibration feature. + * This data should ideally come from board files. But considering + * that none of the boards today have calibration resistors per CS, + * it would be an unnecessary overhead. + */ + zq |= REG_ZQ_DUALCALEN_DISABLE << OMAP44XX_REG_ZQ_DUALCALEN_SHIFT; + + zq |= REG_ZQ_CS0EN_ENABLE << OMAP44XX_REG_ZQ_CS0EN_SHIFT; + + zq |= (cs1_device ? 1 : 0) << OMAP44XX_REG_ZQ_CS1EN_SHIFT; + + return zq; +} + +static u32 get_temp_alert_config(const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 is_derated) +{ + u32 alert = 0, interval; + interval = + TEMP_ALERT_POLL_INTERVAL_MS * 10000 / addressing->t_REFI_us_x10; + if (is_derated) + interval *= 4; + alert |= interval << OMAP44XX_REG_TA_REFINTERVAL_SHIFT; + + alert |= TEMP_ALERT_CONFIG_DEVCT_1 << OMAP44XX_REG_TA_DEVCNT_SHIFT; + + alert |= TEMP_ALERT_CONFIG_DEVWDT_32 << OMAP44XX_REG_TA_DEVWDT_SHIFT; + + alert |= 1 << OMAP44XX_REG_TA_SFEXITEN_SHIFT; + + alert |= 1 << OMAP44XX_REG_TA_CS0EN_SHIFT; + + alert |= (cs1_device ? 1 : 0) << OMAP44XX_REG_TA_CS1EN_SHIFT; + + return alert; +} + +static u32 get_read_idle_ctrl_reg(u8 volt_ramp) +{ + u32 idle = 0, val = 0; + if (volt_ramp) + val = ns_2_cycles(READ_IDLE_INTERVAL_DVFS) / 64 + 1; + else + /*Maximum value in normal conditions - suggested by hw team */ + val = 0x1FF; + idle |= val << OMAP44XX_REG_READ_IDLE_INTERVAL_SHIFT; + + idle |= EMIF_REG_READ_IDLE_LEN_VAL << OMAP44XX_REG_READ_IDLE_LEN_SHIFT; + + return idle; +} + +static u32 get_ddr_phy_ctrl_1(u32 freq, u8 RL) +{ + u32 phy = 0, val = 0; + + phy |= (RL + 2) << OMAP44XX_REG_READ_LATENCY_SHIFT; + + if (freq <= 100000000) + val = EMIF_DLL_SLAVE_DLY_CTRL_100_MHZ_AND_LESS; + else if (freq <= 200000000) + val = EMIF_DLL_SLAVE_DLY_CTRL_200_MHZ; + else + val = EMIF_DLL_SLAVE_DLY_CTRL_400_MHZ; + phy |= val << OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHIFT; + + /* Other fields are constant magic values. Hardcode them together */ + phy |= EMIF_DDR_PHY_CTRL_1_BASE_VAL << + OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHIFT; + + return phy; +} + +static u32 get_emif_mem_size(struct emif_device_details *devices) +{ + u32 size_mbytes = 0, temp; + + if (!devices) + return 0; + + if (devices->cs0_device_details) { + temp = devices->cs0_device_details->density; + size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; + } + + if (devices->cs1_device_details) { + temp = devices->cs1_device_details->density; + size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; + } + /* convert to bytes */ + return size_mbytes << 20; +} + +/* Gets the encoding corresponding to a given DMM section size */ +u32 get_dmm_section_size_map(u32 section_size) +{ + /* + * Section size mapping: + * 0x0: 16-MiB section + * 0x1: 32-MiB section + * 0x2: 64-MiB section + * 0x3: 128-MiB section + * 0x4: 256-MiB section + * 0x5: 512-MiB section + * 0x6: 1-GiB section + * 0x7: 2-GiB section + */ + section_size >>= 24; /* divide by 16 MB */ + return log_2_n_round_down(section_size); +} + +static void emif_calculate_regs( + const struct emif_device_details *emif_dev_details, + u32 freq, struct emif_regs *regs) +{ + u32 temp, sys_freq; + const struct lpddr2_addressing *addressing; + const struct lpddr2_ac_timings *timings; + const struct lpddr2_min_tck *min_tck; + const struct lpddr2_device_details *cs0_dev_details = + emif_dev_details->cs0_device_details; + const struct lpddr2_device_details *cs1_dev_details = + emif_dev_details->cs1_device_details; + const struct lpddr2_device_timings *cs0_dev_timings = + emif_dev_details->cs0_device_timings; + + emif_assert(emif_dev_details); + emif_assert(regs); + /* + * You can not have a device on CS1 without one on CS0 + * So configuring EMIF without a device on CS0 doesn't + * make sense + */ + emif_assert(cs0_dev_details); + emif_assert(cs0_dev_details->type != LPDDR2_TYPE_NVM); + /* + * If there is a device on CS1 it should be same type as CS0 + * (or NVM. But NVM is not supported in this driver yet) + */ + emif_assert((cs1_dev_details == NULL) || + (cs1_dev_details->type == LPDDR2_TYPE_NVM) || + (cs0_dev_details->type == cs1_dev_details->type)); + emif_assert(freq <= MAX_LPDDR2_FREQ); + + set_ddr_clk_period(freq); + + /* + * The device on CS0 is used for all timing calculations + * There is only one set of registers for timings per EMIF. So, if the + * second CS(CS1) has a device, it should have the same timings as the + * device on CS0 + */ + timings = get_timings_table(cs0_dev_timings->ac_timings, freq); + emif_assert(timings); + min_tck = cs0_dev_timings->min_tck; + + temp = addressing_table_index(cs0_dev_details->type, + cs0_dev_details->density, + cs0_dev_details->io_width); + + emif_assert((temp >= 0)); + addressing = &(addressing_table[temp]); + emif_assert(addressing); + + sys_freq = get_sys_clk_freq(); + + regs->sdram_config_init = get_sdram_config_reg(cs0_dev_details, + cs1_dev_details, + addressing, RL_BOOT); + + regs->sdram_config = get_sdram_config_reg(cs0_dev_details, + cs1_dev_details, + addressing, RL_FINAL); + + regs->ref_ctrl = get_sdram_ref_ctrl(freq, addressing); + + regs->sdram_tim1 = get_sdram_tim_1_reg(timings, min_tck, addressing); + + regs->sdram_tim2 = get_sdram_tim_2_reg(timings, min_tck); + + regs->sdram_tim3 = get_sdram_tim_3_reg(timings, min_tck, addressing); + + regs->read_idle_ctrl = get_read_idle_ctrl_reg(LPDDR2_VOLTAGE_STABLE); + + regs->temp_alert_config = + get_temp_alert_config(cs1_dev_details, addressing, 0); + + regs->zq_config = get_zq_config_reg(cs1_dev_details, addressing, + LPDDR2_VOLTAGE_STABLE); + + regs->emif_ddr_phy_ctlr_1_init = + get_ddr_phy_ctrl_1(sys_freq / 2, RL_BOOT); + + regs->emif_ddr_phy_ctlr_1 = + get_ddr_phy_ctrl_1(freq, RL_FINAL); + + regs->freq = freq; + + print_timing_reg(regs->sdram_config_init); + print_timing_reg(regs->sdram_config); + print_timing_reg(regs->ref_ctrl); + print_timing_reg(regs->sdram_tim1); + print_timing_reg(regs->sdram_tim2); + print_timing_reg(regs->sdram_tim3); + print_timing_reg(regs->read_idle_ctrl); + print_timing_reg(regs->temp_alert_config); + print_timing_reg(regs->zq_config); + print_timing_reg(regs->emif_ddr_phy_ctlr_1); + print_timing_reg(regs->emif_ddr_phy_ctlr_1_init); +} +#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */ + +#ifdef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS +/* Base AC Timing values specified by JESD209-2 for 400MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_400_mhz = { + .max_freq = 400000000, + .RL = 6, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* Base AC Timing values specified by JESD209-2 for 333 MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_333_mhz = { + .max_freq = 333000000, + .RL = 5, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* Base AC Timing values specified by JESD209-2 for 200 MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_200_mhz = { + .max_freq = 200000000, + .RL = 3, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 20, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* + * Min tCK values specified by JESD209-2 + * Min tCK specifies the minimum duration of some AC timing parameters in terms + * of the number of cycles. If the calculated number of cycles based on the + * absolute time value is less than the min tCK value, min tCK value should + * be used instead. This typically happens at low frequencies. + */ +static const struct lpddr2_min_tck min_tck_jedec = { + .tRL = 3, + .tRP_AB = 3, + .tRCD = 3, + .tWR = 3, + .tRAS_MIN = 3, + .tRRD = 2, + .tWTR = 2, + .tXP = 2, + .tRTP = 2, + .tCKE = 3, + .tCKESR = 3, + .tFAW = 8 +}; + +static const struct lpddr2_ac_timings const* + jedec_ac_timings[MAX_NUM_SPEEDBINS] = { + &timings_jedec_200_mhz, + &timings_jedec_333_mhz, + &timings_jedec_400_mhz +}; + +static const struct lpddr2_device_timings jedec_default_timings = { + .ac_timings = jedec_ac_timings, + .min_tck = &min_tck_jedec +}; + +void emif_get_device_timings(u32 emif_nr, + const struct lpddr2_device_timings **cs0_device_timings, + const struct lpddr2_device_timings **cs1_device_timings) +{ + /* Assume Identical devices on EMIF1 & EMIF2 */ + *cs0_device_timings = &jedec_default_timings; + *cs1_device_timings = &jedec_default_timings; +} +#endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */ + static void do_sdram_init(u32 base) { const struct emif_regs *regs; @@ -180,11 +802,54 @@ static void do_sdram_init(u32 base) in_sdram = running_from_sdram(); emif_nr = (base == OMAP44XX_EMIF1) ? 1 : 2;
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS emif_get_reg_dump(emif_nr, ®s); if (!regs) { debug("EMIF: reg dump not provided\n"); return; } +#else + /* + * The user has not provided the register values. We need to + * calculate it based on the timings and the DDR frequency + */ + struct emif_device_details dev_details; + struct emif_regs calculated_regs; + + /* + * Get device details: + * - Discovered if CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION is set + * - Obtained from user otherwise + */ + struct lpddr2_device_details cs0_dev_details, cs1_dev_details; + emif_get_device_details(emif_nr, &cs0_dev_details, + &cs1_dev_details); + dev_details.cs0_device_details = &cs0_dev_details; + dev_details.cs1_device_details = &cs1_dev_details; + + /* Return if no devices on this EMIF */ + if (!dev_details.cs0_device_details && + !dev_details.cs1_device_details) { + emif_sizes[emif_nr - 1] = 0; + return; + } + + if (!in_sdram) + emif_sizes[emif_nr - 1] = get_emif_mem_size(&dev_details); + + /* + * Get device timings: + * - Default timings specified by JESD209-2 if + * CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS is set + * - Obtained from user otherwise + */ + emif_get_device_timings(emif_nr, &dev_details.cs0_device_timings, + &dev_details.cs1_device_timings); + + /* Calculate the register values */ + emif_calculate_regs(&dev_details, omap4_ddr_clk(), &calculated_regs); + regs = &calculated_regs; +#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */
/* * Initializing the LPDDR2 device can not happen from SDRAM. @@ -242,8 +907,82 @@ static void dmm_init(u32 base) { const struct dmm_lisa_map_regs *lisa_map_regs;
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS emif_get_dmm_regs(&lisa_map_regs); +#else + u32 emif1_size, emif2_size, mapped_size, section_map = 0; + u32 section_cnt, sys_addr; + struct dmm_lisa_map_regs lis_map_regs_calculated = {0}; + + mapped_size = 0; + section_cnt = 3; + sys_addr = CONFIG_SYS_SDRAM_BASE; + emif1_size = emif_sizes[0]; + emif2_size = emif_sizes[1]; + debug("emif1_size 0x%x emif2_size 0x%x\n", emif1_size, emif2_size); + + if (!emif1_size && !emif2_size) + return; + + /* symmetric interleaved section */ + if (emif1_size && emif2_size) { + mapped_size = min(emif1_size, emif2_size); + section_map = DMM_LISA_MAP_INTERLEAVED_BASE_VAL; + section_map |= 0 << OMAP44XX_SDRC_ADDR_SHIFT; + /* only MSB */ + section_map |= (sys_addr >> 24) << + OMAP44XX_SYS_ADDR_SHIFT; + section_map |= get_dmm_section_size_map(mapped_size * 2) + << OMAP44XX_SYS_SIZE_SHIFT; + lis_map_regs_calculated.dmm_lisa_map_3 = section_map; + emif1_size -= mapped_size; + emif2_size -= mapped_size; + sys_addr += (mapped_size * 2); + section_cnt--; + } + + /* + * Single EMIF section(we can have a maximum of 1 single EMIF + * section- either EMIF1 or EMIF2 or none, but not both) + */ + if (emif1_size) { + section_map = DMM_LISA_MAP_EMIF1_ONLY_BASE_VAL; + section_map |= get_dmm_section_size_map(emif1_size) + << OMAP44XX_SYS_SIZE_SHIFT; + /* only MSB */ + section_map |= (mapped_size >> 24) << + OMAP44XX_SDRC_ADDR_SHIFT; + /* only MSB */ + section_map |= (sys_addr >> 24) << OMAP44XX_SYS_ADDR_SHIFT; + section_cnt--; + } + if (emif2_size) { + section_map = DMM_LISA_MAP_EMIF2_ONLY_BASE_VAL; + section_map |= get_dmm_section_size_map(emif2_size) << + OMAP44XX_SYS_SIZE_SHIFT; + /* only MSB */ + section_map |= mapped_size >> 24 << OMAP44XX_SDRC_ADDR_SHIFT; + /* only MSB */ + section_map |= sys_addr >> 24 << OMAP44XX_SYS_ADDR_SHIFT; + section_cnt--; + } + + if (section_cnt == 2) { + /* Only 1 section - either symmetric or single EMIF */ + lis_map_regs_calculated.dmm_lisa_map_3 = section_map; + lis_map_regs_calculated.dmm_lisa_map_2 = 0; + lis_map_regs_calculated.dmm_lisa_map_1 = 0; + } else { + /* 2 sections - 1 symmetric, 1 single EMIF */ + lis_map_regs_calculated.dmm_lisa_map_2 = section_map; + lis_map_regs_calculated.dmm_lisa_map_1 = 0; + } + + /* TRAP for invalid TILER mappings in section 0 */ + lis_map_regs_calculated.dmm_lisa_map_0 = DMM_LISA_MAP_0_INVAL_ADDR_TRAP;
+ lisa_map_regs = &lis_map_regs_calculated; +#endif struct dmm_lisa_map_regs *hw_lisa_map_regs = (struct dmm_lisa_map_regs *)base;
diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c index c950c87..7757aad 100644 --- a/arch/arm/cpu/armv7/omap4/sdram_elpida.c +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -46,6 +46,8 @@ * - emif_get_device_timings() */
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS + static const struct emif_regs emif_regs_elpida_200_mhz_2cs = { .sdram_config_init = 0x80000eb9, .sdram_config = 0x80001ab9, @@ -129,3 +131,152 @@ static void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs
void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) __attribute__((weak, alias("emif_get_dmm_regs_sdp"))); + +#else + +static const struct lpddr2_device_details elpida_2G_S4_details = { + .type = LPDDR2_TYPE_S4, + .density = LPDDR2_DENSITY_2Gb, + .io_width = LPDDR2_IO_WIDTH_32, + .manufacturer = LPDDR2_MANUFACTURER_ELPIDA +}; + +static void emif_get_device_details_sdp(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details) +{ + u32 omap_rev = omap_revision(); + + /* EMIF1 & EMIF2 have identical configuration */ + *cs0_device_details = elpida_2G_S4_details; + + if (omap_rev == OMAP4430_ES1_0) + cs1_device_details = NULL; + else + *cs1_device_details = elpida_2G_S4_details; +} + +void emif_get_device_details(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details) + __attribute__((weak, alias("emif_get_device_details_sdp"))); + +#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */ + +#ifndef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS +static const struct lpddr2_ac_timings timings_elpida_400_mhz = { + .max_freq = 400000000, + .RL = 6, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_ac_timings timings_elpida_333_mhz = { + .max_freq = 333000000, + .RL = 5, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_ac_timings timings_elpida_200_mhz = { + .max_freq = 200000000, + .RL = 3, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 20, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_min_tck min_tck_elpida = { + .tRL = 3, + .tRP_AB = 3, + .tRCD = 3, + .tWR = 3, + .tRAS_MIN = 3, + .tRRD = 2, + .tWTR = 2, + .tXP = 2, + .tRTP = 2, + .tCKE = 3, + .tCKESR = 3, + .tFAW = 8 +}; + +static const struct lpddr2_ac_timings *elpida_ac_timings[MAX_NUM_SPEEDBINS] = { + &timings_elpida_200_mhz, + &timings_elpida_333_mhz, + &timings_elpida_400_mhz +}; + +static const struct lpddr2_device_timings elpida_2G_S4_timings = { + .ac_timings = elpida_ac_timings, + .min_tck = &min_tck_elpida, +}; + +void emif_get_device_timings_sdp(u32 emif_nr, + const struct lpddr2_device_timings **cs0_device_timings, + const struct lpddr2_device_timings **cs1_device_timings) +{ + u32 omap_rev = omap_revision(); + + /* Identical devices on EMIF1 & EMIF2 */ + *cs0_device_timings = &elpida_2G_S4_timings; + + if (omap_rev == OMAP4430_ES1_0) + *cs1_device_timings = NULL; + else + *cs1_device_timings = &elpida_2G_S4_timings; +} + +void emif_get_device_timings(u32 emif_nr, + const struct lpddr2_device_timings **cs0_device_timings, + const struct lpddr2_device_timings **cs1_device_timings) + __attribute__((weak, alias("emif_get_device_timings_sdp"))); + +#endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */ diff --git a/arch/arm/include/asm/arch-omap4/emif.h b/arch/arm/include/asm/arch-omap4/emif.h index 09e9baa..a167508 100644 --- a/arch/arm/include/asm/arch-omap4/emif.h +++ b/arch/arm/include/asm/arch-omap4/emif.h @@ -1019,7 +1019,16 @@ struct emif_regs { #define emif_assert(c) ({ if (0) hang(); }) #endif
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs); void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs); +#else +void emif_get_device_details(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details); +void emif_get_device_timings(u32 emif_nr, + const struct lpddr2_device_timings **cs0_device_timings, + const struct lpddr2_device_timings **cs1_device_timings); +#endif
#endif diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index c9c86e1..a8dbedb 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -84,12 +84,6 @@ /* GPMC */ #define OMAP44XX_GPMC_BASE 0x50000000
-/* DMM */ -#define OMAP44XX_DMM_BASE 0x4E000000 -#define DMM_LISA_MAP_BASE (OMAP44XX_DMM_BASE + 0x40) -#define DMM_LISA_MAP_SYS_SIZE_MASK (7 << 20) -#define DMM_LISA_MAP_SYS_SIZE_SHIFT 20 -#define DMM_LISA_MAP_SYS_ADDR_MASK (0xFF << 24) /* * Hardware Register Details */ @@ -137,6 +131,10 @@ struct s32ktimer { #define SRAM_SCRATCH_SPACE_ADDR NON_SECURE_SRAM_START /* SRAM scratch space entries */ #define OMAP4_SRAM_SCRATCH_OMAP4_REV SRAM_SCRATCH_SPACE_ADDR +#define OMAP4_SRAM_SCRATCH_EMIF_SIZE (SRAM_SCRATCH_SPACE_ADDR + 0x4) +#define OMAP4_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0xC) +#define OMAP4_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) +#define OMAP4_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x14)
/* Silicon revisions */ #define OMAP4430_SILICON_ID_INVALID 0xFFFFFFFF diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 7183a90..1e62878 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -49,6 +49,7 @@ void bypass_dpll(u32 *const base); void freq_update_core(void); u32 get_sys_clk_freq(void); u32 omap4_ddr_clk(void); +void cancel_out(u32 *num, u32 *den, u32 den_limit); void sdram_init(void); u32 omap4_sdram_size(void);
diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 1daffb7..9f82ef4 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -237,4 +237,9 @@ #define CONFIG_SYS_PL310_BASE 0x48242000 #endif
+/* Defines for SDRAM init */ +#ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS +#endif + #endif /* __CONFIG_H */ diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 68ffa87..6df1c3d 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -243,4 +243,9 @@ #define CONFIG_SYS_PL310_BASE 0x48242000 #endif
Identify SDRAM devices connected to EMIF automatically: LPDDR2 devices have some Mode Registers that provide details about the device such as the type, density, bus width etc. EMIF has the capability to read these registers. If there are no devices connected to a given chip-select reading mode registers will return junk values. After reading as many such registers as possible and matching with expected ranges of values the driver can identify if there is a device connected to the respective CS. If we identify that a device is connected the values read give us complete details about the device.
This along with the base AC timings specified by JESD209-2 allows us to do a complete automatic initialization of SDRAM that works on all boards.
Please note that the default AC timings specified by JESD209-2 will be safe for all devices but not necessarily optimal. However, for the Elpida devices used on Panda and SDP the default timings are both safe and optimal.
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Code re-organization for better readability * Ensured that un-necessary code is compiled out when CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION is not defined --- arch/arm/cpu/armv7/omap4/emif.c | 238 +++++++++++++++++++++++++++++++++++++++ include/configs/omap4_panda.h | 1 + include/configs/omap4_sdp4430.h | 1 + 3 files changed, 240 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index ceead9e..1234a7e 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -792,6 +792,244 @@ void emif_get_device_timings(u32 emif_nr, } #endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */
+#ifdef CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION +const char *get_lpddr2_type(u8 type_id) +{ + switch (type_id) { + case LPDDR2_TYPE_S4: + return "LPDDR2-S4"; + case LPDDR2_TYPE_S2: + return "LPDDR2-S2"; + default: + return NULL; + } +} + +const char *get_lpddr2_io_width(u8 width_id) +{ + switch (width_id) { + case LPDDR2_IO_WIDTH_8: + return "x8"; + case LPDDR2_IO_WIDTH_16: + return "x16"; + case LPDDR2_IO_WIDTH_32: + return "x32"; + default: + return NULL; + } +} + +const char *get_lpddr2_manufacturer(u32 manufacturer) +{ + switch (manufacturer) { + case LPDDR2_MANUFACTURER_SAMSUNG: + return "Samsung"; + case LPDDR2_MANUFACTURER_QIMONDA: + return "Qimonda"; + case LPDDR2_MANUFACTURER_ELPIDA: + return "Elpida"; + case LPDDR2_MANUFACTURER_ETRON: + return "Etron"; + case LPDDR2_MANUFACTURER_NANYA: + return "Nanya"; + case LPDDR2_MANUFACTURER_HYNIX: + return "Hynix"; + case LPDDR2_MANUFACTURER_MOSEL: + return "Mosel"; + case LPDDR2_MANUFACTURER_WINBOND: + return "Winbond"; + case LPDDR2_MANUFACTURER_ESMT: + return "ESMT"; + case LPDDR2_MANUFACTURER_SPANSION: + return "Spansion"; + case LPDDR2_MANUFACTURER_SST: + return "SST"; + case LPDDR2_MANUFACTURER_ZMOS: + return "ZMOS"; + case LPDDR2_MANUFACTURER_INTEL: + return "Intel"; + case LPDDR2_MANUFACTURER_NUMONYX: + return "Numonyx"; + case LPDDR2_MANUFACTURER_MICRON: + return "Micron"; + default: + return NULL; + } +} + +static void display_sdram_details(u32 emif_nr, u32 cs, + struct lpddr2_device_details *device) +{ + const char *mfg_str; + const char *type_str; + char density_str[10]; + u32 density; + + debug("EMIF%d CS%d\t", emif_nr, cs); + + if (!device) { + debug("None\n"); + return; + } + + mfg_str = get_lpddr2_manufacturer(device->manufacturer); + type_str = get_lpddr2_type(device->type); + + density = lpddr2_density_2_size_in_mbytes[device->density]; + if ((density / 1024 * 1024) == density) { + density /= 1024; + sprintf(density_str, "%d GB", density); + } else + sprintf(density_str, "%d MB", density); + if (mfg_str && type_str) + debug("%s\t\t%s\t%s\n", mfg_str, type_str, density_str); +} + +static u8 is_lpddr2_sdram_present(u32 base, u32 cs, + struct lpddr2_device_details *lpddr2_device) +{ + u32 mr = 0, temp; + + mr = get_mr(base, cs, LPDDR2_MR0); + if (mr > 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + temp = (mr & LPDDR2_MR0_DI_MASK) >> LPDDR2_MR0_DI_SHIFT; + if (temp) { + /* Not SDRAM */ + return 0; + } + temp = (mr & LPDDR2_MR0_DNVI_MASK) >> LPDDR2_MR0_DNVI_SHIFT; + + if (temp) { + /* DNV supported - But DNV is only supported for NVM */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR4); + if (mr > 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR5); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + if (!get_lpddr2_manufacturer(mr)) { + /* Manufacturer not identified */ + return 0; + } + lpddr2_device->manufacturer = mr; + + mr = get_mr(base, cs, LPDDR2_MR6); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR7); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR8); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + temp = (mr & MR8_TYPE_MASK) >> MR8_TYPE_SHIFT; + if (!get_lpddr2_type(temp)) { + /* Not SDRAM */ + return 0; + } + lpddr2_device->type = temp; + + temp = (mr & MR8_DENSITY_MASK) >> MR8_DENSITY_SHIFT; + if (temp > LPDDR2_DENSITY_32Gb) { + /* Density not supported */ + return 0; + } + lpddr2_device->density = temp; + + temp = (mr & MR8_IO_WIDTH_MASK) >> MR8_IO_WIDTH_SHIFT; + if (!get_lpddr2_io_width(temp)) { + /* IO width unsupported value */ + return 0; + } + lpddr2_device->io_width = temp; + + /* + * If all the above tests pass we should + * have a device on this chip-select + */ + return 1; +} + +static struct lpddr2_device_details *get_lpddr2_details(u32 base, u8 cs, + struct lpddr2_device_details *lpddr2_dev_details) +{ + u32 phy; + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + if (!lpddr2_dev_details) + return NULL; + + /* Do the minimum init for mode register accesses */ + if (!running_from_sdram()) { + phy = get_ddr_phy_ctrl_1(get_sys_clk_freq() / 2, RL_BOOT); + writel(phy, &emif->emif_ddr_phy_ctrl_1); + } + + if (!(is_lpddr2_sdram_present(base, cs, lpddr2_dev_details))) + return NULL; + + display_sdram_details(emif_num(base), cs, lpddr2_dev_details); + + return lpddr2_dev_details; +} + +void emif_get_device_details(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details) +{ + u32 base = (emif_nr == 1) ? OMAP44XX_EMIF1 : OMAP44XX_EMIF2; + + if (running_from_sdram()) { + /* + * We can not do automatic discovery running from SDRAM + * Most likely we came here by mistake. Indicate error + * by returning NULL + */ + cs0_device_details = NULL; + cs1_device_details = NULL; + } else { + /* + * Automatically find the device details: + * + * Reset the PHY after each call to get_lpddr2_details(). + * If there is nothing connected to a given chip select + * (typically CS1) mode register reads will mess up with + * the PHY state and subsequent initialization won't work. + * PHY reset brings back PHY to a good state. + */ + cs0_device_details = + get_lpddr2_details(base, CS0, cs0_device_details); + emif_reset_phy(base); + + cs1_device_details = + get_lpddr2_details(base, CS1, cs1_device_details); + emif_reset_phy(base); + } +} +#endif /* CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION */ + static void do_sdram_init(u32 base) { const struct emif_regs *regs; diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 9f82ef4..a8dd861 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -239,6 +239,7 @@
/* Defines for SDRAM init */ #ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS #endif
diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 6df1c3d..534f89a 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -245,6 +245,7 @@
- Allow SPL to have .bss disjoint from rest of the image - Allow for .bss setup in CONFIG_SPL_BUILD case too. - Take care of the special case where relocation offset = 0. - Compile out exception handling code and install a simpler vector
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Taken care of the case where .bss is at a lower address comapred to _start --- arch/arm/cpu/armv7/start.S | 50 ++++++++++++++++++++++++++++++---------- arch/arm/cpu/armv7/u-boot.lds | 2 + 2 files changed, 39 insertions(+), 13 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index d2a6207..5be436f 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -42,7 +42,16 @@ _start: b reset ldr pc, _not_used ldr pc, _irq ldr pc, _fiq - +#ifdef CONFIG_SPL_BUILD +_undefined_instruction: .word _undefined_instruction +_software_interrupt: .word _software_interrupt +_prefetch_abort: .word _prefetch_abort +_data_abort: .word _data_abort +_not_used: .word _not_used +_irq: .word _irq +_fiq: .word _fiq +_pad: .word 0x12345678 /* now 16*4=64 */ +#else _undefined_instruction: .word undefined_instruction _software_interrupt: .word software_interrupt _prefetch_abort: .word prefetch_abort @@ -51,6 +60,8 @@ _not_used: .word not_used _irq: .word irq _fiq: .word fiq _pad: .word 0x12345678 /* now 16*4=64 */ +#endif /* CONFIG_SPL_BUILD */ + .global _end_vect _end_vect:
@@ -89,6 +100,10 @@ _armboot_start: _bss_start_ofs: .word __bss_start - _start
+.global _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -182,12 +197,11 @@ stack_setup: mov sp, r4
adr r0, _start -#ifndef CONFIG_SPL_BUILD cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ -#endif mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: @@ -235,20 +249,34 @@ fixnext: add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ cmp r2, r3 blo fixloop + b clear_bss +_rel_dyn_start_ofs: + .word __rel_dyn_start - _start +_rel_dyn_end_ofs: + .word __rel_dyn_end - _start +_dynsym_start_ofs: + .word __dynsym_start - _start + +#endif /* #ifndef CONFIG_SPL_BUILD */
clear_bss: +#ifdef CONFIG_SPL_BUILD + /* No relocation for SPL */ + ldr r0, =__bss_start + ldr r1, =__bss_end__ +#else ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 +#endif mov r2, #0x00000000 /* clear */
clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 bne clbss_l -#endif /* #ifndef CONFIG_SPL_BUILD */
/* * We are done. Do not return, instead branch to second part of board @@ -276,13 +304,6 @@ jump_2_ram: _board_init_r_ofs: .word board_init_r - _start
-_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start - /************************************************************************* * * CPU_init_critical registers @@ -327,6 +348,8 @@ cpu_init_crit: bl lowlevel_init @ go setup pll,mux,memory mov lr, ip @ restore link mov pc, lr @ back to my caller + +#ifndef CONFIG_SPL_BUILD /* ************************************************************************* * @@ -514,4 +537,5 @@ fiq: bad_save_user_regs bl do_fiq
-#endif +#endif /* CONFIG_USE_IRQ */ +#endif /* CONFIG_SPL_BUILD */ diff --git a/arch/arm/cpu/armv7/u-boot.lds b/arch/arm/cpu/armv7/u-boot.lds index dbae54d..40ecf78 100644 --- a/arch/arm/cpu/armv7/u-boot.lds +++ b/arch/arm/cpu/armv7/u-boot.lds @@ -55,6 +55,8 @@ SECTIONS
. = ALIGN(4);
+ __image_copy_end = .; + .rel.dyn : { __rel_dyn_start = .; *(.rel*)
- Provide alternate implementations of board_init_f() board_init_r() for OMAP spl. - Provide linker script - Initialize global data - Add serial console support - Update CONFIG_SYS_TEXT_BASE to allow for SPL's bss and move it to board config header from config.mk
This patch adds two checkpatch warnings that look like false positives. Reported these to checkpatch maintainer.
V2: * Removed the label __flash_image_end because _end serves the same purpose after rebasing to latest mainline
V3: * Moved CONFIG_SYS_TEXT_BASE to board config header and deleted config.mk * Changes for the struct based register accesses * Removed usage of modify_reg_32() macro * omap4_rev_string() reference changed to omap_rev_string() * Folded the patches for linker script changes and console support into this patch * Improved commit message
V4: * Changed the CONFIG_SYS_SPL_* config flags to: CONFIG_SPL_* * Changed the name omap4_rev_string used in spl.c as this file is common for OMAP3/4 --- arch/arm/cpu/armv7/Makefile | 7 ++- arch/arm/cpu/armv7/omap-common/Makefile | 4 + arch/arm/cpu/armv7/omap-common/spl.c | 82 +++++++++++++++++++++++++ arch/arm/cpu/armv7/omap-common/u-boot-spl.lds | 62 +++++++++++++++++++ arch/arm/cpu/armv7/omap4/Makefile | 5 +- arch/arm/cpu/armv7/omap4/board.c | 7 ++ arch/arm/cpu/armv7/omap4/clocks.c | 33 ++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + arch/arm/include/asm/omap_common.h | 2 + board/ti/panda/Makefile | 2 + board/ti/panda/config.mk | 31 --------- board/ti/sdp4430/Makefile | 2 + board/ti/sdp4430/config.mk | 31 --------- include/configs/omap4_panda.h | 26 ++++++++ include/configs/omap4_sdp4430.h | 26 ++++++++ 15 files changed, 257 insertions(+), 64 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/spl.c create mode 100644 arch/arm/cpu/armv7/omap-common/u-boot-spl.lds delete mode 100644 board/ti/panda/config.mk delete mode 100644 board/ti/sdp4430/config.mk
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index 299792a..92a5a96 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -26,7 +26,12 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).o
START := start.o -COBJS := cpu.o cache_v7.o + +ifndef CONFIG_SPL_BUILD +COBJS += cache_v7.o +COBJS += cpu.o +endif + COBJS += syslib.o
SRCS := $(START:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index 8f698f8..0708796 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -30,6 +30,10 @@ SOBJS := reset.o COBJS := timer.o COBJS += utils.o
+ifdef CONFIG_SPL_BUILD +COBJS += spl.o +endif + SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS))
diff --git a/arch/arm/cpu/armv7/omap-common/spl.c b/arch/arm/cpu/armv7/omap-common/spl.c new file mode 100644 index 0000000..b201543 --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/spl.c @@ -0,0 +1,82 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/u-boot.h> +#include <asm/arch/sys_proto.h> +#include <timestamp_autogenerated.h> +#include <version_autogenerated.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Define global data structure pointer to it*/ +static gd_t gdata __attribute__ ((section(".data"))); +static bd_t bdata __attribute__ ((section(".data"))); + +inline void hang(void) +{ + puts("### ERROR ### Please RESET the board ###\n"); + for (;;) + ; +} + +void board_init_f(ulong dummy) +{ + /* + * We call relocate_code() with relocation target same as the + * CONFIG_SYS_SPL_TEXT_BASE. This will result in relocation getting + * skipped. Instead, only .bss initialization will happen. That's + * all we need + */ + debug(">>board_init_f()\n"); + relocate_code(CONFIG_SPL_STACK, &gdata, CONFIG_SPL_TEXT_BASE); +} + +void board_init_r(gd_t *id, ulong dummy) +{ + for (;;) + ; +} + +void preloader_console_init(void) +{ + const char *u_boot_rev = U_BOOT_VERSION; + char rev_string_buffer[50]; + + gd = &gdata; + gd->bd = &bdata; + gd->flags |= GD_FLG_RELOC; + gd->baudrate = CONFIG_BAUDRATE; + + setup_clocks_for_console(); + serial_init(); /* serial communications setup */ + + /* Avoid a second "U-Boot" coming from this string */ + u_boot_rev = &u_boot_rev[7]; + + printf("\nU-Boot SPL %s (%s - %s)\n", u_boot_rev, U_BOOT_DATE, + U_BOOT_TIME); + omap_rev_string(rev_string_buffer); + printf("Texas Instruments %s\n", rev_string_buffer); +} diff --git a/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds b/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds new file mode 100644 index 0000000..8867e06 --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds @@ -0,0 +1,62 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +MEMORY { .sram : ORIGIN = CONFIG_SPL_TEXT_BASE,\ + LENGTH = CONFIG_SPL_MAX_SIZE } +MEMORY { .sdram : ORIGIN = CONFIG_SPL_BSS_START_ADDR, \ + LENGTH = CONFIG_SPL_BSS_MAX_SIZE } + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + .text : + { + __start = .; + arch/arm/cpu/armv7/start.o (.text) + *(.text*) + } >.sram + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(.rodata*)) } >.sram + + . = ALIGN(4); + .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram + . = ALIGN(4); + __image_copy_end = .; + _end = .; + + .bss : + { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + __bss_end__ = .; + } >.sdram +} diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index e1ccd68..e7ee0b8 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -30,9 +30,12 @@ SOBJS += lowlevel_init.o COBJS += board.o COBJS += clocks.o COBJS += emif.o -COBJS += mem.o COBJS += sdram_elpida.o + +ifndef CONFIG_SPL_BUILD +COBJS += mem.o COBJS += sys_info.o +endif
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 786c239..54dd509 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -155,7 +155,14 @@ void s_init(void) init_omap4_revision(); watchdog_init(); set_mux_conf_regs(); +#ifdef CONFIG_SPL_BUILD + preloader_console_init(); +#endif prcm_init(); +#ifdef CONFIG_SPL_BUILD + /* For regular u-boot sdram_init() is called from dram_init() */ + sdram_init(); +#endif }
/* diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c index e8d3a52..f1e233a 100644 --- a/arch/arm/cpu/armv7/omap4/clocks.c +++ b/arch/arm/cpu/armv7/omap4/clocks.c @@ -791,6 +791,39 @@ void lock_dpll(u32 *const base) wait_for_lock(base); }
+void setup_clocks_for_console(void) +{ + /* Do not add any spl_debug prints in this function */ + clrsetbits_le32(&prcm->cm_l4per_clkstctrl, CD_CLKCTRL_CLKTRCTRL_MASK, + CD_CLKCTRL_CLKTRCTRL_SW_WKUP << + CD_CLKCTRL_CLKTRCTRL_SHIFT); + + /* Enable all UARTs - console will be on one of them */ + clrsetbits_le32(&prcm->cm_l4per_uart1_clkctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + + clrsetbits_le32(&prcm->cm_l4per_uart2_clkctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + + clrsetbits_le32(&prcm->cm_l4per_uart3_clkctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + + clrsetbits_le32(&prcm->cm_l4per_uart3_clkctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + + clrsetbits_le32(&prcm->cm_l4per_clkstctrl, CD_CLKCTRL_CLKTRCTRL_MASK, + CD_CLKCTRL_CLKTRCTRL_HW_AUTO << + CD_CLKCTRL_CLKTRCTRL_SHIFT); +} + void prcm_init(void) { switch (omap4_hw_init_context()) { diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 1e62878..a81f8e5 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -44,6 +44,7 @@ u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); void set_pl310_ctrl_reg(u32 val); void omap_rev_string(char *omap4_rev_string); +void setup_clocks_for_console(void); void prcm_init(void); void bypass_dpll(u32 *const base); void freq_update_core(void); diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 33caa4e..69d53d2 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -34,4 +34,6 @@ #define OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL 2 #define OMAP_INIT_CONTEXT_UBOOT_AFTER_CH 3
+void preloader_console_init(void); + #endif /* _OMAP_COMMON_H_ */ diff --git a/board/ti/panda/Makefile b/board/ti/panda/Makefile index 2186403..09f88ee 100644 --- a/board/ti/panda/Makefile +++ b/board/ti/panda/Makefile @@ -25,7 +25,9 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
+ifndef CONFIG_SPL_BUILD COBJS := panda.o +endif
SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/ti/panda/config.mk b/board/ti/panda/config.mk deleted file mode 100644 index 33901a7..0000000 --- a/board/ti/panda/config.mk +++ /dev/null @@ -1,31 +0,0 @@ -# -# (C) Copyright 2006-2009 -# Texas Instruments Incorporated, <www.ti.com> -# -# OMAP 4430 SDP -# see http://www.ti.com/ for more information on Texas Instruments -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -# SDRAM Address Space: -# 8000'0000 - 9fff'ffff (512 MB) -# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 -# (mem base + reserved) - -CONFIG_SYS_TEXT_BASE = 0x80e80000 diff --git a/board/ti/sdp4430/Makefile b/board/ti/sdp4430/Makefile index f1ee544..12f2743 100644 --- a/board/ti/sdp4430/Makefile +++ b/board/ti/sdp4430/Makefile @@ -25,7 +25,9 @@ include $(TOPDIR)/config.mk
+ifndef CONFIG_SPL_BUILD COBJS := sdp.o cmd_bat.o +endif
SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/ti/sdp4430/config.mk b/board/ti/sdp4430/config.mk deleted file mode 100644 index 33901a7..0000000 --- a/board/ti/sdp4430/config.mk +++ /dev/null @@ -1,31 +0,0 @@ -# -# (C) Copyright 2006-2009 -# Texas Instruments Incorporated, <www.ti.com> -# -# OMAP 4430 SDP -# see http://www.ti.com/ for more information on Texas Instruments -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -# SDRAM Address Space: -# 8000'0000 - 9fff'ffff (512 MB) -# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 -# (mem base + reserved) - -CONFIG_SYS_TEXT_BASE = 0x80e80000 diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index a8dd861..1112362 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -243,4 +243,30 @@ #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS #endif
+/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_TEXT_BASE 0x40304350 +#define CONFIG_SPL_MAX_SIZE 0x8000 /* 32 K */ +#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK + +#define CONFIG_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv7/omap-common/u-boot-spl.lds" + +/* + * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM + * 64 bytes before this address should be set aside for u-boot.img's + * header. That is 0x800FFFC0--0x80100000 should not be used for any + * other needs. + */ +#define CONFIG_SYS_TEXT_BASE 0x80100000 + #endif /* __CONFIG_H */ diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 534f89a..6a6be9e 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -249,4 +249,30 @@ #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS #endif
Provide appropriate '-O u-boot' while doing mkimage for u-boot.img
Signed-off-by: Aneesh V aneesh@ti.com --- Makefile | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/Makefile b/Makefile index 0707036..f8ae883 100644 --- a/Makefile +++ b/Makefile @@ -375,7 +375,7 @@ $(obj)u-boot.ldr.srec: $(obj)u-boot.ldr
$(obj)u-boot.img: $(obj)u-boot.bin $(obj)tools/mkimage -A $(ARCH) -T firmware -C none \ - -a $(CONFIG_SYS_TEXT_BASE) -e 0 \ + -O u-boot -a $(CONFIG_SYS_TEXT_BASE) -e 0 \ -n $(shell sed -n -e 's/.*U_BOOT_VERSION//p' $(VERSION_FILE) | \ sed -e 's/"[ ]*$$/ for $(BOARD) board"/') \ -d $< $@
Dear Aneesh V,
Applied, thanks.
- Add MMC raw and FAT mode boot support for OMAP - Provide a means by which parameters passed by ROM-code can be saved in u-boot. - Save boot mode related information passed by OMAP4 ROM-code and use it to determine where to load the u-boot from - Assumes that the image has a mkimage header. Gets the payload size and load address from this header. If the header is not detected assume u-boot.bin as payload
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Squashed the patches that provided MMC support, FAT support, start.S hook for saving parameters, and OMAP4 patch for saving the parameters all into this patch. * Removed the assumption that payload is u-boot.bin. Payload size and address --- arch/arm/cpu/armv7/cpu.c | 7 + arch/arm/cpu/armv7/omap-common/spl.c | 194 +++++++++++++++++++++++++++++- arch/arm/cpu/armv7/omap4/board.c | 21 ++++ arch/arm/cpu/armv7/omap4/lowlevel_init.S | 31 +++++ arch/arm/cpu/armv7/start.S | 1 + arch/arm/include/asm/arch-omap4/omap4.h | 8 ++ arch/arm/include/asm/omap_common.h | 17 +++ include/configs/omap4_panda.h | 5 + include/configs/omap4_sdp4430.h | 5 + 9 files changed, 287 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/cpu.c b/arch/arm/cpu/armv7/cpu.c index def9ced..091e3e0 100644 --- a/arch/arm/cpu/armv7/cpu.c +++ b/arch/arm/cpu/armv7/cpu.c @@ -37,6 +37,13 @@ #include <asm/cache.h> #include <asm/armv7.h>
+void save_boot_params_default(u32 r0, u32 r1, u32 r2, u32 r3) +{ +} + +void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) + __attribute__((weak, alias("save_boot_params_default"))); + int cleanup_before_linux(void) { /* diff --git a/arch/arm/cpu/armv7/omap-common/spl.c b/arch/arm/cpu/armv7/omap-common/spl.c index b201543..d177652 100644 --- a/arch/arm/cpu/armv7/omap-common/spl.c +++ b/arch/arm/cpu/armv7/omap-common/spl.c @@ -24,15 +24,27 @@ */ #include <common.h> #include <asm/u-boot.h> +#include <asm/utils.h> #include <asm/arch/sys_proto.h> +#include <mmc.h> +#include <fat.h> #include <timestamp_autogenerated.h> #include <version_autogenerated.h> +#include <asm/omap_common.h> +#include <asm/arch/mmc_host_def.h> +#include <i2c.h> +#include <image.h>
/* Define global data structure pointer to it*/ static gd_t gdata __attribute__ ((section(".data"))); static bd_t bdata __attribute__ ((section(".data"))); +static const char *image_name; +static u8 image_os; +static u32 image_load_addr; +static u32 image_entry_point; +static u32 image_size;
inline void hang(void) { @@ -53,10 +65,188 @@ void board_init_f(ulong dummy) relocate_code(CONFIG_SPL_STACK, &gdata, CONFIG_SPL_TEXT_BASE); }
+#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + switch (omap_boot_device()) { + case BOOT_DEVICE_MMC1: + omap_mmc_init(0); + break; + case BOOT_DEVICE_MMC2: + omap_mmc_init(1); + break; + } + return 0; +} +#endif + +static void parse_image_header(const struct image_header *header) +{ + u32 header_size = sizeof(struct image_header); + + if (__be32_to_cpu(header->ih_magic) == IH_MAGIC) { + image_size = __be32_to_cpu(header->ih_size) + header_size; + image_entry_point = __be32_to_cpu(header->ih_load); + /* Load including the header */ + image_load_addr = image_entry_point - header_size; + image_os = header->ih_os; + image_name = (const char *)&header->ih_name; + debug("spl: payload image: %s load addr: 0x%x size: %d\n", + image_name, image_load_addr, image_size); + } else { + /* Signature not found - assume u-boot.bin */ + printf("mkimage signature not found - ih_magic = %x\n", + header->ih_magic); + puts("Assuming u-boot.bin ..\n"); + /* Let's assume U-Boot will not be more than 200 KB */ + image_size = 200 * 1024; + image_entry_point = CONFIG_SYS_TEXT_BASE; + image_load_addr = CONFIG_SYS_TEXT_BASE; + image_os = IH_OS_U_BOOT; + image_name = "U-Boot"; + } +} + +static void mmc_load_image_raw(struct mmc *mmc) +{ + u32 image_size_sectors, err; + const struct image_header *header; + + header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - + sizeof(struct image_header)); + + /* read image header to find the image size & load address */ + err = mmc->block_dev.block_read(0, + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR, 1, + (void *)header); + + if (err <= 0) + goto end; + + parse_image_header(header); + + /* convert size to sectors - round up */ + image_size_sectors = (image_size + MMCSD_SECTOR_SIZE - 1) / + MMCSD_SECTOR_SIZE; + + /* Read the header too to avoid extra memcpy */ + err = mmc->block_dev.block_read(0, + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR, + image_size_sectors, (void *)image_load_addr); + +end: + if (err <= 0) { + printf("spl: mmc blk read err - %d\n", err); + hang(); + } +} + +static void mmc_load_image_fat(struct mmc *mmc) +{ + s32 err; + struct image_header *header; + + header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - + sizeof(struct image_header)); + + err = fat_register_device(&mmc->block_dev, + CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION); + if (err) { + printf("spl: fat register err - %d\n", err); + hang(); + } + + err = file_fat_read(CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, + (u8 *)header, sizeof(struct image_header)); + if (err <= 0) + goto end; + + parse_image_header(header); + + err = file_fat_read(CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, + (u8 *)image_load_addr, 0); + +end: + if (err <= 0) { + printf("spl: error reading image %s, err - %d\n", + CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, err); + hang(); + } +} + +static void mmc_load_image(void) +{ + struct mmc *mmc; + int err; + u32 boot_mode; + + mmc_initialize(gd->bd); + /* We register only one device. So, the dev id is always 0 */ + mmc = find_mmc_device(0); + if (!mmc) { + puts("spl: mmc device not found!!\n"); + hang(); + } + + err = mmc_init(mmc); + if (err) { + printf("spl: mmc init failed: err - %d\n", err); + hang(); + } + + boot_mode = omap_boot_mode(); + if (boot_mode == MMCSD_MODE_RAW) { + debug("boot mode - RAW\n"); + mmc_load_image_raw(mmc); + } else if (boot_mode == MMCSD_MODE_FAT) { + debug("boot mode - FAT\n"); + mmc_load_image_fat(mmc); + } else { + puts("spl: wrong MMC boot mode\n"); + hang(); + } +} + +void jump_to_image_no_args(void) +{ + typedef void (*image_entry_noargs_t)(void)__attribute__ ((noreturn)); + image_entry_noargs_t image_entry = + (image_entry_noargs_t) image_entry_point; + + image_entry(); +} + +void jump_to_image_no_args(void) __attribute__ ((noreturn)); void board_init_r(gd_t *id, ulong dummy) { - for (;;) - ; + u32 boot_device; + debug(">>spl:board_init_r()\n"); + + timer_init(); + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + + boot_device = omap_boot_device(); + debug("boot device - %d\n", boot_device); + switch (boot_device) { + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: + mmc_load_image(); + break; + default: + printf("SPL: Un-supported Boot Device - %d!!!\n", boot_device); + hang(); + break; + } + + switch (image_os) { + case IH_OS_U_BOOT: + debug("Jumping to U-Boot\n"); + jump_to_image_no_args(); + break; + default: + puts("Unsupported OS image.. Jumping nevertheless..\n"); + jump_to_image_no_args(); + } }
void preloader_console_init(void) diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 54dd509..2e5739a 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -39,6 +39,27 @@ DECLARE_GLOBAL_DATA_PTR;
u32 *const omap4_revision = (u32 *)OMAP4_SRAM_SCRATCH_OMAP4_REV;
+#ifdef CONFIG_SPL_BUILD +/* + * We use static variables because global data is not ready yet. + * Initialized data is available in SPL right from the beginning. + * We would not typically need to save these parameters in regular + * U-Boot. This is needed only in SPL at the moment. + */ +u32 omap4_boot_device = BOOT_DEVICE_MMC1; +u32 omap4_boot_mode = MMCSD_MODE_FAT; + +u32 omap_boot_device(void) +{ + return omap4_boot_device; +} + +u32 omap_boot_mode(void) +{ + return omap4_boot_mode; +} +#endif + void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) { int i; diff --git a/arch/arm/cpu/armv7/omap4/lowlevel_init.S b/arch/arm/cpu/armv7/omap4/lowlevel_init.S index 6abfbba..91525ec 100644 --- a/arch/arm/cpu/armv7/omap4/lowlevel_init.S +++ b/arch/arm/cpu/armv7/omap4/lowlevel_init.S @@ -27,6 +27,37 @@ */
#include <asm/arch/omap4.h> +#ifdef CONFIG_SPL_BUILD +.global save_boot_params +save_boot_params: + /* + * See if the rom code passed pointer is valid: + * It is not valid if it is not in non-secure SRAM + * This may happen if you are booting with the help of + * debugger + */ + ldr r2, =NON_SECURE_SRAM_START + cmp r2, r0 + bgt 1f + ldr r2, =NON_SECURE_SRAM_END + cmp r2, r0 + blt 1f + + /* Store the boot device in omap4_boot_device */ + ldr r2, [r0, #BOOT_DEVICE_OFFSET] @ r1 <- value of boot device + and r2, #BOOT_DEVICE_MASK + ldr r3, =omap4_boot_device + str r2, [r3] @ omap4_boot_device <- r1 + + /* Store the boot mode (raw/FAT) in omap4_boot_mode */ + ldr r2, [r0, #DEV_DESC_PTR_OFFSET] @ get the device descriptor ptr + ldr r2, [r2, #DEV_DATA_PTR_OFFSET] @ get the pDeviceData ptr + ldr r2, [r2, #BOOT_MODE_OFFSET] @ get the boot mode + ldr r3, =omap4_boot_mode + str r2, [r3] +1: + bx lr +#endif
.globl lowlevel_init lowlevel_init: diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 5be436f..89ea01f 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -134,6 +134,7 @@ IRQ_STACK_START_IN: */
reset: + bl save_boot_params /* * set the cpu to SVC32 mode */ diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index a8dbedb..563544f 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -144,4 +144,12 @@ struct s32ktimer { #define OMAP4430_ES2_2 0x44300220 #define OMAP4430_ES2_3 0x44300230
+/* ROM code defines */ +/* Boot device */ +#define BOOT_DEVICE_MASK 0xFF +#define BOOT_DEVICE_OFFSET 0x8 +#define DEV_DESC_PTR_OFFSET 0x4 +#define DEV_DATA_PTR_OFFSET 0x18 +#define BOOT_MODE_OFFSET 0x8 + #endif diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 69d53d2..d3cb857 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -36,4 +36,21 @@
+/* Boot device */ +#define BOOT_DEVICE_NONE 0 +#define BOOT_DEVICE_XIP 1 +#define BOOT_DEVICE_XIPWAIT 2 +#define BOOT_DEVICE_NAND 3 +#define BOOT_DEVICE_ONE_NAND 4 +#define BOOT_DEVICE_MMC1 5 +#define BOOT_DEVICE_MMC2 6 + +/* Boot type */ +#define MMCSD_MODE_UNDEFINED 0 +#define MMCSD_MODE_RAW 1 +#define MMCSD_MODE_FAT 2 + +u32 omap_boot_device(void); +u32 omap_boot_mode(void); + #endif /* _OMAP_COMMON_H_ */ diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 1112362..f6f283a 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -252,6 +252,11 @@ #define CONFIG_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */
+#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" + #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBDISK_SUPPORT #define CONFIG_SPL_I2C_SUPPORT diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 6a6be9e..346763d 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -258,6 +258,11 @@ #define CONFIG_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */
Hi Aneesh,
I'am not really sure about the save_boot_params() feature you added.
May you point me where I can find this in the OMAP reference docs?
Thanks! Simon
Hi Simon,
On Tuesday 19 July 2011 02:46 PM, Simon Schwarz wrote:
Hi Aneesh,
What I have done for OMAP4 will not work for OMAP3. For OMAP3 you will get only the boot-device(eMMC, MMC/SD, nand etc) and *not* the bootmode(raw vs FAT).
To get boot device you can don one of the following approaches.
1. What x-loader does
git://git.omapzoom.org/repo/x-loader.git - master branch
cpu/omap3/start.S:
reset: ldr r4, scratchpad /* r4 <- scratchpad reg address */ ldr r5, [r0, #0x4] /* r5 <- value of boot device */ str r5, [r4] /* store r5 in scratchpad reg */
See the usage in lib/board.c:
Here are the device numbers: case 0x03: strcpy(boot_dev_name, "ONENAND"); case 0x02: strcpy(boot_dev_name, "NAND"); case 0x05: strcpy(boot_dev_name, "EMMC"); case 0x06: strcpy(boot_dev_name, "MMC/SD1");
This is internal ROM code information and not documented anywhere.
You may assume FAT mode for MMC/SD1 and raw mode for the rest.
2. Read the boot device from a hw register(SYS_BOOT)
See 'chapter 26 Initialization' and look at table 26-3
best regards, Aneesh
- Add mkimage support for OMAP boot image - Add support for OMAP boot image(MLO) generation in the new SPL framework
Signed-off-by: John Rigby john.rigby@linaro.org Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Fixed minor issue with casting away 'const'ness of pointers * Ensure lists are sorted alphabetically * Added an error message * Removed 'packed' attribute from structs * Fixed some other minor comments on V2 * Adapted for the new SPL framework V4: * Replaced CONFIG_SYS_SPL_TEXT_BASE with CONFIG_SPL_TEXT_BASE --- arch/arm/cpu/armv7/omap4/config.mk | 30 +++++ common/image.c | 9 +- include/image.h | 1 + spl/Makefile | 6 + tools/Makefile | 2 + tools/mkimage.c | 2 + tools/mkimage.h | 1 + tools/omapimage.c | 224 ++++++++++++++++++++++++++++++++++++ tools/omapimage.h | 50 ++++++++ 9 files changed, 321 insertions(+), 4 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/config.mk create mode 100644 tools/omapimage.c create mode 100644 tools/omapimage.h
diff --git a/arch/arm/cpu/armv7/omap4/config.mk b/arch/arm/cpu/armv7/omap4/config.mk new file mode 100644 index 0000000..b34fa64 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/config.mk @@ -0,0 +1,30 @@ +# +# Copyright 2011 Linaro Limited +# See file CREDITS for list of people who contributed to this +# project. +# +# (C) Copyright 2010 +# Texas Instruments, <www.ti.com> +# +# Aneesh V aneesh@ti.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +ifdef CONFIG_SPL_BUILD +ALL-y += $(OBJTREE)/MLO +else +ALL-y += $(obj)u-boot.img +endif diff --git a/common/image.c b/common/image.c index e542a57..a141904 100644 --- a/common/image.c +++ b/common/image.c @@ -130,17 +130,18 @@ static const table_entry_t uimage_os[] = { };
static const table_entry_t uimage_type[] = { - { IH_TYPE_INVALID, NULL, "Invalid Image", }, { IH_TYPE_FILESYSTEM, "filesystem", "Filesystem Image", }, { IH_TYPE_FIRMWARE, "firmware", "Firmware", }, + { IH_TYPE_FLATDT, "flat_dt", "Flat Device Tree", }, + { IH_TYPE_INVALID, NULL, "Invalid Image", }, + { IH_TYPE_IMXIMAGE, "imximage", "Freescale i.MX Boot Image",}, { IH_TYPE_KERNEL, "kernel", "Kernel Image", }, + { IH_TYPE_KWBIMAGE, "kwbimage", "Kirkwood Boot Image",}, { IH_TYPE_MULTI, "multi", "Multi-File Image", }, + { IH_TYPE_OMAPIMAGE, "omapimage", "TI OMAP SPL With GP CH",}, { IH_TYPE_RAMDISK, "ramdisk", "RAMDisk Image", }, { IH_TYPE_SCRIPT, "script", "Script", }, { IH_TYPE_STANDALONE, "standalone", "Standalone Program", }, - { IH_TYPE_FLATDT, "flat_dt", "Flat Device Tree", }, - { IH_TYPE_KWBIMAGE, "kwbimage", "Kirkwood Boot Image",}, - { IH_TYPE_IMXIMAGE, "imximage", "Freescale i.MX Boot Image",}, { -1, "", "", }, };
diff --git a/include/image.h b/include/image.h index c31e862..c606644 100644 --- a/include/image.h +++ b/include/image.h @@ -157,6 +157,7 @@ #define IH_TYPE_FLATDT 8 /* Binary Flat Device Tree Blob */ #define IH_TYPE_KWBIMAGE 9 /* Kirkwood Boot Image */ #define IH_TYPE_IMXIMAGE 10 /* Freescale IMXBoot Image */ +#define IH_TYPE_OMAPIMAGE 11 /* TI OMAP Config Header Image */
/* * Compression Types diff --git a/spl/Makefile b/spl/Makefile index 0c0ae2a..5cdd9e9 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -85,6 +85,12 @@ LDPPFLAGS += \ $(shell $(LD) --version | \ sed -ne 's/GNU ld version ([0-9][0-9]*).([0-9][0-9]*).*/-DLD_MAJOR=\1 -DLD_MINOR=\2/p')
+ifdef CONFIG_OMAP +$(OBJTREE)/MLO: $(obj)u-boot-spl.bin + $(OBJTREE)/tools/mkimage -T omapimage \ + -a $(CONFIG_SPL_TEXT_BASE) -d $< $@ +endif + ALL-y += $(obj)u-boot-spl.bin
all: $(ALL-y) diff --git a/tools/Makefile b/tools/Makefile index 97f83f8..cb7f92d 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -88,6 +88,7 @@ OBJ_FILES-$(CONFIG_CMD_LOADS) += img2srec.o OBJ_FILES-$(CONFIG_INCA_IP) += inca-swap-bytes.o NOPED_OBJ_FILES-y += kwbimage.o NOPED_OBJ_FILES-y += imximage.o +NOPED_OBJ_FILES-y += omapimage.o NOPED_OBJ_FILES-y += mkimage.o OBJ_FILES-$(CONFIG_NETCONSOLE) += ncb.o NOPED_OBJ_FILES-y += os_support.o @@ -188,6 +189,7 @@ $(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)md5.o \ $(obj)mkimage.o \ $(obj)os_support.o \ + $(obj)omapimage.o \ $(obj)sha1.o \ $(LIBFDT_OBJS) $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ diff --git a/tools/mkimage.c b/tools/mkimage.c index 60f7263..b6a7cb7 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -156,6 +156,8 @@ main (int argc, char **argv) init_imx_image_type (); /* Init FIT image generation/list support */ init_fit_image_type (); + /* Init TI OMAP Boot image generation/list support */ + init_omap_image_type(); /* Init Default image generation/list support */ init_default_image_type ();
diff --git a/tools/mkimage.h b/tools/mkimage.h index 9033a7d..3b49645 100644 --- a/tools/mkimage.h +++ b/tools/mkimage.h @@ -143,5 +143,6 @@ void init_kwb_image_type (void); void init_imx_image_type (void); void init_default_image_type (void); void init_fit_image_type (void); +void init_omap_image_type(void);
#endif /* _MKIIMAGE_H_ */ diff --git a/tools/omapimage.c b/tools/omapimage.c new file mode 100644 index 0000000..29d91cc --- /dev/null +++ b/tools/omapimage.c @@ -0,0 +1,224 @@ +/* + * (C) Copyright 2010 + * Linaro LTD, www.linaro.org + * Author: John Rigby john.rigby@linaro.org + * Based on TI's signGP.c + * + * (C) Copyright 2009 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * (C) Copyright 2008 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* Required to obtain the getline prototype from stdio.h */ +#define _GNU_SOURCE + +#include "mkimage.h" +#include <image.h> +#include "omapimage.h" + +/* Header size is CH header rounded up to 512 bytes plus GP header */ +#define OMAP_CH_HDR_SIZE 512 +#define OMAP_GP_HDR_SIZE (sizeof(struct gp_header)) +#define OMAP_FILE_HDR_SIZE (OMAP_CH_HDR_SIZE+OMAP_GP_HDR_SIZE) + +static uint8_t omapimage_header[OMAP_FILE_HDR_SIZE]; + +static int omapimage_check_image_types(uint8_t type) +{ + if (type == IH_TYPE_OMAPIMAGE) + return EXIT_SUCCESS; + else { + fprintf(stderr, "Unknown OMAP image type - %x", type); + return EXIT_FAILURE; + } +} + +/* + * Only the simplest image type is currently supported: + * TOC pointing to CHSETTINGS + * TOC terminator + * CHSETTINGS + * + * padding to OMAP_CH_HDR_SIZE bytes + * + * gp header + * size + * load_addr + */ +static int valid_gph_size(uint32_t size) +{ + return size; +} + +static int valid_gph_load_addr(uint32_t load_addr) +{ + return load_addr; +} + +static int omapimage_verify_header(unsigned char *ptr, int image_size, + struct mkimage_params *params) +{ + struct ch_toc *toc = (struct ch_toc *)ptr; + struct gp_header *gph = (struct gp_header *)(ptr+OMAP_CH_HDR_SIZE); + uint32_t offset, size; + + while (toc->section_offset != 0xffffffff + && toc->section_size != 0xffffffff) { + offset = toc->section_offset; + size = toc->section_size; + if (!offset || !size) + return -1; + if (offset >= OMAP_CH_HDR_SIZE || + offset+size >= OMAP_CH_HDR_SIZE) + return -1; + toc++; + } + if (!valid_gph_size(gph->size)) + return -1; + if (!valid_gph_load_addr(gph->load_addr)) + return -1; + + return 0; +} + +static void omapimage_print_section(struct ch_settings *chs) +{ + const char *section_name; + + if (chs->section_key) + section_name = "CHSETTINGS"; + else + section_name = "UNKNOWNKEY"; + + printf("%s (%x) " + "valid:%x " + "version:%x " + "reserved:%x " + "flags:%x\n", + section_name, + chs->section_key, + chs->valid, + chs->version, + chs->reserved, + chs->flags); +} + +static void omapimage_print_header(const void *ptr) +{ + const struct ch_toc *toc = (struct ch_toc *)ptr; + const struct gp_header *gph = + (struct gp_header *)(ptr+OMAP_CH_HDR_SIZE); + uint32_t offset, size; + + while (toc->section_offset != 0xffffffff + && toc->section_size != 0xffffffff) { + offset = toc->section_offset; + size = toc->section_size; + + if (offset >= OMAP_CH_HDR_SIZE || + offset+size >= OMAP_CH_HDR_SIZE) + exit(EXIT_FAILURE); + + printf("Section %s offset %x length %x\n", + toc->section_name, + toc->section_offset, + toc->section_size); + + omapimage_print_section((struct ch_settings *)(ptr+offset)); + toc++; + } + + if (!valid_gph_size(gph->size)) { + fprintf(stderr, + "Error: invalid image size %x\n", + gph->size); + exit(EXIT_FAILURE); + } + + if (!valid_gph_load_addr(gph->load_addr)) { + fprintf(stderr, + "Error: invalid image load address %x\n", + gph->size); + exit(EXIT_FAILURE); + } + + printf("GP Header: Size %x LoadAddr %x\n", + gph->size, gph->load_addr); +} + +static int toc_offset(void *hdr, void *member) +{ + return member - hdr; +} + +static void omapimage_set_header(void *ptr, struct stat *sbuf, int ifd, + struct mkimage_params *params) +{ + struct ch_toc *toc = (struct ch_toc *)ptr; + struct ch_settings *chs = (struct ch_settings *) + (ptr + 2 * sizeof(*toc)); + struct gp_header *gph = (struct gp_header *)(ptr + OMAP_CH_HDR_SIZE); + + toc->section_offset = toc_offset(ptr, chs); + toc->section_size = sizeof(struct ch_settings); + strcpy((char *)toc->section_name, "CHSETTINGS"); + + chs->section_key = KEY_CHSETTINGS; + chs->valid = 0; + chs->version = 1; + chs->reserved = 0; + chs->flags = 0; + + toc++; + memset(toc, 0xff, sizeof(*toc)); + + gph->size = sbuf->st_size - OMAP_FILE_HDR_SIZE; + gph->load_addr = params->addr; +} + +int omapimage_check_params(struct mkimage_params *params) +{ + return (params->dflag && (params->fflag || params->lflag)) || + (params->fflag && (params->dflag || params->lflag)) || + (params->lflag && (params->dflag || params->fflag)); +} + +/* + * omapimage parameters + */ +static struct image_type_params omapimage_params = { + .name = "TI OMAP CH/GP Boot Image support", + .header_size = OMAP_FILE_HDR_SIZE, + .hdr = (void *)&omapimage_header, + .check_image_type = omapimage_check_image_types, + .verify_header = omapimage_verify_header, + .print_header = omapimage_print_header, + .set_header = omapimage_set_header, + .check_params = omapimage_check_params, +}; + +void init_omap_image_type(void) +{ + mkimage_register(&omapimage_params); +} diff --git a/tools/omapimage.h b/tools/omapimage.h new file mode 100644 index 0000000..719db00 --- /dev/null +++ b/tools/omapimage.h @@ -0,0 +1,50 @@ +/* + * (C) Copyright 2010 + * Linaro LTD, www.linaro.org + * Author John Rigby john.rigby@linaro.org + * Based on TI's signGP.c + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _OMAPIMAGE_H_ +#define _OMAPIMAGE_H_ + +struct ch_toc { + uint32_t section_offset; + uint32_t section_size; + uint8_t unused[12]; + uint8_t section_name[12]; +}; + +struct ch_settings { + uint32_t section_key; + uint8_t valid; + uint8_t version; + uint16_t reserved; + uint32_t flags; +}; + +struct gp_header { + uint32_t size; + uint32_t load_addr; +}; + +#define KEY_CHSETTINGS 0xC0C0C0C1 +#endif /* _OMAPIMAGE_H_ */
Dear Sandeep,
please pull this directly with the rest of the OMAP SPL patches.
V3:
- Fixed minor issue with casting away 'const'ness of pointers
- Ensure lists are sorted alphabetically
- Added an error message
- Removed 'packed' attribute from structs
- Fixed some other minor comments on V2
- Adapted for the new SPL framework
V4:
- Replaced CONFIG_SYS_SPL_TEXT_BASE with CONFIG_SPL_TEXT_BASE
Acked-by: Wolfgang Denk wd@denx.de
Dear Albert,
Dear Sandeep,
V3:
V4:
For some reason the change to include/image.h has NOT made it into u-boot-arm/master, therefore all builds are currently broken!
common/image.c:141:4: error: ‘IH_TYPE_OMAPIMAGE’ undeclared here (not in a function)
Best Regards, Reinhard
Hi Reinhard,
Le 02/08/2011 11:08, Reinhard Meyer a écrit :
Dear Albert,
Dear Sandeep,
Signed-off-by: John Rigbyjohn.rigby@linaro.org Signed-off-by: Aneesh Vaneesh@ti.com
V3:
V4:
My fault -- slipped a cam when rebasing. Please re-fetch master (and next and utf8 for anyone who wants them too).
Two notes BTW:
1. due to the merge conflict between UBL and OMAP image additions, I have re-numbered TH_TYPE_OMAPIMAGE value from 11 to 12.
2. after UBL addition, the table_entry_t uimage_type table in common/image.c is no longer sorted by image name. I did not fix this as this could require changes beyond what the merge conflict resolution required.
Apologies for the merge issue.
Amicalement,
Dear Albert,
Dear Albert,
Dear Sandeep,
V3:
V4:
Two notes BTW:
- due to the merge conflict between UBL and OMAP image additions, I
- after UBL addition, the table_entry_t uimage_type table in
Amicalement,
I had locally fixed that define myself, but then got build warnings for some undefined function in the same image-making business (can't recheck that right now, a lengthy MAKEALL is in progress).
For the time being I rather stay based on u-boot/master until such issues are fixed. Anyway a merge of my AT91 stuff with your ARM stuff should not generate any merge conflicts, except maybe boards.cfg.
This series adds mmc SPL support for OMAP4. This is essentially an up-streaming effort for TI's x-loader for OMAP4 using the SPL framework
This work partly draws upon previous work done for x-loader by: Santosh Shilimkar santosh.shilimkar@ti.com Rajendra Nayak rnayak@ti.com and many others
This series depends on the following series for the new SPL framework: http://marc.info/?l=u-boot&m=131056990001719&w=2
Features supported: * Clock init - DPLL locking, clock domains/modules enabling * SDRAM/DMM initialization * Mux initialization * MMC raw read support * MMC FAT read support
Improvments over x-loader: * Code completely revamped * DPLL programming that works for all SYS_CLK frequencies * Automatic SDRAM identification and initialization * Board dependent parts(especially mux) deferred to u-boot. So, same SPL will work for Panda and SDP and most likely on any other board that comes along * Flexible about the payload. Any image with a mkimage header can be loaded. * The core SPL logic is generic and available for OMAP3/4. So, OMAP3 platforms can easily extend this work to add SPL support for the respective boards.
V2: * Some fixes in SDRAM init, clock init * Use of pre-calculated M & N values for DPLL locking instead run-time calculation * Change in make files to allow reuse of common rules between boards * Console initialization moved further earlier in the boot allowing traces from even clock initialization code * Reuse utility macros from a previous series
V3: * Moved to the new SPL framework * struct based register access for clock init * Squashed together related patches as per Wolfgang's suggestions * Re-organization of code in sdram init for better readability * SPL loading the payload using mkimage header * Avoided using custom bit-field accessor macros * Several other minor changes(documented in respective patches)
V4: * Rebased on u-boot-ti/master as on 21 Jul 2011
Aneesh V (11): omap4: utility function to identify the context of hw init omap4: cleanup pin mux data omap4: add OMAP4430 revision check omap4: add clock support omap4: add sdram init support omap4: calculate EMIF register values omap4: automatic sdram detection armv7: start.S: fixes and enhancements for SPL omap: add basic SPL support Correct ih_os for u-boot.img omap: add MMC and FAT support to SPL
John Rigby (1): mkimage: Add OMAP boot image support
Makefile | 2 +- arch/arm/cpu/armv7/Makefile | 7 +- arch/arm/cpu/armv7/cpu.c | 7 + arch/arm/cpu/armv7/omap-common/Makefile | 5 + arch/arm/cpu/armv7/omap-common/spl.c | 272 ++++ arch/arm/cpu/armv7/omap-common/u-boot-spl.lds | 62 + arch/arm/cpu/armv7/omap-common/utils.c | 57 + arch/arm/cpu/armv7/omap4/Makefile | 6 + arch/arm/cpu/armv7/omap4/board.c | 161 +++- arch/arm/cpu/armv7/omap4/clocks.c | 842 +++++++++++++ .../panda => arch/arm/cpu/armv7/omap4}/config.mk | 25 +- arch/arm/cpu/armv7/omap4/emif.c | 1305 ++++++++++++++++++++ arch/arm/cpu/armv7/omap4/lowlevel_init.S | 31 + arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 76 ++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 282 +++++ arch/arm/cpu/armv7/start.S | 50 +- arch/arm/cpu/armv7/u-boot.lds | 2 + arch/arm/include/asm/arch-omap4/clocks.h | 664 ++++++++++ arch/arm/include/asm/arch-omap4/emif.h | 1034 ++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 52 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 72 ++- arch/arm/include/asm/armv7.h | 5 + arch/arm/include/asm/omap_common.h | 56 + board/ti/panda/Makefile | 2 + board/ti/panda/panda.c | 25 +- board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} | 76 +- board/ti/sdp4430/Makefile | 2 + board/ti/sdp4430/config.mk | 31 - board/ti/sdp4430/sdp.c | 25 +- .../{panda/panda.h => sdp4430/sdp4430_mux_data.h} | 128 +-- common/image.c | 9 +- include/configs/omap4_panda.h | 37 + include/configs/omap4_sdp4430.h | 37 + include/image.h | 1 + spl/Makefile | 6 + tools/Makefile | 2 + tools/mkimage.c | 2 + tools/mkimage.h | 1 + tools/omap/clocks_get_m_n.c | 197 +++ tools/omapimage.c | 224 ++++ tools/omapimage.h | 50 + 41 files changed, 5668 insertions(+), 262 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/spl.c create mode 100644 arch/arm/cpu/armv7/omap-common/u-boot-spl.lds create mode 100644 arch/arm/cpu/armv7/omap-common/utils.c create mode 100644 arch/arm/cpu/armv7/omap4/clocks.c rename {board/ti/panda => arch/arm/cpu/armv7/omap4}/config.mk (64%) create mode 100644 arch/arm/cpu/armv7/omap4/emif.c create mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h create mode 100644 arch/arm/cpu/armv7/omap4/sdram_elpida.c create mode 100644 arch/arm/include/asm/arch-omap4/clocks.h create mode 100644 arch/arm/include/asm/arch-omap4/emif.h create mode 100644 arch/arm/include/asm/omap_common.h rename board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} (76%) delete mode 100644 board/ti/sdp4430/config.mk rename board/ti/{panda/panda.h => sdp4430/sdp4430_mux_data.h} (67%) create mode 100644 tools/omap/clocks_get_m_n.c create mode 100644 tools/omapimage.c create mode 100644 tools/omapimage.h
Features supported:
- Clock init - DPLL locking, clock domains/modules enabling
- SDRAM/DMM initialization
- Mux initialization
- MMC raw read support
- MMC FAT read support
- Code completely revamped
- DPLL programming that works for all SYS_CLK frequencies
- Automatic SDRAM identification and initialization
- Board dependent parts(especially mux) deferred to u-boot. So, same SPL will work for Panda and SDP and most likely on any other board that comes along
- Flexible about the payload. Any image with a mkimage header can be loaded.
- The core SPL logic is generic and available for OMAP3/4. So, OMAP3 platforms can easily extend this work to add SPL support for the respective boards.
V2:
- Some fixes in SDRAM init, clock init
- Use of pre-calculated M & N values for DPLL locking instead run-time calculation
- Change in make files to allow reuse of common rules between boards
- Console initialization moved further earlier in the boot allowing traces from even clock initialization code
- Reuse utility macros from a previous series
V3:
- Moved to the new SPL framework
- struct based register access for clock init
- Squashed together related patches as per Wolfgang's suggestions
- Re-organization of code in sdram init for better readability
- SPL loading the payload using mkimage header
- Avoided using custom bit-field accessor macros
- Several other minor changes(documented in respective patches)
V4:
- Rebased on u-boot-ti/master as on 21 Jul 2011
Pushed the series to u-boot-ti
http://git.denx.de/?p=u-boot/u-boot-ti.git;a=summary
Thanks, Sandeep
The basic hardware init of OMAP4(s_init()) can happen in 4 different contexts: 1. SPL running from SRAM 2. U-Boot running from FLASH 3. Non-XIP U-Boot loaded to SDRAM by SPL 4. Non-XIP U-Boot loaded to SDRAM by ROM code using the Configuration Header feature
What level of hw initialization gets done depends on this context. Add a utility function to find this context.
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Changed the context names to more meaningful names as suggested by WD --- arch/arm/include/asm/arch-omap4/sys_proto.h | 49 ++++++++++++++++++++++++++- arch/arm/include/asm/omap_common.h | 34 ++++++++++++++++++ 2 files changed, 82 insertions(+), 1 deletions(-) create mode 100644 arch/arm/include/asm/omap_common.h
diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 4fa4f4b..6b596b4 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -23,10 +23,12 @@
#include <asm/arch/omap4.h> #include <asm/io.h> +#include <asm/omap_common.h>
struct omap_sysinfo { char *board_string; }; +extern const struct omap_sysinfo sysinfo;
void gpmc_init(void); void watchdog_init(void); @@ -37,6 +39,51 @@ u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); void set_pl310_ctrl_reg(u32 val);
-extern const struct omap_sysinfo sysinfo; +static inline u32 running_from_sdram(void) +{ + u32 pc; + asm volatile ("mov %0, pc" : "=r" (pc)); + return ((pc >= OMAP44XX_DRAM_ADDR_SPACE_START) && + (pc < OMAP44XX_DRAM_ADDR_SPACE_END)); +} + +static inline u8 uboot_loaded_by_spl(void) +{ + /* + * Configuration Header is not supported yet, so u-boot init running + * from SDRAM implies that it was loaded by SPL. When this situation + * changes one of these approaches could be taken: + * i. Pass a magic from SPL to U-Boot and U-Boot save it at a known + * location. + * ii. Check the OPP. CH can support only 50% OPP while SPL initializes + * the DPLLs at 100% OPP. + */ + return running_from_sdram(); +} +/* + * The basic hardware init of OMAP(s_init()) can happen in 4 + * different contexts: + * 1. SPL running from SRAM + * 2. U-Boot running from FLASH + * 3. Non-XIP U-Boot loaded to SDRAM by SPL + * 4. Non-XIP U-Boot loaded to SDRAM by ROM code using the + * Configuration Header feature + * + * This function finds this context. + * Defining as inline may help in compiling out unused functions in SPL + */ +static inline u32 omap4_hw_init_context(void) +{ +#ifdef CONFIG_SPL_BUILD + return OMAP_INIT_CONTEXT_SPL; +#else + if (uboot_loaded_by_spl()) + return OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL; + else if (running_from_sdram()) + return OMAP_INIT_CONTEXT_UBOOT_AFTER_CH; + else + return OMAP_INIT_CONTEXT_UBOOT_FROM_NOR; +#endif +}
#endif diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h new file mode 100644 index 0000000..d80f665 --- /dev/null +++ b/arch/arm/include/asm/omap_common.h @@ -0,0 +1,34 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _OMAP_COMMON_H_ +#define _OMAP_COMMON_H_ + +/* HW Init Context */ +#define OMAP_INIT_CONTEXT_SPL 0 +#define OMAP_INIT_CONTEXT_UBOOT_FROM_NOR 1 +#define OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL 2 +#define OMAP_INIT_CONTEXT_UBOOT_AFTER_CH 3 + +#endif /* _OMAP_COMMON_H_ */
- separate mux settings into essential and non essential parts - essential part is board independent as of now(so move it to SoC directory). Will help in having single SPL for all boards. - Non-essential part(the pins not essential for u-boot to function) need to be phased out eventually. - Correct mux data by aligning to the latest settings in x-loader
Signed-off-by: Aneesh V aneesh@ti.com --- This patch add 33 warnings for lines over 80 characters. However, this for the mux table and improves readability.
V3: * Squashed two mux related patches into one --- arch/arm/cpu/armv7/omap4/board.c | 53 ++++++++- arch/arm/cpu/armv7/omap4/omap4_mux_data.h | 76 ++++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 4 +- board/ti/panda/panda.c | 25 +--- board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} | 76 +++--------- board/ti/sdp4430/sdp.c | 25 +--- .../{panda/panda.h => sdp4430/sdp4430_mux_data.h} | 128 +++++++------------ 7 files changed, 209 insertions(+), 178 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/omap4_mux_data.h rename board/ti/{sdp4430/sdp.h => panda/panda_mux_data.h} (76%) rename board/ti/{panda/panda.h => sdp4430/sdp4430_mux_data.h} (67%)
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index de4cc2a..3fd6f84 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -31,17 +31,65 @@ #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> +#include "omap4_mux_data.h"
+void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) +{ + int i; + struct pad_conf_entry *pad = (struct pad_conf_entry *) array; + + for (i = 0; i < size; i++, pad++) + writew(pad->val, base + pad->offset); +} + +static void set_muxconf_regs_essential(void) +{ + do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_essential, + sizeof(core_padconf_array_essential) / + sizeof(struct pad_conf_entry)); + + do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_essential, + sizeof(wkup_padconf_array_essential) / + sizeof(struct pad_conf_entry)); +} + +static void set_mux_conf_regs(void) +{ + switch (omap4_hw_init_context()) { + case OMAP_INIT_CONTEXT_SPL: + set_muxconf_regs_essential(); + break; + case OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL: + set_muxconf_regs_non_essential(); + break; + case OMAP_INIT_CONTEXT_UBOOT_FROM_NOR: + case OMAP_INIT_CONTEXT_UBOOT_AFTER_CH: + set_muxconf_regs_essential(); + set_muxconf_regs_non_essential(); + break; + } +} + /* * Routine: s_init - * Description: Does early system init of muxing and clocks. - * - Called path is with SRAM stack. + * Description: Does early system init of watchdog, muxing, andclocks + * Watchdog disable is done always. For the rest what gets done + * depends on the boot mode in which this function is executed + * 1. s_init of SPL running from SRAM + * 2. s_init of U-Boot running from FLASH + * 3. s_init of U-Boot loaded to SDRAM by SPL + * 4. s_init of U-Boot loaded to SDRAM by ROM code using the + * Configuration Header feature + * Please have a look at the respective functions to see what gets + * done in each of these cases + * This function is called with SRAM stack. */ void s_init(void) { watchdog_init(); + set_mux_conf_regs(); }
/* @@ -124,7 +172,6 @@ int checkboard(void) */ int arch_cpu_init(void) { - set_muxconf_regs(); return 0; }
diff --git a/arch/arm/cpu/armv7/omap4/omap4_mux_data.h b/arch/arm/cpu/armv7/omap4/omap4_mux_data.h new file mode 100644 index 0000000..00c52f8 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/omap4_mux_data.h @@ -0,0 +1,76 @@ + /* + * (C) Copyright 2010 + * Texas Instruments Incorporated, <www.ti.com> + * + * Balaji Krishnamoorthy balajitk@ti.com + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _OMAP4_MUX_DATA_H_ +#define _OMAP4_MUX_DATA_H_ + +#include <asm/arch/mux_omap4.h> + +const struct pad_conf_entry core_padconf_array_essential[] = { + +{GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ +{GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ +{GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ +{GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ +{GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ +{GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ +{GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ +{GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +{GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ +{GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ +{SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ +{SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ +{SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ +{SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ +{SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ +{SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ +{SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ +{SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ +{SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ +{SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ +{I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ +{I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ +{I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ +{I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ +{I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ +{I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ +{I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ +{I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ +{UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ +{UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ +{UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ +{UART3_TX_IRTX, (M0)} /* uart3_tx */ + +}; + +const struct pad_conf_entry wkup_padconf_array_essential[] = { + +{PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ +{PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ +{PAD1_SYS_32K, (IEN | M0)} /* sys_32k */ + +}; + +#endif /* _OMAP4_MUX_DATA_H_ */ diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 6b596b4..3624378 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -24,6 +24,7 @@ #include <asm/arch/omap4.h> #include <asm/io.h> #include <asm/omap_common.h> +#include <asm/arch/mux_omap4.h>
struct omap_sysinfo { char *board_string; @@ -33,7 +34,8 @@ extern const struct omap_sysinfo sysinfo; void gpmc_init(void); void watchdog_init(void); u32 get_device_type(void); -void set_muxconf_regs(void); +void do_set_mux(u32 base, struct pad_conf_entry const *array, int size); +void set_muxconf_regs_non_essential(void); void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c index 78e1910..9afed80 100644 --- a/board/ti/panda/panda.c +++ b/board/ti/panda/panda.c @@ -25,7 +25,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h>
-#include "panda.h" +#include "panda_mux_data.h"
@@ -65,27 +65,14 @@ int misc_init_r(void) return 0; }
-void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) +void set_muxconf_regs_non_essential(void) { - int i; - struct pad_conf_entry *pad = (struct pad_conf_entry *) array; - - for (i = 0; i < size; i++, pad++) - writew(pad->val, base + pad->offset); -} - -/** - * @brief set_muxconf_regs Setting up the configuration Mux registers - * specific to the board. - */ -void set_muxconf_regs(void) -{ - do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array, - sizeof(core_padconf_array) / + do_set_mux(CONTROL_PADCONF_CORE, core_padconf_array_non_essential, + sizeof(core_padconf_array_non_essential) / sizeof(struct pad_conf_entry));
- do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array, - sizeof(wkup_padconf_array) / + do_set_mux(CONTROL_PADCONF_WKUP, wkup_padconf_array_non_essential, + sizeof(wkup_padconf_array_non_essential) / sizeof(struct pad_conf_entry)); }
diff --git a/board/ti/sdp4430/sdp.h b/board/ti/panda/panda_mux_data.h similarity index 76% rename from board/ti/sdp4430/sdp.h rename to board/ti/panda/panda_mux_data.h index bf41067..16cc0ad 100644 --- a/board/ti/sdp4430/sdp.h +++ b/board/ti/panda/panda_mux_data.h @@ -23,22 +23,12 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ +#ifndef _SDP4430_MUX_DATA_H +#define _SDP4430_MUX_DATA_H
-#ifndef _SDP_H_ -#define _SDP_H_ - -#include <asm/io.h> #include <asm/arch/mux_omap4.h>
-const struct pad_conf_entry core_padconf_array[] = { - {GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ - {GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ - {GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ - {GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ - {GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ - {GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ - {GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ - {GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_AD8, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* gpio_32 */ {GPMC_AD9, (PTU | IEN | M3)}, /* gpio_33 */ {GPMC_AD10, (PTU | IEN | M3)}, /* gpio_34 */ @@ -64,8 +54,6 @@ const struct pad_conf_entry core_padconf_array[] = { {GPMC_NWP, (M3)}, /* gpio_54 */ {GPMC_CLK, (PTD | M3)}, /* gpio_55 */ {GPMC_NADV_ALE, (M3)}, /* gpio_56 */ - {GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ - {GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ @@ -96,14 +84,14 @@ const struct pad_conf_entry core_padconf_array[] = { {CAM_SHUTTER, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_shutter */ {CAM_STROBE, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_strobe */ {CAM_GLOBALRESET, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_83 */ - {USBB1_ULPITLL_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M4)},/* usbb1_ulpiphy_clk */ - {USBB1_ULPITLL_STP, (OFF_EN | OFF_OUT_PTD | M4)}, /* usbb1_ulpiphy_stp */ - {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dir */ - {USBB1_ULPITLL_NXT, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_nxt */ - {USBB1_ULPITLL_DAT0, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat0 */ - {USBB1_ULPITLL_DAT1, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat1 */ - {USBB1_ULPITLL_DAT2, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat2 */ - {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat3 */ + {USBB1_ULPITLL_CLK, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cawake */ + {USBB1_ULPITLL_STP, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cadata */ + {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caflag */ + {USBB1_ULPITLL_NXT, (OFF_EN | M1)}, /* hsi1_acready */ + {USBB1_ULPITLL_DAT0, (OFF_EN | M1)}, /* hsi1_acwake */ + {USBB1_ULPITLL_DAT1, (OFF_EN | M1)}, /* hsi1_acdata */ + {USBB1_ULPITLL_DAT2, (OFF_EN | M1)}, /* hsi1_acflag */ + {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caready */ {USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ {USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ {USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ @@ -112,22 +100,12 @@ const struct pad_conf_entry core_padconf_array[] = { {USBB1_HSIC_STROBE, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_strobe */ {USBC1_ICUSB_DP, (IEN | M0)}, /* usbc1_icusb_dp */ {USBC1_ICUSB_DM, (IEN | M0)}, /* usbc1_icusb_dm */ - {SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ - {SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ - {SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ - {SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ - {SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ - {SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ - {SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ - {SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ - {SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ - {SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ {ABE_MCBSP2_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_clkx */ {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ {ABE_MCBSP2_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_fsx */ - {ABE_MCBSP1_CLKX, (IEN | M1)}, /* abe_slimbus1_clock */ - {ABE_MCBSP1_DR, (IEN | M1)}, /* abe_slimbus1_data */ + {ABE_MCBSP1_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_clkx */ + {ABE_MCBSP1_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dr */ {ABE_MCBSP1_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dx */ {ABE_MCBSP1_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_fsx */ {ABE_PDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_ul_data */ @@ -144,14 +122,6 @@ const struct pad_conf_entry core_padconf_array[] = { {UART2_RX, (PTU | IEN | M0)}, /* uart2_rx */ {UART2_TX, (M0)}, /* uart2_tx */ {HDQ_SIO, (M3)}, /* gpio_127 */ - {I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ - {I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ - {I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ - {I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ - {I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ - {I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ - {I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ - {I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ {MCSPI1_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_clk */ {MCSPI1_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_somi */ {MCSPI1_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_simo */ @@ -159,10 +129,6 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI1_CS1, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* mcspi1_cs1 */ {MCSPI1_CS2, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_139 */ {MCSPI1_CS3, (PTU | IEN | M3)}, /* gpio_140 */ - {UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ - {UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ - {UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ - {UART3_TX_IRTX, (M0)}, /* uart3_tx */ {SDMMC5_CLK, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc5_clk */ {SDMMC5_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_cmd */ {SDMMC5_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat0 */ @@ -175,7 +141,7 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI4_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_cs0 */ {UART4_RX, (IEN | M0)}, /* uart4_rx */ {UART4_TX, (M0)}, /* uart4_tx */ - {USBB2_ULPITLL_CLK, (IEN | M3)}, /* gpio_157 */ + {USBB2_ULPITLL_CLK, (PTD | IEN | M3)}, /* gpio_157 */ {USBB2_ULPITLL_STP, (IEN | M5)}, /* dispc2_data23 */ {USBB2_ULPITLL_DIR, (IEN | M5)}, /* dispc2_data22 */ {USBB2_ULPITLL_NXT, (IEN | M5)}, /* dispc2_data21 */ @@ -207,11 +173,11 @@ const struct pad_conf_entry core_padconf_array[] = { {FREF_CLK1_OUT, (M0)}, /* fref_clk1_out */ {FREF_CLK2_OUT, (M0)}, /* fref_clk2_out */ {SYS_NIRQ1, (PTU | IEN | M0)}, /* sys_nirq1 */ - {SYS_NIRQ2, (PTU | IEN | M0)}, /* sys_nirq2 */ + {SYS_NIRQ2, (M7)}, /* sys_nirq2 */ {SYS_BOOT0, (PTU | IEN | M3)}, /* gpio_184 */ {SYS_BOOT1, (M3)}, /* gpio_185 */ {SYS_BOOT2, (PTD | IEN | M3)}, /* gpio_186 */ - {SYS_BOOT3, (M3)}, /* gpio_187 */ + {SYS_BOOT3, (PTD | IEN | M3)}, /* gpio_187 */ {SYS_BOOT4, (M3)}, /* gpio_188 */ {SYS_BOOT5, (PTD | IEN | M3)}, /* gpio_189 */ {DPM_EMU0, (IEN | M0)}, /* dpm_emu0 */ @@ -236,14 +202,12 @@ const struct pad_conf_entry core_padconf_array[] = { {DPM_EMU19, (IEN | M5)}, /* dispc2_data0 */ };
-const struct pad_conf_entry wkup_padconf_array[] = { +const struct pad_conf_entry wkup_padconf_array_non_essential[] = { {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ {PAD1_SIM_CLK, (M0)}, /* sim_clk */ {PAD0_SIM_RESET, (M0)}, /* sim_reset */ {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ - {PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ {PAD1_FREF_XTAL_IN, (M0)}, /* # */ {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ @@ -252,13 +216,15 @@ const struct pad_conf_entry wkup_padconf_array[] = { {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ {PAD1_FREF_CLK4_REQ, (PTU | IEN | M0)}, /* # */ {PAD0_FREF_CLK4_OUT, (M0)}, /* # */ - {PAD1_SYS_32K, (IEN | M0)}, /* sys_32k */ {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ + {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ + {PAD1_FREF_CLK4_REQ, (M3)}, /* gpio_wk7 */ + {PAD0_FREF_CLK4_OUT, (M3)}, /* gpio_wk8 */ };
-#endif +#endif /* _SDP4430_MUX_DATA_H */ diff --git a/board/ti/sdp4430/sdp.c b/board/ti/sdp4430/sdp.c index b13c4c5..a5ea682 100644 --- a/board/ti/sdp4430/sdp.c +++ b/board/ti/sdp4430/sdp.c @@ -27,7 +27,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h>
-#include "sdp.h" +#include "sdp4430_mux_data.h"
@@ -70,27 +70,14 @@ int misc_init_r(void) return 0; }
diff --git a/board/ti/panda/panda.h b/board/ti/sdp4430/sdp4430_mux_data.h similarity index 67% rename from board/ti/panda/panda.h rename to board/ti/sdp4430/sdp4430_mux_data.h index e3d090e..16cc0ad 100644 --- a/board/ti/panda/panda.h +++ b/board/ti/sdp4430/sdp4430_mux_data.h @@ -23,22 +23,12 @@ * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ +#ifndef _SDP4430_MUX_DATA_H +#define _SDP4430_MUX_DATA_H
-#ifndef _PANDA_H_ -#define _PANDA_H_ - -#include <asm/io.h> #include <asm/arch/mux_omap4.h>
-const struct pad_conf_entry core_padconf_array[] = { - {GPMC_AD0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat0 */ - {GPMC_AD1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat1 */ - {GPMC_AD2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat2 */ - {GPMC_AD3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat3 */ - {GPMC_AD4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat4 */ - {GPMC_AD5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat5 */ - {GPMC_AD6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat6 */ - {GPMC_AD7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_dat7 */ +const struct pad_conf_entry core_padconf_array_non_essential[] = { {GPMC_AD8, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* gpio_32 */ {GPMC_AD9, (PTU | IEN | M3)}, /* gpio_33 */ {GPMC_AD10, (PTU | IEN | M3)}, /* gpio_34 */ @@ -53,7 +43,7 @@ const struct pad_conf_entry core_padconf_array[] = { {GPMC_A19, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row7 */ {GPMC_A20, (IEN | M3)}, /* gpio_44 */ {GPMC_A21, (M3)}, /* gpio_45 */ - {GPMC_A22, (M3)}, /* gpio_46 */ + {GPMC_A22, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col6 */ {GPMC_A23, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col7 */ {GPMC_A24, (PTD | M3)}, /* gpio_48 */ {GPMC_A25, (PTD | M3)}, /* gpio_49 */ @@ -64,14 +54,12 @@ const struct pad_conf_entry core_padconf_array[] = { {GPMC_NWP, (M3)}, /* gpio_54 */ {GPMC_CLK, (PTD | M3)}, /* gpio_55 */ {GPMC_NADV_ALE, (M3)}, /* gpio_56 */ - {GPMC_NOE, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M1)}, /* sdmmc2_clk */ - {GPMC_NWE, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* sdmmc2_cmd */ {GPMC_NBE0_CLE, (M3)}, /* gpio_59 */ {GPMC_NBE1, (PTD | M3)}, /* gpio_60 */ {GPMC_WAIT0, (PTU | IEN | M3)}, /* gpio_61 */ - {GPMC_WAIT1, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_62 */ + {GPMC_WAIT1, (IEN | M3)}, /* gpio_62 */ {C2C_DATA11, (PTD | M3)}, /* gpio_100 */ - {C2C_DATA12, (PTU | IEN | M3)}, /* gpio_101 */ + {C2C_DATA12, (M1)}, /* dsi1_te0 */ {C2C_DATA13, (PTD | M3)}, /* gpio_102 */ {C2C_DATA14, (M1)}, /* dsi2_te0 */ {C2C_DATA15, (PTD | M3)}, /* gpio_104 */ @@ -96,14 +84,14 @@ const struct pad_conf_entry core_padconf_array[] = { {CAM_SHUTTER, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_shutter */ {CAM_STROBE, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_strobe */ {CAM_GLOBALRESET, (PTD | OFF_EN | OFF_PD | OFF_OUT_PTD | M3)}, /* gpio_83 */ - {USBB1_ULPITLL_CLK, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M4)},/* usbb1_ulpiphy_clk */ - {USBB1_ULPITLL_STP, (OFF_EN | OFF_OUT_PTD | M4)}, /* usbb1_ulpiphy_stp */ - {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dir */ - {USBB1_ULPITLL_NXT, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_nxt */ - {USBB1_ULPITLL_DAT0, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat0 */ - {USBB1_ULPITLL_DAT1, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat1 */ - {USBB1_ULPITLL_DAT2, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat2 */ - {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat3 */ + {USBB1_ULPITLL_CLK, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cawake */ + {USBB1_ULPITLL_STP, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cadata */ + {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caflag */ + {USBB1_ULPITLL_NXT, (OFF_EN | M1)}, /* hsi1_acready */ + {USBB1_ULPITLL_DAT0, (OFF_EN | M1)}, /* hsi1_acwake */ + {USBB1_ULPITLL_DAT1, (OFF_EN | M1)}, /* hsi1_acdata */ + {USBB1_ULPITLL_DAT2, (OFF_EN | M1)}, /* hsi1_acflag */ + {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caready */ {USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ {USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ {USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ @@ -112,22 +100,12 @@ const struct pad_conf_entry core_padconf_array[] = { {USBB1_HSIC_STROBE, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usbb1_hsic_strobe */ {USBC1_ICUSB_DP, (IEN | M0)}, /* usbc1_icusb_dp */ {USBC1_ICUSB_DM, (IEN | M0)}, /* usbc1_icusb_dm */ - {SDMMC1_CLK, (PTU | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc1_clk */ - {SDMMC1_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_cmd */ - {SDMMC1_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat0 */ - {SDMMC1_DAT1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat1 */ - {SDMMC1_DAT2, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat2 */ - {SDMMC1_DAT3, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat3 */ - {SDMMC1_DAT4, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat4 */ - {SDMMC1_DAT5, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat5 */ - {SDMMC1_DAT6, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat6 */ - {SDMMC1_DAT7, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc1_dat7 */ {ABE_MCBSP2_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_clkx */ {ABE_MCBSP2_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dr */ {ABE_MCBSP2_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp2_dx */ {ABE_MCBSP2_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp2_fsx */ - {ABE_MCBSP1_CLKX, (IEN | M1)}, /* abe_slimbus1_clock */ - {ABE_MCBSP1_DR, (IEN | M1)}, /* abe_slimbus1_data */ + {ABE_MCBSP1_CLKX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_clkx */ + {ABE_MCBSP1_DR, (IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dr */ {ABE_MCBSP1_DX, (OFF_EN | OFF_OUT_PTD | M0)}, /* abe_mcbsp1_dx */ {ABE_MCBSP1_FSX, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_mcbsp1_fsx */ {ABE_PDM_UL_DATA, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* abe_pdm_ul_data */ @@ -144,14 +122,6 @@ const struct pad_conf_entry core_padconf_array[] = { {UART2_RX, (PTU | IEN | M0)}, /* uart2_rx */ {UART2_TX, (M0)}, /* uart2_tx */ {HDQ_SIO, (M3)}, /* gpio_127 */ - {I2C1_SCL, (PTU | IEN | M0)}, /* i2c1_scl */ - {I2C1_SDA, (PTU | IEN | M0)}, /* i2c1_sda */ - {I2C2_SCL, (PTU | IEN | M0)}, /* i2c2_scl */ - {I2C2_SDA, (PTU | IEN | M0)}, /* i2c2_sda */ - {I2C3_SCL, (PTU | IEN | M0)}, /* i2c3_scl */ - {I2C3_SDA, (PTU | IEN | M0)}, /* i2c3_sda */ - {I2C4_SCL, (PTU | IEN | M0)}, /* i2c4_scl */ - {I2C4_SDA, (PTU | IEN | M0)}, /* i2c4_sda */ {MCSPI1_CLK, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_clk */ {MCSPI1_SOMI, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_somi */ {MCSPI1_SIMO, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi1_simo */ @@ -159,10 +129,6 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI1_CS1, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M3)}, /* mcspi1_cs1 */ {MCSPI1_CS2, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_139 */ {MCSPI1_CS3, (PTU | IEN | M3)}, /* gpio_140 */ - {UART3_CTS_RCTX, (PTU | IEN | M0)}, /* uart3_tx */ - {UART3_RTS_SD, (M0)}, /* uart3_rts_sd */ - {UART3_RX_IRRX, (IEN | M0)}, /* uart3_rx */ - {UART3_TX_IRTX, (M0)}, /* uart3_tx */ {SDMMC5_CLK, (PTU | IEN | OFF_EN | OFF_OUT_PTD | M0)}, /* sdmmc5_clk */ {SDMMC5_CMD, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_cmd */ {SDMMC5_DAT0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* sdmmc5_dat0 */ @@ -175,7 +141,7 @@ const struct pad_conf_entry core_padconf_array[] = { {MCSPI4_CS0, (PTD | IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* mcspi4_cs0 */ {UART4_RX, (IEN | M0)}, /* uart4_rx */ {UART4_TX, (M0)}, /* uart4_tx */ - {USBB2_ULPITLL_CLK, (IEN | M3)}, /* gpio_157 */ + {USBB2_ULPITLL_CLK, (PTD | IEN | M3)}, /* gpio_157 */ {USBB2_ULPITLL_STP, (IEN | M5)}, /* dispc2_data23 */ {USBB2_ULPITLL_DIR, (IEN | M5)}, /* dispc2_data22 */ {USBB2_ULPITLL_NXT, (IEN | M5)}, /* dispc2_data21 */ @@ -189,12 +155,12 @@ const struct pad_conf_entry core_padconf_array[] = { {USBB2_ULPITLL_DAT7, (IEN | M5)}, /* dispc2_data11 */ {USBB2_HSIC_DATA, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_169 */ {USBB2_HSIC_STROBE, (PTD | OFF_EN | OFF_OUT_PTU | M3)}, /* gpio_170 */ - {UNIPRO_TX0, (PTD | IEN | M3)}, /* gpio_171 */ + {UNIPRO_TX0, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col0 */ {UNIPRO_TY0, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col1 */ {UNIPRO_TX1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col2 */ {UNIPRO_TY1, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col3 */ - {UNIPRO_TX2, (PTU | IEN | M3)}, /* gpio_0 */ - {UNIPRO_TY2, (PTU | IEN | M3)}, /* gpio_1 */ + {UNIPRO_TX2, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col4 */ + {UNIPRO_TY2, (OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_col5 */ {UNIPRO_RX0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row0 */ {UNIPRO_RY0, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row1 */ {UNIPRO_RX1, (PTU | IEN | OFF_EN | OFF_PD | OFF_IN | M1)}, /* kpd_row2 */ @@ -205,13 +171,13 @@ const struct pad_conf_entry core_padconf_array[] = { {USBA0_OTG_DP, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dp */ {USBA0_OTG_DM, (IEN | OFF_EN | OFF_PD | OFF_IN | M0)}, /* usba0_otg_dm */ {FREF_CLK1_OUT, (M0)}, /* fref_clk1_out */ - {FREF_CLK2_OUT, (PTU | IEN | M3)}, /* gpio_182 */ + {FREF_CLK2_OUT, (M0)}, /* fref_clk2_out */ {SYS_NIRQ1, (PTU | IEN | M0)}, /* sys_nirq1 */ - {SYS_NIRQ2, (PTU | IEN | M0)}, /* sys_nirq2 */ + {SYS_NIRQ2, (M7)}, /* sys_nirq2 */ {SYS_BOOT0, (PTU | IEN | M3)}, /* gpio_184 */ {SYS_BOOT1, (M3)}, /* gpio_185 */ {SYS_BOOT2, (PTD | IEN | M3)}, /* gpio_186 */ - {SYS_BOOT3, (M3)}, /* gpio_187 */ + {SYS_BOOT3, (PTD | IEN | M3)}, /* gpio_187 */ {SYS_BOOT4, (M3)}, /* gpio_188 */ {SYS_BOOT5, (PTD | IEN | M3)}, /* gpio_189 */ {DPM_EMU0, (IEN | M0)}, /* dpm_emu0 */ @@ -236,29 +202,29 @@ const struct pad_conf_entry core_padconf_array[] = { {DPM_EMU19, (IEN | M5)}, /* dispc2_data0 */ };
-const struct pad_conf_entry wkup_padconf_array[] = { - {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ - {PAD1_SIM_CLK, (M0)}, /* sim_clk */ - {PAD0_SIM_RESET, (M0)}, /* sim_reset */ - {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ - {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ - {PAD1_SR_SCL, (PTU | IEN | M0)}, /* sr_scl */ - {PAD0_SR_SDA, (PTU | IEN | M0)}, /* sr_sda */ - {PAD1_FREF_XTAL_IN, (M0)}, /* # */ - {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ - {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ - {PAD0_FREF_CLK0_OUT, (M2)}, /* sys_drm_msecure */ - {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ - {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ - {PAD1_FREF_CLK4_REQ, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_1 */ - {PAD0_FREF_CLK4_OUT, (PTU | OFF_EN | OFF_OUT_PTU | M3)}, /* led status_2 */ - {PAD1_SYS_32K, (IEN | M0)}, /* sys_32k */ - {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ - {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ - {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ - {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ - {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ - {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ +const struct pad_conf_entry wkup_padconf_array_non_essential[] = { + {PAD0_SIM_IO, (IEN | M0)}, /* sim_io */ + {PAD1_SIM_CLK, (M0)}, /* sim_clk */ + {PAD0_SIM_RESET, (M0)}, /* sim_reset */ + {PAD1_SIM_CD, (PTU | IEN | M0)}, /* sim_cd */ + {PAD0_SIM_PWRCTRL, (M0)}, /* sim_pwrctrl */ + {PAD1_FREF_XTAL_IN, (M0)}, /* # */ + {PAD0_FREF_SLICER_IN, (M0)}, /* fref_slicer_in */ + {PAD1_FREF_CLK_IOREQ, (M0)}, /* fref_clk_ioreq */ + {PAD0_FREF_CLK0_OUT, (M2)}, /* sys_drm_msecure */ + {PAD1_FREF_CLK3_REQ, (PTU | IEN | M0)}, /* # */ + {PAD0_FREF_CLK3_OUT, (M0)}, /* fref_clk3_out */ + {PAD1_FREF_CLK4_REQ, (PTU | IEN | M0)}, /* # */ + {PAD0_FREF_CLK4_OUT, (M0)}, /* # */ + {PAD0_SYS_NRESPWRON, (M0)}, /* sys_nrespwron */ + {PAD1_SYS_NRESWARM, (M0)}, /* sys_nreswarm */ + {PAD0_SYS_PWR_REQ, (PTU | M0)}, /* sys_pwr_req */ + {PAD1_SYS_PWRON_RESET, (M3)}, /* gpio_wk29 */ + {PAD0_SYS_BOOT6, (IEN | M3)}, /* gpio_wk9 */ + {PAD1_SYS_BOOT7, (IEN | M3)}, /* gpio_wk10 */ + {PAD1_FREF_CLK3_REQ, (M3)}, /* gpio_wk30 */ + {PAD1_FREF_CLK4_REQ, (M3)}, /* gpio_wk7 */ + {PAD0_FREF_CLK4_OUT, (M3)}, /* gpio_wk8 */ };
Dear Aneesh V,
- {USBB1_ULPITLL_CLK, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cawake */
- {USBB1_ULPITLL_STP, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_cadata */
- {USBB1_ULPITLL_DIR, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caflag */
- {USBB1_ULPITLL_NXT, (OFF_EN | M1)}, /* hsi1_acready */
- {USBB1_ULPITLL_DAT0, (OFF_EN | M1)}, /* hsi1_acwake */
- {USBB1_ULPITLL_DAT1, (OFF_EN | M1)}, /* hsi1_acdata */
- {USBB1_ULPITLL_DAT2, (OFF_EN | M1)}, /* hsi1_acflag */
- {USBB1_ULPITLL_DAT3, (IEN | OFF_EN | OFF_IN | M1)}, /* hsi1_caready */
Lines too long, please fix globally.
Dear Wolfgang,
On Friday 29 July 2011 12:56 AM, Wolfgang Denk wrote:
Dear Aneesh V,
This table looks better and readable if each row is a single line. I had mentioned this in the commit log. Does it make sense to make an exception for this?
Dear Aneesh V,
In message 4E32722C.6020707@ti.com you wrote:
Dear Wolfgang,
Dear Aneesh V,
I agree that it does not make sense to split the lines.
But it seems there is potential to reduce the line length: in may cases, you can just reduce the indentation of the comments.
In many other places the commets are just useless and should be omitted. See for example the (old, existing) lines:
{CAM_SHUTTER, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_shutter */ {CAM_STROBE, (OFF_EN | OFF_PD | OFF_OUT_PTD | M0)}, /* cam_strobe */ ... {USBB1_ULPITLL_DAT4, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat4 */ {USBB1_ULPITLL_DAT5, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat5 */ {USBB1_ULPITLL_DAT6, (IEN | OFF_EN | OFF_PD | OFF_IN | M4)}, /* usbb1_ulpiphy_dat6 */ ... etc.
A comment that just repeats the content of the first argument without any additional information carries zero information and should just be removed.
Dear Wolfgang,
On Friday 29 July 2011 02:26 PM, Wolfgang Denk wrote:
Dear Aneesh V,
In message4E32722C.6020707@ti.com you wrote:
Dear Wolfgang,
Dear Aneesh V,
Yes, for some lines there is potential to reduce the length. But I just aligned the comments vertically for the entire table since more than half of the rows were anyway overflowing.
The two are actually not same. The first column indicates the register name. The documented name specifies the function selected which depends on the last column, the mode(M0, M4 etc). The name of the register happens to be the function selected by M0. So, in those cases, what you said is correct. But IMHO, it's better to document the function selected even in those cases, because when somebody changes the mode here or for a new board, he/she is not likely to update the comment if it is already absent.
For the above please note that first column and comments are indeed different. Please note the difference between ULPI'TLL'_DATA4 and ulpi'phy'_data4.
My patch is already in u-boot-arm. If I have to rework this patch should I create a new patch to fix the problem or should I re-work the original patch?
best regards, Aneesh
Dear Aneesh V,
It's not worth fighting about this. Please feel free to leave as is.
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Added a revision string in addition to the revision number Helps in printing out the OMAP revision at bootup
V3: * Improved the revision check function by saving the value instead of finding it every time. * Improved revision string function by generating it from the revision rather than hard-coding the string per revision --- arch/arm/cpu/armv7/omap4/board.c | 64 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 29 +++++++++--- arch/arm/include/asm/arch-omap4/sys_proto.h | 7 +++ arch/arm/include/asm/armv7.h | 5 ++ 4 files changed, 97 insertions(+), 8 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 3fd6f84..09861a9 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -28,6 +28,7 @@ * MA 02111-1307 USA */ #include <common.h> +#include <asm/armv7.h> #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> @@ -35,6 +36,8 @@
DECLARE_GLOBAL_DATA_PTR;
+u32 *const omap4_revision = (u32 *)OMAP4_SRAM_SCRATCH_OMAP4_REV; + void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) { int i; @@ -72,6 +75,66 @@ static void set_mux_conf_regs(void) } }
+static u32 cortex_a9_rev(void) +{ + + unsigned int rev; + + /* Read Main ID Register (MIDR) */ + asm ("mrc p15, 0, %0, c0, c0, 0" : "=r" (rev)); + + return rev; +} + +static void init_omap4_revision(void) +{ + /* + * For some of the ES2/ES1 boards ID_CODE is not reliable: + * Also, ES1 and ES2 have different ARM revisions + * So use ARM revision for identification + */ + unsigned int arm_rev = cortex_a9_rev(); + + switch (arm_rev) { + case MIDR_CORTEX_A9_R0P1: + *omap4_revision = OMAP4430_ES1_0; + break; + case MIDR_CORTEX_A9_R1P2: + switch (readl(CONTROL_ID_CODE)) { + case OMAP4_CONTROL_ID_CODE_ES2_0: + *omap4_revision = OMAP4430_ES2_0; + break; + case OMAP4_CONTROL_ID_CODE_ES2_1: + *omap4_revision = OMAP4430_ES2_1; + break; + case OMAP4_CONTROL_ID_CODE_ES2_2: + *omap4_revision = OMAP4430_ES2_2; + break; + default: + *omap4_revision = OMAP4430_ES2_0; + break; + } + break; + case MIDR_CORTEX_A9_R1P3: + *omap4_revision = OMAP4430_ES2_3; + break; + default: + *omap4_revision = OMAP4430_SILICON_ID_INVALID; + break; + } +} + +void omap_rev_string(char *omap4_rev_string) +{ + u32 omap4_rev = omap_revision(); + u32 omap4_variant = (omap4_rev & 0xFFFF0000) >> 16; + u32 major_rev = (omap4_rev & 0x00000F00) >> 8; + u32 minor_rev = (omap4_rev & 0x000000F0) >> 4; + + sprintf(omap4_rev_string, "OMAP%x ES%x.%x", omap4_variant, major_rev, + minor_rev); +} + /* * Routine: s_init * Description: Does early system init of watchdog, muxing, andclocks @@ -88,6 +151,7 @@ static void set_mux_conf_regs(void) */ void s_init(void) { + init_omap4_revision(); watchdog_init(); set_mux_conf_regs(); } diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index a30bb33..76b06c2 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -51,6 +51,15 @@ #define CONTROL_PADCONF_CORE (OMAP44XX_L4_CORE_BASE + 0x100000) #define CONTROL_PADCONF_WKUP (OMAP44XX_L4_CORE_BASE + 0x31E000)
+/* CONTROL_ID_CODE */ +#define CONTROL_ID_CODE 0x4A002204 + +#define OMAP4_CONTROL_ID_CODE_ES1_0 0x0B85202F +#define OMAP4_CONTROL_ID_CODE_ES2_0 0x1B85202F +#define OMAP4_CONTROL_ID_CODE_ES2_1 0x3B95C02F +#define OMAP4_CONTROL_ID_CODE_ES2_2 0x4B95C02F +#define OMAP4_CONTROL_ID_CODE_ES2_3 0x6B95C02F + /* UART */ #define UART1_BASE (OMAP44XX_L4_PER_BASE + 0x6a000) #define UART2_BASE (OMAP44XX_L4_PER_BASE + 0x6c000) @@ -119,13 +128,17 @@ struct s32ktimer { /* base address for indirect vectors (internal boot mode) */ #define SRAM_ROM_VECT_BASE 0x4030D000 /* Temporary SRAM stack used while low level init is done */ -#define LOW_LEVEL_SRAM_STACK NON_SECURE_SRAM_END - -/* - * OMAP4 real hardware: - * TODO: Change this to the IDCODE in the hw regsiter - */ -#define CPU_OMAP4430_ES10 1 -#define CPU_OMAP4430_ES20 2 +#define LOW_LEVEL_SRAM_STACK NON_SECURE_SRAM_END +#define SRAM_SCRATCH_SPACE_ADDR NON_SECURE_SRAM_START +/* SRAM scratch space entries */ +#define OMAP4_SRAM_SCRATCH_OMAP4_REV SRAM_SCRATCH_SPACE_ADDR + +/* Silicon revisions */ +#define OMAP4430_SILICON_ID_INVALID 0xFFFFFFFF +#define OMAP4430_ES1_0 0x44300100 +#define OMAP4430_ES2_0 0x44300200 +#define OMAP4430_ES2_1 0x44300210 +#define OMAP4430_ES2_2 0x44300220 +#define OMAP4430_ES2_3 0x44300230
#endif diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 3624378..c10fa18 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -40,6 +40,7 @@ void sr32(void *, u32, u32, u32); u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); void set_pl310_ctrl_reg(u32 val); +void omap_rev_string(char *omap4_rev_string);
static inline u32 running_from_sdram(void) { @@ -88,4 +89,10 @@ static inline u32 omap4_hw_init_context(void) #endif }
+static inline u32 omap_revision(void) +{ + extern u32 *const omap4_revision; + return *omap4_revision; +} + #endif diff --git a/arch/arm/include/asm/armv7.h b/arch/arm/include/asm/armv7.h index 88b9c62..b5784d8 100644 --- a/arch/arm/include/asm/armv7.h +++ b/arch/arm/include/asm/armv7.h @@ -25,6 +25,11 @@ #define ARMV7_H #include <linux/types.h>
+/* Cortex-A9 revisions */ +#define MIDR_CORTEX_A9_R0P1 0x410FC091 +#define MIDR_CORTEX_A9_R1P2 0x411FC092 +#define MIDR_CORTEX_A9_R1P3 0x411FC093 + /* CCSIDR */ #define CCSIDR_LINE_SIZE_OFFSET 0 #define CCSIDR_LINE_SIZE_MASK 0x7
Add support for: 1. DPLL locking 2. Initialization of clock domains and clock modules 3. Setting up the right voltage on voltage rails
This work draws upon previous work done for x-loader by: Santosh Shilimkar santosh.shilimkar@ti.com Rajendra Nayak rnayak@ti.com
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Use pre-calculated M & N values instead of calculated ones * Changes due to make file changes * Some corrections * Do all clock initialization in SPL itself instead of differing some work to u-boot
V3: * Use struct for register addressing * Support only Turbo OPP for MPU. OPP's above this need Smart Reflex enabled * Cleaned up the scale_vcore(). Now takes into account the differing voltage offsets for different revisions of Phoenix. * Removed references to deprecated utility functions - modify_reg_32() etc. * Changed all spl_debug() to debug() * Moved the host-program for calculating DPLL multiplier/divider to tools/omap/ directory. Added more documentation * Replaced calls to omap4_revision() with omap_revision() * Some changes to IVA and ABE dpll locking code --- arch/arm/cpu/armv7/omap4/Makefile | 1 + arch/arm/cpu/armv7/omap4/board.c | 1 + arch/arm/cpu/armv7/omap4/clocks.c | 809 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/clocks.h | 664 ++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 8 + arch/arm/include/asm/omap_common.h | 3 + tools/omap/clocks_get_m_n.c | 197 +++++++ 7 files changed, 1683 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/clocks.c create mode 100644 arch/arm/include/asm/arch-omap4/clocks.h create mode 100644 tools/omap/clocks_get_m_n.c
diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index 987dc9d..ac4b2a6 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -28,6 +28,7 @@ LIB = $(obj)lib$(SOC).o SOBJS += lowlevel_init.o
COBJS += board.o +COBJS += clocks.o COBJS += mem.o COBJS += sys_info.o
diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 09861a9..1c26a66 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -154,6 +154,7 @@ void s_init(void) init_omap4_revision(); watchdog_init(); set_mux_conf_regs(); + prcm_init(); }
/* diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c new file mode 100644 index 0000000..e8d3a52 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/clocks.c @@ -0,0 +1,809 @@ +/* + * + * Clock initialization for OMAP4 + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * Based on previous work by: + * Santosh Shilimkar santosh.shilimkar@ti.com + * Rajendra Nayak rnayak@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/omap_common.h> +#include <asm/arch/clocks.h> +#include <asm/arch/sys_proto.h> +#include <asm/utils.h> + +#ifndef CONFIG_SPL_BUILD +/* + * printing to console doesn't work unless + * this code is executed from SPL + */ +#define printf(fmt, args...) +#define puts(s) +#endif + +#define abs(x) (((x) < 0) ? ((x)*-1) : (x)) + +struct omap4_prcm_regs *const prcm = (struct omap4_prcm_regs *)0x4A004100; + +static const u32 sys_clk_array[8] = { + 12000000, /* 12 MHz */ + 13000000, /* 13 MHz */ + 16800000, /* 16.8 MHz */ + 19200000, /* 19.2 MHz */ + 26000000, /* 26 MHz */ + 27000000, /* 27 MHz */ + 38400000, /* 38.4 MHz */ +}; + +/* + * The M & N values in the following tables are created using the + * following tool: + * tools/omap/clocks_get_m_n.c + * Please use this tool for creating the table for any new frequency. + */ + +/* dpll locked at 1584 MHz - MPU clk at 792 MHz(OPP Turbo) */ +static const struct dpll_params mpu_dpll_params_1584mhz[NUM_SYS_CLKS] = { + {66, 0, 1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {792, 12, 1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {330, 6, 1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {165, 3, 1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {396, 12, 1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {88, 2, 1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {165, 7, 1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +/* dpll locked at 1200 MHz - MPU clk at 600 MHz */ +static const struct dpll_params mpu_dpll_params_1200mhz[NUM_SYS_CLKS] = { + {50, 0, 1, -1, -1, -1, -1, -1}, /* 12 MHz */ + {600, 12, 1, -1, -1, -1, -1, -1}, /* 13 MHz */ + {250, 6, 1, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {125, 3, 1, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {300, 12, 1, -1, -1, -1, -1, -1}, /* 26 MHz */ + {200, 8, 1, -1, -1, -1, -1, -1}, /* 27 MHz */ + {125, 7, 1, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static const struct dpll_params core_dpll_params_1600mhz[NUM_SYS_CLKS] = { + {200, 2, 1, 5, 8, 4, 6, 5}, /* 12 MHz */ + {800, 12, 1, 5, 8, 4, 6, 5}, /* 13 MHz */ + {619, 12, 1, 5, 8, 4, 6, 5}, /* 16.8 MHz */ + {125, 2, 1, 5, 8, 4, 6, 5}, /* 19.2 MHz */ + {400, 12, 1, 5, 8, 4, 6, 5}, /* 26 MHz */ + {800, 26, 1, 5, 8, 4, 6, 5}, /* 27 MHz */ + {125, 5, 1, 5, 8, 4, 6, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params core_dpll_params_es1_1524mhz[NUM_SYS_CLKS] = { + {127, 1, 1, 5, 8, 4, 6, 5}, /* 12 MHz */ + {762, 12, 1, 5, 8, 4, 6, 5}, /* 13 MHz */ + {635, 13, 1, 5, 8, 4, 6, 5}, /* 16.8 MHz */ + {635, 15, 1, 5, 8, 4, 6, 5}, /* 19.2 MHz */ + {381, 12, 1, 5, 8, 4, 6, 5}, /* 26 MHz */ + {254, 8, 1, 5, 8, 4, 6, 5}, /* 27 MHz */ + {496, 24, 1, 5, 8, 4, 6, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params + core_dpll_params_es2_1600mhz_ddr200mhz[NUM_SYS_CLKS] = { + {200, 2, 2, 5, 8, 4, 6, 5}, /* 12 MHz */ + {800, 12, 2, 5, 8, 4, 6, 5}, /* 13 MHz */ + {619, 12, 2, 5, 8, 4, 6, 5}, /* 16.8 MHz */ + {125, 2, 2, 5, 8, 4, 6, 5}, /* 19.2 MHz */ + {400, 12, 2, 5, 8, 4, 6, 5}, /* 26 MHz */ + {800, 26, 2, 5, 8, 4, 6, 5}, /* 27 MHz */ + {125, 5, 2, 5, 8, 4, 6, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params per_dpll_params_1536mhz[NUM_SYS_CLKS] = { + {64, 0, 8, 6, 12, 9, 4, 5}, /* 12 MHz */ + {768, 12, 8, 6, 12, 9, 4, 5}, /* 13 MHz */ + {320, 6, 8, 6, 12, 9, 4, 5}, /* 16.8 MHz */ + {40, 0, 8, 6, 12, 9, 4, 5}, /* 19.2 MHz */ + {384, 12, 8, 6, 12, 9, 4, 5}, /* 26 MHz */ + {256, 8, 8, 6, 12, 9, 4, 5}, /* 27 MHz */ + {20, 0, 8, 6, 12, 9, 4, 5} /* 38.4 MHz */ +}; + +static const struct dpll_params iva_dpll_params_1862mhz[NUM_SYS_CLKS] = { + {931, 11, -1, -1, 4, 7, -1, -1}, /* 12 MHz */ + {931, 12, -1, -1, 4, 7, -1, -1}, /* 13 MHz */ + {665, 11, -1, -1, 4, 7, -1, -1}, /* 16.8 MHz */ + {727, 14, -1, -1, 4, 7, -1, -1}, /* 19.2 MHz */ + {931, 25, -1, -1, 4, 7, -1, -1}, /* 26 MHz */ + {931, 26, -1, -1, 4, 7, -1, -1}, /* 27 MHz */ + {412, 16, -1, -1, 4, 7, -1, -1} /* 38.4 MHz */ +}; + +/* ABE M & N values with sys_clk as source */ +static const struct dpll_params + abe_dpll_params_sysclk_196608khz[NUM_SYS_CLKS] = { + {49, 5, 1, 1, -1, -1, -1, -1}, /* 12 MHz */ + {68, 8, 1, 1, -1, -1, -1, -1}, /* 13 MHz */ + {35, 5, 1, 1, -1, -1, -1, -1}, /* 16.8 MHz */ + {46, 8, 1, 1, -1, -1, -1, -1}, /* 19.2 MHz */ + {34, 8, 1, 1, -1, -1, -1, -1}, /* 26 MHz */ + {29, 7, 1, 1, -1, -1, -1, -1}, /* 27 MHz */ + {64, 24, 1, 1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +/* ABE M & N values with 32K clock as source */ +static const struct dpll_params abe_dpll_params_32k_196608khz = { + 750, 0, 1, 1, -1, -1, -1, -1 +}; + + +static const struct dpll_params usb_dpll_params_1920mhz[NUM_SYS_CLKS] = { + {80, 0, 2, -1, -1, -1, -1, -1}, /* 12 MHz */ + {960, 12, 2, -1, -1, -1, -1, -1}, /* 13 MHz */ + {400, 6, 2, -1, -1, -1, -1, -1}, /* 16.8 MHz */ + {50, 0, 2, -1, -1, -1, -1, -1}, /* 19.2 MHz */ + {480, 12, 2, -1, -1, -1, -1, -1}, /* 26 MHz */ + {320, 8, 2, -1, -1, -1, -1, -1}, /* 27 MHz */ + {25, 0, 2, -1, -1, -1, -1, -1} /* 38.4 MHz */ +}; + +static inline u32 __get_sys_clk_index(void) +{ + u32 ind; + /* + * For ES1 the ROM code calibration of sys clock is not reliable + * due to hw issue. So, use hard-coded value. If this value is not + * correct for any board over-ride this function in board file + * From ES2.0 onwards you will get this information from + * CM_SYS_CLKSEL + */ + if (omap_revision() == OMAP4430_ES1_0) + ind = OMAP_SYS_CLK_IND_38_4_MHZ; + else { + /* SYS_CLKSEL - 1 to match the dpll param array indices */ + ind = (readl(&prcm->cm_sys_clksel) & + CM_SYS_CLKSEL_SYS_CLKSEL_MASK) - 1; + } + return ind; +} + +u32 get_sys_clk_index(void) + __attribute__ ((weak, alias("__get_sys_clk_index"))); + +u32 get_sys_clk_freq(void) +{ + u8 index = get_sys_clk_index(); + return sys_clk_array[index]; +} + +static inline void do_bypass_dpll(u32 *const base) +{ + struct dpll_regs *dpll_regs = (struct dpll_regs *)base; + + clrsetbits_le32(&dpll_regs->cm_clkmode_dpll, + CM_CLKMODE_DPLL_DPLL_EN_MASK, + DPLL_EN_FAST_RELOCK_BYPASS << + CM_CLKMODE_DPLL_EN_SHIFT); +} + +static inline void wait_for_bypass(u32 *const base) +{ + struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; + + if (!wait_on_value(ST_DPLL_CLK_MASK, 0, &dpll_regs->cm_idlest_dpll, + LDELAY)) { + printf("Bypassing DPLL failed %p\n", base); + } +} + +static inline void do_lock_dpll(u32 *const base) +{ + struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; + + clrsetbits_le32(&dpll_regs->cm_clkmode_dpll, + CM_CLKMODE_DPLL_DPLL_EN_MASK, + DPLL_EN_LOCK << CM_CLKMODE_DPLL_EN_SHIFT); +} + +static inline void wait_for_lock(u32 *const base) +{ + struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; + + if (!wait_on_value(ST_DPLL_CLK_MASK, ST_DPLL_CLK_MASK, + &dpll_regs->cm_idlest_dpll, LDELAY)) { + printf("DPLL locking failed for %p\n", base); + hang(); + } +} + +static void do_setup_dpll(u32 *const base, const struct dpll_params *params, + u8 lock) +{ + u32 temp; + struct dpll_regs *const dpll_regs = (struct dpll_regs *)base; + + bypass_dpll(base); + + /* Set M & N */ + temp = readl(&dpll_regs->cm_clksel_dpll); + + temp &= ~CM_CLKSEL_DPLL_M_MASK; + temp |= (params->m << CM_CLKSEL_DPLL_M_SHIFT) & CM_CLKSEL_DPLL_M_MASK; + + temp &= ~CM_CLKSEL_DPLL_N_MASK; + temp |= (params->n << CM_CLKSEL_DPLL_N_SHIFT) & CM_CLKSEL_DPLL_N_MASK; + + writel(temp, &dpll_regs->cm_clksel_dpll); + + /* Lock */ + if (lock) + do_lock_dpll(base); + + /* Setup post-dividers */ + if (params->m2 >= 0) + writel(params->m2, &dpll_regs->cm_div_m2_dpll); + if (params->m3 >= 0) + writel(params->m3, &dpll_regs->cm_div_m3_dpll); + if (params->m4 >= 0) + writel(params->m4, &dpll_regs->cm_div_m4_dpll); + if (params->m5 >= 0) + writel(params->m5, &dpll_regs->cm_div_m5_dpll); + if (params->m6 >= 0) + writel(params->m6, &dpll_regs->cm_div_m6_dpll); + if (params->m7 >= 0) + writel(params->m7, &dpll_regs->cm_div_m7_dpll); + + /* Wait till the DPLL locks */ + if (lock) + wait_for_lock(base); +} + +const struct dpll_params *get_core_dpll_params(void) +{ + u32 sysclk_ind = get_sys_clk_index(); + + switch (omap_revision()) { + case OMAP4430_ES1_0: + return &core_dpll_params_es1_1524mhz[sysclk_ind]; + case OMAP4430_ES2_0: + case OMAP4430_SILICON_ID_INVALID: + /* safest */ + return &core_dpll_params_es2_1600mhz_ddr200mhz[sysclk_ind]; + default: + return &core_dpll_params_1600mhz[sysclk_ind]; + } +} + +u32 omap4_ddr_clk(void) +{ + u32 ddr_clk, sys_clk_khz; + const struct dpll_params *core_dpll_params; + + sys_clk_khz = get_sys_clk_freq() / 1000; + + core_dpll_params = get_core_dpll_params(); + + debug("sys_clk %d\n ", sys_clk_khz * 1000); + + /* Find Core DPLL locked frequency first */ + ddr_clk = sys_clk_khz * 2 * core_dpll_params->m / + (core_dpll_params->n + 1); + /* + * DDR frequency is PHY_ROOT_CLK/2 + * PHY_ROOT_CLK = Fdpll/2/M2 + */ + ddr_clk = ddr_clk / 4 / core_dpll_params->m2; + + ddr_clk *= 1000; /* convert to Hz */ + debug("ddr_clk %d\n ", ddr_clk); + + return ddr_clk; +} + +static void setup_dplls(void) +{ + u32 sysclk_ind, temp; + const struct dpll_params *params; + debug("setup_dplls\n"); + + sysclk_ind = get_sys_clk_index(); + + /* CORE dpll */ + params = get_core_dpll_params(); /* default - safest */ + /* + * Do not lock the core DPLL now. Just set it up. + * Core DPLL will be locked after setting up EMIF + * using the FREQ_UPDATE method(freq_update_core()) + */ + do_setup_dpll(&prcm->cm_clkmode_dpll_core, params, DPLL_NO_LOCK); + /* Set the ratios for CORE_CLK, L3_CLK, L4_CLK */ + temp = (CLKSEL_CORE_X2_DIV_1 << CLKSEL_CORE_SHIFT) | + (CLKSEL_L3_CORE_DIV_2 << CLKSEL_L3_SHIFT) | + (CLKSEL_L4_L3_DIV_2 << CLKSEL_L4_SHIFT); + writel(temp, &prcm->cm_clksel_core); + debug("Core DPLL configured\n"); + + /* lock PER dpll */ + do_setup_dpll(&prcm->cm_clkmode_dpll_per, + &per_dpll_params_1536mhz[sysclk_ind], DPLL_LOCK); + debug("PER DPLL locked\n"); + + /* MPU dpll */ + if (omap_revision() == OMAP4430_ES1_0) + params = &mpu_dpll_params_1200mhz[sysclk_ind]; + else + params = &mpu_dpll_params_1584mhz[sysclk_ind]; + do_setup_dpll(&prcm->cm_clkmode_dpll_mpu, params, DPLL_LOCK); + debug("MPU DPLL locked\n"); +} + +static void setup_non_essential_dplls(void) +{ + u32 sys_clk_khz, abe_ref_clk; + u32 sysclk_ind, sd_div, num, den; + const struct dpll_params *params; + + sysclk_ind = get_sys_clk_index(); + sys_clk_khz = get_sys_clk_freq() / 1000; + + /* IVA */ + clrsetbits_le32(&prcm->cm_bypclk_dpll_iva, + CM_BYPCLK_DPLL_IVA_CLKSEL_MASK, DPLL_IVA_CLKSEL_CORE_X2_DIV_2); + + do_setup_dpll(&prcm->cm_clkmode_dpll_iva, + &iva_dpll_params_1862mhz[sysclk_ind], DPLL_LOCK); + + /* + * USB: + * USB dpll is J-type. Need to set DPLL_SD_DIV for jitter correction + * DPLL_SD_DIV = CEILING ([DPLL_MULT/(DPLL_DIV+1)]* CLKINP / 250) + * - where CLKINP is sys_clk in MHz + * Use CLKINP in KHz and adjust the denominator accordingly so + * that we have enough accuracy and at the same time no overflow + */ + params = &usb_dpll_params_1920mhz[sysclk_ind]; + num = params->m * sys_clk_khz; + den = (params->n + 1) * 250 * 1000; + num += den - 1; + sd_div = num / den; + clrsetbits_le32(&prcm->cm_clksel_dpll_usb, + CM_CLKSEL_DPLL_DPLL_SD_DIV_MASK, + sd_div << CM_CLKSEL_DPLL_DPLL_SD_DIV_SHIFT); + + /* Now setup the dpll with the regular function */ + do_setup_dpll(&prcm->cm_clkmode_dpll_usb, params, DPLL_LOCK); + +#ifdef CONFIG_SYS_OMAP4_ABE_SYSCK + params = &abe_dpll_params_sysclk_196608khz[sysclk_ind]; + abe_ref_clk = CM_ABE_PLL_REF_CLKSEL_CLKSEL_SYSCLK; +#else + params = &abe_dpll_params_32k_196608khz; + abe_ref_clk = CM_ABE_PLL_REF_CLKSEL_CLKSEL_32KCLK; + /* + * We need to enable some additional options to achieve + * 196.608MHz from 32768 Hz + */ + setbits_le32(&prcm->cm_clkmode_dpll_abe, + CM_CLKMODE_DPLL_DRIFTGUARD_EN_MASK| + CM_CLKMODE_DPLL_RELOCK_RAMP_EN_MASK| + CM_CLKMODE_DPLL_LPMODE_EN_MASK| + CM_CLKMODE_DPLL_REGM4XEN_MASK); + /* Spend 4 REFCLK cycles at each stage */ + clrsetbits_le32(&prcm->cm_clkmode_dpll_abe, + CM_CLKMODE_DPLL_RAMP_RATE_MASK, + 1 << CM_CLKMODE_DPLL_RAMP_RATE_SHIFT); +#endif + + /* Select the right reference clk */ + clrsetbits_le32(&prcm->cm_abe_pll_ref_clksel, + CM_ABE_PLL_REF_CLKSEL_CLKSEL_MASK, + abe_ref_clk << CM_ABE_PLL_REF_CLKSEL_CLKSEL_SHIFT); + /* Lock the dpll */ + do_setup_dpll(&prcm->cm_clkmode_dpll_abe, params, DPLL_LOCK); +} + +static void do_scale_vcore(u32 vcore_reg, u32 volt_mv) +{ + u32 temp, offset_code; + u32 step = 12660; /* 12.66 mV represented in uV */ + u32 offset = volt_mv; + + /* convert to uV for better accuracy in the calculations */ + offset *= 1000; + + if (omap_revision() == OMAP4430_ES1_0) + offset -= PHOENIX_SMPS_BASE_VOLT_STD_MODE_UV; + else + offset -= PHOENIX_SMPS_BASE_VOLT_STD_MODE_WITH_OFFSET_UV; + + offset_code = (offset + step - 1) / step; + /* The code starts at 1 not 0 */ + offset_code++; + + debug("do_scale_vcore: volt - %d offset_code - 0x%x\n", volt_mv, + offset_code); + + temp = SMPS_I2C_SLAVE_ADDR | + (vcore_reg << PRM_VC_VAL_BYPASS_REGADDR_SHIFT) | + (offset_code << PRM_VC_VAL_BYPASS_DATA_SHIFT) | + PRM_VC_VAL_BYPASS_VALID_BIT; + writel(temp, &prcm->prm_vc_val_bypass); + if (!wait_on_value(PRM_VC_VAL_BYPASS_VALID_BIT, 0, + &prcm->prm_vc_val_bypass, LDELAY)) { + printf("Scaling voltage failed for 0x%x\n", vcore_reg); + } +} + +/* + * Setup the voltages for vdd_mpu, vdd_core, and vdd_iva + * We set the maximum voltages allowed here because Smart-Reflex is not + * enabled in bootloader. Voltage initialization in the kernel will set + * these to the nominal values after enabling Smart-Reflex + */ +static void scale_vcores(void) +{ + u32 volt, sys_clk_khz, cycles_hi, cycles_low, temp; + + sys_clk_khz = get_sys_clk_freq() / 1000; + + /* + * Setup the dedicated I2C controller for Voltage Control + * I2C clk - high period 40% low period 60% + */ + cycles_hi = sys_clk_khz * 4 / PRM_VC_I2C_CHANNEL_FREQ_KHZ / 10; + cycles_low = sys_clk_khz * 6 / PRM_VC_I2C_CHANNEL_FREQ_KHZ / 10; + /* values to be set in register - less by 5 & 7 respectively */ + cycles_hi -= 5; + cycles_low -= 7; + temp = (cycles_hi << PRM_VC_CFG_I2C_CLK_SCLH_SHIFT) | + (cycles_low << PRM_VC_CFG_I2C_CLK_SCLL_SHIFT); + writel(temp, &prcm->prm_vc_cfg_i2c_clk); + + /* Disable high speed mode and all advanced features */ + writel(0x0, &prcm->prm_vc_cfg_i2c_mode); + + /* + * VCORE 1 - 4430 : supplies vdd_mpu + * Setting a high voltage for Nitro mode as smart reflex is not enabled. + * We use the maximum possible value in the AVS range because the next + * higher voltage in the discrete range (code >= 0b111010) is way too + * high + */ + volt = 1417; + do_scale_vcore(SMPS_REG_ADDR_VCORE1, volt); + + /* VCORE 2 - supplies vdd_iva */ + volt = 1200; + do_scale_vcore(SMPS_REG_ADDR_VCORE2, volt); + + /* VCORE 3 - supplies vdd_core */ + volt = 1200; + do_scale_vcore(SMPS_REG_ADDR_VCORE3, volt); +} + +static inline void enable_clock_domain(u32 *const clkctrl_reg, u32 enable_mode) +{ + clrsetbits_le32(clkctrl_reg, CD_CLKCTRL_CLKTRCTRL_MASK, + enable_mode << CD_CLKCTRL_CLKTRCTRL_SHIFT); + debug("Enable clock domain - 0x%08x\n", clkctrl_reg); +} + +static inline void wait_for_clk_enable(u32 *clkctrl_addr) +{ + u32 clkctrl, idlest = MODULE_CLKCTRL_IDLEST_DISABLED; + u32 bound = LDELAY; + + while ((idlest == MODULE_CLKCTRL_IDLEST_DISABLED) || + (idlest == MODULE_CLKCTRL_IDLEST_TRANSITIONING)) { + + clkctrl = readl(clkctrl_addr); + idlest = (clkctrl & MODULE_CLKCTRL_IDLEST_MASK) >> + MODULE_CLKCTRL_IDLEST_SHIFT; + if (--bound == 0) { + printf("Clock enable failed for 0x%p idlest 0x%x\n", + clkctrl_addr, clkctrl); + return; + } + } +} + +static inline void enable_clock_module(u32 *const clkctrl_addr, u32 enable_mode, + u32 wait_for_enable) +{ + clrsetbits_le32(clkctrl_addr, MODULE_CLKCTRL_MODULEMODE_MASK, + enable_mode << MODULE_CLKCTRL_MODULEMODE_SHIFT); + debug("Enable clock module - 0x%08x\n", clkctrl_addr); + if (wait_for_enable) + wait_for_clk_enable(clkctrl_addr); +} + +/* + * Enable essential clock domains, modules and + * do some additional special settings needed + */ +static void enable_basic_clocks(void) +{ + u32 i, max = 100, wait_for_enable = 1; + u32 *const clk_domains_essential[] = { + &prcm->cm_l4per_clkstctrl, + &prcm->cm_l3init_clkstctrl, + &prcm->cm_memif_clkstctrl, + &prcm->cm_l4cfg_clkstctrl, + 0 + }; + + u32 *const clk_modules_hw_auto_essential[] = { + &prcm->cm_wkup_gpio1_clkctrl, + &prcm->cm_l4per_gpio2_clkctrl, + &prcm->cm_l4per_gpio3_clkctrl, + &prcm->cm_l4per_gpio4_clkctrl, + &prcm->cm_l4per_gpio5_clkctrl, + &prcm->cm_l4per_gpio6_clkctrl, + &prcm->cm_memif_emif_1_clkctrl, + &prcm->cm_memif_emif_2_clkctrl, + &prcm->cm_l3init_hsusbotg_clkctrl, + &prcm->cm_l3init_usbphy_clkctrl, + &prcm->cm_l4cfg_l4_cfg_clkctrl, + 0 + }; + + u32 *const clk_modules_explicit_en_essential[] = { + &prcm->cm_l4per_gptimer2_clkctrl, + &prcm->cm_l3init_hsmmc1_clkctrl, + &prcm->cm_l3init_hsmmc2_clkctrl, + &prcm->cm_l4per_mcspi1_clkctrl, + &prcm->cm_wkup_gptimer1_clkctrl, + &prcm->cm_l4per_i2c1_clkctrl, + &prcm->cm_l4per_i2c2_clkctrl, + &prcm->cm_l4per_i2c3_clkctrl, + &prcm->cm_l4per_i2c4_clkctrl, + &prcm->cm_wkup_wdtimer2_clkctrl, + &prcm->cm_l4per_uart3_clkctrl, + 0 + }; + + /* Enable optional additional functional clock for GPIO4 */ + setbits_le32(&prcm->cm_l4per_gpio4_clkctrl, + GPIO4_CLKCTRL_OPTFCLKEN_MASK); + + /* Enable 96 MHz clock for MMC1 & MMC2 */ + setbits_le32(&prcm->cm_l3init_hsmmc1_clkctrl, + HSMMC_CLKCTRL_CLKSEL_MASK); + setbits_le32(&prcm->cm_l3init_hsmmc2_clkctrl, + HSMMC_CLKCTRL_CLKSEL_MASK); + + /* Select 32KHz clock as the source of GPTIMER1 */ + setbits_le32(&prcm->cm_wkup_gptimer1_clkctrl, + GPTIMER1_CLKCTRL_CLKSEL_MASK); + + /* Enable optional 48M functional clock for USB PHY */ + setbits_le32(&prcm->cm_l3init_usbphy_clkctrl, + USBPHY_CLKCTRL_OPTFCLKEN_PHY_48M_MASK); + + /* Put the clock domains in SW_WKUP mode */ + for (i = 0; (i < max) && clk_domains_essential[i]; i++) { + enable_clock_domain(clk_domains_essential[i], + CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + } + + /* Clock modules that need to be put in HW_AUTO */ + for (i = 0; (i < max) && clk_modules_hw_auto_essential[i]; i++) { + enable_clock_module(clk_modules_hw_auto_essential[i], + MODULE_CLKCTRL_MODULEMODE_HW_AUTO, + wait_for_enable); + }; + + /* Clock modules that need to be put in SW_EXPLICIT_EN mode */ + for (i = 0; (i < max) && clk_modules_explicit_en_essential[i]; i++) { + enable_clock_module(clk_modules_explicit_en_essential[i], + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN, + wait_for_enable); + }; + + /* Put the clock domains in HW_AUTO mode now */ + for (i = 0; (i < max) && clk_domains_essential[i]; i++) { + enable_clock_domain(clk_domains_essential[i], + CD_CLKCTRL_CLKTRCTRL_HW_AUTO); + } +} + +/* + * Enable non-essential clock domains, modules and + * do some additional special settings needed + */ +static void enable_non_essential_clocks(void) +{ + u32 i, max = 100, wait_for_enable = 0; + u32 *const clk_domains_non_essential[] = { + &prcm->cm_mpu_m3_clkstctrl, + &prcm->cm_ivahd_clkstctrl, + &prcm->cm_dsp_clkstctrl, + &prcm->cm_dss_clkstctrl, + &prcm->cm_sgx_clkstctrl, + &prcm->cm1_abe_clkstctrl, + &prcm->cm_c2c_clkstctrl, + &prcm->cm_cam_clkstctrl, + &prcm->cm_dss_clkstctrl, + &prcm->cm_sdma_clkstctrl, + 0 + }; + + u32 *const clk_modules_hw_auto_non_essential[] = { + &prcm->cm_mpu_m3_mpu_m3_clkctrl, + &prcm->cm_ivahd_ivahd_clkctrl, + &prcm->cm_ivahd_sl2_clkctrl, + &prcm->cm_dsp_dsp_clkctrl, + &prcm->cm_l3_2_gpmc_clkctrl, + &prcm->cm_l3instr_l3_3_clkctrl, + &prcm->cm_l3instr_l3_instr_clkctrl, + &prcm->cm_l3instr_intrconn_wp1_clkctrl, + &prcm->cm_l3init_hsi_clkctrl, + &prcm->cm_l3init_hsusbtll_clkctrl, + 0 + }; + + u32 *const clk_modules_explicit_en_non_essential[] = { + &prcm->cm1_abe_aess_clkctrl, + &prcm->cm1_abe_pdm_clkctrl, + &prcm->cm1_abe_dmic_clkctrl, + &prcm->cm1_abe_mcasp_clkctrl, + &prcm->cm1_abe_mcbsp1_clkctrl, + &prcm->cm1_abe_mcbsp2_clkctrl, + &prcm->cm1_abe_mcbsp3_clkctrl, + &prcm->cm1_abe_slimbus_clkctrl, + &prcm->cm1_abe_timer5_clkctrl, + &prcm->cm1_abe_timer6_clkctrl, + &prcm->cm1_abe_timer7_clkctrl, + &prcm->cm1_abe_timer8_clkctrl, + &prcm->cm1_abe_wdt3_clkctrl, + &prcm->cm_l4per_gptimer9_clkctrl, + &prcm->cm_l4per_gptimer10_clkctrl, + &prcm->cm_l4per_gptimer11_clkctrl, + &prcm->cm_l4per_gptimer3_clkctrl, + &prcm->cm_l4per_gptimer4_clkctrl, + &prcm->cm_l4per_hdq1w_clkctrl, + &prcm->cm_l4per_mcbsp4_clkctrl, + &prcm->cm_l4per_mcspi2_clkctrl, + &prcm->cm_l4per_mcspi3_clkctrl, + &prcm->cm_l4per_mcspi4_clkctrl, + &prcm->cm_l4per_mmcsd3_clkctrl, + &prcm->cm_l4per_mmcsd4_clkctrl, + &prcm->cm_l4per_mmcsd5_clkctrl, + &prcm->cm_l4per_uart1_clkctrl, + &prcm->cm_l4per_uart2_clkctrl, + &prcm->cm_l4per_uart4_clkctrl, + &prcm->cm_wkup_keyboard_clkctrl, + &prcm->cm_wkup_wdtimer2_clkctrl, + &prcm->cm_cam_iss_clkctrl, + &prcm->cm_cam_fdif_clkctrl, + &prcm->cm_dss_dss_clkctrl, + &prcm->cm_sgx_sgx_clkctrl, + &prcm->cm_l3init_hsusbhost_clkctrl, + &prcm->cm_l3init_fsusb_clkctrl, + 0 + }; + + /* Enable optional functional clock for ISS */ + setbits_le32(&prcm->cm_cam_iss_clkctrl, ISS_CLKCTRL_OPTFCLKEN_MASK); + + /* Enable all optional functional clocks of DSS */ + setbits_le32(&prcm->cm_dss_dss_clkctrl, DSS_CLKCTRL_OPTFCLKEN_MASK); + + + /* Put the clock domains in SW_WKUP mode */ + for (i = 0; (i < max) && clk_domains_non_essential[i]; i++) { + enable_clock_domain(clk_domains_non_essential[i], + CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + } + + /* Clock modules that need to be put in HW_AUTO */ + for (i = 0; (i < max) && clk_modules_hw_auto_non_essential[i]; i++) { + enable_clock_module(clk_modules_hw_auto_non_essential[i], + MODULE_CLKCTRL_MODULEMODE_HW_AUTO, + wait_for_enable); + }; + + /* Clock modules that need to be put in SW_EXPLICIT_EN mode */ + for (i = 0; (i < max) && clk_modules_explicit_en_non_essential[i]; + i++) { + enable_clock_module(clk_modules_explicit_en_non_essential[i], + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN, + wait_for_enable); + }; + + /* Put the clock domains in HW_AUTO mode now */ + for (i = 0; (i < max) && clk_domains_non_essential[i]; i++) { + enable_clock_domain(clk_domains_non_essential[i], + CD_CLKCTRL_CLKTRCTRL_HW_AUTO); + } + + /* Put camera module in no sleep mode */ + clrsetbits_le32(&prcm->cm_cam_clkstctrl, MODULE_CLKCTRL_MODULEMODE_MASK, + CD_CLKCTRL_CLKTRCTRL_NO_SLEEP << + MODULE_CLKCTRL_MODULEMODE_SHIFT); +} + + +void freq_update_core(void) +{ + u32 freq_config1 = 0; + const struct dpll_params *core_dpll_params; + + core_dpll_params = get_core_dpll_params(); + /* Put EMIF clock domain in sw wakeup mode */ + enable_clock_domain(&prcm->cm_memif_clkstctrl, + CD_CLKCTRL_CLKTRCTRL_SW_WKUP); + wait_for_clk_enable(&prcm->cm_memif_emif_1_clkctrl); + wait_for_clk_enable(&prcm->cm_memif_emif_2_clkctrl); + + freq_config1 = SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK | + SHADOW_FREQ_CONFIG1_DLL_RESET_MASK; + + freq_config1 |= (DPLL_EN_LOCK << SHADOW_FREQ_CONFIG1_DPLL_EN_SHIFT) & + SHADOW_FREQ_CONFIG1_DPLL_EN_MASK; + + freq_config1 |= (core_dpll_params->m2 << + SHADOW_FREQ_CONFIG1_M2_DIV_SHIFT) & + SHADOW_FREQ_CONFIG1_M2_DIV_MASK; + + writel(freq_config1, &prcm->cm_shadow_freq_config1); + if (!wait_on_value(SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK, 0, + &prcm->cm_shadow_freq_config1, LDELAY)) { + puts("FREQ UPDATE procedure failed!!"); + hang(); + } + + /* Put EMIF clock domain back in hw auto mode */ + enable_clock_domain(&prcm->cm_memif_clkstctrl, + CD_CLKCTRL_CLKTRCTRL_HW_AUTO); + wait_for_clk_enable(&prcm->cm_memif_emif_1_clkctrl); + wait_for_clk_enable(&prcm->cm_memif_emif_2_clkctrl); +} + +void bypass_dpll(u32 *const base) +{ + do_bypass_dpll(base); + wait_for_bypass(base); +} + +void lock_dpll(u32 *const base) +{ + do_lock_dpll(base); + wait_for_lock(base); +} + +void prcm_init(void) +{ + switch (omap4_hw_init_context()) { + case OMAP_INIT_CONTEXT_SPL: + case OMAP_INIT_CONTEXT_UBOOT_FROM_NOR: + case OMAP_INIT_CONTEXT_UBOOT_AFTER_CH: + scale_vcores(); + setup_dplls(); + enable_basic_clocks(); + setup_non_essential_dplls(); + enable_non_essential_clocks(); + break; + default: + break; + } +} diff --git a/arch/arm/include/asm/arch-omap4/clocks.h b/arch/arm/include/asm/arch-omap4/clocks.h new file mode 100644 index 0000000..71db39c --- /dev/null +++ b/arch/arm/include/asm/arch-omap4/clocks.h @@ -0,0 +1,664 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _CLOCKS_OMAP4_H_ +#define _CLOCKS_OMAP4_H_ +#include <common.h> + +/* + * Assuming a maximum of 1.5 GHz ARM speed and a minimum of 2 cycles per + * loop, allow for a minimum of 2 ms wait (in reality the wait will be + * much more than that) + */ +#define LDELAY 1000000 + +#define CM_CLKMODE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4120) +#define CM_CLKMODE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8140) +#define CM_CLKMODE_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4160) +#define CM_CLKSEL_CORE (OMAP44XX_L4_CORE_BASE + 0x4100) + +struct omap4_prcm_regs { + /* cm1.ckgen */ + u32 cm_clksel_core; + u32 pad001[1]; + u32 cm_clksel_abe; + u32 pad002[1]; + u32 cm_dll_ctrl; + u32 pad003[3]; + u32 cm_clkmode_dpll_core; + u32 cm_idlest_dpll_core; + u32 cm_autoidle_dpll_core; + u32 cm_clksel_dpll_core; + u32 cm_div_m2_dpll_core; + u32 cm_div_m3_dpll_core; + u32 cm_div_m4_dpll_core; + u32 cm_div_m5_dpll_core; + u32 cm_div_m6_dpll_core; + u32 cm_div_m7_dpll_core; + u32 cm_ssc_deltamstep_dpll_core; + u32 cm_ssc_modfreqdiv_dpll_core; + u32 cm_emu_override_dpll_core; + u32 pad004[3]; + u32 cm_clkmode_dpll_mpu; + u32 cm_idlest_dpll_mpu; + u32 cm_autoidle_dpll_mpu; + u32 cm_clksel_dpll_mpu; + u32 cm_div_m2_dpll_mpu; + u32 pad005[5]; + u32 cm_ssc_deltamstep_dpll_mpu; + u32 cm_ssc_modfreqdiv_dpll_mpu; + u32 pad006[3]; + u32 cm_bypclk_dpll_mpu; + u32 cm_clkmode_dpll_iva; + u32 cm_idlest_dpll_iva; + u32 cm_autoidle_dpll_iva; + u32 cm_clksel_dpll_iva; + u32 pad007[2]; + u32 cm_div_m4_dpll_iva; + u32 cm_div_m5_dpll_iva; + u32 pad008[2]; + u32 cm_ssc_deltamstep_dpll_iva; + u32 cm_ssc_modfreqdiv_dpll_iva; + u32 pad009[3]; + u32 cm_bypclk_dpll_iva; + u32 cm_clkmode_dpll_abe; + u32 cm_idlest_dpll_abe; + u32 cm_autoidle_dpll_abe; + u32 cm_clksel_dpll_abe; + u32 cm_div_m2_dpll_abe; + u32 cm_div_m3_dpll_abe; + u32 pad010[4]; + u32 cm_ssc_deltamstep_dpll_abe; + u32 cm_ssc_modfreqdiv_dpll_abe; + u32 pad011[4]; + u32 cm_clkmode_dpll_ddrphy; + u32 cm_idlest_dpll_ddrphy; + u32 cm_autoidle_dpll_ddrphy; + u32 cm_clksel_dpll_ddrphy; + u32 cm_div_m2_dpll_ddrphy; + u32 pad012[1]; + u32 cm_div_m4_dpll_ddrphy; + u32 cm_div_m5_dpll_ddrphy; + u32 cm_div_m6_dpll_ddrphy; + u32 pad013[1]; + u32 cm_ssc_deltamstep_dpll_ddrphy; + u32 pad014[5]; + u32 cm_shadow_freq_config1; + + /* cm1.dsp */ + u32 pad015[103]; + u32 cm_dsp_clkstctrl; + u32 pad016[7]; + u32 cm_dsp_dsp_clkctrl; + + /* cm1.abe */ + u32 pad017[55]; + u32 cm1_abe_clkstctrl; + u32 pad018[7]; + u32 cm1_abe_l4abe_clkctrl; + u32 pad019[1]; + u32 cm1_abe_aess_clkctrl; + u32 pad020[1]; + u32 cm1_abe_pdm_clkctrl; + u32 pad021[1]; + u32 cm1_abe_dmic_clkctrl; + u32 pad022[1]; + u32 cm1_abe_mcasp_clkctrl; + u32 pad023[1]; + u32 cm1_abe_mcbsp1_clkctrl; + u32 pad024[1]; + u32 cm1_abe_mcbsp2_clkctrl; + u32 pad025[1]; + u32 cm1_abe_mcbsp3_clkctrl; + u32 pad026[1]; + u32 cm1_abe_slimbus_clkctrl; + u32 pad027[1]; + u32 cm1_abe_timer5_clkctrl; + u32 pad028[1]; + u32 cm1_abe_timer6_clkctrl; + u32 pad029[1]; + u32 cm1_abe_timer7_clkctrl; + u32 pad030[1]; + u32 cm1_abe_timer8_clkctrl; + u32 pad031[1]; + u32 cm1_abe_wdt3_clkctrl; + + /* cm2.ckgen */ + u32 pad032[3805]; + u32 cm_clksel_mpu_m3_iss_root; + u32 cm_clksel_usb_60mhz; + u32 cm_scale_fclk; + u32 pad033[1]; + u32 cm_core_dvfs_perf1; + u32 cm_core_dvfs_perf2; + u32 cm_core_dvfs_perf3; + u32 cm_core_dvfs_perf4; + u32 pad034[1]; + u32 cm_core_dvfs_current; + u32 cm_iva_dvfs_perf_tesla; + u32 cm_iva_dvfs_perf_ivahd; + u32 cm_iva_dvfs_perf_abe; + u32 pad035[1]; + u32 cm_iva_dvfs_current; + u32 pad036[1]; + u32 cm_clkmode_dpll_per; + u32 cm_idlest_dpll_per; + u32 cm_autoidle_dpll_per; + u32 cm_clksel_dpll_per; + u32 cm_div_m2_dpll_per; + u32 cm_div_m3_dpll_per; + u32 cm_div_m4_dpll_per; + u32 cm_div_m5_dpll_per; + u32 cm_div_m6_dpll_per; + u32 cm_div_m7_dpll_per; + u32 cm_ssc_deltamstep_dpll_per; + u32 cm_ssc_modfreqdiv_dpll_per; + u32 cm_emu_override_dpll_per; + u32 pad037[3]; + u32 cm_clkmode_dpll_usb; + u32 cm_idlest_dpll_usb; + u32 cm_autoidle_dpll_usb; + u32 cm_clksel_dpll_usb; + u32 cm_div_m2_dpll_usb; + u32 pad038[5]; + u32 cm_ssc_deltamstep_dpll_usb; + u32 cm_ssc_modfreqdiv_dpll_usb; + u32 pad039[1]; + u32 cm_clkdcoldo_dpll_usb; + u32 pad040[2]; + u32 cm_clkmode_dpll_unipro; + u32 cm_idlest_dpll_unipro; + u32 cm_autoidle_dpll_unipro; + u32 cm_clksel_dpll_unipro; + u32 cm_div_m2_dpll_unipro; + u32 pad041[5]; + u32 cm_ssc_deltamstep_dpll_unipro; + u32 cm_ssc_modfreqdiv_dpll_unipro; + + /* cm2.core */ + u32 pad0411[324]; + u32 cm_l3_1_clkstctrl; + u32 pad042[1]; + u32 cm_l3_1_dynamicdep; + u32 pad043[5]; + u32 cm_l3_1_l3_1_clkctrl; + u32 pad044[55]; + u32 cm_l3_2_clkstctrl; + u32 pad045[1]; + u32 cm_l3_2_dynamicdep; + u32 pad046[5]; + u32 cm_l3_2_l3_2_clkctrl; + u32 pad047[1]; + u32 cm_l3_2_gpmc_clkctrl; + u32 pad048[1]; + u32 cm_l3_2_ocmc_ram_clkctrl; + u32 pad049[51]; + u32 cm_mpu_m3_clkstctrl; + u32 cm_mpu_m3_staticdep; + u32 cm_mpu_m3_dynamicdep; + u32 pad050[5]; + u32 cm_mpu_m3_mpu_m3_clkctrl; + u32 pad051[55]; + u32 cm_sdma_clkstctrl; + u32 cm_sdma_staticdep; + u32 cm_sdma_dynamicdep; + u32 pad052[5]; + u32 cm_sdma_sdma_clkctrl; + u32 pad053[55]; + u32 cm_memif_clkstctrl; + u32 pad054[7]; + u32 cm_memif_dmm_clkctrl; + u32 pad055[1]; + u32 cm_memif_emif_fw_clkctrl; + u32 pad056[1]; + u32 cm_memif_emif_1_clkctrl; + u32 pad057[1]; + u32 cm_memif_emif_2_clkctrl; + u32 pad058[1]; + u32 cm_memif_dll_clkctrl; + u32 pad059[3]; + u32 cm_memif_emif_h1_clkctrl; + u32 pad060[1]; + u32 cm_memif_emif_h2_clkctrl; + u32 pad061[1]; + u32 cm_memif_dll_h_clkctrl; + u32 pad062[39]; + u32 cm_c2c_clkstctrl; + u32 cm_c2c_staticdep; + u32 cm_c2c_dynamicdep; + u32 pad063[5]; + u32 cm_c2c_sad2d_clkctrl; + u32 pad064[1]; + u32 cm_c2c_modem_icr_clkctrl; + u32 pad065[1]; + u32 cm_c2c_sad2d_fw_clkctrl; + u32 pad066[51]; + u32 cm_l4cfg_clkstctrl; + u32 pad067[1]; + u32 cm_l4cfg_dynamicdep; + u32 pad068[5]; + u32 cm_l4cfg_l4_cfg_clkctrl; + u32 pad069[1]; + u32 cm_l4cfg_hw_sem_clkctrl; + u32 pad070[1]; + u32 cm_l4cfg_mailbox_clkctrl; + u32 pad071[1]; + u32 cm_l4cfg_sar_rom_clkctrl; + u32 pad072[49]; + u32 cm_l3instr_clkstctrl; + u32 pad073[7]; + u32 cm_l3instr_l3_3_clkctrl; + u32 pad074[1]; + u32 cm_l3instr_l3_instr_clkctrl; + u32 pad075[5]; + u32 cm_l3instr_intrconn_wp1_clkctrl; + + + /* cm2.ivahd */ + u32 pad076[47]; + u32 cm_ivahd_clkstctrl; + u32 pad077[7]; + u32 cm_ivahd_ivahd_clkctrl; + u32 pad078[1]; + u32 cm_ivahd_sl2_clkctrl; + + /* cm2.cam */ + u32 pad079[53]; + u32 cm_cam_clkstctrl; + u32 pad080[7]; + u32 cm_cam_iss_clkctrl; + u32 pad081[1]; + u32 cm_cam_fdif_clkctrl; + + /* cm2.dss */ + u32 pad082[53]; + u32 cm_dss_clkstctrl; + u32 pad083[7]; + u32 cm_dss_dss_clkctrl; + + /* cm2.sgx */ + u32 pad084[55]; + u32 cm_sgx_clkstctrl; + u32 pad085[7]; + u32 cm_sgx_sgx_clkctrl; + + /* cm2.l3init */ + u32 pad086[55]; + u32 cm_l3init_clkstctrl; + + /* cm2.l3init */ + u32 pad087[9]; + u32 cm_l3init_hsmmc1_clkctrl; + u32 pad088[1]; + u32 cm_l3init_hsmmc2_clkctrl; + u32 pad089[1]; + u32 cm_l3init_hsi_clkctrl; + u32 pad090[7]; + u32 cm_l3init_hsusbhost_clkctrl; + u32 pad091[1]; + u32 cm_l3init_hsusbotg_clkctrl; + u32 pad092[1]; + u32 cm_l3init_hsusbtll_clkctrl; + u32 pad093[3]; + u32 cm_l3init_p1500_clkctrl; + u32 pad094[21]; + u32 cm_l3init_fsusb_clkctrl; + u32 pad095[3]; + u32 cm_l3init_usbphy_clkctrl; + + /* cm2.l4per */ + u32 pad096[7]; + u32 cm_l4per_clkstctrl; + u32 pad097[1]; + u32 cm_l4per_dynamicdep; + u32 pad098[5]; + u32 cm_l4per_adc_clkctrl; + u32 pad100[1]; + u32 cm_l4per_gptimer10_clkctrl; + u32 pad101[1]; + u32 cm_l4per_gptimer11_clkctrl; + u32 pad102[1]; + u32 cm_l4per_gptimer2_clkctrl; + u32 pad103[1]; + u32 cm_l4per_gptimer3_clkctrl; + u32 pad104[1]; + u32 cm_l4per_gptimer4_clkctrl; + u32 pad105[1]; + u32 cm_l4per_gptimer9_clkctrl; + u32 pad106[1]; + u32 cm_l4per_elm_clkctrl; + u32 pad107[1]; + u32 cm_l4per_gpio2_clkctrl; + u32 pad108[1]; + u32 cm_l4per_gpio3_clkctrl; + u32 pad109[1]; + u32 cm_l4per_gpio4_clkctrl; + u32 pad110[1]; + u32 cm_l4per_gpio5_clkctrl; + u32 pad111[1]; + u32 cm_l4per_gpio6_clkctrl; + u32 pad112[1]; + u32 cm_l4per_hdq1w_clkctrl; + u32 pad113[1]; + u32 cm_l4per_hecc1_clkctrl; + u32 pad114[1]; + u32 cm_l4per_hecc2_clkctrl; + u32 pad115[1]; + u32 cm_l4per_i2c1_clkctrl; + u32 pad116[1]; + u32 cm_l4per_i2c2_clkctrl; + u32 pad117[1]; + u32 cm_l4per_i2c3_clkctrl; + u32 pad118[1]; + u32 cm_l4per_i2c4_clkctrl; + u32 pad119[1]; + u32 cm_l4per_l4per_clkctrl; + u32 pad1191[3]; + u32 cm_l4per_mcasp2_clkctrl; + u32 pad120[1]; + u32 cm_l4per_mcasp3_clkctrl; + u32 pad121[1]; + u32 cm_l4per_mcbsp4_clkctrl; + u32 pad122[1]; + u32 cm_l4per_mgate_clkctrl; + u32 pad123[1]; + u32 cm_l4per_mcspi1_clkctrl; + u32 pad124[1]; + u32 cm_l4per_mcspi2_clkctrl; + u32 pad125[1]; + u32 cm_l4per_mcspi3_clkctrl; + u32 pad126[1]; + u32 cm_l4per_mcspi4_clkctrl; + u32 pad127[5]; + u32 cm_l4per_mmcsd3_clkctrl; + u32 pad128[1]; + u32 cm_l4per_mmcsd4_clkctrl; + u32 pad129[1]; + u32 cm_l4per_msprohg_clkctrl; + u32 pad130[1]; + u32 cm_l4per_slimbus2_clkctrl; + u32 pad131[1]; + u32 cm_l4per_uart1_clkctrl; + u32 pad132[1]; + u32 cm_l4per_uart2_clkctrl; + u32 pad133[1]; + u32 cm_l4per_uart3_clkctrl; + u32 pad134[1]; + u32 cm_l4per_uart4_clkctrl; + u32 pad135[1]; + u32 cm_l4per_mmcsd5_clkctrl; + u32 pad136[1]; + u32 cm_l4per_i2c5_clkctrl; + u32 pad137[5]; + u32 cm_l4sec_clkstctrl; + u32 cm_l4sec_staticdep; + u32 cm_l4sec_dynamicdep; + u32 pad138[5]; + u32 cm_l4sec_aes1_clkctrl; + u32 pad139[1]; + u32 cm_l4sec_aes2_clkctrl; + u32 pad140[1]; + u32 cm_l4sec_des3des_clkctrl; + u32 pad141[1]; + u32 cm_l4sec_pkaeip29_clkctrl; + u32 pad142[1]; + u32 cm_l4sec_rng_clkctrl; + u32 pad143[1]; + u32 cm_l4sec_sha2md51_clkctrl; + u32 pad144[3]; + u32 cm_l4sec_cryptodma_clkctrl; + u32 pad145[776841]; + + /* l4 wkup regs */ + u32 pad201[6211]; + u32 cm_abe_pll_ref_clksel; + u32 cm_sys_clksel; + u32 pad202[1467]; + u32 cm_wkup_clkstctrl; + u32 pad203[7]; + u32 cm_wkup_l4wkup_clkctrl; + u32 pad204; + u32 cm_wkup_wdtimer1_clkctrl; + u32 pad205; + u32 cm_wkup_wdtimer2_clkctrl; + u32 pad206; + u32 cm_wkup_gpio1_clkctrl; + u32 pad207; + u32 cm_wkup_gptimer1_clkctrl; + u32 pad208; + u32 cm_wkup_gptimer12_clkctrl; + u32 pad209; + u32 cm_wkup_synctimer_clkctrl; + u32 pad210; + u32 cm_wkup_usim_clkctrl; + u32 pad211; + u32 cm_wkup_sarram_clkctrl; + u32 pad212[5]; + u32 cm_wkup_keyboard_clkctrl; + u32 pad213; + u32 cm_wkup_rtc_clkctrl; + u32 pad214; + u32 cm_wkup_bandgap_clkctrl; + u32 pad215[197]; + u32 prm_vc_val_bypass; + u32 prm_vc_cfg_channel; + u32 prm_vc_cfg_i2c_mode; + u32 prm_vc_cfg_i2c_clk; + +}; + +/* DPLL register offsets */ +#define CM_CLKMODE_DPLL 0 +#define CM_IDLEST_DPLL 0x4 +#define CM_AUTOIDLE_DPLL 0x8 +#define CM_CLKSEL_DPLL 0xC +#define CM_DIV_M2_DPLL 0x10 +#define CM_DIV_M3_DPLL 0x14 +#define CM_DIV_M4_DPLL 0x18 +#define CM_DIV_M5_DPLL 0x1C +#define CM_DIV_M6_DPLL 0x20 +#define CM_DIV_M7_DPLL 0x24 + +#define DPLL_CLKOUT_DIV_MASK 0x1F /* post-divider mask */ + +/* CM_CLKMODE_DPLL */ +#define CM_CLKMODE_DPLL_REGM4XEN_SHIFT 11 +#define CM_CLKMODE_DPLL_REGM4XEN_MASK (1 << 11) +#define CM_CLKMODE_DPLL_LPMODE_EN_SHIFT 10 +#define CM_CLKMODE_DPLL_LPMODE_EN_MASK (1 << 10) +#define CM_CLKMODE_DPLL_RELOCK_RAMP_EN_SHIFT 9 +#define CM_CLKMODE_DPLL_RELOCK_RAMP_EN_MASK (1 << 9) +#define CM_CLKMODE_DPLL_DRIFTGUARD_EN_SHIFT 8 +#define CM_CLKMODE_DPLL_DRIFTGUARD_EN_MASK (1 << 8) +#define CM_CLKMODE_DPLL_RAMP_RATE_SHIFT 5 +#define CM_CLKMODE_DPLL_RAMP_RATE_MASK (0x7 << 5) +#define CM_CLKMODE_DPLL_EN_SHIFT 0 +#define CM_CLKMODE_DPLL_EN_MASK (0x7 << 0) + +#define CM_CLKMODE_DPLL_DPLL_EN_SHIFT 0 +#define CM_CLKMODE_DPLL_DPLL_EN_MASK 7 + +#define DPLL_EN_STOP 1 +#define DPLL_EN_MN_BYPASS 4 +#define DPLL_EN_LOW_POWER_BYPASS 5 +#define DPLL_EN_FAST_RELOCK_BYPASS 6 +#define DPLL_EN_LOCK 7 + +/* CM_IDLEST_DPLL fields */ +#define ST_DPLL_CLK_MASK 1 + +/* CM_CLKSEL_DPLL */ +#define CM_CLKSEL_DPLL_DPLL_SD_DIV_SHIFT 24 +#define CM_CLKSEL_DPLL_DPLL_SD_DIV_MASK (0xFF << 24) +#define CM_CLKSEL_DPLL_M_SHIFT 8 +#define CM_CLKSEL_DPLL_M_MASK (0x7FF << 8) +#define CM_CLKSEL_DPLL_N_SHIFT 0 +#define CM_CLKSEL_DPLL_N_MASK 0x7F + +#define OMAP4_DPLL_MAX_N 127 + +/* CM_SYS_CLKSEL */ +#define CM_SYS_CLKSEL_SYS_CLKSEL_MASK 7 + +/* CM_CLKSEL_CORE */ +#define CLKSEL_CORE_SHIFT 0 +#define CLKSEL_L3_SHIFT 4 +#define CLKSEL_L4_SHIFT 8 + +#define CLKSEL_CORE_X2_DIV_1 0 +#define CLKSEL_L3_CORE_DIV_2 1 +#define CLKSEL_L4_L3_DIV_2 1 + +/* CM_ABE_PLL_REF_CLKSEL */ +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_SHIFT 0 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_MASK 1 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_SYSCLK 0 +#define CM_ABE_PLL_REF_CLKSEL_CLKSEL_32KCLK 1 + +/* CM_BYPCLK_DPLL_IVA */ +#define CM_BYPCLK_DPLL_IVA_CLKSEL_SHIFT 0 +#define CM_BYPCLK_DPLL_IVA_CLKSEL_MASK 3 + +#define DPLL_IVA_CLKSEL_CORE_X2_DIV_2 1 + +/* CM_SHADOW_FREQ_CONFIG1 */ +#define SHADOW_FREQ_CONFIG1_FREQ_UPDATE_MASK 1 +#define SHADOW_FREQ_CONFIG1_DLL_OVERRIDE_MASK 4 +#define SHADOW_FREQ_CONFIG1_DLL_RESET_MASK 8 + +#define SHADOW_FREQ_CONFIG1_DPLL_EN_SHIFT 8 +#define SHADOW_FREQ_CONFIG1_DPLL_EN_MASK (7 << 8) + +#define SHADOW_FREQ_CONFIG1_M2_DIV_SHIFT 11 +#define SHADOW_FREQ_CONFIG1_M2_DIV_MASK (0x1F << 11) + +/*CM_<clock_domain>__CLKCTRL */ +#define CD_CLKCTRL_CLKTRCTRL_SHIFT 0 +#define CD_CLKCTRL_CLKTRCTRL_MASK 3 + +#define CD_CLKCTRL_CLKTRCTRL_NO_SLEEP 0 +#define CD_CLKCTRL_CLKTRCTRL_SW_SLEEP 1 +#define CD_CLKCTRL_CLKTRCTRL_SW_WKUP 2 +#define CD_CLKCTRL_CLKTRCTRL_HW_AUTO 3 + + +/* CM_<clock_domain>_<module>_CLKCTRL */ +#define MODULE_CLKCTRL_MODULEMODE_SHIFT 0 +#define MODULE_CLKCTRL_MODULEMODE_MASK 3 +#define MODULE_CLKCTRL_IDLEST_SHIFT 16 +#define MODULE_CLKCTRL_IDLEST_MASK (3 << 16) + +#define MODULE_CLKCTRL_MODULEMODE_SW_DISABLE 0 +#define MODULE_CLKCTRL_MODULEMODE_HW_AUTO 1 +#define MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN 2 + +#define MODULE_CLKCTRL_IDLEST_FULLY_FUNCTIONAL 0 +#define MODULE_CLKCTRL_IDLEST_TRANSITIONING 1 +#define MODULE_CLKCTRL_IDLEST_IDLE 2 +#define MODULE_CLKCTRL_IDLEST_DISABLED 3 + +/* CM_L4PER_GPIO4_CLKCTRL */ +#define GPIO4_CLKCTRL_OPTFCLKEN_MASK (1 << 8) + +/* CM_L3INIT_HSMMCn_CLKCTRL */ +#define HSMMC_CLKCTRL_CLKSEL_MASK (1 << 24) + +/* CM_WKUP_GPTIMER1_CLKCTRL */ +#define GPTIMER1_CLKCTRL_CLKSEL_MASK (1 << 24) + +/* CM_CAM_ISS_CLKCTRL */ +#define ISS_CLKCTRL_OPTFCLKEN_MASK (1 << 8) + +/* CM_DSS_DSS_CLKCTRL */ +#define DSS_CLKCTRL_OPTFCLKEN_MASK 0xF00 + +/* CM_L3INIT_USBPHY_CLKCTRL */ +#define USBPHY_CLKCTRL_OPTFCLKEN_PHY_48M_MASK 8 + +/* Clock frequencies */ +#define OMAP_SYS_CLK_FREQ_38_4_MHZ 38400000 +#define OMAP_SYS_CLK_IND_38_4_MHZ 6 +#define OMAP_32K_CLK_FREQ 32768 + +/* PRM_VC_CFG_I2C_CLK */ +#define PRM_VC_CFG_I2C_CLK_SCLH_SHIFT 0 +#define PRM_VC_CFG_I2C_CLK_SCLH_MASK 0xFF +#define PRM_VC_CFG_I2C_CLK_SCLL_SHIFT 8 +#define PRM_VC_CFG_I2C_CLK_SCLL_MASK (0xFF << 8) + +/* PRM_VC_VAL_BYPASS */ +#define PRM_VC_I2C_CHANNEL_FREQ_KHZ 400 + +#define PRM_VC_VAL_BYPASS_VALID_BIT 0x1000000 +#define PRM_VC_VAL_BYPASS_SLAVEADDR_SHIFT 0 +#define PRM_VC_VAL_BYPASS_SLAVEADDR_MASK 0x7F +#define PRM_VC_VAL_BYPASS_REGADDR_SHIFT 8 +#define PRM_VC_VAL_BYPASS_REGADDR_MASK 0xFF +#define PRM_VC_VAL_BYPASS_DATA_SHIFT 16 +#define PRM_VC_VAL_BYPASS_DATA_MASK 0xFF + +#define SMPS_I2C_SLAVE_ADDR 0x12 +#define SMPS_REG_ADDR_VCORE1 0x55 +#define SMPS_REG_ADDR_VCORE2 0x5B +#define SMPS_REG_ADDR_VCORE3 0x61 + +#define PHOENIX_SMPS_BASE_VOLT_STD_MODE_UV 607700 +#define PHOENIX_SMPS_BASE_VOLT_STD_MODE_WITH_OFFSET_UV 709000 + +/* Defines for DPLL setup */ +#define DPLL_LOCKED_FREQ_TOLERANCE_0 0 +#define DPLL_LOCKED_FREQ_TOLERANCE_500_KHZ 500 +#define DPLL_LOCKED_FREQ_TOLERANCE_1_MHZ 1000 + +#define DPLL_NO_LOCK 0 +#define DPLL_LOCK 1 + +#define NUM_SYS_CLKS 7 + +struct dpll_regs { + u32 cm_clkmode_dpll; + u32 cm_idlest_dpll; + u32 cm_autoidle_dpll; + u32 cm_clksel_dpll; + u32 cm_div_m2_dpll; + u32 cm_div_m3_dpll; + u32 cm_div_m4_dpll; + u32 cm_div_m5_dpll; + u32 cm_div_m6_dpll; + u32 cm_div_m7_dpll; +}; + +/* DPLL parameter table */ +struct dpll_params { + u32 m; + u32 n; + u8 m2; + u8 m3; + u8 m4; + u8 m5; + u8 m6; + u8 m7; +}; + +#endif /* _CLOCKS_OMAP4_H_ */ diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index c10fa18..f871921 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -22,6 +22,7 @@ #define _SYS_PROTO_H_
#include <asm/arch/omap4.h> +#include <asm/arch/clocks.h> #include <asm/io.h> #include <asm/omap_common.h> #include <asm/arch/mux_omap4.h> @@ -31,6 +32,8 @@ struct omap_sysinfo { }; extern const struct omap_sysinfo sysinfo;
+extern struct omap4_prcm_regs *const prcm; + void gpmc_init(void); void watchdog_init(void); u32 get_device_type(void); @@ -41,6 +44,11 @@ u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); void set_pl310_ctrl_reg(u32 val); void omap_rev_string(char *omap4_rev_string); +void prcm_init(void); +void bypass_dpll(u32 *const base); +void freq_update_core(void); +u32 get_sys_clk_freq(void); +u32 omap4_ddr_clk(void);
static inline u32 running_from_sdram(void) { diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index d80f665..33caa4e 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -25,6 +25,9 @@ #ifndef _OMAP_COMMON_H_ #define _OMAP_COMMON_H_
+/* Max value for DPLL multiplier M */ +#define OMAP_DPLL_MAX_N 127 + /* HW Init Context */ #define OMAP_INIT_CONTEXT_SPL 0 #define OMAP_INIT_CONTEXT_UBOOT_FROM_NOR 1 diff --git a/tools/omap/clocks_get_m_n.c b/tools/omap/clocks_get_m_n.c new file mode 100644 index 0000000..cfc1760 --- /dev/null +++ b/tools/omap/clocks_get_m_n.c @@ -0,0 +1,197 @@ +/* + * Program for finding M & N values for DPLLs + * To be run on Host PC + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <stdlib.h> +#include <stdio.h> +typedef unsigned int u32; +#define MAX_N 127 + +/* + * get_m_n_optimized() - Finds optimal DPLL multiplier(M) and divider(N) + * values based on the reference frequency, required output frequency, + * maximum tolerance for output frequency etc. + * + * target_freq_khz - output frequency required in KHz + * ref_freq_khz - reference(input) frequency in KHz + * m - pointer to computed M value + * n - pointer to computed N value + * tolerance_khz - tolerance for the output frequency. When the algorithm + * succeeds in finding vialble M and N values the corresponding output + * frequency will be in the range: + * [target_freq_khz - tolerance_khz, target_freq_khz] + * + * Formula: + * Fdpll = (2 * M * Fref) / (N + 1) + * + * Considerations for lock-time: + * - Smaller the N, better lock-time, especially lock-time will be + * - For acceptable lock-times: + * Fref / (M + 1) >= 1 MHz + * + * Considerations for power: + * - The difference in power for different N values giving the same + * output is negligible. So, we optimize for lock-time + * + * Hard-constraints: + * - N can not be greater than 127(7 bit field for representing N) + * + * Usage: + * $ gcc clocks_get_m_n.c + * $ ./a.out + */ +int get_m_n_optimized(u32 target_freq_khz, u32 ref_freq_khz, u32 *m, u32 *n, + u32 tolerance_khz) +{ + u32 min_freq = target_freq_khz - tolerance_khz; + u32 max_freq = target_freq_khz; + u32 freq, freq_old; + *n = 1; + while (1) { + *m = min_freq / ref_freq_khz / 2 * (*n) ; + freq_old = 0; + while (1) { + freq = ref_freq_khz * 2 * (*m) / (*n); + if (abs(target_freq_khz - freq_old) <= + abs(target_freq_khz - freq)) { + freq = freq_old; + (*m)--; + break; + } + (*m)++; + freq_old = freq; + } + if (freq >= min_freq && freq <= max_freq) + break; + (*n)++; + if ((*n) > MAX_N + 1) { + printf("ref %d m %d n %d target %d : ", + ref_freq_khz, *m, *n, target_freq_khz); + printf("can not find m & n - please consider" + " increasing tolerance\n"); + return -1; + } + } + (*n)--; + printf("ref %d m %d n %d target %d locked %d\n", + ref_freq_khz, *m, *n, target_freq_khz, freq); + if ((ref_freq_khz / (*n + 1)) < 1000) { + printf("\tREFCLK - CLKINP/(N+1) is less than 1 MHz - less than" + " ideal, locking time will be high!\n"); + } + return 0; +} + +void main(void) +{ + u32 m, n; + printf("\nMPU - 2000000\n"); + get_m_n_optimized(2000000, 12000, &m, &n, 0); + get_m_n_optimized(2000000, 13000, &m, &n, 0); + get_m_n_optimized(2000000, 16800, &m, &n, 800); + get_m_n_optimized(2000000, 19200, &m, &n, 0); + get_m_n_optimized(2000000, 26000, &m, &n, 0); + get_m_n_optimized(2000000, 27000, &m, &n, 0); + get_m_n_optimized(2000000, 38400, &m, &n, 0); + + printf("\nMPU - 1200000\n"); + get_m_n_optimized(1200000, 12000, &m, &n, 0); + get_m_n_optimized(1200000, 13000, &m, &n, 0); + get_m_n_optimized(1200000, 16800, &m, &n, 800); + get_m_n_optimized(1200000, 19200, &m, &n, 0); + get_m_n_optimized(1200000, 26000, &m, &n, 0); + get_m_n_optimized(1200000, 27000, &m, &n, 0); + get_m_n_optimized(1200000, 38400, &m, &n, 0); + + printf("\nMPU - 1584000\n"); + get_m_n_optimized(1584000, 12000, &m, &n, 0); + get_m_n_optimized(1584000, 13000, &m, &n, 0); + get_m_n_optimized(1584000, 16800, &m, &n, 400); + get_m_n_optimized(1584000, 19200, &m, &n, 0); + get_m_n_optimized(1584000, 26000, &m, &n, 0); + get_m_n_optimized(1584000, 27000, &m, &n, 0); + get_m_n_optimized(1584000, 38400, &m, &n, 0); + + printf("\nCore 1600000\n"); + get_m_n_optimized(1600000, 12000, &m, &n, 0); + get_m_n_optimized(1600000, 13000, &m, &n, 0); + get_m_n_optimized(1600000, 16800, &m, &n, 200); + get_m_n_optimized(1600000, 19200, &m, &n, 0); + get_m_n_optimized(1600000, 26000, &m, &n, 0); + get_m_n_optimized(1600000, 27000, &m, &n, 0); + get_m_n_optimized(1600000, 38400, &m, &n, 0); + + printf("\nPER 1536000\n"); + get_m_n_optimized(1536000, 12000, &m, &n, 0); + get_m_n_optimized(1536000, 13000, &m, &n, 0); + get_m_n_optimized(1536000, 16800, &m, &n, 0); + get_m_n_optimized(1536000, 19200, &m, &n, 0); + get_m_n_optimized(1536000, 26000, &m, &n, 0); + get_m_n_optimized(1536000, 27000, &m, &n, 0); + get_m_n_optimized(1536000, 38400, &m, &n, 0); + + printf("\nIVA 1862000\n"); + get_m_n_optimized(1862000, 12000, &m, &n, 0); + get_m_n_optimized(1862000, 13000, &m, &n, 0); + get_m_n_optimized(1862000, 16800, &m, &n, 0); + get_m_n_optimized(1862000, 19200, &m, &n, 900); + get_m_n_optimized(1862000, 26000, &m, &n, 0); + get_m_n_optimized(1862000, 27000, &m, &n, 0); + get_m_n_optimized(1862000, 38400, &m, &n, 800); + + printf("\nABE 196608 sys clk\n"); + get_m_n_optimized(196608, 12000, &m, &n, 700); + get_m_n_optimized(196608, 13000, &m, &n, 200); + get_m_n_optimized(196608, 16800, &m, &n, 700); + get_m_n_optimized(196608, 19200, &m, &n, 400); + get_m_n_optimized(196608, 26000, &m, &n, 200); + get_m_n_optimized(196608, 27000, &m, &n, 900); + get_m_n_optimized(196608, 38400, &m, &n, 0); + + printf("\nABE 196608 32K\n"); + get_m_n_optimized(196608000/4, 32768, &m, &n, 0); + + printf("\nUSB 1920000\n"); + get_m_n_optimized(1920000, 12000, &m, &n, 0); + get_m_n_optimized(1920000, 13000, &m, &n, 0); + get_m_n_optimized(1920000, 16800, &m, &n, 0); + get_m_n_optimized(1920000, 19200, &m, &n, 0); + get_m_n_optimized(1920000, 26000, &m, &n, 0); + get_m_n_optimized(1920000, 27000, &m, &n, 0); + get_m_n_optimized(1920000, 38400, &m, &n, 0); + + printf("\nCore ES1 1523712\n"); + get_m_n_optimized(1524000, 12000, &m, &n, 100); + get_m_n_optimized(1524000, 13000, &m, &n, 0); + get_m_n_optimized(1524000, 16800, &m, &n, 0); + get_m_n_optimized(1524000, 19200, &m, &n, 0); + get_m_n_optimized(1524000, 26000, &m, &n, 0); + get_m_n_optimized(1524000, 27000, &m, &n, 0); + + /* exact recommendation for SDPs */ + get_m_n_optimized(1523712, 38400, &m, &n, 0); + +}
Add support for the SDRAM controller (EMIF).
Signed-off-by: Aneesh V aneesh@ti.com --- V2: * Minor corrections in do_lpddr2_init() * Minor corrections to read_idle interval calculation * Sanity test of memory after doing the initialization * Fixed warnings reported with with latest GCC compilers V3: * Removed references to modify_reg_32() * Updated references to OMAP_INIT_CONTEXT_* flags * Replaced calls to omap4_revision() with omap_revision() * Replaced sanity test with get_ram_size() --- arch/arm/cpu/armv7/omap4/Makefile | 2 + arch/arm/cpu/armv7/omap4/board.c | 6 +- arch/arm/cpu/armv7/omap4/emif.c | 328 +++++++++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 131 ++++ arch/arm/include/asm/arch-omap4/clocks.h | 8 +- arch/arm/include/asm/arch-omap4/emif.h | 1025 +++++++++++++++++++++++++++ arch/arm/include/asm/arch-omap4/omap4.h | 5 + arch/arm/include/asm/arch-omap4/sys_proto.h | 2 + 8 files changed, 1500 insertions(+), 7 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/emif.c create mode 100644 arch/arm/cpu/armv7/omap4/sdram_elpida.c create mode 100644 arch/arm/include/asm/arch-omap4/emif.h
diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index ac4b2a6..e1ccd68 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -29,7 +29,9 @@ SOBJS += lowlevel_init.o
COBJS += board.o COBJS += clocks.o +COBJS += emif.o COBJS += mem.o +COBJS += sdram_elpida.o COBJS += sys_info.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 1c26a66..ca107f7 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -189,7 +189,7 @@ void watchdog_init(void) * This is needed because the size of memory installed may be * different on different versions of the board */ -u32 sdram_size(void) +u32 omap4_sdram_size(void) { u32 section, i, total_size = 0, size, addr; for (i = 0; i < 4; i++) { @@ -215,8 +215,8 @@ u32 sdram_size(void) */ int dram_init(void) { - - gd->ram_size = sdram_size(); + sdram_init(); + gd->ram_size = omap4_sdram_size();
return 0; } diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c new file mode 100644 index 0000000..b25c1ee --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -0,0 +1,328 @@ +/* + * EMIF programming + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/arch/emif.h> +#include <asm/arch/clocks.h> +#include <asm/arch/sys_proto.h> +#include <asm/omap_common.h> +#include <asm/utils.h> + +static inline u32 emif_num(u32 base) +{ + if (base == OMAP44XX_EMIF1) + return 1; + else if (base == OMAP44XX_EMIF2) + return 2; + else + return 0; +} + +static inline u32 get_mr(u32 base, u32 cs, u32 mr_addr) +{ + u32 mr; + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + mr_addr |= cs << OMAP44XX_REG_CS_SHIFT; + writel(mr_addr, &emif->emif_lpddr2_mode_reg_cfg); + if (omap_revision() == OMAP4430_ES2_0) + mr = readl(&emif->emif_lpddr2_mode_reg_data_es2); + else + mr = readl(&emif->emif_lpddr2_mode_reg_data); + debug("get_mr: EMIF%d cs %d mr %08x val 0x%x\n", emif_num(base), + cs, mr_addr, mr); + return mr; +} + +static inline void set_mr(u32 base, u32 cs, u32 mr_addr, u32 mr_val) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + mr_addr |= cs << OMAP44XX_REG_CS_SHIFT; + writel(mr_addr, &emif->emif_lpddr2_mode_reg_cfg); + writel(mr_val, &emif->emif_lpddr2_mode_reg_data); +} + +void emif_reset_phy(u32 base) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + u32 iodft; + + iodft = readl(&emif->emif_iodft_tlgc); + iodft |= OMAP44XX_REG_RESET_PHY_MASK; + writel(iodft, &emif->emif_iodft_tlgc); +} + +static void do_lpddr2_init(u32 base, u32 cs) +{ + u32 mr_addr; + + /* Wait till device auto initialization is complete */ + while (get_mr(base, cs, LPDDR2_MR0) & LPDDR2_MR0_DAI_MASK) + ; + set_mr(base, cs, LPDDR2_MR10, MR10_ZQ_ZQINIT); + /* + * tZQINIT = 1 us + * Enough loops assuming a maximum of 2GHz + */ + sdelay(2000); + set_mr(base, cs, LPDDR2_MR1, MR1_BL_8_BT_SEQ_WRAP_EN_NWR_3); + set_mr(base, cs, LPDDR2_MR16, MR16_REF_FULL_ARRAY); + /* + * Enable refresh along with writing MR2 + * Encoding of RL in MR2 is (RL - 2) + */ + mr_addr = LPDDR2_MR2 | OMAP44XX_REG_REFRESH_EN_MASK; + set_mr(base, cs, mr_addr, RL_FINAL - 2); +} + +static void lpddr2_init(u32 base, const struct emif_regs *regs) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + /* Not NVM */ + clrbits_le32(&emif->emif_lpddr2_nvm_config, OMAP44XX_REG_CS1NVMEN_MASK); + + /* + * Keep REG_INITREF_DIS = 1 to prevent re-initialization of SDRAM + * when EMIF_SDRAM_CONFIG register is written + */ + setbits_le32(&emif->emif_sdram_ref_ctrl, OMAP44XX_REG_INITREF_DIS_MASK); + + /* + * Set the SDRAM_CONFIG and PHY_CTRL for the + * un-locked frequency & default RL + */ + writel(regs->sdram_config_init, &emif->emif_sdram_config); + writel(regs->emif_ddr_phy_ctlr_1_init, &emif->emif_ddr_phy_ctrl_1); + + do_lpddr2_init(base, CS0); + if (regs->sdram_config & OMAP44XX_REG_EBANK_MASK) + do_lpddr2_init(base, CS1); + + writel(regs->sdram_config, &emif->emif_sdram_config); + writel(regs->emif_ddr_phy_ctlr_1, &emif->emif_ddr_phy_ctrl_1); + + /* Enable refresh now */ + clrbits_le32(&emif->emif_sdram_ref_ctrl, OMAP44XX_REG_INITREF_DIS_MASK); + +} + +static void emif_update_timings(u32 base, const struct emif_regs *regs) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + writel(regs->ref_ctrl, &emif->emif_sdram_ref_ctrl_shdw); + writel(regs->sdram_tim1, &emif->emif_sdram_tim_1_shdw); + writel(regs->sdram_tim2, &emif->emif_sdram_tim_2_shdw); + writel(regs->sdram_tim3, &emif->emif_sdram_tim_3_shdw); + if (omap_revision() == OMAP4430_ES1_0) { + /* ES1 bug EMIF should be in force idle during freq_update */ + writel(0, &emif->emif_pwr_mgmt_ctrl); + } else { + writel(EMIF_PWR_MGMT_CTRL, &emif->emif_pwr_mgmt_ctrl); + writel(EMIF_PWR_MGMT_CTRL_SHDW, &emif->emif_pwr_mgmt_ctrl_shdw); + } + writel(regs->read_idle_ctrl, &emif->emif_read_idlectrl_shdw); + writel(regs->zq_config, &emif->emif_zq_config); + writel(regs->temp_alert_config, &emif->emif_temp_alert_config); + writel(regs->emif_ddr_phy_ctlr_1, &emif->emif_ddr_phy_ctrl_1_shdw); + /* + * Workaround: + * In a specific situation, the OCP interface between the DMM and + * EMIF may hang. + * 1. A TILER port is used to perform 2D burst writes of + * width 1 and height 8 + * 2. ELLAn port is used to perform reads + * 3. All accesses are routed to the same EMIF controller + * + * Work around to avoid this issue REG_SYS_THRESH_MAX value should + * be kept higher than default 0x7. As per recommondation 0x0A will + * be used for better performance with REG_LL_THRESH_MAX = 0x00 + */ + if (omap_revision() == OMAP4430_ES1_0) { + writel(EMIF_L3_CONFIG_VAL_SYS_THRESH_0A_LL_THRESH_00, + &emif->emif_l3_config); + } +} + +static void do_sdram_init(u32 base) +{ + const struct emif_regs *regs; + u32 in_sdram, emif_nr; + + debug(">>do_sdram_init() %x\n", base); + + in_sdram = running_from_sdram(); + emif_nr = (base == OMAP44XX_EMIF1) ? 1 : 2; + + emif_get_reg_dump(emif_nr, ®s); + if (!regs) { + debug("EMIF: reg dump not provided\n"); + return; + } + + /* + * Initializing the LPDDR2 device can not happen from SDRAM. + * Changing the timing registers in EMIF can happen(going from one + * OPP to another) + */ + if (!in_sdram) + lpddr2_init(base, regs); + + /* Write to the shadow registers */ + emif_update_timings(base, regs); + + debug("<<do_sdram_init() %x\n", base); +} + +void sdram_init_pads(void) +{ + u32 lpddr2io; + struct control_lpddr2io_regs *lpddr2io_regs = + (struct control_lpddr2io_regs *)LPDDR2_IO_REGS_BASE; + u32 omap4_rev = omap_revision(); + + if (omap4_rev == OMAP4430_ES1_0) + lpddr2io = CONTROL_LPDDR2IO_SLEW_125PS_DRV8_PULL_DOWN; + else if (omap4_rev == OMAP4430_ES2_0) + lpddr2io = CONTROL_LPDDR2IO_SLEW_325PS_DRV8_GATE_KEEPER; + else + return; /* Post ES2.1 reset values will work */ + + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io1_0); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io1_1); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io1_2); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io2_0); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io2_1); + writel(lpddr2io, &lpddr2io_regs->control_lpddr2io2_2); + + writel(CONTROL_EFUSE_2_NMOS_PMOS_PTV_CODE_1, CONTROL_EFUSE_2); +} + +static void emif_post_init_config(u32 base) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + u32 omap4_rev = omap_revision(); + + /* reset phy on ES2.0 */ + if (omap4_rev == OMAP4430_ES2_0) + emif_reset_phy(base); + + /* Put EMIF back in smart idle on ES1.0 */ + if (omap4_rev == OMAP4430_ES1_0) + writel(0x80000000, &emif->emif_pwr_mgmt_ctrl); +} + +static void dmm_init(u32 base) +{ + const struct dmm_lisa_map_regs *lisa_map_regs; + + emif_get_dmm_regs(&lisa_map_regs); + + struct dmm_lisa_map_regs *hw_lisa_map_regs = + (struct dmm_lisa_map_regs *)base; + + writel(0, &hw_lisa_map_regs->dmm_lisa_map_3); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_2); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_1); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_0); + + writel(lisa_map_regs->dmm_lisa_map_3, + &hw_lisa_map_regs->dmm_lisa_map_3); + writel(lisa_map_regs->dmm_lisa_map_2, + &hw_lisa_map_regs->dmm_lisa_map_2); + writel(lisa_map_regs->dmm_lisa_map_1, + &hw_lisa_map_regs->dmm_lisa_map_1); + writel(lisa_map_regs->dmm_lisa_map_0, + &hw_lisa_map_regs->dmm_lisa_map_0); +} + +/* + * SDRAM initialization: + * SDRAM initialization has two parts: + * 1. Configuring the SDRAM device + * 2. Update the AC timings related parameters in the EMIF module + * (1) should be done only once and should not be done while we are + * running from SDRAM. + * (2) can and should be done more than once if OPP changes. + * Particularly, this may be needed when we boot without SPL and + * and using Configuration Header(CH). ROM code supports only at 50% OPP + * at boot (low power boot). So u-boot has to switch to OPP100 and update + * the frequency. So, + * Doing (1) and (2) makes sense - first time initialization + * Doing (2) and not (1) makes sense - OPP change (when using CH) + * Doing (1) and not (2) doen't make sense + * See do_sdram_init() for the details + */ +void sdram_init(void) +{ + u32 in_sdram, size_prog, size_detect; + + debug(">>sdram_init()\n"); + + if (omap4_hw_init_context() == OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL) + return; + + in_sdram = running_from_sdram(); + debug("in_sdram = %d\n", in_sdram); + + if (!in_sdram) { + sdram_init_pads(); + bypass_dpll(&prcm->cm_clkmode_dpll_core); + } + + do_sdram_init(OMAP44XX_EMIF1); + do_sdram_init(OMAP44XX_EMIF2); + + if (!in_sdram) { + dmm_init(OMAP44XX_DMM_LISA_MAP_BASE); + emif_post_init_config(OMAP44XX_EMIF1); + emif_post_init_config(OMAP44XX_EMIF2); + + } + + /* for the shadow registers to take effect */ + freq_update_core(); + + /* Do some testing after the init */ + if (!in_sdram) { + size_prog = omap4_sdram_size(); + size_detect = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, + size_prog); + /* Compare with the size programmed */ + if (size_detect != size_prog) { + printf("SDRAM: identified size not same as expected" + " size identified: %x expected: %x\n", + size_detect, + size_prog); + } else + debug("get_ram_size() successful"); + } + + debug("<<sdram_init()\n"); +} diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c new file mode 100644 index 0000000..c950c87 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -0,0 +1,131 @@ +/* + * Timing and Organization details of the Elpida parts used in OMAP4 + * SDPs and Panda + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <asm/arch/emif.h> +#include <asm/arch/sys_proto.h> + +/* + * This file provides details of the LPDDR2 SDRAM parts used on OMAP4430 + * SDP and Panda. Since the parts used and geometry are identical for + * SDP and Panda for a given OMAP4 revision, this information is kept + * here instead of being in board directory. However the key functions + * exported are weakly linked so that they can be over-ridden in the board + * directory if there is a OMAP4 board in the future that uses a different + * memory device or geometry. + * + * For any new board with different memory devices over-ride one or more + * of the following functions as per the CONFIG flags you intend to enable: + * - emif_get_reg_dump() + * - emif_get_dmm_regs() + * - emif_get_device_details() + * - emif_get_device_timings() + */ + +static const struct emif_regs emif_regs_elpida_200_mhz_2cs = { + .sdram_config_init = 0x80000eb9, + .sdram_config = 0x80001ab9, + .ref_ctrl = 0x0000030c, + .sdram_tim1 = 0x08648311, + .sdram_tim2 = 0x101b06ca, + .sdram_tim3 = 0x0048a19f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0x500b3214, + .temp_alert_config = 0xd8016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff808 +}; + +static const struct emif_regs emif_regs_elpida_380_mhz_1cs = { + .sdram_config_init = 0x80000eb1, + .sdram_config = 0x80001ab1, + .ref_ctrl = 0x000005cd, + .sdram_tim1 = 0x10cb0622, + .sdram_tim2 = 0x20350d52, + .sdram_tim3 = 0x00b1431f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0x500b3214, + .temp_alert_config = 0x58016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff418 +}; + +const struct emif_regs emif_regs_elpida_400_mhz_2cs = { + .sdram_config_init = 0x80000eb9, + .sdram_config = 0x80001ab9, + .ref_ctrl = 0x00000618, + .sdram_tim1 = 0x10eb0662, + .sdram_tim2 = 0x20370dd2, + .sdram_tim3 = 0x00b1c33f, + .read_idle_ctrl = 0x000501ff, + .zq_config = 0xd00b3214, + .temp_alert_config = 0xd8016893, + .emif_ddr_phy_ctlr_1_init = 0x049ffff5, + .emif_ddr_phy_ctlr_1 = 0x049ff418 +}; +const struct dmm_lisa_map_regs lisa_map_2G_x_1_x_2 = { + .dmm_lisa_map_0 = 0xFF020100, + .dmm_lisa_map_1 = 0, + .dmm_lisa_map_2 = 0, + .dmm_lisa_map_3 = 0x80540300 +}; + +const struct dmm_lisa_map_regs lisa_map_2G_x_2_x_2 = { + .dmm_lisa_map_0 = 0xFF020100, + .dmm_lisa_map_1 = 0, + .dmm_lisa_map_2 = 0, + .dmm_lisa_map_3 = 0x80640300 +}; + +static void emif_get_reg_dump_sdp(u32 emif_nr, const struct emif_regs **regs) +{ + u32 omap4_rev = omap_revision(); + + /* Same devices and geometry on both EMIFs */ + if (omap4_rev == OMAP4430_ES1_0) + *regs = &emif_regs_elpida_380_mhz_1cs; + else if (omap4_rev == OMAP4430_ES2_0) + *regs = &emif_regs_elpida_200_mhz_2cs; + else + *regs = &emif_regs_elpida_400_mhz_2cs; +} +void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs) + __attribute__((weak, alias("emif_get_reg_dump_sdp"))); + +static void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs + **dmm_lisa_regs) +{ + u32 omap_rev = omap_revision(); + + if (omap_rev == OMAP4430_ES1_0) + *dmm_lisa_regs = &lisa_map_2G_x_1_x_2; + else + *dmm_lisa_regs = &lisa_map_2G_x_2_x_2; +} + +void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) + __attribute__((weak, alias("emif_get_dmm_regs_sdp"))); diff --git a/arch/arm/include/asm/arch-omap4/clocks.h b/arch/arm/include/asm/arch-omap4/clocks.h index 71db39c..37bdcee 100644 --- a/arch/arm/include/asm/arch-omap4/clocks.h +++ b/arch/arm/include/asm/arch-omap4/clocks.h @@ -33,10 +33,10 @@ */ #define LDELAY 1000000
-#define CM_CLKMODE_DPLL_CORE (OMAP44XX_L4_CORE_BASE + 0x4120) -#define CM_CLKMODE_DPLL_PER (OMAP44XX_L4_CORE_BASE + 0x8140) -#define CM_CLKMODE_DPLL_MPU (OMAP44XX_L4_CORE_BASE + 0x4160) -#define CM_CLKSEL_CORE (OMAP44XX_L4_CORE_BASE + 0x4100) +#define CM_CLKMODE_DPLL_CORE 0x4A004120 +#define CM_CLKMODE_DPLL_PER 0x4A008140 +#define CM_CLKMODE_DPLL_MPU 0x4A004160 +#define CM_CLKSEL_CORE 0x4A004100
struct omap4_prcm_regs { /* cm1.ckgen */ diff --git a/arch/arm/include/asm/arch-omap4/emif.h b/arch/arm/include/asm/arch-omap4/emif.h new file mode 100644 index 0000000..09e9baa --- /dev/null +++ b/arch/arm/include/asm/arch-omap4/emif.h @@ -0,0 +1,1025 @@ +/* + * OMAP44xx EMIF header + * + * Copyright (C) 2009-2010 Texas Instruments, Inc. + * + * Aneesh V aneesh@ti.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#ifndef _EMIF_H_ +#define _EMIF_H_ +#include <asm/types.h> +#include <common.h> + +/* Base address */ +#define OMAP44XX_EMIF1 0x4c000000 +#define OMAP44XX_EMIF2 0x4d000000 + +/* Registers shifts and masks */ + +/* EMIF_MOD_ID_REV */ +#define OMAP44XX_REG_SCHEME_SHIFT 30 +#define OMAP44XX_REG_SCHEME_MASK (0x3 << 30) +#define OMAP44XX_REG_MODULE_ID_SHIFT 16 +#define OMAP44XX_REG_MODULE_ID_MASK (0xfff << 16) +#define OMAP44XX_REG_RTL_VERSION_SHIFT 11 +#define OMAP44XX_REG_RTL_VERSION_MASK (0x1f << 11) +#define OMAP44XX_REG_MAJOR_REVISION_SHIFT 8 +#define OMAP44XX_REG_MAJOR_REVISION_MASK (0x7 << 8) +#define OMAP44XX_REG_MINOR_REVISION_SHIFT 0 +#define OMAP44XX_REG_MINOR_REVISION_MASK (0x3f << 0) + +/* STATUS */ +#define OMAP44XX_REG_BE_SHIFT 31 +#define OMAP44XX_REG_BE_MASK (1 << 31) +#define OMAP44XX_REG_DUAL_CLK_MODE_SHIFT 30 +#define OMAP44XX_REG_DUAL_CLK_MODE_MASK (1 << 30) +#define OMAP44XX_REG_FAST_INIT_SHIFT 29 +#define OMAP44XX_REG_FAST_INIT_MASK (1 << 29) +#define OMAP44XX_REG_PHY_DLL_READY_SHIFT 2 +#define OMAP44XX_REG_PHY_DLL_READY_MASK (1 << 2) + +/* SDRAM_CONFIG */ +#define OMAP44XX_REG_SDRAM_TYPE_SHIFT 29 +#define OMAP44XX_REG_SDRAM_TYPE_MASK (0x7 << 29) +#define OMAP44XX_REG_IBANK_POS_SHIFT 27 +#define OMAP44XX_REG_IBANK_POS_MASK (0x3 << 27) +#define OMAP44XX_REG_DDR_TERM_SHIFT 24 +#define OMAP44XX_REG_DDR_TERM_MASK (0x7 << 24) +#define OMAP44XX_REG_DDR2_DDQS_SHIFT 23 +#define OMAP44XX_REG_DDR2_DDQS_MASK (1 << 23) +#define OMAP44XX_REG_DYN_ODT_SHIFT 21 +#define OMAP44XX_REG_DYN_ODT_MASK (0x3 << 21) +#define OMAP44XX_REG_DDR_DISABLE_DLL_SHIFT 20 +#define OMAP44XX_REG_DDR_DISABLE_DLL_MASK (1 << 20) +#define OMAP44XX_REG_SDRAM_DRIVE_SHIFT 18 +#define OMAP44XX_REG_SDRAM_DRIVE_MASK (0x3 << 18) +#define OMAP44XX_REG_CWL_SHIFT 16 +#define OMAP44XX_REG_CWL_MASK (0x3 << 16) +#define OMAP44XX_REG_NARROW_MODE_SHIFT 14 +#define OMAP44XX_REG_NARROW_MODE_MASK (0x3 << 14) +#define OMAP44XX_REG_CL_SHIFT 10 +#define OMAP44XX_REG_CL_MASK (0xf << 10) +#define OMAP44XX_REG_ROWSIZE_SHIFT 7 +#define OMAP44XX_REG_ROWSIZE_MASK (0x7 << 7) +#define OMAP44XX_REG_IBANK_SHIFT 4 +#define OMAP44XX_REG_IBANK_MASK (0x7 << 4) +#define OMAP44XX_REG_EBANK_SHIFT 3 +#define OMAP44XX_REG_EBANK_MASK (1 << 3) +#define OMAP44XX_REG_PAGESIZE_SHIFT 0 +#define OMAP44XX_REG_PAGESIZE_MASK (0x7 << 0) + +/* SDRAM_CONFIG_2 */ +#define OMAP44XX_REG_CS1NVMEN_SHIFT 30 +#define OMAP44XX_REG_CS1NVMEN_MASK (1 << 30) +#define OMAP44XX_REG_EBANK_POS_SHIFT 27 +#define OMAP44XX_REG_EBANK_POS_MASK (1 << 27) +#define OMAP44XX_REG_RDBNUM_SHIFT 4 +#define OMAP44XX_REG_RDBNUM_MASK (0x3 << 4) +#define OMAP44XX_REG_RDBSIZE_SHIFT 0 +#define OMAP44XX_REG_RDBSIZE_MASK (0x7 << 0) + +/* SDRAM_REF_CTRL */ +#define OMAP44XX_REG_INITREF_DIS_SHIFT 31 +#define OMAP44XX_REG_INITREF_DIS_MASK (1 << 31) +#define OMAP44XX_REG_SRT_SHIFT 29 +#define OMAP44XX_REG_SRT_MASK (1 << 29) +#define OMAP44XX_REG_ASR_SHIFT 28 +#define OMAP44XX_REG_ASR_MASK (1 << 28) +#define OMAP44XX_REG_PASR_SHIFT 24 +#define OMAP44XX_REG_PASR_MASK (0x7 << 24) +#define OMAP44XX_REG_REFRESH_RATE_SHIFT 0 +#define OMAP44XX_REG_REFRESH_RATE_MASK (0xffff << 0) + +/* SDRAM_REF_CTRL_SHDW */ +#define OMAP44XX_REG_REFRESH_RATE_SHDW_SHIFT 0 +#define OMAP44XX_REG_REFRESH_RATE_SHDW_MASK (0xffff << 0) + +/* SDRAM_TIM_1 */ +#define OMAP44XX_REG_T_RP_SHIFT 25 +#define OMAP44XX_REG_T_RP_MASK (0xf << 25) +#define OMAP44XX_REG_T_RCD_SHIFT 21 +#define OMAP44XX_REG_T_RCD_MASK (0xf << 21) +#define OMAP44XX_REG_T_WR_SHIFT 17 +#define OMAP44XX_REG_T_WR_MASK (0xf << 17) +#define OMAP44XX_REG_T_RAS_SHIFT 12 +#define OMAP44XX_REG_T_RAS_MASK (0x1f << 12) +#define OMAP44XX_REG_T_RC_SHIFT 6 +#define OMAP44XX_REG_T_RC_MASK (0x3f << 6) +#define OMAP44XX_REG_T_RRD_SHIFT 3 +#define OMAP44XX_REG_T_RRD_MASK (0x7 << 3) +#define OMAP44XX_REG_T_WTR_SHIFT 0 +#define OMAP44XX_REG_T_WTR_MASK (0x7 << 0) + +/* SDRAM_TIM_1_SHDW */ +#define OMAP44XX_REG_T_RP_SHDW_SHIFT 25 +#define OMAP44XX_REG_T_RP_SHDW_MASK (0xf << 25) +#define OMAP44XX_REG_T_RCD_SHDW_SHIFT 21 +#define OMAP44XX_REG_T_RCD_SHDW_MASK (0xf << 21) +#define OMAP44XX_REG_T_WR_SHDW_SHIFT 17 +#define OMAP44XX_REG_T_WR_SHDW_MASK (0xf << 17) +#define OMAP44XX_REG_T_RAS_SHDW_SHIFT 12 +#define OMAP44XX_REG_T_RAS_SHDW_MASK (0x1f << 12) +#define OMAP44XX_REG_T_RC_SHDW_SHIFT 6 +#define OMAP44XX_REG_T_RC_SHDW_MASK (0x3f << 6) +#define OMAP44XX_REG_T_RRD_SHDW_SHIFT 3 +#define OMAP44XX_REG_T_RRD_SHDW_MASK (0x7 << 3) +#define OMAP44XX_REG_T_WTR_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_WTR_SHDW_MASK (0x7 << 0) + +/* SDRAM_TIM_2 */ +#define OMAP44XX_REG_T_XP_SHIFT 28 +#define OMAP44XX_REG_T_XP_MASK (0x7 << 28) +#define OMAP44XX_REG_T_ODT_SHIFT 25 +#define OMAP44XX_REG_T_ODT_MASK (0x7 << 25) +#define OMAP44XX_REG_T_XSNR_SHIFT 16 +#define OMAP44XX_REG_T_XSNR_MASK (0x1ff << 16) +#define OMAP44XX_REG_T_XSRD_SHIFT 6 +#define OMAP44XX_REG_T_XSRD_MASK (0x3ff << 6) +#define OMAP44XX_REG_T_RTP_SHIFT 3 +#define OMAP44XX_REG_T_RTP_MASK (0x7 << 3) +#define OMAP44XX_REG_T_CKE_SHIFT 0 +#define OMAP44XX_REG_T_CKE_MASK (0x7 << 0) + +/* SDRAM_TIM_2_SHDW */ +#define OMAP44XX_REG_T_XP_SHDW_SHIFT 28 +#define OMAP44XX_REG_T_XP_SHDW_MASK (0x7 << 28) +#define OMAP44XX_REG_T_ODT_SHDW_SHIFT 25 +#define OMAP44XX_REG_T_ODT_SHDW_MASK (0x7 << 25) +#define OMAP44XX_REG_T_XSNR_SHDW_SHIFT 16 +#define OMAP44XX_REG_T_XSNR_SHDW_MASK (0x1ff << 16) +#define OMAP44XX_REG_T_XSRD_SHDW_SHIFT 6 +#define OMAP44XX_REG_T_XSRD_SHDW_MASK (0x3ff << 6) +#define OMAP44XX_REG_T_RTP_SHDW_SHIFT 3 +#define OMAP44XX_REG_T_RTP_SHDW_MASK (0x7 << 3) +#define OMAP44XX_REG_T_CKE_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_CKE_SHDW_MASK (0x7 << 0) + +/* SDRAM_TIM_3 */ +#define OMAP44XX_REG_T_CKESR_SHIFT 21 +#define OMAP44XX_REG_T_CKESR_MASK (0x7 << 21) +#define OMAP44XX_REG_ZQ_ZQCS_SHIFT 15 +#define OMAP44XX_REG_ZQ_ZQCS_MASK (0x3f << 15) +#define OMAP44XX_REG_T_TDQSCKMAX_SHIFT 13 +#define OMAP44XX_REG_T_TDQSCKMAX_MASK (0x3 << 13) +#define OMAP44XX_REG_T_RFC_SHIFT 4 +#define OMAP44XX_REG_T_RFC_MASK (0x1ff << 4) +#define OMAP44XX_REG_T_RAS_MAX_SHIFT 0 +#define OMAP44XX_REG_T_RAS_MAX_MASK (0xf << 0) + +/* SDRAM_TIM_3_SHDW */ +#define OMAP44XX_REG_T_CKESR_SHDW_SHIFT 21 +#define OMAP44XX_REG_T_CKESR_SHDW_MASK (0x7 << 21) +#define OMAP44XX_REG_ZQ_ZQCS_SHDW_SHIFT 15 +#define OMAP44XX_REG_ZQ_ZQCS_SHDW_MASK (0x3f << 15) +#define OMAP44XX_REG_T_TDQSCKMAX_SHDW_SHIFT 13 +#define OMAP44XX_REG_T_TDQSCKMAX_SHDW_MASK (0x3 << 13) +#define OMAP44XX_REG_T_RFC_SHDW_SHIFT 4 +#define OMAP44XX_REG_T_RFC_SHDW_MASK (0x1ff << 4) +#define OMAP44XX_REG_T_RAS_MAX_SHDW_SHIFT 0 +#define OMAP44XX_REG_T_RAS_MAX_SHDW_MASK (0xf << 0) + +/* LPDDR2_NVM_TIM */ +#define OMAP44XX_REG_NVM_T_XP_SHIFT 28 +#define OMAP44XX_REG_NVM_T_XP_MASK (0x7 << 28) +#define OMAP44XX_REG_NVM_T_WTR_SHIFT 24 +#define OMAP44XX_REG_NVM_T_WTR_MASK (0x7 << 24) +#define OMAP44XX_REG_NVM_T_RP_SHIFT 20 +#define OMAP44XX_REG_NVM_T_RP_MASK (0xf << 20) +#define OMAP44XX_REG_NVM_T_WRA_SHIFT 16 +#define OMAP44XX_REG_NVM_T_WRA_MASK (0xf << 16) +#define OMAP44XX_REG_NVM_T_RRD_SHIFT 8 +#define OMAP44XX_REG_NVM_T_RRD_MASK (0xff << 8) +#define OMAP44XX_REG_NVM_T_RCDMIN_SHIFT 0 +#define OMAP44XX_REG_NVM_T_RCDMIN_MASK (0xff << 0) + +/* LPDDR2_NVM_TIM_SHDW */ +#define OMAP44XX_REG_NVM_T_XP_SHDW_SHIFT 28 +#define OMAP44XX_REG_NVM_T_XP_SHDW_MASK (0x7 << 28) +#define OMAP44XX_REG_NVM_T_WTR_SHDW_SHIFT 24 +#define OMAP44XX_REG_NVM_T_WTR_SHDW_MASK (0x7 << 24) +#define OMAP44XX_REG_NVM_T_RP_SHDW_SHIFT 20 +#define OMAP44XX_REG_NVM_T_RP_SHDW_MASK (0xf << 20) +#define OMAP44XX_REG_NVM_T_WRA_SHDW_SHIFT 16 +#define OMAP44XX_REG_NVM_T_WRA_SHDW_MASK (0xf << 16) +#define OMAP44XX_REG_NVM_T_RRD_SHDW_SHIFT 8 +#define OMAP44XX_REG_NVM_T_RRD_SHDW_MASK (0xff << 8) +#define OMAP44XX_REG_NVM_T_RCDMIN_SHDW_SHIFT 0 +#define OMAP44XX_REG_NVM_T_RCDMIN_SHDW_MASK (0xff << 0) + +/* PWR_MGMT_CTRL */ +#define OMAP44XX_REG_IDLEMODE_SHIFT 30 +#define OMAP44XX_REG_IDLEMODE_MASK (0x3 << 30) +#define OMAP44XX_REG_PD_TIM_SHIFT 12 +#define OMAP44XX_REG_PD_TIM_MASK (0xf << 12) +#define OMAP44XX_REG_DPD_EN_SHIFT 11 +#define OMAP44XX_REG_DPD_EN_MASK (1 << 11) +#define OMAP44XX_REG_LP_MODE_SHIFT 8 +#define OMAP44XX_REG_LP_MODE_MASK (0x7 << 8) +#define OMAP44XX_REG_SR_TIM_SHIFT 4 +#define OMAP44XX_REG_SR_TIM_MASK (0xf << 4) +#define OMAP44XX_REG_CS_TIM_SHIFT 0 +#define OMAP44XX_REG_CS_TIM_MASK (0xf << 0) + +/* PWR_MGMT_CTRL_SHDW */ +#define OMAP44XX_REG_PD_TIM_SHDW_SHIFT 8 +#define OMAP44XX_REG_PD_TIM_SHDW_MASK (0xf << 8) +#define OMAP44XX_REG_SR_TIM_SHDW_SHIFT 4 +#define OMAP44XX_REG_SR_TIM_SHDW_MASK (0xf << 4) +#define OMAP44XX_REG_CS_TIM_SHDW_SHIFT 0 +#define OMAP44XX_REG_CS_TIM_SHDW_MASK (0xf << 0) + +/* LPDDR2_MODE_REG_DATA */ +#define OMAP44XX_REG_VALUE_0_SHIFT 0 +#define OMAP44XX_REG_VALUE_0_MASK (0x7f << 0) + +/* LPDDR2_MODE_REG_CFG */ +#define OMAP44XX_REG_CS_SHIFT 31 +#define OMAP44XX_REG_CS_MASK (1 << 31) +#define OMAP44XX_REG_REFRESH_EN_SHIFT 30 +#define OMAP44XX_REG_REFRESH_EN_MASK (1 << 30) +#define OMAP44XX_REG_ADDRESS_SHIFT 0 +#define OMAP44XX_REG_ADDRESS_MASK (0xff << 0) + +/* OCP_CONFIG */ +#define OMAP44XX_REG_SYS_THRESH_MAX_SHIFT 24 +#define OMAP44XX_REG_SYS_THRESH_MAX_MASK (0xf << 24) +#define OMAP44XX_REG_LL_THRESH_MAX_SHIFT 16 +#define OMAP44XX_REG_LL_THRESH_MAX_MASK (0xf << 16) +#define OMAP44XX_REG_PR_OLD_COUNT_SHIFT 0 +#define OMAP44XX_REG_PR_OLD_COUNT_MASK (0xff << 0) + +/* OCP_CFG_VAL_1 */ +#define OMAP44XX_REG_SYS_BUS_WIDTH_SHIFT 30 +#define OMAP44XX_REG_SYS_BUS_WIDTH_MASK (0x3 << 30) +#define OMAP44XX_REG_LL_BUS_WIDTH_SHIFT 28 +#define OMAP44XX_REG_LL_BUS_WIDTH_MASK (0x3 << 28) +#define OMAP44XX_REG_WR_FIFO_DEPTH_SHIFT 8 +#define OMAP44XX_REG_WR_FIFO_DEPTH_MASK (0xff << 8) +#define OMAP44XX_REG_CMD_FIFO_DEPTH_SHIFT 0 +#define OMAP44XX_REG_CMD_FIFO_DEPTH_MASK (0xff << 0) + +/* OCP_CFG_VAL_2 */ +#define OMAP44XX_REG_RREG_FIFO_DEPTH_SHIFT 16 +#define OMAP44XX_REG_RREG_FIFO_DEPTH_MASK (0xff << 16) +#define OMAP44XX_REG_RSD_FIFO_DEPTH_SHIFT 8 +#define OMAP44XX_REG_RSD_FIFO_DEPTH_MASK (0xff << 8) +#define OMAP44XX_REG_RCMD_FIFO_DEPTH_SHIFT 0 +#define OMAP44XX_REG_RCMD_FIFO_DEPTH_MASK (0xff << 0) + +/* IODFT_TLGC */ +#define OMAP44XX_REG_TLEC_SHIFT 16 +#define OMAP44XX_REG_TLEC_MASK (0xffff << 16) +#define OMAP44XX_REG_MT_SHIFT 14 +#define OMAP44XX_REG_MT_MASK (1 << 14) +#define OMAP44XX_REG_ACT_CAP_EN_SHIFT 13 +#define OMAP44XX_REG_ACT_CAP_EN_MASK (1 << 13) +#define OMAP44XX_REG_OPG_LD_SHIFT 12 +#define OMAP44XX_REG_OPG_LD_MASK (1 << 12) +#define OMAP44XX_REG_RESET_PHY_SHIFT 10 +#define OMAP44XX_REG_RESET_PHY_MASK (1 << 10) +#define OMAP44XX_REG_MMS_SHIFT 8 +#define OMAP44XX_REG_MMS_MASK (1 << 8) +#define OMAP44XX_REG_MC_SHIFT 4 +#define OMAP44XX_REG_MC_MASK (0x3 << 4) +#define OMAP44XX_REG_PC_SHIFT 1 +#define OMAP44XX_REG_PC_MASK (0x7 << 1) +#define OMAP44XX_REG_TM_SHIFT 0 +#define OMAP44XX_REG_TM_MASK (1 << 0) + +/* IODFT_CTRL_MISR_RSLT */ +#define OMAP44XX_REG_DQM_TLMR_SHIFT 16 +#define OMAP44XX_REG_DQM_TLMR_MASK (0x3ff << 16) +#define OMAP44XX_REG_CTL_TLMR_SHIFT 0 +#define OMAP44XX_REG_CTL_TLMR_MASK (0x7ff << 0) + +/* IODFT_ADDR_MISR_RSLT */ +#define OMAP44XX_REG_ADDR_TLMR_SHIFT 0 +#define OMAP44XX_REG_ADDR_TLMR_MASK (0x1fffff << 0) + +/* IODFT_DATA_MISR_RSLT_1 */ +#define OMAP44XX_REG_DATA_TLMR_31_0_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_31_0_MASK (0xffffffff << 0) + +/* IODFT_DATA_MISR_RSLT_2 */ +#define OMAP44XX_REG_DATA_TLMR_63_32_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_63_32_MASK (0xffffffff << 0) + +/* IODFT_DATA_MISR_RSLT_3 */ +#define OMAP44XX_REG_DATA_TLMR_66_64_SHIFT 0 +#define OMAP44XX_REG_DATA_TLMR_66_64_MASK (0x7 << 0) + +/* PERF_CNT_1 */ +#define OMAP44XX_REG_COUNTER1_SHIFT 0 +#define OMAP44XX_REG_COUNTER1_MASK (0xffffffff << 0) + +/* PERF_CNT_2 */ +#define OMAP44XX_REG_COUNTER2_SHIFT 0 +#define OMAP44XX_REG_COUNTER2_MASK (0xffffffff << 0) + +/* PERF_CNT_CFG */ +#define OMAP44XX_REG_CNTR2_MCONNID_EN_SHIFT 31 +#define OMAP44XX_REG_CNTR2_MCONNID_EN_MASK (1 << 31) +#define OMAP44XX_REG_CNTR2_REGION_EN_SHIFT 30 +#define OMAP44XX_REG_CNTR2_REGION_EN_MASK (1 << 30) +#define OMAP44XX_REG_CNTR2_CFG_SHIFT 16 +#define OMAP44XX_REG_CNTR2_CFG_MASK (0xf << 16) +#define OMAP44XX_REG_CNTR1_MCONNID_EN_SHIFT 15 +#define OMAP44XX_REG_CNTR1_MCONNID_EN_MASK (1 << 15) +#define OMAP44XX_REG_CNTR1_REGION_EN_SHIFT 14 +#define OMAP44XX_REG_CNTR1_REGION_EN_MASK (1 << 14) +#define OMAP44XX_REG_CNTR1_CFG_SHIFT 0 +#define OMAP44XX_REG_CNTR1_CFG_MASK (0xf << 0) + +/* PERF_CNT_SEL */ +#define OMAP44XX_REG_MCONNID2_SHIFT 24 +#define OMAP44XX_REG_MCONNID2_MASK (0xff << 24) +#define OMAP44XX_REG_REGION_SEL2_SHIFT 16 +#define OMAP44XX_REG_REGION_SEL2_MASK (0x3 << 16) +#define OMAP44XX_REG_MCONNID1_SHIFT 8 +#define OMAP44XX_REG_MCONNID1_MASK (0xff << 8) +#define OMAP44XX_REG_REGION_SEL1_SHIFT 0 +#define OMAP44XX_REG_REGION_SEL1_MASK (0x3 << 0) + +/* PERF_CNT_TIM */ +#define OMAP44XX_REG_TOTAL_TIME_SHIFT 0 +#define OMAP44XX_REG_TOTAL_TIME_MASK (0xffffffff << 0) + +/* READ_IDLE_CTRL */ +#define OMAP44XX_REG_READ_IDLE_LEN_SHIFT 16 +#define OMAP44XX_REG_READ_IDLE_LEN_MASK (0xf << 16) +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHIFT 0 +#define OMAP44XX_REG_READ_IDLE_INTERVAL_MASK (0x1ff << 0) + +/* READ_IDLE_CTRL_SHDW */ +#define OMAP44XX_REG_READ_IDLE_LEN_SHDW_SHIFT 16 +#define OMAP44XX_REG_READ_IDLE_LEN_SHDW_MASK (0xf << 16) +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHDW_SHIFT 0 +#define OMAP44XX_REG_READ_IDLE_INTERVAL_SHDW_MASK (0x1ff << 0) + +/* IRQ_EOI */ +#define OMAP44XX_REG_EOI_SHIFT 0 +#define OMAP44XX_REG_EOI_MASK (1 << 0) + +/* IRQSTATUS_RAW_SYS */ +#define OMAP44XX_REG_DNV_SYS_SHIFT 2 +#define OMAP44XX_REG_DNV_SYS_MASK (1 << 2) +#define OMAP44XX_REG_TA_SYS_SHIFT 1 +#define OMAP44XX_REG_TA_SYS_MASK (1 << 1) +#define OMAP44XX_REG_ERR_SYS_SHIFT 0 +#define OMAP44XX_REG_ERR_SYS_MASK (1 << 0) + +/* IRQSTATUS_RAW_LL */ +#define OMAP44XX_REG_DNV_LL_SHIFT 2 +#define OMAP44XX_REG_DNV_LL_MASK (1 << 2) +#define OMAP44XX_REG_TA_LL_SHIFT 1 +#define OMAP44XX_REG_TA_LL_MASK (1 << 1) +#define OMAP44XX_REG_ERR_LL_SHIFT 0 +#define OMAP44XX_REG_ERR_LL_MASK (1 << 0) + +/* IRQSTATUS_SYS */ + +/* IRQSTATUS_LL */ + +/* IRQENABLE_SET_SYS */ +#define OMAP44XX_REG_EN_DNV_SYS_SHIFT 2 +#define OMAP44XX_REG_EN_DNV_SYS_MASK (1 << 2) +#define OMAP44XX_REG_EN_TA_SYS_SHIFT 1 +#define OMAP44XX_REG_EN_TA_SYS_MASK (1 << 1) +#define OMAP44XX_REG_EN_ERR_SYS_SHIFT 0 +#define OMAP44XX_REG_EN_ERR_SYS_MASK (1 << 0) + +/* IRQENABLE_SET_LL */ +#define OMAP44XX_REG_EN_DNV_LL_SHIFT 2 +#define OMAP44XX_REG_EN_DNV_LL_MASK (1 << 2) +#define OMAP44XX_REG_EN_TA_LL_SHIFT 1 +#define OMAP44XX_REG_EN_TA_LL_MASK (1 << 1) +#define OMAP44XX_REG_EN_ERR_LL_SHIFT 0 +#define OMAP44XX_REG_EN_ERR_LL_MASK (1 << 0) + +/* IRQENABLE_CLR_SYS */ + +/* IRQENABLE_CLR_LL */ + +/* ZQ_CONFIG */ +#define OMAP44XX_REG_ZQ_CS1EN_SHIFT 31 +#define OMAP44XX_REG_ZQ_CS1EN_MASK (1 << 31) +#define OMAP44XX_REG_ZQ_CS0EN_SHIFT 30 +#define OMAP44XX_REG_ZQ_CS0EN_MASK (1 << 30) +#define OMAP44XX_REG_ZQ_DUALCALEN_SHIFT 29 +#define OMAP44XX_REG_ZQ_DUALCALEN_MASK (1 << 29) +#define OMAP44XX_REG_ZQ_SFEXITEN_SHIFT 28 +#define OMAP44XX_REG_ZQ_SFEXITEN_MASK (1 << 28) +#define OMAP44XX_REG_ZQ_ZQINIT_MULT_SHIFT 18 +#define OMAP44XX_REG_ZQ_ZQINIT_MULT_MASK (0x3 << 18) +#define OMAP44XX_REG_ZQ_ZQCL_MULT_SHIFT 16 +#define OMAP44XX_REG_ZQ_ZQCL_MULT_MASK (0x3 << 16) +#define OMAP44XX_REG_ZQ_REFINTERVAL_SHIFT 0 +#define OMAP44XX_REG_ZQ_REFINTERVAL_MASK (0xffff << 0) + +/* TEMP_ALERT_CONFIG */ +#define OMAP44XX_REG_TA_CS1EN_SHIFT 31 +#define OMAP44XX_REG_TA_CS1EN_MASK (1 << 31) +#define OMAP44XX_REG_TA_CS0EN_SHIFT 30 +#define OMAP44XX_REG_TA_CS0EN_MASK (1 << 30) +#define OMAP44XX_REG_TA_SFEXITEN_SHIFT 28 +#define OMAP44XX_REG_TA_SFEXITEN_MASK (1 << 28) +#define OMAP44XX_REG_TA_DEVWDT_SHIFT 26 +#define OMAP44XX_REG_TA_DEVWDT_MASK (0x3 << 26) +#define OMAP44XX_REG_TA_DEVCNT_SHIFT 24 +#define OMAP44XX_REG_TA_DEVCNT_MASK (0x3 << 24) +#define OMAP44XX_REG_TA_REFINTERVAL_SHIFT 0 +#define OMAP44XX_REG_TA_REFINTERVAL_MASK (0x3fffff << 0) + +/* OCP_ERR_LOG */ +#define OMAP44XX_REG_MADDRSPACE_SHIFT 14 +#define OMAP44XX_REG_MADDRSPACE_MASK (0x3 << 14) +#define OMAP44XX_REG_MBURSTSEQ_SHIFT 11 +#define OMAP44XX_REG_MBURSTSEQ_MASK (0x7 << 11) +#define OMAP44XX_REG_MCMD_SHIFT 8 +#define OMAP44XX_REG_MCMD_MASK (0x7 << 8) +#define OMAP44XX_REG_MCONNID_SHIFT 0 +#define OMAP44XX_REG_MCONNID_MASK (0xff << 0) + +/* DDR_PHY_CTRL_1 */ +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHIFT 4 +#define OMAP44XX_REG_DDR_PHY_CTRL_1_MASK (0xfffffff << 4) +#define OMAP44XX_REG_READ_LATENCY_SHIFT 0 +#define OMAP44XX_REG_READ_LATENCY_MASK (0xf << 0) +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHIFT 4 +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_MASK (0xFF << 4) +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHIFT 12 +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_MASK (0xFFFFF << 12) + +/* DDR_PHY_CTRL_1_SHDW */ +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHDW_SHIFT 4 +#define OMAP44XX_REG_DDR_PHY_CTRL_1_SHDW_MASK (0xfffffff << 4) +#define OMAP44XX_REG_READ_LATENCY_SHDW_SHIFT 0 +#define OMAP44XX_REG_READ_LATENCY_SHDW_MASK (0xf << 0) +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHDW_SHIFT 4 +#define OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHDW_MASK (0xFF << 4) +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHDW_SHIFT 12 +#define OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHDW_MASK (0xFFFFF << 12) + +/* DDR_PHY_CTRL_2 */ +#define OMAP44XX_REG_DDR_PHY_CTRL_2_SHIFT 0 +#define OMAP44XX_REG_DDR_PHY_CTRL_2_MASK (0xffffffff << 0) + +/* DMM */ +#define OMAP44XX_DMM_LISA_MAP_BASE 0x4E000040 + +/* DMM_LISA_MAP */ +#define OMAP44XX_SYS_ADDR_SHIFT 24 +#define OMAP44XX_SYS_ADDR_MASK (0xff << 24) +#define OMAP44XX_SYS_SIZE_SHIFT 20 +#define OMAP44XX_SYS_SIZE_MASK (0x7 << 20) +#define OMAP44XX_SDRC_INTL_SHIFT 18 +#define OMAP44XX_SDRC_INTL_MASK (0x3 << 18) +#define OMAP44XX_SDRC_ADDRSPC_SHIFT 16 +#define OMAP44XX_SDRC_ADDRSPC_MASK (0x3 << 16) +#define OMAP44XX_SDRC_MAP_SHIFT 8 +#define OMAP44XX_SDRC_MAP_MASK (0x3 << 8) +#define OMAP44XX_SDRC_ADDR_SHIFT 0 +#define OMAP44XX_SDRC_ADDR_MASK (0xff << 0) + +/* DMM_LISA_MAP fields */ +#define DMM_SDRC_MAP_UNMAPPED 0 +#define DMM_SDRC_MAP_EMIF1_ONLY 1 +#define DMM_SDRC_MAP_EMIF2_ONLY 2 +#define DMM_SDRC_MAP_EMIF1_AND_EMIF2 3 + +#define DMM_SDRC_INTL_NONE 0 +#define DMM_SDRC_INTL_128B 1 +#define DMM_SDRC_INTL_256B 2 +#define DMM_SDRC_INTL_512 3 + +#define DMM_SDRC_ADDR_SPC_SDRAM 0 +#define DMM_SDRC_ADDR_SPC_NVM 1 +#define DMM_SDRC_ADDR_SPC_INVALID 2 + +#define DMM_LISA_MAP_INTERLEAVED_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF1_AND_EMIF2 << OMAP44XX_SDRC_MAP_SHIFT) |\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT) |\ + (DMM_SDRC_INTL_128B << OMAP44XX_SDRC_INTL_SHIFT) |\ + (CONFIG_SYS_SDRAM_BASE << OMAP44XX_SYS_ADDR_SHIFT)) + +#define DMM_LISA_MAP_EMIF1_ONLY_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)) + +#define DMM_LISA_MAP_EMIF2_ONLY_BASE_VAL (\ + (DMM_SDRC_MAP_EMIF2_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_SDRAM << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)) + +/* Trap for invalid TILER PAT entries */ +#define DMM_LISA_MAP_0_INVAL_ADDR_TRAP (\ + (0 << OMAP44XX_SDRC_ADDR_SHIFT) |\ + (DMM_SDRC_MAP_EMIF1_ONLY << OMAP44XX_SDRC_MAP_SHIFT)|\ + (DMM_SDRC_ADDR_SPC_INVALID << OMAP44XX_SDRC_ADDRSPC_SHIFT)|\ + (DMM_SDRC_INTL_NONE << OMAP44XX_SDRC_INTL_SHIFT)|\ + (0xFF << OMAP44XX_SYS_ADDR_SHIFT)) + + +/* Reg mapping structure */ +struct emif_reg_struct { + u32 emif_mod_id_rev; + u32 emif_status; + u32 emif_sdram_config; + u32 emif_lpddr2_nvm_config; + u32 emif_sdram_ref_ctrl; + u32 emif_sdram_ref_ctrl_shdw; + u32 emif_sdram_tim_1; + u32 emif_sdram_tim_1_shdw; + u32 emif_sdram_tim_2; + u32 emif_sdram_tim_2_shdw; + u32 emif_sdram_tim_3; + u32 emif_sdram_tim_3_shdw; + u32 emif_lpddr2_nvm_tim; + u32 emif_lpddr2_nvm_tim_shdw; + u32 emif_pwr_mgmt_ctrl; + u32 emif_pwr_mgmt_ctrl_shdw; + u32 emif_lpddr2_mode_reg_data; + u32 padding1[1]; + u32 emif_lpddr2_mode_reg_data_es2; + u32 padding11[1]; + u32 emif_lpddr2_mode_reg_cfg; + u32 emif_l3_config; + u32 emif_l3_cfg_val_1; + u32 emif_l3_cfg_val_2; + u32 emif_iodft_tlgc; + u32 padding2[7]; + u32 emif_perf_cnt_1; + u32 emif_perf_cnt_2; + u32 emif_perf_cnt_cfg; + u32 emif_perf_cnt_sel; + u32 emif_perf_cnt_tim; + u32 padding3; + u32 emif_read_idlectrl; + u32 emif_read_idlectrl_shdw; + u32 padding4; + u32 emif_irqstatus_raw_sys; + u32 emif_irqstatus_raw_ll; + u32 emif_irqstatus_sys; + u32 emif_irqstatus_ll; + u32 emif_irqenable_set_sys; + u32 emif_irqenable_set_ll; + u32 emif_irqenable_clr_sys; + u32 emif_irqenable_clr_ll; + u32 padding5; + u32 emif_zq_config; + u32 emif_temp_alert_config; + u32 emif_l3_err_log; + u32 padding6[4]; + u32 emif_ddr_phy_ctrl_1; + u32 emif_ddr_phy_ctrl_1_shdw; + u32 emif_ddr_phy_ctrl_2; +}; + +struct dmm_lisa_map_regs { + u32 dmm_lisa_map_0; + u32 dmm_lisa_map_1; + u32 dmm_lisa_map_2; + u32 dmm_lisa_map_3; +}; + +struct control_lpddr2io_regs { + u32 control_lpddr2io1_0; + u32 control_lpddr2io1_1; + u32 control_lpddr2io1_2; + u32 control_lpddr2io1_3; + u32 control_lpddr2io2_0; + u32 control_lpddr2io2_1; + u32 control_lpddr2io2_2; + u32 control_lpddr2io2_3; +}; + +#define CS0 0 +#define CS1 1 +/* The maximum frequency at which the LPDDR2 interface can operate in Hz*/ +#define MAX_LPDDR2_FREQ 400000000 /* 400 MHz */ + +/* + * The period of DDR clk is represented as numerator and denominator for + * better accuracy in integer based calculations. However, if the numerator + * and denominator are very huge there may be chances of overflow in + * calculations. So, as a trade-off keep denominator(and consequently + * numerator) within a limit sacrificing some accuracy - but not much + * If denominator and numerator are already small (such as at 400 MHz) + * no adjustment is needed + */ +#define EMIF_PERIOD_DEN_LIMIT 1000 +/* + * Maximum number of different frequencies supported by EMIF driver + * Determines the number of entries in the pointer array for register + * cache + */ +#define EMIF_MAX_NUM_FREQUENCIES 6 +/* + * Indices into the Addressing Table array. + * One entry each for all the different types of devices with different + * addressing schemes + */ +#define ADDR_TABLE_INDEX64M 0 +#define ADDR_TABLE_INDEX128M 1 +#define ADDR_TABLE_INDEX256M 2 +#define ADDR_TABLE_INDEX512M 3 +#define ADDR_TABLE_INDEX1GS4 4 +#define ADDR_TABLE_INDEX2GS4 5 +#define ADDR_TABLE_INDEX4G 6 +#define ADDR_TABLE_INDEX8G 7 +#define ADDR_TABLE_INDEX1GS2 8 +#define ADDR_TABLE_INDEX2GS2 9 +#define ADDR_TABLE_INDEXMAX 10 + +/* Number of Row bits */ +#define ROW_9 0 +#define ROW_10 1 +#define ROW_11 2 +#define ROW_12 3 +#define ROW_13 4 +#define ROW_14 5 +#define ROW_15 6 +#define ROW_16 7 + +/* Number of Column bits */ +#define COL_8 0 +#define COL_9 1 +#define COL_10 2 +#define COL_11 3 +#define COL_7 4 /*Not supported by OMAP included for completeness */ + +/* Number of Banks*/ +#define BANKS1 0 +#define BANKS2 1 +#define BANKS4 2 +#define BANKS8 3 + +/* Refresh rate in micro seconds x 10 */ +#define T_REFI_15_6 156 +#define T_REFI_7_8 78 +#define T_REFI_3_9 39 + +#define EBANK_CS1_DIS 0 +#define EBANK_CS1_EN 1 + +/* Read Latency used by the device at reset */ +#define RL_BOOT 3 +/* Read Latency for the highest frequency you want to use */ +#define RL_FINAL 6 + +/* Interleaving policies at EMIF level- between banks and Chip Selects */ +#define EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING 0 +#define EMIF_INTERLEAVING_POLICY_NO_BANK_INTERLEAVING 3 + +/* + * Interleaving policy to be used + * Currently set to MAX interleaving for better performance + */ +#define EMIF_INTERLEAVING_POLICY EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING + +/* State of the core voltage: + * This is important for some parameters such as read idle control and + * ZQ calibration timings. Timings are much stricter when voltage ramp + * is happening compared to when the voltage is stable. + * We need to calculate two sets of values for these parameters and use + * them accordingly + */ +#define LPDDR2_VOLTAGE_STABLE 0 +#define LPDDR2_VOLTAGE_RAMPING 1 + +/* Length of the forced read idle period in terms of cycles */ +#define EMIF_REG_READ_IDLE_LEN_VAL 5 + +/* Interval between forced 'read idles' */ +/* To be used when voltage is changed for DPS/DVFS - 1us */ +#define READ_IDLE_INTERVAL_DVFS (1*1000) +/* + * To be used when voltage is not scaled except by Smart Reflex + * 50us - or maximum value will do + */ +#define READ_IDLE_INTERVAL_NORMAL (50*1000) + + +/* + * Unless voltage is changing due to DVFS one ZQCS command every 50ms should + * be enough. This shoule be enough also in the case when voltage is changing + * due to smart-reflex. + */ +#define EMIF_ZQCS_INTERVAL_NORMAL_IN_US (50*1000) +/* + * If voltage is changing due to DVFS ZQCS should be performed more + * often(every 50us) + */ +#define EMIF_ZQCS_INTERVAL_DVFS_IN_US 50 + +/* The interval between ZQCL commands as a multiple of ZQCS interval */ +#define REG_ZQ_ZQCL_MULT 4 +/* The interval between ZQINIT commands as a multiple of ZQCL interval */ +#define REG_ZQ_ZQINIT_MULT 3 +/* Enable ZQ Calibration on exiting Self-refresh */ +#define REG_ZQ_SFEXITEN_ENABLE 1 +/* + * ZQ Calibration simultaneously on both chip-selects: + * Needs one calibration resistor per CS + * None of the boards that we know of have this capability + * So disabled by default + */ +#define REG_ZQ_DUALCALEN_DISABLE 0 +/* + * Enable ZQ Calibration by default on CS0. If we are asked to program + * the EMIF there will be something connected to CS0 for sure + */ +#define REG_ZQ_CS0EN_ENABLE 1 + +/* EMIF_PWR_MGMT_CTRL register */ +/* Low power modes */ +#define LP_MODE_DISABLE 0 +#define LP_MODE_CLOCK_STOP 1 +#define LP_MODE_SELF_REFRESH 2 +#define LP_MODE_PWR_DN 3 + +/* REG_DPD_EN */ +#define DPD_DISABLE 0 +#define DPD_ENABLE 1 + +/* Maximum delay before Low Power Modes */ +#define REG_CS_TIM 0xF +#define REG_SR_TIM 0xF +#define REG_PD_TIM 0xF + +/* EMIF_PWR_MGMT_CTRL register */ +#define EMIF_PWR_MGMT_CTRL (\ + ((REG_CS_TIM << OMAP44XX_REG_CS_TIM_SHIFT) & OMAP44XX_REG_CS_TIM_MASK)|\ + ((REG_SR_TIM << OMAP44XX_REG_SR_TIM_SHIFT) & OMAP44XX_REG_SR_TIM_MASK)|\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHIFT) & OMAP44XX_REG_PD_TIM_MASK)|\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHIFT) & OMAP44XX_REG_PD_TIM_MASK)|\ + ((LP_MODE_DISABLE << OMAP44XX_REG_LP_MODE_SHIFT)\ + & OMAP44XX_REG_LP_MODE_MASK) |\ + ((DPD_DISABLE << OMAP44XX_REG_DPD_EN_SHIFT)\ + & OMAP44XX_REG_DPD_EN_MASK))\ + +#define EMIF_PWR_MGMT_CTRL_SHDW (\ + ((REG_CS_TIM << OMAP44XX_REG_CS_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_CS_TIM_SHDW_MASK) |\ + ((REG_SR_TIM << OMAP44XX_REG_SR_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_SR_TIM_SHDW_MASK) |\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_PD_TIM_SHDW_MASK) |\ + ((REG_PD_TIM << OMAP44XX_REG_PD_TIM_SHDW_SHIFT)\ + & OMAP44XX_REG_PD_TIM_SHDW_MASK)) + +/* EMIF_L3_CONFIG register value for ES1*/ +#define EMIF_L3_CONFIG_VAL_SYS_THRESH_0A_LL_THRESH_00 0x0A0000FF +/* + * Value of bits 12:31 of DDR_PHY_CTRL_1 register: + * All these fields have magic values dependent on frequency and + * determined by PHY and DLL integration with EMIF. Setting the magic + * values suggested by hw team. + */ +#define EMIF_DDR_PHY_CTRL_1_BASE_VAL 0x049FF +#define EMIF_DLL_SLAVE_DLY_CTRL_400_MHZ 0x41 +#define EMIF_DLL_SLAVE_DLY_CTRL_200_MHZ 0x80 +#define EMIF_DLL_SLAVE_DLY_CTRL_100_MHZ_AND_LESS 0xFF + +/* +* MR1 value: +* Burst length : 8 +* Burst type : sequential +* Wrap : enabled +* nWR : 3(default). EMIF does not do pre-charge. +* : So nWR is don't care +*/ +#define MR1_BL_8_BT_SEQ_WRAP_EN_NWR_3 0x23 + +/* MR2 */ +#define MR2_RL3_WL1 1 +#define MR2_RL4_WL2 2 +#define MR2_RL5_WL2 3 +#define MR2_RL6_WL3 4 + +/* MR10: ZQ calibration codes */ +#define MR10_ZQ_ZQCS 0x56 +#define MR10_ZQ_ZQCL 0xAB +#define MR10_ZQ_ZQINIT 0xFF +#define MR10_ZQ_ZQRESET 0xC3 + +/* TEMP_ALERT_CONFIG */ +#define TEMP_ALERT_POLL_INTERVAL_MS 360 /* for temp gradient - 5 C/s */ +#define TEMP_ALERT_CONFIG_DEVCT_1 0 +#define TEMP_ALERT_CONFIG_DEVWDT_32 2 + +/* MR16 value: refresh full array(no partial array self refresh) */ +#define MR16_REF_FULL_ARRAY 0 + +/* LPDDR2 IO regs */ +#define CONTROL_LPDDR2IO_SLEW_125PS_DRV8_PULL_DOWN 0x1C1C1C1C +#define CONTROL_LPDDR2IO_SLEW_325PS_DRV8_GATE_KEEPER 0x9E9E9E9E + +/* CONTROL_EFUSE_2 */ +#define CONTROL_EFUSE_2_NMOS_PMOS_PTV_CODE_1 0x00ffc000 + +/* + * Maximum number of entries we keep in our array of timing tables + * We need not keep all the speed bins supported by the device + * We need to keep timing tables for only the speed bins that we + * are interested in + */ +#define MAX_NUM_SPEEDBINS 4 + +/* LPDDR2 Densities */ +#define LPDDR2_DENSITY_64Mb 0 +#define LPDDR2_DENSITY_128Mb 1 +#define LPDDR2_DENSITY_256Mb 2 +#define LPDDR2_DENSITY_512Mb 3 +#define LPDDR2_DENSITY_1Gb 4 +#define LPDDR2_DENSITY_2Gb 5 +#define LPDDR2_DENSITY_4Gb 6 +#define LPDDR2_DENSITY_8Gb 7 +#define LPDDR2_DENSITY_16Gb 8 +#define LPDDR2_DENSITY_32Gb 9 + +/* LPDDR2 type */ +#define LPDDR2_TYPE_S4 0 +#define LPDDR2_TYPE_S2 1 +#define LPDDR2_TYPE_NVM 2 + +/* LPDDR2 IO width */ +#define LPDDR2_IO_WIDTH_32 0 +#define LPDDR2_IO_WIDTH_16 1 +#define LPDDR2_IO_WIDTH_8 2 + +/* Mode register numbers */ +#define LPDDR2_MR0 0 +#define LPDDR2_MR1 1 +#define LPDDR2_MR2 2 +#define LPDDR2_MR3 3 +#define LPDDR2_MR4 4 +#define LPDDR2_MR5 5 +#define LPDDR2_MR6 6 +#define LPDDR2_MR7 7 +#define LPDDR2_MR8 8 +#define LPDDR2_MR9 9 +#define LPDDR2_MR10 10 +#define LPDDR2_MR11 11 +#define LPDDR2_MR16 16 +#define LPDDR2_MR17 17 +#define LPDDR2_MR18 18 + +/* MR0 */ +#define LPDDR2_MR0_DAI_SHIFT 0 +#define LPDDR2_MR0_DAI_MASK 1 +#define LPDDR2_MR0_DI_SHIFT 1 +#define LPDDR2_MR0_DI_MASK (1 << 1) +#define LPDDR2_MR0_DNVI_SHIFT 2 +#define LPDDR2_MR0_DNVI_MASK (1 << 2) + +/* MR4 */ +#define MR4_SDRAM_REF_RATE_SHIFT 0 +#define MR4_SDRAM_REF_RATE_MASK 7 +#define MR4_TUF_SHIFT 7 +#define MR4_TUF_MASK (1 << 7) + +/* MR4 SDRAM Refresh Rate field values */ +#define SDRAM_TEMP_LESS_LOW_SHUTDOWN 0x0 +#define SDRAM_TEMP_LESS_4X_REFRESH_AND_TIMINGS 0x1 +#define SDRAM_TEMP_LESS_2X_REFRESH_AND_TIMINGS 0x2 +#define SDRAM_TEMP_NOMINAL 0x3 +#define SDRAM_TEMP_RESERVED_4 0x4 +#define SDRAM_TEMP_HIGH_DERATE_REFRESH 0x5 +#define SDRAM_TEMP_HIGH_DERATE_REFRESH_AND_TIMINGS 0x6 +#define SDRAM_TEMP_VERY_HIGH_SHUTDOWN 0x7 + +#define LPDDR2_MANUFACTURER_SAMSUNG 1 +#define LPDDR2_MANUFACTURER_QIMONDA 2 +#define LPDDR2_MANUFACTURER_ELPIDA 3 +#define LPDDR2_MANUFACTURER_ETRON 4 +#define LPDDR2_MANUFACTURER_NANYA 5 +#define LPDDR2_MANUFACTURER_HYNIX 6 +#define LPDDR2_MANUFACTURER_MOSEL 7 +#define LPDDR2_MANUFACTURER_WINBOND 8 +#define LPDDR2_MANUFACTURER_ESMT 9 +#define LPDDR2_MANUFACTURER_SPANSION 11 +#define LPDDR2_MANUFACTURER_SST 12 +#define LPDDR2_MANUFACTURER_ZMOS 13 +#define LPDDR2_MANUFACTURER_INTEL 14 +#define LPDDR2_MANUFACTURER_NUMONYX 254 +#define LPDDR2_MANUFACTURER_MICRON 255 + +/* MR8 register fields */ +#define MR8_TYPE_SHIFT 0x0 +#define MR8_TYPE_MASK 0x3 +#define MR8_DENSITY_SHIFT 0x2 +#define MR8_DENSITY_MASK (0xF << 0x2) +#define MR8_IO_WIDTH_SHIFT 0x6 +#define MR8_IO_WIDTH_MASK (0x3 << 0x6) + +struct lpddr2_addressing { + u8 num_banks; + u8 t_REFI_us_x10; + u8 row_sz[2]; /* One entry each for x32 and x16 */ + u8 col_sz[2]; /* One entry each for x32 and x16 */ +}; + +/* Structure for timings from the DDR datasheet */ +struct lpddr2_ac_timings { + u32 max_freq; + u8 RL; + u8 tRPab; + u8 tRCD; + u8 tWR; + u8 tRASmin; + u8 tRRD; + u8 tWTRx2; + u8 tXSR; + u8 tXPx2; + u8 tRFCab; + u8 tRTPx2; + u8 tCKE; + u8 tCKESR; + u8 tZQCS; + u32 tZQCL; + u32 tZQINIT; + u8 tDQSCKMAXx2; + u8 tRASmax; + u8 tFAW; + +}; + +/* + * Min tCK values for some of the parameters: + * If the calculated clock cycles for the respective parameter is + * less than the corresponding min tCK value, we need to set the min + * tCK value. This may happen at lower frequencies. + */ +struct lpddr2_min_tck { + u32 tRL; + u32 tRP_AB; + u32 tRCD; + u32 tWR; + u32 tRAS_MIN; + u32 tRRD; + u32 tWTR; + u32 tXP; + u32 tRTP; + u8 tCKE; + u32 tCKESR; + u32 tFAW; +}; + +struct lpddr2_device_details { + u8 type; + u8 density; + u8 io_width; + u8 manufacturer; +}; + +struct lpddr2_device_timings { + const struct lpddr2_ac_timings **ac_timings; + const struct lpddr2_min_tck *min_tck; +}; + +/* Details of the devices connected to each chip-select of an EMIF instance */ +struct emif_device_details { + const struct lpddr2_device_details *cs0_device_details; + const struct lpddr2_device_details *cs1_device_details; + const struct lpddr2_device_timings *cs0_device_timings; + const struct lpddr2_device_timings *cs1_device_timings; +}; + +/* + * Structure containing shadow of important registers in EMIF + * The calculation function fills in this structure to be later used for + * initialization and DVFS + */ +struct emif_regs { + u32 freq; + u32 sdram_config_init; + u32 sdram_config; + u32 ref_ctrl; + u32 sdram_tim1; + u32 sdram_tim2; + u32 sdram_tim3; + u32 read_idle_ctrl; + u32 zq_config; + u32 temp_alert_config; + u32 emif_ddr_phy_ctlr_1_init; + u32 emif_ddr_phy_ctlr_1; +}; + +/* assert macros */ +#if defined(DEBUG) +#define emif_assert(c) ({ if (!(c)) for (;;); }) +#else +#define emif_assert(c) ({ if (0) hang(); }) +#endif + +void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs); +void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs); + +#endif diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index 76b06c2..c9c86e1 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -51,6 +51,11 @@ #define CONTROL_PADCONF_CORE (OMAP44XX_L4_CORE_BASE + 0x100000) #define CONTROL_PADCONF_WKUP (OMAP44XX_L4_CORE_BASE + 0x31E000)
+/* LPDDR2 IO regs */ +#define LPDDR2_IO_REGS_BASE 0x4A100638 + +#define CONTROL_EFUSE_2 0x4A100704 + /* CONTROL_ID_CODE */ #define CONTROL_ID_CODE 0x4A002204
diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index f871921..7183a90 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -49,6 +49,8 @@ void bypass_dpll(u32 *const base); void freq_update_core(void); u32 get_sys_clk_freq(void); u32 omap4_ddr_clk(void); +void sdram_init(void); +u32 omap4_sdram_size(void);
Calculate EMIF register values based on AC timing parameters from the SDRAM datasheet and the DDR frequency rather than using the hard-coded values.
For a new board the user doen't have to go through the tedious process of calculating the register values. Instead, just provide the AC timings from the device data sheet as input and the driver will automatically calculate the register values.
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Added SDRAM init related CONFIG flags for Panda too. Earlier Panda support for everything was added in a single patch at the end * Replaced calls to omap4_revision() with omap_revision() * Reorganization of code for better readability * Some code re-organization to reduce #ifdef complexities - cleanly separated out functions for getting device details (geometry) vs timings * Ensured un-necessary code is compiled out if CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REG is defined --- arch/arm/cpu/armv7/omap-common/Makefile | 1 + arch/arm/cpu/armv7/omap-common/utils.c | 57 ++ arch/arm/cpu/armv7/omap4/board.c | 9 +- arch/arm/cpu/armv7/omap4/emif.c | 739 +++++++++++++++++++++++++++ arch/arm/cpu/armv7/omap4/sdram_elpida.c | 151 ++++++ arch/arm/include/asm/arch-omap4/emif.h | 9 + arch/arm/include/asm/arch-omap4/omap4.h | 10 +- arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + include/configs/omap4_panda.h | 5 + include/configs/omap4_sdp4430.h | 5 + 10 files changed, 977 insertions(+), 10 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/utils.c
diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index dc01ee5..8f698f8 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -28,6 +28,7 @@ LIB = $(obj)libomap-common.o SOBJS := reset.o
COBJS := timer.o +COBJS += utils.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/arch/arm/cpu/armv7/omap-common/utils.c b/arch/arm/cpu/armv7/omap-common/utils.c new file mode 100644 index 0000000..ea935da --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/utils.c @@ -0,0 +1,57 @@ +/* + * Copyright 2011 Linaro Limited + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +static void do_cancel_out(u32 *num, u32 *den, u32 factor) +{ + while (1) { + if (((*num)/factor*factor == (*num)) && + ((*den)/factor*factor == (*den))) { + (*num) /= factor; + (*den) /= factor; + } else + break; + } +} + +/* + * Cancel out the denominator and numerator of a fraction + * to get smaller numerator and denominator. + */ +void cancel_out(u32 *num, u32 *den, u32 den_limit) +{ + do_cancel_out(num, den, 2); + do_cancel_out(num, den, 3); + do_cancel_out(num, den, 5); + do_cancel_out(num, den, 7); + do_cancel_out(num, den, 11); + do_cancel_out(num, den, 13); + do_cancel_out(num, den, 17); + while ((*den) > den_limit) { + *num /= 2; + /* + * Round up the denominator so that the final fraction + * (num/den) is always <= the desired value + */ + *den = (*den + 1) / 2; + } +} diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index ca107f7..786c239 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -32,6 +32,7 @@ #include <asm/arch/cpu.h> #include <asm/arch/sys_proto.h> #include <asm/sizes.h> +#include <asm/arch/emif.h> #include "omap4_mux_data.h"
DECLARE_GLOBAL_DATA_PTR; @@ -193,13 +194,13 @@ u32 omap4_sdram_size(void) { u32 section, i, total_size = 0, size, addr; for (i = 0; i < 4; i++) { - section = __raw_readl(DMM_LISA_MAP_BASE + i*4); - addr = section & DMM_LISA_MAP_SYS_ADDR_MASK; + section = __raw_readl(OMAP44XX_DMM_LISA_MAP_BASE + i*4); + addr = section & OMAP44XX_SYS_ADDR_MASK; /* See if the address is valid */ if ((addr >= OMAP44XX_DRAM_ADDR_SPACE_START) && (addr < OMAP44XX_DRAM_ADDR_SPACE_END)) { - size = ((section & DMM_LISA_MAP_SYS_SIZE_MASK) >> - DMM_LISA_MAP_SYS_SIZE_SHIFT); + size = ((section & OMAP44XX_SYS_SIZE_MASK) >> + OMAP44XX_SYS_SIZE_SHIFT); size = 1 << size; size *= SZ_16M; total_size += size; diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index b25c1ee..ceead9e 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -170,6 +170,628 @@ static void emif_update_timings(u32 base, const struct emif_regs *regs) } }
+#ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define print_timing_reg(reg) debug(#reg" - 0x%08x\n", (reg)) + +static u32 *const T_num = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_NUM; +static u32 *const T_den = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_T_DEN; +static u32 *const emif_sizes = (u32 *)OMAP4_SRAM_SCRATCH_EMIF_SIZE; + +/* + * Organization and refresh requirements for LPDDR2 devices of different + * types and densities. Derived from JESD209-2 section 2.4 + */ +const struct lpddr2_addressing addressing_table[] = { + /* Banks tREFIx10 rowx32,rowx16 colx32,colx16 density */ + {BANKS4, T_REFI_15_6, {ROW_12, ROW_12}, {COL_7, COL_8} },/*64M */ + {BANKS4, T_REFI_15_6, {ROW_12, ROW_12}, {COL_8, COL_9} },/*128M */ + {BANKS4, T_REFI_7_8, {ROW_13, ROW_13}, {COL_8, COL_9} },/*256M */ + {BANKS4, T_REFI_7_8, {ROW_13, ROW_13}, {COL_9, COL_10} },/*512M */ + {BANKS8, T_REFI_7_8, {ROW_13, ROW_13}, {COL_9, COL_10} },/*1GS4 */ + {BANKS8, T_REFI_3_9, {ROW_14, ROW_14}, {COL_9, COL_10} },/*2GS4 */ + {BANKS8, T_REFI_3_9, {ROW_14, ROW_14}, {COL_10, COL_11} },/*4G */ + {BANKS8, T_REFI_3_9, {ROW_15, ROW_15}, {COL_10, COL_11} },/*8G */ + {BANKS4, T_REFI_7_8, {ROW_14, ROW_14}, {COL_9, COL_10} },/*1GS2 */ + {BANKS4, T_REFI_3_9, {ROW_15, ROW_15}, {COL_9, COL_10} },/*2GS2 */ +}; + +static const u32 lpddr2_density_2_size_in_mbytes[] = { + 8, /* 64Mb */ + 16, /* 128Mb */ + 32, /* 256Mb */ + 64, /* 512Mb */ + 128, /* 1Gb */ + 256, /* 2Gb */ + 512, /* 4Gb */ + 1024, /* 8Gb */ + 2048, /* 16Gb */ + 4096 /* 32Gb */ +}; + +/* + * Calculate the period of DDR clock from frequency value and set the + * denominator and numerator in global variables for easy access later + */ +static void set_ddr_clk_period(u32 freq) +{ + /* + * period = 1/freq + * period_in_ns = 10^9/freq + */ + *T_num = 1000000000; + *T_den = freq; + cancel_out(T_num, T_den, 200); + +} + +/* + * Convert time in nano seconds to number of cycles of DDR clock + */ +static inline u32 ns_2_cycles(u32 ns) +{ + return ((ns * (*T_den)) + (*T_num) - 1) / (*T_num); +} + +/* + * ns_2_cycles with the difference that the time passed is 2 times the actual + * value(to avoid fractions). The cycles returned is for the original value of + * the timing parameter + */ +static inline u32 ns_x2_2_cycles(u32 ns) +{ + return ((ns * (*T_den)) + (*T_num) * 2 - 1) / ((*T_num) * 2); +} + +/* + * Find addressing table index based on the device's type(S2 or S4) and + * density + */ +s8 addressing_table_index(u8 type, u8 density, u8 width) +{ + u8 index; + if ((density > LPDDR2_DENSITY_8Gb) || (width == LPDDR2_IO_WIDTH_8)) + return -1; + + /* + * Look at the way ADDR_TABLE_INDEX* values have been defined + * in emif.h compared to LPDDR2_DENSITY_* values + * The table is layed out in the increasing order of density + * (ignoring type). The exceptions 1GS2 and 2GS2 have been placed + * at the end + */ + if ((type == LPDDR2_TYPE_S2) && (density == LPDDR2_DENSITY_1Gb)) + index = ADDR_TABLE_INDEX1GS2; + else if ((type == LPDDR2_TYPE_S2) && (density == LPDDR2_DENSITY_2Gb)) + index = ADDR_TABLE_INDEX2GS2; + else + index = density; + + debug("emif: addressing table index %d\n", index); + + return index; +} + +/* + * Find the the right timing table from the array of timing + * tables of the device using DDR clock frequency + */ +static const struct lpddr2_ac_timings *get_timings_table(const struct + lpddr2_ac_timings const *const *device_timings, + u32 freq) +{ + u32 i, temp, freq_nearest; + const struct lpddr2_ac_timings *timings = 0; + + emif_assert(freq <= MAX_LPDDR2_FREQ); + emif_assert(device_timings); + + /* + * Start with the maximum allowed frequency - that is always safe + */ + freq_nearest = MAX_LPDDR2_FREQ; + /* + * Find the timings table that has the max frequency value: + * i. Above or equal to the DDR frequency - safe + * ii. The lowest that satisfies condition (i) - optimal + */ + for (i = 0; (i < MAX_NUM_SPEEDBINS) && device_timings[i]; i++) { + temp = device_timings[i]->max_freq; + if ((temp >= freq) && (temp <= freq_nearest)) { + freq_nearest = temp; + timings = device_timings[i]; + } + } + debug("emif: timings table: %d\n", freq_nearest); + return timings; +} + +/* + * Finds the value of emif_sdram_config_reg + * All parameters are programmed based on the device on CS0. + * If there is a device on CS1, it will be same as that on CS0 or + * it will be NVM. We don't support NVM yet. + * If cs1_device pointer is NULL it is assumed that there is no device + * on CS1 + */ +static u32 get_sdram_config_reg(const struct lpddr2_device_details *cs0_device, + const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 RL) +{ + u32 config_reg = 0; + + config_reg |= (cs0_device->type + 4) << OMAP44XX_REG_SDRAM_TYPE_SHIFT; + config_reg |= EMIF_INTERLEAVING_POLICY_MAX_INTERLEAVING << + OMAP44XX_REG_IBANK_POS_SHIFT; + + config_reg |= cs0_device->io_width << OMAP44XX_REG_NARROW_MODE_SHIFT; + + config_reg |= RL << OMAP44XX_REG_CL_SHIFT; + + config_reg |= addressing->row_sz[cs0_device->io_width] << + OMAP44XX_REG_ROWSIZE_SHIFT; + + config_reg |= addressing->num_banks << OMAP44XX_REG_IBANK_SHIFT; + + config_reg |= (cs1_device ? EBANK_CS1_EN : EBANK_CS1_DIS) << + OMAP44XX_REG_EBANK_SHIFT; + + config_reg |= addressing->col_sz[cs0_device->io_width] << + OMAP44XX_REG_PAGESIZE_SHIFT; + + return config_reg; +} + +static u32 get_sdram_ref_ctrl(u32 freq, + const struct lpddr2_addressing *addressing) +{ + u32 ref_ctrl = 0, val = 0, freq_khz; + freq_khz = freq / 1000; + /* + * refresh rate to be set is 'tREFI * freq in MHz + * division by 10000 to account for khz and x10 in t_REFI_us_x10 + */ + val = addressing->t_REFI_us_x10 * freq_khz / 10000; + ref_ctrl |= val << OMAP44XX_REG_REFRESH_RATE_SHIFT; + + return ref_ctrl; +} + +static u32 get_sdram_tim_1_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck, + const struct lpddr2_addressing *addressing) +{ + u32 tim1 = 0, val = 0; + val = max(min_tck->tWTR, ns_x2_2_cycles(timings->tWTRx2)) - 1; + tim1 |= val << OMAP44XX_REG_T_WTR_SHIFT; + + if (addressing->num_banks == BANKS8) + val = (timings->tFAW * (*T_den) + 4 * (*T_num) - 1) / + (4 * (*T_num)) - 1; + else + val = max(min_tck->tRRD, ns_2_cycles(timings->tRRD)) - 1; + + tim1 |= val << OMAP44XX_REG_T_RRD_SHIFT; + + val = ns_2_cycles(timings->tRASmin + timings->tRPab) - 1; + tim1 |= val << OMAP44XX_REG_T_RC_SHIFT; + + val = max(min_tck->tRAS_MIN, ns_2_cycles(timings->tRASmin)) - 1; + tim1 |= val << OMAP44XX_REG_T_RAS_SHIFT; + + val = max(min_tck->tWR, ns_2_cycles(timings->tWR)) - 1; + tim1 |= val << OMAP44XX_REG_T_WR_SHIFT; + + val = max(min_tck->tRCD, ns_2_cycles(timings->tRCD)) - 1; + tim1 |= val << OMAP44XX_REG_T_RCD_SHIFT; + + val = max(min_tck->tRP_AB, ns_2_cycles(timings->tRPab)) - 1; + tim1 |= val << OMAP44XX_REG_T_RP_SHIFT; + + return tim1; +} + +static u32 get_sdram_tim_2_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck) +{ + u32 tim2 = 0, val = 0; + val = max(min_tck->tCKE, timings->tCKE) - 1; + tim2 |= val << OMAP44XX_REG_T_CKE_SHIFT; + + val = max(min_tck->tRTP, ns_x2_2_cycles(timings->tRTPx2)) - 1; + tim2 |= val << OMAP44XX_REG_T_RTP_SHIFT; + + /* + * tXSRD = tRFCab + 10 ns. XSRD and XSNR should have the + * same value + */ + val = ns_2_cycles(timings->tXSR) - 1; + tim2 |= val << OMAP44XX_REG_T_XSRD_SHIFT; + tim2 |= val << OMAP44XX_REG_T_XSNR_SHIFT; + + val = max(min_tck->tXP, ns_x2_2_cycles(timings->tXPx2)) - 1; + tim2 |= val << OMAP44XX_REG_T_XP_SHIFT; + + return tim2; +} + +static u32 get_sdram_tim_3_reg(const struct lpddr2_ac_timings *timings, + const struct lpddr2_min_tck *min_tck, + const struct lpddr2_addressing *addressing) +{ + u32 tim3 = 0, val = 0; + val = min(timings->tRASmax * 10 / addressing->t_REFI_us_x10 - 1, 0xF); + tim3 |= val << OMAP44XX_REG_T_RAS_MAX_SHIFT; + + val = ns_2_cycles(timings->tRFCab) - 1; + tim3 |= val << OMAP44XX_REG_T_RFC_SHIFT; + + val = ns_x2_2_cycles(timings->tDQSCKMAXx2) - 1; + tim3 |= val << OMAP44XX_REG_T_TDQSCKMAX_SHIFT; + + val = ns_2_cycles(timings->tZQCS) - 1; + tim3 |= val << OMAP44XX_REG_ZQ_ZQCS_SHIFT; + + val = max(min_tck->tCKESR, ns_2_cycles(timings->tCKESR)) - 1; + tim3 |= val << OMAP44XX_REG_T_CKESR_SHIFT; + + return tim3; +} + +static u32 get_zq_config_reg(const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 volt_ramp) +{ + u32 zq = 0, val = 0; + if (volt_ramp) + val = + EMIF_ZQCS_INTERVAL_DVFS_IN_US * 10 / + addressing->t_REFI_us_x10; + else + val = + EMIF_ZQCS_INTERVAL_NORMAL_IN_US * 10 / + addressing->t_REFI_us_x10; + zq |= val << OMAP44XX_REG_ZQ_REFINTERVAL_SHIFT; + + zq |= (REG_ZQ_ZQCL_MULT - 1) << OMAP44XX_REG_ZQ_ZQCL_MULT_SHIFT; + + zq |= (REG_ZQ_ZQINIT_MULT - 1) << OMAP44XX_REG_ZQ_ZQINIT_MULT_SHIFT; + + zq |= REG_ZQ_SFEXITEN_ENABLE << OMAP44XX_REG_ZQ_SFEXITEN_SHIFT; + + /* + * Assuming that two chipselects have a single calibration resistor + * If there are indeed two calibration resistors, then this flag should + * be enabled to take advantage of dual calibration feature. + * This data should ideally come from board files. But considering + * that none of the boards today have calibration resistors per CS, + * it would be an unnecessary overhead. + */ + zq |= REG_ZQ_DUALCALEN_DISABLE << OMAP44XX_REG_ZQ_DUALCALEN_SHIFT; + + zq |= REG_ZQ_CS0EN_ENABLE << OMAP44XX_REG_ZQ_CS0EN_SHIFT; + + zq |= (cs1_device ? 1 : 0) << OMAP44XX_REG_ZQ_CS1EN_SHIFT; + + return zq; +} + +static u32 get_temp_alert_config(const struct lpddr2_device_details *cs1_device, + const struct lpddr2_addressing *addressing, + u8 is_derated) +{ + u32 alert = 0, interval; + interval = + TEMP_ALERT_POLL_INTERVAL_MS * 10000 / addressing->t_REFI_us_x10; + if (is_derated) + interval *= 4; + alert |= interval << OMAP44XX_REG_TA_REFINTERVAL_SHIFT; + + alert |= TEMP_ALERT_CONFIG_DEVCT_1 << OMAP44XX_REG_TA_DEVCNT_SHIFT; + + alert |= TEMP_ALERT_CONFIG_DEVWDT_32 << OMAP44XX_REG_TA_DEVWDT_SHIFT; + + alert |= 1 << OMAP44XX_REG_TA_SFEXITEN_SHIFT; + + alert |= 1 << OMAP44XX_REG_TA_CS0EN_SHIFT; + + alert |= (cs1_device ? 1 : 0) << OMAP44XX_REG_TA_CS1EN_SHIFT; + + return alert; +} + +static u32 get_read_idle_ctrl_reg(u8 volt_ramp) +{ + u32 idle = 0, val = 0; + if (volt_ramp) + val = ns_2_cycles(READ_IDLE_INTERVAL_DVFS) / 64 + 1; + else + /*Maximum value in normal conditions - suggested by hw team */ + val = 0x1FF; + idle |= val << OMAP44XX_REG_READ_IDLE_INTERVAL_SHIFT; + + idle |= EMIF_REG_READ_IDLE_LEN_VAL << OMAP44XX_REG_READ_IDLE_LEN_SHIFT; + + return idle; +} + +static u32 get_ddr_phy_ctrl_1(u32 freq, u8 RL) +{ + u32 phy = 0, val = 0; + + phy |= (RL + 2) << OMAP44XX_REG_READ_LATENCY_SHIFT; + + if (freq <= 100000000) + val = EMIF_DLL_SLAVE_DLY_CTRL_100_MHZ_AND_LESS; + else if (freq <= 200000000) + val = EMIF_DLL_SLAVE_DLY_CTRL_200_MHZ; + else + val = EMIF_DLL_SLAVE_DLY_CTRL_400_MHZ; + phy |= val << OMAP44XX_REG_DLL_SLAVE_DLY_CTRL_SHIFT; + + /* Other fields are constant magic values. Hardcode them together */ + phy |= EMIF_DDR_PHY_CTRL_1_BASE_VAL << + OMAP44XX_EMIF_DDR_PHY_CTRL_1_BASE_VAL_SHIFT; + + return phy; +} + +static u32 get_emif_mem_size(struct emif_device_details *devices) +{ + u32 size_mbytes = 0, temp; + + if (!devices) + return 0; + + if (devices->cs0_device_details) { + temp = devices->cs0_device_details->density; + size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; + } + + if (devices->cs1_device_details) { + temp = devices->cs1_device_details->density; + size_mbytes += lpddr2_density_2_size_in_mbytes[temp]; + } + /* convert to bytes */ + return size_mbytes << 20; +} + +/* Gets the encoding corresponding to a given DMM section size */ +u32 get_dmm_section_size_map(u32 section_size) +{ + /* + * Section size mapping: + * 0x0: 16-MiB section + * 0x1: 32-MiB section + * 0x2: 64-MiB section + * 0x3: 128-MiB section + * 0x4: 256-MiB section + * 0x5: 512-MiB section + * 0x6: 1-GiB section + * 0x7: 2-GiB section + */ + section_size >>= 24; /* divide by 16 MB */ + return log_2_n_round_down(section_size); +} + +static void emif_calculate_regs( + const struct emif_device_details *emif_dev_details, + u32 freq, struct emif_regs *regs) +{ + u32 temp, sys_freq; + const struct lpddr2_addressing *addressing; + const struct lpddr2_ac_timings *timings; + const struct lpddr2_min_tck *min_tck; + const struct lpddr2_device_details *cs0_dev_details = + emif_dev_details->cs0_device_details; + const struct lpddr2_device_details *cs1_dev_details = + emif_dev_details->cs1_device_details; + const struct lpddr2_device_timings *cs0_dev_timings = + emif_dev_details->cs0_device_timings; + + emif_assert(emif_dev_details); + emif_assert(regs); + /* + * You can not have a device on CS1 without one on CS0 + * So configuring EMIF without a device on CS0 doesn't + * make sense + */ + emif_assert(cs0_dev_details); + emif_assert(cs0_dev_details->type != LPDDR2_TYPE_NVM); + /* + * If there is a device on CS1 it should be same type as CS0 + * (or NVM. But NVM is not supported in this driver yet) + */ + emif_assert((cs1_dev_details == NULL) || + (cs1_dev_details->type == LPDDR2_TYPE_NVM) || + (cs0_dev_details->type == cs1_dev_details->type)); + emif_assert(freq <= MAX_LPDDR2_FREQ); + + set_ddr_clk_period(freq); + + /* + * The device on CS0 is used for all timing calculations + * There is only one set of registers for timings per EMIF. So, if the + * second CS(CS1) has a device, it should have the same timings as the + * device on CS0 + */ + timings = get_timings_table(cs0_dev_timings->ac_timings, freq); + emif_assert(timings); + min_tck = cs0_dev_timings->min_tck; + + temp = addressing_table_index(cs0_dev_details->type, + cs0_dev_details->density, + cs0_dev_details->io_width); + + emif_assert((temp >= 0)); + addressing = &(addressing_table[temp]); + emif_assert(addressing); + + sys_freq = get_sys_clk_freq(); + + regs->sdram_config_init = get_sdram_config_reg(cs0_dev_details, + cs1_dev_details, + addressing, RL_BOOT); + + regs->sdram_config = get_sdram_config_reg(cs0_dev_details, + cs1_dev_details, + addressing, RL_FINAL); + + regs->ref_ctrl = get_sdram_ref_ctrl(freq, addressing); + + regs->sdram_tim1 = get_sdram_tim_1_reg(timings, min_tck, addressing); + + regs->sdram_tim2 = get_sdram_tim_2_reg(timings, min_tck); + + regs->sdram_tim3 = get_sdram_tim_3_reg(timings, min_tck, addressing); + + regs->read_idle_ctrl = get_read_idle_ctrl_reg(LPDDR2_VOLTAGE_STABLE); + + regs->temp_alert_config = + get_temp_alert_config(cs1_dev_details, addressing, 0); + + regs->zq_config = get_zq_config_reg(cs1_dev_details, addressing, + LPDDR2_VOLTAGE_STABLE); + + regs->emif_ddr_phy_ctlr_1_init = + get_ddr_phy_ctrl_1(sys_freq / 2, RL_BOOT); + + regs->emif_ddr_phy_ctlr_1 = + get_ddr_phy_ctrl_1(freq, RL_FINAL); + + regs->freq = freq; + + print_timing_reg(regs->sdram_config_init); + print_timing_reg(regs->sdram_config); + print_timing_reg(regs->ref_ctrl); + print_timing_reg(regs->sdram_tim1); + print_timing_reg(regs->sdram_tim2); + print_timing_reg(regs->sdram_tim3); + print_timing_reg(regs->read_idle_ctrl); + print_timing_reg(regs->temp_alert_config); + print_timing_reg(regs->zq_config); + print_timing_reg(regs->emif_ddr_phy_ctlr_1); + print_timing_reg(regs->emif_ddr_phy_ctlr_1_init); +} +#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */ + +#ifdef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS +/* Base AC Timing values specified by JESD209-2 for 400MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_400_mhz = { + .max_freq = 400000000, + .RL = 6, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* Base AC Timing values specified by JESD209-2 for 333 MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_333_mhz = { + .max_freq = 333000000, + .RL = 5, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* Base AC Timing values specified by JESD209-2 for 200 MHz operation */ +static const struct lpddr2_ac_timings timings_jedec_200_mhz = { + .max_freq = 200000000, + .RL = 3, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 20, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +/* + * Min tCK values specified by JESD209-2 + * Min tCK specifies the minimum duration of some AC timing parameters in terms + * of the number of cycles. If the calculated number of cycles based on the + * absolute time value is less than the min tCK value, min tCK value should + * be used instead. This typically happens at low frequencies. + */ +static const struct lpddr2_min_tck min_tck_jedec = { + .tRL = 3, + .tRP_AB = 3, + .tRCD = 3, + .tWR = 3, + .tRAS_MIN = 3, + .tRRD = 2, + .tWTR = 2, + .tXP = 2, + .tRTP = 2, + .tCKE = 3, + .tCKESR = 3, + .tFAW = 8 +}; + +static const struct lpddr2_ac_timings const* + jedec_ac_timings[MAX_NUM_SPEEDBINS] = { + &timings_jedec_200_mhz, + &timings_jedec_333_mhz, + &timings_jedec_400_mhz +}; + +static const struct lpddr2_device_timings jedec_default_timings = { + .ac_timings = jedec_ac_timings, + .min_tck = &min_tck_jedec +}; + +void emif_get_device_timings(u32 emif_nr, + const struct lpddr2_device_timings **cs0_device_timings, + const struct lpddr2_device_timings **cs1_device_timings) +{ + /* Assume Identical devices on EMIF1 & EMIF2 */ + *cs0_device_timings = &jedec_default_timings; + *cs1_device_timings = &jedec_default_timings; +} +#endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */ + static void do_sdram_init(u32 base) { const struct emif_regs *regs; @@ -180,11 +802,54 @@ static void do_sdram_init(u32 base) in_sdram = running_from_sdram(); emif_nr = (base == OMAP44XX_EMIF1) ? 1 : 2;
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS emif_get_reg_dump(emif_nr, ®s); if (!regs) { debug("EMIF: reg dump not provided\n"); return; } +#else + /* + * The user has not provided the register values. We need to + * calculate it based on the timings and the DDR frequency + */ + struct emif_device_details dev_details; + struct emif_regs calculated_regs; + + /* + * Get device details: + * - Discovered if CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION is set + * - Obtained from user otherwise + */ + struct lpddr2_device_details cs0_dev_details, cs1_dev_details; + emif_get_device_details(emif_nr, &cs0_dev_details, + &cs1_dev_details); + dev_details.cs0_device_details = &cs0_dev_details; + dev_details.cs1_device_details = &cs1_dev_details; + + /* Return if no devices on this EMIF */ + if (!dev_details.cs0_device_details && + !dev_details.cs1_device_details) { + emif_sizes[emif_nr - 1] = 0; + return; + } + + if (!in_sdram) + emif_sizes[emif_nr - 1] = get_emif_mem_size(&dev_details); + + /* + * Get device timings: + * - Default timings specified by JESD209-2 if + * CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS is set + * - Obtained from user otherwise + */ + emif_get_device_timings(emif_nr, &dev_details.cs0_device_timings, + &dev_details.cs1_device_timings); + + /* Calculate the register values */ + emif_calculate_regs(&dev_details, omap4_ddr_clk(), &calculated_regs); + regs = &calculated_regs; +#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */
/* * Initializing the LPDDR2 device can not happen from SDRAM. @@ -242,8 +907,82 @@ static void dmm_init(u32 base) { const struct dmm_lisa_map_regs *lisa_map_regs;
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS emif_get_dmm_regs(&lisa_map_regs); +#else + u32 emif1_size, emif2_size, mapped_size, section_map = 0; + u32 section_cnt, sys_addr; + struct dmm_lisa_map_regs lis_map_regs_calculated = {0}; + + mapped_size = 0; + section_cnt = 3; + sys_addr = CONFIG_SYS_SDRAM_BASE; + emif1_size = emif_sizes[0]; + emif2_size = emif_sizes[1]; + debug("emif1_size 0x%x emif2_size 0x%x\n", emif1_size, emif2_size); + + if (!emif1_size && !emif2_size) + return; + + /* symmetric interleaved section */ + if (emif1_size && emif2_size) { + mapped_size = min(emif1_size, emif2_size); + section_map = DMM_LISA_MAP_INTERLEAVED_BASE_VAL; + section_map |= 0 << OMAP44XX_SDRC_ADDR_SHIFT; + /* only MSB */ + section_map |= (sys_addr >> 24) << + OMAP44XX_SYS_ADDR_SHIFT; + section_map |= get_dmm_section_size_map(mapped_size * 2) + << OMAP44XX_SYS_SIZE_SHIFT; + lis_map_regs_calculated.dmm_lisa_map_3 = section_map; + emif1_size -= mapped_size; + emif2_size -= mapped_size; + sys_addr += (mapped_size * 2); + section_cnt--; + } + + /* + * Single EMIF section(we can have a maximum of 1 single EMIF + * section- either EMIF1 or EMIF2 or none, but not both) + */ + if (emif1_size) { + section_map = DMM_LISA_MAP_EMIF1_ONLY_BASE_VAL; + section_map |= get_dmm_section_size_map(emif1_size) + << OMAP44XX_SYS_SIZE_SHIFT; + /* only MSB */ + section_map |= (mapped_size >> 24) << + OMAP44XX_SDRC_ADDR_SHIFT; + /* only MSB */ + section_map |= (sys_addr >> 24) << OMAP44XX_SYS_ADDR_SHIFT; + section_cnt--; + } + if (emif2_size) { + section_map = DMM_LISA_MAP_EMIF2_ONLY_BASE_VAL; + section_map |= get_dmm_section_size_map(emif2_size) << + OMAP44XX_SYS_SIZE_SHIFT; + /* only MSB */ + section_map |= mapped_size >> 24 << OMAP44XX_SDRC_ADDR_SHIFT; + /* only MSB */ + section_map |= sys_addr >> 24 << OMAP44XX_SYS_ADDR_SHIFT; + section_cnt--; + } + + if (section_cnt == 2) { + /* Only 1 section - either symmetric or single EMIF */ + lis_map_regs_calculated.dmm_lisa_map_3 = section_map; + lis_map_regs_calculated.dmm_lisa_map_2 = 0; + lis_map_regs_calculated.dmm_lisa_map_1 = 0; + } else { + /* 2 sections - 1 symmetric, 1 single EMIF */ + lis_map_regs_calculated.dmm_lisa_map_2 = section_map; + lis_map_regs_calculated.dmm_lisa_map_1 = 0; + } + + /* TRAP for invalid TILER mappings in section 0 */ + lis_map_regs_calculated.dmm_lisa_map_0 = DMM_LISA_MAP_0_INVAL_ADDR_TRAP;
+ lisa_map_regs = &lis_map_regs_calculated; +#endif struct dmm_lisa_map_regs *hw_lisa_map_regs = (struct dmm_lisa_map_regs *)base;
diff --git a/arch/arm/cpu/armv7/omap4/sdram_elpida.c b/arch/arm/cpu/armv7/omap4/sdram_elpida.c index c950c87..7757aad 100644 --- a/arch/arm/cpu/armv7/omap4/sdram_elpida.c +++ b/arch/arm/cpu/armv7/omap4/sdram_elpida.c @@ -46,6 +46,8 @@ * - emif_get_device_timings() */
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS + static const struct emif_regs emif_regs_elpida_200_mhz_2cs = { .sdram_config_init = 0x80000eb9, .sdram_config = 0x80001ab9, @@ -129,3 +131,152 @@ static void emif_get_dmm_regs_sdp(const struct dmm_lisa_map_regs
void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) __attribute__((weak, alias("emif_get_dmm_regs_sdp"))); + +#else + +static const struct lpddr2_device_details elpida_2G_S4_details = { + .type = LPDDR2_TYPE_S4, + .density = LPDDR2_DENSITY_2Gb, + .io_width = LPDDR2_IO_WIDTH_32, + .manufacturer = LPDDR2_MANUFACTURER_ELPIDA +}; + +static void emif_get_device_details_sdp(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details) +{ + u32 omap_rev = omap_revision(); + + /* EMIF1 & EMIF2 have identical configuration */ + *cs0_device_details = elpida_2G_S4_details; + + if (omap_rev == OMAP4430_ES1_0) + cs1_device_details = NULL; + else + *cs1_device_details = elpida_2G_S4_details; +} + +void emif_get_device_details(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details) + __attribute__((weak, alias("emif_get_device_details_sdp"))); + +#endif /* CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS */ + +#ifndef CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS +static const struct lpddr2_ac_timings timings_elpida_400_mhz = { + .max_freq = 400000000, + .RL = 6, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_ac_timings timings_elpida_333_mhz = { + .max_freq = 333000000, + .RL = 5, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 15, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_ac_timings timings_elpida_200_mhz = { + .max_freq = 200000000, + .RL = 3, + .tRPab = 21, + .tRCD = 18, + .tWR = 15, + .tRASmin = 42, + .tRRD = 10, + .tWTRx2 = 20, + .tXSR = 140, + .tXPx2 = 15, + .tRFCab = 130, + .tRTPx2 = 15, + .tCKE = 3, + .tCKESR = 15, + .tZQCS = 90, + .tZQCL = 360, + .tZQINIT = 1000, + .tDQSCKMAXx2 = 11, + .tRASmax = 70, + .tFAW = 50 +}; + +static const struct lpddr2_min_tck min_tck_elpida = { + .tRL = 3, + .tRP_AB = 3, + .tRCD = 3, + .tWR = 3, + .tRAS_MIN = 3, + .tRRD = 2, + .tWTR = 2, + .tXP = 2, + .tRTP = 2, + .tCKE = 3, + .tCKESR = 3, + .tFAW = 8 +}; + +static const struct lpddr2_ac_timings *elpida_ac_timings[MAX_NUM_SPEEDBINS] = { + &timings_elpida_200_mhz, + &timings_elpida_333_mhz, + &timings_elpida_400_mhz +}; + +static const struct lpddr2_device_timings elpida_2G_S4_timings = { + .ac_timings = elpida_ac_timings, + .min_tck = &min_tck_elpida, +}; + +void emif_get_device_timings_sdp(u32 emif_nr, + const struct lpddr2_device_timings **cs0_device_timings, + const struct lpddr2_device_timings **cs1_device_timings) +{ + u32 omap_rev = omap_revision(); + + /* Identical devices on EMIF1 & EMIF2 */ + *cs0_device_timings = &elpida_2G_S4_timings; + + if (omap_rev == OMAP4430_ES1_0) + *cs1_device_timings = NULL; + else + *cs1_device_timings = &elpida_2G_S4_timings; +} + +void emif_get_device_timings(u32 emif_nr, + const struct lpddr2_device_timings **cs0_device_timings, + const struct lpddr2_device_timings **cs1_device_timings) + __attribute__((weak, alias("emif_get_device_timings_sdp"))); + +#endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */ diff --git a/arch/arm/include/asm/arch-omap4/emif.h b/arch/arm/include/asm/arch-omap4/emif.h index 09e9baa..a167508 100644 --- a/arch/arm/include/asm/arch-omap4/emif.h +++ b/arch/arm/include/asm/arch-omap4/emif.h @@ -1019,7 +1019,16 @@ struct emif_regs { #define emif_assert(c) ({ if (0) hang(); }) #endif
+#ifdef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs); void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs); +#else +void emif_get_device_details(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details); +void emif_get_device_timings(u32 emif_nr, + const struct lpddr2_device_timings **cs0_device_timings, + const struct lpddr2_device_timings **cs1_device_timings); +#endif
#endif diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index c9c86e1..a8dbedb 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -84,12 +84,6 @@ /* GPMC */ #define OMAP44XX_GPMC_BASE 0x50000000
-/* DMM */ -#define OMAP44XX_DMM_BASE 0x4E000000 -#define DMM_LISA_MAP_BASE (OMAP44XX_DMM_BASE + 0x40) -#define DMM_LISA_MAP_SYS_SIZE_MASK (7 << 20) -#define DMM_LISA_MAP_SYS_SIZE_SHIFT 20 -#define DMM_LISA_MAP_SYS_ADDR_MASK (0xFF << 24) /* * Hardware Register Details */ @@ -137,6 +131,10 @@ struct s32ktimer { #define SRAM_SCRATCH_SPACE_ADDR NON_SECURE_SRAM_START /* SRAM scratch space entries */ #define OMAP4_SRAM_SCRATCH_OMAP4_REV SRAM_SCRATCH_SPACE_ADDR +#define OMAP4_SRAM_SCRATCH_EMIF_SIZE (SRAM_SCRATCH_SPACE_ADDR + 0x4) +#define OMAP4_SRAM_SCRATCH_EMIF_T_NUM (SRAM_SCRATCH_SPACE_ADDR + 0xC) +#define OMAP4_SRAM_SCRATCH_EMIF_T_DEN (SRAM_SCRATCH_SPACE_ADDR + 0x10) +#define OMAP4_SRAM_SCRATCH_SPACE_END (SRAM_SCRATCH_SPACE_ADDR + 0x14)
/* Silicon revisions */ #define OMAP4430_SILICON_ID_INVALID 0xFFFFFFFF diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 7183a90..1e62878 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -49,6 +49,7 @@ void bypass_dpll(u32 *const base); void freq_update_core(void); u32 get_sys_clk_freq(void); u32 omap4_ddr_clk(void); +void cancel_out(u32 *num, u32 *den, u32 den_limit); void sdram_init(void); u32 omap4_sdram_size(void);
diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 1daffb7..9f82ef4 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -237,4 +237,9 @@ #define CONFIG_SYS_PL310_BASE 0x48242000 #endif
+/* Defines for SDRAM init */ +#ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS +#endif + #endif /* __CONFIG_H */ diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 68ffa87..6df1c3d 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -243,4 +243,9 @@ #define CONFIG_SYS_PL310_BASE 0x48242000 #endif
Identify SDRAM devices connected to EMIF automatically: LPDDR2 devices have some Mode Registers that provide details about the device such as the type, density, bus width etc. EMIF has the capability to read these registers. If there are no devices connected to a given chip-select reading mode registers will return junk values. After reading as many such registers as possible and matching with expected ranges of values the driver can identify if there is a device connected to the respective CS. If we identify that a device is connected the values read give us complete details about the device.
This along with the base AC timings specified by JESD209-2 allows us to do a complete automatic initialization of SDRAM that works on all boards.
Please note that the default AC timings specified by JESD209-2 will be safe for all devices but not necessarily optimal. However, for the Elpida devices used on Panda and SDP the default timings are both safe and optimal.
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Code re-organization for better readability * Ensured that un-necessary code is compiled out when CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION is not defined --- arch/arm/cpu/armv7/omap4/emif.c | 238 +++++++++++++++++++++++++++++++++++++++ include/configs/omap4_panda.h | 1 + include/configs/omap4_sdp4430.h | 1 + 3 files changed, 240 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap4/emif.c b/arch/arm/cpu/armv7/omap4/emif.c index ceead9e..1234a7e 100644 --- a/arch/arm/cpu/armv7/omap4/emif.c +++ b/arch/arm/cpu/armv7/omap4/emif.c @@ -792,6 +792,244 @@ void emif_get_device_timings(u32 emif_nr, } #endif /* CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS */
+#ifdef CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION +const char *get_lpddr2_type(u8 type_id) +{ + switch (type_id) { + case LPDDR2_TYPE_S4: + return "LPDDR2-S4"; + case LPDDR2_TYPE_S2: + return "LPDDR2-S2"; + default: + return NULL; + } +} + +const char *get_lpddr2_io_width(u8 width_id) +{ + switch (width_id) { + case LPDDR2_IO_WIDTH_8: + return "x8"; + case LPDDR2_IO_WIDTH_16: + return "x16"; + case LPDDR2_IO_WIDTH_32: + return "x32"; + default: + return NULL; + } +} + +const char *get_lpddr2_manufacturer(u32 manufacturer) +{ + switch (manufacturer) { + case LPDDR2_MANUFACTURER_SAMSUNG: + return "Samsung"; + case LPDDR2_MANUFACTURER_QIMONDA: + return "Qimonda"; + case LPDDR2_MANUFACTURER_ELPIDA: + return "Elpida"; + case LPDDR2_MANUFACTURER_ETRON: + return "Etron"; + case LPDDR2_MANUFACTURER_NANYA: + return "Nanya"; + case LPDDR2_MANUFACTURER_HYNIX: + return "Hynix"; + case LPDDR2_MANUFACTURER_MOSEL: + return "Mosel"; + case LPDDR2_MANUFACTURER_WINBOND: + return "Winbond"; + case LPDDR2_MANUFACTURER_ESMT: + return "ESMT"; + case LPDDR2_MANUFACTURER_SPANSION: + return "Spansion"; + case LPDDR2_MANUFACTURER_SST: + return "SST"; + case LPDDR2_MANUFACTURER_ZMOS: + return "ZMOS"; + case LPDDR2_MANUFACTURER_INTEL: + return "Intel"; + case LPDDR2_MANUFACTURER_NUMONYX: + return "Numonyx"; + case LPDDR2_MANUFACTURER_MICRON: + return "Micron"; + default: + return NULL; + } +} + +static void display_sdram_details(u32 emif_nr, u32 cs, + struct lpddr2_device_details *device) +{ + const char *mfg_str; + const char *type_str; + char density_str[10]; + u32 density; + + debug("EMIF%d CS%d\t", emif_nr, cs); + + if (!device) { + debug("None\n"); + return; + } + + mfg_str = get_lpddr2_manufacturer(device->manufacturer); + type_str = get_lpddr2_type(device->type); + + density = lpddr2_density_2_size_in_mbytes[device->density]; + if ((density / 1024 * 1024) == density) { + density /= 1024; + sprintf(density_str, "%d GB", density); + } else + sprintf(density_str, "%d MB", density); + if (mfg_str && type_str) + debug("%s\t\t%s\t%s\n", mfg_str, type_str, density_str); +} + +static u8 is_lpddr2_sdram_present(u32 base, u32 cs, + struct lpddr2_device_details *lpddr2_device) +{ + u32 mr = 0, temp; + + mr = get_mr(base, cs, LPDDR2_MR0); + if (mr > 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + temp = (mr & LPDDR2_MR0_DI_MASK) >> LPDDR2_MR0_DI_SHIFT; + if (temp) { + /* Not SDRAM */ + return 0; + } + temp = (mr & LPDDR2_MR0_DNVI_MASK) >> LPDDR2_MR0_DNVI_SHIFT; + + if (temp) { + /* DNV supported - But DNV is only supported for NVM */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR4); + if (mr > 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR5); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + if (!get_lpddr2_manufacturer(mr)) { + /* Manufacturer not identified */ + return 0; + } + lpddr2_device->manufacturer = mr; + + mr = get_mr(base, cs, LPDDR2_MR6); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR7); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + mr = get_mr(base, cs, LPDDR2_MR8); + if (mr >= 0xFF) { + /* Mode register value bigger than 8 bit */ + return 0; + } + + temp = (mr & MR8_TYPE_MASK) >> MR8_TYPE_SHIFT; + if (!get_lpddr2_type(temp)) { + /* Not SDRAM */ + return 0; + } + lpddr2_device->type = temp; + + temp = (mr & MR8_DENSITY_MASK) >> MR8_DENSITY_SHIFT; + if (temp > LPDDR2_DENSITY_32Gb) { + /* Density not supported */ + return 0; + } + lpddr2_device->density = temp; + + temp = (mr & MR8_IO_WIDTH_MASK) >> MR8_IO_WIDTH_SHIFT; + if (!get_lpddr2_io_width(temp)) { + /* IO width unsupported value */ + return 0; + } + lpddr2_device->io_width = temp; + + /* + * If all the above tests pass we should + * have a device on this chip-select + */ + return 1; +} + +static struct lpddr2_device_details *get_lpddr2_details(u32 base, u8 cs, + struct lpddr2_device_details *lpddr2_dev_details) +{ + u32 phy; + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + + if (!lpddr2_dev_details) + return NULL; + + /* Do the minimum init for mode register accesses */ + if (!running_from_sdram()) { + phy = get_ddr_phy_ctrl_1(get_sys_clk_freq() / 2, RL_BOOT); + writel(phy, &emif->emif_ddr_phy_ctrl_1); + } + + if (!(is_lpddr2_sdram_present(base, cs, lpddr2_dev_details))) + return NULL; + + display_sdram_details(emif_num(base), cs, lpddr2_dev_details); + + return lpddr2_dev_details; +} + +void emif_get_device_details(u32 emif_nr, + struct lpddr2_device_details *cs0_device_details, + struct lpddr2_device_details *cs1_device_details) +{ + u32 base = (emif_nr == 1) ? OMAP44XX_EMIF1 : OMAP44XX_EMIF2; + + if (running_from_sdram()) { + /* + * We can not do automatic discovery running from SDRAM + * Most likely we came here by mistake. Indicate error + * by returning NULL + */ + cs0_device_details = NULL; + cs1_device_details = NULL; + } else { + /* + * Automatically find the device details: + * + * Reset the PHY after each call to get_lpddr2_details(). + * If there is nothing connected to a given chip select + * (typically CS1) mode register reads will mess up with + * the PHY state and subsequent initialization won't work. + * PHY reset brings back PHY to a good state. + */ + cs0_device_details = + get_lpddr2_details(base, CS0, cs0_device_details); + emif_reset_phy(base); + + cs1_device_details = + get_lpddr2_details(base, CS1, cs1_device_details); + emif_reset_phy(base); + } +} +#endif /* CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION */ + static void do_sdram_init(u32 base) { const struct emif_regs *regs; diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 9f82ef4..a8dd861 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -239,6 +239,7 @@
/* Defines for SDRAM init */ #ifndef CONFIG_SYS_EMIF_PRECALCULATED_TIMING_REGS +#define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS #endif
diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 6df1c3d..534f89a 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -245,6 +245,7 @@
- Allow SPL to have .bss disjoint from rest of the image - Allow for .bss setup in CONFIG_SPL_BUILD case too. - Take care of the special case where relocation offset = 0. - Compile out exception handling code and install a simpler vector
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Taken care of the case where .bss is at a lower address comapred to _start
V4: * Rebased to the latest u-boot-ti/master --- arch/arm/cpu/armv7/start.S | 49 +++++++++++++++++++++++++++++++---------- arch/arm/cpu/armv7/u-boot.lds | 2 + 2 files changed, 39 insertions(+), 12 deletions(-)
diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 5c87e9c..02a2535 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -42,7 +42,16 @@ _start: b reset ldr pc, _not_used ldr pc, _irq ldr pc, _fiq - +#ifdef CONFIG_SPL_BUILD +_undefined_instruction: .word _undefined_instruction +_software_interrupt: .word _software_interrupt +_prefetch_abort: .word _prefetch_abort +_data_abort: .word _data_abort +_not_used: .word _not_used +_irq: .word _irq +_fiq: .word _fiq +_pad: .word 0x12345678 /* now 16*4=64 */ +#else _undefined_instruction: .word undefined_instruction _software_interrupt: .word software_interrupt _prefetch_abort: .word prefetch_abort @@ -51,6 +60,8 @@ _not_used: .word not_used _irq: .word irq _fiq: .word fiq _pad: .word 0x12345678 /* now 16*4=64 */ +#endif /* CONFIG_SPL_BUILD */ + .global _end_vect _end_vect:
@@ -89,6 +100,10 @@ _armboot_start: _bss_start_ofs: .word __bss_start - _start
+.global _image_copy_end_ofs +_image_copy_end_ofs: + .word __image_copy_end - _start + .globl _bss_end_ofs _bss_end_ofs: .word __bss_end__ - _start @@ -182,12 +197,11 @@ stack_setup: mov sp, r4
adr r0, _start -#ifndef CONFIG_SPL_BUILD cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ -#endif mov r1, r6 /* r1 <- scratch for copy_loop */ - ldr r3, _bss_start_ofs + ldr r3, _image_copy_end_ofs add r2, r0, r3 /* r2 <- source end address */
copy_loop: @@ -235,20 +249,34 @@ fixnext: add r2, r2, #8 /* each rel.dyn entry is 8 bytes */ cmp r2, r3 blo fixloop + b clear_bss +_rel_dyn_start_ofs: + .word __rel_dyn_start - _start +_rel_dyn_end_ofs: + .word __rel_dyn_end - _start +_dynsym_start_ofs: + .word __dynsym_start - _start + +#endif /* #ifndef CONFIG_SPL_BUILD */
clear_bss: +#ifdef CONFIG_SPL_BUILD + /* No relocation for SPL */ + ldr r0, =__bss_start + ldr r1, =__bss_end__ +#else ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 +#endif mov r2, #0x00000000 /* clear */
clbss_l:str r2, [r0] /* clear loop... */ add r0, r0, #4 cmp r0, r1 bne clbss_l -#endif /* #ifndef CONFIG_SPL_BUILD */
/* * We are done. Do not return, instead branch to second part of board @@ -276,12 +304,6 @@ jump_2_ram: _board_init_r_ofs: .word board_init_r - _start
-_rel_dyn_start_ofs: - .word __rel_dyn_start - _start -_rel_dyn_end_ofs: - .word __rel_dyn_end - _start -_dynsym_start_ofs: - .word __dynsym_start - _start
#ifndef CONFIG_SKIP_LOWLEVEL_INIT /************************************************************************* @@ -329,6 +351,8 @@ cpu_init_crit: mov lr, ip @ restore link mov pc, lr @ back to my caller #endif + +#ifndef CONFIG_SPL_BUILD /* ************************************************************************* * @@ -516,4 +540,5 @@ fiq: bad_save_user_regs bl do_fiq
-#endif +#endif /* CONFIG_USE_IRQ */ +#endif /* CONFIG_SPL_BUILD */ diff --git a/arch/arm/cpu/armv7/u-boot.lds b/arch/arm/cpu/armv7/u-boot.lds index dbae54d..40ecf78 100644 --- a/arch/arm/cpu/armv7/u-boot.lds +++ b/arch/arm/cpu/armv7/u-boot.lds @@ -55,6 +55,8 @@ SECTIONS
. = ALIGN(4);
+ __image_copy_end = .; + .rel.dyn : { __rel_dyn_start = .; *(.rel*)
- Provide alternate implementations of board_init_f() board_init_r() for OMAP spl. - Provide linker script - Initialize global data - Add serial console support - Update CONFIG_SYS_TEXT_BASE to allow for SPL's bss and move it to board config header from config.mk
This patch adds two checkpatch warnings that look like false positives. Reported these to checkpatch maintainer.
V2: * Removed the label __flash_image_end because _end serves the same purpose after rebasing to latest mainline
V3: * Moved CONFIG_SYS_TEXT_BASE to board config header and deleted config.mk * Changes for the struct based register accesses * Removed usage of modify_reg_32() macro * omap4_rev_string() reference changed to omap_rev_string() * Folded the patches for linker script changes and console support into this patch * Improved commit message
V4: * Changed the CONFIG_SYS_SPL_* config flags to: CONFIG_SPL_* * Changed the name omap4_rev_string used in spl.c as this file is common for OMAP3/4 --- arch/arm/cpu/armv7/Makefile | 7 ++- arch/arm/cpu/armv7/omap-common/Makefile | 4 + arch/arm/cpu/armv7/omap-common/spl.c | 82 +++++++++++++++++++++++++ arch/arm/cpu/armv7/omap-common/u-boot-spl.lds | 62 +++++++++++++++++++ arch/arm/cpu/armv7/omap4/Makefile | 5 +- arch/arm/cpu/armv7/omap4/board.c | 7 ++ arch/arm/cpu/armv7/omap4/clocks.c | 33 ++++++++++ arch/arm/include/asm/arch-omap4/sys_proto.h | 1 + arch/arm/include/asm/omap_common.h | 2 + board/ti/panda/Makefile | 2 + board/ti/panda/config.mk | 31 --------- board/ti/sdp4430/Makefile | 2 + board/ti/sdp4430/config.mk | 31 --------- include/configs/omap4_panda.h | 26 ++++++++ include/configs/omap4_sdp4430.h | 26 ++++++++ 15 files changed, 257 insertions(+), 64 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap-common/spl.c create mode 100644 arch/arm/cpu/armv7/omap-common/u-boot-spl.lds delete mode 100644 board/ti/panda/config.mk delete mode 100644 board/ti/sdp4430/config.mk
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index 299792a..92a5a96 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -26,7 +26,12 @@ include $(TOPDIR)/config.mk LIB = $(obj)lib$(CPU).o
START := start.o -COBJS := cpu.o cache_v7.o + +ifndef CONFIG_SPL_BUILD +COBJS += cache_v7.o +COBJS += cpu.o +endif + COBJS += syslib.o
SRCS := $(START:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index 8f698f8..0708796 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -30,6 +30,10 @@ SOBJS := reset.o COBJS := timer.o COBJS += utils.o
+ifdef CONFIG_SPL_BUILD +COBJS += spl.o +endif + SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS))
diff --git a/arch/arm/cpu/armv7/omap-common/spl.c b/arch/arm/cpu/armv7/omap-common/spl.c new file mode 100644 index 0000000..b201543 --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/spl.c @@ -0,0 +1,82 @@ +/* + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/u-boot.h> +#include <asm/arch/sys_proto.h> +#include <timestamp_autogenerated.h> +#include <version_autogenerated.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Define global data structure pointer to it*/ +static gd_t gdata __attribute__ ((section(".data"))); +static bd_t bdata __attribute__ ((section(".data"))); + +inline void hang(void) +{ + puts("### ERROR ### Please RESET the board ###\n"); + for (;;) + ; +} + +void board_init_f(ulong dummy) +{ + /* + * We call relocate_code() with relocation target same as the + * CONFIG_SYS_SPL_TEXT_BASE. This will result in relocation getting + * skipped. Instead, only .bss initialization will happen. That's + * all we need + */ + debug(">>board_init_f()\n"); + relocate_code(CONFIG_SPL_STACK, &gdata, CONFIG_SPL_TEXT_BASE); +} + +void board_init_r(gd_t *id, ulong dummy) +{ + for (;;) + ; +} + +void preloader_console_init(void) +{ + const char *u_boot_rev = U_BOOT_VERSION; + char rev_string_buffer[50]; + + gd = &gdata; + gd->bd = &bdata; + gd->flags |= GD_FLG_RELOC; + gd->baudrate = CONFIG_BAUDRATE; + + setup_clocks_for_console(); + serial_init(); /* serial communications setup */ + + /* Avoid a second "U-Boot" coming from this string */ + u_boot_rev = &u_boot_rev[7]; + + printf("\nU-Boot SPL %s (%s - %s)\n", u_boot_rev, U_BOOT_DATE, + U_BOOT_TIME); + omap_rev_string(rev_string_buffer); + printf("Texas Instruments %s\n", rev_string_buffer); +} diff --git a/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds b/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds new file mode 100644 index 0000000..8867e06 --- /dev/null +++ b/arch/arm/cpu/armv7/omap-common/u-boot-spl.lds @@ -0,0 +1,62 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * (C) Copyright 2010 + * Texas Instruments, <www.ti.com> + * Aneesh V aneesh@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +MEMORY { .sram : ORIGIN = CONFIG_SPL_TEXT_BASE,\ + LENGTH = CONFIG_SPL_MAX_SIZE } +MEMORY { .sdram : ORIGIN = CONFIG_SPL_BSS_START_ADDR, \ + LENGTH = CONFIG_SPL_BSS_MAX_SIZE } + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + .text : + { + __start = .; + arch/arm/cpu/armv7/start.o (.text) + *(.text*) + } >.sram + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(.rodata*)) } >.sram + + . = ALIGN(4); + .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram + . = ALIGN(4); + __image_copy_end = .; + _end = .; + + .bss : + { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + __bss_end__ = .; + } >.sdram +} diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index e1ccd68..e7ee0b8 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -30,9 +30,12 @@ SOBJS += lowlevel_init.o COBJS += board.o COBJS += clocks.o COBJS += emif.o -COBJS += mem.o COBJS += sdram_elpida.o + +ifndef CONFIG_SPL_BUILD +COBJS += mem.o COBJS += sys_info.o +endif
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 786c239..54dd509 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -155,7 +155,14 @@ void s_init(void) init_omap4_revision(); watchdog_init(); set_mux_conf_regs(); +#ifdef CONFIG_SPL_BUILD + preloader_console_init(); +#endif prcm_init(); +#ifdef CONFIG_SPL_BUILD + /* For regular u-boot sdram_init() is called from dram_init() */ + sdram_init(); +#endif }
/* diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c index e8d3a52..f1e233a 100644 --- a/arch/arm/cpu/armv7/omap4/clocks.c +++ b/arch/arm/cpu/armv7/omap4/clocks.c @@ -791,6 +791,39 @@ void lock_dpll(u32 *const base) wait_for_lock(base); }
+void setup_clocks_for_console(void) +{ + /* Do not add any spl_debug prints in this function */ + clrsetbits_le32(&prcm->cm_l4per_clkstctrl, CD_CLKCTRL_CLKTRCTRL_MASK, + CD_CLKCTRL_CLKTRCTRL_SW_WKUP << + CD_CLKCTRL_CLKTRCTRL_SHIFT); + + /* Enable all UARTs - console will be on one of them */ + clrsetbits_le32(&prcm->cm_l4per_uart1_clkctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + + clrsetbits_le32(&prcm->cm_l4per_uart2_clkctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + + clrsetbits_le32(&prcm->cm_l4per_uart3_clkctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + + clrsetbits_le32(&prcm->cm_l4per_uart3_clkctrl, + MODULE_CLKCTRL_MODULEMODE_MASK, + MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN << + MODULE_CLKCTRL_MODULEMODE_SHIFT); + + clrsetbits_le32(&prcm->cm_l4per_clkstctrl, CD_CLKCTRL_CLKTRCTRL_MASK, + CD_CLKCTRL_CLKTRCTRL_HW_AUTO << + CD_CLKCTRL_CLKTRCTRL_SHIFT); +} + void prcm_init(void) { switch (omap4_hw_init_context()) { diff --git a/arch/arm/include/asm/arch-omap4/sys_proto.h b/arch/arm/include/asm/arch-omap4/sys_proto.h index 1e62878..a81f8e5 100644 --- a/arch/arm/include/asm/arch-omap4/sys_proto.h +++ b/arch/arm/include/asm/arch-omap4/sys_proto.h @@ -44,6 +44,7 @@ u32 wait_on_value(u32, u32, void *, u32); void sdelay(unsigned long); void set_pl310_ctrl_reg(u32 val); void omap_rev_string(char *omap4_rev_string); +void setup_clocks_for_console(void); void prcm_init(void); void bypass_dpll(u32 *const base); void freq_update_core(void); diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 33caa4e..69d53d2 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -34,4 +34,6 @@ #define OMAP_INIT_CONTEXT_UBOOT_AFTER_SPL 2 #define OMAP_INIT_CONTEXT_UBOOT_AFTER_CH 3
+void preloader_console_init(void); + #endif /* _OMAP_COMMON_H_ */ diff --git a/board/ti/panda/Makefile b/board/ti/panda/Makefile index 2186403..09f88ee 100644 --- a/board/ti/panda/Makefile +++ b/board/ti/panda/Makefile @@ -25,7 +25,9 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).o
+ifndef CONFIG_SPL_BUILD COBJS := panda.o +endif
SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/ti/panda/config.mk b/board/ti/panda/config.mk deleted file mode 100644 index 33901a7..0000000 --- a/board/ti/panda/config.mk +++ /dev/null @@ -1,31 +0,0 @@ -# -# (C) Copyright 2006-2009 -# Texas Instruments Incorporated, <www.ti.com> -# -# OMAP 4430 SDP -# see http://www.ti.com/ for more information on Texas Instruments -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -# SDRAM Address Space: -# 8000'0000 - 9fff'ffff (512 MB) -# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 -# (mem base + reserved) - -CONFIG_SYS_TEXT_BASE = 0x80e80000 diff --git a/board/ti/sdp4430/Makefile b/board/ti/sdp4430/Makefile index f1ee544..12f2743 100644 --- a/board/ti/sdp4430/Makefile +++ b/board/ti/sdp4430/Makefile @@ -25,7 +25,9 @@ include $(TOPDIR)/config.mk
+ifndef CONFIG_SPL_BUILD COBJS := sdp.o cmd_bat.o +endif
SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS)) diff --git a/board/ti/sdp4430/config.mk b/board/ti/sdp4430/config.mk deleted file mode 100644 index 33901a7..0000000 --- a/board/ti/sdp4430/config.mk +++ /dev/null @@ -1,31 +0,0 @@ -# -# (C) Copyright 2006-2009 -# Texas Instruments Incorporated, <www.ti.com> -# -# OMAP 4430 SDP -# see http://www.ti.com/ for more information on Texas Instruments -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# -# SDRAM Address Space: -# 8000'0000 - 9fff'ffff (512 MB) -# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 -# (mem base + reserved) - -CONFIG_SYS_TEXT_BASE = 0x80e80000 diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index a8dd861..1112362 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -243,4 +243,30 @@ #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS #endif
+/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_TEXT_BASE 0x40304350 +#define CONFIG_SPL_MAX_SIZE 0x8000 /* 32 K */ +#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK + +#define CONFIG_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv7/omap-common/u-boot-spl.lds" + +/* + * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM + * 64 bytes before this address should be set aside for u-boot.img's + * header. That is 0x800FFFC0--0x80100000 should not be used for any + * other needs. + */ +#define CONFIG_SYS_TEXT_BASE 0x80100000 + #endif /* __CONFIG_H */ diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 534f89a..6a6be9e 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -249,4 +249,30 @@ #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS #endif
Provide appropriate '-O u-boot' while doing mkimage for u-boot.img
Signed-off-by: Aneesh V aneesh@ti.com --- Makefile | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/Makefile b/Makefile index 0707036..f8ae883 100644 --- a/Makefile +++ b/Makefile @@ -375,7 +375,7 @@ $(obj)u-boot.ldr.srec: $(obj)u-boot.ldr
$(obj)u-boot.img: $(obj)u-boot.bin $(obj)tools/mkimage -A $(ARCH) -T firmware -C none \ - -a $(CONFIG_SYS_TEXT_BASE) -e 0 \ + -O u-boot -a $(CONFIG_SYS_TEXT_BASE) -e 0 \ -n $(shell sed -n -e 's/.*U_BOOT_VERSION//p' $(VERSION_FILE) | \ sed -e 's/"[ ]*$$/ for $(BOARD) board"/') \ -d $< $@
- Add MMC raw and FAT mode boot support for OMAP - Provide a means by which parameters passed by ROM-code can be saved in u-boot. - Save boot mode related information passed by OMAP4 ROM-code and use it to determine where to load the u-boot from - Assumes that the image has a mkimage header. Gets the payload size and load address from this header. If the header is not detected assume u-boot.bin as payload
Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Squashed the patches that provided MMC support, FAT support, start.S hook for saving parameters, and OMAP4 patch for saving the parameters all into this patch. * Removed the assumption that payload is u-boot.bin. Payload size and address --- arch/arm/cpu/armv7/cpu.c | 7 + arch/arm/cpu/armv7/omap-common/spl.c | 194 +++++++++++++++++++++++++++++- arch/arm/cpu/armv7/omap4/board.c | 21 ++++ arch/arm/cpu/armv7/omap4/lowlevel_init.S | 31 +++++ arch/arm/cpu/armv7/start.S | 1 + arch/arm/include/asm/arch-omap4/omap4.h | 8 ++ arch/arm/include/asm/omap_common.h | 17 +++ include/configs/omap4_panda.h | 5 + include/configs/omap4_sdp4430.h | 5 + 9 files changed, 287 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv7/cpu.c b/arch/arm/cpu/armv7/cpu.c index def9ced..091e3e0 100644 --- a/arch/arm/cpu/armv7/cpu.c +++ b/arch/arm/cpu/armv7/cpu.c @@ -37,6 +37,13 @@ #include <asm/cache.h> #include <asm/armv7.h>
+void save_boot_params_default(u32 r0, u32 r1, u32 r2, u32 r3) +{ +} + +void save_boot_params(u32 r0, u32 r1, u32 r2, u32 r3) + __attribute__((weak, alias("save_boot_params_default"))); + int cleanup_before_linux(void) { /* diff --git a/arch/arm/cpu/armv7/omap-common/spl.c b/arch/arm/cpu/armv7/omap-common/spl.c index b201543..d177652 100644 --- a/arch/arm/cpu/armv7/omap-common/spl.c +++ b/arch/arm/cpu/armv7/omap-common/spl.c @@ -24,15 +24,27 @@ */ #include <common.h> #include <asm/u-boot.h> +#include <asm/utils.h> #include <asm/arch/sys_proto.h> +#include <mmc.h> +#include <fat.h> #include <timestamp_autogenerated.h> #include <version_autogenerated.h> +#include <asm/omap_common.h> +#include <asm/arch/mmc_host_def.h> +#include <i2c.h> +#include <image.h>
/* Define global data structure pointer to it*/ static gd_t gdata __attribute__ ((section(".data"))); static bd_t bdata __attribute__ ((section(".data"))); +static const char *image_name; +static u8 image_os; +static u32 image_load_addr; +static u32 image_entry_point; +static u32 image_size;
inline void hang(void) { @@ -53,10 +65,188 @@ void board_init_f(ulong dummy) relocate_code(CONFIG_SPL_STACK, &gdata, CONFIG_SPL_TEXT_BASE); }
+#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + switch (omap_boot_device()) { + case BOOT_DEVICE_MMC1: + omap_mmc_init(0); + break; + case BOOT_DEVICE_MMC2: + omap_mmc_init(1); + break; + } + return 0; +} +#endif + +static void parse_image_header(const struct image_header *header) +{ + u32 header_size = sizeof(struct image_header); + + if (__be32_to_cpu(header->ih_magic) == IH_MAGIC) { + image_size = __be32_to_cpu(header->ih_size) + header_size; + image_entry_point = __be32_to_cpu(header->ih_load); + /* Load including the header */ + image_load_addr = image_entry_point - header_size; + image_os = header->ih_os; + image_name = (const char *)&header->ih_name; + debug("spl: payload image: %s load addr: 0x%x size: %d\n", + image_name, image_load_addr, image_size); + } else { + /* Signature not found - assume u-boot.bin */ + printf("mkimage signature not found - ih_magic = %x\n", + header->ih_magic); + puts("Assuming u-boot.bin ..\n"); + /* Let's assume U-Boot will not be more than 200 KB */ + image_size = 200 * 1024; + image_entry_point = CONFIG_SYS_TEXT_BASE; + image_load_addr = CONFIG_SYS_TEXT_BASE; + image_os = IH_OS_U_BOOT; + image_name = "U-Boot"; + } +} + +static void mmc_load_image_raw(struct mmc *mmc) +{ + u32 image_size_sectors, err; + const struct image_header *header; + + header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - + sizeof(struct image_header)); + + /* read image header to find the image size & load address */ + err = mmc->block_dev.block_read(0, + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR, 1, + (void *)header); + + if (err <= 0) + goto end; + + parse_image_header(header); + + /* convert size to sectors - round up */ + image_size_sectors = (image_size + MMCSD_SECTOR_SIZE - 1) / + MMCSD_SECTOR_SIZE; + + /* Read the header too to avoid extra memcpy */ + err = mmc->block_dev.block_read(0, + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR, + image_size_sectors, (void *)image_load_addr); + +end: + if (err <= 0) { + printf("spl: mmc blk read err - %d\n", err); + hang(); + } +} + +static void mmc_load_image_fat(struct mmc *mmc) +{ + s32 err; + struct image_header *header; + + header = (struct image_header *)(CONFIG_SYS_TEXT_BASE - + sizeof(struct image_header)); + + err = fat_register_device(&mmc->block_dev, + CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION); + if (err) { + printf("spl: fat register err - %d\n", err); + hang(); + } + + err = file_fat_read(CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, + (u8 *)header, sizeof(struct image_header)); + if (err <= 0) + goto end; + + parse_image_header(header); + + err = file_fat_read(CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, + (u8 *)image_load_addr, 0); + +end: + if (err <= 0) { + printf("spl: error reading image %s, err - %d\n", + CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME, err); + hang(); + } +} + +static void mmc_load_image(void) +{ + struct mmc *mmc; + int err; + u32 boot_mode; + + mmc_initialize(gd->bd); + /* We register only one device. So, the dev id is always 0 */ + mmc = find_mmc_device(0); + if (!mmc) { + puts("spl: mmc device not found!!\n"); + hang(); + } + + err = mmc_init(mmc); + if (err) { + printf("spl: mmc init failed: err - %d\n", err); + hang(); + } + + boot_mode = omap_boot_mode(); + if (boot_mode == MMCSD_MODE_RAW) { + debug("boot mode - RAW\n"); + mmc_load_image_raw(mmc); + } else if (boot_mode == MMCSD_MODE_FAT) { + debug("boot mode - FAT\n"); + mmc_load_image_fat(mmc); + } else { + puts("spl: wrong MMC boot mode\n"); + hang(); + } +} + +void jump_to_image_no_args(void) +{ + typedef void (*image_entry_noargs_t)(void)__attribute__ ((noreturn)); + image_entry_noargs_t image_entry = + (image_entry_noargs_t) image_entry_point; + + image_entry(); +} + +void jump_to_image_no_args(void) __attribute__ ((noreturn)); void board_init_r(gd_t *id, ulong dummy) { - for (;;) - ; + u32 boot_device; + debug(">>spl:board_init_r()\n"); + + timer_init(); + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + + boot_device = omap_boot_device(); + debug("boot device - %d\n", boot_device); + switch (boot_device) { + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: + mmc_load_image(); + break; + default: + printf("SPL: Un-supported Boot Device - %d!!!\n", boot_device); + hang(); + break; + } + + switch (image_os) { + case IH_OS_U_BOOT: + debug("Jumping to U-Boot\n"); + jump_to_image_no_args(); + break; + default: + puts("Unsupported OS image.. Jumping nevertheless..\n"); + jump_to_image_no_args(); + } }
void preloader_console_init(void) diff --git a/arch/arm/cpu/armv7/omap4/board.c b/arch/arm/cpu/armv7/omap4/board.c index 54dd509..2e5739a 100644 --- a/arch/arm/cpu/armv7/omap4/board.c +++ b/arch/arm/cpu/armv7/omap4/board.c @@ -39,6 +39,27 @@ DECLARE_GLOBAL_DATA_PTR;
u32 *const omap4_revision = (u32 *)OMAP4_SRAM_SCRATCH_OMAP4_REV;
+#ifdef CONFIG_SPL_BUILD +/* + * We use static variables because global data is not ready yet. + * Initialized data is available in SPL right from the beginning. + * We would not typically need to save these parameters in regular + * U-Boot. This is needed only in SPL at the moment. + */ +u32 omap4_boot_device = BOOT_DEVICE_MMC1; +u32 omap4_boot_mode = MMCSD_MODE_FAT; + +u32 omap_boot_device(void) +{ + return omap4_boot_device; +} + +u32 omap_boot_mode(void) +{ + return omap4_boot_mode; +} +#endif + void do_set_mux(u32 base, struct pad_conf_entry const *array, int size) { int i; diff --git a/arch/arm/cpu/armv7/omap4/lowlevel_init.S b/arch/arm/cpu/armv7/omap4/lowlevel_init.S index 6abfbba..91525ec 100644 --- a/arch/arm/cpu/armv7/omap4/lowlevel_init.S +++ b/arch/arm/cpu/armv7/omap4/lowlevel_init.S @@ -27,6 +27,37 @@ */
#include <asm/arch/omap4.h> +#ifdef CONFIG_SPL_BUILD +.global save_boot_params +save_boot_params: + /* + * See if the rom code passed pointer is valid: + * It is not valid if it is not in non-secure SRAM + * This may happen if you are booting with the help of + * debugger + */ + ldr r2, =NON_SECURE_SRAM_START + cmp r2, r0 + bgt 1f + ldr r2, =NON_SECURE_SRAM_END + cmp r2, r0 + blt 1f + + /* Store the boot device in omap4_boot_device */ + ldr r2, [r0, #BOOT_DEVICE_OFFSET] @ r1 <- value of boot device + and r2, #BOOT_DEVICE_MASK + ldr r3, =omap4_boot_device + str r2, [r3] @ omap4_boot_device <- r1 + + /* Store the boot mode (raw/FAT) in omap4_boot_mode */ + ldr r2, [r0, #DEV_DESC_PTR_OFFSET] @ get the device descriptor ptr + ldr r2, [r2, #DEV_DATA_PTR_OFFSET] @ get the pDeviceData ptr + ldr r2, [r2, #BOOT_MODE_OFFSET] @ get the boot mode + ldr r3, =omap4_boot_mode + str r2, [r3] +1: + bx lr +#endif
.globl lowlevel_init lowlevel_init: diff --git a/arch/arm/cpu/armv7/start.S b/arch/arm/cpu/armv7/start.S index 02a2535..db8e9d2 100644 --- a/arch/arm/cpu/armv7/start.S +++ b/arch/arm/cpu/armv7/start.S @@ -134,6 +134,7 @@ IRQ_STACK_START_IN: */
reset: + bl save_boot_params /* * set the cpu to SVC32 mode */ diff --git a/arch/arm/include/asm/arch-omap4/omap4.h b/arch/arm/include/asm/arch-omap4/omap4.h index a8dbedb..563544f 100644 --- a/arch/arm/include/asm/arch-omap4/omap4.h +++ b/arch/arm/include/asm/arch-omap4/omap4.h @@ -144,4 +144,12 @@ struct s32ktimer { #define OMAP4430_ES2_2 0x44300220 #define OMAP4430_ES2_3 0x44300230
+/* ROM code defines */ +/* Boot device */ +#define BOOT_DEVICE_MASK 0xFF +#define BOOT_DEVICE_OFFSET 0x8 +#define DEV_DESC_PTR_OFFSET 0x4 +#define DEV_DATA_PTR_OFFSET 0x18 +#define BOOT_MODE_OFFSET 0x8 + #endif diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 69d53d2..d3cb857 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -36,4 +36,21 @@
+/* Boot device */ +#define BOOT_DEVICE_NONE 0 +#define BOOT_DEVICE_XIP 1 +#define BOOT_DEVICE_XIPWAIT 2 +#define BOOT_DEVICE_NAND 3 +#define BOOT_DEVICE_ONE_NAND 4 +#define BOOT_DEVICE_MMC1 5 +#define BOOT_DEVICE_MMC2 6 + +/* Boot type */ +#define MMCSD_MODE_UNDEFINED 0 +#define MMCSD_MODE_RAW 1 +#define MMCSD_MODE_FAT 2 + +u32 omap_boot_device(void); +u32 omap_boot_mode(void); + #endif /* _OMAP_COMMON_H_ */ diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 1112362..f6f283a 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -252,6 +252,11 @@ #define CONFIG_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */
+#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" + #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBDISK_SUPPORT #define CONFIG_SPL_I2C_SUPPORT diff --git a/include/configs/omap4_sdp4430.h b/include/configs/omap4_sdp4430.h index 6a6be9e..346763d 100644 --- a/include/configs/omap4_sdp4430.h +++ b/include/configs/omap4_sdp4430.h @@ -258,6 +258,11 @@ #define CONFIG_SPL_BSS_START_ADDR 0x80000000 #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */
- Add mkimage support for OMAP boot image - Add support for OMAP boot image(MLO) generation in the new SPL framework
Signed-off-by: John Rigby john.rigby@linaro.org Signed-off-by: Aneesh V aneesh@ti.com --- V3: * Fixed minor issue with casting away 'const'ness of pointers * Ensure lists are sorted alphabetically * Added an error message * Removed 'packed' attribute from structs * Fixed some other minor comments on V2 * Adapted for the new SPL framework V4: * Replaced CONFIG_SYS_SPL_TEXT_BASE with CONFIG_SPL_TEXT_BASE --- arch/arm/cpu/armv7/omap4/config.mk | 30 +++++ common/image.c | 9 +- include/image.h | 1 + spl/Makefile | 6 + tools/Makefile | 2 + tools/mkimage.c | 2 + tools/mkimage.h | 1 + tools/omapimage.c | 224 ++++++++++++++++++++++++++++++++++++ tools/omapimage.h | 50 ++++++++ 9 files changed, 321 insertions(+), 4 deletions(-) create mode 100644 arch/arm/cpu/armv7/omap4/config.mk create mode 100644 tools/omapimage.c create mode 100644 tools/omapimage.h
diff --git a/arch/arm/cpu/armv7/omap4/config.mk b/arch/arm/cpu/armv7/omap4/config.mk new file mode 100644 index 0000000..b34fa64 --- /dev/null +++ b/arch/arm/cpu/armv7/omap4/config.mk @@ -0,0 +1,30 @@ +# +# Copyright 2011 Linaro Limited +# See file CREDITS for list of people who contributed to this +# project. +# +# (C) Copyright 2010 +# Texas Instruments, <www.ti.com> +# +# Aneesh V aneesh@ti.com +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +ifdef CONFIG_SPL_BUILD +ALL-y += $(OBJTREE)/MLO +else +ALL-y += $(obj)u-boot.img +endif diff --git a/common/image.c b/common/image.c index 5c7d4f4..5f71c99 100644 --- a/common/image.c +++ b/common/image.c @@ -130,17 +130,18 @@ static const table_entry_t uimage_os[] = { };
static const table_entry_t uimage_type[] = { - { IH_TYPE_INVALID, NULL, "Invalid Image", }, { IH_TYPE_FILESYSTEM, "filesystem", "Filesystem Image", }, { IH_TYPE_FIRMWARE, "firmware", "Firmware", }, + { IH_TYPE_FLATDT, "flat_dt", "Flat Device Tree", }, + { IH_TYPE_INVALID, NULL, "Invalid Image", }, + { IH_TYPE_IMXIMAGE, "imximage", "Freescale i.MX Boot Image",}, { IH_TYPE_KERNEL, "kernel", "Kernel Image", }, + { IH_TYPE_KWBIMAGE, "kwbimage", "Kirkwood Boot Image",}, { IH_TYPE_MULTI, "multi", "Multi-File Image", }, + { IH_TYPE_OMAPIMAGE, "omapimage", "TI OMAP SPL With GP CH",}, { IH_TYPE_RAMDISK, "ramdisk", "RAMDisk Image", }, { IH_TYPE_SCRIPT, "script", "Script", }, { IH_TYPE_STANDALONE, "standalone", "Standalone Program", }, - { IH_TYPE_FLATDT, "flat_dt", "Flat Device Tree", }, - { IH_TYPE_KWBIMAGE, "kwbimage", "Kirkwood Boot Image",}, - { IH_TYPE_IMXIMAGE, "imximage", "Freescale i.MX Boot Image",}, { -1, "", "", }, };
diff --git a/include/image.h b/include/image.h index c31e862..c606644 100644 --- a/include/image.h +++ b/include/image.h @@ -157,6 +157,7 @@ #define IH_TYPE_FLATDT 8 /* Binary Flat Device Tree Blob */ #define IH_TYPE_KWBIMAGE 9 /* Kirkwood Boot Image */ #define IH_TYPE_IMXIMAGE 10 /* Freescale IMXBoot Image */ +#define IH_TYPE_OMAPIMAGE 11 /* TI OMAP Config Header Image */
/* * Compression Types diff --git a/spl/Makefile b/spl/Makefile index 638aab7..2a1fd11 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -85,6 +85,12 @@ LDPPFLAGS += \ $(shell $(LD) --version | \ sed -ne 's/GNU ld version ([0-9][0-9]*).([0-9][0-9]*).*/-DLD_MAJOR=\1 -DLD_MINOR=\2/p')
+ifdef CONFIG_OMAP +$(OBJTREE)/MLO: $(obj)u-boot-spl.bin + $(OBJTREE)/tools/mkimage -T omapimage \ + -a $(CONFIG_SPL_TEXT_BASE) -d $< $@ +endif + ALL-y += $(obj)u-boot-spl.bin
all: $(ALL-y) diff --git a/tools/Makefile b/tools/Makefile index 97f83f8..cb7f92d 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -88,6 +88,7 @@ OBJ_FILES-$(CONFIG_CMD_LOADS) += img2srec.o OBJ_FILES-$(CONFIG_INCA_IP) += inca-swap-bytes.o NOPED_OBJ_FILES-y += kwbimage.o NOPED_OBJ_FILES-y += imximage.o +NOPED_OBJ_FILES-y += omapimage.o NOPED_OBJ_FILES-y += mkimage.o OBJ_FILES-$(CONFIG_NETCONSOLE) += ncb.o NOPED_OBJ_FILES-y += os_support.o @@ -188,6 +189,7 @@ $(obj)mkimage$(SFX): $(obj)crc32.o \ $(obj)md5.o \ $(obj)mkimage.o \ $(obj)os_support.o \ + $(obj)omapimage.o \ $(obj)sha1.o \ $(LIBFDT_OBJS) $(HOSTCC) $(HOSTCFLAGS) $(HOSTLDFLAGS) -o $@ $^ diff --git a/tools/mkimage.c b/tools/mkimage.c index 60f7263..b6a7cb7 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -156,6 +156,8 @@ main (int argc, char **argv) init_imx_image_type (); /* Init FIT image generation/list support */ init_fit_image_type (); + /* Init TI OMAP Boot image generation/list support */ + init_omap_image_type(); /* Init Default image generation/list support */ init_default_image_type ();
diff --git a/tools/mkimage.h b/tools/mkimage.h index 9033a7d..3b49645 100644 --- a/tools/mkimage.h +++ b/tools/mkimage.h @@ -143,5 +143,6 @@ void init_kwb_image_type (void); void init_imx_image_type (void); void init_default_image_type (void); void init_fit_image_type (void); +void init_omap_image_type(void);
#endif /* _MKIIMAGE_H_ */ diff --git a/tools/omapimage.c b/tools/omapimage.c new file mode 100644 index 0000000..29d91cc --- /dev/null +++ b/tools/omapimage.c @@ -0,0 +1,224 @@ +/* + * (C) Copyright 2010 + * Linaro LTD, www.linaro.org + * Author: John Rigby john.rigby@linaro.org + * Based on TI's signGP.c + * + * (C) Copyright 2009 + * Stefano Babic, DENX Software Engineering, sbabic@denx.de. + * + * (C) Copyright 2008 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* Required to obtain the getline prototype from stdio.h */ +#define _GNU_SOURCE + +#include "mkimage.h" +#include <image.h> +#include "omapimage.h" + +/* Header size is CH header rounded up to 512 bytes plus GP header */ +#define OMAP_CH_HDR_SIZE 512 +#define OMAP_GP_HDR_SIZE (sizeof(struct gp_header)) +#define OMAP_FILE_HDR_SIZE (OMAP_CH_HDR_SIZE+OMAP_GP_HDR_SIZE) + +static uint8_t omapimage_header[OMAP_FILE_HDR_SIZE]; + +static int omapimage_check_image_types(uint8_t type) +{ + if (type == IH_TYPE_OMAPIMAGE) + return EXIT_SUCCESS; + else { + fprintf(stderr, "Unknown OMAP image type - %x", type); + return EXIT_FAILURE; + } +} + +/* + * Only the simplest image type is currently supported: + * TOC pointing to CHSETTINGS + * TOC terminator + * CHSETTINGS + * + * padding to OMAP_CH_HDR_SIZE bytes + * + * gp header + * size + * load_addr + */ +static int valid_gph_size(uint32_t size) +{ + return size; +} + +static int valid_gph_load_addr(uint32_t load_addr) +{ + return load_addr; +} + +static int omapimage_verify_header(unsigned char *ptr, int image_size, + struct mkimage_params *params) +{ + struct ch_toc *toc = (struct ch_toc *)ptr; + struct gp_header *gph = (struct gp_header *)(ptr+OMAP_CH_HDR_SIZE); + uint32_t offset, size; + + while (toc->section_offset != 0xffffffff + && toc->section_size != 0xffffffff) { + offset = toc->section_offset; + size = toc->section_size; + if (!offset || !size) + return -1; + if (offset >= OMAP_CH_HDR_SIZE || + offset+size >= OMAP_CH_HDR_SIZE) + return -1; + toc++; + } + if (!valid_gph_size(gph->size)) + return -1; + if (!valid_gph_load_addr(gph->load_addr)) + return -1; + + return 0; +} + +static void omapimage_print_section(struct ch_settings *chs) +{ + const char *section_name; + + if (chs->section_key) + section_name = "CHSETTINGS"; + else + section_name = "UNKNOWNKEY"; + + printf("%s (%x) " + "valid:%x " + "version:%x " + "reserved:%x " + "flags:%x\n", + section_name, + chs->section_key, + chs->valid, + chs->version, + chs->reserved, + chs->flags); +} + +static void omapimage_print_header(const void *ptr) +{ + const struct ch_toc *toc = (struct ch_toc *)ptr; + const struct gp_header *gph = + (struct gp_header *)(ptr+OMAP_CH_HDR_SIZE); + uint32_t offset, size; + + while (toc->section_offset != 0xffffffff + && toc->section_size != 0xffffffff) { + offset = toc->section_offset; + size = toc->section_size; + + if (offset >= OMAP_CH_HDR_SIZE || + offset+size >= OMAP_CH_HDR_SIZE) + exit(EXIT_FAILURE); + + printf("Section %s offset %x length %x\n", + toc->section_name, + toc->section_offset, + toc->section_size); + + omapimage_print_section((struct ch_settings *)(ptr+offset)); + toc++; + } + + if (!valid_gph_size(gph->size)) { + fprintf(stderr, + "Error: invalid image size %x\n", + gph->size); + exit(EXIT_FAILURE); + } + + if (!valid_gph_load_addr(gph->load_addr)) { + fprintf(stderr, + "Error: invalid image load address %x\n", + gph->size); + exit(EXIT_FAILURE); + } + + printf("GP Header: Size %x LoadAddr %x\n", + gph->size, gph->load_addr); +} + +static int toc_offset(void *hdr, void *member) +{ + return member - hdr; +} + +static void omapimage_set_header(void *ptr, struct stat *sbuf, int ifd, + struct mkimage_params *params) +{ + struct ch_toc *toc = (struct ch_toc *)ptr; + struct ch_settings *chs = (struct ch_settings *) + (ptr + 2 * sizeof(*toc)); + struct gp_header *gph = (struct gp_header *)(ptr + OMAP_CH_HDR_SIZE); + + toc->section_offset = toc_offset(ptr, chs); + toc->section_size = sizeof(struct ch_settings); + strcpy((char *)toc->section_name, "CHSETTINGS"); + + chs->section_key = KEY_CHSETTINGS; + chs->valid = 0; + chs->version = 1; + chs->reserved = 0; + chs->flags = 0; + + toc++; + memset(toc, 0xff, sizeof(*toc)); + + gph->size = sbuf->st_size - OMAP_FILE_HDR_SIZE; + gph->load_addr = params->addr; +} + +int omapimage_check_params(struct mkimage_params *params) +{ + return (params->dflag && (params->fflag || params->lflag)) || + (params->fflag && (params->dflag || params->lflag)) || + (params->lflag && (params->dflag || params->fflag)); +} + +/* + * omapimage parameters + */ +static struct image_type_params omapimage_params = { + .name = "TI OMAP CH/GP Boot Image support", + .header_size = OMAP_FILE_HDR_SIZE, + .hdr = (void *)&omapimage_header, + .check_image_type = omapimage_check_image_types, + .verify_header = omapimage_verify_header, + .print_header = omapimage_print_header, + .set_header = omapimage_set_header, + .check_params = omapimage_check_params, +}; + +void init_omap_image_type(void) +{ + mkimage_register(&omapimage_params); +} diff --git a/tools/omapimage.h b/tools/omapimage.h new file mode 100644 index 0000000..719db00 --- /dev/null +++ b/tools/omapimage.h @@ -0,0 +1,50 @@ +/* + * (C) Copyright 2010 + * Linaro LTD, www.linaro.org + * Author John Rigby john.rigby@linaro.org + * Based on TI's signGP.c + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _OMAPIMAGE_H_ +#define _OMAPIMAGE_H_ + +struct ch_toc { + uint32_t section_offset; + uint32_t section_size; + uint8_t unused[12]; + uint8_t section_name[12]; +}; + +struct ch_settings { + uint32_t section_key; + uint8_t valid; + uint8_t version; + uint16_t reserved; + uint32_t flags; +}; + +struct gp_header { + uint32_t size; + uint32_t load_addr; +}; + +#define KEY_CHSETTINGS 0xC0C0C0C1 +#endif /* _OMAPIMAGE_H_ */
participants (15)
Albert ARIBAUD
Aneesh V
Bedia, Vaibhav
Chander M. Kashyap
Daniel Schwierzeck
John Rigby
Mike Frysinger
Måns Rullgård
Paulraj, Sandeep
Po-Yu Chuang
Reinhard Meyer
Scott Wood
Simon Schwarz
V, Aneesh
