[U-Boot] [PATCH] MPC5200 FEC MII speed register
Set a non-zero speed in the MII register so that MII commands will work.
Signed-off-by: Jon Smirl jonsmirl@gmail.com --- drivers/net/mpc5xxx_fec.c | 23 ++++++++++++++++------- 1 files changed, 16 insertions(+), 7 deletions(-)
diff --git a/drivers/net/mpc5xxx_fec.c b/drivers/net/mpc5xxx_fec.c index 89e91c3..1876b76 100644 --- a/drivers/net/mpc5xxx_fec.c +++ b/drivers/net/mpc5xxx_fec.c @@ -285,13 +285,6 @@ static int mpc5xxx_fec_init(struct eth_device *dev, bd_t * bis) }
fec->eth->x_cntrl = 0x00000000; /* half-duplex, heartbeat disabled */ - if (fec->xcv_type != SEVENWIRE) { - /* - * Set MII_SPEED = (1/(mii_speed * 2)) * System Clock - * and do not drop the Preamble. - */ - fec->eth->mii_speed = (((gd->ipb_clk >> 20) / 5) << 1); /* No MII for 7-wire mode */ - }
/* * Set Opcode/Pause Duration Register @@ -649,6 +642,15 @@ static void mpc5xxx_fec_halt(struct eth_device *dev) */ udelay(10);
+ /* don't leave the MII speed set to zero */ + if (fec->xcv_type != SEVENWIRE) { + /* + * Set MII_SPEED = (1/(mii_speed * 2)) * System Clock + * and do not drop the Preamble. + */ + fec->eth->mii_speed = (((gd->ipb_clk >> 20) / 5) << 1); /* No MII for 7-wire mode */ + } + #if (DEBUG & 0x3) printf("Ethernet task stopped\n"); #endif @@ -906,6 +908,13 @@ int mpc5xxx_fec_initialize(bd_t * bis) #else #error fec->xcv_type not initialized. #endif + if (fec->xcv_type != SEVENWIRE) { + /* + * Set MII_SPEED = (1/(mii_speed * 2)) * System Clock + * and do not drop the Preamble. + */ + fec->eth->mii_speed = (((gd->ipb_clk >> 20) / 5) << 1); /* No MII for 7-wire mode */ + }
dev->priv = (void *)fec; dev->iobase = MPC5XXX_FEC;
On Wed, Mar 11, 2009 at 3:08 PM, Jon jonsmirl@gmail.com wrote:
Who's the maintainer for the mpc5200 core code? It isn't clear from the MAINTAINERS file.
- /* don't leave the MII speed set to zero */
Dear Jon Smirl,
In message 9e4733910903122026h638e6cbfl89fa30664dcffd2@mail.gmail.com you wrote:
If in doubt, contact the respective custodian.
See http://www.denx.de/wiki/U-Boot/Custodians
John, could you please apply this.
Without this the MII commands don't work on any of the mpc5200 platforms. mpc5xxx_fec_halt() sets the mii speed register to zero it needs to left at a non-zero speed for the commands to function.
---------- Forwarded message ---------- From: Jon jonsmirl@gmail.com Date: Wed, Mar 11, 2009 at 3:08 PM Subject: [PATCH] MPC5200 FEC MII speed register To: u-boot@lists.denx.de
} /* * Set Opcode/Pause Duration Register
} dev->priv = (void *)fec; dev->iobase = MPC5XXX_FEC;
done
John Rigby
Jon
Jon Smirl
