[U-Boot] [PATCH 2/4] Armada100: SPI Flash support for Marvell gplugD
SPI Flash support added for Marvell GuruPlug-Display. Environment variables are now stored in flash.
Signed-off-by: Ajay Bhargav ajay.bhargav@einfochips.com --- arch/arm/include/asm/arch-armada100/gpio.h | 2 +- arch/arm/include/asm/arch-armada100/mfp.h | 6 + arch/arm/include/asm/arch-armada100/regs-ssp.h | 165 +++++++++++++++ board/Marvell/gplugd/gplugd.c | 20 ++ drivers/spi/Makefile | 1 + drivers/spi/pxa3xx_spi.c | 256 ++++++++++++++++++++++++ include/configs/gplugd.h | 32 +++- 7 files changed, 475 insertions(+), 7 deletions(-) create mode 100644 arch/arm/include/asm/arch-armada100/regs-ssp.h create mode 100644 drivers/spi/pxa3xx_spi.c
diff --git a/arch/arm/include/asm/arch-armada100/gpio.h b/arch/arm/include/asm/arch-armada100/gpio.h index e13c2da..dd23908 100644 --- a/arch/arm/include/asm/arch-armada100/gpio.h +++ b/arch/arm/include/asm/arch-armada100/gpio.h @@ -25,7 +25,7 @@ #define __PXA_GPIO_H
-#define GPIO_REGS_VIRT (0xD4019000) +#define GPIO_REGS_VIRT (0xD4019000)
#define BANK_OFF(n) (((n) < 3) ? (n) << 2 : 0x100 + (((n) - 3) << 2)) #define GPIO_REG(x) (GPIO_REGS_VIRT + (x)) diff --git a/arch/arm/include/asm/arch-armada100/mfp.h b/arch/arm/include/asm/arch-armada100/mfp.h index da76b58..e94be3a 100644 --- a/arch/arm/include/asm/arch-armada100/mfp.h +++ b/arch/arm/include/asm/arch-armada100/mfp.h @@ -83,6 +83,12 @@ #define MFP101_ETH_MDIO (MFP_REG(0x194) | MFP_AF5 | MFP_DRIVE_MEDIUM) #define MFP103_ETH_RXDV (MFP_REG(0x19C) | MFP_AF5 | MFP_DRIVE_MEDIUM)
+/* SPI */ +#define MFP107_SSP2_RXD (MFP_REG(0x1AC) | MFP_AF4 | MFP_DRIVE_MEDIUM) +#define MFP108_SSP2_TXD (MFP_REG(0x1B0) | MFP_AF4 | MFP_DRIVE_MEDIUM) +#define MFP110_SSP2_CS (MFP_REG(0x1B8) | MFP_AF0 | MFP_DRIVE_MEDIUM) +#define MFP111_SSP2_CLK (MFP_REG(0x1BC) | MFP_AF4 | MFP_DRIVE_MEDIUM) + /* More macros can be defined here... */
#define MFP_PIN_MAX 117 diff --git a/arch/arm/include/asm/arch-armada100/regs-ssp.h b/arch/arm/include/asm/arch-armada100/regs-ssp.h new file mode 100644 index 0000000..dbe7e83 --- /dev/null +++ b/arch/arm/include/asm/arch-armada100/regs-ssp.h @@ -0,0 +1,165 @@ +/************************************************************************** + * + * Copyright (c) 2009, 2010 Marvell International Ltd. + * + * This file is part of GNU program. + * + * GNU program is free software: you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation, either version 2 of the License, or (at your + * option) any later version. + * + * GNU program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General + * Public License for more details. + * + * You should have received a copy of the GNU General Public License along + * with this program. + * + * If not, see http://www.gnu.org/licenses/old-licenses/gpl-2.0.html + * + *************************************************************************/ + +#ifndef __ASM_ARCH_REGS_SSP_H +#define __ASM_ARCH_REGS_SSP_H + +/* + * SSP Serial Port Registers + * PXA250, PXA255, PXA26x and PXA27x SSP controllers are all slightly different. + * PXA255, PXA26x and PXA27x have extra ports, registers and bits. + */ + +#define SSCR0 (0x00) /* SSP Control Register 0 */ +#define SSCR1 (0x04) /* SSP Control Register 1 */ +#define SSSR (0x08) /* SSP Status Register */ +#define SSITR (0x0C) /* SSP Interrupt Test Register */ +#define SSDR (0x10) /* SSP Data Write/Data Read Register */ + +#define SSTO (0x28) /* SSP Time Out Register */ +#define SSPSP (0x2C) /* SSP Programmable Serial Protocol */ +#define SSTSA (0x30) /* SSP Tx Timeslot Active */ +#define SSRSA (0x34) /* SSP Rx Timeslot Active */ +#define SSTSS (0x38) /* SSP Timeslot Status */ +#define SSACD (0x3C) /* SSP Audio Clock Divider */ + +#if defined(CONFIG_PXA3xx) || defined(CONFIG_CPU_PXA910) +#define SSACDD (0x40) /* SSP Audio Clock Dither Divider */ +#endif + +/* Common PXA2xx bits first */ +#define SSCR0_DSS (0x0000000f) /* Data Size Select (mask) */ +#define SSCR0_DataSize(x) ((x) - 1) /* Data Size Select [4..16] */ +#define SSCR0_FRF (0x00000030) /* FRame Format (mask) */ +#define SSCR0_Motorola (0x0 << 4) /* Motorola's Serial + Peripheral Interface */ +#define SSCR0_TI (0x1 << 4) /* TI's Synchronous + Serial Protocol (SSP) */ +#define SSCR0_National (0x2 << 4) /* National Microwire */ +#define SSCR0_ECS (1 << 6) /* External clock select */ +#define SSCR0_SSE (1 << 7) /* Synchronous Serial Port Enable */ + +#if defined(CONFIG_PXA25x) +#define SSCR0_SCR (0x0000ff00) /* Serial Clock Rate (mask) */ +#define SSCR0_SerClkDiv(x) ((((x) - 2)/2) << 8) /* Divisor [2..512] */ +#elif defined(CONFIG_PXA27x) || \ + defined(CONFIG_PXA3xx) || \ + defined(CONFIG_CPU_PXA910) +#define SSCR0_SCR (0x000fff00) /* Serial Clock Rate (mask) */ +#define SSCR0_SerClkDiv(x) (((x) - 1) << 8) /* Divisor [1..4096] */ +#endif + +#if defined(CONFIG_PXA27x) || \ + defined(CONFIG_PXA3xx) || \ + defined(CONFIG_CPU_PXA910) +#define SSCR0_EDSS (1 << 20) /* Extended data size select */ +#define SSCR0_NCS (1 << 21) /* Network clock select */ +#define SSCR0_RIM (1 << 22) /* Receive FIFO overrrun + interrupt mask */ +#define SSCR0_TUM (1 << 23) /* Transmit FIFO underrun + interrupt mask */ +#define SSCR0_FRDC (0x07000000) /* Frame rate divider control (mask) */ +#define SSCR0_SlotsPerFrm(x) (((x) - 1) << 24) + /* Time slots per frame [1..8] */ +#define SSCR0_ADC (1 << 30) /* Audio clock select */ +#define SSCR0_MOD (1 << 31) /* Mode (normal or network) */ +#endif + +#if defined(CONFIG_PXA3xx) || defined(CONFIG_CPU_PXA910) +#define SSCR0_FPCKE (1 << 29) /* FIFO packing enable */ +#endif + +#define SSCR1_RIE (1 << 0) /* Receive FIFO Interrupt Enable */ +#define SSCR1_TIE (1 << 1) /* Transmit FIFO Interrupt Enable */ +#define SSCR1_LBM (1 << 2) /* Loop-Back Mode */ +#define SSCR1_SPO (1 << 3) /* Motorola SPI SSPSCLK + polarity setting */ +#define SSCR1_SPH (1 << 4) /* Motorola SPI SSPSCLK phase setting */ +#define SSCR1_MWDS (1 << 5) /* Microwire Transmit Data Size */ +#define SSCR1_TFT (0x000003c0) /* Transmit FIFO Threshold (mask) */ +#define SSCR1_TxTresh(x) (((x) - 1) << 6) /* level [1..16] */ +#define SSCR1_RFT (0x00003c00) /* Receive FIFO Threshold (mask) */ +#define SSCR1_RxTresh(x) (((x) - 1) << 10) /* level [1..16] */ + +#define SSSR_TNF (1 << 2) /* Transmit FIFO Not Full */ +#define SSSR_RNE (1 << 3) /* Receive FIFO Not Empty */ +#define SSSR_BSY (1 << 4) /* SSP Busy */ +#define SSSR_TFS (1 << 5) /* Transmit FIFO Service Request */ +#define SSSR_RFS (1 << 6) /* Receive FIFO Service Request */ +#define SSSR_ROR (1 << 7) /* Receive FIFO Overrun */ + +#define SSCR0_TIM (1 << 23) /* Transmit FIFO Under Run + Interrupt Mask */ +#define SSCR0_RIM (1 << 22) /* Receive FIFO Over + Run interrupt Mask */ +#define SSCR0_NCS (1 << 21) /* Network Clock Select */ +#define SSCR0_EDSS (1 << 20) /* Extended Data Size Select */ + +/* extra bits in PXA255, PXA26x and PXA27x SSP ports */ +#define SSCR0_TISSP (1 << 4) /* TI Sync Serial Protocol */ +#define SSCR0_PSP (3 << 4) /* PSP - Programmable Serial Protocol */ +#define SSCR1_TTELP (1 << 31) /* TXD Tristate Enable Last Phase */ +#define SSCR1_TTE (1 << 30) /* TXD Tristate Enable */ +#define SSCR1_EBCEI (1 << 29) /* Enable Bit Count Error interrupt */ +#define SSCR1_SCFR (1 << 28) /* Slave Clock free Running */ +#define SSCR1_ECRA (1 << 27) /* Enable Clock Request A */ +#define SSCR1_ECRB (1 << 26) /* Enable Clock request B */ +#define SSCR1_SCLKDIR (1 << 25) /* Serial Bit Rate Clock Direction */ +#define SSCR1_SFRMDIR (1 << 24) /* Frame Direction */ +#define SSCR1_RWOT (1 << 23) /* Receive Without Transmit */ +#define SSCR1_TRAIL (1 << 22) /* Trailing Byte */ +#define SSCR1_TSRE (1 << 21) /* Transmit Service Request Enable */ +#define SSCR1_RSRE (1 << 20) /* Receive Service Request Enable */ +#define SSCR1_TINTE (1 << 19) /* Receiver Time-out Interrupt enable */ +#define SSCR1_PINTE (1 << 18) /* Peripheral Trailing + Byte Interupt Enable */ +#define SSCR1_IFS (1 << 16) /* Invert Frame Signal */ +#define SSCR1_STRF (1 << 15) /* Select FIFO or EFWR */ +#define SSCR1_EFWR (1 << 14) /* Enable FIFO Write/Read */ + +#define SSSR_BCE (1 << 23) /* Bit Count Error */ +#define SSSR_CSS (1 << 22) /* Clock Synchronisation Status */ +#define SSSR_TUR (1 << 21) /* Transmit FIFO Under Run */ +#define SSSR_EOC (1 << 20) /* End Of Chain */ +#define SSSR_TINT (1 << 19) /* Receiver Time-out Interrupt */ +#define SSSR_PINT (1 << 18) /* Peripheral Trailing Byte Interrupt */ + +#define SSPSP_FSRT (1 << 25) /* Frame Sync Relative Timing */ +#define SSPSP_DMYSTOP(x) ((x) << 23) /* Dummy Stop */ +#define SSPSP_SFRMWDTH(x) ((x) << 16) /* Serial Frame Width */ +#define SSPSP_SFRMDLY(x) ((x) << 9) /* Serial Frame Delay */ +#define SSPSP_DMYSTRT(x) ((x) << 7) /* Dummy Start */ +#define SSPSP_STRTDLY(x) ((x) << 4) /* Start Delay */ +#define SSPSP_ETDS (1 << 3) /* End of Transfer data State */ +#define SSPSP_SFRMP (1 << 2) /* Serial Frame Polarity */ +#define SSPSP_SCMODE(x) ((x) << 0) /* Serial Bit Rate Clock Mode */ + +#define SSACD_SCDB (1 << 3) /* SSPSYSCLK Divider Bypass */ +#define SSACD_ACPS(x) ((x) << 4) /* Audio clock PLL select */ +#define SSACD_ACDS(x) ((x) << 0) /* Audio clock divider select */ +#if defined(CONFIG_PXA3xx) || defined(CONFIG_CPU_PXA910) +#define SSACD_SCDX8 (1 << 7) /* SYSCLK division ratio select */ +#endif + + +#endif /* __ASM_ARCH_REGS_SSP_H */ diff --git a/board/Marvell/gplugd/gplugd.c b/board/Marvell/gplugd/gplugd.c index 81770fc..0c7a8fd 100644 --- a/board/Marvell/gplugd/gplugd.c +++ b/board/Marvell/gplugd/gplugd.c @@ -47,6 +47,7 @@ DECLARE_GLOBAL_DATA_PTR; #define PHY_LED_VAL 0x5b /* LINK LED1, ACT LED2 */ #define PHY_RST 104 /* GPIO104 - PHY RESET */ #define RTC_IRQ 102 /* GPIO102 - RTC IRQ Input */ +#define SSP2CS 110 /* GPIO110 - SSP Chip Select */ #define FE_CLK_RST 0x1 #define FE_CLK_ENA 0x8
@@ -80,6 +81,11 @@ int board_early_init_f(void) MFP101_ETH_MDIO, MFP103_ETH_RXDV,
+ MFP107_SSP2_RXD, + MFP108_SSP2_TXD, + MFP110_SSP2_CS, + MFP111_SSP2_CLK, + MFP_EOC /*End of configuration*/ }; /* configure MFP's */ @@ -93,11 +99,25 @@ int board_early_init_f(void)
int board_init(void) { + struct armd1apb1_registers *apb1_regs = + (struct armd1apb1_registers *)ARMD1_APBC1_BASE; + struct armd1apb2_registers *apb2_regs = + (struct armd1apb2_registers *)ARMD1_APBC2_BASE; + /* arch number of Board */ gd->bd->bi_arch_number = MACH_TYPE_SHEEVAD; /* adress of boot parameters */ gd->bd->bi_boot_params = armd1_sdram_base(0) + 0x100;
+#ifdef CONFIG_PXA3XX_SPI + /* Enable SSP2 clock */ + writel(0x03, &apb2_regs->ssp2_clkrst); + /* enable GPIO clock */ + writel(0x01, &apb1_regs->gpio); + /* configure GPIO110 as CS# */ + gpio_direction_output(SSP2CS, GPIO_SET); +#endif + return 0; }
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index a9b1ca4..9626772 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -40,6 +40,7 @@ COBJS-$(CONFIG_OMAP3_SPI) += omap3_spi.o COBJS-$(CONFIG_SOFT_SPI) += soft_spi.o COBJS-$(CONFIG_SH_SPI) += sh_spi.o COBJS-$(CONFIG_FSL_ESPI) += fsl_espi.o +COBJS-$(CONFIG_PXA3XX_SPI) += pxa3xx_spi.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/spi/pxa3xx_spi.c b/drivers/spi/pxa3xx_spi.c new file mode 100644 index 0000000..8d05f90 --- /dev/null +++ b/drivers/spi/pxa3xx_spi.c @@ -0,0 +1,256 @@ +/************************************************************************** + * + * Copyright (c) 2009, 2010 Marvell International Ltd. + * + * This file is part of GNU program. + * + * GNU program is free software: you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the + * Free Software Foundation, either version 2 of the License, or (at your + * option) any later version. + * + * GNU program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General + * Public License for more details. + * + * You should have received a copy of the GNU General Public License along + * with this program. + * + * If not, see http://www.gnu.org/licenses/old-licenses/gpl-2.0.html + * + *************************************************************************/ + +/* + * Driver for simulating ssp as spi device for pxa + * + * Copyright (c) 2009 Marvell Inc. + * Lei Wen leiwen@marvell.com + * + * Licensed under the GPL-2 or later. + */ + + +#include <common.h> +#include <malloc.h> +#include <spi.h> + +#include <asm/io.h> +#include <asm/arch/regs-ssp.h> +#include <asm/arch/gpio.h> + +struct pxa_spi_slave { + struct spi_slave slave; + u32 cr0, cr1; + u32 int_cr1; + u32 clear_sr; + const void *tx; + void *rx; + int gpio_cs_inverted; + + void (*write)(struct pxa_spi_slave *pss); + void (*read)(struct pxa_spi_slave *pss); +}; + +#define to_pxa_spi_slave(s) container_of(s, struct pxa_spi_slave, slave) + +#define DEFINE_SSP_REG(reg, off) \ + static inline u32 read_##reg(void) \ +{ return __raw_readl(CONFIG_SYS_SSP_BASE + (off)); } \ +\ +static inline void write_##reg(u32 v) \ +{ __raw_writel(v, CONFIG_SYS_SSP_BASE + (off)); } + +DEFINE_SSP_REG(SSCR0, 0x00) +DEFINE_SSP_REG(SSCR1, 0x04) +DEFINE_SSP_REG(SSSR, 0x08) +DEFINE_SSP_REG(SSITR, 0x0c) +DEFINE_SSP_REG(SSDR, 0x10) +DEFINE_SSP_REG(SSTO, 0x28) +DEFINE_SSP_REG(SSPSP, 0x2c) + +#define DEFAULT_WORD_LEN 8 +#define SSP_FLUSH_NUM 0x2000 +#define RX_THRESH_DFLT 8 +#define TX_THRESH_DFLT 8 +#define TIMOUT_DFLT 1000 + +void spi_cs_activate(struct spi_slave *slave) +{ + struct pxa_spi_slave *pss = to_pxa_spi_slave(slave); + gpio_set_value(slave->cs, pss->gpio_cs_inverted); +} + +void spi_cs_deactivate(struct spi_slave *slave) +{ + struct pxa_spi_slave *pss = to_pxa_spi_slave(slave); + gpio_set_value(slave->cs, !pss->gpio_cs_inverted); +} + +static void null_writer(struct pxa_spi_slave *pss) +{ + while (!(read_SSSR() & SSSR_TNF)) + continue; + + write_SSDR(0); +} + +static void null_reader(struct pxa_spi_slave *pss) +{ + while (!(read_SSSR() & SSSR_RNE)) + continue; + read_SSDR(); +} + +static void u8_writer(struct pxa_spi_slave *pss) +{ + while (!(read_SSSR() & SSSR_TNF)) + continue; + + write_SSDR(*(u8 *)(pss->tx)); + ++pss->tx; +} + +static void u8_reader(struct pxa_spi_slave *pss) +{ + while (!(read_SSSR() & SSSR_RNE)) + continue; + *(u8 *)(pss->rx) = read_SSDR(); + ++pss->rx; +} + +static int flush(void) +{ + unsigned long limit = SSP_FLUSH_NUM; + + do { + while (read_SSSR() & SSSR_RNE) + read_SSDR(); + } while ((read_SSSR() & SSSR_BSY) && limit--); + write_SSSR(SSSR_ROR); + + return limit; +} + +struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, + unsigned int max_hz, unsigned int mode) +{ + struct pxa_spi_slave *pss; + unsigned int clk_div; + + clk_div = ((CONFIG_SSP_CLK / max_hz - 1) & 0xfff) << 8; + + pss = malloc(sizeof(*pss)); + if (!pss) + return NULL; + + pss->slave.bus = bus; + pss->slave.cs = cs; + + pss->cr0 = clk_div + | SSCR0_Motorola + | SSCR0_DataSize(DEFAULT_WORD_LEN) + | SSCR0_SSE; + + pss->cr1 = (SSCR1_RxTresh(RX_THRESH_DFLT) & SSCR1_RFT) | + (SSCR1_TxTresh(TX_THRESH_DFLT) & SSCR1_TFT); + pss->cr1 &= ~(SSCR1_SPO | SSCR1_SPH); + pss->cr1 |= (((mode & SPI_CPHA) != 0) ? SSCR1_SPH : 0) + | (((mode & SPI_CPOL) != 0) ? SSCR1_SPO : 0); + + pss->int_cr1 = SSCR1_TIE | SSCR1_RIE | SSCR1_TINTE; + pss->clear_sr = SSSR_ROR | SSSR_TINT; + + pss->gpio_cs_inverted = mode & SPI_CS_HIGH; + gpio_set_value(cs, !pss->gpio_cs_inverted); + + return &pss->slave; +} + +void spi_free_slave(struct spi_slave *slave) +{ + struct pxa_spi_slave *pss = to_pxa_spi_slave(slave); + free(pss); +} + +void spi_init() +{ + /* Load default SSP configuration */ + write_SSCR0(0); + write_SSCR1(SSCR1_RxTresh(RX_THRESH_DFLT) | + SSCR1_TxTresh(TX_THRESH_DFLT)); + write_SSCR0(SSCR0_SerClkDiv(2) + | SSCR0_Motorola + | SSCR0_DataSize(DEFAULT_WORD_LEN)); + write_SSTO(0); + write_SSPSP(0); +} + +int spi_claim_bus(struct spi_slave *slave) +{ + debug("%s: bus:%i cs:%i\n", __func__, slave->bus, slave->cs); + if (flush() == 0) + return -1; + + return 0; +} + +void spi_release_bus(struct spi_slave *slave) +{ +} + +int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, + void *din, unsigned long flags) +{ + struct pxa_spi_slave *pss = to_pxa_spi_slave(slave); + uint bytes = bitlen / 8; + unsigned long limit; + int ret = 0; + + if (bitlen == 0) + goto done; + + /* we can only do 8 bit transfers */ + if (bitlen % 8) { + flags |= SPI_XFER_END; + goto done; + } + + if (dout) { + pss->tx = dout; + pss->write = u8_writer; + } else + pss->write = null_writer; + + if (din) { + pss->rx = din; + pss->read = u8_reader; + } else + pss->read = null_reader; + + if (flags & SPI_XFER_BEGIN) { + spi_cs_activate(slave); + write_SSCR1(pss->cr1 | pss->int_cr1); + write_SSTO(TIMOUT_DFLT); + write_SSCR0(pss->cr0); + } + + while (bytes--) { + limit = SSP_FLUSH_NUM; + pss->write(pss); + while ((read_SSSR() & SSSR_BSY) && limit--) + udelay(1); + pss->read(pss); + } + + done: + if (flags & SPI_XFER_END) { + /* Stop SSP */ + write_SSSR(pss->clear_sr); + write_SSCR1(read_SSCR1() & ~pss->int_cr1); + write_SSTO(0); + spi_cs_deactivate(slave); + } + + return ret; +} diff --git a/include/configs/gplugd.h b/include/configs/gplugd.h index d2b91d7..f0fb057 100644 --- a/include/configs/gplugd.h +++ b/include/configs/gplugd.h @@ -83,6 +83,31 @@ #define CONFIG_ROOTPATH "/tftpboot" #define CONFIG_SYS_IMG_NAME "uImage"
+/* Flash support */ +#define CONFIG_PXA3XX_SPI + +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_SECT_SIZE 0x4000 +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_OFFSET 0x07C000 + +#if defined(CONFIG_PXA3XX_SPI) +#define CONFIG_PXA3xx +#define CONFIG_SSP_CLK 6500000 +#define CONFIG_SYS_SSP_BASE 0xD401C000 +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 110 +#define CONFIG_ENV_SPI_MAX_HZ 26000 +#define CONFIG_ENV_SPI_MODE 0 +#define CONFIG_CMD_SF +#define SF_PROBE_ONCE_FOR_COMMAND +#define CONFIG_PROBE_FLASH_INIT +#define CONFIG_SPI_FLASH_ATMEL 1 +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_EDITENV +#define CONFIG_CMD_SAVEENV +#endif /*CONFIG_PXA3XX_SPI*/ + /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros @@ -96,10 +121,5 @@
#define CONFIG_SYS_NS16550_COM1 ARMD1_UART3_BASE
-/* - * Environment variables configurations - */ -#define CONFIG_ENV_IS_NOWHERE 1 /* if env in SDRAM */ -#define CONFIG_ENV_SIZE 0x20000 /* 64k */ - #endif /* __CONFIG_GPLUGD_H */ +
Dear Ajay Bhargav,
In message 1310106168-17166-2-git-send-email-ajay.bhargav@einfochips.com you wrote:
No parens areound plain constants values, please.
Please fix globally.
- Copyright (c) 2009, 2010 Marvell International Ltd.
Incorrect multiline comment style. Please fix globally.
Please keep / make list sorted.
- This file is part of GNU program.
- GNU program is free software: you can redistribute it and/or modify it
- under the terms of the GNU General Public License as published by the
- Free Software Foundation, either version 2 of the License, or (at your
- option) any later version.
- GNU program is distributed in the hope that it will be useful, but
- WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General
- Public License for more details.
- You should have received a copy of the GNU General Public License along
- with this program.
- Driver for simulating ssp as spi device for pxa
- Copyright (c) 2009 Marvell Inc.
- Lei Wen leiwen@marvell.com
- Licensed under the GPL-2 or later.
Please remove the redunant parts of the Copyright/License headers. Please fix globally.
- static inline u32 read_##reg(void) \
We don't allow accesses through base address plus offset; please use proper C structs instead.
NAK. Please use C struct.
- while (!(read_SSSR() & SSSR_TNF))
We don't allow camel-case identifiers. Please fix globally.
continue;
Please use a plain ';' instead of this 'continue'. Please fix globally.
@@ -96,10 +121,5 @@
- Environment variables configurations
Please do not add trailing empty lines.
-----Original Message----- From: Ajay Bhargav [mailto:ajay.bhargav@einfochips.com] Sent: Friday, July 08, 2011 11:53 AM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Ajay Bhargav Subject: [PATCH 2/4] Armada100: SPI Flash support for Marvell gplugD
The file name should be mvspi.c
Split this patch as SPI driver support for Armada100 followed by enabling it for this board addressing GPIOs separately.
Regards.. Prafulla . .
Hi Prafulla,
Thanks, I will do that.
Regards, Ajay Bhargav
----- Original Message ----- From: "Prafulla Wadaskar" prafulla@marvell.com To: "Ajay Bhargav" ajay.bhargav@einfochips.com Cc: u-boot@lists.denx.de, "Ashish Karkare" akarkare@marvell.com, "Prabhanjan Sarnaik" sarnaik@marvell.com Sent: Friday, July 8, 2011 8:51:37 PM Subject: RE: [PATCH 2/4] Armada100: SPI Flash support for Marvell gplugD
Ajay Bhargav
Prafulla Wadaskar
