[U-Boot] [PATCH 2/3] nds32: Support AG101P timer DM.
Support AG101P timer device tree flow.
Signed-off-by: rick rick@andestech.com --- arch/nds32/cpu/n1213/ag101/timer.c | 3 +- arch/nds32/dts/ag101p.dts | 8 +++ configs/adp-ag101p_defconfig | 2 + drivers/timer/Kconfig | 6 ++ drivers/timer/Makefile | 1 + drivers/timer/ag101p_timer.c | 122 ++++++++++++++++++++++++++++++++++++ 6 files changed, 141 insertions(+), 1 deletion(-) create mode 100644 drivers/timer/ag101p_timer.c
diff --git a/arch/nds32/cpu/n1213/ag101/timer.c b/arch/nds32/cpu/n1213/ag101/timer.c index 758b354..0c03a10 100644 --- a/arch/nds32/cpu/n1213/ag101/timer.c +++ b/arch/nds32/cpu/n1213/ag101/timer.c @@ -8,7 +8,7 @@ * * SPDX-License-Identifier: GPL-2.0+ */ - +#ifndef CONFIG_TIMER #include <common.h> #include <asm/io.h> #include <faraday/fttmr010.h> @@ -189,3 +189,4 @@ ulong get_tbclk(void) return CONFIG_SYS_CLK_FREQ; #endif } +#endif /* CONFIG_TIMER */ diff --git a/arch/nds32/dts/ag101p.dts b/arch/nds32/dts/ag101p.dts index 2baa3dc..91314b5 100644 --- a/arch/nds32/dts/ag101p.dts +++ b/arch/nds32/dts/ag101p.dts @@ -13,6 +13,7 @@ /* bootargs = "console=ttyS0,38400n8 earlyprintk=uart8250-32bit,0x99600000 debug bootmem_debug memblock=debug loglevel=7"; */ bootargs = "console=ttyS0,38400n8 earlyprintk=uart8250-32bit,0x99600000 debug loglevel=7"; stdout-path = "uart0:38400n8"; + tick-timer = &timer0; };
memory@0 { @@ -46,4 +47,11 @@ no-loopback-test = <1>; };
+ timer0: timer@98400000 { + compatible = "andestech,attmr010"; + reg = <0x98400000 0x1000>; + interrupts = <19 4>; + clock-frequency = <15000000>; + }; + }; diff --git a/configs/adp-ag101p_defconfig b/configs/adp-ag101p_defconfig index 2a7302f..685a961 100644 --- a/configs/adp-ag101p_defconfig +++ b/configs/adp-ag101p_defconfig @@ -18,3 +18,5 @@ CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_TIMER=y +CONFIG_AG101P_TIMER=y diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index e038523..356fa29 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -74,4 +74,10 @@ config ARC_TIMER usually at least one of them exists. Either of them is supported in U-Boot.
+config AG101P_TIMER + bool "Ag101p timer support" + depends on TIMER + help + Select this to enable a timer for Ag101p devices. + endmenu diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index bfe65fc..3dad956 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -12,3 +12,4 @@ obj-$(CONFIG_OMAP_TIMER) += omap-timer.o obj-$(CONFIG_AST_TIMER) += ast_timer.o obj-$(CONFIG_STI_TIMER) += sti-timer.o obj-$(CONFIG_ARC_TIMER) += arc_timer.o +obj-$(CONFIG_AG101P_TIMER) += ag101p_timer.o diff --git a/drivers/timer/ag101p_timer.c b/drivers/timer/ag101p_timer.c new file mode 100644 index 0000000..163402f --- /dev/null +++ b/drivers/timer/ag101p_timer.c @@ -0,0 +1,122 @@ +/* + * Andestech ATFTMR010 timer driver + * + * (C) Copyright 2016 + * Rick Chen, NDS32 Software Engineering, rick@andestech.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <timer.h> +#include <linux/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Timer Control Register + */ +#define T3_UPDOWN (1 << 11) +#define T2_UPDOWN (1 << 10) +#define T1_UPDOWN (1 << 9) +#define T3_OFENABLE (1 << 8) +#define T3_CLOCK (1 << 7) +#define T3_ENABLE (1 << 6) +#define T2_OFENABLE (1 << 5) +#define T2_CLOCK (1 << 4) +#define T2_ENABLE (1 << 3) +#define T1_OFENABLE (1 << 2) +#define T1_CLOCK (1 << 1) +#define T1_ENABLE (1 << 0) + +/* + * Timer Interrupt State & Mask Registers + */ +#define T3_OVERFLOW (1 << 8) +#define T3_MATCH2 (1 << 7) +#define T3_MATCH1 (1 << 6) +#define T2_OVERFLOW (1 << 5) +#define T2_MATCH2 (1 << 4) +#define T2_MATCH1 (1 << 3) +#define T1_OVERFLOW (1 << 2) +#define T1_MATCH2 (1 << 1) +#define T1_MATCH1 (1 << 0) + +struct atftmr_timer_regs { + u32 t1_counter; /* 0x00 */ + u32 t1_load; /* 0x04 */ + u32 t1_match1; /* 0x08 */ + u32 t1_match2; /* 0x0c */ + u32 t2_counter; /* 0x10 */ + u32 t2_load; /* 0x14 */ + u32 t2_match1; /* 0x18 */ + u32 t2_match2; /* 0x1c */ + u32 t3_counter; /* 0x20 */ + u32 t3_load; /* 0x24 */ + u32 t3_match1; /* 0x28 */ + u32 t3_match2; /* 0x2c */ + u32 cr; /* 0x30 */ + u32 int_state; /* 0x34 */ + u32 int_mask; /* 0x38 */ +}; + +struct atftmr_timer_platdata { + struct atftmr_timer_regs *regs; +}; + +static int atftmr_timer_get_count(struct udevice *dev, u64 *count) +{ + struct atftmr_timer_platdata *plat = dev->platdata; + struct atftmr_timer_regs *const regs = plat->regs; + u32 val; + val = readl(®s->t3_counter); + *count = timer_conv_64(val); + return 0; +} + +static int atftmr_timer_probe(struct udevice *dev) +{ + struct atftmr_timer_platdata *plat = dev->platdata; + struct atftmr_timer_regs *const regs = plat->regs; + u32 cr; + writel(0, ®s->t3_load); + writel(0, ®s->t3_counter); + writel(TIMER_LOAD_VAL, ®s->t3_match1); + writel(TIMER_LOAD_VAL, ®s->t3_match2); + /* disable interrupts */ + writel(T3_MATCH1|T3_MATCH2|T3_OVERFLOW , ®s->int_mask); + cr = readl(®s->cr); + cr |= (T3_ENABLE|T3_UPDOWN); + writel(cr, ®s->cr); + return 0; +} + +static int atftme_timer_ofdata_to_platdata(struct udevice *dev) +{ + struct atftmr_timer_platdata *plat = dev_get_platdata(dev); + plat->regs = map_physmem(dev_get_addr(dev), + sizeof(struct atftmr_timer_regs), + MAP_NOCACHE); + return 0; +} + +static const struct timer_ops ag101p_timer_ops = { + .get_count = atftmr_timer_get_count, +}; + +static const struct udevice_id ag101p_timer_ids[] = { + { .compatible = "andestech,attmr010" }, + {} +}; + +U_BOOT_DRIVER(altera_timer) = { + .name = "ag101p_timer", + .id = UCLASS_TIMER, + .of_match = ag101p_timer_ids, + .ofdata_to_platdata = atftme_timer_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct atftmr_timer_platdata), + .probe = atftmr_timer_probe, + .ops = &ag101p_timer_ops, + .flags = DM_FLAG_PRE_RELOC, +};
Andes
