[PATCH v2 00/15] Add CAAM driver model support
This patchset adds the support for following: 1) CAAM Driver model for all i.MX, layerscape, PPC platforms. 2) Added crypto node in device tree files. 3) CAAM support for blob key encryption key(bkek), random number generation. 4) fixed hwrng performance issue in kernel.
i.MX platforms: i.MX6, i.MX7, i.MX7ULP, i.MX8MM/MN/MP/MQ, i.MX8QM/QXP
Layerscape platforms: LS1021, LS1012, LS1028, LS1043, LS1046, LS1088, LS2088, LX2160, LX2162
Powerpc platforms: P3041, P4080, P5040, P2041, T1024, T1042, T2080, T4240
Gaurav Jain (14): crypto/fsl: Add support for CAAM Job ring driver model crypto/fsl: Add CAAM support for bkek, random number generation i.MX8M: crypto: updated device tree for supporting DM in SPL crypto/fsl: i.MX8M: Enable Job ring driver model in SPL and U-Boot. i.MX6: Enable Job ring driver model in U-Boot. i.MX7: Enable Job ring driver model in U-Boot. i.MX7ULP: Enable Job ring driver model in U-Boot. i.MX8: Add crypto node in device tree crypto/fsl: i.MX8: Enable Job ring driver model in SPL and U-Boot. Layerscape: Add crypto node in device tree Layerscape: Enable Job ring driver model in U-Boot. PPC: Add crypto node in device tree PPC: Enable Job ring driver model in U-Boot update CAAM MAINTAINER
Ye Li (1): crypto/fsl: Fix kick_trng
MAINTAINERS | 7 + arch/arm/Kconfig | 9 +- arch/arm/cpu/armv7/ls102xa/Kconfig | 4 + arch/arm/cpu/armv7/ls102xa/cpu.c | 16 + arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 27 ++ arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 10 +- arch/arm/dts/fsl-imx8dx.dtsi | 61 ++- arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi | 34 +- arch/arm/dts/fsl-imx8qm.dtsi | 61 ++- arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi | 34 +- arch/arm/dts/fsl-ls1012a.dtsi | 46 +- arch/arm/dts/fsl-ls1028a.dtsi | 41 +- arch/arm/dts/fsl-ls1043a.dtsi | 45 +- arch/arm/dts/fsl-ls1046a.dtsi | 44 ++ arch/arm/dts/fsl-ls1088a.dtsi | 39 ++ arch/arm/dts/fsl-ls2080a.dtsi | 39 ++ arch/arm/dts/fsl-lx2160a.dtsi | 41 +- arch/arm/dts/imx7ulp.dtsi | 24 + arch/arm/dts/imx8mm-evk-u-boot.dtsi | 18 +- arch/arm/dts/imx8mm.dtsi | 1 + arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 18 +- arch/arm/dts/imx8mn.dtsi | 1 + arch/arm/dts/imx8mp-evk-u-boot.dtsi | 18 +- arch/arm/dts/imx8mp.dtsi | 1 + arch/arm/dts/imx8mq.dtsi | 1 + arch/arm/dts/ls1021a.dtsi | 40 ++ arch/arm/include/asm/arch-imx8/imx-regs.h | 5 +- arch/arm/include/asm/arch-imx8m/imx-regs.h | 1 + arch/arm/mach-imx/cmd_dek.c | 1 + arch/arm/mach-imx/imx8/Kconfig | 9 + arch/arm/mach-imx/imx8/cpu.c | 16 +- arch/arm/mach-imx/imx8m/Kconfig | 23 + arch/arm/mach-imx/imx8m/soc.c | 10 +- arch/arm/mach-imx/mx6/Kconfig | 8 + arch/arm/mach-imx/mx6/soc.c | 12 +- arch/arm/mach-imx/mx7/Kconfig | 3 + arch/arm/mach-imx/mx7/soc.c | 11 +- arch/arm/mach-imx/mx7ulp/Kconfig | 4 + arch/arm/mach-imx/mx7ulp/soc.c | 16 + arch/powerpc/cpu/mpc85xx/Kconfig | 44 ++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 17 +- arch/powerpc/dts/p2041si-post.dtsi | 1 + arch/powerpc/dts/p3041si-post.dtsi | 1 + arch/powerpc/dts/p4080si-post.dtsi | 1 + arch/powerpc/dts/p5040si-post.dtsi | 1 + arch/powerpc/dts/qoriq-sec4.0-0.dtsi | 74 +++ arch/powerpc/dts/qoriq-sec4.2-0.dtsi | 83 ++++ arch/powerpc/dts/qoriq-sec5.2-0.dtsi | 92 ++++ arch/powerpc/dts/t1023si-post.dtsi | 1 + arch/powerpc/dts/t1042si-post.dtsi | 1 + arch/powerpc/dts/t2080si-post.dtsi | 1 + arch/powerpc/dts/t4240si-post.dtsi | 1 + arch/powerpc/include/asm/u-boot-ppc.h | 13 + arch/powerpc/include/asm/u-boot.h | 1 + board/freescale/imx8mm_evk/spl.c | 9 +- board/freescale/imx8mn_evk/spl.c | 8 +- board/freescale/imx8mp_evk/spl.c | 13 +- board/freescale/imx8mq_evk/spl.c | 9 +- board/freescale/imx8qm_mek/spl.c | 6 +- board/freescale/imx8qxp_mek/spl.c | 6 +- board/freescale/ls1012afrdm/ls1012afrdm.c | 7 +- board/freescale/ls1012aqds/ls1012aqds.c | 6 +- board/freescale/ls1012ardb/ls1012ardb.c | 6 +- board/freescale/ls1021aiot/ls1021aiot.c | 6 +- board/freescale/ls1021aqds/ls1021aqds.c | 6 +- board/freescale/ls1021atsn/ls1021atsn.c | 7 +- board/freescale/ls1021atwr/ls1021atwr.c | 8 +- board/freescale/ls1028a/ls1028a.c | 6 +- board/freescale/ls1043ardb/ls1043ardb.c | 6 +- board/freescale/ls1046afrwy/ls1046afrwy.c | 7 +- board/freescale/ls1046aqds/ls1046aqds.c | 7 +- board/freescale/ls1046ardb/ls1046ardb.c | 6 +- board/freescale/ls1088a/ls1088a.c | 6 +- board/freescale/ls2080aqds/ls2080aqds.c | 6 +- board/freescale/ls2080ardb/ls2080ardb.c | 9 +- board/freescale/lx2160a/lx2160a.c | 5 - cmd/Kconfig | 1 + configs/P2041RDB_defconfig | 1 - configs/P3041DS_defconfig | 1 - configs/P4080DS_defconfig | 1 - configs/P5040DS_defconfig | 1 - configs/T1024RDB_defconfig | 1 - configs/T1042D4RDB_defconfig | 1 - configs/T2080QDS_defconfig | 1 - configs/T2080RDB_defconfig | 1 - configs/T4240RDB_defconfig | 1 - configs/ls1021aiot_qspi_defconfig | 1 - configs/ls1021aqds_nor_defconfig | 1 - configs/ls1021aqds_qspi_defconfig | 1 - configs/ls1021atsn_qspi_defconfig | 1 - configs/ls1021atwr_nor_defconfig | 1 - ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1028ardb_tfa_defconfig | 1 - configs/ls1043ardb_tfa_defconfig | 1 - configs/ls1046afrwy_tfa_defconfig | 1 - configs/ls1046aqds_tfa_defconfig | 1 - configs/ls1046ardb_tfa_defconfig | 1 - configs/ls2088aqds_tfa_defconfig | 1 - configs/ls2088ardb_tfa_defconfig | 1 - configs/lx2160aqds_tfa_defconfig | 1 - configs/lx2160ardb_tfa_defconfig | 1 - configs/lx2162aqds_tfa_defconfig | 1 - drivers/crypto/fsl/Kconfig | 9 +- drivers/crypto/fsl/Makefile | 2 + drivers/crypto/fsl/desc.h | 5 + drivers/crypto/fsl/fsl_blob.c | 82 ++++ drivers/crypto/fsl/jobdesc.c | 20 +- drivers/crypto/fsl/jobdesc.h | 4 + drivers/crypto/fsl/jr.c | 457 +++++++++++++----- drivers/crypto/fsl/jr.h | 14 + include/fsl_sec.h | 13 +- scripts/config_whitelist.txt | 1 + 112 files changed, 1633 insertions(+), 286 deletions(-) create mode 100644 arch/powerpc/dts/qoriq-sec4.0-0.dtsi create mode 100644 arch/powerpc/dts/qoriq-sec4.2-0.dtsi create mode 100644 arch/powerpc/dts/qoriq-sec5.2-0.dtsi create mode 100644 arch/powerpc/include/asm/u-boot-ppc.h
added device tree support for job ring driver. sec is initialized based on job ring information processed from device tree.
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- cmd/Kconfig | 1 + drivers/crypto/fsl/Kconfig | 7 + drivers/crypto/fsl/Makefile | 2 + drivers/crypto/fsl/jr.c | 314 +++++++++++++++++++++++------------- drivers/crypto/fsl/jr.h | 14 ++ 5 files changed, 229 insertions(+), 109 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index ffef3cc76c..7e92e9df7d 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1985,6 +1985,7 @@ config CMD_AES
config CMD_BLOB bool "Enable the 'blob' command" + select FSL_BLOB depends on !MX6ULL && !MX6SLL && !MX6SL select IMX_HAB if ARCH_MX6 || ARCH_MX7 || ARCH_MX7ULP || ARCH_IMX8M help diff --git a/drivers/crypto/fsl/Kconfig b/drivers/crypto/fsl/Kconfig index 1f5dfb94bb..6d6c3f8d39 100644 --- a/drivers/crypto/fsl/Kconfig +++ b/drivers/crypto/fsl/Kconfig @@ -64,4 +64,11 @@ config FSL_CAAM_RNG using the prediction resistance flag which means the DRGB is reseeded from the TRNG every time random data is generated.
+config FSL_BLOB + bool "Enable Blob Encap/Decap, Blob KEK support" + help + Enable support for the hardware based crytographic blob encap/decap + module of the CAAM. blobs can be safely placed into non-volatile + storage. blobs can only be decapsulated by the SoC that created it. + Enable support for blob key encryption key generation. endif diff --git a/drivers/crypto/fsl/Makefile b/drivers/crypto/fsl/Makefile index f9c3ccecfc..567ab6a821 100644 --- a/drivers/crypto/fsl/Makefile +++ b/drivers/crypto/fsl/Makefile @@ -1,10 +1,12 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright 2014 Freescale Semiconductor, Inc. +# Copyright 2021 NXP
obj-y += sec.o obj-$(CONFIG_FSL_CAAM) += jr.o fsl_hash.o jobdesc.o error.o obj-$(CONFIG_CMD_BLOB)$(CONFIG_IMX_CAAM_DEK_ENCAP) += fsl_blob.o +obj-$(CONFIG_FSL_BLOB) += fsl_blob.o obj-$(CONFIG_RSA_FREESCALE_EXP) += fsl_rsa.o obj-$(CONFIG_FSL_CAAM_RNG) += rng.o obj-$(CONFIG_FSL_MFGPROT) += fsl_mfgprot.o diff --git a/drivers/crypto/fsl/jr.c b/drivers/crypto/fsl/jr.c index 22b649219e..c5a8b0459e 100644 --- a/drivers/crypto/fsl/jr.c +++ b/drivers/crypto/fsl/jr.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2008-2014 Freescale Semiconductor, Inc. - * Copyright 2018 NXP + * Copyright 2018, 2021 NXP * * Based on CAAM driver in drivers/crypto/caam in Linux */ @@ -11,7 +11,6 @@ #include <linux/kernel.h> #include <log.h> #include <malloc.h> -#include "fsl_sec.h" #include "jr.h" #include "jobdesc.h" #include "desc_constr.h" @@ -21,8 +20,11 @@ #include <asm/cache.h> #include <asm/fsl_pamu.h> #endif +#include <dm.h> #include <dm/lists.h> #include <linux/delay.h> +#include <dm/root.h> +#include <dm/device-internal.h>
#define CIRC_CNT(head, tail, size) (((head) - (tail)) & (size - 1)) #define CIRC_SPACE(head, tail, size) CIRC_CNT((tail), (head) + 1, (size)) @@ -35,20 +37,30 @@ uint32_t sec_offset[CONFIG_SYS_FSL_MAX_NUM_OF_SEC] = { #endif };
+#if CONFIG_IS_ENABLED(DM) +struct udevice *caam_dev; +#else #define SEC_ADDR(idx) \ (ulong)((CONFIG_SYS_FSL_SEC_ADDR + sec_offset[idx]))
#define SEC_JR0_ADDR(idx) \ (ulong)(SEC_ADDR(idx) + \ (CONFIG_SYS_FSL_JR0_OFFSET - CONFIG_SYS_FSL_SEC_OFFSET)) +struct caam_regs caam_st; +#endif
-struct jobring jr0[CONFIG_SYS_FSL_MAX_NUM_OF_SEC]; +static inline u32 jr_start_reg(u8 jrid) +{ + return (1 << jrid); +}
-static inline void start_jr0(uint8_t sec_idx) +#ifndef CONFIG_ARCH_IMX8 +static inline void start_jr(struct caam_regs *caam) { - ccsr_sec_t *sec = (void *)SEC_ADDR(sec_idx); + ccsr_sec_t *sec = caam->sec; u32 ctpr_ms = sec_in32(&sec->ctpr_ms); u32 scfgr = sec_in32(&sec->scfgr); + u32 jrstart = jr_start_reg(caam->jrid);
if (ctpr_ms & SEC_CTPR_MS_VIRT_EN_INCL) { /* VIRT_EN_INCL = 1 & VIRT_EN_POR = 1 or @@ -56,23 +68,17 @@ static inline void start_jr0(uint8_t sec_idx) */ if ((ctpr_ms & SEC_CTPR_MS_VIRT_EN_POR) || (scfgr & SEC_SCFGR_VIRT_EN)) - sec_out32(&sec->jrstartr, CONFIG_JRSTARTR_JR0); + sec_out32(&sec->jrstartr, jrstart); } else { /* VIRT_EN_INCL = 0 && VIRT_EN_POR_VALUE = 1 */ if (ctpr_ms & SEC_CTPR_MS_VIRT_EN_POR) - sec_out32(&sec->jrstartr, CONFIG_JRSTARTR_JR0); + sec_out32(&sec->jrstartr, jrstart); } } +#endif
-static inline void jr_reset_liodn(uint8_t sec_idx) -{ - ccsr_sec_t *sec = (void *)SEC_ADDR(sec_idx); - sec_out32(&sec->jrliodnr[0].ls, 0); -} - -static inline void jr_disable_irq(uint8_t sec_idx) +static inline void jr_disable_irq(struct jr_regs *regs) { - struct jr_regs *regs = (struct jr_regs *)SEC_JR0_ADDR(sec_idx); uint32_t jrcfg = sec_in32(®s->jrcfg1);
jrcfg = jrcfg | JR_INTMASK; @@ -80,10 +86,10 @@ static inline void jr_disable_irq(uint8_t sec_idx) sec_out32(®s->jrcfg1, jrcfg); }
-static void jr_initregs(uint8_t sec_idx) +static void jr_initregs(uint8_t sec_idx, struct caam_regs *caam) { - struct jr_regs *regs = (struct jr_regs *)SEC_JR0_ADDR(sec_idx); - struct jobring *jr = &jr0[sec_idx]; + struct jr_regs *regs = caam->regs; + struct jobring *jr = &caam->jr[sec_idx]; caam_dma_addr_t ip_base = virt_to_phys((void *)jr->input_ring); caam_dma_addr_t op_base = virt_to_phys((void *)jr->output_ring);
@@ -103,16 +109,16 @@ static void jr_initregs(uint8_t sec_idx) sec_out32(®s->irs, JR_SIZE);
if (!jr->irq) - jr_disable_irq(sec_idx); + jr_disable_irq(regs); }
-static int jr_init(uint8_t sec_idx) +static int jr_init(uint8_t sec_idx, struct caam_regs *caam) { - struct jobring *jr = &jr0[sec_idx]; + struct jobring *jr = &caam->jr[sec_idx];
memset(jr, 0, sizeof(struct jobring));
- jr->jq_id = DEFAULT_JR_ID; + jr->jq_id = caam->jrid; jr->irq = DEFAULT_IRQ;
#ifdef CONFIG_FSL_CORENET @@ -134,53 +140,10 @@ static int jr_init(uint8_t sec_idx) memset(jr->input_ring, 0, JR_SIZE * sizeof(caam_dma_addr_t)); memset(jr->output_ring, 0, jr->op_size);
- start_jr0(sec_idx); - - jr_initregs(sec_idx); - - return 0; -} - -static int jr_sw_cleanup(uint8_t sec_idx) -{ - struct jobring *jr = &jr0[sec_idx]; - - jr->head = 0; - jr->tail = 0; - jr->read_idx = 0; - jr->write_idx = 0; - memset(jr->info, 0, sizeof(jr->info)); - memset(jr->input_ring, 0, jr->size * sizeof(caam_dma_addr_t)); - memset(jr->output_ring, 0, jr->size * sizeof(struct op_ring)); - - return 0; -} - -static int jr_hw_reset(uint8_t sec_idx) -{ - struct jr_regs *regs = (struct jr_regs *)SEC_JR0_ADDR(sec_idx); - uint32_t timeout = 100000; - uint32_t jrint, jrcr; - - sec_out32(®s->jrcr, JRCR_RESET); - do { - jrint = sec_in32(®s->jrint); - } while (((jrint & JRINT_ERR_HALT_MASK) == - JRINT_ERR_HALT_INPROGRESS) && --timeout); - - jrint = sec_in32(®s->jrint); - if (((jrint & JRINT_ERR_HALT_MASK) != - JRINT_ERR_HALT_INPROGRESS) && timeout == 0) - return -1; - - timeout = 100000; - sec_out32(®s->jrcr, JRCR_RESET); - do { - jrcr = sec_in32(®s->jrcr); - } while ((jrcr & JRCR_RESET) && --timeout); - - if (timeout == 0) - return -1; +#ifndef CONFIG_ARCH_IMX8 + start_jr(caam); +#endif + jr_initregs(sec_idx, caam);
return 0; } @@ -188,10 +151,10 @@ static int jr_hw_reset(uint8_t sec_idx) /* -1 --- error, can't enqueue -- no space available */ static int jr_enqueue(uint32_t *desc_addr, void (*callback)(uint32_t status, void *arg), - void *arg, uint8_t sec_idx) + void *arg, uint8_t sec_idx, struct caam_regs *caam) { - struct jr_regs *regs = (struct jr_regs *)SEC_JR0_ADDR(sec_idx); - struct jobring *jr = &jr0[sec_idx]; + struct jr_regs *regs = caam->regs; + struct jobring *jr = &caam->jr[sec_idx]; int head = jr->head; uint32_t desc_word; int length = desc_len(desc_addr); @@ -263,10 +226,10 @@ static int jr_enqueue(uint32_t *desc_addr, return 0; }
-static int jr_dequeue(int sec_idx) +static int jr_dequeue(int sec_idx, struct caam_regs *caam) { - struct jr_regs *regs = (struct jr_regs *)SEC_JR0_ADDR(sec_idx); - struct jobring *jr = &jr0[sec_idx]; + struct jr_regs *regs = caam->regs; + struct jobring *jr = &caam->jr[sec_idx]; int head = jr->head; int tail = jr->tail; int idx, i, found; @@ -349,14 +312,18 @@ static void desc_done(uint32_t status, void *arg) { struct result *x = arg; x->status = status; -#ifndef CONFIG_SPL_BUILD caam_jr_strstatus(status); -#endif x->done = 1; }
static inline int run_descriptor_jr_idx(uint32_t *desc, uint8_t sec_idx) { + struct caam_regs *caam; +#if CONFIG_IS_ENABLED(DM) + caam = dev_get_priv(caam_dev); +#else + caam = &caam_st; +#endif unsigned long long timeval = 0; unsigned long long timeout = CONFIG_USEC_DEQ_TIMEOUT; struct result op; @@ -364,7 +331,7 @@ static inline int run_descriptor_jr_idx(uint32_t *desc, uint8_t sec_idx)
memset(&op, 0, sizeof(op));
- ret = jr_enqueue(desc, desc_done, &op, sec_idx); + ret = jr_enqueue(desc, desc_done, &op, sec_idx, caam); if (ret) { debug("Error in SEC enq\n"); ret = JQ_ENQ_ERR; @@ -375,7 +342,7 @@ static inline int run_descriptor_jr_idx(uint32_t *desc, uint8_t sec_idx) udelay(1); timeval += 1;
- ret = jr_dequeue(sec_idx); + ret = jr_dequeue(sec_idx, caam); if (ret) { debug("Error in SEC deq\n"); ret = JQ_DEQ_ERR; @@ -402,13 +369,63 @@ int run_descriptor_jr(uint32_t *desc) return run_descriptor_jr_idx(desc, 0); }
+#ifndef CONFIG_ARCH_IMX8 +static int jr_sw_cleanup(uint8_t sec_idx, struct caam_regs *caam) +{ + struct jobring *jr = &caam->jr[sec_idx]; + + jr->head = 0; + jr->tail = 0; + jr->read_idx = 0; + jr->write_idx = 0; + memset(jr->info, 0, sizeof(jr->info)); + memset(jr->input_ring, 0, jr->size * sizeof(caam_dma_addr_t)); + memset(jr->output_ring, 0, jr->size * sizeof(struct op_ring)); + + return 0; +} + +static int jr_hw_reset(struct jr_regs *regs) +{ + uint32_t timeout = 100000; + uint32_t jrint, jrcr; + + sec_out32(®s->jrcr, JRCR_RESET); + do { + jrint = sec_in32(®s->jrint); + } while (((jrint & JRINT_ERR_HALT_MASK) == + JRINT_ERR_HALT_INPROGRESS) && --timeout); + + jrint = sec_in32(®s->jrint); + if (((jrint & JRINT_ERR_HALT_MASK) != + JRINT_ERR_HALT_INPROGRESS) && timeout == 0) + return -1; + + timeout = 100000; + sec_out32(®s->jrcr, JRCR_RESET); + do { + jrcr = sec_in32(®s->jrcr); + } while ((jrcr & JRCR_RESET) && --timeout); + + if (timeout == 0) + return -1; + + return 0; +} + static inline int jr_reset_sec(uint8_t sec_idx) { - if (jr_hw_reset(sec_idx) < 0) + struct caam_regs *caam; +#if CONFIG_IS_ENABLED(DM) + caam = dev_get_priv(caam_dev); +#else + caam = &caam_st; +#endif + if (jr_hw_reset(caam->regs) < 0) return -1;
/* Clean up the jobring structure maintained by software */ - jr_sw_cleanup(sec_idx); + jr_sw_cleanup(sec_idx, caam);
return 0; } @@ -418,9 +435,15 @@ int jr_reset(void) return jr_reset_sec(0); }
-static inline int sec_reset_idx(uint8_t sec_idx) +int sec_reset(void) { - ccsr_sec_t *sec = (void *)SEC_ADDR(sec_idx); + struct caam_regs *caam; +#if CONFIG_IS_ENABLED(DM) + caam = dev_get_priv(caam_dev); +#else + caam = &caam_st; +#endif + ccsr_sec_t *sec = caam->sec; uint32_t mcfgr = sec_in32(&sec->mcfgr); uint32_t timeout = 100000;
@@ -446,11 +469,7 @@ static inline int sec_reset_idx(uint8_t sec_idx)
return 0; } -int sec_reset(void) -{ - return sec_reset_idx(0); -} -#ifndef CONFIG_SPL_BUILD + static int deinstantiate_rng(u8 sec_idx, int state_handle_mask) { u32 *desc; @@ -496,12 +515,11 @@ static int deinstantiate_rng(u8 sec_idx, int state_handle_mask) return ret; }
-static int instantiate_rng(u8 sec_idx, int gen_sk) +static int instantiate_rng(uint8_t sec_idx, ccsr_sec_t *sec, int gen_sk) { u32 *desc; u32 rdsta_val; int ret = 0, sh_idx, size; - ccsr_sec_t __iomem *sec = (ccsr_sec_t __iomem *)SEC_ADDR(sec_idx); struct rng4tst __iomem *rng = (struct rng4tst __iomem *)&sec->rng;
@@ -554,9 +572,8 @@ static int instantiate_rng(u8 sec_idx, int gen_sk) return ret; }
-static u8 get_rng_vid(uint8_t sec_idx) +static u8 get_rng_vid(ccsr_sec_t *sec) { - ccsr_sec_t *sec = (void *)SEC_ADDR(sec_idx); u8 vid;
if (caam_get_era() < 10) { @@ -574,9 +591,8 @@ static u8 get_rng_vid(uint8_t sec_idx) * By default, the TRNG runs for 200 clocks per sample; * 1200 clocks per sample generates better entropy. */ -static void kick_trng(int ent_delay, uint8_t sec_idx) +static void kick_trng(int ent_delay, ccsr_sec_t *sec) { - ccsr_sec_t __iomem *sec = (ccsr_sec_t __iomem *)SEC_ADDR(sec_idx); struct rng4tst __iomem *rng = (struct rng4tst __iomem *)&sec->rng; u32 val; @@ -603,10 +619,9 @@ static void kick_trng(int ent_delay, uint8_t sec_idx) sec_clrbits32(&rng->rtmctl, RTMCTL_PRGM); }
-static int rng_init(uint8_t sec_idx) +static int rng_init(uint8_t sec_idx, ccsr_sec_t *sec) { int ret, gen_sk, ent_delay = RTSDCTL_ENT_DLY_MIN; - ccsr_sec_t __iomem *sec = (ccsr_sec_t __iomem *)SEC_ADDR(sec_idx); struct rng4tst __iomem *rng = (struct rng4tst __iomem *)&sec->rng; u32 inst_handles; @@ -624,7 +639,7 @@ static int rng_init(uint8_t sec_idx) * the TRNG parameters. */ if (!inst_handles) { - kick_trng(ent_delay, sec_idx); + kick_trng(ent_delay, sec); ent_delay += 400; } /* @@ -634,7 +649,7 @@ static int rng_init(uint8_t sec_idx) * interval, leading to a sucessful initialization of * the RNG. */ - ret = instantiate_rng(sec_idx, gen_sk); + ret = instantiate_rng(sec_idx, sec, gen_sk); } while ((ret == -1) && (ent_delay < RTSDCTL_ENT_DLY_MAX)); if (ret) { printf("SEC%u: Failed to instantiate RNG\n", sec_idx); @@ -647,12 +662,25 @@ static int rng_init(uint8_t sec_idx) return ret; } #endif + int sec_init_idx(uint8_t sec_idx) { - ccsr_sec_t *sec = (void *)SEC_ADDR(sec_idx); - uint32_t mcr = sec_in32(&sec->mcfgr); int ret = 0; - + struct caam_regs *caam; +#if CONFIG_IS_ENABLED(DM) + caam = dev_get_priv(caam_dev); +#else + caam_st.sec = (void *)SEC_ADDR(sec_idx); + caam_st.regs = (struct jr_regs *)SEC_JR0_ADDR(sec_idx); + caam_st.jrid = 0; + caam = &caam_st; +#endif +#ifndef CONFIG_ARCH_IMX8 + ccsr_sec_t *sec = caam->sec; + uint32_t mcr = sec_in32(&sec->mcfgr); +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_IMX8M) + uint32_t jrdid_ms = 0; +#endif #ifdef CONFIG_FSL_CORENET uint32_t liodnr; uint32_t liodn_ns; @@ -682,6 +710,11 @@ int sec_init_idx(uint8_t sec_idx) mcr |= (1 << MCFGR_PS_SHIFT); #endif sec_out32(&sec->mcfgr, mcr); +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_IMX8M) + jrdid_ms = JRDID_MS_TZ_OWN | JRDID_MS_PRIM_TZ | JRDID_MS_PRIM_DID; + sec_out32(&sec->jrliodnr[caam->jrid].ms, jrdid_ms); +#endif + jr_reset();
#ifdef CONFIG_FSL_CORENET #ifdef CONFIG_SPL_BUILD @@ -693,25 +726,26 @@ int sec_init_idx(uint8_t sec_idx) liodn_ns = CONFIG_SPL_JR0_LIODN_NS & JRNSLIODN_MASK; liodn_s = CONFIG_SPL_JR0_LIODN_S & JRSLIODN_MASK;
- liodnr = sec_in32(&sec->jrliodnr[0].ls) & + liodnr = sec_in32(&sec->jrliodnr[caam->jrid].ls) & ~(JRNSLIODN_MASK | JRSLIODN_MASK); liodnr = liodnr | (liodn_ns << JRNSLIODN_SHIFT) | (liodn_s << JRSLIODN_SHIFT); - sec_out32(&sec->jrliodnr[0].ls, liodnr); + sec_out32(&sec->jrliodnr[caam->jrid].ls, liodnr); #else - liodnr = sec_in32(&sec->jrliodnr[0].ls); + liodnr = sec_in32(&sec->jrliodnr[caam->jrid].ls); liodn_ns = (liodnr & JRNSLIODN_MASK) >> JRNSLIODN_SHIFT; liodn_s = (liodnr & JRSLIODN_MASK) >> JRSLIODN_SHIFT; #endif #endif - - ret = jr_init(sec_idx); +#endif + ret = jr_init(sec_idx, caam); if (ret < 0) { printf("SEC%u: initialization failed\n", sec_idx); return -1; }
+#ifndef CONFIG_ARCH_IMX8 #ifdef CONFIG_FSL_CORENET ret = sec_config_pamu_table(liodn_ns, liodn_s); if (ret < 0) @@ -719,9 +753,9 @@ int sec_init_idx(uint8_t sec_idx)
pamu_enable(); #endif -#ifndef CONFIG_SPL_BUILD - if (get_rng_vid(sec_idx) >= 4) { - if (rng_init(sec_idx) < 0) { + + if (get_rng_vid(caam->sec) >= 4) { + if (rng_init(sec_idx, caam->sec) < 0) { printf("SEC%u: RNG instantiation failed\n", sec_idx); return -1; } @@ -743,3 +777,65 @@ int sec_init(void) { return sec_init_idx(0); } + +#if CONFIG_IS_ENABLED(DM) +static int caam_jr_probe(struct udevice *dev) +{ + struct caam_regs *caam = dev_get_priv(dev); + const void *fdt = gd->fdt_blob; + int node = dev_of_offset(dev); + fdt_addr_t addr; + int subnode; + unsigned int jr_node = 0; + + caam_dev = dev; + + addr = dev_read_addr(dev); + if (addr == FDT_ADDR_T_NONE) { + printf("caam_jr: crypto not found\n"); + return -EINVAL; + } + caam->sec = (ccsr_sec_t *)(uintptr_t)addr; + caam->regs = (struct jr_regs *)caam->sec; + + /* Check for enabled job ring subnode */ + fdt_for_each_subnode(subnode, fdt, node) { + if (!fdtdec_get_is_enabled(fdt, subnode)) { + continue; + } + jr_node = fdtdec_get_uint(fdt, subnode, "reg", -1); + if (jr_node > 0) { + caam->regs = (struct jr_regs *)((ulong)caam->sec + jr_node); + while (!(jr_node & 0x0F)) { + jr_node = jr_node >> 4; + } + caam->jrid = jr_node - 1; + break; + } + } + + if (sec_init()) + printf("\nsec_init failed!\n"); + + return 0; +} + +static int caam_jr_bind(struct udevice *dev) +{ + return 0; +} + +static const struct udevice_id caam_jr_match[] = { + { .compatible = "fsl,sec-v4.0" }, + { } +}; + +U_BOOT_DRIVER(caam_jr) = { + .name = "caam_jr", + .id = UCLASS_MISC, + .of_match = caam_jr_match, + .bind = caam_jr_bind, + .probe = caam_jr_probe, + .priv_auto = sizeof(struct caam_regs), +}; +#endif diff --git a/drivers/crypto/fsl/jr.h b/drivers/crypto/fsl/jr.h index 1047aa772c..43cb5e0753 100644 --- a/drivers/crypto/fsl/jr.h +++ b/drivers/crypto/fsl/jr.h @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* * Copyright 2008-2014 Freescale Semiconductor, Inc. + * Copyright 2021 NXP * */
@@ -8,7 +9,9 @@ #define __JR_H
#include <linux/compiler.h> +#include "fsl_sec.h" #include "type.h" +#include <misc.h>
#define JR_SIZE 4 /* Timeout currently defined as 10 sec */ @@ -35,6 +38,10 @@ #define JRSLIODN_SHIFT 0 #define JRSLIODN_MASK 0x00000fff
+#define JRDID_MS_PRIM_DID 1 +#define JRDID_MS_PRIM_TZ (1 << 4) +#define JRDID_MS_TZ_OWN (1 << 15) + #define JQ_DEQ_ERR -1 #define JQ_DEQ_TO_ERR -2 #define JQ_ENQ_ERR -3 @@ -102,6 +109,13 @@ struct result { uint32_t status; };
+struct caam_regs { + ccsr_sec_t *sec; + struct jr_regs *regs; + u8 jrid; + struct jobring jr[CONFIG_SYS_FSL_MAX_NUM_OF_SEC]; +}; + void caam_jr_strstatus(u32 status); int run_descriptor_jr(uint32_t *desc);
cmd/Kconfig | 1 + drivers/crypto/fsl/Kconfig | 7 + drivers/crypto/fsl/Makefile | 2 + drivers/crypto/fsl/jr.c | 314 +++++++++++++++++++++++----------- -- drivers/crypto/fsl/jr.h | 14 ++ 5 files changed, 229 insertions(+), 109 deletions(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index ffef3cc76c..7e92e9df7d 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1985,6 +1985,7 @@ config CMD_AES config CMD_BLOB bool "Enable the 'blob' command"
- select FSL_BLOB
depends on !MX6ULL && !MX6SLL && !MX6SL select IMX_HAB if ARCH_MX6 || ARCH_MX7 || ARCH_MX7ULP || ARCH_IMX8M help diff --git a/drivers/crypto/fsl/Kconfig b/drivers/crypto/fsl/Kconfig index 1f5dfb94bb..6d6c3f8d39 100644 --- a/drivers/crypto/fsl/Kconfig +++ b/drivers/crypto/fsl/Kconfig @@ -64,4 +64,11 @@ config FSL_CAAM_RNG using the prediction resistance flag which means the DRGB is reseeded from the TRNG every time random data is generated. +config FSL_BLOB + bool "Enable Blob Encap/Decap, Blob KEK support"
- help
- Enable support for the hardware based crytographic blob
encap/decap
- module of the CAAM. blobs can be safely placed into non-
volatile
- storage. blobs can only be decapsulated by the SoC that
created it.
- Enable support for blob key encryption key generation.
endif diff --git a/drivers/crypto/fsl/Makefile b/drivers/crypto/fsl/Makefile index f9c3ccecfc..567ab6a821 100644 --- a/drivers/crypto/fsl/Makefile +++ b/drivers/crypto/fsl/Makefile @@ -1,10 +1,12 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright 2014 Freescale Semiconductor, Inc. +# Copyright 2021 NXP obj-y += sec.o obj-$(CONFIG_FSL_CAAM) += jr.o fsl_hash.o jobdesc.o error.o obj-$(CONFIG_CMD_BLOB)$(CONFIG_IMX_CAAM_DEK_ENCAP) += fsl_blob.o +obj-$(CONFIG_FSL_BLOB) += fsl_blob.o
Since CMD_BLOB will select FSL_BLOB, so just replace CMD_BLOB with FSL_BLOB
- Copyright 2018 NXP
- Copyright 2018, 2021 NXP
* * Based on CAAM driver in drivers/crypto/caam in Linux */ @@ -11,7 +11,6 @@ #include <linux/kernel.h> #include <log.h> #include <malloc.h> -#include "fsl_sec.h" #include "jr.h" #include "jobdesc.h" #include "desc_constr.h" @@ -21,8 +20,11 @@ #include <asm/cache.h> #include <asm/fsl_pamu.h> #endif +#include <dm.h> #include <dm/lists.h> #include <linux/delay.h> +#include <dm/root.h> +#include <dm/device-internal.h> #define CIRC_CNT(head, tail, size) (((head) - (tail)) & (size
- 1))
- 1, (size))
@@ -35,20 +37,30 @@ uint32_t sec_offset[CONFIG_SYS_FSL_MAX_NUM_OF_SEC] = { #endif }; +#if CONFIG_IS_ENABLED(DM) +struct udevice *caam_dev; +#else #define SEC_ADDR(idx) \ (ulong)((CONFIG_SYS_FSL_SEC_ADDR + sec_offset[idx])) #define SEC_JR0_ADDR(idx) \ (ulong)(SEC_ADDR(idx) + \ (CONFIG_SYS_FSL_JR0_OFFSET - CONFIG_SYS_FSL_SEC_OFFSET)) +struct caam_regs caam_st; +#endif -struct jobring jr0[CONFIG_SYS_FSL_MAX_NUM_OF_SEC]; +static inline u32 jr_start_reg(u8 jrid) +{
- return (1 << jrid);
+} -static inline void start_jr0(uint8_t sec_idx) +#ifndef CONFIG_ARCH_IMX8 +static inline void start_jr(struct caam_regs *caam) {
- ccsr_sec_t *sec = caam->sec;
- u32 jrstart = jr_start_reg(caam->jrid);
} } +#endif -static inline void jr_reset_liodn(uint8_t sec_idx) -{
*)SEC_JR0_ADDR(sec_idx); uint32_t jrcfg = sec_in32(®s->jrcfg1); jrcfg = jrcfg | JR_INTMASK; @@ -80,10 +86,10 @@ static inline void jr_disable_irq(uint8_t sec_idx) sec_out32(®s->jrcfg1, jrcfg); } -static void jr_initregs(uint8_t sec_idx) +static void jr_initregs(uint8_t sec_idx, struct caam_regs *caam) {
- struct jr_regs *regs = caam->regs;
- struct jobring *jr = &caam->jr[sec_idx];
input_ring);
output_ring);
@@ -103,16 +109,16 @@ static void jr_initregs(uint8_t sec_idx) sec_out32(®s->irs, JR_SIZE); if (!jr->irq)
} -static int jr_init(uint8_t sec_idx) +static int jr_init(uint8_t sec_idx, struct caam_regs *caam) {
- jr->jq_id = caam->jrid;
jr->irq = DEFAULT_IRQ; #ifdef CONFIG_FSL_CORENET @@ -134,53 +140,10 @@ static int jr_init(uint8_t sec_idx) memset(jr->input_ring, 0, JR_SIZE * sizeof(caam_dma_addr_t)); memset(jr->output_ring, 0, jr->op_size);
- jr->head = 0;
- jr->tail = 0;
- jr->read_idx = 0;
op_ring));
- do {
return -1;
- timeout = 100000;
- do {
- if (timeout == 0)
return -1;
- start_jr(caam);
- jr_initregs(sec_idx, caam);
- void *arg, uint8_t sec_idx, struct caam_regs *caam)
int head = jr->head; uint32_t desc_word; int length = desc_len(desc_addr); @@ -263,10 +226,10 @@ static int jr_enqueue(uint32_t *desc_addr, return 0; } -static int jr_dequeue(int sec_idx) +static int jr_dequeue(int sec_idx, struct caam_regs *caam) {
int head = jr->head; int tail = jr->tail; int idx, i, found; @@ -349,14 +312,18 @@ static void desc_done(uint32_t status, void *arg) { struct result *x = arg; x->status = status; -#ifndef CONFIG_SPL_BUILD caam_jr_strstatus(status); -#endif x->done = 1; } static inline int run_descriptor_jr_idx(uint32_t *desc, uint8_t sec_idx) {
- struct caam_regs *caam;
- caam = dev_get_priv(caam_dev);
+#else
- caam = &caam_st;
+#endif unsigned long long timeval = 0; unsigned long long timeout = CONFIG_USEC_DEQ_TIMEOUT; struct result op; @@ -364,7 +331,7 @@ static inline int run_descriptor_jr_idx(uint32_t *desc, uint8_t sec_idx) memset(&op, 0, sizeof(op));
- ret = jr_enqueue(desc, desc_done, &op, sec_idx, caam);
if (ret) { debug("Error in SEC deq\n"); ret = JQ_DEQ_ERR; @@ -402,13 +369,63 @@ int run_descriptor_jr(uint32_t *desc) return run_descriptor_jr_idx(desc, 0); } +#ifndef CONFIG_ARCH_IMX8 +static int jr_sw_cleanup(uint8_t sec_idx, struct caam_regs *caam) +{
- jr->head = 0;
- jr->tail = 0;
- jr->read_idx = 0;
op_ring));
- do {
return -1;
- timeout = 100000;
- do {
- if (timeout == 0)
return -1;
+#else
- caam = &caam_st;
- if (jr_hw_reset(caam->regs) < 0)
return -1; /* Clean up the jobring structure maintained by software */
- jr_sw_cleanup(sec_idx, caam);
return 0; } @@ -418,9 +435,15 @@ int jr_reset(void) return jr_reset_sec(0); } -static inline int sec_reset_idx(uint8_t sec_idx) +int sec_reset(void) {
+#else
- caam = &caam_st;
uint32_t mcfgr = sec_in32(&sec->mcfgr); uint32_t timeout = 100000; @@ -446,11 +469,7 @@ static inline int sec_reset_idx(uint8_t sec_idx) return 0; } -int sec_reset(void) -{
static int deinstantiate_rng(u8 sec_idx, int state_handle_mask) { u32 *desc; @@ -496,12 +515,11 @@ static int deinstantiate_rng(u8 sec_idx, int state_handle_mask) return ret; } -static int instantiate_rng(u8 sec_idx, int gen_sk) +static int instantiate_rng(uint8_t sec_idx, ccsr_sec_t *sec, int gen_sk) { u32 *desc; u32 rdsta_val; int ret = 0, sh_idx, size;
*)SEC_ADDR(sec_idx); struct rng4tst __iomem *rng = (struct rng4tst __iomem *)&sec->rng; @@ -554,9 +572,8 @@ static int instantiate_rng(u8 sec_idx, int gen_sk) return ret; } -static u8 get_rng_vid(uint8_t sec_idx) +static u8 get_rng_vid(ccsr_sec_t *sec) {
u8 vid; if (caam_get_era() < 10) { @@ -574,9 +591,8 @@ static u8 get_rng_vid(uint8_t sec_idx) * By default, the TRNG runs for 200 clocks per sample; * 1200 clocks per sample generates better entropy. */ -static void kick_trng(int ent_delay, uint8_t sec_idx) +static void kick_trng(int ent_delay, ccsr_sec_t *sec) {
*)SEC_ADDR(sec_idx); struct rng4tst __iomem *rng = (struct rng4tst __iomem *)&sec->rng; u32 val; @@ -603,10 +619,9 @@ static void kick_trng(int ent_delay, uint8_t sec_idx) sec_clrbits32(&rng->rtmctl, RTMCTL_PRGM); } -static int rng_init(uint8_t sec_idx) +static int rng_init(uint8_t sec_idx, ccsr_sec_t *sec) { int ret, gen_sk, ent_delay = RTSDCTL_ENT_DLY_MIN;
int ret = 0;
Need to check the caam_dev valid before using it
Best regards, Ye Li
+#else
- caam_st.sec = (void *)SEC_ADDR(sec_idx);
- caam_st.regs = (struct jr_regs *)SEC_JR0_ADDR(sec_idx);
- caam_st.jrid = 0;
- caam = &caam_st;
- uint32_t jrdid_ms = 0;
- jrdid_ms = JRDID_MS_TZ_OWN | JRDID_MS_PRIM_TZ |
JRDID_MS_PRIM_DID;
- sec_out32(&sec->jrliodnr[caam->jrid].ms, jrdid_ms);
- jr_reset();
- liodnr = sec_in32(&sec->jrliodnr[caam->jrid].ls) &
- sec_out32(&sec->jrliodnr[caam->jrid].ls, liodnr);
#else
- liodnr = sec_in32(&sec->jrliodnr[caam->jrid].ls);
- ret = jr_init(sec_idx, caam);
if (ret < 0) { printf("SEC%u: initialization failed\n", sec_idx); return -1; } +#ifndef CONFIG_ARCH_IMX8 #ifdef CONFIG_FSL_CORENET ret = sec_config_pamu_table(liodn_ns, liodn_s); if (ret < 0) @@ -719,9 +753,9 @@ int sec_init_idx(uint8_t sec_idx) pamu_enable(); #endif -#ifndef CONFIG_SPL_BUILD
- if (get_rng_vid(caam->sec) >= 4) {
- struct caam_regs *caam = dev_get_priv(dev);
- const void *fdt = gd->fdt_blob;
- int node = dev_of_offset(dev);
- fdt_addr_t addr;
- int subnode;
- unsigned int jr_node = 0;
- caam_dev = dev;
- addr = dev_read_addr(dev);
- if (addr == FDT_ADDR_T_NONE) {
return -EINVAL;
- caam->sec = (ccsr_sec_t *)(uintptr_t)addr;
- caam->regs = (struct jr_regs *)caam->sec;
- /* Check for enabled job ring subnode */
- fdt_for_each_subnode(subnode, fdt, node) {
continue;
if (jr_node > 0) {
sec + jr_node);
break;
- if (sec_init())
- { .compatible = "fsl,sec-v4.0" },
- .name = "caam_jr",
- .id = UCLASS_MISC,
- .of_match = caam_jr_match,
- .bind = caam_jr_bind,
- .probe = caam_jr_probe,
- .priv_auto = sizeof(struct caam_regs),
- Copyright 2021 NXP
* */ @@ -8,7 +9,9 @@ #define __JR_H #include <linux/compiler.h> +#include "fsl_sec.h" #include "type.h" +#include <misc.h> #define JR_SIZE 4 /* Timeout currently defined as 10 sec */ @@ -35,6 +38,10 @@ #define JRSLIODN_SHIFT 0 #define JRSLIODN_MASK 0x00000fff +#define JRDID_MS_PRIM_DID 1 +#define JRDID_MS_PRIM_TZ (1 << 4) +#define JRDID_MS_TZ_OWN (1 << 15)
#define JQ_DEQ_ERR -1 #define JQ_DEQ_TO_ERR -2 #define JQ_ENQ_ERR -3 @@ -102,6 +109,13 @@ struct result { uint32_t status; }; +struct caam_regs {
- ccsr_sec_t *sec;
- struct jr_regs *regs;
- u8 jrid;
- struct jobring jr[CONFIG_SYS_FSL_MAX_NUM_OF_SEC];
added api and descriptor for blob key encryption key(bkek) generation. added api for random number generation.
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com Signed-off-by: Ji Luo ji.luo@nxp.com --- drivers/crypto/fsl/desc.h | 5 +++ drivers/crypto/fsl/fsl_blob.c | 82 +++++++++++++++++++++++++++++++++++ drivers/crypto/fsl/jobdesc.c | 20 +++++++-- drivers/crypto/fsl/jobdesc.h | 4 ++ 4 files changed, 108 insertions(+), 3 deletions(-)
diff --git a/drivers/crypto/fsl/desc.h b/drivers/crypto/fsl/desc.h index 5705c4f944..5958ebd3ac 100644 --- a/drivers/crypto/fsl/desc.h +++ b/drivers/crypto/fsl/desc.h @@ -4,6 +4,7 @@ * Definitions to support CAAM descriptor instruction generation * * Copyright 2008-2014 Freescale Semiconductor, Inc. + * Copyright 2021 NXP * * Based on desc.h file in linux drivers/crypto/caam */ @@ -15,6 +16,7 @@
#define KEY_BLOB_SIZE 32 #define MAC_SIZE 16 +#define BKEK_SIZE 32
/* Max size of any CAAM descriptor in 32-bit words, inclusive of header */ #define MAX_CAAM_DESCSIZE 64 @@ -463,6 +465,9 @@ #define OP_PROTINFO_HASH_SHA384 0x00000200 #define OP_PROTINFO_HASH_SHA512 0x00000280
+/* PROTINFO fields for Blob Operations */ +#define OP_PROTINFO_MKVB 0x00000002 + /* For non-protocol/alg-only op commands */ #define OP_ALG_TYPE_SHIFT 24 #define OP_ALG_TYPE_MASK (0x7 << OP_ALG_TYPE_SHIFT) diff --git a/drivers/crypto/fsl/fsl_blob.c b/drivers/crypto/fsl/fsl_blob.c index e8202cc569..e8bc009daf 100644 --- a/drivers/crypto/fsl/fsl_blob.c +++ b/drivers/crypto/fsl/fsl_blob.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2021 NXP * */
@@ -152,6 +153,87 @@ int blob_encap(u8 *key_mod, u8 *src, u8 *dst, u32 len) return ret; }
+int derive_blob_kek(u8 *bkek_buf, u8 *key_mod, u32 key_sz) +{ + int ret, size; + u32 *desc; + + if (!IS_ALIGNED((uintptr_t)bkek_buf, ARCH_DMA_MINALIGN) || + !IS_ALIGNED((uintptr_t)key_mod, ARCH_DMA_MINALIGN)) { + puts("Error: derive_bkek: Address arguments are not aligned!\n"); + return -EINVAL; + } + + printf("\nBlob key encryption key(bkek)\n"); + desc = malloc_cache_aligned(sizeof(int) * MAX_CAAM_DESCSIZE); + if (!desc) { + printf("Not enough memory for descriptor allocation\n"); + return -ENOMEM; + } + + size = ALIGN(key_sz, ARCH_DMA_MINALIGN); + flush_dcache_range((unsigned long)key_mod, (unsigned long)key_mod + size); + + /* construct blob key encryption key(bkek) derive descriptor */ + inline_cnstr_jobdesc_derive_bkek(desc, bkek_buf, key_mod, key_sz); + + size = ALIGN(sizeof(int) * MAX_CAAM_DESCSIZE, ARCH_DMA_MINALIGN); + flush_dcache_range((unsigned long)desc, (unsigned long)desc + size); + size = ALIGN(BKEK_SIZE, ARCH_DMA_MINALIGN); + invalidate_dcache_range((unsigned long)bkek_buf, + (unsigned long)bkek_buf + size); + + /* run descriptor */ + ret = run_descriptor_jr(desc); + if (ret < 0) { + printf("Error: %s failed 0x%x\n", __func__, ret); + } else { + invalidate_dcache_range((unsigned long)bkek_buf, + (unsigned long)bkek_buf + size); + puts("derive bkek successful.\n"); + } + + free(desc); + return ret; +} + +int hwrng_generate(u8 *dst, u32 len) +{ + int ret, size; + u32 *desc; + + if (!IS_ALIGNED((uintptr_t)dst, ARCH_DMA_MINALIGN)) { + puts("Error: caam_hwrng_test: Address arguments are not aligned!\n"); + return -EINVAL; + } + + printf("\nRNG generate\n"); + desc = malloc_cache_aligned(sizeof(int) * MAX_CAAM_DESCSIZE); + if (!desc) { + printf("Not enough memory for descriptor allocation\n"); + return -ENOMEM; + } + + inline_cnstr_jobdesc_rng(desc, dst, len); + + size = ALIGN(sizeof(int) * MAX_CAAM_DESCSIZE, ARCH_DMA_MINALIGN); + flush_dcache_range((unsigned long)desc, (unsigned long)desc + size); + size = ALIGN(len, ARCH_DMA_MINALIGN); + invalidate_dcache_range((unsigned long)dst, (unsigned long)dst + size); + + ret = run_descriptor_jr(desc); + if (ret < 0) { + printf("Error: RNG generate failed 0x%x\n", ret); + } else { + invalidate_dcache_range((unsigned long)dst, + (unsigned long)dst + size); + puts("RNG generation successful.\n"); + } + + free(desc); + return ret; +} + #ifdef CONFIG_CMD_DEKBLOB int blob_dek(const u8 *src, u8 *dst, u8 len) { diff --git a/drivers/crypto/fsl/jobdesc.c b/drivers/crypto/fsl/jobdesc.c index c350b32856..d58937c284 100644 --- a/drivers/crypto/fsl/jobdesc.c +++ b/drivers/crypto/fsl/jobdesc.c @@ -4,7 +4,7 @@ * Basic job descriptor construction * * Copyright 2014 Freescale Semiconductor, Inc. - * Copyright 2018 NXP + * Copyright 2018, 2021 NXP * */
@@ -207,7 +207,7 @@ void inline_cnstr_jobdesc_hash(uint32_t *desc, append_store(desc, dma_addr_out, storelen, LDST_CLASS_2_CCB | LDST_SRCDST_BYTE_CONTEXT); } -#ifndef CONFIG_SPL_BUILD + void inline_cnstr_jobdesc_blob_encap(uint32_t *desc, uint8_t *key_idnfr, uint8_t *plain_txt, uint8_t *enc_blob, uint32_t in_sz) @@ -255,7 +255,7 @@ void inline_cnstr_jobdesc_blob_decap(uint32_t *desc, uint8_t *key_idnfr,
append_operation(desc, OP_TYPE_DECAP_PROTOCOL | OP_PCLID_BLOB); } -#endif + /* * Descriptor to instantiate RNG State Handle 0 in normal mode and * load the JDKEK, TDKEK and TDSK registers @@ -334,3 +334,17 @@ void inline_cnstr_jobdesc_pkha_rsaexp(uint32_t *desc, append_fifo_store(desc, dma_addr_out, out_siz, LDST_CLASS_1_CCB | FIFOST_TYPE_PKHA_B); } + +void inline_cnstr_jobdesc_derive_bkek(uint32_t *desc, void *bkek_out, + void *key_mod, uint32_t key_sz) +{ + dma_addr_t dma_key_mod = virt_to_phys(key_mod); + dma_addr_t dma_bkek_out = virt_to_phys(bkek_out); + + init_job_desc(desc, 0); + append_load(desc, dma_key_mod, key_sz, LDST_CLASS_2_CCB | + LDST_SRCDST_BYTE_KEY); + append_seq_out_ptr_intlen(desc, dma_bkek_out, BKEK_SIZE, 0); + append_operation(desc, OP_TYPE_ENCAP_PROTOCOL | OP_PCLID_BLOB | + OP_PROTINFO_MKVB); +} diff --git a/drivers/crypto/fsl/jobdesc.h b/drivers/crypto/fsl/jobdesc.h index c4501abd26..a720d68e82 100644 --- a/drivers/crypto/fsl/jobdesc.h +++ b/drivers/crypto/fsl/jobdesc.h @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2021 NXP * */
@@ -49,4 +50,7 @@ void inline_cnstr_jobdesc_pkha_rsaexp(uint32_t *desc, struct pk_in_params *pkin, uint8_t *out, uint32_t out_siz);
+void inline_cnstr_jobdesc_derive_bkek(uint32_t *desc, void *bkek_out, + void *key_mod, uint32_t key_sz); + #endif
Reviewed-by: Ye Li ye.li@nxp.com
Best regards, Ye Li
* * Based on desc.h file in linux drivers/crypto/caam */ @@ -15,6 +16,7 @@ #define KEY_BLOB_SIZE 32 #define MAC_SIZE 16 +#define BKEK_SIZE 32 /* Max size of any CAAM descriptor in 32-bit words, inclusive of header */ #define MAX_CAAM_DESCSIZE 64 @@ -463,6 +465,9 @@ #define OP_PROTINFO_HASH_SHA384 0x00000200 #define OP_PROTINFO_HASH_SHA512 0x00000280 +/* PROTINFO fields for Blob Operations */ +#define OP_PROTINFO_MKVB 0x00000002
* */ @@ -152,6 +153,87 @@ int blob_encap(u8 *key_mod, u8 *src, u8 *dst, u32 len) return ret; } +int derive_blob_kek(u8 *bkek_buf, u8 *key_mod, u32 key_sz) +{
- int ret, size;
- u32 *desc;
- if (!IS_ALIGNED((uintptr_t)bkek_buf, ARCH_DMA_MINALIGN) ||
- !IS_ALIGNED((uintptr_t)key_mod, ARCH_DMA_MINALIGN)) {
aligned!\n");
return -EINVAL;
- printf("\nBlob key encryption key(bkek)\n");
- desc = malloc_cache_aligned(sizeof(int) *
MAX_CAAM_DESCSIZE);
- if (!desc) {
allocation\n");
return -ENOMEM;
- size = ALIGN(key_sz, ARCH_DMA_MINALIGN);
- flush_dcache_range((unsigned long)key_mod, (unsigned
- /* construct blob key encryption key(bkek) derive descriptor
- inline_cnstr_jobdesc_derive_bkek(desc, bkek_buf, key_mod,
key_sz);
- size = ALIGN(sizeof(int) * MAX_CAAM_DESCSIZE,
ARCH_DMA_MINALIGN);
- flush_dcache_range((unsigned long)desc, (unsigned long)desc
- size);
- size = ALIGN(BKEK_SIZE, ARCH_DMA_MINALIGN);
- invalidate_dcache_range((unsigned long)bkek_buf,
- /* run descriptor */
- ret = run_descriptor_jr(desc);
- if (ret < 0) {
- } else {
size);
- free(desc);
- return ret;
- int ret, size;
- u32 *desc;
- if (!IS_ALIGNED((uintptr_t)dst, ARCH_DMA_MINALIGN)) {
not aligned!\n");
return -EINVAL;
- printf("\nRNG generate\n");
MAX_CAAM_DESCSIZE);
- if (!desc) {
allocation\n");
return -ENOMEM;
- inline_cnstr_jobdesc_rng(desc, dst, len);
ARCH_DMA_MINALIGN);
- size);
- size = ALIGN(len, ARCH_DMA_MINALIGN);
- invalidate_dcache_range((unsigned long)dst, (unsigned
long)dst + size);
- if (ret < 0) {
- } else {
- free(desc);
- return ret;
* */ @@ -207,7 +207,7 @@ void inline_cnstr_jobdesc_hash(uint32_t *desc, append_store(desc, dma_addr_out, storelen, LDST_CLASS_2_CCB | LDST_SRCDST_BYTE_CONTEXT); } -#ifndef CONFIG_SPL_BUILD
void inline_cnstr_jobdesc_blob_encap(uint32_t *desc, uint8_t *key_idnfr, uint8_t *plain_txt, uint8_t *enc_blob, uint32_t in_sz) @@ -255,7 +255,7 @@ void inline_cnstr_jobdesc_blob_decap(uint32_t *desc, uint8_t *key_idnfr, append_operation(desc, OP_TYPE_DECAP_PROTOCOL | OP_PCLID_BLOB); } -#endif
key_sz) +{
- dma_addr_t dma_key_mod = virt_to_phys(key_mod);
- dma_addr_t dma_bkek_out = virt_to_phys(bkek_out);
- init_job_desc(desc, 0);
- append_load(desc, dma_key_mod, key_sz, LDST_CLASS_2_C
CB |
- append_seq_out_ptr_intlen(desc, dma_bkek_out, BKEK_SIZE, 0);
- append_operation(desc, OP_TYPE_ENCAP_PROTOCOL |
OP_PCLID_BLOB |
OP_PROTINFO_
* */ @@ -49,4 +50,7 @@ void inline_cnstr_jobdesc_pkha_rsaexp(uint32_t *desc, struct pk_in_params *pkin, uint8_t *out, uint32_t out_siz); +void inline_cnstr_jobdesc_derive_bkek(uint32_t *desc, void *bkek_out,
key_sz);
#endif
disabled use of JR0 in SPL and uboot, as JR0 is reserved for secure boot.
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- arch/arm/dts/imx8mm-evk-u-boot.dtsi | 18 +++++++++++++++++- arch/arm/dts/imx8mm.dtsi | 1 + arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi | 18 +++++++++++++++++- arch/arm/dts/imx8mn.dtsi | 1 + arch/arm/dts/imx8mp-evk-u-boot.dtsi | 18 +++++++++++++++++- arch/arm/dts/imx8mp.dtsi | 1 + arch/arm/dts/imx8mq.dtsi | 1 + 7 files changed, 55 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/imx8mm-evk-u-boot.dtsi b/arch/arm/dts/imx8mm-evk-u-boot.dtsi index f200afac9f..3c2502cbba 100644 --- a/arch/arm/dts/imx8mm-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-evk-u-boot.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2019 NXP + * Copyright 2019, 2021 NXP */
#include "imx8mm-u-boot.dtsi" @@ -72,6 +72,22 @@ u-boot,dm-spl; };
+&crypto { + u-boot,dm-spl; +}; + +&sec_jr0 { + u-boot,dm-spl; +}; + +&sec_jr1 { + u-boot,dm-spl; +}; + +&sec_jr2 { + u-boot,dm-spl; +}; + &usdhc1 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mm.dtsi b/arch/arm/dts/imx8mm.dtsi index b142b80734..009999bf3a 100644 --- a/arch/arm/dts/imx8mm.dtsi +++ b/arch/arm/dts/imx8mm.dtsi @@ -824,6 +824,7 @@ compatible = "fsl,sec-v4.0-job-ring"; reg = <0x1000 0x1000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; };
sec_jr1: jr@2000 { diff --git a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi index 1d3844437d..b462d24eb2 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2019 NXP + * Copyright 2019, 2021 NXP */
/ { @@ -104,6 +104,22 @@ u-boot,dm-spl; };
+&crypto { + u-boot,dm-spl; +}; + +&sec_jr0 { + u-boot,dm-spl; +}; + +&sec_jr1 { + u-boot,dm-spl; +}; + +&sec_jr2 { + u-boot,dm-spl; +}; + &usdhc1 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mn.dtsi b/arch/arm/dts/imx8mn.dtsi index edcb415b53..1820a5af37 100644 --- a/arch/arm/dts/imx8mn.dtsi +++ b/arch/arm/dts/imx8mn.dtsi @@ -822,6 +822,7 @@ compatible = "fsl,sec-v4.0-job-ring"; reg = <0x1000 0x1000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; };
sec_jr1: jr@2000 { diff --git a/arch/arm/dts/imx8mp-evk-u-boot.dtsi b/arch/arm/dts/imx8mp-evk-u-boot.dtsi index 2abcf1f03d..5415d5b617 100644 --- a/arch/arm/dts/imx8mp-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-evk-u-boot.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2019 NXP + * Copyright 2019, 2021 NXP */
#include "imx8mp-u-boot.dtsi" @@ -67,6 +67,22 @@ u-boot,dm-spl; };
+&crypto { + u-boot,dm-spl; +}; + +&sec_jr0 { + u-boot,dm-spl; +}; + +&sec_jr1 { + u-boot,dm-spl; +}; + +&sec_jr2 { + u-boot,dm-spl; +}; + &i2c1 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mp.dtsi b/arch/arm/dts/imx8mp.dtsi index c2d51a46cb..57b01c3a57 100644 --- a/arch/arm/dts/imx8mp.dtsi +++ b/arch/arm/dts/imx8mp.dtsi @@ -624,6 +624,7 @@ compatible = "fsl,sec-v4.0-job-ring"; reg = <0x1000 0x1000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; };
sec_jr1: jr@2000 { diff --git a/arch/arm/dts/imx8mq.dtsi b/arch/arm/dts/imx8mq.dtsi index a44f729d0e..ecab44ca13 100644 --- a/arch/arm/dts/imx8mq.dtsi +++ b/arch/arm/dts/imx8mq.dtsi @@ -955,6 +955,7 @@ compatible = "fsl,sec-v4.0-job-ring"; reg = <0x1000 0x1000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; };
sec_jr1: jr@2000 {
Best regards, Ye Li
- Copyright 2019 NXP
- Copyright 2019, 2021 NXP
*/ #include "imx8mm-u-boot.dtsi" @@ -72,6 +72,22 @@ u-boot,dm-spl; }; +&crypto {
- u-boot,dm-spl;
+&sec_jr0 {
- u-boot,dm-spl;
+&sec_jr1 {
- u-boot,dm-spl;
+&sec_jr2 {
- u-boot,dm-spl;
&usdhc1 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mm.dtsi b/arch/arm/dts/imx8mm.dtsi index b142b80734..009999bf3a 100644 --- a/arch/arm/dts/imx8mm.dtsi +++ b/arch/arm/dts/imx8mm.dtsi @@ -824,6 +824,7 @@ compatible = "fsl,sec-v4.0- job-ring"; reg = <0x1000 0x1000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>;
}; sec_jr1: jr@2000 { diff --git a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi index 1d3844437d..b462d24eb2 100644 --- a/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-ddr4-evk-u-boot.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /*
*/ / { @@ -104,6 +104,22 @@ u-boot,dm-spl; }; +&crypto {
- u-boot,dm-spl;
+&sec_jr0 {
- u-boot,dm-spl;
+&sec_jr1 {
- u-boot,dm-spl;
+&sec_jr2 {
- u-boot,dm-spl;
&usdhc1 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mn.dtsi b/arch/arm/dts/imx8mn.dtsi index edcb415b53..1820a5af37 100644 --- a/arch/arm/dts/imx8mn.dtsi +++ b/arch/arm/dts/imx8mn.dtsi @@ -822,6 +822,7 @@ compatible = "fsl,sec-v4.0- job-ring"; reg = <0x1000 0x1000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>;
}; sec_jr1: jr@2000 { diff --git a/arch/arm/dts/imx8mp-evk-u-boot.dtsi b/arch/arm/dts/imx8mp-evk-u-boot.dtsi index 2abcf1f03d..5415d5b617 100644 --- a/arch/arm/dts/imx8mp-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-evk-u-boot.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /*
*/ #include "imx8mp-u-boot.dtsi" @@ -67,6 +67,22 @@ u-boot,dm-spl; }; +&crypto {
- u-boot,dm-spl;
+&sec_jr0 {
- u-boot,dm-spl;
+&sec_jr1 {
- u-boot,dm-spl;
+&sec_jr2 {
- u-boot,dm-spl;
&i2c1 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mp.dtsi b/arch/arm/dts/imx8mp.dtsi index c2d51a46cb..57b01c3a57 100644 --- a/arch/arm/dts/imx8mp.dtsi +++ b/arch/arm/dts/imx8mp.dtsi @@ -624,6 +624,7 @@ compatible = "fsl,sec-v4.0- job-ring"; reg = <0x1000 0x1000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>;
}; sec_jr1: jr@2000 { diff --git a/arch/arm/dts/imx8mq.dtsi b/arch/arm/dts/imx8mq.dtsi index a44f729d0e..ecab44ca13 100644 --- a/arch/arm/dts/imx8mq.dtsi +++ b/arch/arm/dts/imx8mq.dtsi @@ -955,6 +955,7 @@ compatible = "fsl,sec-v4.0- job-ring"; reg = <0x1000 0x1000>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>;
+&crypto {
u-boot,dm-spl;
+&sec_jr0 {
u-boot,dm-spl;
+&sec_jr1 {
u-boot,dm-spl;
+&sec_jr2 {
u-boot,dm-spl;
status = "disabled"; }; sec_jr1: jr@2000 {
+&crypto {
u-boot,dm-spl;
+&sec_jr0 {
u-boot,dm-spl;
+&sec_jr1 {
u-boot,dm-spl;
+&sec_jr2 {
u-boot,dm-spl;
+&crypto {
u-boot,dm-spl;
+&sec_jr0 {
u-boot,dm-spl;
+&sec_jr1 {
u-boot,dm-spl;
+&sec_jr2 {
u-boot,dm-spl;
-- 2.17.1
Is there a reason these need to be in board specific dts vs the base ones that are included by all the boards?
Tim
Hello Tim,
-----Original Message----- From: Tim Harvey tharvey@gateworks.com Sent: Friday, September 10, 2021 8:17 PM To: Gaurav Jain gaurav.jain@nxp.com Cc: u-boot u-boot@lists.denx.de; Stefano Babic sbabic@denx.de; Fabio Estevam festevam@gmail.com; Peng Fan peng.fan@nxp.com; Simon Glass sjg@chromium.org; Priyanka Jain priyanka.jain@nxp.com; Ye Li ye.li@nxp.com; Horia Geanta horia.geanta@nxp.com; Ji Luo ji.luo@nxp.com; Franck Lenormand franck.lenormand@nxp.com; Silvano Di Ninno silvano.dininno@nxp.com; Sahil Malhotra sahil.malhotra@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; dl- uboot-imx uboot-imx@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com; Wasim Khan wasim.khan@nxp.com; Alison Wang alison.wang@nxp.com; Pramod Kumar pramod.kumar_1@nxp.com; Andy Tang andy.tang@nxp.com; Adrian Alonso adrian.alonso@nxp.com; Vladimir Oltean olteanv@gmail.com Subject: [EXT] Re: [PATCH v2 03/15] i.MX8M: crypto: updated device tree for supporting DM in SPL
Caution: EXT Email
+&crypto {
u-boot,dm-spl;
+&sec_jr0 {
u-boot,dm-spl;
+&sec_jr1 {
u-boot,dm-spl;
+&sec_jr2 {
u-boot,dm-spl;
status = "disabled"; }; sec_jr1: jr@2000 { diff --git
+&crypto {
u-boot,dm-spl;
+&sec_jr0 {
u-boot,dm-spl;
+&sec_jr1 {
u-boot,dm-spl;
+&sec_jr2 {
u-boot,dm-spl;
+&crypto {
u-boot,dm-spl;
+&sec_jr0 {
u-boot,dm-spl;
+&sec_jr1 {
u-boot,dm-spl;
+&sec_jr2 {
u-boot,dm-spl;
-- 2.17.1
We have different clock for different boards and we want to control job rings for each board separately.
Regards Gaurav Jain
Tim
On Sun, Sep 12, 2021 at 9:55 PM Gaurav Jain gaurav.jain@nxp.com wrote:
Hello Tim,
Caution: EXT Email
+&crypto {
u-boot,dm-spl;
+&sec_jr0 {
u-boot,dm-spl;
+&sec_jr1 {
u-boot,dm-spl;
+&sec_jr2 {
u-boot,dm-spl;
+&crypto {
u-boot,dm-spl;
+&sec_jr0 {
u-boot,dm-spl;
+&sec_jr1 {
u-boot,dm-spl;
+&sec_jr2 {
u-boot,dm-spl;
+&crypto {
u-boot,dm-spl;
+&sec_jr0 {
u-boot,dm-spl;
+&sec_jr1 {
u-boot,dm-spl;
+&sec_jr2 {
u-boot,dm-spl;
-- 2.17.1
Gaurav,
I agree that imx8mm, imx8mn, imx8mp all have different clocks but you are setting adding nodes to 'board' specific u-boot.dtsi's that include common files where instead they should go.
For example arch/arm/dts/imx8mm-evk-u-boot.dtsi includes 'imx8mm-u-boot.dtsi' so you should be adding the crypto/sec_jr0/sec_jr1/sec_jr2 nodes there. Similarly arch/arm/dts/imx8mp-evk-u-boot.dtsi includes 'imx8mp-u-boot.dtsi' so they should go there.
The addition of the common imx8mm-u-boot.dtsi and imx8mp-u-boot.dtsi is rather recent so you may not have seen that. Additionally there doesn't appear to be a common imx8mn-u-boot.dtsi yet and one should be created.
Tim
Hello Tim
-----Original Message----- From: Tim Harvey tharvey@gateworks.com Sent: Friday, September 24, 2021 4:10 AM To: Gaurav Jain gaurav.jain@nxp.com Cc: u-boot u-boot@lists.denx.de; Stefano Babic sbabic@denx.de; Fabio Estevam festevam@gmail.com; Peng Fan peng.fan@nxp.com; Simon Glass sjg@chromium.org; Priyanka Jain priyanka.jain@nxp.com; Ye Li ye.li@nxp.com; Horia Geanta horia.geanta@nxp.com; Ji Luo ji.luo@nxp.com; Franck Lenormand franck.lenormand@nxp.com; Silvano Di Ninno silvano.dininno@nxp.com; Sahil Malhotra sahil.malhotra@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; dl- uboot-imx uboot-imx@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com; Wasim Khan wasim.khan@nxp.com; Alison Wang alison.wang@nxp.com; Pramod Kumar pramod.kumar_1@nxp.com; Andy Tang andy.tang@nxp.com; Adrian Alonso adrian.alonso@nxp.com; Vladimir Oltean olteanv@gmail.com Subject: Re: [EXT] Re: [PATCH v2 03/15] i.MX8M: crypto: updated device tree for supporting DM in SPL
Caution: EXT Email
Hello Tim,
Caution: EXT Email
+&crypto {
u-boot,dm-spl;
+&sec_jr0 {
u-boot,dm-spl;
+&sec_jr1 {
u-boot,dm-spl;
+&sec_jr2 {
u-boot,dm-spl;
+&crypto {
u-boot,dm-spl;
+&sec_jr0 {
u-boot,dm-spl;
+&sec_jr1 {
u-boot,dm-spl;
+&sec_jr2 {
u-boot,dm-spl;
+&crypto {
u-boot,dm-spl;
+&sec_jr0 {
u-boot,dm-spl;
+&sec_jr1 {
u-boot,dm-spl;
+&sec_jr2 {
u-boot,dm-spl;
-- 2.17.1
Gaurav,
For example arch/arm/dts/imx8mm-evk-u-boot.dtsi includes 'imx8mm-u- boot.dtsi' so you should be adding the crypto/sec_jr0/sec_jr1/sec_jr2 nodes there. Similarly arch/arm/dts/imx8mp-evk- u-boot.dtsi includes 'imx8mp-u-boot.dtsi' so they should go there.
CAAM and SEC JR nodes need to be added into base soc dts i.e. imx8mm.dtsi, imx8mn.dtsi, imx8mp.dtsi, imx8mq.dtsi. In kernel SEC nodes are added in similar way in soc dts imx8mm.dtsi and we are using same approach in spl and uboot. Let me know if you have any specific reason to shift the SEC nodes to imx8mm-u-boot.dtsi?
Regards Gaurav Jain
Tim
i.MX8MM/MN/MP/MQ - added support for JR driver model. sec is initialized based on job ring information processed from device tree.
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- arch/arm/Kconfig | 2 +- arch/arm/include/asm/arch-imx8m/imx-regs.h | 1 + arch/arm/mach-imx/imx8m/Kconfig | 23 ++++++++++++++++++++++ arch/arm/mach-imx/imx8m/soc.c | 10 +++++++++- board/freescale/imx8mm_evk/spl.c | 9 ++++++++- board/freescale/imx8mn_evk/spl.c | 8 ++++++-- board/freescale/imx8mp_evk/spl.c | 13 ++++++++++-- board/freescale/imx8mq_evk/spl.c | 9 +++++++-- drivers/crypto/fsl/jr.c | 14 ++++++++++--- scripts/config_whitelist.txt | 1 + 10 files changed, 78 insertions(+), 12 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 2d59562665..af7aad3f9e 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -794,7 +794,7 @@ config ARCH_IMX8M bool "NXP i.MX8M platform" select ARM64 select GPIO_EXTRA_HEADER - select SYS_FSL_HAS_SEC if IMX_HAB + select SYS_FSL_HAS_SEC select SYS_FSL_SEC_COMPAT_4 select SYS_FSL_SEC_LE select DM diff --git a/arch/arm/include/asm/arch-imx8m/imx-regs.h b/arch/arm/include/asm/arch-imx8m/imx-regs.h index b800da13a1..ff8de53f67 100644 --- a/arch/arm/include/asm/arch-imx8m/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8m/imx-regs.h @@ -72,6 +72,7 @@ #define CONFIG_SYS_FSL_SEC_ADDR (CAAM_IPS_BASE_ADDR + \ CONFIG_SYS_FSL_SEC_OFFSET) #define CONFIG_SYS_FSL_JR0_OFFSET (0x1000) +#define CONFIG_SYS_FSL_JR1_OFFSET (0x2000) #define CONFIG_SYS_FSL_JR0_ADDR (CONFIG_SYS_FSL_SEC_ADDR + \ CONFIG_SYS_FSL_JR0_OFFSET) #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index ccaf106be5..3fbdd5c233 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -38,6 +38,11 @@ config TARGET_IMX8MQ_EVK bool "imx8mq_evk" select IMX8MQ select IMX8M_LPDDR4 + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT + select SPL_CRYPTO if SPL
config TARGET_IMX8MQ_PHANBELL bool "imx8mq_phanbell" @@ -50,6 +55,11 @@ config TARGET_IMX8MM_EVK select IMX8MM select SUPPORT_SPL select IMX8M_LPDDR4 + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT + select SPL_CRYPTO if SPL
config TARGET_IMX8MM_ICORE_MX8MM bool "Engicam i.Core MX8M Mini SOM" @@ -81,6 +91,10 @@ config TARGET_IMX8MN_EVK select IMX8MN select SUPPORT_SPL select IMX8M_LPDDR4 + select FSL_CAAM + select FSL_BLOB + select MISC + select SPL_CRYPTO if SPL
config TARGET_IMX8MN_DDR4_EVK bool "imx8mn DDR4 EVK board" @@ -88,6 +102,10 @@ config TARGET_IMX8MN_DDR4_EVK select IMX8MN select SUPPORT_SPL select IMX8M_DDR4 + select FSL_CAAM + select FSL_BLOB + select MISC + select SPL_CRYPTO if SPL
config TARGET_IMX8MP_EVK bool "imx8mp LPDDR4 EVK board" @@ -95,6 +113,11 @@ config TARGET_IMX8MP_EVK select IMX8MP select SUPPORT_SPL select IMX8M_LPDDR4 + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT + select SPL_CRYPTO if SPL
config TARGET_PICO_IMX8MQ bool "Support Technexion Pico iMX8MQ" diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index f2ddc834d4..0fe28f4971 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2017-2019 NXP + * Copyright 2017-2019, 2021 NXP * * Peng Fan peng.fan@nxp.com */ @@ -20,6 +20,7 @@ #include <asm/ptrace.h> #include <asm/armv8/mmu.h> #include <dm/uclass.h> +#include <dm/device.h> #include <efi_loader.h> #include <env.h> #include <env_internal.h> @@ -1187,6 +1188,13 @@ static void acquire_buildinfo(void)
int arch_misc_init(void) { + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); + if (ret) + printf("Failed to initialize %s: %d\n", dev->name, ret); + acquire_buildinfo();
return 0; diff --git a/board/freescale/imx8mm_evk/spl.c b/board/freescale/imx8mm_evk/spl.c index 4ef7f6f180..c81128f442 100644 --- a/board/freescale/imx8mm_evk/spl.c +++ b/board/freescale/imx8mm_evk/spl.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2019 NXP + * Copyright 2019, 2021 NXP */
#include <common.h> @@ -51,6 +51,13 @@ static void spl_dram_init(void)
void spl_board_init(void) { + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); + if (ret) + printf("Failed to initialize %s: %d\n", dev->name, ret); + puts("Normal Boot\n"); }
diff --git a/board/freescale/imx8mn_evk/spl.c b/board/freescale/imx8mn_evk/spl.c index 03f2a56e80..ab19dabf7b 100644 --- a/board/freescale/imx8mn_evk/spl.c +++ b/board/freescale/imx8mn_evk/spl.c @@ -1,7 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0-or-later /* - * Copyright 2018-2019 NXP + * Copyright 2018-2019, 2021 NXP * - * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> @@ -49,6 +49,10 @@ void spl_board_init(void) struct udevice *dev; int ret;
ret = uclass_get_device_by_name(UCLASS_CLK, diff --git a/board/freescale/imx8mp_evk/spl.c b/board/freescale/imx8mp_evk/spl.c index a7564e9b1a..cf9a1235d5 100644 --- a/board/freescale/imx8mp_evk/spl.c +++ b/board/freescale/imx8mp_evk/spl.c @@ -1,7 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0-or-later /* - * Copyright 2018-2019 NXP + * Copyright 2018-2019, 2021 NXP * - * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> @@ -20,6 +20,8 @@ #include <asm/arch/ddr.h> #include <power/pmic.h> #include <power/pca9450.h> +#include <dm/uclass.h> +#include <dm/device.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -35,6 +37,13 @@ void spl_dram_init(void)
void spl_board_init(void) { + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); + if (ret) + printf("Failed to initialize %s: %d\n", dev->name, ret); + /* * Set GIC clock to 500Mhz for OD VDD_SOC. Kernel driver does * not allow to change it. Should set the clock after PMIC diff --git a/board/freescale/imx8mq_evk/spl.c b/board/freescale/imx8mq_evk/spl.c index e8e0efe485..cdd17add08 100644 --- a/board/freescale/imx8mq_evk/spl.c +++ b/board/freescale/imx8mq_evk/spl.c @@ -1,8 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2018 NXP + * Copyright 2018, 2021 NXP * - * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> @@ -22,6 +21,7 @@ #include <asm/mach-imx/gpio.h> #include <asm/mach-imx/mxc_i2c.h> #include <fsl_esdhc_imx.h> +#include <fsl_sec.h> #include <mmc.h> #include <linux/delay.h> #include <power/pmic.h> @@ -199,6 +199,11 @@ int power_init_board(void)
void spl_board_init(void) { +#ifdef CONFIG_FSL_CAAM + if (sec_init()) + printf("\nsec_init failed!\n"); + +#endif puts("Normal Boot\n"); }
diff --git a/drivers/crypto/fsl/jr.c b/drivers/crypto/fsl/jr.c index c5a8b0459e..1b027f253c 100644 --- a/drivers/crypto/fsl/jr.c +++ b/drivers/crypto/fsl/jr.c @@ -43,9 +43,17 @@ struct udevice *caam_dev; #define SEC_ADDR(idx) \ (ulong)((CONFIG_SYS_FSL_SEC_ADDR + sec_offset[idx]))
-#define SEC_JR0_ADDR(idx) \ +#ifndef CONFIG_IMX8M +#define SEC_JR_ADDR(idx) \ (ulong)(SEC_ADDR(idx) + \ (CONFIG_SYS_FSL_JR0_OFFSET - CONFIG_SYS_FSL_SEC_OFFSET)) +#define JR_ID 0 +#else +#define SEC_JR_ADDR(idx) \ + (ulong)(SEC_ADDR(idx) + \ + (CONFIG_SYS_FSL_JR1_OFFSET - CONFIG_SYS_FSL_SEC_OFFSET)) +#define JR_ID 1 +#endif struct caam_regs caam_st; #endif
@@ -671,8 +679,8 @@ int sec_init_idx(uint8_t sec_idx) caam = dev_get_priv(caam_dev); #else caam_st.sec = (void *)SEC_ADDR(sec_idx); - caam_st.regs = (struct jr_regs *)SEC_JR0_ADDR(sec_idx); - caam_st.jrid = 0; + caam_st.regs = (struct jr_regs *)SEC_JR_ADDR(sec_idx); + caam_st.jrid = JR_ID; caam = &caam_st; #endif #ifndef CONFIG_ARCH_IMX8 diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d86f35856f..4f773198e3 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2107,6 +2107,7 @@ CONFIG_SYS_FSL_IFC_SIZE2 CONFIG_SYS_FSL_ISBC_VER CONFIG_SYS_FSL_JR0_ADDR CONFIG_SYS_FSL_JR0_OFFSET +CONFIG_SYS_FSL_JR1_OFFSET CONFIG_SYS_FSL_LS1_CLK_ADDR CONFIG_SYS_FSL_LSCH3_SERDES_ADDR CONFIG_SYS_FSL_MAX_NUM_OF_SEC
Best regards, Ye Li
select SYS_FSL_SEC_COMPAT_4 select SYS_FSL_SEC_LE select DM diff --git a/arch/arm/include/asm/arch-imx8m/imx-regs.h b/arch/arm/include/asm/arch-imx8m/imx-regs.h index b800da13a1..ff8de53f67 100644 --- a/arch/arm/include/asm/arch-imx8m/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8m/imx-regs.h @@ -72,6 +72,7 @@ #define CONFIG_SYS_FSL_SEC_ADDR (CAAM_IPS_BASE_ADDR + \ CONFIG_SYS_FSL_SEC_OFFSET) #define CONFIG_SYS_FSL_JR0_OFFSET (0x1000) +#define CONFIG_SYS_FSL_JR1_OFFSET (0x2000) #define CONFIG_SYS_FSL_JR0_ADDR (CONFIG_SYS_FSL_SEC_ADDR + \ CONFIG_SYS_FSL_JR0_OFFSET) #define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach- imx/imx8m/Kconfig index ccaf106be5..3fbdd5c233 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -38,6 +38,11 @@ config TARGET_IMX8MQ_EVK bool "imx8mq_evk" select IMX8MQ select IMX8M_LPDDR4
- select FSL_CAAM
- select FSL_BLOB
- select MISC
- select ARCH_MISC_INIT
- select SPL_CRYPTO if SPL
- select FSL_CAAM
- select FSL_BLOB
- select MISC
- select FSL_CAAM
- select FSL_BLOB
- select MISC
- select FSL_CAAM
- select FSL_BLOB
- select MISC
- select FSL_CAAM
- select FSL_BLOB
- select MISC
config TARGET_PICO_IMX8MQ bool "Support Technexion Pico iMX8MQ" diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach- imx/imx8m/soc.c index f2ddc834d4..0fe28f4971 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /*
- Copyright 2017-2019 NXP
- Copyright 2017-2019, 2021 NXP
* * Peng Fan peng.fan@nxp.com */ @@ -20,6 +20,7 @@ #include <asm/ptrace.h> #include <asm/armv8/mmu.h> #include <dm/uclass.h> +#include <dm/device.h> #include <efi_loader.h> #include <env.h> #include <env_internal.h> @@ -1187,6 +1188,13 @@ static void acquire_buildinfo(void) int arch_misc_init(void) {
- struct udevice *dev;
- int ret;
- ret = uclass_get_device_by_driver(UCLASS_MISC,
- if (ret)
ret);
acquire_buildinfo(); return 0; diff --git a/board/freescale/imx8mm_evk/spl.c b/board/freescale/imx8mm_evk/spl.c index 4ef7f6f180..c81128f442 100644 --- a/board/freescale/imx8mm_evk/spl.c +++ b/board/freescale/imx8mm_evk/spl.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /*
*/ #include <common.h> @@ -51,6 +51,13 @@ static void spl_dram_init(void) void spl_board_init(void) {
- int ret;
- if (ret)
ret);
puts("Normal Boot\n"); } diff --git a/board/freescale/imx8mn_evk/spl.c b/board/freescale/imx8mn_evk/spl.c index 03f2a56e80..ab19dabf7b 100644 --- a/board/freescale/imx8mn_evk/spl.c +++ b/board/freescale/imx8mn_evk/spl.c @@ -1,7 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0-or-later /*
- Copyright 2018-2019 NXP
- Copyright 2018-2019, 2021 NXP
*/ #include <common.h> @@ -49,6 +49,10 @@ void spl_board_init(void) struct udevice *dev; int ret;
- if (ret)
ret);
puts("Normal Boot\n"); ret = uclass_get_device_by_name(UCLASS_CLK, diff --git a/board/freescale/imx8mp_evk/spl.c b/board/freescale/imx8mp_evk/spl.c index a7564e9b1a..cf9a1235d5 100644 --- a/board/freescale/imx8mp_evk/spl.c +++ b/board/freescale/imx8mp_evk/spl.c @@ -1,7 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0-or-later /*
*/ #include <common.h> @@ -20,6 +20,8 @@ #include <asm/arch/ddr.h> #include <power/pmic.h> #include <power/pca9450.h> +#include <dm/uclass.h> +#include <dm/device.h> DECLARE_GLOBAL_DATA_PTR; @@ -35,6 +37,13 @@ void spl_dram_init(void) void spl_board_init(void) {
- int ret;
- if (ret)
ret);
*/ #include <common.h> @@ -22,6 +21,7 @@ #include <asm/mach-imx/gpio.h> #include <asm/mach-imx/mxc_i2c.h> #include <fsl_esdhc_imx.h> +#include <fsl_sec.h> #include <mmc.h> #include <linux/delay.h> #include <power/pmic.h> @@ -199,6 +199,11 @@ int power_init_board(void) void spl_board_init(void) { +#ifdef CONFIG_FSL_CAAM
- if (sec_init())
+#endif puts("Normal Boot\n"); } diff --git a/drivers/crypto/fsl/jr.c b/drivers/crypto/fsl/jr.c index c5a8b0459e..1b027f253c 100644 --- a/drivers/crypto/fsl/jr.c +++ b/drivers/crypto/fsl/jr.c @@ -43,9 +43,17 @@ struct udevice *caam_dev; #define SEC_ADDR(idx) \ (ulong)((CONFIG_SYS_FSL_SEC_ADDR + sec_offset[idx])) -#define SEC_JR0_ADDR(idx) \ +#ifndef CONFIG_IMX8M +#define SEC_JR_ADDR(idx) \ (ulong)(SEC_ADDR(idx) + \ (CONFIG_SYS_FSL_JR0_OFFSET - CONFIG_SYS_FSL_SEC_OFFSET)) +#define JR_ID 0 +#else +#define SEC_JR_ADDR(idx) \
- (ulong)(SEC_ADDR(idx) + \
- (CONFIG_SYS_FSL_JR1_OFFSET - CONFIG_SYS_FSL_SEC_OFFSET))
+#define JR_ID 1 +#endif struct caam_regs caam_st; #endif @@ -671,8 +679,8 @@ int sec_init_idx(uint8_t sec_idx) caam = dev_get_priv(caam_dev); #else caam_st.sec = (void *)SEC_ADDR(sec_idx);
- caam_st.jrid = 0;
- caam_st.regs = (struct jr_regs *)SEC_JR_ADDR(sec_idx);
- caam_st.jrid = JR_ID;
i.MX6(SX/UL) - added support for JR driver model.
removed sec_init() call, sec is initialized based on job ring information processed from device tree.
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- arch/arm/mach-imx/mx6/Kconfig | 8 ++++++++ arch/arm/mach-imx/mx6/soc.c | 12 ++++++++---- 2 files changed, 16 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 789a50d4e9..a7109bb512 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -378,6 +378,10 @@ config TARGET_MX6SXSABRESD select DM select DM_THERMAL select SUPPORT_SPL + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT
config TARGET_MX6SXSABREAUTO bool "mx6sxsabreauto" @@ -405,6 +409,10 @@ config TARGET_MX6UL_14X14_EVK select DM_THERMAL select SUPPORT_SPL imply CMD_DM + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT
config TARGET_MX6UL_ENGICAM bool "Support Engicam GEAM6UL/Is.IoT" diff --git a/arch/arm/mach-imx/mx6/soc.c b/arch/arm/mach-imx/mx6/soc.c index aacfc854a2..fa6c3778bb 100644 --- a/arch/arm/mach-imx/mx6/soc.c +++ b/arch/arm/mach-imx/mx6/soc.c @@ -4,6 +4,7 @@ * Sascha Hauer, Pengutronix * * (C) Copyright 2009 Freescale Semiconductor, Inc. + * Copyright 2021 NXP */
#include <common.h> @@ -23,7 +24,6 @@ #include <asm/arch/mxc_hdmi.h> #include <asm/arch/crm_regs.h> #include <dm.h> -#include <fsl_sec.h> #include <imx_thermal.h> #include <mmc.h>
@@ -734,9 +734,13 @@ static void setup_serial_number(void)
int arch_misc_init(void) { -#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); + if (ret) + printf("Failed to initialize %s: %d\n", dev->name, ret); + setup_serial_number(); return 0; }
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach- imx/mx6/Kconfig index 789a50d4e9..a7109bb512 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -378,6 +378,10 @@ config TARGET_MX6SXSABRESD select DM select DM_THERMAL select SUPPORT_SPL
- select FSL_CAAM
- select FSL_BLOB
- select MISC
- select FSL_CAAM
- select FSL_BLOB
- select MISC
Can you also enable the JR driver for MX6SABREAUTO, MX6SABRESD and MX6UL_9X9_EVK?
Best regards, Ye Li
config TARGET_MX6UL_ENGICAM bool "Support Engicam GEAM6UL/Is.IoT" diff --git a/arch/arm/mach-imx/mx6/soc.c b/arch/arm/mach- imx/mx6/soc.c index aacfc854a2..fa6c3778bb 100644 --- a/arch/arm/mach-imx/mx6/soc.c +++ b/arch/arm/mach-imx/mx6/soc.c @@ -4,6 +4,7 @@ * Sascha Hauer, Pengutronix * * (C) Copyright 2009 Freescale Semiconductor, Inc.
*/ #include <common.h> @@ -23,7 +24,6 @@ #include <asm/arch/mxc_hdmi.h> #include <asm/arch/crm_regs.h> #include <dm.h> -#include <fsl_sec.h> #include <imx_thermal.h> #include <mmc.h> @@ -734,9 +734,13 @@ static void setup_serial_number(void) int arch_misc_init(void) { -#ifdef CONFIG_FSL_CAAM
- sec_init();
-#endif
- int ret;
- if (ret)
ret);
i.MX7D - added support for JR driver model.
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- arch/arm/Kconfig | 2 +- arch/arm/mach-imx/mx7/Kconfig | 3 +++ arch/arm/mach-imx/mx7/soc.c | 11 +++++++---- 3 files changed, 11 insertions(+), 5 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index af7aad3f9e..addd349e54 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -860,7 +860,7 @@ config ARCH_MX7 select ARCH_MISC_INIT select CPU_V7A select GPIO_EXTRA_HEADER - select SYS_FSL_HAS_SEC if IMX_HAB + select SYS_FSL_HAS_SEC select SYS_FSL_SEC_COMPAT_4 select SYS_FSL_SEC_LE imply BOARD_EARLY_INIT_F diff --git a/arch/arm/mach-imx/mx7/Kconfig b/arch/arm/mach-imx/mx7/Kconfig index adedc01164..b82338e2cc 100644 --- a/arch/arm/mach-imx/mx7/Kconfig +++ b/arch/arm/mach-imx/mx7/Kconfig @@ -60,6 +60,9 @@ config TARGET_MX7DSABRESD select DM_THERMAL select MX7D imply CMD_DM + select FSL_CAAM + select FSL_BLOB + select MISC
config TARGET_PICO_IMX7D bool "pico-imx7d" diff --git a/arch/arm/mach-imx/mx7/soc.c b/arch/arm/mach-imx/mx7/soc.c index fda25ba66a..26b00bc93f 100644 --- a/arch/arm/mach-imx/mx7/soc.c +++ b/arch/arm/mach-imx/mx7/soc.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright (C) 2015 Freescale Semiconductor, Inc. + * Copyright 2021 NXP */
#include <common.h> @@ -18,7 +19,6 @@ #include <dm.h> #include <env.h> #include <imx_thermal.h> -#include <fsl_sec.h> #include <asm/setup.h> #include <linux/delay.h>
@@ -336,6 +336,9 @@ int arch_cpu_init(void) #ifdef CONFIG_ARCH_MISC_INIT int arch_misc_init(void) { + struct udevice *dev; + int ret; + #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG if (is_mx7d()) env_set("soc", "imx7d"); @@ -343,9 +346,9 @@ int arch_misc_init(void) env_set("soc", "imx7s"); #endif
-#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); + if (ret) + printf("Failed to initialize %s: %d\n", dev->name, ret);
return 0; }
Best regards, Ye Li
select SYS_FSL_SEC_COMPAT_4 select SYS_FSL_SEC_LE imply BOARD_EARLY_INIT_F diff --git a/arch/arm/mach-imx/mx7/Kconfig b/arch/arm/mach- imx/mx7/Kconfig index adedc01164..b82338e2cc 100644 --- a/arch/arm/mach-imx/mx7/Kconfig +++ b/arch/arm/mach-imx/mx7/Kconfig @@ -60,6 +60,9 @@ config TARGET_MX7DSABRESD select DM_THERMAL select MX7D imply CMD_DM
- select FSL_CAAM
- select FSL_BLOB
- select MISC
config TARGET_PICO_IMX7D bool "pico-imx7d" diff --git a/arch/arm/mach-imx/mx7/soc.c b/arch/arm/mach- imx/mx7/soc.c index fda25ba66a..26b00bc93f 100644 --- a/arch/arm/mach-imx/mx7/soc.c +++ b/arch/arm/mach-imx/mx7/soc.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright (C) 2015 Freescale Semiconductor, Inc.
*/ #include <common.h> @@ -18,7 +19,6 @@ #include <dm.h> #include <env.h> #include <imx_thermal.h> -#include <fsl_sec.h> #include <asm/setup.h> #include <linux/delay.h> @@ -336,6 +336,9 @@ int arch_cpu_init(void) #ifdef CONFIG_ARCH_MISC_INIT int arch_misc_init(void) {
- int ret;
#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG if (is_mx7d()) env_set("soc", "imx7d"); @@ -343,9 +346,9 @@ int arch_misc_init(void) env_set("soc", "imx7s"); #endif -#ifdef CONFIG_FSL_CAAM
- sec_init();
-#endif
- if (ret)
ret); return 0; }
added crypto node in device tree. sec is initialized based on job ring information processed from device tree.
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- arch/arm/Kconfig | 2 +- arch/arm/dts/imx7ulp.dtsi | 24 ++++++++++++++++++++++++ arch/arm/mach-imx/mx7ulp/Kconfig | 4 ++++ arch/arm/mach-imx/mx7ulp/soc.c | 16 ++++++++++++++++ 4 files changed, 45 insertions(+), 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index addd349e54..b3d11c1a0d 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -848,7 +848,7 @@ config ARCH_MX7ULP bool "NXP MX7ULP" select CPU_V7A select GPIO_EXTRA_HEADER - select SYS_FSL_HAS_SEC if IMX_HAB + select SYS_FSL_HAS_SEC select SYS_FSL_SEC_COMPAT_4 select SYS_FSL_SEC_LE select ROM_UNIFIED_SECTIONS diff --git a/arch/arm/dts/imx7ulp.dtsi b/arch/arm/dts/imx7ulp.dtsi index 7bcd2cc346..494b9d98b2 100644 --- a/arch/arm/dts/imx7ulp.dtsi +++ b/arch/arm/dts/imx7ulp.dtsi @@ -1,5 +1,6 @@ /* * Copyright 2015-2016 Freescale Semiconductor, Inc. + * Copyright 2021 NXP * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as @@ -198,6 +199,29 @@ }; };
+ crypto: crypto@40240000 { + compatible = "fsl,sec-v4.0"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x40240000 0x10000>; + ranges = <0 0x40240000 0x10000>; + clocks = <&clks IMX7ULP_CLK_CAAM>, + <&clks IMX7ULP_CLK_NIC1_BUS_DIV>; + clock-names = "aclk", "ipg"; + + sec_jr0: jr@1000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x1000 0x1000>; + interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr1: jr@2000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x2000 0x1000>; + interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + tpm5: tpm@40260000 { compatible = "fsl,imx7ulp-tpm"; reg = <0x40260000 0x1000>; diff --git a/arch/arm/mach-imx/mx7ulp/Kconfig b/arch/arm/mach-imx/mx7ulp/Kconfig index 2ffac9cf7c..0d9f8ffed9 100644 --- a/arch/arm/mach-imx/mx7ulp/Kconfig +++ b/arch/arm/mach-imx/mx7ulp/Kconfig @@ -25,6 +25,10 @@ config TARGET_MX7ULP_EVK bool "Support mx7ulp EVK board" select MX7ULP select SYS_ARCH_TIMER + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT
endchoice
diff --git a/arch/arm/mach-imx/mx7ulp/soc.c b/arch/arm/mach-imx/mx7ulp/soc.c index 320f24dd29..1cfc751bdc 100644 --- a/arch/arm/mach-imx/mx7ulp/soc.c +++ b/arch/arm/mach-imx/mx7ulp/soc.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright (C) 2016 Freescale Semiconductor, Inc. + * Copyright 2021 NXP */
#include <common.h> @@ -14,6 +15,7 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/hab.h> #include <linux/bitops.h> +#include <dm.h>
#define PMC0_BASE_ADDR 0x410a1000 #define PMC0_CTRL 0x28 @@ -79,6 +81,20 @@ int arch_cpu_init(void) return 0; }
+#if defined(CONFIG_ARCH_MISC_INIT) +int arch_misc_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); + if (ret) + printf("Failed to initialize %s: %d\n", dev->name, ret); + + return 0; +} +#endif + #ifdef CONFIG_BOARD_POSTCLK_INIT int board_postclk_init(void) {
Best regards, Ye Li
#size-cells = <1>;
sec_jr0: jr@1000 {
ring";
sec_jr1: jr@2000 {
ring";
tpm5: tpm@40260000 { compatible = "fsl,imx7ulp-tpm"; reg = <0x40260000 0x1000>; diff --git a/arch/arm/mach-imx/mx7ulp/Kconfig b/arch/arm/mach- imx/mx7ulp/Kconfig index 2ffac9cf7c..0d9f8ffed9 100644 --- a/arch/arm/mach-imx/mx7ulp/Kconfig +++ b/arch/arm/mach-imx/mx7ulp/Kconfig @@ -25,6 +25,10 @@ config TARGET_MX7ULP_EVK bool "Support mx7ulp EVK board" select MX7ULP select SYS_ARCH_TIMER
- select FSL_CAAM
- select FSL_BLOB
- select MISC
endchoice diff --git a/arch/arm/mach-imx/mx7ulp/soc.c b/arch/arm/mach- imx/mx7ulp/soc.c index 320f24dd29..1cfc751bdc 100644 --- a/arch/arm/mach-imx/mx7ulp/soc.c +++ b/arch/arm/mach-imx/mx7ulp/soc.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright (C) 2016 Freescale Semiconductor, Inc.
*/ #include <common.h> @@ -14,6 +15,7 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/hab.h> #include <linux/bitops.h> +#include <dm.h> #define PMC0_BASE_ADDR 0x410a1000 #define PMC0_CTRL 0x28 @@ -79,6 +81,20 @@ int arch_cpu_init(void) return 0; } +#if defined(CONFIG_ARCH_MISC_INIT) +int arch_misc_init(void) +{
- int ret;
- if (ret)
ret);
+} +#endif
i.MX8(QM/QXP) - updated device tree for supporting DM in SPL.
disabled use of JR1 in SPL and uboot, as JR1 is reserved for SECO FW.
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- arch/arm/dts/fsl-imx8dx.dtsi | 61 +++++++++++++++++++++++- arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi | 34 ++++++++++++- arch/arm/dts/fsl-imx8qm.dtsi | 61 +++++++++++++++++++++++- arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi | 34 ++++++++++++- 4 files changed, 186 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/fsl-imx8dx.dtsi b/arch/arm/dts/fsl-imx8dx.dtsi index 7d95cf0b7d..63a56699b5 100644 --- a/arch/arm/dts/fsl-imx8dx.dtsi +++ b/arch/arm/dts/fsl-imx8dx.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2018 NXP + * Copyright 2018, 2021 NXP */
#include <dt-bindings/interrupt-controller/arm-gic.h> @@ -261,6 +261,30 @@ power-domains = <&pd_dma>; }; }; + + pd_caam: PD_CAAM { + compatible = "nxp,imx8-pd"; + reg = <SC_R_NONE>; + #power-domain-cells = <0>; + #address-cells = <1>; + #size-cells = <0>; + + pd_caam_jr1: PD_CAAM_JR1 { + reg = <SC_R_CAAM_JR1>; + #power-domain-cells = <0>; + power-domains = <&pd_caam>; + }; + pd_caam_jr2: PD_CAAM_JR2 { + reg = <SC_R_CAAM_JR2>; + #power-domain-cells = <0>; + power-domains = <&pd_caam>; + }; + pd_caam_jr3: PD_CAAM_JR3 { + reg = <SC_R_CAAM_JR3>; + #power-domain-cells = <0>; + power-domains = <&pd_caam>; + }; + }; };
i2c0: i2c@5a800000 { @@ -609,6 +633,41 @@ }; }; }; + + crypto: caam@0x31400000 { + compatible = "fsl,sec-v4.0"; + reg = <0 0x31400000 0 0x400000>; + interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x31400000 0x400000>; + fsl,first-jr-index = <2>; + fsl,sec-era = <9>; + + sec_jr1: jr1@0x20000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x20000 0x1000>; + interrupts = <GIC_SPI 452 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&pd_caam_jr1>; + status = "disabled"; + }; + + sec_jr2: jr2@30000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x30000 0x1000>; + interrupts = <GIC_SPI 453 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&pd_caam_jr2>; + status = "okay"; + }; + + sec_jr3: jr3@40000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x40000 0x1000>; + interrupts = <GIC_SPI 454 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&pd_caam_jr3>; + status = "okay"; + }; + }; };
&A35_0 { diff --git a/arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi b/arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi index 9e0d264b71..a95209e141 100644 --- a/arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi +++ b/arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2018 NXP + * Copyright 2018, 2021 NXP */
&{/imx8qm-pm} { @@ -80,6 +80,22 @@ u-boot,dm-spl; };
+&pd_caam { + u-boot,dm-spl; +}; + +&pd_caam_jr1 { + u-boot,dm-spl; +}; + +&pd_caam_jr2 { + u-boot,dm-spl; +}; + +&pd_caam_jr3 { + u-boot,dm-spl; +}; + &gpio0 { u-boot,dm-spl; }; @@ -126,3 +142,19 @@ sd-uhs-sdr104; sd-uhs-ddr50; }; + +&crypto { + u-boot,dm-spl; +}; + +&sec_jr1 { + u-boot,dm-spl; +}; + +&sec_jr2 { + u-boot,dm-spl; +}; + +&sec_jr3 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/fsl-imx8qm.dtsi b/arch/arm/dts/fsl-imx8qm.dtsi index 88aeaf65b3..517fb13cad 100644 --- a/arch/arm/dts/fsl-imx8qm.dtsi +++ b/arch/arm/dts/fsl-imx8qm.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2018 NXP + * Copyright 2018, 2021 NXP */
#include <dt-bindings/interrupt-controller/arm-gic.h> @@ -235,6 +235,30 @@ wakeup-irq = <349>; }; }; + + pd_caam: PD_CAAM { + compatible = "nxp,imx8-pd"; + reg = <SC_R_NONE>; + #power-domain-cells = <0>; + #address-cells = <1>; + #size-cells = <0>; + + pd_caam_jr1: PD_CAAM_JR1 { + reg = <SC_R_CAAM_JR1>; + #power-domain-cells = <0>; + power-domains = <&pd_caam>; + }; + pd_caam_jr2: PD_CAAM_JR2 { + reg = <SC_R_CAAM_JR2>; + #power-domain-cells = <0>; + power-domains = <&pd_caam>; + }; + pd_caam_jr3: PD_CAAM_JR3 { + reg = <SC_R_CAAM_JR3>; + #power-domain-cells = <0>; + power-domains = <&pd_caam>; + }; + }; };
i2c0: i2c@5a800000 { @@ -556,6 +580,41 @@ power-domains = <&pd_conn_enet1>; status = "disabled"; }; + + crypto: caam@0x31400000 { + compatible = "fsl,sec-v4.0"; + reg = <0 0x31400000 0 0x400000>; + interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x31400000 0x400000>; + fsl,first-jr-index = <2>; + fsl,sec-era = <9>; + + sec_jr1: jr1@0x20000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x20000 0x1000>; + interrupts = <GIC_SPI 452 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&pd_caam_jr1>; + status = "disabled"; + }; + + sec_jr2: jr2@30000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x30000 0x1000>; + interrupts = <GIC_SPI 453 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&pd_caam_jr2>; + status = "okay"; + }; + + sec_jr3: jr3@40000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x40000 0x1000>; + interrupts = <GIC_SPI 454 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&pd_caam_jr3>; + status = "okay"; + }; + }; };
&A53_0 { diff --git a/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi b/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi index 701af4434d..ae037c7550 100644 --- a/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi +++ b/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2018 NXP + * Copyright 2018, 2021 NXP */
&{/imx8qx-pm} { @@ -80,6 +80,22 @@ u-boot,dm-spl; };
Best regards, Ye Li
diff --git a/arch/arm/dts/fsl-imx8dx.dtsi b/arch/arm/dts/fsl- imx8dx.dtsi index 7d95cf0b7d..63a56699b5 100644 --- a/arch/arm/dts/fsl-imx8dx.dtsi +++ b/arch/arm/dts/fsl-imx8dx.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /*
*/ #include <dt-bindings/interrupt-controller/arm-gic.h> @@ -261,6 +261,30 @@ power-domains = <&pd_dma>; }; };
pd_caam: PD_CAAM {
reg = <SC_R_NONE>;
#size-cells = <0>;
}; i2c0: i2c@5a800000 { @@ -609,6 +633,41 @@ }; }; };
- crypto: caam@0x31400000 {
#size-cells = <1>;
fsl,sec-era = <9>;
status = "okay";
status = "okay";
}; &A35_0 { diff --git a/arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi b/arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi index 9e0d264b71..a95209e141 100644 --- a/arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi +++ b/arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /*
*/ &{/imx8qm-pm} { @@ -80,6 +80,22 @@ u-boot,dm-spl; }; +&pd_caam {
- u-boot,dm-spl;
+&pd_caam_jr1 {
- u-boot,dm-spl;
+&pd_caam_jr2 {
- u-boot,dm-spl;
+&pd_caam_jr3 {
- u-boot,dm-spl;
+&crypto {
- u-boot,dm-spl;
+&sec_jr1 {
- u-boot,dm-spl;
+&sec_jr2 {
- u-boot,dm-spl;
+&sec_jr3 {
- u-boot,dm-spl;
+}; diff --git a/arch/arm/dts/fsl-imx8qm.dtsi b/arch/arm/dts/fsl- imx8qm.dtsi index 88aeaf65b3..517fb13cad 100644 --- a/arch/arm/dts/fsl-imx8qm.dtsi +++ b/arch/arm/dts/fsl-imx8qm.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /*
*/ #include <dt-bindings/interrupt-controller/arm-gic.h> @@ -235,6 +235,30 @@ wakeup-irq = <349>; }; };
pd_caam: PD_CAAM {
reg = <SC_R_NONE>;
#size-cells = <0>;
}; i2c0: i2c@5a800000 { @@ -556,6 +580,41 @@ power-domains = <&pd_conn_enet1>; status = "disabled"; };
#size-cells = <1>;
fsl,sec-era = <9>;
status = "okay";
status = "okay";
}; &A53_0 { diff --git a/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi b/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi index 701af4434d..ae037c7550 100644 --- a/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi +++ b/arch/arm/dts/fsl-imx8qxp-mek-u-boot.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /*
*/ &{/imx8qx-pm} { @@ -80,6 +80,22 @@ u-boot,dm-spl; }; +&pd_caam {
- u-boot,dm-spl;
+&pd_caam_jr1 {
- u-boot,dm-spl;
+&pd_caam_jr2 {
- u-boot,dm-spl;
+&pd_caam_jr3 {
- u-boot,dm-spl;
+&crypto {
- u-boot,dm-spl;
+&sec_jr1 {
- u-boot,dm-spl;
+&sec_jr2 {
- u-boot,dm-spl;
+&sec_jr3 {
- u-boot,dm-spl;
i.MX8(QM/QXP) - added support for JR driver model. sec is initialized based on job ring information processed from device tree.
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com Signed-off-by: Horia Geantă horia.geanta@nxp.com --- arch/arm/Kconfig | 3 +++ arch/arm/include/asm/arch-imx8/imx-regs.h | 5 ++++- arch/arm/mach-imx/cmd_dek.c | 1 + arch/arm/mach-imx/imx8/Kconfig | 9 +++++++++ arch/arm/mach-imx/imx8/cpu.c | 16 ++++++++++++++- board/freescale/imx8qm_mek/spl.c | 6 ++++-- board/freescale/imx8qxp_mek/spl.c | 6 ++++-- drivers/crypto/fsl/Kconfig | 2 +- drivers/crypto/fsl/jr.c | 24 +++++++++++++++++++++++ include/fsl_sec.h | 12 +++++------- 10 files changed, 70 insertions(+), 14 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index b3d11c1a0d..982b285e39 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -785,6 +785,9 @@ config ARCH_LPC32XX config ARCH_IMX8 bool "NXP i.MX8 platform" select ARM64 + select SYS_FSL_HAS_SEC + select SYS_FSL_SEC_COMPAT_4 + select SYS_FSL_SEC_LE select DM select GPIO_EXTRA_HEADER select OF_CONTROL diff --git a/arch/arm/include/asm/arch-imx8/imx-regs.h b/arch/arm/include/asm/arch-imx8/imx-regs.h index ed6e05e556..2d64b0604b 100644 --- a/arch/arm/include/asm/arch-imx8/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8/imx-regs.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2018 NXP + * Copyright 2018, 2021 NXP */
#ifndef __ASM_ARCH_IMX8_REGS_H__ @@ -47,4 +47,7 @@ #define USB_BASE_ADDR 0x5b0d0000 #define USB_PHY0_BASE_ADDR 0x5b100000
+#define CONFIG_SYS_FSL_SEC_ADDR (0x31400000) +#define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1 + #endif /* __ASM_ARCH_IMX8_REGS_H__ */ diff --git a/arch/arm/mach-imx/cmd_dek.c b/arch/arm/mach-imx/cmd_dek.c index 89da89c51d..04c4b20a84 100644 --- a/arch/arm/mach-imx/cmd_dek.c +++ b/arch/arm/mach-imx/cmd_dek.c @@ -9,6 +9,7 @@ #include <command.h> #include <log.h> #include <malloc.h> +#include <memalign.h> #include <asm/byteorder.h> #include <linux/compiler.h> #include <fsl_sec.h> diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index b43739e5c6..9a20ebe84e 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -8,6 +8,7 @@ config AHAB_BOOT
config IMX8 bool + select HAS_CAAM
config MU_BASE_SPL hex "MU base address used in SPL" @@ -72,6 +73,10 @@ config TARGET_IMX8QM_MEK bool "Support i.MX8QM MEK board" select BOARD_LATE_INIT select IMX8QM + select FSL_CAAM + select FSL_BLOB + select ARCH_MISC_INIT + select SPL_CRYPTO if SPL
config TARGET_CONGA_QMX8 bool "Support congatec conga-QMX8 board" @@ -89,6 +94,10 @@ config TARGET_IMX8QXP_MEK bool "Support i.MX8QXP MEK board" select BOARD_LATE_INIT select IMX8QXP + select FSL_CAAM + select FSL_BLOB + select ARCH_MISC_INIT + select SPL_CRYPTO if SPL
endchoice
diff --git a/arch/arm/mach-imx/imx8/cpu.c b/arch/arm/mach-imx/imx8/cpu.c index 02db322f51..86ced79bb7 100644 --- a/arch/arm/mach-imx/imx8/cpu.c +++ b/arch/arm/mach-imx/imx8/cpu.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2018 NXP + * Copyright 2018, 2021 NXP */
#include <common.h> @@ -89,6 +89,20 @@ int arch_cpu_init_dm(void) return 0; }
+#if defined(CONFIG_ARCH_MISC_INIT) +int arch_misc_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); + if (ret) + printf("Failed to initialize %s: %d\n", dev->name, ret); + + return 0; +} +#endif + int print_bootinfo(void) { enum boot_device bt_dev = get_boot_device(); diff --git a/board/freescale/imx8qm_mek/spl.c b/board/freescale/imx8qm_mek/spl.c index 944ba745c0..332a662dee 100644 --- a/board/freescale/imx8qm_mek/spl.c +++ b/board/freescale/imx8qm_mek/spl.c @@ -1,7 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0-or-later /* - * Copyright 2018 NXP + * Copyright 2018, 2021 NXP * - * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> @@ -24,6 +24,8 @@ void spl_board_init(void) { struct udevice *dev;
+ uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(imx8_scu), &dev); + uclass_find_first_device(UCLASS_MISC, &dev);
for (; dev; uclass_find_next_device(&dev)) { diff --git a/board/freescale/imx8qxp_mek/spl.c b/board/freescale/imx8qxp_mek/spl.c index ae6b64ff6e..2fa6840056 100644 --- a/board/freescale/imx8qxp_mek/spl.c +++ b/board/freescale/imx8qxp_mek/spl.c @@ -1,7 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0-or-later /* - * Copyright 2018 NXP + * Copyright 2018, 2021 NXP * - * SPDX-License-Identifier: GPL-2.0+ */
#include <common.h> @@ -39,6 +39,8 @@ void spl_board_init(void) { struct udevice *dev;
for (; dev; uclass_find_next_device(&dev)) { diff --git a/drivers/crypto/fsl/Kconfig b/drivers/crypto/fsl/Kconfig index 6d6c3f8d39..f550ab0e0a 100644 --- a/drivers/crypto/fsl/Kconfig +++ b/drivers/crypto/fsl/Kconfig @@ -9,7 +9,7 @@ config FSL_CAAM
config CAAM_64BIT bool - default y if PHYS_64BIT && !ARCH_IMX8M + default y if PHYS_64BIT && !ARCH_IMX8M && !ARCH_IMX8 help Select Crypto driver for 64 bits CAAM version
diff --git a/drivers/crypto/fsl/jr.c b/drivers/crypto/fsl/jr.c index 1b027f253c..ef133b670a 100644 --- a/drivers/crypto/fsl/jr.c +++ b/drivers/crypto/fsl/jr.c @@ -25,6 +25,7 @@ #include <linux/delay.h> #include <dm/root.h> #include <dm/device-internal.h> +#include <power-domain.h>
#define CIRC_CNT(head, tail, size) (((head) - (tail)) & (size - 1)) #define CIRC_SPACE(head, tail, size) CIRC_CNT((tail), (head) + 1, (size)) @@ -786,6 +787,25 @@ int sec_init(void) return sec_init_idx(0); }
+#ifdef CONFIG_ARCH_IMX8 +static int jr_power_on(int subnode) +{ +#if CONFIG_IS_ENABLED(POWER_DOMAIN) + struct udevice __maybe_unused jr_dev; + struct power_domain pd; + + dev_set_ofnode(&jr_dev, offset_to_ofnode(subnode)); + + /* Need to power on Job Ring before access it */ + if (!power_domain_get(&jr_dev, &pd)) { + if (power_domain_on(&pd)) + return -EINVAL; + } +#endif + return 0; +} +#endif + #if CONFIG_IS_ENABLED(DM) static int caam_jr_probe(struct udevice *dev) { @@ -818,6 +838,10 @@ static int caam_jr_probe(struct udevice *dev) jr_node = jr_node >> 4; } caam->jrid = jr_node - 1; +#ifdef CONFIG_ARCH_IMX8 + if (jr_power_on(subnode)) + return -EINVAL; +#endif break; } } diff --git a/include/fsl_sec.h b/include/fsl_sec.h index c4121696f8..7b6e3e2c20 100644 --- a/include/fsl_sec.h +++ b/include/fsl_sec.h @@ -3,7 +3,7 @@ * Common internal memory map for some Freescale SoCs * * Copyright 2014 Freescale Semiconductor, Inc. - * Copyright 2018 NXP + * Copyright 2018, 2021 NXP */
#ifndef __FSL_SEC_H @@ -194,12 +194,10 @@ typedef struct ccsr_sec { #define SEC_CHAVID_LS_RNG_SHIFT 16 #define SEC_CHAVID_RNG_LS_MASK 0x000f0000
-#define CONFIG_JRSTARTR_JR0 0x00000001 - struct jr_regs { #if defined(CONFIG_SYS_FSL_SEC_LE) && \ !(defined(CONFIG_MX6) || defined(CONFIG_MX7) || \ - defined(CONFIG_MX7ULP) || defined(CONFIG_IMX8M)) + defined(CONFIG_MX7ULP) || defined(CONFIG_IMX8M) || defined(CONFIG_IMX8)) u32 irba_l; u32 irba_h; #else @@ -214,7 +212,7 @@ struct jr_regs { u32 irja; #if defined(CONFIG_SYS_FSL_SEC_LE) && \ !(defined(CONFIG_MX6) || defined(CONFIG_MX7) || \ - defined(CONFIG_MX7ULP) || defined(CONFIG_IMX8M)) + defined(CONFIG_MX7ULP) || defined(CONFIG_IMX8M) || defined(CONFIG_IMX8)) u32 orba_l; u32 orba_h; #else @@ -248,7 +246,7 @@ struct jr_regs { struct sg_entry { #if defined(CONFIG_SYS_FSL_SEC_LE) && \ !(defined(CONFIG_MX6) || defined(CONFIG_MX7) || \ - defined(CONFIG_MX7ULP) || defined(CONFIG_IMX8M)) + defined(CONFIG_MX7ULP) || defined(CONFIG_IMX8M) || defined(CONFIG_IMX8)) uint32_t addr_lo; /* Memory Address - lo */ uint32_t addr_hi; /* Memory Address of start of buffer - hi */ #else @@ -268,7 +266,7 @@ struct sg_entry { };
#if defined(CONFIG_MX6) || defined(CONFIG_MX7) || \ - defined(CONFIG_MX7ULP) || defined(CONFIG_IMX8M) + defined(CONFIG_MX7ULP) || defined(CONFIG_IMX8M) || defined(CONFIG_IMX8) /* Job Ring Base Address */ #define JR_BASE_ADDR(x) (CONFIG_SYS_FSL_SEC_ADDR + 0x1000 * (x + 1)) /* Secure Memory Offset varies accross versions */
Best regards, Ye Li
- select SYS_FSL_SEC_COMPAT_4
- select SYS_FSL_SEC_LE
- Copyright 2018 NXP
- Copyright 2018, 2021 NXP
*/ #ifndef __ASM_ARCH_IMX8_REGS_H__ @@ -47,4 +47,7 @@ #define USB_BASE_ADDR 0x5b0d0000 #define USB_PHY0_BASE_ADDR 0x5b100000 +#define CONFIG_SYS_FSL_SEC_ADDR (0x31400000) +#define CONFIG_SYS_FSL_MAX_NUM_OF_SEC 1
#endif /* __ASM_ARCH_IMX8_REGS_H__ */ diff --git a/arch/arm/mach-imx/cmd_dek.c b/arch/arm/mach- imx/cmd_dek.c index 89da89c51d..04c4b20a84 100644 --- a/arch/arm/mach-imx/cmd_dek.c +++ b/arch/arm/mach-imx/cmd_dek.c @@ -9,6 +9,7 @@ #include <command.h> #include <log.h> #include <malloc.h> +#include <memalign.h> #include <asm/byteorder.h> #include <linux/compiler.h> #include <fsl_sec.h> diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach- imx/imx8/Kconfig index b43739e5c6..9a20ebe84e 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -8,6 +8,7 @@ config AHAB_BOOT config IMX8 bool
- select HAS_CAAM
- select FSL_CAAM
- select FSL_BLOB
- select FSL_CAAM
- select FSL_BLOB
endchoice diff --git a/arch/arm/mach-imx/imx8/cpu.c b/arch/arm/mach- imx/imx8/cpu.c index 02db322f51..86ced79bb7 100644 --- a/arch/arm/mach-imx/imx8/cpu.c +++ b/arch/arm/mach-imx/imx8/cpu.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /*
*/ #include <common.h> @@ -89,6 +89,20 @@ int arch_cpu_init_dm(void) return 0; } +#if defined(CONFIG_ARCH_MISC_INIT) +int arch_misc_init(void) +{
- int ret;
- if (ret)
ret);
+} +#endif
*/ #include <common.h> @@ -24,6 +24,8 @@ void spl_board_init(void) { struct udevice *dev;
- uclass_get_device_by_driver(UCLASS_MISC,
uclass_find_first_device(UCLASS_MISC, &dev); for (; dev; uclass_find_next_device(&dev)) { diff --git a/board/freescale/imx8qxp_mek/spl.c b/board/freescale/imx8qxp_mek/spl.c index ae6b64ff6e..2fa6840056 100644 --- a/board/freescale/imx8qxp_mek/spl.c +++ b/board/freescale/imx8qxp_mek/spl.c @@ -1,7 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0-or-later /*
*/ #include <common.h> @@ -39,6 +39,8 @@ void spl_board_init(void) { struct udevice *dev;
uclass_find_first_device(UCLASS_MISC, &dev); for (; dev; uclass_find_next_device(&dev)) { diff --git a/drivers/crypto/fsl/Kconfig b/drivers/crypto/fsl/Kconfig index 6d6c3f8d39..f550ab0e0a 100644 --- a/drivers/crypto/fsl/Kconfig +++ b/drivers/crypto/fsl/Kconfig @@ -9,7 +9,7 @@ config FSL_CAAM config CAAM_64BIT bool
- default y if PHYS_64BIT && !ARCH_IMX8M && !ARCH_IMX8
help Select Crypto driver for 64 bits CAAM version diff --git a/drivers/crypto/fsl/jr.c b/drivers/crypto/fsl/jr.c index 1b027f253c..ef133b670a 100644 --- a/drivers/crypto/fsl/jr.c +++ b/drivers/crypto/fsl/jr.c @@ -25,6 +25,7 @@ #include <linux/delay.h> #include <dm/root.h> #include <dm/device-internal.h> +#include <power-domain.h> #define CIRC_CNT(head, tail, size) (((head) - (tail)) & (size
- 1))
- 1, (size))
@@ -786,6 +787,25 @@ int sec_init(void) return sec_init_idx(0); } +#ifdef CONFIG_ARCH_IMX8 +static int jr_power_on(int subnode) +{ +#if CONFIG_IS_ENABLED(POWER_DOMAIN)
- struct udevice __maybe_unused jr_dev;
- struct power_domain pd;
- dev_set_ofnode(&jr_dev, offset_to_ofnode(subnode));
- /* Need to power on Job Ring before access it */
- if (!power_domain_get(&jr_dev, &pd)) {
return -EINVAL;
+} +#endif
return -EINVAL;
*/ #ifndef __FSL_SEC_H @@ -194,12 +194,10 @@ typedef struct ccsr_sec { #define SEC_CHAVID_LS_RNG_SHIFT 16 #define SEC_CHAVID_RNG_LS_MASK 0x000f0000 -#define CONFIG_JRSTARTR_JR0 0x00000001
- defined(CONFIG_MX7ULP) || defined(CONFIG_IMX8M) ||
defined(CONFIG_IMX8)) uint32_t addr_lo; /* Memory Address - lo */ uint32_t addr_hi; /* Memory Address of start of buffer - hi */ #else @@ -268,7 +266,7 @@ struct sg_entry { }; #if defined(CONFIG_MX6) || defined(CONFIG_MX7) || \
fix hwrng performance issue in kernel.
Signed-off-by: Ye Li ye.li@nxp.com Acked-by: Gaurav Jain gaurav.jain@nxp.com> --- drivers/crypto/fsl/jr.c | 109 ++++++++++++++++++++++++++++++++++------ include/fsl_sec.h | 1 + 2 files changed, 94 insertions(+), 16 deletions(-)
diff --git a/drivers/crypto/fsl/jr.c b/drivers/crypto/fsl/jr.c index ef133b670a..5e11eb71f7 100644 --- a/drivers/crypto/fsl/jr.c +++ b/drivers/crypto/fsl/jr.c @@ -602,30 +602,107 @@ static u8 get_rng_vid(ccsr_sec_t *sec) */ static void kick_trng(int ent_delay, ccsr_sec_t *sec) { + u32 samples = 512; /* number of bits to generate and test */ + u32 mono_min = 195; + u32 mono_max = 317; + u32 mono_range = mono_max - mono_min; + u32 poker_min = 1031; + u32 poker_max = 1600; + u32 poker_range = poker_max - poker_min + 1; + u32 retries = 2; + u32 lrun_max = 32; + s32 run_1_min = 27; + s32 run_1_max = 107; + s32 run_1_range = run_1_max - run_1_min; + s32 run_2_min = 7; + s32 run_2_max = 62; + s32 run_2_range = run_2_max - run_2_min; + s32 run_3_min = 0; + s32 run_3_max = 39; + s32 run_3_range = run_3_max - run_3_min; + s32 run_4_min = -1; + s32 run_4_max = 26; + s32 run_4_range = run_4_max - run_4_min; + s32 run_5_min = -1; + s32 run_5_max = 18; + s32 run_5_range = run_5_max - run_5_min; + s32 run_6_min = -1; + s32 run_6_max = 17; + s32 run_6_range = run_6_max - run_6_min; + u32 val; + struct rng4tst __iomem *rng = (struct rng4tst __iomem *)&sec->rng; - u32 val;
- /* put RNG4 into program mode */ - sec_setbits32(&rng->rtmctl, RTMCTL_PRGM); - /* rtsdctl bits 0-15 contain "Entropy Delay, which defines the - * length (in system clocks) of each Entropy sample taken - * */ + /* Put RNG in program mode */ + /* Setting both RTMCTL:PRGM and RTMCTL:TRNG_ACC causes TRNG to + * properly invalidate the entropy in the entropy register and + * force re-generation. + */ + sec_setbits32(&rng->rtmctl, RTMCTL_PRGM | RTMCTL_ACC); + + /* Configure the RNG Entropy Delay + * Performance-wise, it does not make sense to + * set the delay to a value that is lower + * than the last one that worked (i.e. the state handles + * were instantiated properly. Thus, instead of wasting + * time trying to set the values controlling the sample + * frequency, the function simply returns. + */ val = sec_in32(&rng->rtsdctl); - val = (val & ~RTSDCTL_ENT_DLY_MASK) | - (ent_delay << RTSDCTL_ENT_DLY_SHIFT); + val &= RTSDCTL_ENT_DLY_MASK; + val >>= RTSDCTL_ENT_DLY_SHIFT; + if (ent_delay < val) { + /* Put RNG4 into run mode */ + sec_clrbits32(&rng->rtmctl, RTMCTL_PRGM | RTMCTL_ACC); + return; + } + + val = (ent_delay << RTSDCTL_ENT_DLY_SHIFT) | samples; sec_out32(&rng->rtsdctl, val); - /* min. freq. count, equal to 1/4 of the entropy sample length */ - sec_out32(&rng->rtfreqmin, ent_delay >> 2); - /* disable maximum frequency count */ - sec_out32(&rng->rtfreqmax, RTFRQMAX_DISABLE); + /* - * select raw sampling in both entropy shifter + * Recommended margins (min,max) for freq. count: + * freq_mul = RO_freq / TRNG_clk_freq + * rtfrqmin = (ent_delay x freq_mul) >> 1; + * rtfrqmax = (ent_delay x freq_mul) << 3; + * Given current deployments of CAAM in i.MX SoCs, and to simplify + * the configuration, we consider [1,16] to be a safe interval + * for the freq_mul and the limits of the interval are used to compute + * rtfrqmin, rtfrqmax + */ + sec_out32(&rng->rtfreqmin, ent_delay >> 1); + sec_out32(&rng->rtfreqmax, ent_delay << 7); + + sec_out32(&rng->rtscmisc, (retries << 16) | lrun_max); + sec_out32(&rng->rtpkrmax, poker_max); + sec_out32(&rng->rtpkrrng, poker_range); + sec_out32(&rng->rsvd1[0], (mono_range << 16) | mono_max); + sec_out32(&rng->rsvd1[1], (run_1_range << 16) | run_1_max); + sec_out32(&rng->rsvd1[2], (run_2_range << 16) | run_2_max); + sec_out32(&rng->rsvd1[3], (run_3_range << 16) | run_3_max); + sec_out32(&rng->rsvd1[4], (run_4_range << 16) | run_4_max); + sec_out32(&rng->rsvd1[5], (run_5_range << 16) | run_5_max); + sec_out32(&rng->rsvd1[6], (run_6_range << 16) | run_6_max); + + val = sec_in32(&rng->rtmctl); + /* + * Select raw sampling in both entropy shifter * and statistical checker */ - sec_setbits32(&rng->rtmctl, RTMCTL_SAMP_MODE_RAW_ES_SC); - /* put RNG4 into run mode */ - sec_clrbits32(&rng->rtmctl, RTMCTL_PRGM); + val &= ~RTMCTL_SAMP_MODE_INVALID; + val |= RTMCTL_SAMP_MODE_RAW_ES_SC; + /* Put RNG4 into run mode */ + val &= ~(RTMCTL_PRGM | RTMCTL_ACC); + /*test with sample mode only */ + sec_out32(&rng->rtmctl, val); + + /* Clear the ERR bit in RTMCTL if set. The TRNG error can occur when the + * RNG clock is not within 1/2x to 8x the system clock. + * This error is possible if ROM code does not initialize the system PLLs + * immediately after PoR. + */ + /* setbits_le32(CAAM_RTMCTL, RTMCTL_ERR); */ }
static int rng_init(uint8_t sec_idx, ccsr_sec_t *sec) diff --git a/include/fsl_sec.h b/include/fsl_sec.h index 7b6e3e2c20..2b3239414a 100644 --- a/include/fsl_sec.h +++ b/include/fsl_sec.h @@ -34,6 +34,7 @@ #if CONFIG_SYS_FSL_SEC_COMPAT >= 4 /* RNG4 TRNG test registers */ struct rng4tst { +#define RTMCTL_ACC 0x20 #define RTMCTL_PRGM 0x00010000 /* 1 -> program mode, 0 -> run mode */ #define RTMCTL_SAMP_MODE_VON_NEUMANN_ES_SC 0 /* use von Neumann data in both entropy shifter and
LS(1021/1012/1028/1043/1046/1088/2088), LX2160 - updated device tree
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- arch/arm/dts/fsl-ls1012a.dtsi | 46 ++++++++++++++++++++++++++++++++++- arch/arm/dts/fsl-ls1028a.dtsi | 41 ++++++++++++++++++++++++++++++- arch/arm/dts/fsl-ls1043a.dtsi | 45 +++++++++++++++++++++++++++++++++- arch/arm/dts/fsl-ls1046a.dtsi | 44 +++++++++++++++++++++++++++++++++ arch/arm/dts/fsl-ls1088a.dtsi | 39 +++++++++++++++++++++++++++++ arch/arm/dts/fsl-ls2080a.dtsi | 39 +++++++++++++++++++++++++++++ arch/arm/dts/fsl-lx2160a.dtsi | 41 ++++++++++++++++++++++++++++++- arch/arm/dts/ls1021a.dtsi | 40 ++++++++++++++++++++++++++++++ 8 files changed, 331 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/fsl-ls1012a.dtsi b/arch/arm/dts/fsl-ls1012a.dtsi index 2894842cf2..20ef111d27 100644 --- a/arch/arm/dts/fsl-ls1012a.dtsi +++ b/arch/arm/dts/fsl-ls1012a.dtsi @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ OR X11 /* - * Copyright 2020 NXP + * Copyright 2020-2021 NXP * Copyright 2016 Freescale Semiconductor */
@@ -71,6 +71,50 @@ bus-width = <4>; };
+ crypto: crypto@1700000 { + compatible = "fsl,sec-v5.4", "fsl,sec-v5.0", + "fsl,sec-v4.0"; + fsl,sec-era = <8>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x00 0x1700000 0x100000>; + reg = <0x00 0x1700000 0x0 0x100000>; + interrupts = <0 75 0x4>; + dma-coherent; + + sec_jr0: jr@10000 { + compatible = "fsl,sec-v5.4-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x10000 0x10000>; + interrupts = <0 71 0x4>; + }; + + sec_jr1: jr@20000 { + compatible = "fsl,sec-v5.4-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x20000 0x10000>; + interrupts = <0 72 0x4>; + }; + + sec_jr2: jr@30000 { + compatible = "fsl,sec-v5.4-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x30000 0x10000>; + interrupts = <0 73 0x4>; + }; + + sec_jr3: jr@40000 { + compatible = "fsl,sec-v5.4-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x40000 0x10000>; + interrupts = <0 74 0x4>; + }; + }; + gpio0: gpio@2300000 { compatible = "fsl,qoriq-gpio"; reg = <0x0 0x2300000 0x0 0x10000>; diff --git a/arch/arm/dts/fsl-ls1028a.dtsi b/arch/arm/dts/fsl-ls1028a.dtsi index 50f9b527cd..c2a156ea8e 100644 --- a/arch/arm/dts/fsl-ls1028a.dtsi +++ b/arch/arm/dts/fsl-ls1028a.dtsi @@ -2,7 +2,7 @@ /* * NXP ls1028a SOC common device tree source * - * Copyright 2019-2020 NXP + * Copyright 2019-2021 NXP * */
@@ -123,6 +123,45 @@ 0x82000000 0x0 0x40000000 0x88 0x40000000 0x0 0x40000000>; /* non-prefetchable memory */ };
+ crypto: crypto@8000000 { + compatible = "fsl,sec-v5.0", "fsl,sec-v4.0"; + fsl,sec-era = <10>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x00 0x8000000 0x100000>; + reg = <0x00 0x8000000 0x0 0x100000>; + interrupts = <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>; + dma-coherent; + + sec_jr0: jr@10000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x10000 0x10000>; + interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr1: jr@20000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x20000 0x10000>; + interrupts = <GIC_SPI 141 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr2: jr@30000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x30000 0x10000>; + interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr3: jr@40000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x40000 0x10000>; + interrupts = <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + pcie@1f0000000 { compatible = "pci-host-ecam-generic"; /* ECAM bus 0, HW has more space reserved but not populated */ diff --git a/arch/arm/dts/fsl-ls1043a.dtsi b/arch/arm/dts/fsl-ls1043a.dtsi index d8171bd03b..51d556e43d 100644 --- a/arch/arm/dts/fsl-ls1043a.dtsi +++ b/arch/arm/dts/fsl-ls1043a.dtsi @@ -2,7 +2,7 @@ /* * Device Tree Include file for NXP Layerscape-1043A family SoC. * - * Copyright 2020 NXP + * Copyright 2020-2021 NXP * Copyright (C) 2014-2015, Freescale Semiconductor * * Mingkai Hu Mingkai.hu@freescale.com @@ -125,6 +125,49 @@ interrupts = <0 43 0x4>; };
+ crypto: crypto@1700000 { + compatible = "fsl,sec-v5.4", "fsl,sec-v5.0", + "fsl,sec-v4.0"; + fsl,sec-era = <3>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x00 0x1700000 0x100000>; + reg = <0x00 0x1700000 0x0 0x100000>; + interrupts = <0 75 0x4>; + + sec_jr0: jr@10000 { + compatible = "fsl,sec-v5.4-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x10000 0x10000>; + interrupts = <0 71 0x4>; + }; + + sec_jr1: jr@20000 { + compatible = "fsl,sec-v5.4-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x20000 0x10000>; + interrupts = <0 72 0x4>; + }; + + sec_jr2: jr@30000 { + compatible = "fsl,sec-v5.4-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x30000 0x10000>; + interrupts = <0 73 0x4>; + }; + + sec_jr3: jr@40000 { + compatible = "fsl,sec-v5.4-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x40000 0x10000>; + interrupts = <0 74 0x4>; + }; + }; + i2c0: i2c@2180000 { compatible = "fsl,vf610-i2c"; #address-cells = <1>; diff --git a/arch/arm/dts/fsl-ls1046a.dtsi b/arch/arm/dts/fsl-ls1046a.dtsi index 9df419a87d..c07fc1441c 100644 --- a/arch/arm/dts/fsl-ls1046a.dtsi +++ b/arch/arm/dts/fsl-ls1046a.dtsi @@ -3,6 +3,7 @@ * Device Tree Include file for Freescale Layerscape-1046A family SoC. * * Copyright (C) 2016, Freescale Semiconductor + * Copyright 2021 NXP * * Mingkai Hu mingkai.hu@nxp.com */ @@ -124,6 +125,49 @@ interrupts = <0 43 0x4>; };
+ crypto: crypto@1700000 { + compatible = "fsl,sec-v5.4", "fsl,sec-v5.0", + "fsl,sec-v4.0"; + fsl,sec-era = <8>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x00 0x1700000 0x100000>; + reg = <0x00 0x1700000 0x0 0x100000>; + interrupts = <0 75 0x4>; + + sec_jr0: jr@10000 { + compatible = "fsl,sec-v5.4-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x10000 0x10000>; + interrupts = <0 71 0x4>; + }; + + sec_jr1: jr@20000 { + compatible = "fsl,sec-v5.4-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x20000 0x10000>; + interrupts = <0 72 0x4>; + }; + + sec_jr2: jr@30000 { + compatible = "fsl,sec-v5.4-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x30000 0x10000>; + interrupts = <0 73 0x4>; + }; + + sec_jr3: jr@40000 { + compatible = "fsl,sec-v5.4-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x40000 0x10000>; + interrupts = <0 74 0x4>; + }; + }; + i2c0: i2c@2180000 { compatible = "fsl,vf610-i2c"; #address-cells = <1>; diff --git a/arch/arm/dts/fsl-ls1088a.dtsi b/arch/arm/dts/fsl-ls1088a.dtsi index 64caa600ad..5c2d7eeac2 100644 --- a/arch/arm/dts/fsl-ls1088a.dtsi +++ b/arch/arm/dts/fsl-ls1088a.dtsi @@ -180,6 +180,45 @@ dr_mode = "host"; };
+ crypto: crypto@8000000 { + compatible = "fsl,sec-v5.0", "fsl,sec-v4.0"; + fsl,sec-era = <8>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x00 0x8000000 0x100000>; + reg = <0x00 0x8000000 0x0 0x100000>; + interrupts = <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>; + dma-coherent; + + sec_jr0: jr@10000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x10000 0x10000>; + interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr1: jr@20000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x20000 0x10000>; + interrupts = <GIC_SPI 141 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr2: jr@30000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x30000 0x10000>; + interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr3: jr@40000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x40000 0x10000>; + interrupts = <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + pcie1: pcie@3400000 { compatible = "fsl,ls-pcie", "snps,dw-pcie"; reg = <0x00 0x03400000 0x0 0x80000 /* dbi registers */ diff --git a/arch/arm/dts/fsl-ls2080a.dtsi b/arch/arm/dts/fsl-ls2080a.dtsi index 7374d580e0..aa739279a8 100644 --- a/arch/arm/dts/fsl-ls2080a.dtsi +++ b/arch/arm/dts/fsl-ls2080a.dtsi @@ -245,6 +245,45 @@ status = "disabled"; };
+ crypto: crypto@8000000 { + compatible = "fsl,sec-v5.0", "fsl,sec-v4.0"; + fsl,sec-era = <8>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x00 0x8000000 0x100000>; + reg = <0x00 0x8000000 0x0 0x100000>; + interrupts = <0 139 0x4>; /* Level high type */ + dma-coherent; + + sec_jr0: jr@10000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x10000 0x10000>; + interrupts = <0 140 0x4>; /* Level high type */ + }; + + sec_jr1: jr@20000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x20000 0x10000>; + interrupts = <0 141 0x4>; /* Level high type */ + }; + + sec_jr2: jr@30000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x30000 0x10000>; + interrupts = <0 142 0x4>; /* Level high type */ + }; + + sec_jr3: jr@40000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x40000 0x10000>; + interrupts = <0 143 0x4>; /* Level high type */ + }; + }; + fsl_mc: fsl-mc@80c000000 { compatible = "fsl,qoriq-mc", "simple-mfd"; reg = <0x00000008 0x0c000000 0 0x40>, /* MC portal base */ diff --git a/arch/arm/dts/fsl-lx2160a.dtsi b/arch/arm/dts/fsl-lx2160a.dtsi index a6f0e9bc56..4c1f06702e 100644 --- a/arch/arm/dts/fsl-lx2160a.dtsi +++ b/arch/arm/dts/fsl-lx2160a.dtsi @@ -2,7 +2,7 @@ /* * NXP lx2160a SOC common device tree source * - * Copyright 2018-2020 NXP + * Copyright 2018-2021 NXP * */
@@ -27,6 +27,45 @@ clock-output-names = "sysclk"; };
+ crypto: crypto@8000000 { + compatible = "fsl,sec-v5.0", "fsl,sec-v4.0"; + fsl,sec-era = <10>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x00 0x8000000 0x100000>; + reg = <0x00 0x8000000 0x0 0x100000>; + interrupts = <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>; + dma-coherent; + + sec_jr0: jr@10000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x10000 0x10000>; + interrupts = <GIC_SPI 140 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr1: jr@20000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x20000 0x10000>; + interrupts = <GIC_SPI 141 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr2: jr@30000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x30000 0x10000>; + interrupts = <GIC_SPI 142 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr3: jr@40000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x40000 0x10000>; + interrupts = <GIC_SPI 143 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + clockgen: clocking@1300000 { compatible = "fsl,ls2080a-clockgen"; reg = <0 0x1300000 0 0xa0000>; diff --git a/arch/arm/dts/ls1021a.dtsi b/arch/arm/dts/ls1021a.dtsi index 7ba2dd2269..d068f266b2 100644 --- a/arch/arm/dts/ls1021a.dtsi +++ b/arch/arm/dts/ls1021a.dtsi @@ -3,6 +3,7 @@ * Freescale ls1021a SOC common device tree source * * Copyright 2013-2015 Freescale Semiconductor, Inc. + * Copyright 2021 NXP */
#include "skeleton.dtsi" @@ -144,6 +145,45 @@ big-endian; };
+ crypto: crypto@1700000 { + compatible = "fsl,sec-v5.0", "fsl,sec-v4.0"; + fsl,sec-era = <7>; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x1700000 0x100000>; + ranges = <0x0 0x1700000 0x100000>; + interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; + + sec_jr0: jr@10000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x10000 0x10000>; + interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr1: jr@20000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x20000 0x10000>; + interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr2: jr@30000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x30000 0x10000>; + interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr3: jr@40000 { + compatible = "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x40000 0x10000>; + interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; + }; + + }; + clockgen: clocking@1ee1000 { #address-cells = <1>; #size-cells = <1>;
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Gaurav Jain Sent: Friday, September 3, 2021 12:33 PM To: u-boot@lists.denx.de Cc: Stefano Babic sbabic@denx.de; Fabio Estevam festevam@gmail.com; Peng Fan peng.fan@nxp.com; Simon Glass sjg@chromium.org; Priyanka Jain priyanka.jain@nxp.com; Ye Li ye.li@nxp.com; Horia Geanta horia.geanta@nxp.com; Ji Luo ji.luo@nxp.com; Franck Lenormand franck.lenormand@nxp.com; Silvano Di Ninno silvano.dininno@nxp.com; Sahil Malhotra sahil.malhotra@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; dl-uboot-imx uboot-imx@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com; Wasim Khan wasim.khan@nxp.com; Alison Wang alison.wang@nxp.com; Pramod Kumar pramod.kumar_1@nxp.com; Andy Tang andy.tang@nxp.com; Adrian Alonso adrian.alonso@nxp.com; Vladimir Oltean olteanv@gmail.com; Gaurav Jain gaurav.jain@nxp.com Subject: [PATCH v2 11/15] Layerscape: Add crypto node in device tree
Reviewed-by: Priyanka Jain priyanka.jain@nxp.com
LS(1021/1012/1028/1043/1046/1088/2088), LX2160, LX2162 platforms are enabled with JR driver model.
removed sec_init() call from board files. removed CONFIG_FSL_CAAM from defconfig files. sec is initialized based on job ring information processed from device tree.
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- arch/arm/cpu/armv7/ls102xa/Kconfig | 4 +++ arch/arm/cpu/armv7/ls102xa/cpu.c | 16 +++++++++++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 27 +++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 10 ++++++- board/freescale/ls1012afrdm/ls1012afrdm.c | 7 +---- board/freescale/ls1012aqds/ls1012aqds.c | 6 +---- board/freescale/ls1012ardb/ls1012ardb.c | 6 +---- board/freescale/ls1021aiot/ls1021aiot.c | 6 ++--- board/freescale/ls1021aqds/ls1021aqds.c | 6 +---- board/freescale/ls1021atsn/ls1021atsn.c | 7 ++--- board/freescale/ls1021atwr/ls1021atwr.c | 8 ++---- board/freescale/ls1028a/ls1028a.c | 6 +---- board/freescale/ls1043ardb/ls1043ardb.c | 6 +---- board/freescale/ls1046afrwy/ls1046afrwy.c | 7 +---- board/freescale/ls1046aqds/ls1046aqds.c | 7 +---- board/freescale/ls1046ardb/ls1046ardb.c | 6 +---- board/freescale/ls1088a/ls1088a.c | 6 +---- board/freescale/ls2080aqds/ls2080aqds.c | 6 +---- board/freescale/ls2080ardb/ls2080ardb.c | 9 +------ board/freescale/lx2160a/lx2160a.c | 5 ---- configs/ls1021aiot_qspi_defconfig | 1 - configs/ls1021aqds_nor_defconfig | 1 - configs/ls1021aqds_qspi_defconfig | 1 - configs/ls1021atsn_qspi_defconfig | 1 - configs/ls1021atwr_nor_defconfig | 1 - ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 1 + configs/ls1028ardb_tfa_defconfig | 1 - configs/ls1043ardb_tfa_defconfig | 1 - configs/ls1046afrwy_tfa_defconfig | 1 - configs/ls1046aqds_tfa_defconfig | 1 - configs/ls1046ardb_tfa_defconfig | 1 - configs/ls2088aqds_tfa_defconfig | 1 - configs/ls2088ardb_tfa_defconfig | 1 - configs/lx2160aqds_tfa_defconfig | 1 - configs/lx2160ardb_tfa_defconfig | 1 - configs/lx2162aqds_tfa_defconfig | 1 - 36 files changed, 75 insertions(+), 102 deletions(-)
diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index 747059b56a..f23c33cbc3 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -20,6 +20,10 @@ config ARCH_LS1021A select SYS_FSL_SEC_LE select SYS_FSL_SRDS_1 select SYS_HAS_SERDES + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply CMD_PCI imply SCSI imply SCSI_AHCI diff --git a/arch/arm/cpu/armv7/ls102xa/cpu.c b/arch/arm/cpu/armv7/ls102xa/cpu.c index d863c9625a..4904592703 100644 --- a/arch/arm/cpu/armv7/ls102xa/cpu.c +++ b/arch/arm/cpu/armv7/ls102xa/cpu.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2021 NXP */
#include <common.h> @@ -20,6 +21,7 @@ #include <config.h> #include <fsl_wdog.h> #include <linux/delay.h> +#include <dm.h>
#include "fsl_epu.h"
@@ -397,3 +399,17 @@ void arch_preboot_os(void) ctrl &= ~ARCH_TIMER_CTRL_ENABLE; asm("mcr p15, 0, %0, c14, c2, 1" : : "r" (ctrl)); } + +#ifdef CONFIG_ARCH_MISC_INIT +int arch_misc_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); + if (ret) + printf("Failed to initialize %s: %d\n", dev->name, ret); + + return 0; +} +#endif diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 9cef363fba..3fad7eb5a4 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -18,6 +18,10 @@ config ARCH_LS1012A select SYS_I2C_MXC select SYS_I2C_MXC_I2C1 if !DM_I2C select SYS_I2C_MXC_I2C2 if !DM_I2C + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply PANIC_HANG
config ARCH_LS1028A @@ -50,6 +54,9 @@ config ARCH_LS1028A select SYS_FSL_ERRATUM_A011334 select SYS_FSL_ESDHC_UNRELIABLE_PULSE_DETECTION_WORKAROUND select RESV_RAM if GIC_V3_ITS + select FSL_CAAM + select FSL_BLOB + select MISC imply PANIC_HANG
config ARCH_LS1043A @@ -83,6 +90,10 @@ config ARCH_LS1043A select SYS_I2C_MXC_I2C2 if !DM_I2C select SYS_I2C_MXC_I2C3 if !DM_I2C select SYS_I2C_MXC_I2C4 if !DM_I2C + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply CMD_PCI
config ARCH_LS1046A @@ -117,6 +128,10 @@ config ARCH_LS1046A select SYS_I2C_MXC_I2C2 if !DM_I2C select SYS_I2C_MXC_I2C3 if !DM_I2C select SYS_I2C_MXC_I2C4 if !DM_I2C + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply SCSI imply SCSI_AHCI
@@ -158,6 +173,9 @@ config ARCH_LS1088A select SYS_I2C_MXC_I2C3 if !TFABOOT select SYS_I2C_MXC_I2C4 if !TFABOOT select RESV_RAM if GIC_V3_ITS + select FSL_CAAM + select FSL_BLOB + select MISC imply SCSI imply PANIC_HANG
@@ -209,6 +227,9 @@ config ARCH_LS2080A select SYS_I2C_MXC_I2C3 if !TFABOOT select SYS_I2C_MXC_I2C4 if !TFABOOT select RESV_RAM if GIC_V3_ITS + select FSL_CAAM + select FSL_BLOB + select MISC imply DISTRO_DEFAULTS imply PANIC_HANG
@@ -238,6 +259,9 @@ config ARCH_LX2162A select BOARD_EARLY_INIT_F select SYS_I2C_MXC select RESV_RAM if GIC_V3_ITS + select FSL_CAAM + select FSL_BLOB + select MISC imply DISTRO_DEFAULTS imply PANIC_HANG imply SCSI @@ -271,6 +295,9 @@ config ARCH_LX2160A select BOARD_EARLY_INIT_F select SYS_I2C_MXC select RESV_RAM if GIC_V3_ITS + select FSL_CAAM + select FSL_BLOB + select MISC imply DISTRO_DEFAULTS imply PANIC_HANG imply SCSI diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index d0103fc881..3a7321313c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2017-2020 NXP + * Copyright 2017-2021 NXP * Copyright 2014-2015 Freescale Semiconductor, Inc. */
@@ -48,6 +48,7 @@ #endif #endif #include <linux/mii.h> +#include <dm.h>
@@ -1649,6 +1650,13 @@ __weak int serdes_misc_init(void)
int arch_misc_init(void) { + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); + if (ret) + printf("Failed to initialize %s: %d\n", dev->name, ret); + serdes_misc_init();
return 0; diff --git a/board/freescale/ls1012afrdm/ls1012afrdm.c b/board/freescale/ls1012afrdm/ls1012afrdm.c index 6473ee0572..7fa1e36a45 100644 --- a/board/freescale/ls1012afrdm/ls1012afrdm.c +++ b/board/freescale/ls1012afrdm/ls1012afrdm.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2017-2018 NXP + * Copyright 2017-2018, 2021 NXP */
#include <common.h> @@ -22,7 +22,6 @@ #include <env_internal.h> #include <fsl_mmdc.h> #include <netdev.h> -#include <fsl_sec.h> #include <net/pfe_eth/pfe/pfe_hw.h>
DECLARE_GLOBAL_DATA_PTR; @@ -176,10 +175,6 @@ int board_init(void) gd->env_addr = (ulong)&default_environment[0]; #endif
-#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif - #ifdef CONFIG_FSL_LS_PPA ppa_init(); #endif diff --git a/board/freescale/ls1012aqds/ls1012aqds.c b/board/freescale/ls1012aqds/ls1012aqds.c index 33a0910a19..1a1c797c2d 100644 --- a/board/freescale/ls1012aqds/ls1012aqds.c +++ b/board/freescale/ls1012aqds/ls1012aqds.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2016 Freescale Semiconductor, Inc. + * Copyright 2021 NXP */
#include <common.h> @@ -28,7 +29,6 @@ #include <fsl_mmdc.h> #include <spl.h> #include <netdev.h> -#include <fsl_sec.h> #include "../common/qixis.h" #include "ls1012aqds_qixis.h" #include "ls1012aqds_pfe.h" @@ -154,10 +154,6 @@ int board_init(void) gd->env_addr = (ulong)&default_environment[0]; #endif
-#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif - #ifdef CONFIG_FSL_LS_PPA ppa_init(); #endif diff --git a/board/freescale/ls1012ardb/ls1012ardb.c b/board/freescale/ls1012ardb/ls1012ardb.c index 62e8af48cf..16fe6e2fc8 100644 --- a/board/freescale/ls1012ardb/ls1012ardb.c +++ b/board/freescale/ls1012ardb/ls1012ardb.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2016 Freescale Semiconductor, Inc. + * Copyright 2021 NXP */
#include <common.h> @@ -27,7 +28,6 @@ #include <env_internal.h> #include <fsl_mmdc.h> #include <netdev.h> -#include <fsl_sec.h> #include <net/pfe_eth/pfe/pfe_hw.h>
DECLARE_GLOBAL_DATA_PTR; @@ -177,10 +177,6 @@ int board_init(void) gd->env_addr = (ulong)&default_environment[0]; #endif
-#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif - #ifdef CONFIG_FSL_LS_PPA ppa_init(); #endif diff --git a/board/freescale/ls1021aiot/ls1021aiot.c b/board/freescale/ls1021aiot/ls1021aiot.c index bfe6137604..5ab03b3340 100644 --- a/board/freescale/ls1021aiot/ls1021aiot.c +++ b/board/freescale/ls1021aiot/ls1021aiot.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2016 Freescale Semiconductor, Inc. + * Copyright 2021 NXP */
#include <common.h> @@ -209,10 +210,7 @@ int misc_init_r(void) device_disable(devdis_tbl, ARRAY_SIZE(devdis_tbl));
#endif - -#ifdef CONFIG_FSL_CAAM - return sec_init(); -#endif + return 0; } #endif
diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index 711d8c2906..63f4c675d3 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2014 Freescale Semiconductor, Inc. - * Copyright 2019 NXP + * Copyright 2019, 2021 NXP */
#include <common.h> @@ -20,7 +20,6 @@ #include <mmc.h> #include <fsl_csu.h> #include <fsl_ifc.h> -#include <fsl_sec.h> #include <spl.h> #include <fsl_devdis.h> #include <fsl_validate.h> @@ -384,9 +383,6 @@ int misc_init_r(void)
#ifdef CONFIG_FSL_DEVICE_DISABLE device_disable(devdis_tbl, ARRAY_SIZE(devdis_tbl)); -#endif -#ifdef CONFIG_FSL_CAAM - return sec_init(); #endif return 0; } diff --git a/board/freescale/ls1021atsn/ls1021atsn.c b/board/freescale/ls1021atsn/ls1021atsn.c index c1acd3040c..e47bd9f899 100644 --- a/board/freescale/ls1021atsn/ls1021atsn.c +++ b/board/freescale/ls1021atsn/ls1021atsn.c @@ -1,5 +1,5 @@ // SPDX-License-Identifier: GPL-2.0 -/* Copyright 2016-2019 NXP Semiconductors +/* Copyright 2016-2019, 2021 NXP Semiconductors */ #include <common.h> #include <clock_legacy.h> @@ -238,10 +238,7 @@ int misc_init_r(void) #ifdef CONFIG_FSL_DEVICE_DISABLE device_disable(devdis_tbl, ARRAY_SIZE(devdis_tbl)); #endif - -#ifdef CONFIG_FSL_CAAM - return sec_init(); -#endif + return 0; } #endif
diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index f0b441db63..a2a87eaf35 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2014 Freescale Semiconductor, Inc. - * Copyright 2019 NXP + * Copyright 2019, 2021 NXP */
#include <common.h> @@ -26,7 +26,6 @@ #include <netdev.h> #include <fsl_mdio.h> #include <tsec.h> -#include <fsl_sec.h> #include <fsl_devdis.h> #include <spl.h> #include <linux/delay.h> @@ -555,10 +554,7 @@ int misc_init_r(void) #if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) config_board_mux(); #endif - -#ifdef CONFIG_FSL_CAAM - return sec_init(); -#endif + return 0; } #endif
diff --git a/board/freescale/ls1028a/ls1028a.c b/board/freescale/ls1028a/ls1028a.c index 5269fd34c6..a868993919 100644 --- a/board/freescale/ls1028a/ls1028a.c +++ b/board/freescale/ls1028a/ls1028a.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2019 NXP + * Copyright 2019, 2021 NXP */
#include <common.h> @@ -77,10 +77,6 @@ int board_init(void) gd->env_addr = (ulong)&default_environment[0]; #endif
-#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif - #ifdef CONFIG_FSL_LS_PPA ppa_init(); #endif diff --git a/board/freescale/ls1043ardb/ls1043ardb.c b/board/freescale/ls1043ardb/ls1043ardb.c index beef26b084..c7f214c236 100644 --- a/board/freescale/ls1043ardb/ls1043ardb.c +++ b/board/freescale/ls1043ardb/ls1043ardb.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2015 Freescale Semiconductor, Inc. + * Copyright 2021 NXP */
#include <common.h> @@ -20,7 +21,6 @@ #include <fm_eth.h> #include <fsl_esdhc.h> #include <fsl_ifc.h> -#include <fsl_sec.h> #include "cpld.h" #ifdef CONFIG_U_QE #include <fsl_qe.h> @@ -211,10 +211,6 @@ int board_init(void) out_le32(SMMU_NSCR0, val); #endif
-#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif - #ifdef CONFIG_FSL_LS_PPA ppa_init(); #endif diff --git a/board/freescale/ls1046afrwy/ls1046afrwy.c b/board/freescale/ls1046afrwy/ls1046afrwy.c index f1c08a13f7..5a298cd311 100644 --- a/board/freescale/ls1046afrwy/ls1046afrwy.c +++ b/board/freescale/ls1046afrwy/ls1046afrwy.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2019 NXP + * Copyright 2019, 2021 NXP */
#include <common.h> @@ -20,7 +20,6 @@ #include <fm_eth.h> #include <fsl_csu.h> #include <fsl_esdhc.h> -#include <fsl_sec.h> #include <fsl_dspi.h> #include "../common/i2c_mux.h"
@@ -135,10 +134,6 @@ val = (in_le32(SMMU_SCR0) | SCR0_CLIENTPD_MASK) & ~(SCR0_USFCFG_MASK); out_le32(SMMU_NSCR0, val); #endif
-#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif - select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT, 0); return 0; } diff --git a/board/freescale/ls1046aqds/ls1046aqds.c b/board/freescale/ls1046aqds/ls1046aqds.c index 2b0786ac30..bc27134250 100644 --- a/board/freescale/ls1046aqds/ls1046aqds.c +++ b/board/freescale/ls1046aqds/ls1046aqds.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2016 Freescale Semiconductor, Inc. - * Copyright 2019-2020 NXP + * Copyright 2019-2021 NXP */
#include <common.h> @@ -27,7 +27,6 @@ #include <fsl_csu.h> #include <fsl_esdhc.h> #include <fsl_ifc.h> -#include <fsl_sec.h> #include <spl.h> #include "../common/i2c_mux.h"
@@ -424,10 +423,6 @@ int board_init(void) out_le32(SMMU_NSCR0, val); #endif
-#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif - return 0; }
diff --git a/board/freescale/ls1046ardb/ls1046ardb.c b/board/freescale/ls1046ardb/ls1046ardb.c index 93ef903f29..2e9a6d44eb 100644 --- a/board/freescale/ls1046ardb/ls1046ardb.c +++ b/board/freescale/ls1046ardb/ls1046ardb.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2016 Freescale Semiconductor, Inc. + * Copyright 2021 NXP */
#include <common.h> @@ -23,7 +24,6 @@ #include <fsl_esdhc.h> #include <power/mc34vr500_pmic.h> #include "cpld.h" -#include <fsl_sec.h>
@@ -85,10 +85,6 @@ int board_init(void) out_le32(SMMU_NSCR0, val); #endif
-#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif - #ifdef CONFIG_FSL_LS_PPA ppa_init(); #endif diff --git a/board/freescale/ls1088a/ls1088a.c b/board/freescale/ls1088a/ls1088a.c index 2f422634d5..532cc93d55 100644 --- a/board/freescale/ls1088a/ls1088a.c +++ b/board/freescale/ls1088a/ls1088a.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright 2017-2018 NXP + * Copyright 2017-2018, 2021 NXP */ #include <common.h> #include <env.h> @@ -12,7 +12,6 @@ #include <netdev.h> #include <fsl_ifc.h> #include <fsl_ddr.h> -#include <fsl_sec.h> #include <asm/global_data.h> #include <asm/io.h> #include <fdt_support.h> @@ -819,9 +818,6 @@ int board_init(void) out_le32(irq_ccsr + IRQCR_OFFSET / 4, AQR105_IRQ_MASK); #endif
-#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif #ifdef CONFIG_FSL_LS_PPA ppa_init(); #endif diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index c48b01f7d7..b22be941b0 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2015 Freescale Semiconductor + * Copyright 2021 NXP */ #include <common.h> #include <env.h> @@ -20,7 +21,6 @@ #include <rtc.h> #include <asm/arch/soc.h> #include <hwconfig.h> -#include <fsl_sec.h> #include <asm/arch/ppa.h> #include <asm/arch-fsl-layerscape/fsl_icid.h> #include "../common/i2c_mux.h" @@ -224,10 +224,6 @@ int board_init(void) #endif #endif
-#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif - #ifdef CONFIG_FSL_LS_PPA ppa_init(); #endif diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index e8722f20c1..b0772f5f04 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -1,7 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2015 Freescale Semiconductor - * Copyright 2017 NXP + * Copyright 2017, 2021 NXP */ #include <common.h> #include <env.h> @@ -23,7 +23,6 @@ #include <asm/arch/mmu.h> #include <asm/arch/soc.h> #include <asm/arch/ppa.h> -#include <fsl_sec.h> #include <asm/arch-fsl-layerscape/fsl_icid.h> #include "../common/i2c_mux.h"
@@ -290,9 +289,6 @@ int board_init(void) QIXIS_WRITE(rst_ctl, QIXIS_RST_CTL_RESET_EN); #endif
-#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif #ifdef CONFIG_FSL_LS_PPA ppa_init(); #endif @@ -301,9 +297,6 @@ int board_init(void) /* invert AQR405 IRQ pins polarity */ out_le32(irq_ccsr + IRQCR_OFFSET / 4, AQR405_IRQ_MASK); #endif -#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif
#if !defined(CONFIG_SYS_EARLY_PCI_INIT) && defined(CONFIG_DM_ETH) pci_init(); diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index f505e82fb9..a5becceeb6 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -14,7 +14,6 @@ #include <errno.h> #include <netdev.h> #include <fsl_ddr.h> -#include <fsl_sec.h> #include <asm/io.h> #include <fdt_support.h> #include <linux/bitops.h> @@ -599,10 +598,6 @@ int board_init(void) out_le32(irq_ccsr + IRQCR_OFFSET / 4, AQR107_IRQ_MASK); #endif
-#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif - #if !defined(CONFIG_SYS_EARLY_PCI_INIT) && defined(CONFIG_DM_ETH) pci_init(); #endif diff --git a/configs/ls1021aiot_qspi_defconfig b/configs/ls1021aiot_qspi_defconfig index 131026ca4d..cf11aa467c 100644 --- a/configs/ls1021aiot_qspi_defconfig +++ b/configs/ls1021aiot_qspi_defconfig @@ -29,7 +29,6 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 4c4050a403..97de7de765 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -42,7 +42,6 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_SATA_CEVA=y -CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index 69a02a4af9..dacdf13ed2 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -43,7 +43,6 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y -CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y diff --git a/configs/ls1021atsn_qspi_defconfig b/configs/ls1021atsn_qspi_defconfig index 6103ab32a4..1e1e7feaf9 100644 --- a/configs/ls1021atsn_qspi_defconfig +++ b/configs/ls1021atsn_qspi_defconfig @@ -30,7 +30,6 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index fa20ee8c0e..e4bb0b1356 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -36,7 +36,6 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0x60300000 CONFIG_DM=y CONFIG_SATA_CEVA=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 78196e6485..2a7c6d092b 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -51,6 +51,7 @@ CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SPL_DM=y +CONFIG_SPL_OF_CONTROL=y # CONFIG_SPL_BLK is not set CONFIG_DM_I2C=y # CONFIG_SPL_DM_I2C is not set diff --git a/configs/ls1028ardb_tfa_defconfig b/configs/ls1028ardb_tfa_defconfig index 6934a597a5..b0ab01a5c3 100644 --- a/configs/ls1028ardb_tfa_defconfig +++ b/configs/ls1028ardb_tfa_defconfig @@ -44,7 +44,6 @@ CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SCSI_AHCI=y CONFIG_SATA_CEVA=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0 diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index 58313e4ae5..987b4efe0e 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -35,7 +35,6 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_NAND=y CONFIG_ENV_ADDR=0x60500000 CONFIG_DM=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y diff --git a/configs/ls1046afrwy_tfa_defconfig b/configs/ls1046afrwy_tfa_defconfig index 96ab70bfaf..2a71936621 100644 --- a/configs/ls1046afrwy_tfa_defconfig +++ b/configs/ls1046afrwy_tfa_defconfig @@ -37,7 +37,6 @@ CONFIG_ENV_ADDR=0x40500000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index 8ae5159f42..d94f14e3b0 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -48,7 +48,6 @@ CONFIG_ENV_SPI_BUS=0 CONFIG_ENV_ADDR=0x40500000 CONFIG_DM=y CONFIG_SATA_CEVA=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y diff --git a/configs/ls1046ardb_tfa_defconfig b/configs/ls1046ardb_tfa_defconfig index 997fa1936e..133b194945 100644 --- a/configs/ls1046ardb_tfa_defconfig +++ b/configs/ls1046ardb_tfa_defconfig @@ -38,7 +38,6 @@ CONFIG_ENV_ADDR=0x40500000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index 113f6a4139..f0cfd01b2a 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -48,7 +48,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0 diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index cfd3df430f..39693ef44c 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -46,7 +46,6 @@ CONFIG_ENV_ADDR=0x580500000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0 diff --git a/configs/lx2160aqds_tfa_defconfig b/configs/lx2160aqds_tfa_defconfig index d52063c7a8..1b094e1857 100644 --- a/configs/lx2160aqds_tfa_defconfig +++ b/configs/lx2160aqds_tfa_defconfig @@ -47,7 +47,6 @@ CONFIG_ENV_ADDR=0x20500000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0 diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index d09bcde92e..52767fcd7d 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -46,7 +46,6 @@ CONFIG_ENV_ADDR=0x20500000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0 diff --git a/configs/lx2162aqds_tfa_defconfig b/configs/lx2162aqds_tfa_defconfig index 2724f045ed..94dd805f97 100644 --- a/configs/lx2162aqds_tfa_defconfig +++ b/configs/lx2162aqds_tfa_defconfig @@ -48,7 +48,6 @@ CONFIG_ENV_ADDR=0x20500000 CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y -CONFIG_FSL_CAAM=y CONFIG_MPC8XXX_GPIO=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Gaurav Jain Sent: Friday, September 3, 2021 12:33 PM To: u-boot@lists.denx.de Cc: Stefano Babic sbabic@denx.de; Fabio Estevam festevam@gmail.com; Peng Fan peng.fan@nxp.com; Simon Glass sjg@chromium.org; Priyanka Jain priyanka.jain@nxp.com; Ye Li ye.li@nxp.com; Horia Geanta horia.geanta@nxp.com; Ji Luo ji.luo@nxp.com; Franck Lenormand franck.lenormand@nxp.com; Silvano Di Ninno silvano.dininno@nxp.com; Sahil Malhotra sahil.malhotra@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; dl-uboot-imx uboot-imx@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com; Wasim Khan wasim.khan@nxp.com; Alison Wang alison.wang@nxp.com; Pramod Kumar pramod.kumar_1@nxp.com; Andy Tang andy.tang@nxp.com; Adrian Alonso adrian.alonso@nxp.com; Vladimir Oltean olteanv@gmail.com; Gaurav Jain gaurav.jain@nxp.com Subject: [PATCH v2 12/15] Layerscape: Enable Job ring driver model in U-Boot.
<snip> Reviewed-by: Priyanka Jain priyanka.jain@nxp.com
device tree imported from linux kernel. c500bee1c5b2 (tag: v5.14-rc4) Linux 5.14-rc4
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- arch/powerpc/dts/p2041si-post.dtsi | 1 + arch/powerpc/dts/p3041si-post.dtsi | 1 + arch/powerpc/dts/p4080si-post.dtsi | 1 + arch/powerpc/dts/p5040si-post.dtsi | 1 + arch/powerpc/dts/qoriq-sec4.0-0.dtsi | 74 ++++++++++++++++++++++ arch/powerpc/dts/qoriq-sec4.2-0.dtsi | 83 +++++++++++++++++++++++++ arch/powerpc/dts/qoriq-sec5.2-0.dtsi | 92 ++++++++++++++++++++++++++++ arch/powerpc/dts/t1023si-post.dtsi | 1 + arch/powerpc/dts/t1042si-post.dtsi | 1 + arch/powerpc/dts/t2080si-post.dtsi | 1 + arch/powerpc/dts/t4240si-post.dtsi | 1 + 11 files changed, 257 insertions(+) create mode 100644 arch/powerpc/dts/qoriq-sec4.0-0.dtsi create mode 100644 arch/powerpc/dts/qoriq-sec4.2-0.dtsi create mode 100644 arch/powerpc/dts/qoriq-sec5.2-0.dtsi
diff --git a/arch/powerpc/dts/p2041si-post.dtsi b/arch/powerpc/dts/p2041si-post.dtsi index 01ab395950..8819199646 100644 --- a/arch/powerpc/dts/p2041si-post.dtsi +++ b/arch/powerpc/dts/p2041si-post.dtsi @@ -11,6 +11,7 @@
/include/ "qoriq-clockgen1.dtsi" /include/ "qoriq-gpio-0.dtsi" +/include/ "qoriq-sec4.2-0.dtsi"
/* include used FMan blocks */ /include/ "qoriq-fman-0.dtsi" diff --git a/arch/powerpc/dts/p3041si-post.dtsi b/arch/powerpc/dts/p3041si-post.dtsi index 21f322f06f..a3e8088d25 100644 --- a/arch/powerpc/dts/p3041si-post.dtsi +++ b/arch/powerpc/dts/p3041si-post.dtsi @@ -11,6 +11,7 @@
/* include used FMan blocks */ /include/ "qoriq-fman-0.dtsi" diff --git a/arch/powerpc/dts/p4080si-post.dtsi b/arch/powerpc/dts/p4080si-post.dtsi index 7c3f2fb92e..56b79b14f4 100644 --- a/arch/powerpc/dts/p4080si-post.dtsi +++ b/arch/powerpc/dts/p4080si-post.dtsi @@ -11,6 +11,7 @@
/include/ "qoriq-clockgen1.dtsi" /include/ "qoriq-gpio-0.dtsi" +/include/ "qoriq-sec4.0-0.dtsi"
/* include used FMan blocks */ /include/ "qoriq-fman-0.dtsi" diff --git a/arch/powerpc/dts/p5040si-post.dtsi b/arch/powerpc/dts/p5040si-post.dtsi index 1efad2d017..fae3ed31a5 100644 --- a/arch/powerpc/dts/p5040si-post.dtsi +++ b/arch/powerpc/dts/p5040si-post.dtsi @@ -11,6 +11,7 @@
/include/ "qoriq-clockgen1.dtsi" /include/ "qoriq-gpio-0.dtsi" +/include/ "qoriq-sec5.2-0.dtsi"
/* include used FMan blocks */ /include/ "qoriq-fman-0.dtsi" diff --git a/arch/powerpc/dts/qoriq-sec4.0-0.dtsi b/arch/powerpc/dts/qoriq-sec4.0-0.dtsi new file mode 100644 index 0000000000..ff348d70f1 --- /dev/null +++ b/arch/powerpc/dts/qoriq-sec4.0-0.dtsi @@ -0,0 +1,74 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-3-Clause) +/* + * QorIQ Sec/Crypto 4.0 device tree stub [ controller @ offset 0x300000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + */ + +crypto: crypto@300000 { + compatible = "fsl,sec-v4.0"; + fsl,sec-era = <1>; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x300000 0x10000>; + ranges = <0 0x300000 0x10000>; + interrupts = <92 2 0 0>; + + sec_jr0: jr@1000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x1000 0x1000>; + interrupts = <88 2 0 0>; + }; + + sec_jr1: jr@2000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x2000 0x1000>; + interrupts = <89 2 0 0>; + }; + + sec_jr2: jr@3000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x3000 0x1000>; + interrupts = <90 2 0 0>; + }; + + sec_jr3: jr@4000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x4000 0x1000>; + interrupts = <91 2 0 0>; + }; + + rtic@6000 { + compatible = "fsl,sec-v4.0-rtic"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x6000 0x100>; + ranges = <0x0 0x6100 0xe00>; + + rtic_a: rtic-a@0 { + compatible = "fsl,sec-v4.0-rtic-memory"; + reg = <0x00 0x20 0x100 0x80>; + }; + + rtic_b: rtic-b@20 { + compatible = "fsl,sec-v4.0-rtic-memory"; + reg = <0x20 0x20 0x200 0x80>; + }; + + rtic_c: rtic-c@40 { + compatible = "fsl,sec-v4.0-rtic-memory"; + reg = <0x40 0x20 0x300 0x80>; + }; + + rtic_d: rtic-d@60 { + compatible = "fsl,sec-v4.0-rtic-memory"; + reg = <0x60 0x20 0x500 0x80>; + }; + }; +}; + +sec_mon: sec_mon@314000 { + compatible = "fsl,sec-v4.0-mon"; + reg = <0x314000 0x1000>; + interrupts = <93 2 0 0>; +}; diff --git a/arch/powerpc/dts/qoriq-sec4.2-0.dtsi b/arch/powerpc/dts/qoriq-sec4.2-0.dtsi new file mode 100644 index 0000000000..57a0bc5c56 --- /dev/null +++ b/arch/powerpc/dts/qoriq-sec4.2-0.dtsi @@ -0,0 +1,83 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-3-Clause) +/* + * QorIQ Sec/Crypto 4.2 device tree stub [ controller @ offset 0x300000 ] + * + * Copyright 2011 Freescale Semiconductor Inc. + */ + +crypto: crypto@300000 { + compatible = "fsl,sec-v4.2", "fsl,sec-v4.0"; + fsl,sec-era = <3>; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x300000 0x10000>; + ranges = <0 0x300000 0x10000>; + interrupts = <92 2 0 0>; + + sec_jr0: jr@1000 { + compatible = "fsl,sec-v4.2-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x1000 0x1000>; + interrupts = <88 2 0 0>; + }; + + sec_jr1: jr@2000 { + compatible = "fsl,sec-v4.2-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x2000 0x1000>; + interrupts = <89 2 0 0>; + }; + + sec_jr2: jr@3000 { + compatible = "fsl,sec-v4.2-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x3000 0x1000>; + interrupts = <90 2 0 0>; + }; + + sec_jr3: jr@4000 { + compatible = "fsl,sec-v4.2-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x4000 0x1000>; + interrupts = <91 2 0 0>; + }; + + rtic@6000 { + compatible = "fsl,sec-v4.2-rtic", + "fsl,sec-v4.0-rtic"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x6000 0x100>; + ranges = <0x0 0x6100 0xe00>; + + rtic_a: rtic-a@0 { + compatible = "fsl,sec-v4.2-rtic-memory", + "fsl,sec-v4.0-rtic-memory"; + reg = <0x00 0x20 0x100 0x80>; + }; + + rtic_b: rtic-b@20 { + compatible = "fsl,sec-v4.2-rtic-memory", + "fsl,sec-v4.0-rtic-memory"; + reg = <0x20 0x20 0x200 0x80>; + }; + + rtic_c: rtic-c@40 { + compatible = "fsl,sec-v4.2-rtic-memory", + "fsl,sec-v4.0-rtic-memory"; + reg = <0x40 0x20 0x300 0x80>; + }; + + rtic_d: rtic-d@60 { + compatible = "fsl,sec-v4.2-rtic-memory", + "fsl,sec-v4.0-rtic-memory"; + reg = <0x60 0x20 0x500 0x80>; + }; + }; +}; + +sec_mon: sec_mon@314000 { + compatible = "fsl,sec-v4.2-mon", "fsl,sec-v4.0-mon"; + reg = <0x314000 0x1000>; + interrupts = <93 2 0 0>; +}; diff --git a/arch/powerpc/dts/qoriq-sec5.2-0.dtsi b/arch/powerpc/dts/qoriq-sec5.2-0.dtsi new file mode 100644 index 0000000000..e5f87effd3 --- /dev/null +++ b/arch/powerpc/dts/qoriq-sec5.2-0.dtsi @@ -0,0 +1,92 @@ +// SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-3-Clause) +/* + * QorIQ Sec/Crypto 5.2 device tree stub [ controller @ offset 0x300000 ] + * + * Copyright 2011-2012 Freescale Semiconductor Inc. + */ + +crypto: crypto@300000 { + compatible = "fsl,sec-v5.2", "fsl,sec-v5.0", "fsl,sec-v4.0"; + fsl,sec-era = <5>; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x300000 0x10000>; + ranges = <0 0x300000 0x10000>; + interrupts = <92 2 0 0>; + + sec_jr0: jr@1000 { + compatible = "fsl,sec-v5.2-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x1000 0x1000>; + interrupts = <88 2 0 0>; + }; + + sec_jr1: jr@2000 { + compatible = "fsl,sec-v5.2-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x2000 0x1000>; + interrupts = <89 2 0 0>; + }; + + sec_jr2: jr@3000 { + compatible = "fsl,sec-v5.2-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x3000 0x1000>; + interrupts = <90 2 0 0>; + }; + + sec_jr3: jr@4000 { + compatible = "fsl,sec-v5.2-job-ring", + "fsl,sec-v5.0-job-ring", + "fsl,sec-v4.0-job-ring"; + reg = <0x4000 0x1000>; + interrupts = <91 2 0 0>; + }; + + rtic@6000 { + compatible = "fsl,sec-v5.2-rtic", + "fsl,sec-v5.0-rtic", + "fsl,sec-v4.0-rtic"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x6000 0x100>; + ranges = <0x0 0x6100 0xe00>; + + rtic_a: rtic-a@0 { + compatible = "fsl,sec-v5.2-rtic-memory", + "fsl,sec-v5.0-rtic-memory", + "fsl,sec-v4.0-rtic-memory"; + reg = <0x00 0x20 0x100 0x80>; + }; + + rtic_b: rtic-b@20 { + compatible = "fsl,sec-v5.2-rtic-memory", + "fsl,sec-v5.0-rtic-memory", + "fsl,sec-v4.0-rtic-memory"; + reg = <0x20 0x20 0x200 0x80>; + }; + + rtic_c: rtic-c@40 { + compatible = "fsl,sec-v5.2-rtic-memory", + "fsl,sec-v5.0-rtic-memory", + "fsl,sec-v4.0-rtic-memory"; + reg = <0x40 0x20 0x300 0x80>; + }; + + rtic_d: rtic-d@60 { + compatible = "fsl,sec-v5.2-rtic-memory", + "fsl,sec-v5.0-rtic-memory", + "fsl,sec-v4.0-rtic-memory"; + reg = <0x60 0x20 0x500 0x80>; + }; + }; +}; + +sec_mon: sec_mon@314000 { + compatible = "fsl,sec-v5.2-mon", "fsl,sec-v5.0-mon", "fsl,sec-v4.0-mon"; + reg = <0x314000 0x1000>; + interrupts = <93 2 0 0>; +}; diff --git a/arch/powerpc/dts/t1023si-post.dtsi b/arch/powerpc/dts/t1023si-post.dtsi index 7284eb9791..6f666a1554 100644 --- a/arch/powerpc/dts/t1023si-post.dtsi +++ b/arch/powerpc/dts/t1023si-post.dtsi @@ -14,6 +14,7 @@ /include/ "qoriq-gpio-1.dtsi" /include/ "qoriq-gpio-2.dtsi" /include/ "qoriq-gpio-3.dtsi" +/include/ "qoriq-sec5.0-0.dtsi"
/* include used FMan blocks */ /include/ "qoriq-fman3l-0.dtsi" diff --git a/arch/powerpc/dts/t1042si-post.dtsi b/arch/powerpc/dts/t1042si-post.dtsi index 5c60944e60..eebbbaf0e1 100644 --- a/arch/powerpc/dts/t1042si-post.dtsi +++ b/arch/powerpc/dts/t1042si-post.dtsi @@ -12,6 +12,7 @@ /include/ "qoriq-gpio-1.dtsi" /include/ "qoriq-gpio-2.dtsi" /include/ "qoriq-gpio-3.dtsi" +/include/ "qoriq-sec5.0-0.dtsi"
/include/ "qoriq-fman3l-0.dtsi" /include/ "qoriq-fman3-0-1g-0.dtsi" diff --git a/arch/powerpc/dts/t2080si-post.dtsi b/arch/powerpc/dts/t2080si-post.dtsi index d8ef579cb7..c06526b3db 100644 --- a/arch/powerpc/dts/t2080si-post.dtsi +++ b/arch/powerpc/dts/t2080si-post.dtsi @@ -13,6 +13,7 @@ /include/ "qoriq-gpio-1.dtsi" /include/ "qoriq-gpio-2.dtsi" /include/ "qoriq-gpio-3.dtsi" +/include/ "qoriq-sec5.2-0.dtsi"
/include/ "qoriq-fman3-0.dtsi" /include/ "qoriq-fman3-0-10g-0-best-effort.dtsi" diff --git a/arch/powerpc/dts/t4240si-post.dtsi b/arch/powerpc/dts/t4240si-post.dtsi index a596f48b54..9fa99ae771 100644 --- a/arch/powerpc/dts/t4240si-post.dtsi +++ b/arch/powerpc/dts/t4240si-post.dtsi @@ -12,6 +12,7 @@ /include/ "qoriq-gpio-1.dtsi" /include/ "qoriq-gpio-2.dtsi" /include/ "qoriq-gpio-3.dtsi" +/include/ "qoriq-sec5.0-0.dtsi"
/include/ "qoriq-fman3-0.dtsi" /include/ "qoriq-fman3-0-1g-0.dtsi"
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Gaurav Jain Sent: Friday, September 3, 2021 12:33 PM To: u-boot@lists.denx.de Cc: Stefano Babic sbabic@denx.de; Fabio Estevam festevam@gmail.com; Peng Fan peng.fan@nxp.com; Simon Glass sjg@chromium.org; Priyanka Jain priyanka.jain@nxp.com; Ye Li ye.li@nxp.com; Horia Geanta horia.geanta@nxp.com; Ji Luo ji.luo@nxp.com; Franck Lenormand franck.lenormand@nxp.com; Silvano Di Ninno silvano.dininno@nxp.com; Sahil Malhotra sahil.malhotra@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; dl-uboot-imx uboot-imx@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com; Wasim Khan wasim.khan@nxp.com; Alison Wang alison.wang@nxp.com; Pramod Kumar pramod.kumar_1@nxp.com; Andy Tang andy.tang@nxp.com; Adrian Alonso adrian.alonso@nxp.com; Vladimir Oltean olteanv@gmail.com; Gaurav Jain gaurav.jain@nxp.com Subject: [PATCH v2 13/15] PPC: Add crypto node in device tree
removed sec_init() call and CONFIG_FSL_CAAM from defconfig. sec is initialized based on job ring information processed from device tree.
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- arch/powerpc/cpu/mpc85xx/Kconfig | 44 +++++++++++++++++++++++++++ arch/powerpc/cpu/mpc85xx/cpu_init.c | 17 +++++++++-- arch/powerpc/include/asm/u-boot-ppc.h | 13 ++++++++ arch/powerpc/include/asm/u-boot.h | 1 + configs/P2041RDB_defconfig | 1 - configs/P3041DS_defconfig | 1 - configs/P4080DS_defconfig | 1 - configs/P5040DS_defconfig | 1 - configs/T1024RDB_defconfig | 1 - configs/T1042D4RDB_defconfig | 1 - configs/T2080QDS_defconfig | 1 - configs/T2080RDB_defconfig | 1 - configs/T4240RDB_defconfig | 1 - 13 files changed, 73 insertions(+), 11 deletions(-) create mode 100644 arch/powerpc/include/asm/u-boot-ppc.h
diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index 395423582a..0744a207a4 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -25,6 +25,10 @@ config TARGET_P3041DS select PHYS_64BIT select ARCH_P3041 select BOARD_LATE_INIT if CHAIN_OF_TRUST + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply CMD_SATA imply PANIC_HANG
@@ -33,6 +37,10 @@ config TARGET_P4080DS select PHYS_64BIT select ARCH_P4080 select BOARD_LATE_INIT if CHAIN_OF_TRUST + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply CMD_SATA imply PANIC_HANG
@@ -41,6 +49,10 @@ config TARGET_P5040DS select PHYS_64BIT select ARCH_P5040 select BOARD_LATE_INIT if CHAIN_OF_TRUST + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply CMD_SATA imply PANIC_HANG
@@ -101,6 +113,10 @@ config TARGET_P2041RDB select ARCH_P2041 select BOARD_LATE_INIT if CHAIN_OF_TRUST select PHYS_64BIT + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply CMD_SATA imply FSL_SATA
@@ -116,6 +132,10 @@ config TARGET_T1024RDB select SUPPORT_SPL select PHYS_64BIT select FSL_DDR_INTERACTIVE + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply CMD_EEPROM imply PANIC_HANG
@@ -125,6 +145,10 @@ config TARGET_T1042RDB select BOARD_LATE_INIT if CHAIN_OF_TRUST select SUPPORT_SPL select PHYS_64BIT + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT
config TARGET_T1042D4RDB bool "Support T1042D4RDB" @@ -132,6 +156,10 @@ config TARGET_T1042D4RDB select BOARD_LATE_INIT if CHAIN_OF_TRUST select SUPPORT_SPL select PHYS_64BIT + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply PANIC_HANG
config TARGET_T1042RDB_PI @@ -140,6 +168,10 @@ config TARGET_T1042RDB_PI select BOARD_LATE_INIT if CHAIN_OF_TRUST select SUPPORT_SPL select PHYS_64BIT + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply PANIC_HANG
config TARGET_T2080QDS @@ -150,6 +182,10 @@ config TARGET_T2080QDS select PHYS_64BIT select FSL_DDR_FIRST_SLOT_QUAD_CAPABLE select FSL_DDR_INTERACTIVE + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply CMD_SATA
config TARGET_T2080RDB @@ -158,6 +194,10 @@ config TARGET_T2080RDB select BOARD_LATE_INIT if CHAIN_OF_TRUST select SUPPORT_SPL select PHYS_64BIT + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply CMD_SATA imply PANIC_HANG
@@ -167,6 +207,10 @@ config TARGET_T4240RDB select SUPPORT_SPL select PHYS_64BIT select FSL_DDR_FIRST_SLOT_QUAD_CAPABLE + select FSL_CAAM + select FSL_BLOB + select MISC + select ARCH_MISC_INIT imply CMD_SATA imply PANIC_HANG
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index e920e01b25..728c6447a8 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -56,6 +56,7 @@ #ifdef CONFIG_U_QE #include <fsl_qe.h> #endif +#include <dm.h>
#ifdef CONFIG_SYS_FSL_SINGLE_SOURCE_CLK /* @@ -974,8 +975,6 @@ int cpu_init_r(void) #endif
#ifdef CONFIG_FSL_CAAM - sec_init(); - #if defined(CONFIG_ARCH_C29X) if ((SVR_SOC_VER(svr) == SVR_C292) || (SVR_SOC_VER(svr) == SVR_C293)) @@ -1014,6 +1013,20 @@ int cpu_init_r(void) return 0; }
+#ifdef CONFIG_ARCH_MISC_INIT +int arch_misc_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(caam_jr), &dev); + if (ret) + printf("Failed to initialize %s: %d\n", dev->name, ret); + + return 0; +} +#endif + void arch_preboot_os(void) { u32 msr; diff --git a/arch/powerpc/include/asm/u-boot-ppc.h b/arch/powerpc/include/asm/u-boot-ppc.h new file mode 100644 index 0000000000..d5a81fb21f --- /dev/null +++ b/arch/powerpc/include/asm/u-boot-ppc.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * Copyright 2021 NXP + * + * Gaurav Jain gaurav.jain@nxp.com + */ + +#ifndef _U_BOOT_PPC_H_ +#define _U_BOOT_PPC_H_ + +int arch_misc_init(void); + +#endif /* _U_BOOT_PPC_H_ */ diff --git a/arch/powerpc/include/asm/u-boot.h b/arch/powerpc/include/asm/u-boot.h index 19b3c0db5f..36af8e5403 100644 --- a/arch/powerpc/include/asm/u-boot.h +++ b/arch/powerpc/include/asm/u-boot.h @@ -21,5 +21,6 @@ /* Use the generic board which requires a unified bd_info */ #include <asm-generic/u-boot.h> #include <asm/ppc.h> +#include <asm/u-boot-ppc.h>
#endif /* __U_BOOT_H__ */ diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index 224ae422d1..7e5f3777de 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -31,7 +31,6 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index 4369f404a5..feeaffb9d8 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -30,7 +30,6 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index f6c43bcd29..6655e76d18 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -30,7 +30,6 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD_NOR_FLASH=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index 2be7c7769e..0eda9cf6fa 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -30,7 +30,6 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index 3533b78ba2..7714a4f0ad 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -39,7 +39,6 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y -CONFIG_FSL_CAAM=y CONFIG_SYS_FSL_DDR3=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index cf6c264f8f..b13a348769 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -35,7 +35,6 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index f92a4573bf..3af4ff5bcf 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -33,7 +33,6 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index 466e91743f..7a642216d6 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -37,7 +37,6 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index 14594b0579..3ff02f4c8c 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -30,7 +30,6 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0xEFF20000 CONFIG_DM=y -CONFIG_FSL_CAAM=y CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_MTD=y
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Gaurav Jain Sent: Friday, September 3, 2021 12:33 PM To: u-boot@lists.denx.de Cc: Stefano Babic sbabic@denx.de; Fabio Estevam festevam@gmail.com; Peng Fan peng.fan@nxp.com; Simon Glass sjg@chromium.org; Priyanka Jain priyanka.jain@nxp.com; Ye Li ye.li@nxp.com; Horia Geanta horia.geanta@nxp.com; Ji Luo ji.luo@nxp.com; Franck Lenormand franck.lenormand@nxp.com; Silvano Di Ninno silvano.dininno@nxp.com; Sahil Malhotra sahil.malhotra@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; dl-uboot-imx uboot-imx@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com; Wasim Khan wasim.khan@nxp.com; Alison Wang alison.wang@nxp.com; Pramod Kumar pramod.kumar_1@nxp.com; Andy Tang andy.tang@nxp.com; Adrian Alonso adrian.alonso@nxp.com; Vladimir Oltean olteanv@gmail.com; Gaurav Jain gaurav.jain@nxp.com Subject: [PATCH v2 14/15] PPC: Enable Job ring driver model in U-Boot
Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- MAINTAINERS | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index 4cf0c33c5d..938f372917 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -1258,3 +1258,10 @@ T: git https://source.denx.de/u-boot/u-boot.git F: configs/tools-only_defconfig F: * F: */ + +CAAM +M: Gaurav Jain gaurav.jain@nxp.com +S: Maintained +F: drivers/crypto/fsl/ +F: include/fsl_sec.h +F: cmd/blob.c
On Fri, Sep 3, 2021 at 12:04 AM Gaurav Jain gaurav.jain@nxp.com wrote:
This patchset adds the support for following:
- CAAM Driver model for all i.MX, layerscape, PPC platforms.
- Added crypto node in device tree files.
- CAAM support for blob key encryption key(bkek), random number generation.
- fixed hwrng performance issue in kernel.
i.MX platforms: i.MX6, i.MX7, i.MX7ULP, i.MX8MM/MN/MP/MQ, i.MX8QM/QXP
Layerscape platforms: LS1021, LS1012, LS1028, LS1043, LS1046, LS1088, LS2088, LX2160, LX2162
Powerpc platforms: P3041, P4080, P5040, P2041, T1024, T1042, T2080, T4240
Gaurav Jain (14): crypto/fsl: Add support for CAAM Job ring driver model crypto/fsl: Add CAAM support for bkek, random number generation i.MX8M: crypto: updated device tree for supporting DM in SPL crypto/fsl: i.MX8M: Enable Job ring driver model in SPL and U-Boot. i.MX6: Enable Job ring driver model in U-Boot. i.MX7: Enable Job ring driver model in U-Boot. i.MX7ULP: Enable Job ring driver model in U-Boot. i.MX8: Add crypto node in device tree crypto/fsl: i.MX8: Enable Job ring driver model in SPL and U-Boot. Layerscape: Add crypto node in device tree Layerscape: Enable Job ring driver model in U-Boot. PPC: Add crypto node in device tree PPC: Enable Job ring driver model in U-Boot update CAAM MAINTAINER
Ye Li (1): crypto/fsl: Fix kick_trng
Gaurav,
I am interested in seeing support added to provide a command to blob/deblob data using CAAM. Peng submitted previously a patch 'crypto: caam: Add fsl caam driver' [1] which was not merged because it was adding a new CAAM driver instead of adding functionality to the existing one. Peng's patch added driver support and added a 'caam' command to allow 'caam genblob' and 'caam decap'.
If that is what you are trying to do in this series I see you add a function derive_blob_kek but it appears to be not used anywhere. Were you going to also add a command or add this to the 'dek_blob' command?
Tim
[1] https://patchwork.ozlabs.org/project/uboot/patch/20210325093036.3270101-32-p...
Hi Tim
-----Original Message----- From: Tim Harvey tharvey@gateworks.com Sent: Friday, September 24, 2021 4:32 AM To: Gaurav Jain gaurav.jain@nxp.com; Peng Fan peng.fan@nxp.com Cc: u-boot u-boot@lists.denx.de; Stefano Babic sbabic@denx.de; Fabio Estevam festevam@gmail.com; Simon Glass sjg@chromium.org; Priyanka Jain priyanka.jain@nxp.com; Ye Li ye.li@nxp.com; Horia Geanta horia.geanta@nxp.com; Ji Luo ji.luo@nxp.com; Franck Lenormand franck.lenormand@nxp.com; Silvano Di Ninno silvano.dininno@nxp.com; Sahil Malhotra sahil.malhotra@nxp.com; Pankaj Gupta pankaj.gupta@nxp.com; Varun Sethi V.Sethi@nxp.com; dl-uboot-imx uboot-imx@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Mingkai Hu mingkai.hu@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; Meenakshi Aggarwal meenakshi.aggarwal@nxp.com; Wasim Khan wasim.khan@nxp.com; Alison Wang alison.wang@nxp.com; Pramod Kumar pramod.kumar_1@nxp.com; Andy Tang andy.tang@nxp.com; Adrian Alonso adrian.alonso@nxp.com; Vladimir Oltean olteanv@gmail.com Subject: [EXT] Re: [PATCH v2 00/15] Add CAAM driver model support
Caution: EXT Email
generation.
Gaurav,
This patch series is modifying the existing CAAM driver to caam driver model. And is common caam implementation for all i.MX, Layerscape and powerpc.
We already have blob encap/decap support added in cmd/blob.c After this patch series, We are also planning to add more feature for blob and command for derive_blob_kek later.
Regards Gaurav Jain
Tim
[1] https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatchwo rk.ozlabs.org%2Fproject%2Fuboot%2Fpatch%2F20210325093036.3270101-32- peng.fan%40oss.nxp.com%2F&data=04%7C01%7Cgaurav.jain%40nxp.com %7C7952867f2b414e4a6c8508d97ee62e2b%7C686ea1d3bc2b4c6fa92cd99c5c3 01635%7C0%7C0%7C637680349347068156%7CUnknown%7CTWFpbGZsb3d8ey JWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C 1000&sdata=AhEHy7E192SGEPn8zhnDM0GbVsKqwXL2EvKTDoV1T1Q%3D& amp;reserved=0
Gaurav Jain
Priyanka Jain (OSS)
Tim Harvey
Ye Li
