[U-Boot] pull request: u-boot-uniphier/master
Hi Tom,
Please pull some updates specific to UniPhier SoCs.
The following changes since commit b217c89e8565ade3aaa9f74c33c93236bf151187:
Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriq (2015-07-20 17:12:52 -0400)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to 62102bee1ff32e7eda8b31558b0b646df74fecfd:
ARM: UniPhier: document reference support card (2015-07-23 23:42:37 +0900)
---------------------------------------------------------------- Masahiro Yamada (8): ARM: dts: UniPhier: add device-specific compatible string for EEPROM ARM: UniPhier: add environment sets for non-FIT Linux boot ARM: UniPhier: add environment variable for TFTP boot ARM: UniPhier: disable CONFIG_FIT ARM: UniPhier: update CONFIG_BOOTARGS ARM: UniPhier: add PH1-sLD3 SoC support ARM: dts: UniPhier: add I2C ch4 device node for PH1-sLD3 ARM: UniPhier: document reference support card
arch/arm/dts/uniphier-ph1-sld3.dtsi | 9 +++++ arch/arm/dts/uniphier-ref-daughter.dtsi | 2 +- arch/arm/mach-uniphier/Kconfig | 12 ++++-- arch/arm/mach-uniphier/Makefile | 7 ++-- arch/arm/mach-uniphier/include/mach/sc-regs.h | 6 ++- arch/arm/mach-uniphier/include/mach/sg-regs.h | 5 ++- arch/arm/mach-uniphier/ph1-sld3/Makefile | 16 ++++++++ arch/arm/mach-uniphier/ph1-sld3/bcu_init.c | 36 ++++++++++++++++++ arch/arm/mach-uniphier/ph1-sld3/boot-mode.c | 97 +++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-uniphier/ph1-sld3/clkrst_init.c | 1 + arch/arm/mach-uniphier/ph1-sld3/early_clkrst_init.c | 1 + arch/arm/mach-uniphier/ph1-sld3/early_pinctrl.c | 23 +++++++++++ arch/arm/mach-uniphier/ph1-sld3/lowlevel_debug.S | 31 +++++++++++++++ arch/arm/mach-uniphier/ph1-sld3/memconf.c | 52 +++++++++++++++++++++++++ arch/arm/mach-uniphier/ph1-sld3/pinctrl.c | 24 ++++++++++++ arch/arm/mach-uniphier/ph1-sld3/platdevice.c | 1 + arch/arm/mach-uniphier/ph1-sld3/pll_init.c | 10 +++++ arch/arm/mach-uniphier/ph1-sld3/pll_spectrum.c | 18 +++++++++ arch/arm/mach-uniphier/ph1-sld3/sbc_init.c | 45 ++++++++++++++++++++++ arch/arm/mach-uniphier/ph1-sld3/sbc_init_3cs.c | 37 ++++++++++++++++++ arch/arm/mach-uniphier/ph1-sld3/sg_init.c | 9 +++++ arch/arm/mach-uniphier/ph1-sld3/umc_init.c | 15 ++++++++ configs/ph1_ld4_defconfig | 2 - configs/ph1_pro4_defconfig | 2 - configs/ph1_sld3_defconfig | 28 ++++++++++++++ configs/ph1_sld8_defconfig | 2 - doc/README.uniphier | 54 ++++++++++++++++++++++++-- include/configs/uniphier.h | 103 ++++++++++++++++++++++++++++++++++++++------------ 28 files changed, 603 insertions(+), 45 deletions(-) create mode 100644 arch/arm/mach-uniphier/ph1-sld3/Makefile create mode 100644 arch/arm/mach-uniphier/ph1-sld3/bcu_init.c create mode 100644 arch/arm/mach-uniphier/ph1-sld3/boot-mode.c create mode 100644 arch/arm/mach-uniphier/ph1-sld3/clkrst_init.c create mode 100644 arch/arm/mach-uniphier/ph1-sld3/early_clkrst_init.c create mode 100644 arch/arm/mach-uniphier/ph1-sld3/early_pinctrl.c create mode 100644 arch/arm/mach-uniphier/ph1-sld3/lowlevel_debug.S create mode 100644 arch/arm/mach-uniphier/ph1-sld3/memconf.c create mode 100644 arch/arm/mach-uniphier/ph1-sld3/pinctrl.c create mode 100644 arch/arm/mach-uniphier/ph1-sld3/platdevice.c create mode 100644 arch/arm/mach-uniphier/ph1-sld3/pll_init.c create mode 100644 arch/arm/mach-uniphier/ph1-sld3/pll_spectrum.c create mode 100644 arch/arm/mach-uniphier/ph1-sld3/sbc_init.c create mode 100644 arch/arm/mach-uniphier/ph1-sld3/sbc_init_3cs.c create mode 100644 arch/arm/mach-uniphier/ph1-sld3/sg_init.c create mode 100644 arch/arm/mach-uniphier/ph1-sld3/umc_init.c create mode 100644 configs/ph1_sld3_defconfig
On Thu, Jul 23, 2015 at 11:49:57PM +0900, Masahiro Yamada wrote:
Hi Tom,
Masahiro Yamada
