Re: [U-Boot] M29W256GL + WEIM in uboot
Marek,
Could you please go slower on this. Please point me what do I have to read because Im not getting the meaning of MMAPED in uboot and how to related this to my NOR flash.
Can you please at least obey basic rules of using a mailing list ?
DO NOT TOP-POST DO NOT DROP IT FROM CC
MMAPed == memory mapped.
M
Regards, Francisco.
On Mon, Feb 13, 2012 at 2:52 PM, Marek Vasut marek.vasut@gmail.com wrote:
Hello, Im new to all of this, but I 've been reading most of the post related to the M29w256 numonyx and the u-boot documentation without any success :(
Im booting from MMC card and I want to parallel nor to be probed by cfi, but I have not succeeded since the uboot code freezes when at the beginning of the Marekfirst "flash_cmd_write" in cfi_flash.c
/* Issue FLASH reset command */ flash_cmd_reset(info);
The CS0_BASE_ADDR has an start address matching #define WEIM_ARB_BASE_ADDR 0x08000000 , however the range of the WEIM interface register settings are between 021B_8000 -- 021B_8098.
Many board files has the WEIM CS0 as the start of the registers and I think this is why the NOR configuration is a matter of config settings like the ones below.
#define CONFIG_SYS_FLASH_BASE CS0_BASE_ADDR #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT #define CONFIG_SYS_FLASH_CFI_AMD_RESET 1
/* Monitor at beginning of flash */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_MONITOR_LEN 0x40000 /* Reserve 256KiB */
#define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x40000)
/* Address and size of Redundant Environment Sector */ #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
If you could give me some help so that at least I could send write commands to the chip without hang pls...
You're pointing CFI to configuration registers, you need to point it to where the NOR flash is MMAPed. If it's not MMAPed, this isn't your driver. M
